[petsc-users] Compilation error with PETSc and intel options
TAY wee-beng
zonexo at gmail.com
Tue Mar 27 23:40:32 CDT 2018
I have an error compiling PETSc with Intel Fortran and its options.
I have attached the configure.log
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
Starting Configure Run at Wed Mar 28 12:35:55 2018
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc="win32fe cl" --with-fc="win32fe ifort" --with-cxx="win32fe cl" --with-mpi-include="/cygdrive/c/Program Files (x86)/IntelSWTools/mpi/2018.2.185/intel64/include" --with-mpi-lib="[/cygdrive/c/Program\ Files\ \(x86\)/IntelSWTools/mpi/2018.2.185/intel64/lib/debug/impi.lib,/cygdrive/c/Program\ Files\ \(x86\)/IntelSWTools/mpi/2018.2.185/intel64/lib/impicxx.lib,/cygdrive/c/Program\ Files\ \(x86\)/IntelSWTools/mpi/2018.2.185/intel64/lib/impicxxd.lib,/cygdrive/c/Program\ Files\ \(x86\)/IntelSWTools/mpi/2018.2.185/intel64/lib/libmpi_ilp64.lib]" --download-fblaslapack=1 --prefix=/cygdrive/c/wtay/Lib/petsc-3.8.4_win64_impi_vs2015_opt --with-debugging=0 --with-shared-libraries=0 --CFLAGS="-QxHost -debug -O3" --CXXFLAGS="-QxHost -debug -O3" --FFLAGS="-QxHost -debug -O3"
Working directory: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4
Machine platform:
('CYGWIN_NT-6.1', 'tsltaywb-work', '2.9.0(0.318/5/3)', '2017-09-12 10:18', 'x86_64', '')
Python version:
2.7.14 (default, Oct 31 2017, 21:12:13)
[GCC 6.4.0]
Pushing language C
Popping language C
Pushing language FC
Popping language FC
TEST configureExternalPackagesDir from config.framework(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/framework.py:830)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:830)
TEST configureDebuggers from config.utilities.debuggers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
Find a default debugger and determine its arguments
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/gdb...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/gdb...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/gdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/gdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/gdb...not found
Checking for program /cygdrive/c/Windows/system32/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/gdb...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/gdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/gdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/gdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/gdb...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/dbx...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/dbx...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/dbx...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/dbx...not found
Checking for program /cygdrive/c/Windows/system32/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/dbx...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/dbx...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/dbx...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/dbx...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/xdb...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/xdb...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/xdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/xdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/xdb...not found
Checking for program /cygdrive/c/Windows/system32/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/xdb...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/xdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/xdb...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/xdb...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/dsymutil...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/dsymutil...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/dsymutil...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/dsymutil...not found
Checking for program /cygdrive/c/Windows/system32/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/dsymutil...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/dsymutil...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/dsymutil...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/dsymutil...not found
Defined make macro "DSYMUTIL" to "true"
TEST configureGit from config.sourceControl(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
Find the Git executable
Checking for program /usr/local/bin/git...not found
Checking for program /usr/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/git...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/git...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/git...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/git...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/git...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/git...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/git...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/git...not found
Checking for program /cygdrive/c/Windows/system32/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/git...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/git...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/git...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/git...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/git...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/git...not found
TEST configureMercurial from config.sourceControl(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
Find the Mercurial executable
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/hg...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/hg...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/hg...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/hg...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/hg...not found
Checking for program /cygdrive/c/Windows/system32/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/hg...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/hg...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/hg...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/hg...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/hg...not found
TEST configureCLanguage from PETSc.options.languages(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
Choose whether to compile the PETSc library using a C or C++ compiler
C language is C
Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
Checks PETSC_DIR and sets if not set
Version Information:
#define PETSC_VERSION_RELEASE 1
#define PETSC_VERSION_MAJOR 3
#define PETSC_VERSION_MINOR 8
#define PETSC_VERSION_SUBMINOR 4
#define PETSC_VERSION_PATCH 0
#define PETSC_VERSION_DATE "Mar, 24, 2018"
#define PETSC_VERSION_GIT "v3.8.4"
#define PETSC_VERSION_DATE_GIT "2018-03-24 21:42:57 -0500"
#define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_ PETSC_VERSION_EQ
#define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
Defined make macro "DIR" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4"
TEST getDatafilespath from PETSc.options.dataFilesPath(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
This is a tarball installation
TEST configureArchitecture from PETSc.options.arch(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/arch.py:36)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:36)
Checks PETSC_ARCH and sets if not set
Defined "ARCH" to ""petsc-3.8.4_win64_impi_vs2015_opt""
TEST setInstallDir from PETSc.options.installDir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
Defined make macro "PREFIXDIR" to "/cygdrive/c/wtay/Lib/petsc-3.8.4_win64_impi_vs2015_opt"
TEST saveReconfigure from PETSc.options.installDir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/installDir.py:75)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:75)
TEST cleanInstallDir from PETSc.options.installDir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/installDir.py:68)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:68)
TEST configureInstallDir from PETSc.options.installDir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/installDir.py:52)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:52)
Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
Changed persistence directory to /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/petsc-3.8.4_win64_impi_vs2015_opt/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/installDir.py:88)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:88)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1614)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1614)
**** printenv ****
LIB=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\lib;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\lib\intel64;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\lib\intel64_win;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\LIB\amd64;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\ATLMFC\LIB\amd64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.10240.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\lib\um\x64;C:\Program Files (x86)\Windows Kits\8.1\lib\winv6.3\um\x64;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\mpi\intel64\bin\..\..\intel64\lib;
VS100COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools\
COMPUTERNAME=TSLTAYWB-WORK
SCRIPT_NAME=compilervars_arch.bat
VT_MPI=impi64
VT_DLL_DIR=C:\Program Files (x86)\IntelSWTools\Trace Analyzer and Collector\9.1.2.024\dll
SYSTEMROOT=C:\Windows
WIN_TITLE_ARCH=Intel(R) 64
SW_SIM_TEMP=C:\ProgramData\SOLIDWORKS\SW_net_sim_temp\
PRODUCT_NAME=Intel Compiler 18.0 Update 2
INFOPATH=/usr/local/info:/usr/share/info:/usr/info
SHELL=/bin/bash
MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\lib\mic;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\compiler\lib\intel64_win_mic
WindowsSDK_ExecutablePath_x86=C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools\
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
IMPI_ENV=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.2.180\windows\mpi\intel64
SW_SIM_HYDRA=C:\Program Files\Common Files\SolidWorks Shared\Simulation Worker Agent\
FrameworkVersion64=v4.0.30319
MPI_DIR=C:\Program Files (x86)\IntelSWTools\mpi\2018.1.156\intel64
UATDATA=C:\Windows\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77
VT_MPI_DLL=impi.dll
include=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\include\intel64;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\ATLMFC\INCLUDE;C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\include\um;C:\Program Files (x86)\Windows Kits\8.1\include\\shared;C:\Program Files (x86)\Windows Kits\8.1\include\\um;C:\Program Files (x86)\Windows Kits\8.1\include\\winrt;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\mpi\intel64\bin\..\..\intel64\include;C:\Program Files (x86)\IntelSWTools\Trace Analyzer and Collector\9.1.2.024\include;C:\Program Files (x86)\IntelSWTools\Trace Analyzer and Collector\9.1.1.019\include;C:\Program Files (x86)\Intel\Trace Analyzer and Collector\9.0.2.045\include
PROFILEREAD=true
NDK_DIR=""
TEC_360_2011=C:\Program Files\Tecplot\Tec360 2011R2\
TEC_360_2016=C:\Program Files\Tecplot\Tec360 2016R2\
COMSPEC=C:\Windows\system32\cmd.exe
WindowsSDKLibVersion=winv6.3\
ANSYS_SYSDIR=winx64
MSMPI_LIB64=C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x64\
ARCH_PATH=intel64
TARGET_ARCH=intel64
ICPP_COMPILER16=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.1.146\windows\
GRIDPRO=C:\Program Files\GridPro
MOZ_PLUGIN_PATH=C:\PROGRAM FILES (X86)\FOXIT SOFTWARE\FOXIT READER\plugins\
HOMEDRIVE=C:
FrameworkVersion=v4.0.30319
SYSTEMDRIVE=C:
HOSTNAME=tsltaywb-work
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\\Intel\Licenses;C:\Program Files (x86)\Common Files\Intel\Licenses
PETSC_ARCH=petsc-3.8.4_win64_impi_vs2015_opt
PROCESSOR_LEVEL=6
AWP_LOCALE182=en-us
LSTC_LICENSE=ANSYS
OS=Windows_NT
__MS_VC_INSTALL_PATH=C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\..\..\VC
TARGET_VS=vs2015
OneDrive=D:\wtay\OneDrive
Platform=X64
MPI_ROOTDIR=C:\OpenFOAM\OpenMPI_v1.6.1-x64
CommandPromptType=Native
USER=TSLTAYWB-WORK+wtay
!C:=C:\cygwin64\bin
PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
IFORT_COMPILER18=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\
Framework40Version=v4.0
BIN_DIR=bin64
TEMP=/tmp
SHLVL=1
P_SCHEMA=C:\Program Files\ANSYS Student\v182\AISOL\CADIntegration\Parasolid\PSchema
VTUNE_AMPLIFIER_2018_DIR=C:\Program Files (x86)\IntelSWTools\VTune Amplifier 2018\
APR_ICONV_PATH=C:\openfoam\Subversion\iconv
AWP_ROOT182=C:\Program Files\ANSYS Student\v182
PETSC_DIR=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4
HOMEPATH=\Users\wtay
WindowsSdkDir=C:\Program Files (x86)\Windows Kits\8.1\
ROOT=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows
MINITAB_LICENSE_FILE=27001 at cceuss.nus.edu.sg
ANS_OLD_ATTACH=1
LOGONSERVER=\\TSLTAYWB-WORK
C_TARGET_ARCH=intel64
MSVS_VAR_SCRIPT="C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\..\..\VC\vcvarsall.bat"
MSVS_VAR_SCRIPT_DIR=C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC
ROOT_ROOT_NAME=windows
PRINTER=Foxit Reader PDF Printer
SESSIONNAME=Console
PETSC_DIR2015=C:\wtay\Lib\petsc-3.8.2_win64_impi_vs2015_debug
_=./config/configure.py
APPDATA=C:\Users\wtay\AppData\Roaming
VT_FMPI_DLL=impi.dll
INSPECTOR_2018_DIR=C:\Program Files (x86)\IntelSWTools\Inspector 2018\
ProgramData=C:\ProgramData
PUBLIC=C:\Users\Public
INSPECTOR_XE_2016_DIR=C:\Program Files (x86)\IntelSWTools\Inspector XE 2016\
VT_ROOT=C:\Program Files (x86)\IntelSWTools\Trace Analyzer and Collector\9.1.2.024\
TMP=/tmp
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\;C:\Program Files\Intel\Wired Networking\
VS110COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\
USERDOMAIN=TSLTAYWB-WORK
ANSYS_SYSDIR32=win32
PRODUCT_NAME_FULL=Intel(R) Compiler 18.0 Update 2 (package 185)
VS90COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools\
COMMONPROGRAMFILES=C:\Program Files\Common Files
VBOX_MSI_INSTALL_PATH=C:\Program Files\Oracle\VirtualBox\
HOME=/home/wtay
LD_LIBRARY_PATH=/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/linux/compiler/lib/intel64_lin
WindowsLibPath=C:\Program Files (x86)\Windows Kits\8.1\References\CommonConfiguration\Neutral
LANG=en_US.UTF-8
VTUNE_AMPLIFIER_XE_2016_DIR=C:\Program Files (x86)\IntelSWTools\VTune Amplifier XE 2016\
MIC_LIBRARY_PATH=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\compiler\lib\mic;
!ExitCode=00000000
PROCESSOR_ARCHITECTURE=AMD64
ALLUSERSPROFILE=C:\ProgramData
VisualStudioVersion=14.0
VT_SLIB_DIR=C:\Program Files (x86)\IntelSWTools\Trace Analyzer and Collector\9.1.2.024\dll
ProgramW6432=C:\Program Files
USERNAME=wtay
FrameworkDIR64=C:\Windows\Microsoft.NET\Framework64
PROMPT=$P$G
ADVISOR_2018_DIR=C:\Program Files (x86)\IntelSWTools\Advisor 2018\
MPI_ENV=D:\Lib\MPICH2
INTEL_DEV_REDIST=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
FrameworkDir=C:\Windows\Microsoft.NET\Framework64
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
CommonProgramW6432=C:\Program Files\Common Files
WINDIR=C:\Windows
ANSYS182_DIR=C:\Program Files\ANSYS Student\v182\ANSYS
NUMBER_OF_PROCESSORS=48
IFORT_COMPILER16=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.1.146\windows\
WindowsSDKVersion=\
WIN_TITLE=Intel Compiler 18.0 Update 2 Intel(R) 64 Visual Studio 2015
TARGET_VS_ARCH=amd64
MSMPI_INC=C:\Program Files (x86)\Microsoft SDKs\MPI\Include\
BIN_ROOT=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\bin\
USERPROFILE=C:\Users\wtay
VS140COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\
PYTHONPATH=C:\Program Files (x86)\IntelSWTools\Advisor 2018\\pythonapi
EXECIGNORE=*.dll
VT_LIB_DIR=C:\Program Files (x86)\IntelSWTools\Trace Analyzer and Collector\9.1.2.024\lib
LIBPATH=C:\Windows\Microsoft.NET\Framework64\v4.0.30319;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\LIB\amd64;C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\ATLMFC\LIB\amd64;C:\Program Files (x86)\Windows Kits\8.1\References\CommonConfiguration\Neutral;\Microsoft.VCLibs\14.0\References\CommonConfiguration\neutral;
ORIGINAL_PATH=/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools:/cygdrive/c/Program Files (x86)/HTML Help Workshop:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86:/cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib:/cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32:/cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64:/cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin:/cygdrive/c/ProgramData/Oracle/Java/javapath:/cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin:/cygdrive/c/Program Files (x86)/Common Files/NetSarang:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis:/cygdrive/c/Windows/system32:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/openfoam/Git/cmd:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll:/cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll:/cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll:/cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin:/cygdrive/c/Windows/system32
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
CADOE_LIBDIR182=C:\Program Files\ANSYS Student\v182\CommonFiles\Language\en-us
PROCESSOR_REVISION=3e04
PATH=/usr/local/bin:/usr/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools:/cygdrive/c/Program Files (x86)/HTML Help Workshop:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86:/cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib:/cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32:/cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64:/cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin:/cygdrive/c/ProgramData/Oracle/Java/javapath:/cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin:/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin:/cygdrive/c/Program Files (x86)/Common Files/NetSarang:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis:/cygdrive/c/Windows/system32:/cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit:/cygdrive/c/openfoam/Git/cmd:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin:/cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin:/cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll:/cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll:/cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll:/cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin:/cygdrive/c/Windows/system32
MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
TEC_360_2017=C:\Program Files\Tecplot\Tecplot 360 EX 2017 R2
TERM=cygwin
TZ=Asia/Singapore
PETSC_DIR_OLD=C:\wtay\Lib\petsc-3.7.4_win64_impi_vs2012_debug
VSINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 14.0\
LOCALAPPDATA=C:\Users\wtay\AppData\Local
WindowsSDK_ExecutablePath_x64=C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools\x64\
UniversalCRTSdkDir=C:\Program Files (x86)\Windows Kits\10\
FLEXLM_TIMEOUT=300000
INTEL_PYTHONPATH=C:\Program Files (x86)\IntelSWTools\Advisor 2018\\pythonapi
SW_SIM_MPIT=INTELMPI
