[petsc-users] PetscInt overflow
Jan Grießer
griesser.jan at googlemail.com
Tue Nov 13 05:40:05 CST 2018
I am finally back from holidays and continued working on the problem. I
think i figured out that the problem is not related to SLEPc but rather to
PETSc. Until now i precomputed my matrix in python and saved it as a
scipy.csr matrix( The matrix is of order 6 Mio x 6 Mio with around 0.004%
nonzero elements). The code i used to convert the scipy sparse matrix to a
PETSc matrix is appended below. But i am wondering if maybe the problem is
that the memory of the individual processors(i use at the moment 60 cores
with 24 GB each ) is simply dumped by the size of the matrix (It is around
13 Gb) or if the PETSc matrix is not correctly distributed.
I am sorry for the late answer and hope someone has any suggestion.
def construct_mat():
D_nn = scipy.sparse.load_npz("../PBC_DynamicalMatrix/DynamicalMatrixPB.npz")
# Create a matrix Ds in parallel
Dyn = PETSc.Mat().create()
Dyn.setSizes(CSRMatrix.shape)
Dyn.setFromOptions()
Dyn.setUp()
Rstart, Rend = Dyn.getOwnershipRange()
# Fill the matrix
csr = (
CSRMatrix.indptr[Rstart:Rend+1] - CSRMatrix.indptr[Rstart],
CSRMatrix.indices[CSRMatrix.indptr[Rstart]:CSRMatrix.indptr[Rend]],
CSRMatrix.data[CSRMatrix.indptr[Rstart]:CSRMatrix.indptr[Rend]]
D = PETSc.Mat().createAIJ(size=CSRMatrix.shape, csr=csr)
D.assemble()
# Free the memory
del CSRDynamicalMatrix_nn
# Return the PETSc dynamical matrix
return D
Am Mi., 24. Okt. 2018 um 18:46 Uhr schrieb Matthew Knepley <
knepley at gmail.com>:
> As it says, if you are looking at performance, you should configure using
> --with-debugging=0.
> It says SLEPc is using 8GB. Is this what you see?
> Matt
> On Wed, Oct 24, 2018 at 12:30 PM Jan Grießer <griesser.jan at googlemail.com>
> wrote:
>> I also run it with the -log_summary :
>> ---------------------------------------------- PETSc Performance Summary:
>> # WARNING!!! #
>> # This code was compiled with a debugging option, #
>> # To get timing results run ./configure #
>> # using --with-debugging=no, the performance will #
>> # be generally two or three times faster. #
>> /work/ws/nemo/fr_jg1080-FreeSurface_Glass-0/GlassSystems/PeriodicSystems/N500000T0.001/SolveEigenvalueProblem_par/Test/Eigensolver_petsc_slepc_no_argparse.py
>> on a arch-linux2-c-debug named int02.nemo.privat with 20 processors, by
>> fr_jg1080 Wed Oct 24 18:26:30 2018
>> Using Petsc Release Version 3.9.4, Sep, 11, 2018
>> Max Max/Min Avg Total
>> Time (sec): 7.474e+02 1.00000 7.474e+02
>> Objects: 3.600e+01 1.00000 3.600e+01
>> Flop: 1.090e+11 1.00346 1.089e+11 2.177e+12
>> Flop/sec: 1.459e+08 1.00346 1.457e+08 2.913e+09
>> Memory: 3.950e+08 1.00296 7.891e+09
>> MPI Messages: 3.808e+04 1.00000 3.808e+04 7.615e+05
>> MPI Message Lengths: 2.211e+10 1.00217 5.802e+05 4.419e+11
>> MPI Reductions: 1.023e+05 1.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>> e.g., VecAXPY() for real vectors of length N
>> --> 2N flop
>> and VecAXPY() for complex vectors of length N
>> --> 8N flop
>> Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages
>> --- -- Message Lengths -- -- Reductions --
>> Avg %Total Avg %Total counts
>> %Total Avg %Total counts %Total
>> 0: Main Stage: 7.4739e+02 100.0% 2.1773e+12 100.0% 7.615e+05
>> 100.0% 5.802e+05 100.0% 1.022e+05 100.0%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>> Count: number of times phase was executed
