[petsc-users] petsc4py: parallel matrix-vector multiplication
Jed Brown
jed at jedbrown.org
Sun May 6 09:52:58 CDT 2018
Robert Speck <r.speck at fz-juelich.de> writes:
> Thanks for your reply and help. Yes, this is going to be a PDE solver
> for structured grids. The first goal would be IDC (or Crank-Nicholson)
> for the heat equation, which would require both solving a linear system
> and application of the matrix.
> The code I wrote for testing parallel matrix-vector multiplication can
> be found here:
> https://github.com/Parallel-in-Time/pySDC/blob/petsc/pySDC/playgrounds/PETSc/playground_matmult.py
> Both vectors and matrix come from the DMDA, but I guess filling them is
> done in a wrong way? Or do I need to convert global/natural vectors to
> local ones somewhere?
Global and Natural are not the same (see user's manual for details).
The matrix acts on a Global vector. See
petsc4py/demo/bratu3d/bratu3d.py for examples of efficiently setting
values (and computing residuals) using Global vectors. It should be
simpler/cleaner code than you currently have.
> Best
> -Robert-
> On 06.05.18 14:44, Dave May wrote:
>> On Sun, 6 May 2018 at 10:40, Robert Speck <r.speck at fz-juelich.de
>> <mailto:r.speck at fz-juelich.de>> wrote:
>> Hi!
>> I would like to do a matrix-vector multiplication (besides using linear
>> solvers and so on) with petsc4py. I took the matrix from this example
>> (https://bitbucket.org/petsc/petsc4py/src/master/demo/kspsolve/petsc-mat.py)
>> This example only produces a matrix. And from the code the matrix
>> produced is identical in serial or parallel.
>> and applied it to a PETSc Vector. All works well in serial, but in
>> parallel (in particular if ordering becomes relevant) the resulting
>> vector looks very different.
>> Given this, the way you defined the x vector in y = A x must be
>> different when run on 1 versus N mpi ranks.
>> Using the shell matrix of this example
>> (https://bitbucket.org/petsc/petsc4py/src/master/demo/poisson2d/poisson2d.py)
>> helps, but then I cannot use matrix-based preconditioners for KSP
>> directly (right?). I also tried using DMDA for creating vectors and
>> matrix and for taking care of their ordering (which seems to be my
>> problem here), but that did not help either.
>> So, my question is this: How do I do easy parallel matrix-vector
>> multiplication with petsc4py in a way that allows me to use parallel
>> linear solvers etc. later on? I want to deal with spatial decomposition
>> as little as possible.
>> What's the context - are you solving a PDE?
>> Assuming you are using your own grid object (e.g. as you might have if
>> solving a PDE), and assuming you are not solving a 1D problem, you
>> actually have to "deal" with the spatial decomposition otherwise
>> performance could be quite terrible - even for something simple like a 5
>> point Laplacian on a structured grid in 2D
>> What data structures should I use? DMDA or
>> PETSc.Vec() and PETSc.Mat() or something else?
>> The mat vec product is not causing you a problem. Your issue appears to
>> be that you do not have a way to label entries in a vector in a
>> consistent manner.
>> What's the objective? Are you solving a PDE? If yes, structured grid? If
>> yes again, use the DMDA. It takes care of all the local-to-global and
>> global-to-local mapping you need.
>> Thanks,
>> Dave
>> Thanks!
>> -Robert-
>> Dr. Robert Speck
>> Juelich Supercomputing Centre
>> Institute for Advanced Simulation
>> Forschungszentrum Juelich GmbH
>> 52425 Juelich, Germany
>> Tel: +49 2461 61 1644
>> Fax: +49 2461 61 6656
>> Email: r.speck at fz-juelich.de <mailto:r.speck at fz-juelich.de>
>> Website: http://www.fz-juelich.de/ias/jsc/speck_r
>> PinT: http://www.fz-juelich.de/ias/jsc/pint
>> 52425 Juelich
>> Sitz der Gesellschaft: Juelich
>> Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
>> Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
>> Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
>> Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
>> Prof. Dr. Sebastian M. Schmidt
> Dr. Robert Speck