UCRTVersion=10.0.10240.0
I_MPI_ROOT=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.2.185\windows\mpi\intel64\bin\..\..
PARAVIEW_HOME=C:\OpenFOAM\ParaView_5.1.2
VT_ADD_LIBS=ws2_32.lib advapi32.lib
FP_NO_HOST_CHECK=NO
WIN_TITLE_VS=Visual Studio 2015
OLDPWD=/cygdrive/d/wtay/Downloads/Source_codes
NETFXSDKDir=C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\
PWD=/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4
MSMPI_LIB32=C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x86\
VCINSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\
TEST resetEnvCompilers from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1621)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1621)
***** WARNING: MPI_DIR (set to C:\Program Files (x86)\IntelSWTools\mpi\2018.1.156\intel64) found in environment variables - ignoring
use ./configure MPI_DIR=$MPI_DIR if you really want to use that value ******
TEST checkEnvCompilers from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1651)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1651)
TEST checkMPICompilerOverride from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1586)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1586)
Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1605)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1605)
OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:426)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:426)
Determine the compiler vendor
Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:436)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:436)
Initialize the compiler and linker flags
Pushing language C
Initialized CFLAGS to -QxHost -debug -O3
Initialized LDFLAGS to
Popping language C
Pushing language CUDA
Initialized CUDAFLAGS to
Popping language CUDA
Pushing language Cxx
Initialized CXXFLAGS to -QxHost -debug -O3
Initialized CXX_CXXFLAGS to
Popping language Cxx
Pushing language FC
Initialized FFLAGS to -QxHost -debug -O3
Popping language FC
Initialized CPPFLAGS to
Initialized CUDAPPFLAGS to
Initialized CXXCPPFLAGS to
Initialized CC_LINKER_FLAGS to []
Initialized CXX_LINKER_FLAGS to []
Initialized FC_LINKER_FLAGS to []
Initialized CUDAC_LINKER_FLAGS to []
Initialized sharedLibraryFlags to []
Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:568)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:568)
Locate a functional C compiler
Checking for program /usr/local/bin/win32fe...not found
Checking for program /usr/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/win32fe...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/win32fe...not found
Checking for program /cygdrive/c/Windows/system32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/win32fe...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/win32fe...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe...found
Defined make macro "CC" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl"
Pushing language C
All intermediate test results are stored in /tmp/petsc-ytughc
All intermediate test results are stored in /tmp/petsc-ytughc/config.setCompilers
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-QxHost'
cl : Command line warning D9002 : ignoring unknown option '-debug'
cl : Command line warning D9002 : ignoring unknown option '-O3'
conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
stdout:
conftest.c
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o
stdout:
stdout:
conftest.c
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
Possible ERROR while running linker: exit code 512
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
stdout:
Testing executable /tmp/petsc-ytughc/config.setCompilers/conftest.exe to see if it can be run
Executing: /tmp/petsc-ytughc/config.setCompilers/conftest.exe
Popping language C
TEST checkCPreprocessor from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:601)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:601)
Locate a functional C preprocessor
Defined make macro "CPP" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -E"
Pushing language C
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -E -I/tmp/petsc-ytughc/config.setCompilers /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
conftest.c
#line 1 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 7 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 11 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 13 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 2 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.c"
#line 1 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
#line 8 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
#line 9 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
#line 10 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
#line 3 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.c"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 34 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 39 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 40 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 41 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#pragma once
#line 151 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 155 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 185 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 188 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 190 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 196 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 200 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 207 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 219 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 228 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 229 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1586 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1611 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1624 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1663 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1775 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1878 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2047 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2149 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2366 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2367 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2595 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2634 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2868 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2878 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2883 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2890 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2891 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2898 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2899 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2911 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2945 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#pragma once
#line 265 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 269 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 352 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 358 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 2971 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 46 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#pragma once
#pragma pack(push, 8)
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
typedef unsigned __int64 uintptr_t;
#line 32 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 33 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
typedef char* va_list;
#line 41 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 42 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 48 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 54 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 58 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 61 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 73 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 81 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 93 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 105 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
void __cdecl __va_start(va_list* , ...);
#line 116 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 152 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 156 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#pragma pack(pop)
#line 47 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 62 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 72 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 80 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
__pragma(pack(push, 8))
#line 88 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 109 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 111 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 113 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 115 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 117 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 118 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 127 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 129 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 130 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 138 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 140 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 146 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 149 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 155 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 167 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 171 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 173 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 179 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 187 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 188 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
typedef unsigned __int64 size_t;
typedef __int64 ptrdiff_t;
typedef __int64 intptr_t;
#line 202 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 206 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 210 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
typedef _Bool __vcrt_bool;
#line 212 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 217 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 221 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 225 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
typedef unsigned short wchar_t;
#line 231 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 238 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 239 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 245 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 257 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 264 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 275 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 276 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 280 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 288 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 289 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
void __cdecl __security_init_cookie(void);
void __cdecl __security_check_cookie( uintptr_t _StackCookie);
__declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
#line 307 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 308 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
extern uintptr_t __security_cookie;
#line 316 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
__pragma(pack(pop))
#line 320 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 25 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 27 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 29 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 36 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 41 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 43 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 58 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 64 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 73 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 91 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 92 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 96 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 102 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 104 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 108 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 110 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef _Bool __crt_bool;
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 149 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 161 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 165 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 188 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 189 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 193 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 200 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 201 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
void __cdecl _invalid_parameter_noinfo(void);
__declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
void __cdecl _invoke_watson(
wchar_t const*,
wchar_t const*,
wchar_t const*,
unsigned int,
uintptr_t);
#line 256 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 257 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 268 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 277 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 278 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 296 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 297 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 304 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 305 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 309 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 323 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 345 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 349 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 354 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 355 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 365 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 366 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 367 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 371 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 377 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 387 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 388 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 397 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 407 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 414 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 419 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 427 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 435 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 436 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 440 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef int errno_t;
typedef unsigned short wint_t;
typedef unsigned short wctype_t;
typedef long __time32_t;
typedef __int64 __time64_t;
typedef struct __crt_locale_data_public
unsigned short const* _locale_pctype;
int _locale_mb_cur_max;
unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
struct __crt_locale_data* locinfo;
struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
unsigned long _Wchar;
unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
#line 480 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 484 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef __time64_t time_t;
#line 491 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 492 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 497 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef size_t rsize_t;
#line 501 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 662 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 677 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 678 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 1753 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 1897 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 1898 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_malloc.h"
__declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
size_t _Count,
size_t _Size
void* __cdecl calloc(
size_t _Count,
size_t _Size
int __cdecl _callnewh(
size_t _Size
void* __cdecl _expand(
void* _Block,
size_t _Size
void __cdecl _free_base(
void* _Block
void __cdecl free(
void* _Block
void* __cdecl _malloc_base(
size_t _Size
void* __cdecl malloc(
size_t _Size
size_t __cdecl _msize(
void* _Block
void* __cdecl _realloc_base(
void* _Block,
size_t _Size
void* __cdecl realloc(
void* _Block,
size_t _Size
void* __cdecl _recalloc(
void* _Block,
size_t _Count,
size_t _Size
void __cdecl _aligned_free(
void* _Block
void* __cdecl _aligned_malloc(
size_t _Size,
size_t _Alignment
void* __cdecl _aligned_offset_malloc(
size_t _Size,
size_t _Alignment,
size_t _Offset
size_t __cdecl _aligned_msize(
void* _Block,
size_t _Alignment,
size_t _Offset
void* __cdecl _aligned_offset_realloc(
void* _Block,
size_t _Size,
size_t _Alignment,
size_t _Offset
void* __cdecl _aligned_offset_recalloc(
void* _Block,
size_t _Count,
size_t _Size,
size_t _Alignment,
size_t _Offset
void* __cdecl _aligned_realloc(
void* _Block,
size_t _Size,
size_t _Alignment
void* __cdecl _aligned_recalloc(
void* _Block,
size_t _Count,
size_t _Size,
size_t _Alignment
#line 211 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_malloc.h"
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
#pragma once
int* __cdecl _errno(void);
errno_t __cdecl _set_errno( int _Value);
errno_t __cdecl _get_errno( int* _Value);
#line 42 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
#line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
extern unsigned long __cdecl __threadid(void);
extern uintptr_t __cdecl __threadhandle(void);
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
void* __cdecl bsearch_s(
void const* _Key,
void const* _Base,
rsize_t _NumOfElements,
rsize_t _SizeOfElements,
int (__cdecl* _PtFuncCompare)(void*, void const*, void const*),
void* _Context
void __cdecl qsort_s(
void* _Base,
void* _Context
#line 41 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
void* __cdecl bsearch(
void const* _Key,
void const* _Base,
int (__cdecl* _PtFuncCompare)(void const*, void const*)
void __cdecl qsort(
void* _Base,
void* __cdecl _lfind_s(
void const* _Key,
void const* _Base,
unsigned int* _NumOfElements,
void* _Context
void* __cdecl _lfind(
void const* _Key,
void const* _Base,
unsigned int _SizeOfElements,
void* __cdecl _lsearch_s(
void const* _Key,
void* _Base,
void* _Context
void* __cdecl _lsearch(
void const* _Key,
void* _Base,
#line 179 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lfind" ". See online help for details."))
