[petsc-users] RAW binary write
Thu Nov 29 10:39:13 CST 2018
On Thu, Nov 29, 2018 at 10:50 AM Sal Am via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Is there a way to write the solution from the system Ax=b in raw binary
> instead of PETSc binary format?
What is "raw binary". You have to have some format.
   Matt
> Currently I am doing:
>   ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,
> "../../python/petscpy/Vector_x_petsc.dat", FILE_MODE_WRITE,
> &viewer);CHKERRQ(ierr);
>   ierr = VecView(x,viewer);CHKERRQ(ierr);CHKERRQ(ierr);
>   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
> And then use PetscBinaryIO to read it back and save it using
> write('newformat', 'wb') to get to raw... however this approach is not good
> it seems as there are some troubles with little/big endian when using the
> resulting converted file on other systems for post-processing.
> Thanks,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/06e780e5/attachment-0001.html>
