[petsc-users] [petsc-maint] how to check if cell is local owned in DMPlex
Jed Brown jed at jedbrown.org
Wed Mar 7 17:54:45 CST 2018
Danyang Su <danyang.su at gmail.com> writes:
> Based on my test, this function works fine using current PETSc-dev
> version, but I cannot get it compiled correctly using other versions for
> Fortran code, as mentioned in the previous emails. I asked this question
> because some of the clusters we use do not have the PETSc-dev version
> and it takes time get staff reinstall another version.
You can install PETSc yourself as a normal user.
