[petsc-users] [petsc-maint] Correct use of PCFactorSetMatOrderingType
Mark Adams
mfadams at lbl.gov
Thu Nov 8 10:32:04 CST 2018
To repeat:
You seem to be saying that OpenFOAM solves the problem in 10 seconds and
PETSc solves it in 14 seconds. Is that correct?
On Thu, Nov 8, 2018 at 3:42 AM Edoardo alinovi via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello Mark,
> Yes, there are 5 KSP calls within a time-step (3 for the solution of
> momentum equation + 2 for the solution of pressure), this is the classical
> non iterative PISO by Issa ( the exact sequence of operations is : solve
> momentum implicitly, solve pressure-correction, momentum explicitly,
> pressure correction). The pressure correction equation ,which is something
> similar to a Poisson equation for incompressible flows, is the one that
> determines the overall performance in my code such as in the others.
> Usually, when the pressure is being solved for the second time, the
> solution is faster since there is a better input guess and, as in my case,
> the preconditioner is not recomputed again.
> Have you got some advices for the multigrid configuration in this
> scenario, which are not the default one, in order to increase performances?
> I do not know if this may impact drastically the performance, but I am
> running on a E4 workstation with 16 Intel's Xeon processors (2.3GH/12MB
> cache) and 128GB of RAM .
> Thank you very much for your helpful comments,
> Edoardo
> Edoardo Alinovi, Ph.D.
> DICCA, Scuola Politecnica
> Universita' di Genova
> 1, via Montallegro
> 16145 Genova, Italy
> email: edoardo.alinovi at dicca.unige.it
> Tel: +39 010 353 2540
> Il giorno mer 7 nov 2018 alle ore 17:59 Mark Adams <mfadams at lbl.gov> ha
> scritto:
>> please respond to petsc-users.
>> You are doing 5 solves here in 14 seconds. You seem to be saying that the
>> two pressure solves are taking all of this time. I don't know why the two
>> solves are different.
>> PETSc solves it in 14 seconds. Is that correct? Hypre seems to be running
>> fine.
>> On Wed, Nov 7, 2018 at 11:24 AM Edoardo alinovi <
>> edoardo.alinovi at gmail.com> wrote:
>>> Thanks a lot Mark for your kind replay. The solver is mine and I use
>>> PETSc for the solution of momentum and pressure. The first is solved very
>>> fast by a standard bcgs + bjacobi, but the pressure is the source of all
>>> evils and, unfortunately, I am pretty sure that almost all the time within
>>> the time-step is needed by KSP to solve the pressure (see log attached). I
>>> have verified this also putting a couple of mpi_wtime around the kspsolve
>>> call. The pressure is solved 2 times (1 prediction + 1 correction), the
>>> prediction takes around 11s , the correction around 4s (here I am avoiding
>>> to recompute the preconditioner), all the rest of the code (flux assembling
>>> + mometum solution + others) around 1s. Openfoam does the same procedure
>>> with the same tolerance in 10s using its gamg version (50 it to converge).
>>> The number of iteration required to solve the pressure with hypre are 12.
>>> Gamg performs similarly to hypre in terms of speed, but with 50 iterations
>>> to converge. Am I missing something in the setup in your opinion?
>>> thanks a lot,
>>> Edo
>>> 1, via Montallegro
>>> 16145 Genova, Italy
>>> Il giorno mer 7 nov 2018 alle ore 16:50 Mark Adams <mfadams at lbl.gov> ha
>>> scritto:
>>>> You can try -pc_type gamg, but hypre is a pretty good solver for the
>>>> Laplacian. If hypre is just a little faster than LU on a 3D problem (that
>>>> takes 10 seconds to solve) then AMG is not doing well. I would expect that
>>>> AMG is taking a lot of iterations (eg, >> 10). You can check that with
>>>> -ksp_monitor.
