[petsc-users] Problem with large grid size
Jed Brown jed at jedbrown.org
Fri Nov 30 10:46:21 CST 2018
"Smith, Barry F. via petsc-users" <petsc-users at mcs.anl.gov> writes:
>    You need to run it on more processors, this one processor doesn't have enough memory to fit the vectors (which by the way are huge 1,614,907,707,076)
This is just a tridiagonal problem; I don't know why the vectors would
be huge when the problem dimension is only a million.
Fazlul, is this your target problem?  The tridiagonal problem can be
solved trivially using Cholesky (-pc_type cholesky; or LU) -- the n=10^7
case takes perhaps a second in serial (and this can be made faster).
The convergence is slow with local preconditioners because information
travels only one element at a time.  Note that I don't get any
memory-related error messages with a 32-bit build of PETSc, but perhaps
I'm not running the same way as you are.
The errors reported by your code are wrong because your stated exact
solution and RHS are not actually compatible.
>     Barry
>> On Nov 29, 2018, at 8:26 PM, Fazlul Huq <huq2090 at gmail.com> wrote:
>> Thanks.
>> I have configured with 64-bit and then when I run, I got the following error message:
>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>> [0]PETSC ERROR: too large an object or bleeding by not properly
>> [0]PETSC ERROR: destroying unneeded objects.
>> [0]PETSC ERROR: Memory allocated 41632 Memory used by process 13361152
>> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
>> [0]PETSC ERROR: Memory requested 1614907707076
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
>> [0]PETSC ERROR: ./poisson_m on a arch-linux2-c-debug named huq2090-XPS-15-9570 by huq2090 Thu Nov 29 20:24:13 2018
>> [0]PETSC ERROR: Configure options --download-hypre --download-mpich --with-64-bit-indices
>> [0]PETSC ERROR: #1 VecCreate_Seq() line 35 in /home/huq2090/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
>> [0]PETSC ERROR: #2 PetscTrMallocDefault() line 183 in /home/huq2090/petsc-3.10.2/src/sys/memory/mtr.c
>> [0]PETSC ERROR: #3 PetscMallocA() line 397 in /home/huq2090/petsc-3.10.2/src/sys/memory/mal.c
>> [0]PETSC ERROR: #4 VecCreate_Seq() line 35 in /home/huq2090/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
>> [0]PETSC ERROR: #5 VecSetType() line 51 in /home/huq2090/petsc-3.10.2/src/vec/vec/interface/vecreg.c
>> [0]PETSC ERROR: #6 VecSetTypeFromOptions_Private() line 1250 in /home/huq2090/petsc-3.10.2/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: #7 VecSetFromOptions() line 1284 in /home/huq2090/petsc-3.10.2/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: #8 main() line 57 in /home/huq2090/petsc-3.10.2/problems/ksp/poisson_m.c
>> [0]PETSC ERROR: No PETSc Option Table entries
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
>> application called MPI_Abort(MPI_COMM_WORLD, 55) - process 0
>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=55
>> system msg for write_line failure : Bad file descriptor
>> Thanks.
>> Sincerely,
>> Huq
>> On Thu, Nov 29, 2018 at 1:51 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> > On Nov 29, 2018, at 1:46 PM, Fazlul Huq via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> > Hello PETSc Developers,
>> > I am trying to run the code (attached herewith) with the following command and it works until the size of the matrix is 99999X99999. But when I try to run with 999999X999999 then I got weird result.
>>    What is that "weird result"?
>>    My guess is for problems that large you need to ./configure PETSc with the additional option --with-64-bit-indices since for such large problems 32 bit integers are not large enough to contain values needed for storing and accessing the sparse matrix.
>>    Barry
>> > The command is:
>> > ./poisson_m -n 999999 -pc_type hypre -pc_hypre_type boomeramg -ksp_view_solution
>> > Any suggestions is appreciated.
>> > Thanks.
>> > Sincerely,
>> > Huq
>> > Fazlul Huq
>> > Graduate Research Assistant
>> > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>> > University of Illinois at Urbana-Champaign (UIUC)
>> > E-mail: huq2090 at gmail.com
>> > <poisson_m.c>
>> Fazlul Huq
