[petsc-users] Coloring SL vs. GREEDY
    Ali Berk Kahraman
    aliberkkahraman at yahoo.com
    Sun Mar 25 04:58:18 CDT 2018
Dear All,
I have an MPI Jacobian data structure for which I want to do coloring on
SNES. When I try MATCOLORINGGREEDY as the coloring type, it gives a
memory allocation error I am currently unable to fix(the error is
generated when SNESSolve calls lower level routines, I couldn't make use
of what valgrind said). However, MATCOLORINGSL works just fine and gives
a good result.
My question is, is there a significant cost difference between SL and
GREEDY, as SL is a sequential algorithm where GREEDY is parallel?
Don't be confused with the memory error, it is definitely my code and
not a bug. The simplest case with GREEDY works where SNES function is
f(x)=x=0.
Best Regards,
Ali Berk Kahraman
M.Sc. Student, Mech.Eng.
Boğaziçi Uni, Istanbul, Turkey