>> Time and Flop: Max - maximum over all processors
>> Ratio - ratio of maximum to minimum over all processors
>> Mess: number of messages sent
>> Avg. len: average message length (bytes)
>> Reduct: number of global reductions
>> Global: entire computation
>> Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>> %T - percent time in this phase %F - percent flop in this
>> phase
>> %M - percent messages in this phase %L - percent message
>> lengths in this phase
>> %R - percent reductions in this phase
>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>> # WARNING!!! #
>> Event Count Time (sec) Flop
>> --- Global --- --- Stage --- Total
>> Max Ratio Max Ratio Max Ratio Mess Avg len
>> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> BuildTwoSidedF 2 1.0 2.6670e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSet 2 1.0 6.8650e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecScatterBegin 2002 1.0 1.4380e+01 1.0 0.00e+00 0.0 7.6e+05 5.8e+05
>> 0.0e+00 2 0100100 0 2 0100100 0 0
>> VecScatterEnd 2002 1.0 3.7604e+01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00 4 0 0 0 0 4 0 0 0 0 0
>> VecSetRandom 1 1.0 1.6440e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatMult 2002 1.0 6.0846e+02 1.2 1.03e+11 1.0 7.6e+05 5.8e+05
>> 0.0e+00 71 94100100 0 71 94100100 0 3376
>> MatAssemblyBegin 3 1.0 2.8129e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 6.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatAssemblyEnd 3 1.0 8.5094e+00 1.0 0.00e+00 0.0 7.6e+02 1.5e+05
>> 3.6e+01 1 0 0 0 0 1 0 0 0 0 0
>> EPSSetUp 1 1.0 1.7351e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 7.6e+01 0 0 0 0 0 0 0 0 0 0 0
>> EPSSolve 1 1.0 6.7891e+02 1.0 1.09e+11 1.0 7.6e+05 5.8e+05
>> 1.0e+05 91100100100100 91100100100100 3207
>> STSetUp 1 1.0 2.2221e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> STApply 2002 1.0 6.0879e+02 1.2 1.03e+11 1.0 7.6e+05 5.8e+05
>> 0.0e+00 71 94100100 0 71 94100100 0 3374
>> BVCopy 999 1.0 2.7157e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> BVMultVec 4004 1.0 2.2918e+00 1.0 2.10e+09 1.0 0.0e+00 0.0e+00
>> 1.6e+04 0 2 0 0 16 0 2 0 0 16 18332
>> BVMultInPlace 999 1.0 4.8399e+01 1.0 1.20e+09 1.0 0.0e+00 0.0e+00
>> 0.0e+00 6 1 0 0 0 6 1 0 0 0 495
>> BVDotVec 4004 1.0 1.0835e+01 1.0 2.70e+09 1.0 0.0e+00 0.0e+00
>> 2.0e+04 1 2 0 0 20 1 2 0 0 20 4986
>> BVOrthogonalizeV 2003 1.0 1.3272e+01 1.0 4.80e+09 1.0 0.0e+00 0.0e+00
>> 5.2e+04 2 4 0 0 51 2 4 0 0 51 7236
>> BVScale 2003 1.0 2.3521e-01 1.0 1.50e+08 1.0 0.0e+00 0.0e+00
>> 0.0e+00 0 0 0 0 0 0 0 0 0 0 12773
>> BVSetRandom 1 1.0 1.6456e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DSSolve 1000 1.0 3.3338e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> DSVectors 1000 1.0 6.0029e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> DSOther 2999 1.0 7.8770e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> Memory usage is given in bytes:
>> Object Type Creations Destructions Memory Descendants'
>> Mem.
>> Reports information only for process 0.
>> Viewer 2 1 840 0.
>> PetscRandom 1 1 646 0.
>> Index Set 4 4 5510472 0.
>> Vector 9 9 11629608 0.
>> Vec Scatter 2 2 1936 0.
>> Matrix 10 10 331855732 0.
>> Preconditioner 1 1 1000 0.
>> Krylov Solver 1 1 1176 0.
>> EPS Solver 1 1 1600 0.
>> Spectral Transform 2 2 1624 0.
>> Basis Vectors 1 1 2168 0.
>> Direct Solver 1 1 2520 0.
>> Region 1 1 672 0.
