[petsc-users] how to check if cell is local owned in DMPlex
Danyang Su
danyang.su at gmail.com
Fri Mar 2 12:41:55 CST 2018
On 18-02-19 03:30 PM, Matthew Knepley wrote:
> On Mon, Feb 19, 2018 at 3:11 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
> Hi Matt,
> Would you please let me know how to check if a cell is local
> owned? When overlap is 0 in DMPlexDistribute, all the cells are
> local owned. How about overlap > 0? It sounds like impossible to
> check by node because a cell can be local owned even if none of
> the nodes in this cell is local owned.
> If a cell is in the PetscSF, then it is not locally owned. The local
> nodes in the SF are sorted, so I use
> PetscFindInt
> (http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscFindInt.html).
Hi Matt,
Would you please give me a little more about how to mark the ghost cells
when overlap > 0? What do you mean a cell is in the PetscSF? I use
PetscSFView to export the graph (original mesh file pile.vtk) and it
exports all the cells, including the ghost cells (PETScSFView.txt).
Danyang
> Thanks,
> Matt
> Thanks,
> Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180302/0907cdf4/attachment-0001.html>
Create DMPlex from cell list, done
PetscSF Object: 2 MPI processes
type: basic
sort=rank-order
[0] Number of roots=21781, leaves=11449, remote ranks=1
[0] 0 <- (0,0)
[0] 1 <- (0,1)
[0] 2 <- (0,2)
[0] 3 <- (0,3)
[0] 4 <- (0,4)
[0] 5 <- (0,5)
[0] 6 <- (0,6)
[0] 7 <- (0,7)
[0] 8 <- (0,8)
[0] 9 <- (0,9)
[0] 10 <- (0,10)
[0] 11 <- (0,11)
[0] 12 <- (0,12)
[0] 13 <- (0,13)
[0] 14 <- (0,14)
[0] 15 <- (0,15)
[0] 16 <- (0,16)
[0] 17 <- (0,17)
[0] 18 <- (0,18)
[0] 19 <- (0,19)
[0] 20 <- (0,20)
[0] 21 <- (0,21)
[0] 22 <- (0,50)
[0] 23 <- (0,51)
[0] 24 <- (0,52)
[0] 25 <- (0,53)
[0] 26 <- (0,54)
[0] 27 <- (0,55)
[0] 28 <- (0,56)
[0] 29 <- (0,57)
[0] 30 <- (0,58)
[0] 31 <- (0,59)
[0] 32 <- (0,60)
[0] 33 <- (0,61)
[0] 34 <- (0,62)
[0] 35 <- (0,63)
[0] 36 <- (0,64)
[0] 37 <- (0,65)
[0] 38 <- (0,66)
[0] 39 <- (0,67)
[0] 40 <- (0,68)
[0] 41 <- (0,69)
[0] 42 <- (0,70)
[0] 43 <- (0,71)
[0] 44 <- (0,100)
[0] 45 <- (0,101)
[0] 46 <- (0,102)
[0] 47 <- (0,103)
[0] 48 <- (0,104)
[0] 49 <- (0,105)
[0] 50 <- (0,106)
[0] 51 <- (0,107)
[0] 52 <- (0,108)
[0] 53 <- (0,109)
[0] 54 <- (0,110)
[0] 55 <- (0,111)
[0] 56 <- (0,112)
[0] 57 <- (0,113)
[0] 58 <- (0,114)
[0] 59 <- (0,115)
[0] 60 <- (0,116)
[0] 61 <- (0,117)
[0] 62 <- (0,118)
[0] 63 <- (0,119)
[0] 64 <- (0,120)
[0] 65 <- (0,121)
[0] 66 <- (0,150)
[0] 67 <- (0,151)
[0] 68 <- (0,152)
[0] 69 <- (0,153)
[0] 70 <- (0,154)
[0] 71 <- (0,155)
[0] 72 <- (0,156)
[0] 73 <- (0,157)
[0] 74 <- (0,158)
[0] 75 <- (0,159)
[0] 76 <- (0,160)
[0] 77 <- (0,161)
[0] 78 <- (0,162)
[0] 79 <- (0,163)
[0] 80 <- (0,164)
[0] 81 <- (0,165)
[0] 82 <- (0,166)
[0] 83 <- (0,167)
[0] 84 <- (0,168)
[0] 85 <- (0,169)
[0] 86 <- (0,170)
[0] 87 <- (0,171)
[0] 88 <- (0,200)
[0] 89 <- (0,201)
[0] 90 <- (0,202)
[0] 91 <- (0,203)
[0] 92 <- (0,204)
[0] 93 <- (0,205)
[0] 94 <- (0,206)
[0] 95 <- (0,207)
[0] 96 <- (0,208)
[0] 97 <- (0,209)
[0] 98 <- (0,210)
[0] 99 <- (0,211)
[0] 100 <- (0,212)
[0] 101 <- (0,213)
[0] 102 <- (0,214)
[0] 103 <- (0,215)
[0] 104 <- (0,216)
[0] 105 <- (0,217)
[0] 106 <- (0,218)
[0] 107 <- (0,219)
[0] 108 <- (0,220)
[0] 109 <- (0,221)
[0] 110 <- (0,222)
[0] 111 <- (0,250)
[0] 112 <- (0,251)
[0] 113 <- (0,252)
[0] 114 <- (0,253)
[0] 115 <- (0,254)
[0] 116 <- (0,255)
[0] 117 <- (0,256)
[0] 118 <- (0,257)
[0] 119 <- (0,258)
[0] 120 <- (0,259)
[0] 121 <- (0,260)
[0] 122 <- (0,261)
[0] 123 <- (0,262)
[0] 124 <- (0,263)
[0] 125 <- (0,264)
[0] 126 <- (0,265)
[0] 127 <- (0,266)
[0] 128 <- (0,267)
[0] 129 <- (0,268)
[0] 130 <- (0,269)
[0] 131 <- (0,270)
[0] 132 <- (0,271)
[0] 133 <- (0,272)
[0] 134 <- (0,300)
[0] 135 <- (0,301)
[0] 136 <- (0,302)
[0] 137 <- (0,303)
[0] 138 <- (0,304)
[0] 139 <- (0,305)
[0] 140 <- (0,306)
[0] 141 <- (0,307)
[0] 142 <- (0,308)
[0] 143 <- (0,309)
[0] 144 <- (0,310)
[0] 145 <- (0,311)
[0] 146 <- (0,312)
[0] 147 <- (0,313)
[0] 148 <- (0,314)
[0] 149 <- (0,315)
[0] 150 <- (0,316)
[0] 151 <- (0,317)
[0] 152 <- (0,318)
[0] 153 <- (0,319)
[0] 154 <- (0,320)
[0] 155 <- (0,321)
[0] 156 <- (0,322)
[0] 157 <- (0,350)
[0] 158 <- (0,351)
[0] 159 <- (0,352)
[0] 160 <- (0,353)
[0] 161 <- (0,354)
[0] 162 <- (0,355)
[0] 163 <- (0,356)
[0] 164 <- (0,357)
[0] 165 <- (0,358)
[0] 166 <- (0,359)
[0] 167 <- (0,360)
[0] 168 <- (0,361)
[0] 169 <- (0,362)
[0] 170 <- (0,363)
[0] 171 <- (0,364)
[0] 172 <- (0,365)
[0] 173 <- (0,366)
[0] 174 <- (0,367)
[0] 175 <- (0,368)
[0] 176 <- (0,369)
[0] 177 <- (0,370)
[0] 178 <- (0,371)
[0] 179 <- (0,372)
[0] 180 <- (0,400)
[0] 181 <- (0,401)
[0] 182 <- (0,402)
[0] 183 <- (0,403)
[0] 184 <- (0,404)
[0] 185 <- (0,405)
[0] 186 <- (0,406)
[0] 187 <- (0,407)
[0] 188 <- (0,408)
[0] 189 <- (0,409)
[0] 190 <- (0,410)
[0] 191 <- (0,411)
[0] 192 <- (0,412)
[0] 193 <- (0,413)
[0] 194 <- (0,414)
[0] 195 <- (0,415)
[0] 196 <- (0,416)
[0] 197 <- (0,417)
[0] 198 <- (0,418)
[0] 199 <- (0,419)
[0] 200 <- (0,420)
[0] 201 <- (0,421)
[0] 202 <- (0,422)
[0] 203 <- (0,423)
[0] 204 <- (0,450)
[0] 205 <- (0,451)
[0] 206 <- (0,452)
[0] 207 <- (0,453)
[0] 208 <- (0,454)
[0] 209 <- (0,455)
[0] 210 <- (0,456)
[0] 211 <- (0,457)
[0] 212 <- (0,458)
[0] 213 <- (0,459)
[0] 214 <- (0,460)
[0] 215 <- (0,461)
[0] 216 <- (0,462)
[0] 217 <- (0,463)
[0] 218 <- (0,464)
[0] 219 <- (0,465)
[0] 220 <- (0,466)
[0] 221 <- (0,467)
[0] 222 <- (0,468)
[0] 223 <- (0,469)
[0] 224 <- (0,470)
[0] 225 <- (0,471)
[0] 226 <- (0,472)
[0] 227 <- (0,473)
[0] 228 <- (0,500)
[0] 229 <- (0,501)
[0] 230 <- (0,502)
[0] 231 <- (0,503)
[0] 232 <- (0,504)
[0] 233 <- (0,505)
[0] 234 <- (0,506)
[0] 235 <- (0,507)
[0] 236 <- (0,508)
[0] 237 <- (0,509)
[0] 238 <- (0,510)
[0] 239 <- (0,511)
[0] 240 <- (0,512)
[0] 241 <- (0,513)
[0] 242 <- (0,514)
[0] 243 <- (0,515)
[0] 244 <- (0,516)
[0] 245 <- (0,517)
[0] 246 <- (0,518)
[0] 247 <- (0,519)
[0] 248 <- (0,520)
[0] 249 <- (0,521)
[0] 250 <- (0,522)
[0] 251 <- (0,523)
[0] 252 <- (0,524)
[0] 253 <- (0,550)
[0] 254 <- (0,551)
[0] 255 <- (0,552)
[0] 256 <- (0,553)
[0] 257 <- (0,554)
[0] 258 <- (0,555)
[0] 259 <- (0,556)
[0] 260 <- (0,557)
[0] 261 <- (0,558)
[0] 262 <- (0,559)
[0] 263 <- (0,560)
[0] 264 <- (0,561)
[0] 265 <- (0,562)
[0] 266 <- (0,563)
[0] 267 <- (0,564)
[0] 268 <- (0,565)
[0] 269 <- (0,566)
[0] 270 <- (0,567)
[0] 271 <- (0,568)
[0] 272 <- (0,569)
[0] 273 <- (0,570)
[0] 274 <- (0,571)
[0] 275 <- (0,572)
[0] 276 <- (0,573)
[0] 277 <- (0,574)
[0] 278 <- (0,575)
[0] 279 <- (0,600)
[0] 280 <- (0,601)
[0] 281 <- (0,602)
[0] 282 <- (0,603)
[0] 283 <- (0,604)
[0] 284 <- (0,605)
[0] 285 <- (0,606)
[0] 286 <- (0,607)
[0] 287 <- (0,608)
[0] 288 <- (0,609)
[0] 289 <- (0,610)
[0] 290 <- (0,611)
[0] 291 <- (0,612)
[0] 292 <- (0,613)
[0] 293 <- (0,614)
[0] 294 <- (0,615)
[0] 295 <- (0,616)
[0] 296 <- (0,617)
[0] 297 <- (0,618)
[0] 298 <- (0,619)
[0] 299 <- (0,620)
[0] 300 <- (0,621)
[0] 301 <- (0,622)
[0] 302 <- (0,623)
[0] 303 <- (0,624)
[0] 304 <- (0,625)
[0] 305 <- (0,650)
[0] 306 <- (0,651)
[0] 307 <- (0,652)
[0] 308 <- (0,653)
[0] 309 <- (0,654)
[0] 310 <- (0,655)
[0] 311 <- (0,656)
[0] 312 <- (0,657)
[0] 313 <- (0,658)
[0] 314 <- (0,659)
[0] 315 <- (0,660)
[0] 316 <- (0,661)
[0] 317 <- (0,662)
[0] 318 <- (0,663)
[0] 319 <- (0,664)
[0] 320 <- (0,665)
[0] 321 <- (0,666)
[0] 322 <- (0,667)
[0] 323 <- (0,668)
[0] 324 <- (0,669)
[0] 325 <- (0,670)
[0] 326 <- (0,671)
[0] 327 <- (0,672)
[0] 328 <- (0,673)
[0] 329 <- (0,674)
[0] 330 <- (0,675)
[0] 331 <- (0,676)
[0] 332 <- (0,700)
[0] 333 <- (0,701)
[0] 334 <- (0,702)
[0] 335 <- (0,703)
[0] 336 <- (0,704)
[0] 337 <- (0,705)
[0] 338 <- (0,706)
[0] 339 <- (0,707)
[0] 340 <- (0,708)
[0] 341 <- (0,709)
[0] 342 <- (0,710)
[0] 343 <- (0,711)
[0] 344 <- (0,712)
[0] 345 <- (0,713)
[0] 346 <- (0,714)
[0] 347 <- (0,715)
[0] 348 <- (0,716)
[0] 349 <- (0,717)
[0] 350 <- (0,718)
[0] 351 <- (0,719)
[0] 352 <- (0,720)
[0] 353 <- (0,721)
[0] 354 <- (0,722)
[0] 355 <- (0,723)
[0] 356 <- (0,724)
[0] 357 <- (0,725)
[0] 358 <- (0,726)
[0] 359 <- (0,750)
[0] 360 <- (0,751)
[0] 361 <- (0,752)
[0] 362 <- (0,753)
[0] 363 <- (0,754)
[0] 364 <- (0,755)
[0] 365 <- (0,756)
[0] 366 <- (0,757)
[0] 367 <- (0,758)
[0] 368 <- (0,759)
[0] 369 <- (0,760)
[0] 370 <- (0,761)
[0] 371 <- (0,762)
[0] 372 <- (0,763)
[0] 373 <- (0,764)
[0] 374 <- (0,765)
[0] 375 <- (0,766)
[0] 376 <- (0,767)
[0] 377 <- (0,768)
[0] 378 <- (0,769)
[0] 379 <- (0,770)
[0] 380 <- (0,771)
[0] 381 <- (0,772)
[0] 382 <- (0,773)
[0] 383 <- (0,774)
[0] 384 <- (0,775)
[0] 385 <- (0,776)
[0] 386 <- (0,800)
[0] 387 <- (0,801)
[0] 388 <- (0,802)
[0] 389 <- (0,803)
[0] 390 <- (0,804)
[0] 391 <- (0,805)
[0] 392 <- (0,806)
[0] 393 <- (0,807)
[0] 394 <- (0,808)
[0] 395 <- (0,809)
[0] 396 <- (0,810)
[0] 397 <- (0,811)
[0] 398 <- (0,812)
[0] 399 <- (0,813)
[0] 400 <- (0,814)
[0] 401 <- (0,815)
[0] 402 <- (0,816)
[0] 403 <- (0,817)
[0] 404 <- (0,818)
[0] 405 <- (0,819)
[0] 406 <- (0,820)
[0] 407 <- (0,821)
[0] 408 <- (0,822)
[0] 409 <- (0,823)
[0] 410 <- (0,824)
[0] 411 <- (0,825)
[0] 412 <- (0,826)
[0] 413 <- (0,850)
[0] 414 <- (0,851)
[0] 415 <- (0,852)
[0] 416 <- (0,853)
[0] 417 <- (0,854)
[0] 418 <- (0,855)
[0] 419 <- (0,856)
[0] 420 <- (0,857)
[0] 421 <- (0,858)
[0] 422 <- (0,859)
[0] 423 <- (0,860)
[0] 424 <- (0,861)
[0] 425 <- (0,862)
[0] 426 <- (0,863)
[0] 427 <- (0,864)
[0] 428 <- (0,865)
[0] 429 <- (0,866)
[0] 430 <- (0,867)
[0] 431 <- (0,868)
[0] 432 <- (0,869)
[0] 433 <- (0,870)
[0] 434 <- (0,871)
[0] 435 <- (0,872)
[0] 436 <- (0,873)
[0] 437 <- (0,874)
[0] 438 <- (0,875)
[0] 439 <- (0,876)
[0] 440 <- (0,900)
[0] 441 <- (0,901)
[0] 442 <- (0,902)
[0] 443 <- (0,903)
[0] 444 <- (0,904)
[0] 445 <- (0,905)
[0] 446 <- (0,906)
[0] 447 <- (0,907)
[0] 448 <- (0,908)
[0] 449 <- (0,909)
[0] 450 <- (0,910)
[0] 451 <- (0,911)
[0] 452 <- (0,912)
[0] 453 <- (0,913)
[0] 454 <- (0,914)
[0] 455 <- (0,915)
[0] 456 <- (0,916)
[0] 457 <- (0,917)
[0] 458 <- (0,918)
[0] 459 <- (0,919)
[0] 460 <- (0,920)
[0] 461 <- (0,921)
[0] 462 <- (0,922)
[0] 463 <- (0,923)
[0] 464 <- (0,924)
[0] 465 <- (0,925)
[0] 466 <- (0,926)
[0] 467 <- (0,950)
[0] 468 <- (0,951)
[0] 469 <- (0,952)
[0] 470 <- (0,953)
[0] 471 <- (0,954)
[0] 472 <- (0,955)
[0] 473 <- (0,956)
[0] 474 <- (0,957)
[0] 475 <- (0,958)
[0] 476 <- (0,959)
[0] 477 <- (0,960)
[0] 478 <- (0,961)
[0] 479 <- (0,962)
[0] 480 <- (0,963)
[0] 481 <- (0,964)
[0] 482 <- (0,965)
[0] 483 <- (0,966)
[0] 484 <- (0,967)
[0] 485 <- (0,968)
[0] 486 <- (0,969)
[0] 487 <- (0,970)
[0] 488 <- (0,971)
[0] 489 <- (0,972)
[0] 490 <- (0,973)
[0] 491 <- (0,974)
[0] 492 <- (0,975)
[0] 493 <- (0,976)
[0] 494 <- (0,1000)
[0] 495 <- (0,1001)
[0] 496 <- (0,1002)
[0] 497 <- (0,1003)
[0] 498 <- (0,1004)
[0] 499 <- (0,1005)
[0] 500 <- (0,1006)
[0] 501 <- (0,1007)
[0] 502 <- (0,1008)
[0] 503 <- (0,1009)
[0] 504 <- (0,1010)
[0] 505 <- (0,1011)
[0] 506 <- (0,1012)
[0] 507 <- (0,1013)
[0] 508 <- (0,1014)
[0] 509 <- (0,1015)
[0] 510 <- (0,1016)
[0] 511 <- (0,1017)
[0] 512 <- (0,1018)
[0] 513 <- (0,1019)
[0] 514 <- (0,1020)
[0] 515 <- (0,1021)
[0] 516 <- (0,1050)
[0] 517 <- (0,1051)
[0] 518 <- (0,1052)
[0] 519 <- (0,1053)
[0] 520 <- (0,1054)
[0] 521 <- (0,1055)
[0] 522 <- (0,1056)
[0] 523 <- (0,1057)
[0] 524 <- (0,1058)
[0] 525 <- (0,1059)
[0] 526 <- (0,1060)
[0] 527 <- (0,1061)
[0] 528 <- (0,1062)
[0] 529 <- (0,1063)
[0] 530 <- (0,1064)
[0] 531 <- (0,1065)
[0] 532 <- (0,1066)
[0] 533 <- (0,1067)
[0] 534 <- (0,1068)
[0] 535 <- (0,1069)
[0] 536 <- (0,1070)
[0] 537 <- (0,1071)
[0] 538 <- (0,1100)
[0] 539 <- (0,1101)
[0] 540 <- (0,1102)
[0] 541 <- (0,1103)
[0] 542 <- (0,1104)
[0] 543 <- (0,1105)
[0] 544 <- (0,1106)
[0] 545 <- (0,1107)
[0] 546 <- (0,1108)
[0] 547 <- (0,1109)
[0] 548 <- (0,1110)
[0] 549 <- (0,1111)
[0] 550 <- (0,1112)
[0] 551 <- (0,1113)
[0] 552 <- (0,1114)
[0] 553 <- (0,1115)
[0] 554 <- (0,1116)
[0] 555 <- (0,1117)
[0] 556 <- (0,1118)
[0] 557 <- (0,1119)
[0] 558 <- (0,1120)
[0] 559 <- (0,1121)
[0] 560 <- (0,1150)
[0] 561 <- (0,1151)
[0] 562 <- (0,1152)
[0] 563 <- (0,1153)
[0] 564 <- (0,1154)
[0] 565 <- (0,1155)
[0] 566 <- (0,1156)
[0] 567 <- (0,1157)
[0] 568 <- (0,1158)
[0] 569 <- (0,1159)
[0] 570 <- (0,1160)
[0] 571 <- (0,1161)
[0] 572 <- (0,1162)
[0] 573 <- (0,1163)
[0] 574 <- (0,1164)
[0] 575 <- (0,1165)
[0] 576 <- (0,1166)
[0] 577 <- (0,1167)
[0] 578 <- (0,1168)
[0] 579 <- (0,1169)
[0] 580 <- (0,1170)
[0] 581 <- (0,1171)
[0] 582 <- (0,1200)
[0] 583 <- (0,1201)
[0] 584 <- (0,1202)
[0] 585 <- (0,1203)
[0] 586 <- (0,1204)
[0] 587 <- (0,1205)
[0] 588 <- (0,1206)
[0] 589 <- (0,1207)
[0] 590 <- (0,1208)
[0] 591 <- (0,1209)
[0] 592 <- (0,1210)
[0] 593 <- (0,1211)
[0] 594 <- (0,1212)
[0] 595 <- (0,1213)
[0] 596 <- (0,1214)
[0] 597 <- (0,1215)
[0] 598 <- (0,1216)
[0] 599 <- (0,1217)
[0] 600 <- (0,1218)
[0] 601 <- (0,1219)
[0] 602 <- (0,1220)
[0] 603 <- (0,1221)
[0] 604 <- (0,1222)
[0] 605 <- (0,1250)
[0] 606 <- (0,1251)
[0] 607 <- (0,1252)
[0] 608 <- (0,1253)
[0] 609 <- (0,1254)
[0] 610 <- (0,1255)
[0] 611 <- (0,1256)
[0] 612 <- (0,1257)
[0] 613 <- (0,1258)
[0] 614 <- (0,1259)
[0] 615 <- (0,1260)
[0] 616 <- (0,1261)
[0] 617 <- (0,1262)
[0] 618 <- (0,1263)
[0] 619 <- (0,1264)
[0] 620 <- (0,1265)
[0] 621 <- (0,1266)
[0] 622 <- (0,1267)
[0] 623 <- (0,1268)
[0] 624 <- (0,1269)
[0] 625 <- (0,1270)
[0] 626 <- (0,1271)
[0] 627 <- (0,1272)
[0] 628 <- (0,1300)
[0] 629 <- (0,1301)
[0] 630 <- (0,1302)
[0] 631 <- (0,1303)
[0] 632 <- (0,1304)
[0] 633 <- (0,1305)
[0] 634 <- (0,1306)
[0] 635 <- (0,1307)
[0] 636 <- (0,1308)
[0] 637 <- (0,1309)
[0] 638 <- (0,1310)
[0] 639 <- (0,1311)
[0] 640 <- (0,1312)
[0] 641 <- (0,1313)
[0] 642 <- (0,1314)
[0] 643 <- (0,1315)
[0] 644 <- (0,1316)
[0] 645 <- (0,1317)
[0] 646 <- (0,1318)
[0] 647 <- (0,1319)
[0] 648 <- (0,1320)
[0] 649 <- (0,1321)
[0] 650 <- (0,1322)
[0] 651 <- (0,1350)
[0] 652 <- (0,1351)
[0] 653 <- (0,1352)
[0] 654 <- (0,1353)
[0] 655 <- (0,1354)
[0] 656 <- (0,1355)
[0] 657 <- (0,1356)
[0] 658 <- (0,1357)
[0] 659 <- (0,1358)
[0] 660 <- (0,1359)
[0] 661 <- (0,1360)
[0] 662 <- (0,1361)
[0] 663 <- (0,1362)
[0] 664 <- (0,1363)
[0] 665 <- (0,1364)
[0] 666 <- (0,1365)
[0] 667 <- (0,1366)
[0] 668 <- (0,1367)
[0] 669 <- (0,1368)
[0] 670 <- (0,1369)
[0] 671 <- (0,1370)
[0] 672 <- (0,1371)
[0] 673 <- (0,1372)
[0] 674 <- (0,1400)
[0] 675 <- (0,1401)
[0] 676 <- (0,1402)
[0] 677 <- (0,1403)
[0] 678 <- (0,1404)
[0] 679 <- (0,1405)
[0] 680 <- (0,1406)
[0] 681 <- (0,1407)
[0] 682 <- (0,1408)
[0] 683 <- (0,1409)
[0] 684 <- (0,1410)
[0] 685 <- (0,1411)
[0] 686 <- (0,1412)
[0] 687 <- (0,1413)
[0] 688 <- (0,1414)
[0] 689 <- (0,1415)
[0] 690 <- (0,1416)
[0] 691 <- (0,1417)
[0] 692 <- (0,1418)
[0] 693 <- (0,1419)
[0] 694 <- (0,1420)
[0] 695 <- (0,1421)
[0] 696 <- (0,1422)
[0] 697 <- (0,1423)
[0] 698 <- (0,1450)
[0] 699 <- (0,1451)
[0] 700 <- (0,1452)
[0] 701 <- (0,1453)
[0] 702 <- (0,1454)
[0] 703 <- (0,1455)
[0] 704 <- (0,1456)
[0] 705 <- (0,1457)
[0] 706 <- (0,1458)
[0] 707 <- (0,1459)
[0] 708 <- (0,1460)
[0] 709 <- (0,1461)
[0] 710 <- (0,1462)
[0] 711 <- (0,1463)
[0] 712 <- (0,1464)
[0] 713 <- (0,1465)
[0] 714 <- (0,1466)
[0] 715 <- (0,1467)
[0] 716 <- (0,1468)
[0] 717 <- (0,1469)
[0] 718 <- (0,1470)
[0] 719 <- (0,1471)
[0] 720 <- (0,1472)
[0] 721 <- (0,1473)
[0] 722 <- (0,1500)
[0] 723 <- (0,1501)
[0] 724 <- (0,1502)
[0] 725 <- (0,1503)
[0] 726 <- (0,1504)
[0] 727 <- (0,1505)
[0] 728 <- (0,1506)
[0] 729 <- (0,1507)
[0] 730 <- (0,1508)
[0] 731 <- (0,1509)
[0] 732 <- (0,1510)
[0] 733 <- (0,1511)
[0] 734 <- (0,1512)
[0] 735 <- (0,1513)
[0] 736 <- (0,1514)
[0] 737 <- (0,1515)
[0] 738 <- (0,1516)
[0] 739 <- (0,1517)
[0] 740 <- (0,1518)
[0] 741 <- (0,1519)
[0] 742 <- (0,1520)
[0] 743 <- (0,1521)
[0] 744 <- (0,1522)
[0] 745 <- (0,1523)
[0] 746 <- (0,1524)
[0] 747 <- (0,1550)
[0] 748 <- (0,1551)
[0] 749 <- (0,1552)
[0] 750 <- (0,1553)
[0] 751 <- (0,1554)
[0] 752 <- (0,1555)
[0] 753 <- (0,1556)
[0] 754 <- (0,1557)
[0] 755 <- (0,1558)
[0] 756 <- (0,1559)
[0] 757 <- (0,1560)
[0] 758 <- (0,1561)
[0] 759 <- (0,1562)
[0] 760 <- (0,1563)
[0] 761 <- (0,1564)
[0] 762 <- (0,1565)
[0] 763 <- (0,1566)
[0] 764 <- (0,1567)
[0] 765 <- (0,1568)
[0] 766 <- (0,1569)
[0] 767 <- (0,1570)
[0] 768 <- (0,1571)
[0] 769 <- (0,1572)
[0] 770 <- (0,1573)
[0] 771 <- (0,1574)
[0] 772 <- (0,1575)
[0] 773 <- (0,1600)
[0] 774 <- (0,1601)
[0] 775 <- (0,1602)
[0] 776 <- (0,1603)
[0] 777 <- (0,1604)
[0] 778 <- (0,1605)
[0] 779 <- (0,1606)
[0] 780 <- (0,1607)
[0] 781 <- (0,1608)
[0] 782 <- (0,1609)
[0] 783 <- (0,1610)
[0] 784 <- (0,1611)
[0] 785 <- (0,1612)
[0] 786 <- (0,1613)
[0] 787 <- (0,1614)
[0] 788 <- (0,1615)
[0] 789 <- (0,1616)
[0] 790 <- (0,1617)
[0] 791 <- (0,1618)
[0] 792 <- (0,1619)
[0] 793 <- (0,1620)
[0] 794 <- (0,1621)
[0] 795 <- (0,1622)
[0] 796 <- (0,1623)
[0] 797 <- (0,1624)
[0] 798 <- (0,1625)
[0] 799 <- (0,1650)
[0] 800 <- (0,1651)
[0] 801 <- (0,1652)
[0] 802 <- (0,1653)
[0] 803 <- (0,1654)
[0] 804 <- (0,1655)
[0] 805 <- (0,1656)
[0] 806 <- (0,1657)
[0] 807 <- (0,1658)
[0] 808 <- (0,1659)
[0] 809 <- (0,1660)
[0] 810 <- (0,1661)
[0] 811 <- (0,1662)
[0] 812 <- (0,1663)
[0] 813 <- (0,1664)
[0] 814 <- (0,1665)
[0] 815 <- (0,1666)
[0] 816 <- (0,1667)
[0] 817 <- (0,1668)
[0] 818 <- (0,1669)
[0] 819 <- (0,1670)
[0] 820 <- (0,1671)
[0] 821 <- (0,1672)
[0] 822 <- (0,1673)
[0] 823 <- (0,1674)
[0] 824 <- (0,1675)
[0] 825 <- (0,1676)
[0] 826 <- (0,1700)
[0] 827 <- (0,1701)
[0] 828 <- (0,1702)
[0] 829 <- (0,1703)
[0] 830 <- (0,1704)
[0] 831 <- (0,1705)
[0] 832 <- (0,1706)
[0] 833 <- (0,1707)
[0] 834 <- (0,1708)
[0] 835 <- (0,1709)
[0] 836 <- (0,1710)
[0] 837 <- (0,1711)
[0] 838 <- (0,1712)
[0] 839 <- (0,1713)
[0] 840 <- (0,1714)
[0] 841 <- (0,1715)
[0] 842 <- (0,1716)
[0] 843 <- (0,1717)
[0] 844 <- (0,1718)
[0] 845 <- (0,1719)
[0] 846 <- (0,1720)
[0] 847 <- (0,1721)
[0] 848 <- (0,1722)
[0] 849 <- (0,1723)
[0] 850 <- (0,1724)
[0] 851 <- (0,1725)
[0] 852 <- (0,1726)
[0] 853 <- (0,1750)
[0] 854 <- (0,1751)
[0] 855 <- (0,1752)
[0] 856 <- (0,1753)
[0] 857 <- (0,1754)
[0] 858 <- (0,1755)
[0] 859 <- (0,1756)
[0] 860 <- (0,1757)
[0] 861 <- (0,1758)
[0] 862 <- (0,1759)
[0] 863 <- (0,1760)
[0] 864 <- (0,1761)
[0] 865 <- (0,1762)
[0] 866 <- (0,1763)
[0] 867 <- (0,1764)
[0] 868 <- (0,1765)
[0] 869 <- (0,1766)
[0] 870 <- (0,1767)
[0] 871 <- (0,1768)
[0] 872 <- (0,1769)
[0] 873 <- (0,1770)
[0] 874 <- (0,1771)
[0] 875 <- (0,1772)
[0] 876 <- (0,1773)
[0] 877 <- (0,1774)
[0] 878 <- (0,1775)
[0] 879 <- (0,1776)
[0] 880 <- (0,1800)
[0] 881 <- (0,1801)
[0] 882 <- (0,1802)
[0] 883 <- (0,1803)
[0] 884 <- (0,1804)
[0] 885 <- (0,1805)
[0] 886 <- (0,1806)
[0] 887 <- (0,1807)
[0] 888 <- (0,1808)
[0] 889 <- (0,1809)
[0] 890 <- (0,1810)
[0] 891 <- (0,1811)
[0] 892 <- (0,1812)
[0] 893 <- (0,1813)
[0] 894 <- (0,1814)
[0] 895 <- (0,1815)
[0] 896 <- (0,1816)
[0] 897 <- (0,1817)
[0] 898 <- (0,1818)
[0] 899 <- (0,1819)
[0] 900 <- (0,1820)
[0] 901 <- (0,1821)
[0] 902 <- (0,1822)
[0] 903 <- (0,1823)
[0] 904 <- (0,1824)
[0] 905 <- (0,1825)
[0] 906 <- (0,1826)
[0] 907 <- (0,1850)
[0] 908 <- (0,1851)
[0] 909 <- (0,1852)
[0] 910 <- (0,1853)
[0] 911 <- (0,1854)
[0] 912 <- (0,1855)
[0] 913 <- (0,1856)
[0] 914 <- (0,1857)
[0] 915 <- (0,1858)
[0] 916 <- (0,1859)
[0] 917 <- (0,1860)
[0] 918 <- (0,1861)
[0] 919 <- (0,1862)
[0] 920 <- (0,1863)
[0] 921 <- (0,1864)
[0] 922 <- (0,1865)
[0] 923 <- (0,1866)
[0] 924 <- (0,1867)
[0] 925 <- (0,1868)
[0] 926 <- (0,1869)
[0] 927 <- (0,1870)
[0] 928 <- (0,1871)
[0] 929 <- (0,1872)
[0] 930 <- (0,1873)
[0] 931 <- (0,1874)
[0] 932 <- (0,1875)
[0] 933 <- (0,1876)
[0] 934 <- (0,1900)
[0] 935 <- (0,1901)
[0] 936 <- (0,1902)
[0] 937 <- (0,1903)
[0] 938 <- (0,1904)
[0] 939 <- (0,1905)
[0] 940 <- (0,1906)
[0] 941 <- (0,1907)
[0] 942 <- (0,1908)
[0] 943 <- (0,1909)
[0] 944 <- (0,1910)
[0] 945 <- (0,1911)
[0] 946 <- (0,1912)
[0] 947 <- (0,1913)
[0] 948 <- (0,1914)
[0] 949 <- (0,1915)
[0] 950 <- (0,1916)
[0] 951 <- (0,1917)
[0] 952 <- (0,1918)
[0] 953 <- (0,1919)
[0] 954 <- (0,1920)
[0] 955 <- (0,1921)
[0] 956 <- (0,1922)
[0] 957 <- (0,1923)
[0] 958 <- (0,1924)
[0] 959 <- (0,1925)
[0] 960 <- (0,1926)
[0] 961 <- (0,1950)
[0] 962 <- (0,1951)
[0] 963 <- (0,1952)
[0] 964 <- (0,1953)
[0] 965 <- (0,1954)
[0] 966 <- (0,1955)
[0] 967 <- (0,1956)
[0] 968 <- (0,1957)
[0] 969 <- (0,1958)
[0] 970 <- (0,1959)
[0] 971 <- (0,1960)
[0] 972 <- (0,1961)
[0] 973 <- (0,1962)
[0] 974 <- (0,1963)
[0] 975 <- (0,1964)
[0] 976 <- (0,1965)
[0] 977 <- (0,1966)
[0] 978 <- (0,1967)
[0] 979 <- (0,1968)
[0] 980 <- (0,1969)
[0] 981 <- (0,1970)
[0] 982 <- (0,1971)
[0] 983 <- (0,1972)
[0] 984 <- (0,1973)
[0] 985 <- (0,1974)
[0] 986 <- (0,1975)
[0] 987 <- (0,1976)
[0] 988 <- (0,2000)
[0] 989 <- (0,2001)
[0] 990 <- (0,2002)
[0] 991 <- (0,2003)
[0] 992 <- (0,2004)
[0] 993 <- (0,2005)
[0] 994 <- (0,2006)
[0] 995 <- (0,2007)
[0] 996 <- (0,2008)
[0] 997 <- (0,2009)
[0] 998 <- (0,2010)
[0] 999 <- (0,2011)
[0] 1000 <- (0,2012)
[0] 1001 <- (0,2013)
[0] 1002 <- (0,2014)
[0] 1003 <- (0,2015)
[0] 1004 <- (0,2016)
[0] 1005 <- (0,2017)
[0] 1006 <- (0,2018)
[0] 1007 <- (0,2019)
[0] 1008 <- (0,2020)
[0] 1009 <- (0,2021)
[0] 1010 <- (0,2050)
[0] 1011 <- (0,2051)
[0] 1012 <- (0,2052)
[0] 1013 <- (0,2053)
[0] 1014 <- (0,2054)
[0] 1015 <- (0,2055)
[0] 1016 <- (0,2056)
[0] 1017 <- (0,2057)
[0] 1018 <- (0,2058)
[0] 1019 <- (0,2059)
[0] 1020 <- (0,2060)
[0] 1021 <- (0,2061)
[0] 1022 <- (0,2062)
[0] 1023 <- (0,2063)
[0] 1024 <- (0,2064)
[0] 1025 <- (0,2065)
[0] 1026 <- (0,2066)
[0] 1027 <- (0,2067)
[0] 1028 <- (0,2068)
[0] 1029 <- (0,2069)
[0] 1030 <- (0,2070)
[0] 1031 <- (0,2071)
[0] 1032 <- (0,2100)
[0] 1033 <- (0,2101)
[0] 1034 <- (0,2102)
[0] 1035 <- (0,2103)
[0] 1036 <- (0,2104)
[0] 1037 <- (0,2105)
[0] 1038 <- (0,2106)
[0] 1039 <- (0,2107)
[0] 1040 <- (0,2108)
[0] 1041 <- (0,2109)
[0] 1042 <- (0,2110)
[0] 1043 <- (0,2111)
[0] 1044 <- (0,2112)
[0] 1045 <- (0,2113)
[0] 1046 <- (0,2114)
[0] 1047 <- (0,2115)
[0] 1048 <- (0,2116)
[0] 1049 <- (0,2117)
[0] 1050 <- (0,2118)
[0] 1051 <- (0,2119)
[0] 1052 <- (0,2120)
[0] 1053 <- (0,2121)
[0] 1054 <- (0,2150)
[0] 1055 <- (0,2151)
[0] 1056 <- (0,2152)
[0] 1057 <- (0,2153)
[0] 1058 <- (0,2154)
[0] 1059 <- (0,2155)
[0] 1060 <- (0,2156)
[0] 1061 <- (0,2157)
[0] 1062 <- (0,2158)
[0] 1063 <- (0,2159)
[0] 1064 <- (0,2160)
[0] 1065 <- (0,2161)
[0] 1066 <- (0,2162)
[0] 1067 <- (0,2163)
[0] 1068 <- (0,2164)
[0] 1069 <- (0,2165)
[0] 1070 <- (0,2166)
[0] 1071 <- (0,2167)
[0] 1072 <- (0,2168)
[0] 1073 <- (0,2169)
[0] 1074 <- (0,2170)
[0] 1075 <- (0,2171)
[0] 1076 <- (0,2200)
[0] 1077 <- (0,2201)
[0] 1078 <- (0,2202)
[0] 1079 <- (0,2203)
[0] 1080 <- (0,2204)
[0] 1081 <- (0,2205)
[0] 1082 <- (0,2206)
[0] 1083 <- (0,2207)
[0] 1084 <- (0,2208)
[0] 1085 <- (0,2209)
[0] 1086 <- (0,2210)
[0] 1087 <- (0,2211)
[0] 1088 <- (0,2212)
[0] 1089 <- (0,2213)
[0] 1090 <- (0,2214)
[0] 1091 <- (0,2215)
[0] 1092 <- (0,2216)
[0] 1093 <- (0,2217)
[0] 1094 <- (0,2218)
[0] 1095 <- (0,2219)
[0] 1096 <- (0,2220)
[0] 1097 <- (0,2221)
[0] 1098 <- (0,2222)
[0] 1099 <- (0,2250)
[0] 1100 <- (0,2251)
[0] 1101 <- (0,2252)
[0] 1102 <- (0,2253)
[0] 1103 <- (0,2254)
[0] 1104 <- (0,2255)
[0] 1105 <- (0,2256)
[0] 1106 <- (0,2257)
[0] 1107 <- (0,2258)
[0] 1108 <- (0,2259)
[0] 1109 <- (0,2260)
[0] 1110 <- (0,2261)
[0] 1111 <- (0,2262)
[0] 1112 <- (0,2263)
[0] 1113 <- (0,2264)
[0] 1114 <- (0,2265)
[0] 1115 <- (0,2266)
[0] 1116 <- (0,2267)
[0] 1117 <- (0,2268)
[0] 1118 <- (0,2269)
[0] 1119 <- (0,2270)
[0] 1120 <- (0,2271)
[0] 1121 <- (0,2272)
[0] 1122 <- (0,2300)
[0] 1123 <- (0,2301)
[0] 1124 <- (0,2302)
[0] 1125 <- (0,2303)
[0] 1126 <- (0,2304)
[0] 1127 <- (0,2305)
[0] 1128 <- (0,2306)
[0] 1129 <- (0,2307)
[0] 1130 <- (0,2308)
[0] 1131 <- (0,2309)
[0] 1132 <- (0,2310)
[0] 1133 <- (0,2311)
[0] 1134 <- (0,2312)
[0] 1135 <- (0,2313)
[0] 1136 <- (0,2314)
[0] 1137 <- (0,2315)
[0] 1138 <- (0,2316)
[0] 1139 <- (0,2317)
[0] 1140 <- (0,2318)
[0] 1141 <- (0,2319)
[0] 1142 <- (0,2320)
[0] 1143 <- (0,2321)
[0] 1144 <- (0,2322)
[0] 1145 <- (0,2350)
[0] 1146 <- (0,2351)
[0] 1147 <- (0,2352)
[0] 1148 <- (0,2353)
[0] 1149 <- (0,2354)
[0] 1150 <- (0,2355)
[0] 1151 <- (0,2356)
[0] 1152 <- (0,2357)
[0] 1153 <- (0,2358)
[0] 1154 <- (0,2359)
[0] 1155 <- (0,2360)
[0] 1156 <- (0,2361)
[0] 1157 <- (0,2362)
[0] 1158 <- (0,2363)
[0] 1159 <- (0,2364)
[0] 1160 <- (0,2365)
[0] 1161 <- (0,2366)
[0] 1162 <- (0,2367)
[0] 1163 <- (0,2368)
[0] 1164 <- (0,2369)
[0] 1165 <- (0,2370)
[0] 1166 <- (0,2371)
[0] 1167 <- (0,2372)
[0] 1168 <- (0,2400)
[0] 1169 <- (0,2401)
[0] 1170 <- (0,2402)
[0] 1171 <- (0,2403)
[0] 1172 <- (0,2404)
[0] 1173 <- (0,2405)
[0] 1174 <- (0,2406)
[0] 1175 <- (0,2407)
[0] 1176 <- (0,2408)
[0] 1177 <- (0,2409)
[0] 1178 <- (0,2410)
[0] 1179 <- (0,2411)
[0] 1180 <- (0,2412)
[0] 1181 <- (0,2413)
[0] 1182 <- (0,2414)
[0] 1183 <- (0,2415)
[0] 1184 <- (0,2416)
[0] 1185 <- (0,2417)
[0] 1186 <- (0,2418)
[0] 1187 <- (0,2419)
[0] 1188 <- (0,2420)
[0] 1189 <- (0,2421)
[0] 1190 <- (0,2422)
[0] 1191 <- (0,2423)
[0] 1192 <- (0,2450)
[0] 1193 <- (0,2451)
[0] 1194 <- (0,2452)
[0] 1195 <- (0,2453)
[0] 1196 <- (0,2454)
[0] 1197 <- (0,2455)
[0] 1198 <- (0,2456)
[0] 1199 <- (0,2457)
[0] 1200 <- (0,2458)
[0] 1201 <- (0,2459)
[0] 1202 <- (0,2460)
[0] 1203 <- (0,2461)
[0] 1204 <- (0,2462)
[0] 1205 <- (0,2463)
[0] 1206 <- (0,2464)
[0] 1207 <- (0,2465)
[0] 1208 <- (0,2466)
[0] 1209 <- (0,2467)
[0] 1210 <- (0,2468)
[0] 1211 <- (0,2469)
[0] 1212 <- (0,2470)
[0] 1213 <- (0,2471)
[0] 1214 <- (0,2472)
[0] 1215 <- (0,2473)
[0] 1216 <- (0,2500)
[0] 1217 <- (0,2501)
[0] 1218 <- (0,2502)
[0] 1219 <- (0,2503)
[0] 1220 <- (0,2504)
[0] 1221 <- (0,2505)
[0] 1222 <- (0,2506)
[0] 1223 <- (0,2507)
[0] 1224 <- (0,2508)
[0] 1225 <- (0,2509)
[0] 1226 <- (0,2510)
[0] 1227 <- (0,2511)
[0] 1228 <- (0,2512)
[0] 1229 <- (0,2513)
[0] 1230 <- (0,2514)
[0] 1231 <- (0,2515)
[0] 1232 <- (0,2516)
[0] 1233 <- (0,2517)
[0] 1234 <- (0,2518)
[0] 1235 <- (0,2519)
[0] 1236 <- (0,2520)
[0] 1237 <- (0,2521)
[0] 1238 <- (0,2522)
[0] 1239 <- (0,2523)
[0] 1240 <- (0,2524)
[0] 1241 <- (0,2550)
[0] 1242 <- (0,2551)
[0] 1243 <- (0,2552)
[0] 1244 <- (0,2553)
[0] 1245 <- (0,2554)
[0] 1246 <- (0,2555)
[0] 1247 <- (0,2556)
[0] 1248 <- (0,2557)
[0] 1249 <- (0,2558)
[0] 1250 <- (0,2559)
[0] 1251 <- (0,2560)
[0] 1252 <- (0,2561)
[0] 1253 <- (0,2562)
[0] 1254 <- (0,2563)
[0] 1255 <- (0,2564)
[0] 1256 <- (0,2565)
[0] 1257 <- (0,2566)
[0] 1258 <- (0,2567)
[0] 1259 <- (0,2568)
[0] 1260 <- (0,2569)
[0] 1261 <- (0,2570)
[0] 1262 <- (0,2571)
[0] 1263 <- (0,2572)
[0] 1264 <- (0,2573)
[0] 1265 <- (0,2574)
[0] 1266 <- (0,2575)
[0] 1267 <- (0,2600)
[0] 1268 <- (0,2601)
[0] 1269 <- (0,2602)
[0] 1270 <- (0,2603)
[0] 1271 <- (0,2604)
[0] 1272 <- (0,2605)
[0] 1273 <- (0,2606)
[0] 1274 <- (0,2607)
[0] 1275 <- (0,2608)
[0] 1276 <- (0,2609)
[0] 1277 <- (0,2610)
[0] 1278 <- (0,2611)
[0] 1279 <- (0,2612)
[0] 1280 <- (0,2613)
[0] 1281 <- (0,2614)
[0] 1282 <- (0,2615)
[0] 1283 <- (0,2616)
[0] 1284 <- (0,2617)
[0] 1285 <- (0,2618)
[0] 1286 <- (0,2619)
[0] 1287 <- (0,2620)
[0] 1288 <- (0,2621)
[0] 1289 <- (0,2622)
[0] 1290 <- (0,2623)
[0] 1291 <- (0,2624)
[0] 1292 <- (0,2625)
[0] 1293 <- (0,2650)
[0] 1294 <- (0,2651)
[0] 1295 <- (0,2652)
[0] 1296 <- (0,2653)
[0] 1297 <- (0,2654)
[0] 1298 <- (0,2655)
[0] 1299 <- (0,2656)
[0] 1300 <- (0,2657)
[0] 1301 <- (0,2658)
[0] 1302 <- (0,2659)
[0] 1303 <- (0,2660)
[0] 1304 <- (0,2661)
[0] 1305 <- (0,2662)
[0] 1306 <- (0,2663)
[0] 1307 <- (0,2664)
[0] 1308 <- (0,2665)
[0] 1309 <- (0,2666)
[0] 1310 <- (0,2667)
[0] 1311 <- (0,2668)
[0] 1312 <- (0,2669)
[0] 1313 <- (0,2670)
[0] 1314 <- (0,2671)
[0] 1315 <- (0,2672)
[0] 1316 <- (0,2673)
[0] 1317 <- (0,2674)
[0] 1318 <- (0,2675)
[0] 1319 <- (0,2676)
[0] 1320 <- (0,2700)
[0] 1321 <- (0,2701)
[0] 1322 <- (0,2702)
[0] 1323 <- (0,2703)
[0] 1324 <- (0,2704)
[0] 1325 <- (0,2705)
[0] 1326 <- (0,2706)
[0] 1327 <- (0,2707)
[0] 1328 <- (0,2708)
[0] 1329 <- (0,2709)
[0] 1330 <- (0,2710)
[0] 1331 <- (0,2711)
[0] 1332 <- (0,2712)
[0] 1333 <- (0,2713)
[0] 1334 <- (0,2714)
[0] 1335 <- (0,2715)
[0] 1336 <- (0,2716)
[0] 1337 <- (0,2717)
[0] 1338 <- (0,2718)
[0] 1339 <- (0,2719)
[0] 1340 <- (0,2720)
[0] 1341 <- (0,2721)
[0] 1342 <- (0,2722)
[0] 1343 <- (0,2723)
[0] 1344 <- (0,2724)
[0] 1345 <- (0,2725)
[0] 1346 <- (0,2726)
[0] 1347 <- (0,2750)
[0] 1348 <- (0,2751)
[0] 1349 <- (0,2752)
[0] 1350 <- (0,2753)
[0] 1351 <- (0,2754)
[0] 1352 <- (0,2755)
[0] 1353 <- (0,2756)
[0] 1354 <- (0,2757)
[0] 1355 <- (0,2758)
[0] 1356 <- (0,2759)
[0] 1357 <- (0,2760)
[0] 1358 <- (0,2761)
[0] 1359 <- (0,2762)
[0] 1360 <- (0,2763)
[0] 1361 <- (0,2764)
[0] 1362 <- (0,2765)
[0] 1363 <- (0,2766)
[0] 1364 <- (0,2767)
[0] 1365 <- (0,2768)
[0] 1366 <- (0,2769)
[0] 1367 <- (0,2770)
[0] 1368 <- (0,2771)
[0] 1369 <- (0,2772)
[0] 1370 <- (0,2773)
[0] 1371 <- (0,2774)
[0] 1372 <- (0,2775)
[0] 1373 <- (0,2776)
[0] 1374 <- (0,2800)
[0] 1375 <- (0,2801)
[0] 1376 <- (0,2802)
[0] 1377 <- (0,2803)
[0] 1378 <- (0,2804)
[0] 1379 <- (0,2805)
[0] 1380 <- (0,2806)
[0] 1381 <- (0,2807)
[0] 1382 <- (0,2808)
[0] 1383 <- (0,2809)
[0] 1384 <- (0,2810)
[0] 1385 <- (0,2811)
[0] 1386 <- (0,2812)
[0] 1387 <- (0,2813)
[0] 1388 <- (0,2814)
[0] 1389 <- (0,2815)
[0] 1390 <- (0,2816)
[0] 1391 <- (0,2817)
[0] 1392 <- (0,2818)
[0] 1393 <- (0,2819)
[0] 1394 <- (0,2820)
[0] 1395 <- (0,2821)
[0] 1396 <- (0,2822)
[0] 1397 <- (0,2823)
[0] 1398 <- (0,2824)
[0] 1399 <- (0,2825)
[0] 1400 <- (0,2826)
[0] 1401 <- (0,2850)
[0] 1402 <- (0,2851)
[0] 1403 <- (0,2852)
[0] 1404 <- (0,2853)
[0] 1405 <- (0,2854)
[0] 1406 <- (0,2855)
[0] 1407 <- (0,2856)
[0] 1408 <- (0,2857)
[0] 1409 <- (0,2858)
[0] 1410 <- (0,2859)
[0] 1411 <- (0,2860)
[0] 1412 <- (0,2861)
[0] 1413 <- (0,2862)
[0] 1414 <- (0,2863)
[0] 1415 <- (0,2864)
[0] 1416 <- (0,2865)
[0] 1417 <- (0,2866)
[0] 1418 <- (0,2867)
[0] 1419 <- (0,2868)
[0] 1420 <- (0,2869)
[0] 1421 <- (0,2870)
[0] 1422 <- (0,2871)
[0] 1423 <- (0,2872)
[0] 1424 <- (0,2873)
[0] 1425 <- (0,2874)
[0] 1426 <- (0,2875)
[0] 1427 <- (0,2876)
[0] 1428 <- (0,2900)
[0] 1429 <- (0,2901)
[0] 1430 <- (0,2902)
[0] 1431 <- (0,2903)
[0] 1432 <- (0,2904)
[0] 1433 <- (0,2905)
[0] 1434 <- (0,2906)
[0] 1435 <- (0,2907)
[0] 1436 <- (0,2908)
[0] 1437 <- (0,2909)
[0] 1438 <- (0,2910)
[0] 1439 <- (0,2911)
[0] 1440 <- (0,2912)
[0] 1441 <- (0,2913)
[0] 1442 <- (0,2914)
[0] 1443 <- (0,2915)
[0] 1444 <- (0,2916)
[0] 1445 <- (0,2917)
[0] 1446 <- (0,2918)
[0] 1447 <- (0,2919)
[0] 1448 <- (0,2920)
[0] 1449 <- (0,2921)
[0] 1450 <- (0,2922)
[0] 1451 <- (0,2923)
[0] 1452 <- (0,2924)
[0] 1453 <- (0,2925)
[0] 1454 <- (0,2926)
[0] 1455 <- (0,2950)
[0] 1456 <- (0,2951)
[0] 1457 <- (0,2952)
[0] 1458 <- (0,2953)
[0] 1459 <- (0,2954)
[0] 1460 <- (0,2955)
[0] 1461 <- (0,2956)
[0] 1462 <- (0,2957)
[0] 1463 <- (0,2958)
[0] 1464 <- (0,2959)
[0] 1465 <- (0,2960)
[0] 1466 <- (0,2961)
[0] 1467 <- (0,2962)
[0] 1468 <- (0,2963)
[0] 1469 <- (0,2964)
[0] 1470 <- (0,2965)
[0] 1471 <- (0,2966)
[0] 1472 <- (0,2967)
[0] 1473 <- (0,2968)
[0] 1474 <- (0,2969)
[0] 1475 <- (0,2970)
[0] 1476 <- (0,2971)
[0] 1477 <- (0,2972)
[0] 1478 <- (0,2973)
[0] 1479 <- (0,2974)
[0] 1480 <- (0,2975)
[0] 1481 <- (0,2976)
[0] 1482 <- (0,3000)
[0] 1483 <- (0,3001)
[0] 1484 <- (0,3002)
[0] 1485 <- (0,3003)
[0] 1486 <- (0,3004)
[0] 1487 <- (0,3005)
[0] 1488 <- (0,3006)
[0] 1489 <- (0,3007)
[0] 1490 <- (0,3008)
[0] 1491 <- (0,3009)
[0] 1492 <- (0,3010)
[0] 1493 <- (0,3011)
[0] 1494 <- (0,3012)
[0] 1495 <- (0,3013)
[0] 1496 <- (0,3014)
[0] 1497 <- (0,3015)
[0] 1498 <- (0,3016)
[0] 1499 <- (0,3017)
[0] 1500 <- (0,3018)
[0] 1501 <- (0,3019)
[0] 1502 <- (0,3020)
[0] 1503 <- (0,3021)
[0] 1504 <- (0,3050)
[0] 1505 <- (0,3051)
[0] 1506 <- (0,3052)
[0] 1507 <- (0,3053)
[0] 1508 <- (0,3054)
[0] 1509 <- (0,3055)
[0] 1510 <- (0,3056)
[0] 1511 <- (0,3057)
[0] 1512 <- (0,3058)
[0] 1513 <- (0,3059)
[0] 1514 <- (0,3060)
[0] 1515 <- (0,3061)
[0] 1516 <- (0,3062)
[0] 1517 <- (0,3063)
[0] 1518 <- (0,3064)
[0] 1519 <- (0,3065)
[0] 1520 <- (0,3066)
[0] 1521 <- (0,3067)
[0] 1522 <- (0,3068)
[0] 1523 <- (0,3069)
[0] 1524 <- (0,3070)
[0] 1525 <- (0,3071)
[0] 1526 <- (0,3100)
[0] 1527 <- (0,3101)
[0] 1528 <- (0,3102)
[0] 1529 <- (0,3103)
[0] 1530 <- (0,3104)
[0] 1531 <- (0,3105)
[0] 1532 <- (0,3106)
[0] 1533 <- (0,3107)
[0] 1534 <- (0,3108)
[0] 1535 <- (0,3109)
[0] 1536 <- (0,3110)
[0] 1537 <- (0,3111)
[0] 1538 <- (0,3112)
[0] 1539 <- (0,3113)
[0] 1540 <- (0,3114)
[0] 1541 <- (0,3115)
[0] 1542 <- (0,3116)
[0] 1543 <- (0,3117)
[0] 1544 <- (0,3118)
[0] 1545 <- (0,3119)
[0] 1546 <- (0,3120)
[0] 1547 <- (0,3121)
[0] 1548 <- (0,3150)
[0] 1549 <- (0,3151)
[0] 1550 <- (0,3152)
[0] 1551 <- (0,3153)
[0] 1552 <- (0,3154)
[0] 1553 <- (0,3155)
[0] 1554 <- (0,3156)
[0] 1555 <- (0,3157)
[0] 1556 <- (0,3158)
[0] 1557 <- (0,3159)
[0] 1558 <- (0,3160)
[0] 1559 <- (0,3161)
[0] 1560 <- (0,3162)
[0] 1561 <- (0,3163)
[0] 1562 <- (0,3164)
[0] 1563 <- (0,3165)
[0] 1564 <- (0,3166)
[0] 1565 <- (0,3167)
[0] 1566 <- (0,3168)
[0] 1567 <- (0,3169)
[0] 1568 <- (0,3170)
[0] 1569 <- (0,3171)
[0] 1570 <- (0,3200)
[0] 1571 <- (0,3201)
[0] 1572 <- (0,3202)
[0] 1573 <- (0,3203)
[0] 1574 <- (0,3204)
[0] 1575 <- (0,3205)
[0] 1576 <- (0,3206)
[0] 1577 <- (0,3207)
[0] 1578 <- (0,3208)
[0] 1579 <- (0,3209)
[0] 1580 <- (0,3210)
[0] 1581 <- (0,3211)
[0] 1582 <- (0,3212)
[0] 1583 <- (0,3213)
[0] 1584 <- (0,3214)
[0] 1585 <- (0,3215)
[0] 1586 <- (0,3216)
[0] 1587 <- (0,3217)
[0] 1588 <- (0,3218)
[0] 1589 <- (0,3219)
[0] 1590 <- (0,3220)
[0] 1591 <- (0,3221)
[0] 1592 <- (0,3222)
[0] 1593 <- (0,3250)
[0] 1594 <- (0,3251)
[0] 1595 <- (0,3252)
[0] 1596 <- (0,3253)
[0] 1597 <- (0,3254)
[0] 1598 <- (0,3255)
[0] 1599 <- (0,3256)
[0] 1600 <- (0,3257)
[0] 1601 <- (0,3258)
[0] 1602 <- (0,3259)
[0] 1603 <- (0,3260)
[0] 1604 <- (0,3261)
[0] 1605 <- (0,3262)
[0] 1606 <- (0,3263)
[0] 1607 <- (0,3264)
[0] 1608 <- (0,3265)
[0] 1609 <- (0,3266)
[0] 1610 <- (0,3267)
[0] 1611 <- (0,3268)
[0] 1612 <- (0,3269)
[0] 1613 <- (0,3270)
[0] 1614 <- (0,3271)
[0] 1615 <- (0,3272)
[0] 1616 <- (0,3300)
[0] 1617 <- (0,3301)
[0] 1618 <- (0,3302)
[0] 1619 <- (0,3303)
[0] 1620 <- (0,3304)
[0] 1621 <- (0,3305)
[0] 1622 <- (0,3306)
[0] 1623 <- (0,3307)
[0] 1624 <- (0,3308)
[0] 1625 <- (0,3309)
[0] 1626 <- (0,3310)
[0] 1627 <- (0,3311)
[0] 1628 <- (0,3312)
[0] 1629 <- (0,3313)
[0] 1630 <- (0,3314)
[0] 1631 <- (0,3315)
[0] 1632 <- (0,3316)
[0] 1633 <- (0,3317)
[0] 1634 <- (0,3318)
[0] 1635 <- (0,3319)
[0] 1636 <- (0,3320)
[0] 1637 <- (0,3321)
[0] 1638 <- (0,3322)
[0] 1639 <- (0,3350)
[0] 1640 <- (0,3351)
[0] 1641 <- (0,3352)
[0] 1642 <- (0,3353)
[0] 1643 <- (0,3354)
[0] 1644 <- (0,3355)
[0] 1645 <- (0,3356)
[0] 1646 <- (0,3357)
[0] 1647 <- (0,3358)
[0] 1648 <- (0,3359)
[0] 1649 <- (0,3360)
[0] 1650 <- (0,3361)
[0] 1651 <- (0,3362)
[0] 1652 <- (0,3363)
[0] 1653 <- (0,3364)
[0] 1654 <- (0,3365)
[0] 1655 <- (0,3366)
[0] 1656 <- (0,3367)
[0] 1657 <- (0,3368)
[0] 1658 <- (0,3369)
[0] 1659 <- (0,3370)
[0] 1660 <- (0,3371)
[0] 1661 <- (0,3372)
[0] 1662 <- (0,3400)
[0] 1663 <- (0,3401)
[0] 1664 <- (0,3402)
[0] 1665 <- (0,3403)
[0] 1666 <- (0,3404)
[0] 1667 <- (0,3405)
[0] 1668 <- (0,3406)
[0] 1669 <- (0,3407)
[0] 1670 <- (0,3408)
[0] 1671 <- (0,3409)
[0] 1672 <- (0,3410)
[0] 1673 <- (0,3411)
[0] 1674 <- (0,3412)
[0] 1675 <- (0,3413)
[0] 1676 <- (0,3414)
[0] 1677 <- (0,3415)
[0] 1678 <- (0,3416)
[0] 1679 <- (0,3417)
[0] 1680 <- (0,3418)
[0] 1681 <- (0,3419)
[0] 1682 <- (0,3420)
[0] 1683 <- (0,3421)
[0] 1684 <- (0,3422)
[0] 1685 <- (0,3423)
[0] 1686 <- (0,3450)
[0] 1687 <- (0,3451)
[0] 1688 <- (0,3452)
[0] 1689 <- (0,3453)
[0] 1690 <- (0,3454)
[0] 1691 <- (0,3455)
[0] 1692 <- (0,3456)
[0] 1693 <- (0,3457)
[0] 1694 <- (0,3458)
[0] 1695 <- (0,3459)
[0] 1696 <- (0,3460)
[0] 1697 <- (0,3461)
[0] 1698 <- (0,3462)
[0] 1699 <- (0,3463)
[0] 1700 <- (0,3464)
[0] 1701 <- (0,3465)
[0] 1702 <- (0,3466)
[0] 1703 <- (0,3467)
[0] 1704 <- (0,3468)
[0] 1705 <- (0,3469)
[0] 1706 <- (0,3470)
[0] 1707 <- (0,3471)
[0] 1708 <- (0,3472)
[0] 1709 <- (0,3473)
[0] 1710 <- (0,3500)
[0] 1711 <- (0,3501)
[0] 1712 <- (0,3502)
[0] 1713 <- (0,3503)
[0] 1714 <- (0,3504)
[0] 1715 <- (0,3505)
[0] 1716 <- (0,3506)
[0] 1717 <- (0,3507)
[0] 1718 <- (0,3508)
[0] 1719 <- (0,3509)
[0] 1720 <- (0,3510)
[0] 1721 <- (0,3511)
[0] 1722 <- (0,3512)
[0] 1723 <- (0,3513)
[0] 1724 <- (0,3514)
[0] 1725 <- (0,3515)
[0] 1726 <- (0,3516)
[0] 1727 <- (0,3517)
[0] 1728 <- (0,3518)
[0] 1729 <- (0,3519)
[0] 1730 <- (0,3520)
[0] 1731 <- (0,3521)
[0] 1732 <- (0,3522)
[0] 1733 <- (0,3523)
[0] 1734 <- (0,3524)
[0] 1735 <- (0,3550)
[0] 1736 <- (0,3551)
[0] 1737 <- (0,3552)
[0] 1738 <- (0,3553)
[0] 1739 <- (0,3554)
[0] 1740 <- (0,3555)
[0] 1741 <- (0,3556)
[0] 1742 <- (0,3557)
[0] 1743 <- (0,3558)
[0] 1744 <- (0,3559)
[0] 1745 <- (0,3560)
[0] 1746 <- (0,3561)
[0] 1747 <- (0,3562)
[0] 1748 <- (0,3563)
[0] 1749 <- (0,3564)
[0] 1750 <- (0,3565)
[0] 1751 <- (0,3566)
[0] 1752 <- (0,3567)
[0] 1753 <- (0,3568)
[0] 1754 <- (0,3569)
[0] 1755 <- (0,3570)
[0] 1756 <- (0,3571)
[0] 1757 <- (0,3572)
[0] 1758 <- (0,3573)
[0] 1759 <- (0,3574)
[0] 1760 <- (0,3575)
[0] 1761 <- (0,3600)
[0] 1762 <- (0,3601)
[0] 1763 <- (0,3602)
[0] 1764 <- (0,3603)
[0] 1765 <- (0,3604)
[0] 1766 <- (0,3605)
[0] 1767 <- (0,3606)
[0] 1768 <- (0,3607)
[0] 1769 <- (0,3608)
[0] 1770 <- (0,3609)
[0] 1771 <- (0,3610)
[0] 1772 <- (0,3611)
[0] 1773 <- (0,3612)
[0] 1774 <- (0,3613)
[0] 1775 <- (0,3614)
[0] 1776 <- (0,3615)
[0] 1777 <- (0,3616)
[0] 1778 <- (0,3617)
[0] 1779 <- (0,3618)
[0] 1780 <- (0,3619)
[0] 1781 <- (0,3620)
[0] 1782 <- (0,3621)
[0] 1783 <- (0,3622)
[0] 1784 <- (0,3623)
[0] 1785 <- (0,3624)
[0] 1786 <- (0,3625)
[0] 1787 <- (0,3650)
[0] 1788 <- (0,3651)
[0] 1789 <- (0,3652)
[0] 1790 <- (0,3653)
[0] 1791 <- (0,3654)
[0] 1792 <- (0,3655)
[0] 1793 <- (0,3656)
[0] 1794 <- (0,3657)
[0] 1795 <- (0,3658)
[0] 1796 <- (0,3659)
[0] 1797 <- (0,3660)
[0] 1798 <- (0,3661)
[0] 1799 <- (0,3662)
[0] 1800 <- (0,3663)
[0] 1801 <- (0,3664)
[0] 1802 <- (0,3665)
[0] 1803 <- (0,3666)
[0] 1804 <- (0,3667)
[0] 1805 <- (0,3668)
[0] 1806 <- (0,3669)
[0] 1807 <- (0,3670)
[0] 1808 <- (0,3671)
[0] 1809 <- (0,3672)
[0] 1810 <- (0,3673)
[0] 1811 <- (0,3674)
[0] 1812 <- (0,3675)
[0] 1813 <- (0,3676)
[0] 1814 <- (0,3700)
[0] 1815 <- (0,3701)
[0] 1816 <- (0,3702)
[0] 1817 <- (0,3703)
[0] 1818 <- (0,3704)
[0] 1819 <- (0,3705)
[0] 1820 <- (0,3706)
[0] 1821 <- (0,3707)
[0] 1822 <- (0,3708)
[0] 1823 <- (0,3709)
[0] 1824 <- (0,3710)
[0] 1825 <- (0,3711)
[0] 1826 <- (0,3712)
[0] 1827 <- (0,3713)
[0] 1828 <- (0,3714)
[0] 1829 <- (0,3715)
[0] 1830 <- (0,3716)
[0] 1831 <- (0,3717)
[0] 1832 <- (0,3718)
[0] 1833 <- (0,3719)
[0] 1834 <- (0,3720)
[0] 1835 <- (0,3721)
[0] 1836 <- (0,3722)
[0] 1837 <- (0,3723)
[0] 1838 <- (0,3724)
[0] 1839 <- (0,3725)
[0] 1840 <- (0,3726)
[0] 1841 <- (0,3750)
[0] 1842 <- (0,3751)
[0] 1843 <- (0,3752)
[0] 1844 <- (0,3753)
[0] 1845 <- (0,3754)
[0] 1846 <- (0,3755)
[0] 1847 <- (0,3756)
[0] 1848 <- (0,3757)
[0] 1849 <- (0,3758)
[0] 1850 <- (0,3759)
[0] 1851 <- (0,3760)
[0] 1852 <- (0,3761)
[0] 1853 <- (0,3762)
[0] 1854 <- (0,3763)
[0] 1855 <- (0,3764)
[0] 1856 <- (0,3765)
[0] 1857 <- (0,3766)
[0] 1858 <- (0,3767)
[0] 1859 <- (0,3768)
[0] 1860 <- (0,3769)
[0] 1861 <- (0,3770)
[0] 1862 <- (0,3771)
[0] 1863 <- (0,3772)
[0] 1864 <- (0,3773)
[0] 1865 <- (0,3774)
[0] 1866 <- (0,3775)
[0] 1867 <- (0,3776)
[0] 1868 <- (0,3800)
[0] 1869 <- (0,3801)
[0] 1870 <- (0,3802)
[0] 1871 <- (0,3803)
[0] 1872 <- (0,3804)
[0] 1873 <- (0,3805)
[0] 1874 <- (0,3806)
[0] 1875 <- (0,3807)
[0] 1876 <- (0,3808)
[0] 1877 <- (0,3809)
[0] 1878 <- (0,3810)
[0] 1879 <- (0,3811)
[0] 1880 <- (0,3812)
[0] 1881 <- (0,3813)
[0] 1882 <- (0,3814)
[0] 1883 <- (0,3815)
[0] 1884 <- (0,3816)
[0] 1885 <- (0,3817)
[0] 1886 <- (0,3818)
[0] 1887 <- (0,3819)
[0] 1888 <- (0,3820)
[0] 1889 <- (0,3821)
[0] 1890 <- (0,3822)
[0] 1891 <- (0,3823)
[0] 1892 <- (0,3824)
[0] 1893 <- (0,3825)
[0] 1894 <- (0,3826)
[0] 1895 <- (0,3850)
[0] 1896 <- (0,3851)
[0] 1897 <- (0,3852)
[0] 1898 <- (0,3853)
[0] 1899 <- (0,3854)
[0] 1900 <- (0,3855)
[0] 1901 <- (0,3856)
[0] 1902 <- (0,3857)
[0] 1903 <- (0,3858)
[0] 1904 <- (0,3859)
[0] 1905 <- (0,3860)
[0] 1906 <- (0,3861)
[0] 1907 <- (0,3862)
[0] 1908 <- (0,3863)
[0] 1909 <- (0,3864)
[0] 1910 <- (0,3865)
[0] 1911 <- (0,3866)
[0] 1912 <- (0,3867)
[0] 1913 <- (0,3868)
[0] 1914 <- (0,3869)
[0] 1915 <- (0,3870)
[0] 1916 <- (0,3871)
[0] 1917 <- (0,3872)
[0] 1918 <- (0,3873)
[0] 1919 <- (0,3874)
[0] 1920 <- (0,3875)
[0] 1921 <- (0,3876)
[0] 1922 <- (0,3900)
[0] 1923 <- (0,3901)
[0] 1924 <- (0,3902)
[0] 1925 <- (0,3903)
[0] 1926 <- (0,3904)
[0] 1927 <- (0,3905)
[0] 1928 <- (0,3906)
[0] 1929 <- (0,3907)
[0] 1930 <- (0,3908)
[0] 1931 <- (0,3909)
[0] 1932 <- (0,3910)
[0] 1933 <- (0,3911)
[0] 1934 <- (0,3912)
[0] 1935 <- (0,3913)
[0] 1936 <- (0,3914)
[0] 1937 <- (0,3915)
[0] 1938 <- (0,3916)
[0] 1939 <- (0,3917)
[0] 1940 <- (0,3918)
[0] 1941 <- (0,3919)
[0] 1942 <- (0,3920)
[0] 1943 <- (0,3921)
[0] 1944 <- (0,3922)
[0] 1945 <- (0,3923)
[0] 1946 <- (0,3924)
[0] 1947 <- (0,3925)
[0] 1948 <- (0,3926)
[0] 1949 <- (0,3950)
[0] 1950 <- (0,3951)
[0] 1951 <- (0,3952)
[0] 1952 <- (0,3953)
[0] 1953 <- (0,3954)
[0] 1954 <- (0,3955)
[0] 1955 <- (0,3956)
[0] 1956 <- (0,3957)
[0] 1957 <- (0,3958)
[0] 1958 <- (0,3959)
[0] 1959 <- (0,3960)
[0] 1960 <- (0,3961)
[0] 1961 <- (0,3962)
[0] 1962 <- (0,3963)
[0] 1963 <- (0,3964)
[0] 1964 <- (0,3965)
[0] 1965 <- (0,3966)
[0] 1966 <- (0,3967)
[0] 1967 <- (0,3968)
[0] 1968 <- (0,3969)
[0] 1969 <- (0,3970)
[0] 1970 <- (0,3971)
[0] 1971 <- (0,3972)
[0] 1972 <- (0,3973)
[0] 1973 <- (0,3974)
[0] 1974 <- (0,3975)
[0] 1975 <- (0,3976)
[0] 1976 <- (0,4000)
[0] 1977 <- (0,4001)
[0] 1978 <- (0,4002)
[0] 1979 <- (0,4003)
[0] 1980 <- (0,4004)
[0] 1981 <- (0,4005)
[0] 1982 <- (0,4006)
[0] 1983 <- (0,4007)
[0] 1984 <- (0,4008)
[0] 1985 <- (0,4009)
[0] 1986 <- (0,4010)
[0] 1987 <- (0,4011)
[0] 1988 <- (0,4012)
[0] 1989 <- (0,4013)
[0] 1990 <- (0,4014)
[0] 1991 <- (0,4015)
[0] 1992 <- (0,4016)
[0] 1993 <- (0,4017)
[0] 1994 <- (0,4018)
[0] 1995 <- (0,4019)
[0] 1996 <- (0,4020)
[0] 1997 <- (0,4021)
[0] 1998 <- (0,4050)
[0] 1999 <- (0,4051)
[0] 2000 <- (0,4052)
[0] 2001 <- (0,4053)
[0] 2002 <- (0,4054)
[0] 2003 <- (0,4055)
[0] 2004 <- (0,4056)
[0] 2005 <- (0,4057)
[0] 2006 <- (0,4058)
[0] 2007 <- (0,4059)
[0] 2008 <- (0,4060)
[0] 2009 <- (0,4061)
[0] 2010 <- (0,4062)
[0] 2011 <- (0,4063)
[0] 2012 <- (0,4064)
[0] 2013 <- (0,4065)
[0] 2014 <- (0,4066)
[0] 2015 <- (0,4067)
[0] 2016 <- (0,4068)
[0] 2017 <- (0,4069)
[0] 2018 <- (0,4070)
[0] 2019 <- (0,4071)
[0] 2020 <- (0,4100)
[0] 2021 <- (0,4101)
[0] 2022 <- (0,4102)
[0] 2023 <- (0,4103)
[0] 2024 <- (0,4104)
[0] 2025 <- (0,4105)
[0] 2026 <- (0,4106)
[0] 2027 <- (0,4107)
[0] 2028 <- (0,4108)
[0] 2029 <- (0,4109)
[0] 2030 <- (0,4110)
[0] 2031 <- (0,4111)
[0] 2032 <- (0,4112)
[0] 2033 <- (0,4113)
[0] 2034 <- (0,4114)
[0] 2035 <- (0,4115)
[0] 2036 <- (0,4116)
[0] 2037 <- (0,4117)
[0] 2038 <- (0,4118)
[0] 2039 <- (0,4119)
[0] 2040 <- (0,4120)
[0] 2041 <- (0,4121)
[0] 2042 <- (0,4150)
[0] 2043 <- (0,4151)
[0] 2044 <- (0,4152)
[0] 2045 <- (0,4153)
[0] 2046 <- (0,4154)
[0] 2047 <- (0,4155)
[0] 2048 <- (0,4156)
[0] 2049 <- (0,4157)
[0] 2050 <- (0,4158)
[0] 2051 <- (0,4159)
[0] 2052 <- (0,4160)
[0] 2053 <- (0,4161)
[0] 2054 <- (0,4162)
[0] 2055 <- (0,4163)
[0] 2056 <- (0,4164)
[0] 2057 <- (0,4165)
[0] 2058 <- (0,4166)
[0] 2059 <- (0,4167)
[0] 2060 <- (0,4168)
[0] 2061 <- (0,4169)
[0] 2062 <- (0,4170)
[0] 2063 <- (0,4171)
[0] 2064 <- (0,4200)
[0] 2065 <- (0,4201)
[0] 2066 <- (0,4202)
[0] 2067 <- (0,4203)
[0] 2068 <- (0,4204)
[0] 2069 <- (0,4205)
[0] 2070 <- (0,4206)
[0] 2071 <- (0,4207)
[0] 2072 <- (0,4208)
[0] 2073 <- (0,4209)
[0] 2074 <- (0,4210)
[0] 2075 <- (0,4211)
[0] 2076 <- (0,4212)
[0] 2077 <- (0,4213)
[0] 2078 <- (0,4214)
[0] 2079 <- (0,4215)
[0] 2080 <- (0,4216)
[0] 2081 <- (0,4217)
[0] 2082 <- (0,4218)
[0] 2083 <- (0,4219)
[0] 2084 <- (0,4220)
[0] 2085 <- (0,4221)
[0] 2086 <- (0,4222)
[0] 2087 <- (0,4250)
[0] 2088 <- (0,4251)
[0] 2089 <- (0,4252)
[0] 2090 <- (0,4253)
[0] 2091 <- (0,4254)
[0] 2092 <- (0,4255)
[0] 2093 <- (0,4256)
[0] 2094 <- (0,4257)
[0] 2095 <- (0,4258)
[0] 2096 <- (0,4259)
[0] 2097 <- (0,4260)
[0] 2098 <- (0,4261)
[0] 2099 <- (0,4262)
[0] 2100 <- (0,4263)
[0] 2101 <- (0,4264)
[0] 2102 <- (0,4265)
[0] 2103 <- (0,4266)
[0] 2104 <- (0,4267)
[0] 2105 <- (0,4268)
[0] 2106 <- (0,4269)
[0] 2107 <- (0,4270)
[0] 2108 <- (0,4271)
[0] 2109 <- (0,4272)
[0] 2110 <- (0,4300)
[0] 2111 <- (0,4301)
[0] 2112 <- (0,4302)
[0] 2113 <- (0,4303)
[0] 2114 <- (0,4304)
[0] 2115 <- (0,4305)
[0] 2116 <- (0,4306)
[0] 2117 <- (0,4307)
[0] 2118 <- (0,4308)
[0] 2119 <- (0,4309)
[0] 2120 <- (0,4310)
[0] 2121 <- (0,4311)
[0] 2122 <- (0,4312)
[0] 2123 <- (0,4313)
[0] 2124 <- (0,4314)
[0] 2125 <- (0,4315)
[0] 2126 <- (0,4316)
[0] 2127 <- (0,4317)
[0] 2128 <- (0,4318)
[0] 2129 <- (0,4319)
[0] 2130 <- (0,4320)
[0] 2131 <- (0,4321)
[0] 2132 <- (0,4322)
[0] 2133 <- (0,4350)
[0] 2134 <- (0,4351)
[0] 2135 <- (0,4352)
[0] 2136 <- (0,4353)
[0] 2137 <- (0,4354)
[0] 2138 <- (0,4355)
[0] 2139 <- (0,4356)
[0] 2140 <- (0,4357)
[0] 2141 <- (0,4358)
[0] 2142 <- (0,4359)
[0] 2143 <- (0,4360)
[0] 2144 <- (0,4361)
[0] 2145 <- (0,4362)
[0] 2146 <- (0,4363)
[0] 2147 <- (0,4364)
[0] 2148 <- (0,4365)
[0] 2149 <- (0,4366)
[0] 2150 <- (0,4367)
[0] 2151 <- (0,4368)
[0] 2152 <- (0,4369)
[0] 2153 <- (0,4370)
[0] 2154 <- (0,4371)
[0] 2155 <- (0,4372)
[0] 2156 <- (0,4400)
[0] 2157 <- (0,4401)
[0] 2158 <- (0,4402)
[0] 2159 <- (0,4403)
[0] 2160 <- (0,4404)
[0] 2161 <- (0,4405)
[0] 2162 <- (0,4406)
[0] 2163 <- (0,4407)
[0] 2164 <- (0,4408)
[0] 2165 <- (0,4409)
[0] 2166 <- (0,4410)
[0] 2167 <- (0,4411)
[0] 2168 <- (0,4412)
[0] 2169 <- (0,4413)
[0] 2170 <- (0,4414)
[0] 2171 <- (0,4415)
[0] 2172 <- (0,4416)
[0] 2173 <- (0,4417)
[0] 2174 <- (0,4418)
[0] 2175 <- (0,4419)
[0] 2176 <- (0,4420)
[0] 2177 <- (0,4421)
[0] 2178 <- (0,4422)
[0] 2179 <- (0,4423)
[0] 2180 <- (0,4450)
[0] 2181 <- (0,4451)
[0] 2182 <- (0,4452)
[0] 2183 <- (0,4453)
[0] 2184 <- (0,4454)
[0] 2185 <- (0,4455)
[0] 2186 <- (0,4456)
[0] 2187 <- (0,4457)
[0] 2188 <- (0,4458)
[0] 2189 <- (0,4459)
[0] 2190 <- (0,4460)
[0] 2191 <- (0,4461)
[0] 2192 <- (0,4462)
[0] 2193 <- (0,4463)
[0] 2194 <- (0,4464)
[0] 2195 <- (0,4465)
[0] 2196 <- (0,4466)
[0] 2197 <- (0,4467)
[0] 2198 <- (0,4468)
[0] 2199 <- (0,4469)
[0] 2200 <- (0,4470)
[0] 2201 <- (0,4471)
[0] 2202 <- (0,4472)
[0] 2203 <- (0,4473)
[0] 2204 <- (0,4500)
[0] 2205 <- (0,4501)
[0] 2206 <- (0,4502)
[0] 2207 <- (0,4503)
[0] 2208 <- (0,4504)
[0] 2209 <- (0,4505)
[0] 2210 <- (0,4506)
[0] 2211 <- (0,4507)
[0] 2212 <- (0,4508)
[0] 2213 <- (0,4509)
[0] 2214 <- (0,4510)
[0] 2215 <- (0,4511)
[0] 2216 <- (0,4512)
[0] 2217 <- (0,4513)
[0] 2218 <- (0,4514)
[0] 2219 <- (0,4515)
[0] 2220 <- (0,4516)
[0] 2221 <- (0,4517)
[0] 2222 <- (0,4518)
[0] 2223 <- (0,4519)
[0] 2224 <- (0,4520)
[0] 2225 <- (0,4521)
[0] 2226 <- (0,4522)
[0] 2227 <- (0,4523)
[0] 2228 <- (0,4524)
[0] 2229 <- (0,4550)
[0] 2230 <- (0,4551)
[0] 2231 <- (0,4552)
[0] 2232 <- (0,4553)
[0] 2233 <- (0,4554)
[0] 2234 <- (0,4555)
[0] 2235 <- (0,4556)
[0] 2236 <- (0,4557)
[0] 2237 <- (0,4558)
[0] 2238 <- (0,4559)
[0] 2239 <- (0,4560)
[0] 2240 <- (0,4561)
[0] 2241 <- (0,4562)
[0] 2242 <- (0,4563)
[0] 2243 <- (0,4564)
[0] 2244 <- (0,4565)
[0] 2245 <- (0,4566)
[0] 2246 <- (0,4567)
[0] 2247 <- (0,4568)
[0] 2248 <- (0,4569)
[0] 2249 <- (0,4570)
[0] 2250 <- (0,4571)
[0] 2251 <- (0,4572)
[0] 2252 <- (0,4573)
[0] 2253 <- (0,4574)
[0] 2254 <- (0,4575)
[0] 2255 <- (0,4600)
[0] 2256 <- (0,4601)
[0] 2257 <- (0,4602)
[0] 2258 <- (0,4603)
[0] 2259 <- (0,4604)
[0] 2260 <- (0,4605)
[0] 2261 <- (0,4606)
[0] 2262 <- (0,4607)
[0] 2263 <- (0,4608)
[0] 2264 <- (0,4609)
[0] 2265 <- (0,4610)
[0] 2266 <- (0,4611)
[0] 2267 <- (0,4612)
[0] 2268 <- (0,4613)
[0] 2269 <- (0,4614)
[0] 2270 <- (0,4615)
[0] 2271 <- (0,4616)
[0] 2272 <- (0,4617)
[0] 2273 <- (0,4618)
[0] 2274 <- (0,4619)
[0] 2275 <- (0,4620)
[0] 2276 <- (0,4621)
[0] 2277 <- (0,4622)
[0] 2278 <- (0,4623)
[0] 2279 <- (0,4624)
[0] 2280 <- (0,4625)
[0] 2281 <- (0,4650)
[0] 2282 <- (0,4651)
[0] 2283 <- (0,4652)
[0] 2284 <- (0,4653)
[0] 2285 <- (0,4654)
[0] 2286 <- (0,4655)
[0] 2287 <- (0,4656)
[0] 2288 <- (0,4657)
[0] 2289 <- (0,4658)
[0] 2290 <- (0,4659)
[0] 2291 <- (0,4660)
[0] 2292 <- (0,4661)
[0] 2293 <- (0,4662)
[0] 2294 <- (0,4663)
[0] 2295 <- (0,4664)
[0] 2296 <- (0,4665)
[0] 2297 <- (0,4666)
[0] 2298 <- (0,4667)
[0] 2299 <- (0,4668)
[0] 2300 <- (0,4669)
[0] 2301 <- (0,4670)
[0] 2302 <- (0,4671)
[0] 2303 <- (0,4672)
[0] 2304 <- (0,4673)
[0] 2305 <- (0,4674)
[0] 2306 <- (0,4675)
[0] 2307 <- (0,4676)
[0] 2308 <- (0,4700)
[0] 2309 <- (0,4701)
[0] 2310 <- (0,4702)
[0] 2311 <- (0,4703)
[0] 2312 <- (0,4704)
[0] 2313 <- (0,4705)
[0] 2314 <- (0,4706)
[0] 2315 <- (0,4707)
[0] 2316 <- (0,4708)
[0] 2317 <- (0,4709)
[0] 2318 <- (0,4710)
[0] 2319 <- (0,4711)
[0] 2320 <- (0,4712)
[0] 2321 <- (0,4713)
[0] 2322 <- (0,4714)
[0] 2323 <- (0,4715)
[0] 2324 <- (0,4716)
[0] 2325 <- (0,4717)
[0] 2326 <- (0,4718)
[0] 2327 <- (0,4719)
[0] 2328 <- (0,4720)
[0] 2329 <- (0,4721)
[0] 2330 <- (0,4722)
[0] 2331 <- (0,4723)
[0] 2332 <- (0,4724)
[0] 2333 <- (0,4725)
[0] 2334 <- (0,4726)
[0] 2335 <- (0,4750)
[0] 2336 <- (0,4751)
[0] 2337 <- (0,4752)
[0] 2338 <- (0,4753)
[0] 2339 <- (0,4754)
[0] 2340 <- (0,4755)
[0] 2341 <- (0,4756)
[0] 2342 <- (0,4757)
[0] 2343 <- (0,4758)
[0] 2344 <- (0,4759)
[0] 2345 <- (0,4760)
[0] 2346 <- (0,4761)
[0] 2347 <- (0,4762)
[0] 2348 <- (0,4763)
[0] 2349 <- (0,4764)
[0] 2350 <- (0,4765)
[0] 2351 <- (0,4766)
[0] 2352 <- (0,4767)
[0] 2353 <- (0,4768)
[0] 2354 <- (0,4769)
[0] 2355 <- (0,4770)
[0] 2356 <- (0,4771)
[0] 2357 <- (0,4772)
[0] 2358 <- (0,4773)
[0] 2359 <- (0,4774)
[0] 2360 <- (0,4775)
[0] 2361 <- (0,4776)
[0] 2362 <- (0,4800)
[0] 2363 <- (0,4801)
[0] 2364 <- (0,4802)
[0] 2365 <- (0,4803)
[0] 2366 <- (0,4804)
[0] 2367 <- (0,4805)
[0] 2368 <- (0,4806)
[0] 2369 <- (0,4807)
[0] 2370 <- (0,4808)
[0] 2371 <- (0,4809)
[0] 2372 <- (0,4810)
[0] 2373 <- (0,4811)
[0] 2374 <- (0,4812)
[0] 2375 <- (0,4813)
[0] 2376 <- (0,4814)
[0] 2377 <- (0,4815)
[0] 2378 <- (0,4816)
[0] 2379 <- (0,4817)
[0] 2380 <- (0,4818)
[0] 2381 <- (0,4819)
[0] 2382 <- (0,4820)
[0] 2383 <- (0,4821)
[0] 2384 <- (0,4822)
[0] 2385 <- (0,4823)
[0] 2386 <- (0,4824)
[0] 2387 <- (0,4825)
[0] 2388 <- (0,4826)
[0] 2389 <- (0,4850)
[0] 2390 <- (0,4851)
[0] 2391 <- (0,4852)
[0] 2392 <- (0,4853)
[0] 2393 <- (0,4854)
[0] 2394 <- (0,4855)
[0] 2395 <- (0,4856)
[0] 2396 <- (0,4857)
[0] 2397 <- (0,4858)
[0] 2398 <- (0,4859)
[0] 2399 <- (0,4860)
[0] 2400 <- (0,4861)
[0] 2401 <- (0,4862)
[0] 2402 <- (0,4863)
[0] 2403 <- (0,4864)
[0] 2404 <- (0,4865)
[0] 2405 <- (0,4866)
[0] 2406 <- (0,4867)
[0] 2407 <- (0,4868)
[0] 2408 <- (0,4869)
[0] 2409 <- (0,4870)
[0] 2410 <- (0,4871)
[0] 2411 <- (0,4872)
[0] 2412 <- (0,4873)
[0] 2413 <- (0,4874)
[0] 2414 <- (0,4875)
[0] 2415 <- (0,4876)
[0] 2416 <- (0,4900)
[0] 2417 <- (0,4901)
[0] 2418 <- (0,4902)
[0] 2419 <- (0,4903)
[0] 2420 <- (0,4904)
[0] 2421 <- (0,4905)
[0] 2422 <- (0,4906)
[0] 2423 <- (0,4907)
[0] 2424 <- (0,4908)
[0] 2425 <- (0,4909)
[0] 2426 <- (0,4910)
[0] 2427 <- (0,4911)
[0] 2428 <- (0,4912)
[0] 2429 <- (0,4913)
[0] 2430 <- (0,4914)
[0] 2431 <- (0,4915)
[0] 2432 <- (0,4916)
[0] 2433 <- (0,4917)
[0] 2434 <- (0,4918)
[0] 2435 <- (0,4919)
[0] 2436 <- (0,4920)
[0] 2437 <- (0,4921)
[0] 2438 <- (0,4922)
[0] 2439 <- (0,4923)
[0] 2440 <- (0,4924)
[0] 2441 <- (0,4925)
[0] 2442 <- (0,4926)
[0] 2443 <- (0,4950)
[0] 2444 <- (0,4951)
[0] 2445 <- (0,4952)
[0] 2446 <- (0,4953)
[0] 2447 <- (0,4954)
[0] 2448 <- (0,4955)
[0] 2449 <- (0,4956)
[0] 2450 <- (0,4957)
[0] 2451 <- (0,4958)
[0] 2452 <- (0,4959)
[0] 2453 <- (0,4960)
[0] 2454 <- (0,4961)
[0] 2455 <- (0,4962)
[0] 2456 <- (0,4963)
[0] 2457 <- (0,4964)
[0] 2458 <- (0,4965)
[0] 2459 <- (0,4966)
[0] 2460 <- (0,4967)
[0] 2461 <- (0,4968)
[0] 2462 <- (0,4969)
[0] 2463 <- (0,4970)
[0] 2464 <- (0,4971)
[0] 2465 <- (0,4972)
[0] 2466 <- (0,4973)
[0] 2467 <- (0,4974)
[0] 2468 <- (0,4975)
[0] 2469 <- (0,4976)
[0] 2470 <- (0,5000)
[0] 2471 <- (0,5001)
[0] 2472 <- (0,5002)
[0] 2473 <- (0,5003)
[0] 2474 <- (0,5004)
[0] 2475 <- (0,5005)
[0] 2476 <- (0,5006)
[0] 2477 <- (0,5007)
[0] 2478 <- (0,5008)
[0] 2479 <- (0,5009)
[0] 2480 <- (0,5010)
[0] 2481 <- (0,5011)
[0] 2482 <- (0,5012)
[0] 2483 <- (0,5013)
[0] 2484 <- (0,5014)
[0] 2485 <- (0,5015)
[0] 2486 <- (0,5016)
[0] 2487 <- (0,5017)
[0] 2488 <- (0,5018)
[0] 2489 <- (0,5019)
[0] 2490 <- (0,5020)
[0] 2491 <- (0,5021)
[0] 2492 <- (0,5050)
[0] 2493 <- (0,5051)
[0] 2494 <- (0,5052)
[0] 2495 <- (0,5053)
[0] 2496 <- (0,5054)
[0] 2497 <- (0,5055)
[0] 2498 <- (0,5056)
[0] 2499 <- (0,5057)
[0] 2500 <- (0,5058)
[0] 2501 <- (0,5059)
[0] 2502 <- (0,5060)
[0] 2503 <- (0,5061)
[0] 2504 <- (0,5062)
[0] 2505 <- (0,5063)
[0] 2506 <- (0,5064)
[0] 2507 <- (0,5065)
[0] 2508 <- (0,5066)
[0] 2509 <- (0,5067)
[0] 2510 <- (0,5068)
[0] 2511 <- (0,5069)
[0] 2512 <- (0,5070)
[0] 2513 <- (0,5071)
[0] 2514 <- (0,5100)
[0] 2515 <- (0,5101)
[0] 2516 <- (0,5102)
[0] 2517 <- (0,5103)
[0] 2518 <- (0,5104)
[0] 2519 <- (0,5105)
[0] 2520 <- (0,5106)
[0] 2521 <- (0,5107)
[0] 2522 <- (0,5108)
[0] 2523 <- (0,5109)
[0] 2524 <- (0,5110)
[0] 2525 <- (0,5111)
[0] 2526 <- (0,5112)
[0] 2527 <- (0,5113)
[0] 2528 <- (0,5114)
[0] 2529 <- (0,5115)
[0] 2530 <- (0,5116)
[0] 2531 <- (0,5117)
[0] 2532 <- (0,5118)
[0] 2533 <- (0,5119)
[0] 2534 <- (0,5120)
[0] 2535 <- (0,5121)
[0] 2536 <- (0,5150)
[0] 2537 <- (0,5151)
[0] 2538 <- (0,5152)
[0] 2539 <- (0,5153)
[0] 2540 <- (0,5154)
[0] 2541 <- (0,5155)
[0] 2542 <- (0,5156)
[0] 2543 <- (0,5157)
[0] 2544 <- (0,5158)
[0] 2545 <- (0,5159)
[0] 2546 <- (0,5160)
[0] 2547 <- (0,5161)
[0] 2548 <- (0,5162)
[0] 2549 <- (0,5163)
[0] 2550 <- (0,5164)
[0] 2551 <- (0,5165)
[0] 2552 <- (0,5166)
[0] 2553 <- (0,5167)
[0] 2554 <- (0,5168)
[0] 2555 <- (0,5169)
[0] 2556 <- (0,5170)
[0] 2557 <- (0,5171)
[0] 2558 <- (0,5200)
[0] 2559 <- (0,5201)
[0] 2560 <- (0,5202)
[0] 2561 <- (0,5203)
[0] 2562 <- (0,5204)
[0] 2563 <- (0,5205)
[0] 2564 <- (0,5206)
[0] 2565 <- (0,5207)
[0] 2566 <- (0,5208)
[0] 2567 <- (0,5209)
[0] 2568 <- (0,5210)
[0] 2569 <- (0,5211)
[0] 2570 <- (0,5212)
[0] 2571 <- (0,5213)
[0] 2572 <- (0,5214)
[0] 2573 <- (0,5215)
[0] 2574 <- (0,5216)
[0] 2575 <- (0,5217)
[0] 2576 <- (0,5218)
[0] 2577 <- (0,5219)
[0] 2578 <- (0,5220)
[0] 2579 <- (0,5221)
[0] 2580 <- (0,5222)
[0] 2581 <- (0,5250)
[0] 2582 <- (0,5251)
[0] 2583 <- (0,5252)
[0] 2584 <- (0,5253)
[0] 2585 <- (0,5254)
[0] 2586 <- (0,5255)
[0] 2587 <- (0,5256)
[0] 2588 <- (0,5257)
[0] 2589 <- (0,5258)
[0] 2590 <- (0,5259)
[0] 2591 <- (0,5260)
[0] 2592 <- (0,5261)
[0] 2593 <- (0,5262)
[0] 2594 <- (0,5263)
[0] 2595 <- (0,5264)
[0] 2596 <- (0,5265)
[0] 2597 <- (0,5266)
[0] 2598 <- (0,5267)
[0] 2599 <- (0,5268)
[0] 2600 <- (0,5269)
[0] 2601 <- (0,5270)
[0] 2602 <- (0,5271)
[0] 2603 <- (0,5272)
[0] 2604 <- (0,5300)
[0] 2605 <- (0,5301)
[0] 2606 <- (0,5302)
[0] 2607 <- (0,5303)
[0] 2608 <- (0,5304)
[0] 2609 <- (0,5305)
[0] 2610 <- (0,5306)
[0] 2611 <- (0,5307)
[0] 2612 <- (0,5308)
[0] 2613 <- (0,5309)
[0] 2614 <- (0,5310)
[0] 2615 <- (0,5311)
[0] 2616 <- (0,5312)
[0] 2617 <- (0,5313)
[0] 2618 <- (0,5314)
[0] 2619 <- (0,5315)
[0] 2620 <- (0,5316)
[0] 2621 <- (0,5317)
[0] 2622 <- (0,5318)
[0] 2623 <- (0,5319)
[0] 2624 <- (0,5320)
[0] 2625 <- (0,5321)
[0] 2626 <- (0,5322)
[0] 2627 <- (0,5350)
[0] 2628 <- (0,5351)
[0] 2629 <- (0,5352)
[0] 2630 <- (0,5353)
[0] 2631 <- (0,5354)
[0] 2632 <- (0,5355)
[0] 2633 <- (0,5356)
[0] 2634 <- (0,5357)
[0] 2635 <- (0,5358)
[0] 2636 <- (0,5359)
[0] 2637 <- (0,5360)
[0] 2638 <- (0,5361)
[0] 2639 <- (0,5362)
[0] 2640 <- (0,5363)
[0] 2641 <- (0,5364)
[0] 2642 <- (0,5365)
[0] 2643 <- (0,5366)
[0] 2644 <- (0,5367)
[0] 2645 <- (0,5368)
[0] 2646 <- (0,5369)
[0] 2647 <- (0,5370)
[0] 2648 <- (0,5371)
[0] 2649 <- (0,5372)
[0] 2650 <- (0,5400)
[0] 2651 <- (0,5401)
[0] 2652 <- (0,5402)
[0] 2653 <- (0,5403)
[0] 2654 <- (0,5404)
[0] 2655 <- (0,5405)
[0] 2656 <- (0,5406)
[0] 2657 <- (0,5407)
[0] 2658 <- (0,5408)
[0] 2659 <- (0,5409)
[0] 2660 <- (0,5410)
[0] 2661 <- (0,5411)
[0] 2662 <- (0,5412)
[0] 2663 <- (0,5413)
[0] 2664 <- (0,5414)
[0] 2665 <- (0,5415)
[0] 2666 <- (0,5416)
[0] 2667 <- (0,5417)
[0] 2668 <- (0,5418)
[0] 2669 <- (0,5419)
[0] 2670 <- (0,5420)
[0] 2671 <- (0,5421)
[0] 2672 <- (0,5422)
[0] 2673 <- (0,5423)
[0] 2674 <- (0,5450)
[0] 2675 <- (0,5451)
[0] 2676 <- (0,5452)
[0] 2677 <- (0,5453)
[0] 2678 <- (0,5454)
[0] 2679 <- (0,5455)
[0] 2680 <- (0,5456)
[0] 2681 <- (0,5457)
[0] 2682 <- (0,5458)
[0] 2683 <- (0,5459)
[0] 2684 <- (0,5460)
[0] 2685 <- (0,5461)
[0] 2686 <- (0,5462)
[0] 2687 <- (0,5463)
[0] 2688 <- (0,5464)
[0] 2689 <- (0,5465)
[0] 2690 <- (0,5466)
[0] 2691 <- (0,5467)
[0] 2692 <- (0,5468)
[0] 2693 <- (0,5469)
[0] 2694 <- (0,5470)
[0] 2695 <- (0,5471)
[0] 2696 <- (0,5472)
[0] 2697 <- (0,5473)
[0] 2698 <- (0,5500)
[0] 2699 <- (0,5501)
[0] 2700 <- (0,5502)
[0] 2701 <- (0,5503)
[0] 2702 <- (0,5504)
[0] 2703 <- (0,5505)
[0] 2704 <- (0,5506)
[0] 2705 <- (0,5507)
[0] 2706 <- (0,5508)
[0] 2707 <- (0,5509)
[0] 2708 <- (0,5510)
[0] 2709 <- (0,5511)
[0] 2710 <- (0,5512)
[0] 2711 <- (0,5513)
[0] 2712 <- (0,5514)
[0] 2713 <- (0,5515)
[0] 2714 <- (0,5516)
[0] 2715 <- (0,5517)
[0] 2716 <- (0,5518)
[0] 2717 <- (0,5519)
[0] 2718 <- (0,5520)
[0] 2719 <- (0,5521)
[0] 2720 <- (0,5522)
[0] 2721 <- (0,5523)
[0] 2722 <- (0,5524)
[0] 2723 <- (0,5550)
[0] 2724 <- (0,5551)
[0] 2725 <- (0,5552)
[0] 2726 <- (0,5553)
[0] 2727 <- (0,5554)
[0] 2728 <- (0,5555)
[0] 2729 <- (0,5556)
[0] 2730 <- (0,5557)
[0] 2731 <- (0,5558)
[0] 2732 <- (0,5559)
[0] 2733 <- (0,5560)
[0] 2734 <- (0,5561)
[0] 2735 <- (0,5562)
[0] 2736 <- (0,5563)
[0] 2737 <- (0,5564)
[0] 2738 <- (0,5565)
[0] 2739 <- (0,5566)
[0] 2740 <- (0,5567)
[0] 2741 <- (0,5568)
[0] 2742 <- (0,5569)
[0] 2743 <- (0,5570)
[0] 2744 <- (0,5571)
[0] 2745 <- (0,5572)
[0] 2746 <- (0,5573)
[0] 2747 <- (0,5574)
[0] 2748 <- (0,5575)
[0] 2749 <- (0,5600)
[0] 2750 <- (0,5601)
[0] 2751 <- (0,5602)
[0] 2752 <- (0,5603)
[0] 2753 <- (0,5604)
[0] 2754 <- (0,5605)
[0] 2755 <- (0,5606)
[0] 2756 <- (0,5607)
[0] 2757 <- (0,5608)
[0] 2758 <- (0,5609)
[0] 2759 <- (0,5610)
[0] 2760 <- (0,5611)
[0] 2761 <- (0,5612)
[0] 2762 <- (0,5613)
[0] 2763 <- (0,5614)
[0] 2764 <- (0,5615)
[0] 2765 <- (0,5616)
[0] 2766 <- (0,5617)
[0] 2767 <- (0,5618)
[0] 2768 <- (0,5619)
[0] 2769 <- (0,5620)
[0] 2770 <- (0,5621)
[0] 2771 <- (0,5622)
[0] 2772 <- (0,5623)
[0] 2773 <- (0,5624)
[0] 2774 <- (0,5625)
[0] 2775 <- (0,5650)
[0] 2776 <- (0,5651)
[0] 2777 <- (0,5652)
[0] 2778 <- (0,5653)
[0] 2779 <- (0,5654)
[0] 2780 <- (0,5655)
[0] 2781 <- (0,5656)
[0] 2782 <- (0,5657)
[0] 2783 <- (0,5658)
[0] 2784 <- (0,5659)
[0] 2785 <- (0,5660)
[0] 2786 <- (0,5661)
[0] 2787 <- (0,5662)
[0] 2788 <- (0,5663)
[0] 2789 <- (0,5664)
[0] 2790 <- (0,5665)
[0] 2791 <- (0,5666)
[0] 2792 <- (0,5667)
[0] 2793 <- (0,5668)
[0] 2794 <- (0,5669)
[0] 2795 <- (0,5670)
[0] 2796 <- (0,5671)
[0] 2797 <- (0,5672)
[0] 2798 <- (0,5673)
[0] 2799 <- (0,5674)
[0] 2800 <- (0,5675)
[0] 2801 <- (0,5676)
[0] 2802 <- (0,5700)
[0] 2803 <- (0,5701)
[0] 2804 <- (0,5702)
[0] 2805 <- (0,5703)
[0] 2806 <- (0,5704)
[0] 2807 <- (0,5705)
[0] 2808 <- (0,5706)
[0] 2809 <- (0,5707)
[0] 2810 <- (0,5708)
[0] 2811 <- (0,5709)
[0] 2812 <- (0,5710)
[0] 2813 <- (0,5711)
[0] 2814 <- (0,5712)
[0] 2815 <- (0,5713)
[0] 2816 <- (0,5714)
[0] 2817 <- (0,5715)
[0] 2818 <- (0,5716)
[0] 2819 <- (0,5717)
[0] 2820 <- (0,5718)
[0] 2821 <- (0,5719)
[0] 2822 <- (0,5720)
[0] 2823 <- (0,5721)
[0] 2824 <- (0,5722)
[0] 2825 <- (0,5723)
[0] 2826 <- (0,5724)
[0] 2827 <- (0,5725)
[0] 2828 <- (0,5726)
[0] 2829 <- (0,5750)
[0] 2830 <- (0,5751)
[0] 2831 <- (0,5752)
[0] 2832 <- (0,5753)
