[petsc-users] Could not determine how to create a shared library!
Zhang, Hong
hongzhang at anl.gov
Thu May 3 14:19:06 CDT 2018
The MKL version you are trying to use does not match the environment setting on Theta.
hongzh at thetalogin6:~/Projects/petsc (master)$ module list
Currently Loaded Modulefiles:
1) modules/3.2.10.6 10) dmapp/7.1.1-6.0.4.0_46.2__gb8abda2.ari 19) PrgEnv-intel/6.0.4
2) eproxy/2.0.16-6.0.4.1_3.1__g001b199.ari 11) gni-headers/5.0.11-6.0.4.0_7.2__g7136988.ari 20) craype-mic-knl
3) intel/18.0.0.128 12) xpmem/2.2.2-6.0.4.1_18.2__g43b0535.ari 21) cray-mpich/7.7.0
4) craype-network-aries 13) job/2.2.2-6.0.4.0_8.2__g3c644b5.ari 22) nompirun/nompirun
5) craype/2.5.14 14) dvs/2.7_2.2.36-6.0.4.1_16.2__g4c8274a 23) darshan/3.1.5
6) cray-libsci/18.04.1 15) alps/6.4.2-6.0.4.1_3.1__gb8adc61.ari 24) trackdeps
7) udreg/2.3.2-6.0.4.0_12.2__g2f9c3ee.ari 16) rca/2.2.15-6.0.4.1_13.1__g46acb0f.ari 25) xalt
8) ugni/6.0.14-6.0.4.0_14.1__ge7db4a2.ari 17) atp/2.1.1 26) cray-hdf5-parallel/1.10.1.1
9) pmi/5.0.13 18) perftools-base/7.0.1
By default, 18.0.0.128 is loaded. Your petsc configuration should work with 18.0.2.199 if you do
module swap intel/18.0.0.128 intel/18.0.2.199
Hong (Mr.)
On May 3, 2018, at 11:00 AM, Kong, Fande <fande.kong at inl.gov<mailto:fande.kong at inl.gov>> wrote:
I get the PETSc complied, but theta does not like the shared lib, I think.
I am switching back to a static lib. I ever successfully built and ran the PETSc with the static compiling.
But I encountered a problem this time on building blaslapack.
Fande
On Tue, May 1, 2018 at 2:22 PM, Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
This is theta..
Try: using --LDFLAGS=-dynamic option
[as listed in config/examples/arch-cray-xc40-knl-opt.py]
Satish
On Tue, 1 May 2018, Kong, Fande wrote:
> Hi All,
> I can build a static petsc library on a supercomputer, but could not do the
> same thing with " --with-shared-libraries=1".
> The log file is attached.
> Fande,
<configure.log 2.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180503/a47c2c6c/attachment.html>