>> Average time to get PetscTime(): 1.19209e-07
>> Average time for MPI_Barrier(): 2.67982e-05
>> Average time for zero size MPI_Send(): 1.08957e-05
>> #PETSc Option Table entries:
>> -bv_type mat
>> -eps_view_pre
>> -log_summary
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> Configure options: --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>> --download-mumps --with-shared-libraries=True --download-scalapack
>> Libraries compiled on 2018-10-17 20:02:31 on login2.nemo.privat
>> Machine characteristics:
>> Linux-3.10.0-693.21.1.el7.x86_64-x86_64-with-centos-7.4.1708-Core
>> Using PETSc directory: /home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4
>> Using PETSc arch: arch-linux2-c-debug
>> Using C compiler: mpicc -fPIC -wd1572 -g
>> Using Fortran compiler: mpif90 -fPIC -g
>> Using include paths:
>> -I/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/include
>> -I/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/arch-linux2-c-debug/include
>> Using C linker: mpicc
>> Using Fortran linker: mpif90
>> Using libraries:
>> -Wl,-rpath,/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/arch-linux2-c-debug/lib
>> -L/home/fr/fr_fr/fr_jg1080/Libaries/petsc-3.9.4/arch-linux2-c-debug/lib
>> -lpetsc
>> -Wl,-rpath,/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/mpi/intel64/lib/debug_mt
>> -L/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/mpi/intel64/lib/debug_mt
>> -Wl,-rpath,/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/lib/intel64
>> -L/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries/linux/lib/intel64
>> -Wl,-rpath,/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries_2018.3.222/linux/compiler/lib/intel64_lin
>> -L/opt/bwhpc/common/compiler/intel/2018.3.222/compilers_and_libraries_2018.3.222/linux/compiler/lib/intel64_lin
>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>> -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5
>> -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib/debug_mt
>> -Wl,-rpath,/opt/intel/mpi-rt/2017.0.0/intel64/lib -lcmumps -ldmumps
>> -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -llapack -lblas -lX11
>> -lstdc++ -ldl -lmpifort -lmpi -lmpigi -lrt -lpthread -lifport
>> -lifcoremt_pic -limf -lsvml -lm -lipgo -lirc -lgcc_s -lirc_s -lstdc++ -ldl
>> # WARNING!!! #
>> Am Mi., 24. Okt. 2018 um 18:07 Uhr schrieb Jan Grießer <
>> griesser.jan at googlemail.com>:
>>> For some reason i get only this error message, also when is use the
>>> -eps_view_pre. I started the program with nev=1, there the output is (with
>>> -bv_type vecs -bv_type mat -eps_view_pre)
>>> EPS Object: 20 MPI processes
>>> type: krylovschur
>>> 50% of basis vectors kept after restart
>>> using the locking variant
>>> problem type: symmetric eigenvalue problem
>>> selected portion of the spectrum: smallest real parts
>>> number of eigenvalues (nev): 1
>>> number of column vectors (ncv): 3
>>> maximum dimension of projected problem (mpd): 2
>>> maximum number of iterations: 1000
>>> tolerance: 1e-08
>>> convergence test: relative to the eigenvalue
>>> BV Object: 20 MPI processes
>>> type: mat
>>> 4 columns of global length 1500000
>>> vector orthogonalization method: classical Gram-Schmidt
>>> orthogonalization refinement: if needed (eta: 0.7071)
>>> block orthogonalization method: GS
>>> doing matmult as a single matrix-matrix product
>>> DS Object: 20 MPI processes
>>> type: hep
>>> parallel operation mode: REDUNDANT
>>> solving the problem with: Implicit QR method (_steqr)
>>> ST Object: 20 MPI processes
>>> type: shift
>>> shift: 0.
>>> number of matrices: 1
>>> Am Mi., 24. Okt. 2018 um 16:14 Uhr schrieb Matthew Knepley <
>>>> On Wed, Oct 24, 2018 at 10:03 AM Jan Grießer <
>>>> griesser.jan at googlemail.com> wrote:
>>>>> This is the error message i get from my program:
>>>>> Shape of the dynamical matrix: (1500000, 1500000)
>>>> Petsc installs a signal handler, so there should be a PETSc-specific
>>>> message before this one. Is something eating
>>>> your output?
