[petsc-users] Print the KSP for Schur complement
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Mar 12 13:02:27 CDT 2018
If you call the KSPView() after you have fully constructed and used the Schur complement then it should print all the information without the PC has not been set up so information may be incomplete but it only has that information after the solve is complete.
Barry
> On Mar 12, 2018, at 12:49 PM, John <johnlucassaturday at gmail.com> wrote:
> Hi PETSc team:
> I am trying to analyze my code with which explicitly builds a Schur complement.
> I tried to print the inner solver for the Schur complement by calling
> MatSchurComplementGetKSP(S, &ksp_s);
> KSPView(ksp_s, PETSC_VIEWER_STDOUT_WORLD);
> However, the info printed on screen cannot fully display the pc info:
> PC Object: (pc0_inner_) 48 MPI processes
> type: ml
> type is MULTIPLICATIVE, levels=0 cycles=unknown
> Cycles per PCApply=0
> Using externally compute Galerkin coarse grid matrices
> linear system matrix = precond matrix:
> Mat Object: 48 MPI processes
> type: mpiaij
> rows=823875, cols=823875
> total: nonzeros=35031501, allocated nonzeros=35031501
> total number of mallocs used during MatSetValues calls =0
> using I-node (on process 0) routines: found 5615 nodes, limit used is 5
> I tried to run a PETSc fieldsplit, by calling -fieldsplit_p_inner_ flag, I can get all the inner solver info on screen.
> Is there a way to print the solver in the definition of the Schur complement for the A_00 matrix for my case?
> Thanks!
> John
