[petsc-users] monitoring the convergence of fieldsplit 0 and 1
Klaij, Christiaan
C.Klaij at marin.nl
Tue May 15 04:25:01 CDT 2018
Matt,
Just a reminder. With petsc-3.8.4 the issue is still there.
Chris
dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | www.marin.nl<http://www.marin.nl>
[LinkedIn]<https://www.linkedin.com/company/marin> [YouTube] <http://www.youtube.com/marinmultimedia> [Twitter] <https://twitter.com/MARIN_nieuws> [Facebook] <https://www.facebook.com/marin.wageningen>
MARIN news: MARIN at WindDays 2018, June 13 & 14, Rotterdam<http://www.marin.nl/web/News/News-items/MARIN-at-WindDays-2018-June-13-14-Rotterdam.htm>
Sent: Wednesday, January 18, 2017 4:13 PM
To: Klaij, Christiaan
Cc: Lawrence Mitchell; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] monitoring the convergence of fieldsplit 0 and 1
On Wed, Jan 18, 2017 at 4:42 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Thanks Lawrence, that nicely explains the unexpected behaviour!
I guess in general there ought to be getters for the four
ksp(A00)'s that occur in the full factorization.
Yes, we will fix it. I think that the default retrieval should get the 00 block, not the inner as well.
Matt
Chris
dr. ir. Christiaan Klaij | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44<tel:%2B31%20317%2049%2033%2044> | mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/Verification-and-validation-exercises-for-flow-around-KVLCC2-tanker.htm
From: Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk<mailto:lawrence.mitchell at imperial.ac.uk>>
Sent: Wednesday, January 18, 2017 10:59 AM
To: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Cc: bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>; Klaij, Christiaan
On 18/01/17 08:40, Klaij, Christiaan wrote:
> Barry,
> I've managed to replicate the problem with 3.7.4
> snes/examples/tutorials/ex70.c. Basically I've added
> KSPGetTotalIterations to main (file is attached):
PCFieldSplitGetSubKSP returns, in the Schur case:
MatSchurComplementGet(pc->schur, &ksp);
in subksp[0]
and
pc->schur in subksp[1]
In your case, subksp[0] is the (preonly) approximation to A^{-1} *inside*
S = D - C A_inner^{-1} B
And subksp[1] is the approximation to S^{-1}.
Since each application of S to a vector (required in S^{-1}) requires
one application of A^{-1}, because you use 225 iterations in total to
invert S, you also use 225 applications of the KSP on A_inner.
There doesn't appear to be a way to get the KSP used for A^{-1} if
you've asked for different approximations to A^{-1} in the 0,0 block
and inside S.
Cheers,
Lawrence
> $ diff -u ex70.c.bak ex70.c
> --- ex70.c.bak2017-01-18 09:25:46.286174830 +0100
> +++ ex70.c2017-01-18 09:03:40.904483434 +0100
> @@ -669,6 +669,10 @@
> KSP ksp;
> PetscErrorCode ierr;
> + KSP *subksp;
> + PC pc;
> + PetscInt numsplit = 1, nusediter_vv, nusediter_pp;
> ierr = PetscInitialize(&argc, &argv, NULL, help);CHKERRQ(ierr);
> s.nx = 4;
> s.ny = 6;
> @@ -690,6 +694,13 @@
> ierr = StokesSetupPC(&s, ksp);CHKERRQ(ierr);
> ierr = KSPSolve(ksp, s.b, s.x);CHKERRQ(ierr);
> + ierr = KSPGetPC(ksp, &pc);CHKERRQ(ierr);
> + ierr = PCFieldSplitGetSubKSP(pc,&numsplit,&subksp); CHKERRQ(ierr);
> + ierr = KSPGetTotalIterations(subksp[0],&nusediter_vv); CHKERRQ(ierr);
> + ierr = KSPGetTotalIterations(subksp[1],&nusediter_pp); CHKERRQ(ierr);
> + ierr = PetscPrintf(PETSC_COMM_WORLD," total u solves = %i\n", nusediter_vv); CHKERRQ(ierr);
> + ierr = PetscPrintf(PETSC_COMM_WORLD," total p solves = %i\n", nusediter_pp); CHKERRQ(ierr);
> /* don't trust, verify! */
> ierr = StokesCalcResidual(&s);CHKERRQ(ierr);
> ierr = StokesCalcError(&s);CHKERRQ(ierr);
> Now run as follows:
> $ mpirun -n 2 ./ex70 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi -fieldsplit_1_pc_type jacobi -fieldsplit_1_inner_ksp_type preonly -fieldsplit_1_inner_pc_type jacobi -fieldsplit_1_upper_ksp_type preonly -fieldsplit_1_upper_pc_type jacobi -fieldsplit_0_ksp_converged_reason -fieldsplit_1_ksp_converged_reason
> Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 5
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 14
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 16
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 17
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 18
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 20
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 21
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 23
> Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
> total u solves = 225
> total p solves = 225
> residual u = 9.67257e-06
> residual p = 5.42082e-07
> residual [u,p] = 9.68775e-06
> discretization error u = 0.0106464
> discretization error p = 1.85907
> discretization error [u,p] = 1.8591
> So here again the total of 225 is correct for p, but for u it
> should be 60. Hope this helps you find the problem.
> Chris
> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl> | http://www.marin.nl
> MARIN news: http://www.marin.nl/web/News/News-items/Few-places-left-for-Offshore-and-Ship-hydrodynamics-courses.htm
> From: Klaij, Christiaan
> Sent: Tuesday, January 17, 2017 8:45 AM
> To: Barry Smith
> Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> Well, that's it, all the rest was hard coded. Here's the relevant part of the code:
> CALL PCSetType(pc_system,PCFIELDSPLIT,ierr); CHKERRQ(ierr)
> CALL PCFieldSplitSetType(pc_system,PC_COMPOSITE_SCHUR,ierr); CHKERRQ(ierr)
> CALL PCFieldSplitSetIS(pc_system,"0",isgs(1),ierr); CHKERRQ(ierr)
> CALL PCFieldSplitSetIS(pc_system,"1",isgs(2),ierr); CHKERRQ(ierr)
> CALL PCFieldSplitSetSchurFactType(pc_system,PC_FIELDSPLIT_SCHUR_FACT_FULL,ierr);CHKERRQ(ierr)
> CALL PCFieldSplitSetSchurPre(pc_system,PC_FIELDSPLIT_SCHUR_PRE_SELFP,PETSC_NULL_OBJECT,ierr);CHKERRQ(ierr)
> CALL KSPSetTolerances(ksp_system,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_REAL,maxiter,ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_0_ksp_rtol","0.01",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_ksp_rtol","0.01",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_0_ksp_pc_side","right",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_ksp_pc_side","right",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_0_ksp_type","gmres",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_upper_ksp_type","preonly",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_upper_pc_type","jacobi",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_inner_ksp_type","preonly",ierr); CHKERRQ(ierr)
> CALL PetscOptionsSetValue(PETSC_NULL_OBJECT,"-sys_fieldsplit_1_inner_pc_type","jacobi",ierr); CHKERRQ(ierr)
> From: Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>>
> Sent: Monday, January 16, 2017 9:28 PM
> Please send all the command line options you use.
>> On Jan 16, 2017, at 1:47 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
>> Barry,
>> Sure, here's the output with:
>> -sys_ksp_view -sys_ksp_converged_reason -sys_fieldsplit_0_ksp_converged_reason -sys_fieldsplit_1_ksp_converged_reason
>> (In my previous email, I rearranged 0 & 1 for easy summing.)
>> Chris
>> Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 1
>> Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
>> Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 2
>> Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 6
>> Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 7
>> Linear sys_fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 3
>> Linear sys_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 8
>> Linear sys_ solve converged due to CONVERGED_RTOL iterations 6
>> KSP Object:(sys_) 1 MPI processes
>> type: fgmres
>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>> GMRES: happy breakdown tolerance 1e-30
>> maximum iterations=300, initial guess is zero
>> tolerances: relative=0.01, absolute=1e-50, divergence=10000.
