[petsc-users] Global Numbering
Wed Mar 21 13:25:21 CDT 2018
On Wed, Mar 21, 2018 at 2:18 PM, Mohammad Hassan Baghaei <
mhbaghaei at mail.sjtu.edu.cn> wrote:
> Sorry ! In fact, I am trying to construct the radius and theta coordinate
> for the circular domain I am having before going to the main local
> functions. I needed that for my local functions.
It sounds like you are having trouble with parallel programming. Maybe get
your stuff working in serial, and then
look at a book like Using MPI by Gropp, et.al. or Scientific Computing by
Eijkhout to understand more about parallelism.
    Matt
> *From:* Matthew Knepley [mailto:knepley at gmail.com]
> *Sent:* Thursday, March 22, 2018 1:45 AM
> *To:* Mohammad Hassan Baghaei <mhbaghaei at mail.sjtu.edu.cn>
> *Cc:* PETSc <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Global Numbering
> On Wed, Mar 21, 2018 at 1:28 PM, Mohammad Hassan Baghaei <
> I am trying to fill a vector based on global coordinate.
> You can see how this might be too vague for me to follow.
> As I am trying to use VecGetValues() on the global coordinate,
> Okay, this does not work for any parallel vector.
> I find it that argument goes out of range, since I am using global
> numbering rather than local numbering.
> It is not the numbering that is a problem. It is that parallel Vectors in
> PETSc are distributed. You cannot directly access
> data you do not own. You can send it to one process (for example using
> VecScatterCreateToZero()), but this is of course
> not scalable.
>   Thanks,
>     Matt
> *Sent:* Wednesday, March 21, 2018 10:38 PM
> On Wed, Mar 21, 2018 at 8:18 AM, Mohammad Hassan Baghaei <
> Hello
> I am trying to create a global vector of coordinates based on the
> parallelized dm. I find it really hard to work with the local numbering,
> how can I manage to create a kind of numbering on global level so that I
> could easily access to the nodes based on the new numbering. Thanks for
> your time.
> DMGetCoordinates() gives you a global vector.
> DMGetCoordinatesLocal() gives you a local vector.
> What are you trying to do?
>   Thanks,
>      Matt
> Amir
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180321/84ddb1f0/attachment.html>
