[petsc-users] PETSC_VIEWER_DRAW_(Comm) Fortran interface missing?
Tim Steinhoff
kandanovian at gmail.com
Tue Mar 6 10:23:51 CST 2018
Hi Barry,
thanks for your fast response. Yes, I'm fine with that.
Indeed, my code with the routine PETSC_VIEWER_STDOUT_(comm) was
compilable, but turned out it did not work properly at runtime
(hangs).
When using PETSC_VIEWER_DRAW_(comm), the compiler immediately gives an
error and I was confused.
Volker
By the way, the output parameter description of
PetscViewerASCIIGetStdout is missing in the documentation:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Viewer/PetscViewerASCIIGetStdout.html
2018-03-06 16:26 GMT+01:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
> Tim,
> The PETSC_VIEWER_STDOUT_(comm) construct doesn't work in Fortran. Only the
> PETSC_VIEWER_STDOUT_WORLD or PETSC_VIEWER_STDOUT_SELF work. This is also true for
> draw see src/ksp/ksp/examples/tutorials/ex100f.F90
> Note that you can use PetscViewerDrawOpen() to get a draw to open on any communicator you like.
> Does this answer your question or did I misunderstand?
> Barry
>> On Mar 6, 2018, at 9:02 AM, Tim Steinhoff <kandanovian at gmail.com> wrote:
>> Hi all,
>> it seems like the routine PETSC_VIEWER_DRAW_(comm) is not available
>> in Fortran, while PETSC_VIEWER_STDOUT_(comm) is.
>> Is there anything I can do about it? (I am using the current maint
>> branch of PETSc)
>> Thank you very much and kind regards,
>> Volker
