[petsc-users] Problems with DMDAVecGetArrayF90 + Intel
    Satish Balay
    balay at mcs.anl.gov
    Tue May 15 11:14:01 CDT 2018
On Tue, 15 May 2018, Jed Brown wrote:
> Wow, how did this ever work with other compilers?
> To ensure everything gets fixed, I see we have
>   #define F90Array3d void
> and then arguments are defined as
>   F90Array3d *ptr
> We could make this type-safe by
>   typedef struct { void *ptr; } F90Array3d;
The following appears to be sufficient. [void* more appropriate than void - as these are pointers anyway?]
-#define F90Array1d void
-#define F90Array2d void
-#define F90Array3d void
-#define F90Array4d void
+typedef void* F90Array1d;
+typedef void* F90Array2d;
+typedef void* F90Array3d;
+typedef void* F90Array4d;
> and use this for arguments:
>   F90Array3d a
Don't need this change..
Attaching my current patch..
Satish
diff --git a/include/petsc/private/f90impl.h b/include/petsc/private/f90impl.h
index a35efb76bd..4f26c8ffea 100644
--- a/include/petsc/private/f90impl.h
+++ b/include/petsc/private/f90impl.h
@@ -15,11 +15,10 @@
 #endif
 #if defined(PETSC_USING_F90)
 PETSC_EXTERN PetscErrorCode F90Array1dCreate(void*,MPI_Datatype,PetscInt,PetscInt,F90Array1d* PETSC_F90_2PTR_PROTO_NOVAR);
 PETSC_EXTERN PetscErrorCode F90Array1dAccess(F90Array1d*,MPI_Datatype,void** PETSC_F90_2PTR_PROTO_NOVAR);
diff --git a/src/dm/impls/composite/f90-custom/zfddaf90.c b/src/dm/impls/composite/f90-custom/zfddaf90.c
index abc0a27a01..2633c9e86a 100644
--- a/src/dm/impls/composite/f90-custom/zfddaf90.c
+++ b/src/dm/impls/composite/f90-custom/zfddaf90.c
@@ -24,8 +24,8 @@ PETSC_EXTERN void PETSC_STDCALL dmcompositegetaccessvpvp_(DM *dm,Vec *v,Vec *v1,
 PETSC_EXTERN void PETSC_STDCALL dmcompositerestoreaccessvpvp_(DM *dm,Vec *v,Vec *v1,F90Array1d *p1,Vec *v2,F90Array1d *p2,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd1) PETSC_F90_2PTR_PROTO(ptrd2))
   *ierr = DMCompositeRestoreAccess(*dm,*v,v1,0,v2,0);
-  *ierr = F90Array1dDestroy(&p1,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd1));
-  *ierr = F90Array1dDestroy(&p2,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd2));
+  *ierr = F90Array1dDestroy(p1,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd1));
+  *ierr = F90Array1dDestroy(p2,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd2));
 PETSC_EXTERN void PETSC_STDCALL dmcompositegetentriesarray_(DM *dm, DM *dmarray, PetscErrorCode *ierr)
diff --git a/src/dm/impls/da/f90-custom/zda1f90.c b/src/dm/impls/da/f90-custom/zda1f90.c
index 082027725f..41cc58534f 100644
--- a/src/dm/impls/da/f90-custom/zda1f90.c
+++ b/src/dm/impls/da/f90-custom/zda1f90.c
@@ -74,7 +74,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayf901_(DM *da,Vec *v,F90Array1
   PetscScalar *fa;
   *ierr = F90Array1dAccess(a,MPIU_SCALAR,(void**)&fa PETSC_F90_2PTR_PARAM(ptrd));
   *ierr = VecRestoreArray(*v,&fa);if (*ierr) return;
-  *ierr = F90Array1dDestroy(&a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
+  *ierr = F90Array1dDestroy(a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayf902_(DM *da,Vec *v,F90Array2d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -113,7 +113,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayf902_(DM *da,Vec *v,F90Array2
   PetscScalar *fa;
   *ierr = F90Array2dAccess(a,MPIU_SCALAR,(void**)&fa PETSC_F90_2PTR_PARAM(ptrd));
-  *ierr = F90Array2dDestroy(&a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
+  *ierr = F90Array2dDestroy(a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayf903_(DM *da,Vec *v,F90Array3d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -154,7 +154,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayf903_(DM *da,Vec *v,F90Array3
   PetscScalar *fa;
   *ierr = F90Array3dAccess(a,MPIU_SCALAR,(void**)&fa PETSC_F90_2PTR_PARAM(ptrd));
-  *ierr = F90Array3dDestroy(&a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
+  *ierr = F90Array3dDestroy(a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayf904_(DM *da,Vec *v,F90Array4d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -190,7 +190,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayf904_(DM *da,Vec *v,F90Array4
   *ierr = F90Array4dAccess(a,MPIU_SCALAR,(void**)&fa PETSC_F90_2PTR_PARAM(ptrd));
-  *ierr = F90Array4dDestroy(&a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
+  *ierr = F90Array4dDestroy(a,MPIU_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayreadf901_(DM *da,Vec *v,F90Array1d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -223,7 +223,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayreadf901_(DM *da,Vec *v,F90Ar
   const PetscScalar *fa;
   *ierr = VecRestoreArrayRead(*v,&fa);if (*ierr) return;
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayreadf902_(DM *da,Vec *v,F90Array2d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -262,7 +262,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayreadf902_(DM *da,Vec *v,F90Ar
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayreadf903_(DM *da,Vec *v,F90Array3d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -303,7 +303,7 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayreadf903_(DM *da,Vec *v,F90Ar
 PETSC_EXTERN void PETSC_STDCALL dmdavecgetarrayreadf904_(DM *da,Vec *v,F90Array4d *a,PetscErrorCode *ierr PETSC_F90_2PTR_PROTO(ptrd))
@@ -339,5 +339,5 @@ PETSC_EXTERN void PETSC_STDCALL dmdavecrestorearrayreadf904_(DM *da,Vec *v,F90Ar