>> right preconditioning
>> using UNPRECONDITIONED norm type for convergence test
>> PC Object:(sys_) 1 MPI processes
>> type: fieldsplit
>> FieldSplit with Schur preconditioner, factorization FULL
>> Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
>> Split info:
>> Split number 0 Defined by IS
>> Split number 1 Defined by IS
>> KSP solver for A00 block
>> KSP Object: (sys_fieldsplit_0_) 1 MPI processes
>> type: gmres
>> maximum iterations=10000, initial guess is zero
>> PC Object: (sys_fieldsplit_0_) 1 MPI processes
>> type: ilu
>> ILU: out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: natural
>> factor fill ratio given 1., needed 1.
>> Factored matrix follows:
>> Mat Object: 1 MPI processes
>> type: seqaij
>> rows=9600, cols=9600
>> package used to perform factorization: petsc
>> total: nonzeros=47280, allocated nonzeros=47280
>> total number of mallocs used during MatSetValues calls =0
>> not using I-node routines
>> linear system matrix = precond matrix:
>> Mat Object: (sys_fieldsplit_0_) 1 MPI processes
>> type: seqaij
>> KSP solver for upper A00 in upper triangular factor
>> KSP Object: (sys_fieldsplit_1_upper_) 1 MPI processes
>> type: preonly
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using NONE norm type for convergence test
>> PC Object: (sys_fieldsplit_1_upper_) 1 MPI processes
>> type: jacobi
>> type: seqaij
>> KSP solver for S = A11 - A10 inv(A00) A01
>> KSP Object: (sys_fieldsplit_1_) 1 MPI processes
>> type: gmres
>> PC Object: (sys_fieldsplit_1_) 1 MPI processes
>> type: ilu
>> 0 levels of fill
>> type: seqaij
>> rows=3200, cols=3200
>> total: nonzeros=40404, allocated nonzeros=40404
>> linear system matrix followed by preconditioner matrix:
>> Mat Object: (sys_fieldsplit_1_) 1 MPI processes
>> type: schurcomplement
>> Schur complement A11 - A10 inv(A00) A01
>> A11
>> type: seqaij
>> A10
>> type: seqaij
>> rows=3200, cols=9600
>> KSP of A00
>> KSP Object: (sys_fieldsplit_1_inner_) 1 MPI processes
>> type: preonly
>> PC Object: (sys_fieldsplit_1_inner_) 1 MPI processes
>> type: jacobi
>> type: seqaij
>> A01
>> type: seqaij
>> rows=9600, cols=3200
>> type: seqaij
>> type: nest
>> rows=12800, cols=12800
>> Matrix object:
>> type=nest, rows=2, cols=2
>> MatNest structure:
>> (0,0) : prefix="mom_", type=seqaij, rows=9600, cols=9600
>> (0,1) : prefix="grad_", type=seqaij, rows=9600, cols=3200
>> (1,0) : prefix="div_", type=seqaij, rows=3200, cols=9600
>> (1,1) : prefix="stab_", type=seqaij, rows=3200, cols=3200
>> type: nest
>> Matrix object:
>> MatNest structure:
>> (0,0) : prefix="sys_fieldsplit_0_", type=seqaij, rows=9600, cols=9600
>> (0,1) : type=seqaij, rows=9600, cols=3200
>> (1,0) : type=seqaij, rows=3200, cols=9600
>> (1,1) : prefix="sys_fieldsplit_1_", type=seqaij, rows=3200, cols=3200
>> nusediter_vv 37
>> nusediter_pp 37
>> MARIN news: http://www.marin.nl/web/News/News-items/The-Ocean-Cleanup-testing-continues.htm
>> Sent: Friday, January 13, 2017 7:51 PM
>> Yes, I would have expected this to work. Could you send the output from -ksp_view in this case?