void* __cdecl lfind(
void const* _Key,
void const* _Base,
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lsearch" ". See online help for details."))
void* __cdecl lsearch(
void const* _Key,
void* _Base,
#line 203 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
#pragma once
errno_t __cdecl _itow_s(
int _Value,
wchar_t* _Buffer,
size_t _BufferCount,
int _Radix
#line 61 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _itow( int _Value, wchar_t *_Buffer, int _Radix);
#line 68 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
errno_t __cdecl _ltow_s(
long _Value,
wchar_t* _Buffer,
int _Radix
#line 84 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ltow( long _Value, wchar_t *_Buffer, int _Radix);
#line 91 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
errno_t __cdecl _ultow_s(
unsigned long _Value,
wchar_t* _Buffer,
int _Radix
#line 106 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ultow( unsigned long _Value, wchar_t *_Buffer, int _Radix);
#line 113 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
double __cdecl wcstod(
wchar_t const* _String,
wchar_t** _EndPtr
double __cdecl _wcstod_l(
wchar_t** _EndPtr,
_locale_t _Locale
long __cdecl wcstol(
wchar_t** _EndPtr,
int _Radix
long __cdecl _wcstol_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
long long __cdecl wcstoll(
wchar_t** _EndPtr,
int _Radix
long long __cdecl _wcstoll_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long __cdecl wcstoul(
wchar_t** _EndPtr,
int _Radix
unsigned long __cdecl _wcstoul_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long long __cdecl wcstoull(
wchar_t** _EndPtr,
int _Radix
unsigned long long __cdecl _wcstoull_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
long double __cdecl wcstold(
wchar_t** _EndPtr
long double __cdecl _wcstold_l(
wchar_t** _EndPtr,
_locale_t _Locale
float __cdecl wcstof(
wchar_t** _EndPtr
float __cdecl _wcstof_l(
wchar_t** _EndPtr,
_locale_t _Locale
double __cdecl _wtof(
double __cdecl _wtof_l(
_locale_t _Locale
int __cdecl _wtoi(
int __cdecl _wtoi_l(
_locale_t _Locale
long __cdecl _wtol(
long __cdecl _wtol_l(
_locale_t _Locale
long long __cdecl _wtoll(
long long __cdecl _wtoll_l(
_locale_t _Locale
errno_t __cdecl _i64tow_s(
__int64 _Value,
wchar_t* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
wchar_t* __cdecl _i64tow(
__int64 _Value,
wchar_t* _Buffer,
int _Radix
errno_t __cdecl _ui64tow_s(
unsigned __int64 _Value,
wchar_t* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
wchar_t* __cdecl _ui64tow(
wchar_t* _Buffer,
int _Radix
__int64 __cdecl _wtoi64(
__int64 __cdecl _wtoi64_l(
_locale_t _Locale
__int64 __cdecl _wcstoi64(
wchar_t** _EndPtr,
int _Radix
__int64 __cdecl _wcstoi64_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned __int64 __cdecl _wcstoui64(
wchar_t** _EndPtr,
int _Radix
unsigned __int64 __cdecl _wcstoui64_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
__declspec(allocator) wchar_t* __cdecl _wfullpath(
wchar_t* _Buffer,
wchar_t const* _Path,
size_t _BufferCount
errno_t __cdecl _wmakepath_s(
wchar_t* _Buffer,
wchar_t const* _Drive,
wchar_t const* _Dir,
wchar_t const* _Filename,
wchar_t const* _Ext
#line 359 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wmakepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wmakepath( wchar_t *_Buffer, wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext);
#line 368 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
void __cdecl _wperror(
wchar_t const* _ErrMsg
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsplitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
void __cdecl _wsplitpath(
wchar_t const* _FullPath,
wchar_t* _Drive,
wchar_t* _Dir,
wchar_t* _Filename,
wchar_t* _Ext
errno_t __cdecl _wsplitpath_s(
wchar_t* _Drive,
size_t _DriveCount,
wchar_t* _Dir,
size_t _DirCount,
wchar_t* _Filename,
size_t _FilenameCount,
wchar_t* _Ext,
size_t _ExtCount
#line 398 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
errno_t __cdecl _wdupenv_s(
wchar_t** _Buffer,
size_t* _BufferCount,
wchar_t const* _VarName
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wdupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
wchar_t* __cdecl _wgetenv(
errno_t __cdecl _wgetenv_s(
size_t* _RequiredCount,
wchar_t* _Buffer,
#line 436 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
int __cdecl _wputenv(
wchar_t const* _EnvString
errno_t __cdecl _wputenv_s(
wchar_t const* _Name,
wchar_t const* _Value
errno_t __cdecl _wsearchenv_s(
wchar_t const* _VarName,
wchar_t* _Buffer,
size_t _BufferCount
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsearchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wsearchenv( wchar_t const* _Filename, wchar_t const* _VarName, wchar_t *_ResultPath);
#line 468 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
int __cdecl _wsystem(
wchar_t const* _Command
#line 474 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#pragma once
#line 12 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 29 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 71 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 78 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 79 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 84 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 85 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
__pragma(pack(pop))
#line 16 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 24 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
void __cdecl _swab(
char* _Buf1,
char* _Buf2,
int _SizeInBytes
__declspec(noreturn) void __cdecl exit( int _Code);
__declspec(noreturn) void __cdecl _exit( int _Code);
__declspec(noreturn) void __cdecl _Exit( int _Code);
__declspec(noreturn) void __cdecl quick_exit( int _Code);
__declspec(noreturn) void __cdecl abort(void);
unsigned int __cdecl _set_abort_behavior(
unsigned int _Flags,
unsigned int _Mask
typedef int (__cdecl* _onexit_t)(void);
#line 73 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 82 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl atexit(void (__cdecl*)(void));
_onexit_t __cdecl _onexit( _onexit_t _Func);
#line 142 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl at_quick_exit(void (__cdecl*)(void));
typedef void (__cdecl* _purecall_handler)(void);
typedef void (__cdecl* _invalid_parameter_handler)(
wchar_t const*,
wchar_t const*,
wchar_t const*,
unsigned int,
uintptr_t
_purecall_handler __cdecl _set_purecall_handler(
_purecall_handler _Handler
_purecall_handler __cdecl _get_purecall_handler(void);
_invalid_parameter_handler __cdecl _set_invalid_parameter_handler(
_invalid_parameter_handler _Handler
_invalid_parameter_handler __cdecl _get_invalid_parameter_handler(void);
_invalid_parameter_handler __cdecl _set_thread_local_invalid_parameter_handler(
_invalid_parameter_handler __cdecl _get_thread_local_invalid_parameter_handler(void);
#line 185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 198 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl _set_error_mode( int _Mode);
unsigned long* __cdecl __doserrno(void);
errno_t __cdecl _set_doserrno( unsigned long _Value);
errno_t __cdecl _get_doserrno( unsigned long * _Value);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __sys_errlist(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int * __cdecl __sys_nerr(void);
void __cdecl perror( char const* _ErrMsg);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_pgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __p__pgmptr (void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_wpgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t** __cdecl __p__wpgmptr(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_fmode" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int* __cdecl __p__fmode (void);
#line 248 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _get_pgmptr ( char** _Value);
errno_t __cdecl _get_wpgmptr( wchar_t** _Value);
errno_t __cdecl _set_fmode ( int _Mode );
errno_t __cdecl _get_fmode ( int* _PMode);
typedef struct _div_t
int quot;
int rem;
} div_t;
typedef struct _ldiv_t
long quot;
long rem;
} ldiv_t;
typedef struct _lldiv_t
long long quot;
long long rem;
} lldiv_t;
int __cdecl abs ( int _Number);
long __cdecl labs ( long _Number);
long long __cdecl llabs ( long long _Number);
__int64 __cdecl _abs64( __int64 _Number);
unsigned short __cdecl _byteswap_ushort( unsigned short _Number);
unsigned long __cdecl _byteswap_ulong ( unsigned long _Number);
unsigned __int64 __cdecl _byteswap_uint64( unsigned __int64 _Number);
div_t __cdecl div ( int _Numerator, int _Denominator);
ldiv_t __cdecl ldiv ( long _Numerator, long _Denominator);
lldiv_t __cdecl lldiv( long long _Numerator, long long _Denominator);
#pragma warning (push)
#pragma warning (disable:6540)
unsigned int __cdecl _rotl(
unsigned int _Value,
int _Shift
unsigned long __cdecl _lrotl(
int _Shift
unsigned __int64 __cdecl _rotl64(
int _Shift
unsigned int __cdecl _rotr(
int _Shift
unsigned long __cdecl _lrotr(
int _Shift
unsigned __int64 __cdecl _rotr64(
int _Shift
#pragma warning (pop)
void __cdecl srand( unsigned int _Seed);
int __cdecl rand(void);
#line 348 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma pack(push, 4)
typedef struct
unsigned char ld[10];
} _LDOUBLE;
#pragma pack(pop)
#line 405 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
typedef struct
double x;
} _CRT_DOUBLE;
typedef struct
float f;
} _CRT_FLOAT;
typedef struct
long double x;
} _LONGDOUBLE;
typedef struct
unsigned char ld12[12];
} _LDBL12;
#pragma pack(pop)
double __cdecl atof ( char const* _String);
int __cdecl atoi ( char const* _String);
long __cdecl atol ( char const* _String);
long long __cdecl atoll ( char const* _String);
__int64 __cdecl _atoi64( char const* _String);
double __cdecl _atof_l ( char const* _String, _locale_t _Locale);
int __cdecl _atoi_l ( char const* _String, _locale_t _Locale);
long __cdecl _atol_l ( char const* _String, _locale_t _Locale);
long long __cdecl _atoll_l ( char const* _String, _locale_t _Locale);
__int64 __cdecl _atoi64_l( char const* _String, _locale_t _Locale);
int __cdecl _atoflt ( _CRT_FLOAT* _Result, char const* _String);
int __cdecl _atodbl ( _CRT_DOUBLE* _Result, char* _String);
int __cdecl _atoldbl( _LDOUBLE* _Result, char* _String);
int __cdecl _atoflt_l(
_locale_t _Locale
int __cdecl _atodbl_l(
char* _String,
_locale_t _Locale
int __cdecl _atoldbl_l(
_LDOUBLE* _Result,
char* _String,
_locale_t _Locale
float __cdecl strtof(
char** _EndPtr
float __cdecl _strtof_l(
char** _EndPtr,
_locale_t _Locale
double __cdecl strtod(
char** _EndPtr
double __cdecl _strtod_l(
char** _EndPtr,
_locale_t _Locale
long double __cdecl strtold(
char** _EndPtr
long double __cdecl _strtold_l(
char** _EndPtr,
_locale_t _Locale
long __cdecl strtol(
char** _EndPtr,
int _Radix
long __cdecl _strtol_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
long long __cdecl strtoll(
char** _EndPtr,
int _Radix
long long __cdecl _strtoll_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long __cdecl strtoul(
char** _EndPtr,
int _Radix
unsigned long __cdecl _strtoul_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long long __cdecl strtoull(
char** _EndPtr,
int _Radix
unsigned long long __cdecl _strtoull_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
__int64 __cdecl _strtoi64(
char** _EndPtr,
int _Radix
__int64 __cdecl _strtoi64_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned __int64 __cdecl _strtoui64(
char** _EndPtr,
int _Radix
unsigned __int64 __cdecl _strtoui64_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
errno_t __cdecl _itoa_s(
int _Value,
char* _Buffer,
int _Radix
#line 631 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _itoa( int _Value, char *_Buffer, int _Radix);
#line 638 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _ltoa_s(
long _Value,
char* _Buffer,
int _Radix
#line 654 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ltoa( long _Value, char *_Buffer, int _Radix);
#line 661 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _ultoa_s(
char* _Buffer,
int _Radix
#line 677 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ultoa( unsigned long _Value, char *_Buffer, int _Radix);
#line 684 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _i64toa_s(
__int64 _Value,
char* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _i64toa(
__int64 _Value,
char* _Buffer,
int _Radix
errno_t __cdecl _ui64toa_s(
char* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _ui64toa(
char* _Buffer,
int _Radix
errno_t __cdecl _ecvt_s(
char* _Buffer,
double _Value,
int _DigitCount,
int* _PtDec,
int* _PtSign
#line 749 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _ecvt(
double _Value,
int _DigitCount,
int* _PtDec,
int* _PtSign
errno_t __cdecl _fcvt_s(
char* _Buffer,
double _Value,
int _FractionalDigitCount,
int* _PtDec,
int* _PtSign
#line 778 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _fcvt(
double _Value,
int* _PtDec,
int* _PtSign
errno_t __cdecl _gcvt_s(
char* _Buffer,
double _Value,
int _DigitCount
#line 803 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_gcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _gcvt(
double _Value,
int _DigitCount,
char* _Buffer
#line 824 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 826 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 832 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl ___mb_cur_max_func(void);
int __cdecl ___mb_cur_max_l_func(_locale_t);
#line 839 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl mblen(
char const* _Ch,
size_t _MaxCount
int __cdecl _mblen_l(
char const* _Ch,
size_t _MaxCount,
_locale_t _Locale
size_t __cdecl _mbstrlen(
char const* _String
size_t __cdecl _mbstrlen_l(
_locale_t _Locale
size_t __cdecl _mbstrnlen(
size_t _MaxCount
size_t __cdecl _mbstrnlen_l(
size_t _MaxCount,
_locale_t _Locale
int __cdecl mbtowc(
wchar_t* _DstCh,
char const* _SrcCh,
size_t _SrcSizeInBytes
int __cdecl _mbtowc_l(
wchar_t* _DstCh,
char const* _SrcCh,
size_t _SrcSizeInBytes,
_locale_t _Locale
errno_t __cdecl mbstowcs_s(
size_t* _PtNumOfCharConverted,
wchar_t* _DstBuf,
size_t _SizeInWords,
char const* _SrcBuf,
size_t _MaxCount
#line 914 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "mbstowcs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl mbstowcs( wchar_t *_Dest, char const* _Source, size_t _MaxCount);
#line 921 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _mbstowcs_s_l(
wchar_t* _DstBuf,
size_t _MaxCount,
_locale_t _Locale
#line 940 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_mbstowcs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _mbstowcs_l( wchar_t *_Dest, char const* _Source, size_t _MaxCount, _locale_t _Locale);
#line 949 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wctomb_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
int __cdecl wctomb(
char* _MbCh,
wchar_t _WCh
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctomb_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
int __cdecl _wctomb_l(
char* _MbCh,
wchar_t _WCh,
_locale_t _Locale
errno_t __cdecl wctomb_s(
int* _SizeConverted,
char* _MbCh,
rsize_t _SizeInBytes,
wchar_t _WCh
#line 977 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _wctomb_s_l(
char* _MbCh,
wchar_t _WCh,
_locale_t _Locale);
errno_t __cdecl wcstombs_s(
char* _Dst,
size_t _DstSizeInBytes,
wchar_t const* _Src,
size_t _MaxCountInBytes
#line 1002 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstombs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl wcstombs( char *_Dest, wchar_t const* _Source, size_t _MaxCount);
#line 1009 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _wcstombs_s_l(
char* _Dst,
size_t _MaxCountInBytes,
_locale_t _Locale
#line 1028 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcstombs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _wcstombs_l( char *_Dest, wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale);
#line 1037 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(allocator) char* __cdecl _fullpath(
char* _Buffer,
char const* _Path,
size_t _BufferCount
errno_t __cdecl _makepath_s(
char* _Buffer,
char const* _Drive,
char const* _Dir,
char const* _Filename,
char const* _Ext
#line 1085 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_makepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _makepath( char *_Buffer, char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext);
