[petsc-users] how to check if cell is local owned in DMPlex
Sun Mar 4 10:08:03 CST 2018
On Fri, Mar 2, 2018 at 3:22 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matt,
> I use the latest Fortran style in PETSc 3.8. Enclosed are the PETSc
> configuration, code compiling log and the function that causes compiling
> error. The compiling error happens after I include petscsf.h in the
> following section. I didn't find petscsf.h in petsc/finclude/ folder so I
> use the head file in the 'include' folder and this seems not allowed.
I apologize for taking so long. The PetscSF definitions are in
#include <petsc/finclude/petscis.h>
You are correct that they should be moved out.
     Matt
#ifdef PETSC_V3_8_X
> #include <petsc/finclude/petscsys.h>
> #include <petsc/finclude/petscdmplex.h>
> #include <petsc/finclude/petscdmlabel.h>
> #include <petscsf.h>
>       use petscsys
>       use petscdmplex
>       use petscsf
> #endif
> Thanks,
> Danyang
> On 18-03-02 12:08 PM, Matthew Knepley wrote:
> On Fri, Mar 2, 2018 at 3:00 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> On 18-03-02 10:58 AM, Matthew Knepley wrote:
>> On Fri, Mar 2, 2018 at 1:41 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>> On 18-02-19 03:30 PM, Matthew Knepley wrote:
>>> On Mon, Feb 19, 2018 at 3:11 PM, Danyang Su <danyang.su at gmail.com>
>>> wrote:
>>>> Hi Matt,
>>>> Would you please let me know how to check if a cell is local owned?
>>>> When overlap is 0 in DMPlexDistribute, all the cells are local owned. How
>>>> about overlap > 0? It sounds like impossible to check by node because a
>>>> cell can be local owned even if none of the nodes in this cell is local
>>>> owned.
>>> If a cell is in the PetscSF, then it is not locally owned. The local
>>> nodes in the SF are sorted, so I use
>>> PetscFindInt (http://www.mcs.anl.gov/petsc/
>>> petsc-current/docs/manualpages/Sys/PetscFindInt.html).
>>> Hi Matt,
>>> Would you please give me a little more about how to mark the ghost cells
>>> when overlap > 0? What do you mean a cell is in the PetscSF? I use
>>> PetscSFView to export the graph (original mesh file pile.vtk) and it
>>> exports all the cells, including the ghost cells (PETScSFView.txt).
>> Yes, I will send you some sample code when I get time. The first problem
>> is that you are looking at a different PetscSF. This looks like the
>> one returned by DMPlexDistribute(). This is mapping the serial mesh to
>> the parallel mesh. You want
>>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpage
>> s/DM/DMGetPointSF.html
>> Then you can look at
>>   https://bitbucket.org/petsc/petsc/src/1788fc36644e622df8cb
>> 1a0de85676ccc5af0239/src/dm/impls/plex/plexsubmesh.c?at=
>> master&fileviewer=file-view-default#plexsubmesh.c-683
>> I get the pointSF, get out the list of leaves, and find points in it
>> using PetscFindInt()
>> Hi Matt,
>> By using the local dm, I can get the PetscSF I want, as shown below. Now
>> I need to get the number of ghost cells or local cells (here 4944) or
>> number of leaves (here 825) for each processor. I try to use
>> PetscSFGetGraph to get number of leaves in Fortran. After including
>> "petscsf.h", I got compilation error saying "You need a ISO C conforming
>> compiler to use the glibc headers". Is there any alternative way to do
>> this? I do not need the ghost-neighbor mapping, but just the number of
>> local owned cells.
> Also, make sure you are using the latest Fortran style for PETSc:
> manualpages/Sys/UsingFortran.html
>>   [0] Number of roots=11449, leaves=825, remote ranks=1
>>   [0] 4944 <- (1,0)
>>   [0] 4945 <- (1,28)
>>   [0] 4946 <- (1,56)
>>   [1] Number of roots=11695, leaves=538, remote ranks=1
>>   [1] 5056 <- (0,21)
>>   [1] 5057 <- (0,43)
>>   [1] 5058 <- (0,65)
>>   [1] 5059 <- (0,87)
>> In file included from /usr/include/features.h:375:0,
>>                  from /usr/include/stdio.h:28,
>>                  from /home/dsu/Soft/PETSc/petsc-3.8
>> .3/include/petscsys.h:175,
>> .3/include/petscsf.h:7,
>>                  from ../../solver/solver_ddmethod.F90:4837:
>> /usr/include/x86_64-linux-gnu/sys/cdefs.h:30:3: error: #error "You need
>> a ISO C conforming compile\
>>  # error "You need a ISO C conforming compiler to use the glibc headers"
> Can you send this to petsc-maint at mcs.anl.gov? It looks like a build
> problem that can be fixed.
>   Thanks,
>     Matt
>> Thanks,
>> Danyang
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Danyang
>>>   Thanks,
>>>     Matt
>>>> Thanks,
>>>> Danyang
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.caam.rice.edu/%7Emk51/>
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180304/8aad59c1/attachment.html>
