[petsc-users] Problem with large grid size
Smith, Barry F. bsmith at mcs.anl.gov
Thu Nov 29 20:45:53 CST 2018
   You need to run it on more processors, this one processor doesn't have enough memory to fit the vectors (which by the way are huge 1,614,907,707,076)
    Barry
> On Nov 29, 2018, at 8:26 PM, Fazlul Huq <huq2090 at gmail.com> wrote:
> Thanks.
> I have configured with 64-bit and then when I run, I got the following error message:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Out of memory. This could be due to allocating
> [0]PETSC ERROR: too large an object or bleeding by not properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated 41632 Memory used by process 13361152
> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
> [0]PETSC ERROR: Memory requested 1614907707076
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
> [0]PETSC ERROR: ./poisson_m on a arch-linux2-c-debug named huq2090-XPS-15-9570 by huq2090 Thu Nov 29 20:24:13 2018
> [0]PETSC ERROR: Configure options --download-hypre --download-mpich --with-64-bit-indices
> [0]PETSC ERROR: #1 VecCreate_Seq() line 35 in /home/huq2090/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
> [0]PETSC ERROR: #2 PetscTrMallocDefault() line 183 in /home/huq2090/petsc-3.10.2/src/sys/memory/mtr.c
> [0]PETSC ERROR: #3 PetscMallocA() line 397 in /home/huq2090/petsc-3.10.2/src/sys/memory/mal.c
> [0]PETSC ERROR: #4 VecCreate_Seq() line 35 in /home/huq2090/petsc-3.10.2/src/vec/vec/impls/seq/bvec3.c
> [0]PETSC ERROR: #5 VecSetType() line 51 in /home/huq2090/petsc-3.10.2/src/vec/vec/interface/vecreg.c
> [0]PETSC ERROR: #6 VecSetTypeFromOptions_Private() line 1250 in /home/huq2090/petsc-3.10.2/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #7 VecSetFromOptions() line 1284 in /home/huq2090/petsc-3.10.2/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #8 main() line 57 in /home/huq2090/petsc-3.10.2/problems/ksp/poisson_m.c
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_WORLD, 55) - process 0
> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=55
> system msg for write_line failure : Bad file descriptor
> Thanks.
> Sincerely,
> Huq
> On Thu, Nov 29, 2018 at 1:51 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Nov 29, 2018, at 1:46 PM, Fazlul Huq via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > Hello PETSc Developers,
> > I am trying to run the code (attached herewith) with the following command and it works until the size of the matrix is 99999X99999. But when I try to run with 999999X999999 then I got weird result.
>    What is that "weird result"?
>    My guess is for problems that large you need to ./configure PETSc with the additional option --with-64-bit-indices since for such large problems 32 bit integers are not large enough to contain values needed for storing and accessing the sparse matrix.
>    Barry
> > The command is:
> > ./poisson_m -n 999999 -pc_type hypre -pc_hypre_type boomeramg -ksp_view_solution
> > Any suggestions is appreciated.
> > Thanks.
> > Sincerely,
> > Huq
> > Fazlul Huq
> > Graduate Research Assistant
> > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> > University of Illinois at Urbana-Champaign (UIUC)
> > E-mail: huq2090 at gmail.com
> > <poisson_m.c>
> Fazlul Huq
