[petsc-users] PETSc-MUMPS interface, numeric and symbolic factorisation
    Y. Shidi
    ys453 at cam.ac.uk
    Fri May 11 12:02:16 CDT 2018
Thank you very much for your reply, Barry.
>    This is a bug in PETSc. Since you are providing a new matrix with
> the same "state" value as the previous matrix the PC code the
> following code
So what you mean is that every time I change the value in the matrix,
the PETSc only determines if the nonzero pattern change but not the
values, and if it is unchanged neither of symbolic and numeric
happens.
I found the following code:
   if (!pc->setupcalled) {
     ierr            = PetscInfo(pc,"Setting up PC for first
time\n");CHKERRQ(ierr);
     pc->flag        = DIFFERENT_NONZERO_PATTERN;
   } else if (matstate == pc->matstate) {
     ierr = PetscInfo(pc,"Leaving PC with identical preconditioner since
operator is unchanged\n");CHKERRQ(ierr);
     PetscFunctionReturn(0);
   } else {
     if (matnonzerostate > pc->matnonzerostate) {
        ierr = PetscInfo(pc,"Setting up PC with different nonzero
pattern\n");CHKERRQ(ierr);
     } else {
       ierr = PetscInfo(pc,"Setting up PC with same nonzero
       pc->flag            = SAME_NONZERO_PATTERN;
and I commend out "else if (matstate == pc->matstate){}", so it
will do "Setting up PC with same nonzero pattern\n"; and it seems
work in my case, only "MatFactorNumeric_MUMPS()" is calling in the
subsequent iterations. But I am not quite sure, need some more tests.
Thank you very much for your help indeed.
Kind Regards,
Shidi
On 2018-05-11 16:13, Smith, Barry F. wrote:
>> On May 11, 2018, at 8:14 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>> Thank you for your reply.
>>> How are you changing the matrix? Do you remember to assemble?
>> I use MatCreateMPIAIJWithArrays() to create the matrix,
>> and after that I call MatAssemblyBegin() and MatAssemblyEnd().
>   If you use MatCreateMPIAIJWithArrays() you don't need to call
>> But I actually destroy the matrix at the end of each iteration
>> and create the matrix at the beginning of each iteration.
> following code
> kicks in:
>   ierr =
> PetscObjectStateGet((PetscObject)pc->pmat,&matstate);CHKERRQ(ierr);
>   ierr = MatGetNonzeroState(pc->pmat,&matnonzerostate);CHKERRQ(ierr);
> since operator is unchanged\n");CHKERRQ(ierr);
> and it returns without refactoring.
>    We need an additional check that the matrix also remains the same.
>     We will also need a test example that reproduces the problem to
> confirm that we have fixed it.
>   Barry
>> Cheers,
>> Shidi
>> On 2018-05-11 12:59, Matthew Knepley wrote:
>>> On Fri, May 11, 2018 at 7:14 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>> Dear Matt,
>>>> Thank you for your help last time.
>>>> I want to get more detail about the Petsc-MUMPS factorisation;
>>>> so I go to look the code "/src/mat/impls/aij/mpi/mumps/mumps.c".
>>>> And I found the following functions are quite important to
>>>> the question:
>>>> PetscErrorCode MatCholeskyFactorSymbolic_MUMPS(Mat F,Mat A,IS
>>>> r,const MatFactorInfo *info);
>>>> PetscErrorCode MatFactorNumeric_MUMPS(Mat F,Mat A,const
>>>> PetscErrorCode MatSolve_MUMPS(Mat A,Vec b,Vec x);
>>>> I print some sentence to trace when these functions are called.
>>>> Then I test my code; the values in the matrix is changing but the
>>>> structure stays the same. Below is the output.
>>>> We can see that at 0th step, all the symbolic, numeric and solve
>>>> are called; in the subsequent steps only the solve stage is called,
>>>> the numeric step is not called.
>>>  Matt
>>>> Iteration 0 Step 0.0005 Time 0.0005
>>>> [INFO]: Direct Solver setup
>>>> finish MatCholeskyFactorSymbolic_MUMPS
>>>> finish MatFactorNumeric_MUMPS
>>>> MatSolve_MUMPS
>>>> Iteration 1 Step 0.0005 Time 0.0005
>>>> MatSolve_MUMPS
>>>> Iteration 2 Step 0.0005 Time 0.001
>>>> MatSolve_MUMPS
>>>> [INFO]: End of program!!!