[0] 2833 <- (0,5754)
[0] 2834 <- (0,5755)
[0] 2835 <- (0,5756)
[0] 2836 <- (0,5757)
[0] 2837 <- (0,5758)
[0] 2838 <- (0,5759)
[0] 2839 <- (0,5760)
[0] 2840 <- (0,5761)
[0] 2841 <- (0,5762)
[0] 2842 <- (0,5763)
[0] 2843 <- (0,5764)
[0] 2844 <- (0,5765)
[0] 2845 <- (0,5766)
[0] 2846 <- (0,5767)
[0] 2847 <- (0,5768)
[0] 2848 <- (0,5769)
[0] 2849 <- (0,5770)
[0] 2850 <- (0,5771)
[0] 2851 <- (0,5772)
[0] 2852 <- (0,5773)
[0] 2853 <- (0,5774)
[0] 2854 <- (0,5775)
[0] 2855 <- (0,5776)
[0] 2856 <- (0,5800)
[0] 2857 <- (0,5801)
[0] 2858 <- (0,5802)
[0] 2859 <- (0,5803)
[0] 2860 <- (0,5804)
[0] 2861 <- (0,5805)
[0] 2862 <- (0,5806)
[0] 2863 <- (0,5807)
[0] 2864 <- (0,5808)
[0] 2865 <- (0,5809)
[0] 2866 <- (0,5810)
[0] 2867 <- (0,5811)
[0] 2868 <- (0,5812)
[0] 2869 <- (0,5813)
[0] 2870 <- (0,5814)
[0] 2871 <- (0,5815)
[0] 2872 <- (0,5816)
[0] 2873 <- (0,5817)
[0] 2874 <- (0,5818)
[0] 2875 <- (0,5819)
[0] 2876 <- (0,5820)
[0] 2877 <- (0,5821)
[0] 2878 <- (0,5822)
[0] 2879 <- (0,5823)
[0] 2880 <- (0,5824)
[0] 2881 <- (0,5825)
[0] 2882 <- (0,5826)
[0] 2883 <- (0,5850)
[0] 2884 <- (0,5851)
[0] 2885 <- (0,5852)
[0] 2886 <- (0,5853)
[0] 2887 <- (0,5854)
[0] 2888 <- (0,5855)
[0] 2889 <- (0,5856)
[0] 2890 <- (0,5857)
[0] 2891 <- (0,5858)
[0] 2892 <- (0,5859)
[0] 2893 <- (0,5860)
[0] 2894 <- (0,5861)
[0] 2895 <- (0,5862)
[0] 2896 <- (0,5863)
[0] 2897 <- (0,5864)
[0] 2898 <- (0,5865)
[0] 2899 <- (0,5866)
[0] 2900 <- (0,5867)
[0] 2901 <- (0,5868)
[0] 2902 <- (0,5869)
[0] 2903 <- (0,5870)
[0] 2904 <- (0,5871)
[0] 2905 <- (0,5872)
[0] 2906 <- (0,5873)
[0] 2907 <- (0,5874)
[0] 2908 <- (0,5875)
[0] 2909 <- (0,5876)
[0] 2910 <- (0,5900)
[0] 2911 <- (0,5901)
[0] 2912 <- (0,5902)
[0] 2913 <- (0,5903)
[0] 2914 <- (0,5904)
[0] 2915 <- (0,5905)
[0] 2916 <- (0,5906)
[0] 2917 <- (0,5907)
[0] 2918 <- (0,5908)
[0] 2919 <- (0,5909)
[0] 2920 <- (0,5910)
[0] 2921 <- (0,5911)
[0] 2922 <- (0,5912)
[0] 2923 <- (0,5913)
[0] 2924 <- (0,5914)
[0] 2925 <- (0,5915)
[0] 2926 <- (0,5916)
[0] 2927 <- (0,5917)
[0] 2928 <- (0,5918)
[0] 2929 <- (0,5919)
[0] 2930 <- (0,5920)
[0] 2931 <- (0,5921)
[0] 2932 <- (0,5922)
[0] 2933 <- (0,5923)
[0] 2934 <- (0,5924)
[0] 2935 <- (0,5925)
[0] 2936 <- (0,5926)
[0] 2937 <- (0,5950)
[0] 2938 <- (0,5951)
[0] 2939 <- (0,5952)
[0] 2940 <- (0,5953)
[0] 2941 <- (0,5954)
[0] 2942 <- (0,5955)
[0] 2943 <- (0,5956)
[0] 2944 <- (0,5957)
[0] 2945 <- (0,5958)
[0] 2946 <- (0,5959)
[0] 2947 <- (0,5960)
[0] 2948 <- (0,5961)
[0] 2949 <- (0,5962)
[0] 2950 <- (0,5963)
[0] 2951 <- (0,5964)
[0] 2952 <- (0,5965)
[0] 2953 <- (0,5966)
[0] 2954 <- (0,5967)
[0] 2955 <- (0,5968)
[0] 2956 <- (0,5969)
[0] 2957 <- (0,5970)
[0] 2958 <- (0,5971)
[0] 2959 <- (0,5972)
[0] 2960 <- (0,5973)
[0] 2961 <- (0,5974)
[0] 2962 <- (0,5975)
[0] 2963 <- (0,5976)
[0] 2964 <- (0,6000)
[0] 2965 <- (0,6001)
[0] 2966 <- (0,6002)
[0] 2967 <- (0,6003)
[0] 2968 <- (0,6004)
[0] 2969 <- (0,6005)
[0] 2970 <- (0,6006)
[0] 2971 <- (0,6007)
[0] 2972 <- (0,6008)
[0] 2973 <- (0,6009)
[0] 2974 <- (0,6010)
[0] 2975 <- (0,6011)
[0] 2976 <- (0,6012)
[0] 2977 <- (0,6013)
[0] 2978 <- (0,6014)
[0] 2979 <- (0,6015)
[0] 2980 <- (0,6016)
[0] 2981 <- (0,6017)
[0] 2982 <- (0,6018)
[0] 2983 <- (0,6019)
[0] 2984 <- (0,6020)
[0] 2985 <- (0,6021)
[0] 2986 <- (0,6050)
[0] 2987 <- (0,6051)
[0] 2988 <- (0,6052)
[0] 2989 <- (0,6053)
[0] 2990 <- (0,6054)
[0] 2991 <- (0,6055)
[0] 2992 <- (0,6056)
[0] 2993 <- (0,6057)
[0] 2994 <- (0,6058)
[0] 2995 <- (0,6059)
[0] 2996 <- (0,6060)
[0] 2997 <- (0,6061)
[0] 2998 <- (0,6062)
[0] 2999 <- (0,6063)
[0] 3000 <- (0,6064)
[0] 3001 <- (0,6065)
[0] 3002 <- (0,6066)
[0] 3003 <- (0,6067)
[0] 3004 <- (0,6068)
[0] 3005 <- (0,6069)
[0] 3006 <- (0,6070)
[0] 3007 <- (0,6071)
[0] 3008 <- (0,6100)
[0] 3009 <- (0,6101)
[0] 3010 <- (0,6102)
[0] 3011 <- (0,6103)
[0] 3012 <- (0,6104)
[0] 3013 <- (0,6105)
[0] 3014 <- (0,6106)
[0] 3015 <- (0,6107)
[0] 3016 <- (0,6108)
[0] 3017 <- (0,6109)
[0] 3018 <- (0,6110)
[0] 3019 <- (0,6111)
[0] 3020 <- (0,6112)
[0] 3021 <- (0,6113)
[0] 3022 <- (0,6114)
[0] 3023 <- (0,6115)
[0] 3024 <- (0,6116)
[0] 3025 <- (0,6117)
[0] 3026 <- (0,6118)
[0] 3027 <- (0,6119)
[0] 3028 <- (0,6120)
[0] 3029 <- (0,6121)
[0] 3030 <- (0,6150)
[0] 3031 <- (0,6151)
[0] 3032 <- (0,6152)
[0] 3033 <- (0,6153)
[0] 3034 <- (0,6154)
[0] 3035 <- (0,6155)
[0] 3036 <- (0,6156)
[0] 3037 <- (0,6157)
[0] 3038 <- (0,6158)
[0] 3039 <- (0,6159)
[0] 3040 <- (0,6160)
[0] 3041 <- (0,6161)
[0] 3042 <- (0,6162)
[0] 3043 <- (0,6163)
[0] 3044 <- (0,6164)
[0] 3045 <- (0,6165)
[0] 3046 <- (0,6166)
[0] 3047 <- (0,6167)
[0] 3048 <- (0,6168)
[0] 3049 <- (0,6169)
[0] 3050 <- (0,6170)
[0] 3051 <- (0,6171)
[0] 3052 <- (0,6200)
[0] 3053 <- (0,6201)
[0] 3054 <- (0,6202)
[0] 3055 <- (0,6203)
[0] 3056 <- (0,6204)
[0] 3057 <- (0,6205)
[0] 3058 <- (0,6206)
[0] 3059 <- (0,6207)
[0] 3060 <- (0,6208)
[0] 3061 <- (0,6209)
[0] 3062 <- (0,6210)
[0] 3063 <- (0,6211)
[0] 3064 <- (0,6212)
[0] 3065 <- (0,6213)
[0] 3066 <- (0,6214)
[0] 3067 <- (0,6215)
[0] 3068 <- (0,6216)
[0] 3069 <- (0,6217)
[0] 3070 <- (0,6218)
[0] 3071 <- (0,6219)
[0] 3072 <- (0,6220)
[0] 3073 <- (0,6221)
[0] 3074 <- (0,6222)
[0] 3075 <- (0,6250)
[0] 3076 <- (0,6251)
[0] 3077 <- (0,6252)
[0] 3078 <- (0,6253)
[0] 3079 <- (0,6254)
[0] 3080 <- (0,6255)
[0] 3081 <- (0,6256)
[0] 3082 <- (0,6257)
[0] 3083 <- (0,6258)
[0] 3084 <- (0,6259)
[0] 3085 <- (0,6260)
[0] 3086 <- (0,6261)
[0] 3087 <- (0,6262)
[0] 3088 <- (0,6263)
[0] 3089 <- (0,6264)
[0] 3090 <- (0,6265)
[0] 3091 <- (0,6266)
[0] 3092 <- (0,6267)
[0] 3093 <- (0,6268)
[0] 3094 <- (0,6269)
[0] 3095 <- (0,6270)
[0] 3096 <- (0,6271)
[0] 3097 <- (0,6272)
[0] 3098 <- (0,6300)
[0] 3099 <- (0,6301)
[0] 3100 <- (0,6302)
[0] 3101 <- (0,6303)
[0] 3102 <- (0,6304)
[0] 3103 <- (0,6305)
[0] 3104 <- (0,6306)
[0] 3105 <- (0,6307)
[0] 3106 <- (0,6308)
[0] 3107 <- (0,6309)
[0] 3108 <- (0,6310)
[0] 3109 <- (0,6311)
[0] 3110 <- (0,6312)
[0] 3111 <- (0,6313)
[0] 3112 <- (0,6314)
[0] 3113 <- (0,6315)
[0] 3114 <- (0,6316)
[0] 3115 <- (0,6317)
[0] 3116 <- (0,6318)
[0] 3117 <- (0,6319)
[0] 3118 <- (0,6320)
[0] 3119 <- (0,6321)
[0] 3120 <- (0,6322)
[0] 3121 <- (0,6350)
[0] 3122 <- (0,6351)
[0] 3123 <- (0,6352)
[0] 3124 <- (0,6353)
[0] 3125 <- (0,6354)
[0] 3126 <- (0,6355)
[0] 3127 <- (0,6356)
[0] 3128 <- (0,6357)
[0] 3129 <- (0,6358)
[0] 3130 <- (0,6359)
[0] 3131 <- (0,6360)
[0] 3132 <- (0,6361)
[0] 3133 <- (0,6362)
[0] 3134 <- (0,6363)
[0] 3135 <- (0,6364)
[0] 3136 <- (0,6365)
[0] 3137 <- (0,6366)
[0] 3138 <- (0,6367)
[0] 3139 <- (0,6368)
[0] 3140 <- (0,6369)
[0] 3141 <- (0,6370)
[0] 3142 <- (0,6371)
[0] 3143 <- (0,6372)
[0] 3144 <- (0,6400)
[0] 3145 <- (0,6401)
[0] 3146 <- (0,6402)
[0] 3147 <- (0,6403)
[0] 3148 <- (0,6404)
[0] 3149 <- (0,6405)
[0] 3150 <- (0,6406)
[0] 3151 <- (0,6407)
[0] 3152 <- (0,6408)
[0] 3153 <- (0,6409)
[0] 3154 <- (0,6410)
[0] 3155 <- (0,6411)
[0] 3156 <- (0,6412)
[0] 3157 <- (0,6413)
[0] 3158 <- (0,6414)
[0] 3159 <- (0,6415)
[0] 3160 <- (0,6416)
[0] 3161 <- (0,6417)
[0] 3162 <- (0,6418)
[0] 3163 <- (0,6419)
[0] 3164 <- (0,6420)
[0] 3165 <- (0,6421)
[0] 3166 <- (0,6422)
[0] 3167 <- (0,6423)
[0] 3168 <- (0,6450)
[0] 3169 <- (0,6451)
[0] 3170 <- (0,6452)
[0] 3171 <- (0,6453)
[0] 3172 <- (0,6454)
[0] 3173 <- (0,6455)
[0] 3174 <- (0,6456)
[0] 3175 <- (0,6457)
[0] 3176 <- (0,6458)
[0] 3177 <- (0,6459)
[0] 3178 <- (0,6460)
[0] 3179 <- (0,6461)
[0] 3180 <- (0,6462)
[0] 3181 <- (0,6463)
[0] 3182 <- (0,6464)
[0] 3183 <- (0,6465)
[0] 3184 <- (0,6466)
[0] 3185 <- (0,6467)
[0] 3186 <- (0,6468)
[0] 3187 <- (0,6469)
[0] 3188 <- (0,6470)
[0] 3189 <- (0,6471)
[0] 3190 <- (0,6472)
[0] 3191 <- (0,6473)
[0] 3192 <- (0,6474)
[0] 3193 <- (0,6500)
[0] 3194 <- (0,6501)
[0] 3195 <- (0,6502)
[0] 3196 <- (0,6503)
[0] 3197 <- (0,6504)
[0] 3198 <- (0,6505)
[0] 3199 <- (0,6506)
[0] 3200 <- (0,6507)
[0] 3201 <- (0,6508)
[0] 3202 <- (0,6509)
[0] 3203 <- (0,6510)
[0] 3204 <- (0,6511)
[0] 3205 <- (0,6512)
[0] 3206 <- (0,6513)
[0] 3207 <- (0,6514)
[0] 3208 <- (0,6515)
[0] 3209 <- (0,6516)
[0] 3210 <- (0,6517)
[0] 3211 <- (0,6518)
[0] 3212 <- (0,6519)
[0] 3213 <- (0,6520)
[0] 3214 <- (0,6521)
[0] 3215 <- (0,6522)
[0] 3216 <- (0,6523)
[0] 3217 <- (0,6524)
[0] 3218 <- (0,6550)
[0] 3219 <- (0,6551)
[0] 3220 <- (0,6552)
[0] 3221 <- (0,6553)
[0] 3222 <- (0,6554)
[0] 3223 <- (0,6555)
[0] 3224 <- (0,6556)
[0] 3225 <- (0,6557)
[0] 3226 <- (0,6558)
[0] 3227 <- (0,6559)
[0] 3228 <- (0,6560)
[0] 3229 <- (0,6561)
[0] 3230 <- (0,6562)
[0] 3231 <- (0,6563)
[0] 3232 <- (0,6564)
[0] 3233 <- (0,6565)
[0] 3234 <- (0,6566)
[0] 3235 <- (0,6567)
[0] 3236 <- (0,6568)
[0] 3237 <- (0,6569)
[0] 3238 <- (0,6570)
[0] 3239 <- (0,6571)
[0] 3240 <- (0,6572)
[0] 3241 <- (0,6573)
[0] 3242 <- (0,6574)
[0] 3243 <- (0,6575)
[0] 3244 <- (0,6600)
[0] 3245 <- (0,6601)
[0] 3246 <- (0,6602)
[0] 3247 <- (0,6603)
[0] 3248 <- (0,6604)
[0] 3249 <- (0,6605)
[0] 3250 <- (0,6606)
[0] 3251 <- (0,6607)
[0] 3252 <- (0,6608)
[0] 3253 <- (0,6609)
[0] 3254 <- (0,6610)
[0] 3255 <- (0,6611)
[0] 3256 <- (0,6612)
[0] 3257 <- (0,6613)
[0] 3258 <- (0,6614)
[0] 3259 <- (0,6615)
[0] 3260 <- (0,6616)
[0] 3261 <- (0,6617)
[0] 3262 <- (0,6618)
[0] 3263 <- (0,6619)
[0] 3264 <- (0,6620)
[0] 3265 <- (0,6621)
[0] 3266 <- (0,6622)
[0] 3267 <- (0,6623)
[0] 3268 <- (0,6624)
[0] 3269 <- (0,6625)
[0] 3270 <- (0,6650)
[0] 3271 <- (0,6651)
[0] 3272 <- (0,6652)
[0] 3273 <- (0,6653)
[0] 3274 <- (0,6654)
[0] 3275 <- (0,6655)
[0] 3276 <- (0,6656)
[0] 3277 <- (0,6657)
[0] 3278 <- (0,6658)
[0] 3279 <- (0,6659)
[0] 3280 <- (0,6660)
[0] 3281 <- (0,6661)
[0] 3282 <- (0,6662)
[0] 3283 <- (0,6663)
[0] 3284 <- (0,6664)
[0] 3285 <- (0,6665)
[0] 3286 <- (0,6666)
[0] 3287 <- (0,6667)
[0] 3288 <- (0,6668)
[0] 3289 <- (0,6669)
[0] 3290 <- (0,6670)
[0] 3291 <- (0,6671)
[0] 3292 <- (0,6672)
[0] 3293 <- (0,6673)
[0] 3294 <- (0,6674)
[0] 3295 <- (0,6675)
[0] 3296 <- (0,6676)
[0] 3297 <- (0,6700)
[0] 3298 <- (0,6701)
[0] 3299 <- (0,6702)
[0] 3300 <- (0,6703)
[0] 3301 <- (0,6704)
[0] 3302 <- (0,6705)
[0] 3303 <- (0,6706)
[0] 3304 <- (0,6707)
[0] 3305 <- (0,6708)
[0] 3306 <- (0,6709)
[0] 3307 <- (0,6710)
[0] 3308 <- (0,6711)
[0] 3309 <- (0,6712)
[0] 3310 <- (0,6713)
[0] 3311 <- (0,6714)
[0] 3312 <- (0,6715)
[0] 3313 <- (0,6716)
[0] 3314 <- (0,6717)
[0] 3315 <- (0,6718)
[0] 3316 <- (0,6719)
[0] 3317 <- (0,6720)
[0] 3318 <- (0,6721)
[0] 3319 <- (0,6722)
[0] 3320 <- (0,6723)
[0] 3321 <- (0,6724)
[0] 3322 <- (0,6725)
[0] 3323 <- (0,6726)
[0] 3324 <- (0,6750)
[0] 3325 <- (0,6751)
[0] 3326 <- (0,6752)
[0] 3327 <- (0,6753)
[0] 3328 <- (0,6754)
[0] 3329 <- (0,6755)
[0] 3330 <- (0,6756)
[0] 3331 <- (0,6757)
[0] 3332 <- (0,6758)
[0] 3333 <- (0,6759)
[0] 3334 <- (0,6760)
[0] 3335 <- (0,6761)
[0] 3336 <- (0,6762)
[0] 3337 <- (0,6763)
[0] 3338 <- (0,6764)
[0] 3339 <- (0,6765)
[0] 3340 <- (0,6766)
[0] 3341 <- (0,6767)
[0] 3342 <- (0,6768)
[0] 3343 <- (0,6769)
[0] 3344 <- (0,6770)
[0] 3345 <- (0,6771)
[0] 3346 <- (0,6772)
[0] 3347 <- (0,6773)
[0] 3348 <- (0,6774)
[0] 3349 <- (0,6775)
[0] 3350 <- (0,6776)
[0] 3351 <- (0,6800)
[0] 3352 <- (0,6801)
[0] 3353 <- (0,6802)
[0] 3354 <- (0,6803)
[0] 3355 <- (0,6804)
[0] 3356 <- (0,6805)
[0] 3357 <- (0,6806)
[0] 3358 <- (0,6807)
[0] 3359 <- (0,6808)
[0] 3360 <- (0,6809)
[0] 3361 <- (0,6810)
[0] 3362 <- (0,6811)
[0] 3363 <- (0,6812)
[0] 3364 <- (0,6813)
[0] 3365 <- (0,6814)
[0] 3366 <- (0,6815)
[0] 3367 <- (0,6816)
[0] 3368 <- (0,6817)
[0] 3369 <- (0,6818)
[0] 3370 <- (0,6819)
[0] 3371 <- (0,6820)
[0] 3372 <- (0,6821)
[0] 3373 <- (0,6822)
[0] 3374 <- (0,6823)
[0] 3375 <- (0,6824)
[0] 3376 <- (0,6825)
[0] 3377 <- (0,6826)
[0] 3378 <- (0,6850)
[0] 3379 <- (0,6851)
[0] 3380 <- (0,6852)
[0] 3381 <- (0,6853)
[0] 3382 <- (0,6854)
[0] 3383 <- (0,6855)
[0] 3384 <- (0,6856)
[0] 3385 <- (0,6857)
[0] 3386 <- (0,6858)
[0] 3387 <- (0,6859)
[0] 3388 <- (0,6860)
[0] 3389 <- (0,6861)
[0] 3390 <- (0,6862)
[0] 3391 <- (0,6863)
[0] 3392 <- (0,6864)
[0] 3393 <- (0,6865)
[0] 3394 <- (0,6866)
[0] 3395 <- (0,6867)
[0] 3396 <- (0,6868)
[0] 3397 <- (0,6869)
[0] 3398 <- (0,6870)
[0] 3399 <- (0,6871)
[0] 3400 <- (0,6872)
[0] 3401 <- (0,6873)
[0] 3402 <- (0,6874)
[0] 3403 <- (0,6875)
[0] 3404 <- (0,6876)
[0] 3405 <- (0,6900)
[0] 3406 <- (0,6901)
[0] 3407 <- (0,6902)
[0] 3408 <- (0,6903)
[0] 3409 <- (0,6904)
[0] 3410 <- (0,6905)
[0] 3411 <- (0,6906)
[0] 3412 <- (0,6907)
[0] 3413 <- (0,6908)
[0] 3414 <- (0,6909)
[0] 3415 <- (0,6910)
[0] 3416 <- (0,6911)
[0] 3417 <- (0,6912)
[0] 3418 <- (0,6913)
[0] 3419 <- (0,6914)
[0] 3420 <- (0,6915)
[0] 3421 <- (0,6916)
[0] 3422 <- (0,6917)
[0] 3423 <- (0,6918)
[0] 3424 <- (0,6919)
[0] 3425 <- (0,6920)
[0] 3426 <- (0,6921)
[0] 3427 <- (0,6922)
[0] 3428 <- (0,6923)
[0] 3429 <- (0,6924)
[0] 3430 <- (0,6925)
[0] 3431 <- (0,6926)
[0] 3432 <- (0,6950)
[0] 3433 <- (0,6951)
[0] 3434 <- (0,6952)
[0] 3435 <- (0,6953)
[0] 3436 <- (0,6954)
[0] 3437 <- (0,6955)
[0] 3438 <- (0,6956)
[0] 3439 <- (0,6957)
[0] 3440 <- (0,6958)
[0] 3441 <- (0,6959)
[0] 3442 <- (0,6960)
[0] 3443 <- (0,6961)
[0] 3444 <- (0,6962)
[0] 3445 <- (0,6963)
[0] 3446 <- (0,6964)
[0] 3447 <- (0,6965)
[0] 3448 <- (0,6966)
[0] 3449 <- (0,6967)
[0] 3450 <- (0,6968)
[0] 3451 <- (0,6969)
[0] 3452 <- (0,6970)
[0] 3453 <- (0,6971)
[0] 3454 <- (0,6972)
[0] 3455 <- (0,6973)
[0] 3456 <- (0,6974)
[0] 3457 <- (0,6975)
[0] 3458 <- (0,6976)
[0] 3459 <- (0,7000)
[0] 3460 <- (0,7001)
[0] 3461 <- (0,7002)
[0] 3462 <- (0,7003)
[0] 3463 <- (0,7004)
[0] 3464 <- (0,7005)
[0] 3465 <- (0,7006)
[0] 3466 <- (0,7007)
[0] 3467 <- (0,7008)
[0] 3468 <- (0,7009)
[0] 3469 <- (0,7010)
[0] 3470 <- (0,7011)
[0] 3471 <- (0,7012)
[0] 3472 <- (0,7013)
[0] 3473 <- (0,7014)
[0] 3474 <- (0,7015)
[0] 3475 <- (0,7016)
[0] 3476 <- (0,7017)
[0] 3477 <- (0,7018)
[0] 3478 <- (0,7019)
[0] 3479 <- (0,7020)
[0] 3480 <- (0,7021)
[0] 3481 <- (0,7050)
[0] 3482 <- (0,7051)
[0] 3483 <- (0,7052)
[0] 3484 <- (0,7053)
[0] 3485 <- (0,7054)
[0] 3486 <- (0,7055)
[0] 3487 <- (0,7056)
[0] 3488 <- (0,7057)
[0] 3489 <- (0,7058)
[0] 3490 <- (0,7059)
[0] 3491 <- (0,7060)
[0] 3492 <- (0,7061)
[0] 3493 <- (0,7062)
[0] 3494 <- (0,7063)
[0] 3495 <- (0,7064)
[0] 3496 <- (0,7065)
[0] 3497 <- (0,7066)
[0] 3498 <- (0,7067)
[0] 3499 <- (0,7068)
[0] 3500 <- (0,7069)
[0] 3501 <- (0,7070)
[0] 3502 <- (0,7071)
[0] 3503 <- (0,7100)
[0] 3504 <- (0,7101)
[0] 3505 <- (0,7102)
[0] 3506 <- (0,7103)
[0] 3507 <- (0,7104)
[0] 3508 <- (0,7105)
[0] 3509 <- (0,7106)
[0] 3510 <- (0,7107)
[0] 3511 <- (0,7108)
[0] 3512 <- (0,7109)
[0] 3513 <- (0,7110)
[0] 3514 <- (0,7111)
[0] 3515 <- (0,7112)
[0] 3516 <- (0,7113)
[0] 3517 <- (0,7114)
[0] 3518 <- (0,7115)
[0] 3519 <- (0,7116)
[0] 3520 <- (0,7117)
[0] 3521 <- (0,7118)
[0] 3522 <- (0,7119)
[0] 3523 <- (0,7120)
[0] 3524 <- (0,7121)
[0] 3525 <- (0,7150)
[0] 3526 <- (0,7151)
[0] 3527 <- (0,7152)
[0] 3528 <- (0,7153)
[0] 3529 <- (0,7154)
[0] 3530 <- (0,7155)
[0] 3531 <- (0,7156)
[0] 3532 <- (0,7157)
[0] 3533 <- (0,7158)
[0] 3534 <- (0,7159)
[0] 3535 <- (0,7160)
[0] 3536 <- (0,7161)
[0] 3537 <- (0,7162)
[0] 3538 <- (0,7163)
[0] 3539 <- (0,7164)
[0] 3540 <- (0,7165)
[0] 3541 <- (0,7166)
[0] 3542 <- (0,7167)
[0] 3543 <- (0,7168)
[0] 3544 <- (0,7169)
[0] 3545 <- (0,7170)
[0] 3546 <- (0,7171)
[0] 3547 <- (0,7200)
[0] 3548 <- (0,7201)
[0] 3549 <- (0,7202)
[0] 3550 <- (0,7203)
[0] 3551 <- (0,7204)
[0] 3552 <- (0,7205)
[0] 3553 <- (0,7206)
[0] 3554 <- (0,7207)
[0] 3555 <- (0,7208)
[0] 3556 <- (0,7209)
[0] 3557 <- (0,7210)
[0] 3558 <- (0,7211)
[0] 3559 <- (0,7212)
[0] 3560 <- (0,7213)
[0] 3561 <- (0,7214)
[0] 3562 <- (0,7215)
[0] 3563 <- (0,7216)
[0] 3564 <- (0,7217)
[0] 3565 <- (0,7218)
[0] 3566 <- (0,7219)
[0] 3567 <- (0,7220)
[0] 3568 <- (0,7221)
[0] 3569 <- (0,7222)
[0] 3570 <- (0,7250)
[0] 3571 <- (0,7251)
[0] 3572 <- (0,7252)
[0] 3573 <- (0,7253)
[0] 3574 <- (0,7254)
[0] 3575 <- (0,7255)
[0] 3576 <- (0,7256)
[0] 3577 <- (0,7257)
[0] 3578 <- (0,7258)
[0] 3579 <- (0,7259)
[0] 3580 <- (0,7260)
[0] 3581 <- (0,7261)
[0] 3582 <- (0,7262)
[0] 3583 <- (0,7263)
[0] 3584 <- (0,7264)
[0] 3585 <- (0,7265)
[0] 3586 <- (0,7266)
[0] 3587 <- (0,7267)
[0] 3588 <- (0,7268)
[0] 3589 <- (0,7269)
[0] 3590 <- (0,7270)
[0] 3591 <- (0,7271)
[0] 3592 <- (0,7272)
[0] 3593 <- (0,7300)
[0] 3594 <- (0,7301)
[0] 3595 <- (0,7302)
[0] 3596 <- (0,7303)
[0] 3597 <- (0,7304)
[0] 3598 <- (0,7305)
[0] 3599 <- (0,7306)
[0] 3600 <- (0,7307)
[0] 3601 <- (0,7308)
[0] 3602 <- (0,7309)
[0] 3603 <- (0,7310)
[0] 3604 <- (0,7311)
[0] 3605 <- (0,7312)
[0] 3606 <- (0,7313)
[0] 3607 <- (0,7314)
[0] 3608 <- (0,7315)
[0] 3609 <- (0,7316)
[0] 3610 <- (0,7317)
[0] 3611 <- (0,7318)
[0] 3612 <- (0,7319)
[0] 3613 <- (0,7320)
[0] 3614 <- (0,7321)
[0] 3615 <- (0,7322)
[0] 3616 <- (0,7350)
[0] 3617 <- (0,7351)
[0] 3618 <- (0,7352)
[0] 3619 <- (0,7353)
[0] 3620 <- (0,7354)
[0] 3621 <- (0,7355)
[0] 3622 <- (0,7356)
[0] 3623 <- (0,7357)
[0] 3624 <- (0,7358)
[0] 3625 <- (0,7359)
[0] 3626 <- (0,7360)
[0] 3627 <- (0,7361)
[0] 3628 <- (0,7362)
[0] 3629 <- (0,7363)
[0] 3630 <- (0,7364)
[0] 3631 <- (0,7365)
[0] 3632 <- (0,7366)
[0] 3633 <- (0,7367)
[0] 3634 <- (0,7368)
[0] 3635 <- (0,7369)
[0] 3636 <- (0,7370)
[0] 3637 <- (0,7371)
[0] 3638 <- (0,7372)
[0] 3639 <- (0,7400)
[0] 3640 <- (0,7401)
[0] 3641 <- (0,7402)
[0] 3642 <- (0,7403)
[0] 3643 <- (0,7404)
[0] 3644 <- (0,7405)
[0] 3645 <- (0,7406)
[0] 3646 <- (0,7407)
[0] 3647 <- (0,7408)
[0] 3648 <- (0,7409)
[0] 3649 <- (0,7410)
[0] 3650 <- (0,7411)
[0] 3651 <- (0,7412)
[0] 3652 <- (0,7413)
[0] 3653 <- (0,7414)
[0] 3654 <- (0,7415)
[0] 3655 <- (0,7416)
[0] 3656 <- (0,7417)
[0] 3657 <- (0,7418)
[0] 3658 <- (0,7419)
[0] 3659 <- (0,7420)
[0] 3660 <- (0,7421)
[0] 3661 <- (0,7422)
[0] 3662 <- (0,7423)
[0] 3663 <- (0,7450)
[0] 3664 <- (0,7451)
[0] 3665 <- (0,7452)
[0] 3666 <- (0,7453)
[0] 3667 <- (0,7454)
[0] 3668 <- (0,7455)
[0] 3669 <- (0,7456)
[0] 3670 <- (0,7457)
[0] 3671 <- (0,7458)
[0] 3672 <- (0,7459)
[0] 3673 <- (0,7460)
[0] 3674 <- (0,7461)
[0] 3675 <- (0,7462)
[0] 3676 <- (0,7463)
[0] 3677 <- (0,7464)
[0] 3678 <- (0,7465)
[0] 3679 <- (0,7466)
[0] 3680 <- (0,7467)
[0] 3681 <- (0,7468)
[0] 3682 <- (0,7469)
[0] 3683 <- (0,7470)
[0] 3684 <- (0,7471)
[0] 3685 <- (0,7472)
[0] 3686 <- (0,7473)
[0] 3687 <- (0,7474)
[0] 3688 <- (0,7500)
[0] 3689 <- (0,7501)
[0] 3690 <- (0,7502)
[0] 3691 <- (0,7503)
[0] 3692 <- (0,7504)
[0] 3693 <- (0,7505)
[0] 3694 <- (0,7506)
[0] 3695 <- (0,7507)
[0] 3696 <- (0,7508)
[0] 3697 <- (0,7509)
[0] 3698 <- (0,7510)
[0] 3699 <- (0,7511)
[0] 3700 <- (0,7512)
[0] 3701 <- (0,7513)
[0] 3702 <- (0,7514)
[0] 3703 <- (0,7515)
[0] 3704 <- (0,7516)
[0] 3705 <- (0,7517)
[0] 3706 <- (0,7518)
[0] 3707 <- (0,7519)
[0] 3708 <- (0,7520)
[0] 3709 <- (0,7521)
[0] 3710 <- (0,7522)
[0] 3711 <- (0,7523)
[0] 3712 <- (0,7524)
[0] 3713 <- (0,7550)
[0] 3714 <- (0,7551)
[0] 3715 <- (0,7552)
[0] 3716 <- (0,7553)
[0] 3717 <- (0,7554)
[0] 3718 <- (0,7555)
[0] 3719 <- (0,7556)
[0] 3720 <- (0,7557)
[0] 3721 <- (0,7558)
[0] 3722 <- (0,7559)
[0] 3723 <- (0,7560)
[0] 3724 <- (0,7561)
[0] 3725 <- (0,7562)
[0] 3726 <- (0,7563)
[0] 3727 <- (0,7564)
[0] 3728 <- (0,7565)
[0] 3729 <- (0,7566)
[0] 3730 <- (0,7567)
[0] 3731 <- (0,7568)
[0] 3732 <- (0,7569)
[0] 3733 <- (0,7570)
[0] 3734 <- (0,7571)
[0] 3735 <- (0,7572)
[0] 3736 <- (0,7573)
[0] 3737 <- (0,7574)
[0] 3738 <- (0,7575)
[0] 3739 <- (0,7600)
[0] 3740 <- (0,7601)
[0] 3741 <- (0,7602)
[0] 3742 <- (0,7603)
[0] 3743 <- (0,7604)
[0] 3744 <- (0,7605)
[0] 3745 <- (0,7606)
[0] 3746 <- (0,7607)
[0] 3747 <- (0,7608)
[0] 3748 <- (0,7609)
[0] 3749 <- (0,7610)
[0] 3750 <- (0,7611)
[0] 3751 <- (0,7612)
[0] 3752 <- (0,7613)
[0] 3753 <- (0,7614)
[0] 3754 <- (0,7615)
[0] 3755 <- (0,7616)
[0] 3756 <- (0,7617)
[0] 3757 <- (0,7618)
[0] 3758 <- (0,7619)
[0] 3759 <- (0,7620)
[0] 3760 <- (0,7621)
[0] 3761 <- (0,7622)
[0] 3762 <- (0,7623)
[0] 3763 <- (0,7624)
[0] 3764 <- (0,7625)
[0] 3765 <- (0,7650)
[0] 3766 <- (0,7651)
[0] 3767 <- (0,7652)
[0] 3768 <- (0,7653)
[0] 3769 <- (0,7654)
[0] 3770 <- (0,7655)
[0] 3771 <- (0,7656)
[0] 3772 <- (0,7657)
[0] 3773 <- (0,7658)
[0] 3774 <- (0,7659)
[0] 3775 <- (0,7660)
[0] 3776 <- (0,7661)
[0] 3777 <- (0,7662)
[0] 3778 <- (0,7663)
[0] 3779 <- (0,7664)
[0] 3780 <- (0,7665)
[0] 3781 <- (0,7666)
[0] 3782 <- (0,7667)
[0] 3783 <- (0,7668)
[0] 3784 <- (0,7669)
[0] 3785 <- (0,7670)
[0] 3786 <- (0,7671)
[0] 3787 <- (0,7672)
[0] 3788 <- (0,7673)
[0] 3789 <- (0,7674)
[0] 3790 <- (0,7675)
[0] 3791 <- (0,7676)
[0] 3792 <- (0,7700)
[0] 3793 <- (0,7701)
[0] 3794 <- (0,7702)
[0] 3795 <- (0,7703)
[0] 3796 <- (0,7704)
[0] 3797 <- (0,7705)
[0] 3798 <- (0,7706)
[0] 3799 <- (0,7707)
[0] 3800 <- (0,7708)
[0] 3801 <- (0,7709)
[0] 3802 <- (0,7710)
[0] 3803 <- (0,7711)
[0] 3804 <- (0,7712)
[0] 3805 <- (0,7713)
[0] 3806 <- (0,7714)
[0] 3807 <- (0,7715)
[0] 3808 <- (0,7716)
[0] 3809 <- (0,7717)
[0] 3810 <- (0,7718)
[0] 3811 <- (0,7719)
[0] 3812 <- (0,7720)
[0] 3813 <- (0,7721)
[0] 3814 <- (0,7722)
[0] 3815 <- (0,7723)
[0] 3816 <- (0,7724)
[0] 3817 <- (0,7725)
[0] 3818 <- (0,7726)
[0] 3819 <- (0,7750)
[0] 3820 <- (0,7751)
[0] 3821 <- (0,7752)
[0] 3822 <- (0,7753)
[0] 3823 <- (0,7754)
[0] 3824 <- (0,7755)
[0] 3825 <- (0,7756)
[0] 3826 <- (0,7757)
[0] 3827 <- (0,7758)
[0] 3828 <- (0,7759)
[0] 3829 <- (0,7760)
[0] 3830 <- (0,7761)
[0] 3831 <- (0,7762)
[0] 3832 <- (0,7763)
[0] 3833 <- (0,7764)
[0] 3834 <- (0,7765)
[0] 3835 <- (0,7766)
[0] 3836 <- (0,7767)
[0] 3837 <- (0,7768)
[0] 3838 <- (0,7769)
[0] 3839 <- (0,7770)
[0] 3840 <- (0,7771)
[0] 3841 <- (0,7772)
[0] 3842 <- (0,7773)
[0] 3843 <- (0,7774)
[0] 3844 <- (0,7775)
[0] 3845 <- (0,7776)
[0] 3846 <- (0,7800)
[0] 3847 <- (0,7801)
[0] 3848 <- (0,7802)
[0] 3849 <- (0,7803)
[0] 3850 <- (0,7804)
[0] 3851 <- (0,7805)
[0] 3852 <- (0,7806)
[0] 3853 <- (0,7807)
[0] 3854 <- (0,7808)
[0] 3855 <- (0,7809)
[0] 3856 <- (0,7810)
[0] 3857 <- (0,7811)
[0] 3858 <- (0,7812)
[0] 3859 <- (0,7813)
[0] 3860 <- (0,7814)
[0] 3861 <- (0,7815)
[0] 3862 <- (0,7816)
[0] 3863 <- (0,7817)
[0] 3864 <- (0,7818)
[0] 3865 <- (0,7819)
[0] 3866 <- (0,7820)
[0] 3867 <- (0,7821)
[0] 3868 <- (0,7822)
[0] 3869 <- (0,7823)
[0] 3870 <- (0,7824)
[0] 3871 <- (0,7825)
[0] 3872 <- (0,7826)
[0] 3873 <- (0,7850)
[0] 3874 <- (0,7851)
[0] 3875 <- (0,7852)
[0] 3876 <- (0,7853)
[0] 3877 <- (0,7854)
[0] 3878 <- (0,7855)
[0] 3879 <- (0,7856)
[0] 3880 <- (0,7857)
[0] 3881 <- (0,7858)
[0] 3882 <- (0,7859)
[0] 3883 <- (0,7860)
[0] 3884 <- (0,7861)
[0] 3885 <- (0,7862)
[0] 3886 <- (0,7863)
[0] 3887 <- (0,7864)
[0] 3888 <- (0,7865)
[0] 3889 <- (0,7866)
[0] 3890 <- (0,7867)
[0] 3891 <- (0,7868)
[0] 3892 <- (0,7869)
[0] 3893 <- (0,7870)
[0] 3894 <- (0,7871)
[0] 3895 <- (0,7872)
[0] 3896 <- (0,7873)
[0] 3897 <- (0,7874)
[0] 3898 <- (0,7875)
[0] 3899 <- (0,7876)
[0] 3900 <- (0,7900)
[0] 3901 <- (0,7901)
[0] 3902 <- (0,7902)
[0] 3903 <- (0,7903)
[0] 3904 <- (0,7904)
[0] 3905 <- (0,7905)
[0] 3906 <- (0,7906)
[0] 3907 <- (0,7907)
[0] 3908 <- (0,7908)
[0] 3909 <- (0,7909)
[0] 3910 <- (0,7910)
[0] 3911 <- (0,7911)
[0] 3912 <- (0,7912)
[0] 3913 <- (0,7913)
[0] 3914 <- (0,7914)
[0] 3915 <- (0,7915)
[0] 3916 <- (0,7916)
[0] 3917 <- (0,7917)
[0] 3918 <- (0,7918)
[0] 3919 <- (0,7919)
[0] 3920 <- (0,7920)
[0] 3921 <- (0,7921)
[0] 3922 <- (0,7922)
[0] 3923 <- (0,7923)
[0] 3924 <- (0,7924)
[0] 3925 <- (0,7925)
[0] 3926 <- (0,7926)
[0] 3927 <- (0,7950)
[0] 3928 <- (0,7951)
[0] 3929 <- (0,7952)
[0] 3930 <- (0,7953)
[0] 3931 <- (0,7954)
[0] 3932 <- (0,7955)
[0] 3933 <- (0,7956)
[0] 3934 <- (0,7957)
[0] 3935 <- (0,7958)
[0] 3936 <- (0,7959)
[0] 3937 <- (0,7960)
[0] 3938 <- (0,7961)
[0] 3939 <- (0,7962)
[0] 3940 <- (0,7963)
[0] 3941 <- (0,7964)
[0] 3942 <- (0,7965)
[0] 3943 <- (0,7966)
[0] 3944 <- (0,7967)
[0] 3945 <- (0,7968)
[0] 3946 <- (0,7969)
[0] 3947 <- (0,7970)
[0] 3948 <- (0,7971)
[0] 3949 <- (0,7972)
[0] 3950 <- (0,7973)
[0] 3951 <- (0,7974)
[0] 3952 <- (0,7975)
[0] 3953 <- (0,7976)
[0] 3954 <- (0,8000)
[0] 3955 <- (0,8001)
[0] 3956 <- (0,8002)
[0] 3957 <- (0,8003)
[0] 3958 <- (0,8004)
[0] 3959 <- (0,8005)
[0] 3960 <- (0,8006)
[0] 3961 <- (0,8007)
[0] 3962 <- (0,8008)
[0] 3963 <- (0,8009)
[0] 3964 <- (0,8010)
[0] 3965 <- (0,8011)
[0] 3966 <- (0,8012)
[0] 3967 <- (0,8013)
[0] 3968 <- (0,8014)
[0] 3969 <- (0,8015)
[0] 3970 <- (0,8016)
[0] 3971 <- (0,8017)
[0] 3972 <- (0,8018)
[0] 3973 <- (0,8019)
[0] 3974 <- (0,8020)
[0] 3975 <- (0,8021)
[0] 3976 <- (0,8050)
[0] 3977 <- (0,8051)
[0] 3978 <- (0,8052)
[0] 3979 <- (0,8053)
[0] 3980 <- (0,8054)
[0] 3981 <- (0,8055)
[0] 3982 <- (0,8056)
[0] 3983 <- (0,8057)
[0] 3984 <- (0,8058)
[0] 3985 <- (0,8059)
[0] 3986 <- (0,8060)
[0] 3987 <- (0,8061)
[0] 3988 <- (0,8062)
[0] 3989 <- (0,8063)
[0] 3990 <- (0,8064)
[0] 3991 <- (0,8065)
[0] 3992 <- (0,8066)
[0] 3993 <- (0,8067)
[0] 3994 <- (0,8068)
[0] 3995 <- (0,8069)
[0] 3996 <- (0,8070)
[0] 3997 <- (0,8071)
[0] 3998 <- (0,8100)
[0] 3999 <- (0,8101)
[0] 4000 <- (0,8102)
[0] 4001 <- (0,8103)
[0] 4002 <- (0,8104)
[0] 4003 <- (0,8105)
[0] 4004 <- (0,8106)
[0] 4005 <- (0,8107)
[0] 4006 <- (0,8108)
[0] 4007 <- (0,8109)
[0] 4008 <- (0,8110)
[0] 4009 <- (0,8111)
[0] 4010 <- (0,8112)
[0] 4011 <- (0,8113)
[0] 4012 <- (0,8114)
[0] 4013 <- (0,8115)
[0] 4014 <- (0,8116)
[0] 4015 <- (0,8117)
[0] 4016 <- (0,8118)
[0] 4017 <- (0,8119)
[0] 4018 <- (0,8120)
[0] 4019 <- (0,8121)
[0] 4020 <- (0,8150)
[0] 4021 <- (0,8151)
[0] 4022 <- (0,8152)
[0] 4023 <- (0,8153)
[0] 4024 <- (0,8154)
[0] 4025 <- (0,8155)
[0] 4026 <- (0,8156)
[0] 4027 <- (0,8157)
[0] 4028 <- (0,8158)
[0] 4029 <- (0,8159)
[0] 4030 <- (0,8160)
[0] 4031 <- (0,8161)
[0] 4032 <- (0,8162)
[0] 4033 <- (0,8163)
[0] 4034 <- (0,8164)
[0] 4035 <- (0,8165)
[0] 4036 <- (0,8166)
[0] 4037 <- (0,8167)
[0] 4038 <- (0,8168)
[0] 4039 <- (0,8169)
[0] 4040 <- (0,8170)
[0] 4041 <- (0,8171)
[0] 4042 <- (0,8200)
[0] 4043 <- (0,8201)
[0] 4044 <- (0,8202)
[0] 4045 <- (0,8203)
[0] 4046 <- (0,8204)
[0] 4047 <- (0,8205)
[0] 4048 <- (0,8206)
[0] 4049 <- (0,8207)
[0] 4050 <- (0,8208)
[0] 4051 <- (0,8209)
[0] 4052 <- (0,8210)
[0] 4053 <- (0,8211)
[0] 4054 <- (0,8212)
[0] 4055 <- (0,8213)
[0] 4056 <- (0,8214)
[0] 4057 <- (0,8215)
[0] 4058 <- (0,8216)
[0] 4059 <- (0,8217)
[0] 4060 <- (0,8218)
[0] 4061 <- (0,8219)
[0] 4062 <- (0,8220)
[0] 4063 <- (0,8221)
[0] 4064 <- (0,8222)
[0] 4065 <- (0,8250)
[0] 4066 <- (0,8251)
[0] 4067 <- (0,8252)
[0] 4068 <- (0,8253)
[0] 4069 <- (0,8254)
[0] 4070 <- (0,8255)
[0] 4071 <- (0,8256)
[0] 4072 <- (0,8257)
[0] 4073 <- (0,8258)
[0] 4074 <- (0,8259)
[0] 4075 <- (0,8260)
[0] 4076 <- (0,8261)
[0] 4077 <- (0,8262)
[0] 4078 <- (0,8263)
[0] 4079 <- (0,8264)
[0] 4080 <- (0,8265)
[0] 4081 <- (0,8266)
[0] 4082 <- (0,8267)
[0] 4083 <- (0,8268)
[0] 4084 <- (0,8269)
[0] 4085 <- (0,8270)
[0] 4086 <- (0,8271)
[0] 4087 <- (0,8272)
[0] 4088 <- (0,8300)
[0] 4089 <- (0,8301)
[0] 4090 <- (0,8302)
[0] 4091 <- (0,8303)
[0] 4092 <- (0,8304)
[0] 4093 <- (0,8305)
[0] 4094 <- (0,8306)
[0] 4095 <- (0,8307)
[0] 4096 <- (0,8308)
[0] 4097 <- (0,8309)
[0] 4098 <- (0,8310)
[0] 4099 <- (0,8311)
[0] 4100 <- (0,8312)
[0] 4101 <- (0,8313)
[0] 4102 <- (0,8314)
[0] 4103 <- (0,8315)
[0] 4104 <- (0,8316)
[0] 4105 <- (0,8317)
[0] 4106 <- (0,8318)
[0] 4107 <- (0,8319)
[0] 4108 <- (0,8320)
[0] 4109 <- (0,8321)
[0] 4110 <- (0,8322)
[0] 4111 <- (0,8350)
[0] 4112 <- (0,8351)
[0] 4113 <- (0,8352)
[0] 4114 <- (0,8353)
[0] 4115 <- (0,8354)
[0] 4116 <- (0,8355)
[0] 4117 <- (0,8356)
[0] 4118 <- (0,8357)
[0] 4119 <- (0,8358)
[0] 4120 <- (0,8359)
[0] 4121 <- (0,8360)
[0] 4122 <- (0,8361)
[0] 4123 <- (0,8362)
[0] 4124 <- (0,8363)
[0] 4125 <- (0,8364)
[0] 4126 <- (0,8365)
[0] 4127 <- (0,8366)
[0] 4128 <- (0,8367)
[0] 4129 <- (0,8368)
[0] 4130 <- (0,8369)
[0] 4131 <- (0,8370)
[0] 4132 <- (0,8371)
[0] 4133 <- (0,8372)
[0] 4134 <- (0,8400)
[0] 4135 <- (0,8401)
[0] 4136 <- (0,8402)
[0] 4137 <- (0,8403)
[0] 4138 <- (0,8404)
[0] 4139 <- (0,8405)
[0] 4140 <- (0,8406)
[0] 4141 <- (0,8407)
[0] 4142 <- (0,8408)
[0] 4143 <- (0,8409)
[0] 4144 <- (0,8410)
[0] 4145 <- (0,8411)
[0] 4146 <- (0,8412)
[0] 4147 <- (0,8413)
[0] 4148 <- (0,8414)
[0] 4149 <- (0,8415)
[0] 4150 <- (0,8416)
[0] 4151 <- (0,8417)
[0] 4152 <- (0,8418)
[0] 4153 <- (0,8419)
[0] 4154 <- (0,8420)
[0] 4155 <- (0,8421)
[0] 4156 <- (0,8422)
[0] 4157 <- (0,8423)
[0] 4158 <- (0,8450)
[0] 4159 <- (0,8451)
[0] 4160 <- (0,8452)
[0] 4161 <- (0,8453)
[0] 4162 <- (0,8454)
[0] 4163 <- (0,8455)
[0] 4164 <- (0,8456)
[0] 4165 <- (0,8457)
[0] 4166 <- (0,8458)
[0] 4167 <- (0,8459)
[0] 4168 <- (0,8460)
[0] 4169 <- (0,8461)
[0] 4170 <- (0,8462)
[0] 4171 <- (0,8463)
[0] 4172 <- (0,8464)
[0] 4173 <- (0,8465)
[0] 4174 <- (0,8466)
[0] 4175 <- (0,8467)
[0] 4176 <- (0,8468)
[0] 4177 <- (0,8469)
[0] 4178 <- (0,8470)
[0] 4179 <- (0,8471)
[0] 4180 <- (0,8472)
[0] 4181 <- (0,8473)
[0] 4182 <- (0,8474)
[0] 4183 <- (0,8500)
[0] 4184 <- (0,8501)
[0] 4185 <- (0,8502)
[0] 4186 <- (0,8503)
[0] 4187 <- (0,8504)
[0] 4188 <- (0,8505)
[0] 4189 <- (0,8506)
[0] 4190 <- (0,8507)
[0] 4191 <- (0,8508)
[0] 4192 <- (0,8509)
[0] 4193 <- (0,8510)
[0] 4194 <- (0,8511)
[0] 4195 <- (0,8512)
[0] 4196 <- (0,8513)
[0] 4197 <- (0,8514)
[0] 4198 <- (0,8515)
[0] 4199 <- (0,8516)
[0] 4200 <- (0,8517)
[0] 4201 <- (0,8518)
[0] 4202 <- (0,8519)
[0] 4203 <- (0,8520)
[0] 4204 <- (0,8521)
[0] 4205 <- (0,8522)
[0] 4206 <- (0,8523)
[0] 4207 <- (0,8524)
[0] 4208 <- (0,8550)
[0] 4209 <- (0,8551)
[0] 4210 <- (0,8552)
[0] 4211 <- (0,8553)
[0] 4212 <- (0,8554)
[0] 4213 <- (0,8555)
[0] 4214 <- (0,8556)
[0] 4215 <- (0,8557)
[0] 4216 <- (0,8558)
[0] 4217 <- (0,8559)
[0] 4218 <- (0,8560)
[0] 4219 <- (0,8561)
[0] 4220 <- (0,8562)
[0] 4221 <- (0,8563)
[0] 4222 <- (0,8564)
[0] 4223 <- (0,8565)
[0] 4224 <- (0,8566)
[0] 4225 <- (0,8567)
[0] 4226 <- (0,8568)
[0] 4227 <- (0,8569)
[0] 4228 <- (0,8570)
[0] 4229 <- (0,8571)
[0] 4230 <- (0,8572)
[0] 4231 <- (0,8573)
[0] 4232 <- (0,8574)
[0] 4233 <- (0,8575)
[0] 4234 <- (0,8600)
[0] 4235 <- (0,8601)
[0] 4236 <- (0,8602)
[0] 4237 <- (0,8603)
[0] 4238 <- (0,8604)
[0] 4239 <- (0,8605)
[0] 4240 <- (0,8606)
[0] 4241 <- (0,8607)
[0] 4242 <- (0,8608)
[0] 4243 <- (0,8609)
[0] 4244 <- (0,8610)
[0] 4245 <- (0,8611)
[0] 4246 <- (0,8612)
[0] 4247 <- (0,8613)
[0] 4248 <- (0,8614)
[0] 4249 <- (0,8615)
[0] 4250 <- (0,8616)
[0] 4251 <- (0,8617)
[0] 4252 <- (0,8618)
[0] 4253 <- (0,8619)
[0] 4254 <- (0,8620)
[0] 4255 <- (0,8621)
[0] 4256 <- (0,8622)
[0] 4257 <- (0,8623)
[0] 4258 <- (0,8624)
[0] 4259 <- (0,8625)
[0] 4260 <- (0,8650)
[0] 4261 <- (0,8651)
[0] 4262 <- (0,8652)
[0] 4263 <- (0,8653)
[0] 4264 <- (0,8654)
[0] 4265 <- (0,8655)
[0] 4266 <- (0,8656)
[0] 4267 <- (0,8657)
[0] 4268 <- (0,8658)
[0] 4269 <- (0,8659)
[0] 4270 <- (0,8660)
[0] 4271 <- (0,8661)
[0] 4272 <- (0,8662)
[0] 4273 <- (0,8663)
[0] 4274 <- (0,8664)
[0] 4275 <- (0,8665)
[0] 4276 <- (0,8666)
[0] 4277 <- (0,8667)
[0] 4278 <- (0,8668)
[0] 4279 <- (0,8669)
[0] 4280 <- (0,8670)
[0] 4281 <- (0,8671)
[0] 4282 <- (0,8672)
[0] 4283 <- (0,8673)
[0] 4284 <- (0,8674)
[0] 4285 <- (0,8675)
[0] 4286 <- (0,8676)
[0] 4287 <- (0,8700)
[0] 4288 <- (0,8701)
[0] 4289 <- (0,8702)
[0] 4290 <- (0,8703)
[0] 4291 <- (0,8704)
[0] 4292 <- (0,8705)
[0] 4293 <- (0,8706)
[0] 4294 <- (0,8707)
[0] 4295 <- (0,8708)
[0] 4296 <- (0,8709)
[0] 4297 <- (0,8710)
[0] 4298 <- (0,8711)
[0] 4299 <- (0,8712)
[0] 4300 <- (0,8713)
[0] 4301 <- (0,8714)
[0] 4302 <- (0,8715)
[0] 4303 <- (0,8716)
[0] 4304 <- (0,8717)
[0] 4305 <- (0,8718)
[0] 4306 <- (0,8719)
[0] 4307 <- (0,8720)
[0] 4308 <- (0,8721)
[0] 4309 <- (0,8722)
[0] 4310 <- (0,8723)
[0] 4311 <- (0,8724)
[0] 4312 <- (0,8725)
[0] 4313 <- (0,8726)
[0] 4314 <- (0,8750)
[0] 4315 <- (0,8751)
[0] 4316 <- (0,8752)
[0] 4317 <- (0,8753)
[0] 4318 <- (0,8754)
[0] 4319 <- (0,8755)
[0] 4320 <- (0,8756)
[0] 4321 <- (0,8757)
[0] 4322 <- (0,8758)
[0] 4323 <- (0,8759)
[0] 4324 <- (0,8760)
[0] 4325 <- (0,8761)
[0] 4326 <- (0,8762)
[0] 4327 <- (0,8763)
[0] 4328 <- (0,8764)
[0] 4329 <- (0,8765)
[0] 4330 <- (0,8766)
[0] 4331 <- (0,8767)
[0] 4332 <- (0,8768)
[0] 4333 <- (0,8769)
[0] 4334 <- (0,8770)
[0] 4335 <- (0,8771)
[0] 4336 <- (0,8772)
[0] 4337 <- (0,8773)
[0] 4338 <- (0,8774)
[0] 4339 <- (0,8775)
[0] 4340 <- (0,8776)
[0] 4341 <- (0,8800)
[0] 4342 <- (0,8801)
[0] 4343 <- (0,8802)
[0] 4344 <- (0,8803)
[0] 4345 <- (0,8804)
[0] 4346 <- (0,8805)
[0] 4347 <- (0,8806)
[0] 4348 <- (0,8807)
[0] 4349 <- (0,8808)
[0] 4350 <- (0,8809)
[0] 4351 <- (0,8810)
[0] 4352 <- (0,8811)
[0] 4353 <- (0,8812)
[0] 4354 <- (0,8813)
[0] 4355 <- (0,8814)
[0] 4356 <- (0,8815)
[0] 4357 <- (0,8816)
[0] 4358 <- (0,8817)
[0] 4359 <- (0,8818)
[0] 4360 <- (0,8819)
[0] 4361 <- (0,8820)
[0] 4362 <- (0,8821)
[0] 4363 <- (0,8822)
[0] 4364 <- (0,8823)
[0] 4365 <- (0,8824)
[0] 4366 <- (0,8825)
[0] 4367 <- (0,8826)
[0] 4368 <- (0,8850)
[0] 4369 <- (0,8851)
[0] 4370 <- (0,8852)
[0] 4371 <- (0,8853)
[0] 4372 <- (0,8854)
[0] 4373 <- (0,8855)
[0] 4374 <- (0,8856)
[0] 4375 <- (0,8857)
[0] 4376 <- (0,8858)
[0] 4377 <- (0,8859)
[0] 4378 <- (0,8860)
[0] 4379 <- (0,8861)
[0] 4380 <- (0,8862)
[0] 4381 <- (0,8863)
[0] 4382 <- (0,8864)
[0] 4383 <- (0,8865)
[0] 4384 <- (0,8866)
[0] 4385 <- (0,8867)
[0] 4386 <- (0,8868)
[0] 4387 <- (0,8869)
[0] 4388 <- (0,8870)
[0] 4389 <- (0,8871)
[0] 4390 <- (0,8872)
[0] 4391 <- (0,8873)
[0] 4392 <- (0,8874)
[0] 4393 <- (0,8875)
[0] 4394 <- (0,8876)
[0] 4395 <- (0,8900)
[0] 4396 <- (0,8901)
[0] 4397 <- (0,8902)
[0] 4398 <- (0,8903)
[0] 4399 <- (0,8904)
[0] 4400 <- (0,8905)
[0] 4401 <- (0,8906)
[0] 4402 <- (0,8907)
[0] 4403 <- (0,8908)
[0] 4404 <- (0,8909)
[0] 4405 <- (0,8910)
[0] 4406 <- (0,8911)
[0] 4407 <- (0,8912)
[0] 4408 <- (0,8913)
[0] 4409 <- (0,8914)
[0] 4410 <- (0,8915)
[0] 4411 <- (0,8916)
[0] 4412 <- (0,8917)
[0] 4413 <- (0,8918)
[0] 4414 <- (0,8919)
[0] 4415 <- (0,8920)
[0] 4416 <- (0,8921)
[0] 4417 <- (0,8922)
[0] 4418 <- (0,8923)
[0] 4419 <- (0,8924)
[0] 4420 <- (0,8925)
[0] 4421 <- (0,8926)
[0] 4422 <- (0,8950)
[0] 4423 <- (0,8951)
[0] 4424 <- (0,8952)
[0] 4425 <- (0,8953)
[0] 4426 <- (0,8954)
[0] 4427 <- (0,8955)
[0] 4428 <- (0,8956)
[0] 4429 <- (0,8957)
[0] 4430 <- (0,8958)
[0] 4431 <- (0,8959)
[0] 4432 <- (0,8960)
[0] 4433 <- (0,8961)
[0] 4434 <- (0,8962)
[0] 4435 <- (0,8963)
[0] 4436 <- (0,8964)
[0] 4437 <- (0,8965)
[0] 4438 <- (0,8966)
[0] 4439 <- (0,8967)
[0] 4440 <- (0,8968)
[0] 4441 <- (0,8969)
[0] 4442 <- (0,8970)
[0] 4443 <- (0,8971)
[0] 4444 <- (0,8972)
[0] 4445 <- (0,8973)
[0] 4446 <- (0,8974)
[0] 4447 <- (0,8975)
[0] 4448 <- (0,8976)
[0] 4449 <- (0,9000)
[0] 4450 <- (0,9001)
[0] 4451 <- (0,9002)
[0] 4452 <- (0,9003)
[0] 4453 <- (0,9004)
[0] 4454 <- (0,9005)
[0] 4455 <- (0,9006)
[0] 4456 <- (0,9007)
[0] 4457 <- (0,9008)
[0] 4458 <- (0,9009)
[0] 4459 <- (0,9010)
[0] 4460 <- (0,9011)
[0] 4461 <- (0,9012)
[0] 4462 <- (0,9013)
[0] 4463 <- (0,9014)
[0] 4464 <- (0,9015)
[0] 4465 <- (0,9016)
[0] 4466 <- (0,9017)
[0] 4467 <- (0,9018)
[0] 4468 <- (0,9019)
[0] 4469 <- (0,9020)
[0] 4470 <- (0,9021)
[0] 4471 <- (0,9050)
[0] 4472 <- (0,9051)
[0] 4473 <- (0,9052)
[0] 4474 <- (0,9053)
[0] 4475 <- (0,9054)
[0] 4476 <- (0,9055)
[0] 4477 <- (0,9056)
[0] 4478 <- (0,9057)
[0] 4479 <- (0,9058)
[0] 4480 <- (0,9059)
[0] 4481 <- (0,9060)
[0] 4482 <- (0,9061)
[0] 4483 <- (0,9062)
[0] 4484 <- (0,9063)
[0] 4485 <- (0,9064)
[0] 4486 <- (0,9065)
[0] 4487 <- (0,9066)
[0] 4488 <- (0,9067)
[0] 4489 <- (0,9068)
[0] 4490 <- (0,9069)
[0] 4491 <- (0,9070)
[0] 4492 <- (0,9071)
[0] 4493 <- (0,9100)
[0] 4494 <- (0,9101)
[0] 4495 <- (0,9102)
[0] 4496 <- (0,9103)
[0] 4497 <- (0,9104)
[0] 4498 <- (0,9105)
[0] 4499 <- (0,9106)
[0] 4500 <- (0,9107)
[0] 4501 <- (0,9108)
[0] 4502 <- (0,9109)
[0] 4503 <- (0,9110)
[0] 4504 <- (0,9111)
[0] 4505 <- (0,9112)
[0] 4506 <- (0,9113)
[0] 4507 <- (0,9114)
[0] 4508 <- (0,9115)
[0] 4509 <- (0,9116)
[0] 4510 <- (0,9117)
[0] 4511 <- (0,9118)
[0] 4512 <- (0,9119)
[0] 4513 <- (0,9120)
[0] 4514 <- (0,9121)
[0] 4515 <- (0,9150)
[0] 4516 <- (0,9151)
[0] 4517 <- (0,9152)
[0] 4518 <- (0,9153)
[0] 4519 <- (0,9154)
[0] 4520 <- (0,9155)
[0] 4521 <- (0,9156)
[0] 4522 <- (0,9157)
[0] 4523 <- (0,9158)
[0] 4524 <- (0,9159)
[0] 4525 <- (0,9160)
[0] 4526 <- (0,9161)
[0] 4527 <- (0,9162)
[0] 4528 <- (0,9163)
[0] 4529 <- (0,9164)
[0] 4530 <- (0,9165)
[0] 4531 <- (0,9166)
[0] 4532 <- (0,9167)
[0] 4533 <- (0,9168)
[0] 4534 <- (0,9169)
[0] 4535 <- (0,9170)
[0] 4536 <- (0,9171)
[0] 4537 <- (0,9200)
[0] 4538 <- (0,9201)
[0] 4539 <- (0,9202)
[0] 4540 <- (0,9203)
[0] 4541 <- (0,9204)
[0] 4542 <- (0,9205)
[0] 4543 <- (0,9206)
[0] 4544 <- (0,9207)
[0] 4545 <- (0,9208)
[0] 4546 <- (0,9209)
[0] 4547 <- (0,9210)
[0] 4548 <- (0,9211)
[0] 4549 <- (0,9212)
[0] 4550 <- (0,9213)
[0] 4551 <- (0,9214)
[0] 4552 <- (0,9215)
[0] 4553 <- (0,9216)
[0] 4554 <- (0,9217)
[0] 4555 <- (0,9218)
[0] 4556 <- (0,9219)
[0] 4557 <- (0,9220)
[0] 4558 <- (0,9221)
[0] 4559 <- (0,9222)
[0] 4560 <- (0,9250)
[0] 4561 <- (0,9251)
[0] 4562 <- (0,9252)
[0] 4563 <- (0,9253)
[0] 4564 <- (0,9254)
[0] 4565 <- (0,9255)
[0] 4566 <- (0,9256)
[0] 4567 <- (0,9257)
[0] 4568 <- (0,9258)
[0] 4569 <- (0,9259)
[0] 4570 <- (0,9260)
[0] 4571 <- (0,9261)
[0] 4572 <- (0,9262)
[0] 4573 <- (0,9263)
[0] 4574 <- (0,9264)
[0] 4575 <- (0,9265)
[0] 4576 <- (0,9266)
[0] 4577 <- (0,9267)
[0] 4578 <- (0,9268)
[0] 4579 <- (0,9269)
[0] 4580 <- (0,9270)
[0] 4581 <- (0,9271)
[0] 4582 <- (0,9272)
[0] 4583 <- (0,9300)
[0] 4584 <- (0,9301)
[0] 4585 <- (0,9302)
[0] 4586 <- (0,9303)
[0] 4587 <- (0,9304)
[0] 4588 <- (0,9305)
[0] 4589 <- (0,9306)
[0] 4590 <- (0,9307)
[0] 4591 <- (0,9308)
[0] 4592 <- (0,9309)
[0] 4593 <- (0,9310)
[0] 4594 <- (0,9311)
[0] 4595 <- (0,9312)
[0] 4596 <- (0,9313)
[0] 4597 <- (0,9314)
[0] 4598 <- (0,9315)
[0] 4599 <- (0,9316)
[0] 4600 <- (0,9317)
[0] 4601 <- (0,9318)
[0] 4602 <- (0,9319)
[0] 4603 <- (0,9320)
[0] 4604 <- (0,9321)
[0] 4605 <- (0,9322)
[0] 4606 <- (0,9350)
[0] 4607 <- (0,9351)
[0] 4608 <- (0,9352)
[0] 4609 <- (0,9353)
[0] 4610 <- (0,9354)
[0] 4611 <- (0,9355)
[0] 4612 <- (0,9356)
[0] 4613 <- (0,9357)
[0] 4614 <- (0,9358)
[0] 4615 <- (0,9359)
[0] 4616 <- (0,9360)
[0] 4617 <- (0,9361)
[0] 4618 <- (0,9362)
[0] 4619 <- (0,9363)
[0] 4620 <- (0,9364)
[0] 4621 <- (0,9365)
[0] 4622 <- (0,9366)
[0] 4623 <- (0,9367)
[0] 4624 <- (0,9368)
[0] 4625 <- (0,9369)
[0] 4626 <- (0,9370)
[0] 4627 <- (0,9371)
[0] 4628 <- (0,9372)
[0] 4629 <- (0,9400)
[0] 4630 <- (0,9401)
[0] 4631 <- (0,9402)
[0] 4632 <- (0,9403)
[0] 4633 <- (0,9404)
[0] 4634 <- (0,9405)
[0] 4635 <- (0,9406)
[0] 4636 <- (0,9407)
[0] 4637 <- (0,9408)
[0] 4638 <- (0,9409)
[0] 4639 <- (0,9410)
[0] 4640 <- (0,9411)
[0] 4641 <- (0,9412)
[0] 4642 <- (0,9413)
[0] 4643 <- (0,9414)
[0] 4644 <- (0,9415)
[0] 4645 <- (0,9416)
[0] 4646 <- (0,9417)
[0] 4647 <- (0,9418)
[0] 4648 <- (0,9419)
[0] 4649 <- (0,9420)
[0] 4650 <- (0,9421)
[0] 4651 <- (0,9422)
[0] 4652 <- (0,9423)
[0] 4653 <- (0,9450)
[0] 4654 <- (0,9451)
[0] 4655 <- (0,9452)
[0] 4656 <- (0,9453)
[0] 4657 <- (0,9454)
[0] 4658 <- (0,9455)
[0] 4659 <- (0,9456)
[0] 4660 <- (0,9457)
[0] 4661 <- (0,9458)
[0] 4662 <- (0,9459)
[0] 4663 <- (0,9460)
[0] 4664 <- (0,9461)
[0] 4665 <- (0,9462)
[0] 4666 <- (0,9463)
[0] 4667 <- (0,9464)
[0] 4668 <- (0,9465)
[0] 4669 <- (0,9466)
[0] 4670 <- (0,9467)
[0] 4671 <- (0,9468)
[0] 4672 <- (0,9469)
[0] 4673 <- (0,9470)
[0] 4674 <- (0,9471)
[0] 4675 <- (0,9472)
[0] 4676 <- (0,9473)
[0] 4677 <- (0,9474)
[0] 4678 <- (0,9500)
[0] 4679 <- (0,9501)
[0] 4680 <- (0,9502)
[0] 4681 <- (0,9503)
[0] 4682 <- (0,9504)
[0] 4683 <- (0,9505)
[0] 4684 <- (0,9506)
[0] 4685 <- (0,9507)
[0] 4686 <- (0,9508)
[0] 4687 <- (0,9509)
[0] 4688 <- (0,9510)
[0] 4689 <- (0,9511)
[0] 4690 <- (0,9512)
[0] 4691 <- (0,9513)
[0] 4692 <- (0,9514)
[0] 4693 <- (0,9515)
[0] 4694 <- (0,9516)
[0] 4695 <- (0,9517)
[0] 4696 <- (0,9518)
[0] 4697 <- (0,9519)
[0] 4698 <- (0,9520)
[0] 4699 <- (0,9521)
[0] 4700 <- (0,9522)
[0] 4701 <- (0,9523)
[0] 4702 <- (0,9524)
[0] 4703 <- (0,9550)
[0] 4704 <- (0,9551)
[0] 4705 <- (0,9552)
[0] 4706 <- (0,9553)
[0] 4707 <- (0,9554)
[0] 4708 <- (0,9555)
[0] 4709 <- (0,9556)
[0] 4710 <- (0,9557)
[0] 4711 <- (0,9558)
[0] 4712 <- (0,9559)
[0] 4713 <- (0,9560)
[0] 4714 <- (0,9561)
[0] 4715 <- (0,9562)
[0] 4716 <- (0,9563)
[0] 4717 <- (0,9564)
[0] 4718 <- (0,9565)
[0] 4719 <- (0,9566)
[0] 4720 <- (0,9567)
[0] 4721 <- (0,9568)
[0] 4722 <- (0,9569)
[0] 4723 <- (0,9570)
[0] 4724 <- (0,9571)
[0] 4725 <- (0,9572)
[0] 4726 <- (0,9573)
[0] 4727 <- (0,9574)
[0] 4728 <- (0,9575)
[0] 4729 <- (0,9600)
[0] 4730 <- (0,9601)
[0] 4731 <- (0,9602)
[0] 4732 <- (0,9603)
[0] 4733 <- (0,9604)
[0] 4734 <- (0,9605)
[0] 4735 <- (0,9606)
[0] 4736 <- (0,9607)
[0] 4737 <- (0,9608)
[0] 4738 <- (0,9609)
[0] 4739 <- (0,9610)
[0] 4740 <- (0,9611)
[0] 4741 <- (0,9612)
[0] 4742 <- (0,9613)
[0] 4743 <- (0,9614)
[0] 4744 <- (0,9615)
[0] 4745 <- (0,9616)
[0] 4746 <- (0,9617)
[0] 4747 <- (0,9618)
[0] 4748 <- (0,9619)
[0] 4749 <- (0,9620)
[0] 4750 <- (0,9621)
[0] 4751 <- (0,9622)
[0] 4752 <- (0,9623)
[0] 4753 <- (0,9624)
[0] 4754 <- (0,9625)
[0] 4755 <- (0,9650)
[0] 4756 <- (0,9651)
[0] 4757 <- (0,9652)
[0] 4758 <- (0,9653)
[0] 4759 <- (0,9654)
[0] 4760 <- (0,9655)
[0] 4761 <- (0,9656)
[0] 4762 <- (0,9657)
[0] 4763 <- (0,9658)
[0] 4764 <- (0,9659)
[0] 4765 <- (0,9660)
[0] 4766 <- (0,9661)
[0] 4767 <- (0,9662)
[0] 4768 <- (0,9663)
[0] 4769 <- (0,9664)
[0] 4770 <- (0,9665)
[0] 4771 <- (0,9666)
[0] 4772 <- (0,9667)
[0] 4773 <- (0,9668)
[0] 4774 <- (0,9669)
[0] 4775 <- (0,9670)
[0] 4776 <- (0,9671)
[0] 4777 <- (0,9672)
[0] 4778 <- (0,9673)
[0] 4779 <- (0,9674)
[0] 4780 <- (0,9675)
[0] 4781 <- (0,9676)
[0] 4782 <- (0,9700)
[0] 4783 <- (0,9701)
[0] 4784 <- (0,9702)
[0] 4785 <- (0,9703)
[0] 4786 <- (0,9704)
[0] 4787 <- (0,9705)
[0] 4788 <- (0,9706)
[0] 4789 <- (0,9707)
[0] 4790 <- (0,9708)
[0] 4791 <- (0,9709)
[0] 4792 <- (0,9710)
[0] 4793 <- (0,9711)
[0] 4794 <- (0,9712)
[0] 4795 <- (0,9713)
[0] 4796 <- (0,9714)
[0] 4797 <- (0,9715)
[0] 4798 <- (0,9716)
[0] 4799 <- (0,9717)
[0] 4800 <- (0,9718)
[0] 4801 <- (0,9719)
[0] 4802 <- (0,9720)
[0] 4803 <- (0,9721)
[0] 4804 <- (0,9722)
[0] 4805 <- (0,9723)
[0] 4806 <- (0,9724)
[0] 4807 <- (0,9725)
[0] 4808 <- (0,9726)
[0] 4809 <- (0,9750)
[0] 4810 <- (0,9751)
[0] 4811 <- (0,9752)
[0] 4812 <- (0,9753)
[0] 4813 <- (0,9754)
[0] 4814 <- (0,9755)
[0] 4815 <- (0,9756)
[0] 4816 <- (0,9757)
[0] 4817 <- (0,9758)
[0] 4818 <- (0,9759)
[0] 4819 <- (0,9760)
[0] 4820 <- (0,9761)
[0] 4821 <- (0,9762)
[0] 4822 <- (0,9763)
[0] 4823 <- (0,9764)
[0] 4824 <- (0,9765)
[0] 4825 <- (0,9766)
[0] 4826 <- (0,9767)
[0] 4827 <- (0,9768)
[0] 4828 <- (0,9769)
[0] 4829 <- (0,9770)
[0] 4830 <- (0,9771)
[0] 4831 <- (0,9772)
[0] 4832 <- (0,9773)
[0] 4833 <- (0,9774)
[0] 4834 <- (0,9775)
[0] 4835 <- (0,9776)
[0] 4836 <- (0,9800)
[0] 4837 <- (0,9801)
[0] 4838 <- (0,9802)
[0] 4839 <- (0,9803)
[0] 4840 <- (0,9804)
[0] 4841 <- (0,9805)
[0] 4842 <- (0,9806)
[0] 4843 <- (0,9807)
[0] 4844 <- (0,9808)
[0] 4845 <- (0,9809)
[0] 4846 <- (0,9810)
[0] 4847 <- (0,9811)
[0] 4848 <- (0,9812)
[0] 4849 <- (0,9813)
[0] 4850 <- (0,9814)
[0] 4851 <- (0,9815)
[0] 4852 <- (0,9816)
[0] 4853 <- (0,9817)
[0] 4854 <- (0,9818)
[0] 4855 <- (0,9819)
[0] 4856 <- (0,9820)
[0] 4857 <- (0,9821)
[0] 4858 <- (0,9822)
[0] 4859 <- (0,9823)
[0] 4860 <- (0,9824)
[0] 4861 <- (0,9825)
[0] 4862 <- (0,9826)
[0] 4863 <- (0,9850)
[0] 4864 <- (0,9851)
[0] 4865 <- (0,9852)
[0] 4866 <- (0,9853)
[0] 4867 <- (0,9854)
[0] 4868 <- (0,9855)
[0] 4869 <- (0,9856)
[0] 4870 <- (0,9857)
[0] 4871 <- (0,9858)
[0] 4872 <- (0,9859)
[0] 4873 <- (0,9860)
[0] 4874 <- (0,9861)
[0] 4875 <- (0,9862)
[0] 4876 <- (0,9863)
[0] 4877 <- (0,9864)
[0] 4878 <- (0,9865)
[0] 4879 <- (0,9866)
[0] 4880 <- (0,9867)
[0] 4881 <- (0,9868)
[0] 4882 <- (0,9869)
[0] 4883 <- (0,9870)
[0] 4884 <- (0,9871)
[0] 4885 <- (0,9872)
[0] 4886 <- (0,9873)
[0] 4887 <- (0,9874)
[0] 4888 <- (0,9875)
[0] 4889 <- (0,9876)
[0] 4890 <- (0,9900)
[0] 4891 <- (0,9901)
[0] 4892 <- (0,9902)
[0] 4893 <- (0,9903)
[0] 4894 <- (0,9904)
[0] 4895 <- (0,9905)
[0] 4896 <- (0,9906)
[0] 4897 <- (0,9907)
[0] 4898 <- (0,9908)
[0] 4899 <- (0,9909)
[0] 4900 <- (0,9910)
[0] 4901 <- (0,9911)
[0] 4902 <- (0,9912)
[0] 4903 <- (0,9913)
[0] 4904 <- (0,9914)
[0] 4905 <- (0,9915)
[0] 4906 <- (0,9916)
[0] 4907 <- (0,9917)
[0] 4908 <- (0,9918)
[0] 4909 <- (0,9919)
[0] 4910 <- (0,9920)
[0] 4911 <- (0,9921)
[0] 4912 <- (0,9922)
[0] 4913 <- (0,9923)
[0] 4914 <- (0,9924)
[0] 4915 <- (0,9925)
[0] 4916 <- (0,9926)
[0] 4917 <- (0,9950)
[0] 4918 <- (0,9951)
[0] 4919 <- (0,9952)
[0] 4920 <- (0,9953)
[0] 4921 <- (0,9954)
[0] 4922 <- (0,9955)
[0] 4923 <- (0,9956)
[0] 4924 <- (0,9957)
[0] 4925 <- (0,9958)
[0] 4926 <- (0,9959)
[0] 4927 <- (0,9960)
[0] 4928 <- (0,9961)
[0] 4929 <- (0,9962)
[0] 4930 <- (0,9963)
[0] 4931 <- (0,9964)
[0] 4932 <- (0,9965)
[0] 4933 <- (0,9966)
[0] 4934 <- (0,9967)
[0] 4935 <- (0,9968)
[0] 4936 <- (0,9969)
[0] 4937 <- (0,9970)
[0] 4938 <- (0,9971)
[0] 4939 <- (0,9972)
[0] 4940 <- (0,9973)
[0] 4941 <- (0,9974)
[0] 4942 <- (0,9975)
[0] 4943 <- (0,9976)
[0] 4944 <- (0,22)
[0] 4945 <- (0,72)
[0] 4946 <- (0,122)
[0] 4947 <- (0,172)
[0] 4948 <- (0,173)
[0] 4949 <- (0,223)
[0] 4950 <- (0,273)
[0] 4951 <- (0,323)
[0] 4952 <- (0,373)
[0] 4953 <- (0,374)
[0] 4954 <- (0,424)
[0] 4955 <- (0,474)
[0] 4956 <- (0,475)
[0] 4957 <- (0,525)
[0] 4958 <- (0,526)
[0] 4959 <- (0,576)
[0] 4960 <- (0,626)
[0] 4961 <- (0,627)
[0] 4962 <- (0,677)
[0] 4963 <- (0,727)
[0] 4964 <- (0,777)
[0] 4965 <- (0,827)
[0] 4966 <- (0,877)
[0] 4967 <- (0,927)
[0] 4968 <- (0,977)
[0] 4969 <- (0,1022)
[0] 4970 <- (0,1072)
[0] 4971 <- (0,1122)
[0] 4972 <- (0,1172)
[0] 4973 <- (0,1173)
[0] 4974 <- (0,1223)
[0] 4975 <- (0,1273)
[0] 4976 <- (0,1323)
[0] 4977 <- (0,1373)
[0] 4978 <- (0,1374)
[0] 4979 <- (0,1424)
[0] 4980 <- (0,1474)
[0] 4981 <- (0,1475)
[0] 4982 <- (0,1525)
[0] 4983 <- (0,1526)
[0] 4984 <- (0,1576)
[0] 4985 <- (0,1626)
[0] 4986 <- (0,1627)
[0] 4987 <- (0,1677)
[0] 4988 <- (0,1727)
[0] 4989 <- (0,1777)
[0] 4990 <- (0,1827)
[0] 4991 <- (0,1877)
[0] 4992 <- (0,1927)
[0] 4993 <- (0,1977)
[0] 4994 <- (0,2022)
[0] 4995 <- (0,2072)
[0] 4996 <- (0,2122)
[0] 4997 <- (0,2172)
[0] 4998 <- (0,2173)
[0] 4999 <- (0,2223)
[0] 5000 <- (0,2273)
[0] 5001 <- (0,2323)
[0] 5002 <- (0,2373)
[0] 5003 <- (0,2374)
[0] 5004 <- (0,2424)
[0] 5005 <- (0,2474)
[0] 5006 <- (0,2475)
[0] 5007 <- (0,2525)
[0] 5008 <- (0,2526)
[0] 5009 <- (0,2576)
[0] 5010 <- (0,2626)
[0] 5011 <- (0,2627)
[0] 5012 <- (0,2677)
[0] 5013 <- (0,2727)
[0] 5014 <- (0,2777)
[0] 5015 <- (0,2827)
[0] 5016 <- (0,2877)
[0] 5017 <- (0,2927)
[0] 5018 <- (0,2977)
[0] 5019 <- (0,3022)
[0] 5020 <- (0,3072)
[0] 5021 <- (0,3122)
[0] 5022 <- (0,3172)
[0] 5023 <- (0,3173)
[0] 5024 <- (0,3223)
[0] 5025 <- (0,3273)
[0] 5026 <- (0,3323)
[0] 5027 <- (0,3373)
[0] 5028 <- (0,3374)
[0] 5029 <- (0,3424)
[0] 5030 <- (0,3474)
[0] 5031 <- (0,3475)
[0] 5032 <- (0,3525)
[0] 5033 <- (0,3526)
[0] 5034 <- (0,3576)
[0] 5035 <- (0,3626)
[0] 5036 <- (0,3627)
[0] 5037 <- (0,3677)
[0] 5038 <- (0,3727)
[0] 5039 <- (0,3777)
[0] 5040 <- (0,3827)
[0] 5041 <- (0,3877)
[0] 5042 <- (0,3927)
[0] 5043 <- (0,3977)
[0] 5044 <- (0,4022)
[0] 5045 <- (0,4072)
[0] 5046 <- (0,4122)
[0] 5047 <- (0,4172)
[0] 5048 <- (0,4173)
[0] 5049 <- (0,4223)
[0] 5050 <- (0,4273)
[0] 5051 <- (0,4323)
[0] 5052 <- (0,4373)
[0] 5053 <- (0,4374)
[0] 5054 <- (0,4424)
[0] 5055 <- (0,4474)
[0] 5056 <- (0,4475)
[0] 5057 <- (0,4525)
[0] 5058 <- (0,4526)
[0] 5059 <- (0,4576)
[0] 5060 <- (0,4626)
[0] 5061 <- (0,4627)
[0] 5062 <- (0,4677)
[0] 5063 <- (0,4727)
[0] 5064 <- (0,4777)
[0] 5065 <- (0,4827)
[0] 5066 <- (0,4877)
[0] 5067 <- (0,4927)
[0] 5068 <- (0,4977)
[0] 5069 <- (0,5022)
[0] 5070 <- (0,5072)
[0] 5071 <- (0,5122)
[0] 5072 <- (0,5172)
[0] 5073 <- (0,5173)
[0] 5074 <- (0,5223)
[0] 5075 <- (0,5273)
[0] 5076 <- (0,5323)
[0] 5077 <- (0,5373)
[0] 5078 <- (0,5374)
[0] 5079 <- (0,5424)
[0] 5080 <- (0,5425)
[0] 5081 <- (0,5474)
[0] 5082 <- (0,5475)
[0] 5083 <- (0,5525)
[0] 5084 <- (0,5526)
[0] 5085 <- (0,5576)
[0] 5086 <- (0,5626)
[0] 5087 <- (0,5627)
[0] 5088 <- (0,5677)
[0] 5089 <- (0,5727)
[0] 5090 <- (0,5777)
[0] 5091 <- (0,5827)
[0] 5092 <- (0,5877)
[0] 5093 <- (0,5927)
[0] 5094 <- (0,5977)
[0] 5095 <- (0,6022)
[0] 5096 <- (0,6072)
[0] 5097 <- (0,6122)
[0] 5098 <- (0,6172)
[0] 5099 <- (0,6173)
[0] 5100 <- (0,6223)
[0] 5101 <- (0,6273)
[0] 5102 <- (0,6323)
[0] 5103 <- (0,6373)
[0] 5104 <- (0,6374)
[0] 5105 <- (0,6424)
[0] 5106 <- (0,6425)
[0] 5107 <- (0,6475)
[0] 5108 <- (0,6525)
[0] 5109 <- (0,6526)
[0] 5110 <- (0,6576)
[0] 5111 <- (0,6626)
[0] 5112 <- (0,6627)
[0] 5113 <- (0,6677)
[0] 5114 <- (0,6727)
[0] 5115 <- (0,6777)
[0] 5116 <- (0,6827)
[0] 5117 <- (0,6877)
[0] 5118 <- (0,6927)
[0] 5119 <- (0,6977)
[0] 5120 <- (0,7022)
[0] 5121 <- (0,7072)
[0] 5122 <- (0,7122)
[0] 5123 <- (0,7172)
[0] 5124 <- (0,7173)
[0] 5125 <- (0,7223)
[0] 5126 <- (0,7273)
[0] 5127 <- (0,7323)
[0] 5128 <- (0,7373)
[0] 5129 <- (0,7374)
[0] 5130 <- (0,7424)
[0] 5131 <- (0,7425)
[0] 5132 <- (0,7475)
[0] 5133 <- (0,7525)
[0] 5134 <- (0,7526)
[0] 5135 <- (0,7576)
[0] 5136 <- (0,7626)
[0] 5137 <- (0,7627)
[0] 5138 <- (0,7677)
[0] 5139 <- (0,7727)
[0] 5140 <- (0,7777)
[0] 5141 <- (0,7827)
[0] 5142 <- (0,7877)
[0] 5143 <- (0,7927)
[0] 5144 <- (0,7977)
[0] 5145 <- (0,8022)
[0] 5146 <- (0,8072)
[0] 5147 <- (0,8122)
[0] 5148 <- (0,8172)
[0] 5149 <- (0,8173)
[0] 5150 <- (0,8223)
[0] 5151 <- (0,8273)
[0] 5152 <- (0,8323)
[0] 5153 <- (0,8373)
[0] 5154 <- (0,8374)
[0] 5155 <- (0,8424)
[0] 5156 <- (0,8425)
[0] 5157 <- (0,8475)
[0] 5158 <- (0,8525)
[0] 5159 <- (0,8526)
[0] 5160 <- (0,8576)
[0] 5161 <- (0,8626)
[0] 5162 <- (0,8627)
[0] 5163 <- (0,8677)
[0] 5164 <- (0,8727)
[0] 5165 <- (0,8777)
[0] 5166 <- (0,8827)
[0] 5167 <- (0,8877)
[0] 5168 <- (0,8927)
[0] 5169 <- (0,8977)
[0] 5170 <- (0,9022)
[0] 5171 <- (0,9072)
[0] 5172 <- (0,9122)
[0] 5173 <- (0,9172)
[0] 5174 <- (0,9173)
[0] 5175 <- (0,9223)
[0] 5176 <- (0,9273)
[0] 5177 <- (0,9323)
[0] 5178 <- (0,9373)
[0] 5179 <- (0,9374)
[0] 5180 <- (0,9424)
[0] 5181 <- (0,9425)
[0] 5182 <- (0,9475)
[0] 5183 <- (0,9525)
[0] 5184 <- (0,9526)
[0] 5185 <- (0,9576)
[0] 5186 <- (0,9626)
[0] 5187 <- (0,9627)
[0] 5188 <- (0,9677)
[0] 5189 <- (0,9727)
[0] 5190 <- (0,9777)
[0] 5191 <- (0,9827)
[0] 5192 <- (0,9877)
[0] 5193 <- (0,9927)
[0] 5194 <- (0,9977)
[0] 5195 <- (0,10000)
[0] 5196 <- (0,10001)
[0] 5197 <- (0,10002)
[0] 5198 <- (0,10003)
[0] 5199 <- (0,10004)
[0] 5200 <- (0,10005)
[0] 5201 <- (0,10006)
[0] 5202 <- (0,10007)
[0] 5203 <- (0,10008)
[0] 5204 <- (0,10009)
[0] 5205 <- (0,10010)
[0] 5206 <- (0,10011)
[0] 5207 <- (0,10012)
[0] 5208 <- (0,10013)
[0] 5209 <- (0,10014)
[0] 5210 <- (0,10015)
[0] 5211 <- (0,10016)
[0] 5212 <- (0,10017)
[0] 5213 <- (0,10018)
[0] 5214 <- (0,10019)
[0] 5215 <- (0,10020)
[0] 5216 <- (0,10021)
[0] 5217 <- (0,10051)
[0] 5218 <- (0,10052)
[0] 5219 <- (0,10053)
[0] 5220 <- (0,10054)
[0] 5221 <- (0,10055)
[0] 5222 <- (0,10056)
[0] 5223 <- (0,10057)
[0] 5224 <- (0,10058)
[0] 5225 <- (0,10059)
[0] 5226 <- (0,10060)
[0] 5227 <- (0,10061)
[0] 5228 <- (0,10062)
[0] 5229 <- (0,10063)
[0] 5230 <- (0,10064)
[0] 5231 <- (0,10065)
[0] 5232 <- (0,10066)
[0] 5233 <- (0,10067)
[0] 5234 <- (0,10068)
[0] 5235 <- (0,10069)
[0] 5236 <- (0,10070)
[0] 5237 <- (0,10071)
[0] 5238 <- (0,10072)
[0] 5239 <- (0,10102)
[0] 5240 <- (0,10103)
[0] 5241 <- (0,10104)
[0] 5242 <- (0,10105)
[0] 5243 <- (0,10106)
[0] 5244 <- (0,10107)
[0] 5245 <- (0,10108)
[0] 5246 <- (0,10109)
[0] 5247 <- (0,10110)
[0] 5248 <- (0,10111)
[0] 5249 <- (0,10112)
[0] 5250 <- (0,10113)
[0] 5251 <- (0,10114)
[0] 5252 <- (0,10115)
[0] 5253 <- (0,10116)
[0] 5254 <- (0,10117)
[0] 5255 <- (0,10118)
[0] 5256 <- (0,10119)
[0] 5257 <- (0,10120)
[0] 5258 <- (0,10121)
[0] 5259 <- (0,10122)
[0] 5260 <- (0,10123)
[0] 5261 <- (0,10153)
[0] 5262 <- (0,10154)
[0] 5263 <- (0,10155)
[0] 5264 <- (0,10156)
[0] 5265 <- (0,10157)
[0] 5266 <- (0,10158)
[0] 5267 <- (0,10159)
[0] 5268 <- (0,10160)
[0] 5269 <- (0,10161)
[0] 5270 <- (0,10162)
[0] 5271 <- (0,10163)
[0] 5272 <- (0,10164)
[0] 5273 <- (0,10165)
[0] 5274 <- (0,10166)
[0] 5275 <- (0,10167)
[0] 5276 <- (0,10168)
[0] 5277 <- (0,10169)
[0] 5278 <- (0,10170)
[0] 5279 <- (0,10171)
[0] 5280 <- (0,10172)
[0] 5281 <- (0,10173)
[0] 5282 <- (0,10174)
[0] 5283 <- (0,10204)
[0] 5284 <- (0,10205)
[0] 5285 <- (0,10206)
[0] 5286 <- (0,10207)
[0] 5287 <- (0,10208)
[0] 5288 <- (0,10209)
[0] 5289 <- (0,10210)
[0] 5290 <- (0,10211)
[0] 5291 <- (0,10212)
[0] 5292 <- (0,10213)
[0] 5293 <- (0,10214)
[0] 5294 <- (0,10215)
[0] 5295 <- (0,10216)
[0] 5296 <- (0,10217)
[0] 5297 <- (0,10218)
[0] 5298 <- (0,10219)
[0] 5299 <- (0,10220)
[0] 5300 <- (0,10221)
[0] 5301 <- (0,10222)
[0] 5302 <- (0,10223)
[0] 5303 <- (0,10224)
[0] 5304 <- (0,10225)
[0] 5305 <- (0,10255)
[0] 5306 <- (0,10256)
[0] 5307 <- (0,10257)
[0] 5308 <- (0,10258)
[0] 5309 <- (0,10259)
[0] 5310 <- (0,10260)
[0] 5311 <- (0,10261)
[0] 5312 <- (0,10262)
[0] 5313 <- (0,10263)
[0] 5314 <- (0,10264)
[0] 5315 <- (0,10265)
[0] 5316 <- (0,10266)
[0] 5317 <- (0,10267)
[0] 5318 <- (0,10268)
[0] 5319 <- (0,10269)
[0] 5320 <- (0,10270)
[0] 5321 <- (0,10271)
[0] 5322 <- (0,10272)
[0] 5323 <- (0,10273)
[0] 5324 <- (0,10274)
[0] 5325 <- (0,10275)
[0] 5326 <- (0,10276)
[0] 5327 <- (0,10277)
[0] 5328 <- (0,10306)
[0] 5329 <- (0,10307)
[0] 5330 <- (0,10308)
[0] 5331 <- (0,10309)
[0] 5332 <- (0,10310)
[0] 5333 <- (0,10311)
[0] 5334 <- (0,10312)
[0] 5335 <- (0,10313)
[0] 5336 <- (0,10314)
[0] 5337 <- (0,10315)
[0] 5338 <- (0,10316)
[0] 5339 <- (0,10317)
[0] 5340 <- (0,10318)
[0] 5341 <- (0,10319)
[0] 5342 <- (0,10320)
[0] 5343 <- (0,10321)
[0] 5344 <- (0,10322)
[0] 5345 <- (0,10323)
[0] 5346 <- (0,10324)
[0] 5347 <- (0,10325)
[0] 5348 <- (0,10326)
[0] 5349 <- (0,10327)
[0] 5350 <- (0,10328)
[0] 5351 <- (0,10357)
[0] 5352 <- (0,10358)
[0] 5353 <- (0,10359)
[0] 5354 <- (0,10360)
[0] 5355 <- (0,10361)
[0] 5356 <- (0,10362)
[0] 5357 <- (0,10363)
[0] 5358 <- (0,10364)
[0] 5359 <- (0,10365)
[0] 5360 <- (0,10366)
[0] 5361 <- (0,10367)
[0] 5362 <- (0,10368)
[0] 5363 <- (0,10369)
[0] 5364 <- (0,10370)
[0] 5365 <- (0,10371)
[0] 5366 <- (0,10372)
[0] 5367 <- (0,10373)
[0] 5368 <- (0,10374)
[0] 5369 <- (0,10375)
[0] 5370 <- (0,10376)
[0] 5371 <- (0,10377)
[0] 5372 <- (0,10378)
[0] 5373 <- (0,10379)
[0] 5374 <- (0,10408)
[0] 5375 <- (0,10409)
[0] 5376 <- (0,10410)
[0] 5377 <- (0,10411)
[0] 5378 <- (0,10412)
[0] 5379 <- (0,10413)
[0] 5380 <- (0,10414)
[0] 5381 <- (0,10415)
[0] 5382 <- (0,10416)
[0] 5383 <- (0,10417)
[0] 5384 <- (0,10418)
[0] 5385 <- (0,10419)
[0] 5386 <- (0,10420)
[0] 5387 <- (0,10421)
[0] 5388 <- (0,10422)
[0] 5389 <- (0,10423)
[0] 5390 <- (0,10424)
[0] 5391 <- (0,10425)
[0] 5392 <- (0,10426)
[0] 5393 <- (0,10427)
[0] 5394 <- (0,10428)
[0] 5395 <- (0,10429)
[0] 5396 <- (0,10430)
[0] 5397 <- (0,10459)
[0] 5398 <- (0,10460)
[0] 5399 <- (0,10461)
[0] 5400 <- (0,10462)
[0] 5401 <- (0,10463)
[0] 5402 <- (0,10464)
[0] 5403 <- (0,10465)
[0] 5404 <- (0,10466)
[0] 5405 <- (0,10467)
[0] 5406 <- (0,10468)
[0] 5407 <- (0,10469)
[0] 5408 <- (0,10470)
[0] 5409 <- (0,10471)
[0] 5410 <- (0,10472)
[0] 5411 <- (0,10473)
[0] 5412 <- (0,10474)
[0] 5413 <- (0,10475)
[0] 5414 <- (0,10476)
[0] 5415 <- (0,10477)
[0] 5416 <- (0,10478)
[0] 5417 <- (0,10479)
[0] 5418 <- (0,10480)
[0] 5419 <- (0,10481)
[0] 5420 <- (0,10482)
[0] 5421 <- (0,10510)
[0] 5422 <- (0,10511)
[0] 5423 <- (0,10512)
[0] 5424 <- (0,10513)
[0] 5425 <- (0,10514)
[0] 5426 <- (0,10515)
[0] 5427 <- (0,10516)
[0] 5428 <- (0,10517)
[0] 5429 <- (0,10518)
[0] 5430 <- (0,10519)
[0] 5431 <- (0,10520)
[0] 5432 <- (0,10521)
[0] 5433 <- (0,10522)
[0] 5434 <- (0,10523)
[0] 5435 <- (0,10524)
[0] 5436 <- (0,10525)
[0] 5437 <- (0,10526)
[0] 5438 <- (0,10527)
[0] 5439 <- (0,10528)
[0] 5440 <- (0,10529)
[0] 5441 <- (0,10530)
[0] 5442 <- (0,10531)
[0] 5443 <- (0,10532)
[0] 5444 <- (0,10533)
[0] 5445 <- (0,10561)
[0] 5446 <- (0,10562)
[0] 5447 <- (0,10563)
[0] 5448 <- (0,10564)
[0] 5449 <- (0,10565)
[0] 5450 <- (0,10566)
[0] 5451 <- (0,10567)
[0] 5452 <- (0,10568)
[0] 5453 <- (0,10569)
[0] 5454 <- (0,10570)
[0] 5455 <- (0,10571)
[0] 5456 <- (0,10572)
[0] 5457 <- (0,10573)
[0] 5458 <- (0,10574)
[0] 5459 <- (0,10575)
[0] 5460 <- (0,10576)
[0] 5461 <- (0,10577)
[0] 5462 <- (0,10578)
[0] 5463 <- (0,10579)
[0] 5464 <- (0,10580)
[0] 5465 <- (0,10581)
[0] 5466 <- (0,10582)
[0] 5467 <- (0,10583)
[0] 5468 <- (0,10584)
[0] 5469 <- (0,10585)
[0] 5470 <- (0,10612)
[0] 5471 <- (0,10613)
[0] 5472 <- (0,10614)
[0] 5473 <- (0,10615)
[0] 5474 <- (0,10616)
[0] 5475 <- (0,10617)
[0] 5476 <- (0,10618)
[0] 5477 <- (0,10619)
[0] 5478 <- (0,10620)
[0] 5479 <- (0,10621)
[0] 5480 <- (0,10622)
[0] 5481 <- (0,10623)
[0] 5482 <- (0,10624)
[0] 5483 <- (0,10625)
[0] 5484 <- (0,10626)
[0] 5485 <- (0,10627)
[0] 5486 <- (0,10628)
[0] 5487 <- (0,10629)
[0] 5488 <- (0,10630)
[0] 5489 <- (0,10631)
[0] 5490 <- (0,10632)
[0] 5491 <- (0,10633)
[0] 5492 <- (0,10634)
[0] 5493 <- (0,10635)
[0] 5494 <- (0,10636)
[0] 5495 <- (0,10637)
[0] 5496 <- (0,10663)
[0] 5497 <- (0,10664)
[0] 5498 <- (0,10665)
[0] 5499 <- (0,10666)
[0] 5500 <- (0,10667)
[0] 5501 <- (0,10668)
[0] 5502 <- (0,10669)
[0] 5503 <- (0,10670)
[0] 5504 <- (0,10671)
[0] 5505 <- (0,10672)
[0] 5506 <- (0,10673)
[0] 5507 <- (0,10674)
[0] 5508 <- (0,10675)
[0] 5509 <- (0,10676)
[0] 5510 <- (0,10677)
[0] 5511 <- (0,10678)
[0] 5512 <- (0,10679)
[0] 5513 <- (0,10680)
[0] 5514 <- (0,10681)
[0] 5515 <- (0,10682)
[0] 5516 <- (0,10683)
[0] 5517 <- (0,10684)
[0] 5518 <- (0,10685)
[0] 5519 <- (0,10686)
[0] 5520 <- (0,10687)
[0] 5521 <- (0,10688)
[0] 5522 <- (0,10714)
[0] 5523 <- (0,10715)
[0] 5524 <- (0,10716)
[0] 5525 <- (0,10717)
[0] 5526 <- (0,10718)
[0] 5527 <- (0,10719)
[0] 5528 <- (0,10720)
[0] 5529 <- (0,10721)
[0] 5530 <- (0,10722)
[0] 5531 <- (0,10723)
[0] 5532 <- (0,10724)
[0] 5533 <- (0,10725)
[0] 5534 <- (0,10726)
[0] 5535 <- (0,10727)
[0] 5536 <- (0,10728)
[0] 5537 <- (0,10729)
[0] 5538 <- (0,10730)
[0] 5539 <- (0,10731)
[0] 5540 <- (0,10732)
[0] 5541 <- (0,10733)
[0] 5542 <- (0,10734)
[0] 5543 <- (0,10735)
[0] 5544 <- (0,10736)
[0] 5545 <- (0,10737)
[0] 5546 <- (0,10738)
[0] 5547 <- (0,10739)
[0] 5548 <- (0,10740)
[0] 5549 <- (0,10765)
[0] 5550 <- (0,10766)
[0] 5551 <- (0,10767)
[0] 5552 <- (0,10768)
[0] 5553 <- (0,10769)
[0] 5554 <- (0,10770)
[0] 5555 <- (0,10771)
[0] 5556 <- (0,10772)
[0] 5557 <- (0,10773)
[0] 5558 <- (0,10774)
[0] 5559 <- (0,10775)
[0] 5560 <- (0,10776)
[0] 5561 <- (0,10777)
[0] 5562 <- (0,10778)
[0] 5563 <- (0,10779)
[0] 5564 <- (0,10780)
[0] 5565 <- (0,10781)
[0] 5566 <- (0,10782)
[0] 5567 <- (0,10783)
[0] 5568 <- (0,10784)
[0] 5569 <- (0,10785)
[0] 5570 <- (0,10786)
[0] 5571 <- (0,10787)
[0] 5572 <- (0,10788)
[0] 5573 <- (0,10789)
[0] 5574 <- (0,10790)
[0] 5575 <- (0,10791)
[0] 5576 <- (0,10816)
[0] 5577 <- (0,10817)
[0] 5578 <- (0,10818)
[0] 5579 <- (0,10819)
[0] 5580 <- (0,10820)
[0] 5581 <- (0,10821)
[0] 5582 <- (0,10822)
[0] 5583 <- (0,10823)
[0] 5584 <- (0,10824)
[0] 5585 <- (0,10825)
[0] 5586 <- (0,10826)
[0] 5587 <- (0,10827)
[0] 5588 <- (0,10828)
[0] 5589 <- (0,10829)
[0] 5590 <- (0,10830)
[0] 5591 <- (0,10831)
[0] 5592 <- (0,10832)
[0] 5593 <- (0,10833)
[0] 5594 <- (0,10834)
[0] 5595 <- (0,10835)
[0] 5596 <- (0,10836)
[0] 5597 <- (0,10837)
[0] 5598 <- (0,10838)
[0] 5599 <- (0,10839)
[0] 5600 <- (0,10840)
[0] 5601 <- (0,10841)
[0] 5602 <- (0,10842)
[0] 5603 <- (0,10867)
[0] 5604 <- (0,10868)
[0] 5605 <- (0,10869)
[0] 5606 <- (0,10870)
[0] 5607 <- (0,10871)
[0] 5608 <- (0,10872)
[0] 5609 <- (0,10873)
[0] 5610 <- (0,10874)
[0] 5611 <- (0,10875)
[0] 5612 <- (0,10876)
[0] 5613 <- (0,10877)
[0] 5614 <- (0,10878)
[0] 5615 <- (0,10879)
[0] 5616 <- (0,10880)
[0] 5617 <- (0,10881)
[0] 5618 <- (0,10882)
[0] 5619 <- (0,10883)
[0] 5620 <- (0,10884)
[0] 5621 <- (0,10885)
[0] 5622 <- (0,10886)
[0] 5623 <- (0,10887)
[0] 5624 <- (0,10888)
[0] 5625 <- (0,10889)
[0] 5626 <- (0,10890)
[0] 5627 <- (0,10891)
[0] 5628 <- (0,10892)
[0] 5629 <- (0,10893)
[0] 5630 <- (0,10918)
