[petsc-users] DIVERGED_NANORING with PC GAMG
Mark Adams mfadams at lbl.gov
Mon Nov 5 14:12:10 CST 2018
On Mon, Nov 5, 2018 at 12:50 PM Thibaut Appel <t.appel17 at imperial.ac.uk>
wrote:
> Hi Mark,
> Yes it doesn't seem to be usable. Unfortunately we're aiming to do 3D so
> direct solvers are not a viable solution and PETSc' ILU is not parallel and
> we can't use HYPRE (complex arithmetic)
I think SuperLU has a parallel ILU but in my opinion parallel ILU is not a
big deal. Neither is optimal and the math win (faster convergence) with
parallel is offset by the cost of synchronization, in some form, for a true
parallel ILU. So I think the PETSc default gmres/(local)ILU is your
best option.
> Thibaut
> On 01/11/2018 20:42, Mark Adams wrote:
> On Wed, Oct 31, 2018 at 8:11 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> > On Oct 31, 2018, at 5:39 PM, Appel, Thibaut via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> > Well yes naturally for the residual but adding -ksp_true_residual just
>> gives
>> >   0 KSP unpreconditioned resid norm 3.583290589961e+00 true resid norm
>> 3.583290589961e+00 ||r(i)||/||b|| 1.000000000000e+00
>> >   1 KSP unpreconditioned resid norm 0.000000000000e+00 true resid norm
>> > Linear solve converged due to CONVERGED_ATOL iterations 1
>>    Very bad stuff is happening in the preconditioner. The preconditioner
>> must have a null space (which it shouldn't have to be a useful
>> preconditioner).
> Yea, you are far away from an optimal preconditioner for this system. In
> low frequency (indefinite) Helmholtz is very very hard. Now, something very
> bad is going on here but even if you fix it standard AMG is not good for
> these problems. I would use direct solvers or grind away it with ILU.
>> > Mark - if that helps - a Poisson equation is used for the pressure so
>> the Helmholtz is the same as for the velocity in the interior.
>> > Thibaut
>> >> Le 31 oct. 2018 à 21:05, Mark Adams <mfadams at lbl.gov> a écrit :
>> >> These are indefinite (bad) Helmholtz problems. Right?
>> >> On Wed, Oct 31, 2018 at 2:38 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>> >> On Wed, Oct 31, 2018 at 2:13 PM Thibaut Appel <
>> t.appel17 at imperial.ac.uk> wrote:
>> >> Hi Mark, Matthew,
>> >> Thanks for taking the time.
>> >> 1) You're not suggesting having -fieldsplit_X_ksp_type fgmres for each
>> field, are you?
>> >> 2) No, the matrix has pressure in one of the fields. Here it's a 2D
>> problem (but we're also doing 3D), the unknowns are (p,u,v) and those are
>> my 3 fields. We are dealing with subsonic/transsonic flows so it is
>> convection dominated indeed.
>> >> 3) We are in frequency domain with respect to time, i.e.
>> \partial{phi}/\partial{t} = -i*omega*phi.
>> >> 4) Hypre is unfortunately not an option since we are in complex
>> arithmetic.
>> >>> I'm not sure about "-fieldsplit_pc_type gamg" GAMG should work on one
>> block, and hence be a subpc. I'm not up on fieldsplit syntax.
>> >> According to the online manual page this syntax applies the suffix to
>> all the defined fields?
>> >>> Mark is correct. I wanted you to change the smoother. He shows how to
>> change it to Richardson (make sure you add the self-scale option), which is
>> probably the best choice.
>> >>>   Thanks,
>> >>>      Matt
>> >> You did tell me to set it to GMRES if I'm not mistaken, that's why I
>> tried "-fieldsplit_mg_levels_ksp_type gmres" (mentioned in the email).
>> Also, it wasn't clear whether these should be applied to each block or the
>> whole system, as the online manual pages + .pdf manual barely mention
>> smoothers and how to manipulate MG objects with KSP/PC, this especially
>> with PCFIELDSPLIT where examples are scarce.
>> >> From what I can gather from your suggestions I tried (lines with X are
>> repeated for X={0,1,2})
>> >> This looks good. How can an identically zero vector produce a 0
>> residual? You should always monitor with
>> >>   -ksp_monitor_true_residual.