>>>> I am wondering if there is any possibility to split the numeric
>>>> and solve stage (as you mentioned using KSPSolve).
>>>> Thank you very much indeed.
>>>> Kind Regards,
>>>> Shidi
>>>> On 2018-05-04 21:10, Y. Shidi wrote:
>>>> Thank you very much for your reply.
>>>> That is really clear.
>>>> Kind Regards,
>>>> Shidi
>>>> On 2018-05-04 21:05, Matthew Knepley wrote:
>>>> On Fri, May 4, 2018 at 3:54 PM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>> Dear Matt,
>>>> Thank you very much for your reply!
>>>> So what you mean is that I can just do the KSPSolve() every
>>>> iteration
>>>> once the MUMPS is set?
>>>> Yes.
>>>> That means inside the KSPSolve() the numerical factorization is
>>>> performed. If that is the case, it seems that the ksp object is
>>>> not changed when the values in the matrix are changed.
>>>> Yes.
>>>> Or do I need to call both KSPSetOperators() and KSPSolve()?
>>>> If you do SetOperators, it will redo the factorization. If you do
>>>> not,
>>>> it will look
>>>> at the Mat object, determine that the structure has not changed,
>>>> and
>>>> just redo
>>>> the numerical factorization.
>>>> Thanks,
>>>> Matt
>>>> On 2018-05-04 14:44, Matthew Knepley wrote:
>>>> On Fri, May 4, 2018 at 9:40 AM, Y. Shidi <ys453 at cam.ac.uk> wrote:
>>>> Dear PETSc users,
>>>> I am currently using MUMPS to solve linear systems directly.
>>>> Generally, we use ICNTL(7) or ICNTL(29) to do the preprocessing
>>>> step and then solve the system.
>>>> In my code, the values in the matrix is changed in each iteration,
>>>> but the structure of the matrix stays the same, which means the
>>>> performance can be improved if symbolic factorisation is only
>>>> performed once. Hence, it is necessary to split the symbolic
>>>> and numeric factorisation. However, I cannot find a specific step
>>>> (control parameter) to perform the numeric factorisation.
>>>> I have used ICNTL(3) and ICNTL(4) to print the MUMPS information,
>>>> it seems that the symbolic and numeric factorisation always perform
>>>> together.
>>>> If you use KSPSolve instead, it will automatically preserve the
>>>> symbolic
>>>> factorization.
>>>> Thanks,
>>>> Matt
>>>> So I am wondering if anyone has an idea about it.
>>>> Below is how I set up MUMPS solver:
>>>> PC pc;
>>>> PetscBool flg_mumps, flg_mumps_ch;
>>>> flg_mumps = PETSC_FALSE;
>>>> flg_mumps_ch = PETSC_FALSE;
>>>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_lu", &flg_mumps,
>>>> NULL);
>>>> PetscOptionsGetBool(NULL, NULL, "-use_mumps_ch", &flg_mumps_ch,
>>>> NULL);
>>>> if(flg_mumps ||flg_mumps_ch)
>>>> KSPSetType(_ksp, KSPPREONLY);
>>>> PetscInt ival,icntl;
>>>> PetscReal val;
>>>> KSPGetPC(_ksp, &pc);
>>>> /// Set preconditioner type
>>>> if(flg_mumps)
>>>> PCSetType(pc, PCLU);
>>>> else if(flg_mumps_ch)
>>>> MatSetOption(A, MAT_SPD, PETSC_TRUE);
>>>> PCSetType(pc, PCCHOLESKY);
>>>> PCFactorSetMatSolverPackage(pc, MATSOLVERMUMPS);
>>>> PCFactorSetUpMatSolverPackage(pc);
>>>> PCFactorGetMatrix(pc, &_F);
>>>> icntl = 7; ival = 0;
>>>> MatMumpsSetIcntl( _F, icntl, ival );
>>>> MatMumpsSetIcntl(_F, 3, 6);
>>>> MatMumpsSetIcntl(_F, 4, 2);
>>>> KSPSetUp(_ksp);
>>>> Kind Regards,
>>>> Shidi
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to
>>>> which
>>>> their experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ [1] [1] [1]
>>>> Links:
>>>> [1] http://www.caam.rice.edu/~mk51/ [2] [2]
>>>> which
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ [1] [2]
>>>> Links:
>>>> [1] https://www.cse.buffalo.edu/~knepley/ [1]
>>>> [2] http://www.caam.rice.edu/~mk51/ [2]
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ [2]
>>> Links:
