[petsc-users] PetscInt overflow
Matthew Knepley
knepley at gmail.com
Tue Nov 13 06:58:05 CST 2018
On Tue, Nov 13, 2018 at 6:40 AM Jan Grießer <griesser.jan at googlemail.com>
wrote:
> I am finally back from holidays and continued working on the problem. I
> think i figured out that the problem is not related to SLEPc but rather to
> PETSc. Until now i precomputed my matrix in python and saved it as a
> scipy.csr matrix( The matrix is of order 6 Mio x 6 Mio with around 0.004%
> nonzero elements). The code i used to convert the scipy sparse matrix to a
> PETSc matrix is appended below. But i am wondering if maybe the problem is
> that the memory of the individual processors(i use at the moment 60 cores
> with 24 GB each ) is simply dumped by the size of the matrix (It is around
> 13 Gb) or if the PETSc matrix is not correctly distributed.
> I am sorry for the late answer and hope someone has any suggestion.
The code below makes it look like you are loading the entire CSR matrix on
every process (load_npz) and then
selecting a portion of it to stick into PETSc. The memory footprint of this
strategy will explode.
Matt
> def construct_mat():
> D_nn =
> scipy.sparse.load_npz("../PBC_DynamicalMatrix/DynamicalMatrixPB.npz")
> # Create a matrix Ds in parallel
> Dyn = PETSc.Mat().create()
> Dyn.setSizes(CSRMatrix.shape)
> Dyn.setFromOptions()
> Dyn.setUp()
> Rstart, Rend = Dyn.getOwnershipRange()
> # Fill the matrix
> csr = (
> CSRMatrix.indptr[Rstart:Rend+1] - CSRMatrix.indptr[Rstart],
> CSRMatrix.indices[CSRMatrix.indptr[Rstart]:CSRMatrix.indptr[Rend]],
> CSRMatrix.data[CSRMatrix.indptr[Rstart]:CSRMatrix.indptr[Rend]]
> D = PETSc.Mat().createAIJ(size=CSRMatrix.shape, csr=csr)
> D.assemble()
> # Free the memory
> del CSRDynamicalMatrix_nn
> # Return the PETSc dynamical matrix
> return D
> Am Mi., 24. Okt. 2018 um 18:46 Uhr schrieb Matthew Knepley <
> knepley at gmail.com>:
>> As it says, if you are looking at performance, you should configure using
>> --with-debugging=0.
>> It says SLEPc is using 8GB. Is this what you see?
>> Matt
>> On Wed, Oct 24, 2018 at 12:30 PM Jan Grießer <griesser.jan at googlemail.com>
>> wrote:
>>> I also run it with the -log_summary :
>>> ---------------------------------------------- PETSc Performance
>>> Summary: ----------------------------------------------
>>> # WARNING!!! #
>>> # This code was compiled with a debugging option, #
>>> # To get timing results run ./configure #
>>> # using --with-debugging=no, the performance will #
>>> # be generally two or three times faster. #
>>> /work/ws/nemo/fr_jg1080-FreeSurface_Glass-0/GlassSystems/PeriodicSystems/N500000T0.001/SolveEigenvalueProblem_par/Test/Eigensolver_petsc_slepc_no_argparse.py
>>> on a arch-linux2-c-debug named int02.nemo.privat with 20 processors, by
>>> fr_jg1080 Wed Oct 24 18:26:30 2018
>>> Using Petsc Release Version 3.9.4, Sep, 11, 2018
>>> Max Max/Min Avg Total
>>> Time (sec): 7.474e+02 1.00000 7.474e+02
>>> Objects: 3.600e+01 1.00000 3.600e+01
>>> Flop: 1.090e+11 1.00346 1.089e+11 2.177e+12
>>> Flop/sec: 1.459e+08 1.00346 1.457e+08 2.913e+09
>>> Memory: 3.950e+08 1.00296 7.891e+09
>>> MPI Messages: 3.808e+04 1.00000 3.808e+04 7.615e+05
>>> MPI Message Lengths: 2.211e+10 1.00217 5.802e+05 4.419e+11
>>> MPI Reductions: 1.023e+05 1.00000
>>> Flop counting convention: 1 flop = 1 real number operation of type
>>> (multiply/divide/add/subtract)
>>> e.g., VecAXPY() for real vectors of length N
>>> --> 2N flop
>>> and VecAXPY() for complex vectors of length
>>> N --> 8N flop
>>> Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages
>>> --- -- Message Lengths -- -- Reductions --
>>> Avg %Total Avg %Total counts
>>> %Total Avg %Total counts %Total
>>> 0: Main Stage: 7.4739e+02 100.0% 2.1773e+12 100.0% 7.615e+05
>>> 100.0% 5.802e+05 100.0% 1.022e+05 100.0%
>>> See the 'Profiling' chapter of the users' manual for details on
>>> interpreting output.
