[petsc-users] slepc-master does not configure correctly
Jose E. Roman jroman at dsic.upv.es
Thu Mar 22 03:43:51 CDT 2018
Fixed
https://bitbucket.org/slepc/slepc/commits/464bcc967aa18470486aba71868e0ae158c3fe49
> El 22 mar 2018, a las 3:23, Satish Balay <balay at mcs.anl.gov> escribió:
> The primary change is -  DESTDIR in petscvariables is replaced with PREFIXDIR
> i.e:
> diff --git a/config/packages/petsc.py b/config/packages/petsc.py
> index e89779e15..f2577e4c6 100644
> --- a/config/packages/petsc.py
> +++ b/config/packages/petsc.py
> @@ -90,8 +90,8 @@ class PETSc(package.Package):
>           self.precision = v
>         elif k == 'MAKE':
>           self.make = v
> -        elif k == 'DESTDIR':
> +        elif k == 'PREFIXDIR':
>           self.destdir = v
>         elif k == 'BFORT':
>           self.bfort = v
>         elif k == 'TEST_RUNS':
> But then 'self.destdir' should be replaced by a more appropriate name
> 'self.prefixdir' [and update its usage from other source files]
> Satish
> On Thu, 22 Mar 2018, Jed Brown wrote:
>> Yes, DESTDIR is something that is only used during "make install".  If
>> you had a prefix install of PETSc, it should get PETSC_DIR (set to that
>> prefix) and empty PETSC_ARCH.
>> "Kong, Fande" <fande.kong at inl.gov> writes:
>>> Hi All,
>>> ~/projects/slepc]> PETSC_ARCH=arch-darwin-c-debug-master ./configure
>>> *Checking environment...Traceback (most recent call last):  File
>>> "./configure", line 10, in <module>
>>> execfile(os.path.join(os.path.dirname(__file__), 'config',
>>> 'configure.py'))  File "./config/configure.py", line 206, in <module>
>>> log.write('PETSc install directory: '+petsc.destdir)AttributeError: PETSc
>>> instance has no attribute 'destdir'*
>>> SLEPc may be needed to synchronized for new changes in PETSc.
>>> Thanks,
>>> Fande Kong
