[petsc-users] Error while reading/writing petsc file
Nelson David Rufus nelrufus at umich.edu
Mon Mar 5 13:10:07 CST 2018
Thanks Matt. I will try to use a 32 bit integer to see if the problem goes
away. I had a query about compatibility of while reading and writing files
compiled with different int varaints. For example, in the past, I've
noticed that a file written using an int32 petsc installation (using code
similar to below) had trouble being read by an int64 petsc installation. Is
this an issue?
Nelson David Rufus
PhD Student
Computational Materials Physics Group
Mechanical Engineering
University of Michigan
On Mon, Mar 5, 2018 at 1:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 5, 2018 at 1:52 PM, Nelson David Rufus <nelrufus at umich.edu>
> wrote:
>> Hello,
>> I am writing a vector on a petsc binary file and subsequently reading the
>> same in another part of the code.
>> This works well for smaller vector sizes but fails for a large vector
>> (vectorsize=2048000000 <(204)%20800-0000>; PetscScalar=PetscComplex).
>> For a large vector, when the read vector is probed for values, I seems to
>> me that it is populated with uninitialized values.
> The number of bytes written will not fit in a 32-bit integer. We do not
> exhaustively check for problems. I recommend
> reconfiguring with 64-bit ints and retrying.
>   Thanks,
>      Matt
>> This size is close to the int32 limit (2^31 -1) but does not really
>> breach it. Hence i am nt using 64 bit integer. Can you please help me
>> figure out what might be going wrong here.? I'm appending with this mail
>> snippets of the code which read wnd write the petsc file.
>> // Snippet which writes v (a vector constructed using global size) to
>> the file. Note that this snippet is part of a parallel code
>>       PetscViewer viewer;
>>       error = PetscViewerBinaryOpen(PETSC_CO
>> MM_WORLD,fileName.c_str(),FILE_MODE_WRITE,&viewer);
>>       checkPETScError(error, "unbale to open binary file");
>>       error = VecView(v,viewer);
>>       checkPETScError(error, "unable to use VecView");
>>       error = PetscViewerDestroy(&viewer);
>>       checkPETScError(error,"unable to destry viewer");
>>       // cleanup
>>       error = VecDestroy(&v);
>>       checkPETScError(error,"unable to destroy vector");
>>       error = PetscOptionsSetValue(NULL,"-viewer_binary_mpiio","");
>>       checkPETScError(error, "error in PetscOptionsSetValue");
>> // Snippet which reads v (this is part of a serial code)
>> PetscViewer viewer;
>>   error = PetscViewerBinaryOpen(PETSC_COMM_WORLD,fileName.c_str(),FILE
>> _MODE_READ,&viewer);
>>   error = VecLoad(v,viewer);
>>   // write to console
>>   //error = VecView(v,PETSC_VIEWER_STDOUT_WORLD);
>>   //checkPETScError(error, "unable to write to console");
>>   // copy petsc vec to stl vector
>>   std::vector<std::complex<double> > dummy(vecSize);
>>   PetscScalar *pointerX;
>>   VecGetArray(v, &pointerX);
>>   std::copy(&(pointerX[0]),&(pointerX[vecSize]),dummy.begin());
>>   VecRestoreArray(v, &pointerX);
>>   // subsequently dummy is written to an stl vector.
>> Thanks,
>> Nelson David Rufus
>> PhD Student
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180305/066d28da/attachment-0001.html>
