[petsc-users] [SLEPc] SIGFPE Arithmetic exception in EPSGD
Harshad Sahasrabudhe
harshad.sahasrabudhe at gmail.com
Thu May 3 22:45:37 CDT 2018
> I think the residual of the first unconverged eigenvalue is set to INF on
> purpose and not calculated in the iteration when a converged eigenvalue is
> found. Dividing the INF residual is a mistake:
Found the line where d->nR[i] is set to infinity:
src/eps/impls/davidson/common/dvd_updatev.c
static PetscErrorCode dvd_updateV_start(dvdDashboard *d)
124 for (i=0;i<d->eps->ncv;i++) d->nR[i] = PETSC_MAX_REAL;
On Thu, May 3, 2018 at 11:39 PM, Harshad Sahasrabudhe <
harshad.sahasrabudhe at gmail.com> wrote:
> Jumps like this usually indicate something is going very poorly in the
>> algorithm. I hope the algorithmic experts have a chance to look at your
>> case.
> if (d->nR[i]/a < data->fix) {
> I think your suggestion will certainly fix this issue:
> if (d->nR[i] < a*data->fix) {
> Just my guess.
> On Thu, May 3, 2018 at 11:28 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> > On May 3, 2018, at 10:24 PM, Harshad Sahasrabudhe <
>> > Hi Barry,
>> > There's an overflow in the division:
>> > Program received signal SIGFPE, Arithmetic exception.
>> > 0x00002aaab377ea26 in dvd_improvex_jd_lit_const_0 (d=0x1d29078, i=0,
>> theta=0x1f396f8, thetai=0x1f39718, maxits=0x7fffffff816c,
>> tol=0x7fffffff8140)
>> > at /depot/ncn/apps/conte/conte-gcc-petsc35-dbg/libs/slepc/build
>> -real/src/eps/impls/davidson/common/dvd_improvex.c:1112
>> > 1112 if (d->nR[i]/a < data->fix) {
>> > (gdb) p d->nR[i]
>> > $7 = 1.7976931348623157e+308
>> > (gdb) p a
>> > $8 = 0.15744695659409991
>> > It looks like the residual is very high in the first GD iteration and
>> rapidly drops in the second iteration
>> > 240 EPS nconv=0 first unconverged value (error) 0.0999172
>> (1.11889357e-12)
>> > 241 EPS nconv=1 first unconverged value (error) 0.100311
>> (1.79769313e+308)
>> case.
>> Barry
>> > 242 EPS nconv=1 first unconverged value (error) 0.100311
>> (2.39980067e-04)
>> > Thanks,
>> > Harshad
>> > On Thu, May 3, 2018 at 11:11 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> > Likely the problem is due to the division by a when a is zero. Perhaps
>> the code needs above a check that a is not zero. Or rewrite the check as
>> > Barry
>> > > On May 3, 2018, at 7:58 PM, Harshad Sahasrabudhe <
>> > > Hello,
>> > > I am solving for the lowest eigenvalues and eigenvectors of symmetric
>> positive definite matrices in the generalized eigenvalue problem. I am
>> using the GD solver with the default settings of PCBJACOBI. When I run a
>> standalone executable on 16 processes which loads the matrices from a file
>> and solves the eigenproblem, I get converged results in ~600 iterations. I
>> am using PETSc/SLEPc 3.5.4.
