[petsc-users] Obtaining compiling and building information from a.out
TAY wee-beng
zonexo at gmail.com
Thu Mar 29 00:48:02 CDT 2018
On 28/3/2018 5:45 PM, Matthew Knepley wrote:
> On Tue, Mar 27, 2018 at 10:17 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> Hi Dave,
> I looked at the output using log_view and re-compile. However,
> although I use the same options "-xHost -g -O3 -openmp" (some
> filenames and dir names are now different but they are actually
> the same), I still get different results timing. I have attach
> both, fast and slow. So what else can I do to pinpoint the
> differences?
> The solver options must be different. In Fast, there is almost no time
> in LUFactor, but in Slow its half the time.
> Matt
Hi Matt,
Finally found that it was because I was using KSPRICHARDSON in the new
code. KSPGMRES in the old code is much faster.
I also tried cg, lsqr, fgmres. CG and GMRES seem similar in term of best
performance. Are there any other recommendations to try? The Poisson eqn
is symmetric.
I also tried -pc_type mg -pc_mg_nlevels 2 instead of -poisson_pc_type
gamg -poisson_pc_gamg_agg_nsmooths 1.
It reduces the runtime from 2.25 to 1.46min.
However, I found that my subroutine is very similar to my momentum
subroutine, which is based on KSPSolve:
0. DMDACreate, DMDACreate3d etc
1. Assemble matrix
2. KSPSetOperators, KSPSetType etc
3. KSPSolve
However, the 2D Poisson example in ex5f.F90 uses SNESSetDM, SNESSolve
etc. So does it matter if I use SNESSolve or KSPSolve if I'm using
-pc_type mg?
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng (Zheng Weiming) 郑伟明
> Personal research webpage:http://tayweebeng.wixsite.com/website
> <http://tayweebeng.wixsite.com/website>
> Youtube research showcase:https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
> <https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA>
> linkedin:www.linkedin.com/in/tay-weebeng
> <http://www.linkedin.com/in/tay-weebeng>
> On 27/3/2018 5:22 PM, Dave May wrote:
>> On 27 March 2018 at 10:16, TAY wee-beng <zonexo at gmail.com
>> Hi,
>> I have been compiling and building different version of my
>> CFD with the intel 2016, 2018 compilers, and also different
>> compiling options.
>> I tested a version of my a.out and it is much faster than the
>> other a.out, using only 3 min instead of more than 10min to
>> solve a certain case using GAMG.
>> However, I can't recall how it was compiled. I only know that
>> I used the intel 2016 compiler.
>> So is there any way I can find out how the a.out was
>> compiled? Like what options were used?
>> Since you posted to the list I presume "a.out" links against petsc...
>> If so, run your code with
>> -log_view
>> Upon calling PetscFinalize(), you will get all the options given
>> to PETSc configure, plus the CFLAGS, link lines, etc.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180329/a4a1fd8c/attachment.html>