>>>> The PISO algorithm is a multistage algorithm with a pressure correction
>>>> in it. It also has a solve for the velocity, from what I can tell. Are you
>>>> building PISO yourself and using PETSc just for the pressure correction?
>>>> Are you sure the time is spent in this solver? You can use -log_view to see
>>>> performance numbers and look for KSPSolve to see how much time is spent in
>>>> the PETSc solver.
>>>> Mark
>>>> On Wed, Nov 7, 2018 at 10:26 AM Zhang, Hong via petsc-maint <
>>>> petsc-maint at mcs.anl.gov> wrote:
>>>>> Edoardo:
>>>>> Forwarding your request to petsc-maint where you can get fast and
>>>>> expert advise. I do not have suggestion for your application, but someone
>>>>> in our team likely will make suggestion.
>>>>> Hong
>>>>> Hello Hong,
>>>>>> Well, using -sub_pc_type lu it super slow. I am desperately triying
>>>>>> to enhance performaces of my code (CFD, finite volume, PISO alghoritm), in
>>>>>> particular I have a strong bottleneck in the solution of pressure
>>>>>> correction equation which takes almost the 90% of computational time. Using
>>>>>> multigrid as preconditoner (hypre with default options) is slighlty
>>>>>> better, but comparing the results against the multigrid used in openFOAM,
>>>>>> my code is losing 10s/iteration which a huge amount of time. Now, since
>>>>>> that all the time is employed by KSPSolve, I feel a bit powerless. Do you
>>>>>> have any helpful advice?
>>>>>> Thank you very much!
>>>>>> 1, via Montallegro
>>>>>> 16145 Genova, Italy
>>>>>> Il giorno mar 6 nov 2018 alle ore 17:15 Zhang, Hong <
>>>>>> hzhang at mcs.anl.gov> ha scritto:
>>>>>>> Edoardo:
>>>>>>> Interesting. I thought it would not affect performance much. What
>>>>>>> happens if you use -sub_pc_type lu'?
>>>>>>> Hong
>>>>>>> Dear Hong and Matt,
>>>>>>>> thank you for your kind replay. I have just tested your suggestions
>>>>>>>> and applied " -sub_pc_type ilu -sub_pc_factor_mat_ordering_type nd/rcm"
>>>>>>>> and, in both cases, I have found a deterioration of performances
>>>>>>>> with respect to doing nothing (thus just putting default PCBJACOBI). Is it
>>>>>>>> normal? However, I guess this is very problem dependent.
>>>>>>>> 1, via Montallegro
>>>>>>>> 16145 Genova, Italy
>>>>>>>> Il giorno mar 6 nov 2018 alle ore 16:04 Zhang, Hong <
>>>>>>>>> Edoardo:
>>>>>>>>> You can test runtime option '-sub_pc_factor_mat_ordering_type' and
>>>>>>>>> use '-log_view' to get performance on different orderings,
>>>>>>>>> e.g.,petsc/src/ksp/ksp/examples/tutorials/ex2.c:
>>>>>>>>> mpiexec -n 2 ./ex2 -ksp_view -sub_pc_type ilu
>>>>>>>>> I do not think the ordering inside block for ilu would affect
>>>>>>>>> performance much. Let us know what you will get.
>>>>>>>>> Hong
>>>>>>>>> Dear users,
>>>>>>>>>> I have a question about the correct use of the option
>>>>>>>>>> "PCFactorSetMatOrderingType" in PETSc.
>>>>>>>>>> I am solving a problem with 2.5M of unknowns distributed along 16
>>>>>>>>>> processors and I am using the block jacobi preconditioner and MPIAIJ
>>>>>>>>>> matrix format. I cannot figure out if the above option can be useful or not
>>>>>>>>>> in decreasing the computational time. Any suggestion or tips?
>>>>>>>>>> Thank you very much for the kind help
>>>>>>>>>> 1, via Montallegro
>>>>>>>>>> 16145 Genova, Italy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181108/68d73a1d/attachment-0001.html>
