[petsc-users] using PETSC_NULL_INTEGER in preallocation routines
Sanjay Govindjee
s_g at berkeley.edu
Mon May 14 12:04:36 CDT 2018
Yes the error is shape mis-match since PETSC_NULL_INTEGER has been
changed to be an array (whereas it used to just be an integer), and the
subroutine is expecting an integer not an array.
If 0 is what will always be expected, then I agree, just pass 0. But if
there is a potential for this to change
in the future, then it seems better to hide this under a named entity.
-sanjay
On 5/14/18 5:52 PM, Smith, Barry F. wrote:
>> On May 14, 2018, at 10:45 AM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
>> Barry,
>> Is it then incorrect (and potentially dangerous) to use PETSC_NULL_INTEGER(1) for these arguments, even if that
>> currently works?
> I thought you got warnings or errors because you are passing an array instead of a value?
> Anyways since Fortran is pass by reference passing either a PetscInt II or PetscInt II(1) does the same things but modern Fortran compilers require you to pass a scalar when expected (II) and an array when expected (II(1)) otherwise the compiler warns or errors. Better to pass what is expected, in this case a 0.
> Barry
>> -sanjay
>> On 5/14/18 5:40 PM, Smith, Barry F. wrote:
>>> Chris,
>>> These arguments should never have been PETSC_NULL_INTEGER since they are integers (and not pointers or arrays), you should pass 0 for them.
>>> Barry
>>>> On May 14, 2018, at 4:45 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>>>> With petsc-3.7.5, I had F90 code like this:
>>>> CALL MatSeqAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,ierr); CHKERRQ(ierr)
>>>> CALL MatMPIAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr); CHKERRQ(ierr)
>>>> which worked fine. Now, with petsc-3.8.4, the same code gives this compilation error:
>>>> error #6634: The shape matching rules of actual arguments and dummy arguments have been violated. [PETSC_NULL_INTEGER]
>>>> CALL MatSeqAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
>>>> CALL MatMPIAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
>>>> What's the intended usage now, simply 0 instead of PETSC_NULL_INTEGER?
>>>> Chris
>>>> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
>>>> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
>>>> MARIN news: http://www.marin.nl/web/News/News-items/120-papers-presented-at-NAV2018.htm