>> > > However, when I use the same settings in my software, which uses
>> LibMesh (0.9.5) for FEM discretization, I get a SIGFPE. The backtrace is:
>> tol=0x7fffffff8140)
>> > > #0 0x00002aaab377ea26 in dvd_improvex_jd_lit_const_0 (d=0x1d29078,
>> i=0, theta=0x1f396f8, thetai=0x1f39718, maxits=0x7fffffff816c,
>> tol=0x7fffffff8140)
>> > > #1 0x00002aaab3774316 in dvd_improvex_jd_gen (d=0x1d29078, r_s=0,
>> r_e=1, size_D=0x7fffffff821c) at /depot/ncn/apps/conte/conte-gc
>> c-petsc35-dbg/libs/slepc/build-real/src/eps/impls/davidson/c
>> ommon/dvd_improvex.c:316
>> > > #2 0x00002aaab3731ec4 in dvd_updateV_update_gen (d=0x1d29078) at
>> -real/src/eps/impls/davidson/common/dvd_updatev.c:360
>> > > #3 0x00002aaab3730296 in dvd_updateV_extrapol (d=0x1d29078) at
>> -real/src/eps/impls/davidson/common/dvd_updatev.c:193
>> > > #4 0x00002aaab3727cbc in EPSSolve_XD (eps=0x1d0ee10) at
>> -real/src/eps/impls/davidson/common/davidson.c:299
>> > > #5 0x00002aaab35bafc8 in EPSSolve (eps=0x1d0ee10) at
>> -real/src/eps/interface/epssolve.c:99
>> > > #6 0x00002aaab30dbaf9 in libMesh::SlepcEigenSolver<double>::_solve_generalized_helper
>> (this=0x1b19880, mat_A=0x1c906d0, mat_B=0x1cb16b0, nev=5, ncv=20,
>> tol=9.9999999999999998e-13, m_its=3000) at src/solvers/slepc_eigen_solver
>> .C:519
>> > > #7 0x00002aaab30da56a in libMesh::SlepcEigenSolver<double>::solve_generalized
>> (this=0x1b19880, matrix_A_in=..., matrix_B_in=..., nev=5, ncv=20,
>> .C:316
>> > > #8 0x00002aaab30fb02e in libMesh::EigenSystem::solve
>> (this=0x1b19930) at src/systems/eigen_system.C:241
>> > > #9 0x00002aaab30e48a9 in libMesh::CondensedEigenSystem::solve
>> (this=0x1b19930) at src/systems/condensed_eigen_system.C:106
>> > > #10 0x00002aaaacce0e78 in EMSchrodingerFEM::do_solve (this=0x19d6a90)
>> at EMSchrodingerFEM.cpp:879
>> > > #11 0x00002aaaadaae3e5 in Simulation::solve (this=0x19d6a90) at
>> Simulation.cpp:789
>> > > #12 0x00002aaaad52458b in NonlinearPoissonFEM::do_my_assemble
>> (this=0x19da050, x=..., residual=0x7fffffff9eb0, jacobian=0x0) at
>> NonlinearPoissonFEM.cpp:179
>> > > #13 0x00002aaaad555eec in NonlinearPoisson::my_assemble_residual
>> (x=..., r=..., s=...) at NonlinearPoisson.cpp:1469
>> > > #14 0x00002aaab30c5dc3 in libMesh::__libmesh_petsc_snes_residual
>> (snes=0x1b9ed70, x=0x1a50330, r=0x1a47a50, ctx=0x19e5a60) at
>> src/solvers/petsc_nonlinear_solver.C:137
>> > > #15 0x00002aaab41048b9 in SNESComputeFunction (snes=0x1b9ed70,
>> x=0x1a50330, y=0x1a47a50) at /depot/ncn/apps/conte/conte-gc
>> c-petsc35-dbg/libs/petsc/build-real/src/snes/interface/snes.c:2033
>> > > #16 0x00002aaaad1c9ad8 in SNESShellSolve_PredictorCorrector
>> (snes=0x1b9ed70, vec_sol=0x1a2a5a0) at PredictorCorrectorModule.cpp:413
>> > > #17 0x00002aaab4653e3d in SNESSolve_Shell (snes=0x1b9ed70) at
>> /depot/ncn/apps/conte/conte-gcc-petsc35-dbg/libs/petsc/build
>> -real/src/snes/impls/shell/snesshell.c:167
>> > > #18 0x00002aaab4116fb7 in SNESSolve (snes=0x1b9ed70, b=0x0,
>> x=0x1a2a5a0) at /depot/ncn/apps/conte/conte-gc
>> c-petsc35-dbg/libs/petsc/build-real/src/snes/interface/snes.c:3743
>> > > #19 0x00002aaab30c7c3c in libMesh::PetscNonlinearSolver<double>::solve
>> (this=0x19e5a60, jac_in=..., x_in=..., r_in=...) at
>> src/solvers/petsc_nonlinear_solver.C:714
>> > > #20 0x00002aaab3136ad9 in libMesh::NonlinearImplicitSystem::solve