#line 1094 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_splitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
void __cdecl _splitpath(
char const* _FullPath,
char* _Drive,
char* _Dir,
char* _Filename,
char* _Ext
errno_t __cdecl _splitpath_s(
char* _Drive,
size_t _DriveCount,
char* _Dir,
size_t _DirCount,
char* _Filename,
char* _Ext,
size_t _ExtCount
errno_t __cdecl getenv_s(
char* _Buffer,
rsize_t _BufferCount,
char const* _VarName
#line 1140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int* __cdecl __p___argc (void);
char*** __cdecl __p___argv (void);
wchar_t*** __cdecl __p___wargv(void);
#line 1157 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
char*** __cdecl __p__environ (void);
wchar_t*** __cdecl __p__wenviron(void);
#line 1164 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1174 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_dupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl getenv(
#line 1193 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1198 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _dupenv_s(
char** _Buffer,
#line 1209 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl system(
char const* _Command
int __cdecl _putenv(
char const* _EnvString
errno_t __cdecl _putenv_s(
char const* _Name,
char const* _Value
errno_t __cdecl _searchenv_s(
char const* _VarName,
char* _Buffer,
size_t _BufferCount
#line 1245 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_searchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _searchenv( char const* _Filename, char const* _VarName, char *_Buffer);
#line 1252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetErrorMode" " " "instead. See online help for details."))
void __cdecl _seterrormode(
int _Mode
__declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Beep" " " "instead. See online help for details."))
void __cdecl _beep(
unsigned _Frequency,
unsigned _Duration
__declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Sleep" " " "instead. See online help for details."))
void __cdecl _sleep(
unsigned long _Duration
#line 1271 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1285 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma warning(push)
#pragma warning(disable: 4141)
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ecvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl ecvt(
double _Value,
int _DigitCount,
int* _PtDec,
int* _PtSign
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_fcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl fcvt(
double _Value,
int* _PtDec,
int* _PtSign
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_gcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl gcvt(
double _Value,
int _DigitCount,
char* _DstBuf
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_itoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl itoa(
int _Value,
char* _Buffer,
int _Radix
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ltoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl ltoa(
long _Value,
char* _Buffer,
int _Radix
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_swab" ". See online help for details."))
void __cdecl swab(
char* _Buf1,
char* _Buf2,
int _SizeInBytes
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ultoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl ultoa(
char* _Buffer,
int _Radix
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_putenv" ". See online help for details."))
int __cdecl putenv(
#line 1354 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma warning(pop)
_onexit_t __cdecl onexit( _onexit_t _Func);
#line 1360 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__pragma(pack(pop))
#line 4 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Popping language C
TEST checkCUDACompiler from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:642)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:642)
Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:682)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:682)
Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:794)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:794)
Locate a functional Cxx compiler
Checking for program /usr/local/bin/win32fe...not found
Checking for program /usr/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/win32fe...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/win32fe...not found
Checking for program /cygdrive/c/Windows/system32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/win32fe...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/win32fe...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe...found
Defined make macro "CXX" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl"
Pushing language Cxx
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.cc
stdout:
cl : Command line warning D9002 : ignoring unknown option '-QxHost'
cl : Command line warning D9002 : ignoring unknown option '-debug'
cl : Command line warning D9002 : ignoring unknown option '-O3'
conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
stdout:
conftest.cc
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Popping language Cxx
Pushing language FC
Popping language FC
Pushing language CXX
Popping language CXX
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o
stdout:
stdout:
conftest.cc
Successful compile:
Source:
int main() {
return 0;
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
Possible ERROR while running linker: exit code 512
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
return 0;
stdout:
Testing executable /tmp/petsc-ytughc/config.setCompilers/conftest.exe to see if it can be run
Executing: /tmp/petsc-ytughc/config.setCompilers/conftest.exe
TEST checkCxxPreprocessor from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:832)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:832)
Locate a functional Cxx preprocessor
Defined make macro "CXXCPP" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -E"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -E -I/tmp/petsc-ytughc/config.setCompilers /tmp/petsc-ytughc/config.setCompilers/conftest.cc
stdout:
conftest.cc
#line 1 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.cc"
#line 1 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 7 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 11 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 13 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\confdefs.h"
#line 2 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.cc"
#line 1 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
extern "C" {
#line 9 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
#line 10 "c:\\cygwin64\\tmp\\petsc-ytughc\\config.setcompilers\\conffix.h"
#line 3 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.cc"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
#pragma once
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#pragma once
#line 91 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#line 252 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#line 253 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#line 255 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#line 257 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#line 258 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\xkeycheck.h"
#line 8 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 34 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 39 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 40 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 41 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#pragma once
#line 151 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 155 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 185 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 188 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 190 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 196 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 200 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 207 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 219 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 228 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 229 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1586 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1611 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1624 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1663 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1775 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1878 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2047 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2149 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2361 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
extern "C" {
#line 2367 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2595 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2634 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2868 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2878 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2883 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2890 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2891 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2898 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2899 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2911 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2945 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 2969 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#pragma once
extern "C" {
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 265 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 269 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 352 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 356 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 358 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\ConcurrencySal.h"
#line 2971 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\sal.h"
#line 46 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#pragma once
#pragma pack(push, 8)
extern "C" {
#line 20 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
typedef unsigned __int64 uintptr_t;
#line 32 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 33 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
typedef char* va_list;
#line 41 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 42 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 48 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 54 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 58 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 61 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 73 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 81 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 93 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 105 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
void __cdecl __va_start(va_list* , ...);
#line 116 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#line 120 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
extern "C++"
template <typename _Ty>
struct __vcrt_va_list_is_reference
enum : bool { __the_value = false };
struct __vcrt_va_list_is_reference<_Ty&>
enum : bool { __the_value = true };
struct __vcrt_va_list_is_reference<_Ty&&>
void __vcrt_va_start_verify_argument_type() throw()
static_assert(!__vcrt_va_list_is_reference<_Ty>::__the_value, "va_start argument must not have reference type and must not be parenthesized");
#line 156 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vadefs.h"
#pragma pack(pop)
#line 47 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 80 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
__pragma(pack(push, 8)) extern "C" {
#line 88 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 109 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 111 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 113 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 115 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 117 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 118 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 127 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 129 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 130 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 138 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 140 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 146 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 149 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 155 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 167 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 171 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 173 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 179 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 187 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 188 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
typedef unsigned __int64 size_t;
typedef __int64 ptrdiff_t;
typedef __int64 intptr_t;
#line 202 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
typedef bool __vcrt_bool;
#line 212 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 217 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 221 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 225 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 238 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 239 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 245 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
extern "C++"
template <typename _CountofType, size_t _SizeOfArray>
char (*__countof_helper(__unaligned _CountofType (&_Array)[_SizeOfArray]))[_SizeOfArray];
#line 257 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 264 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 275 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 276 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 280 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 288 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 289 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
void __cdecl __security_init_cookie(void);
void __cdecl __security_check_cookie( uintptr_t _StackCookie);
__declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
#line 307 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 308 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
extern uintptr_t __security_cookie;
#line 316 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
} __pragma(pack(pop))
#line 320 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\vcruntime.h"
#line 10 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#pragma once
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 25 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 27 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 29 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 36 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 41 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 43 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 58 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 64 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 73 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 91 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 92 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 96 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 102 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 104 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 108 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 110 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
extern "C++"
template<bool _Enable, typename _Ty>
struct _CrtEnableIf;
template<typename _Ty>
struct _CrtEnableIf<true, _Ty>
typedef _Ty _Type;
#line 131 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef bool __crt_bool;
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 149 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 161 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 165 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 188 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 189 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 193 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 200 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 201 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
void __cdecl _invalid_parameter_noinfo(void);
__declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
void __cdecl _invoke_watson(
wchar_t const*,
wchar_t const*,
wchar_t const*,
unsigned int,
uintptr_t);
#line 256 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 257 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 268 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 277 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 278 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 296 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 297 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 304 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 305 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 309 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 323 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 345 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 349 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 354 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 355 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 365 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 366 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 367 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 371 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 377 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 387 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 388 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 397 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 407 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 414 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 419 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 427 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 435 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 436 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 440 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef int errno_t;
typedef unsigned short wint_t;
typedef unsigned short wctype_t;
typedef long __time32_t;
typedef __int64 __time64_t;
typedef struct __crt_locale_data_public
unsigned short const* _locale_pctype;
int _locale_mb_cur_max;
unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
struct __crt_locale_data* locinfo;
struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
unsigned long _Wchar;
unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
#line 480 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 484 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef __time64_t time_t;
#line 491 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 492 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 497 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
typedef size_t rsize_t;
#line 501 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 677 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 678 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 1753 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 1897 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 1898 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt.h"
#line 11 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 23 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 25 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 27 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 28 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 33 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 36 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 38 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 39 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 40 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 45 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 48 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 50 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 51 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 52 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 57 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 59 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 62 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 64 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 65 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 66 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\crtdefs.h"
#line 9 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#pragma pack(push,8)
#line 22 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 23 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 31 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 50 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 52 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 59 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 60 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 66 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 68 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 69 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 75 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 77 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 78 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 84 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 86 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 87 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 93 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 95 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 96 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 102 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 104 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 105 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 137 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 139 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 156 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 157 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 158 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 167 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 222 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 223 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 233 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 235 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 236 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 241 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 243 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 245 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 247 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#pragma detect_mismatch("_MSC_VER", "1900")
#line 255 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#pragma detect_mismatch("_ITERATOR_DEBUG_LEVEL", "0")
#line 259 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#pragma detect_mismatch("RuntimeLibrary", "MT_StaticRelease")
#line 270 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 271 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 272 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 285 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 286 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 291 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 296 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 298 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 299 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 311 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 313 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 317 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 385 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 391 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 394 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 399 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 411 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#pragma once
#line 24 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 41 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 45 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 50 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 51 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 56 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#pragma comment(lib, "libcpmt" "" "")
#line 65 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 67 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 69 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\use_ansi.h"
#line 413 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 417 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 421 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 443 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 445 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 446 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 451 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 453 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 454 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 459 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 461 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 462 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 472 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 477 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 479 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 481 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 482 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 486 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 491 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 496 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 497 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 498 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 529 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 530 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 557 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 577 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
typedef long long _Longlong;
typedef unsigned long long _ULonglong;
namespace std {
enum _Uninitialized
_Noinit
#pragma warning(disable:4412)
class _Lockit
public:
#line 644 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
__thiscall _Lockit();
explicit __thiscall _Lockit(int);
__thiscall ~_Lockit() noexcept;
#line 648 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
static void __cdecl _Lockit_ctor(int);
static void __cdecl _Lockit_dtor(int);
private:
static void __cdecl _Lockit_ctor(_Lockit *);
static void __cdecl _Lockit_ctor(_Lockit *, int);
static void __cdecl _Lockit_dtor(_Lockit *);
public:
_Lockit(const _Lockit&) = delete;
_Lockit& operator=(const _Lockit&) = delete;
private:
int _Locktype;
#line 677 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 763 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
class _Init_locks
public:
#line 780 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
__thiscall _Init_locks();
__thiscall ~_Init_locks() noexcept;
#line 783 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
private:
static void __cdecl _Init_locks_ctor(_Init_locks *);
static void __cdecl _Init_locks_dtor(_Init_locks *);
#line 797 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 802 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
void __cdecl _Atexit(void (__cdecl *)(void));
typedef unsigned long _Uint32t;
#pragma pack(pop)
#line 819 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 820 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\yvals.h"
#line 6 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_malloc.h"
__declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
size_t _Count,
size_t _Size
void* __cdecl calloc(
size_t _Count,
size_t _Size
int __cdecl _callnewh(
size_t _Size
void* __cdecl _expand(
void* _Block,
size_t _Size
void __cdecl _free_base(
void* _Block
void __cdecl free(
void* _Block
void* __cdecl _malloc_base(
size_t _Size
void* __cdecl malloc(
size_t _Size
size_t __cdecl _msize(
void* _Block
void* __cdecl _realloc_base(
void* _Block,
size_t _Size
void* __cdecl realloc(
void* _Block,
size_t _Size
void* __cdecl _recalloc(
void* _Block,
size_t _Count,
size_t _Size
void __cdecl _aligned_free(
void* _Block
void* __cdecl _aligned_malloc(
size_t _Size,
size_t _Alignment
void* __cdecl _aligned_offset_malloc(
size_t _Size,
size_t _Alignment,
size_t _Offset
size_t __cdecl _aligned_msize(
void* _Block,
size_t _Alignment,
size_t _Offset
void* __cdecl _aligned_offset_realloc(
void* _Block,
size_t _Size,
size_t _Alignment,
size_t _Offset
void* __cdecl _aligned_offset_recalloc(
void* _Block,
size_t _Count,
size_t _Size,
size_t _Alignment,
size_t _Offset
void* __cdecl _aligned_realloc(
void* _Block,
size_t _Size,
size_t _Alignment
void* __cdecl _aligned_recalloc(
void* _Block,
size_t _Count,
size_t _Size,
size_t _Alignment
#line 211 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_malloc.h"
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
#pragma once
namespace std
typedef decltype(__nullptr) nullptr_t;
using ::std::nullptr_t;
#line 25 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
int* __cdecl _errno(void);
errno_t __cdecl _set_errno( int _Value);
errno_t __cdecl _get_errno( int* _Value);
#line 42 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
#line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stddef.h"
extern unsigned long __cdecl __threadid(void);
extern uintptr_t __cdecl __threadhandle(void);
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
void* __cdecl bsearch_s(
void const* _Key,
void const* _Base,
rsize_t _NumOfElements,
rsize_t _SizeOfElements,
int (__cdecl* _PtFuncCompare)(void*, void const*, void const*),
void* _Context
void __cdecl qsort_s(
void* _Base,
void* _Context
#line 41 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
void* __cdecl bsearch(
void const* _Key,
void const* _Base,
int (__cdecl* _PtFuncCompare)(void const*, void const*)
void __cdecl qsort(
void* _Base,
void* __cdecl _lfind_s(
void const* _Key,
void const* _Base,
unsigned int* _NumOfElements,
void* _Context
void* __cdecl _lfind(
void const* _Key,
void const* _Base,
unsigned int _SizeOfElements,
void* __cdecl _lsearch_s(
void const* _Key,
void* _Base,
void* _Context
void* __cdecl _lsearch(
void const* _Key,
void* _Base,
#line 179 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lfind" ". See online help for details."))
void* __cdecl lfind(
void const* _Key,
void const* _Base,
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lsearch" ". See online help for details."))
void* __cdecl lsearch(
void const* _Key,
void* _Base,
#line 203 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_search.h"
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
#pragma once
errno_t __cdecl _itow_s(
int _Value,
wchar_t* _Buffer,
int _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _itow_s( int _Value, wchar_t (&_Buffer)[_Size], int _Radix) throw() { return _itow_s(_Value, _Buffer, _Size, _Radix); } }
#line 61 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _itow( int _Value, wchar_t *_Buffer, int _Radix);
#line 68 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
errno_t __cdecl _ltow_s(
long _Value,
wchar_t* _Buffer,
int _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ltow_s( long _Value, wchar_t (&_Buffer)[_Size], int _Radix) throw() { return _ltow_s(_Value, _Buffer, _Size, _Radix); } }
#line 84 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ltow( long _Value, wchar_t *_Buffer, int _Radix);
#line 91 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
errno_t __cdecl _ultow_s(
unsigned long _Value,
wchar_t* _Buffer,
int _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ultow_s( unsigned long _Value, wchar_t (&_Buffer)[_Size], int _Radix) throw() { return _ultow_s(_Value, _Buffer, _Size, _Radix); } }
#line 106 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ultow( unsigned long _Value, wchar_t *_Buffer, int _Radix);
#line 113 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
double __cdecl wcstod(
wchar_t const* _String,
wchar_t** _EndPtr
double __cdecl _wcstod_l(
wchar_t** _EndPtr,
_locale_t _Locale
long __cdecl wcstol(
wchar_t** _EndPtr,
int _Radix
long __cdecl _wcstol_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
