[petsc-users] PETSC_VIEWER_DRAW_(Comm) Fortran interface missing?
Satish Balay
balay at mcs.anl.gov
Thu Mar 8 09:50:07 CST 2018
Great! I've merged balay/ftn-VIEWER_DRAW/maint to 'maint'
Satish
On Thu, 8 Mar 2018, Tim Steinhoff wrote:
> Yeah, thanks Satish.
> PETSC_VIEWER_DRAW_() works perfectly and I could not reproduce my
> above mentioned issue with PETSC_VIEWER_STDOUT_(), so probably I
> messed something up.
> Thanks again for your great support,
> Volker
> 2018-03-06 18:14 GMT+01:00 Satish Balay <balay at mcs.anl.gov>:
> > Ok - I've added ftn interface for PETSC_VIEWER_DRAW_() [similar to
> > PETSC_VIEWER_STDOUT_()] in branch balay/ftn-VIEWER_DRAW/maint.
> > You can give it a try and see if it works.
> > Satish
> > On Tue, 6 Mar 2018, Satish Balay wrote:
> >> Hm - I do see the fortran interface code for PETSC_VIEWER_STDOUT_()
> >> https://bitbucket.org/petsc/petsc/src/049452fa31a1384b9850ba16ebcec79c99e4198c/src/sys/classes/viewer/impls/ascii/ftn-custom/zvcreatef.c?at=master&fileviewer=file-view-default
> >> and it does appear to work for me.
> >> balay at asterix /home/balay/petsc/src/mat/examples/tests (master *=)
> >> $ git diff
> >> diff --git a/src/mat/examples/tests/ex16f90.F90 b/src/mat/examples/tests/ex16f90.F90
> >> index 6bb83b4644..fee44aea95 100644
> >> --- a/src/mat/examples/tests/ex16f90.F90
> >> +++ b/src/mat/examples/tests/ex16f90.F90
> >> @@ -15,6 +15,7 @@
> >> PetscInt one
> >> PetscScalar v(1)
> >> PetscScalar, pointer :: array(:,:)
> >> + PetscViewer vw
> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> >> @@ -49,7 +50,8 @@
> >> ! Print the matrix to the screen
> >> - call MatView(A,PETSC_VIEWER_STDOUT_WORLD,ierr);CHKERRA(ierr)
> >> + vw = PETSC_VIEWER_STDOUT_(PETSC_COMM_WORLD)
> >> + call MatView(A,vw,ierr);CHKERRA(ierr)
> >> $ mpiexec -n 2 ./ex16f90
> >> Mat Object: 2 MPI processes
> >> type: mpidense
> >> 9.0000000000000000e+00 4.5000000000000000e+00
> >> 4.5000000000000000e+00 3.0000000000000000e+00
> >> 3.0000000000000000e+00 2.2500000000000000e+00
> >> Satish
> >> On Tue, 6 Mar 2018, Tim Steinhoff wrote:
> >> > Hi Barry,
> >> > thanks for your fast response. Yes, I'm fine with that.
> >> > Indeed, my code with the routine PETSC_VIEWER_STDOUT_(comm) was
> >> > compilable, but turned out it did not work properly at runtime
> >> > (hangs).
> >> > When using PETSC_VIEWER_DRAW_(comm), the compiler immediately gives an
> >> > error and I was confused.
> >> > Thanks,
> >> > Volker
> >> > By the way, the output parameter description of
> >> > PetscViewerASCIIGetStdout is missing in the documentation:
> >> > http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerASCIIGetStdout.html
> >> > 2018-03-06 16:26 GMT+01:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
> >> > > Tim,
> >> > > The PETSC_VIEWER_STDOUT_(comm) construct doesn't work in Fortran. Only the
> >> > > PETSC_VIEWER_STDOUT_WORLD or PETSC_VIEWER_STDOUT_SELF work. This is also true for
> >> > > draw see src/ksp/ksp/examples/tutorials/ex100f.F90
> >> > > Note that you can use PetscViewerDrawOpen() to get a draw to open on any communicator you like.
> >> > > Does this answer your question or did I misunderstand?
> >> > > Barry
> >> > >> On Mar 6, 2018, at 9:02 AM, Tim Steinhoff <kandanovian at gmail.com> wrote:
> >> > >> Hi all,
> >> > >> it seems like the routine PETSC_VIEWER_DRAW_(comm) is not available
> >> > >> in Fortran, while PETSC_VIEWER_STDOUT_(comm) is.
> >> > >> Is there anything I can do about it? (I am using the current maint
> >> > >> branch of PETSc)
> >> > >> Thank you very much and kind regards,
> >> > >> Volker