[0] 5631 <- (0,10919)
[0] 5632 <- (0,10920)
[0] 5633 <- (0,10921)
[0] 5634 <- (0,10922)
[0] 5635 <- (0,10923)
[0] 5636 <- (0,10924)
[0] 5637 <- (0,10925)
[0] 5638 <- (0,10926)
[0] 5639 <- (0,10927)
[0] 5640 <- (0,10928)
[0] 5641 <- (0,10929)
[0] 5642 <- (0,10930)
[0] 5643 <- (0,10931)
[0] 5644 <- (0,10932)
[0] 5645 <- (0,10933)
[0] 5646 <- (0,10934)
[0] 5647 <- (0,10935)
[0] 5648 <- (0,10936)
[0] 5649 <- (0,10937)
[0] 5650 <- (0,10938)
[0] 5651 <- (0,10939)
[0] 5652 <- (0,10940)
[0] 5653 <- (0,10941)
[0] 5654 <- (0,10942)
[0] 5655 <- (0,10943)
[0] 5656 <- (0,10944)
[0] 5657 <- (0,10969)
[0] 5658 <- (0,10970)
[0] 5659 <- (0,10971)
[0] 5660 <- (0,10972)
[0] 5661 <- (0,10973)
[0] 5662 <- (0,10974)
[0] 5663 <- (0,10975)
[0] 5664 <- (0,10976)
[0] 5665 <- (0,10977)
[0] 5666 <- (0,10978)
[0] 5667 <- (0,10979)
[0] 5668 <- (0,10980)
[0] 5669 <- (0,10981)
[0] 5670 <- (0,10982)
[0] 5671 <- (0,10983)
[0] 5672 <- (0,10984)
[0] 5673 <- (0,10985)
[0] 5674 <- (0,10986)
[0] 5675 <- (0,10987)
[0] 5676 <- (0,10988)
[0] 5677 <- (0,10989)
[0] 5678 <- (0,10990)
[0] 5679 <- (0,10991)
[0] 5680 <- (0,10992)
[0] 5681 <- (0,10993)
[0] 5682 <- (0,10994)
[0] 5683 <- (0,10995)
[0] 5684 <- (0,11020)
[0] 5685 <- (0,11021)
[0] 5686 <- (0,11022)
[0] 5687 <- (0,11023)
[0] 5688 <- (0,11024)
[0] 5689 <- (0,11025)
[0] 5690 <- (0,11026)
[0] 5691 <- (0,11027)
[0] 5692 <- (0,11028)
[0] 5693 <- (0,11029)
[0] 5694 <- (0,11030)
[0] 5695 <- (0,11031)
[0] 5696 <- (0,11032)
[0] 5697 <- (0,11033)
[0] 5698 <- (0,11034)
[0] 5699 <- (0,11035)
[0] 5700 <- (0,11036)
[0] 5701 <- (0,11037)
[0] 5702 <- (0,11038)
[0] 5703 <- (0,11039)
[0] 5704 <- (0,11040)
[0] 5705 <- (0,11041)
[0] 5706 <- (0,11042)
[0] 5707 <- (0,11043)
[0] 5708 <- (0,11044)
[0] 5709 <- (0,11045)
[0] 5710 <- (0,11046)
[0] 5711 <- (0,11071)
[0] 5712 <- (0,11072)
[0] 5713 <- (0,11073)
[0] 5714 <- (0,11074)
[0] 5715 <- (0,11075)
[0] 5716 <- (0,11076)
[0] 5717 <- (0,11077)
[0] 5718 <- (0,11078)
[0] 5719 <- (0,11079)
[0] 5720 <- (0,11080)
[0] 5721 <- (0,11081)
[0] 5722 <- (0,11082)
[0] 5723 <- (0,11083)
[0] 5724 <- (0,11084)
[0] 5725 <- (0,11085)
[0] 5726 <- (0,11086)
[0] 5727 <- (0,11087)
[0] 5728 <- (0,11088)
[0] 5729 <- (0,11089)
[0] 5730 <- (0,11090)
[0] 5731 <- (0,11091)
[0] 5732 <- (0,11092)
[0] 5733 <- (0,11122)
[0] 5734 <- (0,11123)
[0] 5735 <- (0,11124)
[0] 5736 <- (0,11125)
[0] 5737 <- (0,11126)
[0] 5738 <- (0,11127)
[0] 5739 <- (0,11128)
[0] 5740 <- (0,11129)
[0] 5741 <- (0,11130)
[0] 5742 <- (0,11131)
[0] 5743 <- (0,11132)
[0] 5744 <- (0,11133)
[0] 5745 <- (0,11134)
[0] 5746 <- (0,11135)
[0] 5747 <- (0,11136)
[0] 5748 <- (0,11137)
[0] 5749 <- (0,11138)
[0] 5750 <- (0,11139)
[0] 5751 <- (0,11140)
[0] 5752 <- (0,11141)
[0] 5753 <- (0,11142)
[0] 5754 <- (0,11143)
[0] 5755 <- (0,11173)
[0] 5756 <- (0,11174)
[0] 5757 <- (0,11175)
[0] 5758 <- (0,11176)
[0] 5759 <- (0,11177)
[0] 5760 <- (0,11178)
[0] 5761 <- (0,11179)
[0] 5762 <- (0,11180)
[0] 5763 <- (0,11181)
[0] 5764 <- (0,11182)
[0] 5765 <- (0,11183)
[0] 5766 <- (0,11184)
[0] 5767 <- (0,11185)
[0] 5768 <- (0,11186)
[0] 5769 <- (0,11187)
[0] 5770 <- (0,11188)
[0] 5771 <- (0,11189)
[0] 5772 <- (0,11190)
[0] 5773 <- (0,11191)
[0] 5774 <- (0,11192)
[0] 5775 <- (0,11193)
[0] 5776 <- (0,11194)
[0] 5777 <- (0,11224)
[0] 5778 <- (0,11225)
[0] 5779 <- (0,11226)
[0] 5780 <- (0,11227)
[0] 5781 <- (0,11228)
[0] 5782 <- (0,11229)
[0] 5783 <- (0,11230)
[0] 5784 <- (0,11231)
[0] 5785 <- (0,11232)
[0] 5786 <- (0,11233)
[0] 5787 <- (0,11234)
[0] 5788 <- (0,11235)
[0] 5789 <- (0,11236)
[0] 5790 <- (0,11237)
[0] 5791 <- (0,11238)
[0] 5792 <- (0,11239)
[0] 5793 <- (0,11240)
[0] 5794 <- (0,11241)
[0] 5795 <- (0,11242)
[0] 5796 <- (0,11243)
[0] 5797 <- (0,11244)
[0] 5798 <- (0,11245)
[0] 5799 <- (0,11275)
[0] 5800 <- (0,11276)
[0] 5801 <- (0,11277)
[0] 5802 <- (0,11278)
[0] 5803 <- (0,11279)
[0] 5804 <- (0,11280)
[0] 5805 <- (0,11281)
[0] 5806 <- (0,11282)
[0] 5807 <- (0,11283)
[0] 5808 <- (0,11284)
[0] 5809 <- (0,11285)
[0] 5810 <- (0,11286)
[0] 5811 <- (0,11287)
[0] 5812 <- (0,11288)
[0] 5813 <- (0,11289)
[0] 5814 <- (0,11290)
[0] 5815 <- (0,11291)
[0] 5816 <- (0,11292)
[0] 5817 <- (0,11293)
[0] 5818 <- (0,11294)
[0] 5819 <- (0,11295)
[0] 5820 <- (0,11296)
[0] 5821 <- (0,11326)
[0] 5822 <- (0,11327)
[0] 5823 <- (0,11328)
[0] 5824 <- (0,11329)
[0] 5825 <- (0,11330)
[0] 5826 <- (0,11331)
[0] 5827 <- (0,11332)
[0] 5828 <- (0,11333)
[0] 5829 <- (0,11334)
[0] 5830 <- (0,11335)
[0] 5831 <- (0,11336)
[0] 5832 <- (0,11337)
[0] 5833 <- (0,11338)
[0] 5834 <- (0,11339)
[0] 5835 <- (0,11340)
[0] 5836 <- (0,11341)
[0] 5837 <- (0,11342)
[0] 5838 <- (0,11343)
[0] 5839 <- (0,11344)
[0] 5840 <- (0,11345)
[0] 5841 <- (0,11346)
[0] 5842 <- (0,11347)
[0] 5843 <- (0,11348)
[0] 5844 <- (0,11377)
[0] 5845 <- (0,11378)
[0] 5846 <- (0,11379)
[0] 5847 <- (0,11380)
[0] 5848 <- (0,11381)
[0] 5849 <- (0,11382)
[0] 5850 <- (0,11383)
[0] 5851 <- (0,11384)
[0] 5852 <- (0,11385)
[0] 5853 <- (0,11386)
[0] 5854 <- (0,11387)
[0] 5855 <- (0,11388)
[0] 5856 <- (0,11389)
[0] 5857 <- (0,11390)
[0] 5858 <- (0,11391)
[0] 5859 <- (0,11392)
[0] 5860 <- (0,11393)
[0] 5861 <- (0,11394)
[0] 5862 <- (0,11395)
[0] 5863 <- (0,11396)
[0] 5864 <- (0,11397)
[0] 5865 <- (0,11398)
[0] 5866 <- (0,11399)
[0] 5867 <- (0,11428)
[0] 5868 <- (0,11429)
[0] 5869 <- (0,11430)
[0] 5870 <- (0,11431)
[0] 5871 <- (0,11432)
[0] 5872 <- (0,11433)
[0] 5873 <- (0,11434)
[0] 5874 <- (0,11435)
[0] 5875 <- (0,11436)
[0] 5876 <- (0,11437)
[0] 5877 <- (0,11438)
[0] 5878 <- (0,11439)
[0] 5879 <- (0,11440)
[0] 5880 <- (0,11441)
[0] 5881 <- (0,11442)
[0] 5882 <- (0,11443)
[0] 5883 <- (0,11444)
[0] 5884 <- (0,11445)
[0] 5885 <- (0,11446)
[0] 5886 <- (0,11447)
[0] 5887 <- (0,11448)
[0] 5888 <- (0,11449)
[0] 5889 <- (0,11450)
[0] 5890 <- (0,11479)
[0] 5891 <- (0,11480)
[0] 5892 <- (0,11481)
[0] 5893 <- (0,11482)
[0] 5894 <- (0,11483)
[0] 5895 <- (0,11484)
[0] 5896 <- (0,11485)
[0] 5897 <- (0,11486)
[0] 5898 <- (0,11487)
[0] 5899 <- (0,11488)
[0] 5900 <- (0,11489)
[0] 5901 <- (0,11490)
[0] 5902 <- (0,11491)
[0] 5903 <- (0,11492)
[0] 5904 <- (0,11493)
[0] 5905 <- (0,11494)
[0] 5906 <- (0,11495)
[0] 5907 <- (0,11496)
[0] 5908 <- (0,11497)
[0] 5909 <- (0,11498)
[0] 5910 <- (0,11499)
[0] 5911 <- (0,11500)
[0] 5912 <- (0,11501)
[0] 5913 <- (0,11530)
[0] 5914 <- (0,11531)
[0] 5915 <- (0,11532)
[0] 5916 <- (0,11533)
[0] 5917 <- (0,11534)
[0] 5918 <- (0,11535)
[0] 5919 <- (0,11536)
[0] 5920 <- (0,11537)
[0] 5921 <- (0,11538)
[0] 5922 <- (0,11539)
[0] 5923 <- (0,11540)
[0] 5924 <- (0,11541)
[0] 5925 <- (0,11542)
[0] 5926 <- (0,11543)
[0] 5927 <- (0,11544)
[0] 5928 <- (0,11545)
[0] 5929 <- (0,11546)
[0] 5930 <- (0,11547)
[0] 5931 <- (0,11548)
[0] 5932 <- (0,11549)
[0] 5933 <- (0,11550)
[0] 5934 <- (0,11551)
[0] 5935 <- (0,11552)
[0] 5936 <- (0,11553)
[0] 5937 <- (0,11581)
[0] 5938 <- (0,11582)
[0] 5939 <- (0,11583)
[0] 5940 <- (0,11584)
[0] 5941 <- (0,11585)
[0] 5942 <- (0,11586)
[0] 5943 <- (0,11587)
[0] 5944 <- (0,11588)
[0] 5945 <- (0,11589)
[0] 5946 <- (0,11590)
[0] 5947 <- (0,11591)
[0] 5948 <- (0,11592)
[0] 5949 <- (0,11593)
[0] 5950 <- (0,11594)
[0] 5951 <- (0,11595)
[0] 5952 <- (0,11596)
[0] 5953 <- (0,11597)
[0] 5954 <- (0,11598)
[0] 5955 <- (0,11599)
[0] 5956 <- (0,11600)
[0] 5957 <- (0,11601)
[0] 5958 <- (0,11602)
[0] 5959 <- (0,11603)
[0] 5960 <- (0,11604)
[0] 5961 <- (0,11632)
[0] 5962 <- (0,11633)
[0] 5963 <- (0,11634)
[0] 5964 <- (0,11635)
[0] 5965 <- (0,11636)
[0] 5966 <- (0,11637)
[0] 5967 <- (0,11638)
[0] 5968 <- (0,11639)
[0] 5969 <- (0,11640)
[0] 5970 <- (0,11641)
[0] 5971 <- (0,11642)
[0] 5972 <- (0,11643)
[0] 5973 <- (0,11644)
[0] 5974 <- (0,11645)
[0] 5975 <- (0,11646)
[0] 5976 <- (0,11647)
[0] 5977 <- (0,11648)
[0] 5978 <- (0,11649)
[0] 5979 <- (0,11650)
[0] 5980 <- (0,11651)
[0] 5981 <- (0,11652)
[0] 5982 <- (0,11653)
[0] 5983 <- (0,11654)
[0] 5984 <- (0,11655)
[0] 5985 <- (0,11656)
[0] 5986 <- (0,11683)
[0] 5987 <- (0,11684)
[0] 5988 <- (0,11685)
[0] 5989 <- (0,11686)
[0] 5990 <- (0,11687)
[0] 5991 <- (0,11688)
[0] 5992 <- (0,11689)
[0] 5993 <- (0,11690)
[0] 5994 <- (0,11691)
[0] 5995 <- (0,11692)
[0] 5996 <- (0,11693)
[0] 5997 <- (0,11694)
[0] 5998 <- (0,11695)
[0] 5999 <- (0,11696)
[0] 6000 <- (0,11697)
[0] 6001 <- (0,11698)
[0] 6002 <- (0,11699)
[0] 6003 <- (0,11700)
[0] 6004 <- (0,11701)
[0] 6005 <- (0,11702)
[0] 6006 <- (0,11703)
[0] 6007 <- (0,11704)
[0] 6008 <- (0,11705)
[0] 6009 <- (0,11706)
[0] 6010 <- (0,11707)
[0] 6011 <- (0,11708)
[0] 6012 <- (0,11734)
[0] 6013 <- (0,11735)
[0] 6014 <- (0,11736)
[0] 6015 <- (0,11737)
[0] 6016 <- (0,11738)
[0] 6017 <- (0,11739)
[0] 6018 <- (0,11740)
[0] 6019 <- (0,11741)
[0] 6020 <- (0,11742)
[0] 6021 <- (0,11743)
[0] 6022 <- (0,11744)
[0] 6023 <- (0,11745)
[0] 6024 <- (0,11746)
[0] 6025 <- (0,11747)
[0] 6026 <- (0,11748)
[0] 6027 <- (0,11749)
[0] 6028 <- (0,11750)
[0] 6029 <- (0,11751)
[0] 6030 <- (0,11752)
[0] 6031 <- (0,11753)
[0] 6032 <- (0,11754)
[0] 6033 <- (0,11755)
[0] 6034 <- (0,11756)
[0] 6035 <- (0,11757)
[0] 6036 <- (0,11758)
[0] 6037 <- (0,11759)
[0] 6038 <- (0,11785)
[0] 6039 <- (0,11786)
[0] 6040 <- (0,11787)
[0] 6041 <- (0,11788)
[0] 6042 <- (0,11789)
[0] 6043 <- (0,11790)
[0] 6044 <- (0,11791)
[0] 6045 <- (0,11792)
[0] 6046 <- (0,11793)
[0] 6047 <- (0,11794)
[0] 6048 <- (0,11795)
[0] 6049 <- (0,11796)
[0] 6050 <- (0,11797)
[0] 6051 <- (0,11798)
[0] 6052 <- (0,11799)
[0] 6053 <- (0,11800)
[0] 6054 <- (0,11801)
[0] 6055 <- (0,11802)
[0] 6056 <- (0,11803)
[0] 6057 <- (0,11804)
[0] 6058 <- (0,11805)
[0] 6059 <- (0,11806)
[0] 6060 <- (0,11807)
[0] 6061 <- (0,11808)
[0] 6062 <- (0,11809)
[0] 6063 <- (0,11810)
[0] 6064 <- (0,11811)
[0] 6065 <- (0,11836)
[0] 6066 <- (0,11837)
[0] 6067 <- (0,11838)
[0] 6068 <- (0,11839)
[0] 6069 <- (0,11840)
[0] 6070 <- (0,11841)
[0] 6071 <- (0,11842)
[0] 6072 <- (0,11843)
[0] 6073 <- (0,11844)
[0] 6074 <- (0,11845)
[0] 6075 <- (0,11846)
[0] 6076 <- (0,11847)
[0] 6077 <- (0,11848)
[0] 6078 <- (0,11849)
[0] 6079 <- (0,11850)
[0] 6080 <- (0,11851)
[0] 6081 <- (0,11852)
[0] 6082 <- (0,11853)
[0] 6083 <- (0,11854)
[0] 6084 <- (0,11855)
[0] 6085 <- (0,11856)
[0] 6086 <- (0,11857)
[0] 6087 <- (0,11858)
[0] 6088 <- (0,11859)
[0] 6089 <- (0,11860)
[0] 6090 <- (0,11861)
[0] 6091 <- (0,11862)
[0] 6092 <- (0,11887)
[0] 6093 <- (0,11888)
[0] 6094 <- (0,11889)
[0] 6095 <- (0,11890)
[0] 6096 <- (0,11891)
[0] 6097 <- (0,11892)
[0] 6098 <- (0,11893)
[0] 6099 <- (0,11894)
[0] 6100 <- (0,11895)
[0] 6101 <- (0,11896)
[0] 6102 <- (0,11897)
[0] 6103 <- (0,11898)
[0] 6104 <- (0,11899)
[0] 6105 <- (0,11900)
[0] 6106 <- (0,11901)
[0] 6107 <- (0,11902)
[0] 6108 <- (0,11903)
[0] 6109 <- (0,11904)
[0] 6110 <- (0,11905)
[0] 6111 <- (0,11906)
[0] 6112 <- (0,11907)
[0] 6113 <- (0,11908)
[0] 6114 <- (0,11909)
[0] 6115 <- (0,11910)
[0] 6116 <- (0,11911)
[0] 6117 <- (0,11912)
[0] 6118 <- (0,11913)
[0] 6119 <- (0,11938)
[0] 6120 <- (0,11939)
[0] 6121 <- (0,11940)
[0] 6122 <- (0,11941)
[0] 6123 <- (0,11942)
[0] 6124 <- (0,11943)
[0] 6125 <- (0,11944)
[0] 6126 <- (0,11945)
[0] 6127 <- (0,11946)
[0] 6128 <- (0,11947)
[0] 6129 <- (0,11948)
[0] 6130 <- (0,11949)
[0] 6131 <- (0,11950)
[0] 6132 <- (0,11951)
[0] 6133 <- (0,11952)
[0] 6134 <- (0,11953)
[0] 6135 <- (0,11954)
[0] 6136 <- (0,11955)
[0] 6137 <- (0,11956)
[0] 6138 <- (0,11957)
[0] 6139 <- (0,11958)
[0] 6140 <- (0,11959)
[0] 6141 <- (0,11960)
[0] 6142 <- (0,11961)
[0] 6143 <- (0,11962)
[0] 6144 <- (0,11963)
[0] 6145 <- (0,11964)
[0] 6146 <- (0,11989)
[0] 6147 <- (0,11990)
[0] 6148 <- (0,11991)
[0] 6149 <- (0,11992)
[0] 6150 <- (0,11993)
[0] 6151 <- (0,11994)
[0] 6152 <- (0,11995)
[0] 6153 <- (0,11996)
[0] 6154 <- (0,11997)
[0] 6155 <- (0,11998)
[0] 6156 <- (0,11999)
[0] 6157 <- (0,12000)
[0] 6158 <- (0,12001)
[0] 6159 <- (0,12002)
[0] 6160 <- (0,12003)
[0] 6161 <- (0,12004)
[0] 6162 <- (0,12005)
[0] 6163 <- (0,12006)
[0] 6164 <- (0,12007)
[0] 6165 <- (0,12008)
[0] 6166 <- (0,12009)
[0] 6167 <- (0,12010)
[0] 6168 <- (0,12011)
[0] 6169 <- (0,12012)
[0] 6170 <- (0,12013)
[0] 6171 <- (0,12014)
[0] 6172 <- (0,12015)
[0] 6173 <- (0,12040)
[0] 6174 <- (0,12041)
[0] 6175 <- (0,12042)
[0] 6176 <- (0,12043)
[0] 6177 <- (0,12044)
[0] 6178 <- (0,12045)
[0] 6179 <- (0,12046)
[0] 6180 <- (0,12047)
[0] 6181 <- (0,12048)
[0] 6182 <- (0,12049)
[0] 6183 <- (0,12050)
[0] 6184 <- (0,12051)
[0] 6185 <- (0,12052)
[0] 6186 <- (0,12053)
[0] 6187 <- (0,12054)
[0] 6188 <- (0,12055)
[0] 6189 <- (0,12056)
[0] 6190 <- (0,12057)
[0] 6191 <- (0,12058)
[0] 6192 <- (0,12059)
[0] 6193 <- (0,12060)
[0] 6194 <- (0,12061)
[0] 6195 <- (0,12062)
[0] 6196 <- (0,12063)
[0] 6197 <- (0,12064)
[0] 6198 <- (0,12065)
[0] 6199 <- (0,12066)
[0] 6200 <- (0,12091)
[0] 6201 <- (0,12092)
[0] 6202 <- (0,12093)
[0] 6203 <- (0,12094)
[0] 6204 <- (0,12095)
[0] 6205 <- (0,12096)
[0] 6206 <- (0,12097)
[0] 6207 <- (0,12098)
[0] 6208 <- (0,12099)
[0] 6209 <- (0,12100)
[0] 6210 <- (0,12101)
[0] 6211 <- (0,12102)
[0] 6212 <- (0,12103)
[0] 6213 <- (0,12104)
[0] 6214 <- (0,12105)
[0] 6215 <- (0,12106)
[0] 6216 <- (0,12107)
[0] 6217 <- (0,12108)
[0] 6218 <- (0,12109)
[0] 6219 <- (0,12110)
[0] 6220 <- (0,12111)
[0] 6221 <- (0,12112)
[0] 6222 <- (0,12113)
[0] 6223 <- (0,12114)
[0] 6224 <- (0,12115)
[0] 6225 <- (0,12116)
[0] 6226 <- (0,12117)
[0] 6227 <- (0,12142)
[0] 6228 <- (0,12143)
[0] 6229 <- (0,12144)
[0] 6230 <- (0,12145)
[0] 6231 <- (0,12146)
[0] 6232 <- (0,12147)
[0] 6233 <- (0,12148)
[0] 6234 <- (0,12149)
[0] 6235 <- (0,12150)
[0] 6236 <- (0,12151)
[0] 6237 <- (0,12152)
[0] 6238 <- (0,12153)
[0] 6239 <- (0,12154)
[0] 6240 <- (0,12155)
[0] 6241 <- (0,12156)
[0] 6242 <- (0,12157)
[0] 6243 <- (0,12158)
[0] 6244 <- (0,12159)
[0] 6245 <- (0,12160)
[0] 6246 <- (0,12161)
[0] 6247 <- (0,12162)
[0] 6248 <- (0,12163)
[0] 6249 <- (0,12193)
[0] 6250 <- (0,12194)
[0] 6251 <- (0,12195)
[0] 6252 <- (0,12196)
[0] 6253 <- (0,12197)
[0] 6254 <- (0,12198)
[0] 6255 <- (0,12199)
[0] 6256 <- (0,12200)
[0] 6257 <- (0,12201)
[0] 6258 <- (0,12202)
[0] 6259 <- (0,12203)
[0] 6260 <- (0,12204)
[0] 6261 <- (0,12205)
[0] 6262 <- (0,12206)
[0] 6263 <- (0,12207)
[0] 6264 <- (0,12208)
[0] 6265 <- (0,12209)
[0] 6266 <- (0,12210)
[0] 6267 <- (0,12211)
[0] 6268 <- (0,12212)
[0] 6269 <- (0,12213)
[0] 6270 <- (0,12214)
[0] 6271 <- (0,12244)
[0] 6272 <- (0,12245)
[0] 6273 <- (0,12246)
[0] 6274 <- (0,12247)
[0] 6275 <- (0,12248)
[0] 6276 <- (0,12249)
[0] 6277 <- (0,12250)
[0] 6278 <- (0,12251)
[0] 6279 <- (0,12252)
[0] 6280 <- (0,12253)
[0] 6281 <- (0,12254)
[0] 6282 <- (0,12255)
[0] 6283 <- (0,12256)
[0] 6284 <- (0,12257)
[0] 6285 <- (0,12258)
[0] 6286 <- (0,12259)
[0] 6287 <- (0,12260)
[0] 6288 <- (0,12261)
[0] 6289 <- (0,12262)
[0] 6290 <- (0,12263)
[0] 6291 <- (0,12264)
[0] 6292 <- (0,12265)
[0] 6293 <- (0,12295)
[0] 6294 <- (0,12296)
[0] 6295 <- (0,12297)
[0] 6296 <- (0,12298)
[0] 6297 <- (0,12299)
[0] 6298 <- (0,12300)
[0] 6299 <- (0,12301)
[0] 6300 <- (0,12302)
[0] 6301 <- (0,12303)
[0] 6302 <- (0,12304)
[0] 6303 <- (0,12305)
[0] 6304 <- (0,12306)
[0] 6305 <- (0,12307)
[0] 6306 <- (0,12308)
[0] 6307 <- (0,12309)
[0] 6308 <- (0,12310)
[0] 6309 <- (0,12311)
[0] 6310 <- (0,12312)
[0] 6311 <- (0,12313)
[0] 6312 <- (0,12314)
[0] 6313 <- (0,12315)
[0] 6314 <- (0,12316)
[0] 6315 <- (0,12346)
[0] 6316 <- (0,12347)
[0] 6317 <- (0,12348)
[0] 6318 <- (0,12349)
[0] 6319 <- (0,12350)
[0] 6320 <- (0,12351)
[0] 6321 <- (0,12352)
[0] 6322 <- (0,12353)
[0] 6323 <- (0,12354)
[0] 6324 <- (0,12355)
[0] 6325 <- (0,12356)
[0] 6326 <- (0,12357)
[0] 6327 <- (0,12358)
[0] 6328 <- (0,12359)
[0] 6329 <- (0,12360)
[0] 6330 <- (0,12361)
[0] 6331 <- (0,12362)
[0] 6332 <- (0,12363)
[0] 6333 <- (0,12364)
[0] 6334 <- (0,12365)
[0] 6335 <- (0,12366)
[0] 6336 <- (0,12367)
[0] 6337 <- (0,12397)
[0] 6338 <- (0,12398)
[0] 6339 <- (0,12399)
[0] 6340 <- (0,12400)
[0] 6341 <- (0,12401)
[0] 6342 <- (0,12402)
[0] 6343 <- (0,12403)
[0] 6344 <- (0,12404)
[0] 6345 <- (0,12405)
[0] 6346 <- (0,12406)
[0] 6347 <- (0,12407)
[0] 6348 <- (0,12408)
[0] 6349 <- (0,12409)
[0] 6350 <- (0,12410)
[0] 6351 <- (0,12411)
[0] 6352 <- (0,12412)
[0] 6353 <- (0,12413)
[0] 6354 <- (0,12414)
[0] 6355 <- (0,12415)
[0] 6356 <- (0,12416)
[0] 6357 <- (0,12417)
[0] 6358 <- (0,12418)
[0] 6359 <- (0,12419)
[0] 6360 <- (0,12448)
[0] 6361 <- (0,12449)
[0] 6362 <- (0,12450)
[0] 6363 <- (0,12451)
[0] 6364 <- (0,12452)
[0] 6365 <- (0,12453)
[0] 6366 <- (0,12454)
[0] 6367 <- (0,12455)
[0] 6368 <- (0,12456)
[0] 6369 <- (0,12457)
[0] 6370 <- (0,12458)
[0] 6371 <- (0,12459)
[0] 6372 <- (0,12460)
[0] 6373 <- (0,12461)
[0] 6374 <- (0,12462)
[0] 6375 <- (0,12463)
[0] 6376 <- (0,12464)
[0] 6377 <- (0,12465)
[0] 6378 <- (0,12466)
[0] 6379 <- (0,12467)
[0] 6380 <- (0,12468)
[0] 6381 <- (0,12469)
[0] 6382 <- (0,12470)
[0] 6383 <- (0,12499)
[0] 6384 <- (0,12500)
[0] 6385 <- (0,12501)
[0] 6386 <- (0,12502)
[0] 6387 <- (0,12503)
[0] 6388 <- (0,12504)
[0] 6389 <- (0,12505)
[0] 6390 <- (0,12506)
[0] 6391 <- (0,12507)
[0] 6392 <- (0,12508)
[0] 6393 <- (0,12509)
[0] 6394 <- (0,12510)
[0] 6395 <- (0,12511)
[0] 6396 <- (0,12512)
[0] 6397 <- (0,12513)
[0] 6398 <- (0,12514)
[0] 6399 <- (0,12515)
[0] 6400 <- (0,12516)
[0] 6401 <- (0,12517)
[0] 6402 <- (0,12518)
[0] 6403 <- (0,12519)
[0] 6404 <- (0,12520)
[0] 6405 <- (0,12521)
[0] 6406 <- (0,12550)
[0] 6407 <- (0,12551)
[0] 6408 <- (0,12552)
[0] 6409 <- (0,12553)
[0] 6410 <- (0,12554)
[0] 6411 <- (0,12555)
[0] 6412 <- (0,12556)
[0] 6413 <- (0,12557)
[0] 6414 <- (0,12558)
[0] 6415 <- (0,12559)
[0] 6416 <- (0,12560)
[0] 6417 <- (0,12561)
[0] 6418 <- (0,12562)
[0] 6419 <- (0,12563)
[0] 6420 <- (0,12564)
[0] 6421 <- (0,12565)
[0] 6422 <- (0,12566)
[0] 6423 <- (0,12567)
[0] 6424 <- (0,12568)
[0] 6425 <- (0,12569)
[0] 6426 <- (0,12570)
[0] 6427 <- (0,12571)
[0] 6428 <- (0,12572)
[0] 6429 <- (0,12601)
[0] 6430 <- (0,12602)
[0] 6431 <- (0,12603)
[0] 6432 <- (0,12604)
[0] 6433 <- (0,12605)
[0] 6434 <- (0,12606)
[0] 6435 <- (0,12607)
[0] 6436 <- (0,12608)
[0] 6437 <- (0,12609)
[0] 6438 <- (0,12610)
[0] 6439 <- (0,12611)
[0] 6440 <- (0,12612)
[0] 6441 <- (0,12613)
[0] 6442 <- (0,12614)
[0] 6443 <- (0,12615)
[0] 6444 <- (0,12616)
[0] 6445 <- (0,12617)
[0] 6446 <- (0,12618)
[0] 6447 <- (0,12619)
[0] 6448 <- (0,12620)
[0] 6449 <- (0,12621)
[0] 6450 <- (0,12622)
[0] 6451 <- (0,12623)
[0] 6452 <- (0,12624)
[0] 6453 <- (0,12652)
[0] 6454 <- (0,12653)
[0] 6455 <- (0,12654)
[0] 6456 <- (0,12655)
[0] 6457 <- (0,12656)
[0] 6458 <- (0,12657)
[0] 6459 <- (0,12658)
[0] 6460 <- (0,12659)
[0] 6461 <- (0,12660)
[0] 6462 <- (0,12661)
[0] 6463 <- (0,12662)
[0] 6464 <- (0,12663)
[0] 6465 <- (0,12664)
[0] 6466 <- (0,12665)
[0] 6467 <- (0,12666)
[0] 6468 <- (0,12667)
[0] 6469 <- (0,12668)
[0] 6470 <- (0,12669)
[0] 6471 <- (0,12670)
[0] 6472 <- (0,12671)
[0] 6473 <- (0,12672)
[0] 6474 <- (0,12673)
[0] 6475 <- (0,12674)
[0] 6476 <- (0,12675)
[0] 6477 <- (0,12703)
[0] 6478 <- (0,12704)
[0] 6479 <- (0,12705)
[0] 6480 <- (0,12706)
[0] 6481 <- (0,12707)
[0] 6482 <- (0,12708)
[0] 6483 <- (0,12709)
[0] 6484 <- (0,12710)
[0] 6485 <- (0,12711)
[0] 6486 <- (0,12712)
[0] 6487 <- (0,12713)
[0] 6488 <- (0,12714)
[0] 6489 <- (0,12715)
[0] 6490 <- (0,12716)
[0] 6491 <- (0,12717)
[0] 6492 <- (0,12718)
[0] 6493 <- (0,12719)
[0] 6494 <- (0,12720)
[0] 6495 <- (0,12721)
[0] 6496 <- (0,12722)
[0] 6497 <- (0,12723)
[0] 6498 <- (0,12724)
[0] 6499 <- (0,12725)
[0] 6500 <- (0,12726)
[0] 6501 <- (0,12727)
[0] 6502 <- (0,12754)
[0] 6503 <- (0,12755)
[0] 6504 <- (0,12756)
[0] 6505 <- (0,12757)
[0] 6506 <- (0,12758)
[0] 6507 <- (0,12759)
[0] 6508 <- (0,12760)
[0] 6509 <- (0,12761)
[0] 6510 <- (0,12762)
[0] 6511 <- (0,12763)
[0] 6512 <- (0,12764)
[0] 6513 <- (0,12765)
[0] 6514 <- (0,12766)
[0] 6515 <- (0,12767)
[0] 6516 <- (0,12768)
[0] 6517 <- (0,12769)
[0] 6518 <- (0,12770)
[0] 6519 <- (0,12771)
[0] 6520 <- (0,12772)
[0] 6521 <- (0,12773)
[0] 6522 <- (0,12774)
[0] 6523 <- (0,12775)
[0] 6524 <- (0,12776)
[0] 6525 <- (0,12777)
[0] 6526 <- (0,12778)
[0] 6527 <- (0,12779)
[0] 6528 <- (0,12805)
[0] 6529 <- (0,12806)
[0] 6530 <- (0,12807)
[0] 6531 <- (0,12808)
[0] 6532 <- (0,12809)
[0] 6533 <- (0,12810)
[0] 6534 <- (0,12811)
[0] 6535 <- (0,12812)
[0] 6536 <- (0,12813)
[0] 6537 <- (0,12814)
[0] 6538 <- (0,12815)
[0] 6539 <- (0,12816)
[0] 6540 <- (0,12817)
[0] 6541 <- (0,12818)
[0] 6542 <- (0,12819)
[0] 6543 <- (0,12820)
[0] 6544 <- (0,12821)
[0] 6545 <- (0,12822)
[0] 6546 <- (0,12823)
[0] 6547 <- (0,12824)
[0] 6548 <- (0,12825)
[0] 6549 <- (0,12826)
[0] 6550 <- (0,12827)
[0] 6551 <- (0,12828)
[0] 6552 <- (0,12829)
[0] 6553 <- (0,12830)
[0] 6554 <- (0,12856)
[0] 6555 <- (0,12857)
[0] 6556 <- (0,12858)
[0] 6557 <- (0,12859)
[0] 6558 <- (0,12860)
[0] 6559 <- (0,12861)
[0] 6560 <- (0,12862)
[0] 6561 <- (0,12863)
[0] 6562 <- (0,12864)
[0] 6563 <- (0,12865)
[0] 6564 <- (0,12866)
[0] 6565 <- (0,12867)
[0] 6566 <- (0,12868)
[0] 6567 <- (0,12869)
[0] 6568 <- (0,12870)
[0] 6569 <- (0,12871)
[0] 6570 <- (0,12872)
[0] 6571 <- (0,12873)
[0] 6572 <- (0,12874)
[0] 6573 <- (0,12875)
[0] 6574 <- (0,12876)
[0] 6575 <- (0,12877)
[0] 6576 <- (0,12878)
[0] 6577 <- (0,12879)
[0] 6578 <- (0,12880)
[0] 6579 <- (0,12881)
[0] 6580 <- (0,12882)
[0] 6581 <- (0,12907)
[0] 6582 <- (0,12908)
[0] 6583 <- (0,12909)
[0] 6584 <- (0,12910)
[0] 6585 <- (0,12911)
[0] 6586 <- (0,12912)
[0] 6587 <- (0,12913)
[0] 6588 <- (0,12914)
[0] 6589 <- (0,12915)
[0] 6590 <- (0,12916)
[0] 6591 <- (0,12917)
[0] 6592 <- (0,12918)
[0] 6593 <- (0,12919)
[0] 6594 <- (0,12920)
[0] 6595 <- (0,12921)
[0] 6596 <- (0,12922)
[0] 6597 <- (0,12923)
[0] 6598 <- (0,12924)
[0] 6599 <- (0,12925)
[0] 6600 <- (0,12926)
[0] 6601 <- (0,12927)
[0] 6602 <- (0,12928)
[0] 6603 <- (0,12929)
[0] 6604 <- (0,12930)
[0] 6605 <- (0,12931)
[0] 6606 <- (0,12932)
[0] 6607 <- (0,12933)
[0] 6608 <- (0,12958)
[0] 6609 <- (0,12959)
[0] 6610 <- (0,12960)
[0] 6611 <- (0,12961)
[0] 6612 <- (0,12962)
[0] 6613 <- (0,12963)
[0] 6614 <- (0,12964)
[0] 6615 <- (0,12965)
[0] 6616 <- (0,12966)
[0] 6617 <- (0,12967)
[0] 6618 <- (0,12968)
[0] 6619 <- (0,12969)
[0] 6620 <- (0,12970)
[0] 6621 <- (0,12971)
[0] 6622 <- (0,12972)
[0] 6623 <- (0,12973)
[0] 6624 <- (0,12974)
[0] 6625 <- (0,12975)
[0] 6626 <- (0,12976)
[0] 6627 <- (0,12977)
[0] 6628 <- (0,12978)
[0] 6629 <- (0,12979)
[0] 6630 <- (0,12980)
[0] 6631 <- (0,12981)
[0] 6632 <- (0,12982)
[0] 6633 <- (0,12983)
[0] 6634 <- (0,12984)
[0] 6635 <- (0,13009)
[0] 6636 <- (0,13010)
[0] 6637 <- (0,13011)
[0] 6638 <- (0,13012)
[0] 6639 <- (0,13013)
[0] 6640 <- (0,13014)
[0] 6641 <- (0,13015)
[0] 6642 <- (0,13016)
[0] 6643 <- (0,13017)
[0] 6644 <- (0,13018)
[0] 6645 <- (0,13019)
[0] 6646 <- (0,13020)
[0] 6647 <- (0,13021)
[0] 6648 <- (0,13022)
[0] 6649 <- (0,13023)
[0] 6650 <- (0,13024)
[0] 6651 <- (0,13025)
[0] 6652 <- (0,13026)
[0] 6653 <- (0,13027)
[0] 6654 <- (0,13028)
[0] 6655 <- (0,13029)
[0] 6656 <- (0,13030)
[0] 6657 <- (0,13031)
[0] 6658 <- (0,13032)
[0] 6659 <- (0,13033)
[0] 6660 <- (0,13034)
[0] 6661 <- (0,13035)
[0] 6662 <- (0,13060)
[0] 6663 <- (0,13061)
[0] 6664 <- (0,13062)
[0] 6665 <- (0,13063)
[0] 6666 <- (0,13064)
[0] 6667 <- (0,13065)
[0] 6668 <- (0,13066)
[0] 6669 <- (0,13067)
[0] 6670 <- (0,13068)
[0] 6671 <- (0,13069)
[0] 6672 <- (0,13070)
[0] 6673 <- (0,13071)
[0] 6674 <- (0,13072)
[0] 6675 <- (0,13073)
[0] 6676 <- (0,13074)
[0] 6677 <- (0,13075)
[0] 6678 <- (0,13076)
[0] 6679 <- (0,13077)
[0] 6680 <- (0,13078)
[0] 6681 <- (0,13079)
[0] 6682 <- (0,13080)
[0] 6683 <- (0,13081)
[0] 6684 <- (0,13082)
[0] 6685 <- (0,13083)
[0] 6686 <- (0,13084)
[0] 6687 <- (0,13085)
[0] 6688 <- (0,13086)
[0] 6689 <- (0,13111)
[0] 6690 <- (0,13112)
[0] 6691 <- (0,13113)
[0] 6692 <- (0,13114)
[0] 6693 <- (0,13115)
[0] 6694 <- (0,13116)
[0] 6695 <- (0,13117)
[0] 6696 <- (0,13118)
[0] 6697 <- (0,13119)
[0] 6698 <- (0,13120)
[0] 6699 <- (0,13121)
[0] 6700 <- (0,13122)
[0] 6701 <- (0,13123)
[0] 6702 <- (0,13124)
[0] 6703 <- (0,13125)
[0] 6704 <- (0,13126)
[0] 6705 <- (0,13127)
[0] 6706 <- (0,13128)
[0] 6707 <- (0,13129)
[0] 6708 <- (0,13130)
[0] 6709 <- (0,13131)
[0] 6710 <- (0,13132)
[0] 6711 <- (0,13133)
[0] 6712 <- (0,13134)
[0] 6713 <- (0,13135)
[0] 6714 <- (0,13136)
[0] 6715 <- (0,13137)
[0] 6716 <- (0,13162)
[0] 6717 <- (0,13163)
[0] 6718 <- (0,13164)
[0] 6719 <- (0,13165)
[0] 6720 <- (0,13166)
[0] 6721 <- (0,13167)
[0] 6722 <- (0,13168)
[0] 6723 <- (0,13169)
[0] 6724 <- (0,13170)
[0] 6725 <- (0,13171)
[0] 6726 <- (0,13172)
[0] 6727 <- (0,13173)
[0] 6728 <- (0,13174)
[0] 6729 <- (0,13175)
[0] 6730 <- (0,13176)
[0] 6731 <- (0,13177)
[0] 6732 <- (0,13178)
[0] 6733 <- (0,13179)
[0] 6734 <- (0,13180)
[0] 6735 <- (0,13181)
[0] 6736 <- (0,13182)
[0] 6737 <- (0,13183)
[0] 6738 <- (0,13184)
[0] 6739 <- (0,13185)
[0] 6740 <- (0,13186)
[0] 6741 <- (0,13187)
[0] 6742 <- (0,13188)
[0] 6743 <- (0,13213)
[0] 6744 <- (0,13214)
[0] 6745 <- (0,13215)
[0] 6746 <- (0,13216)
[0] 6747 <- (0,13217)
[0] 6748 <- (0,13218)
[0] 6749 <- (0,13219)
[0] 6750 <- (0,13220)
[0] 6751 <- (0,13221)
[0] 6752 <- (0,13222)
[0] 6753 <- (0,13223)
[0] 6754 <- (0,13224)
[0] 6755 <- (0,13225)
[0] 6756 <- (0,13226)
[0] 6757 <- (0,13227)
[0] 6758 <- (0,13228)
[0] 6759 <- (0,13229)
[0] 6760 <- (0,13230)
[0] 6761 <- (0,13231)
[0] 6762 <- (0,13232)
[0] 6763 <- (0,13233)
[0] 6764 <- (0,13234)
[0] 6765 <- (0,13264)
[0] 6766 <- (0,13265)
[0] 6767 <- (0,13266)
[0] 6768 <- (0,13267)
[0] 6769 <- (0,13268)
[0] 6770 <- (0,13269)
[0] 6771 <- (0,13270)
[0] 6772 <- (0,13271)
[0] 6773 <- (0,13272)
[0] 6774 <- (0,13273)
[0] 6775 <- (0,13274)
[0] 6776 <- (0,13275)
[0] 6777 <- (0,13276)
[0] 6778 <- (0,13277)
[0] 6779 <- (0,13278)
[0] 6780 <- (0,13279)
[0] 6781 <- (0,13280)
[0] 6782 <- (0,13281)
[0] 6783 <- (0,13282)
[0] 6784 <- (0,13283)
[0] 6785 <- (0,13284)
[0] 6786 <- (0,13285)
[0] 6787 <- (0,13315)
[0] 6788 <- (0,13316)
[0] 6789 <- (0,13317)
[0] 6790 <- (0,13318)
[0] 6791 <- (0,13319)
[0] 6792 <- (0,13320)
[0] 6793 <- (0,13321)
[0] 6794 <- (0,13322)
[0] 6795 <- (0,13323)
[0] 6796 <- (0,13324)
[0] 6797 <- (0,13325)
[0] 6798 <- (0,13326)
[0] 6799 <- (0,13327)
[0] 6800 <- (0,13328)
[0] 6801 <- (0,13329)
[0] 6802 <- (0,13330)
[0] 6803 <- (0,13331)
[0] 6804 <- (0,13332)
[0] 6805 <- (0,13333)
[0] 6806 <- (0,13334)
[0] 6807 <- (0,13335)
[0] 6808 <- (0,13336)
[0] 6809 <- (0,13366)
[0] 6810 <- (0,13367)
[0] 6811 <- (0,13368)
[0] 6812 <- (0,13369)
[0] 6813 <- (0,13370)
[0] 6814 <- (0,13371)
[0] 6815 <- (0,13372)
[0] 6816 <- (0,13373)
[0] 6817 <- (0,13374)
[0] 6818 <- (0,13375)
[0] 6819 <- (0,13376)
[0] 6820 <- (0,13377)
[0] 6821 <- (0,13378)
[0] 6822 <- (0,13379)
[0] 6823 <- (0,13380)
[0] 6824 <- (0,13381)
[0] 6825 <- (0,13382)
[0] 6826 <- (0,13383)
[0] 6827 <- (0,13384)
[0] 6828 <- (0,13385)
[0] 6829 <- (0,13386)
[0] 6830 <- (0,13387)
[0] 6831 <- (0,13417)
[0] 6832 <- (0,13418)
[0] 6833 <- (0,13419)
[0] 6834 <- (0,13420)
[0] 6835 <- (0,13421)
[0] 6836 <- (0,13422)
[0] 6837 <- (0,13423)
[0] 6838 <- (0,13424)
[0] 6839 <- (0,13425)
[0] 6840 <- (0,13426)
[0] 6841 <- (0,13427)
[0] 6842 <- (0,13428)
[0] 6843 <- (0,13429)
[0] 6844 <- (0,13430)
[0] 6845 <- (0,13431)
[0] 6846 <- (0,13432)
[0] 6847 <- (0,13433)
[0] 6848 <- (0,13434)
[0] 6849 <- (0,13435)
[0] 6850 <- (0,13436)
[0] 6851 <- (0,13437)
[0] 6852 <- (0,13438)
[0] 6853 <- (0,13468)
[0] 6854 <- (0,13469)
[0] 6855 <- (0,13470)
[0] 6856 <- (0,13471)
[0] 6857 <- (0,13472)
[0] 6858 <- (0,13473)
[0] 6859 <- (0,13474)
[0] 6860 <- (0,13475)
[0] 6861 <- (0,13476)
[0] 6862 <- (0,13477)
[0] 6863 <- (0,13478)
[0] 6864 <- (0,13479)
[0] 6865 <- (0,13480)
[0] 6866 <- (0,13481)
[0] 6867 <- (0,13482)
[0] 6868 <- (0,13483)
[0] 6869 <- (0,13484)
[0] 6870 <- (0,13485)
[0] 6871 <- (0,13486)
[0] 6872 <- (0,13487)
[0] 6873 <- (0,13488)
[0] 6874 <- (0,13489)
[0] 6875 <- (0,13490)
[0] 6876 <- (0,13519)
[0] 6877 <- (0,13520)
[0] 6878 <- (0,13521)
[0] 6879 <- (0,13522)
[0] 6880 <- (0,13523)
[0] 6881 <- (0,13524)
[0] 6882 <- (0,13525)
[0] 6883 <- (0,13526)
[0] 6884 <- (0,13527)
[0] 6885 <- (0,13528)
[0] 6886 <- (0,13529)
[0] 6887 <- (0,13530)
[0] 6888 <- (0,13531)
[0] 6889 <- (0,13532)
[0] 6890 <- (0,13533)
[0] 6891 <- (0,13534)
[0] 6892 <- (0,13535)
[0] 6893 <- (0,13536)
[0] 6894 <- (0,13537)
[0] 6895 <- (0,13538)
[0] 6896 <- (0,13539)
[0] 6897 <- (0,13540)
[0] 6898 <- (0,13541)
[0] 6899 <- (0,13570)
[0] 6900 <- (0,13571)
[0] 6901 <- (0,13572)
[0] 6902 <- (0,13573)
[0] 6903 <- (0,13574)
[0] 6904 <- (0,13575)
[0] 6905 <- (0,13576)
[0] 6906 <- (0,13577)
[0] 6907 <- (0,13578)
[0] 6908 <- (0,13579)
[0] 6909 <- (0,13580)
[0] 6910 <- (0,13581)
[0] 6911 <- (0,13582)
[0] 6912 <- (0,13583)
[0] 6913 <- (0,13584)
[0] 6914 <- (0,13585)
[0] 6915 <- (0,13586)
[0] 6916 <- (0,13587)
[0] 6917 <- (0,13588)
[0] 6918 <- (0,13589)
[0] 6919 <- (0,13590)
[0] 6920 <- (0,13591)
[0] 6921 <- (0,13592)
[0] 6922 <- (0,13621)
[0] 6923 <- (0,13622)
[0] 6924 <- (0,13623)
[0] 6925 <- (0,13624)
[0] 6926 <- (0,13625)
[0] 6927 <- (0,13626)
[0] 6928 <- (0,13627)
[0] 6929 <- (0,13628)
[0] 6930 <- (0,13629)
[0] 6931 <- (0,13630)
[0] 6932 <- (0,13631)
[0] 6933 <- (0,13632)
[0] 6934 <- (0,13633)
[0] 6935 <- (0,13634)
[0] 6936 <- (0,13635)
[0] 6937 <- (0,13636)
[0] 6938 <- (0,13637)
[0] 6939 <- (0,13638)
[0] 6940 <- (0,13639)
[0] 6941 <- (0,13640)
[0] 6942 <- (0,13641)
[0] 6943 <- (0,13642)
[0] 6944 <- (0,13643)
[0] 6945 <- (0,13672)
[0] 6946 <- (0,13673)
[0] 6947 <- (0,13674)
[0] 6948 <- (0,13675)
[0] 6949 <- (0,13676)
[0] 6950 <- (0,13677)
[0] 6951 <- (0,13678)
[0] 6952 <- (0,13679)
[0] 6953 <- (0,13680)
[0] 6954 <- (0,13681)
[0] 6955 <- (0,13682)
[0] 6956 <- (0,13683)
[0] 6957 <- (0,13684)
[0] 6958 <- (0,13685)
[0] 6959 <- (0,13686)
[0] 6960 <- (0,13687)
[0] 6961 <- (0,13688)
[0] 6962 <- (0,13689)
[0] 6963 <- (0,13690)
[0] 6964 <- (0,13691)
[0] 6965 <- (0,13692)
[0] 6966 <- (0,13693)
[0] 6967 <- (0,13694)
[0] 6968 <- (0,13695)
[0] 6969 <- (0,13723)
[0] 6970 <- (0,13724)
[0] 6971 <- (0,13725)
[0] 6972 <- (0,13726)
[0] 6973 <- (0,13727)
[0] 6974 <- (0,13728)
[0] 6975 <- (0,13729)
[0] 6976 <- (0,13730)
[0] 6977 <- (0,13731)
[0] 6978 <- (0,13732)
[0] 6979 <- (0,13733)
[0] 6980 <- (0,13734)
[0] 6981 <- (0,13735)
[0] 6982 <- (0,13736)
[0] 6983 <- (0,13737)
[0] 6984 <- (0,13738)
[0] 6985 <- (0,13739)
[0] 6986 <- (0,13740)
[0] 6987 <- (0,13741)
[0] 6988 <- (0,13742)
[0] 6989 <- (0,13743)
[0] 6990 <- (0,13744)
[0] 6991 <- (0,13745)
[0] 6992 <- (0,13746)
[0] 6993 <- (0,13774)
[0] 6994 <- (0,13775)
[0] 6995 <- (0,13776)
[0] 6996 <- (0,13777)
[0] 6997 <- (0,13778)
[0] 6998 <- (0,13779)
[0] 6999 <- (0,13780)
[0] 7000 <- (0,13781)
[0] 7001 <- (0,13782)
[0] 7002 <- (0,13783)
[0] 7003 <- (0,13784)
[0] 7004 <- (0,13785)
[0] 7005 <- (0,13786)
[0] 7006 <- (0,13787)
[0] 7007 <- (0,13788)
[0] 7008 <- (0,13789)
[0] 7009 <- (0,13790)
[0] 7010 <- (0,13791)
[0] 7011 <- (0,13792)
[0] 7012 <- (0,13793)
[0] 7013 <- (0,13794)
[0] 7014 <- (0,13795)
[0] 7015 <- (0,13796)
[0] 7016 <- (0,13797)
[0] 7017 <- (0,13798)
[0] 7018 <- (0,13825)
[0] 7019 <- (0,13826)
[0] 7020 <- (0,13827)
[0] 7021 <- (0,13828)
[0] 7022 <- (0,13829)
[0] 7023 <- (0,13830)
[0] 7024 <- (0,13831)
[0] 7025 <- (0,13832)
[0] 7026 <- (0,13833)
[0] 7027 <- (0,13834)
[0] 7028 <- (0,13835)
[0] 7029 <- (0,13836)
[0] 7030 <- (0,13837)
[0] 7031 <- (0,13838)
[0] 7032 <- (0,13839)
[0] 7033 <- (0,13840)
[0] 7034 <- (0,13841)
[0] 7035 <- (0,13842)
[0] 7036 <- (0,13843)
[0] 7037 <- (0,13844)
[0] 7038 <- (0,13845)
[0] 7039 <- (0,13846)
[0] 7040 <- (0,13847)
[0] 7041 <- (0,13848)
[0] 7042 <- (0,13849)
[0] 7043 <- (0,13850)
[0] 7044 <- (0,13876)
[0] 7045 <- (0,13877)
[0] 7046 <- (0,13878)
[0] 7047 <- (0,13879)
[0] 7048 <- (0,13880)
[0] 7049 <- (0,13881)
[0] 7050 <- (0,13882)
[0] 7051 <- (0,13883)
[0] 7052 <- (0,13884)
[0] 7053 <- (0,13885)
[0] 7054 <- (0,13886)
[0] 7055 <- (0,13887)
[0] 7056 <- (0,13888)
[0] 7057 <- (0,13889)
[0] 7058 <- (0,13890)
[0] 7059 <- (0,13891)
[0] 7060 <- (0,13892)
[0] 7061 <- (0,13893)
[0] 7062 <- (0,13894)
[0] 7063 <- (0,13895)
[0] 7064 <- (0,13896)
[0] 7065 <- (0,13897)
[0] 7066 <- (0,13898)
[0] 7067 <- (0,13899)
[0] 7068 <- (0,13900)
[0] 7069 <- (0,13901)
[0] 7070 <- (0,13927)
[0] 7071 <- (0,13928)
[0] 7072 <- (0,13929)
[0] 7073 <- (0,13930)
[0] 7074 <- (0,13931)
[0] 7075 <- (0,13932)
[0] 7076 <- (0,13933)
[0] 7077 <- (0,13934)
[0] 7078 <- (0,13935)
[0] 7079 <- (0,13936)
[0] 7080 <- (0,13937)
[0] 7081 <- (0,13938)
[0] 7082 <- (0,13939)
[0] 7083 <- (0,13940)
[0] 7084 <- (0,13941)
[0] 7085 <- (0,13942)
[0] 7086 <- (0,13943)
[0] 7087 <- (0,13944)
[0] 7088 <- (0,13945)
[0] 7089 <- (0,13946)
[0] 7090 <- (0,13947)
[0] 7091 <- (0,13948)
[0] 7092 <- (0,13949)
[0] 7093 <- (0,13950)
[0] 7094 <- (0,13951)
[0] 7095 <- (0,13952)
[0] 7096 <- (0,13953)
[0] 7097 <- (0,13978)
[0] 7098 <- (0,13979)
[0] 7099 <- (0,13980)
[0] 7100 <- (0,13981)
[0] 7101 <- (0,13982)
[0] 7102 <- (0,13983)
[0] 7103 <- (0,13984)
[0] 7104 <- (0,13985)
[0] 7105 <- (0,13986)
[0] 7106 <- (0,13987)
[0] 7107 <- (0,13988)
[0] 7108 <- (0,13989)
[0] 7109 <- (0,13990)
[0] 7110 <- (0,13991)
[0] 7111 <- (0,13992)
[0] 7112 <- (0,13993)
[0] 7113 <- (0,13994)
[0] 7114 <- (0,13995)
[0] 7115 <- (0,13996)
[0] 7116 <- (0,13997)
[0] 7117 <- (0,13998)
[0] 7118 <- (0,13999)
[0] 7119 <- (0,14000)
[0] 7120 <- (0,14001)
[0] 7121 <- (0,14002)
[0] 7122 <- (0,14003)
[0] 7123 <- (0,14004)
[0] 7124 <- (0,14029)
[0] 7125 <- (0,14030)
[0] 7126 <- (0,14031)
[0] 7127 <- (0,14032)
[0] 7128 <- (0,14033)
[0] 7129 <- (0,14034)
[0] 7130 <- (0,14035)
[0] 7131 <- (0,14036)
[0] 7132 <- (0,14037)
[0] 7133 <- (0,14038)
[0] 7134 <- (0,14039)
[0] 7135 <- (0,14040)
[0] 7136 <- (0,14041)
[0] 7137 <- (0,14042)
[0] 7138 <- (0,14043)
[0] 7139 <- (0,14044)
[0] 7140 <- (0,14045)
[0] 7141 <- (0,14046)
[0] 7142 <- (0,14047)
[0] 7143 <- (0,14048)
[0] 7144 <- (0,14049)
[0] 7145 <- (0,14050)
[0] 7146 <- (0,14051)
[0] 7147 <- (0,14052)
[0] 7148 <- (0,14053)
[0] 7149 <- (0,14054)
[0] 7150 <- (0,14055)
[0] 7151 <- (0,14080)
[0] 7152 <- (0,14081)
[0] 7153 <- (0,14082)
[0] 7154 <- (0,14083)
[0] 7155 <- (0,14084)
[0] 7156 <- (0,14085)
[0] 7157 <- (0,14086)
[0] 7158 <- (0,14087)
[0] 7159 <- (0,14088)
[0] 7160 <- (0,14089)
[0] 7161 <- (0,14090)
[0] 7162 <- (0,14091)
[0] 7163 <- (0,14092)
[0] 7164 <- (0,14093)
[0] 7165 <- (0,14094)
[0] 7166 <- (0,14095)
[0] 7167 <- (0,14096)
[0] 7168 <- (0,14097)
[0] 7169 <- (0,14098)
[0] 7170 <- (0,14099)
[0] 7171 <- (0,14100)
[0] 7172 <- (0,14101)
[0] 7173 <- (0,14102)
[0] 7174 <- (0,14103)
[0] 7175 <- (0,14104)
[0] 7176 <- (0,14105)
[0] 7177 <- (0,14106)
[0] 7178 <- (0,14131)
[0] 7179 <- (0,14132)
[0] 7180 <- (0,14133)
[0] 7181 <- (0,14134)
[0] 7182 <- (0,14135)
[0] 7183 <- (0,14136)
[0] 7184 <- (0,14137)
[0] 7185 <- (0,14138)
[0] 7186 <- (0,14139)
[0] 7187 <- (0,14140)
[0] 7188 <- (0,14141)
[0] 7189 <- (0,14142)
[0] 7190 <- (0,14143)
[0] 7191 <- (0,14144)
[0] 7192 <- (0,14145)
[0] 7193 <- (0,14146)
[0] 7194 <- (0,14147)
[0] 7195 <- (0,14148)
[0] 7196 <- (0,14149)
[0] 7197 <- (0,14150)
[0] 7198 <- (0,14151)
[0] 7199 <- (0,14152)
[0] 7200 <- (0,14153)
[0] 7201 <- (0,14154)
[0] 7202 <- (0,14155)
[0] 7203 <- (0,14156)
[0] 7204 <- (0,14157)
[0] 7205 <- (0,14182)
[0] 7206 <- (0,14183)
[0] 7207 <- (0,14184)
[0] 7208 <- (0,14185)
[0] 7209 <- (0,14186)
[0] 7210 <- (0,14187)
[0] 7211 <- (0,14188)
[0] 7212 <- (0,14189)
[0] 7213 <- (0,14190)
[0] 7214 <- (0,14191)
[0] 7215 <- (0,14192)
[0] 7216 <- (0,14193)
[0] 7217 <- (0,14194)
[0] 7218 <- (0,14195)
[0] 7219 <- (0,14196)
[0] 7220 <- (0,14197)
[0] 7221 <- (0,14198)
[0] 7222 <- (0,14199)
[0] 7223 <- (0,14200)
[0] 7224 <- (0,14201)
[0] 7225 <- (0,14202)
[0] 7226 <- (0,14203)
[0] 7227 <- (0,14204)
[0] 7228 <- (0,14205)
[0] 7229 <- (0,14206)
[0] 7230 <- (0,14207)
[0] 7231 <- (0,14208)
[0] 7232 <- (0,14233)
[0] 7233 <- (0,14234)
[0] 7234 <- (0,14235)
[0] 7235 <- (0,14236)
[0] 7236 <- (0,14237)
[0] 7237 <- (0,14238)
[0] 7238 <- (0,14239)
[0] 7239 <- (0,14240)
[0] 7240 <- (0,14241)
[0] 7241 <- (0,14242)
[0] 7242 <- (0,14243)
[0] 7243 <- (0,14244)
[0] 7244 <- (0,14245)
[0] 7245 <- (0,14246)
[0] 7246 <- (0,14247)
[0] 7247 <- (0,14248)
[0] 7248 <- (0,14249)
[0] 7249 <- (0,14250)
[0] 7250 <- (0,14251)
[0] 7251 <- (0,14252)
[0] 7252 <- (0,14253)
[0] 7253 <- (0,14254)
[0] 7254 <- (0,14255)
[0] 7255 <- (0,14256)
[0] 7256 <- (0,14257)
[0] 7257 <- (0,14258)
[0] 7258 <- (0,14259)
[0] 7259 <- (0,14284)
[0] 7260 <- (0,14285)
[0] 7261 <- (0,14286)
[0] 7262 <- (0,14287)
[0] 7263 <- (0,14288)
[0] 7264 <- (0,14289)
[0] 7265 <- (0,14290)
[0] 7266 <- (0,14291)
[0] 7267 <- (0,14292)
[0] 7268 <- (0,14293)
[0] 7269 <- (0,14294)
[0] 7270 <- (0,14295)
[0] 7271 <- (0,14296)
[0] 7272 <- (0,14297)
[0] 7273 <- (0,14298)
[0] 7274 <- (0,14299)
[0] 7275 <- (0,14300)
[0] 7276 <- (0,14301)
[0] 7277 <- (0,14302)
[0] 7278 <- (0,14303)
[0] 7279 <- (0,14304)
[0] 7280 <- (0,14305)
[0] 7281 <- (0,14335)
[0] 7282 <- (0,14336)
[0] 7283 <- (0,14337)
[0] 7284 <- (0,14338)
[0] 7285 <- (0,14339)
[0] 7286 <- (0,14340)
[0] 7287 <- (0,14341)
[0] 7288 <- (0,14342)
[0] 7289 <- (0,14343)
[0] 7290 <- (0,14344)
[0] 7291 <- (0,14345)
[0] 7292 <- (0,14346)
[0] 7293 <- (0,14347)
[0] 7294 <- (0,14348)
[0] 7295 <- (0,14349)
[0] 7296 <- (0,14350)
[0] 7297 <- (0,14351)
[0] 7298 <- (0,14352)
[0] 7299 <- (0,14353)
[0] 7300 <- (0,14354)
[0] 7301 <- (0,14355)
[0] 7302 <- (0,14356)
[0] 7303 <- (0,14386)
[0] 7304 <- (0,14387)
[0] 7305 <- (0,14388)
[0] 7306 <- (0,14389)
[0] 7307 <- (0,14390)
[0] 7308 <- (0,14391)
[0] 7309 <- (0,14392)
[0] 7310 <- (0,14393)
[0] 7311 <- (0,14394)
[0] 7312 <- (0,14395)
[0] 7313 <- (0,14396)
[0] 7314 <- (0,14397)
[0] 7315 <- (0,14398)
[0] 7316 <- (0,14399)
[0] 7317 <- (0,14400)
[0] 7318 <- (0,14401)
[0] 7319 <- (0,14402)
[0] 7320 <- (0,14403)
[0] 7321 <- (0,14404)
[0] 7322 <- (0,14405)
[0] 7323 <- (0,14406)
[0] 7324 <- (0,14407)
[0] 7325 <- (0,14437)
[0] 7326 <- (0,14438)
[0] 7327 <- (0,14439)
[0] 7328 <- (0,14440)
[0] 7329 <- (0,14441)
[0] 7330 <- (0,14442)
[0] 7331 <- (0,14443)
[0] 7332 <- (0,14444)
[0] 7333 <- (0,14445)
[0] 7334 <- (0,14446)
[0] 7335 <- (0,14447)
[0] 7336 <- (0,14448)
[0] 7337 <- (0,14449)
[0] 7338 <- (0,14450)
[0] 7339 <- (0,14451)
[0] 7340 <- (0,14452)
[0] 7341 <- (0,14453)
[0] 7342 <- (0,14454)
[0] 7343 <- (0,14455)
[0] 7344 <- (0,14456)
[0] 7345 <- (0,14457)
[0] 7346 <- (0,14458)
[0] 7347 <- (0,14488)
[0] 7348 <- (0,14489)
[0] 7349 <- (0,14490)
[0] 7350 <- (0,14491)
[0] 7351 <- (0,14492)
[0] 7352 <- (0,14493)
[0] 7353 <- (0,14494)
[0] 7354 <- (0,14495)
[0] 7355 <- (0,14496)
[0] 7356 <- (0,14497)
[0] 7357 <- (0,14498)
[0] 7358 <- (0,14499)
[0] 7359 <- (0,14500)
[0] 7360 <- (0,14501)
[0] 7361 <- (0,14502)
[0] 7362 <- (0,14503)
[0] 7363 <- (0,14504)
[0] 7364 <- (0,14505)
[0] 7365 <- (0,14506)
[0] 7366 <- (0,14507)
[0] 7367 <- (0,14508)
[0] 7368 <- (0,14509)
[0] 7369 <- (0,14539)
[0] 7370 <- (0,14540)
[0] 7371 <- (0,14541)
[0] 7372 <- (0,14542)
[0] 7373 <- (0,14543)
[0] 7374 <- (0,14544)
[0] 7375 <- (0,14545)
[0] 7376 <- (0,14546)
[0] 7377 <- (0,14547)
[0] 7378 <- (0,14548)
[0] 7379 <- (0,14549)
[0] 7380 <- (0,14550)
[0] 7381 <- (0,14551)
[0] 7382 <- (0,14552)
[0] 7383 <- (0,14553)
[0] 7384 <- (0,14554)
[0] 7385 <- (0,14555)
[0] 7386 <- (0,14556)
[0] 7387 <- (0,14557)
[0] 7388 <- (0,14558)
[0] 7389 <- (0,14559)
[0] 7390 <- (0,14560)
[0] 7391 <- (0,14561)
[0] 7392 <- (0,14590)
[0] 7393 <- (0,14591)
[0] 7394 <- (0,14592)
[0] 7395 <- (0,14593)
[0] 7396 <- (0,14594)
[0] 7397 <- (0,14595)
[0] 7398 <- (0,14596)
[0] 7399 <- (0,14597)
[0] 7400 <- (0,14598)
[0] 7401 <- (0,14599)
[0] 7402 <- (0,14600)
[0] 7403 <- (0,14601)
[0] 7404 <- (0,14602)
[0] 7405 <- (0,14603)
[0] 7406 <- (0,14604)
[0] 7407 <- (0,14605)
[0] 7408 <- (0,14606)
[0] 7409 <- (0,14607)
[0] 7410 <- (0,14608)
[0] 7411 <- (0,14609)
[0] 7412 <- (0,14610)
[0] 7413 <- (0,14611)
[0] 7414 <- (0,14612)
[0] 7415 <- (0,14641)
[0] 7416 <- (0,14642)
[0] 7417 <- (0,14643)
[0] 7418 <- (0,14644)
[0] 7419 <- (0,14645)
[0] 7420 <- (0,14646)
[0] 7421 <- (0,14647)
[0] 7422 <- (0,14648)
[0] 7423 <- (0,14649)
[0] 7424 <- (0,14650)
[0] 7425 <- (0,14651)
[0] 7426 <- (0,14652)
[0] 7427 <- (0,14653)
[0] 7428 <- (0,14654)
[0] 7429 <- (0,14655)
[0] 7430 <- (0,14656)
[0] 7431 <- (0,14657)
[0] 7432 <- (0,14658)
[0] 7433 <- (0,14659)
[0] 7434 <- (0,14660)
[0] 7435 <- (0,14661)
[0] 7436 <- (0,14662)
[0] 7437 <- (0,14663)
[0] 7438 <- (0,14692)
[0] 7439 <- (0,14693)
[0] 7440 <- (0,14694)
[0] 7441 <- (0,14695)
[0] 7442 <- (0,14696)
[0] 7443 <- (0,14697)
[0] 7444 <- (0,14698)
[0] 7445 <- (0,14699)
[0] 7446 <- (0,14700)
[0] 7447 <- (0,14701)
[0] 7448 <- (0,14702)
[0] 7449 <- (0,14703)
[0] 7450 <- (0,14704)
[0] 7451 <- (0,14705)
[0] 7452 <- (0,14706)
[0] 7453 <- (0,14707)
[0] 7454 <- (0,14708)
[0] 7455 <- (0,14709)
[0] 7456 <- (0,14710)
[0] 7457 <- (0,14711)
[0] 7458 <- (0,14712)
[0] 7459 <- (0,14713)
[0] 7460 <- (0,14714)
[0] 7461 <- (0,14743)
[0] 7462 <- (0,14744)
[0] 7463 <- (0,14745)
[0] 7464 <- (0,14746)
[0] 7465 <- (0,14747)
[0] 7466 <- (0,14748)
[0] 7467 <- (0,14749)
[0] 7468 <- (0,14750)
[0] 7469 <- (0,14751)
[0] 7470 <- (0,14752)
[0] 7471 <- (0,14753)
[0] 7472 <- (0,14754)
[0] 7473 <- (0,14755)
[0] 7474 <- (0,14756)
[0] 7475 <- (0,14757)
[0] 7476 <- (0,14758)
[0] 7477 <- (0,14759)
[0] 7478 <- (0,14760)
[0] 7479 <- (0,14761)
[0] 7480 <- (0,14762)
[0] 7481 <- (0,14763)
[0] 7482 <- (0,14764)
[0] 7483 <- (0,14765)
[0] 7484 <- (0,14766)
[0] 7485 <- (0,14794)
[0] 7486 <- (0,14795)
[0] 7487 <- (0,14796)
[0] 7488 <- (0,14797)
[0] 7489 <- (0,14798)
[0] 7490 <- (0,14799)
[0] 7491 <- (0,14800)
[0] 7492 <- (0,14801)
[0] 7493 <- (0,14802)
[0] 7494 <- (0,14803)
[0] 7495 <- (0,14804)
[0] 7496 <- (0,14805)
[0] 7497 <- (0,14806)
[0] 7498 <- (0,14807)
[0] 7499 <- (0,14808)
[0] 7500 <- (0,14809)
[0] 7501 <- (0,14810)
[0] 7502 <- (0,14811)
[0] 7503 <- (0,14812)
[0] 7504 <- (0,14813)
[0] 7505 <- (0,14814)
[0] 7506 <- (0,14815)
[0] 7507 <- (0,14816)
[0] 7508 <- (0,14817)
[0] 7509 <- (0,14845)
[0] 7510 <- (0,14846)
[0] 7511 <- (0,14847)
[0] 7512 <- (0,14848)
[0] 7513 <- (0,14849)
[0] 7514 <- (0,14850)
[0] 7515 <- (0,14851)
[0] 7516 <- (0,14852)
[0] 7517 <- (0,14853)
[0] 7518 <- (0,14854)
[0] 7519 <- (0,14855)
[0] 7520 <- (0,14856)
[0] 7521 <- (0,14857)
[0] 7522 <- (0,14858)
[0] 7523 <- (0,14859)
[0] 7524 <- (0,14860)
[0] 7525 <- (0,14861)
[0] 7526 <- (0,14862)
[0] 7527 <- (0,14863)
[0] 7528 <- (0,14864)
[0] 7529 <- (0,14865)
[0] 7530 <- (0,14866)
[0] 7531 <- (0,14867)
[0] 7532 <- (0,14868)
[0] 7533 <- (0,14869)
[0] 7534 <- (0,14896)
[0] 7535 <- (0,14897)
[0] 7536 <- (0,14898)
[0] 7537 <- (0,14899)
[0] 7538 <- (0,14900)
[0] 7539 <- (0,14901)
[0] 7540 <- (0,14902)
[0] 7541 <- (0,14903)
[0] 7542 <- (0,14904)
[0] 7543 <- (0,14905)
[0] 7544 <- (0,14906)
[0] 7545 <- (0,14907)
[0] 7546 <- (0,14908)
[0] 7547 <- (0,14909)
[0] 7548 <- (0,14910)
[0] 7549 <- (0,14911)
[0] 7550 <- (0,14912)
[0] 7551 <- (0,14913)
[0] 7552 <- (0,14914)
[0] 7553 <- (0,14915)
[0] 7554 <- (0,14916)
[0] 7555 <- (0,14917)
[0] 7556 <- (0,14918)
[0] 7557 <- (0,14919)
[0] 7558 <- (0,14920)
[0] 7559 <- (0,14921)
[0] 7560 <- (0,14947)
[0] 7561 <- (0,14948)
[0] 7562 <- (0,14949)
[0] 7563 <- (0,14950)
[0] 7564 <- (0,14951)
[0] 7565 <- (0,14952)
[0] 7566 <- (0,14953)
[0] 7567 <- (0,14954)
[0] 7568 <- (0,14955)
[0] 7569 <- (0,14956)
[0] 7570 <- (0,14957)
[0] 7571 <- (0,14958)
[0] 7572 <- (0,14959)
[0] 7573 <- (0,14960)
[0] 7574 <- (0,14961)
[0] 7575 <- (0,14962)
[0] 7576 <- (0,14963)
[0] 7577 <- (0,14964)
[0] 7578 <- (0,14965)
[0] 7579 <- (0,14966)
[0] 7580 <- (0,14967)
[0] 7581 <- (0,14968)
[0] 7582 <- (0,14969)
[0] 7583 <- (0,14970)
[0] 7584 <- (0,14971)
[0] 7585 <- (0,14972)
[0] 7586 <- (0,14998)
[0] 7587 <- (0,14999)
[0] 7588 <- (0,15000)
[0] 7589 <- (0,15001)
[0] 7590 <- (0,15002)
[0] 7591 <- (0,15003)
[0] 7592 <- (0,15004)
[0] 7593 <- (0,15005)
[0] 7594 <- (0,15006)
[0] 7595 <- (0,15007)
[0] 7596 <- (0,15008)
[0] 7597 <- (0,15009)
[0] 7598 <- (0,15010)
[0] 7599 <- (0,15011)
[0] 7600 <- (0,15012)
[0] 7601 <- (0,15013)
[0] 7602 <- (0,15014)
[0] 7603 <- (0,15015)
[0] 7604 <- (0,15016)
[0] 7605 <- (0,15017)
[0] 7606 <- (0,15018)
[0] 7607 <- (0,15019)
[0] 7608 <- (0,15020)
[0] 7609 <- (0,15021)
[0] 7610 <- (0,15022)
[0] 7611 <- (0,15023)
[0] 7612 <- (0,15024)
[0] 7613 <- (0,15049)
[0] 7614 <- (0,15050)
[0] 7615 <- (0,15051)
[0] 7616 <- (0,15052)
[0] 7617 <- (0,15053)
[0] 7618 <- (0,15054)
[0] 7619 <- (0,15055)
[0] 7620 <- (0,15056)
[0] 7621 <- (0,15057)
[0] 7622 <- (0,15058)
[0] 7623 <- (0,15059)
[0] 7624 <- (0,15060)
[0] 7625 <- (0,15061)
[0] 7626 <- (0,15062)
[0] 7627 <- (0,15063)
[0] 7628 <- (0,15064)
[0] 7629 <- (0,15065)
[0] 7630 <- (0,15066)
[0] 7631 <- (0,15067)
[0] 7632 <- (0,15068)
[0] 7633 <- (0,15069)
[0] 7634 <- (0,15070)
[0] 7635 <- (0,15071)
[0] 7636 <- (0,15072)
[0] 7637 <- (0,15073)
[0] 7638 <- (0,15074)
[0] 7639 <- (0,15075)
[0] 7640 <- (0,15100)
[0] 7641 <- (0,15101)
[0] 7642 <- (0,15102)
[0] 7643 <- (0,15103)
[0] 7644 <- (0,15104)
[0] 7645 <- (0,15105)
[0] 7646 <- (0,15106)
[0] 7647 <- (0,15107)
[0] 7648 <- (0,15108)
[0] 7649 <- (0,15109)
[0] 7650 <- (0,15110)
[0] 7651 <- (0,15111)
[0] 7652 <- (0,15112)
[0] 7653 <- (0,15113)
[0] 7654 <- (0,15114)
[0] 7655 <- (0,15115)
[0] 7656 <- (0,15116)
[0] 7657 <- (0,15117)
[0] 7658 <- (0,15118)
[0] 7659 <- (0,15119)
[0] 7660 <- (0,15120)
[0] 7661 <- (0,15121)
[0] 7662 <- (0,15122)
[0] 7663 <- (0,15123)
[0] 7664 <- (0,15124)
[0] 7665 <- (0,15125)
[0] 7666 <- (0,15126)
[0] 7667 <- (0,15151)
[0] 7668 <- (0,15152)
[0] 7669 <- (0,15153)
[0] 7670 <- (0,15154)
[0] 7671 <- (0,15155)
[0] 7672 <- (0,15156)
[0] 7673 <- (0,15157)
[0] 7674 <- (0,15158)
[0] 7675 <- (0,15159)
[0] 7676 <- (0,15160)
[0] 7677 <- (0,15161)
[0] 7678 <- (0,15162)
[0] 7679 <- (0,15163)
[0] 7680 <- (0,15164)
[0] 7681 <- (0,15165)
[0] 7682 <- (0,15166)
[0] 7683 <- (0,15167)
[0] 7684 <- (0,15168)
[0] 7685 <- (0,15169)
[0] 7686 <- (0,15170)
[0] 7687 <- (0,15171)
[0] 7688 <- (0,15172)
[0] 7689 <- (0,15173)
[0] 7690 <- (0,15174)
[0] 7691 <- (0,15175)
[0] 7692 <- (0,15176)
[0] 7693 <- (0,15177)
[0] 7694 <- (0,15202)
[0] 7695 <- (0,15203)
[0] 7696 <- (0,15204)
[0] 7697 <- (0,15205)
[0] 7698 <- (0,15206)
[0] 7699 <- (0,15207)
[0] 7700 <- (0,15208)
[0] 7701 <- (0,15209)
[0] 7702 <- (0,15210)
[0] 7703 <- (0,15211)
[0] 7704 <- (0,15212)
[0] 7705 <- (0,15213)
[0] 7706 <- (0,15214)
[0] 7707 <- (0,15215)
[0] 7708 <- (0,15216)
[0] 7709 <- (0,15217)
[0] 7710 <- (0,15218)
[0] 7711 <- (0,15219)
[0] 7712 <- (0,15220)
[0] 7713 <- (0,15221)
[0] 7714 <- (0,15222)
[0] 7715 <- (0,15223)
[0] 7716 <- (0,15224)
[0] 7717 <- (0,15225)
[0] 7718 <- (0,15226)
[0] 7719 <- (0,15227)
[0] 7720 <- (0,15228)
[0] 7721 <- (0,15253)
[0] 7722 <- (0,15254)
[0] 7723 <- (0,15255)
[0] 7724 <- (0,15256)
[0] 7725 <- (0,15257)
[0] 7726 <- (0,15258)
[0] 7727 <- (0,15259)
[0] 7728 <- (0,15260)
[0] 7729 <- (0,15261)
[0] 7730 <- (0,15262)
[0] 7731 <- (0,15263)
[0] 7732 <- (0,15264)
[0] 7733 <- (0,15265)
[0] 7734 <- (0,15266)
[0] 7735 <- (0,15267)
[0] 7736 <- (0,15268)
[0] 7737 <- (0,15269)
[0] 7738 <- (0,15270)
[0] 7739 <- (0,15271)
[0] 7740 <- (0,15272)
[0] 7741 <- (0,15273)
[0] 7742 <- (0,15274)
[0] 7743 <- (0,15275)
[0] 7744 <- (0,15276)
[0] 7745 <- (0,15277)
[0] 7746 <- (0,15278)
[0] 7747 <- (0,15279)
[0] 7748 <- (0,15304)
[0] 7749 <- (0,15305)
[0] 7750 <- (0,15306)
[0] 7751 <- (0,15307)
[0] 7752 <- (0,15308)
[0] 7753 <- (0,15309)
[0] 7754 <- (0,15310)
[0] 7755 <- (0,15311)
[0] 7756 <- (0,15312)
[0] 7757 <- (0,15313)
[0] 7758 <- (0,15314)
[0] 7759 <- (0,15315)
[0] 7760 <- (0,15316)
[0] 7761 <- (0,15317)
[0] 7762 <- (0,15318)
[0] 7763 <- (0,15319)
[0] 7764 <- (0,15320)
[0] 7765 <- (0,15321)
[0] 7766 <- (0,15322)
[0] 7767 <- (0,15323)
[0] 7768 <- (0,15324)
[0] 7769 <- (0,15325)
[0] 7770 <- (0,15326)
[0] 7771 <- (0,15327)
[0] 7772 <- (0,15328)
[0] 7773 <- (0,15329)
[0] 7774 <- (0,15330)
[0] 7775 <- (0,15355)
[0] 7776 <- (0,15356)
[0] 7777 <- (0,15357)
[0] 7778 <- (0,15358)
[0] 7779 <- (0,15359)
[0] 7780 <- (0,15360)
[0] 7781 <- (0,15361)
[0] 7782 <- (0,15362)
[0] 7783 <- (0,15363)
[0] 7784 <- (0,15364)
[0] 7785 <- (0,15365)
[0] 7786 <- (0,15366)
[0] 7787 <- (0,15367)
[0] 7788 <- (0,15368)
[0] 7789 <- (0,15369)
[0] 7790 <- (0,15370)
[0] 7791 <- (0,15371)
[0] 7792 <- (0,15372)
[0] 7793 <- (0,15373)
[0] 7794 <- (0,15374)
[0] 7795 <- (0,15375)
[0] 7796 <- (0,15376)
[0] 7797 <- (0,15406)
[0] 7798 <- (0,15407)
[0] 7799 <- (0,15408)
[0] 7800 <- (0,15409)
[0] 7801 <- (0,15410)
[0] 7802 <- (0,15411)
[0] 7803 <- (0,15412)
[0] 7804 <- (0,15413)
[0] 7805 <- (0,15414)
[0] 7806 <- (0,15415)
[0] 7807 <- (0,15416)
[0] 7808 <- (0,15417)
[0] 7809 <- (0,15418)
[0] 7810 <- (0,15419)
[0] 7811 <- (0,15420)
[0] 7812 <- (0,15421)
[0] 7813 <- (0,15422)
[0] 7814 <- (0,15423)
[0] 7815 <- (0,15424)
[0] 7816 <- (0,15425)
[0] 7817 <- (0,15426)
[0] 7818 <- (0,15427)
[0] 7819 <- (0,15457)
[0] 7820 <- (0,15458)
[0] 7821 <- (0,15459)
[0] 7822 <- (0,15460)
[0] 7823 <- (0,15461)
[0] 7824 <- (0,15462)
[0] 7825 <- (0,15463)
[0] 7826 <- (0,15464)
[0] 7827 <- (0,15465)
[0] 7828 <- (0,15466)
[0] 7829 <- (0,15467)
[0] 7830 <- (0,15468)
[0] 7831 <- (0,15469)
[0] 7832 <- (0,15470)
[0] 7833 <- (0,15471)
[0] 7834 <- (0,15472)
[0] 7835 <- (0,15473)
[0] 7836 <- (0,15474)
[0] 7837 <- (0,15475)
[0] 7838 <- (0,15476)
[0] 7839 <- (0,15477)
[0] 7840 <- (0,15478)
[0] 7841 <- (0,15508)
[0] 7842 <- (0,15509)
[0] 7843 <- (0,15510)
[0] 7844 <- (0,15511)
[0] 7845 <- (0,15512)
[0] 7846 <- (0,15513)
[0] 7847 <- (0,15514)
[0] 7848 <- (0,15515)
[0] 7849 <- (0,15516)
[0] 7850 <- (0,15517)
[0] 7851 <- (0,15518)
[0] 7852 <- (0,15519)
[0] 7853 <- (0,15520)
[0] 7854 <- (0,15521)
[0] 7855 <- (0,15522)
[0] 7856 <- (0,15523)
[0] 7857 <- (0,15524)
[0] 7858 <- (0,15525)
[0] 7859 <- (0,15526)
[0] 7860 <- (0,15527)
[0] 7861 <- (0,15528)
[0] 7862 <- (0,15529)
[0] 7863 <- (0,15559)
[0] 7864 <- (0,15560)
[0] 7865 <- (0,15561)
[0] 7866 <- (0,15562)
[0] 7867 <- (0,15563)
[0] 7868 <- (0,15564)
[0] 7869 <- (0,15565)
[0] 7870 <- (0,15566)
[0] 7871 <- (0,15567)
[0] 7872 <- (0,15568)
[0] 7873 <- (0,15569)
[0] 7874 <- (0,15570)
[0] 7875 <- (0,15571)
[0] 7876 <- (0,15572)
[0] 7877 <- (0,15573)
[0] 7878 <- (0,15574)
[0] 7879 <- (0,15575)
[0] 7880 <- (0,15576)
[0] 7881 <- (0,15577)
[0] 7882 <- (0,15578)
[0] 7883 <- (0,15579)
[0] 7884 <- (0,15580)
[0] 7885 <- (0,15610)
[0] 7886 <- (0,15611)
[0] 7887 <- (0,15612)
[0] 7888 <- (0,15613)
[0] 7889 <- (0,15614)
[0] 7890 <- (0,15615)
[0] 7891 <- (0,15616)
[0] 7892 <- (0,15617)
[0] 7893 <- (0,15618)
[0] 7894 <- (0,15619)
[0] 7895 <- (0,15620)
[0] 7896 <- (0,15621)
[0] 7897 <- (0,15622)
[0] 7898 <- (0,15623)
[0] 7899 <- (0,15624)
[0] 7900 <- (0,15625)
[0] 7901 <- (0,15626)
[0] 7902 <- (0,15627)
[0] 7903 <- (0,15628)
[0] 7904 <- (0,15629)
[0] 7905 <- (0,15630)
[0] 7906 <- (0,15631)
[0] 7907 <- (0,15632)
[0] 7908 <- (0,15661)
[0] 7909 <- (0,15662)
[0] 7910 <- (0,15663)
[0] 7911 <- (0,15664)
[0] 7912 <- (0,15665)
[0] 7913 <- (0,15666)
[0] 7914 <- (0,15667)
[0] 7915 <- (0,15668)
[0] 7916 <- (0,15669)
[0] 7917 <- (0,15670)
[0] 7918 <- (0,15671)
[0] 7919 <- (0,15672)
[0] 7920 <- (0,15673)
[0] 7921 <- (0,15674)
[0] 7922 <- (0,15675)
[0] 7923 <- (0,15676)
[0] 7924 <- (0,15677)
[0] 7925 <- (0,15678)
[0] 7926 <- (0,15679)
[0] 7927 <- (0,15680)
[0] 7928 <- (0,15681)
[0] 7929 <- (0,15682)
[0] 7930 <- (0,15683)
[0] 7931 <- (0,15712)
[0] 7932 <- (0,15713)
[0] 7933 <- (0,15714)
[0] 7934 <- (0,15715)
[0] 7935 <- (0,15716)
[0] 7936 <- (0,15717)
[0] 7937 <- (0,15718)
[0] 7938 <- (0,15719)
[0] 7939 <- (0,15720)
[0] 7940 <- (0,15721)
[0] 7941 <- (0,15722)
[0] 7942 <- (0,15723)
[0] 7943 <- (0,15724)
[0] 7944 <- (0,15725)
[0] 7945 <- (0,15726)
[0] 7946 <- (0,15727)
[0] 7947 <- (0,15728)
[0] 7948 <- (0,15729)
[0] 7949 <- (0,15730)
[0] 7950 <- (0,15731)
[0] 7951 <- (0,15732)
[0] 7952 <- (0,15733)
[0] 7953 <- (0,15734)
[0] 7954 <- (0,15763)
[0] 7955 <- (0,15764)
[0] 7956 <- (0,15765)
[0] 7957 <- (0,15766)
[0] 7958 <- (0,15767)
[0] 7959 <- (0,15768)
[0] 7960 <- (0,15769)
[0] 7961 <- (0,15770)
[0] 7962 <- (0,15771)
[0] 7963 <- (0,15772)
[0] 7964 <- (0,15773)
[0] 7965 <- (0,15774)
[0] 7966 <- (0,15775)
[0] 7967 <- (0,15776)
[0] 7968 <- (0,15777)
[0] 7969 <- (0,15778)
[0] 7970 <- (0,15779)
[0] 7971 <- (0,15780)
[0] 7972 <- (0,15781)
[0] 7973 <- (0,15782)
[0] 7974 <- (0,15783)
[0] 7975 <- (0,15784)
[0] 7976 <- (0,15785)
[0] 7977 <- (0,15814)
[0] 7978 <- (0,15815)
[0] 7979 <- (0,15816)
[0] 7980 <- (0,15817)
[0] 7981 <- (0,15818)
[0] 7982 <- (0,15819)
[0] 7983 <- (0,15820)
[0] 7984 <- (0,15821)
[0] 7985 <- (0,15822)
[0] 7986 <- (0,15823)
[0] 7987 <- (0,15824)
[0] 7988 <- (0,15825)
[0] 7989 <- (0,15826)
[0] 7990 <- (0,15827)
[0] 7991 <- (0,15828)
[0] 7992 <- (0,15829)
[0] 7993 <- (0,15830)
[0] 7994 <- (0,15831)
[0] 7995 <- (0,15832)
[0] 7996 <- (0,15833)
[0] 7997 <- (0,15834)
[0] 7998 <- (0,15835)
[0] 7999 <- (0,15836)
[0] 8000 <- (0,15837)
[0] 8001 <- (0,15865)
[0] 8002 <- (0,15866)
[0] 8003 <- (0,15867)
[0] 8004 <- (0,15868)
[0] 8005 <- (0,15869)
[0] 8006 <- (0,15870)
[0] 8007 <- (0,15871)
[0] 8008 <- (0,15872)
[0] 8009 <- (0,15873)
[0] 8010 <- (0,15874)
[0] 8011 <- (0,15875)
[0] 8012 <- (0,15876)
[0] 8013 <- (0,15877)
[0] 8014 <- (0,15878)
[0] 8015 <- (0,15879)
[0] 8016 <- (0,15880)
[0] 8017 <- (0,15881)
[0] 8018 <- (0,15882)
[0] 8019 <- (0,15883)
[0] 8020 <- (0,15884)
[0] 8021 <- (0,15885)
[0] 8022 <- (0,15886)
[0] 8023 <- (0,15887)
[0] 8024 <- (0,15888)
[0] 8025 <- (0,15916)
[0] 8026 <- (0,15917)
[0] 8027 <- (0,15918)
[0] 8028 <- (0,15919)
[0] 8029 <- (0,15920)
[0] 8030 <- (0,15921)
[0] 8031 <- (0,15922)
[0] 8032 <- (0,15923)
[0] 8033 <- (0,15924)
[0] 8034 <- (0,15925)
[0] 8035 <- (0,15926)
[0] 8036 <- (0,15927)
[0] 8037 <- (0,15928)
[0] 8038 <- (0,15929)
[0] 8039 <- (0,15930)
[0] 8040 <- (0,15931)
[0] 8041 <- (0,15932)
[0] 8042 <- (0,15933)
[0] 8043 <- (0,15934)
[0] 8044 <- (0,15935)
[0] 8045 <- (0,15936)
[0] 8046 <- (0,15937)
[0] 8047 <- (0,15938)
[0] 8048 <- (0,15939)
[0] 8049 <- (0,15940)
[0] 8050 <- (0,15967)
[0] 8051 <- (0,15968)
[0] 8052 <- (0,15969)
[0] 8053 <- (0,15970)
[0] 8054 <- (0,15971)
[0] 8055 <- (0,15972)
[0] 8056 <- (0,15973)
[0] 8057 <- (0,15974)
[0] 8058 <- (0,15975)
[0] 8059 <- (0,15976)
[0] 8060 <- (0,15977)
[0] 8061 <- (0,15978)
[0] 8062 <- (0,15979)
[0] 8063 <- (0,15980)
[0] 8064 <- (0,15981)
[0] 8065 <- (0,15982)
[0] 8066 <- (0,15983)
[0] 8067 <- (0,15984)
[0] 8068 <- (0,15985)
[0] 8069 <- (0,15986)
[0] 8070 <- (0,15987)
[0] 8071 <- (0,15988)
[0] 8072 <- (0,15989)
[0] 8073 <- (0,15990)
[0] 8074 <- (0,15991)
[0] 8075 <- (0,15992)
[0] 8076 <- (0,16018)
[0] 8077 <- (0,16019)
[0] 8078 <- (0,16020)
[0] 8079 <- (0,16021)
[0] 8080 <- (0,16022)
[0] 8081 <- (0,16023)
[0] 8082 <- (0,16024)
[0] 8083 <- (0,16025)
[0] 8084 <- (0,16026)
[0] 8085 <- (0,16027)
[0] 8086 <- (0,16028)
[0] 8087 <- (0,16029)
[0] 8088 <- (0,16030)
[0] 8089 <- (0,16031)
[0] 8090 <- (0,16032)
[0] 8091 <- (0,16033)
[0] 8092 <- (0,16034)
[0] 8093 <- (0,16035)
[0] 8094 <- (0,16036)
[0] 8095 <- (0,16037)
[0] 8096 <- (0,16038)
[0] 8097 <- (0,16039)
[0] 8098 <- (0,16040)
[0] 8099 <- (0,16041)
[0] 8100 <- (0,16042)
[0] 8101 <- (0,16043)
[0] 8102 <- (0,16069)
[0] 8103 <- (0,16070)
[0] 8104 <- (0,16071)
[0] 8105 <- (0,16072)
[0] 8106 <- (0,16073)
[0] 8107 <- (0,16074)
[0] 8108 <- (0,16075)
[0] 8109 <- (0,16076)
[0] 8110 <- (0,16077)
[0] 8111 <- (0,16078)
[0] 8112 <- (0,16079)
[0] 8113 <- (0,16080)
[0] 8114 <- (0,16081)
[0] 8115 <- (0,16082)
[0] 8116 <- (0,16083)
[0] 8117 <- (0,16084)
[0] 8118 <- (0,16085)
[0] 8119 <- (0,16086)
[0] 8120 <- (0,16087)
[0] 8121 <- (0,16088)
[0] 8122 <- (0,16089)
[0] 8123 <- (0,16090)
[0] 8124 <- (0,16091)
[0] 8125 <- (0,16092)
[0] 8126 <- (0,16093)
[0] 8127 <- (0,16094)
[0] 8128 <- (0,16095)
[0] 8129 <- (0,16120)
[0] 8130 <- (0,16121)
[0] 8131 <- (0,16122)
[0] 8132 <- (0,16123)
[0] 8133 <- (0,16124)
[0] 8134 <- (0,16125)
[0] 8135 <- (0,16126)
[0] 8136 <- (0,16127)
[0] 8137 <- (0,16128)
[0] 8138 <- (0,16129)
[0] 8139 <- (0,16130)
[0] 8140 <- (0,16131)
[0] 8141 <- (0,16132)
[0] 8142 <- (0,16133)
[0] 8143 <- (0,16134)
[0] 8144 <- (0,16135)
[0] 8145 <- (0,16136)
[0] 8146 <- (0,16137)
[0] 8147 <- (0,16138)
[0] 8148 <- (0,16139)
[0] 8149 <- (0,16140)
[0] 8150 <- (0,16141)
[0] 8151 <- (0,16142)
[0] 8152 <- (0,16143)
[0] 8153 <- (0,16144)
[0] 8154 <- (0,16145)
[0] 8155 <- (0,16146)
[0] 8156 <- (0,16171)
[0] 8157 <- (0,16172)
[0] 8158 <- (0,16173)
[0] 8159 <- (0,16174)
[0] 8160 <- (0,16175)
[0] 8161 <- (0,16176)
[0] 8162 <- (0,16177)
[0] 8163 <- (0,16178)
[0] 8164 <- (0,16179)
[0] 8165 <- (0,16180)
[0] 8166 <- (0,16181)
[0] 8167 <- (0,16182)
[0] 8168 <- (0,16183)
[0] 8169 <- (0,16184)
[0] 8170 <- (0,16185)
[0] 8171 <- (0,16186)
[0] 8172 <- (0,16187)
[0] 8173 <- (0,16188)
[0] 8174 <- (0,16189)
[0] 8175 <- (0,16190)
[0] 8176 <- (0,16191)
[0] 8177 <- (0,16192)
[0] 8178 <- (0,16193)
[0] 8179 <- (0,16194)
[0] 8180 <- (0,16195)
[0] 8181 <- (0,16196)
[0] 8182 <- (0,16197)
[0] 8183 <- (0,16222)
[0] 8184 <- (0,16223)
[0] 8185 <- (0,16224)
[0] 8186 <- (0,16225)
[0] 8187 <- (0,16226)
[0] 8188 <- (0,16227)
[0] 8189 <- (0,16228)
[0] 8190 <- (0,16229)
[0] 8191 <- (0,16230)
[0] 8192 <- (0,16231)
[0] 8193 <- (0,16232)
[0] 8194 <- (0,16233)
[0] 8195 <- (0,16234)
[0] 8196 <- (0,16235)
[0] 8197 <- (0,16236)
[0] 8198 <- (0,16237)
[0] 8199 <- (0,16238)
[0] 8200 <- (0,16239)
[0] 8201 <- (0,16240)
[0] 8202 <- (0,16241)
[0] 8203 <- (0,16242)
[0] 8204 <- (0,16243)
[0] 8205 <- (0,16244)
[0] 8206 <- (0,16245)
[0] 8207 <- (0,16246)
[0] 8208 <- (0,16247)
[0] 8209 <- (0,16248)
[0] 8210 <- (0,16273)
[0] 8211 <- (0,16274)
[0] 8212 <- (0,16275)
[0] 8213 <- (0,16276)
[0] 8214 <- (0,16277)
[0] 8215 <- (0,16278)
[0] 8216 <- (0,16279)
[0] 8217 <- (0,16280)
[0] 8218 <- (0,16281)
[0] 8219 <- (0,16282)
[0] 8220 <- (0,16283)
[0] 8221 <- (0,16284)
[0] 8222 <- (0,16285)
[0] 8223 <- (0,16286)
[0] 8224 <- (0,16287)
[0] 8225 <- (0,16288)
[0] 8226 <- (0,16289)
[0] 8227 <- (0,16290)
[0] 8228 <- (0,16291)
[0] 8229 <- (0,16292)
[0] 8230 <- (0,16293)
[0] 8231 <- (0,16294)
[0] 8232 <- (0,16295)
[0] 8233 <- (0,16296)
[0] 8234 <- (0,16297)
[0] 8235 <- (0,16298)
[0] 8236 <- (0,16299)
[0] 8237 <- (0,16324)
[0] 8238 <- (0,16325)
[0] 8239 <- (0,16326)
[0] 8240 <- (0,16327)
[0] 8241 <- (0,16328)
[0] 8242 <- (0,16329)
[0] 8243 <- (0,16330)
[0] 8244 <- (0,16331)
[0] 8245 <- (0,16332)
[0] 8246 <- (0,16333)
[0] 8247 <- (0,16334)
[0] 8248 <- (0,16335)
[0] 8249 <- (0,16336)
[0] 8250 <- (0,16337)
[0] 8251 <- (0,16338)
[0] 8252 <- (0,16339)
[0] 8253 <- (0,16340)
[0] 8254 <- (0,16341)
[0] 8255 <- (0,16342)
[0] 8256 <- (0,16343)
[0] 8257 <- (0,16344)
[0] 8258 <- (0,16345)
[0] 8259 <- (0,16346)
[0] 8260 <- (0,16347)
[0] 8261 <- (0,16348)
[0] 8262 <- (0,16349)
[0] 8263 <- (0,16350)
[0] 8264 <- (0,16375)
[0] 8265 <- (0,16376)
[0] 8266 <- (0,16377)
[0] 8267 <- (0,16378)
[0] 8268 <- (0,16379)
[0] 8269 <- (0,16380)
[0] 8270 <- (0,16381)
[0] 8271 <- (0,16382)
[0] 8272 <- (0,16383)
[0] 8273 <- (0,16384)
[0] 8274 <- (0,16385)
[0] 8275 <- (0,16386)
[0] 8276 <- (0,16387)
[0] 8277 <- (0,16388)
[0] 8278 <- (0,16389)
[0] 8279 <- (0,16390)
[0] 8280 <- (0,16391)
[0] 8281 <- (0,16392)
[0] 8282 <- (0,16393)
[0] 8283 <- (0,16394)
[0] 8284 <- (0,16395)
[0] 8285 <- (0,16396)
[0] 8286 <- (0,16397)
[0] 8287 <- (0,16398)
[0] 8288 <- (0,16399)
[0] 8289 <- (0,16400)
[0] 8290 <- (0,16401)
[0] 8291 <- (0,16426)
[0] 8292 <- (0,16427)
[0] 8293 <- (0,16428)
[0] 8294 <- (0,16429)
[0] 8295 <- (0,16430)
[0] 8296 <- (0,16431)
[0] 8297 <- (0,16432)
[0] 8298 <- (0,16433)
[0] 8299 <- (0,16434)
[0] 8300 <- (0,16435)
[0] 8301 <- (0,16436)
[0] 8302 <- (0,16437)
[0] 8303 <- (0,16438)
[0] 8304 <- (0,16439)
[0] 8305 <- (0,16440)
[0] 8306 <- (0,16441)
[0] 8307 <- (0,16442)
[0] 8308 <- (0,16443)
[0] 8309 <- (0,16444)
[0] 8310 <- (0,16445)
[0] 8311 <- (0,16446)
[0] 8312 <- (0,16447)
[0] 8313 <- (0,16477)
[0] 8314 <- (0,16478)
[0] 8315 <- (0,16479)
[0] 8316 <- (0,16480)
[0] 8317 <- (0,16481)
[0] 8318 <- (0,16482)
[0] 8319 <- (0,16483)
[0] 8320 <- (0,16484)
