[petsc-users] Could not execute "['git', 'rev-parse', '--git-dir']"
Wed Mar 7 13:33:08 CST 2018
balay at asterix /home/balay
$ git rev-parse --git-dir
fatal: Not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
$ echo $?
128
$ cd petsc
balay at asterix /home/balay/petsc (next *=)
.git
$ echo $?
0
So - for some reason, git is an error in /home/kongf/workhome/projects/petsc-3.7.7/arch-linux2-c-opt-64bit/externalpackages/git.hypre
You can try:
cd /home/kongf/workhome/projects/petsc-3.7.7/arch-linux2-c-opt-64bit/externalpackages/git.hypre
echo $?
git fsck
If this works - you can rerun configure and see if the error persists
Satish
On Wed, 7 Mar 2018, Kong, Fande wrote:
> Hi PETSc team:
> What is the possible reason for this?
> The log file is attached.
> Fande,
