[petsc-users] [petsc-maint] two-level Schwarz
Matthew Knepley
knepley at gmail.com
Sat Mar 17 06:28:59 CDT 2018
On Fri, Mar 16, 2018 at 11:35 PM, John <johnlucassaturday at gmail.com> wrote:
> Hi PETSc team:
> I am curious if the two-level Schwarz preconditioner, as is illustrated in
> R. Tuminaro's paper ``on a multilevel preconditioning module for
> unstructured mesh Krylov solvers: two-level Schwarz", is readily available
> from command line options?
Hopefully I understand from my quick look at the paper. It looks like 2
levels MG, using DD as the smoother for the fine grid:
-pc_type mg -pc_mg_nlevels 2 -pc_mg_galerkin
-mg_levels_pc_type asm
The coarse grid will automatically be LU as in the paper. You can use
PCTELESCOPE to move the coarse grid to a subset
of processes or one process (PCREDUNDANT also works here). You do not have
to use Galerkin projection, but could
rediscretize on the coarse grid.
Matt
> Thanks,
> John
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180317/f0ee1985/attachment.html>