long long __cdecl wcstoll(
wchar_t** _EndPtr,
int _Radix
long long __cdecl _wcstoll_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long __cdecl wcstoul(
wchar_t** _EndPtr,
int _Radix
unsigned long __cdecl _wcstoul_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long long __cdecl wcstoull(
wchar_t** _EndPtr,
int _Radix
unsigned long long __cdecl _wcstoull_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
long double __cdecl wcstold(
wchar_t** _EndPtr
long double __cdecl _wcstold_l(
wchar_t** _EndPtr,
_locale_t _Locale
float __cdecl wcstof(
wchar_t** _EndPtr
float __cdecl _wcstof_l(
wchar_t** _EndPtr,
_locale_t _Locale
double __cdecl _wtof(
double __cdecl _wtof_l(
_locale_t _Locale
int __cdecl _wtoi(
int __cdecl _wtoi_l(
_locale_t _Locale
long __cdecl _wtol(
long __cdecl _wtol_l(
_locale_t _Locale
long long __cdecl _wtoll(
long long __cdecl _wtoll_l(
_locale_t _Locale
errno_t __cdecl _i64tow_s(
__int64 _Value,
wchar_t* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
wchar_t* __cdecl _i64tow(
__int64 _Value,
wchar_t* _Buffer,
int _Radix
errno_t __cdecl _ui64tow_s(
unsigned __int64 _Value,
wchar_t* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
wchar_t* __cdecl _ui64tow(
wchar_t* _Buffer,
int _Radix
__int64 __cdecl _wtoi64(
__int64 __cdecl _wtoi64_l(
_locale_t _Locale
__int64 __cdecl _wcstoi64(
wchar_t** _EndPtr,
int _Radix
__int64 __cdecl _wcstoi64_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned __int64 __cdecl _wcstoui64(
wchar_t** _EndPtr,
int _Radix
unsigned __int64 __cdecl _wcstoui64_l(
wchar_t** _EndPtr,
int _Radix,
_locale_t _Locale
__declspec(allocator) wchar_t* __cdecl _wfullpath(
wchar_t* _Buffer,
wchar_t const* _Path,
size_t _BufferCount
errno_t __cdecl _wmakepath_s(
wchar_t* _Buffer,
wchar_t const* _Drive,
wchar_t const* _Dir,
wchar_t const* _Filename,
wchar_t const* _Ext
extern "C++" { template <size_t _Size> inline errno_t __cdecl _wmakepath_s(wchar_t (&_Buffer)[_Size], wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext) throw() { return _wmakepath_s(_Buffer, _Size, _Drive, _Dir, _Filename, _Ext); } }
#line 359 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wmakepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wmakepath( wchar_t *_Buffer, wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext);
#line 368 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
void __cdecl _wperror(
wchar_t const* _ErrMsg
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsplitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
void __cdecl _wsplitpath(
wchar_t const* _FullPath,
wchar_t* _Drive,
wchar_t* _Dir,
wchar_t* _Filename,
wchar_t* _Ext
errno_t __cdecl _wsplitpath_s(
wchar_t* _Drive,
size_t _DriveCount,
wchar_t* _Dir,
size_t _DirCount,
wchar_t* _Filename,
size_t _FilenameCount,
wchar_t* _Ext,
size_t _ExtCount
extern "C++" { template <size_t _DriveSize, size_t _DirSize, size_t _NameSize, size_t _ExtSize> inline errno_t __cdecl _wsplitpath_s( wchar_t const* _Path, wchar_t (&_Drive)[_DriveSize], wchar_t (&_Dir)[_DirSize], wchar_t (&_Name)[_NameSize], wchar_t (&_Ext)[_ExtSize] ) throw() { return _wsplitpath_s(_Path, _Drive, _DriveSize, _Dir, _DirSize, _Name, _NameSize, _Ext, _ExtSize); } }
#line 398 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
errno_t __cdecl _wdupenv_s(
wchar_t** _Buffer,
size_t* _BufferCount,
wchar_t const* _VarName
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wdupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
wchar_t* __cdecl _wgetenv(
errno_t __cdecl _wgetenv_s(
size_t* _RequiredCount,
wchar_t* _Buffer,
size_t _BufferCount,
extern "C++" { template <size_t _Size> inline errno_t __cdecl _wgetenv_s( size_t* _RequiredCount, wchar_t (&_Buffer)[_Size], wchar_t const* _VarName) throw() { return _wgetenv_s(_RequiredCount, _Buffer, _Size, _VarName); } }
#line 436 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
int __cdecl _wputenv(
wchar_t const* _EnvString
errno_t __cdecl _wputenv_s(
wchar_t const* _Name,
wchar_t const* _Value
errno_t __cdecl _wsearchenv_s(
wchar_t const* _VarName,
wchar_t* _Buffer,
size_t _BufferCount
extern "C++" { template <size_t _Size> inline errno_t __cdecl _wsearchenv_s( wchar_t const* _Filename, wchar_t const* _VarName, wchar_t (&_ResultPath)[_Size]) throw() { return _wsearchenv_s(_Filename, _VarName, _ResultPath, _Size); } }
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsearchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wsearchenv( wchar_t const* _Filename, wchar_t const* _VarName, wchar_t *_ResultPath);
#line 468 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
int __cdecl _wsystem(
wchar_t const* _Command
#line 474 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\corecrt_wstdlib.h"
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#pragma once
#line 12 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 29 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 71 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 78 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 79 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 84 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 85 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\limits.h"
#line 16 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 24 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
void __cdecl _swab(
char* _Buf1,
char* _Buf2,
int _SizeInBytes
__declspec(noreturn) void __cdecl exit( int _Code);
__declspec(noreturn) void __cdecl _exit( int _Code);
__declspec(noreturn) void __cdecl _Exit( int _Code);
__declspec(noreturn) void __cdecl quick_exit( int _Code);
__declspec(noreturn) void __cdecl abort(void);
unsigned int __cdecl _set_abort_behavior(
unsigned int _Flags,
unsigned int _Mask
typedef int (__cdecl* _onexit_t)(void);
#line 73 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 82 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl atexit(void (__cdecl*)(void));
_onexit_t __cdecl _onexit( _onexit_t _Func);
#line 142 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl at_quick_exit(void (__cdecl*)(void));
typedef void (__cdecl* _purecall_handler)(void);
typedef void (__cdecl* _invalid_parameter_handler)(
wchar_t const*,
wchar_t const*,
wchar_t const*,
unsigned int,
uintptr_t
_purecall_handler __cdecl _set_purecall_handler(
_purecall_handler _Handler
_purecall_handler __cdecl _get_purecall_handler(void);
_invalid_parameter_handler __cdecl _set_invalid_parameter_handler(
_invalid_parameter_handler _Handler
_invalid_parameter_handler __cdecl _get_invalid_parameter_handler(void);
_invalid_parameter_handler __cdecl _set_thread_local_invalid_parameter_handler(
_invalid_parameter_handler __cdecl _get_thread_local_invalid_parameter_handler(void);
#line 185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 198 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl _set_error_mode( int _Mode);
unsigned long* __cdecl __doserrno(void);
errno_t __cdecl _set_doserrno( unsigned long _Value);
errno_t __cdecl _get_doserrno( unsigned long * _Value);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __sys_errlist(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int * __cdecl __sys_nerr(void);
void __cdecl perror( char const* _ErrMsg);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_pgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __p__pgmptr (void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_wpgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t** __cdecl __p__wpgmptr(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_fmode" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int* __cdecl __p__fmode (void);
#line 248 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _get_pgmptr ( char** _Value);
errno_t __cdecl _get_wpgmptr( wchar_t** _Value);
errno_t __cdecl _set_fmode ( int _Mode );
errno_t __cdecl _get_fmode ( int* _PMode);
typedef struct _div_t
int quot;
int rem;
} div_t;
typedef struct _ldiv_t
long quot;
long rem;
} ldiv_t;
typedef struct _lldiv_t
long long quot;
long long rem;
} lldiv_t;
int __cdecl abs ( int _Number);
long __cdecl labs ( long _Number);
long long __cdecl llabs ( long long _Number);
__int64 __cdecl _abs64( __int64 _Number);
unsigned short __cdecl _byteswap_ushort( unsigned short _Number);
unsigned long __cdecl _byteswap_ulong ( unsigned long _Number);
unsigned __int64 __cdecl _byteswap_uint64( unsigned __int64 _Number);
div_t __cdecl div ( int _Numerator, int _Denominator);
ldiv_t __cdecl ldiv ( long _Numerator, long _Denominator);
lldiv_t __cdecl lldiv( long long _Numerator, long long _Denominator);
#pragma warning (push)
#pragma warning (disable:6540)
unsigned int __cdecl _rotl(
unsigned int _Value,
int _Shift
unsigned long __cdecl _lrotl(
int _Shift
unsigned __int64 __cdecl _rotl64(
int _Shift
unsigned int __cdecl _rotr(
int _Shift
unsigned long __cdecl _lrotr(
int _Shift
unsigned __int64 __cdecl _rotr64(
int _Shift
#pragma warning (pop)
void __cdecl srand( unsigned int _Seed);
int __cdecl rand(void);
#line 348 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
extern "C++"
inline long abs(long const _X) throw()
return labs(_X);
inline long long abs(long long const _X) throw()
return llabs(_X);
inline ldiv_t div(long const _A1, long const _A2) throw()
return ldiv(_A1, _A2);
inline lldiv_t div(long long const _A1, long long const _A2) throw()
return lldiv(_A1, _A2);
#line 375 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma pack(push, 4)
typedef struct
unsigned char ld[10];
} _LDOUBLE;
#pragma pack(pop)
#line 405 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
typedef struct
double x;
} _CRT_DOUBLE;
typedef struct
float f;
} _CRT_FLOAT;
typedef struct
long double x;
} _LONGDOUBLE;
typedef struct
unsigned char ld12[12];
} _LDBL12;
#pragma pack(pop)
double __cdecl atof ( char const* _String);
int __cdecl atoi ( char const* _String);
long __cdecl atol ( char const* _String);
long long __cdecl atoll ( char const* _String);
__int64 __cdecl _atoi64( char const* _String);
double __cdecl _atof_l ( char const* _String, _locale_t _Locale);
int __cdecl _atoi_l ( char const* _String, _locale_t _Locale);
long __cdecl _atol_l ( char const* _String, _locale_t _Locale);
long long __cdecl _atoll_l ( char const* _String, _locale_t _Locale);
__int64 __cdecl _atoi64_l( char const* _String, _locale_t _Locale);
int __cdecl _atoflt ( _CRT_FLOAT* _Result, char const* _String);
int __cdecl _atodbl ( _CRT_DOUBLE* _Result, char* _String);
int __cdecl _atoldbl( _LDOUBLE* _Result, char* _String);
int __cdecl _atoflt_l(
_locale_t _Locale
int __cdecl _atodbl_l(
char* _String,
_locale_t _Locale
int __cdecl _atoldbl_l(
_LDOUBLE* _Result,
char* _String,
_locale_t _Locale
float __cdecl strtof(
char** _EndPtr
float __cdecl _strtof_l(
char** _EndPtr,
_locale_t _Locale
double __cdecl strtod(
char** _EndPtr
double __cdecl _strtod_l(
char** _EndPtr,
_locale_t _Locale
long double __cdecl strtold(
char** _EndPtr
long double __cdecl _strtold_l(
char** _EndPtr,
_locale_t _Locale
long __cdecl strtol(
char** _EndPtr,
int _Radix
long __cdecl _strtol_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
long long __cdecl strtoll(
char** _EndPtr,
int _Radix
long long __cdecl _strtoll_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long __cdecl strtoul(
char** _EndPtr,
int _Radix
unsigned long __cdecl _strtoul_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned long long __cdecl strtoull(
char** _EndPtr,
int _Radix
unsigned long long __cdecl _strtoull_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
__int64 __cdecl _strtoi64(
char** _EndPtr,
int _Radix
__int64 __cdecl _strtoi64_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
unsigned __int64 __cdecl _strtoui64(
char** _EndPtr,
int _Radix
unsigned __int64 __cdecl _strtoui64_l(
char** _EndPtr,
int _Radix,
_locale_t _Locale
errno_t __cdecl _itoa_s(
int _Value,
char* _Buffer,
int _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _itoa_s( int _Value, char (&_Buffer)[_Size], int _Radix) throw() { return _itoa_s(_Value, _Buffer, _Size, _Radix); } }
#line 631 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _itoa( int _Value, char *_Buffer, int _Radix);
#line 638 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _ltoa_s(
long _Value,
char* _Buffer,
int _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ltoa_s( long _Value, char (&_Buffer)[_Size], int _Radix) throw() { return _ltoa_s(_Value, _Buffer, _Size, _Radix); } }
#line 654 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ltoa( long _Value, char *_Buffer, int _Radix);
#line 661 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _ultoa_s(
char* _Buffer,
int _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ultoa_s( unsigned long _Value, char (&_Buffer)[_Size], int _Radix) throw() { return _ultoa_s(_Value, _Buffer, _Size, _Radix); } }
#line 677 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ultoa( unsigned long _Value, char *_Buffer, int _Radix);
#line 684 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _i64toa_s(
__int64 _Value,
char* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _i64toa(
__int64 _Value,
char* _Buffer,
int _Radix
errno_t __cdecl _ui64toa_s(
char* _Buffer,
int _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _ui64toa(
char* _Buffer,
int _Radix
errno_t __cdecl _ecvt_s(
char* _Buffer,
double _Value,
int _DigitCount,
int* _PtDec,
int* _PtSign
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ecvt_s(char (&_Buffer)[_Size], double _Value, int _DigitCount, int* _PtDec, int* _PtSign) throw() { return _ecvt_s(_Buffer, _Size, _Value, _DigitCount, _PtDec, _PtSign); } }
#line 749 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _ecvt(
double _Value,
int _DigitCount,
int* _PtDec,
int* _PtSign
errno_t __cdecl _fcvt_s(
char* _Buffer,
double _Value,
int _FractionalDigitCount,
int* _PtDec,
int* _PtSign
extern "C++" { template <size_t _Size> inline errno_t __cdecl _fcvt_s(char (&_Buffer)[_Size], double _Value, int _FractionalDigitCount, int* _PtDec, int* _PtSign) throw() { return _fcvt_s(_Buffer, _Size, _Value, _FractionalDigitCount, _PtDec, _PtSign); } }
#line 778 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _fcvt(
double _Value,
int* _PtDec,
int* _PtSign
errno_t __cdecl _gcvt_s(
char* _Buffer,
double _Value,
int _DigitCount
extern "C++" { template <size_t _Size> inline errno_t __cdecl _gcvt_s(char (&_Buffer)[_Size], double _Value, int _DigitCount) throw() { return _gcvt_s(_Buffer, _Size, _Value, _DigitCount); } }
#line 803 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_gcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl _gcvt(
double _Value,
int _DigitCount,
char* _Buffer
#line 824 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 826 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 832 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl ___mb_cur_max_func(void);
int __cdecl ___mb_cur_max_l_func(_locale_t);
#line 839 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl mblen(
char const* _Ch,
size_t _MaxCount
int __cdecl _mblen_l(
char const* _Ch,
size_t _MaxCount,
_locale_t _Locale
size_t __cdecl _mbstrlen(
char const* _String
size_t __cdecl _mbstrlen_l(
_locale_t _Locale
size_t __cdecl _mbstrnlen(
size_t _MaxCount
size_t __cdecl _mbstrnlen_l(
size_t _MaxCount,
_locale_t _Locale
int __cdecl mbtowc(
wchar_t* _DstCh,
char const* _SrcCh,
size_t _SrcSizeInBytes
int __cdecl _mbtowc_l(
wchar_t* _DstCh,
char const* _SrcCh,
size_t _SrcSizeInBytes,
_locale_t _Locale
errno_t __cdecl mbstowcs_s(
size_t* _PtNumOfCharConverted,
wchar_t* _DstBuf,
size_t _SizeInWords,
char const* _SrcBuf,
size_t _MaxCount
extern "C++" { template <size_t _Size> inline errno_t __cdecl mbstowcs_s( size_t* _PtNumOfCharConverted, wchar_t (&_Dest)[_Size], char const* _Source, size_t _MaxCount) throw() { return mbstowcs_s(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount); } }
#line 914 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "mbstowcs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl mbstowcs( wchar_t *_Dest, char const* _Source, size_t _MaxCount);
#line 921 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _mbstowcs_s_l(
wchar_t* _DstBuf,
size_t _MaxCount,
_locale_t _Locale
extern "C++" { template <size_t _Size> inline errno_t __cdecl _mbstowcs_s_l( size_t* _PtNumOfCharConverted, wchar_t (&_Dest)[_Size], char const* _Source, size_t _MaxCount, _locale_t _Locale) throw() { return _mbstowcs_s_l(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount, _Locale); } }