>>> Phase summary info:
>>> Count: number of times phase was executed
>>> Time and Flop: Max - maximum over all processors
>>> Ratio - ratio of maximum to minimum over all
>>> processors
>>> Mess: number of messages sent
>>> Avg. len: average message length (bytes)
>>> Reduct: number of global reductions
>>> Global: entire computation
>>> Stage: stages of a computation. Set stages with PetscLogStagePush()
>>> and PetscLogStagePop().
>>> %T - percent time in this phase %F - percent flop in this
>>> phase
>>> %M - percent messages in this phase %L - percent message
>>> lengths in this phase
>>> %R - percent reductions in this phase
>>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>>> # WARNING!!! #
>>> Event Count Time (sec) Flop
>>> --- Global --- --- Stage --- Total
>>> Max Ratio Max Ratio Max Ratio Mess Avg len
>>> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>>> --- Event Stage 0: Main Stage
>>> BuildTwoSidedF 2 1.0 2.6670e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> VecSet 2 1.0 6.8650e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecScatterBegin 2002 1.0 1.4380e+01 1.0 0.00e+00 0.0 7.6e+05 5.8e+05
>>> 0.0e+00 2 0100100 0 2 0100100 0 0
>>> VecScatterEnd 2002 1.0 3.7604e+01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00 4 0 0 0 0 4 0 0 0 0 0
>>> VecSetRandom 1 1.0 1.6440e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> MatMult 2002 1.0 6.0846e+02 1.2 1.03e+11 1.0 7.6e+05 5.8e+05
>>> 0.0e+00 71 94100100 0 71 94100100 0 3376
>>> MatAssemblyBegin 3 1.0 2.8129e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> MatAssemblyEnd 3 1.0 8.5094e+00 1.0 0.00e+00 0.0 7.6e+02 1.5e+05
>>> 3.6e+01 1 0 0 0 0 1 0 0 0 0 0
>>> EPSSetUp 1 1.0 1.7351e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 7.6e+01 0 0 0 0 0 0 0 0 0 0 0
>>> EPSSolve 1 1.0 6.7891e+02 1.0 1.09e+11 1.0 7.6e+05 5.8e+05
>>> 1.0e+05 91100100100100 91100100100100 3207
>>> STSetUp 1 1.0 2.2221e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
>>> STApply 2002 1.0 6.0879e+02 1.2 1.03e+11 1.0 7.6e+05 5.8e+05
>>> 0.0e+00 71 94100100 0 71 94100100 0 3374
>>> BVCopy 999 1.0 2.7157e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>>> BVMultVec 4004 1.0 2.2918e+00 1.0 2.10e+09 1.0 0.0e+00 0.0e+00
>>> 1.6e+04 0 2 0 0 16 0 2 0 0 16 18332
>>> BVMultInPlace 999 1.0 4.8399e+01 1.0 1.20e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 6 1 0 0 0 6 1 0 0 0 495
>>> BVDotVec 4004 1.0 1.0835e+01 1.0 2.70e+09 1.0 0.0e+00 0.0e+00
>>> 2.0e+04 1 2 0 0 20 1 2 0 0 20 4986
>>> BVOrthogonalizeV 2003 1.0 1.3272e+01 1.0 4.80e+09 1.0 0.0e+00 0.0e+00
>>> 5.2e+04 2 4 0 0 51 2 4 0 0 51 7236
>>> BVScale 2003 1.0 2.3521e-01 1.0 1.50e+08 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 12773
>>> BVSetRandom 1 1.0 1.6456e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>> DSSolve 1000 1.0 3.3338e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> DSVectors 1000 1.0 6.0029e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>>> DSOther 2999 1.0 7.8770e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> Memory usage is given in bytes:
>>> Object Type Creations Destructions Memory Descendants'
>>> Mem.