>>>> Thanks,
>>>> Matt
>>>>> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>>>> = PID 122676 RUNNING AT n3512.nemo.privat
>>>>> = EXIT CODE: 9
>>>>> = CLEANING UP REMAINING PROCESSES
>>>>> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>>>> Intel(R) MPI Library troubleshooting guide:
>>>>> https://software.intel.com/node/561764
>>>>> Am Mi., 24. Okt. 2018 um 16:01 Uhr schrieb Matthew Knepley <
>>>>>> On Wed, Oct 24, 2018 at 9:38 AM Jan Grießer <
>>>>>>> Hey,
>>>>>>> i tried to run my program as you said with -bv_type vecs and/or
>>>>>>> -bv_type mat, but instead of the PETScInt overflow i now get an MPI Error 9
>>>>>> Send the actual error.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> message, which i assume (after googling a little bit around) should
>>>>>>> be a memory problem. I tried to run it also on slightly bigger compute
>>>>>>> nodes on our cluster with 20 cores with each 12 GB and 24 GB but the
>>>>>>> problem still remains. The actual limit appears to be a 1.5 Million x 1.5
>>>>>>> Million where i searched for NEV = 1500 and MPD = 500/ 200 eigenvalues.
>>>>>>> Do you have maybe an idea what the error could be? I appended also
>>>>>>> the python method i used to solve the problem. I also tried to solve the
>>>>>>> problem with spectrum solving but the error message remains the same.
>>>>>>> def solve_eigensystem(DynMatrix_nn, NEV, MPD, Dimension):
>>>>>>> # Create the solver
>>>>>>> # E is used as an acronym for the EPS solver (EPS = Eigenvalue
>>>>>>> problem solver)
>>>>>>> E = SLEPc.EPS().create()
>>>>>>> # Set the preconditioner
>>>>>>> pc = PETSc.PC().create()
>>>>>>> pc.setType(pc.Type.BJACOBI)
>>>>>>> # Set the linear solver
>>>>>>> # Create the KSP object
>>>>>>> ksp = PETSc.KSP().create()
>>>>>>> # Create the solver, in this case GMRES
>>>>>>> ksp.setType(ksp.Type.GMRES)
>>>>>>> # Set the tolerances of the GMRES solver
>>>>>>> # Link it to the PC
>>>>>>> ksp.setPC(pc)
>>>>>>> # Set up the spectral transformations
>>>>>>> st = SLEPc.ST().create()
>>>>>>> st.setType("shift")
>>>>>>> st.setKSP(ksp)
>>>>>>> # MPD stands for "maximum projected dimension". It has to due with
>>>>>>> computational cost, please read Chap. 2.6.5 of SLEPc docu for
>>>>>>> # an explanation. At the moment mpd is only a guess
>>>>>>> E.setDimensions(nev=NEV, mpd = MPD)
>>>>>>> # Eigenvalues should be real, therefore we start to order them from
>>>>>>> the smallest real value |l.real|
>>>>>>> E.setWhichEigenpairs(E.Which.SMALLEST_REAL)
>>>>>>> # Since the dynamical matrix is symmetric and real it is hermitian
>>>>>>> E.setProblemType(SLEPc.EPS.ProblemType.HEP)
>>>>>>> # Use the Krylov Schur method to solve the eigenvalue problem
>>>>>>> E.setType(E.Type.KRYLOVSCHUR)
>>>>>>> # Set the convergence criterion to relative to the eigenvalue and
>>>>>>> the maximal number of iterations
>>>>>>> E.setConvergenceTest(E.Conv.REL)
>>>>>>> E.setTolerances(tol = 1e-8, max_it = 5000)
>>>>>>> # Set the matrix in order to solve
>>>>>>> E.setOperators(DynMatrix_nn, None)
>>>>>>> # Sets EPS options from the options database. This routine must be
>>>>>>> called before `setUp()` if the user is to be allowed to set dthe solver
>>>>>>> type.
>>>>>>> E.setFromOptions()
>>>>>>> # Sets up all the internal data structures necessary for the
>>>>>>> execution of the eigensolver.
