[petsc-users] error regarding filling section fields
Matthew Knepley
knepley at gmail.com
Sun Mar 11 20:00:03 CDT 2018
On Sun, Mar 11, 2018 at 10:39 PM, Mohammad Hassan Baghaei <
mhbaghaei at mail.sjtu.edu.cn> wrote:
> Hi
> I am trying to fill the global vector . Using single processor, it works
> fine. However, switching to several processors, I get the error regarding
> the section offset out of range for several points. The short of error
> message is below. Can you let me know what causes the offset to become [0,0
> ( in this case and How I can solve this issue. Thanks for your time.
This looks like you have not called PetscSectionSetChart(), or anything
else, on this Section. It could
be you only set it up on 1 process. I am not sure what you are trying to do.
Matt
> Amir
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Argument out of range
> [1]PETSC ERROR: Section point 1 should be in [0, 0)
> [1]PETSC ERROR: #1 PetscSectionGetOffset() line 1155 in
> /home/amir/petsc/src/vec/is/utils/vsectionis.c
> [1]PETSC ERROR: #2 PetscSectionGetFieldOffset() line 1208 in
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180312/daa91f33/attachment.html>
