[petsc-users] RAW binary write
Sal Am
tempohoper at gmail.com
Fri Nov 30 03:03:42 CST 2018
Hi Matthew,
by raw I mean something the equivalent of pure C++ like
std::fstream fout("Vector_b.bin",std::ios::out | std::ios::binary);
fout.write((char*)&b[i],sizeof(std::complex<double>));
fout.close(); //std::vector< std::complex<double> > b
i.e. without the PETSc format information, so I can use the resulting data
in other software.
Thanks
On Thu, Nov 29, 2018 at 4:39 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Nov 29, 2018 at 10:50 AM Sal Am via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Is there a way to write the solution from the system Ax=b in raw binary
>> instead of PETSc binary format?
> What is "raw binary". You have to have some format.
> Matt
>> Currently I am doing:
>> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,
>> "../../python/petscpy/Vector_x_petsc.dat", FILE_MODE_WRITE,
>> &viewer);CHKERRQ(ierr);
>> ierr = VecView(x,viewer);CHKERRQ(ierr);CHKERRQ(ierr);
>> ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>> And then use PetscBinaryIO to read it back and save it using
>> write('newformat', 'wb') to get to raw... however this approach is not good
>> it seems as there are some troubles with little/big endian when using the
>> resulting converted file on other systems for post-processing.
>> Thanks,
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181130/651a3d98/attachment.html>