>>>>>>> E.setUp()
>>>>>>> # Solve eigenvalue problem
>>>>>>> E.solve()
>>>>>>> Print = PETSc.Sys.Print
>>>>>>> Print()
>>>>>>> Print("****************************")
>>>>>>> Print("***SLEPc Solution Results***")
>>>>>>> its = E.getIterationNumber()
>>>>>>> Print("Number of iterations of the method: ", its)
>>>>>>> eps_type = E.getType()
>>>>>>> Print("Solution method: ", eps_type)
>>>>>>> nev, ncv, mpd = E.getDimensions()
>>>>>>> Print("Number of requested eigenvalues: ", nev)
>>>>>>> Print("Number of computeded eigenvectors: ", ncv)
>>>>>>> tol, maxit = E.getTolerances()
>>>>>>> Print("Stopping condition: (tol, maxit)", (tol, maxit))
>>>>>>> # Get the type of convergence
>>>>>>> conv_test = E.getConvergenceTest()
>>>>>>> Print("Selected convergence test: ", conv_test)
>>>>>>> # Get the used spectral transformation
>>>>>>> get_st = E.getST()
>>>>>>> Print("Selected spectral transformation: ", get_st)
>>>>>>> # Get the applied direct solver
>>>>>>> get_ksp = E.getDS()
>>>>>>> Print("Selected direct solver: ", get_ksp)
>>>>>>> nconv = E.getConverged()
>>>>>>> Print("Number of converged eigenpairs: ", nconv)
>>>>>>> Am Fr., 19. Okt. 2018 um 21:00 Uhr schrieb Smith, Barry F. <
>>>>>>> bsmith at mcs.anl.gov>:
>>>>>>>> > On Oct 19, 2018, at 7:56 AM, Zhang, Junchao <jczhang at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>> > On Fri, Oct 19, 2018 at 4:02 AM Jan Grießer <
>>>>>>>> > With more than 1 MPI process you mean i should use spectrum
>>>>>>>> slicing in divide the full problem in smaller subproblems?
>>>>>>>> > The --with-64-bit-indices is not a possibility for me since i
>>>>>>>> configured petsc with mumps, which does not allow to use the 64-bit version
>>>>>>>> (At least this was the error message when i tried to configure PETSc )
>>>>>>>> > MUMPS 5.1.2 manual chapter 2.4.2 says it supports "Selective
>>>>>>>> 64-bit integer feature" and "full 64-bit integer version" as well.
>>>>>>>> They use to achieve this by compiling with special Fortran
>>>>>>>> flags to promote integers to 64 bit; this is too fragile for our taste so
>>>>>>>> we never hooked PETSc up wit it. If they have a dependable way of using 64
>>>>>>>> bit integers we should add that to our mumps.py and test it.
>>>>>>>> Barry
>>>>>>>> > Am Mi., 17. Okt. 2018 um 18:24 Uhr schrieb Jose E. Roman <
>>>>>>>> jroman at dsic.upv.es>:
>>>>>>>> > To use BVVECS just add the command-line option -bv_type vecs
>>>>>>>> > This causes to use a separate Vec for each column, instead of a
>>>>>>>> single long Vec of size n*m. But it is considerably slower than the default.
>>>>>>>> > Anyway, for such large problems you should consider using more
>>>>>>>> than 1 MPI process. In that case the error may disappear because the local
>>>>>>>> size is smaller than 768000.
>>>>>>>> > Jose
>>>>>>>> > > El 17 oct 2018, a las 17:58, Matthew Knepley <knepley at gmail.com>
>>>>>>>> escribió:
>>>>>>>> > > On Wed, Oct 17, 2018 at 11:54 AM Jan Grießer <
>>>>>>>> > > Hi all,
>>>>>>>> > > i am using slepc4py and petsc4py to solve for the smallest real
>>>>>>>> eigenvalues and eigenvectors. For my test cases with a matrix A of the size
>>>>>>>> 30k x 30k solving for the smallest soutions works quite well, but when i
>>>>>>>> increase the dimension of my system to around A = 768000 x 768000 or 3
>>>>>>>> million x 3 million and ask for the smallest real 3000 (the number is
>>>>>>>> increasing with increasing system size) eigenvalues and eigenvectors i get
>>>>>>>> the output (for the 768000):
>>>>>>>> > > The product 4001 times 768000 overflows the size of PetscInt;
>>>>>>>> consider reducing the number of columns, or use BVVECS instead
>>>>>>>> > > i understand that the requested number of eigenvectors and
>>>>>>>> eigenvalues is causing an overflow but i do not understand the solution of
>>>>>>>> the problem which is stated in the error message. Can someone tell me what
>>>>>>>> exactly BVVECS is and how i can use it? Or is there any other solution to
>>>>>>>> my problem ?
>>>>>>>> > > You can also reconfigure with 64-bit integers:
>>>>>>>> > > Thanks,
>>>>>>>> > > Matt
>>>>>>>> > > Thank you very much in advance,
>>>>>>>> > > Jan
>>>>>>>> > > What most experimenters take for granted before they begin
>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>> their experiments lead.
>>>>>>>> > > -- Norbert Wiener
>>>>>>>> > > https://www.cse.buffalo.edu/~knepley/
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181113/9a970ed1/attachment-0001.html>