#line 940 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_mbstowcs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _mbstowcs_l( wchar_t *_Dest, char const* _Source, size_t _MaxCount, _locale_t _Locale);
#line 949 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wctomb_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
int __cdecl wctomb(
char* _MbCh,
wchar_t _WCh
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctomb_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
int __cdecl _wctomb_l(
char* _MbCh,
wchar_t _WCh,
_locale_t _Locale
errno_t __cdecl wctomb_s(
int* _SizeConverted,
char* _MbCh,
rsize_t _SizeInBytes,
wchar_t _WCh
#line 977 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _wctomb_s_l(
char* _MbCh,
wchar_t _WCh,
_locale_t _Locale);
errno_t __cdecl wcstombs_s(
char* _Dst,
size_t _DstSizeInBytes,
wchar_t const* _Src,
size_t _MaxCountInBytes
extern "C++" { template <size_t _Size> inline errno_t __cdecl wcstombs_s( size_t* _PtNumOfCharConverted, char (&_Dest)[_Size], wchar_t const* _Source, size_t _MaxCount) throw() { return wcstombs_s(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount); } }
#line 1002 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstombs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl wcstombs( char *_Dest, wchar_t const* _Source, size_t _MaxCount);
#line 1009 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _wcstombs_s_l(
char* _Dst,
size_t _MaxCountInBytes,
_locale_t _Locale
extern "C++" { template <size_t _Size> inline errno_t __cdecl _wcstombs_s_l( size_t* _PtNumOfCharConverted, char (&_Dest)[_Size], wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale) throw() { return _wcstombs_s_l(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount, _Locale); } }
#line 1028 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcstombs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _wcstombs_l( char *_Dest, wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale);
#line 1037 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(allocator) char* __cdecl _fullpath(
char* _Buffer,
char const* _Path,
size_t _BufferCount
errno_t __cdecl _makepath_s(
char* _Buffer,
char const* _Drive,
char const* _Dir,
char const* _Filename,
char const* _Ext
extern "C++" { template <size_t _Size> inline errno_t __cdecl _makepath_s(char (&_Buffer)[_Size], char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext) throw() { return _makepath_s(_Buffer, _Size, _Drive, _Dir, _Filename, _Ext); } }
#line 1085 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_makepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _makepath( char *_Buffer, char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext);
#line 1094 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_splitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
void __cdecl _splitpath(
char const* _FullPath,
char* _Drive,
char* _Dir,
char* _Filename,
char* _Ext
errno_t __cdecl _splitpath_s(
char* _Drive,
size_t _DriveCount,
char* _Dir,
size_t _DirCount,
char* _Filename,
char* _Ext,
size_t _ExtCount
extern "C++" { template <size_t _DriveSize, size_t _DirSize, size_t _NameSize, size_t _ExtSize> inline errno_t __cdecl _splitpath_s( char const* _Dest, char (&_Drive)[_DriveSize], char (&_Dir)[_DirSize], char (&_Name)[_NameSize], char (&_Ext)[_ExtSize] ) throw() { return _splitpath_s(_Dest, _Drive, _DriveSize, _Dir, _DirSize, _Name, _NameSize, _Ext, _ExtSize); } }
errno_t __cdecl getenv_s(
char* _Buffer,
rsize_t _BufferCount,
char const* _VarName
#line 1140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int* __cdecl __p___argc (void);
char*** __cdecl __p___argv (void);
wchar_t*** __cdecl __p___wargv(void);
#line 1157 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
char*** __cdecl __p__environ (void);
wchar_t*** __cdecl __p__wenviron(void);
#line 1164 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1174 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_dupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl getenv(
extern "C++" { template <size_t _Size> inline errno_t __cdecl getenv_s( size_t* _RequiredCount, char (&_Buffer)[_Size], char const* _VarName) throw() { return getenv_s(_RequiredCount, _Buffer, _Size, _VarName); } }
#line 1193 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 1198 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
errno_t __cdecl _dupenv_s(
char** _Buffer,
#line 1209 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
int __cdecl system(
char const* _Command
int __cdecl _putenv(
char const* _EnvString
errno_t __cdecl _putenv_s(
char const* _Name,
char const* _Value
errno_t __cdecl _searchenv_s(
char const* _VarName,
char* _Buffer,
size_t _BufferCount
extern "C++" { template <size_t _Size> inline errno_t __cdecl _searchenv_s( char const* _Filename, char const* _VarName, char (&_Buffer)[_Size]) throw() { return _searchenv_s(_Filename, _VarName, _Buffer, _Size); } }
#line 1245 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_searchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _searchenv( char const* _Filename, char const* _VarName, char *_Buffer);
#line 1252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
__declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetErrorMode" " " "instead. See online help for details."))
void __cdecl _seterrormode(
int _Mode
__declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Beep" " " "instead. See online help for details."))
void __cdecl _beep(
unsigned _Frequency,
unsigned _Duration
__declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Sleep" " " "instead. See online help for details."))
void __cdecl _sleep(
unsigned long _Duration
#line 1271 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma warning(push)
#pragma warning(disable: 4141)
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ecvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl ecvt(
double _Value,
int _DigitCount,
int* _PtDec,
int* _PtSign
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_fcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl fcvt(
double _Value,
int* _PtDec,
int* _PtSign
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_gcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl gcvt(
double _Value,
int _DigitCount,
char* _DstBuf
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_itoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl itoa(
int _Value,
char* _Buffer,
int _Radix
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ltoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl ltoa(
long _Value,
char* _Buffer,
int _Radix
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_swab" ". See online help for details."))
void __cdecl swab(
char* _Buf1,
char* _Buf2,
int _SizeInBytes
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ultoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
char* __cdecl ultoa(
char* _Buffer,
int _Radix
__declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_putenv" ". See online help for details."))
int __cdecl putenv(
#line 1354 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#pragma warning(pop)
_onexit_t __cdecl onexit( _onexit_t _Func);
#line 1360 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.10240.0\\ucrt\\stdlib.h"
#line 14 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
#line 15 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
namespace std {
using :: size_t; using :: div_t; using :: ldiv_t;
using :: abort; using :: abs; using :: atexit;
using :: atof; using :: atoi; using :: atol;
using :: bsearch; using :: calloc; using :: div;
using :: exit; using :: free;
using :: labs; using :: ldiv; using :: malloc;
using :: mblen; using :: mbstowcs; using :: mbtowc;
using :: qsort; using :: rand; using :: realloc;
using :: srand; using :: strtod; using :: strtol;
using :: strtoul;
using :: wcstombs; using :: wctomb;
using :: lldiv_t;
using :: getenv;
using :: system;
#line 36 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
using :: atoll; using :: llabs; using :: lldiv;
using :: strtof; using :: strtold;
using :: strtoll; using :: strtoull;
using :: _Exit; using :: at_quick_exit; using :: quick_exit;
#line 44 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
#line 46 "C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\INCLUDE\\cstdlib"
#line 4 "C:\\cygwin64\\tmp\\PE681A~1\\CONFIG~1.SET\\conftest.cc"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Popping language Cxx
TEST checkFortranCompiler from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:949)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:949)
Locate a functional Fortran compiler
Checking for program /usr/local/bin/win32fe...not found
Checking for program /usr/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/bin/intel64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/CommonExtensions/Microsoft/TestWindow/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/MSBuild/14.0/bin/amd64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/BIN/amd64/win32fe...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/VC/VCPackages/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Team Tools/Performance Tools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/bin/x86/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.2.185/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Advisor 2018/bin32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/VTune Amplifier 2018/bin64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Inspector 2018/bin32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.1.156/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.5.267/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.0.124/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2016 R1/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2017.0.109/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.2.180/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tec360 2011R2/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2016.1.146/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/NetSarang/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redis/win32fe...not found
Checking for program /cygdrive/c/Windows/system32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/win32fe...not found
Checking for program /cygdrive/c/openfoam/Git/cmd/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2018 R1/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Tecplot/Tecplot 360 EX 2017 R3/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.2.024/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/IntelSWTools/Trace Analyzer and Collector/9.1.1.019/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/win32fe...not found
Checking for program /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe...found
Defined make macro "FC" to "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe ifort"
Pushing language FC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe ifort -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe ifort -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe ifort -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
ipo: error #11018: Cannot open libpetsc-ufod4vtr9mqHvKIQiVAm.lib
LINK : C:\cygwin64\tmp\PE681A~1\CONFIG~1.SET\conftest.exe not found or not built by the last incremental link; performing full link
LINK : fatal error LNK1104: cannot open file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
Possible ERROR while running linker: exit code 20480
stdout:
LINK : fatal error LNK1104: cannot open file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe ifort -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.F90
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Testing executable /tmp/petsc-ytughc/config.setCompilers/conftest.exe to see if it can be run
Executing: /tmp/petsc-ytughc/config.setCompilers/conftest.exe
Popping language FC
TEST checkFortranComments from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:970)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:970)
Make sure fortran comment "!" works
Pushing language FC
Successful compile:
Source:
! comment
program main
end
Fortran comments can use ! in column 1
Popping language FC
TEST checkLargeFileIO from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1087)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1087)
TEST checkArchiver from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1186)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1186)
Check that the archiver exists and can make a library usable by the compiler
Pushing language C
Executing: ar -V
stdout:
GNU ar (GNU Binutils) 2.29.1.20171006
Copyright (C) 2017 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
Defined make macro "FAST_AR_FLAGS" to "Scq"
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-QxHost'
cl : Command line warning D9002 : ignoring unknown option '-debug'
cl : Command line warning D9002 : ignoring unknown option '-O3'
conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int foo(int a) {
return a+1;
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/bin/ar...found
Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-ytughc/config.setCompilers/libconf1.a /tmp/petsc-ytughc/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-ytughc/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- c
Ranlib is not functional with your archiver. Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
stdout:
conftest.c
Successful compile:
Source:
int foo(int a) {
return a+1;
Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-ytughc/config.setCompilers/libconf1.a
stdout:
conftest.c
Successful compile:
Source:
extern int foo(int);
int main() {
int b = foo(1); if (b);
return 0;
Pushing language C
Popping language C
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -o /tmp/petsc-ytughc/config.setCompilers/conftest.exe -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.o -L/tmp/petsc-ytughc/config.setCompilers -lconf1
stdout:
LINK : fatal error LNK1181: cannot open input file 'libconf1.lib'
Possible ERROR while running linker: exit code 512
stdout:
LINK : fatal error LNK1181: cannot open input file 'libconf1.lib'Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
stdout:
Defined make macro "AR_FLAGS" to "cr"
Defined make macro "AR_LIB_SUFFIX" to "lib"
Popping language C
TEST checkSharedLinker from config.setCompilers(/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py:1300)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1300)
Check that the linker can produce shared libraries
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Checking shared linker /usr/bin/ar using flags []
Defined make macro "LD_SHARED" to "/usr/bin/ar"
Trying C compiler flag
stdout:
conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejecting compiler flag due to
conftest.c
Rejected C compiler flag because it was not compatible with shared linker /usr/bin/ar using flags []
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl --help
stdout:
Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
Usage: win32fe <tool> --<win32fe options> -<tool options> <files>
<tool> must be the first argument to win32fe
<tool>: {cl,icl,df,f90,ifl,bcc32,lib,tlib}
cl: Microsoft 32-bit C/C++ Optimizing Compiler
icl: Intel C/C++ Optimizing Compiler
df: Compaq Visual Fortran Optimizing Compiler
f90: Compaq Visual Fortran90 Optimizing Compiler
ifl: Intel Fortran Optimizing Compiler
ifort: Intel Fortran Optimizing Compiler
nvcc: NVIDIA CUDA Compiler Driver
bcc32: Borland C++ for Win32
lib: Microsoft Library Manager
tlib: Borland Library Manager
<win32fe options>:
--help: Output this help message and help for <tool>
--path <arg>: <arg> specifies an addition to the PATH that is required
(ex. the location of a required .dll)
--use <arg>: <arg> specifies the variant of <tool> to use
--verbose: Echo to stdout the translated commandline
and other diagnostic information
--version: Output version info for win32fe and <tool>
--wait_for_debugger: Inserts an infinite wait after creation of <tool>
and outputs PID so one can manually attach a debugger to the
current process. In the debugger, one must set:
tool::waitfordebugger = 0
to continue the execution normally.
