[petsc-users] Could not determine how to create a shared library!
Kong, Fande
fande.kong at inl.gov
Thu May 3 13:25:33 CDT 2018
On Thu, May 3, 2018 at 11:50 AM, Zhang, Hong <hongzhang at anl.gov> wrote:
> Alternatively you can use --with-blaslapack-dir=/opt/
> intel/compilers_and_libraries/linux/mkl/lib/intel64 to let petsc pick the
> right libs for you.
This used to work, but does not work any more.
Fande,
> Hong (Mr.)
> On May 3, 2018, at 11:32 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> --with-blaslapack-lib=-mkl -L' + os.environ['MKLROOT'] + '/lib/intel64
> works.
> Fande,
> On Thu, May 3, 2018 at 10:09 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> Ok you are not 'building blaslapack' - but using mkl [as per
>> configure.log].
>> I'll have to check the issue. It might be something to do with using
>> mkl as a static library..
>> Hong might have some suggestions wrt theta builds.
>> Satish
>> On Thu, 3 May 2018, Satish Balay wrote:
>> > Perhaps you should use MKL on theta? Again check
>> config/examples/arch-cray-xc40-knl-opt.py
>> > Satish
>> > On Thu, 3 May 2018, Kong, Fande wrote:
>> > > Thanks,
>> > > I get the PETSc complied, but theta does not like the shared lib, I
>> think.
>> > > I am switching back to a static lib. I ever successfully built and
>> ran
>> > > the PETSc with the static compiling.
>> > > But I encountered a problem this time on building blaslapack.
>> > > Thanks,
>> > > Fande
>> > > On Tue, May 1, 2018 at 2:22 PM, Satish Balay <balay at mcs.anl.gov>
>> wrote:
>> > > > This is theta..
>> > > > Try: using --LDFLAGS=-dynamic option
>> > > > [as listed in config/examples/arch-cray-xc40-knl-opt.py]
>> > > > Satish
>> > > > On Tue, 1 May 2018, Kong, Fande wrote:
>> > > > > Hi All,
>> > > > > I can build a static petsc library on a supercomputer, but could
>> not do
>> > > > the
>> > > > > same thing with " --with-shared-libraries=1".
>> > > > > The log file is attached.
>> > > > > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180503/cfae9f06/attachment.html>
