[petsc-users] VecGetArrayReadF90 with gfortran
Samuel Lanthaler s.lanthaler at gmail.com
Fri Mar 23 12:45:42 CDT 2018
Thank you very much for your effort Satish. It appears that even in your
version of the example, I'm having the same problem with a pointer that
is not properly assigned. Seems weird, I also tried recompiling petsc,
but that gave me the same. The configure file for petsc is also attached.
Btw. It appears the latest version of gfortran I have access to on my
work station is gcc-6.3.
 >> mpif90 --version
GNU Fortran (GCC) 6.3.0
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Does anyone maybe have any ideas?
Samuel
On 03/23/2018 05:42 PM, Satish Balay wrote:
> Attaching the modified version that works with complex [using complex build of petsc]
> BTW: I'm using the following gfortran [but I don't think the version makes any difference] with petsc-3.8 (maint branch):
> $ gfortran --version
> GNU Fortran (GCC) 8.0.1 20180222 (Red Hat 8.0.1-0.16)
> Satish
> balay at asterix /home/balay/download-pine
> $ make ex2f
> mpif90 -c -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g    -I/home/balay/petsc/include -I/home/balay/petsc/arch-cmplx/include    -o ex2f.o ex2f.F90
> mpif90 -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g   -o ex2f ex2f.o  -Wl,-rpath,/home/balay/petsc/arch-cmplx/lib -L/home/balay/petsc/arch-cmplx/lib -Wl,-rpath,/home/balay/soft/mpich-3.3b1/lib -L/home/balay/soft/mpich-3.3b1/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/8 -L/usr/lib/gcc/x86_64-redhat-linux/8 -lpetsc -llapack -lblas -lX11 -lpthread -lm -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lmpicxx -lstdc++ -lm -Wl,-rpath,/home/balay/soft/mpich-3.3b1/lib -L/home/balay/soft/mpich-3.3b1/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/8 -L/usr/lib/gcc/x86_64-redhat-linux/8 -ldl -Wl,-rpath,/home/balay/soft/mpich-3.3b1/lib -lmpi -lgcc_s -ldl
> /usr/bin/rm -f ex2f.o
> $ ./ex2f
>   setting values
>   assembling vector
>   copying vector to array
>   N =           10
>   m =           10
>   getting vecX size
>   getting ownership range
>   ownership range:            0          10
>   copy values to global array
>   vecX_pt:
>   SIZE =           10
>                    (1.0000000000000000,0.0000000000000000)
>                    (2.0000000000000000,0.0000000000000000)
>                    (3.0000000000000000,0.0000000000000000)
>                    (4.0000000000000000,0.0000000000000000)
>                    (5.0000000000000000,0.0000000000000000)
>                    (6.0000000000000000,0.0000000000000000)
>                    (7.0000000000000000,0.0000000000000000)
>                    (8.0000000000000000,0.0000000000000000)
>                    (9.0000000000000000,0.0000000000000000)
>                    (10.000000000000000,0.0000000000000000)
>   copy_buffer =
>   calling allreduce
>   buffer =
> On Fri, 23 Mar 2018, Satish Balay wrote:
>> I'm attaching the modified code - that appears to work fine for me. My changes are:
>> 1. use .F90 suffix - so the compiler does the f90 freeform/preprocessing automatically
>> 2. remove slepc references and use petsc only
>> 3. compile with a petsc formatted makefile
>> 4. replace complex with real*8 - thats compatible with PetscScalar
>> So perhaps you can modify your version of test code - to be closer to
>> this one [or vice versa] to see what is triggering the difference in
>> behavior.
>> Satish
>> On Fri, 23 Mar 2018, Samuel Lanthaler wrote:
>>> Hi all,
>>> I am having trouble using the function VecGetArrayReadF90 under gfortran. I
>>> have created a minimal example and put it in the attachment. Basically, it
>>> appears that the input pointer is empty upon return from
>>> VecGetArrayReadF90. The code runs fine, when compiled with ifort, so I
>>> don't know what's going on.
>>> I am attaching the code and makefile that I used, as well as the command
>>> line output that I can see. Though the errors are just to do with the fact
>>> that the output pointer is empty, so the command line output is not all
>>> that helpful...
>>> Thanks in advance for your help!
>>> Sam
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180323/6cdc4aad/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180323/6cdc4aad/attachment-0003.bin>
