[petsc-users] Preconditioner for a elasticity problem with Robin boundary conditions
    Matthew Knepley
    knepley at gmail.com
    Mon May 14 16:59:32 CDT 2018
On Mon, May 14, 2018 at 5:45 PM, Salazar De Troya, Miguel <
salazardetro1 at llnl.gov> wrote:
> Hello,
> Up until now, I have been solving my elasticity problem using the gamg
> preconditioner with the following options:
> -ksp_monitor_true_residual
> -ksp_converged_reason
> -ksp_type cg
> -log_view
> -mg_levels_esteig_ksp_type cg
> -mg_levels_ksp_chebyshev_esteig_steps 10
> -mg_levels_ksp_type chebyshev
> -mg_levels_pc_type sor
> -pc_type gamg
> -pc_gamg_verbose 7
> -pc_gamg_type agg
> -pc_gamg_agg_nsmooths 1
> -pc_gamg_threshold 0.001
> -snes_linesearch_type basic
> -snes_atol 1e-6
> -ksp_atol 1e-7
> -ksp_rtol 1e-9
> -ksp_norm_type unpreconditioned
> It has worked great so far, even for my problem where I have two materials
> with more than 1e3 ratio.
> Now, when I add robin boundary conditions, the solver fails with
> DIVERGED_INDEFINITE_PC. Using -ksp_type bcgs makes the solver converge. I
> imagine it is because it can handle the indefinite PC. Why is the PC
> indefinite for the Robin problem?
It matters how you are enforcing the conditions. Just write out the problem
completely for 1 vertex constrained. It should be clear whether its
symmetric or not.
> Is there any way to make it positive definite?
It should be possible if the BC are imposed in the right way.
> I am also passing the rigid body modes of my mesh to the solver. I am not
> sure if these modes change with the Robin boundary conditions, they should
> not, should they?
No, these are precisely the null modes of the symbol, and not affected by
BC.
    Matt
> Thanks
> Miguel
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180514/87aa11e8/attachment-0001.html>