>> (this=0x19e4b80) at src/systems/nonlinear_implicit_system.C:183
>> > > #21 0x00002aaaad5791f3 in NonlinearPoisson::execute_solver
>> (this=0x19da050) at NonlinearPoisson.cpp:1218
>> > > #22 0x00002aaaad554a99 in NonlinearPoisson::do_solve (this=0x19da050)
>> at NonlinearPoisson.cpp:961
>> > > #23 0x00002aaaadaae3e5 in Simulation::solve (this=0x19da050) at
>> Simulation.cpp:789
>> > > #24 0x00002aaaad1c9657 in PredictorCorrectorModule::do_solve
>> (this=0x19c0210) at PredictorCorrectorModule.cpp:334
>> > > #25 0x00002aaaadaae3e5 in Simulation::solve (this=0x19c0210) at
>> Simulation.cpp:789
>> > > #26 0x00002aaaad9e8f4a in Nemo::run_simulations (this=0x63ba80
>> <Nemo::instance()::impl>) at Nemo.cpp:1367
>> > > #27 0x0000000000426f36 in main (argc=2, argv=0x7fffffffd0f8) at
>> main.cpp:452
>> > > Here is the log_view from the standalone executable:
>> > > *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript
>> -r -fCourier9' to print this document ***
>> > > ---------------------------------------------- PETSc Performance
>> Summary: ----------------------------------------------
>> > > ./libmesh_solve_eigenproblem on a linux named
>> conte-a373.rcac.purdue.edu with 16 processors, by hsahasra Thu May 3
>> 20:56:03 2018
>> > > Using Petsc Release Version 3.5.4, May, 23, 2015
>> > > Max Max/Min Avg Total
>> > > Time (sec): 2.628e+01 1.00158 2.625e+01
>> > > Objects: 6.400e+03 1.00000 6.400e+03
>> > > Flops: 3.576e+09 1.00908 3.564e+09 5.702e+10
>> > > Flops/sec: 1.363e+08 1.00907 1.358e+08 2.172e+09
>> > > MPI Messages: 1.808e+04 2.74920 1.192e+04 1.907e+05
>> > > MPI Message Lengths: 4.500e+07 1.61013 3.219e+03 6.139e+08
>> > > MPI Reductions: 8.522e+03 1.00000
>> > > Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>> > > e.g., VecAXPY() for real vectors of
>> length N --> 2N flops
>> > > and VecAXPY() for complex vectors of
>> length N --> 8N flops
>> > > Summary of Stages: ----- Time ------ ----- Flops ----- ---
>> Messages --- -- Message Lengths -- -- Reductions --
>> > > Avg %Total Avg %Total counts
>> %Total Avg %Total counts %Total
>> > > 0: Main Stage: 2.6254e+01 100.0% 5.7023e+10 100.0% 1.907e+05
>> 100.0% 3.219e+03 100.0% 8.521e+03 100.0%
>> > > See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> > > Phase summary info:
>> > > Count: number of times phase was executed
>> > > Time and Flops: Max - maximum over all processors
>> > > Ratio - ratio of maximum to minimum over all
>> processors
>> > > Mess: number of messages sent
>> > > Avg. len: average message length (bytes)
>> > > Reduct: number of global reductions
>> > > Global: entire computation
>> > > Stage: stages of a computation. Set stages with
>> PetscLogStagePush() and PetscLogStagePop().
>> > > %T - percent time in this phase %F - percent flops in
>> this phase
>> > > %M - percent messages in this phase %L - percent message
>> lengths in this phase
>> > > %R - percent reductions in this phase
>> > > Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max
>> time over all processors)
>> > > Event Count Time (sec) Flops
>> --- Global --- --- Stage --- Total
>> > > Max Ratio Max Ratio Max Ratio Mess Avg
>> len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>> > > --- Event Stage 0: Main Stage
>> > > MatMult 1639 1.0 4.7509e+00 1.7 3.64e+08 1.1 1.9e+05
>> 3.0e+03 0.0e+00 13 10100 93 0 13 10100 93 0 1209