[0] 8321 <- (0,16485)
[0] 8322 <- (0,16486)
[0] 8323 <- (0,16487)
[0] 8324 <- (0,16488)
[0] 8325 <- (0,16489)
[0] 8326 <- (0,16490)
[0] 8327 <- (0,16491)
[0] 8328 <- (0,16492)
[0] 8329 <- (0,16493)
[0] 8330 <- (0,16494)
[0] 8331 <- (0,16495)
[0] 8332 <- (0,16496)
[0] 8333 <- (0,16497)
[0] 8334 <- (0,16498)
[0] 8335 <- (0,16528)
[0] 8336 <- (0,16529)
[0] 8337 <- (0,16530)
[0] 8338 <- (0,16531)
[0] 8339 <- (0,16532)
[0] 8340 <- (0,16533)
[0] 8341 <- (0,16534)
[0] 8342 <- (0,16535)
[0] 8343 <- (0,16536)
[0] 8344 <- (0,16537)
[0] 8345 <- (0,16538)
[0] 8346 <- (0,16539)
[0] 8347 <- (0,16540)
[0] 8348 <- (0,16541)
[0] 8349 <- (0,16542)
[0] 8350 <- (0,16543)
[0] 8351 <- (0,16544)
[0] 8352 <- (0,16545)
[0] 8353 <- (0,16546)
[0] 8354 <- (0,16547)
[0] 8355 <- (0,16548)
[0] 8356 <- (0,16549)
[0] 8357 <- (0,16579)
[0] 8358 <- (0,16580)
[0] 8359 <- (0,16581)
[0] 8360 <- (0,16582)
[0] 8361 <- (0,16583)
[0] 8362 <- (0,16584)
[0] 8363 <- (0,16585)
[0] 8364 <- (0,16586)
[0] 8365 <- (0,16587)
[0] 8366 <- (0,16588)
[0] 8367 <- (0,16589)
[0] 8368 <- (0,16590)
[0] 8369 <- (0,16591)
[0] 8370 <- (0,16592)
[0] 8371 <- (0,16593)
[0] 8372 <- (0,16594)
[0] 8373 <- (0,16595)
[0] 8374 <- (0,16596)
[0] 8375 <- (0,16597)
[0] 8376 <- (0,16598)
[0] 8377 <- (0,16599)
[0] 8378 <- (0,16600)
[0] 8379 <- (0,16630)
[0] 8380 <- (0,16631)
[0] 8381 <- (0,16632)
[0] 8382 <- (0,16633)
[0] 8383 <- (0,16634)
[0] 8384 <- (0,16635)
[0] 8385 <- (0,16636)
[0] 8386 <- (0,16637)
[0] 8387 <- (0,16638)
[0] 8388 <- (0,16639)
[0] 8389 <- (0,16640)
[0] 8390 <- (0,16641)
[0] 8391 <- (0,16642)
[0] 8392 <- (0,16643)
[0] 8393 <- (0,16644)
[0] 8394 <- (0,16645)
[0] 8395 <- (0,16646)
[0] 8396 <- (0,16647)
[0] 8397 <- (0,16648)
[0] 8398 <- (0,16649)
[0] 8399 <- (0,16650)
[0] 8400 <- (0,16651)
[0] 8401 <- (0,16681)
[0] 8402 <- (0,16682)
[0] 8403 <- (0,16683)
[0] 8404 <- (0,16684)
[0] 8405 <- (0,16685)
[0] 8406 <- (0,16686)
[0] 8407 <- (0,16687)
[0] 8408 <- (0,16688)
[0] 8409 <- (0,16689)
[0] 8410 <- (0,16690)
[0] 8411 <- (0,16691)
[0] 8412 <- (0,16692)
[0] 8413 <- (0,16693)
[0] 8414 <- (0,16694)
[0] 8415 <- (0,16695)
[0] 8416 <- (0,16696)
[0] 8417 <- (0,16697)
[0] 8418 <- (0,16698)
[0] 8419 <- (0,16699)
[0] 8420 <- (0,16700)
[0] 8421 <- (0,16701)
[0] 8422 <- (0,16702)
[0] 8423 <- (0,16703)
[0] 8424 <- (0,16732)
[0] 8425 <- (0,16733)
[0] 8426 <- (0,16734)
[0] 8427 <- (0,16735)
[0] 8428 <- (0,16736)
[0] 8429 <- (0,16737)
[0] 8430 <- (0,16738)
[0] 8431 <- (0,16739)
[0] 8432 <- (0,16740)
[0] 8433 <- (0,16741)
[0] 8434 <- (0,16742)
[0] 8435 <- (0,16743)
[0] 8436 <- (0,16744)
[0] 8437 <- (0,16745)
[0] 8438 <- (0,16746)
[0] 8439 <- (0,16747)
[0] 8440 <- (0,16748)
[0] 8441 <- (0,16749)
[0] 8442 <- (0,16750)
[0] 8443 <- (0,16751)
[0] 8444 <- (0,16752)
[0] 8445 <- (0,16753)
[0] 8446 <- (0,16754)
[0] 8447 <- (0,16783)
[0] 8448 <- (0,16784)
[0] 8449 <- (0,16785)
[0] 8450 <- (0,16786)
[0] 8451 <- (0,16787)
[0] 8452 <- (0,16788)
[0] 8453 <- (0,16789)
[0] 8454 <- (0,16790)
[0] 8455 <- (0,16791)
[0] 8456 <- (0,16792)
[0] 8457 <- (0,16793)
[0] 8458 <- (0,16794)
[0] 8459 <- (0,16795)
[0] 8460 <- (0,16796)
[0] 8461 <- (0,16797)
[0] 8462 <- (0,16798)
[0] 8463 <- (0,16799)
[0] 8464 <- (0,16800)
[0] 8465 <- (0,16801)
[0] 8466 <- (0,16802)
[0] 8467 <- (0,16803)
[0] 8468 <- (0,16804)
[0] 8469 <- (0,16805)
[0] 8470 <- (0,16834)
[0] 8471 <- (0,16835)
[0] 8472 <- (0,16836)
[0] 8473 <- (0,16837)
[0] 8474 <- (0,16838)
[0] 8475 <- (0,16839)
[0] 8476 <- (0,16840)
[0] 8477 <- (0,16841)
[0] 8478 <- (0,16842)
[0] 8479 <- (0,16843)
[0] 8480 <- (0,16844)
[0] 8481 <- (0,16845)
[0] 8482 <- (0,16846)
[0] 8483 <- (0,16847)
[0] 8484 <- (0,16848)
[0] 8485 <- (0,16849)
[0] 8486 <- (0,16850)
[0] 8487 <- (0,16851)
[0] 8488 <- (0,16852)
[0] 8489 <- (0,16853)
[0] 8490 <- (0,16854)
[0] 8491 <- (0,16855)
[0] 8492 <- (0,16856)
[0] 8493 <- (0,16885)
[0] 8494 <- (0,16886)
[0] 8495 <- (0,16887)
[0] 8496 <- (0,16888)
[0] 8497 <- (0,16889)
[0] 8498 <- (0,16890)
[0] 8499 <- (0,16891)
[0] 8500 <- (0,16892)
[0] 8501 <- (0,16893)
[0] 8502 <- (0,16894)
[0] 8503 <- (0,16895)
[0] 8504 <- (0,16896)
[0] 8505 <- (0,16897)
[0] 8506 <- (0,16898)
[0] 8507 <- (0,16899)
[0] 8508 <- (0,16900)
[0] 8509 <- (0,16901)
[0] 8510 <- (0,16902)
[0] 8511 <- (0,16903)
[0] 8512 <- (0,16904)
[0] 8513 <- (0,16905)
[0] 8514 <- (0,16906)
[0] 8515 <- (0,16907)
[0] 8516 <- (0,16908)
[0] 8517 <- (0,16936)
[0] 8518 <- (0,16937)
[0] 8519 <- (0,16938)
[0] 8520 <- (0,16939)
[0] 8521 <- (0,16940)
[0] 8522 <- (0,16941)
[0] 8523 <- (0,16942)
[0] 8524 <- (0,16943)
[0] 8525 <- (0,16944)
[0] 8526 <- (0,16945)
[0] 8527 <- (0,16946)
[0] 8528 <- (0,16947)
[0] 8529 <- (0,16948)
[0] 8530 <- (0,16949)
[0] 8531 <- (0,16950)
[0] 8532 <- (0,16951)
[0] 8533 <- (0,16952)
[0] 8534 <- (0,16953)
[0] 8535 <- (0,16954)
[0] 8536 <- (0,16955)
[0] 8537 <- (0,16956)
[0] 8538 <- (0,16957)
[0] 8539 <- (0,16958)
[0] 8540 <- (0,16959)
[0] 8541 <- (0,16987)
[0] 8542 <- (0,16988)
[0] 8543 <- (0,16989)
[0] 8544 <- (0,16990)
[0] 8545 <- (0,16991)
[0] 8546 <- (0,16992)
[0] 8547 <- (0,16993)
[0] 8548 <- (0,16994)
[0] 8549 <- (0,16995)
[0] 8550 <- (0,16996)
[0] 8551 <- (0,16997)
[0] 8552 <- (0,16998)
[0] 8553 <- (0,16999)
[0] 8554 <- (0,17000)
[0] 8555 <- (0,17001)
[0] 8556 <- (0,17002)
[0] 8557 <- (0,17003)
[0] 8558 <- (0,17004)
[0] 8559 <- (0,17005)
[0] 8560 <- (0,17006)
[0] 8561 <- (0,17007)
[0] 8562 <- (0,17008)
[0] 8563 <- (0,17009)
[0] 8564 <- (0,17010)
[0] 8565 <- (0,17011)
[0] 8566 <- (0,17038)
[0] 8567 <- (0,17039)
[0] 8568 <- (0,17040)
[0] 8569 <- (0,17041)
[0] 8570 <- (0,17042)
[0] 8571 <- (0,17043)
[0] 8572 <- (0,17044)
[0] 8573 <- (0,17045)
[0] 8574 <- (0,17046)
[0] 8575 <- (0,17047)
[0] 8576 <- (0,17048)
[0] 8577 <- (0,17049)
[0] 8578 <- (0,17050)
[0] 8579 <- (0,17051)
[0] 8580 <- (0,17052)
[0] 8581 <- (0,17053)
[0] 8582 <- (0,17054)
[0] 8583 <- (0,17055)
[0] 8584 <- (0,17056)
[0] 8585 <- (0,17057)
[0] 8586 <- (0,17058)
[0] 8587 <- (0,17059)
[0] 8588 <- (0,17060)
[0] 8589 <- (0,17061)
[0] 8590 <- (0,17062)
[0] 8591 <- (0,17063)
[0] 8592 <- (0,17089)
[0] 8593 <- (0,17090)
[0] 8594 <- (0,17091)
[0] 8595 <- (0,17092)
[0] 8596 <- (0,17093)
[0] 8597 <- (0,17094)
[0] 8598 <- (0,17095)
[0] 8599 <- (0,17096)
[0] 8600 <- (0,17097)
[0] 8601 <- (0,17098)
[0] 8602 <- (0,17099)
[0] 8603 <- (0,17100)
[0] 8604 <- (0,17101)
[0] 8605 <- (0,17102)
[0] 8606 <- (0,17103)
[0] 8607 <- (0,17104)
[0] 8608 <- (0,17105)
[0] 8609 <- (0,17106)
[0] 8610 <- (0,17107)
[0] 8611 <- (0,17108)
[0] 8612 <- (0,17109)
[0] 8613 <- (0,17110)
[0] 8614 <- (0,17111)
[0] 8615 <- (0,17112)
[0] 8616 <- (0,17113)
[0] 8617 <- (0,17114)
[0] 8618 <- (0,17140)
[0] 8619 <- (0,17141)
[0] 8620 <- (0,17142)
[0] 8621 <- (0,17143)
[0] 8622 <- (0,17144)
[0] 8623 <- (0,17145)
[0] 8624 <- (0,17146)
[0] 8625 <- (0,17147)
[0] 8626 <- (0,17148)
[0] 8627 <- (0,17149)
[0] 8628 <- (0,17150)
[0] 8629 <- (0,17151)
[0] 8630 <- (0,17152)
[0] 8631 <- (0,17153)
[0] 8632 <- (0,17154)
[0] 8633 <- (0,17155)
[0] 8634 <- (0,17156)
[0] 8635 <- (0,17157)
[0] 8636 <- (0,17158)
[0] 8637 <- (0,17159)
[0] 8638 <- (0,17160)
[0] 8639 <- (0,17161)
[0] 8640 <- (0,17162)
[0] 8641 <- (0,17163)
[0] 8642 <- (0,17164)
[0] 8643 <- (0,17165)
[0] 8644 <- (0,17166)
[0] 8645 <- (0,17191)
[0] 8646 <- (0,17192)
[0] 8647 <- (0,17193)
[0] 8648 <- (0,17194)
[0] 8649 <- (0,17195)
[0] 8650 <- (0,17196)
[0] 8651 <- (0,17197)
[0] 8652 <- (0,17198)
[0] 8653 <- (0,17199)
[0] 8654 <- (0,17200)
[0] 8655 <- (0,17201)
[0] 8656 <- (0,17202)
[0] 8657 <- (0,17203)
[0] 8658 <- (0,17204)
[0] 8659 <- (0,17205)
[0] 8660 <- (0,17206)
[0] 8661 <- (0,17207)
[0] 8662 <- (0,17208)
[0] 8663 <- (0,17209)
[0] 8664 <- (0,17210)
[0] 8665 <- (0,17211)
[0] 8666 <- (0,17212)
[0] 8667 <- (0,17213)
[0] 8668 <- (0,17214)
[0] 8669 <- (0,17215)
[0] 8670 <- (0,17216)
[0] 8671 <- (0,17217)
[0] 8672 <- (0,17242)
[0] 8673 <- (0,17243)
[0] 8674 <- (0,17244)
[0] 8675 <- (0,17245)
[0] 8676 <- (0,17246)
[0] 8677 <- (0,17247)
[0] 8678 <- (0,17248)
[0] 8679 <- (0,17249)
[0] 8680 <- (0,17250)
[0] 8681 <- (0,17251)
[0] 8682 <- (0,17252)
[0] 8683 <- (0,17253)
[0] 8684 <- (0,17254)
[0] 8685 <- (0,17255)
[0] 8686 <- (0,17256)
[0] 8687 <- (0,17257)
[0] 8688 <- (0,17258)
[0] 8689 <- (0,17259)
[0] 8690 <- (0,17260)
[0] 8691 <- (0,17261)
[0] 8692 <- (0,17262)
[0] 8693 <- (0,17263)
[0] 8694 <- (0,17264)
[0] 8695 <- (0,17265)
[0] 8696 <- (0,17266)
[0] 8697 <- (0,17267)
[0] 8698 <- (0,17268)
[0] 8699 <- (0,17293)
[0] 8700 <- (0,17294)
[0] 8701 <- (0,17295)
[0] 8702 <- (0,17296)
[0] 8703 <- (0,17297)
[0] 8704 <- (0,17298)
[0] 8705 <- (0,17299)
[0] 8706 <- (0,17300)
[0] 8707 <- (0,17301)
[0] 8708 <- (0,17302)
[0] 8709 <- (0,17303)
[0] 8710 <- (0,17304)
[0] 8711 <- (0,17305)
[0] 8712 <- (0,17306)
[0] 8713 <- (0,17307)
[0] 8714 <- (0,17308)
[0] 8715 <- (0,17309)
[0] 8716 <- (0,17310)
[0] 8717 <- (0,17311)
[0] 8718 <- (0,17312)
[0] 8719 <- (0,17313)
[0] 8720 <- (0,17314)
[0] 8721 <- (0,17315)
[0] 8722 <- (0,17316)
[0] 8723 <- (0,17317)
[0] 8724 <- (0,17318)
[0] 8725 <- (0,17319)
[0] 8726 <- (0,17344)
[0] 8727 <- (0,17345)
[0] 8728 <- (0,17346)
[0] 8729 <- (0,17347)
[0] 8730 <- (0,17348)
[0] 8731 <- (0,17349)
[0] 8732 <- (0,17350)
[0] 8733 <- (0,17351)
[0] 8734 <- (0,17352)
[0] 8735 <- (0,17353)
[0] 8736 <- (0,17354)
[0] 8737 <- (0,17355)
[0] 8738 <- (0,17356)
[0] 8739 <- (0,17357)
[0] 8740 <- (0,17358)
[0] 8741 <- (0,17359)
[0] 8742 <- (0,17360)
[0] 8743 <- (0,17361)
[0] 8744 <- (0,17362)
[0] 8745 <- (0,17363)
[0] 8746 <- (0,17364)
[0] 8747 <- (0,17365)
[0] 8748 <- (0,17366)
[0] 8749 <- (0,17367)
[0] 8750 <- (0,17368)
[0] 8751 <- (0,17369)
[0] 8752 <- (0,17370)
[0] 8753 <- (0,17395)
[0] 8754 <- (0,17396)
[0] 8755 <- (0,17397)
[0] 8756 <- (0,17398)
[0] 8757 <- (0,17399)
[0] 8758 <- (0,17400)
[0] 8759 <- (0,17401)
[0] 8760 <- (0,17402)
[0] 8761 <- (0,17403)
[0] 8762 <- (0,17404)
[0] 8763 <- (0,17405)
[0] 8764 <- (0,17406)
[0] 8765 <- (0,17407)
[0] 8766 <- (0,17408)
[0] 8767 <- (0,17409)
[0] 8768 <- (0,17410)
[0] 8769 <- (0,17411)
[0] 8770 <- (0,17412)
[0] 8771 <- (0,17413)
[0] 8772 <- (0,17414)
[0] 8773 <- (0,17415)
[0] 8774 <- (0,17416)
[0] 8775 <- (0,17417)
[0] 8776 <- (0,17418)
[0] 8777 <- (0,17419)
[0] 8778 <- (0,17420)
[0] 8779 <- (0,17421)
[0] 8780 <- (0,17446)
[0] 8781 <- (0,17447)
[0] 8782 <- (0,17448)
[0] 8783 <- (0,17449)
[0] 8784 <- (0,17450)
[0] 8785 <- (0,17451)
[0] 8786 <- (0,17452)
[0] 8787 <- (0,17453)
[0] 8788 <- (0,17454)
[0] 8789 <- (0,17455)
[0] 8790 <- (0,17456)
[0] 8791 <- (0,17457)
[0] 8792 <- (0,17458)
[0] 8793 <- (0,17459)
[0] 8794 <- (0,17460)
[0] 8795 <- (0,17461)
[0] 8796 <- (0,17462)
[0] 8797 <- (0,17463)
[0] 8798 <- (0,17464)
[0] 8799 <- (0,17465)
[0] 8800 <- (0,17466)
[0] 8801 <- (0,17467)
[0] 8802 <- (0,17468)
[0] 8803 <- (0,17469)
[0] 8804 <- (0,17470)
[0] 8805 <- (0,17471)
[0] 8806 <- (0,17472)
[0] 8807 <- (0,17497)
[0] 8808 <- (0,17498)
[0] 8809 <- (0,17499)
[0] 8810 <- (0,17500)
[0] 8811 <- (0,17501)
[0] 8812 <- (0,17502)
[0] 8813 <- (0,17503)
[0] 8814 <- (0,17504)
[0] 8815 <- (0,17505)
[0] 8816 <- (0,17506)
[0] 8817 <- (0,17507)
[0] 8818 <- (0,17508)
[0] 8819 <- (0,17509)
[0] 8820 <- (0,17510)
[0] 8821 <- (0,17511)
[0] 8822 <- (0,17512)
[0] 8823 <- (0,17513)
[0] 8824 <- (0,17514)
[0] 8825 <- (0,17515)
[0] 8826 <- (0,17516)
[0] 8827 <- (0,17517)
[0] 8828 <- (0,17518)
[0] 8829 <- (0,17548)
[0] 8830 <- (0,17549)
[0] 8831 <- (0,17550)
[0] 8832 <- (0,17551)
[0] 8833 <- (0,17552)
[0] 8834 <- (0,17553)
[0] 8835 <- (0,17554)
[0] 8836 <- (0,17555)
[0] 8837 <- (0,17556)
[0] 8838 <- (0,17557)
[0] 8839 <- (0,17558)
[0] 8840 <- (0,17559)
[0] 8841 <- (0,17560)
[0] 8842 <- (0,17561)
[0] 8843 <- (0,17562)
[0] 8844 <- (0,17563)
[0] 8845 <- (0,17564)
[0] 8846 <- (0,17565)
[0] 8847 <- (0,17566)
[0] 8848 <- (0,17567)
[0] 8849 <- (0,17568)
[0] 8850 <- (0,17569)
[0] 8851 <- (0,17599)
[0] 8852 <- (0,17600)
[0] 8853 <- (0,17601)
[0] 8854 <- (0,17602)
[0] 8855 <- (0,17603)
[0] 8856 <- (0,17604)
[0] 8857 <- (0,17605)
[0] 8858 <- (0,17606)
[0] 8859 <- (0,17607)
[0] 8860 <- (0,17608)
[0] 8861 <- (0,17609)
[0] 8862 <- (0,17610)
[0] 8863 <- (0,17611)
[0] 8864 <- (0,17612)
[0] 8865 <- (0,17613)
[0] 8866 <- (0,17614)
[0] 8867 <- (0,17615)
[0] 8868 <- (0,17616)
[0] 8869 <- (0,17617)
[0] 8870 <- (0,17618)
[0] 8871 <- (0,17619)
[0] 8872 <- (0,17620)
[0] 8873 <- (0,17650)
[0] 8874 <- (0,17651)
[0] 8875 <- (0,17652)
[0] 8876 <- (0,17653)
[0] 8877 <- (0,17654)
[0] 8878 <- (0,17655)
[0] 8879 <- (0,17656)
[0] 8880 <- (0,17657)
[0] 8881 <- (0,17658)
[0] 8882 <- (0,17659)
[0] 8883 <- (0,17660)
[0] 8884 <- (0,17661)
[0] 8885 <- (0,17662)
[0] 8886 <- (0,17663)
[0] 8887 <- (0,17664)
[0] 8888 <- (0,17665)
[0] 8889 <- (0,17666)
[0] 8890 <- (0,17667)
[0] 8891 <- (0,17668)
[0] 8892 <- (0,17669)
[0] 8893 <- (0,17670)
[0] 8894 <- (0,17671)
[0] 8895 <- (0,17701)
[0] 8896 <- (0,17702)
[0] 8897 <- (0,17703)
[0] 8898 <- (0,17704)
[0] 8899 <- (0,17705)
[0] 8900 <- (0,17706)
[0] 8901 <- (0,17707)
[0] 8902 <- (0,17708)
[0] 8903 <- (0,17709)
[0] 8904 <- (0,17710)
[0] 8905 <- (0,17711)
[0] 8906 <- (0,17712)
[0] 8907 <- (0,17713)
[0] 8908 <- (0,17714)
[0] 8909 <- (0,17715)
[0] 8910 <- (0,17716)
[0] 8911 <- (0,17717)
[0] 8912 <- (0,17718)
[0] 8913 <- (0,17719)
[0] 8914 <- (0,17720)
[0] 8915 <- (0,17721)
[0] 8916 <- (0,17722)
[0] 8917 <- (0,17752)
[0] 8918 <- (0,17753)
[0] 8919 <- (0,17754)
[0] 8920 <- (0,17755)
[0] 8921 <- (0,17756)
[0] 8922 <- (0,17757)
[0] 8923 <- (0,17758)
[0] 8924 <- (0,17759)
[0] 8925 <- (0,17760)
[0] 8926 <- (0,17761)
[0] 8927 <- (0,17762)
[0] 8928 <- (0,17763)
[0] 8929 <- (0,17764)
[0] 8930 <- (0,17765)
[0] 8931 <- (0,17766)
[0] 8932 <- (0,17767)
[0] 8933 <- (0,17768)
[0] 8934 <- (0,17769)
[0] 8935 <- (0,17770)
[0] 8936 <- (0,17771)
[0] 8937 <- (0,17772)
[0] 8938 <- (0,17773)
[0] 8939 <- (0,17774)
[0] 8940 <- (0,17803)
[0] 8941 <- (0,17804)
[0] 8942 <- (0,17805)
[0] 8943 <- (0,17806)
[0] 8944 <- (0,17807)
[0] 8945 <- (0,17808)
[0] 8946 <- (0,17809)
[0] 8947 <- (0,17810)
[0] 8948 <- (0,17811)
[0] 8949 <- (0,17812)
[0] 8950 <- (0,17813)
[0] 8951 <- (0,17814)
[0] 8952 <- (0,17815)
[0] 8953 <- (0,17816)
[0] 8954 <- (0,17817)
[0] 8955 <- (0,17818)
[0] 8956 <- (0,17819)
[0] 8957 <- (0,17820)
[0] 8958 <- (0,17821)
[0] 8959 <- (0,17822)
[0] 8960 <- (0,17823)
[0] 8961 <- (0,17824)
[0] 8962 <- (0,17825)
[0] 8963 <- (0,17854)
[0] 8964 <- (0,17855)
[0] 8965 <- (0,17856)
[0] 8966 <- (0,17857)
[0] 8967 <- (0,17858)
[0] 8968 <- (0,17859)
[0] 8969 <- (0,17860)
[0] 8970 <- (0,17861)
[0] 8971 <- (0,17862)
[0] 8972 <- (0,17863)
[0] 8973 <- (0,17864)
[0] 8974 <- (0,17865)
[0] 8975 <- (0,17866)
[0] 8976 <- (0,17867)
[0] 8977 <- (0,17868)
[0] 8978 <- (0,17869)
[0] 8979 <- (0,17870)
[0] 8980 <- (0,17871)
[0] 8981 <- (0,17872)
[0] 8982 <- (0,17873)
[0] 8983 <- (0,17874)
[0] 8984 <- (0,17875)
[0] 8985 <- (0,17876)
[0] 8986 <- (0,17905)
[0] 8987 <- (0,17906)
[0] 8988 <- (0,17907)
[0] 8989 <- (0,17908)
[0] 8990 <- (0,17909)
[0] 8991 <- (0,17910)
[0] 8992 <- (0,17911)
[0] 8993 <- (0,17912)
[0] 8994 <- (0,17913)
[0] 8995 <- (0,17914)
[0] 8996 <- (0,17915)
[0] 8997 <- (0,17916)
[0] 8998 <- (0,17917)
[0] 8999 <- (0,17918)
[0] 9000 <- (0,17919)
[0] 9001 <- (0,17920)
[0] 9002 <- (0,17921)
[0] 9003 <- (0,17922)
[0] 9004 <- (0,17923)
[0] 9005 <- (0,17924)
[0] 9006 <- (0,17925)
[0] 9007 <- (0,17926)
[0] 9008 <- (0,17927)
[0] 9009 <- (0,17956)
[0] 9010 <- (0,17957)
[0] 9011 <- (0,17958)
[0] 9012 <- (0,17959)
[0] 9013 <- (0,17960)
[0] 9014 <- (0,17961)
[0] 9015 <- (0,17962)
[0] 9016 <- (0,17963)
[0] 9017 <- (0,17964)
[0] 9018 <- (0,17965)
[0] 9019 <- (0,17966)
[0] 9020 <- (0,17967)
[0] 9021 <- (0,17968)
[0] 9022 <- (0,17969)
[0] 9023 <- (0,17970)
[0] 9024 <- (0,17971)
[0] 9025 <- (0,17972)
[0] 9026 <- (0,17973)
[0] 9027 <- (0,17974)
[0] 9028 <- (0,17975)
[0] 9029 <- (0,17976)
[0] 9030 <- (0,17977)
[0] 9031 <- (0,17978)
[0] 9032 <- (0,17979)
[0] 9033 <- (0,18007)
[0] 9034 <- (0,18008)
[0] 9035 <- (0,18009)
[0] 9036 <- (0,18010)
[0] 9037 <- (0,18011)
[0] 9038 <- (0,18012)
[0] 9039 <- (0,18013)
[0] 9040 <- (0,18014)
[0] 9041 <- (0,18015)
[0] 9042 <- (0,18016)
[0] 9043 <- (0,18017)
[0] 9044 <- (0,18018)
[0] 9045 <- (0,18019)
[0] 9046 <- (0,18020)
[0] 9047 <- (0,18021)
[0] 9048 <- (0,18022)
[0] 9049 <- (0,18023)
[0] 9050 <- (0,18024)
[0] 9051 <- (0,18025)
[0] 9052 <- (0,18026)
[0] 9053 <- (0,18027)
[0] 9054 <- (0,18028)
[0] 9055 <- (0,18029)
[0] 9056 <- (0,18030)
[0] 9057 <- (0,18031)
[0] 9058 <- (0,18058)
[0] 9059 <- (0,18059)
[0] 9060 <- (0,18060)
[0] 9061 <- (0,18061)
[0] 9062 <- (0,18062)
[0] 9063 <- (0,18063)
[0] 9064 <- (0,18064)
[0] 9065 <- (0,18065)
[0] 9066 <- (0,18066)
[0] 9067 <- (0,18067)
[0] 9068 <- (0,18068)
[0] 9069 <- (0,18069)
[0] 9070 <- (0,18070)
[0] 9071 <- (0,18071)
[0] 9072 <- (0,18072)
[0] 9073 <- (0,18073)
[0] 9074 <- (0,18074)
[0] 9075 <- (0,18075)
[0] 9076 <- (0,18076)
[0] 9077 <- (0,18077)
[0] 9078 <- (0,18078)
[0] 9079 <- (0,18079)
[0] 9080 <- (0,18080)
[0] 9081 <- (0,18081)
[0] 9082 <- (0,18082)
[0] 9083 <- (0,18109)
[0] 9084 <- (0,18110)
[0] 9085 <- (0,18111)
[0] 9086 <- (0,18112)
[0] 9087 <- (0,18113)
[0] 9088 <- (0,18114)
[0] 9089 <- (0,18115)
[0] 9090 <- (0,18116)
[0] 9091 <- (0,18117)
[0] 9092 <- (0,18118)
[0] 9093 <- (0,18119)
[0] 9094 <- (0,18120)
[0] 9095 <- (0,18121)
[0] 9096 <- (0,18122)
[0] 9097 <- (0,18123)
[0] 9098 <- (0,18124)
[0] 9099 <- (0,18125)
[0] 9100 <- (0,18126)
[0] 9101 <- (0,18127)
[0] 9102 <- (0,18128)
[0] 9103 <- (0,18129)
[0] 9104 <- (0,18130)
[0] 9105 <- (0,18131)
[0] 9106 <- (0,18132)
[0] 9107 <- (0,18133)
[0] 9108 <- (0,18134)
[0] 9109 <- (0,18160)
[0] 9110 <- (0,18161)
[0] 9111 <- (0,18162)
[0] 9112 <- (0,18163)
[0] 9113 <- (0,18164)
[0] 9114 <- (0,18165)
[0] 9115 <- (0,18166)
[0] 9116 <- (0,18167)
[0] 9117 <- (0,18168)
[0] 9118 <- (0,18169)
[0] 9119 <- (0,18170)
[0] 9120 <- (0,18171)
[0] 9121 <- (0,18172)
[0] 9122 <- (0,18173)
[0] 9123 <- (0,18174)
[0] 9124 <- (0,18175)
[0] 9125 <- (0,18176)
[0] 9126 <- (0,18177)
[0] 9127 <- (0,18178)
[0] 9128 <- (0,18179)
[0] 9129 <- (0,18180)
[0] 9130 <- (0,18181)
[0] 9131 <- (0,18182)
[0] 9132 <- (0,18183)
[0] 9133 <- (0,18184)
[0] 9134 <- (0,18185)
[0] 9135 <- (0,18211)
[0] 9136 <- (0,18212)
[0] 9137 <- (0,18213)
[0] 9138 <- (0,18214)
[0] 9139 <- (0,18215)
[0] 9140 <- (0,18216)
[0] 9141 <- (0,18217)
[0] 9142 <- (0,18218)
[0] 9143 <- (0,18219)
[0] 9144 <- (0,18220)
[0] 9145 <- (0,18221)
[0] 9146 <- (0,18222)
[0] 9147 <- (0,18223)
[0] 9148 <- (0,18224)
[0] 9149 <- (0,18225)
[0] 9150 <- (0,18226)
[0] 9151 <- (0,18227)
[0] 9152 <- (0,18228)
[0] 9153 <- (0,18229)
[0] 9154 <- (0,18230)
[0] 9155 <- (0,18231)
[0] 9156 <- (0,18232)
[0] 9157 <- (0,18233)
[0] 9158 <- (0,18234)
[0] 9159 <- (0,18235)
[0] 9160 <- (0,18236)
[0] 9161 <- (0,18237)
[0] 9162 <- (0,18262)
[0] 9163 <- (0,18263)
[0] 9164 <- (0,18264)
[0] 9165 <- (0,18265)
[0] 9166 <- (0,18266)
[0] 9167 <- (0,18267)
[0] 9168 <- (0,18268)
[0] 9169 <- (0,18269)
[0] 9170 <- (0,18270)
[0] 9171 <- (0,18271)
[0] 9172 <- (0,18272)
[0] 9173 <- (0,18273)
[0] 9174 <- (0,18274)
[0] 9175 <- (0,18275)
[0] 9176 <- (0,18276)
[0] 9177 <- (0,18277)
[0] 9178 <- (0,18278)
[0] 9179 <- (0,18279)
[0] 9180 <- (0,18280)
[0] 9181 <- (0,18281)
[0] 9182 <- (0,18282)
[0] 9183 <- (0,18283)
[0] 9184 <- (0,18284)
[0] 9185 <- (0,18285)
[0] 9186 <- (0,18286)
[0] 9187 <- (0,18287)
[0] 9188 <- (0,18288)
[0] 9189 <- (0,18313)
[0] 9190 <- (0,18314)
[0] 9191 <- (0,18315)
[0] 9192 <- (0,18316)
[0] 9193 <- (0,18317)
[0] 9194 <- (0,18318)
[0] 9195 <- (0,18319)
[0] 9196 <- (0,18320)
[0] 9197 <- (0,18321)
[0] 9198 <- (0,18322)
[0] 9199 <- (0,18323)
[0] 9200 <- (0,18324)
[0] 9201 <- (0,18325)
[0] 9202 <- (0,18326)
[0] 9203 <- (0,18327)
[0] 9204 <- (0,18328)
[0] 9205 <- (0,18329)
[0] 9206 <- (0,18330)
[0] 9207 <- (0,18331)
[0] 9208 <- (0,18332)
[0] 9209 <- (0,18333)
[0] 9210 <- (0,18334)
[0] 9211 <- (0,18335)
[0] 9212 <- (0,18336)
[0] 9213 <- (0,18337)
[0] 9214 <- (0,18338)
[0] 9215 <- (0,18339)
[0] 9216 <- (0,18364)
[0] 9217 <- (0,18365)
[0] 9218 <- (0,18366)
[0] 9219 <- (0,18367)
[0] 9220 <- (0,18368)
[0] 9221 <- (0,18369)
[0] 9222 <- (0,18370)
[0] 9223 <- (0,18371)
[0] 9224 <- (0,18372)
[0] 9225 <- (0,18373)
[0] 9226 <- (0,18374)
[0] 9227 <- (0,18375)
[0] 9228 <- (0,18376)
[0] 9229 <- (0,18377)
[0] 9230 <- (0,18378)
[0] 9231 <- (0,18379)
[0] 9232 <- (0,18380)
[0] 9233 <- (0,18381)
[0] 9234 <- (0,18382)
[0] 9235 <- (0,18383)
[0] 9236 <- (0,18384)
[0] 9237 <- (0,18385)
[0] 9238 <- (0,18386)
[0] 9239 <- (0,18387)
[0] 9240 <- (0,18388)
[0] 9241 <- (0,18389)
[0] 9242 <- (0,18390)
[0] 9243 <- (0,18415)
[0] 9244 <- (0,18416)
[0] 9245 <- (0,18417)
[0] 9246 <- (0,18418)
[0] 9247 <- (0,18419)
[0] 9248 <- (0,18420)
[0] 9249 <- (0,18421)
[0] 9250 <- (0,18422)
[0] 9251 <- (0,18423)
[0] 9252 <- (0,18424)
[0] 9253 <- (0,18425)
[0] 9254 <- (0,18426)
[0] 9255 <- (0,18427)
[0] 9256 <- (0,18428)
[0] 9257 <- (0,18429)
[0] 9258 <- (0,18430)
[0] 9259 <- (0,18431)
[0] 9260 <- (0,18432)
[0] 9261 <- (0,18433)
[0] 9262 <- (0,18434)
[0] 9263 <- (0,18435)
[0] 9264 <- (0,18436)
[0] 9265 <- (0,18437)
[0] 9266 <- (0,18438)
[0] 9267 <- (0,18439)
[0] 9268 <- (0,18440)
[0] 9269 <- (0,18441)
[0] 9270 <- (0,18466)
[0] 9271 <- (0,18467)
[0] 9272 <- (0,18468)
[0] 9273 <- (0,18469)
[0] 9274 <- (0,18470)
[0] 9275 <- (0,18471)
[0] 9276 <- (0,18472)
[0] 9277 <- (0,18473)
[0] 9278 <- (0,18474)
[0] 9279 <- (0,18475)
[0] 9280 <- (0,18476)
[0] 9281 <- (0,18477)
[0] 9282 <- (0,18478)
[0] 9283 <- (0,18479)
[0] 9284 <- (0,18480)
[0] 9285 <- (0,18481)
[0] 9286 <- (0,18482)
[0] 9287 <- (0,18483)
[0] 9288 <- (0,18484)
[0] 9289 <- (0,18485)
[0] 9290 <- (0,18486)
[0] 9291 <- (0,18487)
[0] 9292 <- (0,18488)
[0] 9293 <- (0,18489)
[0] 9294 <- (0,18490)
[0] 9295 <- (0,18491)
[0] 9296 <- (0,18492)
[0] 9297 <- (0,18517)
[0] 9298 <- (0,18518)
[0] 9299 <- (0,18519)
[0] 9300 <- (0,18520)
[0] 9301 <- (0,18521)
[0] 9302 <- (0,18522)
[0] 9303 <- (0,18523)
[0] 9304 <- (0,18524)
[0] 9305 <- (0,18525)
[0] 9306 <- (0,18526)
[0] 9307 <- (0,18527)
[0] 9308 <- (0,18528)
[0] 9309 <- (0,18529)
[0] 9310 <- (0,18530)
[0] 9311 <- (0,18531)
[0] 9312 <- (0,18532)
[0] 9313 <- (0,18533)
[0] 9314 <- (0,18534)
[0] 9315 <- (0,18535)
[0] 9316 <- (0,18536)
[0] 9317 <- (0,18537)
[0] 9318 <- (0,18538)
[0] 9319 <- (0,18539)
[0] 9320 <- (0,18540)
[0] 9321 <- (0,18541)
[0] 9322 <- (0,18542)
[0] 9323 <- (0,18543)
[0] 9324 <- (0,18568)
[0] 9325 <- (0,18569)
[0] 9326 <- (0,18570)
[0] 9327 <- (0,18571)
[0] 9328 <- (0,18572)
[0] 9329 <- (0,18573)
[0] 9330 <- (0,18574)
[0] 9331 <- (0,18575)
[0] 9332 <- (0,18576)
[0] 9333 <- (0,18577)
[0] 9334 <- (0,18578)
[0] 9335 <- (0,18579)
[0] 9336 <- (0,18580)
[0] 9337 <- (0,18581)
[0] 9338 <- (0,18582)
[0] 9339 <- (0,18583)
[0] 9340 <- (0,18584)
[0] 9341 <- (0,18585)
[0] 9342 <- (0,18586)
[0] 9343 <- (0,18587)
[0] 9344 <- (0,18588)
[0] 9345 <- (0,18589)
[0] 9346 <- (0,18619)
[0] 9347 <- (0,18620)
[0] 9348 <- (0,18621)
[0] 9349 <- (0,18622)
[0] 9350 <- (0,18623)
[0] 9351 <- (0,18624)
[0] 9352 <- (0,18625)
[0] 9353 <- (0,18626)
[0] 9354 <- (0,18627)
[0] 9355 <- (0,18628)
[0] 9356 <- (0,18629)
[0] 9357 <- (0,18630)
[0] 9358 <- (0,18631)
[0] 9359 <- (0,18632)
[0] 9360 <- (0,18633)
[0] 9361 <- (0,18634)
[0] 9362 <- (0,18635)
[0] 9363 <- (0,18636)
[0] 9364 <- (0,18637)
[0] 9365 <- (0,18638)
[0] 9366 <- (0,18639)
[0] 9367 <- (0,18640)
[0] 9368 <- (0,18670)
[0] 9369 <- (0,18671)
[0] 9370 <- (0,18672)
[0] 9371 <- (0,18673)
[0] 9372 <- (0,18674)
[0] 9373 <- (0,18675)
[0] 9374 <- (0,18676)
[0] 9375 <- (0,18677)
[0] 9376 <- (0,18678)
[0] 9377 <- (0,18679)
[0] 9378 <- (0,18680)
[0] 9379 <- (0,18681)
[0] 9380 <- (0,18682)
[0] 9381 <- (0,18683)
[0] 9382 <- (0,18684)
[0] 9383 <- (0,18685)
[0] 9384 <- (0,18686)
[0] 9385 <- (0,18687)
[0] 9386 <- (0,18688)
[0] 9387 <- (0,18689)
[0] 9388 <- (0,18690)
[0] 9389 <- (0,18691)
[0] 9390 <- (0,18721)
[0] 9391 <- (0,18722)
[0] 9392 <- (0,18723)
[0] 9393 <- (0,18724)
[0] 9394 <- (0,18725)
[0] 9395 <- (0,18726)
[0] 9396 <- (0,18727)
[0] 9397 <- (0,18728)
[0] 9398 <- (0,18729)
[0] 9399 <- (0,18730)
[0] 9400 <- (0,18731)
[0] 9401 <- (0,18732)
[0] 9402 <- (0,18733)
[0] 9403 <- (0,18734)
[0] 9404 <- (0,18735)
[0] 9405 <- (0,18736)
[0] 9406 <- (0,18737)
[0] 9407 <- (0,18738)
[0] 9408 <- (0,18739)
[0] 9409 <- (0,18740)
[0] 9410 <- (0,18741)
[0] 9411 <- (0,18742)
[0] 9412 <- (0,18772)
[0] 9413 <- (0,18773)
[0] 9414 <- (0,18774)
[0] 9415 <- (0,18775)
[0] 9416 <- (0,18776)
[0] 9417 <- (0,18777)
[0] 9418 <- (0,18778)
[0] 9419 <- (0,18779)
[0] 9420 <- (0,18780)
[0] 9421 <- (0,18781)
[0] 9422 <- (0,18782)
[0] 9423 <- (0,18783)
[0] 9424 <- (0,18784)
[0] 9425 <- (0,18785)
[0] 9426 <- (0,18786)
[0] 9427 <- (0,18787)
[0] 9428 <- (0,18788)
[0] 9429 <- (0,18789)
[0] 9430 <- (0,18790)
[0] 9431 <- (0,18791)
[0] 9432 <- (0,18792)
[0] 9433 <- (0,18793)
[0] 9434 <- (0,18823)
[0] 9435 <- (0,18824)
[0] 9436 <- (0,18825)
[0] 9437 <- (0,18826)
[0] 9438 <- (0,18827)
[0] 9439 <- (0,18828)
[0] 9440 <- (0,18829)
[0] 9441 <- (0,18830)
[0] 9442 <- (0,18831)
[0] 9443 <- (0,18832)
[0] 9444 <- (0,18833)
[0] 9445 <- (0,18834)
[0] 9446 <- (0,18835)
[0] 9447 <- (0,18836)
[0] 9448 <- (0,18837)
[0] 9449 <- (0,18838)
[0] 9450 <- (0,18839)
[0] 9451 <- (0,18840)
[0] 9452 <- (0,18841)
[0] 9453 <- (0,18842)
[0] 9454 <- (0,18843)
[0] 9455 <- (0,18844)
[0] 9456 <- (0,18845)
[0] 9457 <- (0,18874)
[0] 9458 <- (0,18875)
[0] 9459 <- (0,18876)
[0] 9460 <- (0,18877)
[0] 9461 <- (0,18878)
[0] 9462 <- (0,18879)
[0] 9463 <- (0,18880)
[0] 9464 <- (0,18881)
[0] 9465 <- (0,18882)
[0] 9466 <- (0,18883)
[0] 9467 <- (0,18884)
[0] 9468 <- (0,18885)
[0] 9469 <- (0,18886)
[0] 9470 <- (0,18887)
[0] 9471 <- (0,18888)
[0] 9472 <- (0,18889)
[0] 9473 <- (0,18890)
[0] 9474 <- (0,18891)
[0] 9475 <- (0,18892)
[0] 9476 <- (0,18893)
[0] 9477 <- (0,18894)
[0] 9478 <- (0,18895)
[0] 9479 <- (0,18896)
[0] 9480 <- (0,18925)
[0] 9481 <- (0,18926)
[0] 9482 <- (0,18927)
[0] 9483 <- (0,18928)
[0] 9484 <- (0,18929)
[0] 9485 <- (0,18930)
[0] 9486 <- (0,18931)
[0] 9487 <- (0,18932)
[0] 9488 <- (0,18933)
[0] 9489 <- (0,18934)
[0] 9490 <- (0,18935)
[0] 9491 <- (0,18936)
[0] 9492 <- (0,18937)
[0] 9493 <- (0,18938)
[0] 9494 <- (0,18939)
[0] 9495 <- (0,18940)
[0] 9496 <- (0,18941)
[0] 9497 <- (0,18942)
[0] 9498 <- (0,18943)
[0] 9499 <- (0,18944)
[0] 9500 <- (0,18945)
[0] 9501 <- (0,18946)
[0] 9502 <- (0,18947)
[0] 9503 <- (0,18976)
[0] 9504 <- (0,18977)
[0] 9505 <- (0,18978)
[0] 9506 <- (0,18979)
[0] 9507 <- (0,18980)
[0] 9508 <- (0,18981)
[0] 9509 <- (0,18982)
[0] 9510 <- (0,18983)
[0] 9511 <- (0,18984)
[0] 9512 <- (0,18985)
[0] 9513 <- (0,18986)
[0] 9514 <- (0,18987)
[0] 9515 <- (0,18988)
[0] 9516 <- (0,18989)
[0] 9517 <- (0,18990)
[0] 9518 <- (0,18991)
[0] 9519 <- (0,18992)
[0] 9520 <- (0,18993)
[0] 9521 <- (0,18994)
[0] 9522 <- (0,18995)
[0] 9523 <- (0,18996)
[0] 9524 <- (0,18997)
[0] 9525 <- (0,18998)
[0] 9526 <- (0,19027)
[0] 9527 <- (0,19028)
[0] 9528 <- (0,19029)
[0] 9529 <- (0,19030)
[0] 9530 <- (0,19031)
[0] 9531 <- (0,19032)
[0] 9532 <- (0,19033)
[0] 9533 <- (0,19034)
[0] 9534 <- (0,19035)
[0] 9535 <- (0,19036)
[0] 9536 <- (0,19037)
[0] 9537 <- (0,19038)
[0] 9538 <- (0,19039)
[0] 9539 <- (0,19040)
[0] 9540 <- (0,19041)
[0] 9541 <- (0,19042)
[0] 9542 <- (0,19043)
[0] 9543 <- (0,19044)
[0] 9544 <- (0,19045)
[0] 9545 <- (0,19046)
[0] 9546 <- (0,19047)
[0] 9547 <- (0,19048)
[0] 9548 <- (0,19049)
[0] 9549 <- (0,19050)
[0] 9550 <- (0,19078)
[0] 9551 <- (0,19079)
[0] 9552 <- (0,19080)
[0] 9553 <- (0,19081)
[0] 9554 <- (0,19082)
[0] 9555 <- (0,19083)
[0] 9556 <- (0,19084)
[0] 9557 <- (0,19085)
[0] 9558 <- (0,19086)
[0] 9559 <- (0,19087)
[0] 9560 <- (0,19088)
[0] 9561 <- (0,19089)
[0] 9562 <- (0,19090)
[0] 9563 <- (0,19091)
[0] 9564 <- (0,19092)
[0] 9565 <- (0,19093)
[0] 9566 <- (0,19094)
[0] 9567 <- (0,19095)
[0] 9568 <- (0,19096)
[0] 9569 <- (0,19097)
[0] 9570 <- (0,19098)
[0] 9571 <- (0,19099)
[0] 9572 <- (0,19100)
[0] 9573 <- (0,19101)
[0] 9574 <- (0,19102)
[0] 9575 <- (0,19129)
[0] 9576 <- (0,19130)
[0] 9577 <- (0,19131)
[0] 9578 <- (0,19132)
[0] 9579 <- (0,19133)
[0] 9580 <- (0,19134)
[0] 9581 <- (0,19135)
[0] 9582 <- (0,19136)
[0] 9583 <- (0,19137)
[0] 9584 <- (0,19138)
[0] 9585 <- (0,19139)
[0] 9586 <- (0,19140)
[0] 9587 <- (0,19141)
[0] 9588 <- (0,19142)
[0] 9589 <- (0,19143)
[0] 9590 <- (0,19144)
[0] 9591 <- (0,19145)
[0] 9592 <- (0,19146)
[0] 9593 <- (0,19147)
[0] 9594 <- (0,19148)
[0] 9595 <- (0,19149)
[0] 9596 <- (0,19150)
[0] 9597 <- (0,19151)
[0] 9598 <- (0,19152)
[0] 9599 <- (0,19153)
[0] 9600 <- (0,19180)
[0] 9601 <- (0,19181)
[0] 9602 <- (0,19182)
[0] 9603 <- (0,19183)
[0] 9604 <- (0,19184)
[0] 9605 <- (0,19185)
[0] 9606 <- (0,19186)
[0] 9607 <- (0,19187)
[0] 9608 <- (0,19188)
[0] 9609 <- (0,19189)
[0] 9610 <- (0,19190)
[0] 9611 <- (0,19191)
[0] 9612 <- (0,19192)
[0] 9613 <- (0,19193)
[0] 9614 <- (0,19194)
[0] 9615 <- (0,19195)
[0] 9616 <- (0,19196)
[0] 9617 <- (0,19197)
[0] 9618 <- (0,19198)
[0] 9619 <- (0,19199)
[0] 9620 <- (0,19200)
[0] 9621 <- (0,19201)
[0] 9622 <- (0,19202)
[0] 9623 <- (0,19203)
[0] 9624 <- (0,19204)
[0] 9625 <- (0,19205)
[0] 9626 <- (0,19231)
[0] 9627 <- (0,19232)
[0] 9628 <- (0,19233)
[0] 9629 <- (0,19234)
[0] 9630 <- (0,19235)
[0] 9631 <- (0,19236)
[0] 9632 <- (0,19237)
[0] 9633 <- (0,19238)
[0] 9634 <- (0,19239)
[0] 9635 <- (0,19240)
[0] 9636 <- (0,19241)
[0] 9637 <- (0,19242)
[0] 9638 <- (0,19243)
[0] 9639 <- (0,19244)
[0] 9640 <- (0,19245)
[0] 9641 <- (0,19246)
[0] 9642 <- (0,19247)
[0] 9643 <- (0,19248)
[0] 9644 <- (0,19249)
[0] 9645 <- (0,19250)
[0] 9646 <- (0,19251)
[0] 9647 <- (0,19252)
[0] 9648 <- (0,19253)
[0] 9649 <- (0,19254)
[0] 9650 <- (0,19255)
[0] 9651 <- (0,19256)
[0] 9652 <- (0,19282)
[0] 9653 <- (0,19283)
[0] 9654 <- (0,19284)
[0] 9655 <- (0,19285)
[0] 9656 <- (0,19286)
[0] 9657 <- (0,19287)
[0] 9658 <- (0,19288)
[0] 9659 <- (0,19289)
[0] 9660 <- (0,19290)
[0] 9661 <- (0,19291)
[0] 9662 <- (0,19292)
[0] 9663 <- (0,19293)
[0] 9664 <- (0,19294)
[0] 9665 <- (0,19295)
[0] 9666 <- (0,19296)
[0] 9667 <- (0,19297)
[0] 9668 <- (0,19298)
[0] 9669 <- (0,19299)
[0] 9670 <- (0,19300)
[0] 9671 <- (0,19301)
[0] 9672 <- (0,19302)
[0] 9673 <- (0,19303)
[0] 9674 <- (0,19304)
[0] 9675 <- (0,19305)
[0] 9676 <- (0,19306)
[0] 9677 <- (0,19307)
[0] 9678 <- (0,19308)
[0] 9679 <- (0,19333)
[0] 9680 <- (0,19334)
[0] 9681 <- (0,19335)
[0] 9682 <- (0,19336)
[0] 9683 <- (0,19337)
[0] 9684 <- (0,19338)
[0] 9685 <- (0,19339)
[0] 9686 <- (0,19340)
[0] 9687 <- (0,19341)
[0] 9688 <- (0,19342)
[0] 9689 <- (0,19343)
[0] 9690 <- (0,19344)
[0] 9691 <- (0,19345)
[0] 9692 <- (0,19346)
[0] 9693 <- (0,19347)
[0] 9694 <- (0,19348)
[0] 9695 <- (0,19349)
[0] 9696 <- (0,19350)
[0] 9697 <- (0,19351)
[0] 9698 <- (0,19352)
[0] 9699 <- (0,19353)
[0] 9700 <- (0,19354)
[0] 9701 <- (0,19355)
[0] 9702 <- (0,19356)
[0] 9703 <- (0,19357)
[0] 9704 <- (0,19358)
[0] 9705 <- (0,19359)
[0] 9706 <- (0,19384)
[0] 9707 <- (0,19385)
[0] 9708 <- (0,19386)
[0] 9709 <- (0,19387)
[0] 9710 <- (0,19388)
[0] 9711 <- (0,19389)
[0] 9712 <- (0,19390)
[0] 9713 <- (0,19391)
[0] 9714 <- (0,19392)
[0] 9715 <- (0,19393)
[0] 9716 <- (0,19394)
[0] 9717 <- (0,19395)
[0] 9718 <- (0,19396)
[0] 9719 <- (0,19397)
[0] 9720 <- (0,19398)
[0] 9721 <- (0,19399)
[0] 9722 <- (0,19400)
[0] 9723 <- (0,19401)
[0] 9724 <- (0,19402)
[0] 9725 <- (0,19403)
[0] 9726 <- (0,19404)
[0] 9727 <- (0,19405)
[0] 9728 <- (0,19406)
[0] 9729 <- (0,19407)
[0] 9730 <- (0,19408)
[0] 9731 <- (0,19409)
[0] 9732 <- (0,19410)
[0] 9733 <- (0,19435)
[0] 9734 <- (0,19436)
[0] 9735 <- (0,19437)
[0] 9736 <- (0,19438)
[0] 9737 <- (0,19439)
[0] 9738 <- (0,19440)
[0] 9739 <- (0,19441)
[0] 9740 <- (0,19442)
[0] 9741 <- (0,19443)
[0] 9742 <- (0,19444)
[0] 9743 <- (0,19445)
[0] 9744 <- (0,19446)
[0] 9745 <- (0,19447)
[0] 9746 <- (0,19448)
[0] 9747 <- (0,19449)
[0] 9748 <- (0,19450)
[0] 9749 <- (0,19451)
[0] 9750 <- (0,19452)
[0] 9751 <- (0,19453)
[0] 9752 <- (0,19454)
[0] 9753 <- (0,19455)
[0] 9754 <- (0,19456)
[0] 9755 <- (0,19457)
[0] 9756 <- (0,19458)
[0] 9757 <- (0,19459)
[0] 9758 <- (0,19460)
[0] 9759 <- (0,19461)
[0] 9760 <- (0,19486)
[0] 9761 <- (0,19487)
[0] 9762 <- (0,19488)
[0] 9763 <- (0,19489)
[0] 9764 <- (0,19490)
[0] 9765 <- (0,19491)
[0] 9766 <- (0,19492)
[0] 9767 <- (0,19493)
[0] 9768 <- (0,19494)
[0] 9769 <- (0,19495)
[0] 9770 <- (0,19496)
[0] 9771 <- (0,19497)
[0] 9772 <- (0,19498)
[0] 9773 <- (0,19499)
[0] 9774 <- (0,19500)
[0] 9775 <- (0,19501)
[0] 9776 <- (0,19502)
[0] 9777 <- (0,19503)
[0] 9778 <- (0,19504)
[0] 9779 <- (0,19505)
[0] 9780 <- (0,19506)
[0] 9781 <- (0,19507)
[0] 9782 <- (0,19508)
[0] 9783 <- (0,19509)
[0] 9784 <- (0,19510)
[0] 9785 <- (0,19511)
[0] 9786 <- (0,19512)
[0] 9787 <- (0,19537)
[0] 9788 <- (0,19538)
[0] 9789 <- (0,19539)
[0] 9790 <- (0,19540)
[0] 9791 <- (0,19541)
[0] 9792 <- (0,19542)
[0] 9793 <- (0,19543)
[0] 9794 <- (0,19544)
[0] 9795 <- (0,19545)
[0] 9796 <- (0,19546)
[0] 9797 <- (0,19547)
[0] 9798 <- (0,19548)
[0] 9799 <- (0,19549)
[0] 9800 <- (0,19550)
[0] 9801 <- (0,19551)
[0] 9802 <- (0,19552)
[0] 9803 <- (0,19553)
[0] 9804 <- (0,19554)
[0] 9805 <- (0,19555)
[0] 9806 <- (0,19556)
[0] 9807 <- (0,19557)
[0] 9808 <- (0,19558)
[0] 9809 <- (0,19559)
[0] 9810 <- (0,19560)
[0] 9811 <- (0,19561)
[0] 9812 <- (0,19562)
[0] 9813 <- (0,19563)
[0] 9814 <- (0,19588)
[0] 9815 <- (0,19589)
[0] 9816 <- (0,19590)
[0] 9817 <- (0,19591)
[0] 9818 <- (0,19592)
[0] 9819 <- (0,19593)
[0] 9820 <- (0,19594)
[0] 9821 <- (0,19595)
[0] 9822 <- (0,19596)
[0] 9823 <- (0,19597)
[0] 9824 <- (0,19598)
[0] 9825 <- (0,19599)
[0] 9826 <- (0,19600)
[0] 9827 <- (0,19601)
[0] 9828 <- (0,19602)
[0] 9829 <- (0,19603)
[0] 9830 <- (0,19604)
[0] 9831 <- (0,19605)
[0] 9832 <- (0,19606)
[0] 9833 <- (0,19607)
[0] 9834 <- (0,19608)
[0] 9835 <- (0,19609)
[0] 9836 <- (0,19610)
[0] 9837 <- (0,19611)
[0] 9838 <- (0,19612)
[0] 9839 <- (0,19613)
[0] 9840 <- (0,19614)
[0] 9841 <- (0,19639)
[0] 9842 <- (0,19640)
[0] 9843 <- (0,19641)
[0] 9844 <- (0,19642)
[0] 9845 <- (0,19643)
[0] 9846 <- (0,19644)
[0] 9847 <- (0,19645)
[0] 9848 <- (0,19646)
[0] 9849 <- (0,19647)
[0] 9850 <- (0,19648)
[0] 9851 <- (0,19649)
[0] 9852 <- (0,19650)
[0] 9853 <- (0,19651)
[0] 9854 <- (0,19652)
[0] 9855 <- (0,19653)
[0] 9856 <- (0,19654)
[0] 9857 <- (0,19655)
[0] 9858 <- (0,19656)
[0] 9859 <- (0,19657)
[0] 9860 <- (0,19658)
[0] 9861 <- (0,19659)
[0] 9862 <- (0,19660)
[0] 9863 <- (0,19690)
[0] 9864 <- (0,19691)
[0] 9865 <- (0,19692)
[0] 9866 <- (0,19693)
[0] 9867 <- (0,19694)
[0] 9868 <- (0,19695)
[0] 9869 <- (0,19696)
[0] 9870 <- (0,19697)
[0] 9871 <- (0,19698)
[0] 9872 <- (0,19699)
[0] 9873 <- (0,19700)
[0] 9874 <- (0,19701)
[0] 9875 <- (0,19702)
[0] 9876 <- (0,19703)
[0] 9877 <- (0,19704)
[0] 9878 <- (0,19705)
[0] 9879 <- (0,19706)
[0] 9880 <- (0,19707)
[0] 9881 <- (0,19708)
[0] 9882 <- (0,19709)
[0] 9883 <- (0,19710)
[0] 9884 <- (0,19711)
[0] 9885 <- (0,19741)
[0] 9886 <- (0,19742)
[0] 9887 <- (0,19743)
[0] 9888 <- (0,19744)
[0] 9889 <- (0,19745)
[0] 9890 <- (0,19746)
[0] 9891 <- (0,19747)
[0] 9892 <- (0,19748)
[0] 9893 <- (0,19749)
[0] 9894 <- (0,19750)
[0] 9895 <- (0,19751)
[0] 9896 <- (0,19752)
[0] 9897 <- (0,19753)
[0] 9898 <- (0,19754)
[0] 9899 <- (0,19755)
[0] 9900 <- (0,19756)
[0] 9901 <- (0,19757)
[0] 9902 <- (0,19758)
[0] 9903 <- (0,19759)
[0] 9904 <- (0,19760)
[0] 9905 <- (0,19761)
[0] 9906 <- (0,19762)
[0] 9907 <- (0,19792)
[0] 9908 <- (0,19793)
[0] 9909 <- (0,19794)
[0] 9910 <- (0,19795)
[0] 9911 <- (0,19796)
[0] 9912 <- (0,19797)
[0] 9913 <- (0,19798)
[0] 9914 <- (0,19799)
[0] 9915 <- (0,19800)
[0] 9916 <- (0,19801)
[0] 9917 <- (0,19802)
[0] 9918 <- (0,19803)
[0] 9919 <- (0,19804)
[0] 9920 <- (0,19805)
[0] 9921 <- (0,19806)
[0] 9922 <- (0,19807)
[0] 9923 <- (0,19808)
[0] 9924 <- (0,19809)
[0] 9925 <- (0,19810)
[0] 9926 <- (0,19811)
[0] 9927 <- (0,19812)
[0] 9928 <- (0,19813)
[0] 9929 <- (0,19843)
[0] 9930 <- (0,19844)
[0] 9931 <- (0,19845)
[0] 9932 <- (0,19846)
[0] 9933 <- (0,19847)
[0] 9934 <- (0,19848)
[0] 9935 <- (0,19849)
[0] 9936 <- (0,19850)
[0] 9937 <- (0,19851)
[0] 9938 <- (0,19852)
[0] 9939 <- (0,19853)
[0] 9940 <- (0,19854)
[0] 9941 <- (0,19855)
[0] 9942 <- (0,19856)
[0] 9943 <- (0,19857)
[0] 9944 <- (0,19858)
[0] 9945 <- (0,19859)
[0] 9946 <- (0,19860)
[0] 9947 <- (0,19861)
[0] 9948 <- (0,19862)
[0] 9949 <- (0,19863)
[0] 9950 <- (0,19864)
[0] 9951 <- (0,19894)
[0] 9952 <- (0,19895)
[0] 9953 <- (0,19896)
[0] 9954 <- (0,19897)
[0] 9955 <- (0,19898)
[0] 9956 <- (0,19899)
[0] 9957 <- (0,19900)
[0] 9958 <- (0,19901)
[0] 9959 <- (0,19902)
[0] 9960 <- (0,19903)
[0] 9961 <- (0,19904)
[0] 9962 <- (0,19905)
[0] 9963 <- (0,19906)
[0] 9964 <- (0,19907)
[0] 9965 <- (0,19908)
[0] 9966 <- (0,19909)
[0] 9967 <- (0,19910)
[0] 9968 <- (0,19911)
[0] 9969 <- (0,19912)
[0] 9970 <- (0,19913)
[0] 9971 <- (0,19914)
[0] 9972 <- (0,19915)
[0] 9973 <- (0,19916)
[0] 9974 <- (0,19945)
[0] 9975 <- (0,19946)
[0] 9976 <- (0,19947)
[0] 9977 <- (0,19948)
[0] 9978 <- (0,19949)
[0] 9979 <- (0,19950)
[0] 9980 <- (0,19951)
[0] 9981 <- (0,19952)
[0] 9982 <- (0,19953)
[0] 9983 <- (0,19954)
[0] 9984 <- (0,19955)
[0] 9985 <- (0,19956)
[0] 9986 <- (0,19957)
[0] 9987 <- (0,19958)
[0] 9988 <- (0,19959)
[0] 9989 <- (0,19960)
[0] 9990 <- (0,19961)
[0] 9991 <- (0,19962)
[0] 9992 <- (0,19963)
[0] 9993 <- (0,19964)
[0] 9994 <- (0,19965)
[0] 9995 <- (0,19966)
[0] 9996 <- (0,19967)
[0] 9997 <- (0,19996)
[0] 9998 <- (0,19997)
[0] 9999 <- (0,19998)
[0] 10000 <- (0,19999)
[0] 10001 <- (0,20000)
[0] 10002 <- (0,20001)
[0] 10003 <- (0,20002)
[0] 10004 <- (0,20003)
[0] 10005 <- (0,20004)
[0] 10006 <- (0,20005)
[0] 10007 <- (0,20006)
[0] 10008 <- (0,20007)
[0] 10009 <- (0,20008)
[0] 10010 <- (0,20009)
[0] 10011 <- (0,20010)
[0] 10012 <- (0,20011)
[0] 10013 <- (0,20012)
[0] 10014 <- (0,20013)
[0] 10015 <- (0,20014)
[0] 10016 <- (0,20015)
[0] 10017 <- (0,20016)
[0] 10018 <- (0,20017)
[0] 10019 <- (0,20018)
[0] 10020 <- (0,20047)
[0] 10021 <- (0,20048)
[0] 10022 <- (0,20049)
[0] 10023 <- (0,20050)
[0] 10024 <- (0,20051)
[0] 10025 <- (0,20052)
[0] 10026 <- (0,20053)
[0] 10027 <- (0,20054)
[0] 10028 <- (0,20055)
[0] 10029 <- (0,20056)
[0] 10030 <- (0,20057)
[0] 10031 <- (0,20058)
[0] 10032 <- (0,20059)
[0] 10033 <- (0,20060)
[0] 10034 <- (0,20061)
[0] 10035 <- (0,20062)
[0] 10036 <- (0,20063)
[0] 10037 <- (0,20064)
[0] 10038 <- (0,20065)
[0] 10039 <- (0,20066)
[0] 10040 <- (0,20067)
[0] 10041 <- (0,20068)
[0] 10042 <- (0,20069)
[0] 10043 <- (0,20098)
[0] 10044 <- (0,20099)
[0] 10045 <- (0,20100)
[0] 10046 <- (0,20101)
[0] 10047 <- (0,20102)
[0] 10048 <- (0,20103)
[0] 10049 <- (0,20104)
[0] 10050 <- (0,20105)
[0] 10051 <- (0,20106)
[0] 10052 <- (0,20107)
[0] 10053 <- (0,20108)
[0] 10054 <- (0,20109)
[0] 10055 <- (0,20110)
[0] 10056 <- (0,20111)
[0] 10057 <- (0,20112)
[0] 10058 <- (0,20113)
[0] 10059 <- (0,20114)
[0] 10060 <- (0,20115)
[0] 10061 <- (0,20116)
[0] 10062 <- (0,20117)
[0] 10063 <- (0,20118)
[0] 10064 <- (0,20119)
[0] 10065 <- (0,20120)
[0] 10066 <- (0,20121)
[0] 10067 <- (0,20149)
[0] 10068 <- (0,20150)
[0] 10069 <- (0,20151)
[0] 10070 <- (0,20152)
[0] 10071 <- (0,20153)
[0] 10072 <- (0,20154)
[0] 10073 <- (0,20155)
[0] 10074 <- (0,20156)
[0] 10075 <- (0,20157)
[0] 10076 <- (0,20158)
[0] 10077 <- (0,20159)
[0] 10078 <- (0,20160)
[0] 10079 <- (0,20161)
[0] 10080 <- (0,20162)
[0] 10081 <- (0,20163)
[0] 10082 <- (0,20164)
[0] 10083 <- (0,20165)
[0] 10084 <- (0,20166)
[0] 10085 <- (0,20167)
[0] 10086 <- (0,20168)
[0] 10087 <- (0,20169)
[0] 10088 <- (0,20170)
[0] 10089 <- (0,20171)
[0] 10090 <- (0,20172)
[0] 10091 <- (0,20173)
[0] 10092 <- (0,20200)
[0] 10093 <- (0,20201)
[0] 10094 <- (0,20202)
[0] 10095 <- (0,20203)
[0] 10096 <- (0,20204)
[0] 10097 <- (0,20205)
[0] 10098 <- (0,20206)
[0] 10099 <- (0,20207)
[0] 10100 <- (0,20208)
[0] 10101 <- (0,20209)
[0] 10102 <- (0,20210)
[0] 10103 <- (0,20211)
[0] 10104 <- (0,20212)
[0] 10105 <- (0,20213)
[0] 10106 <- (0,20214)
[0] 10107 <- (0,20215)
[0] 10108 <- (0,20216)
[0] 10109 <- (0,20217)
[0] 10110 <- (0,20218)
[0] 10111 <- (0,20219)
[0] 10112 <- (0,20220)
[0] 10113 <- (0,20221)
[0] 10114 <- (0,20222)
[0] 10115 <- (0,20223)
[0] 10116 <- (0,20224)
[0] 10117 <- (0,20251)
[0] 10118 <- (0,20252)
[0] 10119 <- (0,20253)
[0] 10120 <- (0,20254)
[0] 10121 <- (0,20255)
[0] 10122 <- (0,20256)
[0] 10123 <- (0,20257)
[0] 10124 <- (0,20258)
[0] 10125 <- (0,20259)
[0] 10126 <- (0,20260)
[0] 10127 <- (0,20261)
[0] 10128 <- (0,20262)
[0] 10129 <- (0,20263)
[0] 10130 <- (0,20264)
[0] 10131 <- (0,20265)
[0] 10132 <- (0,20266)
[0] 10133 <- (0,20267)
[0] 10134 <- (0,20268)
[0] 10135 <- (0,20269)
[0] 10136 <- (0,20270)
[0] 10137 <- (0,20271)
[0] 10138 <- (0,20272)
[0] 10139 <- (0,20273)
[0] 10140 <- (0,20274)
[0] 10141 <- (0,20275)
[0] 10142 <- (0,20276)
[0] 10143 <- (0,20302)
[0] 10144 <- (0,20303)
[0] 10145 <- (0,20304)
[0] 10146 <- (0,20305)
[0] 10147 <- (0,20306)
[0] 10148 <- (0,20307)
[0] 10149 <- (0,20308)
[0] 10150 <- (0,20309)
[0] 10151 <- (0,20310)
[0] 10152 <- (0,20311)
[0] 10153 <- (0,20312)
[0] 10154 <- (0,20313)
[0] 10155 <- (0,20314)
[0] 10156 <- (0,20315)
[0] 10157 <- (0,20316)
[0] 10158 <- (0,20317)
[0] 10159 <- (0,20318)
[0] 10160 <- (0,20319)
[0] 10161 <- (0,20320)
[0] 10162 <- (0,20321)
[0] 10163 <- (0,20322)
[0] 10164 <- (0,20323)
[0] 10165 <- (0,20324)
[0] 10166 <- (0,20325)
[0] 10167 <- (0,20326)
[0] 10168 <- (0,20327)
[0] 10169 <- (0,20353)
[0] 10170 <- (0,20354)
[0] 10171 <- (0,20355)
[0] 10172 <- (0,20356)
[0] 10173 <- (0,20357)
[0] 10174 <- (0,20358)
[0] 10175 <- (0,20359)
[0] 10176 <- (0,20360)
[0] 10177 <- (0,20361)
[0] 10178 <- (0,20362)
[0] 10179 <- (0,20363)
[0] 10180 <- (0,20364)
[0] 10181 <- (0,20365)
[0] 10182 <- (0,20366)
[0] 10183 <- (0,20367)
[0] 10184 <- (0,20368)
[0] 10185 <- (0,20369)
[0] 10186 <- (0,20370)
[0] 10187 <- (0,20371)
[0] 10188 <- (0,20372)
[0] 10189 <- (0,20373)
[0] 10190 <- (0,20374)
[0] 10191 <- (0,20375)
[0] 10192 <- (0,20376)
[0] 10193 <- (0,20377)
[0] 10194 <- (0,20378)
[0] 10195 <- (0,20379)
[0] 10196 <- (0,20404)
[0] 10197 <- (0,20405)
[0] 10198 <- (0,20406)
[0] 10199 <- (0,20407)
[0] 10200 <- (0,20408)
[0] 10201 <- (0,20409)
[0] 10202 <- (0,20410)
[0] 10203 <- (0,20411)
[0] 10204 <- (0,20412)
[0] 10205 <- (0,20413)
[0] 10206 <- (0,20414)
[0] 10207 <- (0,20415)
[0] 10208 <- (0,20416)
[0] 10209 <- (0,20417)
[0] 10210 <- (0,20418)
[0] 10211 <- (0,20419)
[0] 10212 <- (0,20420)
[0] 10213 <- (0,20421)
[0] 10214 <- (0,20422)
[0] 10215 <- (0,20423)
[0] 10216 <- (0,20424)
[0] 10217 <- (0,20425)
[0] 10218 <- (0,20426)
[0] 10219 <- (0,20427)
[0] 10220 <- (0,20428)
[0] 10221 <- (0,20429)
[0] 10222 <- (0,20430)
[0] 10223 <- (0,20455)
[0] 10224 <- (0,20456)
[0] 10225 <- (0,20457)
[0] 10226 <- (0,20458)
[0] 10227 <- (0,20459)
[0] 10228 <- (0,20460)
[0] 10229 <- (0,20461)
[0] 10230 <- (0,20462)
[0] 10231 <- (0,20463)
[0] 10232 <- (0,20464)
[0] 10233 <- (0,20465)
[0] 10234 <- (0,20466)
[0] 10235 <- (0,20467)
[0] 10236 <- (0,20468)
[0] 10237 <- (0,20469)
[0] 10238 <- (0,20470)
[0] 10239 <- (0,20471)
[0] 10240 <- (0,20472)
[0] 10241 <- (0,20473)
[0] 10242 <- (0,20474)
[0] 10243 <- (0,20475)
[0] 10244 <- (0,20476)
[0] 10245 <- (0,20477)
[0] 10246 <- (0,20478)
[0] 10247 <- (0,20479)
[0] 10248 <- (0,20480)
[0] 10249 <- (0,20481)
[0] 10250 <- (0,20506)
[0] 10251 <- (0,20507)
[0] 10252 <- (0,20508)
[0] 10253 <- (0,20509)
[0] 10254 <- (0,20510)
[0] 10255 <- (0,20511)
[0] 10256 <- (0,20512)
[0] 10257 <- (0,20513)
[0] 10258 <- (0,20514)
[0] 10259 <- (0,20515)
[0] 10260 <- (0,20516)
[0] 10261 <- (0,20517)
[0] 10262 <- (0,20518)
[0] 10263 <- (0,20519)
[0] 10264 <- (0,20520)
[0] 10265 <- (0,20521)
[0] 10266 <- (0,20522)
[0] 10267 <- (0,20523)
[0] 10268 <- (0,20524)
[0] 10269 <- (0,20525)
[0] 10270 <- (0,20526)
[0] 10271 <- (0,20527)
[0] 10272 <- (0,20528)
[0] 10273 <- (0,20529)
[0] 10274 <- (0,20530)
[0] 10275 <- (0,20531)
[0] 10276 <- (0,20532)
[0] 10277 <- (0,20557)
[0] 10278 <- (0,20558)
[0] 10279 <- (0,20559)
[0] 10280 <- (0,20560)
[0] 10281 <- (0,20561)
[0] 10282 <- (0,20562)
[0] 10283 <- (0,20563)
[0] 10284 <- (0,20564)
[0] 10285 <- (0,20565)
[0] 10286 <- (0,20566)
[0] 10287 <- (0,20567)
[0] 10288 <- (0,20568)
[0] 10289 <- (0,20569)
[0] 10290 <- (0,20570)
[0] 10291 <- (0,20571)
[0] 10292 <- (0,20572)
[0] 10293 <- (0,20573)
[0] 10294 <- (0,20574)
[0] 10295 <- (0,20575)
[0] 10296 <- (0,20576)
[0] 10297 <- (0,20577)
[0] 10298 <- (0,20578)
[0] 10299 <- (0,20579)
[0] 10300 <- (0,20580)
[0] 10301 <- (0,20581)
[0] 10302 <- (0,20582)
[0] 10303 <- (0,20583)
[0] 10304 <- (0,20608)
[0] 10305 <- (0,20609)
[0] 10306 <- (0,20610)
[0] 10307 <- (0,20611)
[0] 10308 <- (0,20612)
[0] 10309 <- (0,20613)
[0] 10310 <- (0,20614)
[0] 10311 <- (0,20615)
[0] 10312 <- (0,20616)
[0] 10313 <- (0,20617)
[0] 10314 <- (0,20618)
[0] 10315 <- (0,20619)
[0] 10316 <- (0,20620)
[0] 10317 <- (0,20621)
[0] 10318 <- (0,20622)
[0] 10319 <- (0,20623)
[0] 10320 <- (0,20624)
[0] 10321 <- (0,20625)
[0] 10322 <- (0,20626)
[0] 10323 <- (0,20627)
[0] 10324 <- (0,20628)
[0] 10325 <- (0,20629)
[0] 10326 <- (0,20630)
[0] 10327 <- (0,20631)
[0] 10328 <- (0,20632)
[0] 10329 <- (0,20633)
[0] 10330 <- (0,20634)
[0] 10331 <- (0,20659)
[0] 10332 <- (0,20660)
[0] 10333 <- (0,20661)
[0] 10334 <- (0,20662)
[0] 10335 <- (0,20663)
[0] 10336 <- (0,20664)
[0] 10337 <- (0,20665)
[0] 10338 <- (0,20666)
[0] 10339 <- (0,20667)
[0] 10340 <- (0,20668)
[0] 10341 <- (0,20669)
[0] 10342 <- (0,20670)
[0] 10343 <- (0,20671)
[0] 10344 <- (0,20672)
[0] 10345 <- (0,20673)
[0] 10346 <- (0,20674)
[0] 10347 <- (0,20675)
[0] 10348 <- (0,20676)
[0] 10349 <- (0,20677)
[0] 10350 <- (0,20678)
[0] 10351 <- (0,20679)
[0] 10352 <- (0,20680)
[0] 10353 <- (0,20681)
[0] 10354 <- (0,20682)
[0] 10355 <- (0,20683)
[0] 10356 <- (0,20684)
[0] 10357 <- (0,20685)
[0] 10358 <- (0,20710)
[0] 10359 <- (0,20711)
[0] 10360 <- (0,20712)
[0] 10361 <- (0,20713)
[0] 10362 <- (0,20714)
[0] 10363 <- (0,20715)
[0] 10364 <- (0,20716)
[0] 10365 <- (0,20717)
[0] 10366 <- (0,20718)
[0] 10367 <- (0,20719)
[0] 10368 <- (0,20720)
[0] 10369 <- (0,20721)
[0] 10370 <- (0,20722)
[0] 10371 <- (0,20723)
[0] 10372 <- (0,20724)
[0] 10373 <- (0,20725)
[0] 10374 <- (0,20726)
[0] 10375 <- (0,20727)
[0] 10376 <- (0,20728)
[0] 10377 <- (0,20729)
[0] 10378 <- (0,20730)
[0] 10379 <- (0,20731)
[0] 10380 <- (0,20761)
[0] 10381 <- (0,20762)
[0] 10382 <- (0,20763)
[0] 10383 <- (0,20764)
[0] 10384 <- (0,20765)
[0] 10385 <- (0,20766)
[0] 10386 <- (0,20767)
[0] 10387 <- (0,20768)
[0] 10388 <- (0,20769)
[0] 10389 <- (0,20770)
[0] 10390 <- (0,20771)
[0] 10391 <- (0,20772)
[0] 10392 <- (0,20773)
[0] 10393 <- (0,20774)
[0] 10394 <- (0,20775)
[0] 10395 <- (0,20776)
[0] 10396 <- (0,20777)
[0] 10397 <- (0,20778)
[0] 10398 <- (0,20779)
[0] 10399 <- (0,20780)
[0] 10400 <- (0,20781)
[0] 10401 <- (0,20782)
[0] 10402 <- (0,20812)
[0] 10403 <- (0,20813)
[0] 10404 <- (0,20814)
[0] 10405 <- (0,20815)
[0] 10406 <- (0,20816)
[0] 10407 <- (0,20817)
[0] 10408 <- (0,20818)
[0] 10409 <- (0,20819)
[0] 10410 <- (0,20820)
[0] 10411 <- (0,20821)
[0] 10412 <- (0,20822)
[0] 10413 <- (0,20823)
[0] 10414 <- (0,20824)
[0] 10415 <- (0,20825)
[0] 10416 <- (0,20826)
[0] 10417 <- (0,20827)
[0] 10418 <- (0,20828)
[0] 10419 <- (0,20829)
[0] 10420 <- (0,20830)
[0] 10421 <- (0,20831)
[0] 10422 <- (0,20832)
[0] 10423 <- (0,20833)
[0] 10424 <- (0,20863)
[0] 10425 <- (0,20864)
[0] 10426 <- (0,20865)
[0] 10427 <- (0,20866)
[0] 10428 <- (0,20867)
[0] 10429 <- (0,20868)
[0] 10430 <- (0,20869)
[0] 10431 <- (0,20870)
[0] 10432 <- (0,20871)
[0] 10433 <- (0,20872)
[0] 10434 <- (0,20873)
[0] 10435 <- (0,20874)
[0] 10436 <- (0,20875)
[0] 10437 <- (0,20876)
[0] 10438 <- (0,20877)
[0] 10439 <- (0,20878)
[0] 10440 <- (0,20879)
[0] 10441 <- (0,20880)
[0] 10442 <- (0,20881)
[0] 10443 <- (0,20882)
[0] 10444 <- (0,20883)
[0] 10445 <- (0,20884)
[0] 10446 <- (0,20914)
[0] 10447 <- (0,20915)
[0] 10448 <- (0,20916)
[0] 10449 <- (0,20917)
[0] 10450 <- (0,20918)
[0] 10451 <- (0,20919)
[0] 10452 <- (0,20920)
[0] 10453 <- (0,20921)
[0] 10454 <- (0,20922)
[0] 10455 <- (0,20923)
[0] 10456 <- (0,20924)
[0] 10457 <- (0,20925)
[0] 10458 <- (0,20926)
[0] 10459 <- (0,20927)
[0] 10460 <- (0,20928)
[0] 10461 <- (0,20929)
[0] 10462 <- (0,20930)
[0] 10463 <- (0,20931)
[0] 10464 <- (0,20932)
[0] 10465 <- (0,20933)
[0] 10466 <- (0,20934)
[0] 10467 <- (0,20935)
[0] 10468 <- (0,20965)
[0] 10469 <- (0,20966)
[0] 10470 <- (0,20967)
[0] 10471 <- (0,20968)
[0] 10472 <- (0,20969)
[0] 10473 <- (0,20970)
[0] 10474 <- (0,20971)
[0] 10475 <- (0,20972)
[0] 10476 <- (0,20973)
[0] 10477 <- (0,20974)
[0] 10478 <- (0,20975)
[0] 10479 <- (0,20976)
[0] 10480 <- (0,20977)
[0] 10481 <- (0,20978)
[0] 10482 <- (0,20979)
[0] 10483 <- (0,20980)
[0] 10484 <- (0,20981)
[0] 10485 <- (0,20982)
[0] 10486 <- (0,20983)
[0] 10487 <- (0,20984)
[0] 10488 <- (0,20985)
[0] 10489 <- (0,20986)
[0] 10490 <- (0,20987)
[0] 10491 <- (0,21016)
[0] 10492 <- (0,21017)
[0] 10493 <- (0,21018)
[0] 10494 <- (0,21019)
[0] 10495 <- (0,21020)
[0] 10496 <- (0,21021)
[0] 10497 <- (0,21022)
[0] 10498 <- (0,21023)
[0] 10499 <- (0,21024)
[0] 10500 <- (0,21025)
[0] 10501 <- (0,21026)
[0] 10502 <- (0,21027)
[0] 10503 <- (0,21028)
[0] 10504 <- (0,21029)
[0] 10505 <- (0,21030)
[0] 10506 <- (0,21031)
[0] 10507 <- (0,21032)
[0] 10508 <- (0,21033)
[0] 10509 <- (0,21034)
[0] 10510 <- (0,21035)
[0] 10511 <- (0,21036)
[0] 10512 <- (0,21037)
[0] 10513 <- (0,21038)
[0] 10514 <- (0,21067)
[0] 10515 <- (0,21068)
[0] 10516 <- (0,21069)
[0] 10517 <- (0,21070)
[0] 10518 <- (0,21071)
[0] 10519 <- (0,21072)
[0] 10520 <- (0,21073)
[0] 10521 <- (0,21074)
[0] 10522 <- (0,21075)
[0] 10523 <- (0,21076)
[0] 10524 <- (0,21077)
[0] 10525 <- (0,21078)
[0] 10526 <- (0,21079)
[0] 10527 <- (0,21080)
[0] 10528 <- (0,21081)
[0] 10529 <- (0,21082)
[0] 10530 <- (0,21083)
[0] 10531 <- (0,21084)
[0] 10532 <- (0,21085)
[0] 10533 <- (0,21086)
[0] 10534 <- (0,21087)
[0] 10535 <- (0,21088)
[0] 10536 <- (0,21089)
[0] 10537 <- (0,21118)
[0] 10538 <- (0,21119)
[0] 10539 <- (0,21120)
[0] 10540 <- (0,21121)
[0] 10541 <- (0,21122)
[0] 10542 <- (0,21123)
[0] 10543 <- (0,21124)
[0] 10544 <- (0,21125)
[0] 10545 <- (0,21126)
[0] 10546 <- (0,21127)
[0] 10547 <- (0,21128)
[0] 10548 <- (0,21129)
[0] 10549 <- (0,21130)
[0] 10550 <- (0,21131)
[0] 10551 <- (0,21132)
[0] 10552 <- (0,21133)
[0] 10553 <- (0,21134)
[0] 10554 <- (0,21135)
[0] 10555 <- (0,21136)
[0] 10556 <- (0,21137)
[0] 10557 <- (0,21138)
[0] 10558 <- (0,21139)
[0] 10559 <- (0,21140)
[0] 10560 <- (0,21169)
[0] 10561 <- (0,21170)
[0] 10562 <- (0,21171)
[0] 10563 <- (0,21172)
[0] 10564 <- (0,21173)
[0] 10565 <- (0,21174)
[0] 10566 <- (0,21175)
[0] 10567 <- (0,21176)
[0] 10568 <- (0,21177)
[0] 10569 <- (0,21178)
[0] 10570 <- (0,21179)
[0] 10571 <- (0,21180)
[0] 10572 <- (0,21181)
[0] 10573 <- (0,21182)
[0] 10574 <- (0,21183)
[0] 10575 <- (0,21184)
[0] 10576 <- (0,21185)
[0] 10577 <- (0,21186)
[0] 10578 <- (0,21187)
[0] 10579 <- (0,21188)
[0] 10580 <- (0,21189)
[0] 10581 <- (0,21190)
[0] 10582 <- (0,21191)
[0] 10583 <- (0,21192)
[0] 10584 <- (0,21220)
[0] 10585 <- (0,21221)
[0] 10586 <- (0,21222)
[0] 10587 <- (0,21223)
[0] 10588 <- (0,21224)
[0] 10589 <- (0,21225)
[0] 10590 <- (0,21226)
[0] 10591 <- (0,21227)
[0] 10592 <- (0,21228)
[0] 10593 <- (0,21229)
[0] 10594 <- (0,21230)
[0] 10595 <- (0,21231)
[0] 10596 <- (0,21232)
[0] 10597 <- (0,21233)
[0] 10598 <- (0,21234)
[0] 10599 <- (0,21235)
[0] 10600 <- (0,21236)
[0] 10601 <- (0,21237)
[0] 10602 <- (0,21238)
[0] 10603 <- (0,21239)
[0] 10604 <- (0,21240)
[0] 10605 <- (0,21241)
[0] 10606 <- (0,21242)
[0] 10607 <- (0,21243)
[0] 10608 <- (0,21244)
[0] 10609 <- (0,21271)
[0] 10610 <- (0,21272)
[0] 10611 <- (0,21273)
[0] 10612 <- (0,21274)
[0] 10613 <- (0,21275)
[0] 10614 <- (0,21276)
[0] 10615 <- (0,21277)
[0] 10616 <- (0,21278)
[0] 10617 <- (0,21279)
[0] 10618 <- (0,21280)
[0] 10619 <- (0,21281)
[0] 10620 <- (0,21282)
[0] 10621 <- (0,21283)
[0] 10622 <- (0,21284)
[0] 10623 <- (0,21285)
[0] 10624 <- (0,21286)
[0] 10625 <- (0,21287)
[0] 10626 <- (0,21288)
[0] 10627 <- (0,21289)
[0] 10628 <- (0,21290)
[0] 10629 <- (0,21291)
[0] 10630 <- (0,21292)
[0] 10631 <- (0,21293)
[0] 10632 <- (0,21294)
[0] 10633 <- (0,21295)
[0] 10634 <- (0,21322)
[0] 10635 <- (0,21323)
[0] 10636 <- (0,21324)
[0] 10637 <- (0,21325)
[0] 10638 <- (0,21326)
[0] 10639 <- (0,21327)
[0] 10640 <- (0,21328)
[0] 10641 <- (0,21329)
[0] 10642 <- (0,21330)
[0] 10643 <- (0,21331)
[0] 10644 <- (0,21332)
[0] 10645 <- (0,21333)
[0] 10646 <- (0,21334)
[0] 10647 <- (0,21335)
[0] 10648 <- (0,21336)
[0] 10649 <- (0,21337)
[0] 10650 <- (0,21338)
[0] 10651 <- (0,21339)
[0] 10652 <- (0,21340)
[0] 10653 <- (0,21341)
[0] 10654 <- (0,21342)
[0] 10655 <- (0,21343)
[0] 10656 <- (0,21344)
[0] 10657 <- (0,21345)
[0] 10658 <- (0,21346)
[0] 10659 <- (0,21347)
[0] 10660 <- (0,21373)
[0] 10661 <- (0,21374)
[0] 10662 <- (0,21375)
[0] 10663 <- (0,21376)
[0] 10664 <- (0,21377)
[0] 10665 <- (0,21378)
[0] 10666 <- (0,21379)
[0] 10667 <- (0,21380)
[0] 10668 <- (0,21381)
[0] 10669 <- (0,21382)
[0] 10670 <- (0,21383)
[0] 10671 <- (0,21384)
[0] 10672 <- (0,21385)
[0] 10673 <- (0,21386)
[0] 10674 <- (0,21387)
[0] 10675 <- (0,21388)
[0] 10676 <- (0,21389)
[0] 10677 <- (0,21390)
[0] 10678 <- (0,21391)
[0] 10679 <- (0,21392)
[0] 10680 <- (0,21393)
[0] 10681 <- (0,21394)
[0] 10682 <- (0,21395)
[0] 10683 <- (0,21396)
[0] 10684 <- (0,21397)
[0] 10685 <- (0,21398)
[0] 10686 <- (0,21424)
[0] 10687 <- (0,21425)
[0] 10688 <- (0,21426)
[0] 10689 <- (0,21427)
[0] 10690 <- (0,21428)
[0] 10691 <- (0,21429)
[0] 10692 <- (0,21430)
[0] 10693 <- (0,21431)
[0] 10694 <- (0,21432)
[0] 10695 <- (0,21433)
[0] 10696 <- (0,21434)
[0] 10697 <- (0,21435)
[0] 10698 <- (0,21436)
[0] 10699 <- (0,21437)
[0] 10700 <- (0,21438)
[0] 10701 <- (0,21439)
[0] 10702 <- (0,21440)
[0] 10703 <- (0,21441)
[0] 10704 <- (0,21442)
[0] 10705 <- (0,21443)
[0] 10706 <- (0,21444)
[0] 10707 <- (0,21445)
[0] 10708 <- (0,21446)
[0] 10709 <- (0,21447)
[0] 10710 <- (0,21448)
[0] 10711 <- (0,21449)
[0] 10712 <- (0,21450)
[0] 10713 <- (0,21475)
[0] 10714 <- (0,21476)
[0] 10715 <- (0,21477)
[0] 10716 <- (0,21478)
[0] 10717 <- (0,21479)
[0] 10718 <- (0,21480)
[0] 10719 <- (0,21481)
[0] 10720 <- (0,21482)
[0] 10721 <- (0,21483)
[0] 10722 <- (0,21484)
[0] 10723 <- (0,21485)
[0] 10724 <- (0,21486)
[0] 10725 <- (0,21487)
[0] 10726 <- (0,21488)
[0] 10727 <- (0,21489)
[0] 10728 <- (0,21490)
[0] 10729 <- (0,21491)
[0] 10730 <- (0,21492)
[0] 10731 <- (0,21493)
[0] 10732 <- (0,21494)
[0] 10733 <- (0,21495)
[0] 10734 <- (0,21496)
[0] 10735 <- (0,21497)
[0] 10736 <- (0,21498)
[0] 10737 <- (0,21499)
[0] 10738 <- (0,21500)
[0] 10739 <- (0,21501)
[0] 10740 <- (0,21526)
[0] 10741 <- (0,21527)
[0] 10742 <- (0,21528)
[0] 10743 <- (0,21529)
[0] 10744 <- (0,21530)
[0] 10745 <- (0,21531)
[0] 10746 <- (0,21532)
[0] 10747 <- (0,21533)
[0] 10748 <- (0,21534)
[0] 10749 <- (0,21535)
[0] 10750 <- (0,21536)
[0] 10751 <- (0,21537)
[0] 10752 <- (0,21538)
[0] 10753 <- (0,21539)
[0] 10754 <- (0,21540)
[0] 10755 <- (0,21541)
[0] 10756 <- (0,21542)
[0] 10757 <- (0,21543)
[0] 10758 <- (0,21544)
[0] 10759 <- (0,21545)
[0] 10760 <- (0,21546)
[0] 10761 <- (0,21547)
[0] 10762 <- (0,21548)
[0] 10763 <- (0,21549)
[0] 10764 <- (0,21550)
[0] 10765 <- (0,21551)
[0] 10766 <- (0,21552)
[0] 10767 <- (0,21577)
[0] 10768 <- (0,21578)
[0] 10769 <- (0,21579)
[0] 10770 <- (0,21580)
[0] 10771 <- (0,21581)
[0] 10772 <- (0,21582)
[0] 10773 <- (0,21583)
[0] 10774 <- (0,21584)
[0] 10775 <- (0,21585)
[0] 10776 <- (0,21586)
[0] 10777 <- (0,21587)
[0] 10778 <- (0,21588)
[0] 10779 <- (0,21589)
[0] 10780 <- (0,21590)
[0] 10781 <- (0,21591)
[0] 10782 <- (0,21592)
[0] 10783 <- (0,21593)
[0] 10784 <- (0,21594)
[0] 10785 <- (0,21595)
[0] 10786 <- (0,21596)
[0] 10787 <- (0,21597)
[0] 10788 <- (0,21598)
[0] 10789 <- (0,21599)
[0] 10790 <- (0,21600)
[0] 10791 <- (0,21601)
[0] 10792 <- (0,21602)
[0] 10793 <- (0,21603)
[0] 10794 <- (0,21628)
[0] 10795 <- (0,21629)
[0] 10796 <- (0,21630)
[0] 10797 <- (0,21631)
[0] 10798 <- (0,21632)
[0] 10799 <- (0,21633)
[0] 10800 <- (0,21634)
[0] 10801 <- (0,21635)
[0] 10802 <- (0,21636)
[0] 10803 <- (0,21637)
[0] 10804 <- (0,21638)
[0] 10805 <- (0,21639)
[0] 10806 <- (0,21640)
[0] 10807 <- (0,21641)
[0] 10808 <- (0,21642)
[0] 10809 <- (0,21643)
[0] 10810 <- (0,21644)
[0] 10811 <- (0,21645)
[0] 10812 <- (0,21646)
[0] 10813 <- (0,21647)
[0] 10814 <- (0,21648)
[0] 10815 <- (0,21649)
[0] 10816 <- (0,21650)
[0] 10817 <- (0,21651)
[0] 10818 <- (0,21652)
[0] 10819 <- (0,21653)
[0] 10820 <- (0,21654)
[0] 10821 <- (0,21679)
[0] 10822 <- (0,21680)
[0] 10823 <- (0,21681)
[0] 10824 <- (0,21682)
[0] 10825 <- (0,21683)
[0] 10826 <- (0,21684)
[0] 10827 <- (0,21685)
[0] 10828 <- (0,21686)
[0] 10829 <- (0,21687)
[0] 10830 <- (0,21688)
[0] 10831 <- (0,21689)
[0] 10832 <- (0,21690)
[0] 10833 <- (0,21691)
[0] 10834 <- (0,21692)
[0] 10835 <- (0,21693)
[0] 10836 <- (0,21694)
[0] 10837 <- (0,21695)
[0] 10838 <- (0,21696)
[0] 10839 <- (0,21697)
[0] 10840 <- (0,21698)
[0] 10841 <- (0,21699)
[0] 10842 <- (0,21700)
[0] 10843 <- (0,21701)
[0] 10844 <- (0,21702)
[0] 10845 <- (0,21703)
[0] 10846 <- (0,21704)
[0] 10847 <- (0,21705)
[0] 10848 <- (0,21730)
[0] 10849 <- (0,21731)
[0] 10850 <- (0,21732)
[0] 10851 <- (0,21733)
[0] 10852 <- (0,21734)
[0] 10853 <- (0,21735)
[0] 10854 <- (0,21736)
[0] 10855 <- (0,21737)
[0] 10856 <- (0,21738)
[0] 10857 <- (0,21739)
[0] 10858 <- (0,21740)
[0] 10859 <- (0,21741)
[0] 10860 <- (0,21742)
[0] 10861 <- (0,21743)
[0] 10862 <- (0,21744)
[0] 10863 <- (0,21745)
[0] 10864 <- (0,21746)
[0] 10865 <- (0,21747)
[0] 10866 <- (0,21748)
[0] 10867 <- (0,21749)
[0] 10868 <- (0,21750)
[0] 10869 <- (0,21751)
[0] 10870 <- (0,21752)
[0] 10871 <- (0,21753)
[0] 10872 <- (0,21754)
[0] 10873 <- (0,21755)
[0] 10874 <- (0,21756)
[0] 10875 <- (0,10022)
[0] 10876 <- (0,10023)
[0] 10877 <- (0,10073)
[0] 10878 <- (0,10074)
[0] 10879 <- (0,10124)
[0] 10880 <- (0,10125)
[0] 10881 <- (0,10175)
[0] 10882 <- (0,10176)
[0] 10883 <- (0,10177)
[0] 10884 <- (0,10226)
[0] 10885 <- (0,10227)
[0] 10886 <- (0,10228)
[0] 10887 <- (0,10278)
[0] 10888 <- (0,10279)
[0] 10889 <- (0,10329)
[0] 10890 <- (0,10330)
[0] 10891 <- (0,10380)
[0] 10892 <- (0,10381)
[0] 10893 <- (0,10382)
[0] 10894 <- (0,10431)
[0] 10895 <- (0,10432)
[0] 10896 <- (0,10433)
[0] 10897 <- (0,10483)
[0] 10898 <- (0,10484)
[0] 10899 <- (0,10485)
[0] 10900 <- (0,10534)
[0] 10901 <- (0,10535)
[0] 10902 <- (0,10536)
[0] 10903 <- (0,10537)
[0] 10904 <- (0,10586)
[0] 10905 <- (0,10587)
[0] 10906 <- (0,10588)
[0] 10907 <- (0,10638)
[0] 10908 <- (0,10639)
[0] 10909 <- (0,10640)
[0] 10910 <- (0,10689)
[0] 10911 <- (0,10690)
[0] 10912 <- (0,10691)
[0] 10913 <- (0,10741)
[0] 10914 <- (0,10742)
[0] 10915 <- (0,10792)
[0] 10916 <- (0,10793)
[0] 10917 <- (0,10843)
[0] 10918 <- (0,10844)
[0] 10919 <- (0,10894)
[0] 10920 <- (0,10895)
[0] 10921 <- (0,10945)
[0] 10922 <- (0,10946)
[0] 10923 <- (0,10996)
[0] 10924 <- (0,10997)
[0] 10925 <- (0,11047)
[0] 10926 <- (0,11048)
[0] 10927 <- (0,11093)
[0] 10928 <- (0,11094)
[0] 10929 <- (0,11144)
[0] 10930 <- (0,11145)
[0] 10931 <- (0,11195)
[0] 10932 <- (0,11196)
[0] 10933 <- (0,11246)
[0] 10934 <- (0,11247)
[0] 10935 <- (0,11248)
[0] 10936 <- (0,11297)
[0] 10937 <- (0,11298)
[0] 10938 <- (0,11299)
[0] 10939 <- (0,11349)
[0] 10940 <- (0,11350)
[0] 10941 <- (0,11400)
[0] 10942 <- (0,11401)
[0] 10943 <- (0,11451)
[0] 10944 <- (0,11452)
[0] 10945 <- (0,11453)
[0] 10946 <- (0,11502)
[0] 10947 <- (0,11503)
[0] 10948 <- (0,11504)
[0] 10949 <- (0,11554)
[0] 10950 <- (0,11555)
[0] 10951 <- (0,11556)
[0] 10952 <- (0,11605)
[0] 10953 <- (0,11606)
[0] 10954 <- (0,11607)
[0] 10955 <- (0,11608)
[0] 10956 <- (0,11657)
[0] 10957 <- (0,11658)
[0] 10958 <- (0,11659)
[0] 10959 <- (0,11709)
[0] 10960 <- (0,11710)
[0] 10961 <- (0,11711)
[0] 10962 <- (0,11760)
[0] 10963 <- (0,11761)
[0] 10964 <- (0,11762)
[0] 10965 <- (0,11812)
