[petsc-users] PetscPartitioner is missing for fortran
Matthew Knepley
knepley at gmail.com
Tue Nov 27 10:05:34 CST 2018
On Tue, Nov 27, 2018 at 10:51 AM Jiaoyan Li via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Thanks, Chris, for your kind reply. Yes, I believe the mailing list is the
> most convenient way for Petsc's to communicate with each other.
Hi Jiaoyan,
I will fix this. Its taking me a few days because its the end of the
semester and things get a little compressed. I should have it done this
week.
Matt
> Also, I am wondering if you may happen to use "PetscPartitioner" before?
> Have you ever tried to fix Petsc-Fortran problem by yourself before? I
> believe Petsc needs to build an interface for Fortran from the C source
> code. But, I don't know where Petsc does that. I am just trying to see if I
> can fix it by myself. Thank you.
> Jiaoyan
> On 11/27/18, 00:44, "petsc-users on behalf of Klaij, Christiaan via
> petsc-users" <petsc-users-bounces at mcs.anl.gov on behalf of
> Hi Jiaoyan,
> I've been using the fortran interface since 2004. During these
> years I only found a handful of things missing. After an email to
> this list the developers are usually quite fast in fixing the
> problem.
> Chris
> Date: Mon, 26 Nov 2018 16:41:29 +0000
> From: Jiaoyan Li <Jiaoyan.Li at inl.gov>
> To: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: [petsc-users] PetscPartitioner is missing for fortran
> Message-ID: <CA349658-2D98-4BA4-9773-C3685A0CC8AC at inl.gov>
> Content-Type: text/plain; charset="utf-8"
> Dear Petsc Users:
> I am developing a Fortran code which uses Petsc APIs. But, seems the
> interface between Fortran and Petsc is not completed, as replied by Barry.
> Is there anyone may have some experience on building the Fortran interface
> for Petsc? Any suggestions or comments are highly appreciated. Thank you.
> Have a nice day,
> Jiaoyan
> On 11/21/18, 19:25, "Smith, Barry F." <bsmith at mcs.anl.gov<mailto:
> bsmith at mcs.anl.gov>> wrote:
> Matt,
> PetscPartitioner is missing from
> lib/petsc/conf/bfort-petsc.txt
> Barry
> > On Nov 21, 2018, at 3:33 PM, Jiaoyan Li via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> > Dear Petsc users:
> > I am trying to use Petsc APIs for Fortran. One problem that I am
> facing right now is about the PetscPartitioner, i.e.,
> > #include ?petsc/finclude/petsc.h?
> > use petscdmplex
> > PetscPartitioner :: part
> > PetscErrorCode :: ierr
> > Call PetscPartitionerCreate(PETSC_COMM_WORLD, part, ierr)
> > But, I got the error message as follows:
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Null argument, when expecting valid pointer
> > [0]PETSC ERROR: Null Pointer: Parameter # 2
> > [0]PETSC ERROR: See
> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs.anl.gov_petsc_documentation_faq.html&d=DwIGaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=5MMpjBrVOPpVGfIH9op1r4nz1k4YC8LDRnpo_HwMgZU&m=1lomdbavAvxQQpe-IZtEv3xEovYeZ9lxbOzN-sE8CUQ&s=BYCTTDqEflIdLwRAkF4txknqLg0jeyOcdodQkfHj-TA&e=
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.10.2, unknown
> > [0]PETSC ERROR: ./htm3d on a arch-linux2-c-opt named fn607018 by
> LIJ Wed Nov 21 16:30:35 2018
> > [0]PETSC ERROR: Configure options --download-fblaslapack
> --with-mpi-dir=/opt/mpitch-3.2.1 -download-exodusii --download-hdf5
> --download-netcdf --download-zlib --download-pnetcdf
> > [0]PETSC ERROR: #1 PetscPartitionerCreate() line 601 in
> /home/lij/packages/petsc/src/dm/impls/plex/plexpartition.c
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Null argument, when expecting valid pointer
> > [1]PETSC ERROR: Null Pointer: Parameter # 2
> > [1]PETSC ERROR: See
> > [1]PETSC ERROR: Petsc Release Version 3.10.2, unknown
> > [1]PETSC ERROR: ./htm3d on a arch-linux2-c-opt named fn607018 by
> > [1]PETSC ERROR: Configure options --download-fblaslapack
> > [1]PETSC ERROR: #1 PetscPartitionerCreate() line 601 in
> > [2]PETSC ERROR: --------------------- Error Message
> > [2]PETSC ERROR: Null argument, when expecting valid pointer
> > [2]PETSC ERROR: Null Pointer: Parameter # 2
> > [2]PETSC ERROR: See
> > [2]PETSC ERROR: Petsc Release Version 3.10.2, unknown
> > [2]PETSC ERROR: ./htm3d on a arch-linux2-c-opt named fn607018 by
> > [2]PETSC ERROR: Configure options --download-fblaslapack
> > [2]PETSC ERROR: #1 PetscPartitionerCreate() line 601 in
> > [3]PETSC ERROR: --------------------- Error Message
> > [3]PETSC ERROR: Null argument, when expecting valid pointer
> > [3]PETSC ERROR: Null Pointer: Parameter # 2
> > [3]PETSC ERROR: See
> > [3]PETSC ERROR: Petsc Release Version 3.10.2, unknown
> > [3]PETSC ERROR: ./htm3d on a arch-linux2-c-opt named fn607018 by
> > [3]PETSC ERROR: Configure options --download-fblaslapack
> > [3]PETSC ERROR: #1 PetscPartitionerCreate() line 601 in
> > Is there anyone who may encounter similar problem before? Any
> suggestions or commends are highly appreciated. Thank you very much.
> > Best,
> > Jiaoyan
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.mcs.anl.gov_pipermail_petsc-2Dusers_attachments_20181126_0b196ca9_attachment.html&d=DwIGaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=5MMpjBrVOPpVGfIH9op1r4nz1k4YC8LDRnpo_HwMgZU&m=uadiAPfKAyRcJODTiOtF9X7aTXnk7oBkmdranjsZy8o&s=Q_uM9F9ZoKMnIbdEj6lTkgBeXBhS0xUTDZZ1wMCbLds&e=
> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl |
> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.marin.nl&d=DwIGaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=5MMpjBrVOPpVGfIH9op1r4nz1k4YC8LDRnpo_HwMgZU&m=uadiAPfKAyRcJODTiOtF9X7aTXnk7oBkmdranjsZy8o&s=X4nF6ffp6hFk5qLA9Q_KN8PjMOU5-rQMhKxQ4j5gIVo&e=
> MARIN news:
> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.marin.nl_web_News_News-2Ditems_Maritime-2Dwith-2Da-2DMission-2DTKI-2DEvent-2Dop-2Dhet-2DSS-2DRotterdam-2D30-2Dnovember.htm&d=DwIGaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=5MMpjBrVOPpVGfIH9op1r4nz1k4YC8LDRnpo_HwMgZU&m=uadiAPfKAyRcJODTiOtF9X7aTXnk7oBkmdranjsZy8o&s=2K4w9VlCutEzg1zz_NVlsKwk8ECfHknpdmXzF4hyBfo&e=
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181127/ef989c74/attachment.html>
