[petsc-users] Performance of MatSetValues and display the converged tolerance archieved in KSPSolve
Smith, Barry F.
bsmith at mcs.anl.gov
Mon May 7 15:24:55 CDT 2018
> On May 7, 2018, at 10:34 AM, NAN ZHAO <zhaonanavril at gmail.com> wrote:
> Dear all,
> I am trying to integrated PETSC in a legacy FEM code, but I had a few troubles to get the performance of MatSetValues to match the old subroutines in the sequtial implementation :
> 1. I use MatSetVaules per element, to add the matrix value to each row and col this element had, and find it really slow compared with my old subroutine which directly add the value to a 1-d array to store the value in CRS format. For a case with 12K unknown, my old subroutines takes several seconds, but MatSetValues takes around 50 seconds to finish the matrix calculation part.... Did I do something wrong, I do have preallocation giving non-zeros for each row in this MATSEQ matrix...
50 seconds means something is incorrect with the preallocation: http://www.mcs.anl.gov/petsc/documentation/faq.html#efficient-assembly
> 2. I switched to MatCreateSeqAIJWithArrays, and the performance seems to be OK. I do not understand the difference, does MatCreateSeqAIJWithArrays call MatSetValues internally?
The i, j, and a arrays are not copied by this routine, PETSc uses exactly what you provided without copying hence it is fast.
> or it is just the difference with INSERT_VALUES vs ADD_VALUES?
Insert vs add shouldn't make a performance difference.
> 3, I want to know the converged rtol,atol of a KSPSolve, how to I do it?
If you want to know the convergence criteria used by the test you can call KSPGetTolerances()
You can run with -ksp_monitor to see the norm of the (preconditioned) residual at each iteration or -ksp_monitor_true_residual to see the norm of the non-preconditioned residual.
You can use KSPSetResidualHistory() to have the residual norm saved at each iteration then after KSPSolve() you can access the array to see the final residual norm.
> 4. I want to do a parallel implement of this too, but worried about the performance of MatSetValues, should I use MatCreateMPIAIJWithArrays?
First you need to get the preallocation working for sequential than change to parallel.
> Thanks,
> Nan