>> > > MatSolve 1045 1.0 6.4188e-01 1.0 2.16e+08 1.1 0.0e+00
>> 0.0e+00 0.0e+00 2 6 0 0 0 2 6 0 0 0 5163
>> > > MatLUFactorNum 1 1.0 2.0798e-02 3.5 9.18e+05 1.1 0.0e+00
>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 664
>> > > MatILUFactorSym 1 1.0 1.1777e-02 5.9 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> > > MatAssemblyBegin 4 1.0 1.3677e-01 6.8 0.00e+00 0.0 0.0e+00
>> 0.0e+00 8.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> > > MatAssemblyEnd 4 1.0 3.7882e-02 1.3 0.00e+00 0.0 4.6e+02
>> 7.5e+02 1.6e+01 0 0 0 0 0 0 0 0 0 0 0
>> > > MatGetRowIJ 1 1.0 7.1526e-06 3.8 0.00e+00 0.0 0.0e+00
>> > > MatGetOrdering 1 1.0 2.3198e-04 1.4 0.00e+00 0.0 0.0e+00
>> > > MatZeroEntries 33 1.0 1.1992e-04 1.1 0.00e+00 0.0 0.0e+00
>> > > MatLoad 2 1.0 2.9271e-01 1.0 0.00e+00 0.0 5.5e+02
>> 7.6e+04 2.6e+01 1 0 0 7 0 1 0 0 7 0 0
>> > > VecCopy 2096 1.0 4.0181e-02 1.1 0.00e+00 0.0 0.0e+00
>> > > VecSet 1047 1.0 1.7598e-02 1.1 0.00e+00 0.0 0.0e+00
>> > > VecScatterBegin 1639 1.0 4.3395e-01 2.0 0.00e+00 0.0 1.9e+05
>> 3.0e+03 0.0e+00 1 0100 93 0 1 0100 93 0 0
>> > > VecScatterEnd 1639 1.0 3.2399e+00 2.3 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00 8 0 0 0 0 8 0 0 0 0 0
>> > > VecReduceArith 2096 1.0 5.6402e-02 1.1 3.27e+07 1.0 0.0e+00
>> 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 9287
>> > > VecReduceComm 1572 1.0 5.5213e+00 1.2 0.00e+00 0.0 0.0e+00
>> 0.0e+00 1.6e+03 20 0 0 0 18 20 0 0 0 18 0
>> > > EPSSetUp 1 1.0 9.0121e-02 1.3 0.00e+00 0.0 0.0e+00
>> 0.0e+00 5.2e+01 0 0 0 0 1 0 0 0 0 1 0
>> > > EPSSolve 1 1.0 2.5917e+01 1.0 3.58e+09 1.0 1.9e+05
>> 3.0e+03 8.5e+03 99100100 93100 99100100 93100 2200
>> > > STSetUp 1 1.0 4.8380e-03 5.6 0.00e+00 0.0 0.0e+00
>> 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> > > KSPSetUp 1 1.0 1.1921e-06 0.0 0.00e+00 0.0 0.0e+00
>> > > KSPSolve 1045 1.0 6.8107e-01 1.0 2.17e+08 1.1 0.0e+00
>> 0.0e+00 0.0e+00 3 6 0 0 0 3 6 0 0 0 4886
>> > > PCSetUp 2 1.0 2.3827e-02 2.8 9.18e+05 1.1 0.0e+00
>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 580
>> > > PCApply 1045 1.0 7.0819e-01 1.0 2.17e+08 1.1 0.0e+00
>> 0.0e+00 0.0e+00 3 6 0 0 0 3 6 0 0 0 4699
>> > > BVCreate 529 1.0 3.7145e+00 1.6 0.00e+00 0.0 0.0e+00
>> 0.0e+00 3.2e+03 11 0 0 0 37 11 0 0 0 37 0
>> > > BVCopy 1048 1.0 1.3941e-02 1.2 0.00e+00 0.0 0.0e+00
>> > > BVMult 3761 1.0 3.6953e+00 1.1 2.00e+09 1.0 0.0e+00
>> 0.0e+00 0.0e+00 14 56 0 0 0 14 56 0 0 0 8674
>> > > BVDot 2675 1.0 9.6611e+00 1.3 1.08e+09 1.0 6.8e+04
>> 3.0e+03 2.7e+03 34 30 36 33 31 34 30 36 33 31 1791
>> > > BVOrthogonalize 526 1.0 4.0705e+00 1.1 7.89e+08 1.0 6.8e+04
>> 3.0e+03 5.9e+02 15 22 36 33 7 15 22 36 33 7 3092
>> > > BVScale 1047 1.0 1.6144e-02 1.1 8.18e+06 1.0 0.0e+00
>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 8105
>> > > BVSetRandom 5 1.0 4.7204e-02 2.0 0.00e+00 0.0 0.0e+00
>> > > BVMatProject 1046 1.0 5.1708e+00 1.4 6.11e+08 1.0 0.0e+00
>> 0.0e+00 1.6e+03 18 17 0 0 18 18 17 0 0 18 1891
>> > > DSSolve 533 1.0 9.7243e-01 1.0 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00 4 0 0 0 0 4 0 0 0 0 0
>> > > DSVectors 1048 1.0 1.3440e-03 1.4 0.00e+00 0.0 0.0e+00
>> > > DSOther 2123 1.0 8.8778e-03 1.1 0.00e+00 0.0 0.0e+00
>> > > Memory usage is given in bytes:
>> > > Object Type Creations Destructions Memory
>> Descendants' Mem.
>> > > Reports information only for process 0.
