[petsc-users] Compile petsc using intel mpi
Thu Nov 29 07:19:35 CST 2018
On Thu, Nov 29, 2018 at 8:17 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Ok, this makes sense, but the reason to use sudo was this one:
sudo rm RDict.log
  Matt
> [Errno 13] Permission denied: 'RDict.log'
>   File "./config/configure.py", line 391, in petsc_configure
>     framework =
> config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:],
> loadArgDB = 0)
>   File
> "/home/edo/software/petsc_intel/config/BuildSystem/config/framework.py",
> line 80, in __init__
>     argDB = RDict.RDict(load = loadArgDB)
>   File "/home/edo/software/petsc_intel/config/BuildSystem/RDict.py", line
> 90, in __init__
>     self.setupLogFile()
> 145, in setupLogFile
>     self.logFile = file(filename, 'a')
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica,
> Universita' degli Studi di Genova,
> 1, via Montallegro,
> 16145 Genova, Italy
> Il giorno gio 29 nov 2018 alle ore 14:10 Matthew Knepley <
> knepley at gmail.com> ha scritto:
>> On Thu, Nov 29, 2018 at 4:23 AM Edoardo alinovi <
>> edoardo.alinovi at gmail.com> wrote:
>>> Hello guys,
>>> thank you very much for you suggestions and sorry for getting back you
>>> late. Unfortunately, actually my attempts to compile with intel are not
>>> successful.
>>> Here my command:
>> Do NOT sudo the configure. This is really dangerous, and as you see
>> 'root' has a different path than you do. Run configure normally
>> and make, and only use 'sudo' for 'make install'.
>>   Thanks,
>>      Matt
>>> sudo ./configure --prefix=/home/edo/software/petsc-3.10.2
>>> PETSC_ARCH=arch-intel-opt --with-cc=mpiicc --with-cxx=mpiiccp
>>> --with-fc=mpiifort FOPTFLAGS='-O3' COPTFLAGS='-O3' CXXOPTFLAGS='-O3'
>>> --with-blas-lapack-dir=/home/edo/intel/mkl/lib/intel64/ --with-debugging=no
>>> --download-fblaslapack=1 --download-superlu_dist --download-mumps
>>> --download-hypre --download-metis --download-parmetis
>>> The log file states that:
>>> ------------------ LOG ------------------
>>> TEST checkCCompiler from
>>> config.setCompilers(/home/edo/software/petsc_intel/config/BuildSystem/config/setCompilers.py:587)
>>> TESTING: checkCCompiler from
>>> config.setCompilers(config/BuildSystem/config/setCompilers.py:587)
>>>   Locate a functional C compiler
>>> Checking for program /usr/sbin/mpiicc...not found
>>> Checking for program /usr/bin/mpiicc...not found
>>> Checking for program /sbin/mpiicc...not found
>>> Checking for program /bin/mpiicc...not found
>>> /home/edo/software/petsc_intel/lib/petsc/bin/win32fe/mpiicc...not found
>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>> for details):
>>> C compiler you provided with -with-cc=mpiicc does not work.
>>> It seems that petsc is not able to find mpiicc. However, the path to
>>> intel is well defined in my .bashrc and I can easily compile a test file
>>> with those compiler.
>>> if I put the full path in --with-cc= ...  then I get:
>>> /home/edo/intel/compilers_and_libraries_2019/linux/mpi/intel64/bin/mpiicc...found
>>>                 Defined make macro "CC" to
>>> "/home/edo/intel/compilers_and_libraries_2019/linux/mpi/intel64/bin/mpiicc"
>>>                 Pushing language C
>>>                             All intermediate test results are stored in
>>> /tmp/petsc-ZLGfap
>>> /tmp/petsc-ZLGfap/config.setCompilers
>>> Executing:
>>> -c -o /tmp/petsc-ZLGfap/config.setCompilers/conftest.o
>>> -I/tmp/petsc-ZLGfap/config.setCompilers
>>>  /tmp/petsc-ZLGfap/config.setCompilers/conftest.c
>>> Possible ERROR while running compiler: exit code 32512
>>> stderr:
>>> /home/edo/intel/compilers_and_libraries_2019/linux/mpi/intel64/bin/mpiicc:
>>> line 557: icc: command not found
>>> Source:
>>> #include "confdefs.h"
>>> #include "conffix.h"
>>> int main() {
>>>   return 0;
>>>                 Popping language C
>>>             Error testing C compiler: Cannot compile C with
>>>               Deleting "CC"
>>> Do you see any error in my setup?
>>> Thank you very much!
>>> 1, via Montallegro,
>>> 16145 Genova, Italy
>>> Il giorno mar 27 nov 2018 alle ore 17:16 Matthew Knepley <
>>>> On Tue, Nov 27, 2018 at 6:25 AM Edoardo alinovi via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>>> Dear users,
>>>>> I have installed intel parallel studio on my workstation and  thus I
>>>>> would like to take advantage of intel compiler.
>>>>> Before messing up my installation, have you got some guidelines to
>>>>> survive at this attempt? I have found here in the mailing list the
>>>>> following instructions:
>>>>> --with-cc=icc --with-fc=ifort --with-mpi-include=/path-to-intel
>>>>> --with-mpi-lib=/path-to-intel
>>>> Yes, this looks right.
>>>>> Are they correct?
>>>>> Also I have an already existing and clean installation of petsc using
>>>>> openmpi. I would like to retain this installtion since it is working very
>>>>> well and switching between the two  somehow. Any tips on this?
>>>> When you do the Intel configuration, use a different name like
>>>> --PETSC_ARCH=arch-intelps-opt
>>>>   Thanks,
>>>>     Matt
>>>>> I will never stop to say thank you for your precious support!
>>>>> Edoardo
>>>>> 1, via Montallegro,
>>>>> 16145 Genova, Italy
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/5e0167f6/attachment.html>