>>> Reports information only for process 0.
>>> Viewer 2 1 840 0.
>>> PetscRandom 1 1 646 0.
>>> Index Set 4 4 5510472 0.
>>> Vector 9 9 11629608 0.
>>> Vec Scatter 2 2 1936 0.
>>> Matrix 10 10 331855732 0.
>>> Preconditioner 1 1 1000 0.
>>> Krylov Solver 1 1 1176 0.
>>> EPS Solver 1 1 1600 0.
>>> Spectral Transform 2 2 1624 0.
>>> Basis Vectors 1 1 2168 0.
>>> Direct Solver 1 1 2520 0.
>>> Region 1 1 672 0.
>>> Average time to get PetscTime(): 1.19209e-07
>>> Average time for MPI_Barrier(): 2.67982e-05
>>> Average time for zero size MPI_Send(): 1.08957e-05
>>> #PETSc Option Table entries:
>>> -bv_type mat
>>> -eps_view_pre
>>> -log_summary
>>> #End of PETSc Option Table entries
>>> Compiled without FORTRAN kernels
>>> Compiled with full precision matrices (default)
>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>> Configure options: --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>>> --download-mumps --with-shared-libraries=True --download-scalapack
>>> Libraries compiled on 2018-10-17 20:02:31 on login2.nemo.privat
>>> Machine characteristics:
>>> Linux-3.10.0-693.21.1.el7.x86_64-x86_64-with-centos-7.4.1708-Core
>>> Using PETSc directory: /home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4
>>> Using PETSc arch: arch-linux2-c-debug
>>> Using C compiler: mpicc -fPIC -wd1572 -g
>>> Using Fortran compiler: mpif90 -fPIC -g
>>> Using include paths:
>>> -I/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/include
>>> -I/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/arch-linux2-c-debug/include
>>> Using C linker: mpicc
>>> Using Fortran linker: mpif90
>>> Using libraries:
>>> -Wl,-rpath,/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/arch-linux2-c-debug/lib
>>> -L/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/arch-linux2-c-debug/lib
>>> -lpetsc
>>> -Wl,-rpath,/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/mpi/intel64/lib/debug_mt
>>> -L/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/mpi/intel64/lib/debug_mt
>>> -Wl,-rpath,/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/lib/intel64
>>> -L/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/lib/intel64
>>> -Wl,-rpath,/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries_2018.3.222/linux/compiler/lib/intel64_lin
>>> -L/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries_2018.3.222/linux/compiler/lib/intel64_lin
>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>>> -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib/debug_mt
>>> -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib -lcmumps -ldmumps
>>> -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -llapack -lblas -lX11
>>> -lstdc++ -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -lifport
>>> -lifcoremt_pic -limf -lsvml -lm -lipgo -lirc -lgcc_s -lirc_s -lstdc++ -ldl
>>> # WARNING!!! #
>>> Am Mi., 24. Okt. 2018 um 18:07 Uhr schrieb Jan Grießer <
>>> griesser.jan at googlemail.com>:
