[petsc-users] how to check if cell is local owned in DMPlex
Danyang Su danyang.su at gmail.com
Sun Mar 4 13:05:05 CST 2018
On 18-03-04 08:08 AM, Matthew Knepley wrote:
> On Fri, Mar 2, 2018 at 3:22 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     Hi Matt,
>     I use the latest Fortran style in PETSc 3.8. Enclosed are the
>     PETSc configuration, code compiling log and the function that
>     causes compiling error. The compiling error happens after I
>     include petscsf.h in the following section. I didn't find
>     petscsf.h in petsc/finclude/ folder so I use the head file in the
>     'include' folder and this seems not allowed.
> I apologize for taking so long. The PetscSF definitions are in
> #include <petsc/finclude/petscis.h>
Hi Matt,
After including
       use petscis
I still get error saying undefined reference to `petscsfgetgraph_'
Did I miss any other head file?
Danyang
> You are correct that they should be moved out.
>   Thanks,
>      Matt
>     #ifdef PETSC_V3_8_X
>     #include <petsc/finclude/petscsys.h>
>     #include <petsc/finclude/petscdmplex.h>
>     #include <petsc/finclude/petscdmlabel.h>
>     #include <petscsf.h>
>           use petscsys
>           use petscdmplex
>           use petscsf
>     #endif
>     Thanks,
>     Danyang
>     On 18-03-02 12:08 PM, Matthew Knepley wrote:
>>     On Fri, Mar 2, 2018 at 3:00 PM, Danyang Su <danyang.su at gmail.com
>>         On 18-03-02 10:58 AM, Matthew Knepley wrote:
>>>         On Fri, Mar 2, 2018 at 1:41 PM, Danyang Su
>>>         <danyang.su at gmail.com <mailto:danyang.su at gmail.com>> wrote:
>>>             On 18-02-19 03:30 PM, Matthew Knepley wrote:
>>>>             On Mon, Feb 19, 2018 at 3:11 PM, Danyang Su
>>>>                 Hi Matt,
>>>>                 Would you please let me know how to check if a cell
>>>>                 is local owned? When overlap is 0 in
>>>>                 DMPlexDistribute, all the cells are local owned.
>>>>                 How about overlap > 0? It sounds like impossible to
>>>>                 check by node because a cell can be local owned
>>>>                 even if none of the nodes in this cell is local owned.
>>>>             If a cell is in the PetscSF, then it is not locally
>>>>             owned. The local nodes in the SF are sorted, so I use
>>>>             PetscFindInt
>>>>             (http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscFindInt.html
>>>>             <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscFindInt.html>).
>>>             Hi Matt,
>>>             Would you please give me a little more about how to mark
>>>             the ghost cells when overlap > 0? What do you mean a
>>>             cell is in the PetscSF? I use PetscSFView to export the
>>>             graph (original mesh file pile.vtk) and it exports all
>>>             the cells, including the ghost cells (PETScSFView.txt).
>>>         Yes, I will send you some sample code when I get time. The
>>>         first problem is that you are looking at a different
>>>         PetscSF. This looks like the
>>>         one returned by DMPlexDistribute(). This is mapping the
>>>         serial mesh to the parallel mesh. You want
>>>         http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMGetPointSF.html
>>>         <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMGetPointSF.html>
>>>         Then you can look at
>>>         https://bitbucket.org/petsc/petsc/src/1788fc36644e622df8cb1a0de85676ccc5af0239/src/dm/impls/plex/plexsubmesh.c?at=master&fileviewer=file-view-default#plexsubmesh.c-683
>>>         <https://bitbucket.org/petsc/petsc/src/1788fc36644e622df8cb1a0de85676ccc5af0239/src/dm/impls/plex/plexsubmesh.c?at=master&fileviewer=file-view-default#plexsubmesh.c-683>
>>>         I get the pointSF, get out the list of leaves, and find
>>>         points in it using PetscFindInt()
>>         Hi Matt,
>>         By using the local dm, I can get the PetscSF I want, as shown
>>         below. Now I need to get the number of ghost cells or local
>>         cells (here 4944) or number of leaves (here 825) for each
>>         processor. I try to use PetscSFGetGraph to get number of
>>         leaves in Fortran. After including "petscsf.h", I got
>>         compilation error saying "You need a ISO C conforming
>>         compiler to use the glibc headers". Is there any alternative
>>         way to do this? I do not need the ghost-neighbor mapping, but
>>         just the number of local owned cells.
>>     Also, make sure you are using the latest Fortran style for PETSc:
>>     http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
>>     <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html>
>>           [0] Number of roots=11449, leaves=825, remote ranks=1
>>           [0] 4944 <- (1,0)
>>           [0] 4945 <- (1,28)
>>           [0] 4946 <- (1,56)
>>           [1] Number of roots=11695, leaves=538, remote ranks=1
>>           [1] 5056 <- (0,21)
>>           [1] 5057 <- (0,43)
>>           [1] 5058 <- (0,65)
>>           [1] 5059 <- (0,87)
>>         In file included from /usr/include/features.h:375:0,
>>                          from /usr/include/stdio.h:28,
>>                          from
>>         /home/dsu/Soft/PETSc/petsc-3.8.3/include/petscsys.h:175,
>>                          from
>>         /home/dsu/Soft/PETSc/petsc-3.8.3/include/petscsf.h:7,
>>                          from ../../solver/solver_ddmethod.F90:4837:
>>         /usr/include/x86_64-linux-gnu/sys/cdefs.h:30:3: error: #error
>>         "You need a ISO C conforming compile\
>>          # error "You need a ISO C conforming compiler to use the
>>         glibc headers"
>>     Can you send this to petsc-maint at mcs.anl.gov
>>     <mailto:petsc-maint at mcs.anl.gov>? It looks like a build problem
>>     that can be fixed.
>>       Thanks,
>>         Matt
>>         Thanks,
>>         Danyang
>>>           Thanks,
>>>             Matt
>>>             Thanks,
>>>             Danyang
>>>>               Thanks,
>>>>                 Matt
>>>>                 Thanks,
>>>>                 Danyang
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>>             https://www.cse.buffalo.edu/~knepley/
>>>>             <http://www.caam.rice.edu/%7Emk51/>
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180304/9aa8b831/attachment-0001.html>