[0] 10966 <- (0,11813)
[0] 10967 <- (0,11863)
[0] 10968 <- (0,11864)
[0] 10969 <- (0,11914)
[0] 10970 <- (0,11915)
[0] 10971 <- (0,11965)
[0] 10972 <- (0,11966)
[0] 10973 <- (0,12016)
[0] 10974 <- (0,12017)
[0] 10975 <- (0,12067)
[0] 10976 <- (0,12068)
[0] 10977 <- (0,12118)
[0] 10978 <- (0,12119)
[0] 10979 <- (0,12164)
[0] 10980 <- (0,12165)
[0] 10981 <- (0,12215)
[0] 10982 <- (0,12216)
[0] 10983 <- (0,12266)
[0] 10984 <- (0,12267)
[0] 10985 <- (0,12317)
[0] 10986 <- (0,12318)
[0] 10987 <- (0,12319)
[0] 10988 <- (0,12368)
[0] 10989 <- (0,12369)
[0] 10990 <- (0,12370)
[0] 10991 <- (0,12420)
[0] 10992 <- (0,12421)
[0] 10993 <- (0,12471)
[0] 10994 <- (0,12472)
[0] 10995 <- (0,12522)
[0] 10996 <- (0,12523)
[0] 10997 <- (0,12524)
[0] 10998 <- (0,12573)
[0] 10999 <- (0,12574)
[0] 11000 <- (0,12575)
[0] 11001 <- (0,12625)
[0] 11002 <- (0,12626)
[0] 11003 <- (0,12627)
[0] 11004 <- (0,12676)
[0] 11005 <- (0,12677)
[0] 11006 <- (0,12678)
[0] 11007 <- (0,12679)
[0] 11008 <- (0,12728)
[0] 11009 <- (0,12729)
[0] 11010 <- (0,12730)
[0] 11011 <- (0,12780)
[0] 11012 <- (0,12781)
[0] 11013 <- (0,12782)
[0] 11014 <- (0,12831)
[0] 11015 <- (0,12832)
[0] 11016 <- (0,12833)
[0] 11017 <- (0,12883)
[0] 11018 <- (0,12884)
[0] 11019 <- (0,12934)
[0] 11020 <- (0,12935)
[0] 11021 <- (0,12985)
[0] 11022 <- (0,12986)
[0] 11023 <- (0,13036)
[0] 11024 <- (0,13037)
[0] 11025 <- (0,13087)
[0] 11026 <- (0,13088)
[0] 11027 <- (0,13138)
[0] 11028 <- (0,13139)
[0] 11029 <- (0,13189)
[0] 11030 <- (0,13190)
[0] 11031 <- (0,13235)
[0] 11032 <- (0,13236)
[0] 11033 <- (0,13286)
[0] 11034 <- (0,13287)
[0] 11035 <- (0,13337)
[0] 11036 <- (0,13338)
[0] 11037 <- (0,13388)
[0] 11038 <- (0,13389)
[0] 11039 <- (0,13390)
[0] 11040 <- (0,13439)
[0] 11041 <- (0,13440)
[0] 11042 <- (0,13441)
[0] 11043 <- (0,13491)
[0] 11044 <- (0,13492)
[0] 11045 <- (0,13542)
[0] 11046 <- (0,13543)
[0] 11047 <- (0,13593)
[0] 11048 <- (0,13594)
[0] 11049 <- (0,13595)
[0] 11050 <- (0,13644)
[0] 11051 <- (0,13645)
[0] 11052 <- (0,13646)
[0] 11053 <- (0,13696)
[0] 11054 <- (0,13697)
[0] 11055 <- (0,13698)
[0] 11056 <- (0,13747)
[0] 11057 <- (0,13748)
[0] 11058 <- (0,13749)
[0] 11059 <- (0,13750)
[0] 11060 <- (0,13799)
[0] 11061 <- (0,13800)
[0] 11062 <- (0,13801)
[0] 11063 <- (0,13851)
[0] 11064 <- (0,13852)
[0] 11065 <- (0,13853)
[0] 11066 <- (0,13902)
[0] 11067 <- (0,13903)
[0] 11068 <- (0,13904)
[0] 11069 <- (0,13954)
[0] 11070 <- (0,13955)
[0] 11071 <- (0,14005)
[0] 11072 <- (0,14006)
[0] 11073 <- (0,14056)
[0] 11074 <- (0,14057)
[0] 11075 <- (0,14107)
[0] 11076 <- (0,14108)
[0] 11077 <- (0,14158)
[0] 11078 <- (0,14159)
[0] 11079 <- (0,14209)
[0] 11080 <- (0,14210)
[0] 11081 <- (0,14260)
[0] 11082 <- (0,14261)
[0] 11083 <- (0,14306)
[0] 11084 <- (0,14307)
[0] 11085 <- (0,14357)
[0] 11086 <- (0,14358)
[0] 11087 <- (0,14408)
[0] 11088 <- (0,14409)
[0] 11089 <- (0,14459)
[0] 11090 <- (0,14460)
[0] 11091 <- (0,14461)
[0] 11092 <- (0,14510)
[0] 11093 <- (0,14511)
[0] 11094 <- (0,14512)
[0] 11095 <- (0,14562)
[0] 11096 <- (0,14563)
[0] 11097 <- (0,14613)
[0] 11098 <- (0,14614)
[0] 11099 <- (0,14664)
[0] 11100 <- (0,14665)
[0] 11101 <- (0,14666)
[0] 11102 <- (0,14715)
[0] 11103 <- (0,14716)
[0] 11104 <- (0,14717)
[0] 11105 <- (0,14767)
[0] 11106 <- (0,14768)
[0] 11107 <- (0,14769)
[0] 11108 <- (0,14818)
[0] 11109 <- (0,14819)
[0] 11110 <- (0,14820)
[0] 11111 <- (0,14821)
[0] 11112 <- (0,14870)
[0] 11113 <- (0,14871)
[0] 11114 <- (0,14872)
[0] 11115 <- (0,14922)
[0] 11116 <- (0,14923)
[0] 11117 <- (0,14924)
[0] 11118 <- (0,14973)
[0] 11119 <- (0,14974)
[0] 11120 <- (0,14975)
[0] 11121 <- (0,15025)
[0] 11122 <- (0,15026)
[0] 11123 <- (0,15076)
[0] 11124 <- (0,15077)
[0] 11125 <- (0,15127)
[0] 11126 <- (0,15128)
[0] 11127 <- (0,15178)
[0] 11128 <- (0,15179)
[0] 11129 <- (0,15229)
[0] 11130 <- (0,15230)
[0] 11131 <- (0,15280)
[0] 11132 <- (0,15281)
[0] 11133 <- (0,15331)
[0] 11134 <- (0,15332)
[0] 11135 <- (0,15377)
[0] 11136 <- (0,15378)
[0] 11137 <- (0,15428)
[0] 11138 <- (0,15429)
[0] 11139 <- (0,15479)
[0] 11140 <- (0,15480)
[0] 11141 <- (0,15530)
[0] 11142 <- (0,15531)
[0] 11143 <- (0,15532)
[0] 11144 <- (0,15581)
[0] 11145 <- (0,15582)
[0] 11146 <- (0,15583)
[0] 11147 <- (0,15633)
[0] 11148 <- (0,15634)
[0] 11149 <- (0,15684)
[0] 11150 <- (0,15685)
[0] 11151 <- (0,15735)
[0] 11152 <- (0,15736)
[0] 11153 <- (0,15737)
[0] 11154 <- (0,15786)
[0] 11155 <- (0,15787)
[0] 11156 <- (0,15788)
[0] 11157 <- (0,15789)
[0] 11158 <- (0,15838)
[0] 11159 <- (0,15839)
[0] 11160 <- (0,15840)
[0] 11161 <- (0,15889)
[0] 11162 <- (0,15890)
[0] 11163 <- (0,15891)
[0] 11164 <- (0,15892)
[0] 11165 <- (0,15941)
[0] 11166 <- (0,15942)
[0] 11167 <- (0,15943)
[0] 11168 <- (0,15993)
[0] 11169 <- (0,15994)
[0] 11170 <- (0,15995)
[0] 11171 <- (0,16044)
[0] 11172 <- (0,16045)
[0] 11173 <- (0,16046)
[0] 11174 <- (0,16096)
[0] 11175 <- (0,16097)
[0] 11176 <- (0,16147)
[0] 11177 <- (0,16148)
[0] 11178 <- (0,16198)
[0] 11179 <- (0,16199)
[0] 11180 <- (0,16249)
[0] 11181 <- (0,16250)
[0] 11182 <- (0,16300)
[0] 11183 <- (0,16301)
[0] 11184 <- (0,16351)
[0] 11185 <- (0,16352)
[0] 11186 <- (0,16402)
[0] 11187 <- (0,16403)
[0] 11188 <- (0,16448)
[0] 11189 <- (0,16449)
[0] 11190 <- (0,16499)
[0] 11191 <- (0,16500)
[0] 11192 <- (0,16550)
[0] 11193 <- (0,16551)
[0] 11194 <- (0,16601)
[0] 11195 <- (0,16602)
[0] 11196 <- (0,16603)
[0] 11197 <- (0,16652)
[0] 11198 <- (0,16653)
[0] 11199 <- (0,16654)
[0] 11200 <- (0,16704)
[0] 11201 <- (0,16705)
[0] 11202 <- (0,16755)
[0] 11203 <- (0,16756)
[0] 11204 <- (0,16806)
[0] 11205 <- (0,16807)
[0] 11206 <- (0,16808)
[0] 11207 <- (0,16857)
[0] 11208 <- (0,16858)
[0] 11209 <- (0,16859)
[0] 11210 <- (0,16860)
[0] 11211 <- (0,16909)
[0] 11212 <- (0,16910)
[0] 11213 <- (0,16911)
[0] 11214 <- (0,16960)
[0] 11215 <- (0,16961)
[0] 11216 <- (0,16962)
[0] 11217 <- (0,16963)
[0] 11218 <- (0,17012)
[0] 11219 <- (0,17013)
[0] 11220 <- (0,17014)
[0] 11221 <- (0,17064)
[0] 11222 <- (0,17065)
[0] 11223 <- (0,17066)
[0] 11224 <- (0,17115)
[0] 11225 <- (0,17116)
[0] 11226 <- (0,17117)
[0] 11227 <- (0,17167)
[0] 11228 <- (0,17168)
[0] 11229 <- (0,17218)
[0] 11230 <- (0,17219)
[0] 11231 <- (0,17269)
[0] 11232 <- (0,17270)
[0] 11233 <- (0,17320)
[0] 11234 <- (0,17321)
[0] 11235 <- (0,17371)
[0] 11236 <- (0,17372)
[0] 11237 <- (0,17422)
[0] 11238 <- (0,17423)
[0] 11239 <- (0,17473)
[0] 11240 <- (0,17474)
[0] 11241 <- (0,17519)
[0] 11242 <- (0,17520)
[0] 11243 <- (0,17570)
[0] 11244 <- (0,17571)
[0] 11245 <- (0,17621)
[0] 11246 <- (0,17622)
[0] 11247 <- (0,17672)
[0] 11248 <- (0,17673)
[0] 11249 <- (0,17674)
[0] 11250 <- (0,17723)
[0] 11251 <- (0,17724)
[0] 11252 <- (0,17725)
[0] 11253 <- (0,17775)
[0] 11254 <- (0,17776)
[0] 11255 <- (0,17826)
[0] 11256 <- (0,17827)
[0] 11257 <- (0,17877)
[0] 11258 <- (0,17878)
[0] 11259 <- (0,17879)
[0] 11260 <- (0,17928)
[0] 11261 <- (0,17929)
[0] 11262 <- (0,17930)
[0] 11263 <- (0,17931)
[0] 11264 <- (0,17980)
[0] 11265 <- (0,17981)
[0] 11266 <- (0,17982)
[0] 11267 <- (0,18032)
[0] 11268 <- (0,18033)
[0] 11269 <- (0,18034)
[0] 11270 <- (0,18083)
[0] 11271 <- (0,18084)
[0] 11272 <- (0,18085)
[0] 11273 <- (0,18135)
[0] 11274 <- (0,18136)
[0] 11275 <- (0,18137)
[0] 11276 <- (0,18186)
[0] 11277 <- (0,18187)
[0] 11278 <- (0,18188)
[0] 11279 <- (0,18238)
[0] 11280 <- (0,18239)
[0] 11281 <- (0,18289)
[0] 11282 <- (0,18290)
[0] 11283 <- (0,18340)
[0] 11284 <- (0,18341)
[0] 11285 <- (0,18391)
[0] 11286 <- (0,18392)
[0] 11287 <- (0,18442)
[0] 11288 <- (0,18443)
[0] 11289 <- (0,18493)
[0] 11290 <- (0,18494)
[0] 11291 <- (0,18544)
[0] 11292 <- (0,18545)
[0] 11293 <- (0,18590)
[0] 11294 <- (0,18591)
[0] 11295 <- (0,18641)
[0] 11296 <- (0,18642)
[0] 11297 <- (0,18692)
[0] 11298 <- (0,18693)
[0] 11299 <- (0,18743)
[0] 11300 <- (0,18744)
[0] 11301 <- (0,18745)
[0] 11302 <- (0,18794)
[0] 11303 <- (0,18795)
[0] 11304 <- (0,18796)
[0] 11305 <- (0,18846)
[0] 11306 <- (0,18847)
[0] 11307 <- (0,18897)
[0] 11308 <- (0,18898)
[0] 11309 <- (0,18948)
[0] 11310 <- (0,18949)
[0] 11311 <- (0,18950)
[0] 11312 <- (0,18999)
[0] 11313 <- (0,19000)
[0] 11314 <- (0,19001)
[0] 11315 <- (0,19002)
[0] 11316 <- (0,19051)
[0] 11317 <- (0,19052)
[0] 11318 <- (0,19053)
[0] 11319 <- (0,19103)
[0] 11320 <- (0,19104)
[0] 11321 <- (0,19105)
[0] 11322 <- (0,19154)
[0] 11323 <- (0,19155)
[0] 11324 <- (0,19156)
[0] 11325 <- (0,19206)
[0] 11326 <- (0,19207)
[0] 11327 <- (0,19208)
[0] 11328 <- (0,19257)
[0] 11329 <- (0,19258)
[0] 11330 <- (0,19259)
[0] 11331 <- (0,19309)
[0] 11332 <- (0,19310)
[0] 11333 <- (0,19360)
[0] 11334 <- (0,19361)
[0] 11335 <- (0,19411)
[0] 11336 <- (0,19412)
[0] 11337 <- (0,19462)
[0] 11338 <- (0,19463)
[0] 11339 <- (0,19513)
[0] 11340 <- (0,19514)
[0] 11341 <- (0,19564)
[0] 11342 <- (0,19565)
[0] 11343 <- (0,19615)
[0] 11344 <- (0,19616)
[0] 11345 <- (0,19661)
[0] 11346 <- (0,19662)
[0] 11347 <- (0,19712)
[0] 11348 <- (0,19713)
[0] 11349 <- (0,19763)
[0] 11350 <- (0,19764)
[0] 11351 <- (0,19814)
[0] 11352 <- (0,19815)
[0] 11353 <- (0,19816)
[0] 11354 <- (0,19865)
[0] 11355 <- (0,19866)
[0] 11356 <- (0,19867)
[0] 11357 <- (0,19917)
[0] 11358 <- (0,19918)
[0] 11359 <- (0,19968)
[0] 11360 <- (0,19969)
[0] 11361 <- (0,20019)
[0] 11362 <- (0,20020)
[0] 11363 <- (0,20021)
[0] 11364 <- (0,20070)
[0] 11365 <- (0,20071)
[0] 11366 <- (0,20072)
[0] 11367 <- (0,20073)
[0] 11368 <- (0,20122)
[0] 11369 <- (0,20123)
[0] 11370 <- (0,20124)
[0] 11371 <- (0,20174)
[0] 11372 <- (0,20175)
[0] 11373 <- (0,20176)
[0] 11374 <- (0,20225)
[0] 11375 <- (0,20226)
[0] 11376 <- (0,20227)
[0] 11377 <- (0,20277)
[0] 11378 <- (0,20278)
[0] 11379 <- (0,20279)
[0] 11380 <- (0,20328)
[0] 11381 <- (0,20329)
[0] 11382 <- (0,20330)
[0] 11383 <- (0,20380)
[0] 11384 <- (0,20381)
[0] 11385 <- (0,20431)
[0] 11386 <- (0,20432)
[0] 11387 <- (0,20482)
[0] 11388 <- (0,20483)
[0] 11389 <- (0,20533)
[0] 11390 <- (0,20534)
[0] 11391 <- (0,20584)
[0] 11392 <- (0,20585)
[0] 11393 <- (0,20635)
[0] 11394 <- (0,20636)
[0] 11395 <- (0,20686)
[0] 11396 <- (0,20687)
[0] 11397 <- (0,20732)
[0] 11398 <- (0,20733)
[0] 11399 <- (0,20783)
[0] 11400 <- (0,20784)
[0] 11401 <- (0,20834)
[0] 11402 <- (0,20835)
[0] 11403 <- (0,20885)
[0] 11404 <- (0,20886)
[0] 11405 <- (0,20887)
[0] 11406 <- (0,20936)
[0] 11407 <- (0,20937)
[0] 11408 <- (0,20938)
[0] 11409 <- (0,20988)
[0] 11410 <- (0,20989)
[0] 11411 <- (0,21039)
[0] 11412 <- (0,21040)
[0] 11413 <- (0,21090)
[0] 11414 <- (0,21091)
[0] 11415 <- (0,21092)
[0] 11416 <- (0,21141)
[0] 11417 <- (0,21142)
[0] 11418 <- (0,21143)
[0] 11419 <- (0,21144)
[0] 11420 <- (0,21193)
[0] 11421 <- (0,21194)
[0] 11422 <- (0,21195)
[0] 11423 <- (0,21245)
[0] 11424 <- (0,21246)
[0] 11425 <- (0,21247)
[0] 11426 <- (0,21296)
[0] 11427 <- (0,21297)
[0] 11428 <- (0,21298)
[0] 11429 <- (0,21348)
[0] 11430 <- (0,21349)
[0] 11431 <- (0,21350)
[0] 11432 <- (0,21399)
[0] 11433 <- (0,21400)
[0] 11434 <- (0,21401)
[0] 11435 <- (0,21451)
[0] 11436 <- (0,21452)
[0] 11437 <- (0,21502)
[0] 11438 <- (0,21503)
[0] 11439 <- (0,21553)
[0] 11440 <- (0,21554)
[0] 11441 <- (0,21604)
[0] 11442 <- (0,21605)
[0] 11443 <- (0,21655)
[0] 11444 <- (0,21656)
[0] 11445 <- (0,21706)
[0] 11446 <- (0,21707)
[0] 11447 <- (0,21757)
[0] 11448 <- (0,21758)
[1] Number of roots=0, leaves=11695, remote ranks=1
[1] 0 <- (0,22)
[1] 1 <- (0,23)
[1] 2 <- (0,24)
[1] 3 <- (0,25)
[1] 4 <- (0,26)
[1] 5 <- (0,27)
[1] 6 <- (0,28)
[1] 7 <- (0,29)
[1] 8 <- (0,30)
[1] 9 <- (0,31)
[1] 10 <- (0,32)
[1] 11 <- (0,33)
[1] 12 <- (0,34)
[1] 13 <- (0,35)
[1] 14 <- (0,36)
[1] 15 <- (0,37)
[1] 16 <- (0,38)
[1] 17 <- (0,39)
[1] 18 <- (0,40)
[1] 19 <- (0,41)
[1] 20 <- (0,42)
[1] 21 <- (0,43)
[1] 22 <- (0,44)
[1] 23 <- (0,45)
[1] 24 <- (0,46)
[1] 25 <- (0,47)
[1] 26 <- (0,48)
[1] 27 <- (0,49)
[1] 28 <- (0,72)
[1] 29 <- (0,73)
[1] 30 <- (0,74)
[1] 31 <- (0,75)
[1] 32 <- (0,76)
[1] 33 <- (0,77)
[1] 34 <- (0,78)
[1] 35 <- (0,79)
[1] 36 <- (0,80)
[1] 37 <- (0,81)
[1] 38 <- (0,82)
[1] 39 <- (0,83)
[1] 40 <- (0,84)
[1] 41 <- (0,85)
[1] 42 <- (0,86)
[1] 43 <- (0,87)
[1] 44 <- (0,88)
[1] 45 <- (0,89)
[1] 46 <- (0,90)
[1] 47 <- (0,91)
[1] 48 <- (0,92)
[1] 49 <- (0,93)
[1] 50 <- (0,94)
[1] 51 <- (0,95)
[1] 52 <- (0,96)
[1] 53 <- (0,97)
[1] 54 <- (0,98)
[1] 55 <- (0,99)
[1] 56 <- (0,122)
[1] 57 <- (0,123)
[1] 58 <- (0,124)
[1] 59 <- (0,125)
[1] 60 <- (0,126)
[1] 61 <- (0,127)
[1] 62 <- (0,128)
[1] 63 <- (0,129)
[1] 64 <- (0,130)
[1] 65 <- (0,131)
[1] 66 <- (0,132)
[1] 67 <- (0,133)
[1] 68 <- (0,134)
[1] 69 <- (0,135)
[1] 70 <- (0,136)
[1] 71 <- (0,137)
[1] 72 <- (0,138)
[1] 73 <- (0,139)
[1] 74 <- (0,140)
[1] 75 <- (0,141)
[1] 76 <- (0,142)
[1] 77 <- (0,143)
[1] 78 <- (0,144)
[1] 79 <- (0,145)
[1] 80 <- (0,146)
[1] 81 <- (0,147)
[1] 82 <- (0,148)
[1] 83 <- (0,149)
[1] 84 <- (0,172)
[1] 85 <- (0,173)
[1] 86 <- (0,174)
[1] 87 <- (0,175)
[1] 88 <- (0,176)
[1] 89 <- (0,177)
[1] 90 <- (0,178)
[1] 91 <- (0,179)
[1] 92 <- (0,180)
[1] 93 <- (0,181)
[1] 94 <- (0,182)
[1] 95 <- (0,183)
[1] 96 <- (0,184)
[1] 97 <- (0,185)
[1] 98 <- (0,186)
[1] 99 <- (0,187)
[1] 100 <- (0,188)
[1] 101 <- (0,189)
[1] 102 <- (0,190)
[1] 103 <- (0,191)
[1] 104 <- (0,192)
[1] 105 <- (0,193)
[1] 106 <- (0,194)
[1] 107 <- (0,195)
[1] 108 <- (0,196)
[1] 109 <- (0,197)
[1] 110 <- (0,198)
[1] 111 <- (0,199)
[1] 112 <- (0,223)
[1] 113 <- (0,224)
[1] 114 <- (0,225)
[1] 115 <- (0,226)
[1] 116 <- (0,227)
[1] 117 <- (0,228)
[1] 118 <- (0,229)
[1] 119 <- (0,230)
[1] 120 <- (0,231)
[1] 121 <- (0,232)
[1] 122 <- (0,233)
[1] 123 <- (0,234)
[1] 124 <- (0,235)
[1] 125 <- (0,236)
[1] 126 <- (0,237)
[1] 127 <- (0,238)
[1] 128 <- (0,239)
[1] 129 <- (0,240)
[1] 130 <- (0,241)
[1] 131 <- (0,242)
[1] 132 <- (0,243)
[1] 133 <- (0,244)
[1] 134 <- (0,245)
[1] 135 <- (0,246)
[1] 136 <- (0,247)
[1] 137 <- (0,248)
[1] 138 <- (0,249)
[1] 139 <- (0,273)
[1] 140 <- (0,274)
[1] 141 <- (0,275)
[1] 142 <- (0,276)
[1] 143 <- (0,277)
[1] 144 <- (0,278)
[1] 145 <- (0,279)
[1] 146 <- (0,280)
[1] 147 <- (0,281)
[1] 148 <- (0,282)
[1] 149 <- (0,283)
[1] 150 <- (0,284)
[1] 151 <- (0,285)
[1] 152 <- (0,286)
[1] 153 <- (0,287)
[1] 154 <- (0,288)
[1] 155 <- (0,289)
[1] 156 <- (0,290)
[1] 157 <- (0,291)
[1] 158 <- (0,292)
[1] 159 <- (0,293)
[1] 160 <- (0,294)
[1] 161 <- (0,295)
[1] 162 <- (0,296)
[1] 163 <- (0,297)
[1] 164 <- (0,298)
[1] 165 <- (0,299)
[1] 166 <- (0,323)
[1] 167 <- (0,324)
[1] 168 <- (0,325)
[1] 169 <- (0,326)
[1] 170 <- (0,327)
[1] 171 <- (0,328)
[1] 172 <- (0,329)
[1] 173 <- (0,330)
[1] 174 <- (0,331)
[1] 175 <- (0,332)
[1] 176 <- (0,333)
[1] 177 <- (0,334)
[1] 178 <- (0,335)
[1] 179 <- (0,336)
[1] 180 <- (0,337)
[1] 181 <- (0,338)
[1] 182 <- (0,339)
[1] 183 <- (0,340)
[1] 184 <- (0,341)
[1] 185 <- (0,342)
[1] 186 <- (0,343)
[1] 187 <- (0,344)
[1] 188 <- (0,345)
[1] 189 <- (0,346)
[1] 190 <- (0,347)
[1] 191 <- (0,348)
[1] 192 <- (0,349)
[1] 193 <- (0,373)
[1] 194 <- (0,374)
[1] 195 <- (0,375)
[1] 196 <- (0,376)
[1] 197 <- (0,377)
[1] 198 <- (0,378)
[1] 199 <- (0,379)
[1] 200 <- (0,380)
[1] 201 <- (0,381)
[1] 202 <- (0,382)
[1] 203 <- (0,383)
[1] 204 <- (0,384)
[1] 205 <- (0,385)
[1] 206 <- (0,386)
[1] 207 <- (0,387)
[1] 208 <- (0,388)
[1] 209 <- (0,389)
[1] 210 <- (0,390)
[1] 211 <- (0,391)
[1] 212 <- (0,392)
[1] 213 <- (0,393)
[1] 214 <- (0,394)
[1] 215 <- (0,395)
[1] 216 <- (0,396)
[1] 217 <- (0,397)
[1] 218 <- (0,398)
[1] 219 <- (0,399)
[1] 220 <- (0,424)
[1] 221 <- (0,425)
[1] 222 <- (0,426)
[1] 223 <- (0,427)
[1] 224 <- (0,428)
[1] 225 <- (0,429)
[1] 226 <- (0,430)
[1] 227 <- (0,431)
[1] 228 <- (0,432)
[1] 229 <- (0,433)
[1] 230 <- (0,434)
[1] 231 <- (0,435)
[1] 232 <- (0,436)
[1] 233 <- (0,437)
[1] 234 <- (0,438)
[1] 235 <- (0,439)
[1] 236 <- (0,440)
[1] 237 <- (0,441)
[1] 238 <- (0,442)
[1] 239 <- (0,443)
[1] 240 <- (0,444)
[1] 241 <- (0,445)
[1] 242 <- (0,446)
[1] 243 <- (0,447)
[1] 244 <- (0,448)
[1] 245 <- (0,449)
[1] 246 <- (0,474)
[1] 247 <- (0,475)
[1] 248 <- (0,476)
[1] 249 <- (0,477)
[1] 250 <- (0,478)
[1] 251 <- (0,479)
[1] 252 <- (0,480)
[1] 253 <- (0,481)
[1] 254 <- (0,482)
[1] 255 <- (0,483)
[1] 256 <- (0,484)
[1] 257 <- (0,485)
[1] 258 <- (0,486)
[1] 259 <- (0,487)
[1] 260 <- (0,488)
[1] 261 <- (0,489)
[1] 262 <- (0,490)
[1] 263 <- (0,491)
[1] 264 <- (0,492)
[1] 265 <- (0,493)
[1] 266 <- (0,494)
[1] 267 <- (0,495)
[1] 268 <- (0,496)
[1] 269 <- (0,497)
[1] 270 <- (0,498)
[1] 271 <- (0,499)
[1] 272 <- (0,525)
[1] 273 <- (0,526)
[1] 274 <- (0,527)
[1] 275 <- (0,528)
[1] 276 <- (0,529)
[1] 277 <- (0,530)
[1] 278 <- (0,531)
[1] 279 <- (0,532)
[1] 280 <- (0,533)
[1] 281 <- (0,534)
[1] 282 <- (0,535)
[1] 283 <- (0,536)
[1] 284 <- (0,537)
[1] 285 <- (0,538)
[1] 286 <- (0,539)
[1] 287 <- (0,540)
[1] 288 <- (0,541)
[1] 289 <- (0,542)
[1] 290 <- (0,543)
[1] 291 <- (0,544)
[1] 292 <- (0,545)
[1] 293 <- (0,546)
[1] 294 <- (0,547)
[1] 295 <- (0,548)
[1] 296 <- (0,549)
[1] 297 <- (0,576)
[1] 298 <- (0,577)
[1] 299 <- (0,578)
[1] 300 <- (0,579)
[1] 301 <- (0,580)
[1] 302 <- (0,581)
[1] 303 <- (0,582)
[1] 304 <- (0,583)
[1] 305 <- (0,584)
[1] 306 <- (0,585)
[1] 307 <- (0,586)
[1] 308 <- (0,587)
[1] 309 <- (0,588)
[1] 310 <- (0,589)
[1] 311 <- (0,590)
[1] 312 <- (0,591)
[1] 313 <- (0,592)
[1] 314 <- (0,593)
[1] 315 <- (0,594)
[1] 316 <- (0,595)
[1] 317 <- (0,596)
[1] 318 <- (0,597)
[1] 319 <- (0,598)
[1] 320 <- (0,599)
[1] 321 <- (0,626)
[1] 322 <- (0,627)
[1] 323 <- (0,628)
[1] 324 <- (0,629)
[1] 325 <- (0,630)
[1] 326 <- (0,631)
[1] 327 <- (0,632)
[1] 328 <- (0,633)
[1] 329 <- (0,634)
[1] 330 <- (0,635)
[1] 331 <- (0,636)
[1] 332 <- (0,637)
[1] 333 <- (0,638)
[1] 334 <- (0,639)
[1] 335 <- (0,640)
[1] 336 <- (0,641)
[1] 337 <- (0,642)
[1] 338 <- (0,643)
[1] 339 <- (0,644)
[1] 340 <- (0,645)
[1] 341 <- (0,646)
[1] 342 <- (0,647)
[1] 343 <- (0,648)
[1] 344 <- (0,649)
[1] 345 <- (0,677)
[1] 346 <- (0,678)
[1] 347 <- (0,679)
[1] 348 <- (0,680)
[1] 349 <- (0,681)
[1] 350 <- (0,682)
[1] 351 <- (0,683)
[1] 352 <- (0,684)
[1] 353 <- (0,685)
[1] 354 <- (0,686)
[1] 355 <- (0,687)
[1] 356 <- (0,688)
[1] 357 <- (0,689)
[1] 358 <- (0,690)
[1] 359 <- (0,691)
[1] 360 <- (0,692)
[1] 361 <- (0,693)
[1] 362 <- (0,694)
[1] 363 <- (0,695)
[1] 364 <- (0,696)
[1] 365 <- (0,697)
[1] 366 <- (0,698)
[1] 367 <- (0,699)
[1] 368 <- (0,727)
[1] 369 <- (0,728)
[1] 370 <- (0,729)
[1] 371 <- (0,730)
[1] 372 <- (0,731)
[1] 373 <- (0,732)
[1] 374 <- (0,733)
[1] 375 <- (0,734)
[1] 376 <- (0,735)
[1] 377 <- (0,736)
[1] 378 <- (0,737)
[1] 379 <- (0,738)
[1] 380 <- (0,739)
[1] 381 <- (0,740)
[1] 382 <- (0,741)
[1] 383 <- (0,742)
[1] 384 <- (0,743)
[1] 385 <- (0,744)
[1] 386 <- (0,745)
[1] 387 <- (0,746)
[1] 388 <- (0,747)
[1] 389 <- (0,748)
[1] 390 <- (0,749)
[1] 391 <- (0,777)
[1] 392 <- (0,778)
[1] 393 <- (0,779)
[1] 394 <- (0,780)
[1] 395 <- (0,781)
[1] 396 <- (0,782)
[1] 397 <- (0,783)
[1] 398 <- (0,784)
[1] 399 <- (0,785)
[1] 400 <- (0,786)
[1] 401 <- (0,787)
[1] 402 <- (0,788)
[1] 403 <- (0,789)
[1] 404 <- (0,790)
[1] 405 <- (0,791)
[1] 406 <- (0,792)
[1] 407 <- (0,793)
[1] 408 <- (0,794)
[1] 409 <- (0,795)
[1] 410 <- (0,796)
[1] 411 <- (0,797)
[1] 412 <- (0,798)
[1] 413 <- (0,799)
[1] 414 <- (0,827)
[1] 415 <- (0,828)
[1] 416 <- (0,829)
[1] 417 <- (0,830)
[1] 418 <- (0,831)
[1] 419 <- (0,832)
[1] 420 <- (0,833)
[1] 421 <- (0,834)
[1] 422 <- (0,835)
[1] 423 <- (0,836)
[1] 424 <- (0,837)
[1] 425 <- (0,838)
[1] 426 <- (0,839)
[1] 427 <- (0,840)
[1] 428 <- (0,841)
[1] 429 <- (0,842)
[1] 430 <- (0,843)
[1] 431 <- (0,844)
[1] 432 <- (0,845)
[1] 433 <- (0,846)
[1] 434 <- (0,847)
[1] 435 <- (0,848)
[1] 436 <- (0,849)
[1] 437 <- (0,877)
[1] 438 <- (0,878)
[1] 439 <- (0,879)
[1] 440 <- (0,880)
[1] 441 <- (0,881)
[1] 442 <- (0,882)
[1] 443 <- (0,883)
[1] 444 <- (0,884)
[1] 445 <- (0,885)
[1] 446 <- (0,886)
[1] 447 <- (0,887)
[1] 448 <- (0,888)
[1] 449 <- (0,889)
[1] 450 <- (0,890)
[1] 451 <- (0,891)
[1] 452 <- (0,892)
[1] 453 <- (0,893)
[1] 454 <- (0,894)
[1] 455 <- (0,895)
[1] 456 <- (0,896)
[1] 457 <- (0,897)
[1] 458 <- (0,898)
[1] 459 <- (0,899)
[1] 460 <- (0,927)
[1] 461 <- (0,928)
[1] 462 <- (0,929)
[1] 463 <- (0,930)
[1] 464 <- (0,931)
[1] 465 <- (0,932)
[1] 466 <- (0,933)
[1] 467 <- (0,934)
[1] 468 <- (0,935)
[1] 469 <- (0,936)
[1] 470 <- (0,937)
[1] 471 <- (0,938)
[1] 472 <- (0,939)
[1] 473 <- (0,940)
[1] 474 <- (0,941)
[1] 475 <- (0,942)
[1] 476 <- (0,943)
[1] 477 <- (0,944)
[1] 478 <- (0,945)
[1] 479 <- (0,946)
[1] 480 <- (0,947)
[1] 481 <- (0,948)
[1] 482 <- (0,949)
[1] 483 <- (0,977)
[1] 484 <- (0,978)
[1] 485 <- (0,979)
[1] 486 <- (0,980)
[1] 487 <- (0,981)
[1] 488 <- (0,982)
[1] 489 <- (0,983)
[1] 490 <- (0,984)
[1] 491 <- (0,985)
[1] 492 <- (0,986)
[1] 493 <- (0,987)
[1] 494 <- (0,988)
[1] 495 <- (0,989)
[1] 496 <- (0,990)
[1] 497 <- (0,991)
[1] 498 <- (0,992)
[1] 499 <- (0,993)
[1] 500 <- (0,994)
[1] 501 <- (0,995)
[1] 502 <- (0,996)
[1] 503 <- (0,997)
[1] 504 <- (0,998)
[1] 505 <- (0,999)
[1] 506 <- (0,1022)
[1] 507 <- (0,1023)
[1] 508 <- (0,1024)
[1] 509 <- (0,1025)
[1] 510 <- (0,1026)
[1] 511 <- (0,1027)
[1] 512 <- (0,1028)
[1] 513 <- (0,1029)
[1] 514 <- (0,1030)
[1] 515 <- (0,1031)
[1] 516 <- (0,1032)
[1] 517 <- (0,1033)
[1] 518 <- (0,1034)
[1] 519 <- (0,1035)
[1] 520 <- (0,1036)
[1] 521 <- (0,1037)
[1] 522 <- (0,1038)
[1] 523 <- (0,1039)
[1] 524 <- (0,1040)
[1] 525 <- (0,1041)
[1] 526 <- (0,1042)
[1] 527 <- (0,1043)
[1] 528 <- (0,1044)
[1] 529 <- (0,1045)
[1] 530 <- (0,1046)
[1] 531 <- (0,1047)
[1] 532 <- (0,1048)
[1] 533 <- (0,1049)
[1] 534 <- (0,1072)
[1] 535 <- (0,1073)
[1] 536 <- (0,1074)
[1] 537 <- (0,1075)
[1] 538 <- (0,1076)
[1] 539 <- (0,1077)
[1] 540 <- (0,1078)
[1] 541 <- (0,1079)
[1] 542 <- (0,1080)
[1] 543 <- (0,1081)
[1] 544 <- (0,1082)
[1] 545 <- (0,1083)
[1] 546 <- (0,1084)
[1] 547 <- (0,1085)
[1] 548 <- (0,1086)
[1] 549 <- (0,1087)
[1] 550 <- (0,1088)
[1] 551 <- (0,1089)
[1] 552 <- (0,1090)
[1] 553 <- (0,1091)
[1] 554 <- (0,1092)
[1] 555 <- (0,1093)
[1] 556 <- (0,1094)
[1] 557 <- (0,1095)
[1] 558 <- (0,1096)
[1] 559 <- (0,1097)
[1] 560 <- (0,1098)
[1] 561 <- (0,1099)
[1] 562 <- (0,1122)
[1] 563 <- (0,1123)
[1] 564 <- (0,1124)
[1] 565 <- (0,1125)
[1] 566 <- (0,1126)
[1] 567 <- (0,1127)
[1] 568 <- (0,1128)
[1] 569 <- (0,1129)
[1] 570 <- (0,1130)
[1] 571 <- (0,1131)
[1] 572 <- (0,1132)
[1] 573 <- (0,1133)
[1] 574 <- (0,1134)
[1] 575 <- (0,1135)
[1] 576 <- (0,1136)
[1] 577 <- (0,1137)
[1] 578 <- (0,1138)
[1] 579 <- (0,1139)
[1] 580 <- (0,1140)
[1] 581 <- (0,1141)
[1] 582 <- (0,1142)
[1] 583 <- (0,1143)
[1] 584 <- (0,1144)
[1] 585 <- (0,1145)
[1] 586 <- (0,1146)
[1] 587 <- (0,1147)
[1] 588 <- (0,1148)
[1] 589 <- (0,1149)
[1] 590 <- (0,1172)
[1] 591 <- (0,1173)
[1] 592 <- (0,1174)
[1] 593 <- (0,1175)
[1] 594 <- (0,1176)
[1] 595 <- (0,1177)
[1] 596 <- (0,1178)
[1] 597 <- (0,1179)
[1] 598 <- (0,1180)
[1] 599 <- (0,1181)
[1] 600 <- (0,1182)
[1] 601 <- (0,1183)
[1] 602 <- (0,1184)
[1] 603 <- (0,1185)
[1] 604 <- (0,1186)
[1] 605 <- (0,1187)
[1] 606 <- (0,1188)
[1] 607 <- (0,1189)
[1] 608 <- (0,1190)
[1] 609 <- (0,1191)
[1] 610 <- (0,1192)
[1] 611 <- (0,1193)
[1] 612 <- (0,1194)
[1] 613 <- (0,1195)
[1] 614 <- (0,1196)
[1] 615 <- (0,1197)
[1] 616 <- (0,1198)
[1] 617 <- (0,1199)
[1] 618 <- (0,1223)
[1] 619 <- (0,1224)
[1] 620 <- (0,1225)
[1] 621 <- (0,1226)
[1] 622 <- (0,1227)
[1] 623 <- (0,1228)
[1] 624 <- (0,1229)
[1] 625 <- (0,1230)
[1] 626 <- (0,1231)
[1] 627 <- (0,1232)
[1] 628 <- (0,1233)
[1] 629 <- (0,1234)
[1] 630 <- (0,1235)
[1] 631 <- (0,1236)
[1] 632 <- (0,1237)
[1] 633 <- (0,1238)
[1] 634 <- (0,1239)
[1] 635 <- (0,1240)
[1] 636 <- (0,1241)
[1] 637 <- (0,1242)
[1] 638 <- (0,1243)
[1] 639 <- (0,1244)
[1] 640 <- (0,1245)
[1] 641 <- (0,1246)
[1] 642 <- (0,1247)
[1] 643 <- (0,1248)
[1] 644 <- (0,1249)
[1] 645 <- (0,1273)
[1] 646 <- (0,1274)
[1] 647 <- (0,1275)
[1] 648 <- (0,1276)
[1] 649 <- (0,1277)
[1] 650 <- (0,1278)
[1] 651 <- (0,1279)
[1] 652 <- (0,1280)
[1] 653 <- (0,1281)
[1] 654 <- (0,1282)
[1] 655 <- (0,1283)
[1] 656 <- (0,1284)
[1] 657 <- (0,1285)
[1] 658 <- (0,1286)
[1] 659 <- (0,1287)
[1] 660 <- (0,1288)
[1] 661 <- (0,1289)
[1] 662 <- (0,1290)
[1] 663 <- (0,1291)
[1] 664 <- (0,1292)
[1] 665 <- (0,1293)
[1] 666 <- (0,1294)
[1] 667 <- (0,1295)
[1] 668 <- (0,1296)
[1] 669 <- (0,1297)
[1] 670 <- (0,1298)
[1] 671 <- (0,1299)
[1] 672 <- (0,1323)
[1] 673 <- (0,1324)
[1] 674 <- (0,1325)
[1] 675 <- (0,1326)
[1] 676 <- (0,1327)
[1] 677 <- (0,1328)
[1] 678 <- (0,1329)
[1] 679 <- (0,1330)
[1] 680 <- (0,1331)
[1] 681 <- (0,1332)
[1] 682 <- (0,1333)
[1] 683 <- (0,1334)
[1] 684 <- (0,1335)
[1] 685 <- (0,1336)
[1] 686 <- (0,1337)
[1] 687 <- (0,1338)
[1] 688 <- (0,1339)
[1] 689 <- (0,1340)
[1] 690 <- (0,1341)
[1] 691 <- (0,1342)
[1] 692 <- (0,1343)
[1] 693 <- (0,1344)
[1] 694 <- (0,1345)
[1] 695 <- (0,1346)
[1] 696 <- (0,1347)
[1] 697 <- (0,1348)
[1] 698 <- (0,1349)
[1] 699 <- (0,1373)
[1] 700 <- (0,1374)
[1] 701 <- (0,1375)
[1] 702 <- (0,1376)
[1] 703 <- (0,1377)
[1] 704 <- (0,1378)
[1] 705 <- (0,1379)
[1] 706 <- (0,1380)
[1] 707 <- (0,1381)
[1] 708 <- (0,1382)
[1] 709 <- (0,1383)
[1] 710 <- (0,1384)
[1] 711 <- (0,1385)
[1] 712 <- (0,1386)
[1] 713 <- (0,1387)
[1] 714 <- (0,1388)
[1] 715 <- (0,1389)
[1] 716 <- (0,1390)
[1] 717 <- (0,1391)
[1] 718 <- (0,1392)
[1] 719 <- (0,1393)
[1] 720 <- (0,1394)
[1] 721 <- (0,1395)
[1] 722 <- (0,1396)
[1] 723 <- (0,1397)
[1] 724 <- (0,1398)
[1] 725 <- (0,1399)
[1] 726 <- (0,1424)
[1] 727 <- (0,1425)
[1] 728 <- (0,1426)
[1] 729 <- (0,1427)
[1] 730 <- (0,1428)
[1] 731 <- (0,1429)
[1] 732 <- (0,1430)
[1] 733 <- (0,1431)
[1] 734 <- (0,1432)
[1] 735 <- (0,1433)
[1] 736 <- (0,1434)
[1] 737 <- (0,1435)
[1] 738 <- (0,1436)
[1] 739 <- (0,1437)
[1] 740 <- (0,1438)
[1] 741 <- (0,1439)
[1] 742 <- (0,1440)
[1] 743 <- (0,1441)
[1] 744 <- (0,1442)
[1] 745 <- (0,1443)
[1] 746 <- (0,1444)
[1] 747 <- (0,1445)
[1] 748 <- (0,1446)
[1] 749 <- (0,1447)
[1] 750 <- (0,1448)
[1] 751 <- (0,1449)
[1] 752 <- (0,1474)
[1] 753 <- (0,1475)
[1] 754 <- (0,1476)
[1] 755 <- (0,1477)
[1] 756 <- (0,1478)
[1] 757 <- (0,1479)
[1] 758 <- (0,1480)
[1] 759 <- (0,1481)
[1] 760 <- (0,1482)
[1] 761 <- (0,1483)
[1] 762 <- (0,1484)
[1] 763 <- (0,1485)
[1] 764 <- (0,1486)
[1] 765 <- (0,1487)
[1] 766 <- (0,1488)
[1] 767 <- (0,1489)
[1] 768 <- (0,1490)
[1] 769 <- (0,1491)
[1] 770 <- (0,1492)
[1] 771 <- (0,1493)
[1] 772 <- (0,1494)
[1] 773 <- (0,1495)
[1] 774 <- (0,1496)
[1] 775 <- (0,1497)
[1] 776 <- (0,1498)
[1] 777 <- (0,1499)
[1] 778 <- (0,1525)
[1] 779 <- (0,1526)
[1] 780 <- (0,1527)
[1] 781 <- (0,1528)
[1] 782 <- (0,1529)
[1] 783 <- (0,1530)
[1] 784 <- (0,1531)
[1] 785 <- (0,1532)
[1] 786 <- (0,1533)
[1] 787 <- (0,1534)
[1] 788 <- (0,1535)
[1] 789 <- (0,1536)
[1] 790 <- (0,1537)
[1] 791 <- (0,1538)
[1] 792 <- (0,1539)
[1] 793 <- (0,1540)
[1] 794 <- (0,1541)
[1] 795 <- (0,1542)
[1] 796 <- (0,1543)
[1] 797 <- (0,1544)
[1] 798 <- (0,1545)
[1] 799 <- (0,1546)
[1] 800 <- (0,1547)
[1] 801 <- (0,1548)
[1] 802 <- (0,1549)
[1] 803 <- (0,1576)
[1] 804 <- (0,1577)
[1] 805 <- (0,1578)
[1] 806 <- (0,1579)
[1] 807 <- (0,1580)
[1] 808 <- (0,1581)
[1] 809 <- (0,1582)
[1] 810 <- (0,1583)
[1] 811 <- (0,1584)
[1] 812 <- (0,1585)
[1] 813 <- (0,1586)
[1] 814 <- (0,1587)
[1] 815 <- (0,1588)
[1] 816 <- (0,1589)
[1] 817 <- (0,1590)
[1] 818 <- (0,1591)
[1] 819 <- (0,1592)
[1] 820 <- (0,1593)
[1] 821 <- (0,1594)
[1] 822 <- (0,1595)
[1] 823 <- (0,1596)
[1] 824 <- (0,1597)
[1] 825 <- (0,1598)
[1] 826 <- (0,1599)
[1] 827 <- (0,1626)
[1] 828 <- (0,1627)
[1] 829 <- (0,1628)
[1] 830 <- (0,1629)
[1] 831 <- (0,1630)
[1] 832 <- (0,1631)
[1] 833 <- (0,1632)
[1] 834 <- (0,1633)
[1] 835 <- (0,1634)
[1] 836 <- (0,1635)
[1] 837 <- (0,1636)
[1] 838 <- (0,1637)
[1] 839 <- (0,1638)
[1] 840 <- (0,1639)
[1] 841 <- (0,1640)
[1] 842 <- (0,1641)
[1] 843 <- (0,1642)
[1] 844 <- (0,1643)
[1] 845 <- (0,1644)
[1] 846 <- (0,1645)
[1] 847 <- (0,1646)
[1] 848 <- (0,1647)
[1] 849 <- (0,1648)
[1] 850 <- (0,1649)
[1] 851 <- (0,1677)
[1] 852 <- (0,1678)
[1] 853 <- (0,1679)
[1] 854 <- (0,1680)
[1] 855 <- (0,1681)
[1] 856 <- (0,1682)
[1] 857 <- (0,1683)
[1] 858 <- (0,1684)
[1] 859 <- (0,1685)
[1] 860 <- (0,1686)
[1] 861 <- (0,1687)
[1] 862 <- (0,1688)
[1] 863 <- (0,1689)
[1] 864 <- (0,1690)
[1] 865 <- (0,1691)
[1] 866 <- (0,1692)
[1] 867 <- (0,1693)
[1] 868 <- (0,1694)
[1] 869 <- (0,1695)
[1] 870 <- (0,1696)
[1] 871 <- (0,1697)
[1] 872 <- (0,1698)
[1] 873 <- (0,1699)
[1] 874 <- (0,1727)
[1] 875 <- (0,1728)
[1] 876 <- (0,1729)
[1] 877 <- (0,1730)
[1] 878 <- (0,1731)
[1] 879 <- (0,1732)
[1] 880 <- (0,1733)
[1] 881 <- (0,1734)
[1] 882 <- (0,1735)
[1] 883 <- (0,1736)
[1] 884 <- (0,1737)
[1] 885 <- (0,1738)
[1] 886 <- (0,1739)
[1] 887 <- (0,1740)
[1] 888 <- (0,1741)
[1] 889 <- (0,1742)
[1] 890 <- (0,1743)
[1] 891 <- (0,1744)
[1] 892 <- (0,1745)
[1] 893 <- (0,1746)
[1] 894 <- (0,1747)
[1] 895 <- (0,1748)
[1] 896 <- (0,1749)
[1] 897 <- (0,1777)
[1] 898 <- (0,1778)
[1] 899 <- (0,1779)
[1] 900 <- (0,1780)
[1] 901 <- (0,1781)
[1] 902 <- (0,1782)
[1] 903 <- (0,1783)
[1] 904 <- (0,1784)
[1] 905 <- (0,1785)
[1] 906 <- (0,1786)
[1] 907 <- (0,1787)
[1] 908 <- (0,1788)
[1] 909 <- (0,1789)
[1] 910 <- (0,1790)
[1] 911 <- (0,1791)
[1] 912 <- (0,1792)
[1] 913 <- (0,1793)
[1] 914 <- (0,1794)
[1] 915 <- (0,1795)
[1] 916 <- (0,1796)
[1] 917 <- (0,1797)
[1] 918 <- (0,1798)
[1] 919 <- (0,1799)
[1] 920 <- (0,1827)
[1] 921 <- (0,1828)
[1] 922 <- (0,1829)
[1] 923 <- (0,1830)
[1] 924 <- (0,1831)
[1] 925 <- (0,1832)
[1] 926 <- (0,1833)
[1] 927 <- (0,1834)
[1] 928 <- (0,1835)
[1] 929 <- (0,1836)
[1] 930 <- (0,1837)
[1] 931 <- (0,1838)
[1] 932 <- (0,1839)
[1] 933 <- (0,1840)
[1] 934 <- (0,1841)
[1] 935 <- (0,1842)
[1] 936 <- (0,1843)
[1] 937 <- (0,1844)
[1] 938 <- (0,1845)
[1] 939 <- (0,1846)
[1] 940 <- (0,1847)
[1] 941 <- (0,1848)
[1] 942 <- (0,1849)
[1] 943 <- (0,1877)
[1] 944 <- (0,1878)
[1] 945 <- (0,1879)
[1] 946 <- (0,1880)
[1] 947 <- (0,1881)
[1] 948 <- (0,1882)
[1] 949 <- (0,1883)
[1] 950 <- (0,1884)
[1] 951 <- (0,1885)
[1] 952 <- (0,1886)
[1] 953 <- (0,1887)
[1] 954 <- (0,1888)
[1] 955 <- (0,1889)
[1] 956 <- (0,1890)
[1] 957 <- (0,1891)
[1] 958 <- (0,1892)
[1] 959 <- (0,1893)
[1] 960 <- (0,1894)
[1] 961 <- (0,1895)
[1] 962 <- (0,1896)
[1] 963 <- (0,1897)
[1] 964 <- (0,1898)
[1] 965 <- (0,1899)
[1] 966 <- (0,1927)
[1] 967 <- (0,1928)
[1] 968 <- (0,1929)
[1] 969 <- (0,1930)
[1] 970 <- (0,1931)
[1] 971 <- (0,1932)
[1] 972 <- (0,1933)
[1] 973 <- (0,1934)
[1] 974 <- (0,1935)
[1] 975 <- (0,1936)
[1] 976 <- (0,1937)
[1] 977 <- (0,1938)
[1] 978 <- (0,1939)
[1] 979 <- (0,1940)
[1] 980 <- (0,1941)
[1] 981 <- (0,1942)
[1] 982 <- (0,1943)
[1] 983 <- (0,1944)
[1] 984 <- (0,1945)
[1] 985 <- (0,1946)
[1] 986 <- (0,1947)
[1] 987 <- (0,1948)
[1] 988 <- (0,1949)
[1] 989 <- (0,1977)
[1] 990 <- (0,1978)
[1] 991 <- (0,1979)
[1] 992 <- (0,1980)
[1] 993 <- (0,1981)
[1] 994 <- (0,1982)
[1] 995 <- (0,1983)
[1] 996 <- (0,1984)
[1] 997 <- (0,1985)
[1] 998 <- (0,1986)
[1] 999 <- (0,1987)
[1] 1000 <- (0,1988)
[1] 1001 <- (0,1989)
[1] 1002 <- (0,1990)
[1] 1003 <- (0,1991)
[1] 1004 <- (0,1992)
[1] 1005 <- (0,1993)
[1] 1006 <- (0,1994)
[1] 1007 <- (0,1995)
[1] 1008 <- (0,1996)
[1] 1009 <- (0,1997)
[1] 1010 <- (0,1998)
[1] 1011 <- (0,1999)
[1] 1012 <- (0,2022)
[1] 1013 <- (0,2023)
[1] 1014 <- (0,2024)
[1] 1015 <- (0,2025)
[1] 1016 <- (0,2026)
[1] 1017 <- (0,2027)
[1] 1018 <- (0,2028)
[1] 1019 <- (0,2029)
[1] 1020 <- (0,2030)
[1] 1021 <- (0,2031)
[1] 1022 <- (0,2032)
[1] 1023 <- (0,2033)
[1] 1024 <- (0,2034)
[1] 1025 <- (0,2035)
[1] 1026 <- (0,2036)
[1] 1027 <- (0,2037)
[1] 1028 <- (0,2038)
[1] 1029 <- (0,2039)
[1] 1030 <- (0,2040)
[1] 1031 <- (0,2041)
[1] 1032 <- (0,2042)
[1] 1033 <- (0,2043)
[1] 1034 <- (0,2044)
[1] 1035 <- (0,2045)
[1] 1036 <- (0,2046)
[1] 1037 <- (0,2047)
[1] 1038 <- (0,2048)
[1] 1039 <- (0,2049)
[1] 1040 <- (0,2072)
[1] 1041 <- (0,2073)
[1] 1042 <- (0,2074)
[1] 1043 <- (0,2075)
[1] 1044 <- (0,2076)
[1] 1045 <- (0,2077)
[1] 1046 <- (0,2078)
[1] 1047 <- (0,2079)
[1] 1048 <- (0,2080)
[1] 1049 <- (0,2081)
[1] 1050 <- (0,2082)
[1] 1051 <- (0,2083)
[1] 1052 <- (0,2084)
[1] 1053 <- (0,2085)
[1] 1054 <- (0,2086)
[1] 1055 <- (0,2087)
[1] 1056 <- (0,2088)
[1] 1057 <- (0,2089)
[1] 1058 <- (0,2090)
[1] 1059 <- (0,2091)
[1] 1060 <- (0,2092)
[1] 1061 <- (0,2093)
[1] 1062 <- (0,2094)
[1] 1063 <- (0,2095)
[1] 1064 <- (0,2096)
[1] 1065 <- (0,2097)
[1] 1066 <- (0,2098)
[1] 1067 <- (0,2099)
[1] 1068 <- (0,2122)
[1] 1069 <- (0,2123)
[1] 1070 <- (0,2124)
[1] 1071 <- (0,2125)
[1] 1072 <- (0,2126)
[1] 1073 <- (0,2127)
[1] 1074 <- (0,2128)
[1] 1075 <- (0,2129)
[1] 1076 <- (0,2130)
[1] 1077 <- (0,2131)
[1] 1078 <- (0,2132)
[1] 1079 <- (0,2133)
[1] 1080 <- (0,2134)
[1] 1081 <- (0,2135)
[1] 1082 <- (0,2136)
[1] 1083 <- (0,2137)
[1] 1084 <- (0,2138)
[1] 1085 <- (0,2139)
[1] 1086 <- (0,2140)
[1] 1087 <- (0,2141)
[1] 1088 <- (0,2142)
[1] 1089 <- (0,2143)
[1] 1090 <- (0,2144)
[1] 1091 <- (0,2145)
[1] 1092 <- (0,2146)
[1] 1093 <- (0,2147)
[1] 1094 <- (0,2148)
[1] 1095 <- (0,2149)
[1] 1096 <- (0,2172)
[1] 1097 <- (0,2173)
[1] 1098 <- (0,2174)
[1] 1099 <- (0,2175)
[1] 1100 <- (0,2176)
[1] 1101 <- (0,2177)
[1] 1102 <- (0,2178)
[1] 1103 <- (0,2179)
[1] 1104 <- (0,2180)
[1] 1105 <- (0,2181)
[1] 1106 <- (0,2182)
[1] 1107 <- (0,2183)
[1] 1108 <- (0,2184)
[1] 1109 <- (0,2185)
[1] 1110 <- (0,2186)
[1] 1111 <- (0,2187)
[1] 1112 <- (0,2188)
[1] 1113 <- (0,2189)
[1] 1114 <- (0,2190)
[1] 1115 <- (0,2191)
[1] 1116 <- (0,2192)
[1] 1117 <- (0,2193)
[1] 1118 <- (0,2194)
[1] 1119 <- (0,2195)
[1] 1120 <- (0,2196)
[1] 1121 <- (0,2197)
[1] 1122 <- (0,2198)
[1] 1123 <- (0,2199)
[1] 1124 <- (0,2223)
[1] 1125 <- (0,2224)
[1] 1126 <- (0,2225)
[1] 1127 <- (0,2226)
[1] 1128 <- (0,2227)
[1] 1129 <- (0,2228)
[1] 1130 <- (0,2229)
[1] 1131 <- (0,2230)
[1] 1132 <- (0,2231)
[1] 1133 <- (0,2232)
[1] 1134 <- (0,2233)
[1] 1135 <- (0,2234)
[1] 1136 <- (0,2235)
[1] 1137 <- (0,2236)
[1] 1138 <- (0,2237)
[1] 1139 <- (0,2238)
[1] 1140 <- (0,2239)
[1] 1141 <- (0,2240)
[1] 1142 <- (0,2241)
[1] 1143 <- (0,2242)
[1] 1144 <- (0,2243)
[1] 1145 <- (0,2244)
[1] 1146 <- (0,2245)
[1] 1147 <- (0,2246)
[1] 1148 <- (0,2247)
[1] 1149 <- (0,2248)
[1] 1150 <- (0,2249)
[1] 1151 <- (0,2273)
[1] 1152 <- (0,2274)
[1] 1153 <- (0,2275)
[1] 1154 <- (0,2276)
[1] 1155 <- (0,2277)
[1] 1156 <- (0,2278)
[1] 1157 <- (0,2279)
[1] 1158 <- (0,2280)
[1] 1159 <- (0,2281)
[1] 1160 <- (0,2282)
[1] 1161 <- (0,2283)
[1] 1162 <- (0,2284)
[1] 1163 <- (0,2285)
[1] 1164 <- (0,2286)
[1] 1165 <- (0,2287)
[1] 1166 <- (0,2288)
[1] 1167 <- (0,2289)
[1] 1168 <- (0,2290)
[1] 1169 <- (0,2291)
[1] 1170 <- (0,2292)
[1] 1171 <- (0,2293)
[1] 1172 <- (0,2294)
[1] 1173 <- (0,2295)
[1] 1174 <- (0,2296)
[1] 1175 <- (0,2297)
[1] 1176 <- (0,2298)
[1] 1177 <- (0,2299)
[1] 1178 <- (0,2323)
[1] 1179 <- (0,2324)
[1] 1180 <- (0,2325)
[1] 1181 <- (0,2326)
[1] 1182 <- (0,2327)
[1] 1183 <- (0,2328)
[1] 1184 <- (0,2329)
[1] 1185 <- (0,2330)
[1] 1186 <- (0,2331)
[1] 1187 <- (0,2332)
[1] 1188 <- (0,2333)
[1] 1189 <- (0,2334)
[1] 1190 <- (0,2335)
[1] 1191 <- (0,2336)
[1] 1192 <- (0,2337)
[1] 1193 <- (0,2338)
[1] 1194 <- (0,2339)
[1] 1195 <- (0,2340)
[1] 1196 <- (0,2341)
[1] 1197 <- (0,2342)
[1] 1198 <- (0,2343)
[1] 1199 <- (0,2344)
[1] 1200 <- (0,2345)
[1] 1201 <- (0,2346)
[1] 1202 <- (0,2347)
[1] 1203 <- (0,2348)
[1] 1204 <- (0,2349)
[1] 1205 <- (0,2373)
[1] 1206 <- (0,2374)
[1] 1207 <- (0,2375)
[1] 1208 <- (0,2376)
[1] 1209 <- (0,2377)
[1] 1210 <- (0,2378)
[1] 1211 <- (0,2379)
[1] 1212 <- (0,2380)
[1] 1213 <- (0,2381)
[1] 1214 <- (0,2382)
[1] 1215 <- (0,2383)
[1] 1216 <- (0,2384)
[1] 1217 <- (0,2385)
[1] 1218 <- (0,2386)
[1] 1219 <- (0,2387)
[1] 1220 <- (0,2388)
[1] 1221 <- (0,2389)
[1] 1222 <- (0,2390)
[1] 1223 <- (0,2391)
[1] 1224 <- (0,2392)
[1] 1225 <- (0,2393)
[1] 1226 <- (0,2394)
[1] 1227 <- (0,2395)
[1] 1228 <- (0,2396)
[1] 1229 <- (0,2397)
[1] 1230 <- (0,2398)
[1] 1231 <- (0,2399)
[1] 1232 <- (0,2424)
[1] 1233 <- (0,2425)
[1] 1234 <- (0,2426)
[1] 1235 <- (0,2427)
[1] 1236 <- (0,2428)
[1] 1237 <- (0,2429)
[1] 1238 <- (0,2430)
[1] 1239 <- (0,2431)
[1] 1240 <- (0,2432)
[1] 1241 <- (0,2433)
[1] 1242 <- (0,2434)
[1] 1243 <- (0,2435)
[1] 1244 <- (0,2436)
[1] 1245 <- (0,2437)
[1] 1246 <- (0,2438)
[1] 1247 <- (0,2439)
[1] 1248 <- (0,2440)
[1] 1249 <- (0,2441)
[1] 1250 <- (0,2442)
[1] 1251 <- (0,2443)
[1] 1252 <- (0,2444)
[1] 1253 <- (0,2445)
[1] 1254 <- (0,2446)
[1] 1255 <- (0,2447)
[1] 1256 <- (0,2448)
[1] 1257 <- (0,2449)
[1] 1258 <- (0,2474)
[1] 1259 <- (0,2475)
[1] 1260 <- (0,2476)
[1] 1261 <- (0,2477)
[1] 1262 <- (0,2478)
[1] 1263 <- (0,2479)
[1] 1264 <- (0,2480)
[1] 1265 <- (0,2481)
[1] 1266 <- (0,2482)
[1] 1267 <- (0,2483)
[1] 1268 <- (0,2484)
[1] 1269 <- (0,2485)
[1] 1270 <- (0,2486)
[1] 1271 <- (0,2487)
[1] 1272 <- (0,2488)
[1] 1273 <- (0,2489)
[1] 1274 <- (0,2490)
[1] 1275 <- (0,2491)
[1] 1276 <- (0,2492)
[1] 1277 <- (0,2493)
[1] 1278 <- (0,2494)
[1] 1279 <- (0,2495)
[1] 1280 <- (0,2496)
[1] 1281 <- (0,2497)
[1] 1282 <- (0,2498)
[1] 1283 <- (0,2499)
[1] 1284 <- (0,2525)
[1] 1285 <- (0,2526)
[1] 1286 <- (0,2527)
[1] 1287 <- (0,2528)
[1] 1288 <- (0,2529)
[1] 1289 <- (0,2530)
[1] 1290 <- (0,2531)
[1] 1291 <- (0,2532)
[1] 1292 <- (0,2533)
[1] 1293 <- (0,2534)
[1] 1294 <- (0,2535)
[1] 1295 <- (0,2536)
[1] 1296 <- (0,2537)
[1] 1297 <- (0,2538)
[1] 1298 <- (0,2539)
[1] 1299 <- (0,2540)
[1] 1300 <- (0,2541)
[1] 1301 <- (0,2542)
[1] 1302 <- (0,2543)
[1] 1303 <- (0,2544)
[1] 1304 <- (0,2545)
[1] 1305 <- (0,2546)
[1] 1306 <- (0,2547)
[1] 1307 <- (0,2548)
[1] 1308 <- (0,2549)
[1] 1309 <- (0,2576)
[1] 1310 <- (0,2577)
[1] 1311 <- (0,2578)
[1] 1312 <- (0,2579)
[1] 1313 <- (0,2580)
[1] 1314 <- (0,2581)
[1] 1315 <- (0,2582)
[1] 1316 <- (0,2583)
[1] 1317 <- (0,2584)
[1] 1318 <- (0,2585)
[1] 1319 <- (0,2586)
[1] 1320 <- (0,2587)
[1] 1321 <- (0,2588)
[1] 1322 <- (0,2589)
[1] 1323 <- (0,2590)
[1] 1324 <- (0,2591)
[1] 1325 <- (0,2592)
[1] 1326 <- (0,2593)
[1] 1327 <- (0,2594)
[1] 1328 <- (0,2595)
[1] 1329 <- (0,2596)
[1] 1330 <- (0,2597)
[1] 1331 <- (0,2598)
[1] 1332 <- (0,2599)
[1] 1333 <- (0,2626)
[1] 1334 <- (0,2627)
[1] 1335 <- (0,2628)
[1] 1336 <- (0,2629)
[1] 1337 <- (0,2630)
[1] 1338 <- (0,2631)
[1] 1339 <- (0,2632)
[1] 1340 <- (0,2633)
[1] 1341 <- (0,2634)
[1] 1342 <- (0,2635)
[1] 1343 <- (0,2636)
[1] 1344 <- (0,2637)
[1] 1345 <- (0,2638)
[1] 1346 <- (0,2639)
[1] 1347 <- (0,2640)
[1] 1348 <- (0,2641)
[1] 1349 <- (0,2642)
[1] 1350 <- (0,2643)
[1] 1351 <- (0,2644)
[1] 1352 <- (0,2645)
[1] 1353 <- (0,2646)
[1] 1354 <- (0,2647)
[1] 1355 <- (0,2648)
[1] 1356 <- (0,2649)
[1] 1357 <- (0,2677)
[1] 1358 <- (0,2678)
[1] 1359 <- (0,2679)
[1] 1360 <- (0,2680)
[1] 1361 <- (0,2681)
[1] 1362 <- (0,2682)
[1] 1363 <- (0,2683)
[1] 1364 <- (0,2684)
[1] 1365 <- (0,2685)
[1] 1366 <- (0,2686)
[1] 1367 <- (0,2687)
[1] 1368 <- (0,2688)
[1] 1369 <- (0,2689)
[1] 1370 <- (0,2690)
[1] 1371 <- (0,2691)
[1] 1372 <- (0,2692)
[1] 1373 <- (0,2693)
[1] 1374 <- (0,2694)
[1] 1375 <- (0,2695)
[1] 1376 <- (0,2696)
[1] 1377 <- (0,2697)
[1] 1378 <- (0,2698)
[1] 1379 <- (0,2699)
[1] 1380 <- (0,2727)
[1] 1381 <- (0,2728)
[1] 1382 <- (0,2729)
[1] 1383 <- (0,2730)
[1] 1384 <- (0,2731)
[1] 1385 <- (0,2732)
[1] 1386 <- (0,2733)
[1] 1387 <- (0,2734)
[1] 1388 <- (0,2735)
[1] 1389 <- (0,2736)
[1] 1390 <- (0,2737)
[1] 1391 <- (0,2738)
[1] 1392 <- (0,2739)
[1] 1393 <- (0,2740)
[1] 1394 <- (0,2741)
[1] 1395 <- (0,2742)
[1] 1396 <- (0,2743)
[1] 1397 <- (0,2744)
[1] 1398 <- (0,2745)
[1] 1399 <- (0,2746)
[1] 1400 <- (0,2747)
[1] 1401 <- (0,2748)
[1] 1402 <- (0,2749)
[1] 1403 <- (0,2777)
[1] 1404 <- (0,2778)
[1] 1405 <- (0,2779)
[1] 1406 <- (0,2780)
[1] 1407 <- (0,2781)
[1] 1408 <- (0,2782)
[1] 1409 <- (0,2783)
[1] 1410 <- (0,2784)
[1] 1411 <- (0,2785)
[1] 1412 <- (0,2786)
[1] 1413 <- (0,2787)
[1] 1414 <- (0,2788)
[1] 1415 <- (0,2789)
[1] 1416 <- (0,2790)
[1] 1417 <- (0,2791)
[1] 1418 <- (0,2792)
[1] 1419 <- (0,2793)
[1] 1420 <- (0,2794)
[1] 1421 <- (0,2795)
[1] 1422 <- (0,2796)
[1] 1423 <- (0,2797)
[1] 1424 <- (0,2798)
[1] 1425 <- (0,2799)
[1] 1426 <- (0,2827)
[1] 1427 <- (0,2828)
[1] 1428 <- (0,2829)
[1] 1429 <- (0,2830)
[1] 1430 <- (0,2831)
[1] 1431 <- (0,2832)
[1] 1432 <- (0,2833)
[1] 1433 <- (0,2834)
[1] 1434 <- (0,2835)
[1] 1435 <- (0,2836)
[1] 1436 <- (0,2837)
[1] 1437 <- (0,2838)
[1] 1438 <- (0,2839)
[1] 1439 <- (0,2840)
[1] 1440 <- (0,2841)
[1] 1441 <- (0,2842)
[1] 1442 <- (0,2843)
[1] 1443 <- (0,2844)
[1] 1444 <- (0,2845)
[1] 1445 <- (0,2846)
[1] 1446 <- (0,2847)
[1] 1447 <- (0,2848)
[1] 1448 <- (0,2849)
[1] 1449 <- (0,2877)
[1] 1450 <- (0,2878)
[1] 1451 <- (0,2879)
[1] 1452 <- (0,2880)
[1] 1453 <- (0,2881)
[1] 1454 <- (0,2882)
[1] 1455 <- (0,2883)
[1] 1456 <- (0,2884)
[1] 1457 <- (0,2885)
[1] 1458 <- (0,2886)
[1] 1459 <- (0,2887)
[1] 1460 <- (0,2888)
[1] 1461 <- (0,2889)
[1] 1462 <- (0,2890)
[1] 1463 <- (0,2891)
[1] 1464 <- (0,2892)
[1] 1465 <- (0,2893)
[1] 1466 <- (0,2894)
[1] 1467 <- (0,2895)
[1] 1468 <- (0,2896)
[1] 1469 <- (0,2897)
[1] 1470 <- (0,2898)
[1] 1471 <- (0,2899)
[1] 1472 <- (0,2927)
[1] 1473 <- (0,2928)
[1] 1474 <- (0,2929)
[1] 1475 <- (0,2930)
[1] 1476 <- (0,2931)
[1] 1477 <- (0,2932)
[1] 1478 <- (0,2933)
[1] 1479 <- (0,2934)
[1] 1480 <- (0,2935)
[1] 1481 <- (0,2936)
[1] 1482 <- (0,2937)
[1] 1483 <- (0,2938)
[1] 1484 <- (0,2939)
[1] 1485 <- (0,2940)
[1] 1486 <- (0,2941)
[1] 1487 <- (0,2942)
[1] 1488 <- (0,2943)
[1] 1489 <- (0,2944)
[1] 1490 <- (0,2945)
[1] 1491 <- (0,2946)
[1] 1492 <- (0,2947)
[1] 1493 <- (0,2948)
[1] 1494 <- (0,2949)
[1] 1495 <- (0,2977)
[1] 1496 <- (0,2978)
[1] 1497 <- (0,2979)
[1] 1498 <- (0,2980)
[1] 1499 <- (0,2981)
[1] 1500 <- (0,2982)
[1] 1501 <- (0,2983)
[1] 1502 <- (0,2984)
[1] 1503 <- (0,2985)
[1] 1504 <- (0,2986)
[1] 1505 <- (0,2987)
[1] 1506 <- (0,2988)
[1] 1507 <- (0,2989)
[1] 1508 <- (0,2990)
[1] 1509 <- (0,2991)
[1] 1510 <- (0,2992)
[1] 1511 <- (0,2993)
[1] 1512 <- (0,2994)
[1] 1513 <- (0,2995)
[1] 1514 <- (0,2996)
[1] 1515 <- (0,2997)
[1] 1516 <- (0,2998)
[1] 1517 <- (0,2999)
[1] 1518 <- (0,3022)
[1] 1519 <- (0,3023)
[1] 1520 <- (0,3024)
[1] 1521 <- (0,3025)
[1] 1522 <- (0,3026)
[1] 1523 <- (0,3027)
[1] 1524 <- (0,3028)
[1] 1525 <- (0,3029)
[1] 1526 <- (0,3030)
[1] 1527 <- (0,3031)
[1] 1528 <- (0,3032)
[1] 1529 <- (0,3033)
[1] 1530 <- (0,3034)
[1] 1531 <- (0,3035)
[1] 1532 <- (0,3036)
[1] 1533 <- (0,3037)
[1] 1534 <- (0,3038)
[1] 1535 <- (0,3039)
[1] 1536 <- (0,3040)
[1] 1537 <- (0,3041)
[1] 1538 <- (0,3042)
[1] 1539 <- (0,3043)
[1] 1540 <- (0,3044)
[1] 1541 <- (0,3045)
[1] 1542 <- (0,3046)
[1] 1543 <- (0,3047)
[1] 1544 <- (0,3048)
[1] 1545 <- (0,3049)
[1] 1546 <- (0,3072)
[1] 1547 <- (0,3073)
[1] 1548 <- (0,3074)
[1] 1549 <- (0,3075)
[1] 1550 <- (0,3076)
[1] 1551 <- (0,3077)
[1] 1552 <- (0,3078)
[1] 1553 <- (0,3079)
[1] 1554 <- (0,3080)
[1] 1555 <- (0,3081)
[1] 1556 <- (0,3082)
[1] 1557 <- (0,3083)
[1] 1558 <- (0,3084)
[1] 1559 <- (0,3085)
[1] 1560 <- (0,3086)
[1] 1561 <- (0,3087)
[1] 1562 <- (0,3088)
[1] 1563 <- (0,3089)
[1] 1564 <- (0,3090)
[1] 1565 <- (0,3091)
[1] 1566 <- (0,3092)
[1] 1567 <- (0,3093)
[1] 1568 <- (0,3094)
[1] 1569 <- (0,3095)
[1] 1570 <- (0,3096)
[1] 1571 <- (0,3097)
[1] 1572 <- (0,3098)
[1] 1573 <- (0,3099)
[1] 1574 <- (0,3122)
[1] 1575 <- (0,3123)
[1] 1576 <- (0,3124)
[1] 1577 <- (0,3125)
[1] 1578 <- (0,3126)
[1] 1579 <- (0,3127)
[1] 1580 <- (0,3128)
[1] 1581 <- (0,3129)
[1] 1582 <- (0,3130)
[1] 1583 <- (0,3131)
[1] 1584 <- (0,3132)
[1] 1585 <- (0,3133)
[1] 1586 <- (0,3134)
[1] 1587 <- (0,3135)
[1] 1588 <- (0,3136)
[1] 1589 <- (0,3137)
[1] 1590 <- (0,3138)
[1] 1591 <- (0,3139)
[1] 1592 <- (0,3140)
[1] 1593 <- (0,3141)
[1] 1594 <- (0,3142)
[1] 1595 <- (0,3143)
[1] 1596 <- (0,3144)
[1] 1597 <- (0,3145)
[1] 1598 <- (0,3146)
[1] 1599 <- (0,3147)
[1] 1600 <- (0,3148)
[1] 1601 <- (0,3149)
[1] 1602 <- (0,3172)
[1] 1603 <- (0,3173)
[1] 1604 <- (0,3174)
[1] 1605 <- (0,3175)
[1] 1606 <- (0,3176)
[1] 1607 <- (0,3177)
[1] 1608 <- (0,3178)
[1] 1609 <- (0,3179)
[1] 1610 <- (0,3180)
[1] 1611 <- (0,3181)
[1] 1612 <- (0,3182)
[1] 1613 <- (0,3183)
[1] 1614 <- (0,3184)
[1] 1615 <- (0,3185)
[1] 1616 <- (0,3186)
[1] 1617 <- (0,3187)
[1] 1618 <- (0,3188)
[1] 1619 <- (0,3189)
[1] 1620 <- (0,3190)
[1] 1621 <- (0,3191)
[1] 1622 <- (0,3192)
[1] 1623 <- (0,3193)
[1] 1624 <- (0,3194)
[1] 1625 <- (0,3195)
[1] 1626 <- (0,3196)
[1] 1627 <- (0,3197)
[1] 1628 <- (0,3198)
[1] 1629 <- (0,3199)
[1] 1630 <- (0,3223)
[1] 1631 <- (0,3224)
[1] 1632 <- (0,3225)
[1] 1633 <- (0,3226)
[1] 1634 <- (0,3227)
[1] 1635 <- (0,3228)
[1] 1636 <- (0,3229)
[1] 1637 <- (0,3230)
[1] 1638 <- (0,3231)
[1] 1639 <- (0,3232)
[1] 1640 <- (0,3233)
[1] 1641 <- (0,3234)
[1] 1642 <- (0,3235)
[1] 1643 <- (0,3236)
[1] 1644 <- (0,3237)
[1] 1645 <- (0,3238)
[1] 1646 <- (0,3239)
[1] 1647 <- (0,3240)
[1] 1648 <- (0,3241)
[1] 1649 <- (0,3242)
[1] 1650 <- (0,3243)
[1] 1651 <- (0,3244)
[1] 1652 <- (0,3245)
[1] 1653 <- (0,3246)
[1] 1654 <- (0,3247)
[1] 1655 <- (0,3248)
[1] 1656 <- (0,3249)
[1] 1657 <- (0,3273)
[1] 1658 <- (0,3274)
[1] 1659 <- (0,3275)
[1] 1660 <- (0,3276)
[1] 1661 <- (0,3277)
[1] 1662 <- (0,3278)
[1] 1663 <- (0,3279)
[1] 1664 <- (0,3280)
[1] 1665 <- (0,3281)
[1] 1666 <- (0,3282)
[1] 1667 <- (0,3283)
[1] 1668 <- (0,3284)
[1] 1669 <- (0,3285)
[1] 1670 <- (0,3286)
[1] 1671 <- (0,3287)
[1] 1672 <- (0,3288)
[1] 1673 <- (0,3289)
[1] 1674 <- (0,3290)
[1] 1675 <- (0,3291)
[1] 1676 <- (0,3292)
[1] 1677 <- (0,3293)
[1] 1678 <- (0,3294)
[1] 1679 <- (0,3295)
[1] 1680 <- (0,3296)
[1] 1681 <- (0,3297)
[1] 1682 <- (0,3298)
[1] 1683 <- (0,3299)
[1] 1684 <- (0,3323)
[1] 1685 <- (0,3324)
[1] 1686 <- (0,3325)
[1] 1687 <- (0,3326)
[1] 1688 <- (0,3327)
[1] 1689 <- (0,3328)
[1] 1690 <- (0,3329)
[1] 1691 <- (0,3330)
[1] 1692 <- (0,3331)
[1] 1693 <- (0,3332)
[1] 1694 <- (0,3333)
[1] 1695 <- (0,3334)
[1] 1696 <- (0,3335)
[1] 1697 <- (0,3336)
[1] 1698 <- (0,3337)
[1] 1699 <- (0,3338)
[1] 1700 <- (0,3339)
[1] 1701 <- (0,3340)
[1] 1702 <- (0,3341)
[1] 1703 <- (0,3342)
[1] 1704 <- (0,3343)
[1] 1705 <- (0,3344)
[1] 1706 <- (0,3345)
[1] 1707 <- (0,3346)
[1] 1708 <- (0,3347)
[1] 1709 <- (0,3348)
[1] 1710 <- (0,3349)
[1] 1711 <- (0,3373)
[1] 1712 <- (0,3374)
[1] 1713 <- (0,3375)
[1] 1714 <- (0,3376)
[1] 1715 <- (0,3377)
[1] 1716 <- (0,3378)
[1] 1717 <- (0,3379)
[1] 1718 <- (0,3380)
[1] 1719 <- (0,3381)
[1] 1720 <- (0,3382)
[1] 1721 <- (0,3383)
[1] 1722 <- (0,3384)
[1] 1723 <- (0,3385)
[1] 1724 <- (0,3386)
[1] 1725 <- (0,3387)
[1] 1726 <- (0,3388)
[1] 1727 <- (0,3389)
[1] 1728 <- (0,3390)
[1] 1729 <- (0,3391)
[1] 1730 <- (0,3392)
[1] 1731 <- (0,3393)
[1] 1732 <- (0,3394)
[1] 1733 <- (0,3395)
[1] 1734 <- (0,3396)
[1] 1735 <- (0,3397)
[1] 1736 <- (0,3398)
[1] 1737 <- (0,3399)
[1] 1738 <- (0,3424)
[1] 1739 <- (0,3425)
[1] 1740 <- (0,3426)
[1] 1741 <- (0,3427)
[1] 1742 <- (0,3428)
[1] 1743 <- (0,3429)
[1] 1744 <- (0,3430)
[1] 1745 <- (0,3431)
[1] 1746 <- (0,3432)
[1] 1747 <- (0,3433)
[1] 1748 <- (0,3434)
[1] 1749 <- (0,3435)
[1] 1750 <- (0,3436)
[1] 1751 <- (0,3437)
[1] 1752 <- (0,3438)
[1] 1753 <- (0,3439)
[1] 1754 <- (0,3440)
[1] 1755 <- (0,3441)
[1] 1756 <- (0,3442)
[1] 1757 <- (0,3443)
[1] 1758 <- (0,3444)
[1] 1759 <- (0,3445)
[1] 1760 <- (0,3446)
[1] 1761 <- (0,3447)
[1] 1762 <- (0,3448)
[1] 1763 <- (0,3449)
[1] 1764 <- (0,3474)
[1] 1765 <- (0,3475)
[1] 1766 <- (0,3476)
[1] 1767 <- (0,3477)
[1] 1768 <- (0,3478)
[1] 1769 <- (0,3479)
[1] 1770 <- (0,3480)
[1] 1771 <- (0,3481)
[1] 1772 <- (0,3482)
[1] 1773 <- (0,3483)
[1] 1774 <- (0,3484)
[1] 1775 <- (0,3485)
[1] 1776 <- (0,3486)
[1] 1777 <- (0,3487)
[1] 1778 <- (0,3488)
[1] 1779 <- (0,3489)
[1] 1780 <- (0,3490)
[1] 1781 <- (0,3491)
[1] 1782 <- (0,3492)
[1] 1783 <- (0,3493)
[1] 1784 <- (0,3494)
[1] 1785 <- (0,3495)
[1] 1786 <- (0,3496)
[1] 1787 <- (0,3497)
[1] 1788 <- (0,3498)
[1] 1789 <- (0,3499)
[1] 1790 <- (0,3525)
[1] 1791 <- (0,3526)
[1] 1792 <- (0,3527)
[1] 1793 <- (0,3528)
[1] 1794 <- (0,3529)
[1] 1795 <- (0,3530)
[1] 1796 <- (0,3531)
[1] 1797 <- (0,3532)
[1] 1798 <- (0,3533)
[1] 1799 <- (0,3534)
[1] 1800 <- (0,3535)
[1] 1801 <- (0,3536)
[1] 1802 <- (0,3537)
[1] 1803 <- (0,3538)
[1] 1804 <- (0,3539)
[1] 1805 <- (0,3540)
[1] 1806 <- (0,3541)
[1] 1807 <- (0,3542)
[1] 1808 <- (0,3543)
[1] 1809 <- (0,3544)
[1] 1810 <- (0,3545)
[1] 1811 <- (0,3546)
[1] 1812 <- (0,3547)
[1] 1813 <- (0,3548)
[1] 1814 <- (0,3549)
[1] 1815 <- (0,3576)
[1] 1816 <- (0,3577)
[1] 1817 <- (0,3578)
[1] 1818 <- (0,3579)
[1] 1819 <- (0,3580)
[1] 1820 <- (0,3581)
[1] 1821 <- (0,3582)
[1] 1822 <- (0,3583)
[1] 1823 <- (0,3584)
[1] 1824 <- (0,3585)
[1] 1825 <- (0,3586)
[1] 1826 <- (0,3587)
[1] 1827 <- (0,3588)
[1] 1828 <- (0,3589)
[1] 1829 <- (0,3590)
[1] 1830 <- (0,3591)
[1] 1831 <- (0,3592)
[1] 1832 <- (0,3593)
[1] 1833 <- (0,3594)
[1] 1834 <- (0,3595)
[1] 1835 <- (0,3596)
[1] 1836 <- (0,3597)
[1] 1837 <- (0,3598)
[1] 1838 <- (0,3599)
[1] 1839 <- (0,3626)
[1] 1840 <- (0,3627)
[1] 1841 <- (0,3628)
[1] 1842 <- (0,3629)
[1] 1843 <- (0,3630)
[1] 1844 <- (0,3631)
[1] 1845 <- (0,3632)
[1] 1846 <- (0,3633)
[1] 1847 <- (0,3634)
[1] 1848 <- (0,3635)
[1] 1849 <- (0,3636)
[1] 1850 <- (0,3637)
[1] 1851 <- (0,3638)
[1] 1852 <- (0,3639)
[1] 1853 <- (0,3640)
[1] 1854 <- (0,3641)
[1] 1855 <- (0,3642)
[1] 1856 <- (0,3643)
[1] 1857 <- (0,3644)
[1] 1858 <- (0,3645)
[1] 1859 <- (0,3646)
[1] 1860 <- (0,3647)
[1] 1861 <- (0,3648)
[1] 1862 <- (0,3649)
[1] 1863 <- (0,3677)
[1] 1864 <- (0,3678)
[1] 1865 <- (0,3679)
[1] 1866 <- (0,3680)
[1] 1867 <- (0,3681)
[1] 1868 <- (0,3682)
[1] 1869 <- (0,3683)
[1] 1870 <- (0,3684)
[1] 1871 <- (0,3685)
[1] 1872 <- (0,3686)
[1] 1873 <- (0,3687)
[1] 1874 <- (0,3688)
[1] 1875 <- (0,3689)
[1] 1876 <- (0,3690)
[1] 1877 <- (0,3691)
[1] 1878 <- (0,3692)
[1] 1879 <- (0,3693)
[1] 1880 <- (0,3694)
[1] 1881 <- (0,3695)
[1] 1882 <- (0,3696)
[1] 1883 <- (0,3697)
[1] 1884 <- (0,3698)
[1] 1885 <- (0,3699)
[1] 1886 <- (0,3727)
[1] 1887 <- (0,3728)
[1] 1888 <- (0,3729)
[1] 1889 <- (0,3730)
[1] 1890 <- (0,3731)
[1] 1891 <- (0,3732)
[1] 1892 <- (0,3733)
[1] 1893 <- (0,3734)
[1] 1894 <- (0,3735)
[1] 1895 <- (0,3736)
[1] 1896 <- (0,3737)
[1] 1897 <- (0,3738)
[1] 1898 <- (0,3739)
[1] 1899 <- (0,3740)
[1] 1900 <- (0,3741)
[1] 1901 <- (0,3742)
[1] 1902 <- (0,3743)
[1] 1903 <- (0,3744)
[1] 1904 <- (0,3745)
[1] 1905 <- (0,3746)
[1] 1906 <- (0,3747)
[1] 1907 <- (0,3748)
[1] 1908 <- (0,3749)
[1] 1909 <- (0,3777)
[1] 1910 <- (0,3778)
[1] 1911 <- (0,3779)
[1] 1912 <- (0,3780)
[1] 1913 <- (0,3781)
[1] 1914 <- (0,3782)
[1] 1915 <- (0,3783)
[1] 1916 <- (0,3784)
[1] 1917 <- (0,3785)
[1] 1918 <- (0,3786)
[1] 1919 <- (0,3787)
[1] 1920 <- (0,3788)
[1] 1921 <- (0,3789)
[1] 1922 <- (0,3790)
[1] 1923 <- (0,3791)
[1] 1924 <- (0,3792)
[1] 1925 <- (0,3793)
[1] 1926 <- (0,3794)
[1] 1927 <- (0,3795)
[1] 1928 <- (0,3796)
[1] 1929 <- (0,3797)
[1] 1930 <- (0,3798)
[1] 1931 <- (0,3799)
[1] 1932 <- (0,3827)
[1] 1933 <- (0,3828)
[1] 1934 <- (0,3829)
[1] 1935 <- (0,3830)
[1] 1936 <- (0,3831)
[1] 1937 <- (0,3832)
[1] 1938 <- (0,3833)
[1] 1939 <- (0,3834)
[1] 1940 <- (0,3835)
[1] 1941 <- (0,3836)
[1] 1942 <- (0,3837)
[1] 1943 <- (0,3838)
[1] 1944 <- (0,3839)
[1] 1945 <- (0,3840)
[1] 1946 <- (0,3841)
[1] 1947 <- (0,3842)
[1] 1948 <- (0,3843)
[1] 1949 <- (0,3844)
[1] 1950 <- (0,3845)
[1] 1951 <- (0,3846)
[1] 1952 <- (0,3847)
[1] 1953 <- (0,3848)
[1] 1954 <- (0,3849)
[1] 1955 <- (0,3877)
[1] 1956 <- (0,3878)
[1] 1957 <- (0,3879)
[1] 1958 <- (0,3880)
[1] 1959 <- (0,3881)
[1] 1960 <- (0,3882)
[1] 1961 <- (0,3883)
[1] 1962 <- (0,3884)
[1] 1963 <- (0,3885)
[1] 1964 <- (0,3886)
[1] 1965 <- (0,3887)
[1] 1966 <- (0,3888)
[1] 1967 <- (0,3889)
[1] 1968 <- (0,3890)
[1] 1969 <- (0,3891)
[1] 1970 <- (0,3892)
[1] 1971 <- (0,3893)
[1] 1972 <- (0,3894)
[1] 1973 <- (0,3895)
[1] 1974 <- (0,3896)
[1] 1975 <- (0,3897)
[1] 1976 <- (0,3898)
[1] 1977 <- (0,3899)
[1] 1978 <- (0,3927)
[1] 1979 <- (0,3928)
[1] 1980 <- (0,3929)
[1] 1981 <- (0,3930)
[1] 1982 <- (0,3931)
[1] 1983 <- (0,3932)
[1] 1984 <- (0,3933)
[1] 1985 <- (0,3934)
[1] 1986 <- (0,3935)
[1] 1987 <- (0,3936)
[1] 1988 <- (0,3937)
[1] 1989 <- (0,3938)
[1] 1990 <- (0,3939)
[1] 1991 <- (0,3940)
[1] 1992 <- (0,3941)
[1] 1993 <- (0,3942)
[1] 1994 <- (0,3943)
[1] 1995 <- (0,3944)
[1] 1996 <- (0,3945)
[1] 1997 <- (0,3946)
[1] 1998 <- (0,3947)
[1] 1999 <- (0,3948)
[1] 2000 <- (0,3949)
[1] 2001 <- (0,3977)
[1] 2002 <- (0,3978)
[1] 2003 <- (0,3979)
[1] 2004 <- (0,3980)
[1] 2005 <- (0,3981)
[1] 2006 <- (0,3982)
[1] 2007 <- (0,3983)
[1] 2008 <- (0,3984)
[1] 2009 <- (0,3985)
[1] 2010 <- (0,3986)
[1] 2011 <- (0,3987)
[1] 2012 <- (0,3988)
[1] 2013 <- (0,3989)
[1] 2014 <- (0,3990)
[1] 2015 <- (0,3991)
[1] 2016 <- (0,3992)
[1] 2017 <- (0,3993)
[1] 2018 <- (0,3994)
[1] 2019 <- (0,3995)
[1] 2020 <- (0,3996)
[1] 2021 <- (0,3997)
[1] 2022 <- (0,3998)
[1] 2023 <- (0,3999)
[1] 2024 <- (0,4022)
[1] 2025 <- (0,4023)
[1] 2026 <- (0,4024)
[1] 2027 <- (0,4025)
[1] 2028 <- (0,4026)
[1] 2029 <- (0,4027)
[1] 2030 <- (0,4028)
[1] 2031 <- (0,4029)
[1] 2032 <- (0,4030)
[1] 2033 <- (0,4031)
[1] 2034 <- (0,4032)
[1] 2035 <- (0,4033)
[1] 2036 <- (0,4034)
[1] 2037 <- (0,4035)
[1] 2038 <- (0,4036)
[1] 2039 <- (0,4037)
[1] 2040 <- (0,4038)
[1] 2041 <- (0,4039)
[1] 2042 <- (0,4040)
[1] 2043 <- (0,4041)
[1] 2044 <- (0,4042)
[1] 2045 <- (0,4043)
[1] 2046 <- (0,4044)
[1] 2047 <- (0,4045)
[1] 2048 <- (0,4046)
[1] 2049 <- (0,4047)
[1] 2050 <- (0,4048)
[1] 2051 <- (0,4049)
[1] 2052 <- (0,4072)
[1] 2053 <- (0,4073)
[1] 2054 <- (0,4074)
[1] 2055 <- (0,4075)
[1] 2056 <- (0,4076)
[1] 2057 <- (0,4077)
[1] 2058 <- (0,4078)
[1] 2059 <- (0,4079)
[1] 2060 <- (0,4080)
[1] 2061 <- (0,4081)
[1] 2062 <- (0,4082)
[1] 2063 <- (0,4083)
[1] 2064 <- (0,4084)
[1] 2065 <- (0,4085)
[1] 2066 <- (0,4086)
[1] 2067 <- (0,4087)
[1] 2068 <- (0,4088)
[1] 2069 <- (0,4089)
[1] 2070 <- (0,4090)
[1] 2071 <- (0,4091)
[1] 2072 <- (0,4092)
[1] 2073 <- (0,4093)
[1] 2074 <- (0,4094)
[1] 2075 <- (0,4095)
[1] 2076 <- (0,4096)
[1] 2077 <- (0,4097)
[1] 2078 <- (0,4098)
[1] 2079 <- (0,4099)
[1] 2080 <- (0,4122)
[1] 2081 <- (0,4123)
[1] 2082 <- (0,4124)
[1] 2083 <- (0,4125)
[1] 2084 <- (0,4126)
[1] 2085 <- (0,4127)
[1] 2086 <- (0,4128)
[1] 2087 <- (0,4129)
[1] 2088 <- (0,4130)
[1] 2089 <- (0,4131)
[1] 2090 <- (0,4132)
[1] 2091 <- (0,4133)
[1] 2092 <- (0,4134)
[1] 2093 <- (0,4135)
[1] 2094 <- (0,4136)
[1] 2095 <- (0,4137)
[1] 2096 <- (0,4138)
[1] 2097 <- (0,4139)
[1] 2098 <- (0,4140)
[1] 2099 <- (0,4141)
[1] 2100 <- (0,4142)
[1] 2101 <- (0,4143)
[1] 2102 <- (0,4144)
[1] 2103 <- (0,4145)
[1] 2104 <- (0,4146)
[1] 2105 <- (0,4147)
[1] 2106 <- (0,4148)
[1] 2107 <- (0,4149)
[1] 2108 <- (0,4172)
[1] 2109 <- (0,4173)
[1] 2110 <- (0,4174)
[1] 2111 <- (0,4175)
[1] 2112 <- (0,4176)
[1] 2113 <- (0,4177)
[1] 2114 <- (0,4178)
[1] 2115 <- (0,4179)
[1] 2116 <- (0,4180)
[1] 2117 <- (0,4181)
[1] 2118 <- (0,4182)
[1] 2119 <- (0,4183)
[1] 2120 <- (0,4184)
[1] 2121 <- (0,4185)
[1] 2122 <- (0,4186)
[1] 2123 <- (0,4187)
[1] 2124 <- (0,4188)
[1] 2125 <- (0,4189)
[1] 2126 <- (0,4190)
[1] 2127 <- (0,4191)
[1] 2128 <- (0,4192)
[1] 2129 <- (0,4193)
[1] 2130 <- (0,4194)
[1] 2131 <- (0,4195)
[1] 2132 <- (0,4196)
[1] 2133 <- (0,4197)
[1] 2134 <- (0,4198)
[1] 2135 <- (0,4199)
[1] 2136 <- (0,4223)
[1] 2137 <- (0,4224)
[1] 2138 <- (0,4225)
[1] 2139 <- (0,4226)
[1] 2140 <- (0,4227)
[1] 2141 <- (0,4228)
[1] 2142 <- (0,4229)
[1] 2143 <- (0,4230)
[1] 2144 <- (0,4231)
[1] 2145 <- (0,4232)
[1] 2146 <- (0,4233)
[1] 2147 <- (0,4234)
[1] 2148 <- (0,4235)
[1] 2149 <- (0,4236)
[1] 2150 <- (0,4237)
[1] 2151 <- (0,4238)
[1] 2152 <- (0,4239)
[1] 2153 <- (0,4240)
[1] 2154 <- (0,4241)
[1] 2155 <- (0,4242)
[1] 2156 <- (0,4243)
[1] 2157 <- (0,4244)
[1] 2158 <- (0,4245)
[1] 2159 <- (0,4246)
[1] 2160 <- (0,4247)
[1] 2161 <- (0,4248)
[1] 2162 <- (0,4249)
[1] 2163 <- (0,4273)
[1] 2164 <- (0,4274)
[1] 2165 <- (0,4275)
[1] 2166 <- (0,4276)
[1] 2167 <- (0,4277)
[1] 2168 <- (0,4278)
[1] 2169 <- (0,4279)
[1] 2170 <- (0,4280)
[1] 2171 <- (0,4281)
[1] 2172 <- (0,4282)
[1] 2173 <- (0,4283)
[1] 2174 <- (0,4284)
[1] 2175 <- (0,4285)
[1] 2176 <- (0,4286)
[1] 2177 <- (0,4287)
[1] 2178 <- (0,4288)
[1] 2179 <- (0,4289)
[1] 2180 <- (0,4290)
[1] 2181 <- (0,4291)
[1] 2182 <- (0,4292)
[1] 2183 <- (0,4293)
[1] 2184 <- (0,4294)
[1] 2185 <- (0,4295)
[1] 2186 <- (0,4296)
[1] 2187 <- (0,4297)
[1] 2188 <- (0,4298)
[1] 2189 <- (0,4299)
[1] 2190 <- (0,4323)
[1] 2191 <- (0,4324)
[1] 2192 <- (0,4325)
[1] 2193 <- (0,4326)
[1] 2194 <- (0,4327)
[1] 2195 <- (0,4328)
[1] 2196 <- (0,4329)
[1] 2197 <- (0,4330)
[1] 2198 <- (0,4331)
[1] 2199 <- (0,4332)
[1] 2200 <- (0,4333)
[1] 2201 <- (0,4334)
[1] 2202 <- (0,4335)
[1] 2203 <- (0,4336)
[1] 2204 <- (0,4337)
[1] 2205 <- (0,4338)
[1] 2206 <- (0,4339)
[1] 2207 <- (0,4340)
[1] 2208 <- (0,4341)
[1] 2209 <- (0,4342)
[1] 2210 <- (0,4343)
[1] 2211 <- (0,4344)
[1] 2212 <- (0,4345)
[1] 2213 <- (0,4346)
[1] 2214 <- (0,4347)
[1] 2215 <- (0,4348)
[1] 2216 <- (0,4349)
[1] 2217 <- (0,4373)
[1] 2218 <- (0,4374)
[1] 2219 <- (0,4375)
[1] 2220 <- (0,4376)
[1] 2221 <- (0,4377)
[1] 2222 <- (0,4378)
[1] 2223 <- (0,4379)
[1] 2224 <- (0,4380)
[1] 2225 <- (0,4381)
[1] 2226 <- (0,4382)
[1] 2227 <- (0,4383)
[1] 2228 <- (0,4384)
[1] 2229 <- (0,4385)
[1] 2230 <- (0,4386)
[1] 2231 <- (0,4387)
[1] 2232 <- (0,4388)
[1] 2233 <- (0,4389)
[1] 2234 <- (0,4390)
[1] 2235 <- (0,4391)
[1] 2236 <- (0,4392)
[1] 2237 <- (0,4393)
[1] 2238 <- (0,4394)
[1] 2239 <- (0,4395)
[1] 2240 <- (0,4396)
[1] 2241 <- (0,4397)
[1] 2242 <- (0,4398)
[1] 2243 <- (0,4399)
[1] 2244 <- (0,4424)
[1] 2245 <- (0,4425)
[1] 2246 <- (0,4426)
[1] 2247 <- (0,4427)
[1] 2248 <- (0,4428)
[1] 2249 <- (0,4429)
[1] 2250 <- (0,4430)
[1] 2251 <- (0,4431)
[1] 2252 <- (0,4432)
[1] 2253 <- (0,4433)
[1] 2254 <- (0,4434)
[1] 2255 <- (0,4435)
[1] 2256 <- (0,4436)
[1] 2257 <- (0,4437)
[1] 2258 <- (0,4438)
[1] 2259 <- (0,4439)
[1] 2260 <- (0,4440)
[1] 2261 <- (0,4441)
[1] 2262 <- (0,4442)
[1] 2263 <- (0,4443)
[1] 2264 <- (0,4444)
[1] 2265 <- (0,4445)
[1] 2266 <- (0,4446)
[1] 2267 <- (0,4447)
[1] 2268 <- (0,4448)
[1] 2269 <- (0,4449)
[1] 2270 <- (0,4474)
[1] 2271 <- (0,4475)
[1] 2272 <- (0,4476)
[1] 2273 <- (0,4477)
[1] 2274 <- (0,4478)
[1] 2275 <- (0,4479)
[1] 2276 <- (0,4480)
[1] 2277 <- (0,4481)
[1] 2278 <- (0,4482)
[1] 2279 <- (0,4483)
[1] 2280 <- (0,4484)
[1] 2281 <- (0,4485)
[1] 2282 <- (0,4486)
[1] 2283 <- (0,4487)
[1] 2284 <- (0,4488)
[1] 2285 <- (0,4489)
[1] 2286 <- (0,4490)
[1] 2287 <- (0,4491)
[1] 2288 <- (0,4492)
[1] 2289 <- (0,4493)
[1] 2290 <- (0,4494)
[1] 2291 <- (0,4495)
[1] 2292 <- (0,4496)
[1] 2293 <- (0,4497)
[1] 2294 <- (0,4498)
[1] 2295 <- (0,4499)
[1] 2296 <- (0,4525)
[1] 2297 <- (0,4526)
[1] 2298 <- (0,4527)
[1] 2299 <- (0,4528)
[1] 2300 <- (0,4529)
[1] 2301 <- (0,4530)
[1] 2302 <- (0,4531)
[1] 2303 <- (0,4532)
[1] 2304 <- (0,4533)
[1] 2305 <- (0,4534)
[1] 2306 <- (0,4535)
[1] 2307 <- (0,4536)
[1] 2308 <- (0,4537)
[1] 2309 <- (0,4538)
[1] 2310 <- (0,4539)
[1] 2311 <- (0,4540)
[1] 2312 <- (0,4541)
[1] 2313 <- (0,4542)
[1] 2314 <- (0,4543)
[1] 2315 <- (0,4544)
[1] 2316 <- (0,4545)
[1] 2317 <- (0,4546)
[1] 2318 <- (0,4547)
[1] 2319 <- (0,4548)
[1] 2320 <- (0,4549)
[1] 2321 <- (0,4576)
[1] 2322 <- (0,4577)
[1] 2323 <- (0,4578)
[1] 2324 <- (0,4579)
[1] 2325 <- (0,4580)
[1] 2326 <- (0,4581)
[1] 2327 <- (0,4582)
[1] 2328 <- (0,4583)
[1] 2329 <- (0,4584)
[1] 2330 <- (0,4585)
[1] 2331 <- (0,4586)
[1] 2332 <- (0,4587)
[1] 2333 <- (0,4588)
[1] 2334 <- (0,4589)
[1] 2335 <- (0,4590)
[1] 2336 <- (0,4591)
[1] 2337 <- (0,4592)
[1] 2338 <- (0,4593)
[1] 2339 <- (0,4594)
[1] 2340 <- (0,4595)
[1] 2341 <- (0,4596)
[1] 2342 <- (0,4597)
[1] 2343 <- (0,4598)
[1] 2344 <- (0,4599)
[1] 2345 <- (0,4626)
[1] 2346 <- (0,4627)
[1] 2347 <- (0,4628)
[1] 2348 <- (0,4629)
[1] 2349 <- (0,4630)
[1] 2350 <- (0,4631)
[1] 2351 <- (0,4632)
[1] 2352 <- (0,4633)
[1] 2353 <- (0,4634)
[1] 2354 <- (0,4635)
[1] 2355 <- (0,4636)
[1] 2356 <- (0,4637)
[1] 2357 <- (0,4638)
[1] 2358 <- (0,4639)
[1] 2359 <- (0,4640)
[1] 2360 <- (0,4641)
[1] 2361 <- (0,4642)
[1] 2362 <- (0,4643)
[1] 2363 <- (0,4644)
[1] 2364 <- (0,4645)
[1] 2365 <- (0,4646)