>>>> For some reason i get only this error message, also when is use the
>>>> -eps_view_pre. I started the program with nev=1, there the output is (with
>>>> -bv_type vecs -bv_type mat -eps_view_pre)
>>>> EPS Object: 20 MPI processes
>>>> type: krylovschur
>>>> 50% of basis vectors kept after restart
>>>> using the locking variant
>>>> problem type: symmetric eigenvalue problem
>>>> selected portion of the spectrum: smallest real parts
>>>> number of eigenvalues (nev): 1
>>>> number of column vectors (ncv): 3
>>>> maximum dimension of projected problem (mpd): 2
>>>> maximum number of iterations: 1000
>>>> tolerance: 1e-08
>>>> convergence test: relative to the eigenvalue
>>>> BV Object: 20 MPI processes
>>>> type: mat
>>>> 4 columns of global length 1500000
>>>> vector orthogonalization method: classical Gram-Schmidt
>>>> orthogonalization refinement: if needed (eta: 0.7071)
>>>> block orthogonalization method: GS
>>>> doing matmult as a single matrix-matrix product
>>>> DS Object: 20 MPI processes
>>>> type: hep
>>>> parallel operation mode: REDUNDANT
>>>> solving the problem with: Implicit QR method (_steqr)
>>>> ST Object: 20 MPI processes
>>>> type: shift
>>>> shift: 0.
>>>> number of matrices: 1
>>>> Am Mi., 24. Okt. 2018 um 16:14 Uhr schrieb Matthew Knepley <
>>>>> On Wed, Oct 24, 2018 at 10:03 AM Jan Grießer <
>>>>> griesser.jan at googlemail.com> wrote:
>>>>>> This is the error message i get from my program:
>>>>>> Shape of the dynamical matrix: (1500000, 1500000)
>>>>> Petsc installs a signal handler, so there should be a PETSc-specific
>>>>> message before this one. Is something eating
>>>>> your output?
>>>>> Thanks,
>>>>> Matt
>>>>>> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>>>>> = PID 122676 RUNNING AT n3512.nemo.privat
>>>>>> = EXIT CODE: 9
>>>>>> = CLEANING UP REMAINING PROCESSES
>>>>>> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>>>>> Intel(R) MPI Library troubleshooting guide:
>>>>>> https://software.intel.com/node/561764
>>>>>> Am Mi., 24. Okt. 2018 um 16:01 Uhr schrieb Matthew Knepley <
>>>>>>> On Wed, Oct 24, 2018 at 9:38 AM Jan Grießer <
>>>>>>>> Hey,
>>>>>>>> i tried to run my program as you said with -bv_type vecs and/or
>>>>>>>> -bv_type mat, but instead of the PETScInt overflow i now get an MPI Error 9
>>>>>>> Send the actual error.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> message, which i assume (after googling a little bit around) should
>>>>>>>> be a memory problem. I tried to run it also on slightly bigger compute
>>>>>>>> nodes on our cluster with 20 cores with each 12 GB and 24 GB but the
>>>>>>>> problem still remains. The actual limit appears to be a 1.5 Million x 1.5
>>>>>>>> Million where i searched for NEV = 1500 and MPD = 500/ 200 eigenvalues.
>>>>>>>> Do you have maybe an idea what the error could be? I appended also
>>>>>>>> the python method i used to solve the problem. I also tried to solve the
>>>>>>>> problem with spectrum solving but the error message remains the same.