>> > > Viewer 3 2 1504 0
>> > > Matrix 3196 3190 31529868 0
>> > > Vector 2653 2651 218802920 0
>> > > Vector Scatter 2 0 0 0
>> > > Index Set 7 7 84184 0
>> > > Eigenvalue Problem Solver 1 1 4564 0
>> > > PetscRandom 1 1 632 0
>> > > Spectral Transform 1 1 828 0
>> > > Krylov Solver 2 2 2320 0
>> > > Preconditioner 2 2 1912 0
>> > > Basis Vectors 530 530 1111328 0
>> > > Region 1 1 648 0
>> > > Direct solver 1 1 201200 0
>> > > Average time to get PetscTime(): 9.53674e-08
>> > > Average time for MPI_Barrier(): 0.0004704
>> > > Average time for zero size MPI_Send(): 0.000118256
>> > > #PETSc Option Table entries:
>> > > -eps_monitor
>> > > -f1 A.mat
>> > > -f2 B.mat
>> > > -log_view
>> > > -matload_block_size 1
>> > > -ncv 70
>> > > -st_ksp_tol 1e-12
>> > > #End of PETSc Option Table entries
>> > > Compiled without FORTRAN kernels
>> > > Compiled with full precision matrices (default)
>> > > sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> > > Configure options: --with-x=0 --download-hdf5=1
>> --with-scalar-type=real --with-single-library=1 --with-pic=1
>> --with-shared-libraries=0 --with-clanguage=C++ --with-fortran=1
>> --with-debugging=0 --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpicxx
>> --download-metis=1 --download-parmetis=1 --with-valgrind-dir=/apps/rhel6/valgrind/3.8.1/
>> --download-mumps=1 --with-fortran-kernels=0 --download-superlu_dist=1
>> --download-scalapack --download-fblaslapack=1
>> > > Libraries compiled on Thu Sep 22 10:19:43 2016 on
>> carter-g008.rcac.purdue.edu
>> > > Machine characteristics: Linux-2.6.32-573.8.1.el6.x86_6
>> 4-x86_64-with-redhat-6.7-Santiago
>> > > Using PETSc directory: /depot/ncn/apps/conte/conte-gc
>> c-petsc35/libs/petsc/build-real
>> > > Using PETSc arch: linux
>> > > Using C compiler: mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing
>> -Wno-unknown-pragmas -O -fPIC ${COPTFLAGS} ${CFLAGS}
>> > > Using Fortran compiler: mpif90 -fPIC -Wall -Wno-unused-variable
>> -ffree-line-length-0 -O ${FOPTFLAGS} ${FFLAGS}
>> > > Using include paths: -I/depot/ncn/apps/conte/conte-
>> gcc-petsc35/libs/petsc/build-real/linux/include
>> -I/depot/ncn/apps/conte/conte-gcc-petsc35/libs/petsc/build-real/include
>> -I/depot/ncn/apps/conte/conte-gcc-petsc35/libs/petsc/build-real/linux/include
>> -I/apps/rhel6/valgrind/3.8.1/include -I/depot/apps/ncn/conte/mpich-
>> 3.1/include
>> > > Using C linker: mpicxx
>> > > Using Fortran linker: mpif90
>> > > Using libraries: -Wl,-rpath,/depot/ncn/apps/con
>> te/conte-gcc-petsc35/libs/petsc/build-real/linux/lib
>> -L/depot/ncn/apps/conte/conte-gcc-petsc35/libs/petsc/build-real/linux/lib
>> -lpetsc -Wl,-rpath,/depot/ncn/apps/conte/conte-gcc-petsc35/libs/petsc/build-real/linux/lib
>> -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack
>> -lsuperlu_dist_3.3 -lflapack -lfblas -lparmetis -lmetis -lpthread -lssl
>> -lcrypto -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lz
>> -Wl,-rpath,/depot/apps/ncn/conte/mpich-3.1/lib
>> -L/depot/apps/ncn/conte/mpich-3.1/lib -Wl,-rpath,/apps/rhel6/gcc/5.2
>> .0/lib/gcc/x86_64-unknown-linux-gnu/5.2.0 -L/apps/rhel6/gcc/5.2.0/lib/gc
>> c/x86_64-unknown-linux-gnu/5.2.0 -Wl,-rpath,/apps/rhel6/gcc/5.2.0/lib64
>> -L/apps/rhel6/gcc/5.2.0/lib64 -Wl,-rpath,/apps/rhel6/gcc/5.2.0/lib
>> -L/apps/rhel6/gcc/5.2.0/lib -lmpichf90 -lgfortran -lm -lgfortran -lm
>> -lquadmath -lm -lmpichcxx -lstdc++ -Wl,-rpath,/depot/apps/ncn/conte/mpich-3.1/lib
>> -L/apps/rhel6/gcc/5.2.0/lib -ldl -Wl,-rpath,/depot/apps/ncn/conte/mpich-3.1/lib
>> -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
>> > > Can you please point me to what could be going wrong with the larger
>> software?
>> > > Thanks!
>> > > Harshad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180503/aeb811d3/attachment-0001.html>
