[petsc-users] slepc-master does not configure correctly
Fande Kong
fdkong.jd at gmail.com
Thu Mar 22 14:37:58 CDT 2018
Thanks, Jose,
Works fine.
Fande,
On Thu, Mar 22, 2018 at 2:43 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> Fixed
> https://bitbucket.org/slepc/slepc/commits/464bcc967aa18470486aba71868e0a
> e158c3fe49
> > El 22 mar 2018, a las 3:23, Satish Balay <balay at mcs.anl.gov> escribió:
> > The primary change is - DESTDIR in petscvariables is replaced with
> PREFIXDIR
> > i.e:
> > diff --git a/config/packages/petsc.py b/config/packages/petsc.py
> > index e89779e15..f2577e4c6 100644
> > --- a/config/packages/petsc.py
> > +++ b/config/packages/petsc.py
> > @@ -90,8 +90,8 @@ class PETSc(package.Package):
> > self.precision = v
> > elif k == 'MAKE':
> > self.make = v
> > - elif k == 'DESTDIR':
> > + elif k == 'PREFIXDIR':
> > self.destdir = v
> > elif k == 'BFORT':
> > self.bfort = v
> > elif k == 'TEST_RUNS':
> > But then 'self.destdir' should be replaced by a more appropriate name
> > 'self.prefixdir' [and update its usage from other source files]
> > Satish
> > On Thu, 22 Mar 2018, Jed Brown wrote:
> >> Yes, DESTDIR is something that is only used during "make install". If
> >> you had a prefix install of PETSc, it should get PETSC_DIR (set to that
> >> prefix) and empty PETSC_ARCH.
> >> "Kong, Fande" <fande.kong at inl.gov> writes:
> >>> Hi All,
> >>> ~/projects/slepc]> PETSC_ARCH=arch-darwin-c-debug-master ./configure
> >>> *Checking environment...Traceback (most recent call last): File
> >>> "./configure", line 10, in <module>
> >>> execfile(os.path.join(os.path.dirname(__file__), 'config',
> >>> 'configure.py')) File "./config/configure.py", line 206, in <module>
> >>> log.write('PETSc install directory: '+petsc.destdir)AttributeError:
> PETSc
> >>> instance has no attribute 'destdir'*
> >>> SLEPc may be needed to synchronized for new changes in PETSc.
> >>> Thanks,
> >>> Fande Kong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180322/35c04a55/attachment-0001.html>