[1] 2366 <- (0,4647)
[1] 2367 <- (0,4648)
[1] 2368 <- (0,4649)
[1] 2369 <- (0,4677)
[1] 2370 <- (0,4678)
[1] 2371 <- (0,4679)
[1] 2372 <- (0,4680)
[1] 2373 <- (0,4681)
[1] 2374 <- (0,4682)
[1] 2375 <- (0,4683)
[1] 2376 <- (0,4684)
[1] 2377 <- (0,4685)
[1] 2378 <- (0,4686)
[1] 2379 <- (0,4687)
[1] 2380 <- (0,4688)
[1] 2381 <- (0,4689)
[1] 2382 <- (0,4690)
[1] 2383 <- (0,4691)
[1] 2384 <- (0,4692)
[1] 2385 <- (0,4693)
[1] 2386 <- (0,4694)
[1] 2387 <- (0,4695)
[1] 2388 <- (0,4696)
[1] 2389 <- (0,4697)
[1] 2390 <- (0,4698)
[1] 2391 <- (0,4699)
[1] 2392 <- (0,4727)
[1] 2393 <- (0,4728)
[1] 2394 <- (0,4729)
[1] 2395 <- (0,4730)
[1] 2396 <- (0,4731)
[1] 2397 <- (0,4732)
[1] 2398 <- (0,4733)
[1] 2399 <- (0,4734)
[1] 2400 <- (0,4735)
[1] 2401 <- (0,4736)
[1] 2402 <- (0,4737)
[1] 2403 <- (0,4738)
[1] 2404 <- (0,4739)
[1] 2405 <- (0,4740)
[1] 2406 <- (0,4741)
[1] 2407 <- (0,4742)
[1] 2408 <- (0,4743)
[1] 2409 <- (0,4744)
[1] 2410 <- (0,4745)
[1] 2411 <- (0,4746)
[1] 2412 <- (0,4747)
[1] 2413 <- (0,4748)
[1] 2414 <- (0,4749)
[1] 2415 <- (0,4777)
[1] 2416 <- (0,4778)
[1] 2417 <- (0,4779)
[1] 2418 <- (0,4780)
[1] 2419 <- (0,4781)
[1] 2420 <- (0,4782)
[1] 2421 <- (0,4783)
[1] 2422 <- (0,4784)
[1] 2423 <- (0,4785)
[1] 2424 <- (0,4786)
[1] 2425 <- (0,4787)
[1] 2426 <- (0,4788)
[1] 2427 <- (0,4789)
[1] 2428 <- (0,4790)
[1] 2429 <- (0,4791)
[1] 2430 <- (0,4792)
[1] 2431 <- (0,4793)
[1] 2432 <- (0,4794)
[1] 2433 <- (0,4795)
[1] 2434 <- (0,4796)
[1] 2435 <- (0,4797)
[1] 2436 <- (0,4798)
[1] 2437 <- (0,4799)
[1] 2438 <- (0,4827)
[1] 2439 <- (0,4828)
[1] 2440 <- (0,4829)
[1] 2441 <- (0,4830)
[1] 2442 <- (0,4831)
[1] 2443 <- (0,4832)
[1] 2444 <- (0,4833)
[1] 2445 <- (0,4834)
[1] 2446 <- (0,4835)
[1] 2447 <- (0,4836)
[1] 2448 <- (0,4837)
[1] 2449 <- (0,4838)
[1] 2450 <- (0,4839)
[1] 2451 <- (0,4840)
[1] 2452 <- (0,4841)
[1] 2453 <- (0,4842)
[1] 2454 <- (0,4843)
[1] 2455 <- (0,4844)
[1] 2456 <- (0,4845)
[1] 2457 <- (0,4846)
[1] 2458 <- (0,4847)
[1] 2459 <- (0,4848)
[1] 2460 <- (0,4849)
[1] 2461 <- (0,4877)
[1] 2462 <- (0,4878)
[1] 2463 <- (0,4879)
[1] 2464 <- (0,4880)
[1] 2465 <- (0,4881)
[1] 2466 <- (0,4882)
[1] 2467 <- (0,4883)
[1] 2468 <- (0,4884)
[1] 2469 <- (0,4885)
[1] 2470 <- (0,4886)
[1] 2471 <- (0,4887)
[1] 2472 <- (0,4888)
[1] 2473 <- (0,4889)
[1] 2474 <- (0,4890)
[1] 2475 <- (0,4891)
[1] 2476 <- (0,4892)
[1] 2477 <- (0,4893)
[1] 2478 <- (0,4894)
[1] 2479 <- (0,4895)
[1] 2480 <- (0,4896)
[1] 2481 <- (0,4897)
[1] 2482 <- (0,4898)
[1] 2483 <- (0,4899)
[1] 2484 <- (0,4927)
[1] 2485 <- (0,4928)
[1] 2486 <- (0,4929)
[1] 2487 <- (0,4930)
[1] 2488 <- (0,4931)
[1] 2489 <- (0,4932)
[1] 2490 <- (0,4933)
[1] 2491 <- (0,4934)
[1] 2492 <- (0,4935)
[1] 2493 <- (0,4936)
[1] 2494 <- (0,4937)
[1] 2495 <- (0,4938)
[1] 2496 <- (0,4939)
[1] 2497 <- (0,4940)
[1] 2498 <- (0,4941)
[1] 2499 <- (0,4942)
[1] 2500 <- (0,4943)
[1] 2501 <- (0,4944)
[1] 2502 <- (0,4945)
[1] 2503 <- (0,4946)
[1] 2504 <- (0,4947)
[1] 2505 <- (0,4948)
[1] 2506 <- (0,4949)
[1] 2507 <- (0,4977)
[1] 2508 <- (0,4978)
[1] 2509 <- (0,4979)
[1] 2510 <- (0,4980)
[1] 2511 <- (0,4981)
[1] 2512 <- (0,4982)
[1] 2513 <- (0,4983)
[1] 2514 <- (0,4984)
[1] 2515 <- (0,4985)
[1] 2516 <- (0,4986)
[1] 2517 <- (0,4987)
[1] 2518 <- (0,4988)
[1] 2519 <- (0,4989)
[1] 2520 <- (0,4990)
[1] 2521 <- (0,4991)
[1] 2522 <- (0,4992)
[1] 2523 <- (0,4993)
[1] 2524 <- (0,4994)
[1] 2525 <- (0,4995)
[1] 2526 <- (0,4996)
[1] 2527 <- (0,4997)
[1] 2528 <- (0,4998)
[1] 2529 <- (0,4999)
[1] 2530 <- (0,5022)
[1] 2531 <- (0,5023)
[1] 2532 <- (0,5024)
[1] 2533 <- (0,5025)
[1] 2534 <- (0,5026)
[1] 2535 <- (0,5027)
[1] 2536 <- (0,5028)
[1] 2537 <- (0,5029)
[1] 2538 <- (0,5030)
[1] 2539 <- (0,5031)
[1] 2540 <- (0,5032)
[1] 2541 <- (0,5033)
[1] 2542 <- (0,5034)
[1] 2543 <- (0,5035)
[1] 2544 <- (0,5036)
[1] 2545 <- (0,5037)
[1] 2546 <- (0,5038)
[1] 2547 <- (0,5039)
[1] 2548 <- (0,5040)
[1] 2549 <- (0,5041)
[1] 2550 <- (0,5042)
[1] 2551 <- (0,5043)
[1] 2552 <- (0,5044)
[1] 2553 <- (0,5045)
[1] 2554 <- (0,5046)
[1] 2555 <- (0,5047)
[1] 2556 <- (0,5048)
[1] 2557 <- (0,5049)
[1] 2558 <- (0,5072)
[1] 2559 <- (0,5073)
[1] 2560 <- (0,5074)
[1] 2561 <- (0,5075)
[1] 2562 <- (0,5076)
[1] 2563 <- (0,5077)
[1] 2564 <- (0,5078)
[1] 2565 <- (0,5079)
[1] 2566 <- (0,5080)
[1] 2567 <- (0,5081)
[1] 2568 <- (0,5082)
[1] 2569 <- (0,5083)
[1] 2570 <- (0,5084)
[1] 2571 <- (0,5085)
[1] 2572 <- (0,5086)
[1] 2573 <- (0,5087)
[1] 2574 <- (0,5088)
[1] 2575 <- (0,5089)
[1] 2576 <- (0,5090)
[1] 2577 <- (0,5091)
[1] 2578 <- (0,5092)
[1] 2579 <- (0,5093)
[1] 2580 <- (0,5094)
[1] 2581 <- (0,5095)
[1] 2582 <- (0,5096)
[1] 2583 <- (0,5097)
[1] 2584 <- (0,5098)
[1] 2585 <- (0,5099)
[1] 2586 <- (0,5122)
[1] 2587 <- (0,5123)
[1] 2588 <- (0,5124)
[1] 2589 <- (0,5125)
[1] 2590 <- (0,5126)
[1] 2591 <- (0,5127)
[1] 2592 <- (0,5128)
[1] 2593 <- (0,5129)
[1] 2594 <- (0,5130)
[1] 2595 <- (0,5131)
[1] 2596 <- (0,5132)
[1] 2597 <- (0,5133)
[1] 2598 <- (0,5134)
[1] 2599 <- (0,5135)
[1] 2600 <- (0,5136)
[1] 2601 <- (0,5137)
[1] 2602 <- (0,5138)
[1] 2603 <- (0,5139)
[1] 2604 <- (0,5140)
[1] 2605 <- (0,5141)
[1] 2606 <- (0,5142)
[1] 2607 <- (0,5143)
[1] 2608 <- (0,5144)
[1] 2609 <- (0,5145)
[1] 2610 <- (0,5146)
[1] 2611 <- (0,5147)
[1] 2612 <- (0,5148)
[1] 2613 <- (0,5149)
[1] 2614 <- (0,5172)
[1] 2615 <- (0,5173)
[1] 2616 <- (0,5174)
[1] 2617 <- (0,5175)
[1] 2618 <- (0,5176)
[1] 2619 <- (0,5177)
[1] 2620 <- (0,5178)
[1] 2621 <- (0,5179)
[1] 2622 <- (0,5180)
[1] 2623 <- (0,5181)
[1] 2624 <- (0,5182)
[1] 2625 <- (0,5183)
[1] 2626 <- (0,5184)
[1] 2627 <- (0,5185)
[1] 2628 <- (0,5186)
[1] 2629 <- (0,5187)
[1] 2630 <- (0,5188)
[1] 2631 <- (0,5189)
[1] 2632 <- (0,5190)
[1] 2633 <- (0,5191)
[1] 2634 <- (0,5192)
[1] 2635 <- (0,5193)
[1] 2636 <- (0,5194)
[1] 2637 <- (0,5195)
[1] 2638 <- (0,5196)
[1] 2639 <- (0,5197)
[1] 2640 <- (0,5198)
[1] 2641 <- (0,5199)
[1] 2642 <- (0,5223)
[1] 2643 <- (0,5224)
[1] 2644 <- (0,5225)
[1] 2645 <- (0,5226)
[1] 2646 <- (0,5227)
[1] 2647 <- (0,5228)
[1] 2648 <- (0,5229)
[1] 2649 <- (0,5230)
[1] 2650 <- (0,5231)
[1] 2651 <- (0,5232)
[1] 2652 <- (0,5233)
[1] 2653 <- (0,5234)
[1] 2654 <- (0,5235)
[1] 2655 <- (0,5236)
[1] 2656 <- (0,5237)
[1] 2657 <- (0,5238)
[1] 2658 <- (0,5239)
[1] 2659 <- (0,5240)
[1] 2660 <- (0,5241)
[1] 2661 <- (0,5242)
[1] 2662 <- (0,5243)
[1] 2663 <- (0,5244)
[1] 2664 <- (0,5245)
[1] 2665 <- (0,5246)
[1] 2666 <- (0,5247)
[1] 2667 <- (0,5248)
[1] 2668 <- (0,5249)
[1] 2669 <- (0,5273)
[1] 2670 <- (0,5274)
[1] 2671 <- (0,5275)
[1] 2672 <- (0,5276)
[1] 2673 <- (0,5277)
[1] 2674 <- (0,5278)
[1] 2675 <- (0,5279)
[1] 2676 <- (0,5280)
[1] 2677 <- (0,5281)
[1] 2678 <- (0,5282)
[1] 2679 <- (0,5283)
[1] 2680 <- (0,5284)
[1] 2681 <- (0,5285)
[1] 2682 <- (0,5286)
[1] 2683 <- (0,5287)
[1] 2684 <- (0,5288)
[1] 2685 <- (0,5289)
[1] 2686 <- (0,5290)
[1] 2687 <- (0,5291)
[1] 2688 <- (0,5292)
[1] 2689 <- (0,5293)
[1] 2690 <- (0,5294)
[1] 2691 <- (0,5295)
[1] 2692 <- (0,5296)
[1] 2693 <- (0,5297)
[1] 2694 <- (0,5298)
[1] 2695 <- (0,5299)
[1] 2696 <- (0,5323)
[1] 2697 <- (0,5324)
[1] 2698 <- (0,5325)
[1] 2699 <- (0,5326)
[1] 2700 <- (0,5327)
[1] 2701 <- (0,5328)
[1] 2702 <- (0,5329)
[1] 2703 <- (0,5330)
[1] 2704 <- (0,5331)
[1] 2705 <- (0,5332)
[1] 2706 <- (0,5333)
[1] 2707 <- (0,5334)
[1] 2708 <- (0,5335)
[1] 2709 <- (0,5336)
[1] 2710 <- (0,5337)
[1] 2711 <- (0,5338)
[1] 2712 <- (0,5339)
[1] 2713 <- (0,5340)
[1] 2714 <- (0,5341)
[1] 2715 <- (0,5342)
[1] 2716 <- (0,5343)
[1] 2717 <- (0,5344)
[1] 2718 <- (0,5345)
[1] 2719 <- (0,5346)
[1] 2720 <- (0,5347)
[1] 2721 <- (0,5348)
[1] 2722 <- (0,5349)
[1] 2723 <- (0,5373)
[1] 2724 <- (0,5374)
[1] 2725 <- (0,5375)
[1] 2726 <- (0,5376)
[1] 2727 <- (0,5377)
[1] 2728 <- (0,5378)
[1] 2729 <- (0,5379)
[1] 2730 <- (0,5380)
[1] 2731 <- (0,5381)
[1] 2732 <- (0,5382)
[1] 2733 <- (0,5383)
[1] 2734 <- (0,5384)
[1] 2735 <- (0,5385)
[1] 2736 <- (0,5386)
[1] 2737 <- (0,5387)
[1] 2738 <- (0,5388)
[1] 2739 <- (0,5389)
[1] 2740 <- (0,5390)
[1] 2741 <- (0,5391)
[1] 2742 <- (0,5392)
[1] 2743 <- (0,5393)
[1] 2744 <- (0,5394)
[1] 2745 <- (0,5395)
[1] 2746 <- (0,5396)
[1] 2747 <- (0,5397)
[1] 2748 <- (0,5398)
[1] 2749 <- (0,5399)
[1] 2750 <- (0,5424)
[1] 2751 <- (0,5425)
[1] 2752 <- (0,5426)
[1] 2753 <- (0,5427)
[1] 2754 <- (0,5428)
[1] 2755 <- (0,5429)
[1] 2756 <- (0,5430)
[1] 2757 <- (0,5431)
[1] 2758 <- (0,5432)
[1] 2759 <- (0,5433)
[1] 2760 <- (0,5434)
[1] 2761 <- (0,5435)
[1] 2762 <- (0,5436)
[1] 2763 <- (0,5437)
[1] 2764 <- (0,5438)
[1] 2765 <- (0,5439)
[1] 2766 <- (0,5440)
[1] 2767 <- (0,5441)
[1] 2768 <- (0,5442)
[1] 2769 <- (0,5443)
[1] 2770 <- (0,5444)
[1] 2771 <- (0,5445)
[1] 2772 <- (0,5446)
[1] 2773 <- (0,5447)
[1] 2774 <- (0,5448)
[1] 2775 <- (0,5449)
[1] 2776 <- (0,5474)
[1] 2777 <- (0,5475)
[1] 2778 <- (0,5476)
[1] 2779 <- (0,5477)
[1] 2780 <- (0,5478)
[1] 2781 <- (0,5479)
[1] 2782 <- (0,5480)
[1] 2783 <- (0,5481)
[1] 2784 <- (0,5482)
[1] 2785 <- (0,5483)
[1] 2786 <- (0,5484)
[1] 2787 <- (0,5485)
[1] 2788 <- (0,5486)
[1] 2789 <- (0,5487)
[1] 2790 <- (0,5488)
[1] 2791 <- (0,5489)
[1] 2792 <- (0,5490)
[1] 2793 <- (0,5491)
[1] 2794 <- (0,5492)
[1] 2795 <- (0,5493)
[1] 2796 <- (0,5494)
[1] 2797 <- (0,5495)
[1] 2798 <- (0,5496)
[1] 2799 <- (0,5497)
[1] 2800 <- (0,5498)
[1] 2801 <- (0,5499)
[1] 2802 <- (0,5525)
[1] 2803 <- (0,5526)
[1] 2804 <- (0,5527)
[1] 2805 <- (0,5528)
[1] 2806 <- (0,5529)
[1] 2807 <- (0,5530)
[1] 2808 <- (0,5531)
[1] 2809 <- (0,5532)
[1] 2810 <- (0,5533)
[1] 2811 <- (0,5534)
[1] 2812 <- (0,5535)
[1] 2813 <- (0,5536)
[1] 2814 <- (0,5537)
[1] 2815 <- (0,5538)
[1] 2816 <- (0,5539)
[1] 2817 <- (0,5540)
[1] 2818 <- (0,5541)
[1] 2819 <- (0,5542)
[1] 2820 <- (0,5543)
[1] 2821 <- (0,5544)
[1] 2822 <- (0,5545)
[1] 2823 <- (0,5546)
[1] 2824 <- (0,5547)
[1] 2825 <- (0,5548)
[1] 2826 <- (0,5549)
[1] 2827 <- (0,5576)
[1] 2828 <- (0,5577)
[1] 2829 <- (0,5578)
[1] 2830 <- (0,5579)
[1] 2831 <- (0,5580)
[1] 2832 <- (0,5581)
[1] 2833 <- (0,5582)
[1] 2834 <- (0,5583)
[1] 2835 <- (0,5584)
[1] 2836 <- (0,5585)
[1] 2837 <- (0,5586)
[1] 2838 <- (0,5587)
[1] 2839 <- (0,5588)
[1] 2840 <- (0,5589)
[1] 2841 <- (0,5590)
[1] 2842 <- (0,5591)
[1] 2843 <- (0,5592)
[1] 2844 <- (0,5593)
[1] 2845 <- (0,5594)
[1] 2846 <- (0,5595)
[1] 2847 <- (0,5596)
[1] 2848 <- (0,5597)
[1] 2849 <- (0,5598)
[1] 2850 <- (0,5599)
[1] 2851 <- (0,5626)
[1] 2852 <- (0,5627)
[1] 2853 <- (0,5628)
[1] 2854 <- (0,5629)
[1] 2855 <- (0,5630)
[1] 2856 <- (0,5631)
[1] 2857 <- (0,5632)
[1] 2858 <- (0,5633)
[1] 2859 <- (0,5634)
[1] 2860 <- (0,5635)
[1] 2861 <- (0,5636)
[1] 2862 <- (0,5637)
[1] 2863 <- (0,5638)
[1] 2864 <- (0,5639)
[1] 2865 <- (0,5640)
[1] 2866 <- (0,5641)
[1] 2867 <- (0,5642)
[1] 2868 <- (0,5643)
[1] 2869 <- (0,5644)
[1] 2870 <- (0,5645)
[1] 2871 <- (0,5646)
[1] 2872 <- (0,5647)
[1] 2873 <- (0,5648)
[1] 2874 <- (0,5649)
[1] 2875 <- (0,5677)
[1] 2876 <- (0,5678)
[1] 2877 <- (0,5679)
[1] 2878 <- (0,5680)
[1] 2879 <- (0,5681)
[1] 2880 <- (0,5682)
[1] 2881 <- (0,5683)
[1] 2882 <- (0,5684)
[1] 2883 <- (0,5685)
[1] 2884 <- (0,5686)
[1] 2885 <- (0,5687)
[1] 2886 <- (0,5688)
[1] 2887 <- (0,5689)
[1] 2888 <- (0,5690)
[1] 2889 <- (0,5691)
[1] 2890 <- (0,5692)
[1] 2891 <- (0,5693)
[1] 2892 <- (0,5694)
[1] 2893 <- (0,5695)
[1] 2894 <- (0,5696)
[1] 2895 <- (0,5697)
[1] 2896 <- (0,5698)
[1] 2897 <- (0,5699)
[1] 2898 <- (0,5727)
[1] 2899 <- (0,5728)
[1] 2900 <- (0,5729)
[1] 2901 <- (0,5730)
[1] 2902 <- (0,5731)
[1] 2903 <- (0,5732)
[1] 2904 <- (0,5733)
[1] 2905 <- (0,5734)
[1] 2906 <- (0,5735)
[1] 2907 <- (0,5736)
[1] 2908 <- (0,5737)
[1] 2909 <- (0,5738)
[1] 2910 <- (0,5739)
[1] 2911 <- (0,5740)
[1] 2912 <- (0,5741)
[1] 2913 <- (0,5742)
[1] 2914 <- (0,5743)
[1] 2915 <- (0,5744)
[1] 2916 <- (0,5745)
[1] 2917 <- (0,5746)
[1] 2918 <- (0,5747)
[1] 2919 <- (0,5748)
[1] 2920 <- (0,5749)
[1] 2921 <- (0,5777)
[1] 2922 <- (0,5778)
[1] 2923 <- (0,5779)
[1] 2924 <- (0,5780)
[1] 2925 <- (0,5781)
[1] 2926 <- (0,5782)
[1] 2927 <- (0,5783)
[1] 2928 <- (0,5784)
[1] 2929 <- (0,5785)
[1] 2930 <- (0,5786)
[1] 2931 <- (0,5787)
[1] 2932 <- (0,5788)
[1] 2933 <- (0,5789)
[1] 2934 <- (0,5790)
[1] 2935 <- (0,5791)
[1] 2936 <- (0,5792)
[1] 2937 <- (0,5793)
[1] 2938 <- (0,5794)
[1] 2939 <- (0,5795)
[1] 2940 <- (0,5796)
[1] 2941 <- (0,5797)
[1] 2942 <- (0,5798)
[1] 2943 <- (0,5799)
[1] 2944 <- (0,5827)
[1] 2945 <- (0,5828)
[1] 2946 <- (0,5829)
[1] 2947 <- (0,5830)
[1] 2948 <- (0,5831)
[1] 2949 <- (0,5832)
[1] 2950 <- (0,5833)
[1] 2951 <- (0,5834)
[1] 2952 <- (0,5835)
[1] 2953 <- (0,5836)
[1] 2954 <- (0,5837)
[1] 2955 <- (0,5838)
[1] 2956 <- (0,5839)
[1] 2957 <- (0,5840)
[1] 2958 <- (0,5841)
[1] 2959 <- (0,5842)
[1] 2960 <- (0,5843)
[1] 2961 <- (0,5844)
[1] 2962 <- (0,5845)
[1] 2963 <- (0,5846)
[1] 2964 <- (0,5847)
[1] 2965 <- (0,5848)
[1] 2966 <- (0,5849)
[1] 2967 <- (0,5877)
[1] 2968 <- (0,5878)
[1] 2969 <- (0,5879)
[1] 2970 <- (0,5880)
[1] 2971 <- (0,5881)
[1] 2972 <- (0,5882)
[1] 2973 <- (0,5883)
[1] 2974 <- (0,5884)
[1] 2975 <- (0,5885)
[1] 2976 <- (0,5886)
[1] 2977 <- (0,5887)
[1] 2978 <- (0,5888)
[1] 2979 <- (0,5889)
[1] 2980 <- (0,5890)
[1] 2981 <- (0,5891)
[1] 2982 <- (0,5892)
[1] 2983 <- (0,5893)
[1] 2984 <- (0,5894)
[1] 2985 <- (0,5895)
[1] 2986 <- (0,5896)
[1] 2987 <- (0,5897)
[1] 2988 <- (0,5898)
[1] 2989 <- (0,5899)
[1] 2990 <- (0,5927)
[1] 2991 <- (0,5928)
[1] 2992 <- (0,5929)
[1] 2993 <- (0,5930)
[1] 2994 <- (0,5931)
[1] 2995 <- (0,5932)
[1] 2996 <- (0,5933)
[1] 2997 <- (0,5934)
[1] 2998 <- (0,5935)
[1] 2999 <- (0,5936)
[1] 3000 <- (0,5937)
[1] 3001 <- (0,5938)
[1] 3002 <- (0,5939)
[1] 3003 <- (0,5940)
[1] 3004 <- (0,5941)
[1] 3005 <- (0,5942)
[1] 3006 <- (0,5943)
[1] 3007 <- (0,5944)
[1] 3008 <- (0,5945)
[1] 3009 <- (0,5946)
[1] 3010 <- (0,5947)
[1] 3011 <- (0,5948)
[1] 3012 <- (0,5949)
[1] 3013 <- (0,5977)
[1] 3014 <- (0,5978)
[1] 3015 <- (0,5979)
[1] 3016 <- (0,5980)
[1] 3017 <- (0,5981)
[1] 3018 <- (0,5982)
[1] 3019 <- (0,5983)
[1] 3020 <- (0,5984)
[1] 3021 <- (0,5985)
[1] 3022 <- (0,5986)
[1] 3023 <- (0,5987)
[1] 3024 <- (0,5988)
[1] 3025 <- (0,5989)
[1] 3026 <- (0,5990)
[1] 3027 <- (0,5991)
[1] 3028 <- (0,5992)
[1] 3029 <- (0,5993)
[1] 3030 <- (0,5994)
[1] 3031 <- (0,5995)
[1] 3032 <- (0,5996)
[1] 3033 <- (0,5997)
[1] 3034 <- (0,5998)
[1] 3035 <- (0,5999)
[1] 3036 <- (0,6022)
[1] 3037 <- (0,6023)
[1] 3038 <- (0,6024)
[1] 3039 <- (0,6025)
[1] 3040 <- (0,6026)
[1] 3041 <- (0,6027)
[1] 3042 <- (0,6028)
[1] 3043 <- (0,6029)
[1] 3044 <- (0,6030)
[1] 3045 <- (0,6031)
[1] 3046 <- (0,6032)
[1] 3047 <- (0,6033)
[1] 3048 <- (0,6034)
[1] 3049 <- (0,6035)
[1] 3050 <- (0,6036)
[1] 3051 <- (0,6037)
[1] 3052 <- (0,6038)
[1] 3053 <- (0,6039)
[1] 3054 <- (0,6040)
[1] 3055 <- (0,6041)
[1] 3056 <- (0,6042)
[1] 3057 <- (0,6043)
[1] 3058 <- (0,6044)
[1] 3059 <- (0,6045)
[1] 3060 <- (0,6046)
[1] 3061 <- (0,6047)
[1] 3062 <- (0,6048)
[1] 3063 <- (0,6049)
[1] 3064 <- (0,6072)
[1] 3065 <- (0,6073)
[1] 3066 <- (0,6074)
[1] 3067 <- (0,6075)
[1] 3068 <- (0,6076)
[1] 3069 <- (0,6077)
[1] 3070 <- (0,6078)
[1] 3071 <- (0,6079)
[1] 3072 <- (0,6080)
[1] 3073 <- (0,6081)
[1] 3074 <- (0,6082)
[1] 3075 <- (0,6083)
[1] 3076 <- (0,6084)
[1] 3077 <- (0,6085)
[1] 3078 <- (0,6086)
[1] 3079 <- (0,6087)
[1] 3080 <- (0,6088)
[1] 3081 <- (0,6089)
[1] 3082 <- (0,6090)
[1] 3083 <- (0,6091)
[1] 3084 <- (0,6092)
[1] 3085 <- (0,6093)
[1] 3086 <- (0,6094)
[1] 3087 <- (0,6095)
[1] 3088 <- (0,6096)
[1] 3089 <- (0,6097)
[1] 3090 <- (0,6098)
[1] 3091 <- (0,6099)
[1] 3092 <- (0,6122)
[1] 3093 <- (0,6123)
[1] 3094 <- (0,6124)
[1] 3095 <- (0,6125)
[1] 3096 <- (0,6126)
[1] 3097 <- (0,6127)
[1] 3098 <- (0,6128)
[1] 3099 <- (0,6129)
[1] 3100 <- (0,6130)
[1] 3101 <- (0,6131)
[1] 3102 <- (0,6132)
[1] 3103 <- (0,6133)
[1] 3104 <- (0,6134)
[1] 3105 <- (0,6135)
[1] 3106 <- (0,6136)
[1] 3107 <- (0,6137)
[1] 3108 <- (0,6138)
[1] 3109 <- (0,6139)
[1] 3110 <- (0,6140)
[1] 3111 <- (0,6141)
[1] 3112 <- (0,6142)
[1] 3113 <- (0,6143)
[1] 3114 <- (0,6144)
[1] 3115 <- (0,6145)
[1] 3116 <- (0,6146)
[1] 3117 <- (0,6147)
[1] 3118 <- (0,6148)
[1] 3119 <- (0,6149)
[1] 3120 <- (0,6172)
[1] 3121 <- (0,6173)
[1] 3122 <- (0,6174)
[1] 3123 <- (0,6175)
[1] 3124 <- (0,6176)
[1] 3125 <- (0,6177)
[1] 3126 <- (0,6178)
[1] 3127 <- (0,6179)
[1] 3128 <- (0,6180)
[1] 3129 <- (0,6181)
[1] 3130 <- (0,6182)
[1] 3131 <- (0,6183)
[1] 3132 <- (0,6184)
[1] 3133 <- (0,6185)
[1] 3134 <- (0,6186)
[1] 3135 <- (0,6187)
[1] 3136 <- (0,6188)
[1] 3137 <- (0,6189)
[1] 3138 <- (0,6190)
[1] 3139 <- (0,6191)
[1] 3140 <- (0,6192)
[1] 3141 <- (0,6193)
[1] 3142 <- (0,6194)
[1] 3143 <- (0,6195)
[1] 3144 <- (0,6196)
[1] 3145 <- (0,6197)
[1] 3146 <- (0,6198)
[1] 3147 <- (0,6199)
[1] 3148 <- (0,6223)
[1] 3149 <- (0,6224)
[1] 3150 <- (0,6225)
[1] 3151 <- (0,6226)
[1] 3152 <- (0,6227)
[1] 3153 <- (0,6228)
[1] 3154 <- (0,6229)
[1] 3155 <- (0,6230)
[1] 3156 <- (0,6231)
[1] 3157 <- (0,6232)
[1] 3158 <- (0,6233)
[1] 3159 <- (0,6234)
[1] 3160 <- (0,6235)
[1] 3161 <- (0,6236)
[1] 3162 <- (0,6237)
[1] 3163 <- (0,6238)
[1] 3164 <- (0,6239)
[1] 3165 <- (0,6240)
[1] 3166 <- (0,6241)
[1] 3167 <- (0,6242)
[1] 3168 <- (0,6243)
[1] 3169 <- (0,6244)
[1] 3170 <- (0,6245)
[1] 3171 <- (0,6246)
[1] 3172 <- (0,6247)
[1] 3173 <- (0,6248)
[1] 3174 <- (0,6249)
[1] 3175 <- (0,6273)
[1] 3176 <- (0,6274)
[1] 3177 <- (0,6275)
[1] 3178 <- (0,6276)
[1] 3179 <- (0,6277)
[1] 3180 <- (0,6278)
[1] 3181 <- (0,6279)
[1] 3182 <- (0,6280)
[1] 3183 <- (0,6281)
[1] 3184 <- (0,6282)
[1] 3185 <- (0,6283)
[1] 3186 <- (0,6284)
[1] 3187 <- (0,6285)
[1] 3188 <- (0,6286)
[1] 3189 <- (0,6287)
[1] 3190 <- (0,6288)
[1] 3191 <- (0,6289)
[1] 3192 <- (0,6290)
[1] 3193 <- (0,6291)
[1] 3194 <- (0,6292)
[1] 3195 <- (0,6293)
[1] 3196 <- (0,6294)
[1] 3197 <- (0,6295)
[1] 3198 <- (0,6296)
[1] 3199 <- (0,6297)
[1] 3200 <- (0,6298)
[1] 3201 <- (0,6299)
[1] 3202 <- (0,6323)
[1] 3203 <- (0,6324)
[1] 3204 <- (0,6325)
[1] 3205 <- (0,6326)
[1] 3206 <- (0,6327)
[1] 3207 <- (0,6328)
[1] 3208 <- (0,6329)
[1] 3209 <- (0,6330)
[1] 3210 <- (0,6331)
[1] 3211 <- (0,6332)
[1] 3212 <- (0,6333)
[1] 3213 <- (0,6334)
[1] 3214 <- (0,6335)
[1] 3215 <- (0,6336)
[1] 3216 <- (0,6337)
[1] 3217 <- (0,6338)
[1] 3218 <- (0,6339)
[1] 3219 <- (0,6340)
[1] 3220 <- (0,6341)
[1] 3221 <- (0,6342)
[1] 3222 <- (0,6343)
[1] 3223 <- (0,6344)
[1] 3224 <- (0,6345)
[1] 3225 <- (0,6346)
[1] 3226 <- (0,6347)
[1] 3227 <- (0,6348)
[1] 3228 <- (0,6349)
[1] 3229 <- (0,6373)
[1] 3230 <- (0,6374)
[1] 3231 <- (0,6375)
[1] 3232 <- (0,6376)
[1] 3233 <- (0,6377)
[1] 3234 <- (0,6378)
[1] 3235 <- (0,6379)
[1] 3236 <- (0,6380)
[1] 3237 <- (0,6381)
[1] 3238 <- (0,6382)
[1] 3239 <- (0,6383)
[1] 3240 <- (0,6384)
[1] 3241 <- (0,6385)
[1] 3242 <- (0,6386)
[1] 3243 <- (0,6387)
[1] 3244 <- (0,6388)
[1] 3245 <- (0,6389)
[1] 3246 <- (0,6390)
[1] 3247 <- (0,6391)
[1] 3248 <- (0,6392)
[1] 3249 <- (0,6393)
[1] 3250 <- (0,6394)
[1] 3251 <- (0,6395)
[1] 3252 <- (0,6396)
[1] 3253 <- (0,6397)
[1] 3254 <- (0,6398)
[1] 3255 <- (0,6399)
[1] 3256 <- (0,6424)
[1] 3257 <- (0,6425)
[1] 3258 <- (0,6426)
[1] 3259 <- (0,6427)
[1] 3260 <- (0,6428)
[1] 3261 <- (0,6429)
[1] 3262 <- (0,6430)
[1] 3263 <- (0,6431)
[1] 3264 <- (0,6432)
[1] 3265 <- (0,6433)
[1] 3266 <- (0,6434)
[1] 3267 <- (0,6435)
[1] 3268 <- (0,6436)
[1] 3269 <- (0,6437)
[1] 3270 <- (0,6438)
[1] 3271 <- (0,6439)
[1] 3272 <- (0,6440)
[1] 3273 <- (0,6441)
[1] 3274 <- (0,6442)
[1] 3275 <- (0,6443)
[1] 3276 <- (0,6444)
[1] 3277 <- (0,6445)
[1] 3278 <- (0,6446)
[1] 3279 <- (0,6447)
[1] 3280 <- (0,6448)
[1] 3281 <- (0,6449)
[1] 3282 <- (0,6475)
[1] 3283 <- (0,6476)
[1] 3284 <- (0,6477)
[1] 3285 <- (0,6478)
[1] 3286 <- (0,6479)
[1] 3287 <- (0,6480)
[1] 3288 <- (0,6481)
[1] 3289 <- (0,6482)
[1] 3290 <- (0,6483)
[1] 3291 <- (0,6484)
[1] 3292 <- (0,6485)
[1] 3293 <- (0,6486)
[1] 3294 <- (0,6487)
[1] 3295 <- (0,6488)
[1] 3296 <- (0,6489)
[1] 3297 <- (0,6490)
[1] 3298 <- (0,6491)
[1] 3299 <- (0,6492)
[1] 3300 <- (0,6493)
[1] 3301 <- (0,6494)
[1] 3302 <- (0,6495)
[1] 3303 <- (0,6496)
[1] 3304 <- (0,6497)
[1] 3305 <- (0,6498)
[1] 3306 <- (0,6499)
[1] 3307 <- (0,6525)
[1] 3308 <- (0,6526)
[1] 3309 <- (0,6527)
[1] 3310 <- (0,6528)
[1] 3311 <- (0,6529)
[1] 3312 <- (0,6530)
[1] 3313 <- (0,6531)
[1] 3314 <- (0,6532)
[1] 3315 <- (0,6533)
[1] 3316 <- (0,6534)
[1] 3317 <- (0,6535)
[1] 3318 <- (0,6536)
[1] 3319 <- (0,6537)
[1] 3320 <- (0,6538)
[1] 3321 <- (0,6539)
[1] 3322 <- (0,6540)
[1] 3323 <- (0,6541)
[1] 3324 <- (0,6542)
[1] 3325 <- (0,6543)
[1] 3326 <- (0,6544)
[1] 3327 <- (0,6545)
[1] 3328 <- (0,6546)
[1] 3329 <- (0,6547)
[1] 3330 <- (0,6548)
[1] 3331 <- (0,6549)
[1] 3332 <- (0,6576)
[1] 3333 <- (0,6577)
[1] 3334 <- (0,6578)
[1] 3335 <- (0,6579)
[1] 3336 <- (0,6580)
[1] 3337 <- (0,6581)
[1] 3338 <- (0,6582)
[1] 3339 <- (0,6583)
[1] 3340 <- (0,6584)
[1] 3341 <- (0,6585)
[1] 3342 <- (0,6586)
[1] 3343 <- (0,6587)
[1] 3344 <- (0,6588)
[1] 3345 <- (0,6589)
[1] 3346 <- (0,6590)
[1] 3347 <- (0,6591)
[1] 3348 <- (0,6592)
[1] 3349 <- (0,6593)
[1] 3350 <- (0,6594)
[1] 3351 <- (0,6595)
[1] 3352 <- (0,6596)
[1] 3353 <- (0,6597)
[1] 3354 <- (0,6598)
[1] 3355 <- (0,6599)
[1] 3356 <- (0,6626)
[1] 3357 <- (0,6627)
[1] 3358 <- (0,6628)
[1] 3359 <- (0,6629)
[1] 3360 <- (0,6630)
[1] 3361 <- (0,6631)
[1] 3362 <- (0,6632)
[1] 3363 <- (0,6633)
[1] 3364 <- (0,6634)
[1] 3365 <- (0,6635)
[1] 3366 <- (0,6636)
[1] 3367 <- (0,6637)
[1] 3368 <- (0,6638)
[1] 3369 <- (0,6639)
[1] 3370 <- (0,6640)
[1] 3371 <- (0,6641)
[1] 3372 <- (0,6642)
[1] 3373 <- (0,6643)
[1] 3374 <- (0,6644)
[1] 3375 <- (0,6645)
[1] 3376 <- (0,6646)
[1] 3377 <- (0,6647)
[1] 3378 <- (0,6648)
[1] 3379 <- (0,6649)
[1] 3380 <- (0,6677)
[1] 3381 <- (0,6678)
[1] 3382 <- (0,6679)
[1] 3383 <- (0,6680)
[1] 3384 <- (0,6681)
[1] 3385 <- (0,6682)
[1] 3386 <- (0,6683)
[1] 3387 <- (0,6684)
[1] 3388 <- (0,6685)
[1] 3389 <- (0,6686)
[1] 3390 <- (0,6687)
[1] 3391 <- (0,6688)
[1] 3392 <- (0,6689)
[1] 3393 <- (0,6690)
[1] 3394 <- (0,6691)
[1] 3395 <- (0,6692)
[1] 3396 <- (0,6693)
[1] 3397 <- (0,6694)
[1] 3398 <- (0,6695)
[1] 3399 <- (0,6696)
[1] 3400 <- (0,6697)
[1] 3401 <- (0,6698)
[1] 3402 <- (0,6699)
[1] 3403 <- (0,6727)
[1] 3404 <- (0,6728)
[1] 3405 <- (0,6729)
[1] 3406 <- (0,6730)
[1] 3407 <- (0,6731)
[1] 3408 <- (0,6732)
[1] 3409 <- (0,6733)
[1] 3410 <- (0,6734)
[1] 3411 <- (0,6735)
[1] 3412 <- (0,6736)
[1] 3413 <- (0,6737)
[1] 3414 <- (0,6738)
[1] 3415 <- (0,6739)
[1] 3416 <- (0,6740)
[1] 3417 <- (0,6741)
[1] 3418 <- (0,6742)
[1] 3419 <- (0,6743)
[1] 3420 <- (0,6744)
[1] 3421 <- (0,6745)
[1] 3422 <- (0,6746)
[1] 3423 <- (0,6747)
[1] 3424 <- (0,6748)
[1] 3425 <- (0,6749)
[1] 3426 <- (0,6777)
[1] 3427 <- (0,6778)
[1] 3428 <- (0,6779)
[1] 3429 <- (0,6780)
[1] 3430 <- (0,6781)
[1] 3431 <- (0,6782)
[1] 3432 <- (0,6783)
[1] 3433 <- (0,6784)
[1] 3434 <- (0,6785)
[1] 3435 <- (0,6786)
[1] 3436 <- (0,6787)
[1] 3437 <- (0,6788)
[1] 3438 <- (0,6789)
[1] 3439 <- (0,6790)
[1] 3440 <- (0,6791)
[1] 3441 <- (0,6792)
[1] 3442 <- (0,6793)
[1] 3443 <- (0,6794)
[1] 3444 <- (0,6795)
[1] 3445 <- (0,6796)
[1] 3446 <- (0,6797)
[1] 3447 <- (0,6798)
[1] 3448 <- (0,6799)
[1] 3449 <- (0,6827)
[1] 3450 <- (0,6828)
[1] 3451 <- (0,6829)
[1] 3452 <- (0,6830)
[1] 3453 <- (0,6831)
[1] 3454 <- (0,6832)
[1] 3455 <- (0,6833)
[1] 3456 <- (0,6834)
[1] 3457 <- (0,6835)
[1] 3458 <- (0,6836)
[1] 3459 <- (0,6837)
[1] 3460 <- (0,6838)
[1] 3461 <- (0,6839)
[1] 3462 <- (0,6840)
[1] 3463 <- (0,6841)
[1] 3464 <- (0,6842)
[1] 3465 <- (0,6843)
[1] 3466 <- (0,6844)
[1] 3467 <- (0,6845)
[1] 3468 <- (0,6846)
[1] 3469 <- (0,6847)
[1] 3470 <- (0,6848)
[1] 3471 <- (0,6849)
[1] 3472 <- (0,6877)
[1] 3473 <- (0,6878)
[1] 3474 <- (0,6879)
[1] 3475 <- (0,6880)
[1] 3476 <- (0,6881)
[1] 3477 <- (0,6882)
[1] 3478 <- (0,6883)
[1] 3479 <- (0,6884)
[1] 3480 <- (0,6885)
[1] 3481 <- (0,6886)
[1] 3482 <- (0,6887)
[1] 3483 <- (0,6888)
[1] 3484 <- (0,6889)
[1] 3485 <- (0,6890)
[1] 3486 <- (0,6891)
[1] 3487 <- (0,6892)
[1] 3488 <- (0,6893)
[1] 3489 <- (0,6894)
[1] 3490 <- (0,6895)
[1] 3491 <- (0,6896)
[1] 3492 <- (0,6897)
[1] 3493 <- (0,6898)
[1] 3494 <- (0,6899)
[1] 3495 <- (0,6927)
[1] 3496 <- (0,6928)
[1] 3497 <- (0,6929)
[1] 3498 <- (0,6930)
[1] 3499 <- (0,6931)
[1] 3500 <- (0,6932)
[1] 3501 <- (0,6933)
[1] 3502 <- (0,6934)
[1] 3503 <- (0,6935)
[1] 3504 <- (0,6936)
[1] 3505 <- (0,6937)
[1] 3506 <- (0,6938)
[1] 3507 <- (0,6939)
[1] 3508 <- (0,6940)
[1] 3509 <- (0,6941)
[1] 3510 <- (0,6942)
[1] 3511 <- (0,6943)
[1] 3512 <- (0,6944)
[1] 3513 <- (0,6945)
[1] 3514 <- (0,6946)
[1] 3515 <- (0,6947)
[1] 3516 <- (0,6948)
[1] 3517 <- (0,6949)
[1] 3518 <- (0,6977)
[1] 3519 <- (0,6978)
[1] 3520 <- (0,6979)
[1] 3521 <- (0,6980)
[1] 3522 <- (0,6981)
[1] 3523 <- (0,6982)
[1] 3524 <- (0,6983)
[1] 3525 <- (0,6984)
[1] 3526 <- (0,6985)
[1] 3527 <- (0,6986)
[1] 3528 <- (0,6987)
[1] 3529 <- (0,6988)
[1] 3530 <- (0,6989)
[1] 3531 <- (0,6990)
[1] 3532 <- (0,6991)
[1] 3533 <- (0,6992)
[1] 3534 <- (0,6993)
[1] 3535 <- (0,6994)
[1] 3536 <- (0,6995)
[1] 3537 <- (0,6996)
[1] 3538 <- (0,6997)
[1] 3539 <- (0,6998)
[1] 3540 <- (0,6999)
[1] 3541 <- (0,7022)
[1] 3542 <- (0,7023)
[1] 3543 <- (0,7024)
[1] 3544 <- (0,7025)
[1] 3545 <- (0,7026)
[1] 3546 <- (0,7027)
[1] 3547 <- (0,7028)
[1] 3548 <- (0,7029)
[1] 3549 <- (0,7030)
[1] 3550 <- (0,7031)
[1] 3551 <- (0,7032)
[1] 3552 <- (0,7033)
[1] 3553 <- (0,7034)
[1] 3554 <- (0,7035)
[1] 3555 <- (0,7036)
[1] 3556 <- (0,7037)
[1] 3557 <- (0,7038)
[1] 3558 <- (0,7039)
[1] 3559 <- (0,7040)
[1] 3560 <- (0,7041)
[1] 3561 <- (0,7042)
[1] 3562 <- (0,7043)
[1] 3563 <- (0,7044)
[1] 3564 <- (0,7045)
[1] 3565 <- (0,7046)
[1] 3566 <- (0,7047)
[1] 3567 <- (0,7048)
[1] 3568 <- (0,7049)
[1] 3569 <- (0,7072)
[1] 3570 <- (0,7073)
[1] 3571 <- (0,7074)
[1] 3572 <- (0,7075)
[1] 3573 <- (0,7076)
[1] 3574 <- (0,7077)
[1] 3575 <- (0,7078)
[1] 3576 <- (0,7079)
[1] 3577 <- (0,7080)
[1] 3578 <- (0,7081)
[1] 3579 <- (0,7082)
[1] 3580 <- (0,7083)
[1] 3581 <- (0,7084)
[1] 3582 <- (0,7085)
[1] 3583 <- (0,7086)
[1] 3584 <- (0,7087)
[1] 3585 <- (0,7088)
[1] 3586 <- (0,7089)
[1] 3587 <- (0,7090)
[1] 3588 <- (0,7091)
[1] 3589 <- (0,7092)
[1] 3590 <- (0,7093)
[1] 3591 <- (0,7094)
[1] 3592 <- (0,7095)
[1] 3593 <- (0,7096)
[1] 3594 <- (0,7097)
[1] 3595 <- (0,7098)
[1] 3596 <- (0,7099)
[1] 3597 <- (0,7122)
[1] 3598 <- (0,7123)
[1] 3599 <- (0,7124)
[1] 3600 <- (0,7125)
[1] 3601 <- (0,7126)
[1] 3602 <- (0,7127)
[1] 3603 <- (0,7128)
[1] 3604 <- (0,7129)
[1] 3605 <- (0,7130)
[1] 3606 <- (0,7131)
[1] 3607 <- (0,7132)
[1] 3608 <- (0,7133)
[1] 3609 <- (0,7134)
[1] 3610 <- (0,7135)
[1] 3611 <- (0,7136)
[1] 3612 <- (0,7137)
[1] 3613 <- (0,7138)
[1] 3614 <- (0,7139)
[1] 3615 <- (0,7140)
[1] 3616 <- (0,7141)
[1] 3617 <- (0,7142)
[1] 3618 <- (0,7143)
[1] 3619 <- (0,7144)
[1] 3620 <- (0,7145)
[1] 3621 <- (0,7146)
[1] 3622 <- (0,7147)
[1] 3623 <- (0,7148)
[1] 3624 <- (0,7149)
[1] 3625 <- (0,7172)
[1] 3626 <- (0,7173)
[1] 3627 <- (0,7174)
[1] 3628 <- (0,7175)
[1] 3629 <- (0,7176)
[1] 3630 <- (0,7177)
[1] 3631 <- (0,7178)
[1] 3632 <- (0,7179)
[1] 3633 <- (0,7180)
[1] 3634 <- (0,7181)
[1] 3635 <- (0,7182)
[1] 3636 <- (0,7183)
[1] 3637 <- (0,7184)
[1] 3638 <- (0,7185)
[1] 3639 <- (0,7186)
[1] 3640 <- (0,7187)
[1] 3641 <- (0,7188)
[1] 3642 <- (0,7189)
[1] 3643 <- (0,7190)
[1] 3644 <- (0,7191)
[1] 3645 <- (0,7192)
[1] 3646 <- (0,7193)
[1] 3647 <- (0,7194)
[1] 3648 <- (0,7195)
[1] 3649 <- (0,7196)
[1] 3650 <- (0,7197)
[1] 3651 <- (0,7198)
[1] 3652 <- (0,7199)
[1] 3653 <- (0,7223)
[1] 3654 <- (0,7224)
[1] 3655 <- (0,7225)
[1] 3656 <- (0,7226)
[1] 3657 <- (0,7227)
[1] 3658 <- (0,7228)
[1] 3659 <- (0,7229)
[1] 3660 <- (0,7230)
[1] 3661 <- (0,7231)
[1] 3662 <- (0,7232)
[1] 3663 <- (0,7233)
[1] 3664 <- (0,7234)
[1] 3665 <- (0,7235)
[1] 3666 <- (0,7236)
[1] 3667 <- (0,7237)
[1] 3668 <- (0,7238)
[1] 3669 <- (0,7239)
[1] 3670 <- (0,7240)
[1] 3671 <- (0,7241)
[1] 3672 <- (0,7242)
[1] 3673 <- (0,7243)
[1] 3674 <- (0,7244)
[1] 3675 <- (0,7245)
[1] 3676 <- (0,7246)
[1] 3677 <- (0,7247)
[1] 3678 <- (0,7248)
[1] 3679 <- (0,7249)
[1] 3680 <- (0,7273)
[1] 3681 <- (0,7274)
[1] 3682 <- (0,7275)
[1] 3683 <- (0,7276)
[1] 3684 <- (0,7277)
[1] 3685 <- (0,7278)
[1] 3686 <- (0,7279)
[1] 3687 <- (0,7280)
[1] 3688 <- (0,7281)
[1] 3689 <- (0,7282)
[1] 3690 <- (0,7283)
[1] 3691 <- (0,7284)
[1] 3692 <- (0,7285)
[1] 3693 <- (0,7286)
[1] 3694 <- (0,7287)
[1] 3695 <- (0,7288)
[1] 3696 <- (0,7289)
[1] 3697 <- (0,7290)
[1] 3698 <- (0,7291)
[1] 3699 <- (0,7292)
[1] 3700 <- (0,7293)
[1] 3701 <- (0,7294)
[1] 3702 <- (0,7295)
[1] 3703 <- (0,7296)
[1] 3704 <- (0,7297)
[1] 3705 <- (0,7298)
[1] 3706 <- (0,7299)
[1] 3707 <- (0,7323)
[1] 3708 <- (0,7324)
[1] 3709 <- (0,7325)
[1] 3710 <- (0,7326)
[1] 3711 <- (0,7327)
[1] 3712 <- (0,7328)
[1] 3713 <- (0,7329)
[1] 3714 <- (0,7330)
[1] 3715 <- (0,7331)
[1] 3716 <- (0,7332)
[1] 3717 <- (0,7333)
[1] 3718 <- (0,7334)
[1] 3719 <- (0,7335)
[1] 3720 <- (0,7336)
[1] 3721 <- (0,7337)
[1] 3722 <- (0,7338)
[1] 3723 <- (0,7339)
[1] 3724 <- (0,7340)
[1] 3725 <- (0,7341)
[1] 3726 <- (0,7342)
[1] 3727 <- (0,7343)
[1] 3728 <- (0,7344)
[1] 3729 <- (0,7345)
[1] 3730 <- (0,7346)
[1] 3731 <- (0,7347)
[1] 3732 <- (0,7348)
[1] 3733 <- (0,7349)
[1] 3734 <- (0,7373)
[1] 3735 <- (0,7374)
[1] 3736 <- (0,7375)
[1] 3737 <- (0,7376)
[1] 3738 <- (0,7377)
[1] 3739 <- (0,7378)
[1] 3740 <- (0,7379)
[1] 3741 <- (0,7380)
[1] 3742 <- (0,7381)
[1] 3743 <- (0,7382)
[1] 3744 <- (0,7383)
[1] 3745 <- (0,7384)
[1] 3746 <- (0,7385)
[1] 3747 <- (0,7386)
[1] 3748 <- (0,7387)
[1] 3749 <- (0,7388)
[1] 3750 <- (0,7389)
[1] 3751 <- (0,7390)
[1] 3752 <- (0,7391)
[1] 3753 <- (0,7392)
[1] 3754 <- (0,7393)
[1] 3755 <- (0,7394)
[1] 3756 <- (0,7395)
[1] 3757 <- (0,7396)
[1] 3758 <- (0,7397)
[1] 3759 <- (0,7398)
[1] 3760 <- (0,7399)
[1] 3761 <- (0,7424)
[1] 3762 <- (0,7425)
[1] 3763 <- (0,7426)
[1] 3764 <- (0,7427)
[1] 3765 <- (0,7428)
[1] 3766 <- (0,7429)
[1] 3767 <- (0,7430)
[1] 3768 <- (0,7431)
[1] 3769 <- (0,7432)
[1] 3770 <- (0,7433)
[1] 3771 <- (0,7434)
[1] 3772 <- (0,7435)
[1] 3773 <- (0,7436)
[1] 3774 <- (0,7437)
[1] 3775 <- (0,7438)
[1] 3776 <- (0,7439)
[1] 3777 <- (0,7440)
[1] 3778 <- (0,7441)
[1] 3779 <- (0,7442)
[1] 3780 <- (0,7443)
[1] 3781 <- (0,7444)
[1] 3782 <- (0,7445)
[1] 3783 <- (0,7446)
[1] 3784 <- (0,7447)
[1] 3785 <- (0,7448)
[1] 3786 <- (0,7449)
[1] 3787 <- (0,7475)
[1] 3788 <- (0,7476)
[1] 3789 <- (0,7477)
[1] 3790 <- (0,7478)
[1] 3791 <- (0,7479)
[1] 3792 <- (0,7480)
[1] 3793 <- (0,7481)
[1] 3794 <- (0,7482)
[1] 3795 <- (0,7483)
[1] 3796 <- (0,7484)
[1] 3797 <- (0,7485)
[1] 3798 <- (0,7486)
[1] 3799 <- (0,7487)
[1] 3800 <- (0,7488)
[1] 3801 <- (0,7489)
[1] 3802 <- (0,7490)
[1] 3803 <- (0,7491)
[1] 3804 <- (0,7492)
[1] 3805 <- (0,7493)
[1] 3806 <- (0,7494)
[1] 3807 <- (0,7495)
[1] 3808 <- (0,7496)
[1] 3809 <- (0,7497)
[1] 3810 <- (0,7498)
[1] 3811 <- (0,7499)
[1] 3812 <- (0,7525)
[1] 3813 <- (0,7526)
[1] 3814 <- (0,7527)
[1] 3815 <- (0,7528)
[1] 3816 <- (0,7529)
[1] 3817 <- (0,7530)
[1] 3818 <- (0,7531)
[1] 3819 <- (0,7532)
[1] 3820 <- (0,7533)
[1] 3821 <- (0,7534)
[1] 3822 <- (0,7535)
[1] 3823 <- (0,7536)
[1] 3824 <- (0,7537)
[1] 3825 <- (0,7538)
[1] 3826 <- (0,7539)
[1] 3827 <- (0,7540)
[1] 3828 <- (0,7541)
[1] 3829 <- (0,7542)
[1] 3830 <- (0,7543)
[1] 3831 <- (0,7544)
[1] 3832 <- (0,7545)
[1] 3833 <- (0,7546)
[1] 3834 <- (0,7547)
[1] 3835 <- (0,7548)
[1] 3836 <- (0,7549)
[1] 3837 <- (0,7576)
[1] 3838 <- (0,7577)
[1] 3839 <- (0,7578)
[1] 3840 <- (0,7579)
[1] 3841 <- (0,7580)
[1] 3842 <- (0,7581)
[1] 3843 <- (0,7582)
[1] 3844 <- (0,7583)
[1] 3845 <- (0,7584)
[1] 3846 <- (0,7585)
[1] 3847 <- (0,7586)
[1] 3848 <- (0,7587)
[1] 3849 <- (0,7588)
[1] 3850 <- (0,7589)
[1] 3851 <- (0,7590)
[1] 3852 <- (0,7591)
[1] 3853 <- (0,7592)
[1] 3854 <- (0,7593)
[1] 3855 <- (0,7594)
[1] 3856 <- (0,7595)
[1] 3857 <- (0,7596)
[1] 3858 <- (0,7597)
[1] 3859 <- (0,7598)
[1] 3860 <- (0,7599)
[1] 3861 <- (0,7626)
[1] 3862 <- (0,7627)
[1] 3863 <- (0,7628)
[1] 3864 <- (0,7629)
[1] 3865 <- (0,7630)
[1] 3866 <- (0,7631)
[1] 3867 <- (0,7632)
[1] 3868 <- (0,7633)
[1] 3869 <- (0,7634)
[1] 3870 <- (0,7635)
[1] 3871 <- (0,7636)
[1] 3872 <- (0,7637)
[1] 3873 <- (0,7638)
[1] 3874 <- (0,7639)
[1] 3875 <- (0,7640)
[1] 3876 <- (0,7641)
[1] 3877 <- (0,7642)
[1] 3878 <- (0,7643)
[1] 3879 <- (0,7644)
[1] 3880 <- (0,7645)
[1] 3881 <- (0,7646)
[1] 3882 <- (0,7647)
[1] 3883 <- (0,7648)
[1] 3884 <- (0,7649)
[1] 3885 <- (0,7677)
[1] 3886 <- (0,7678)
[1] 3887 <- (0,7679)
[1] 3888 <- (0,7680)
[1] 3889 <- (0,7681)
[1] 3890 <- (0,7682)
[1] 3891 <- (0,7683)
[1] 3892 <- (0,7684)
[1] 3893 <- (0,7685)
[1] 3894 <- (0,7686)
[1] 3895 <- (0,7687)
[1] 3896 <- (0,7688)
[1] 3897 <- (0,7689)
[1] 3898 <- (0,7690)
[1] 3899 <- (0,7691)
[1] 3900 <- (0,7692)
[1] 3901 <- (0,7693)
[1] 3902 <- (0,7694)
[1] 3903 <- (0,7695)
[1] 3904 <- (0,7696)
[1] 3905 <- (0,7697)
[1] 3906 <- (0,7698)
[1] 3907 <- (0,7699)
[1] 3908 <- (0,7727)
[1] 3909 <- (0,7728)
[1] 3910 <- (0,7729)
[1] 3911 <- (0,7730)
[1] 3912 <- (0,7731)
[1] 3913 <- (0,7732)
[1] 3914 <- (0,7733)
[1] 3915 <- (0,7734)
[1] 3916 <- (0,7735)
[1] 3917 <- (0,7736)
[1] 3918 <- (0,7737)
[1] 3919 <- (0,7738)
[1] 3920 <- (0,7739)
[1] 3921 <- (0,7740)
[1] 3922 <- (0,7741)
[1] 3923 <- (0,7742)
[1] 3924 <- (0,7743)
[1] 3925 <- (0,7744)
[1] 3926 <- (0,7745)
[1] 3927 <- (0,7746)
[1] 3928 <- (0,7747)
[1] 3929 <- (0,7748)
[1] 3930 <- (0,7749)
[1] 3931 <- (0,7777)
[1] 3932 <- (0,7778)
[1] 3933 <- (0,7779)
[1] 3934 <- (0,7780)
[1] 3935 <- (0,7781)
[1] 3936 <- (0,7782)
[1] 3937 <- (0,7783)
[1] 3938 <- (0,7784)
[1] 3939 <- (0,7785)
[1] 3940 <- (0,7786)
[1] 3941 <- (0,7787)
[1] 3942 <- (0,7788)
[1] 3943 <- (0,7789)
[1] 3944 <- (0,7790)
[1] 3945 <- (0,7791)
[1] 3946 <- (0,7792)
[1] 3947 <- (0,7793)
[1] 3948 <- (0,7794)
[1] 3949 <- (0,7795)
[1] 3950 <- (0,7796)
[1] 3951 <- (0,7797)
[1] 3952 <- (0,7798)
[1] 3953 <- (0,7799)
[1] 3954 <- (0,7827)
[1] 3955 <- (0,7828)
[1] 3956 <- (0,7829)
[1] 3957 <- (0,7830)
[1] 3958 <- (0,7831)
[1] 3959 <- (0,7832)
[1] 3960 <- (0,7833)
[1] 3961 <- (0,7834)
[1] 3962 <- (0,7835)
[1] 3963 <- (0,7836)
[1] 3964 <- (0,7837)
[1] 3965 <- (0,7838)
[1] 3966 <- (0,7839)
[1] 3967 <- (0,7840)
[1] 3968 <- (0,7841)
[1] 3969 <- (0,7842)
[1] 3970 <- (0,7843)
[1] 3971 <- (0,7844)
[1] 3972 <- (0,7845)
[1] 3973 <- (0,7846)
[1] 3974 <- (0,7847)
[1] 3975 <- (0,7848)
[1] 3976 <- (0,7849)
[1] 3977 <- (0,7877)
[1] 3978 <- (0,7878)
[1] 3979 <- (0,7879)
[1] 3980 <- (0,7880)
[1] 3981 <- (0,7881)
[1] 3982 <- (0,7882)
[1] 3983 <- (0,7883)
[1] 3984 <- (0,7884)
[1] 3985 <- (0,7885)
[1] 3986 <- (0,7886)
[1] 3987 <- (0,7887)
[1] 3988 <- (0,7888)
[1] 3989 <- (0,7889)
[1] 3990 <- (0,7890)
[1] 3991 <- (0,7891)
[1] 3992 <- (0,7892)
[1] 3993 <- (0,7893)
[1] 3994 <- (0,7894)
[1] 3995 <- (0,7895)
[1] 3996 <- (0,7896)
[1] 3997 <- (0,7897)
[1] 3998 <- (0,7898)
[1] 3999 <- (0,7899)
[1] 4000 <- (0,7927)
[1] 4001 <- (0,7928)
[1] 4002 <- (0,7929)
[1] 4003 <- (0,7930)
[1] 4004 <- (0,7931)
[1] 4005 <- (0,7932)
[1] 4006 <- (0,7933)
[1] 4007 <- (0,7934)
[1] 4008 <- (0,7935)
[1] 4009 <- (0,7936)
[1] 4010 <- (0,7937)
[1] 4011 <- (0,7938)
[1] 4012 <- (0,7939)
[1] 4013 <- (0,7940)
[1] 4014 <- (0,7941)
[1] 4015 <- (0,7942)
[1] 4016 <- (0,7943)
[1] 4017 <- (0,7944)
[1] 4018 <- (0,7945)
[1] 4019 <- (0,7946)
[1] 4020 <- (0,7947)
[1] 4021 <- (0,7948)
[1] 4022 <- (0,7949)
[1] 4023 <- (0,7977)
[1] 4024 <- (0,7978)
[1] 4025 <- (0,7979)
[1] 4026 <- (0,7980)
[1] 4027 <- (0,7981)
[1] 4028 <- (0,7982)
[1] 4029 <- (0,7983)
[1] 4030 <- (0,7984)
[1] 4031 <- (0,7985)
[1] 4032 <- (0,7986)
[1] 4033 <- (0,7987)
[1] 4034 <- (0,7988)
[1] 4035 <- (0,7989)
[1] 4036 <- (0,7990)
[1] 4037 <- (0,7991)
[1] 4038 <- (0,7992)
[1] 4039 <- (0,7993)
[1] 4040 <- (0,7994)
[1] 4041 <- (0,7995)
[1] 4042 <- (0,7996)
[1] 4043 <- (0,7997)
[1] 4044 <- (0,7998)
[1] 4045 <- (0,7999)
[1] 4046 <- (0,8022)
[1] 4047 <- (0,8023)
[1] 4048 <- (0,8024)
[1] 4049 <- (0,8025)
[1] 4050 <- (0,8026)
[1] 4051 <- (0,8027)
[1] 4052 <- (0,8028)
[1] 4053 <- (0,8029)
[1] 4054 <- (0,8030)
[1] 4055 <- (0,8031)
[1] 4056 <- (0,8032)
[1] 4057 <- (0,8033)
[1] 4058 <- (0,8034)
[1] 4059 <- (0,8035)
[1] 4060 <- (0,8036)
[1] 4061 <- (0,8037)
[1] 4062 <- (0,8038)
[1] 4063 <- (0,8039)
[1] 4064 <- (0,8040)
[1] 4065 <- (0,8041)
[1] 4066 <- (0,8042)
[1] 4067 <- (0,8043)
[1] 4068 <- (0,8044)
[1] 4069 <- (0,8045)
[1] 4070 <- (0,8046)
[1] 4071 <- (0,8047)
[1] 4072 <- (0,8048)
[1] 4073 <- (0,8049)
[1] 4074 <- (0,8072)
[1] 4075 <- (0,8073)
[1] 4076 <- (0,8074)
[1] 4077 <- (0,8075)
[1] 4078 <- (0,8076)
[1] 4079 <- (0,8077)
[1] 4080 <- (0,8078)
[1] 4081 <- (0,8079)
[1] 4082 <- (0,8080)
[1] 4083 <- (0,8081)
[1] 4084 <- (0,8082)
[1] 4085 <- (0,8083)
[1] 4086 <- (0,8084)
[1] 4087 <- (0,8085)
[1] 4088 <- (0,8086)
[1] 4089 <- (0,8087)
[1] 4090 <- (0,8088)
[1] 4091 <- (0,8089)
[1] 4092 <- (0,8090)
[1] 4093 <- (0,8091)
[1] 4094 <- (0,8092)
[1] 4095 <- (0,8093)
[1] 4096 <- (0,8094)
[1] 4097 <- (0,8095)
[1] 4098 <- (0,8096)
[1] 4099 <- (0,8097)
[1] 4100 <- (0,8098)
[1] 4101 <- (0,8099)
[1] 4102 <- (0,8122)
[1] 4103 <- (0,8123)
[1] 4104 <- (0,8124)
[1] 4105 <- (0,8125)
[1] 4106 <- (0,8126)
[1] 4107 <- (0,8127)
[1] 4108 <- (0,8128)
[1] 4109 <- (0,8129)
[1] 4110 <- (0,8130)
[1] 4111 <- (0,8131)
[1] 4112 <- (0,8132)
[1] 4113 <- (0,8133)
[1] 4114 <- (0,8134)
[1] 4115 <- (0,8135)
[1] 4116 <- (0,8136)
[1] 4117 <- (0,8137)
[1] 4118 <- (0,8138)
[1] 4119 <- (0,8139)
[1] 4120 <- (0,8140)
[1] 4121 <- (0,8141)
[1] 4122 <- (0,8142)
[1] 4123 <- (0,8143)
[1] 4124 <- (0,8144)
[1] 4125 <- (0,8145)
[1] 4126 <- (0,8146)
[1] 4127 <- (0,8147)
[1] 4128 <- (0,8148)
[1] 4129 <- (0,8149)
[1] 4130 <- (0,8172)
[1] 4131 <- (0,8173)
[1] 4132 <- (0,8174)
[1] 4133 <- (0,8175)
[1] 4134 <- (0,8176)
[1] 4135 <- (0,8177)
[1] 4136 <- (0,8178)
[1] 4137 <- (0,8179)
[1] 4138 <- (0,8180)
[1] 4139 <- (0,8181)
[1] 4140 <- (0,8182)
[1] 4141 <- (0,8183)
[1] 4142 <- (0,8184)
[1] 4143 <- (0,8185)
[1] 4144 <- (0,8186)
[1] 4145 <- (0,8187)
[1] 4146 <- (0,8188)
[1] 4147 <- (0,8189)
[1] 4148 <- (0,8190)
[1] 4149 <- (0,8191)
[1] 4150 <- (0,8192)
[1] 4151 <- (0,8193)
[1] 4152 <- (0,8194)
[1] 4153 <- (0,8195)
[1] 4154 <- (0,8196)
[1] 4155 <- (0,8197)
[1] 4156 <- (0,8198)
[1] 4157 <- (0,8199)
[1] 4158 <- (0,8223)
[1] 4159 <- (0,8224)
[1] 4160 <- (0,8225)
[1] 4161 <- (0,8226)
[1] 4162 <- (0,8227)
[1] 4163 <- (0,8228)
[1] 4164 <- (0,8229)
[1] 4165 <- (0,8230)
[1] 4166 <- (0,8231)
[1] 4167 <- (0,8232)
[1] 4168 <- (0,8233)
[1] 4169 <- (0,8234)
[1] 4170 <- (0,8235)
[1] 4171 <- (0,8236)
[1] 4172 <- (0,8237)
[1] 4173 <- (0,8238)
[1] 4174 <- (0,8239)
[1] 4175 <- (0,8240)
[1] 4176 <- (0,8241)
[1] 4177 <- (0,8242)
[1] 4178 <- (0,8243)
[1] 4179 <- (0,8244)
[1] 4180 <- (0,8245)
[1] 4181 <- (0,8246)
[1] 4182 <- (0,8247)
[1] 4183 <- (0,8248)
[1] 4184 <- (0,8249)
[1] 4185 <- (0,8273)
[1] 4186 <- (0,8274)
[1] 4187 <- (0,8275)
[1] 4188 <- (0,8276)
[1] 4189 <- (0,8277)
[1] 4190 <- (0,8278)
[1] 4191 <- (0,8279)
[1] 4192 <- (0,8280)
[1] 4193 <- (0,8281)
[1] 4194 <- (0,8282)
[1] 4195 <- (0,8283)
[1] 4196 <- (0,8284)
[1] 4197 <- (0,8285)
[1] 4198 <- (0,8286)
[1] 4199 <- (0,8287)
[1] 4200 <- (0,8288)
[1] 4201 <- (0,8289)
[1] 4202 <- (0,8290)
[1] 4203 <- (0,8291)
[1] 4204 <- (0,8292)
[1] 4205 <- (0,8293)
[1] 4206 <- (0,8294)
[1] 4207 <- (0,8295)
[1] 4208 <- (0,8296)
[1] 4209 <- (0,8297)
[1] 4210 <- (0,8298)
[1] 4211 <- (0,8299)
[1] 4212 <- (0,8323)
[1] 4213 <- (0,8324)
[1] 4214 <- (0,8325)
[1] 4215 <- (0,8326)
[1] 4216 <- (0,8327)
[1] 4217 <- (0,8328)
[1] 4218 <- (0,8329)
[1] 4219 <- (0,8330)
[1] 4220 <- (0,8331)
[1] 4221 <- (0,8332)
[1] 4222 <- (0,8333)
[1] 4223 <- (0,8334)
[1] 4224 <- (0,8335)
[1] 4225 <- (0,8336)
[1] 4226 <- (0,8337)
[1] 4227 <- (0,8338)
[1] 4228 <- (0,8339)
[1] 4229 <- (0,8340)
[1] 4230 <- (0,8341)
[1] 4231 <- (0,8342)
[1] 4232 <- (0,8343)
[1] 4233 <- (0,8344)
[1] 4234 <- (0,8345)
[1] 4235 <- (0,8346)
[1] 4236 <- (0,8347)
[1] 4237 <- (0,8348)
[1] 4238 <- (0,8349)
[1] 4239 <- (0,8373)
[1] 4240 <- (0,8374)
[1] 4241 <- (0,8375)
[1] 4242 <- (0,8376)
[1] 4243 <- (0,8377)
[1] 4244 <- (0,8378)
[1] 4245 <- (0,8379)
[1] 4246 <- (0,8380)
[1] 4247 <- (0,8381)
[1] 4248 <- (0,8382)
[1] 4249 <- (0,8383)
[1] 4250 <- (0,8384)
[1] 4251 <- (0,8385)
[1] 4252 <- (0,8386)
[1] 4253 <- (0,8387)
[1] 4254 <- (0,8388)
[1] 4255 <- (0,8389)
[1] 4256 <- (0,8390)
[1] 4257 <- (0,8391)
[1] 4258 <- (0,8392)
[1] 4259 <- (0,8393)
[1] 4260 <- (0,8394)
[1] 4261 <- (0,8395)
[1] 4262 <- (0,8396)
[1] 4263 <- (0,8397)
[1] 4264 <- (0,8398)
[1] 4265 <- (0,8399)
[1] 4266 <- (0,8424)
[1] 4267 <- (0,8425)
[1] 4268 <- (0,8426)
[1] 4269 <- (0,8427)
[1] 4270 <- (0,8428)
[1] 4271 <- (0,8429)
[1] 4272 <- (0,8430)
[1] 4273 <- (0,8431)
[1] 4274 <- (0,8432)
[1] 4275 <- (0,8433)
[1] 4276 <- (0,8434)
[1] 4277 <- (0,8435)
[1] 4278 <- (0,8436)
[1] 4279 <- (0,8437)
[1] 4280 <- (0,8438)
[1] 4281 <- (0,8439)
[1] 4282 <- (0,8440)
[1] 4283 <- (0,8441)
[1] 4284 <- (0,8442)
[1] 4285 <- (0,8443)
[1] 4286 <- (0,8444)
[1] 4287 <- (0,8445)
[1] 4288 <- (0,8446)
[1] 4289 <- (0,8447)
[1] 4290 <- (0,8448)
[1] 4291 <- (0,8449)
[1] 4292 <- (0,8475)
[1] 4293 <- (0,8476)
[1] 4294 <- (0,8477)
[1] 4295 <- (0,8478)
[1] 4296 <- (0,8479)
[1] 4297 <- (0,8480)
[1] 4298 <- (0,8481)
[1] 4299 <- (0,8482)
[1] 4300 <- (0,8483)
[1] 4301 <- (0,8484)
[1] 4302 <- (0,8485)
[1] 4303 <- (0,8486)
[1] 4304 <- (0,8487)
[1] 4305 <- (0,8488)
[1] 4306 <- (0,8489)
[1] 4307 <- (0,8490)
[1] 4308 <- (0,8491)
[1] 4309 <- (0,8492)
[1] 4310 <- (0,8493)
[1] 4311 <- (0,8494)
[1] 4312 <- (0,8495)
[1] 4313 <- (0,8496)
[1] 4314 <- (0,8497)
[1] 4315 <- (0,8498)
[1] 4316 <- (0,8499)
[1] 4317 <- (0,8525)
[1] 4318 <- (0,8526)
[1] 4319 <- (0,8527)
[1] 4320 <- (0,8528)
[1] 4321 <- (0,8529)
[1] 4322 <- (0,8530)
[1] 4323 <- (0,8531)
[1] 4324 <- (0,8532)
[1] 4325 <- (0,8533)
[1] 4326 <- (0,8534)
[1] 4327 <- (0,8535)
[1] 4328 <- (0,8536)
[1] 4329 <- (0,8537)
[1] 4330 <- (0,8538)
[1] 4331 <- (0,8539)
[1] 4332 <- (0,8540)
[1] 4333 <- (0,8541)
[1] 4334 <- (0,8542)
[1] 4335 <- (0,8543)
[1] 4336 <- (0,8544)
[1] 4337 <- (0,8545)
[1] 4338 <- (0,8546)
[1] 4339 <- (0,8547)
[1] 4340 <- (0,8548)
[1] 4341 <- (0,8549)
[1] 4342 <- (0,8576)
[1] 4343 <- (0,8577)
[1] 4344 <- (0,8578)
[1] 4345 <- (0,8579)
[1] 4346 <- (0,8580)
[1] 4347 <- (0,8581)
[1] 4348 <- (0,8582)
[1] 4349 <- (0,8583)
[1] 4350 <- (0,8584)
[1] 4351 <- (0,8585)
[1] 4352 <- (0,8586)
[1] 4353 <- (0,8587)
[1] 4354 <- (0,8588)
[1] 4355 <- (0,8589)
[1] 4356 <- (0,8590)
[1] 4357 <- (0,8591)
[1] 4358 <- (0,8592)
[1] 4359 <- (0,8593)
[1] 4360 <- (0,8594)
[1] 4361 <- (0,8595)
[1] 4362 <- (0,8596)
[1] 4363 <- (0,8597)
[1] 4364 <- (0,8598)
[1] 4365 <- (0,8599)
[1] 4366 <- (0,8626)
[1] 4367 <- (0,8627)
[1] 4368 <- (0,8628)
[1] 4369 <- (0,8629)
[1] 4370 <- (0,8630)
[1] 4371 <- (0,8631)
[1] 4372 <- (0,8632)
[1] 4373 <- (0,8633)
[1] 4374 <- (0,8634)
[1] 4375 <- (0,8635)
[1] 4376 <- (0,8636)
[1] 4377 <- (0,8637)
[1] 4378 <- (0,8638)
[1] 4379 <- (0,8639)
[1] 4380 <- (0,8640)
[1] 4381 <- (0,8641)
[1] 4382 <- (0,8642)
[1] 4383 <- (0,8643)
[1] 4384 <- (0,8644)
[1] 4385 <- (0,8645)
[1] 4386 <- (0,8646)
[1] 4387 <- (0,8647)
[1] 4388 <- (0,8648)
[1] 4389 <- (0,8649)
[1] 4390 <- (0,8677)
[1] 4391 <- (0,8678)
[1] 4392 <- (0,8679)
[1] 4393 <- (0,8680)
[1] 4394 <- (0,8681)
[1] 4395 <- (0,8682)
[1] 4396 <- (0,8683)
[1] 4397 <- (0,8684)
[1] 4398 <- (0,8685)
[1] 4399 <- (0,8686)
[1] 4400 <- (0,8687)
[1] 4401 <- (0,8688)
[1] 4402 <- (0,8689)
[1] 4403 <- (0,8690)
[1] 4404 <- (0,8691)
[1] 4405 <- (0,8692)
[1] 4406 <- (0,8693)
[1] 4407 <- (0,8694)
[1] 4408 <- (0,8695)
[1] 4409 <- (0,8696)
[1] 4410 <- (0,8697)
[1] 4411 <- (0,8698)
[1] 4412 <- (0,8699)
[1] 4413 <- (0,8727)
[1] 4414 <- (0,8728)
[1] 4415 <- (0,8729)
[1] 4416 <- (0,8730)
[1] 4417 <- (0,8731)
[1] 4418 <- (0,8732)
[1] 4419 <- (0,8733)
[1] 4420 <- (0,8734)
[1] 4421 <- (0,8735)
[1] 4422 <- (0,8736)
[1] 4423 <- (0,8737)
[1] 4424 <- (0,8738)
[1] 4425 <- (0,8739)
[1] 4426 <- (0,8740)
[1] 4427 <- (0,8741)
[1] 4428 <- (0,8742)
[1] 4429 <- (0,8743)
[1] 4430 <- (0,8744)
[1] 4431 <- (0,8745)
[1] 4432 <- (0,8746)
[1] 4433 <- (0,8747)
[1] 4434 <- (0,8748)
[1] 4435 <- (0,8749)
[1] 4436 <- (0,8777)
[1] 4437 <- (0,8778)
[1] 4438 <- (0,8779)
[1] 4439 <- (0,8780)
[1] 4440 <- (0,8781)
[1] 4441 <- (0,8782)
[1] 4442 <- (0,8783)
[1] 4443 <- (0,8784)
[1] 4444 <- (0,8785)
[1] 4445 <- (0,8786)
[1] 4446 <- (0,8787)
[1] 4447 <- (0,8788)
[1] 4448 <- (0,8789)
[1] 4449 <- (0,8790)
[1] 4450 <- (0,8791)
[1] 4451 <- (0,8792)
[1] 4452 <- (0,8793)
[1] 4453 <- (0,8794)
[1] 4454 <- (0,8795)
[1] 4455 <- (0,8796)
[1] 4456 <- (0,8797)
[1] 4457 <- (0,8798)
[1] 4458 <- (0,8799)
[1] 4459 <- (0,8827)
[1] 4460 <- (0,8828)
[1] 4461 <- (0,8829)
[1] 4462 <- (0,8830)
[1] 4463 <- (0,8831)
[1] 4464 <- (0,8832)
[1] 4465 <- (0,8833)
[1] 4466 <- (0,8834)
[1] 4467 <- (0,8835)
[1] 4468 <- (0,8836)
[1] 4469 <- (0,8837)
[1] 4470 <- (0,8838)
[1] 4471 <- (0,8839)
[1] 4472 <- (0,8840)
[1] 4473 <- (0,8841)
[1] 4474 <- (0,8842)
[1] 4475 <- (0,8843)
[1] 4476 <- (0,8844)
[1] 4477 <- (0,8845)
[1] 4478 <- (0,8846)
[1] 4479 <- (0,8847)
[1] 4480 <- (0,8848)
[1] 4481 <- (0,8849)
[1] 4482 <- (0,8877)
[1] 4483 <- (0,8878)
[1] 4484 <- (0,8879)
[1] 4485 <- (0,8880)
[1] 4486 <- (0,8881)
[1] 4487 <- (0,8882)
[1] 4488 <- (0,8883)
[1] 4489 <- (0,8884)
[1] 4490 <- (0,8885)
[1] 4491 <- (0,8886)
[1] 4492 <- (0,8887)
[1] 4493 <- (0,8888)
[1] 4494 <- (0,8889)
[1] 4495 <- (0,8890)
[1] 4496 <- (0,8891)
[1] 4497 <- (0,8892)
[1] 4498 <- (0,8893)
[1] 4499 <- (0,8894)
[1] 4500 <- (0,8895)
[1] 4501 <- (0,8896)
[1] 4502 <- (0,8897)
[1] 4503 <- (0,8898)
[1] 4504 <- (0,8899)
[1] 4505 <- (0,8927)
[1] 4506 <- (0,8928)
[1] 4507 <- (0,8929)
[1] 4508 <- (0,8930)
[1] 4509 <- (0,8931)
[1] 4510 <- (0,8932)
[1] 4511 <- (0,8933)
[1] 4512 <- (0,8934)
[1] 4513 <- (0,8935)
[1] 4514 <- (0,8936)
[1] 4515 <- (0,8937)
[1] 4516 <- (0,8938)
[1] 4517 <- (0,8939)
[1] 4518 <- (0,8940)
[1] 4519 <- (0,8941)
[1] 4520 <- (0,8942)
[1] 4521 <- (0,8943)
[1] 4522 <- (0,8944)
[1] 4523 <- (0,8945)
[1] 4524 <- (0,8946)
[1] 4525 <- (0,8947)
[1] 4526 <- (0,8948)
[1] 4527 <- (0,8949)
[1] 4528 <- (0,8977)
[1] 4529 <- (0,8978)
[1] 4530 <- (0,8979)
[1] 4531 <- (0,8980)
[1] 4532 <- (0,8981)
[1] 4533 <- (0,8982)
[1] 4534 <- (0,8983)
[1] 4535 <- (0,8984)
[1] 4536 <- (0,8985)
[1] 4537 <- (0,8986)
[1] 4538 <- (0,8987)
[1] 4539 <- (0,8988)
[1] 4540 <- (0,8989)
[1] 4541 <- (0,8990)
[1] 4542 <- (0,8991)
[1] 4543 <- (0,8992)
[1] 4544 <- (0,8993)
[1] 4545 <- (0,8994)
[1] 4546 <- (0,8995)
[1] 4547 <- (0,8996)
[1] 4548 <- (0,8997)
[1] 4549 <- (0,8998)
[1] 4550 <- (0,8999)
[1] 4551 <- (0,9022)
[1] 4552 <- (0,9023)
[1] 4553 <- (0,9024)
[1] 4554 <- (0,9025)
[1] 4555 <- (0,9026)
[1] 4556 <- (0,9027)
[1] 4557 <- (0,9028)
[1] 4558 <- (0,9029)
[1] 4559 <- (0,9030)
[1] 4560 <- (0,9031)
[1] 4561 <- (0,9032)
[1] 4562 <- (0,9033)
[1] 4563 <- (0,9034)
[1] 4564 <- (0,9035)
[1] 4565 <- (0,9036)
[1] 4566 <- (0,9037)
[1] 4567 <- (0,9038)
[1] 4568 <- (0,9039)
[1] 4569 <- (0,9040)
[1] 4570 <- (0,9041)
[1] 4571 <- (0,9042)
[1] 4572 <- (0,9043)
[1] 4573 <- (0,9044)
[1] 4574 <- (0,9045)
[1] 4575 <- (0,9046)
[1] 4576 <- (0,9047)
[1] 4577 <- (0,9048)
[1] 4578 <- (0,9049)
[1] 4579 <- (0,9072)
[1] 4580 <- (0,9073)
[1] 4581 <- (0,9074)
[1] 4582 <- (0,9075)
[1] 4583 <- (0,9076)
[1] 4584 <- (0,9077)
[1] 4585 <- (0,9078)
[1] 4586 <- (0,9079)
[1] 4587 <- (0,9080)
[1] 4588 <- (0,9081)
[1] 4589 <- (0,9082)
[1] 4590 <- (0,9083)
[1] 4591 <- (0,9084)
[1] 4592 <- (0,9085)
[1] 4593 <- (0,9086)
[1] 4594 <- (0,9087)
[1] 4595 <- (0,9088)
[1] 4596 <- (0,9089)
[1] 4597 <- (0,9090)
[1] 4598 <- (0,9091)
[1] 4599 <- (0,9092)
[1] 4600 <- (0,9093)
[1] 4601 <- (0,9094)
[1] 4602 <- (0,9095)
[1] 4603 <- (0,9096)
[1] 4604 <- (0,9097)
[1] 4605 <- (0,9098)
[1] 4606 <- (0,9099)
[1] 4607 <- (0,9122)
[1] 4608 <- (0,9123)
[1] 4609 <- (0,9124)
[1] 4610 <- (0,9125)
[1] 4611 <- (0,9126)
[1] 4612 <- (0,9127)
[1] 4613 <- (0,9128)
[1] 4614 <- (0,9129)
[1] 4615 <- (0,9130)
[1] 4616 <- (0,9131)
[1] 4617 <- (0,9132)
[1] 4618 <- (0,9133)
[1] 4619 <- (0,9134)
[1] 4620 <- (0,9135)
[1] 4621 <- (0,9136)
[1] 4622 <- (0,9137)
[1] 4623 <- (0,9138)
[1] 4624 <- (0,9139)
[1] 4625 <- (0,9140)
[1] 4626 <- (0,9141)
[1] 4627 <- (0,9142)
[1] 4628 <- (0,9143)
[1] 4629 <- (0,9144)
[1] 4630 <- (0,9145)
[1] 4631 <- (0,9146)
[1] 4632 <- (0,9147)
[1] 4633 <- (0,9148)
[1] 4634 <- (0,9149)
[1] 4635 <- (0,9172)
[1] 4636 <- (0,9173)
[1] 4637 <- (0,9174)
[1] 4638 <- (0,9175)
[1] 4639 <- (0,9176)
[1] 4640 <- (0,9177)
[1] 4641 <- (0,9178)
[1] 4642 <- (0,9179)
[1] 4643 <- (0,9180)
[1] 4644 <- (0,9181)
[1] 4645 <- (0,9182)
[1] 4646 <- (0,9183)
[1] 4647 <- (0,9184)
[1] 4648 <- (0,9185)
[1] 4649 <- (0,9186)
[1] 4650 <- (0,9187)
[1] 4651 <- (0,9188)
[1] 4652 <- (0,9189)
[1] 4653 <- (0,9190)
[1] 4654 <- (0,9191)
[1] 4655 <- (0,9192)
[1] 4656 <- (0,9193)
[1] 4657 <- (0,9194)
[1] 4658 <- (0,9195)
[1] 4659 <- (0,9196)
[1] 4660 <- (0,9197)
[1] 4661 <- (0,9198)
[1] 4662 <- (0,9199)
[1] 4663 <- (0,9223)
[1] 4664 <- (0,9224)
[1] 4665 <- (0,9225)
[1] 4666 <- (0,9226)
[1] 4667 <- (0,9227)
[1] 4668 <- (0,9228)
[1] 4669 <- (0,9229)
[1] 4670 <- (0,9230)
[1] 4671 <- (0,9231)
[1] 4672 <- (0,9232)
[1] 4673 <- (0,9233)
[1] 4674 <- (0,9234)
[1] 4675 <- (0,9235)
[1] 4676 <- (0,9236)
[1] 4677 <- (0,9237)
[1] 4678 <- (0,9238)
[1] 4679 <- (0,9239)
[1] 4680 <- (0,9240)
[1] 4681 <- (0,9241)
[1] 4682 <- (0,9242)
[1] 4683 <- (0,9243)
[1] 4684 <- (0,9244)
[1] 4685 <- (0,9245)
[1] 4686 <- (0,9246)
[1] 4687 <- (0,9247)
[1] 4688 <- (0,9248)
[1] 4689 <- (0,9249)
[1] 4690 <- (0,9273)
[1] 4691 <- (0,9274)
[1] 4692 <- (0,9275)
[1] 4693 <- (0,9276)
[1] 4694 <- (0,9277)
[1] 4695 <- (0,9278)
[1] 4696 <- (0,9279)
[1] 4697 <- (0,9280)
[1] 4698 <- (0,9281)
[1] 4699 <- (0,9282)
[1] 4700 <- (0,9283)
[1] 4701 <- (0,9284)
[1] 4702 <- (0,9285)
[1] 4703 <- (0,9286)
[1] 4704 <- (0,9287)
[1] 4705 <- (0,9288)
[1] 4706 <- (0,9289)
[1] 4707 <- (0,9290)
[1] 4708 <- (0,9291)
[1] 4709 <- (0,9292)
[1] 4710 <- (0,9293)
[1] 4711 <- (0,9294)
[1] 4712 <- (0,9295)
[1] 4713 <- (0,9296)
[1] 4714 <- (0,9297)
[1] 4715 <- (0,9298)
[1] 4716 <- (0,9299)
[1] 4717 <- (0,9323)
[1] 4718 <- (0,9324)
[1] 4719 <- (0,9325)
[1] 4720 <- (0,9326)
[1] 4721 <- (0,9327)
[1] 4722 <- (0,9328)
[1] 4723 <- (0,9329)
[1] 4724 <- (0,9330)
[1] 4725 <- (0,9331)
[1] 4726 <- (0,9332)
[1] 4727 <- (0,9333)
[1] 4728 <- (0,9334)
[1] 4729 <- (0,9335)
[1] 4730 <- (0,9336)
[1] 4731 <- (0,9337)
[1] 4732 <- (0,9338)
[1] 4733 <- (0,9339)
[1] 4734 <- (0,9340)
[1] 4735 <- (0,9341)
[1] 4736 <- (0,9342)
[1] 4737 <- (0,9343)
[1] 4738 <- (0,9344)
[1] 4739 <- (0,9345)
[1] 4740 <- (0,9346)
[1] 4741 <- (0,9347)
[1] 4742 <- (0,9348)
[1] 4743 <- (0,9349)
[1] 4744 <- (0,9373)
[1] 4745 <- (0,9374)
[1] 4746 <- (0,9375)
[1] 4747 <- (0,9376)
[1] 4748 <- (0,9377)
[1] 4749 <- (0,9378)
[1] 4750 <- (0,9379)
[1] 4751 <- (0,9380)
[1] 4752 <- (0,9381)
[1] 4753 <- (0,9382)
[1] 4754 <- (0,9383)
[1] 4755 <- (0,9384)
[1] 4756 <- (0,9385)
[1] 4757 <- (0,9386)
[1] 4758 <- (0,9387)
[1] 4759 <- (0,9388)
[1] 4760 <- (0,9389)
[1] 4761 <- (0,9390)
[1] 4762 <- (0,9391)
[1] 4763 <- (0,9392)
[1] 4764 <- (0,9393)
[1] 4765 <- (0,9394)
[1] 4766 <- (0,9395)
[1] 4767 <- (0,9396)
[1] 4768 <- (0,9397)
[1] 4769 <- (0,9398)
[1] 4770 <- (0,9399)
[1] 4771 <- (0,9424)
[1] 4772 <- (0,9425)
[1] 4773 <- (0,9426)
[1] 4774 <- (0,9427)
[1] 4775 <- (0,9428)
[1] 4776 <- (0,9429)
[1] 4777 <- (0,9430)
[1] 4778 <- (0,9431)
[1] 4779 <- (0,9432)
[1] 4780 <- (0,9433)
[1] 4781 <- (0,9434)
[1] 4782 <- (0,9435)
[1] 4783 <- (0,9436)
[1] 4784 <- (0,9437)
[1] 4785 <- (0,9438)
[1] 4786 <- (0,9439)
[1] 4787 <- (0,9440)
[1] 4788 <- (0,9441)
[1] 4789 <- (0,9442)
[1] 4790 <- (0,9443)
[1] 4791 <- (0,9444)
[1] 4792 <- (0,9445)
[1] 4793 <- (0,9446)
[1] 4794 <- (0,9447)
[1] 4795 <- (0,9448)
[1] 4796 <- (0,9449)
[1] 4797 <- (0,9475)
[1] 4798 <- (0,9476)
[1] 4799 <- (0,9477)
[1] 4800 <- (0,9478)
[1] 4801 <- (0,9479)
[1] 4802 <- (0,9480)
[1] 4803 <- (0,9481)
[1] 4804 <- (0,9482)
[1] 4805 <- (0,9483)
[1] 4806 <- (0,9484)
[1] 4807 <- (0,9485)
[1] 4808 <- (0,9486)
[1] 4809 <- (0,9487)
[1] 4810 <- (0,9488)
[1] 4811 <- (0,9489)
[1] 4812 <- (0,9490)
[1] 4813 <- (0,9491)
[1] 4814 <- (0,9492)
[1] 4815 <- (0,9493)
[1] 4816 <- (0,9494)
[1] 4817 <- (0,9495)
[1] 4818 <- (0,9496)
[1] 4819 <- (0,9497)
[1] 4820 <- (0,9498)
[1] 4821 <- (0,9499)
[1] 4822 <- (0,9525)
[1] 4823 <- (0,9526)
[1] 4824 <- (0,9527)
[1] 4825 <- (0,9528)
[1] 4826 <- (0,9529)
[1] 4827 <- (0,9530)
[1] 4828 <- (0,9531)
[1] 4829 <- (0,9532)
[1] 4830 <- (0,9533)
[1] 4831 <- (0,9534)
[1] 4832 <- (0,9535)
[1] 4833 <- (0,9536)
[1] 4834 <- (0,9537)
[1] 4835 <- (0,9538)
[1] 4836 <- (0,9539)
[1] 4837 <- (0,9540)
[1] 4838 <- (0,9541)
[1] 4839 <- (0,9542)
[1] 4840 <- (0,9543)
[1] 4841 <- (0,9544)
[1] 4842 <- (0,9545)
[1] 4843 <- (0,9546)
[1] 4844 <- (0,9547)
[1] 4845 <- (0,9548)
[1] 4846 <- (0,9549)
[1] 4847 <- (0,9576)
[1] 4848 <- (0,9577)
[1] 4849 <- (0,9578)
[1] 4850 <- (0,9579)
[1] 4851 <- (0,9580)
[1] 4852 <- (0,9581)
[1] 4853 <- (0,9582)
[1] 4854 <- (0,9583)
[1] 4855 <- (0,9584)
[1] 4856 <- (0,9585)
[1] 4857 <- (0,9586)
[1] 4858 <- (0,9587)
[1] 4859 <- (0,9588)
[1] 4860 <- (0,9589)
[1] 4861 <- (0,9590)
[1] 4862 <- (0,9591)
[1] 4863 <- (0,9592)
[1] 4864 <- (0,9593)
[1] 4865 <- (0,9594)
[1] 4866 <- (0,9595)
[1] 4867 <- (0,9596)
[1] 4868 <- (0,9597)
[1] 4869 <- (0,9598)
[1] 4870 <- (0,9599)
[1] 4871 <- (0,9626)
[1] 4872 <- (0,9627)
[1] 4873 <- (0,9628)
[1] 4874 <- (0,9629)
[1] 4875 <- (0,9630)
[1] 4876 <- (0,9631)
[1] 4877 <- (0,9632)
[1] 4878 <- (0,9633)
[1] 4879 <- (0,9634)
[1] 4880 <- (0,9635)
[1] 4881 <- (0,9636)
[1] 4882 <- (0,9637)
[1] 4883 <- (0,9638)
[1] 4884 <- (0,9639)
[1] 4885 <- (0,9640)
[1] 4886 <- (0,9641)
[1] 4887 <- (0,9642)
[1] 4888 <- (0,9643)
[1] 4889 <- (0,9644)
[1] 4890 <- (0,9645)
[1] 4891 <- (0,9646)
[1] 4892 <- (0,9647)
[1] 4893 <- (0,9648)
[1] 4894 <- (0,9649)
[1] 4895 <- (0,9677)
[1] 4896 <- (0,9678)
[1] 4897 <- (0,9679)
[1] 4898 <- (0,9680)
[1] 4899 <- (0,9681)
[1] 4900 <- (0,9682)
[1] 4901 <- (0,9683)
[1] 4902 <- (0,9684)
[1] 4903 <- (0,9685)
[1] 4904 <- (0,9686)
[1] 4905 <- (0,9687)
[1] 4906 <- (0,9688)
[1] 4907 <- (0,9689)
[1] 4908 <- (0,9690)
[1] 4909 <- (0,9691)
[1] 4910 <- (0,9692)
[1] 4911 <- (0,9693)
[1] 4912 <- (0,9694)
[1] 4913 <- (0,9695)
[1] 4914 <- (0,9696)
[1] 4915 <- (0,9697)
[1] 4916 <- (0,9698)
[1] 4917 <- (0,9699)
[1] 4918 <- (0,9727)
[1] 4919 <- (0,9728)
[1] 4920 <- (0,9729)
[1] 4921 <- (0,9730)
[1] 4922 <- (0,9731)
[1] 4923 <- (0,9732)
[1] 4924 <- (0,9733)
[1] 4925 <- (0,9734)
[1] 4926 <- (0,9735)
[1] 4927 <- (0,9736)
[1] 4928 <- (0,9737)
[1] 4929 <- (0,9738)
[1] 4930 <- (0,9739)
[1] 4931 <- (0,9740)
[1] 4932 <- (0,9741)
[1] 4933 <- (0,9742)
[1] 4934 <- (0,9743)
[1] 4935 <- (0,9744)
[1] 4936 <- (0,9745)
[1] 4937 <- (0,9746)
[1] 4938 <- (0,9747)
[1] 4939 <- (0,9748)
[1] 4940 <- (0,9749)
[1] 4941 <- (0,9777)
[1] 4942 <- (0,9778)
[1] 4943 <- (0,9779)
[1] 4944 <- (0,9780)
[1] 4945 <- (0,9781)
[1] 4946 <- (0,9782)
[1] 4947 <- (0,9783)
[1] 4948 <- (0,9784)
[1] 4949 <- (0,9785)
[1] 4950 <- (0,9786)
[1] 4951 <- (0,9787)
[1] 4952 <- (0,9788)
[1] 4953 <- (0,9789)
[1] 4954 <- (0,9790)
[1] 4955 <- (0,9791)
[1] 4956 <- (0,9792)
[1] 4957 <- (0,9793)
[1] 4958 <- (0,9794)
[1] 4959 <- (0,9795)
[1] 4960 <- (0,9796)
[1] 4961 <- (0,9797)
[1] 4962 <- (0,9798)
[1] 4963 <- (0,9799)
[1] 4964 <- (0,9827)
[1] 4965 <- (0,9828)
[1] 4966 <- (0,9829)
[1] 4967 <- (0,9830)
[1] 4968 <- (0,9831)
[1] 4969 <- (0,9832)
[1] 4970 <- (0,9833)
[1] 4971 <- (0,9834)
[1] 4972 <- (0,9835)
[1] 4973 <- (0,9836)
[1] 4974 <- (0,9837)
[1] 4975 <- (0,9838)
[1] 4976 <- (0,9839)
[1] 4977 <- (0,9840)
[1] 4978 <- (0,9841)
[1] 4979 <- (0,9842)
[1] 4980 <- (0,9843)
[1] 4981 <- (0,9844)
[1] 4982 <- (0,9845)
[1] 4983 <- (0,9846)
[1] 4984 <- (0,9847)
[1] 4985 <- (0,9848)
[1] 4986 <- (0,9849)
[1] 4987 <- (0,9877)
[1] 4988 <- (0,9878)
[1] 4989 <- (0,9879)
[1] 4990 <- (0,9880)
[1] 4991 <- (0,9881)
[1] 4992 <- (0,9882)
[1] 4993 <- (0,9883)
[1] 4994 <- (0,9884)
[1] 4995 <- (0,9885)
[1] 4996 <- (0,9886)
[1] 4997 <- (0,9887)
[1] 4998 <- (0,9888)
[1] 4999 <- (0,9889)
[1] 5000 <- (0,9890)
[1] 5001 <- (0,9891)
[1] 5002 <- (0,9892)
[1] 5003 <- (0,9893)
[1] 5004 <- (0,9894)
[1] 5005 <- (0,9895)
[1] 5006 <- (0,9896)
[1] 5007 <- (0,9897)
[1] 5008 <- (0,9898)
[1] 5009 <- (0,9899)
[1] 5010 <- (0,9927)
[1] 5011 <- (0,9928)
[1] 5012 <- (0,9929)
[1] 5013 <- (0,9930)
[1] 5014 <- (0,9931)
[1] 5015 <- (0,9932)
[1] 5016 <- (0,9933)
[1] 5017 <- (0,9934)
[1] 5018 <- (0,9935)
[1] 5019 <- (0,9936)
[1] 5020 <- (0,9937)
[1] 5021 <- (0,9938)
[1] 5022 <- (0,9939)
[1] 5023 <- (0,9940)
[1] 5024 <- (0,9941)
[1] 5025 <- (0,9942)
[1] 5026 <- (0,9943)
[1] 5027 <- (0,9944)
[1] 5028 <- (0,9945)
[1] 5029 <- (0,9946)
[1] 5030 <- (0,9947)
[1] 5031 <- (0,9948)
[1] 5032 <- (0,9949)
[1] 5033 <- (0,9977)
[1] 5034 <- (0,9978)
[1] 5035 <- (0,9979)
[1] 5036 <- (0,9980)
[1] 5037 <- (0,9981)
[1] 5038 <- (0,9982)
[1] 5039 <- (0,9983)
[1] 5040 <- (0,9984)
[1] 5041 <- (0,9985)
[1] 5042 <- (0,9986)
[1] 5043 <- (0,9987)
[1] 5044 <- (0,9988)
[1] 5045 <- (0,9989)
[1] 5046 <- (0,9990)
[1] 5047 <- (0,9991)
[1] 5048 <- (0,9992)
[1] 5049 <- (0,9993)
[1] 5050 <- (0,9994)
[1] 5051 <- (0,9995)
[1] 5052 <- (0,9996)
[1] 5053 <- (0,9997)
[1] 5054 <- (0,9998)
[1] 5055 <- (0,9999)
[1] 5056 <- (0,21)
[1] 5057 <- (0,71)
[1] 5058 <- (0,121)
[1] 5059 <- (0,171)
[1] 5060 <- (0,221)
[1] 5061 <- (0,222)
[1] 5062 <- (0,272)
[1] 5063 <- (0,322)
[1] 5064 <- (0,372)
[1] 5065 <- (0,422)
[1] 5066 <- (0,423)
[1] 5067 <- (0,473)
[1] 5068 <- (0,523)
[1] 5069 <- (0,524)
[1] 5070 <- (0,574)
[1] 5071 <- (0,575)
[1] 5072 <- (0,625)
[1] 5073 <- (0,675)
[1] 5074 <- (0,676)
[1] 5075 <- (0,726)
[1] 5076 <- (0,776)
[1] 5077 <- (0,826)
[1] 5078 <- (0,876)
[1] 5079 <- (0,926)
[1] 5080 <- (0,976)
[1] 5081 <- (0,1021)
[1] 5082 <- (0,1071)
[1] 5083 <- (0,1121)
[1] 5084 <- (0,1171)
[1] 5085 <- (0,1221)
[1] 5086 <- (0,1222)
[1] 5087 <- (0,1272)
[1] 5088 <- (0,1322)
[1] 5089 <- (0,1372)
[1] 5090 <- (0,1422)
[1] 5091 <- (0,1423)
[1] 5092 <- (0,1473)
[1] 5093 <- (0,1523)
[1] 5094 <- (0,1524)
[1] 5095 <- (0,1574)
[1] 5096 <- (0,1575)
[1] 5097 <- (0,1625)
[1] 5098 <- (0,1675)
[1] 5099 <- (0,1676)
[1] 5100 <- (0,1726)
[1] 5101 <- (0,1776)
[1] 5102 <- (0,1826)
[1] 5103 <- (0,1876)
[1] 5104 <- (0,1926)
[1] 5105 <- (0,1976)
[1] 5106 <- (0,2021)
[1] 5107 <- (0,2071)
[1] 5108 <- (0,2121)
[1] 5109 <- (0,2171)
[1] 5110 <- (0,2221)
[1] 5111 <- (0,2222)
[1] 5112 <- (0,2272)
[1] 5113 <- (0,2322)
[1] 5114 <- (0,2372)
[1] 5115 <- (0,2422)
[1] 5116 <- (0,2423)
[1] 5117 <- (0,2473)
[1] 5118 <- (0,2523)
[1] 5119 <- (0,2524)
[1] 5120 <- (0,2574)
[1] 5121 <- (0,2575)
[1] 5122 <- (0,2625)
[1] 5123 <- (0,2675)
[1] 5124 <- (0,2676)
[1] 5125 <- (0,2726)
[1] 5126 <- (0,2776)
[1] 5127 <- (0,2826)
[1] 5128 <- (0,2876)
[1] 5129 <- (0,2926)
[1] 5130 <- (0,2976)
[1] 5131 <- (0,3021)
[1] 5132 <- (0,3071)
[1] 5133 <- (0,3121)
[1] 5134 <- (0,3171)
[1] 5135 <- (0,3221)
[1] 5136 <- (0,3222)
[1] 5137 <- (0,3272)
[1] 5138 <- (0,3322)
[1] 5139 <- (0,3372)
[1] 5140 <- (0,3422)
[1] 5141 <- (0,3423)
[1] 5142 <- (0,3473)
[1] 5143 <- (0,3523)
[1] 5144 <- (0,3524)
[1] 5145 <- (0,3574)
[1] 5146 <- (0,3575)
[1] 5147 <- (0,3625)
[1] 5148 <- (0,3675)
[1] 5149 <- (0,3676)
[1] 5150 <- (0,3726)
[1] 5151 <- (0,3776)
[1] 5152 <- (0,3826)
[1] 5153 <- (0,3876)
[1] 5154 <- (0,3926)
[1] 5155 <- (0,3976)
[1] 5156 <- (0,4021)
[1] 5157 <- (0,4071)
[1] 5158 <- (0,4121)
[1] 5159 <- (0,4171)
[1] 5160 <- (0,4221)
[1] 5161 <- (0,4222)
[1] 5162 <- (0,4272)
[1] 5163 <- (0,4322)
[1] 5164 <- (0,4372)
[1] 5165 <- (0,4422)
[1] 5166 <- (0,4423)
[1] 5167 <- (0,4473)
[1] 5168 <- (0,4523)
[1] 5169 <- (0,4524)
[1] 5170 <- (0,4574)
[1] 5171 <- (0,4575)
[1] 5172 <- (0,4625)
[1] 5173 <- (0,4675)
[1] 5174 <- (0,4676)
[1] 5175 <- (0,4726)
[1] 5176 <- (0,4776)
[1] 5177 <- (0,4826)
[1] 5178 <- (0,4876)
[1] 5179 <- (0,4926)
[1] 5180 <- (0,4976)
[1] 5181 <- (0,5021)
[1] 5182 <- (0,5071)
[1] 5183 <- (0,5121)
[1] 5184 <- (0,5171)
