[petsc-users] Could not execute "['git', 'rev-parse', '--git-dir']"
Kong, Fande fande.kong at inl.gov
Wed Mar 7 13:46:48 CST 2018
[kongf at falcon1 git.hypre]$ git rev-parse  --git-dir
.git
[kongf at falcon1 git.hypre]$ echo $?
0
[kongf at falcon1 git.hypre]$ git fsck
Checking object directories: 100% (256/256), done.
Checking objects: 100% (22710/22710), done.
But the same  error still persists!
Fande,
On Wed, Mar 7, 2018 at 12:33 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> balay at asterix /home/balay
> fatal: Not a git repository (or any parent up to mount point /)
> Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
> $ echo $?
> 128
> $ cd petsc
> balay at asterix /home/balay/petsc (next *=)
> .git
> $ echo $?
> 0
> So - for some reason, git is an error in /home/kongf/workhome/projects/
> petsc-3.7.7/arch-linux2-c-opt-64bit/externalpackages/git.hypre
> You can try:
> cd /home/kongf/workhome/projects/petsc-3.7.7/arch-linux2-c-opt-
> echo $?
> git fsck
> If this works - you can rerun configure and see if the error persists
> Satish
> On Wed, 7 Mar 2018, Kong, Fande wrote:
> > Hi PETSc team:
> > What is the possible reason for this?
> > The log file is attached.
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180307/dea0dd95/attachment.html>