>>> On Jan 13, 2017, at 3:46 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
>>> Barry,
>>> It's been a while but I'm finally using this function in
>>> 3.7.4. Is it supposed to work with fieldsplit? Here's why.
>>> I'm solving a Navier-Stokes system with fieldsplit (pc has one
>>> velocity solve and one pressure solve) and trying to retrieve the
>>> totals like this:
>>> CALL KSPSolve(ksp_system,rr_system,xx_system,ierr); CHKERRQ(ierr)
>>> CALL PCFieldSplitGetSubKSP(pc_system,numsplit,subksp,ierr); CHKERRQ(ierr)
>>> CALL KSPGetTotalIterations(subksp(1),nusediter_vv,ierr); CHKERRQ(ierr)
>>> CALL KSPGetTotalIterations(subksp(2),nusediter_pp,ierr); CHKERRQ(ierr)
>>> print *, 'nusediter_vv', nusediter_vv
>>> print *, 'nusediter_pp', nusediter_pp
>>> Running the code shows this surprise:
>>> nusediter_vv 37
>>> nusediter_pp 37
>>> So the value of nusediter_pp is indeed 37, but for nusediter_vv
>>> it should be 66. Any idea what went wrong?
>>> Chris
>>> MARIN news: http://www.marin.nl/web/News/News-items/MARIN-wishes-you-a-challenging-inspiring-2017.htm
>>> Sent: Saturday, April 11, 2015 12:27 AM
>>> Chris,
>>> I have added KSPGetTotalIterations() to the branch barry/add-ksp-total-iterations/master and next. After tests it will go into master
>>> Barry
>>>> On Apr 10, 2015, at 8:07 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
>>>> Barry,
>>>> Sure, I can call PCFieldSplitGetSubKSP() to get the fieldsplit_0
>>>> ksp and then KSPGetIterationNumber, but what does this number
>>>> mean?
>>>> It appears to be the number of iterations of the last time that
>>>> the subsystem was solved, right? If so, this corresponds to the
>>>> last iteration of the coupled system, how about all the previous
>>>> iterations?
>>>> Chris
>>>> Sent: Friday, April 10, 2015 2:48 PM
>>>> Chris,
>>>> It appears you should call PCFieldSplitGetSubKSP() and then get the information you want out of the individual KSPs. If this doesn't work please let us know.
>>>> Barry
>>>>> On Apr 10, 2015, at 6:48 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
>>>>> A question when using PCFieldSplit: for each linear iteration of
>>>>> the system, how many iterations for fielsplit 0 and 1?
>>>>> One way to find out is to run with -ksp_monitor,
>>>>> -fieldsplit_0_ksp_monitor and -fieldsplit_0_ksp_monitor. This
>>>>> gives the complete convergence history.
>>>>> Another way, suggested by Matt, is to use -ksp_monitor,
>>>>> -fieldsplit_0_ksp_converged_reason and
>>>>> -fieldsplit_1_ksp_converged_reason. This gives only the totals
>>>>> for fieldsplit 0 and 1 (but without saying for which one).
>>>>> Both ways require to somehow process the output, which is a bit
>>>>> inconvenient. Could KSPGetResidualHistory perhaps return (some)
>>>>> information on the subsystems' convergence for processing inside
>>>>> the code?
>>>>> Chris
>>>>> CFD Researcher
>>>>> E mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>
>>>>> MARIN
>>>>> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
>>>>> T +31 317 49 39 11<tel:%2B31%20317%2049%2039%2011>, F +31 317 49 32 45<tel:%2B31%20317%2049%2032%2045>, I www.marin.nl<http://www.marin.nl>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180515/a5cdaad6/attachment-0001.html>
Type: image/png
Desc: imagec0b128.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180515/a5cdaad6/attachment-0004.png>
Type: image/png
Desc: imageb21668.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180515/a5cdaad6/attachment-0005.png>
Type: image/png
Desc: imagec00de8.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180515/a5cdaad6/attachment-0006.png>
Type: image/png
Desc: imagea2abab.PNG
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180515/a5cdaad6/attachment-0007.png>
