[petsc-users] Non deterministic results with MUMPS?
    Tim Steinhoff
    kandanovian at gmail.com
    Wed Mar 14 06:10:37 CDT 2018
I guess that the partioning is fixed, as two results can also differ
when I call two successive solves, where matrix and rhs vector and
everything is identical.
In that case the factorization/partitioning is reused by MUMPS and
only the solving phase is executed twice, which alone leads to
slightly different results on two processes.
The MUMPS manual says that there is some kind of dynamical task
scheduling for the pivoting part, but I could not find any
information, if they use something similar in the solving phase.
2018-03-13 21:59 GMT+01:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>> On Mar 13, 2018, at 1:10 PM, Tim Steinhoff <kandanovian at gmail.com> wrote:
>> Thanks for your fast reply.
>> I see that I can't expect the same results when changing the number of
>> processes, but how does MPI change the order of operations, when there
>> are for example 2 processes and the partitioning is fixed?
>     Hmm, how do you know the partitioning is fixed? Is there the use of a random number generator in MUMPS or the partitioning packages uses?
>    Barry
>> With GMRES I could not prorduce that behavior, no matter how many processes.
>> 2018-03-13 18:17 GMT+01:00 Stefano Zampini <stefano.zampini at gmail.com>:
>>> This is expected. In parallel, you cannot assume the order of operations is
>>> preserved
>>> Il 13 Mar 2018 8:14 PM, "Tim Steinhoff" <kandanovian at gmail.com> ha scritto:
>>>> Hi all,
>>>> I get some randomness when solving certain equation systems with MUMPS.
>>>> When I repeatedly solve the attached equation system by ksp example
>>>> 10, I get different solution vectors and therefore different residual
>>>> norms.
>>>> jac at jac-VirtualBox:~/data/rep/petsc/src/ksp/ksp/examples/tutorials$
>>>> mpiexec -np 4 ./ex10 -f ./1.mat -rhs ./1.vec -ksp_type preonly
>>>> -pc_type lu -pc_factor_mat_solver_package mumps
>>>> Number of iterations =   1
>>>> Residual norm 4.15502e-12
>>>> Residual norm 4.17364e-12
>>>> It seems to be depending on a combination of number of processes and
>>>> the equation system.
>>>> I used GCC 7.2.0, Intel 16, MUMPS 5.1.1 / 5.1.2 (with & without
>>>> metis/parmetis), openMPI 2.1.2. All with the same results.
>>>> PETSc configuration is the current maint branch:
>>>> ./configure --download-mumps --with-debugging=0 --COPTFLAGS="-O3"
>>>> --CXXOPTFLAGS="-O3" --FOPTFLAGS="-O3" --with-scalapack
>>>> Using "--download-fblaslapack --download-scalapack" didnt make a
>>>> difference neither.
>>>> Can anyone reproduce that issue?
>>>> Thanks and kind regards,
>>>> Volker