[1] 5185 <- (0,5221)
[1] 5186 <- (0,5222)
[1] 5187 <- (0,5272)
[1] 5188 <- (0,5322)
[1] 5189 <- (0,5372)
[1] 5190 <- (0,5422)
[1] 5191 <- (0,5423)
[1] 5192 <- (0,5473)
[1] 5193 <- (0,5523)
[1] 5194 <- (0,5524)
[1] 5195 <- (0,5574)
[1] 5196 <- (0,5575)
[1] 5197 <- (0,5625)
[1] 5198 <- (0,5675)
[1] 5199 <- (0,5676)
[1] 5200 <- (0,5726)
[1] 5201 <- (0,5776)
[1] 5202 <- (0,5826)
[1] 5203 <- (0,5876)
[1] 5204 <- (0,5926)
[1] 5205 <- (0,5976)
[1] 5206 <- (0,6021)
[1] 5207 <- (0,6071)
[1] 5208 <- (0,6121)
[1] 5209 <- (0,6171)
[1] 5210 <- (0,6221)
[1] 5211 <- (0,6222)
[1] 5212 <- (0,6272)
[1] 5213 <- (0,6322)
[1] 5214 <- (0,6372)
[1] 5215 <- (0,6422)
[1] 5216 <- (0,6423)
[1] 5217 <- (0,6473)
[1] 5218 <- (0,6474)
[1] 5219 <- (0,6523)
[1] 5220 <- (0,6524)
[1] 5221 <- (0,6574)
[1] 5222 <- (0,6575)
[1] 5223 <- (0,6625)
[1] 5224 <- (0,6675)
[1] 5225 <- (0,6676)
[1] 5226 <- (0,6726)
[1] 5227 <- (0,6776)
[1] 5228 <- (0,6826)
[1] 5229 <- (0,6876)
[1] 5230 <- (0,6926)
[1] 5231 <- (0,6976)
[1] 5232 <- (0,7021)
[1] 5233 <- (0,7071)
[1] 5234 <- (0,7121)
[1] 5235 <- (0,7171)
[1] 5236 <- (0,7221)
[1] 5237 <- (0,7222)
[1] 5238 <- (0,7272)
[1] 5239 <- (0,7322)
[1] 5240 <- (0,7372)
[1] 5241 <- (0,7422)
[1] 5242 <- (0,7423)
[1] 5243 <- (0,7473)
[1] 5244 <- (0,7474)
[1] 5245 <- (0,7524)
[1] 5246 <- (0,7574)
[1] 5247 <- (0,7575)
[1] 5248 <- (0,7625)
[1] 5249 <- (0,7675)
[1] 5250 <- (0,7676)
[1] 5251 <- (0,7726)
[1] 5252 <- (0,7776)
[1] 5253 <- (0,7826)
[1] 5254 <- (0,7876)
[1] 5255 <- (0,7926)
[1] 5256 <- (0,7976)
[1] 5257 <- (0,8021)
[1] 5258 <- (0,8071)
[1] 5259 <- (0,8121)
[1] 5260 <- (0,8171)
[1] 5261 <- (0,8221)
[1] 5262 <- (0,8222)
[1] 5263 <- (0,8272)
[1] 5264 <- (0,8322)
[1] 5265 <- (0,8372)
[1] 5266 <- (0,8422)
[1] 5267 <- (0,8423)
[1] 5268 <- (0,8473)
[1] 5269 <- (0,8474)
[1] 5270 <- (0,8524)
[1] 5271 <- (0,8574)
[1] 5272 <- (0,8575)
[1] 5273 <- (0,8625)
[1] 5274 <- (0,8675)
[1] 5275 <- (0,8676)
[1] 5276 <- (0,8726)
[1] 5277 <- (0,8776)
[1] 5278 <- (0,8826)
[1] 5279 <- (0,8876)
[1] 5280 <- (0,8926)
[1] 5281 <- (0,8976)
[1] 5282 <- (0,9021)
[1] 5283 <- (0,9071)
[1] 5284 <- (0,9121)
[1] 5285 <- (0,9171)
[1] 5286 <- (0,9221)
[1] 5287 <- (0,9222)
[1] 5288 <- (0,9272)
[1] 5289 <- (0,9322)
[1] 5290 <- (0,9372)
[1] 5291 <- (0,9422)
[1] 5292 <- (0,9423)
[1] 5293 <- (0,9473)
[1] 5294 <- (0,9474)
[1] 5295 <- (0,9524)
[1] 5296 <- (0,9574)
[1] 5297 <- (0,9575)
[1] 5298 <- (0,9625)
[1] 5299 <- (0,9675)
[1] 5300 <- (0,9676)
[1] 5301 <- (0,9726)
[1] 5302 <- (0,9776)
[1] 5303 <- (0,9826)
[1] 5304 <- (0,9876)
[1] 5305 <- (0,9926)
[1] 5306 <- (0,9976)
[1] 5307 <- (0,10022)
[1] 5308 <- (0,10023)
[1] 5309 <- (0,10024)
[1] 5310 <- (0,10025)
[1] 5311 <- (0,10026)
[1] 5312 <- (0,10027)
[1] 5313 <- (0,10028)
[1] 5314 <- (0,10029)
[1] 5315 <- (0,10030)
[1] 5316 <- (0,10031)
[1] 5317 <- (0,10032)
[1] 5318 <- (0,10033)
[1] 5319 <- (0,10034)
[1] 5320 <- (0,10035)
[1] 5321 <- (0,10036)
[1] 5322 <- (0,10037)
[1] 5323 <- (0,10038)
[1] 5324 <- (0,10039)
[1] 5325 <- (0,10040)
[1] 5326 <- (0,10041)
[1] 5327 <- (0,10042)
[1] 5328 <- (0,10043)
[1] 5329 <- (0,10044)
[1] 5330 <- (0,10045)
[1] 5331 <- (0,10046)
[1] 5332 <- (0,10047)
[1] 5333 <- (0,10048)
[1] 5334 <- (0,10049)
[1] 5335 <- (0,10050)
[1] 5336 <- (0,10073)
[1] 5337 <- (0,10074)
[1] 5338 <- (0,10075)
[1] 5339 <- (0,10076)
[1] 5340 <- (0,10077)
[1] 5341 <- (0,10078)
[1] 5342 <- (0,10079)
[1] 5343 <- (0,10080)
[1] 5344 <- (0,10081)
[1] 5345 <- (0,10082)
[1] 5346 <- (0,10083)
[1] 5347 <- (0,10084)
[1] 5348 <- (0,10085)
[1] 5349 <- (0,10086)
[1] 5350 <- (0,10087)
[1] 5351 <- (0,10088)
[1] 5352 <- (0,10089)
[1] 5353 <- (0,10090)
[1] 5354 <- (0,10091)
[1] 5355 <- (0,10092)
[1] 5356 <- (0,10093)
[1] 5357 <- (0,10094)
[1] 5358 <- (0,10095)
[1] 5359 <- (0,10096)
[1] 5360 <- (0,10097)
[1] 5361 <- (0,10098)
[1] 5362 <- (0,10099)
[1] 5363 <- (0,10100)
[1] 5364 <- (0,10101)
[1] 5365 <- (0,10124)
[1] 5366 <- (0,10125)
[1] 5367 <- (0,10126)
[1] 5368 <- (0,10127)
[1] 5369 <- (0,10128)
[1] 5370 <- (0,10129)
[1] 5371 <- (0,10130)
[1] 5372 <- (0,10131)
[1] 5373 <- (0,10132)
[1] 5374 <- (0,10133)
[1] 5375 <- (0,10134)
[1] 5376 <- (0,10135)
[1] 5377 <- (0,10136)
[1] 5378 <- (0,10137)
[1] 5379 <- (0,10138)
[1] 5380 <- (0,10139)
[1] 5381 <- (0,10140)
[1] 5382 <- (0,10141)
[1] 5383 <- (0,10142)
[1] 5384 <- (0,10143)
[1] 5385 <- (0,10144)
[1] 5386 <- (0,10145)
[1] 5387 <- (0,10146)
[1] 5388 <- (0,10147)
[1] 5389 <- (0,10148)
[1] 5390 <- (0,10149)
[1] 5391 <- (0,10150)
[1] 5392 <- (0,10151)
[1] 5393 <- (0,10152)
[1] 5394 <- (0,10175)
[1] 5395 <- (0,10176)
[1] 5396 <- (0,10177)
[1] 5397 <- (0,10178)
[1] 5398 <- (0,10179)
[1] 5399 <- (0,10180)
[1] 5400 <- (0,10181)
[1] 5401 <- (0,10182)
[1] 5402 <- (0,10183)
[1] 5403 <- (0,10184)
[1] 5404 <- (0,10185)
[1] 5405 <- (0,10186)
[1] 5406 <- (0,10187)
[1] 5407 <- (0,10188)
[1] 5408 <- (0,10189)
[1] 5409 <- (0,10190)
[1] 5410 <- (0,10191)
[1] 5411 <- (0,10192)
[1] 5412 <- (0,10193)
[1] 5413 <- (0,10194)
[1] 5414 <- (0,10195)
[1] 5415 <- (0,10196)
[1] 5416 <- (0,10197)
[1] 5417 <- (0,10198)
[1] 5418 <- (0,10199)
[1] 5419 <- (0,10200)
[1] 5420 <- (0,10201)
[1] 5421 <- (0,10202)
[1] 5422 <- (0,10203)
[1] 5423 <- (0,10226)
[1] 5424 <- (0,10227)
[1] 5425 <- (0,10228)
[1] 5426 <- (0,10229)
[1] 5427 <- (0,10230)
[1] 5428 <- (0,10231)
[1] 5429 <- (0,10232)
[1] 5430 <- (0,10233)
[1] 5431 <- (0,10234)
[1] 5432 <- (0,10235)
[1] 5433 <- (0,10236)
[1] 5434 <- (0,10237)
[1] 5435 <- (0,10238)
[1] 5436 <- (0,10239)
[1] 5437 <- (0,10240)
[1] 5438 <- (0,10241)
[1] 5439 <- (0,10242)
[1] 5440 <- (0,10243)
[1] 5441 <- (0,10244)
[1] 5442 <- (0,10245)
[1] 5443 <- (0,10246)
[1] 5444 <- (0,10247)
[1] 5445 <- (0,10248)
[1] 5446 <- (0,10249)
[1] 5447 <- (0,10250)
[1] 5448 <- (0,10251)
[1] 5449 <- (0,10252)
[1] 5450 <- (0,10253)
[1] 5451 <- (0,10254)
[1] 5452 <- (0,10278)
[1] 5453 <- (0,10279)
[1] 5454 <- (0,10280)
[1] 5455 <- (0,10281)
[1] 5456 <- (0,10282)
[1] 5457 <- (0,10283)
[1] 5458 <- (0,10284)
[1] 5459 <- (0,10285)
[1] 5460 <- (0,10286)
[1] 5461 <- (0,10287)
[1] 5462 <- (0,10288)
[1] 5463 <- (0,10289)
[1] 5464 <- (0,10290)
[1] 5465 <- (0,10291)
[1] 5466 <- (0,10292)
[1] 5467 <- (0,10293)
[1] 5468 <- (0,10294)
[1] 5469 <- (0,10295)
[1] 5470 <- (0,10296)
[1] 5471 <- (0,10297)
[1] 5472 <- (0,10298)
[1] 5473 <- (0,10299)
[1] 5474 <- (0,10300)
[1] 5475 <- (0,10301)
[1] 5476 <- (0,10302)
[1] 5477 <- (0,10303)
[1] 5478 <- (0,10304)
[1] 5479 <- (0,10305)
[1] 5480 <- (0,10329)
[1] 5481 <- (0,10330)
[1] 5482 <- (0,10331)
[1] 5483 <- (0,10332)
[1] 5484 <- (0,10333)
[1] 5485 <- (0,10334)
[1] 5486 <- (0,10335)
[1] 5487 <- (0,10336)
[1] 5488 <- (0,10337)
[1] 5489 <- (0,10338)
[1] 5490 <- (0,10339)
[1] 5491 <- (0,10340)
[1] 5492 <- (0,10341)
[1] 5493 <- (0,10342)
[1] 5494 <- (0,10343)
[1] 5495 <- (0,10344)
[1] 5496 <- (0,10345)
[1] 5497 <- (0,10346)
[1] 5498 <- (0,10347)
[1] 5499 <- (0,10348)
[1] 5500 <- (0,10349)
[1] 5501 <- (0,10350)
[1] 5502 <- (0,10351)
[1] 5503 <- (0,10352)
[1] 5504 <- (0,10353)
[1] 5505 <- (0,10354)
[1] 5506 <- (0,10355)
[1] 5507 <- (0,10356)
[1] 5508 <- (0,10380)
[1] 5509 <- (0,10381)
[1] 5510 <- (0,10382)
[1] 5511 <- (0,10383)
[1] 5512 <- (0,10384)
[1] 5513 <- (0,10385)
[1] 5514 <- (0,10386)
[1] 5515 <- (0,10387)
[1] 5516 <- (0,10388)
[1] 5517 <- (0,10389)
[1] 5518 <- (0,10390)
[1] 5519 <- (0,10391)
[1] 5520 <- (0,10392)
[1] 5521 <- (0,10393)
[1] 5522 <- (0,10394)
[1] 5523 <- (0,10395)
[1] 5524 <- (0,10396)
[1] 5525 <- (0,10397)
[1] 5526 <- (0,10398)
[1] 5527 <- (0,10399)
[1] 5528 <- (0,10400)
[1] 5529 <- (0,10401)
[1] 5530 <- (0,10402)
[1] 5531 <- (0,10403)
[1] 5532 <- (0,10404)
[1] 5533 <- (0,10405)
[1] 5534 <- (0,10406)
[1] 5535 <- (0,10407)
[1] 5536 <- (0,10431)
[1] 5537 <- (0,10432)
[1] 5538 <- (0,10433)
[1] 5539 <- (0,10434)
[1] 5540 <- (0,10435)
[1] 5541 <- (0,10436)
[1] 5542 <- (0,10437)
[1] 5543 <- (0,10438)
[1] 5544 <- (0,10439)
[1] 5545 <- (0,10440)
[1] 5546 <- (0,10441)
[1] 5547 <- (0,10442)
[1] 5548 <- (0,10443)
[1] 5549 <- (0,10444)
[1] 5550 <- (0,10445)
[1] 5551 <- (0,10446)
[1] 5552 <- (0,10447)
[1] 5553 <- (0,10448)
[1] 5554 <- (0,10449)
[1] 5555 <- (0,10450)
[1] 5556 <- (0,10451)
[1] 5557 <- (0,10452)
[1] 5558 <- (0,10453)
[1] 5559 <- (0,10454)
[1] 5560 <- (0,10455)
[1] 5561 <- (0,10456)
[1] 5562 <- (0,10457)
[1] 5563 <- (0,10458)
[1] 5564 <- (0,10483)
[1] 5565 <- (0,10484)
[1] 5566 <- (0,10485)
[1] 5567 <- (0,10486)
[1] 5568 <- (0,10487)
[1] 5569 <- (0,10488)
[1] 5570 <- (0,10489)
[1] 5571 <- (0,10490)
[1] 5572 <- (0,10491)
[1] 5573 <- (0,10492)
[1] 5574 <- (0,10493)
[1] 5575 <- (0,10494)
[1] 5576 <- (0,10495)
[1] 5577 <- (0,10496)
[1] 5578 <- (0,10497)
[1] 5579 <- (0,10498)
[1] 5580 <- (0,10499)
[1] 5581 <- (0,10500)
[1] 5582 <- (0,10501)
[1] 5583 <- (0,10502)
[1] 5584 <- (0,10503)
[1] 5585 <- (0,10504)
[1] 5586 <- (0,10505)
[1] 5587 <- (0,10506)
[1] 5588 <- (0,10507)
[1] 5589 <- (0,10508)
[1] 5590 <- (0,10509)
[1] 5591 <- (0,10534)
[1] 5592 <- (0,10535)
[1] 5593 <- (0,10536)
[1] 5594 <- (0,10537)
[1] 5595 <- (0,10538)
[1] 5596 <- (0,10539)
[1] 5597 <- (0,10540)
[1] 5598 <- (0,10541)
[1] 5599 <- (0,10542)
[1] 5600 <- (0,10543)
[1] 5601 <- (0,10544)
[1] 5602 <- (0,10545)
[1] 5603 <- (0,10546)
[1] 5604 <- (0,10547)
[1] 5605 <- (0,10548)
[1] 5606 <- (0,10549)
[1] 5607 <- (0,10550)
[1] 5608 <- (0,10551)
[1] 5609 <- (0,10552)
[1] 5610 <- (0,10553)
[1] 5611 <- (0,10554)
[1] 5612 <- (0,10555)
[1] 5613 <- (0,10556)
[1] 5614 <- (0,10557)
[1] 5615 <- (0,10558)
[1] 5616 <- (0,10559)
[1] 5617 <- (0,10560)
[1] 5618 <- (0,10586)
[1] 5619 <- (0,10587)
[1] 5620 <- (0,10588)
[1] 5621 <- (0,10589)
[1] 5622 <- (0,10590)
[1] 5623 <- (0,10591)
[1] 5624 <- (0,10592)
[1] 5625 <- (0,10593)
[1] 5626 <- (0,10594)
[1] 5627 <- (0,10595)
[1] 5628 <- (0,10596)
[1] 5629 <- (0,10597)
[1] 5630 <- (0,10598)
[1] 5631 <- (0,10599)
[1] 5632 <- (0,10600)
[1] 5633 <- (0,10601)
[1] 5634 <- (0,10602)
[1] 5635 <- (0,10603)
[1] 5636 <- (0,10604)
[1] 5637 <- (0,10605)
[1] 5638 <- (0,10606)
[1] 5639 <- (0,10607)
[1] 5640 <- (0,10608)
[1] 5641 <- (0,10609)
[1] 5642 <- (0,10610)
[1] 5643 <- (0,10611)
[1] 5644 <- (0,10638)
[1] 5645 <- (0,10639)
[1] 5646 <- (0,10640)
[1] 5647 <- (0,10641)
[1] 5648 <- (0,10642)
[1] 5649 <- (0,10643)
[1] 5650 <- (0,10644)
[1] 5651 <- (0,10645)
[1] 5652 <- (0,10646)
[1] 5653 <- (0,10647)
[1] 5654 <- (0,10648)
[1] 5655 <- (0,10649)
[1] 5656 <- (0,10650)
[1] 5657 <- (0,10651)
[1] 5658 <- (0,10652)
[1] 5659 <- (0,10653)
[1] 5660 <- (0,10654)
[1] 5661 <- (0,10655)
[1] 5662 <- (0,10656)
[1] 5663 <- (0,10657)
[1] 5664 <- (0,10658)
[1] 5665 <- (0,10659)
[1] 5666 <- (0,10660)
[1] 5667 <- (0,10661)
[1] 5668 <- (0,10662)
[1] 5669 <- (0,10689)
[1] 5670 <- (0,10690)
[1] 5671 <- (0,10691)
[1] 5672 <- (0,10692)
[1] 5673 <- (0,10693)
[1] 5674 <- (0,10694)
[1] 5675 <- (0,10695)
[1] 5676 <- (0,10696)
[1] 5677 <- (0,10697)
[1] 5678 <- (0,10698)
[1] 5679 <- (0,10699)
[1] 5680 <- (0,10700)
[1] 5681 <- (0,10701)
[1] 5682 <- (0,10702)
[1] 5683 <- (0,10703)
[1] 5684 <- (0,10704)
[1] 5685 <- (0,10705)
[1] 5686 <- (0,10706)
[1] 5687 <- (0,10707)
[1] 5688 <- (0,10708)
[1] 5689 <- (0,10709)
[1] 5690 <- (0,10710)
[1] 5691 <- (0,10711)
[1] 5692 <- (0,10712)
[1] 5693 <- (0,10713)
[1] 5694 <- (0,10741)
[1] 5695 <- (0,10742)
[1] 5696 <- (0,10743)
[1] 5697 <- (0,10744)
[1] 5698 <- (0,10745)
[1] 5699 <- (0,10746)
[1] 5700 <- (0,10747)
[1] 5701 <- (0,10748)
[1] 5702 <- (0,10749)
[1] 5703 <- (0,10750)
[1] 5704 <- (0,10751)
[1] 5705 <- (0,10752)
[1] 5706 <- (0,10753)
[1] 5707 <- (0,10754)
[1] 5708 <- (0,10755)
[1] 5709 <- (0,10756)
[1] 5710 <- (0,10757)
[1] 5711 <- (0,10758)
[1] 5712 <- (0,10759)
[1] 5713 <- (0,10760)
[1] 5714 <- (0,10761)
[1] 5715 <- (0,10762)
[1] 5716 <- (0,10763)
[1] 5717 <- (0,10764)
[1] 5718 <- (0,10792)
[1] 5719 <- (0,10793)
[1] 5720 <- (0,10794)
[1] 5721 <- (0,10795)
[1] 5722 <- (0,10796)
[1] 5723 <- (0,10797)
[1] 5724 <- (0,10798)
[1] 5725 <- (0,10799)
[1] 5726 <- (0,10800)
[1] 5727 <- (0,10801)
[1] 5728 <- (0,10802)
[1] 5729 <- (0,10803)
[1] 5730 <- (0,10804)
[1] 5731 <- (0,10805)
[1] 5732 <- (0,10806)
[1] 5733 <- (0,10807)
[1] 5734 <- (0,10808)
[1] 5735 <- (0,10809)
[1] 5736 <- (0,10810)
[1] 5737 <- (0,10811)
[1] 5738 <- (0,10812)
[1] 5739 <- (0,10813)
[1] 5740 <- (0,10814)
[1] 5741 <- (0,10815)
[1] 5742 <- (0,10843)
[1] 5743 <- (0,10844)
[1] 5744 <- (0,10845)
[1] 5745 <- (0,10846)
[1] 5746 <- (0,10847)
[1] 5747 <- (0,10848)
[1] 5748 <- (0,10849)
[1] 5749 <- (0,10850)
[1] 5750 <- (0,10851)
[1] 5751 <- (0,10852)
[1] 5752 <- (0,10853)
[1] 5753 <- (0,10854)
[1] 5754 <- (0,10855)
[1] 5755 <- (0,10856)
[1] 5756 <- (0,10857)
[1] 5757 <- (0,10858)
[1] 5758 <- (0,10859)
[1] 5759 <- (0,10860)
[1] 5760 <- (0,10861)
[1] 5761 <- (0,10862)
[1] 5762 <- (0,10863)
[1] 5763 <- (0,10864)
[1] 5764 <- (0,10865)
[1] 5765 <- (0,10866)
[1] 5766 <- (0,10894)
[1] 5767 <- (0,10895)
[1] 5768 <- (0,10896)
[1] 5769 <- (0,10897)
[1] 5770 <- (0,10898)
[1] 5771 <- (0,10899)
[1] 5772 <- (0,10900)
[1] 5773 <- (0,10901)
[1] 5774 <- (0,10902)
[1] 5775 <- (0,10903)
[1] 5776 <- (0,10904)
[1] 5777 <- (0,10905)
[1] 5778 <- (0,10906)
[1] 5779 <- (0,10907)
[1] 5780 <- (0,10908)
[1] 5781 <- (0,10909)
[1] 5782 <- (0,10910)
[1] 5783 <- (0,10911)
[1] 5784 <- (0,10912)
[1] 5785 <- (0,10913)
[1] 5786 <- (0,10914)
[1] 5787 <- (0,10915)
[1] 5788 <- (0,10916)
[1] 5789 <- (0,10917)
[1] 5790 <- (0,10945)
[1] 5791 <- (0,10946)
[1] 5792 <- (0,10947)
[1] 5793 <- (0,10948)
[1] 5794 <- (0,10949)
[1] 5795 <- (0,10950)
[1] 5796 <- (0,10951)
[1] 5797 <- (0,10952)
[1] 5798 <- (0,10953)
[1] 5799 <- (0,10954)
[1] 5800 <- (0,10955)
[1] 5801 <- (0,10956)
[1] 5802 <- (0,10957)
[1] 5803 <- (0,10958)
[1] 5804 <- (0,10959)
[1] 5805 <- (0,10960)
[1] 5806 <- (0,10961)
[1] 5807 <- (0,10962)
[1] 5808 <- (0,10963)
[1] 5809 <- (0,10964)
[1] 5810 <- (0,10965)
[1] 5811 <- (0,10966)
[1] 5812 <- (0,10967)
[1] 5813 <- (0,10968)
[1] 5814 <- (0,10996)
[1] 5815 <- (0,10997)
[1] 5816 <- (0,10998)
[1] 5817 <- (0,10999)
[1] 5818 <- (0,11000)
[1] 5819 <- (0,11001)
[1] 5820 <- (0,11002)
[1] 5821 <- (0,11003)
[1] 5822 <- (0,11004)
[1] 5823 <- (0,11005)
[1] 5824 <- (0,11006)
[1] 5825 <- (0,11007)
[1] 5826 <- (0,11008)
[1] 5827 <- (0,11009)
[1] 5828 <- (0,11010)
[1] 5829 <- (0,11011)
[1] 5830 <- (0,11012)
[1] 5831 <- (0,11013)
[1] 5832 <- (0,11014)
[1] 5833 <- (0,11015)
[1] 5834 <- (0,11016)
[1] 5835 <- (0,11017)
[1] 5836 <- (0,11018)
[1] 5837 <- (0,11019)
[1] 5838 <- (0,11047)
[1] 5839 <- (0,11048)
[1] 5840 <- (0,11049)
[1] 5841 <- (0,11050)
[1] 5842 <- (0,11051)
[1] 5843 <- (0,11052)
[1] 5844 <- (0,11053)
[1] 5845 <- (0,11054)
[1] 5846 <- (0,11055)
[1] 5847 <- (0,11056)
[1] 5848 <- (0,11057)
[1] 5849 <- (0,11058)
[1] 5850 <- (0,11059)
[1] 5851 <- (0,11060)
[1] 5852 <- (0,11061)
[1] 5853 <- (0,11062)
[1] 5854 <- (0,11063)
[1] 5855 <- (0,11064)
[1] 5856 <- (0,11065)
[1] 5857 <- (0,11066)
[1] 5858 <- (0,11067)
[1] 5859 <- (0,11068)
[1] 5860 <- (0,11069)
[1] 5861 <- (0,11070)
[1] 5862 <- (0,11093)
[1] 5863 <- (0,11094)
[1] 5864 <- (0,11095)
[1] 5865 <- (0,11096)
[1] 5866 <- (0,11097)
[1] 5867 <- (0,11098)
[1] 5868 <- (0,11099)
[1] 5869 <- (0,11100)
[1] 5870 <- (0,11101)
[1] 5871 <- (0,11102)
[1] 5872 <- (0,11103)
[1] 5873 <- (0,11104)
[1] 5874 <- (0,11105)
[1] 5875 <- (0,11106)
[1] 5876 <- (0,11107)
[1] 5877 <- (0,11108)
[1] 5878 <- (0,11109)
[1] 5879 <- (0,11110)
[1] 5880 <- (0,11111)
[1] 5881 <- (0,11112)
[1] 5882 <- (0,11113)
[1] 5883 <- (0,11114)
[1] 5884 <- (0,11115)
[1] 5885 <- (0,11116)
[1] 5886 <- (0,11117)
[1] 5887 <- (0,11118)
[1] 5888 <- (0,11119)
[1] 5889 <- (0,11120)
[1] 5890 <- (0,11121)
[1] 5891 <- (0,11144)
[1] 5892 <- (0,11145)
[1] 5893 <- (0,11146)
[1] 5894 <- (0,11147)
[1] 5895 <- (0,11148)
[1] 5896 <- (0,11149)
[1] 5897 <- (0,11150)
[1] 5898 <- (0,11151)
[1] 5899 <- (0,11152)
[1] 5900 <- (0,11153)
[1] 5901 <- (0,11154)
[1] 5902 <- (0,11155)
[1] 5903 <- (0,11156)
[1] 5904 <- (0,11157)
[1] 5905 <- (0,11158)
[1] 5906 <- (0,11159)
[1] 5907 <- (0,11160)
[1] 5908 <- (0,11161)
[1] 5909 <- (0,11162)
[1] 5910 <- (0,11163)
[1] 5911 <- (0,11164)
[1] 5912 <- (0,11165)
[1] 5913 <- (0,11166)
[1] 5914 <- (0,11167)
[1] 5915 <- (0,11168)
[1] 5916 <- (0,11169)
[1] 5917 <- (0,11170)
[1] 5918 <- (0,11171)
[1] 5919 <- (0,11172)
[1] 5920 <- (0,11195)
[1] 5921 <- (0,11196)
[1] 5922 <- (0,11197)
[1] 5923 <- (0,11198)
[1] 5924 <- (0,11199)
[1] 5925 <- (0,11200)
[1] 5926 <- (0,11201)
[1] 5927 <- (0,11202)
[1] 5928 <- (0,11203)
[1] 5929 <- (0,11204)
[1] 5930 <- (0,11205)
[1] 5931 <- (0,11206)
[1] 5932 <- (0,11207)
[1] 5933 <- (0,11208)
[1] 5934 <- (0,11209)
[1] 5935 <- (0,11210)
[1] 5936 <- (0,11211)
[1] 5937 <- (0,11212)
[1] 5938 <- (0,11213)
[1] 5939 <- (0,11214)
[1] 5940 <- (0,11215)
[1] 5941 <- (0,11216)
[1] 5942 <- (0,11217)
[1] 5943 <- (0,11218)
[1] 5944 <- (0,11219)
[1] 5945 <- (0,11220)
[1] 5946 <- (0,11221)
[1] 5947 <- (0,11222)
[1] 5948 <- (0,11223)
[1] 5949 <- (0,11246)
[1] 5950 <- (0,11247)
[1] 5951 <- (0,11248)
[1] 5952 <- (0,11249)
[1] 5953 <- (0,11250)
[1] 5954 <- (0,11251)
[1] 5955 <- (0,11252)
[1] 5956 <- (0,11253)
[1] 5957 <- (0,11254)
[1] 5958 <- (0,11255)
[1] 5959 <- (0,11256)
[1] 5960 <- (0,11257)
[1] 5961 <- (0,11258)
[1] 5962 <- (0,11259)
[1] 5963 <- (0,11260)
[1] 5964 <- (0,11261)
[1] 5965 <- (0,11262)
[1] 5966 <- (0,11263)
[1] 5967 <- (0,11264)
[1] 5968 <- (0,11265)
[1] 5969 <- (0,11266)
[1] 5970 <- (0,11267)
[1] 5971 <- (0,11268)
[1] 5972 <- (0,11269)
[1] 5973 <- (0,11270)
[1] 5974 <- (0,11271)
[1] 5975 <- (0,11272)
[1] 5976 <- (0,11273)
[1] 5977 <- (0,11274)
[1] 5978 <- (0,11297)
[1] 5979 <- (0,11298)
[1] 5980 <- (0,11299)
[1] 5981 <- (0,11300)
[1] 5982 <- (0,11301)
[1] 5983 <- (0,11302)
[1] 5984 <- (0,11303)
[1] 5985 <- (0,11304)
[1] 5986 <- (0,11305)
[1] 5987 <- (0,11306)
[1] 5988 <- (0,11307)
[1] 5989 <- (0,11308)
[1] 5990 <- (0,11309)
[1] 5991 <- (0,11310)
[1] 5992 <- (0,11311)
[1] 5993 <- (0,11312)
[1] 5994 <- (0,11313)
[1] 5995 <- (0,11314)
[1] 5996 <- (0,11315)
[1] 5997 <- (0,11316)
[1] 5998 <- (0,11317)
[1] 5999 <- (0,11318)
[1] 6000 <- (0,11319)
[1] 6001 <- (0,11320)
[1] 6002 <- (0,11321)
[1] 6003 <- (0,11322)
[1] 6004 <- (0,11323)
[1] 6005 <- (0,11324)
[1] 6006 <- (0,11325)
[1] 6007 <- (0,11349)
[1] 6008 <- (0,11350)
[1] 6009 <- (0,11351)
[1] 6010 <- (0,11352)
[1] 6011 <- (0,11353)
[1] 6012 <- (0,11354)
[1] 6013 <- (0,11355)
[1] 6014 <- (0,11356)
[1] 6015 <- (0,11357)
[1] 6016 <- (0,11358)
[1] 6017 <- (0,11359)
[1] 6018 <- (0,11360)
[1] 6019 <- (0,11361)
[1] 6020 <- (0,11362)
[1] 6021 <- (0,11363)
[1] 6022 <- (0,11364)
[1] 6023 <- (0,11365)
[1] 6024 <- (0,11366)
[1] 6025 <- (0,11367)
[1] 6026 <- (0,11368)
[1] 6027 <- (0,11369)
[1] 6028 <- (0,11370)
[1] 6029 <- (0,11371)
[1] 6030 <- (0,11372)
[1] 6031 <- (0,11373)
[1] 6032 <- (0,11374)
[1] 6033 <- (0,11375)
[1] 6034 <- (0,11376)
[1] 6035 <- (0,11400)
[1] 6036 <- (0,11401)
[1] 6037 <- (0,11402)
[1] 6038 <- (0,11403)
[1] 6039 <- (0,11404)
[1] 6040 <- (0,11405)
[1] 6041 <- (0,11406)
[1] 6042 <- (0,11407)
[1] 6043 <- (0,11408)
[1] 6044 <- (0,11409)
[1] 6045 <- (0,11410)
[1] 6046 <- (0,11411)
[1] 6047 <- (0,11412)
[1] 6048 <- (0,11413)
[1] 6049 <- (0,11414)
[1] 6050 <- (0,11415)
[1] 6051 <- (0,11416)
[1] 6052 <- (0,11417)
[1] 6053 <- (0,11418)
[1] 6054 <- (0,11419)
[1] 6055 <- (0,11420)
[1] 6056 <- (0,11421)
[1] 6057 <- (0,11422)
[1] 6058 <- (0,11423)
[1] 6059 <- (0,11424)
[1] 6060 <- (0,11425)
[1] 6061 <- (0,11426)
[1] 6062 <- (0,11427)
[1] 6063 <- (0,11451)
[1] 6064 <- (0,11452)
[1] 6065 <- (0,11453)
[1] 6066 <- (0,11454)
[1] 6067 <- (0,11455)
[1] 6068 <- (0,11456)
[1] 6069 <- (0,11457)
[1] 6070 <- (0,11458)
[1] 6071 <- (0,11459)
[1] 6072 <- (0,11460)
[1] 6073 <- (0,11461)
[1] 6074 <- (0,11462)
[1] 6075 <- (0,11463)
[1] 6076 <- (0,11464)
[1] 6077 <- (0,11465)
[1] 6078 <- (0,11466)
[1] 6079 <- (0,11467)
[1] 6080 <- (0,11468)
[1] 6081 <- (0,11469)
[1] 6082 <- (0,11470)
[1] 6083 <- (0,11471)
[1] 6084 <- (0,11472)
[1] 6085 <- (0,11473)
[1] 6086 <- (0,11474)
[1] 6087 <- (0,11475)
[1] 6088 <- (0,11476)
[1] 6089 <- (0,11477)
[1] 6090 <- (0,11478)
[1] 6091 <- (0,11502)
[1] 6092 <- (0,11503)
[1] 6093 <- (0,11504)
[1] 6094 <- (0,11505)
[1] 6095 <- (0,11506)
[1] 6096 <- (0,11507)
[1] 6097 <- (0,11508)
[1] 6098 <- (0,11509)
[1] 6099 <- (0,11510)
[1] 6100 <- (0,11511)
[1] 6101 <- (0,11512)
[1] 6102 <- (0,11513)
[1] 6103 <- (0,11514)
[1] 6104 <- (0,11515)
[1] 6105 <- (0,11516)
[1] 6106 <- (0,11517)
[1] 6107 <- (0,11518)
[1] 6108 <- (0,11519)
[1] 6109 <- (0,11520)
[1] 6110 <- (0,11521)
[1] 6111 <- (0,11522)
[1] 6112 <- (0,11523)
[1] 6113 <- (0,11524)
[1] 6114 <- (0,11525)
[1] 6115 <- (0,11526)
[1] 6116 <- (0,11527)
[1] 6117 <- (0,11528)
[1] 6118 <- (0,11529)
[1] 6119 <- (0,11554)
[1] 6120 <- (0,11555)
[1] 6121 <- (0,11556)
[1] 6122 <- (0,11557)
[1] 6123 <- (0,11558)
[1] 6124 <- (0,11559)
[1] 6125 <- (0,11560)
[1] 6126 <- (0,11561)
[1] 6127 <- (0,11562)
[1] 6128 <- (0,11563)
[1] 6129 <- (0,11564)
[1] 6130 <- (0,11565)
[1] 6131 <- (0,11566)
[1] 6132 <- (0,11567)
[1] 6133 <- (0,11568)
[1] 6134 <- (0,11569)
[1] 6135 <- (0,11570)
[1] 6136 <- (0,11571)
[1] 6137 <- (0,11572)
[1] 6138 <- (0,11573)
[1] 6139 <- (0,11574)
[1] 6140 <- (0,11575)
[1] 6141 <- (0,11576)
[1] 6142 <- (0,11577)
[1] 6143 <- (0,11578)
[1] 6144 <- (0,11579)
[1] 6145 <- (0,11580)
[1] 6146 <- (0,11605)
[1] 6147 <- (0,11606)
[1] 6148 <- (0,11607)
[1] 6149 <- (0,11608)
[1] 6150 <- (0,11609)
[1] 6151 <- (0,11610)
[1] 6152 <- (0,11611)
[1] 6153 <- (0,11612)
[1] 6154 <- (0,11613)
[1] 6155 <- (0,11614)
[1] 6156 <- (0,11615)
[1] 6157 <- (0,11616)
[1] 6158 <- (0,11617)
[1] 6159 <- (0,11618)
[1] 6160 <- (0,11619)
[1] 6161 <- (0,11620)
[1] 6162 <- (0,11621)
[1] 6163 <- (0,11622)
[1] 6164 <- (0,11623)
[1] 6165 <- (0,11624)
[1] 6166 <- (0,11625)
[1] 6167 <- (0,11626)
[1] 6168 <- (0,11627)
[1] 6169 <- (0,11628)
[1] 6170 <- (0,11629)
[1] 6171 <- (0,11630)
[1] 6172 <- (0,11631)
[1] 6173 <- (0,11657)
[1] 6174 <- (0,11658)
[1] 6175 <- (0,11659)
[1] 6176 <- (0,11660)
[1] 6177 <- (0,11661)
[1] 6178 <- (0,11662)
[1] 6179 <- (0,11663)
[1] 6180 <- (0,11664)
[1] 6181 <- (0,11665)
[1] 6182 <- (0,11666)
[1] 6183 <- (0,11667)
[1] 6184 <- (0,11668)
[1] 6185 <- (0,11669)
[1] 6186 <- (0,11670)
[1] 6187 <- (0,11671)
[1] 6188 <- (0,11672)
[1] 6189 <- (0,11673)
[1] 6190 <- (0,11674)
[1] 6191 <- (0,11675)
[1] 6192 <- (0,11676)
[1] 6193 <- (0,11677)
[1] 6194 <- (0,11678)
[1] 6195 <- (0,11679)
[1] 6196 <- (0,11680)
[1] 6197 <- (0,11681)
[1] 6198 <- (0,11682)
[1] 6199 <- (0,11709)
[1] 6200 <- (0,11710)
[1] 6201 <- (0,11711)
[1] 6202 <- (0,11712)
[1] 6203 <- (0,11713)
[1] 6204 <- (0,11714)
[1] 6205 <- (0,11715)
[1] 6206 <- (0,11716)
[1] 6207 <- (0,11717)
[1] 6208 <- (0,11718)
[1] 6209 <- (0,11719)
[1] 6210 <- (0,11720)
[1] 6211 <- (0,11721)
[1] 6212 <- (0,11722)
[1] 6213 <- (0,11723)
[1] 6214 <- (0,11724)
[1] 6215 <- (0,11725)
[1] 6216 <- (0,11726)
[1] 6217 <- (0,11727)
[1] 6218 <- (0,11728)
[1] 6219 <- (0,11729)
[1] 6220 <- (0,11730)
[1] 6221 <- (0,11731)
[1] 6222 <- (0,11732)
[1] 6223 <- (0,11733)
[1] 6224 <- (0,11760)
[1] 6225 <- (0,11761)
[1] 6226 <- (0,11762)
[1] 6227 <- (0,11763)
[1] 6228 <- (0,11764)
[1] 6229 <- (0,11765)
[1] 6230 <- (0,11766)
[1] 6231 <- (0,11767)
[1] 6232 <- (0,11768)
[1] 6233 <- (0,11769)
[1] 6234 <- (0,11770)
[1] 6235 <- (0,11771)
[1] 6236 <- (0,11772)
[1] 6237 <- (0,11773)
[1] 6238 <- (0,11774)
[1] 6239 <- (0,11775)
[1] 6240 <- (0,11776)
[1] 6241 <- (0,11777)
[1] 6242 <- (0,11778)
[1] 6243 <- (0,11779)
[1] 6244 <- (0,11780)
[1] 6245 <- (0,11781)
[1] 6246 <- (0,11782)
[1] 6247 <- (0,11783)
[1] 6248 <- (0,11784)
[1] 6249 <- (0,11812)
[1] 6250 <- (0,11813)
[1] 6251 <- (0,11814)
[1] 6252 <- (0,11815)
[1] 6253 <- (0,11816)
[1] 6254 <- (0,11817)
[1] 6255 <- (0,11818)
[1] 6256 <- (0,11819)
[1] 6257 <- (0,11820)
[1] 6258 <- (0,11821)
[1] 6259 <- (0,11822)
[1] 6260 <- (0,11823)
[1] 6261 <- (0,11824)
[1] 6262 <- (0,11825)
[1] 6263 <- (0,11826)
[1] 6264 <- (0,11827)
[1] 6265 <- (0,11828)
[1] 6266 <- (0,11829)
[1] 6267 <- (0,11830)
[1] 6268 <- (0,11831)
[1] 6269 <- (0,11832)
[1] 6270 <- (0,11833)
[1] 6271 <- (0,11834)
[1] 6272 <- (0,11835)
[1] 6273 <- (0,11863)
[1] 6274 <- (0,11864)
[1] 6275 <- (0,11865)
[1] 6276 <- (0,11866)
[1] 6277 <- (0,11867)
[1] 6278 <- (0,11868)
[1] 6279 <- (0,11869)
[1] 6280 <- (0,11870)
[1] 6281 <- (0,11871)
[1] 6282 <- (0,11872)
[1] 6283 <- (0,11873)
[1] 6284 <- (0,11874)
[1] 6285 <- (0,11875)
[1] 6286 <- (0,11876)
[1] 6287 <- (0,11877)
[1] 6288 <- (0,11878)
[1] 6289 <- (0,11879)
[1] 6290 <- (0,11880)
[1] 6291 <- (0,11881)
[1] 6292 <- (0,11882)
[1] 6293 <- (0,11883)
[1] 6294 <- (0,11884)
[1] 6295 <- (0,11885)
[1] 6296 <- (0,11886)
[1] 6297 <- (0,11914)
[1] 6298 <- (0,11915)
[1] 6299 <- (0,11916)
[1] 6300 <- (0,11917)
[1] 6301 <- (0,11918)
[1] 6302 <- (0,11919)
[1] 6303 <- (0,11920)
[1] 6304 <- (0,11921)
[1] 6305 <- (0,11922)
[1] 6306 <- (0,11923)
[1] 6307 <- (0,11924)
[1] 6308 <- (0,11925)
[1] 6309 <- (0,11926)
[1] 6310 <- (0,11927)
[1] 6311 <- (0,11928)
[1] 6312 <- (0,11929)
[1] 6313 <- (0,11930)
[1] 6314 <- (0,11931)
[1] 6315 <- (0,11932)
[1] 6316 <- (0,11933)
[1] 6317 <- (0,11934)
[1] 6318 <- (0,11935)
[1] 6319 <- (0,11936)
[1] 6320 <- (0,11937)
[1] 6321 <- (0,11965)
[1] 6322 <- (0,11966)
[1] 6323 <- (0,11967)
[1] 6324 <- (0,11968)
[1] 6325 <- (0,11969)
[1] 6326 <- (0,11970)
[1] 6327 <- (0,11971)
[1] 6328 <- (0,11972)
[1] 6329 <- (0,11973)
[1] 6330 <- (0,11974)
[1] 6331 <- (0,11975)
[1] 6332 <- (0,11976)
[1] 6333 <- (0,11977)
[1] 6334 <- (0,11978)
[1] 6335 <- (0,11979)
[1] 6336 <- (0,11980)
[1] 6337 <- (0,11981)
[1] 6338 <- (0,11982)
[1] 6339 <- (0,11983)
[1] 6340 <- (0,11984)
[1] 6341 <- (0,11985)
[1] 6342 <- (0,11986)
[1] 6343 <- (0,11987)
[1] 6344 <- (0,11988)
[1] 6345 <- (0,12016)
[1] 6346 <- (0,12017)
[1] 6347 <- (0,12018)
[1] 6348 <- (0,12019)
[1] 6349 <- (0,12020)
[1] 6350 <- (0,12021)
[1] 6351 <- (0,12022)
[1] 6352 <- (0,12023)
[1] 6353 <- (0,12024)
[1] 6354 <- (0,12025)
[1] 6355 <- (0,12026)
[1] 6356 <- (0,12027)
[1] 6357 <- (0,12028)
[1] 6358 <- (0,12029)
[1] 6359 <- (0,12030)
[1] 6360 <- (0,12031)
[1] 6361 <- (0,12032)
[1] 6362 <- (0,12033)
[1] 6363 <- (0,12034)
[1] 6364 <- (0,12035)
[1] 6365 <- (0,12036)
[1] 6366 <- (0,12037)
[1] 6367 <- (0,12038)
[1] 6368 <- (0,12039)
[1] 6369 <- (0,12067)
[1] 6370 <- (0,12068)
[1] 6371 <- (0,12069)
[1] 6372 <- (0,12070)
[1] 6373 <- (0,12071)
[1] 6374 <- (0,12072)
[1] 6375 <- (0,12073)
[1] 6376 <- (0,12074)
[1] 6377 <- (0,12075)
[1] 6378 <- (0,12076)
[1] 6379 <- (0,12077)
[1] 6380 <- (0,12078)
[1] 6381 <- (0,12079)
[1] 6382 <- (0,12080)
[1] 6383 <- (0,12081)
[1] 6384 <- (0,12082)
[1] 6385 <- (0,12083)
[1] 6386 <- (0,12084)
[1] 6387 <- (0,12085)
[1] 6388 <- (0,12086)
[1] 6389 <- (0,12087)
[1] 6390 <- (0,12088)
[1] 6391 <- (0,12089)
[1] 6392 <- (0,12090)
[1] 6393 <- (0,12118)
[1] 6394 <- (0,12119)
[1] 6395 <- (0,12120)
[1] 6396 <- (0,12121)
[1] 6397 <- (0,12122)
[1] 6398 <- (0,12123)
[1] 6399 <- (0,12124)
[1] 6400 <- (0,12125)
[1] 6401 <- (0,12126)
[1] 6402 <- (0,12127)
[1] 6403 <- (0,12128)
[1] 6404 <- (0,12129)
[1] 6405 <- (0,12130)
[1] 6406 <- (0,12131)
[1] 6407 <- (0,12132)
[1] 6408 <- (0,12133)
[1] 6409 <- (0,12134)
[1] 6410 <- (0,12135)
[1] 6411 <- (0,12136)
[1] 6412 <- (0,12137)
[1] 6413 <- (0,12138)
[1] 6414 <- (0,12139)
[1] 6415 <- (0,12140)
[1] 6416 <- (0,12141)
[1] 6417 <- (0,12164)
[1] 6418 <- (0,12165)
[1] 6419 <- (0,12166)
[1] 6420 <- (0,12167)
[1] 6421 <- (0,12168)
[1] 6422 <- (0,12169)
[1] 6423 <- (0,12170)
[1] 6424 <- (0,12171)
[1] 6425 <- (0,12172)
[1] 6426 <- (0,12173)
[1] 6427 <- (0,12174)
[1] 6428 <- (0,12175)
[1] 6429 <- (0,12176)
[1] 6430 <- (0,12177)
[1] 6431 <- (0,12178)
[1] 6432 <- (0,12179)
[1] 6433 <- (0,12180)
[1] 6434 <- (0,12181)
[1] 6435 <- (0,12182)
[1] 6436 <- (0,12183)
[1] 6437 <- (0,12184)
[1] 6438 <- (0,12185)
[1] 6439 <- (0,12186)
[1] 6440 <- (0,12187)
[1] 6441 <- (0,12188)
[1] 6442 <- (0,12189)
[1] 6443 <- (0,12190)
[1] 6444 <- (0,12191)
[1] 6445 <- (0,12192)
[1] 6446 <- (0,12215)
[1] 6447 <- (0,12216)
[1] 6448 <- (0,12217)
[1] 6449 <- (0,12218)
[1] 6450 <- (0,12219)
[1] 6451 <- (0,12220)
[1] 6452 <- (0,12221)
[1] 6453 <- (0,12222)
[1] 6454 <- (0,12223)
[1] 6455 <- (0,12224)
[1] 6456 <- (0,12225)
[1] 6457 <- (0,12226)
[1] 6458 <- (0,12227)
[1] 6459 <- (0,12228)
[1] 6460 <- (0,12229)
[1] 6461 <- (0,12230)
[1] 6462 <- (0,12231)
[1] 6463 <- (0,12232)
[1] 6464 <- (0,12233)
[1] 6465 <- (0,12234)
[1] 6466 <- (0,12235)
[1] 6467 <- (0,12236)
[1] 6468 <- (0,12237)
[1] 6469 <- (0,12238)
[1] 6470 <- (0,12239)
[1] 6471 <- (0,12240)
[1] 6472 <- (0,12241)
[1] 6473 <- (0,12242)
[1] 6474 <- (0,12243)
[1] 6475 <- (0,12266)
[1] 6476 <- (0,12267)
[1] 6477 <- (0,12268)
[1] 6478 <- (0,12269)
[1] 6479 <- (0,12270)
[1] 6480 <- (0,12271)
[1] 6481 <- (0,12272)
[1] 6482 <- (0,12273)
[1] 6483 <- (0,12274)
[1] 6484 <- (0,12275)
[1] 6485 <- (0,12276)
[1] 6486 <- (0,12277)
[1] 6487 <- (0,12278)
[1] 6488 <- (0,12279)
[1] 6489 <- (0,12280)
[1] 6490 <- (0,12281)
[1] 6491 <- (0,12282)
[1] 6492 <- (0,12283)
[1] 6493 <- (0,12284)
[1] 6494 <- (0,12285)
[1] 6495 <- (0,12286)
[1] 6496 <- (0,12287)
[1] 6497 <- (0,12288)
[1] 6498 <- (0,12289)
[1] 6499 <- (0,12290)
[1] 6500 <- (0,12291)
[1] 6501 <- (0,12292)
[1] 6502 <- (0,12293)
[1] 6503 <- (0,12294)
[1] 6504 <- (0,12317)
[1] 6505 <- (0,12318)
[1] 6506 <- (0,12319)
[1] 6507 <- (0,12320)
[1] 6508 <- (0,12321)
[1] 6509 <- (0,12322)
[1] 6510 <- (0,12323)
[1] 6511 <- (0,12324)
[1] 6512 <- (0,12325)
[1] 6513 <- (0,12326)
[1] 6514 <- (0,12327)
[1] 6515 <- (0,12328)
[1] 6516 <- (0,12329)
[1] 6517 <- (0,12330)
[1] 6518 <- (0,12331)
[1] 6519 <- (0,12332)
[1] 6520 <- (0,12333)
[1] 6521 <- (0,12334)
[1] 6522 <- (0,12335)
[1] 6523 <- (0,12336)
[1] 6524 <- (0,12337)
[1] 6525 <- (0,12338)
[1] 6526 <- (0,12339)
[1] 6527 <- (0,12340)
[1] 6528 <- (0,12341)
[1] 6529 <- (0,12342)
[1] 6530 <- (0,12343)
[1] 6531 <- (0,12344)
[1] 6532 <- (0,12345)
[1] 6533 <- (0,12368)
[1] 6534 <- (0,12369)
[1] 6535 <- (0,12370)
[1] 6536 <- (0,12371)
[1] 6537 <- (0,12372)
[1] 6538 <- (0,12373)
[1] 6539 <- (0,12374)
[1] 6540 <- (0,12375)
[1] 6541 <- (0,12376)
[1] 6542 <- (0,12377)
[1] 6543 <- (0,12378)
[1] 6544 <- (0,12379)
[1] 6545 <- (0,12380)
[1] 6546 <- (0,12381)
[1] 6547 <- (0,12382)
[1] 6548 <- (0,12383)
[1] 6549 <- (0,12384)
[1] 6550 <- (0,12385)
[1] 6551 <- (0,12386)
[1] 6552 <- (0,12387)
[1] 6553 <- (0,12388)
[1] 6554 <- (0,12389)
[1] 6555 <- (0,12390)
[1] 6556 <- (0,12391)
[1] 6557 <- (0,12392)
[1] 6558 <- (0,12393)
[1] 6559 <- (0,12394)
[1] 6560 <- (0,12395)
[1] 6561 <- (0,12396)
[1] 6562 <- (0,12420)
[1] 6563 <- (0,12421)
[1] 6564 <- (0,12422)
[1] 6565 <- (0,12423)
[1] 6566 <- (0,12424)
[1] 6567 <- (0,12425)
[1] 6568 <- (0,12426)
[1] 6569 <- (0,12427)
[1] 6570 <- (0,12428)
[1] 6571 <- (0,12429)
[1] 6572 <- (0,12430)
[1] 6573 <- (0,12431)
[1] 6574 <- (0,12432)
[1] 6575 <- (0,12433)
[1] 6576 <- (0,12434)
[1] 6577 <- (0,12435)
[1] 6578 <- (0,12436)
[1] 6579 <- (0,12437)
[1] 6580 <- (0,12438)
[1] 6581 <- (0,12439)
[1] 6582 <- (0,12440)
[1] 6583 <- (0,12441)
[1] 6584 <- (0,12442)
[1] 6585 <- (0,12443)
[1] 6586 <- (0,12444)
[1] 6587 <- (0,12445)
[1] 6588 <- (0,12446)
[1] 6589 <- (0,12447)
[1] 6590 <- (0,12471)
[1] 6591 <- (0,12472)
[1] 6592 <- (0,12473)
[1] 6593 <- (0,12474)
[1] 6594 <- (0,12475)
[1] 6595 <- (0,12476)
[1] 6596 <- (0,12477)
[1] 6597 <- (0,12478)
[1] 6598 <- (0,12479)
[1] 6599 <- (0,12480)
[1] 6600 <- (0,12481)
[1] 6601 <- (0,12482)
[1] 6602 <- (0,12483)
[1] 6603 <- (0,12484)
[1] 6604 <- (0,12485)
[1] 6605 <- (0,12486)
[1] 6606 <- (0,12487)
[1] 6607 <- (0,12488)
[1] 6608 <- (0,12489)
[1] 6609 <- (0,12490)
[1] 6610 <- (0,12491)
[1] 6611 <- (0,12492)
[1] 6612 <- (0,12493)
[1] 6613 <- (0,12494)
[1] 6614 <- (0,12495)
[1] 6615 <- (0,12496)
[1] 6616 <- (0,12497)
[1] 6617 <- (0,12498)
[1] 6618 <- (0,12522)
[1] 6619 <- (0,12523)
[1] 6620 <- (0,12524)
[1] 6621 <- (0,12525)
[1] 6622 <- (0,12526)
[1] 6623 <- (0,12527)
[1] 6624 <- (0,12528)
[1] 6625 <- (0,12529)
[1] 6626 <- (0,12530)
[1] 6627 <- (0,12531)
[1] 6628 <- (0,12532)
[1] 6629 <- (0,12533)
[1] 6630 <- (0,12534)
[1] 6631 <- (0,12535)
[1] 6632 <- (0,12536)
[1] 6633 <- (0,12537)
[1] 6634 <- (0,12538)
[1] 6635 <- (0,12539)
[1] 6636 <- (0,12540)
[1] 6637 <- (0,12541)
[1] 6638 <- (0,12542)
[1] 6639 <- (0,12543)
[1] 6640 <- (0,12544)
[1] 6641 <- (0,12545)
[1] 6642 <- (0,12546)
[1] 6643 <- (0,12547)
[1] 6644 <- (0,12548)
[1] 6645 <- (0,12549)
[1] 6646 <- (0,12573)
[1] 6647 <- (0,12574)
[1] 6648 <- (0,12575)
[1] 6649 <- (0,12576)
[1] 6650 <- (0,12577)
[1] 6651 <- (0,12578)
[1] 6652 <- (0,12579)
[1] 6653 <- (0,12580)
[1] 6654 <- (0,12581)
[1] 6655 <- (0,12582)
[1] 6656 <- (0,12583)
[1] 6657 <- (0,12584)
[1] 6658 <- (0,12585)
[1] 6659 <- (0,12586)
[1] 6660 <- (0,12587)
[1] 6661 <- (0,12588)
[1] 6662 <- (0,12589)
[1] 6663 <- (0,12590)
[1] 6664 <- (0,12591)
[1] 6665 <- (0,12592)
[1] 6666 <- (0,12593)
[1] 6667 <- (0,12594)
[1] 6668 <- (0,12595)
[1] 6669 <- (0,12596)
[1] 6670 <- (0,12597)
[1] 6671 <- (0,12598)
[1] 6672 <- (0,12599)
[1] 6673 <- (0,12600)
[1] 6674 <- (0,12625)
[1] 6675 <- (0,12626)
[1] 6676 <- (0,12627)
[1] 6677 <- (0,12628)
[1] 6678 <- (0,12629)
[1] 6679 <- (0,12630)
[1] 6680 <- (0,12631)
[1] 6681 <- (0,12632)
[1] 6682 <- (0,12633)
[1] 6683 <- (0,12634)
[1] 6684 <- (0,12635)
[1] 6685 <- (0,12636)
[1] 6686 <- (0,12637)
[1] 6687 <- (0,12638)
[1] 6688 <- (0,12639)
[1] 6689 <- (0,12640)
[1] 6690 <- (0,12641)
[1] 6691 <- (0,12642)
[1] 6692 <- (0,12643)
[1] 6693 <- (0,12644)
[1] 6694 <- (0,12645)
[1] 6695 <- (0,12646)
[1] 6696 <- (0,12647)
[1] 6697 <- (0,12648)
[1] 6698 <- (0,12649)
[1] 6699 <- (0,12650)
[1] 6700 <- (0,12651)
[1] 6701 <- (0,12676)
[1] 6702 <- (0,12677)
[1] 6703 <- (0,12678)
[1] 6704 <- (0,12679)
[1] 6705 <- (0,12680)
[1] 6706 <- (0,12681)
[1] 6707 <- (0,12682)
[1] 6708 <- (0,12683)
[1] 6709 <- (0,12684)
[1] 6710 <- (0,12685)
[1] 6711 <- (0,12686)
[1] 6712 <- (0,12687)
[1] 6713 <- (0,12688)
[1] 6714 <- (0,12689)
[1] 6715 <- (0,12690)
[1] 6716 <- (0,12691)
[1] 6717 <- (0,12692)
[1] 6718 <- (0,12693)
[1] 6719 <- (0,12694)
[1] 6720 <- (0,12695)
[1] 6721 <- (0,12696)
[1] 6722 <- (0,12697)
[1] 6723 <- (0,12698)
[1] 6724 <- (0,12699)
[1] 6725 <- (0,12700)
[1] 6726 <- (0,12701)
[1] 6727 <- (0,12702)
[1] 6728 <- (0,12728)
[1] 6729 <- (0,12729)
[1] 6730 <- (0,12730)
[1] 6731 <- (0,12731)
[1] 6732 <- (0,12732)
[1] 6733 <- (0,12733)
[1] 6734 <- (0,12734)
[1] 6735 <- (0,12735)
[1] 6736 <- (0,12736)
[1] 6737 <- (0,12737)
[1] 6738 <- (0,12738)
[1] 6739 <- (0,12739)
[1] 6740 <- (0,12740)
[1] 6741 <- (0,12741)
[1] 6742 <- (0,12742)
[1] 6743 <- (0,12743)
[1] 6744 <- (0,12744)
[1] 6745 <- (0,12745)
[1] 6746 <- (0,12746)
[1] 6747 <- (0,12747)
[1] 6748 <- (0,12748)
[1] 6749 <- (0,12749)
[1] 6750 <- (0,12750)
[1] 6751 <- (0,12751)
[1] 6752 <- (0,12752)
[1] 6753 <- (0,12753)
[1] 6754 <- (0,12780)
[1] 6755 <- (0,12781)
[1] 6756 <- (0,12782)
[1] 6757 <- (0,12783)
[1] 6758 <- (0,12784)
[1] 6759 <- (0,12785)
[1] 6760 <- (0,12786)
[1] 6761 <- (0,12787)
[1] 6762 <- (0,12788)
[1] 6763 <- (0,12789)
[1] 6764 <- (0,12790)
[1] 6765 <- (0,12791)
[1] 6766 <- (0,12792)
[1] 6767 <- (0,12793)
[1] 6768 <- (0,12794)
[1] 6769 <- (0,12795)
[1] 6770 <- (0,12796)
[1] 6771 <- (0,12797)
[1] 6772 <- (0,12798)
[1] 6773 <- (0,12799)
[1] 6774 <- (0,12800)
[1] 6775 <- (0,12801)
[1] 6776 <- (0,12802)
[1] 6777 <- (0,12803)
[1] 6778 <- (0,12804)
[1] 6779 <- (0,12831)
[1] 6780 <- (0,12832)
[1] 6781 <- (0,12833)
[1] 6782 <- (0,12834)
[1] 6783 <- (0,12835)
[1] 6784 <- (0,12836)
[1] 6785 <- (0,12837)
[1] 6786 <- (0,12838)
[1] 6787 <- (0,12839)
[1] 6788 <- (0,12840)
[1] 6789 <- (0,12841)
[1] 6790 <- (0,12842)
[1] 6791 <- (0,12843)
[1] 6792 <- (0,12844)
[1] 6793 <- (0,12845)
[1] 6794 <- (0,12846)
[1] 6795 <- (0,12847)
[1] 6796 <- (0,12848)
[1] 6797 <- (0,12849)
[1] 6798 <- (0,12850)
[1] 6799 <- (0,12851)
[1] 6800 <- (0,12852)
[1] 6801 <- (0,12853)
[1] 6802 <- (0,12854)
[1] 6803 <- (0,12855)
[1] 6804 <- (0,12883)
[1] 6805 <- (0,12884)
[1] 6806 <- (0,12885)
[1] 6807 <- (0,12886)
[1] 6808 <- (0,12887)
[1] 6809 <- (0,12888)
[1] 6810 <- (0,12889)
[1] 6811 <- (0,12890)
[1] 6812 <- (0,12891)
[1] 6813 <- (0,12892)
[1] 6814 <- (0,12893)
[1] 6815 <- (0,12894)
[1] 6816 <- (0,12895)
[1] 6817 <- (0,12896)
[1] 6818 <- (0,12897)
[1] 6819 <- (0,12898)
[1] 6820 <- (0,12899)
[1] 6821 <- (0,12900)
[1] 6822 <- (0,12901)
[1] 6823 <- (0,12902)
[1] 6824 <- (0,12903)
[1] 6825 <- (0,12904)
[1] 6826 <- (0,12905)
[1] 6827 <- (0,12906)
[1] 6828 <- (0,12934)
[1] 6829 <- (0,12935)
[1] 6830 <- (0,12936)
[1] 6831 <- (0,12937)
[1] 6832 <- (0,12938)
[1] 6833 <- (0,12939)
[1] 6834 <- (0,12940)
[1] 6835 <- (0,12941)
[1] 6836 <- (0,12942)
[1] 6837 <- (0,12943)
[1] 6838 <- (0,12944)
[1] 6839 <- (0,12945)
[1] 6840 <- (0,12946)
[1] 6841 <- (0,12947)
[1] 6842 <- (0,12948)
[1] 6843 <- (0,12949)
[1] 6844 <- (0,12950)
[1] 6845 <- (0,12951)
[1] 6846 <- (0,12952)
[1] 6847 <- (0,12953)
[1] 6848 <- (0,12954)
[1] 6849 <- (0,12955)
[1] 6850 <- (0,12956)
[1] 6851 <- (0,12957)
[1] 6852 <- (0,12985)
[1] 6853 <- (0,12986)
[1] 6854 <- (0,12987)
[1] 6855 <- (0,12988)
[1] 6856 <- (0,12989)
[1] 6857 <- (0,12990)
[1] 6858 <- (0,12991)
[1] 6859 <- (0,12992)
[1] 6860 <- (0,12993)
[1] 6861 <- (0,12994)
[1] 6862 <- (0,12995)
[1] 6863 <- (0,12996)
[1] 6864 <- (0,12997)
[1] 6865 <- (0,12998)
[1] 6866 <- (0,12999)
[1] 6867 <- (0,13000)
[1] 6868 <- (0,13001)
[1] 6869 <- (0,13002)
[1] 6870 <- (0,13003)
[1] 6871 <- (0,13004)
[1] 6872 <- (0,13005)
[1] 6873 <- (0,13006)
[1] 6874 <- (0,13007)
[1] 6875 <- (0,13008)
[1] 6876 <- (0,13036)
[1] 6877 <- (0,13037)
[1] 6878 <- (0,13038)
[1] 6879 <- (0,13039)
[1] 6880 <- (0,13040)
[1] 6881 <- (0,13041)
[1] 6882 <- (0,13042)
[1] 6883 <- (0,13043)
[1] 6884 <- (0,13044)
[1] 6885 <- (0,13045)
[1] 6886 <- (0,13046)
[1] 6887 <- (0,13047)
[1] 6888 <- (0,13048)
[1] 6889 <- (0,13049)
[1] 6890 <- (0,13050)
[1] 6891 <- (0,13051)
[1] 6892 <- (0,13052)
[1] 6893 <- (0,13053)
[1] 6894 <- (0,13054)
[1] 6895 <- (0,13055)
[1] 6896 <- (0,13056)
[1] 6897 <- (0,13057)
[1] 6898 <- (0,13058)
[1] 6899 <- (0,13059)
[1] 6900 <- (0,13087)
[1] 6901 <- (0,13088)
[1] 6902 <- (0,13089)
[1] 6903 <- (0,13090)
[1] 6904 <- (0,13091)
[1] 6905 <- (0,13092)
[1] 6906 <- (0,13093)
[1] 6907 <- (0,13094)
[1] 6908 <- (0,13095)
[1] 6909 <- (0,13096)
[1] 6910 <- (0,13097)
[1] 6911 <- (0,13098)
[1] 6912 <- (0,13099)
[1] 6913 <- (0,13100)
[1] 6914 <- (0,13101)
[1] 6915 <- (0,13102)
[1] 6916 <- (0,13103)
[1] 6917 <- (0,13104)
[1] 6918 <- (0,13105)
[1] 6919 <- (0,13106)
[1] 6920 <- (0,13107)
[1] 6921 <- (0,13108)
[1] 6922 <- (0,13109)
[1] 6923 <- (0,13110)
[1] 6924 <- (0,13138)
[1] 6925 <- (0,13139)
[1] 6926 <- (0,13140)
[1] 6927 <- (0,13141)
[1] 6928 <- (0,13142)
[1] 6929 <- (0,13143)
[1] 6930 <- (0,13144)
[1] 6931 <- (0,13145)
[1] 6932 <- (0,13146)
[1] 6933 <- (0,13147)
[1] 6934 <- (0,13148)
[1] 6935 <- (0,13149)
[1] 6936 <- (0,13150)
[1] 6937 <- (0,13151)
[1] 6938 <- (0,13152)
[1] 6939 <- (0,13153)
[1] 6940 <- (0,13154)
[1] 6941 <- (0,13155)
[1] 6942 <- (0,13156)
[1] 6943 <- (0,13157)
[1] 6944 <- (0,13158)
[1] 6945 <- (0,13159)
[1] 6946 <- (0,13160)
[1] 6947 <- (0,13161)
[1] 6948 <- (0,13189)
[1] 6949 <- (0,13190)
[1] 6950 <- (0,13191)
[1] 6951 <- (0,13192)
[1] 6952 <- (0,13193)
[1] 6953 <- (0,13194)
[1] 6954 <- (0,13195)
[1] 6955 <- (0,13196)
[1] 6956 <- (0,13197)
[1] 6957 <- (0,13198)
[1] 6958 <- (0,13199)
[1] 6959 <- (0,13200)
[1] 6960 <- (0,13201)
[1] 6961 <- (0,13202)
[1] 6962 <- (0,13203)
[1] 6963 <- (0,13204)
[1] 6964 <- (0,13205)
[1] 6965 <- (0,13206)
[1] 6966 <- (0,13207)
[1] 6967 <- (0,13208)
[1] 6968 <- (0,13209)
[1] 6969 <- (0,13210)
[1] 6970 <- (0,13211)
[1] 6971 <- (0,13212)
[1] 6972 <- (0,13235)
[1] 6973 <- (0,13236)
[1] 6974 <- (0,13237)
[1] 6975 <- (0,13238)
[1] 6976 <- (0,13239)
[1] 6977 <- (0,13240)
[1] 6978 <- (0,13241)
[1] 6979 <- (0,13242)
[1] 6980 <- (0,13243)
[1] 6981 <- (0,13244)
[1] 6982 <- (0,13245)
[1] 6983 <- (0,13246)
[1] 6984 <- (0,13247)
[1] 6985 <- (0,13248)
[1] 6986 <- (0,13249)
[1] 6987 <- (0,13250)
[1] 6988 <- (0,13251)
[1] 6989 <- (0,13252)
[1] 6990 <- (0,13253)
[1] 6991 <- (0,13254)
[1] 6992 <- (0,13255)
[1] 6993 <- (0,13256)
[1] 6994 <- (0,13257)
[1] 6995 <- (0,13258)
[1] 6996 <- (0,13259)
[1] 6997 <- (0,13260)
[1] 6998 <- (0,13261)
[1] 6999 <- (0,13262)
[1] 7000 <- (0,13263)
[1] 7001 <- (0,13286)
[1] 7002 <- (0,13287)
[1] 7003 <- (0,13288)
[1] 7004 <- (0,13289)
[1] 7005 <- (0,13290)
[1] 7006 <- (0,13291)
[1] 7007 <- (0,13292)
[1] 7008 <- (0,13293)
[1] 7009 <- (0,13294)
[1] 7010 <- (0,13295)
[1] 7011 <- (0,13296)
[1] 7012 <- (0,13297)
[1] 7013 <- (0,13298)
[1] 7014 <- (0,13299)
[1] 7015 <- (0,13300)
[1] 7016 <- (0,13301)
[1] 7017 <- (0,13302)
[1] 7018 <- (0,13303)
[1] 7019 <- (0,13304)
[1] 7020 <- (0,13305)
[1] 7021 <- (0,13306)
[1] 7022 <- (0,13307)
[1] 7023 <- (0,13308)
[1] 7024 <- (0,13309)
[1] 7025 <- (0,13310)
[1] 7026 <- (0,13311)
[1] 7027 <- (0,13312)
[1] 7028 <- (0,13313)
[1] 7029 <- (0,13314)
[1] 7030 <- (0,13337)
[1] 7031 <- (0,13338)
[1] 7032 <- (0,13339)
[1] 7033 <- (0,13340)
[1] 7034 <- (0,13341)
[1] 7035 <- (0,13342)
[1] 7036 <- (0,13343)
[1] 7037 <- (0,13344)
[1] 7038 <- (0,13345)
[1] 7039 <- (0,13346)
[1] 7040 <- (0,13347)
[1] 7041 <- (0,13348)
[1] 7042 <- (0,13349)
[1] 7043 <- (0,13350)
[1] 7044 <- (0,13351)
[1] 7045 <- (0,13352)
[1] 7046 <- (0,13353)
[1] 7047 <- (0,13354)
[1] 7048 <- (0,13355)
[1] 7049 <- (0,13356)
[1] 7050 <- (0,13357)
[1] 7051 <- (0,13358)
[1] 7052 <- (0,13359)
[1] 7053 <- (0,13360)
[1] 7054 <- (0,13361)
[1] 7055 <- (0,13362)
[1] 7056 <- (0,13363)
[1] 7057 <- (0,13364)
[1] 7058 <- (0,13365)
[1] 7059 <- (0,13388)
[1] 7060 <- (0,13389)
[1] 7061 <- (0,13390)
[1] 7062 <- (0,13391)
[1] 7063 <- (0,13392)
[1] 7064 <- (0,13393)
[1] 7065 <- (0,13394)
[1] 7066 <- (0,13395)
[1] 7067 <- (0,13396)
[1] 7068 <- (0,13397)
[1] 7069 <- (0,13398)
[1] 7070 <- (0,13399)
[1] 7071 <- (0,13400)
[1] 7072 <- (0,13401)
[1] 7073 <- (0,13402)
[1] 7074 <- (0,13403)
[1] 7075 <- (0,13404)
[1] 7076 <- (0,13405)
[1] 7077 <- (0,13406)
[1] 7078 <- (0,13407)
[1] 7079 <- (0,13408)
[1] 7080 <- (0,13409)
[1] 7081 <- (0,13410)
[1] 7082 <- (0,13411)
[1] 7083 <- (0,13412)
[1] 7084 <- (0,13413)
[1] 7085 <- (0,13414)
[1] 7086 <- (0,13415)
[1] 7087 <- (0,13416)
[1] 7088 <- (0,13439)
[1] 7089 <- (0,13440)
[1] 7090 <- (0,13441)
[1] 7091 <- (0,13442)
[1] 7092 <- (0,13443)
[1] 7093 <- (0,13444)
[1] 7094 <- (0,13445)
[1] 7095 <- (0,13446)
[1] 7096 <- (0,13447)
[1] 7097 <- (0,13448)
[1] 7098 <- (0,13449)
[1] 7099 <- (0,13450)
[1] 7100 <- (0,13451)
[1] 7101 <- (0,13452)
[1] 7102 <- (0,13453)
[1] 7103 <- (0,13454)
[1] 7104 <- (0,13455)
[1] 7105 <- (0,13456)
[1] 7106 <- (0,13457)
[1] 7107 <- (0,13458)
[1] 7108 <- (0,13459)
[1] 7109 <- (0,13460)
[1] 7110 <- (0,13461)
[1] 7111 <- (0,13462)
[1] 7112 <- (0,13463)
[1] 7113 <- (0,13464)
[1] 7114 <- (0,13465)
[1] 7115 <- (0,13466)
[1] 7116 <- (0,13467)
[1] 7117 <- (0,13491)
[1] 7118 <- (0,13492)
[1] 7119 <- (0,13493)
[1] 7120 <- (0,13494)
[1] 7121 <- (0,13495)
[1] 7122 <- (0,13496)
[1] 7123 <- (0,13497)
[1] 7124 <- (0,13498)
[1] 7125 <- (0,13499)
[1] 7126 <- (0,13500)
[1] 7127 <- (0,13501)
[1] 7128 <- (0,13502)
[1] 7129 <- (0,13503)
[1] 7130 <- (0,13504)
[1] 7131 <- (0,13505)
[1] 7132 <- (0,13506)
[1] 7133 <- (0,13507)
[1] 7134 <- (0,13508)
[1] 7135 <- (0,13509)
[1] 7136 <- (0,13510)
[1] 7137 <- (0,13511)
[1] 7138 <- (0,13512)
[1] 7139 <- (0,13513)
[1] 7140 <- (0,13514)
[1] 7141 <- (0,13515)
[1] 7142 <- (0,13516)
[1] 7143 <- (0,13517)
[1] 7144 <- (0,13518)
[1] 7145 <- (0,13542)
[1] 7146 <- (0,13543)
[1] 7147 <- (0,13544)
[1] 7148 <- (0,13545)
[1] 7149 <- (0,13546)
[1] 7150 <- (0,13547)
[1] 7151 <- (0,13548)
[1] 7152 <- (0,13549)
[1] 7153 <- (0,13550)
[1] 7154 <- (0,13551)
[1] 7155 <- (0,13552)
[1] 7156 <- (0,13553)
[1] 7157 <- (0,13554)
[1] 7158 <- (0,13555)
[1] 7159 <- (0,13556)
[1] 7160 <- (0,13557)
[1] 7161 <- (0,13558)
[1] 7162 <- (0,13559)
[1] 7163 <- (0,13560)
[1] 7164 <- (0,13561)
[1] 7165 <- (0,13562)
[1] 7166 <- (0,13563)
[1] 7167 <- (0,13564)
[1] 7168 <- (0,13565)
[1] 7169 <- (0,13566)
[1] 7170 <- (0,13567)
[1] 7171 <- (0,13568)
[1] 7172 <- (0,13569)
[1] 7173 <- (0,13593)
[1] 7174 <- (0,13594)
[1] 7175 <- (0,13595)
[1] 7176 <- (0,13596)
[1] 7177 <- (0,13597)
[1] 7178 <- (0,13598)
[1] 7179 <- (0,13599)
[1] 7180 <- (0,13600)
[1] 7181 <- (0,13601)
[1] 7182 <- (0,13602)
[1] 7183 <- (0,13603)
[1] 7184 <- (0,13604)
[1] 7185 <- (0,13605)
[1] 7186 <- (0,13606)
[1] 7187 <- (0,13607)
[1] 7188 <- (0,13608)
[1] 7189 <- (0,13609)
[1] 7190 <- (0,13610)
[1] 7191 <- (0,13611)
[1] 7192 <- (0,13612)
[1] 7193 <- (0,13613)
[1] 7194 <- (0,13614)
[1] 7195 <- (0,13615)
[1] 7196 <- (0,13616)
[1] 7197 <- (0,13617)
[1] 7198 <- (0,13618)
[1] 7199 <- (0,13619)
[1] 7200 <- (0,13620)
[1] 7201 <- (0,13644)
[1] 7202 <- (0,13645)
[1] 7203 <- (0,13646)
[1] 7204 <- (0,13647)
[1] 7205 <- (0,13648)
[1] 7206 <- (0,13649)
[1] 7207 <- (0,13650)
[1] 7208 <- (0,13651)
[1] 7209 <- (0,13652)
[1] 7210 <- (0,13653)
[1] 7211 <- (0,13654)
[1] 7212 <- (0,13655)
[1] 7213 <- (0,13656)
[1] 7214 <- (0,13657)
[1] 7215 <- (0,13658)
[1] 7216 <- (0,13659)
[1] 7217 <- (0,13660)
[1] 7218 <- (0,13661)
[1] 7219 <- (0,13662)
[1] 7220 <- (0,13663)
[1] 7221 <- (0,13664)
[1] 7222 <- (0,13665)
[1] 7223 <- (0,13666)
[1] 7224 <- (0,13667)
[1] 7225 <- (0,13668)
[1] 7226 <- (0,13669)
[1] 7227 <- (0,13670)
[1] 7228 <- (0,13671)
[1] 7229 <- (0,13696)
[1] 7230 <- (0,13697)
[1] 7231 <- (0,13698)
[1] 7232 <- (0,13699)
[1] 7233 <- (0,13700)
[1] 7234 <- (0,13701)
[1] 7235 <- (0,13702)
[1] 7236 <- (0,13703)
[1] 7237 <- (0,13704)
[1] 7238 <- (0,13705)
[1] 7239 <- (0,13706)
[1] 7240 <- (0,13707)
[1] 7241 <- (0,13708)
[1] 7242 <- (0,13709)
[1] 7243 <- (0,13710)
[1] 7244 <- (0,13711)
[1] 7245 <- (0,13712)
[1] 7246 <- (0,13713)
[1] 7247 <- (0,13714)
[1] 7248 <- (0,13715)
[1] 7249 <- (0,13716)
[1] 7250 <- (0,13717)
[1] 7251 <- (0,13718)
[1] 7252 <- (0,13719)
[1] 7253 <- (0,13720)
[1] 7254 <- (0,13721)
[1] 7255 <- (0,13722)
[1] 7256 <- (0,13747)
[1] 7257 <- (0,13748)
[1] 7258 <- (0,13749)
[1] 7259 <- (0,13750)
[1] 7260 <- (0,13751)
[1] 7261 <- (0,13752)
[1] 7262 <- (0,13753)
[1] 7263 <- (0,13754)
[1] 7264 <- (0,13755)
[1] 7265 <- (0,13756)
[1] 7266 <- (0,13757)
[1] 7267 <- (0,13758)
[1] 7268 <- (0,13759)
[1] 7269 <- (0,13760)
[1] 7270 <- (0,13761)
[1] 7271 <- (0,13762)
[1] 7272 <- (0,13763)
[1] 7273 <- (0,13764)
[1] 7274 <- (0,13765)
[1] 7275 <- (0,13766)
[1] 7276 <- (0,13767)
[1] 7277 <- (0,13768)
[1] 7278 <- (0,13769)
[1] 7279 <- (0,13770)
[1] 7280 <- (0,13771)
[1] 7281 <- (0,13772)
[1] 7282 <- (0,13773)
[1] 7283 <- (0,13799)
[1] 7284 <- (0,13800)
[1] 7285 <- (0,13801)
[1] 7286 <- (0,13802)
[1] 7287 <- (0,13803)
[1] 7288 <- (0,13804)
[1] 7289 <- (0,13805)
[1] 7290 <- (0,13806)
[1] 7291 <- (0,13807)
[1] 7292 <- (0,13808)
[1] 7293 <- (0,13809)
[1] 7294 <- (0,13810)
[1] 7295 <- (0,13811)
[1] 7296 <- (0,13812)
[1] 7297 <- (0,13813)
[1] 7298 <- (0,13814)
[1] 7299 <- (0,13815)
[1] 7300 <- (0,13816)
[1] 7301 <- (0,13817)
[1] 7302 <- (0,13818)
[1] 7303 <- (0,13819)
[1] 7304 <- (0,13820)
[1] 7305 <- (0,13821)
[1] 7306 <- (0,13822)
[1] 7307 <- (0,13823)
[1] 7308 <- (0,13824)
[1] 7309 <- (0,13851)
[1] 7310 <- (0,13852)
[1] 7311 <- (0,13853)
[1] 7312 <- (0,13854)
[1] 7313 <- (0,13855)
[1] 7314 <- (0,13856)
[1] 7315 <- (0,13857)
[1] 7316 <- (0,13858)
[1] 7317 <- (0,13859)
[1] 7318 <- (0,13860)
[1] 7319 <- (0,13861)
[1] 7320 <- (0,13862)
[1] 7321 <- (0,13863)
[1] 7322 <- (0,13864)
[1] 7323 <- (0,13865)
[1] 7324 <- (0,13866)
[1] 7325 <- (0,13867)
[1] 7326 <- (0,13868)
[1] 7327 <- (0,13869)
[1] 7328 <- (0,13870)
[1] 7329 <- (0,13871)
[1] 7330 <- (0,13872)
[1] 7331 <- (0,13873)
[1] 7332 <- (0,13874)
[1] 7333 <- (0,13875)
[1] 7334 <- (0,13902)
[1] 7335 <- (0,13903)
[1] 7336 <- (0,13904)
[1] 7337 <- (0,13905)
[1] 7338 <- (0,13906)
[1] 7339 <- (0,13907)
[1] 7340 <- (0,13908)
[1] 7341 <- (0,13909)
[1] 7342 <- (0,13910)
[1] 7343 <- (0,13911)
[1] 7344 <- (0,13912)
[1] 7345 <- (0,13913)
[1] 7346 <- (0,13914)
[1] 7347 <- (0,13915)
[1] 7348 <- (0,13916)
[1] 7349 <- (0,13917)
[1] 7350 <- (0,13918)
[1] 7351 <- (0,13919)
[1] 7352 <- (0,13920)
[1] 7353 <- (0,13921)
[1] 7354 <- (0,13922)
[1] 7355 <- (0,13923)
[1] 7356 <- (0,13924)
[1] 7357 <- (0,13925)
[1] 7358 <- (0,13926)
[1] 7359 <- (0,13954)
[1] 7360 <- (0,13955)
[1] 7361 <- (0,13956)
[1] 7362 <- (0,13957)
[1] 7363 <- (0,13958)
[1] 7364 <- (0,13959)
[1] 7365 <- (0,13960)
[1] 7366 <- (0,13961)
[1] 7367 <- (0,13962)
[1] 7368 <- (0,13963)
[1] 7369 <- (0,13964)
[1] 7370 <- (0,13965)
[1] 7371 <- (0,13966)
[1] 7372 <- (0,13967)
[1] 7373 <- (0,13968)
[1] 7374 <- (0,13969)
[1] 7375 <- (0,13970)
[1] 7376 <- (0,13971)
[1] 7377 <- (0,13972)
[1] 7378 <- (0,13973)
[1] 7379 <- (0,13974)
[1] 7380 <- (0,13975)
[1] 7381 <- (0,13976)
[1] 7382 <- (0,13977)
[1] 7383 <- (0,14005)
[1] 7384 <- (0,14006)
[1] 7385 <- (0,14007)
[1] 7386 <- (0,14008)
[1] 7387 <- (0,14009)
[1] 7388 <- (0,14010)
[1] 7389 <- (0,14011)
[1] 7390 <- (0,14012)
[1] 7391 <- (0,14013)
[1] 7392 <- (0,14014)
[1] 7393 <- (0,14015)
[1] 7394 <- (0,14016)
[1] 7395 <- (0,14017)
[1] 7396 <- (0,14018)
[1] 7397 <- (0,14019)
[1] 7398 <- (0,14020)
[1] 7399 <- (0,14021)
[1] 7400 <- (0,14022)
[1] 7401 <- (0,14023)
[1] 7402 <- (0,14024)
[1] 7403 <- (0,14025)
[1] 7404 <- (0,14026)
[1] 7405 <- (0,14027)
[1] 7406 <- (0,14028)
[1] 7407 <- (0,14056)
[1] 7408 <- (0,14057)
[1] 7409 <- (0,14058)
[1] 7410 <- (0,14059)
[1] 7411 <- (0,14060)
[1] 7412 <- (0,14061)
[1] 7413 <- (0,14062)
[1] 7414 <- (0,14063)
[1] 7415 <- (0,14064)
[1] 7416 <- (0,14065)
[1] 7417 <- (0,14066)
[1] 7418 <- (0,14067)
[1] 7419 <- (0,14068)
[1] 7420 <- (0,14069)
[1] 7421 <- (0,14070)
[1] 7422 <- (0,14071)
[1] 7423 <- (0,14072)
[1] 7424 <- (0,14073)
[1] 7425 <- (0,14074)
[1] 7426 <- (0,14075)
[1] 7427 <- (0,14076)
[1] 7428 <- (0,14077)
[1] 7429 <- (0,14078)
[1] 7430 <- (0,14079)
[1] 7431 <- (0,14107)
[1] 7432 <- (0,14108)
[1] 7433 <- (0,14109)
[1] 7434 <- (0,14110)
[1] 7435 <- (0,14111)
[1] 7436 <- (0,14112)
[1] 7437 <- (0,14113)
[1] 7438 <- (0,14114)
[1] 7439 <- (0,14115)
[1] 7440 <- (0,14116)
[1] 7441 <- (0,14117)
[1] 7442 <- (0,14118)
[1] 7443 <- (0,14119)
[1] 7444 <- (0,14120)
[1] 7445 <- (0,14121)
[1] 7446 <- (0,14122)
[1] 7447 <- (0,14123)
[1] 7448 <- (0,14124)
[1] 7449 <- (0,14125)
[1] 7450 <- (0,14126)
[1] 7451 <- (0,14127)
[1] 7452 <- (0,14128)
[1] 7453 <- (0,14129)
[1] 7454 <- (0,14130)
[1] 7455 <- (0,14158)
[1] 7456 <- (0,14159)
[1] 7457 <- (0,14160)
[1] 7458 <- (0,14161)
[1] 7459 <- (0,14162)
[1] 7460 <- (0,14163)
[1] 7461 <- (0,14164)
[1] 7462 <- (0,14165)
[1] 7463 <- (0,14166)
[1] 7464 <- (0,14167)
[1] 7465 <- (0,14168)
[1] 7466 <- (0,14169)
[1] 7467 <- (0,14170)
[1] 7468 <- (0,14171)
[1] 7469 <- (0,14172)
[1] 7470 <- (0,14173)
[1] 7471 <- (0,14174)
[1] 7472 <- (0,14175)
[1] 7473 <- (0,14176)
[1] 7474 <- (0,14177)
[1] 7475 <- (0,14178)
[1] 7476 <- (0,14179)
[1] 7477 <- (0,14180)
[1] 7478 <- (0,14181)
[1] 7479 <- (0,14209)
[1] 7480 <- (0,14210)
[1] 7481 <- (0,14211)
[1] 7482 <- (0,14212)
[1] 7483 <- (0,14213)
[1] 7484 <- (0,14214)
[1] 7485 <- (0,14215)
[1] 7486 <- (0,14216)
[1] 7487 <- (0,14217)
[1] 7488 <- (0,14218)
[1] 7489 <- (0,14219)
[1] 7490 <- (0,14220)
[1] 7491 <- (0,14221)
[1] 7492 <- (0,14222)
[1] 7493 <- (0,14223)
[1] 7494 <- (0,14224)
[1] 7495 <- (0,14225)
[1] 7496 <- (0,14226)
[1] 7497 <- (0,14227)
[1] 7498 <- (0,14228)
[1] 7499 <- (0,14229)
[1] 7500 <- (0,14230)
[1] 7501 <- (0,14231)
[1] 7502 <- (0,14232)
[1] 7503 <- (0,14260)
[1] 7504 <- (0,14261)
[1] 7505 <- (0,14262)
[1] 7506 <- (0,14263)
[1] 7507 <- (0,14264)
[1] 7508 <- (0,14265)
[1] 7509 <- (0,14266)
[1] 7510 <- (0,14267)
[1] 7511 <- (0,14268)
[1] 7512 <- (0,14269)
[1] 7513 <- (0,14270)
[1] 7514 <- (0,14271)
[1] 7515 <- (0,14272)
[1] 7516 <- (0,14273)
[1] 7517 <- (0,14274)
[1] 7518 <- (0,14275)
[1] 7519 <- (0,14276)
[1] 7520 <- (0,14277)
[1] 7521 <- (0,14278)
[1] 7522 <- (0,14279)
[1] 7523 <- (0,14280)
[1] 7524 <- (0,14281)
[1] 7525 <- (0,14282)
[1] 7526 <- (0,14283)
[1] 7527 <- (0,14306)
[1] 7528 <- (0,14307)
[1] 7529 <- (0,14308)
[1] 7530 <- (0,14309)
[1] 7531 <- (0,14310)
[1] 7532 <- (0,14311)
[1] 7533 <- (0,14312)
[1] 7534 <- (0,14313)
[1] 7535 <- (0,14314)
[1] 7536 <- (0,14315)
[1] 7537 <- (0,14316)
[1] 7538 <- (0,14317)
[1] 7539 <- (0,14318)
[1] 7540 <- (0,14319)
[1] 7541 <- (0,14320)
[1] 7542 <- (0,14321)
[1] 7543 <- (0,14322)
[1] 7544 <- (0,14323)
[1] 7545 <- (0,14324)
[1] 7546 <- (0,14325)
[1] 7547 <- (0,14326)
[1] 7548 <- (0,14327)
[1] 7549 <- (0,14328)
[1] 7550 <- (0,14329)
[1] 7551 <- (0,14330)
[1] 7552 <- (0,14331)
[1] 7553 <- (0,14332)
[1] 7554 <- (0,14333)
[1] 7555 <- (0,14334)
[1] 7556 <- (0,14357)
[1] 7557 <- (0,14358)
[1] 7558 <- (0,14359)
[1] 7559 <- (0,14360)
[1] 7560 <- (0,14361)
[1] 7561 <- (0,14362)
[1] 7562 <- (0,14363)
[1] 7563 <- (0,14364)
[1] 7564 <- (0,14365)
[1] 7565 <- (0,14366)
[1] 7566 <- (0,14367)
[1] 7567 <- (0,14368)
[1] 7568 <- (0,14369)
[1] 7569 <- (0,14370)
[1] 7570 <- (0,14371)
[1] 7571 <- (0,14372)
[1] 7572 <- (0,14373)
[1] 7573 <- (0,14374)
[1] 7574 <- (0,14375)
[1] 7575 <- (0,14376)
[1] 7576 <- (0,14377)
[1] 7577 <- (0,14378)
[1] 7578 <- (0,14379)
[1] 7579 <- (0,14380)
[1] 7580 <- (0,14381)
[1] 7581 <- (0,14382)
[1] 7582 <- (0,14383)
[1] 7583 <- (0,14384)
[1] 7584 <- (0,14385)
[1] 7585 <- (0,14408)
[1] 7586 <- (0,14409)
[1] 7587 <- (0,14410)
[1] 7588 <- (0,14411)
[1] 7589 <- (0,14412)
[1] 7590 <- (0,14413)
[1] 7591 <- (0,14414)
[1] 7592 <- (0,14415)
[1] 7593 <- (0,14416)
[1] 7594 <- (0,14417)
[1] 7595 <- (0,14418)
[1] 7596 <- (0,14419)
[1] 7597 <- (0,14420)
[1] 7598 <- (0,14421)
[1] 7599 <- (0,14422)
[1] 7600 <- (0,14423)
[1] 7601 <- (0,14424)
[1] 7602 <- (0,14425)
[1] 7603 <- (0,14426)
[1] 7604 <- (0,14427)
[1] 7605 <- (0,14428)
[1] 7606 <- (0,14429)
[1] 7607 <- (0,14430)
[1] 7608 <- (0,14431)
[1] 7609 <- (0,14432)
[1] 7610 <- (0,14433)
[1] 7611 <- (0,14434)
[1] 7612 <- (0,14435)
[1] 7613 <- (0,14436)
[1] 7614 <- (0,14459)
[1] 7615 <- (0,14460)
[1] 7616 <- (0,14461)
[1] 7617 <- (0,14462)
[1] 7618 <- (0,14463)
[1] 7619 <- (0,14464)
[1] 7620 <- (0,14465)
[1] 7621 <- (0,14466)
[1] 7622 <- (0,14467)
[1] 7623 <- (0,14468)
[1] 7624 <- (0,14469)
[1] 7625 <- (0,14470)
[1] 7626 <- (0,14471)
[1] 7627 <- (0,14472)
[1] 7628 <- (0,14473)
[1] 7629 <- (0,14474)
[1] 7630 <- (0,14475)
[1] 7631 <- (0,14476)
[1] 7632 <- (0,14477)
[1] 7633 <- (0,14478)
[1] 7634 <- (0,14479)
[1] 7635 <- (0,14480)
[1] 7636 <- (0,14481)
[1] 7637 <- (0,14482)
[1] 7638 <- (0,14483)
[1] 7639 <- (0,14484)
[1] 7640 <- (0,14485)
[1] 7641 <- (0,14486)
[1] 7642 <- (0,14487)
[1] 7643 <- (0,14510)
[1] 7644 <- (0,14511)
[1] 7645 <- (0,14512)
[1] 7646 <- (0,14513)
[1] 7647 <- (0,14514)
[1] 7648 <- (0,14515)
[1] 7649 <- (0,14516)
[1] 7650 <- (0,14517)
[1] 7651 <- (0,14518)
[1] 7652 <- (0,14519)
[1] 7653 <- (0,14520)
[1] 7654 <- (0,14521)
[1] 7655 <- (0,14522)
[1] 7656 <- (0,14523)
[1] 7657 <- (0,14524)
[1] 7658 <- (0,14525)
[1] 7659 <- (0,14526)
[1] 7660 <- (0,14527)
[1] 7661 <- (0,14528)
[1] 7662 <- (0,14529)
[1] 7663 <- (0,14530)
[1] 7664 <- (0,14531)
[1] 7665 <- (0,14532)
[1] 7666 <- (0,14533)
[1] 7667 <- (0,14534)
[1] 7668 <- (0,14535)
[1] 7669 <- (0,14536)
[1] 7670 <- (0,14537)
[1] 7671 <- (0,14538)
[1] 7672 <- (0,14562)
[1] 7673 <- (0,14563)
[1] 7674 <- (0,14564)
[1] 7675 <- (0,14565)
[1] 7676 <- (0,14566)
[1] 7677 <- (0,14567)
[1] 7678 <- (0,14568)
[1] 7679 <- (0,14569)
[1] 7680 <- (0,14570)
[1] 7681 <- (0,14571)
[1] 7682 <- (0,14572)
[1] 7683 <- (0,14573)
[1] 7684 <- (0,14574)
[1] 7685 <- (0,14575)
[1] 7686 <- (0,14576)
[1] 7687 <- (0,14577)
[1] 7688 <- (0,14578)
[1] 7689 <- (0,14579)
[1] 7690 <- (0,14580)
[1] 7691 <- (0,14581)
[1] 7692 <- (0,14582)
[1] 7693 <- (0,14583)
[1] 7694 <- (0,14584)
[1] 7695 <- (0,14585)
[1] 7696 <- (0,14586)
[1] 7697 <- (0,14587)
[1] 7698 <- (0,14588)
[1] 7699 <- (0,14589)
[1] 7700 <- (0,14613)
[1] 7701 <- (0,14614)
[1] 7702 <- (0,14615)
[1] 7703 <- (0,14616)
[1] 7704 <- (0,14617)
[1] 7705 <- (0,14618)
[1] 7706 <- (0,14619)
[1] 7707 <- (0,14620)
[1] 7708 <- (0,14621)
[1] 7709 <- (0,14622)
[1] 7710 <- (0,14623)
[1] 7711 <- (0,14624)
[1] 7712 <- (0,14625)
[1] 7713 <- (0,14626)
[1] 7714 <- (0,14627)
[1] 7715 <- (0,14628)
[1] 7716 <- (0,14629)
[1] 7717 <- (0,14630)
[1] 7718 <- (0,14631)
[1] 7719 <- (0,14632)
[1] 7720 <- (0,14633)
[1] 7721 <- (0,14634)
[1] 7722 <- (0,14635)
[1] 7723 <- (0,14636)
[1] 7724 <- (0,14637)
[1] 7725 <- (0,14638)
[1] 7726 <- (0,14639)
[1] 7727 <- (0,14640)
[1] 7728 <- (0,14664)
[1] 7729 <- (0,14665)
[1] 7730 <- (0,14666)
[1] 7731 <- (0,14667)
[1] 7732 <- (0,14668)
[1] 7733 <- (0,14669)
[1] 7734 <- (0,14670)
[1] 7735 <- (0,14671)
[1] 7736 <- (0,14672)
[1] 7737 <- (0,14673)
[1] 7738 <- (0,14674)
[1] 7739 <- (0,14675)
[1] 7740 <- (0,14676)
[1] 7741 <- (0,14677)
[1] 7742 <- (0,14678)
[1] 7743 <- (0,14679)
[1] 7744 <- (0,14680)
[1] 7745 <- (0,14681)
[1] 7746 <- (0,14682)
[1] 7747 <- (0,14683)
[1] 7748 <- (0,14684)
[1] 7749 <- (0,14685)
[1] 7750 <- (0,14686)
[1] 7751 <- (0,14687)
[1] 7752 <- (0,14688)
[1] 7753 <- (0,14689)
[1] 7754 <- (0,14690)
[1] 7755 <- (0,14691)
[1] 7756 <- (0,14715)
[1] 7757 <- (0,14716)
[1] 7758 <- (0,14717)
[1] 7759 <- (0,14718)
[1] 7760 <- (0,14719)
[1] 7761 <- (0,14720)
[1] 7762 <- (0,14721)
[1] 7763 <- (0,14722)
[1] 7764 <- (0,14723)
[1] 7765 <- (0,14724)
[1] 7766 <- (0,14725)
[1] 7767 <- (0,14726)
[1] 7768 <- (0,14727)
[1] 7769 <- (0,14728)
[1] 7770 <- (0,14729)
[1] 7771 <- (0,14730)
[1] 7772 <- (0,14731)
[1] 7773 <- (0,14732)
[1] 7774 <- (0,14733)
[1] 7775 <- (0,14734)
[1] 7776 <- (0,14735)
[1] 7777 <- (0,14736)
[1] 7778 <- (0,14737)
[1] 7779 <- (0,14738)
[1] 7780 <- (0,14739)
[1] 7781 <- (0,14740)
[1] 7782 <- (0,14741)
[1] 7783 <- (0,14742)
[1] 7784 <- (0,14767)
[1] 7785 <- (0,14768)
[1] 7786 <- (0,14769)
[1] 7787 <- (0,14770)
[1] 7788 <- (0,14771)
[1] 7789 <- (0,14772)
[1] 7790 <- (0,14773)
[1] 7791 <- (0,14774)
[1] 7792 <- (0,14775)
[1] 7793 <- (0,14776)
[1] 7794 <- (0,14777)
[1] 7795 <- (0,14778)
[1] 7796 <- (0,14779)
[1] 7797 <- (0,14780)
[1] 7798 <- (0,14781)
[1] 7799 <- (0,14782)
[1] 7800 <- (0,14783)
[1] 7801 <- (0,14784)
[1] 7802 <- (0,14785)
[1] 7803 <- (0,14786)
[1] 7804 <- (0,14787)
[1] 7805 <- (0,14788)
[1] 7806 <- (0,14789)
[1] 7807 <- (0,14790)
[1] 7808 <- (0,14791)
[1] 7809 <- (0,14792)
[1] 7810 <- (0,14793)
[1] 7811 <- (0,14818)
[1] 7812 <- (0,14819)
[1] 7813 <- (0,14820)
[1] 7814 <- (0,14821)
[1] 7815 <- (0,14822)
[1] 7816 <- (0,14823)
[1] 7817 <- (0,14824)
[1] 7818 <- (0,14825)
[1] 7819 <- (0,14826)
[1] 7820 <- (0,14827)
[1] 7821 <- (0,14828)
[1] 7822 <- (0,14829)
[1] 7823 <- (0,14830)
[1] 7824 <- (0,14831)
[1] 7825 <- (0,14832)
[1] 7826 <- (0,14833)
[1] 7827 <- (0,14834)
[1] 7828 <- (0,14835)
[1] 7829 <- (0,14836)
[1] 7830 <- (0,14837)
[1] 7831 <- (0,14838)
[1] 7832 <- (0,14839)
[1] 7833 <- (0,14840)
[1] 7834 <- (0,14841)
[1] 7835 <- (0,14842)
[1] 7836 <- (0,14843)
[1] 7837 <- (0,14844)
[1] 7838 <- (0,14870)
[1] 7839 <- (0,14871)
[1] 7840 <- (0,14872)
[1] 7841 <- (0,14873)
[1] 7842 <- (0,14874)
[1] 7843 <- (0,14875)
[1] 7844 <- (0,14876)
[1] 7845 <- (0,14877)
[1] 7846 <- (0,14878)
[1] 7847 <- (0,14879)
[1] 7848 <- (0,14880)
[1] 7849 <- (0,14881)
[1] 7850 <- (0,14882)
[1] 7851 <- (0,14883)
[1] 7852 <- (0,14884)
[1] 7853 <- (0,14885)
[1] 7854 <- (0,14886)
[1] 7855 <- (0,14887)
[1] 7856 <- (0,14888)
[1] 7857 <- (0,14889)
[1] 7858 <- (0,14890)
[1] 7859 <- (0,14891)
[1] 7860 <- (0,14892)
[1] 7861 <- (0,14893)
[1] 7862 <- (0,14894)
[1] 7863 <- (0,14895)
[1] 7864 <- (0,14922)
[1] 7865 <- (0,14923)
[1] 7866 <- (0,14924)
[1] 7867 <- (0,14925)
[1] 7868 <- (0,14926)
[1] 7869 <- (0,14927)
[1] 7870 <- (0,14928)
[1] 7871 <- (0,14929)
[1] 7872 <- (0,14930)
[1] 7873 <- (0,14931)
[1] 7874 <- (0,14932)
[1] 7875 <- (0,14933)
[1] 7876 <- (0,14934)
[1] 7877 <- (0,14935)
[1] 7878 <- (0,14936)
[1] 7879 <- (0,14937)