--win-l: For compilers, define -lfoo to link foo.lib instead of libfoo.lib
--woff: Suppress win32fe specific warning messages
For compilers:
win32fe will map the following <tool options> to their native options:
-c: Compile Only, generates an object file with .o extension
This will invoke the compiler once for each file listed.
-l<library>: Link the file lib<library>.lib or if using --win-l also, <library>.lib
-o <file>: Output=<file> context dependent
-D<macro>: Define <macro>
-I<path>: Add <path> to the include path
-L<path>: Add <path> to the link path
-g: Generate debug symbols in objects when specified for compilation,
and in executables when specified for linking (some compilers
specification at both times for full debugging support).
-O: Enable compiletime and/or linktime optimizations.
Ex: win32fe cl -g -c foo.c --verbose -Iinclude
Note: win32fe will automatically find the system library paths and
system include paths, relieving the user of the need to invoke a
particular shell.
cl specific help:
win32fe uses -nologo by default for nonverbose output. Use the flag:
-logo to disable this feature.
-g is identical to -Z7.
-O is identical to -O2.
Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
C/C++ COMPILER OPTIONS
-OPTIMIZATION-
/O1 minimize space /O2 maximize speed
/Ob<n> inline expansion (default n=0) /Od disable optimizations (default)
/Og enable global optimization /Oi[-] enable intrinsic functions
/Os favor code space /Ot favor code speed
/Ox maximum optimizations
/favor:<blend|AMD64|INTEL64|ATOM> select processor to optimize for, one of:
blend - a combination of optimizations for several different x64 processors
AMD64 - 64-bit AMD processors
INTEL64 - Intel(R)64 architecture processors
ATOM - Intel(R) Atom(TM) processors
-CODE GENERATION-
/Gw[-] separate global variables for linker
/GF enable read-only string pooling /Gm[-] enable minimal rebuild
/Gy[-] separate functions for linker /GS[-] enable security checks
/GR[-] enable C++ RTTI /GX[-] enable C++ EH (same as /EHsc)
/guard:cf[-] enable CFG (control flow guard)
/EHs enable C++ EH (no SEH exceptions) /EHa enable C++ EH (w/ SEH exceptions)
/EHc extern "C" defaults to nothrow
/EHr always generate noexcept runtime termination checks
/fp:<except[-]|fast|precise|strict> choose floating-point model:
except[-] - consider floating-point exceptions when generating code
fast - "fast" floating-point model; results are less predictable
precise - "precise" floating-point model; results are predictable
strict - "strict" floating-point model (implies /fp:except)
/Qfast_transcendentals generate inline FP intrinsics even with /fp:except
/Qpar[-] enable parallel code generation
/Qpar-report:1 auto-parallelizer diagnostic; indicate parallelized loops
/Qpar-report:2 auto-parallelizer diagnostic; indicate loops not parallelized
/Qvec-report:1 auto-vectorizer diagnostic; indicate vectorized loops
/Qvec-report:2 auto-vectorizer diagnostic; indicate loops not vectorized
/GL[-] enable link-time code generation
/volatile:<iso|ms> choose volatile model:
iso - Acquire/release semantics not guaranteed on volatile accesses
ms - Acquire/release semantics guaranteed on volatile accesses
/GA optimize for Windows Application /Ge force stack checking for all funcs
/Gs[num] control stack checking calls /Gh enable _penter function call
/GH enable _pexit function call /GT generate fiber-safe TLS accesses
/RTC1 Enable fast checks (/RTCsu) /RTCc Convert to smaller type checks
/RTCs Stack Frame runtime checking /RTCu Uninitialized local usage checks
/clr[:option] compile for common language runtime, where option is:
pure - produce IL-only output file (no native executable code)
safe - produce IL-only verifiable output file
initialAppDomain - enable initial AppDomain behavior of Visual C++ 2002
noAssembly - do not produce an assembly
nostdlib - ignore the default \clr directory
/homeparams Force parameters passed in registers to be written to the stack
/GZ Enable stack checks (/RTCs)
/arch:AVX enable use of instructions available with AVX-enabled CPUs
/arch:AVX2 enable use of instructions available with AVX2-enabled CPUs
/Gv __vectorcall calling convention
-OUTPUT FILES-
/Fa[file] name assembly listing file /FA[scu] configure assembly listing
/Fd[file] name .PDB file /Fe<file> name executable file
/Fm[file] name map file /Fo<file> name object file
/Fp<file> name precompiled header file /Fr[file] name source browser file
/FR[file] name extended .SBR file /Fi[file] name preprocessed file
/Fd: <file> name .PDB file /Fe: <file> name executable file
/Fm: <file> name map file /Fo: <file> name object file
/Fp: <file> name .PCH file /FR: <file> name extended .SBR file
/Fi: <file> name preprocessed file
/doc[file] process XML documentation comments and optionally name the .xdc file
-PREPROCESSOR-
/AI<dir> add to assembly search path /FU<file> forced using assembly/module
/C don't strip comments /D<name>{=|#}<text> define macro
/E preprocess to stdout /EP preprocess to stdout, no #line
/P preprocess to file /Fx merge injected code to file
/FI<file> name forced include file /U<name> remove predefined macro
/u remove all predefined macros /I<dir> add to include search path
/X ignore "standard places"
-LANGUAGE-
/Zi enable debugging information /Z7 enable old-style debug info
/Zp[n] pack structs on n-byte boundary /Za disable extensions
/Ze enable extensions (default) /Zl omit default library name in .OBJ
/Zs syntax check only /vd{0|1|2} disable/enable vtordisp
/vm<x> type of pointers to members
/Zc:arg1[,arg2] C++ language conformance, where arguments can be:
forScope[-] enforce Standard C++ for scoping rules
wchar_t[-] wchar_t is the native type, not a typedef
auto[-] enforce the new Standard C++ meaning for auto
trigraphs[-] enable trigraphs (off by default)
rvalueCast[-] enforce Standard C++ explicit type conversion rules
strictStrings[-] disable string-literal to [char|wchar_t]*
conversion (off by default)
implicitNoexcept[-] enable implicit noexcept on required functions
threadSafeInit[-] enable thread-safe local static initialization
inline[-] remove unreferenced function or data if it is
COMDAT or has internal linkage only (off by default)
sizedDealloc[-] enable C++14 global sized deallocation
functions (on by default)
throwingNew[-] assume operator new throws on failure (off by default)
referenceBinding[-] a temporary will not bind to an non-const
lvalue reference (off by default)
/ZH:SHA_256 use SHA256 for file checksum in debug info (experimental)
/Zo[-] generate richer debugging information for optimized code (on by default)
/ZW enable WinRT language extensions
/constexpr:depth<N> use <N> as the recursion depth limit
for constexpr (default: 512)
/constexpr:backtrace<N> show <N> constexpr evaluations
in diagnostics (default: 10)
/constexpr:steps<N> terminate constexpr evaluation after
<N> steps (default: 100000)
/ZI enable Edit and Continue debug info
/openmp enable OpenMP 2.0 language extensions
-MISCELLANEOUS-
@<file> options response file /?, /help print this help message
/bigobj generate extended object format /c compile only, no link
/errorReport:option Report internal compiler errors to Microsoft
none - do not send report
prompt - prompt to immediately send report
queue - at next admin logon, prompt to send report (default)
send - send report automatically
/FC use full pathnames in diagnostics /H<num> max external name length
/J default char type is unsigned
/MP[n] use up to 'n' processes for compilation
/nologo suppress copyright message
/sdl enable additional security features and warnings
/showIncludes show include file names /Tc<source file> compile file as .c
/Tp<source file> compile file as .cpp /TC compile all files as .c
/TP compile all files as .cpp /V<string> set version string
/w disable all warnings /wd<n> disable warning n
/we<n> treat warning n as an error /wo<n> issue warning n once
/w<l><n> set warning level 1-4 for n /W<n> set warning level (default n=1)
/Wall enable all warnings /WL enable one line diagnostics
/WX treat warnings as errors /Yc[file] create .PCH file
/Yd put debug info in every .OBJ /Yl[sym] inject .PCH ref for debug lib
/Yu[file] use .PCH file /Y- disable all PCH options
/Zm<n> max memory alloc (% of default) /FS force to use MSPDBSRV.EXE
/await enable resumable functions extension
/Wv:xx[.yy[.zzzzz]] disable warnings introduced after version xx.yy.zzzzz
/source-charset:<iana-name>|.nnnn set source character set
/execution-charset:<iana-name>|.nnnn set execution character set
/utf-8 set source and execution character set to UTF-8
/validate-charset[-] validate UTF-8 files for only legal characters
-LINKING-
/LD Create .DLL /LDd Create .DLL debug library
/LN Create a .netmodule /F<num> set stack size
/link [linker options and libraries] /MD link with MSVCRT.LIB
/MT link with LIBCMT.LIB /MDd link with MSVCRTD.LIB debug lib
/MTd link with LIBCMTD.LIB debug lib
-CODE ANALYSIS-
/analyze[-] Enable native analysis /analyze:quiet[-] No warning to console
/analyze:log<name> Warnings to file /analyze:autolog Log to *.pftlog
/analyze:autolog:ext<ext> Log to *.<ext>/analyze:autolog- No log file
/analyze:WX- Warnings not fatal /analyze:stacksize<num> Max stack frame
/analyze:max_paths<num> Max paths /analyze:only Analyze, no code gen
Trying C compiler flag -PIC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 -PIC /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-PIC'
conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejecting compiler flag -PIC due to
conftest.c
Rejected C compiler flag -PIC because it was not compatible with shared linker /usr/bin/ar using flags []
Trying C compiler flag -fPIC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 -fPIC /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-fPIC'
conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejecting compiler flag -fPIC due to
conftest.c
Rejected C compiler flag -fPIC because it was not compatible with shared linker /usr/bin/ar using flags []
Trying C compiler flag -KPIC
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 -KPIC /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-KPIC'
conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejecting compiler flag -KPIC due to
conftest.c
Rejected C compiler flag -KPIC because it was not compatible with shared linker /usr/bin/ar using flags []
Trying C compiler flag -qpic
Executing: /cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/bin/win32fe/win32fe cl -c -o /tmp/petsc-ytughc/config.setCompilers/conftest.o -I/tmp/petsc-ytughc/config.setCompilers -QxHost -debug -O3 -qpic /tmp/petsc-ytughc/config.setCompilers/conftest.c
stdout:
cl : Command line warning D9002 : ignoring unknown option '-qpic'
conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejecting compiler flag -qpic due to
conftest.c
Rejected C compiler flag -qpic because it was not compatible with shared linker /usr/bin/ar using flags []
Deleting "LD_SHARED"
CONFIGURATION CRASH (Please send configure.log to petsc-maint at mcs.anl.gov)
sharedLinker File "./config/configure.py", line 393, in petsc_configure
framework.configure(out = sys.stdout)
File "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/framework.py", line 1086, in configure
self.processChildren()
File "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/framework.py", line 1075, in processChildren
self.serialEvaluation(self.childGraph)
File "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/framework.py", line 1056, in serialEvaluation
child.configure()
File "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py", line 1695, in configure
self.executeTest(self.checkSharedLinker)
File "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/base.py", line 126, in executeTest
ret = test(*args,**kargs)
File "/cygdrive/d/wtay/Downloads/Source_codes/petsc-3.8.4/config/BuildSystem/config/setCompilers.py", line 1345, in checkSharedLinker
del self.sharedLinker
Finishing Configure Run at Wed Mar 28 12:36:23 2018
