[petsc-users] [petsc-maint] how to check if cell is local owned in DMPlex
Danyang Su
danyang.su at gmail.com
Thu Mar 8 17:51:43 CST 2018
On 18-03-07 03:54 PM, Jed Brown wrote:
> Danyang Su <danyang.su at gmail.com> writes:
>> Based on my test, this function works fine using current PETSc-dev
>> version, but I cannot get it compiled correctly using other versions for
>> Fortran code, as mentioned in the previous emails. I asked this question
>> because some of the clusters we use do not have the PETSc-dev version
>> and it takes time get staff reinstall another version.
> You can install PETSc yourself as a normal user.
Thanks, Jed. This is the way I will follow.
Danyang
