[petsc-users] petsc4py: parallel matrix-vector multiplication
Robert Speck r.speck at fz-juelich.de
Sun May 6 09:34:04 CDT 2018
Thanks for your reply and help. Yes, this is going to be a PDE solver
for structured grids. The first goal would be IDC (or Crank-Nicholson)
for the heat equation, which would require both solving a linear system
and application of the matrix.
The code I wrote for testing parallel matrix-vector multiplication can
be found here:
https://github.com/Parallel-in-Time/pySDC/blob/petsc/pySDC/playgrounds/PETSc/playground_matmult.py
Both vectors and matrix come from the DMDA, but I guess filling them is
done in a wrong way? Or do I need to convert global/natural vectors to
local ones somewhere?
Best
-Robert-
On 06.05.18 14:44, Dave May wrote:
> On Sun, 6 May 2018 at 10:40, Robert Speck <r.speck at fz-juelich.de
> <mailto:r.speck at fz-juelich.de>> wrote:
>     Hi!
>     I would like to do a matrix-vector multiplication (besides using linear
>     solvers and so on) with petsc4py. I took the matrix from this example
>     (https://bitbucket.org/petsc/petsc4py/src/master/demo/kspsolve/petsc-mat.py)
> This example only produces a matrix. And from the code the matrix
> produced is identical in serial or parallel.
>     and applied it to a PETSc Vector. All works well in serial, but in
>     parallel (in particular if ordering becomes relevant) the resulting
>     vector looks very different.
> Given this, the way you defined the x vector in y = A x must be
> different when run on 1 versus N mpi ranks.
>     Using the shell matrix of this example
>     (https://bitbucket.org/petsc/petsc4py/src/master/demo/poisson2d/poisson2d.py)
>     helps, but then I cannot use matrix-based preconditioners for KSP
>     directly (right?). I also tried using DMDA for creating vectors and
>     matrix and for taking care of their ordering (which seems to be my
>     problem here), but that did not help either.
>     So, my question is this: How do I do easy parallel matrix-vector
>     multiplication with petsc4py in a way that allows me to use parallel
>     linear solvers etc. later on? I want to deal with spatial decomposition
>     as little as possible.
> What's the context - are you solving a PDE?
> Assuming you are using your own grid object (e.g. as you might have if
> solving a PDE), and assuming you are not solving a 1D problem, you
> actually have to "deal" with the spatial decomposition otherwise
> performance could be quite terrible - even for something simple like a 5
> point Laplacian on a structured grid in 2D
>     What data structures should I use? DMDA or
>     PETSc.Vec() and PETSc.Mat() or something else?
> The mat vec product is not causing you a problem. Your issue appears to
> be that you do not have a way to label entries in a vector in a
> consistent manner.
> What's the objective? Are you solving a PDE? If yes, structured grid? If
> yes again, use the DMDA. It takes care of all the local-to-global and
> global-to-local mapping you need.
> Thanks,
>   Dave
>     Thanks!
>     -Robert-
>     Dr. Robert Speck
>     Juelich Supercomputing Centre
>     Institute for Advanced Simulation
>     Forschungszentrum Juelich GmbH
>     52425 Juelich, Germany
>     Tel: +49 2461 61 1644
>     Fax: +49 2461 61 6656
>     Email:   r.speck at fz-juelich.de <mailto:r.speck at fz-juelich.de>
>     Website: http://www.fz-juelich.de/ias/jsc/speck_r
>     PinT:    http://www.fz-juelich.de/ias/jsc/pint
>     52425 Juelich
>     Sitz der Gesellschaft: Juelich
>     Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
>     Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
>     Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
>     Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
>     Prof. Dr. Sebastian M. Schmidt
Dr. Robert Speck