>>>>>>>> def solve_eigensystem(DynMatrix_nn, NEV, MPD, Dimension):
>>>>>>>> # Create the solver
>>>>>>>> # E is used as an acronym for the EPS solver (EPS = Eigenvalue
>>>>>>>> problem solver)
>>>>>>>> E = SLEPc.EPS().create()
>>>>>>>> # Set the preconditioner
>>>>>>>> pc = PETSc.PC().create()
>>>>>>>> pc.setType(pc.Type.BJACOBI)
>>>>>>>> # Set the linear solver
>>>>>>>> # Create the KSP object
>>>>>>>> ksp = PETSc.KSP().create()
>>>>>>>> # Create the solver, in this case GMRES
>>>>>>>> ksp.setType(ksp.Type.GMRES)
>>>>>>>> # Set the tolerances of the GMRES solver
>>>>>>>> # Link it to the PC
>>>>>>>> ksp.setPC(pc)
>>>>>>>> # Set up the spectral transformations
>>>>>>>> st = SLEPc.ST().create()
>>>>>>>> st.setType("shift")
>>>>>>>> st.setKSP(ksp)
>>>>>>>> # MPD stands for "maximum projected dimension". It has to due with
>>>>>>>> computational cost, please read Chap. 2.6.5 of SLEPc docu for
>>>>>>>> # an explanation. At the moment mpd is only a guess
>>>>>>>> E.setDimensions(nev=NEV, mpd = MPD)
>>>>>>>> # Eigenvalues should be real, therefore we start to order them from
>>>>>>>> the smallest real value |l.real|
>>>>>>>> E.setWhichEigenpairs(E.Which.SMALLEST_REAL)
>>>>>>>> # Since the dynamical matrix is symmetric and real it is hermitian
>>>>>>>> E.setProblemType(SLEPc.EPS.ProblemType.HEP)
>>>>>>>> # Use the Krylov Schur method to solve the eigenvalue problem
>>>>>>>> E.setType(E.Type.KRYLOVSCHUR)
>>>>>>>> # Set the convergence criterion to relative to the eigenvalue and
>>>>>>>> the maximal number of iterations
>>>>>>>> E.setConvergenceTest(E.Conv.REL)
>>>>>>>> E.setTolerances(tol = 1e-8, max_it = 5000)
>>>>>>>> # Set the matrix in order to solve
>>>>>>>> E.setOperators(DynMatrix_nn, None)
>>>>>>>> # Sets EPS options from the options database. This routine must be
>>>>>>>> called before `setUp()` if the user is to be allowed to set dthe solver
>>>>>>>> type.
>>>>>>>> E.setFromOptions()
>>>>>>>> # Sets up all the internal data structures necessary for the
>>>>>>>> execution of the eigensolver.
>>>>>>>> E.setUp()
>>>>>>>> # Solve eigenvalue problem
>>>>>>>> E.solve()
>>>>>>>> Print = PETSc.Sys.Print
>>>>>>>> Print()
>>>>>>>> Print("****************************")
>>>>>>>> Print("***SLEPc Solution Results***")
>>>>>>>> its = E.getIterationNumber()
>>>>>>>> Print("Number of iterations of the method: ", its)
>>>>>>>> eps_type = E.getType()
>>>>>>>> Print("Solution method: ", eps_type)
>>>>>>>> nev, ncv, mpd = E.getDimensions()
>>>>>>>> Print("Number of requested eigenvalues: ", nev)
>>>>>>>> Print("Number of computeded eigenvectors: ", ncv)
>>>>>>>> tol, maxit = E.getTolerances()
>>>>>>>> Print("Stopping condition: (tol, maxit)", (tol, maxit))
>>>>>>>> # Get the type of convergence
>>>>>>>> conv_test = E.getConvergenceTest()
>>>>>>>> Print("Selected convergence test: ", conv_test)
>>>>>>>> # Get the used spectral transformation
>>>>>>>> get_st = E.getST()
>>>>>>>> Print("Selected spectral transformation: ", get_st)
>>>>>>>> # Get the applied direct solver
>>>>>>>> get_ksp = E.getDS()
>>>>>>>> Print("Selected direct solver: ", get_ksp)
>>>>>>>> nconv = E.getConverged()
>>>>>>>> Print("Number of converged eigenpairs: ", nconv)
>>>>>>>> Am Fr., 19. Okt. 2018 um 21:00 Uhr schrieb Smith, Barry F. <
>>>>>>>> bsmith at mcs.anl.gov>:
>>>>>>>>> > On Oct 19, 2018, at 7:56 AM, Zhang, Junchao <jczhang at mcs.anl.gov>
>>>>>>>>> wrote:
>>>>>>>>> > On Fri, Oct 19, 2018 at 4:02 AM Jan Grießer <
>>>>>>>>> > With more than 1 MPI process you mean i should use spectrum
>>>>>>>>> slicing in divide the full problem in smaller subproblems?
