[petsc-users] Problems with DMDAVecGetArrayF90 + Intel
    Satish Balay
    balay at mcs.anl.gov
    Tue May 15 10:38:21 CDT 2018
Looks like this issue got introduced with:
http://bitbucket.org/petsc/petsc/commits/fcfd50eb5fb
Satish
On Tue, 15 May 2018, Jed Brown wrote:
> Wow, how did this ever work with other compilers?
> To ensure everything gets fixed, I see we have
>   #define F90Array3d void
> and then arguments are defined as
>   F90Array3d *ptr
> We could make this type-safe by
>   typedef struct { void *ptr; } F90Array3d;
> and use this for arguments:
>   F90Array3d a
> Randall Mackie <rlmackie862 at gmail.com> writes:
> >> On Apr 10, 2018, at 5:40 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> On Tue, 10 Apr 2018, Jeff Hammond wrote:
> >>> Can you try on a non-KNL host?  It's a bug either way but I want to
> >>> determine if KNL host is the issue.
> >> Breaks on 'E5-2695 v4' aswell (bebop.lcrc) with '-axcore-avx2' and 'icc (ICC) 18.0.1 20171018'
> >>> Based only what I see below, Randy doesn't seem to be reporting a
> >>> KNL-specific issue.  Is that incorrect?
> >> Hardware details weren't mentioned in this thread.
> >>> Again, there is clearly a bug here, but it helps to localize the problem as
> >>> much as possible.
> >>>>>>> On Thu, 5 Apr 2018, Randall Mackie wrote:
> >>>>>> so I assume this is an Intel bug, but before we submit a bug
> >>>>>> report I wanted to see if anyone else had similar experiences?
> >> Randy,
> >> I'll leave this to you to file a report with Intel.
> >> Thanks,
> >> Satish
> > Hi Satish,
> > As requested we filed a report with Intel, and this is their response:
> > From: Intel Customer Support <supportreplies at intel.com <mailto:supportreplies at intel.com>>
> > Sent: 14 May 2018 19:56
> > Subject: Intel Developer Products Support - Update to Service Request#:03369230
> > Hello,
> > An update was made to service request on May 14, 2018:
> > Thank you for the additional information. Our engineering team investigated this case. Please see the following resolution:
> > There is a bug in customer’s code:
> > At line 157 of “/src/dm/impls/da/f90-custom/zda1f90.c”
> > *ierr = F90Array3dDestroy(&a,PETSC_SCALAR PETSC_F90_2PTR_PARAM(ptrd));
> > Here “&a” should be “a” because “a” was passed from call at line 79 of “test.F90” as the 3rd arguments DMDAVecRestoreArrayF90(da1,vec1,ptr_v1,ierr). In fortran the array descriptor of assumed-shape array will be passed by address so when it is passed to another C function it shouldn’t be taken address again. There are other places in the code having the same error. After removing “&” the code can be built and run without error.
> > In addition, this issue was discussed 4 years ago https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2014-April/021232.html <https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2014-April/021232.html> without noticing the bug in the code, more likely a user coding error.
> > I am going to close out this case as not a compiler defect. You can reopen by posting a reply if you have any problem with the above resolution.
> > Sign in <https://supporttickets.intel.com/ICS_CX_Support_Request_Detail?id=5000P00000hEKLaQAO&lang=null> to view and update your request or to get additional information. You can also reply to this email with questions or comments.
> > Regards,
> > Devorah
> > Intel will use your personal information solely for the purpose it was collected. We will not use your personal information for a different purpose without first asking your permission. In order to fulfill the purpose, we may need to share your personal information within Intel Corporation, Intel subsidiaries worldwide, or with authorized third parties.
> > Privacy <http://www.intel.com/privacy> – Cookies <http://www.intel.com/cookies>
> > Intel may contact you in order to obtain your feedback on the quality of the support you received. We give you many choices regarding our use of your personal information for quality assurance and marketing purposes. You may update and request access to your contact details and communication preferences by using one of the following methods: visit the specific product or service website; use the Contact Us <https://www-ssl.intel.com/content/www/us/en/forms/privacy-contact-us.html> form; or send a letter to the postal address below.
> > Intel Corporation; Mailstop RNB4-145; 2200 Mission College Blvd.; Santa Clara, CA 95054 USA
> > ® Intel Corporation – Legal Information <http://www.intel.com/content/www/us/en/legal/terms-of-use.html> – www.intel.com <http://www.intel.com/>
> > Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
> > *Other names and brands may be claimed as the property of others.
> > *********************PLEASE DO NOT DELETE*********************
> > Thread ID: ref:_00DU0YT3c._5000PhEKLa:ref
> > You must include this text in any reply to this email. Thank you.
