[petsc-users] DIVERGED_NANORING with PC GAMG
Thibaut Appel
t.appel17 at imperial.ac.uk
Mon Nov 5 11:49:22 CST 2018
Hi Mark,
Yes it doesn't seem to be usable. Unfortunately we're aiming to do 3D so
direct solvers are not a viable solution and PETSc' ILU is not parallel
and we can't use HYPRE (complex arithmetic)
Thibaut
On 01/11/2018 20:42, Mark Adams wrote:
> On Wed, Oct 31, 2018 at 8:11 PM Smith, Barry F. <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
> > On Oct 31, 2018, at 5:39 PM, Appel, Thibaut via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> > Well yes naturally for the residual but adding
> -ksp_true_residual just gives
> > 0 KSP unpreconditioned resid norm 3.583290589961e+00 true
> resid norm 3.583290589961e+00 ||r(i)||/||b|| 1.000000000000e+00
> > 1 KSP unpreconditioned resid norm 0.000000000000e+00 true
> > Linear solve converged due to CONVERGED_ATOL iterations 1
> Very bad stuff is happening in the preconditioner. The
> preconditioner must have a null space (which it shouldn't have to
> be a useful preconditioner).
> Yea, you are far away from an optimal preconditioner for this system.
> In low frequency (indefinite) Helmholtz is very very hard. Now,
> something very bad is going on here but even if you fix it standard
> AMG is not good for these problems. I would use direct solvers or
> grind away it with ILU.
> > Mark - if that helps - a Poisson equation is used for the
> pressure so the Helmholtz is the same as for the velocity in the
> interior.
> > Thibaut
> >> Le 31 oct. 2018 à 21:05, Mark Adams <mfadams at lbl.gov
> <mailto:mfadams at lbl.gov>> a écrit :
> >> These are indefinite (bad) Helmholtz problems. Right?
> >> On Wed, Oct 31, 2018 at 2:38 PM Matthew Knepley
> <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> >> On Wed, Oct 31, 2018 at 2:13 PM Thibaut Appel
> <t.appel17 at imperial.ac.uk <mailto:t.appel17 at imperial.ac.uk>> wrote:
> >> Hi Mark, Matthew,
> >> Thanks for taking the time.
> >> 1) You're not suggesting having -fieldsplit_X_ksp_type fgmres
> for each field, are you?
> >> 2) No, the matrix has pressure in one of the fields. Here it's
> a 2D problem (but we're also doing 3D), the unknowns are (p,u,v)
> and those are my 3 fields. We are dealing with subsonic/transsonic
> flows so it is convection dominated indeed.
> >> 3) We are in frequency domain with respect to time, i.e.
> \partial{phi}/\partial{t} = -i*omega*phi.
> >> 4) Hypre is unfortunately not an option since we are in complex
> arithmetic.
> >>> I'm not sure about "-fieldsplit_pc_type gamg" GAMG should work
> on one block, and hence be a subpc. I'm not up on fieldsplit syntax.
> >> According to the online manual page this syntax applies the
> suffix to all the defined fields?
> >>> Mark is correct. I wanted you to change the smoother. He shows
> how to change it to Richardson (make sure you add the self-scale
> option), which is probably the best choice.
> >>> Thanks,
> >>> Matt
> >> You did tell me to set it to GMRES if I'm not mistaken, that's
> why I tried "-fieldsplit_mg_levels_ksp_type gmres" (mentioned in
> the email). Also, it wasn't clear whether these should be applied
> to each block or the whole system, as the online manual pages +
> .pdf manual barely mention smoothers and how to manipulate MG
> objects with KSP/PC, this especially with PCFIELDSPLIT where
> examples are scarce.
> >> From what I can gather from your suggestions I tried (lines
> with X are repeated for X={0,1,2})
> >> This looks good. How can an identically zero vector produce a 0
> residual? You should always monitor with
> >> -ksp_monitor_true_residual.
