[petsc-users] Problem with solving Poisson eqn for some cases
Matthew Knepley
knepley at gmail.com
Fri Mar 16 12:15:07 CDT 2018
On Fri, Mar 16, 2018 at 12:54 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 15/3/2018 6:21 PM, Matthew Knepley wrote:
> On Thu, Mar 15, 2018 at 3:51 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I'm running a CFD code which solves the momentum and Poisson eqns.
>> Due to poor scaling with HYPRE at higher cpu no., I decided to try using
>> PETSc with boomeramg and gamg.
>> I tested for some small cases and it work well. However, for the large
>> problem which has poor scaling, it gives an error when I change my Poisson
>> solver from pure HYPRE to PETSc with boomeramg and gamg.
>> The error is :
>> Caught signal number 11 SEGV: Segmentation Violation, probably memory
>> access out of range
>> I tried using:
>> -poisson_ksp_type richardson -poisson_pc_type hypre
>> -poisson_pc_type_hypre boomeramg
>> -poisson_ksp_type gmres -poisson_pc_type hypre -poisson_pc_type_hypre
>> boomeramg
>> -poisson_pc_type gamg -poisson_pc_gamg_agg_nsmooths 1
>> but they all gave similar error.
>> So why is this so? How should I troubleshoot? I am now running a debug
>> ver of PETSc to check the error msg.
> 1) For anything like this, we would like to see a stack trace from the
> debugger or valgrind output.
> 2) We do have several Poisson examples. Does it fail for you on those?
> Hi,
> Can you recommend me some suitable egs? Esp in Fortran?
Here is 2D Poisson
https://bitbucket.org/petsc/petsc/src/4b6141395f14f0c7d1415a2ff0158eec75a27d63/src/snes/examples/tutorials/ex5f.F90?at=master&fileviewer=file-view-default
> 3) You can also try ML, which is the same type of MG as GAMG.
> (--download-ml).
> My cluster can't connect to the internet. Where can I 1st download it?
> Similarly, how can I find out the location of the ext software by myself?
The locations are all in the configure Python modules:
https://bitbucket.org/petsc/petsc/src/4b6141395f14f0c7d1415a2ff0158eec75a27d63/config/BuildSystem/config/packages/ml.py?at=master&fileviewer=file-view-default
Matt
> Thanks,
> Matt
>> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>> Personal research webpage: http://tayweebeng.wixsite.com/website
>> Youtube research showcase: https://www.youtube.com/channe
>> l/UC72ZHtvQNMpNs2uRTSToiLA
>> linkedin: www.linkedin.com/in/tay-weebeng
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180316/a893b2e5/attachment.html>