>> >>    Thanks,
>> >>     Matt
>> >> -ksp_view_pre -ksp_monitor -ksp_converged_reason \
>> >> -ksp_type fgmres -ksp_rtol 1.0e-8 \
>> >> -pc_type fieldsplit \
>> >> -pc_fieldsplit_type multiplicative \
>> >> -pc_fieldsplit_block_size 3 \
>> >> -pc_fieldsplit_0_fields 0 \
>> >> -pc_fieldsplit_1_fields 1 \
>> >> -pc_fieldsplit_2_fields 2 \
>> >> -fieldsplit_X_pc_type gamg \
>> >> -fieldsplit_X_ksp_type gmres \
>> >> -fieldsplit_X_ksp_rtol 1e-10 \
>> >> -fieldsplit_X_mg_levels_ksp_type richardson \
>> >> -fieldsplit_X_mg_levels_pc_type sor \
>> >> -fieldsplit_X_pc_gamg_agg_nsmooths 0 \
>> >> -fieldsplit_X_mg_levels_ksp_richardson_self_scale \
>> >> -log_view
>> >> which yields
>> >> KSP Object: 1 MPI processes
>> >>   type: fgmres
>> >>     restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> >>     happy breakdown tolerance 1e-30
>> >>   maximum iterations=10000, initial guess is zero
>> >>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>> >>   left preconditioning
>> >>   using DEFAULT norm type for convergence test
>> >> PC Object: 1 MPI processes
>> >>   type: fieldsplit
>> >>   PC has not been set up so information may be incomplete
>> >>     FieldSplit with MULTIPLICATIVE composition: total splits = 3,
>> blocksize = 3
>> >>     Solver info for each split is in the following KSP objects:
>> >>   Split number 0 Fields  0
>> >>   KSP Object: (fieldsplit_0_) 1 MPI processes
>> >>     type: preonly
>> >>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>> >>   PC Object: (fieldsplit_0_) 1 MPI processes
>> >>     type not yet set
>> >>   Split number 1 Fields  1
>> >>   KSP Object: (fieldsplit_1_) 1 MPI processes
>> >>     type: preonly
>> >>   PC Object: (fieldsplit_1_) 1 MPI processes
>> >>     type not yet set
>> >>   Split number 2 Fields  2
>> >>   KSP Object: (fieldsplit_2_) 1 MPI processes
>> >>     type: preonly
>> >>   PC Object: (fieldsplit_2_) 1 MPI processes
>> >>     type not yet set
>> >>   linear system matrix = precond matrix:
>> >>   Mat Object: 1 MPI processes
>> >>     type: seqaij
>> >>     rows=52500, cols=52500
>> >>     total: nonzeros=1127079, allocated nonzeros=1128624
>> >>     total number of mallocs used during MatSetValues calls =0
>> >>       not using I-node routines
>> >>   0 KSP Residual norm 3.583290589961e+00
>> >>   1 KSP Residual norm 0.000000000000e+00
>> >> so something must not be set correctly. The solution is identically
>> zero everywhere.
>> >> Is that option list what you meant? If you could let me know what
>> should be corrected.
>> >> Thanks for your support,
>> >> Thibaut
>> >> On 31/10/2018 16:43, Mark Adams wrote:
>> >>> On Tue, Oct 30, 2018 at 5:23 PM Appel, Thibaut via petsc-users <
>> >>> Dear users,
>> >>> Following a suggestion from Matthew Knepley I’ve been trying to apply
>> fieldsplit/gamg for my set of PDEs but I’m still encountering issues
>> despite various tests. pc_gamg simply won’t start.
>> >>> Note that direct solvers always yield the correct, physical result.
>> >>> Removing the fieldsplit to focus on the gamg bit and trying to solve
>> the linear system on a modest size problem still gives, with
>> >>> '-ksp_monitor -ksp_rtol 1.0e-10 -ksp_gmres_restart 300 -ksp_type
>> gmres -pc_type gamg'
>> >>> [3]PETSC ERROR: --------------------- Error Message
>> >>> [3]PETSC ERROR: Petsc has generated inconsistent data
>> >>> [3]PETSC ERROR: Have un-symmetric graph (apparently). Use
>> '-(null)pc_gamg_sym_graph true' to symetrize the graph or
>> '-(null)pc_gamg_threshold -1' if the matrix is structurally symmetric.
>> >>> And since then, after adding '-pc_gamg_sym_graph true' I have been
>> getting
>> >>> [0]PETSC ERROR: --------------------- Error Message
>> >>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> >>> [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at iteration
>> >>> -ksp_chebyshev_esteig_noisy 0/1 does not change anything
>> >>> Knowing that Chebyshev eigen estimator needs a positive spectrum I
>> tried ‘-mg_levels_ksp_type gmres’ but iterations would just go on endlessly.
>> >>> This is OK, but you need to use '-ksp_type fgmres' (this could be why
>> it is failing ...).
>> >>> It looks like your matrix is 1) just the velocity field and 2) very
>> unsymmetric (eg, convection dominated). I would start with
>> ‘-mg_levels_ksp_type richardson -mg_levels_pc_type sor’.
>> >>> I would also start with unsmoothed aggregation: '-pc_gamg_nsmooths 0'
>> >>> It seems that I have indeed eigenvalues of rather high magnitude in
>> the spectrum of my operator without being able to determine the reason.
>> >>> The eigenvectors look like small artifacts at the wall-inflow or
>> wall-outflow corners with zero anywhere else but I do not know how to
>> interpret this.
>> >>> Equations are time-harmonic linearized Navier-Stokes to which a
>> forcing is applied, there’s no time-marching.
>> >>> You mean you are in frequency domain?
>> >>> Matrix is formed with a MPIAIJ type. The formulation is
>> incompressible, in complex arithmetic and the 2D physical domain is mapped
>> to a logically rectangular,
>> >>> This kind of messes up the null space that AMG depends on but AMG
>> theory is gone for NS anyway.
>> >>> regular collocated grid with a high-order finite difference method.
>> >>> I determine the ownership of the rows/degrees of freedom of the
>> matrix with PetscSplitOwnership and I’m not using DMDA.
>> >>> Our iterative solvers are probably not going to work well on this but
>> you should test hypre also (-pc_type hypre -pc_hypre_type boomeramg). You
>> need to configure PETSc to download hypre.
>> >>> Mark
>> >>> The Fortran application code is memory-leak free and has undergone a
>> strict verification/validation procedure for different variations of the
>> PDEs.
>> >>> If there’s any problem with the matrix what could help for the
>> diagnostic? At this point I’m running out of ideas so I would really
>> appreciate additional suggestions and discussions.
>> >>> Thanks for your continued support,
>> >>> Thibaut
>> >> What most experimenters take for granted before they begin their
>> experiments lead.
>> >> -- Norbert Wiener
>> >> https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/4c196628/attachment.html>