> >> Thanks,
> >> Matt
> >> -ksp_view_pre -ksp_monitor -ksp_converged_reason \
> >> -ksp_type fgmres -ksp_rtol 1.0e-8 \
> >> -pc_type fieldsplit \
> >> -pc_fieldsplit_type multiplicative \
> >> -pc_fieldsplit_block_size 3 \
> >> -pc_fieldsplit_0_fields 0 \
> >> -pc_fieldsplit_1_fields 1 \
> >> -pc_fieldsplit_2_fields 2 \
> >> -fieldsplit_X_pc_type gamg \
> >> -fieldsplit_X_ksp_type gmres \
> >> -fieldsplit_X_ksp_rtol 1e-10 \
> >> -fieldsplit_X_mg_levels_ksp_type richardson \
> >> -fieldsplit_X_mg_levels_pc_type sor \
> >> -fieldsplit_X_pc_gamg_agg_nsmooths 0 \
> >> -fieldsplit_X_mg_levels_ksp_richardson_self_scale \
> >> -log_view
> >> which yields
> >> KSP Object: 1 MPI processes
> >> type: fgmres
> >> restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >> happy breakdown tolerance 1e-30
> >> maximum iterations=10000, initial guess is zero
> >> tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
> >> left preconditioning
> >> using DEFAULT norm type for convergence test
> >> PC Object: 1 MPI processes
> >> type: fieldsplit
> >> PC has not been set up so information may be incomplete
> >> FieldSplit with MULTIPLICATIVE composition: total splits =
> 3, blocksize = 3
> >> Solver info for each split is in the following KSP objects:
> >> Split number 0 Fields 0
> >> KSP Object: (fieldsplit_0_) 1 MPI processes
> >> type: preonly
> >> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> >> PC Object: (fieldsplit_0_) 1 MPI processes
> >> type not yet set
> >> Split number 1 Fields 1
> >> KSP Object: (fieldsplit_1_) 1 MPI processes
> >> type: preonly
> >> PC Object: (fieldsplit_1_) 1 MPI processes
> >> type not yet set
> >> Split number 2 Fields 2
> >> KSP Object: (fieldsplit_2_) 1 MPI processes
> >> type: preonly
> >> PC Object: (fieldsplit_2_) 1 MPI processes
> >> type not yet set
> >> linear system matrix = precond matrix:
> >> Mat Object: 1 MPI processes
> >> type: seqaij
> >> rows=52500, cols=52500
> >> total: nonzeros=1127079, allocated nonzeros=1128624
> >> total number of mallocs used during MatSetValues calls =0
> >> not using I-node routines
> >> 0 KSP Residual norm 3.583290589961e+00
> >> 1 KSP Residual norm 0.000000000000e+00
> >> so something must not be set correctly. The solution is
> identically zero everywhere.
> >> Is that option list what you meant? If you could let me know
> what should be corrected.
> >> Thanks for your support,
> >> Thibaut
> >> On 31/10/2018 16:43, Mark Adams wrote:
> >>> On Tue, Oct 30, 2018 at 5:23 PM Appel, Thibaut via petsc-users
> >>> Dear users,
> >>> Following a suggestion from Matthew Knepley I’ve been trying
> to apply fieldsplit/gamg for my set of PDEs but I’m still
> encountering issues despite various tests. pc_gamg simply won’t start.
> >>> Note that direct solvers always yield the correct, physical
> result.
> >>> Removing the fieldsplit to focus on the gamg bit and trying to
> solve the linear system on a modest size problem still gives, with
> >>> '-ksp_monitor -ksp_rtol 1.0e-10 -ksp_gmres_restart 300
> -ksp_type gmres -pc_type gamg'
> >>> [3]PETSC ERROR: --------------------- Error Message
> >>> [3]PETSC ERROR: Petsc has generated inconsistent data
> >>> [3]PETSC ERROR: Have un-symmetric graph (apparently). Use
> '-(null)pc_gamg_sym_graph true' to symetrize the graph or
> '-(null)pc_gamg_threshold -1' if the matrix is structurally symmetric.
> >>> And since then, after adding '-pc_gamg_sym_graph true' I have
> been getting
> >>> [0]PETSC ERROR: --------------------- Error Message
> >>> [0]PETSC ERROR: Petsc has generated inconsistent data
> >>> [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at
> iteration
> >>> -ksp_chebyshev_esteig_noisy 0/1 does not change anything
> >>> Knowing that Chebyshev eigen estimator needs a positive
> spectrum I tried ‘-mg_levels_ksp_type gmres’ but iterations would
> just go on endlessly.
> >>> This is OK, but you need to use '-ksp_type fgmres' (this could
> be why it is failing ...).
> >>> It looks like your matrix is 1) just the velocity field and 2)
> very unsymmetric (eg, convection dominated). I would start with
> ‘-mg_levels_ksp_type richardson -mg_levels_pc_type sor’.
> >>> I would also start with unsmoothed aggregation:
> '-pc_gamg_nsmooths 0'
> >>> It seems that I have indeed eigenvalues of rather high
> magnitude in the spectrum of my operator without being able to
> determine the reason.
> >>> The eigenvectors look like small artifacts at the wall-inflow
> or wall-outflow corners with zero anywhere else but I do not know
> how to interpret this.
> >>> Equations are time-harmonic linearized Navier-Stokes to which
> a forcing is applied, there’s no time-marching.
> >>> You mean you are in frequency domain?
> >>> Matrix is formed with a MPIAIJ type. The formulation is
> incompressible, in complex arithmetic and the 2D physical domain
> is mapped to a logically rectangular,
> >>> This kind of messes up the null space that AMG depends on but
> AMG theory is gone for NS anyway.
> >>> regular collocated grid with a high-order finite difference
> method.
> >>> I determine the ownership of the rows/degrees of freedom of
> the matrix with PetscSplitOwnership and I’m not using DMDA.
> >>> Our iterative solvers are probably not going to work well on
> this but you should test hypre also (-pc_type hypre -pc_hypre_type
> boomeramg). You need to configure PETSc to download hypre.
> >>> Mark
> >>> The Fortran application code is memory-leak free and has
> undergone a strict verification/validation procedure for different
> variations of the PDEs.
> >>> If there’s any problem with the matrix what could help for the
> diagnostic? At this point I’m running out of ideas so I would
> really appreciate additional suggestions and discussions.
> >>> Thanks for your continued support,
> >>> Thibaut
> >> What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any results
> to which their experiments lead.
> >> -- Norbert Wiener
> >> https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181105/78892b30/attachment-0001.html>
