[petsc-users] Error while reading/writing petsc file
Matthew Knepley
knepley at gmail.com
Mon Mar 5 12:56:11 CST 2018
On Mon, Mar 5, 2018 at 1:52 PM, Nelson David Rufus <nelrufus at umich.edu>
wrote:
> Hello,
> I am writing a vector on a petsc binary file and subsequently reading the
> same in another part of the code.
> This works well for smaller vector sizes but fails for a large vector
> (vectorsize=2048000000 <(204)%20800-0000>; PetscScalar=PetscComplex). For
> a large vector, when the read vector is probed for values, I seems to me
> that it is populated with uninitialized values.
The number of bytes written will not fit in a 32-bit integer. We do not
exhaustively check for problems. I recommend
reconfiguring with 64-bit ints and retrying.
Matt
> This size is close to the int32 limit (2^31 -1) but does not really breach
> it. Hence i am nt using 64 bit integer. Can you please help me figure out
> what might be going wrong here.? I'm appending with this mail snippets of
> the code which read wnd write the petsc file.
> // Snippet which writes v (a vector constructed using global size) to the
> file. Note that this snippet is part of a parallel code
> PetscViewer viewer;
> error = PetscViewerBinaryOpen(PETSC_COMM_WORLD,fileName.c_str(),
> FILE_MODE_WRITE,&viewer);
> checkPETScError(error, "unbale to open binary file");
> error = VecView(v,viewer);
> checkPETScError(error, "unable to use VecView");
> error = PetscViewerDestroy(&viewer);
> checkPETScError(error,"unable to destry viewer");
> // cleanup
> error = VecDestroy(&v);
> checkPETScError(error,"unable to destroy vector");
> error = PetscOptionsSetValue(NULL,"-viewer_binary_mpiio","");
> checkPETScError(error, "error in PetscOptionsSetValue");
> // Snippet which reads v (this is part of a serial code)
> PetscViewer viewer;
> FILE_MODE_READ,&viewer);
> error = VecLoad(v,viewer);
> // write to console
> //error = VecView(v,PETSC_VIEWER_STDOUT_WORLD);
> //checkPETScError(error, "unable to write to console");
> // copy petsc vec to stl vector
> std::vector<std::complex<double> > dummy(vecSize);
> PetscScalar *pointerX;
> VecGetArray(v, &pointerX);
> std::copy(&(pointerX[0]),&(pointerX[vecSize]),dummy.begin());
> VecRestoreArray(v, &pointerX);
> // subsequently dummy is written to an stl vector.
> Thanks,
> Nelson David Rufus
> PhD Student
> Computational Materials Physics Group
> Mechanical Engineering
> University of Michigan
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180305/5c9232c4/attachment.html>