>>>>>>>>> > The --with-64-bit-indices is not a possibility for me since i
>>>>>>>>> configured petsc with mumps, which does not allow to use the 64-bit version
>>>>>>>>> (At least this was the error message when i tried to configure PETSc )
>>>>>>>>> > MUMPS 5.1.2 manual chapter 2.4.2 says it supports "Selective
>>>>>>>>> 64-bit integer feature" and "full 64-bit integer version" as well.
>>>>>>>>> They use to achieve this by compiling with special Fortran
>>>>>>>>> flags to promote integers to 64 bit; this is too fragile for our taste so
>>>>>>>>> we never hooked PETSc up wit it. If they have a dependable way of using 64
>>>>>>>>> bit integers we should add that to our mumps.py and test it.
>>>>>>>>> Barry
>>>>>>>>> > Am Mi., 17. Okt. 2018 um 18:24 Uhr schrieb Jose E. Roman <
>>>>>>>>> jroman at dsic.upv.es>:
>>>>>>>>> > To use BVVECS just add the command-line option -bv_type vecs
>>>>>>>>> > This causes to use a separate Vec for each column, instead of a
>>>>>>>>> single long Vec of size n*m. But it is considerably slower than the default.
>>>>>>>>> > Anyway, for such large problems you should consider using more
>>>>>>>>> than 1 MPI process. In that case the error may disappear because the local
>>>>>>>>> size is smaller than 768000.
>>>>>>>>> > Jose
>>>>>>>>> > > El 17 oct 2018, a las 17:58, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> escribió:
>>>>>>>>> > > On Wed, Oct 17, 2018 at 11:54 AM Jan Grießer <
>>>>>>>>> > > Hi all,
>>>>>>>>> > > i am using slepc4py and petsc4py to solve for the smallest
>>>>>>>>> real eigenvalues and eigenvectors. For my test cases with a matrix A of the
>>>>>>>>> size 30k x 30k solving for the smallest soutions works quite well, but when
>>>>>>>>> i increase the dimension of my system to around A = 768000 x 768000 or 3
>>>>>>>>> million x 3 million and ask for the smallest real 3000 (the number is
>>>>>>>>> increasing with increasing system size) eigenvalues and eigenvectors i get
>>>>>>>>> the output (for the 768000):
>>>>>>>>> > > The product 4001 times 768000 overflows the size of PetscInt;
>>>>>>>>> consider reducing the number of columns, or use BVVECS instead
>>>>>>>>> > > i understand that the requested number of eigenvectors and
>>>>>>>>> eigenvalues is causing an overflow but i do not understand the solution of
>>>>>>>>> the problem which is stated in the error message. Can someone tell me what
>>>>>>>>> exactly BVVECS is and how i can use it? Or is there any other solution to
>>>>>>>>> my problem ?
>>>>>>>>> > > You can also reconfigure with 64-bit integers:
>>>>>>>>> > > Thanks,
>>>>>>>>> > > Matt
>>>>>>>>> > > Thank you very much in advance,
>>>>>>>>> > > Jan
>>>>>>>>> > > What most experimenters take for granted before they begin
>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>> their experiments lead.
>>>>>>>>> > > -- Norbert Wiener
>>>>>>>>> > > https://www.cse.buffalo.edu/~knepley/
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181113/56611b23/attachment-0001.html>
