[petsc-users] how to check if cell is local owned in DMPlex
Matthew Knepley
knepley at gmail.com
Fri Mar 2 12:58:58 CST 2018
On Fri, Mar 2, 2018 at 1:41 PM, Danyang Su <danyang.su at gmail.com> wrote:
> On 18-02-19 03:30 PM, Matthew Knepley wrote:
> On Mon, Feb 19, 2018 at 3:11 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi Matt,
>> Would you please let me know how to check if a cell is local owned? When
>> overlap is 0 in DMPlexDistribute, all the cells are local owned. How about
>> overlap > 0? It sounds like impossible to check by node because a cell can
>> be local owned even if none of the nodes in this cell is local owned.
> If a cell is in the PetscSF, then it is not locally owned. The local nodes
> in the SF are sorted, so I use
> PetscFindInt (http://www.mcs.anl.gov/petsc/petsc-current/docs/
> manualpages/Sys/PetscFindInt.html).
> Hi Matt,
> Would you please give me a little more about how to mark the ghost cells
> when overlap > 0? What do you mean a cell is in the PetscSF? I use
> PetscSFView to export the graph (original mesh file pile.vtk) and it
> exports all the cells, including the ghost cells (PETScSFView.txt).
Yes, I will send you some sample code when I get time. The first problem is
that you are looking at a different PetscSF. This looks like the
one returned by DMPlexDistribute(). This is mapping the serial mesh to the
parallel mesh. You want
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMGetPointSF.html
Then you can look at
https://bitbucket.org/petsc/petsc/src/1788fc36644e622df8cb1a0de85676ccc5af0239/src/dm/impls/plex/plexsubmesh.c?at=master&fileviewer=file-view-default#plexsubmesh.c-683
I get the pointSF, get out the list of leaves, and find points in it using
PetscFindInt()
Matt
> Thanks,
> Danyang
> Thanks,
> Matt
>> Thanks,
>> Danyang
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180302/1f4ff4c4/attachment.html>
