[petsc-users] using PETSC_NULL_INTEGER in preallocation routines
Sanjay Govindjee
s_g at berkeley.edu
Mon May 14 10:45:42 CDT 2018
Barry,
Is it then incorrect (and potentially dangerous) to use
PETSC_NULL_INTEGER(1) for these arguments, even if that
currently works?
-sanjay
On 5/14/18 5:40 PM, Smith, Barry F. wrote:
> Chris,
> These arguments should never have been PETSC_NULL_INTEGER since they are integers (and not pointers or arrays), you should pass 0 for them.
> Barry
>> On May 14, 2018, at 4:45 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
>> With petsc-3.7.5, I had F90 code like this:
>> CALL MatSeqAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,ierr); CHKERRQ(ierr)
>> CALL MatMPIAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr); CHKERRQ(ierr)
>> which worked fine. Now, with petsc-3.8.4, the same code gives this compilation error:
>> error #6634: The shape matching rules of actual arguments and dummy arguments have been violated. [PETSC_NULL_INTEGER]
>> CALL MatSeqAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
>> CALL MatMPIAIJSetPreallocation(aa_symmetric,PETSC_NULL_INTEGER,d_nnz,PETSC_NULL_INTEGER,o_nnz,ierr); if (ierr .ne. 0) then ; call PetscErrorF(ierr); return; endif
>> What's the intended usage now, simply 0 instead of PETSC_NULL_INTEGER?
>> Chris
>> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development
>> MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
>> MARIN news: http://www.marin.nl/web/News/News-items/120-papers-presented-at-NAV2018.htm