[1] 7880 <- (0,14938)
[1] 7881 <- (0,14939)
[1] 7882 <- (0,14940)
[1] 7883 <- (0,14941)
[1] 7884 <- (0,14942)
[1] 7885 <- (0,14943)
[1] 7886 <- (0,14944)
[1] 7887 <- (0,14945)
[1] 7888 <- (0,14946)
[1] 7889 <- (0,14973)
[1] 7890 <- (0,14974)
[1] 7891 <- (0,14975)
[1] 7892 <- (0,14976)
[1] 7893 <- (0,14977)
[1] 7894 <- (0,14978)
[1] 7895 <- (0,14979)
[1] 7896 <- (0,14980)
[1] 7897 <- (0,14981)
[1] 7898 <- (0,14982)
[1] 7899 <- (0,14983)
[1] 7900 <- (0,14984)
[1] 7901 <- (0,14985)
[1] 7902 <- (0,14986)
[1] 7903 <- (0,14987)
[1] 7904 <- (0,14988)
[1] 7905 <- (0,14989)
[1] 7906 <- (0,14990)
[1] 7907 <- (0,14991)
[1] 7908 <- (0,14992)
[1] 7909 <- (0,14993)
[1] 7910 <- (0,14994)
[1] 7911 <- (0,14995)
[1] 7912 <- (0,14996)
[1] 7913 <- (0,14997)
[1] 7914 <- (0,15025)
[1] 7915 <- (0,15026)
[1] 7916 <- (0,15027)
[1] 7917 <- (0,15028)
[1] 7918 <- (0,15029)
[1] 7919 <- (0,15030)
[1] 7920 <- (0,15031)
[1] 7921 <- (0,15032)
[1] 7922 <- (0,15033)
[1] 7923 <- (0,15034)
[1] 7924 <- (0,15035)
[1] 7925 <- (0,15036)
[1] 7926 <- (0,15037)
[1] 7927 <- (0,15038)
[1] 7928 <- (0,15039)
[1] 7929 <- (0,15040)
[1] 7930 <- (0,15041)
[1] 7931 <- (0,15042)
[1] 7932 <- (0,15043)
[1] 7933 <- (0,15044)
[1] 7934 <- (0,15045)
[1] 7935 <- (0,15046)
[1] 7936 <- (0,15047)
[1] 7937 <- (0,15048)
[1] 7938 <- (0,15076)
[1] 7939 <- (0,15077)
[1] 7940 <- (0,15078)
[1] 7941 <- (0,15079)
[1] 7942 <- (0,15080)
[1] 7943 <- (0,15081)
[1] 7944 <- (0,15082)
[1] 7945 <- (0,15083)
[1] 7946 <- (0,15084)
[1] 7947 <- (0,15085)
[1] 7948 <- (0,15086)
[1] 7949 <- (0,15087)
[1] 7950 <- (0,15088)
[1] 7951 <- (0,15089)
[1] 7952 <- (0,15090)
[1] 7953 <- (0,15091)
[1] 7954 <- (0,15092)
[1] 7955 <- (0,15093)
[1] 7956 <- (0,15094)
[1] 7957 <- (0,15095)
[1] 7958 <- (0,15096)
[1] 7959 <- (0,15097)
[1] 7960 <- (0,15098)
[1] 7961 <- (0,15099)
[1] 7962 <- (0,15127)
[1] 7963 <- (0,15128)
[1] 7964 <- (0,15129)
[1] 7965 <- (0,15130)
[1] 7966 <- (0,15131)
[1] 7967 <- (0,15132)
[1] 7968 <- (0,15133)
[1] 7969 <- (0,15134)
[1] 7970 <- (0,15135)
[1] 7971 <- (0,15136)
[1] 7972 <- (0,15137)
[1] 7973 <- (0,15138)
[1] 7974 <- (0,15139)
[1] 7975 <- (0,15140)
[1] 7976 <- (0,15141)
[1] 7977 <- (0,15142)
[1] 7978 <- (0,15143)
[1] 7979 <- (0,15144)
[1] 7980 <- (0,15145)
[1] 7981 <- (0,15146)
[1] 7982 <- (0,15147)
[1] 7983 <- (0,15148)
[1] 7984 <- (0,15149)
[1] 7985 <- (0,15150)
[1] 7986 <- (0,15178)
[1] 7987 <- (0,15179)
[1] 7988 <- (0,15180)
[1] 7989 <- (0,15181)
[1] 7990 <- (0,15182)
[1] 7991 <- (0,15183)
[1] 7992 <- (0,15184)
[1] 7993 <- (0,15185)
[1] 7994 <- (0,15186)
[1] 7995 <- (0,15187)
[1] 7996 <- (0,15188)
[1] 7997 <- (0,15189)
[1] 7998 <- (0,15190)
[1] 7999 <- (0,15191)
[1] 8000 <- (0,15192)
[1] 8001 <- (0,15193)
[1] 8002 <- (0,15194)
[1] 8003 <- (0,15195)
[1] 8004 <- (0,15196)
[1] 8005 <- (0,15197)
[1] 8006 <- (0,15198)
[1] 8007 <- (0,15199)
[1] 8008 <- (0,15200)
[1] 8009 <- (0,15201)
[1] 8010 <- (0,15229)
[1] 8011 <- (0,15230)
[1] 8012 <- (0,15231)
[1] 8013 <- (0,15232)
[1] 8014 <- (0,15233)
[1] 8015 <- (0,15234)
[1] 8016 <- (0,15235)
[1] 8017 <- (0,15236)
[1] 8018 <- (0,15237)
[1] 8019 <- (0,15238)
[1] 8020 <- (0,15239)
[1] 8021 <- (0,15240)
[1] 8022 <- (0,15241)
[1] 8023 <- (0,15242)
[1] 8024 <- (0,15243)
[1] 8025 <- (0,15244)
[1] 8026 <- (0,15245)
[1] 8027 <- (0,15246)
[1] 8028 <- (0,15247)
[1] 8029 <- (0,15248)
[1] 8030 <- (0,15249)
[1] 8031 <- (0,15250)
[1] 8032 <- (0,15251)
[1] 8033 <- (0,15252)
[1] 8034 <- (0,15280)
[1] 8035 <- (0,15281)
[1] 8036 <- (0,15282)
[1] 8037 <- (0,15283)
[1] 8038 <- (0,15284)
[1] 8039 <- (0,15285)
[1] 8040 <- (0,15286)
[1] 8041 <- (0,15287)
[1] 8042 <- (0,15288)
[1] 8043 <- (0,15289)
[1] 8044 <- (0,15290)
[1] 8045 <- (0,15291)
[1] 8046 <- (0,15292)
[1] 8047 <- (0,15293)
[1] 8048 <- (0,15294)
[1] 8049 <- (0,15295)
[1] 8050 <- (0,15296)
[1] 8051 <- (0,15297)
[1] 8052 <- (0,15298)
[1] 8053 <- (0,15299)
[1] 8054 <- (0,15300)
[1] 8055 <- (0,15301)
[1] 8056 <- (0,15302)
[1] 8057 <- (0,15303)
[1] 8058 <- (0,15331)
[1] 8059 <- (0,15332)
[1] 8060 <- (0,15333)
[1] 8061 <- (0,15334)
[1] 8062 <- (0,15335)
[1] 8063 <- (0,15336)
[1] 8064 <- (0,15337)
[1] 8065 <- (0,15338)
[1] 8066 <- (0,15339)
[1] 8067 <- (0,15340)
[1] 8068 <- (0,15341)
[1] 8069 <- (0,15342)
[1] 8070 <- (0,15343)
[1] 8071 <- (0,15344)
[1] 8072 <- (0,15345)
[1] 8073 <- (0,15346)
[1] 8074 <- (0,15347)
[1] 8075 <- (0,15348)
[1] 8076 <- (0,15349)
[1] 8077 <- (0,15350)
[1] 8078 <- (0,15351)
[1] 8079 <- (0,15352)
[1] 8080 <- (0,15353)
[1] 8081 <- (0,15354)
[1] 8082 <- (0,15377)
[1] 8083 <- (0,15378)
[1] 8084 <- (0,15379)
[1] 8085 <- (0,15380)
[1] 8086 <- (0,15381)
[1] 8087 <- (0,15382)
[1] 8088 <- (0,15383)
[1] 8089 <- (0,15384)
[1] 8090 <- (0,15385)
[1] 8091 <- (0,15386)
[1] 8092 <- (0,15387)
[1] 8093 <- (0,15388)
[1] 8094 <- (0,15389)
[1] 8095 <- (0,15390)
[1] 8096 <- (0,15391)
[1] 8097 <- (0,15392)
[1] 8098 <- (0,15393)
[1] 8099 <- (0,15394)
[1] 8100 <- (0,15395)
[1] 8101 <- (0,15396)
[1] 8102 <- (0,15397)
[1] 8103 <- (0,15398)
[1] 8104 <- (0,15399)
[1] 8105 <- (0,15400)
[1] 8106 <- (0,15401)
[1] 8107 <- (0,15402)
[1] 8108 <- (0,15403)
[1] 8109 <- (0,15404)
[1] 8110 <- (0,15405)
[1] 8111 <- (0,15428)
[1] 8112 <- (0,15429)
[1] 8113 <- (0,15430)
[1] 8114 <- (0,15431)
[1] 8115 <- (0,15432)
[1] 8116 <- (0,15433)
[1] 8117 <- (0,15434)
[1] 8118 <- (0,15435)
[1] 8119 <- (0,15436)
[1] 8120 <- (0,15437)
[1] 8121 <- (0,15438)
[1] 8122 <- (0,15439)
[1] 8123 <- (0,15440)
[1] 8124 <- (0,15441)
[1] 8125 <- (0,15442)
[1] 8126 <- (0,15443)
[1] 8127 <- (0,15444)
[1] 8128 <- (0,15445)
[1] 8129 <- (0,15446)
[1] 8130 <- (0,15447)
[1] 8131 <- (0,15448)
[1] 8132 <- (0,15449)
[1] 8133 <- (0,15450)
[1] 8134 <- (0,15451)
[1] 8135 <- (0,15452)
[1] 8136 <- (0,15453)
[1] 8137 <- (0,15454)
[1] 8138 <- (0,15455)
[1] 8139 <- (0,15456)
[1] 8140 <- (0,15479)
[1] 8141 <- (0,15480)
[1] 8142 <- (0,15481)
[1] 8143 <- (0,15482)
[1] 8144 <- (0,15483)
[1] 8145 <- (0,15484)
[1] 8146 <- (0,15485)
[1] 8147 <- (0,15486)
[1] 8148 <- (0,15487)
[1] 8149 <- (0,15488)
[1] 8150 <- (0,15489)
[1] 8151 <- (0,15490)
[1] 8152 <- (0,15491)
[1] 8153 <- (0,15492)
[1] 8154 <- (0,15493)
[1] 8155 <- (0,15494)
[1] 8156 <- (0,15495)
[1] 8157 <- (0,15496)
[1] 8158 <- (0,15497)
[1] 8159 <- (0,15498)
[1] 8160 <- (0,15499)
[1] 8161 <- (0,15500)
[1] 8162 <- (0,15501)
[1] 8163 <- (0,15502)
[1] 8164 <- (0,15503)
[1] 8165 <- (0,15504)
[1] 8166 <- (0,15505)
[1] 8167 <- (0,15506)
[1] 8168 <- (0,15507)
[1] 8169 <- (0,15530)
[1] 8170 <- (0,15531)
[1] 8171 <- (0,15532)
[1] 8172 <- (0,15533)
[1] 8173 <- (0,15534)
[1] 8174 <- (0,15535)
[1] 8175 <- (0,15536)
[1] 8176 <- (0,15537)
[1] 8177 <- (0,15538)
[1] 8178 <- (0,15539)
[1] 8179 <- (0,15540)
[1] 8180 <- (0,15541)
[1] 8181 <- (0,15542)
[1] 8182 <- (0,15543)
[1] 8183 <- (0,15544)
[1] 8184 <- (0,15545)
[1] 8185 <- (0,15546)
[1] 8186 <- (0,15547)
[1] 8187 <- (0,15548)
[1] 8188 <- (0,15549)
[1] 8189 <- (0,15550)
[1] 8190 <- (0,15551)
[1] 8191 <- (0,15552)
[1] 8192 <- (0,15553)
[1] 8193 <- (0,15554)
[1] 8194 <- (0,15555)
[1] 8195 <- (0,15556)
[1] 8196 <- (0,15557)
[1] 8197 <- (0,15558)
[1] 8198 <- (0,15581)
[1] 8199 <- (0,15582)
[1] 8200 <- (0,15583)
[1] 8201 <- (0,15584)
[1] 8202 <- (0,15585)
[1] 8203 <- (0,15586)
[1] 8204 <- (0,15587)
[1] 8205 <- (0,15588)
[1] 8206 <- (0,15589)
[1] 8207 <- (0,15590)
[1] 8208 <- (0,15591)
[1] 8209 <- (0,15592)
[1] 8210 <- (0,15593)
[1] 8211 <- (0,15594)
[1] 8212 <- (0,15595)
[1] 8213 <- (0,15596)
[1] 8214 <- (0,15597)
[1] 8215 <- (0,15598)
[1] 8216 <- (0,15599)
[1] 8217 <- (0,15600)
[1] 8218 <- (0,15601)
[1] 8219 <- (0,15602)
[1] 8220 <- (0,15603)
[1] 8221 <- (0,15604)
[1] 8222 <- (0,15605)
[1] 8223 <- (0,15606)
[1] 8224 <- (0,15607)
[1] 8225 <- (0,15608)
[1] 8226 <- (0,15609)
[1] 8227 <- (0,15633)
[1] 8228 <- (0,15634)
[1] 8229 <- (0,15635)
[1] 8230 <- (0,15636)
[1] 8231 <- (0,15637)
[1] 8232 <- (0,15638)
[1] 8233 <- (0,15639)
[1] 8234 <- (0,15640)
[1] 8235 <- (0,15641)
[1] 8236 <- (0,15642)
[1] 8237 <- (0,15643)
[1] 8238 <- (0,15644)
[1] 8239 <- (0,15645)
[1] 8240 <- (0,15646)
[1] 8241 <- (0,15647)
[1] 8242 <- (0,15648)
[1] 8243 <- (0,15649)
[1] 8244 <- (0,15650)
[1] 8245 <- (0,15651)
[1] 8246 <- (0,15652)
[1] 8247 <- (0,15653)
[1] 8248 <- (0,15654)
[1] 8249 <- (0,15655)
[1] 8250 <- (0,15656)
[1] 8251 <- (0,15657)
[1] 8252 <- (0,15658)
[1] 8253 <- (0,15659)
[1] 8254 <- (0,15660)
[1] 8255 <- (0,15684)
[1] 8256 <- (0,15685)
[1] 8257 <- (0,15686)
[1] 8258 <- (0,15687)
[1] 8259 <- (0,15688)
[1] 8260 <- (0,15689)
[1] 8261 <- (0,15690)
[1] 8262 <- (0,15691)
[1] 8263 <- (0,15692)
[1] 8264 <- (0,15693)
[1] 8265 <- (0,15694)
[1] 8266 <- (0,15695)
[1] 8267 <- (0,15696)
[1] 8268 <- (0,15697)
[1] 8269 <- (0,15698)
[1] 8270 <- (0,15699)
[1] 8271 <- (0,15700)
[1] 8272 <- (0,15701)
[1] 8273 <- (0,15702)
[1] 8274 <- (0,15703)
[1] 8275 <- (0,15704)
[1] 8276 <- (0,15705)
[1] 8277 <- (0,15706)
[1] 8278 <- (0,15707)
[1] 8279 <- (0,15708)
[1] 8280 <- (0,15709)
[1] 8281 <- (0,15710)
[1] 8282 <- (0,15711)
[1] 8283 <- (0,15735)
[1] 8284 <- (0,15736)
[1] 8285 <- (0,15737)
[1] 8286 <- (0,15738)
[1] 8287 <- (0,15739)
[1] 8288 <- (0,15740)
[1] 8289 <- (0,15741)
[1] 8290 <- (0,15742)
[1] 8291 <- (0,15743)
[1] 8292 <- (0,15744)
[1] 8293 <- (0,15745)
[1] 8294 <- (0,15746)
[1] 8295 <- (0,15747)
[1] 8296 <- (0,15748)
[1] 8297 <- (0,15749)
[1] 8298 <- (0,15750)
[1] 8299 <- (0,15751)
[1] 8300 <- (0,15752)
[1] 8301 <- (0,15753)
[1] 8302 <- (0,15754)
[1] 8303 <- (0,15755)
[1] 8304 <- (0,15756)
[1] 8305 <- (0,15757)
[1] 8306 <- (0,15758)
[1] 8307 <- (0,15759)
[1] 8308 <- (0,15760)
[1] 8309 <- (0,15761)
[1] 8310 <- (0,15762)
[1] 8311 <- (0,15786)
[1] 8312 <- (0,15787)
[1] 8313 <- (0,15788)
[1] 8314 <- (0,15789)
[1] 8315 <- (0,15790)
[1] 8316 <- (0,15791)
[1] 8317 <- (0,15792)
[1] 8318 <- (0,15793)
[1] 8319 <- (0,15794)
[1] 8320 <- (0,15795)
[1] 8321 <- (0,15796)
[1] 8322 <- (0,15797)
[1] 8323 <- (0,15798)
[1] 8324 <- (0,15799)
[1] 8325 <- (0,15800)
[1] 8326 <- (0,15801)
[1] 8327 <- (0,15802)
[1] 8328 <- (0,15803)
[1] 8329 <- (0,15804)
[1] 8330 <- (0,15805)
[1] 8331 <- (0,15806)
[1] 8332 <- (0,15807)
[1] 8333 <- (0,15808)
[1] 8334 <- (0,15809)
[1] 8335 <- (0,15810)
[1] 8336 <- (0,15811)
[1] 8337 <- (0,15812)
[1] 8338 <- (0,15813)
[1] 8339 <- (0,15838)
[1] 8340 <- (0,15839)
[1] 8341 <- (0,15840)
[1] 8342 <- (0,15841)
[1] 8343 <- (0,15842)
[1] 8344 <- (0,15843)
[1] 8345 <- (0,15844)
[1] 8346 <- (0,15845)
[1] 8347 <- (0,15846)
[1] 8348 <- (0,15847)
[1] 8349 <- (0,15848)
[1] 8350 <- (0,15849)
[1] 8351 <- (0,15850)
[1] 8352 <- (0,15851)
[1] 8353 <- (0,15852)
[1] 8354 <- (0,15853)
[1] 8355 <- (0,15854)
[1] 8356 <- (0,15855)
[1] 8357 <- (0,15856)
[1] 8358 <- (0,15857)
[1] 8359 <- (0,15858)
[1] 8360 <- (0,15859)
[1] 8361 <- (0,15860)
[1] 8362 <- (0,15861)
[1] 8363 <- (0,15862)
[1] 8364 <- (0,15863)
[1] 8365 <- (0,15864)
[1] 8366 <- (0,15889)
[1] 8367 <- (0,15890)
[1] 8368 <- (0,15891)
[1] 8369 <- (0,15892)
[1] 8370 <- (0,15893)
[1] 8371 <- (0,15894)
[1] 8372 <- (0,15895)
[1] 8373 <- (0,15896)
[1] 8374 <- (0,15897)
[1] 8375 <- (0,15898)
[1] 8376 <- (0,15899)
[1] 8377 <- (0,15900)
[1] 8378 <- (0,15901)
[1] 8379 <- (0,15902)
[1] 8380 <- (0,15903)
[1] 8381 <- (0,15904)
[1] 8382 <- (0,15905)
[1] 8383 <- (0,15906)
[1] 8384 <- (0,15907)
[1] 8385 <- (0,15908)
[1] 8386 <- (0,15909)
[1] 8387 <- (0,15910)
[1] 8388 <- (0,15911)
[1] 8389 <- (0,15912)
[1] 8390 <- (0,15913)
[1] 8391 <- (0,15914)
[1] 8392 <- (0,15915)
[1] 8393 <- (0,15941)
[1] 8394 <- (0,15942)
[1] 8395 <- (0,15943)
[1] 8396 <- (0,15944)
[1] 8397 <- (0,15945)
[1] 8398 <- (0,15946)
[1] 8399 <- (0,15947)
[1] 8400 <- (0,15948)
[1] 8401 <- (0,15949)
[1] 8402 <- (0,15950)
[1] 8403 <- (0,15951)
[1] 8404 <- (0,15952)
[1] 8405 <- (0,15953)
[1] 8406 <- (0,15954)
[1] 8407 <- (0,15955)
[1] 8408 <- (0,15956)
[1] 8409 <- (0,15957)
[1] 8410 <- (0,15958)
[1] 8411 <- (0,15959)
[1] 8412 <- (0,15960)
[1] 8413 <- (0,15961)
[1] 8414 <- (0,15962)
[1] 8415 <- (0,15963)
[1] 8416 <- (0,15964)
[1] 8417 <- (0,15965)
[1] 8418 <- (0,15966)
[1] 8419 <- (0,15993)
[1] 8420 <- (0,15994)
[1] 8421 <- (0,15995)
[1] 8422 <- (0,15996)
[1] 8423 <- (0,15997)
[1] 8424 <- (0,15998)
[1] 8425 <- (0,15999)
[1] 8426 <- (0,16000)
[1] 8427 <- (0,16001)
[1] 8428 <- (0,16002)
[1] 8429 <- (0,16003)
[1] 8430 <- (0,16004)
[1] 8431 <- (0,16005)
[1] 8432 <- (0,16006)
[1] 8433 <- (0,16007)
[1] 8434 <- (0,16008)
[1] 8435 <- (0,16009)
[1] 8436 <- (0,16010)
[1] 8437 <- (0,16011)
[1] 8438 <- (0,16012)
[1] 8439 <- (0,16013)
[1] 8440 <- (0,16014)
[1] 8441 <- (0,16015)
[1] 8442 <- (0,16016)
[1] 8443 <- (0,16017)
[1] 8444 <- (0,16044)
[1] 8445 <- (0,16045)
[1] 8446 <- (0,16046)
[1] 8447 <- (0,16047)
[1] 8448 <- (0,16048)
[1] 8449 <- (0,16049)
[1] 8450 <- (0,16050)
[1] 8451 <- (0,16051)
[1] 8452 <- (0,16052)
[1] 8453 <- (0,16053)
[1] 8454 <- (0,16054)
[1] 8455 <- (0,16055)
[1] 8456 <- (0,16056)
[1] 8457 <- (0,16057)
[1] 8458 <- (0,16058)
[1] 8459 <- (0,16059)
[1] 8460 <- (0,16060)
[1] 8461 <- (0,16061)
[1] 8462 <- (0,16062)
[1] 8463 <- (0,16063)
[1] 8464 <- (0,16064)
[1] 8465 <- (0,16065)
[1] 8466 <- (0,16066)
[1] 8467 <- (0,16067)
[1] 8468 <- (0,16068)
[1] 8469 <- (0,16096)
[1] 8470 <- (0,16097)
[1] 8471 <- (0,16098)
[1] 8472 <- (0,16099)
[1] 8473 <- (0,16100)
[1] 8474 <- (0,16101)
[1] 8475 <- (0,16102)
[1] 8476 <- (0,16103)
[1] 8477 <- (0,16104)
[1] 8478 <- (0,16105)
[1] 8479 <- (0,16106)
[1] 8480 <- (0,16107)
[1] 8481 <- (0,16108)
[1] 8482 <- (0,16109)
[1] 8483 <- (0,16110)
[1] 8484 <- (0,16111)
[1] 8485 <- (0,16112)
[1] 8486 <- (0,16113)
[1] 8487 <- (0,16114)
[1] 8488 <- (0,16115)
[1] 8489 <- (0,16116)
[1] 8490 <- (0,16117)
[1] 8491 <- (0,16118)
[1] 8492 <- (0,16119)
[1] 8493 <- (0,16147)
[1] 8494 <- (0,16148)
[1] 8495 <- (0,16149)
[1] 8496 <- (0,16150)
[1] 8497 <- (0,16151)
[1] 8498 <- (0,16152)
[1] 8499 <- (0,16153)
[1] 8500 <- (0,16154)
[1] 8501 <- (0,16155)
[1] 8502 <- (0,16156)
[1] 8503 <- (0,16157)
[1] 8504 <- (0,16158)
[1] 8505 <- (0,16159)
[1] 8506 <- (0,16160)
[1] 8507 <- (0,16161)
[1] 8508 <- (0,16162)
[1] 8509 <- (0,16163)
[1] 8510 <- (0,16164)
[1] 8511 <- (0,16165)
[1] 8512 <- (0,16166)
[1] 8513 <- (0,16167)
[1] 8514 <- (0,16168)
[1] 8515 <- (0,16169)
[1] 8516 <- (0,16170)
[1] 8517 <- (0,16198)
[1] 8518 <- (0,16199)
[1] 8519 <- (0,16200)
[1] 8520 <- (0,16201)
[1] 8521 <- (0,16202)
[1] 8522 <- (0,16203)
[1] 8523 <- (0,16204)
[1] 8524 <- (0,16205)
[1] 8525 <- (0,16206)
[1] 8526 <- (0,16207)
[1] 8527 <- (0,16208)
[1] 8528 <- (0,16209)
[1] 8529 <- (0,16210)
[1] 8530 <- (0,16211)
[1] 8531 <- (0,16212)
[1] 8532 <- (0,16213)
[1] 8533 <- (0,16214)
[1] 8534 <- (0,16215)
[1] 8535 <- (0,16216)
[1] 8536 <- (0,16217)
[1] 8537 <- (0,16218)
[1] 8538 <- (0,16219)
[1] 8539 <- (0,16220)
[1] 8540 <- (0,16221)
[1] 8541 <- (0,16249)
[1] 8542 <- (0,16250)
[1] 8543 <- (0,16251)
[1] 8544 <- (0,16252)
[1] 8545 <- (0,16253)
[1] 8546 <- (0,16254)
[1] 8547 <- (0,16255)
[1] 8548 <- (0,16256)
[1] 8549 <- (0,16257)
[1] 8550 <- (0,16258)
[1] 8551 <- (0,16259)
[1] 8552 <- (0,16260)
[1] 8553 <- (0,16261)
[1] 8554 <- (0,16262)
[1] 8555 <- (0,16263)
[1] 8556 <- (0,16264)
[1] 8557 <- (0,16265)
[1] 8558 <- (0,16266)
[1] 8559 <- (0,16267)
[1] 8560 <- (0,16268)
[1] 8561 <- (0,16269)
[1] 8562 <- (0,16270)
[1] 8563 <- (0,16271)
[1] 8564 <- (0,16272)
[1] 8565 <- (0,16300)
[1] 8566 <- (0,16301)
[1] 8567 <- (0,16302)
[1] 8568 <- (0,16303)
[1] 8569 <- (0,16304)
[1] 8570 <- (0,16305)
[1] 8571 <- (0,16306)
[1] 8572 <- (0,16307)
[1] 8573 <- (0,16308)
[1] 8574 <- (0,16309)
[1] 8575 <- (0,16310)
[1] 8576 <- (0,16311)
[1] 8577 <- (0,16312)
[1] 8578 <- (0,16313)
[1] 8579 <- (0,16314)
[1] 8580 <- (0,16315)
[1] 8581 <- (0,16316)
[1] 8582 <- (0,16317)
[1] 8583 <- (0,16318)
[1] 8584 <- (0,16319)
[1] 8585 <- (0,16320)
[1] 8586 <- (0,16321)
[1] 8587 <- (0,16322)
[1] 8588 <- (0,16323)
[1] 8589 <- (0,16351)
[1] 8590 <- (0,16352)
[1] 8591 <- (0,16353)
[1] 8592 <- (0,16354)
[1] 8593 <- (0,16355)
[1] 8594 <- (0,16356)
[1] 8595 <- (0,16357)
[1] 8596 <- (0,16358)
[1] 8597 <- (0,16359)
[1] 8598 <- (0,16360)
[1] 8599 <- (0,16361)
[1] 8600 <- (0,16362)
[1] 8601 <- (0,16363)
[1] 8602 <- (0,16364)
[1] 8603 <- (0,16365)
[1] 8604 <- (0,16366)
[1] 8605 <- (0,16367)
[1] 8606 <- (0,16368)
[1] 8607 <- (0,16369)
[1] 8608 <- (0,16370)
[1] 8609 <- (0,16371)
[1] 8610 <- (0,16372)
[1] 8611 <- (0,16373)
[1] 8612 <- (0,16374)
[1] 8613 <- (0,16402)
[1] 8614 <- (0,16403)
[1] 8615 <- (0,16404)
[1] 8616 <- (0,16405)
[1] 8617 <- (0,16406)
[1] 8618 <- (0,16407)
[1] 8619 <- (0,16408)
[1] 8620 <- (0,16409)
[1] 8621 <- (0,16410)
[1] 8622 <- (0,16411)
[1] 8623 <- (0,16412)
[1] 8624 <- (0,16413)
[1] 8625 <- (0,16414)
[1] 8626 <- (0,16415)
[1] 8627 <- (0,16416)
[1] 8628 <- (0,16417)
[1] 8629 <- (0,16418)
[1] 8630 <- (0,16419)
[1] 8631 <- (0,16420)
[1] 8632 <- (0,16421)
[1] 8633 <- (0,16422)
[1] 8634 <- (0,16423)
[1] 8635 <- (0,16424)
[1] 8636 <- (0,16425)
[1] 8637 <- (0,16448)
[1] 8638 <- (0,16449)
[1] 8639 <- (0,16450)
[1] 8640 <- (0,16451)
[1] 8641 <- (0,16452)
[1] 8642 <- (0,16453)
[1] 8643 <- (0,16454)
[1] 8644 <- (0,16455)
[1] 8645 <- (0,16456)
[1] 8646 <- (0,16457)
[1] 8647 <- (0,16458)
[1] 8648 <- (0,16459)
[1] 8649 <- (0,16460)
[1] 8650 <- (0,16461)
[1] 8651 <- (0,16462)
[1] 8652 <- (0,16463)
[1] 8653 <- (0,16464)
[1] 8654 <- (0,16465)
[1] 8655 <- (0,16466)
[1] 8656 <- (0,16467)
[1] 8657 <- (0,16468)
[1] 8658 <- (0,16469)
[1] 8659 <- (0,16470)
[1] 8660 <- (0,16471)
[1] 8661 <- (0,16472)
[1] 8662 <- (0,16473)
[1] 8663 <- (0,16474)
[1] 8664 <- (0,16475)
[1] 8665 <- (0,16476)
[1] 8666 <- (0,16499)
[1] 8667 <- (0,16500)
[1] 8668 <- (0,16501)
[1] 8669 <- (0,16502)
[1] 8670 <- (0,16503)
[1] 8671 <- (0,16504)
[1] 8672 <- (0,16505)
[1] 8673 <- (0,16506)
[1] 8674 <- (0,16507)
[1] 8675 <- (0,16508)
[1] 8676 <- (0,16509)
[1] 8677 <- (0,16510)
[1] 8678 <- (0,16511)
[1] 8679 <- (0,16512)
[1] 8680 <- (0,16513)
[1] 8681 <- (0,16514)
[1] 8682 <- (0,16515)
[1] 8683 <- (0,16516)
[1] 8684 <- (0,16517)
[1] 8685 <- (0,16518)
[1] 8686 <- (0,16519)
[1] 8687 <- (0,16520)
[1] 8688 <- (0,16521)
[1] 8689 <- (0,16522)
[1] 8690 <- (0,16523)
[1] 8691 <- (0,16524)
[1] 8692 <- (0,16525)
[1] 8693 <- (0,16526)
[1] 8694 <- (0,16527)
[1] 8695 <- (0,16550)
[1] 8696 <- (0,16551)
[1] 8697 <- (0,16552)
[1] 8698 <- (0,16553)
[1] 8699 <- (0,16554)
[1] 8700 <- (0,16555)
[1] 8701 <- (0,16556)
[1] 8702 <- (0,16557)
[1] 8703 <- (0,16558)
[1] 8704 <- (0,16559)
[1] 8705 <- (0,16560)
[1] 8706 <- (0,16561)
[1] 8707 <- (0,16562)
[1] 8708 <- (0,16563)
[1] 8709 <- (0,16564)
[1] 8710 <- (0,16565)
[1] 8711 <- (0,16566)
[1] 8712 <- (0,16567)
[1] 8713 <- (0,16568)
[1] 8714 <- (0,16569)
[1] 8715 <- (0,16570)
[1] 8716 <- (0,16571)
[1] 8717 <- (0,16572)
[1] 8718 <- (0,16573)
[1] 8719 <- (0,16574)
[1] 8720 <- (0,16575)
[1] 8721 <- (0,16576)
[1] 8722 <- (0,16577)
[1] 8723 <- (0,16578)
[1] 8724 <- (0,16601)
[1] 8725 <- (0,16602)
[1] 8726 <- (0,16603)
[1] 8727 <- (0,16604)
[1] 8728 <- (0,16605)
[1] 8729 <- (0,16606)
[1] 8730 <- (0,16607)
[1] 8731 <- (0,16608)
[1] 8732 <- (0,16609)
[1] 8733 <- (0,16610)
[1] 8734 <- (0,16611)
[1] 8735 <- (0,16612)
[1] 8736 <- (0,16613)
[1] 8737 <- (0,16614)
[1] 8738 <- (0,16615)
[1] 8739 <- (0,16616)
[1] 8740 <- (0,16617)
[1] 8741 <- (0,16618)
[1] 8742 <- (0,16619)
[1] 8743 <- (0,16620)
[1] 8744 <- (0,16621)
[1] 8745 <- (0,16622)
[1] 8746 <- (0,16623)
[1] 8747 <- (0,16624)
[1] 8748 <- (0,16625)
[1] 8749 <- (0,16626)
[1] 8750 <- (0,16627)
[1] 8751 <- (0,16628)
[1] 8752 <- (0,16629)
[1] 8753 <- (0,16652)
[1] 8754 <- (0,16653)
[1] 8755 <- (0,16654)
[1] 8756 <- (0,16655)
[1] 8757 <- (0,16656)
[1] 8758 <- (0,16657)
[1] 8759 <- (0,16658)
[1] 8760 <- (0,16659)
[1] 8761 <- (0,16660)
[1] 8762 <- (0,16661)
[1] 8763 <- (0,16662)
[1] 8764 <- (0,16663)
[1] 8765 <- (0,16664)
[1] 8766 <- (0,16665)
[1] 8767 <- (0,16666)
[1] 8768 <- (0,16667)
[1] 8769 <- (0,16668)
[1] 8770 <- (0,16669)
[1] 8771 <- (0,16670)
[1] 8772 <- (0,16671)
[1] 8773 <- (0,16672)
[1] 8774 <- (0,16673)
[1] 8775 <- (0,16674)
[1] 8776 <- (0,16675)
[1] 8777 <- (0,16676)
[1] 8778 <- (0,16677)
[1] 8779 <- (0,16678)
[1] 8780 <- (0,16679)
[1] 8781 <- (0,16680)
[1] 8782 <- (0,16704)
[1] 8783 <- (0,16705)
[1] 8784 <- (0,16706)
[1] 8785 <- (0,16707)
[1] 8786 <- (0,16708)
[1] 8787 <- (0,16709)
[1] 8788 <- (0,16710)
[1] 8789 <- (0,16711)
[1] 8790 <- (0,16712)
[1] 8791 <- (0,16713)
[1] 8792 <- (0,16714)
[1] 8793 <- (0,16715)
[1] 8794 <- (0,16716)
[1] 8795 <- (0,16717)
[1] 8796 <- (0,16718)
[1] 8797 <- (0,16719)
[1] 8798 <- (0,16720)
[1] 8799 <- (0,16721)
[1] 8800 <- (0,16722)
[1] 8801 <- (0,16723)
[1] 8802 <- (0,16724)
[1] 8803 <- (0,16725)
[1] 8804 <- (0,16726)
[1] 8805 <- (0,16727)
[1] 8806 <- (0,16728)
[1] 8807 <- (0,16729)
[1] 8808 <- (0,16730)
[1] 8809 <- (0,16731)
[1] 8810 <- (0,16755)
[1] 8811 <- (0,16756)
[1] 8812 <- (0,16757)
[1] 8813 <- (0,16758)
[1] 8814 <- (0,16759)
[1] 8815 <- (0,16760)
[1] 8816 <- (0,16761)
[1] 8817 <- (0,16762)
[1] 8818 <- (0,16763)
[1] 8819 <- (0,16764)
[1] 8820 <- (0,16765)
[1] 8821 <- (0,16766)
[1] 8822 <- (0,16767)
[1] 8823 <- (0,16768)
[1] 8824 <- (0,16769)
[1] 8825 <- (0,16770)
[1] 8826 <- (0,16771)
[1] 8827 <- (0,16772)
[1] 8828 <- (0,16773)
[1] 8829 <- (0,16774)
[1] 8830 <- (0,16775)
[1] 8831 <- (0,16776)
[1] 8832 <- (0,16777)
[1] 8833 <- (0,16778)
[1] 8834 <- (0,16779)
[1] 8835 <- (0,16780)
[1] 8836 <- (0,16781)
[1] 8837 <- (0,16782)
[1] 8838 <- (0,16806)
[1] 8839 <- (0,16807)
[1] 8840 <- (0,16808)
[1] 8841 <- (0,16809)
[1] 8842 <- (0,16810)
[1] 8843 <- (0,16811)
[1] 8844 <- (0,16812)
[1] 8845 <- (0,16813)
[1] 8846 <- (0,16814)
[1] 8847 <- (0,16815)
[1] 8848 <- (0,16816)
[1] 8849 <- (0,16817)
[1] 8850 <- (0,16818)
[1] 8851 <- (0,16819)
[1] 8852 <- (0,16820)
[1] 8853 <- (0,16821)
[1] 8854 <- (0,16822)
[1] 8855 <- (0,16823)
[1] 8856 <- (0,16824)
[1] 8857 <- (0,16825)
[1] 8858 <- (0,16826)
[1] 8859 <- (0,16827)
[1] 8860 <- (0,16828)
[1] 8861 <- (0,16829)
[1] 8862 <- (0,16830)
[1] 8863 <- (0,16831)
[1] 8864 <- (0,16832)
[1] 8865 <- (0,16833)
[1] 8866 <- (0,16857)
[1] 8867 <- (0,16858)
[1] 8868 <- (0,16859)
[1] 8869 <- (0,16860)
[1] 8870 <- (0,16861)
[1] 8871 <- (0,16862)
[1] 8872 <- (0,16863)
[1] 8873 <- (0,16864)
[1] 8874 <- (0,16865)
[1] 8875 <- (0,16866)
[1] 8876 <- (0,16867)
[1] 8877 <- (0,16868)
[1] 8878 <- (0,16869)
[1] 8879 <- (0,16870)
[1] 8880 <- (0,16871)
[1] 8881 <- (0,16872)
[1] 8882 <- (0,16873)
[1] 8883 <- (0,16874)
[1] 8884 <- (0,16875)
[1] 8885 <- (0,16876)
[1] 8886 <- (0,16877)
[1] 8887 <- (0,16878)
[1] 8888 <- (0,16879)
[1] 8889 <- (0,16880)
[1] 8890 <- (0,16881)
[1] 8891 <- (0,16882)
[1] 8892 <- (0,16883)
[1] 8893 <- (0,16884)
[1] 8894 <- (0,16909)
[1] 8895 <- (0,16910)
[1] 8896 <- (0,16911)
[1] 8897 <- (0,16912)
[1] 8898 <- (0,16913)
[1] 8899 <- (0,16914)
[1] 8900 <- (0,16915)
[1] 8901 <- (0,16916)
[1] 8902 <- (0,16917)
[1] 8903 <- (0,16918)
[1] 8904 <- (0,16919)
[1] 8905 <- (0,16920)
[1] 8906 <- (0,16921)
[1] 8907 <- (0,16922)
[1] 8908 <- (0,16923)
[1] 8909 <- (0,16924)
[1] 8910 <- (0,16925)
[1] 8911 <- (0,16926)
[1] 8912 <- (0,16927)
[1] 8913 <- (0,16928)
[1] 8914 <- (0,16929)
[1] 8915 <- (0,16930)
[1] 8916 <- (0,16931)
[1] 8917 <- (0,16932)
[1] 8918 <- (0,16933)
[1] 8919 <- (0,16934)
[1] 8920 <- (0,16935)
[1] 8921 <- (0,16960)
[1] 8922 <- (0,16961)
[1] 8923 <- (0,16962)
[1] 8924 <- (0,16963)
[1] 8925 <- (0,16964)
[1] 8926 <- (0,16965)
[1] 8927 <- (0,16966)
[1] 8928 <- (0,16967)
[1] 8929 <- (0,16968)
[1] 8930 <- (0,16969)
[1] 8931 <- (0,16970)
[1] 8932 <- (0,16971)
[1] 8933 <- (0,16972)
[1] 8934 <- (0,16973)
[1] 8935 <- (0,16974)
[1] 8936 <- (0,16975)
[1] 8937 <- (0,16976)
[1] 8938 <- (0,16977)
[1] 8939 <- (0,16978)
[1] 8940 <- (0,16979)
[1] 8941 <- (0,16980)
[1] 8942 <- (0,16981)
[1] 8943 <- (0,16982)
[1] 8944 <- (0,16983)
[1] 8945 <- (0,16984)
[1] 8946 <- (0,16985)
[1] 8947 <- (0,16986)
[1] 8948 <- (0,17012)
[1] 8949 <- (0,17013)
[1] 8950 <- (0,17014)
[1] 8951 <- (0,17015)
[1] 8952 <- (0,17016)
[1] 8953 <- (0,17017)
[1] 8954 <- (0,17018)
[1] 8955 <- (0,17019)
[1] 8956 <- (0,17020)
[1] 8957 <- (0,17021)
[1] 8958 <- (0,17022)
[1] 8959 <- (0,17023)
[1] 8960 <- (0,17024)
[1] 8961 <- (0,17025)
[1] 8962 <- (0,17026)
[1] 8963 <- (0,17027)
[1] 8964 <- (0,17028)
[1] 8965 <- (0,17029)
[1] 8966 <- (0,17030)
[1] 8967 <- (0,17031)
[1] 8968 <- (0,17032)
[1] 8969 <- (0,17033)
[1] 8970 <- (0,17034)
[1] 8971 <- (0,17035)
[1] 8972 <- (0,17036)
[1] 8973 <- (0,17037)
[1] 8974 <- (0,17064)
[1] 8975 <- (0,17065)
[1] 8976 <- (0,17066)
[1] 8977 <- (0,17067)
[1] 8978 <- (0,17068)
[1] 8979 <- (0,17069)
[1] 8980 <- (0,17070)
[1] 8981 <- (0,17071)
[1] 8982 <- (0,17072)
[1] 8983 <- (0,17073)
[1] 8984 <- (0,17074)
[1] 8985 <- (0,17075)
[1] 8986 <- (0,17076)
[1] 8987 <- (0,17077)
[1] 8988 <- (0,17078)
[1] 8989 <- (0,17079)
[1] 8990 <- (0,17080)
[1] 8991 <- (0,17081)
[1] 8992 <- (0,17082)
[1] 8993 <- (0,17083)
[1] 8994 <- (0,17084)
[1] 8995 <- (0,17085)
[1] 8996 <- (0,17086)
[1] 8997 <- (0,17087)
[1] 8998 <- (0,17088)
[1] 8999 <- (0,17115)
[1] 9000 <- (0,17116)
[1] 9001 <- (0,17117)
[1] 9002 <- (0,17118)
[1] 9003 <- (0,17119)
[1] 9004 <- (0,17120)
[1] 9005 <- (0,17121)
[1] 9006 <- (0,17122)
[1] 9007 <- (0,17123)
[1] 9008 <- (0,17124)
[1] 9009 <- (0,17125)
[1] 9010 <- (0,17126)
[1] 9011 <- (0,17127)
[1] 9012 <- (0,17128)
[1] 9013 <- (0,17129)
[1] 9014 <- (0,17130)
[1] 9015 <- (0,17131)
[1] 9016 <- (0,17132)
[1] 9017 <- (0,17133)
[1] 9018 <- (0,17134)
[1] 9019 <- (0,17135)
[1] 9020 <- (0,17136)
[1] 9021 <- (0,17137)
[1] 9022 <- (0,17138)
[1] 9023 <- (0,17139)
[1] 9024 <- (0,17167)
[1] 9025 <- (0,17168)
[1] 9026 <- (0,17169)
[1] 9027 <- (0,17170)
[1] 9028 <- (0,17171)
[1] 9029 <- (0,17172)
[1] 9030 <- (0,17173)
[1] 9031 <- (0,17174)
[1] 9032 <- (0,17175)
[1] 9033 <- (0,17176)
[1] 9034 <- (0,17177)
[1] 9035 <- (0,17178)
[1] 9036 <- (0,17179)
[1] 9037 <- (0,17180)
[1] 9038 <- (0,17181)
[1] 9039 <- (0,17182)
[1] 9040 <- (0,17183)
[1] 9041 <- (0,17184)
[1] 9042 <- (0,17185)
[1] 9043 <- (0,17186)
[1] 9044 <- (0,17187)
[1] 9045 <- (0,17188)
[1] 9046 <- (0,17189)
[1] 9047 <- (0,17190)
[1] 9048 <- (0,17218)
[1] 9049 <- (0,17219)
[1] 9050 <- (0,17220)
[1] 9051 <- (0,17221)
[1] 9052 <- (0,17222)
[1] 9053 <- (0,17223)
[1] 9054 <- (0,17224)
[1] 9055 <- (0,17225)
[1] 9056 <- (0,17226)
[1] 9057 <- (0,17227)
[1] 9058 <- (0,17228)
[1] 9059 <- (0,17229)
[1] 9060 <- (0,17230)
[1] 9061 <- (0,17231)
[1] 9062 <- (0,17232)
[1] 9063 <- (0,17233)
[1] 9064 <- (0,17234)
[1] 9065 <- (0,17235)
[1] 9066 <- (0,17236)
[1] 9067 <- (0,17237)
[1] 9068 <- (0,17238)
[1] 9069 <- (0,17239)
[1] 9070 <- (0,17240)
[1] 9071 <- (0,17241)
[1] 9072 <- (0,17269)
[1] 9073 <- (0,17270)
[1] 9074 <- (0,17271)
[1] 9075 <- (0,17272)
[1] 9076 <- (0,17273)
[1] 9077 <- (0,17274)
[1] 9078 <- (0,17275)
[1] 9079 <- (0,17276)
[1] 9080 <- (0,17277)
[1] 9081 <- (0,17278)
[1] 9082 <- (0,17279)
[1] 9083 <- (0,17280)
[1] 9084 <- (0,17281)
[1] 9085 <- (0,17282)
[1] 9086 <- (0,17283)
[1] 9087 <- (0,17284)
[1] 9088 <- (0,17285)
[1] 9089 <- (0,17286)
[1] 9090 <- (0,17287)
[1] 9091 <- (0,17288)
[1] 9092 <- (0,17289)
[1] 9093 <- (0,17290)
[1] 9094 <- (0,17291)
[1] 9095 <- (0,17292)
[1] 9096 <- (0,17320)
[1] 9097 <- (0,17321)
[1] 9098 <- (0,17322)
[1] 9099 <- (0,17323)
[1] 9100 <- (0,17324)
[1] 9101 <- (0,17325)
[1] 9102 <- (0,17326)
[1] 9103 <- (0,17327)
[1] 9104 <- (0,17328)
[1] 9105 <- (0,17329)
[1] 9106 <- (0,17330)
[1] 9107 <- (0,17331)
[1] 9108 <- (0,17332)
[1] 9109 <- (0,17333)
[1] 9110 <- (0,17334)
[1] 9111 <- (0,17335)
[1] 9112 <- (0,17336)
[1] 9113 <- (0,17337)
[1] 9114 <- (0,17338)
[1] 9115 <- (0,17339)
[1] 9116 <- (0,17340)
[1] 9117 <- (0,17341)
[1] 9118 <- (0,17342)
[1] 9119 <- (0,17343)
[1] 9120 <- (0,17371)
[1] 9121 <- (0,17372)
[1] 9122 <- (0,17373)
[1] 9123 <- (0,17374)
[1] 9124 <- (0,17375)
[1] 9125 <- (0,17376)
[1] 9126 <- (0,17377)
[1] 9127 <- (0,17378)
[1] 9128 <- (0,17379)
[1] 9129 <- (0,17380)
[1] 9130 <- (0,17381)
[1] 9131 <- (0,17382)
[1] 9132 <- (0,17383)
[1] 9133 <- (0,17384)
[1] 9134 <- (0,17385)
[1] 9135 <- (0,17386)
[1] 9136 <- (0,17387)
[1] 9137 <- (0,17388)
[1] 9138 <- (0,17389)
[1] 9139 <- (0,17390)
[1] 9140 <- (0,17391)
[1] 9141 <- (0,17392)
[1] 9142 <- (0,17393)
[1] 9143 <- (0,17394)
[1] 9144 <- (0,17422)
[1] 9145 <- (0,17423)
[1] 9146 <- (0,17424)
[1] 9147 <- (0,17425)
[1] 9148 <- (0,17426)
[1] 9149 <- (0,17427)
[1] 9150 <- (0,17428)
[1] 9151 <- (0,17429)
[1] 9152 <- (0,17430)
[1] 9153 <- (0,17431)
[1] 9154 <- (0,17432)
[1] 9155 <- (0,17433)
[1] 9156 <- (0,17434)
[1] 9157 <- (0,17435)
[1] 9158 <- (0,17436)
[1] 9159 <- (0,17437)
[1] 9160 <- (0,17438)
[1] 9161 <- (0,17439)
[1] 9162 <- (0,17440)
[1] 9163 <- (0,17441)
[1] 9164 <- (0,17442)
[1] 9165 <- (0,17443)
[1] 9166 <- (0,17444)
[1] 9167 <- (0,17445)
[1] 9168 <- (0,17473)
[1] 9169 <- (0,17474)
[1] 9170 <- (0,17475)
[1] 9171 <- (0,17476)
[1] 9172 <- (0,17477)
[1] 9173 <- (0,17478)
[1] 9174 <- (0,17479)
[1] 9175 <- (0,17480)
[1] 9176 <- (0,17481)
[1] 9177 <- (0,17482)
[1] 9178 <- (0,17483)
[1] 9179 <- (0,17484)
[1] 9180 <- (0,17485)
[1] 9181 <- (0,17486)
[1] 9182 <- (0,17487)
[1] 9183 <- (0,17488)
[1] 9184 <- (0,17489)
[1] 9185 <- (0,17490)
[1] 9186 <- (0,17491)
[1] 9187 <- (0,17492)
[1] 9188 <- (0,17493)
[1] 9189 <- (0,17494)
[1] 9190 <- (0,17495)
[1] 9191 <- (0,17496)
[1] 9192 <- (0,17519)
[1] 9193 <- (0,17520)
[1] 9194 <- (0,17521)
[1] 9195 <- (0,17522)
[1] 9196 <- (0,17523)
[1] 9197 <- (0,17524)
[1] 9198 <- (0,17525)
[1] 9199 <- (0,17526)
[1] 9200 <- (0,17527)
[1] 9201 <- (0,17528)
[1] 9202 <- (0,17529)
[1] 9203 <- (0,17530)
[1] 9204 <- (0,17531)
[1] 9205 <- (0,17532)
[1] 9206 <- (0,17533)
[1] 9207 <- (0,17534)
[1] 9208 <- (0,17535)
[1] 9209 <- (0,17536)
[1] 9210 <- (0,17537)
[1] 9211 <- (0,17538)
[1] 9212 <- (0,17539)
[1] 9213 <- (0,17540)
[1] 9214 <- (0,17541)
[1] 9215 <- (0,17542)
[1] 9216 <- (0,17543)
[1] 9217 <- (0,17544)
[1] 9218 <- (0,17545)
[1] 9219 <- (0,17546)
[1] 9220 <- (0,17547)
[1] 9221 <- (0,17570)
[1] 9222 <- (0,17571)
[1] 9223 <- (0,17572)
[1] 9224 <- (0,17573)
[1] 9225 <- (0,17574)
[1] 9226 <- (0,17575)
[1] 9227 <- (0,17576)
[1] 9228 <- (0,17577)
[1] 9229 <- (0,17578)
[1] 9230 <- (0,17579)
[1] 9231 <- (0,17580)
[1] 9232 <- (0,17581)
[1] 9233 <- (0,17582)
[1] 9234 <- (0,17583)
[1] 9235 <- (0,17584)
[1] 9236 <- (0,17585)
[1] 9237 <- (0,17586)
[1] 9238 <- (0,17587)
[1] 9239 <- (0,17588)
[1] 9240 <- (0,17589)
[1] 9241 <- (0,17590)
[1] 9242 <- (0,17591)
[1] 9243 <- (0,17592)
[1] 9244 <- (0,17593)
[1] 9245 <- (0,17594)
[1] 9246 <- (0,17595)
[1] 9247 <- (0,17596)
[1] 9248 <- (0,17597)
[1] 9249 <- (0,17598)
[1] 9250 <- (0,17621)
[1] 9251 <- (0,17622)
[1] 9252 <- (0,17623)
[1] 9253 <- (0,17624)
[1] 9254 <- (0,17625)
[1] 9255 <- (0,17626)
[1] 9256 <- (0,17627)
[1] 9257 <- (0,17628)
[1] 9258 <- (0,17629)
[1] 9259 <- (0,17630)
[1] 9260 <- (0,17631)
[1] 9261 <- (0,17632)
[1] 9262 <- (0,17633)
[1] 9263 <- (0,17634)
[1] 9264 <- (0,17635)
[1] 9265 <- (0,17636)
[1] 9266 <- (0,17637)
[1] 9267 <- (0,17638)
[1] 9268 <- (0,17639)
[1] 9269 <- (0,17640)
[1] 9270 <- (0,17641)
[1] 9271 <- (0,17642)
[1] 9272 <- (0,17643)
[1] 9273 <- (0,17644)
[1] 9274 <- (0,17645)
[1] 9275 <- (0,17646)
[1] 9276 <- (0,17647)
[1] 9277 <- (0,17648)
[1] 9278 <- (0,17649)
[1] 9279 <- (0,17672)
[1] 9280 <- (0,17673)
[1] 9281 <- (0,17674)
[1] 9282 <- (0,17675)
[1] 9283 <- (0,17676)
[1] 9284 <- (0,17677)
[1] 9285 <- (0,17678)
[1] 9286 <- (0,17679)
[1] 9287 <- (0,17680)
[1] 9288 <- (0,17681)
[1] 9289 <- (0,17682)
[1] 9290 <- (0,17683)
[1] 9291 <- (0,17684)
[1] 9292 <- (0,17685)
[1] 9293 <- (0,17686)
[1] 9294 <- (0,17687)
[1] 9295 <- (0,17688)
[1] 9296 <- (0,17689)
[1] 9297 <- (0,17690)
[1] 9298 <- (0,17691)
[1] 9299 <- (0,17692)
[1] 9300 <- (0,17693)
[1] 9301 <- (0,17694)
[1] 9302 <- (0,17695)
[1] 9303 <- (0,17696)
[1] 9304 <- (0,17697)
[1] 9305 <- (0,17698)
[1] 9306 <- (0,17699)
[1] 9307 <- (0,17700)
[1] 9308 <- (0,17723)
[1] 9309 <- (0,17724)
[1] 9310 <- (0,17725)
[1] 9311 <- (0,17726)
[1] 9312 <- (0,17727)
[1] 9313 <- (0,17728)
[1] 9314 <- (0,17729)
[1] 9315 <- (0,17730)
[1] 9316 <- (0,17731)
[1] 9317 <- (0,17732)
[1] 9318 <- (0,17733)
[1] 9319 <- (0,17734)
[1] 9320 <- (0,17735)
[1] 9321 <- (0,17736)
[1] 9322 <- (0,17737)
[1] 9323 <- (0,17738)
[1] 9324 <- (0,17739)
[1] 9325 <- (0,17740)
[1] 9326 <- (0,17741)
[1] 9327 <- (0,17742)
[1] 9328 <- (0,17743)
[1] 9329 <- (0,17744)
[1] 9330 <- (0,17745)
[1] 9331 <- (0,17746)
[1] 9332 <- (0,17747)
[1] 9333 <- (0,17748)
[1] 9334 <- (0,17749)
[1] 9335 <- (0,17750)
[1] 9336 <- (0,17751)
[1] 9337 <- (0,17775)
[1] 9338 <- (0,17776)
[1] 9339 <- (0,17777)
[1] 9340 <- (0,17778)
[1] 9341 <- (0,17779)
[1] 9342 <- (0,17780)
[1] 9343 <- (0,17781)
[1] 9344 <- (0,17782)
[1] 9345 <- (0,17783)
[1] 9346 <- (0,17784)
[1] 9347 <- (0,17785)
[1] 9348 <- (0,17786)
[1] 9349 <- (0,17787)
[1] 9350 <- (0,17788)
[1] 9351 <- (0,17789)
[1] 9352 <- (0,17790)
[1] 9353 <- (0,17791)
[1] 9354 <- (0,17792)
[1] 9355 <- (0,17793)
[1] 9356 <- (0,17794)
[1] 9357 <- (0,17795)
[1] 9358 <- (0,17796)
[1] 9359 <- (0,17797)
[1] 9360 <- (0,17798)
[1] 9361 <- (0,17799)
[1] 9362 <- (0,17800)
[1] 9363 <- (0,17801)
[1] 9364 <- (0,17802)
[1] 9365 <- (0,17826)
[1] 9366 <- (0,17827)
[1] 9367 <- (0,17828)
[1] 9368 <- (0,17829)
[1] 9369 <- (0,17830)
[1] 9370 <- (0,17831)
[1] 9371 <- (0,17832)
[1] 9372 <- (0,17833)
[1] 9373 <- (0,17834)
[1] 9374 <- (0,17835)
[1] 9375 <- (0,17836)
[1] 9376 <- (0,17837)
[1] 9377 <- (0,17838)
[1] 9378 <- (0,17839)
[1] 9379 <- (0,17840)
[1] 9380 <- (0,17841)
[1] 9381 <- (0,17842)
[1] 9382 <- (0,17843)
[1] 9383 <- (0,17844)
[1] 9384 <- (0,17845)
[1] 9385 <- (0,17846)
[1] 9386 <- (0,17847)
[1] 9387 <- (0,17848)
[1] 9388 <- (0,17849)
[1] 9389 <- (0,17850)
[1] 9390 <- (0,17851)
[1] 9391 <- (0,17852)
[1] 9392 <- (0,17853)
[1] 9393 <- (0,17877)
[1] 9394 <- (0,17878)
[1] 9395 <- (0,17879)
[1] 9396 <- (0,17880)
[1] 9397 <- (0,17881)
[1] 9398 <- (0,17882)
[1] 9399 <- (0,17883)
[1] 9400 <- (0,17884)
[1] 9401 <- (0,17885)
[1] 9402 <- (0,17886)
[1] 9403 <- (0,17887)
[1] 9404 <- (0,17888)
[1] 9405 <- (0,17889)
[1] 9406 <- (0,17890)
[1] 9407 <- (0,17891)
[1] 9408 <- (0,17892)
[1] 9409 <- (0,17893)
[1] 9410 <- (0,17894)
[1] 9411 <- (0,17895)
[1] 9412 <- (0,17896)
[1] 9413 <- (0,17897)
[1] 9414 <- (0,17898)
[1] 9415 <- (0,17899)
[1] 9416 <- (0,17900)
[1] 9417 <- (0,17901)
[1] 9418 <- (0,17902)
[1] 9419 <- (0,17903)
[1] 9420 <- (0,17904)
[1] 9421 <- (0,17928)
[1] 9422 <- (0,17929)
[1] 9423 <- (0,17930)
[1] 9424 <- (0,17931)
[1] 9425 <- (0,17932)
[1] 9426 <- (0,17933)
[1] 9427 <- (0,17934)
[1] 9428 <- (0,17935)
[1] 9429 <- (0,17936)
[1] 9430 <- (0,17937)
[1] 9431 <- (0,17938)
[1] 9432 <- (0,17939)
[1] 9433 <- (0,17940)
[1] 9434 <- (0,17941)
[1] 9435 <- (0,17942)
[1] 9436 <- (0,17943)
[1] 9437 <- (0,17944)
[1] 9438 <- (0,17945)
[1] 9439 <- (0,17946)
[1] 9440 <- (0,17947)
[1] 9441 <- (0,17948)
[1] 9442 <- (0,17949)
[1] 9443 <- (0,17950)
[1] 9444 <- (0,17951)
[1] 9445 <- (0,17952)
[1] 9446 <- (0,17953)
[1] 9447 <- (0,17954)
[1] 9448 <- (0,17955)
[1] 9449 <- (0,17980)
[1] 9450 <- (0,17981)
[1] 9451 <- (0,17982)
[1] 9452 <- (0,17983)
[1] 9453 <- (0,17984)
[1] 9454 <- (0,17985)
[1] 9455 <- (0,17986)
[1] 9456 <- (0,17987)
[1] 9457 <- (0,17988)
[1] 9458 <- (0,17989)
[1] 9459 <- (0,17990)
[1] 9460 <- (0,17991)
[1] 9461 <- (0,17992)
[1] 9462 <- (0,17993)
[1] 9463 <- (0,17994)
[1] 9464 <- (0,17995)
[1] 9465 <- (0,17996)
[1] 9466 <- (0,17997)
[1] 9467 <- (0,17998)
[1] 9468 <- (0,17999)
[1] 9469 <- (0,18000)
[1] 9470 <- (0,18001)
[1] 9471 <- (0,18002)
[1] 9472 <- (0,18003)
[1] 9473 <- (0,18004)
[1] 9474 <- (0,18005)
[1] 9475 <- (0,18006)
[1] 9476 <- (0,18032)
[1] 9477 <- (0,18033)
[1] 9478 <- (0,18034)
[1] 9479 <- (0,18035)
[1] 9480 <- (0,18036)
[1] 9481 <- (0,18037)
[1] 9482 <- (0,18038)
[1] 9483 <- (0,18039)
[1] 9484 <- (0,18040)
[1] 9485 <- (0,18041)
[1] 9486 <- (0,18042)
[1] 9487 <- (0,18043)
[1] 9488 <- (0,18044)
[1] 9489 <- (0,18045)
[1] 9490 <- (0,18046)
[1] 9491 <- (0,18047)
[1] 9492 <- (0,18048)
[1] 9493 <- (0,18049)
[1] 9494 <- (0,18050)
[1] 9495 <- (0,18051)
[1] 9496 <- (0,18052)
[1] 9497 <- (0,18053)
[1] 9498 <- (0,18054)
[1] 9499 <- (0,18055)
[1] 9500 <- (0,18056)
[1] 9501 <- (0,18057)
[1] 9502 <- (0,18083)
[1] 9503 <- (0,18084)
[1] 9504 <- (0,18085)
[1] 9505 <- (0,18086)
[1] 9506 <- (0,18087)
[1] 9507 <- (0,18088)
[1] 9508 <- (0,18089)
[1] 9509 <- (0,18090)
[1] 9510 <- (0,18091)
[1] 9511 <- (0,18092)
[1] 9512 <- (0,18093)
[1] 9513 <- (0,18094)
[1] 9514 <- (0,18095)
[1] 9515 <- (0,18096)
[1] 9516 <- (0,18097)
[1] 9517 <- (0,18098)
[1] 9518 <- (0,18099)
[1] 9519 <- (0,18100)
[1] 9520 <- (0,18101)
[1] 9521 <- (0,18102)
[1] 9522 <- (0,18103)
[1] 9523 <- (0,18104)
[1] 9524 <- (0,18105)
[1] 9525 <- (0,18106)
[1] 9526 <- (0,18107)
[1] 9527 <- (0,18108)
[1] 9528 <- (0,18135)
[1] 9529 <- (0,18136)
[1] 9530 <- (0,18137)
[1] 9531 <- (0,18138)
[1] 9532 <- (0,18139)
[1] 9533 <- (0,18140)
[1] 9534 <- (0,18141)
[1] 9535 <- (0,18142)
[1] 9536 <- (0,18143)
[1] 9537 <- (0,18144)
[1] 9538 <- (0,18145)
[1] 9539 <- (0,18146)
[1] 9540 <- (0,18147)
[1] 9541 <- (0,18148)
[1] 9542 <- (0,18149)
[1] 9543 <- (0,18150)
[1] 9544 <- (0,18151)
[1] 9545 <- (0,18152)
[1] 9546 <- (0,18153)
[1] 9547 <- (0,18154)
[1] 9548 <- (0,18155)
[1] 9549 <- (0,18156)
[1] 9550 <- (0,18157)
[1] 9551 <- (0,18158)
[1] 9552 <- (0,18159)
[1] 9553 <- (0,18186)
[1] 9554 <- (0,18187)
[1] 9555 <- (0,18188)
[1] 9556 <- (0,18189)
[1] 9557 <- (0,18190)
[1] 9558 <- (0,18191)
[1] 9559 <- (0,18192)
[1] 9560 <- (0,18193)
[1] 9561 <- (0,18194)
[1] 9562 <- (0,18195)
[1] 9563 <- (0,18196)
[1] 9564 <- (0,18197)
[1] 9565 <- (0,18198)
[1] 9566 <- (0,18199)
[1] 9567 <- (0,18200)
[1] 9568 <- (0,18201)
[1] 9569 <- (0,18202)
[1] 9570 <- (0,18203)
[1] 9571 <- (0,18204)
[1] 9572 <- (0,18205)
[1] 9573 <- (0,18206)
[1] 9574 <- (0,18207)
[1] 9575 <- (0,18208)
[1] 9576 <- (0,18209)
[1] 9577 <- (0,18210)
[1] 9578 <- (0,18238)
[1] 9579 <- (0,18239)
[1] 9580 <- (0,18240)
[1] 9581 <- (0,18241)
[1] 9582 <- (0,18242)
[1] 9583 <- (0,18243)
[1] 9584 <- (0,18244)
[1] 9585 <- (0,18245)
[1] 9586 <- (0,18246)
[1] 9587 <- (0,18247)
[1] 9588 <- (0,18248)
[1] 9589 <- (0,18249)
[1] 9590 <- (0,18250)
[1] 9591 <- (0,18251)
[1] 9592 <- (0,18252)
[1] 9593 <- (0,18253)
[1] 9594 <- (0,18254)
[1] 9595 <- (0,18255)
[1] 9596 <- (0,18256)
[1] 9597 <- (0,18257)
[1] 9598 <- (0,18258)
[1] 9599 <- (0,18259)
[1] 9600 <- (0,18260)
[1] 9601 <- (0,18261)
[1] 9602 <- (0,18289)
[1] 9603 <- (0,18290)
[1] 9604 <- (0,18291)
[1] 9605 <- (0,18292)
[1] 9606 <- (0,18293)
[1] 9607 <- (0,18294)
[1] 9608 <- (0,18295)
[1] 9609 <- (0,18296)
[1] 9610 <- (0,18297)
[1] 9611 <- (0,18298)
[1] 9612 <- (0,18299)
[1] 9613 <- (0,18300)
[1] 9614 <- (0,18301)
[1] 9615 <- (0,18302)
[1] 9616 <- (0,18303)
[1] 9617 <- (0,18304)
[1] 9618 <- (0,18305)
[1] 9619 <- (0,18306)
[1] 9620 <- (0,18307)
[1] 9621 <- (0,18308)
[1] 9622 <- (0,18309)
[1] 9623 <- (0,18310)
[1] 9624 <- (0,18311)
[1] 9625 <- (0,18312)
[1] 9626 <- (0,18340)
[1] 9627 <- (0,18341)
[1] 9628 <- (0,18342)
[1] 9629 <- (0,18343)
[1] 9630 <- (0,18344)
[1] 9631 <- (0,18345)
[1] 9632 <- (0,18346)
[1] 9633 <- (0,18347)
[1] 9634 <- (0,18348)
[1] 9635 <- (0,18349)
[1] 9636 <- (0,18350)
[1] 9637 <- (0,18351)
[1] 9638 <- (0,18352)
[1] 9639 <- (0,18353)
[1] 9640 <- (0,18354)
[1] 9641 <- (0,18355)
[1] 9642 <- (0,18356)
[1] 9643 <- (0,18357)
[1] 9644 <- (0,18358)
[1] 9645 <- (0,18359)
[1] 9646 <- (0,18360)
[1] 9647 <- (0,18361)
[1] 9648 <- (0,18362)
[1] 9649 <- (0,18363)
[1] 9650 <- (0,18391)
[1] 9651 <- (0,18392)
[1] 9652 <- (0,18393)
[1] 9653 <- (0,18394)
[1] 9654 <- (0,18395)
[1] 9655 <- (0,18396)
[1] 9656 <- (0,18397)
[1] 9657 <- (0,18398)
[1] 9658 <- (0,18399)
[1] 9659 <- (0,18400)
[1] 9660 <- (0,18401)
[1] 9661 <- (0,18402)
[1] 9662 <- (0,18403)
[1] 9663 <- (0,18404)
[1] 9664 <- (0,18405)
[1] 9665 <- (0,18406)
[1] 9666 <- (0,18407)
[1] 9667 <- (0,18408)
[1] 9668 <- (0,18409)
[1] 9669 <- (0,18410)
[1] 9670 <- (0,18411)
[1] 9671 <- (0,18412)
[1] 9672 <- (0,18413)
[1] 9673 <- (0,18414)
[1] 9674 <- (0,18442)
[1] 9675 <- (0,18443)
[1] 9676 <- (0,18444)
[1] 9677 <- (0,18445)
[1] 9678 <- (0,18446)
[1] 9679 <- (0,18447)
[1] 9680 <- (0,18448)
[1] 9681 <- (0,18449)
[1] 9682 <- (0,18450)
[1] 9683 <- (0,18451)
[1] 9684 <- (0,18452)
[1] 9685 <- (0,18453)
[1] 9686 <- (0,18454)
[1] 9687 <- (0,18455)
[1] 9688 <- (0,18456)
[1] 9689 <- (0,18457)
[1] 9690 <- (0,18458)
[1] 9691 <- (0,18459)
[1] 9692 <- (0,18460)
[1] 9693 <- (0,18461)
[1] 9694 <- (0,18462)
[1] 9695 <- (0,18463)
[1] 9696 <- (0,18464)
[1] 9697 <- (0,18465)
[1] 9698 <- (0,18493)
[1] 9699 <- (0,18494)
[1] 9700 <- (0,18495)
[1] 9701 <- (0,18496)
[1] 9702 <- (0,18497)
[1] 9703 <- (0,18498)
[1] 9704 <- (0,18499)
[1] 9705 <- (0,18500)
[1] 9706 <- (0,18501)
[1] 9707 <- (0,18502)
[1] 9708 <- (0,18503)
[1] 9709 <- (0,18504)
[1] 9710 <- (0,18505)
[1] 9711 <- (0,18506)
[1] 9712 <- (0,18507)
[1] 9713 <- (0,18508)
[1] 9714 <- (0,18509)
[1] 9715 <- (0,18510)
[1] 9716 <- (0,18511)
[1] 9717 <- (0,18512)
[1] 9718 <- (0,18513)
[1] 9719 <- (0,18514)
[1] 9720 <- (0,18515)
[1] 9721 <- (0,18516)
[1] 9722 <- (0,18544)
[1] 9723 <- (0,18545)
[1] 9724 <- (0,18546)
[1] 9725 <- (0,18547)
[1] 9726 <- (0,18548)
[1] 9727 <- (0,18549)
[1] 9728 <- (0,18550)
[1] 9729 <- (0,18551)
[1] 9730 <- (0,18552)
[1] 9731 <- (0,18553)
[1] 9732 <- (0,18554)
[1] 9733 <- (0,18555)
[1] 9734 <- (0,18556)
[1] 9735 <- (0,18557)
[1] 9736 <- (0,18558)
[1] 9737 <- (0,18559)
[1] 9738 <- (0,18560)
[1] 9739 <- (0,18561)
[1] 9740 <- (0,18562)
[1] 9741 <- (0,18563)
[1] 9742 <- (0,18564)
[1] 9743 <- (0,18565)
[1] 9744 <- (0,18566)
[1] 9745 <- (0,18567)
[1] 9746 <- (0,18590)
[1] 9747 <- (0,18591)
[1] 9748 <- (0,18592)
[1] 9749 <- (0,18593)
[1] 9750 <- (0,18594)
[1] 9751 <- (0,18595)
[1] 9752 <- (0,18596)
[1] 9753 <- (0,18597)
[1] 9754 <- (0,18598)
[1] 9755 <- (0,18599)
[1] 9756 <- (0,18600)
[1] 9757 <- (0,18601)
[1] 9758 <- (0,18602)
[1] 9759 <- (0,18603)
[1] 9760 <- (0,18604)
[1] 9761 <- (0,18605)
[1] 9762 <- (0,18606)
[1] 9763 <- (0,18607)
[1] 9764 <- (0,18608)
[1] 9765 <- (0,18609)
[1] 9766 <- (0,18610)
[1] 9767 <- (0,18611)
[1] 9768 <- (0,18612)
[1] 9769 <- (0,18613)
[1] 9770 <- (0,18614)
[1] 9771 <- (0,18615)
[1] 9772 <- (0,18616)
[1] 9773 <- (0,18617)
[1] 9774 <- (0,18618)
[1] 9775 <- (0,18641)
[1] 9776 <- (0,18642)
[1] 9777 <- (0,18643)
[1] 9778 <- (0,18644)
[1] 9779 <- (0,18645)
[1] 9780 <- (0,18646)
[1] 9781 <- (0,18647)
[1] 9782 <- (0,18648)
[1] 9783 <- (0,18649)
[1] 9784 <- (0,18650)
[1] 9785 <- (0,18651)
[1] 9786 <- (0,18652)
[1] 9787 <- (0,18653)
[1] 9788 <- (0,18654)
[1] 9789 <- (0,18655)
[1] 9790 <- (0,18656)
[1] 9791 <- (0,18657)
[1] 9792 <- (0,18658)
[1] 9793 <- (0,18659)
[1] 9794 <- (0,18660)
[1] 9795 <- (0,18661)
[1] 9796 <- (0,18662)
[1] 9797 <- (0,18663)
[1] 9798 <- (0,18664)
[1] 9799 <- (0,18665)
[1] 9800 <- (0,18666)
[1] 9801 <- (0,18667)
[1] 9802 <- (0,18668)
[1] 9803 <- (0,18669)
[1] 9804 <- (0,18692)
[1] 9805 <- (0,18693)
[1] 9806 <- (0,18694)
[1] 9807 <- (0,18695)
[1] 9808 <- (0,18696)
[1] 9809 <- (0,18697)
[1] 9810 <- (0,18698)
[1] 9811 <- (0,18699)
[1] 9812 <- (0,18700)
[1] 9813 <- (0,18701)
[1] 9814 <- (0,18702)
[1] 9815 <- (0,18703)
[1] 9816 <- (0,18704)
[1] 9817 <- (0,18705)
[1] 9818 <- (0,18706)
[1] 9819 <- (0,18707)
[1] 9820 <- (0,18708)
[1] 9821 <- (0,18709)
[1] 9822 <- (0,18710)
[1] 9823 <- (0,18711)
[1] 9824 <- (0,18712)
[1] 9825 <- (0,18713)
[1] 9826 <- (0,18714)
[1] 9827 <- (0,18715)
[1] 9828 <- (0,18716)
[1] 9829 <- (0,18717)
[1] 9830 <- (0,18718)
[1] 9831 <- (0,18719)
[1] 9832 <- (0,18720)
[1] 9833 <- (0,18743)
[1] 9834 <- (0,18744)
[1] 9835 <- (0,18745)
[1] 9836 <- (0,18746)
[1] 9837 <- (0,18747)
[1] 9838 <- (0,18748)
[1] 9839 <- (0,18749)
[1] 9840 <- (0,18750)
[1] 9841 <- (0,18751)
[1] 9842 <- (0,18752)
[1] 9843 <- (0,18753)
[1] 9844 <- (0,18754)
[1] 9845 <- (0,18755)
[1] 9846 <- (0,18756)
[1] 9847 <- (0,18757)
[1] 9848 <- (0,18758)
[1] 9849 <- (0,18759)
[1] 9850 <- (0,18760)
[1] 9851 <- (0,18761)
[1] 9852 <- (0,18762)
[1] 9853 <- (0,18763)
[1] 9854 <- (0,18764)
[1] 9855 <- (0,18765)
[1] 9856 <- (0,18766)
[1] 9857 <- (0,18767)
[1] 9858 <- (0,18768)
[1] 9859 <- (0,18769)
[1] 9860 <- (0,18770)
[1] 9861 <- (0,18771)
[1] 9862 <- (0,18794)
[1] 9863 <- (0,18795)
[1] 9864 <- (0,18796)
[1] 9865 <- (0,18797)
[1] 9866 <- (0,18798)
[1] 9867 <- (0,18799)
[1] 9868 <- (0,18800)
[1] 9869 <- (0,18801)
[1] 9870 <- (0,18802)
[1] 9871 <- (0,18803)
[1] 9872 <- (0,18804)
[1] 9873 <- (0,18805)
[1] 9874 <- (0,18806)
[1] 9875 <- (0,18807)
[1] 9876 <- (0,18808)
[1] 9877 <- (0,18809)
[1] 9878 <- (0,18810)
[1] 9879 <- (0,18811)
[1] 9880 <- (0,18812)
[1] 9881 <- (0,18813)
[1] 9882 <- (0,18814)
[1] 9883 <- (0,18815)
[1] 9884 <- (0,18816)
[1] 9885 <- (0,18817)
[1] 9886 <- (0,18818)
[1] 9887 <- (0,18819)
[1] 9888 <- (0,18820)
[1] 9889 <- (0,18821)
[1] 9890 <- (0,18822)
[1] 9891 <- (0,18846)
[1] 9892 <- (0,18847)
[1] 9893 <- (0,18848)
[1] 9894 <- (0,18849)
[1] 9895 <- (0,18850)
[1] 9896 <- (0,18851)
[1] 9897 <- (0,18852)
[1] 9898 <- (0,18853)
[1] 9899 <- (0,18854)
[1] 9900 <- (0,18855)
[1] 9901 <- (0,18856)
[1] 9902 <- (0,18857)
[1] 9903 <- (0,18858)
[1] 9904 <- (0,18859)
[1] 9905 <- (0,18860)
[1] 9906 <- (0,18861)
[1] 9907 <- (0,18862)
[1] 9908 <- (0,18863)
[1] 9909 <- (0,18864)
[1] 9910 <- (0,18865)
[1] 9911 <- (0,18866)
[1] 9912 <- (0,18867)
[1] 9913 <- (0,18868)
[1] 9914 <- (0,18869)
[1] 9915 <- (0,18870)
[1] 9916 <- (0,18871)
[1] 9917 <- (0,18872)
[1] 9918 <- (0,18873)
[1] 9919 <- (0,18897)
[1] 9920 <- (0,18898)
[1] 9921 <- (0,18899)
[1] 9922 <- (0,18900)
[1] 9923 <- (0,18901)
[1] 9924 <- (0,18902)
[1] 9925 <- (0,18903)
[1] 9926 <- (0,18904)
[1] 9927 <- (0,18905)
[1] 9928 <- (0,18906)
[1] 9929 <- (0,18907)
[1] 9930 <- (0,18908)
[1] 9931 <- (0,18909)
[1] 9932 <- (0,18910)
[1] 9933 <- (0,18911)
[1] 9934 <- (0,18912)
[1] 9935 <- (0,18913)
[1] 9936 <- (0,18914)
[1] 9937 <- (0,18915)
[1] 9938 <- (0,18916)
[1] 9939 <- (0,18917)
[1] 9940 <- (0,18918)
[1] 9941 <- (0,18919)
[1] 9942 <- (0,18920)
[1] 9943 <- (0,18921)
[1] 9944 <- (0,18922)
[1] 9945 <- (0,18923)
[1] 9946 <- (0,18924)
[1] 9947 <- (0,18948)
[1] 9948 <- (0,18949)
[1] 9949 <- (0,18950)
[1] 9950 <- (0,18951)
[1] 9951 <- (0,18952)
[1] 9952 <- (0,18953)
[1] 9953 <- (0,18954)
[1] 9954 <- (0,18955)
[1] 9955 <- (0,18956)
[1] 9956 <- (0,18957)
[1] 9957 <- (0,18958)
[1] 9958 <- (0,18959)
[1] 9959 <- (0,18960)
[1] 9960 <- (0,18961)
[1] 9961 <- (0,18962)
[1] 9962 <- (0,18963)
[1] 9963 <- (0,18964)
[1] 9964 <- (0,18965)
[1] 9965 <- (0,18966)
[1] 9966 <- (0,18967)
[1] 9967 <- (0,18968)
[1] 9968 <- (0,18969)
[1] 9969 <- (0,18970)
[1] 9970 <- (0,18971)
[1] 9971 <- (0,18972)
[1] 9972 <- (0,18973)
[1] 9973 <- (0,18974)
[1] 9974 <- (0,18975)
[1] 9975 <- (0,18999)
[1] 9976 <- (0,19000)
[1] 9977 <- (0,19001)
[1] 9978 <- (0,19002)
[1] 9979 <- (0,19003)
[1] 9980 <- (0,19004)
[1] 9981 <- (0,19005)
[1] 9982 <- (0,19006)
[1] 9983 <- (0,19007)
[1] 9984 <- (0,19008)
[1] 9985 <- (0,19009)
[1] 9986 <- (0,19010)
[1] 9987 <- (0,19011)
[1] 9988 <- (0,19012)
[1] 9989 <- (0,19013)
[1] 9990 <- (0,19014)
[1] 9991 <- (0,19015)
[1] 9992 <- (0,19016)
[1] 9993 <- (0,19017)
[1] 9994 <- (0,19018)
[1] 9995 <- (0,19019)
[1] 9996 <- (0,19020)
[1] 9997 <- (0,19021)
[1] 9998 <- (0,19022)
[1] 9999 <- (0,19023)
[1] 10000 <- (0,19024)
[1] 10001 <- (0,19025)
[1] 10002 <- (0,19026)
[1] 10003 <- (0,19051)
[1] 10004 <- (0,19052)
[1] 10005 <- (0,19053)
[1] 10006 <- (0,19054)
[1] 10007 <- (0,19055)
[1] 10008 <- (0,19056)
[1] 10009 <- (0,19057)
[1] 10010 <- (0,19058)
[1] 10011 <- (0,19059)
[1] 10012 <- (0,19060)
[1] 10013 <- (0,19061)
[1] 10014 <- (0,19062)
[1] 10015 <- (0,19063)
[1] 10016 <- (0,19064)
[1] 10017 <- (0,19065)
[1] 10018 <- (0,19066)
[1] 10019 <- (0,19067)
[1] 10020 <- (0,19068)
[1] 10021 <- (0,19069)
[1] 10022 <- (0,19070)
[1] 10023 <- (0,19071)
[1] 10024 <- (0,19072)
[1] 10025 <- (0,19073)
[1] 10026 <- (0,19074)
[1] 10027 <- (0,19075)
[1] 10028 <- (0,19076)
[1] 10029 <- (0,19077)
[1] 10030 <- (0,19103)
[1] 10031 <- (0,19104)
[1] 10032 <- (0,19105)
[1] 10033 <- (0,19106)
[1] 10034 <- (0,19107)
[1] 10035 <- (0,19108)
[1] 10036 <- (0,19109)
[1] 10037 <- (0,19110)
[1] 10038 <- (0,19111)
[1] 10039 <- (0,19112)
[1] 10040 <- (0,19113)
[1] 10041 <- (0,19114)
[1] 10042 <- (0,19115)
[1] 10043 <- (0,19116)
[1] 10044 <- (0,19117)
[1] 10045 <- (0,19118)
[1] 10046 <- (0,19119)
[1] 10047 <- (0,19120)
[1] 10048 <- (0,19121)
[1] 10049 <- (0,19122)
[1] 10050 <- (0,19123)
[1] 10051 <- (0,19124)
[1] 10052 <- (0,19125)
[1] 10053 <- (0,19126)
[1] 10054 <- (0,19127)
[1] 10055 <- (0,19128)
[1] 10056 <- (0,19154)
[1] 10057 <- (0,19155)
[1] 10058 <- (0,19156)
[1] 10059 <- (0,19157)
[1] 10060 <- (0,19158)
[1] 10061 <- (0,19159)
[1] 10062 <- (0,19160)
[1] 10063 <- (0,19161)
[1] 10064 <- (0,19162)
[1] 10065 <- (0,19163)
[1] 10066 <- (0,19164)
[1] 10067 <- (0,19165)
[1] 10068 <- (0,19166)
[1] 10069 <- (0,19167)
[1] 10070 <- (0,19168)
[1] 10071 <- (0,19169)
[1] 10072 <- (0,19170)
[1] 10073 <- (0,19171)
[1] 10074 <- (0,19172)
[1] 10075 <- (0,19173)
[1] 10076 <- (0,19174)
[1] 10077 <- (0,19175)
[1] 10078 <- (0,19176)
[1] 10079 <- (0,19177)
[1] 10080 <- (0,19178)
[1] 10081 <- (0,19179)
[1] 10082 <- (0,19206)
[1] 10083 <- (0,19207)
[1] 10084 <- (0,19208)
[1] 10085 <- (0,19209)
[1] 10086 <- (0,19210)
[1] 10087 <- (0,19211)
[1] 10088 <- (0,19212)
[1] 10089 <- (0,19213)
[1] 10090 <- (0,19214)
[1] 10091 <- (0,19215)
[1] 10092 <- (0,19216)
[1] 10093 <- (0,19217)
[1] 10094 <- (0,19218)
[1] 10095 <- (0,19219)
[1] 10096 <- (0,19220)
[1] 10097 <- (0,19221)
[1] 10098 <- (0,19222)
[1] 10099 <- (0,19223)
[1] 10100 <- (0,19224)
[1] 10101 <- (0,19225)
[1] 10102 <- (0,19226)
[1] 10103 <- (0,19227)
[1] 10104 <- (0,19228)
[1] 10105 <- (0,19229)
[1] 10106 <- (0,19230)
[1] 10107 <- (0,19257)
[1] 10108 <- (0,19258)
[1] 10109 <- (0,19259)
[1] 10110 <- (0,19260)
[1] 10111 <- (0,19261)
[1] 10112 <- (0,19262)
[1] 10113 <- (0,19263)
[1] 10114 <- (0,19264)
[1] 10115 <- (0,19265)
[1] 10116 <- (0,19266)
[1] 10117 <- (0,19267)
[1] 10118 <- (0,19268)
[1] 10119 <- (0,19269)
[1] 10120 <- (0,19270)
[1] 10121 <- (0,19271)
[1] 10122 <- (0,19272)
[1] 10123 <- (0,19273)
[1] 10124 <- (0,19274)
[1] 10125 <- (0,19275)
[1] 10126 <- (0,19276)
[1] 10127 <- (0,19277)
[1] 10128 <- (0,19278)
[1] 10129 <- (0,19279)
[1] 10130 <- (0,19280)
[1] 10131 <- (0,19281)
[1] 10132 <- (0,19309)
[1] 10133 <- (0,19310)
[1] 10134 <- (0,19311)
[1] 10135 <- (0,19312)
[1] 10136 <- (0,19313)
[1] 10137 <- (0,19314)
[1] 10138 <- (0,19315)
[1] 10139 <- (0,19316)
[1] 10140 <- (0,19317)
[1] 10141 <- (0,19318)
[1] 10142 <- (0,19319)
[1] 10143 <- (0,19320)
[1] 10144 <- (0,19321)
[1] 10145 <- (0,19322)
[1] 10146 <- (0,19323)
[1] 10147 <- (0,19324)
[1] 10148 <- (0,19325)
[1] 10149 <- (0,19326)
[1] 10150 <- (0,19327)
[1] 10151 <- (0,19328)
[1] 10152 <- (0,19329)
[1] 10153 <- (0,19330)
[1] 10154 <- (0,19331)
[1] 10155 <- (0,19332)
[1] 10156 <- (0,19360)
[1] 10157 <- (0,19361)
[1] 10158 <- (0,19362)
[1] 10159 <- (0,19363)
[1] 10160 <- (0,19364)
[1] 10161 <- (0,19365)
[1] 10162 <- (0,19366)
[1] 10163 <- (0,19367)
[1] 10164 <- (0,19368)
[1] 10165 <- (0,19369)
[1] 10166 <- (0,19370)
[1] 10167 <- (0,19371)
[1] 10168 <- (0,19372)
[1] 10169 <- (0,19373)
[1] 10170 <- (0,19374)
[1] 10171 <- (0,19375)
[1] 10172 <- (0,19376)
[1] 10173 <- (0,19377)
[1] 10174 <- (0,19378)
[1] 10175 <- (0,19379)
[1] 10176 <- (0,19380)
[1] 10177 <- (0,19381)
[1] 10178 <- (0,19382)
[1] 10179 <- (0,19383)
[1] 10180 <- (0,19411)
[1] 10181 <- (0,19412)
[1] 10182 <- (0,19413)
[1] 10183 <- (0,19414)
[1] 10184 <- (0,19415)
[1] 10185 <- (0,19416)
[1] 10186 <- (0,19417)
[1] 10187 <- (0,19418)
[1] 10188 <- (0,19419)
[1] 10189 <- (0,19420)
[1] 10190 <- (0,19421)
[1] 10191 <- (0,19422)
[1] 10192 <- (0,19423)
[1] 10193 <- (0,19424)
[1] 10194 <- (0,19425)
[1] 10195 <- (0,19426)
[1] 10196 <- (0,19427)
[1] 10197 <- (0,19428)
[1] 10198 <- (0,19429)
[1] 10199 <- (0,19430)
[1] 10200 <- (0,19431)
[1] 10201 <- (0,19432)
[1] 10202 <- (0,19433)
[1] 10203 <- (0,19434)
[1] 10204 <- (0,19462)
[1] 10205 <- (0,19463)
[1] 10206 <- (0,19464)
[1] 10207 <- (0,19465)
[1] 10208 <- (0,19466)
[1] 10209 <- (0,19467)
[1] 10210 <- (0,19468)
[1] 10211 <- (0,19469)
[1] 10212 <- (0,19470)
[1] 10213 <- (0,19471)
[1] 10214 <- (0,19472)
[1] 10215 <- (0,19473)
[1] 10216 <- (0,19474)
[1] 10217 <- (0,19475)
[1] 10218 <- (0,19476)
[1] 10219 <- (0,19477)
[1] 10220 <- (0,19478)
[1] 10221 <- (0,19479)
[1] 10222 <- (0,19480)
[1] 10223 <- (0,19481)
[1] 10224 <- (0,19482)
[1] 10225 <- (0,19483)
[1] 10226 <- (0,19484)
[1] 10227 <- (0,19485)
[1] 10228 <- (0,19513)
[1] 10229 <- (0,19514)
[1] 10230 <- (0,19515)
[1] 10231 <- (0,19516)
[1] 10232 <- (0,19517)
[1] 10233 <- (0,19518)
[1] 10234 <- (0,19519)
[1] 10235 <- (0,19520)
[1] 10236 <- (0,19521)
[1] 10237 <- (0,19522)
[1] 10238 <- (0,19523)
[1] 10239 <- (0,19524)
[1] 10240 <- (0,19525)
[1] 10241 <- (0,19526)
[1] 10242 <- (0,19527)
[1] 10243 <- (0,19528)
[1] 10244 <- (0,19529)
[1] 10245 <- (0,19530)
[1] 10246 <- (0,19531)
[1] 10247 <- (0,19532)
[1] 10248 <- (0,19533)
[1] 10249 <- (0,19534)
[1] 10250 <- (0,19535)
[1] 10251 <- (0,19536)
[1] 10252 <- (0,19564)
[1] 10253 <- (0,19565)
[1] 10254 <- (0,19566)
[1] 10255 <- (0,19567)
[1] 10256 <- (0,19568)
[1] 10257 <- (0,19569)
[1] 10258 <- (0,19570)
[1] 10259 <- (0,19571)
[1] 10260 <- (0,19572)
[1] 10261 <- (0,19573)
[1] 10262 <- (0,19574)
[1] 10263 <- (0,19575)
[1] 10264 <- (0,19576)
[1] 10265 <- (0,19577)
[1] 10266 <- (0,19578)
[1] 10267 <- (0,19579)
[1] 10268 <- (0,19580)
[1] 10269 <- (0,19581)
[1] 10270 <- (0,19582)
[1] 10271 <- (0,19583)
[1] 10272 <- (0,19584)
[1] 10273 <- (0,19585)
[1] 10274 <- (0,19586)
[1] 10275 <- (0,19587)
[1] 10276 <- (0,19615)
[1] 10277 <- (0,19616)
[1] 10278 <- (0,19617)
[1] 10279 <- (0,19618)
[1] 10280 <- (0,19619)
[1] 10281 <- (0,19620)
[1] 10282 <- (0,19621)
[1] 10283 <- (0,19622)
[1] 10284 <- (0,19623)
[1] 10285 <- (0,19624)
[1] 10286 <- (0,19625)
[1] 10287 <- (0,19626)
[1] 10288 <- (0,19627)
[1] 10289 <- (0,19628)
[1] 10290 <- (0,19629)
[1] 10291 <- (0,19630)
[1] 10292 <- (0,19631)
[1] 10293 <- (0,19632)
[1] 10294 <- (0,19633)
[1] 10295 <- (0,19634)
[1] 10296 <- (0,19635)
[1] 10297 <- (0,19636)
[1] 10298 <- (0,19637)
[1] 10299 <- (0,19638)
[1] 10300 <- (0,19661)
[1] 10301 <- (0,19662)
[1] 10302 <- (0,19663)
[1] 10303 <- (0,19664)
[1] 10304 <- (0,19665)
[1] 10305 <- (0,19666)
[1] 10306 <- (0,19667)
[1] 10307 <- (0,19668)
[1] 10308 <- (0,19669)
[1] 10309 <- (0,19670)
[1] 10310 <- (0,19671)
[1] 10311 <- (0,19672)
[1] 10312 <- (0,19673)
[1] 10313 <- (0,19674)
[1] 10314 <- (0,19675)
[1] 10315 <- (0,19676)
[1] 10316 <- (0,19677)
[1] 10317 <- (0,19678)
[1] 10318 <- (0,19679)
[1] 10319 <- (0,19680)
[1] 10320 <- (0,19681)
[1] 10321 <- (0,19682)
[1] 10322 <- (0,19683)
[1] 10323 <- (0,19684)
[1] 10324 <- (0,19685)
[1] 10325 <- (0,19686)
[1] 10326 <- (0,19687)
[1] 10327 <- (0,19688)
[1] 10328 <- (0,19689)
[1] 10329 <- (0,19712)
[1] 10330 <- (0,19713)
[1] 10331 <- (0,19714)
[1] 10332 <- (0,19715)
[1] 10333 <- (0,19716)
[1] 10334 <- (0,19717)
[1] 10335 <- (0,19718)
[1] 10336 <- (0,19719)
[1] 10337 <- (0,19720)
[1] 10338 <- (0,19721)
[1] 10339 <- (0,19722)
[1] 10340 <- (0,19723)
[1] 10341 <- (0,19724)
[1] 10342 <- (0,19725)
[1] 10343 <- (0,19726)
[1] 10344 <- (0,19727)
[1] 10345 <- (0,19728)
[1] 10346 <- (0,19729)
[1] 10347 <- (0,19730)
[1] 10348 <- (0,19731)
[1] 10349 <- (0,19732)
[1] 10350 <- (0,19733)
[1] 10351 <- (0,19734)
[1] 10352 <- (0,19735)
[1] 10353 <- (0,19736)
[1] 10354 <- (0,19737)
[1] 10355 <- (0,19738)
[1] 10356 <- (0,19739)
[1] 10357 <- (0,19740)
[1] 10358 <- (0,19763)
[1] 10359 <- (0,19764)
[1] 10360 <- (0,19765)
[1] 10361 <- (0,19766)
[1] 10362 <- (0,19767)
[1] 10363 <- (0,19768)
[1] 10364 <- (0,19769)
[1] 10365 <- (0,19770)
[1] 10366 <- (0,19771)
[1] 10367 <- (0,19772)
[1] 10368 <- (0,19773)
[1] 10369 <- (0,19774)
[1] 10370 <- (0,19775)
[1] 10371 <- (0,19776)
[1] 10372 <- (0,19777)
[1] 10373 <- (0,19778)
[1] 10374 <- (0,19779)
[1] 10375 <- (0,19780)
[1] 10376 <- (0,19781)
[1] 10377 <- (0,19782)
[1] 10378 <- (0,19783)
[1] 10379 <- (0,19784)
[1] 10380 <- (0,19785)
[1] 10381 <- (0,19786)
[1] 10382 <- (0,19787)
[1] 10383 <- (0,19788)
[1] 10384 <- (0,19789)
[1] 10385 <- (0,19790)
[1] 10386 <- (0,19791)
[1] 10387 <- (0,19814)
[1] 10388 <- (0,19815)
[1] 10389 <- (0,19816)
[1] 10390 <- (0,19817)
[1] 10391 <- (0,19818)
[1] 10392 <- (0,19819)
[1] 10393 <- (0,19820)
[1] 10394 <- (0,19821)
[1] 10395 <- (0,19822)
[1] 10396 <- (0,19823)
[1] 10397 <- (0,19824)
[1] 10398 <- (0,19825)
[1] 10399 <- (0,19826)
[1] 10400 <- (0,19827)
[1] 10401 <- (0,19828)
[1] 10402 <- (0,19829)
[1] 10403 <- (0,19830)
[1] 10404 <- (0,19831)
[1] 10405 <- (0,19832)
[1] 10406 <- (0,19833)
[1] 10407 <- (0,19834)
[1] 10408 <- (0,19835)
[1] 10409 <- (0,19836)
[1] 10410 <- (0,19837)
[1] 10411 <- (0,19838)
[1] 10412 <- (0,19839)
[1] 10413 <- (0,19840)
[1] 10414 <- (0,19841)
[1] 10415 <- (0,19842)
[1] 10416 <- (0,19865)
[1] 10417 <- (0,19866)
[1] 10418 <- (0,19867)
[1] 10419 <- (0,19868)
[1] 10420 <- (0,19869)
[1] 10421 <- (0,19870)
[1] 10422 <- (0,19871)
[1] 10423 <- (0,19872)
[1] 10424 <- (0,19873)
[1] 10425 <- (0,19874)
[1] 10426 <- (0,19875)
[1] 10427 <- (0,19876)
[1] 10428 <- (0,19877)
[1] 10429 <- (0,19878)
[1] 10430 <- (0,19879)
[1] 10431 <- (0,19880)
[1] 10432 <- (0,19881)
[1] 10433 <- (0,19882)
[1] 10434 <- (0,19883)
[1] 10435 <- (0,19884)
[1] 10436 <- (0,19885)
[1] 10437 <- (0,19886)
[1] 10438 <- (0,19887)
[1] 10439 <- (0,19888)
[1] 10440 <- (0,19889)
[1] 10441 <- (0,19890)
[1] 10442 <- (0,19891)
[1] 10443 <- (0,19892)
[1] 10444 <- (0,19893)
[1] 10445 <- (0,19917)
[1] 10446 <- (0,19918)
[1] 10447 <- (0,19919)
[1] 10448 <- (0,19920)
[1] 10449 <- (0,19921)
[1] 10450 <- (0,19922)
[1] 10451 <- (0,19923)
[1] 10452 <- (0,19924)
[1] 10453 <- (0,19925)
[1] 10454 <- (0,19926)
[1] 10455 <- (0,19927)
[1] 10456 <- (0,19928)
[1] 10457 <- (0,19929)
[1] 10458 <- (0,19930)
[1] 10459 <- (0,19931)
[1] 10460 <- (0,19932)
[1] 10461 <- (0,19933)
[1] 10462 <- (0,19934)
[1] 10463 <- (0,19935)
[1] 10464 <- (0,19936)
[1] 10465 <- (0,19937)
[1] 10466 <- (0,19938)
[1] 10467 <- (0,19939)
[1] 10468 <- (0,19940)
[1] 10469 <- (0,19941)
[1] 10470 <- (0,19942)
[1] 10471 <- (0,19943)
[1] 10472 <- (0,19944)
[1] 10473 <- (0,19968)
[1] 10474 <- (0,19969)
[1] 10475 <- (0,19970)
[1] 10476 <- (0,19971)
[1] 10477 <- (0,19972)
[1] 10478 <- (0,19973)
[1] 10479 <- (0,19974)
[1] 10480 <- (0,19975)
[1] 10481 <- (0,19976)
[1] 10482 <- (0,19977)
[1] 10483 <- (0,19978)
[1] 10484 <- (0,19979)
[1] 10485 <- (0,19980)
[1] 10486 <- (0,19981)
[1] 10487 <- (0,19982)
[1] 10488 <- (0,19983)
[1] 10489 <- (0,19984)
[1] 10490 <- (0,19985)
[1] 10491 <- (0,19986)
[1] 10492 <- (0,19987)
[1] 10493 <- (0,19988)
[1] 10494 <- (0,19989)
[1] 10495 <- (0,19990)
[1] 10496 <- (0,19991)
[1] 10497 <- (0,19992)
[1] 10498 <- (0,19993)
[1] 10499 <- (0,19994)
[1] 10500 <- (0,19995)
[1] 10501 <- (0,20019)
[1] 10502 <- (0,20020)
[1] 10503 <- (0,20021)
[1] 10504 <- (0,20022)
[1] 10505 <- (0,20023)
[1] 10506 <- (0,20024)
[1] 10507 <- (0,20025)
[1] 10508 <- (0,20026)
[1] 10509 <- (0,20027)
[1] 10510 <- (0,20028)
[1] 10511 <- (0,20029)
[1] 10512 <- (0,20030)
[1] 10513 <- (0,20031)
[1] 10514 <- (0,20032)
[1] 10515 <- (0,20033)
[1] 10516 <- (0,20034)
[1] 10517 <- (0,20035)
[1] 10518 <- (0,20036)
[1] 10519 <- (0,20037)
[1] 10520 <- (0,20038)
[1] 10521 <- (0,20039)
[1] 10522 <- (0,20040)
[1] 10523 <- (0,20041)
[1] 10524 <- (0,20042)
[1] 10525 <- (0,20043)
[1] 10526 <- (0,20044)
[1] 10527 <- (0,20045)
[1] 10528 <- (0,20046)
[1] 10529 <- (0,20070)
[1] 10530 <- (0,20071)
[1] 10531 <- (0,20072)
[1] 10532 <- (0,20073)
[1] 10533 <- (0,20074)
[1] 10534 <- (0,20075)
[1] 10535 <- (0,20076)
[1] 10536 <- (0,20077)
[1] 10537 <- (0,20078)
[1] 10538 <- (0,20079)
[1] 10539 <- (0,20080)
[1] 10540 <- (0,20081)
[1] 10541 <- (0,20082)
[1] 10542 <- (0,20083)
[1] 10543 <- (0,20084)
[1] 10544 <- (0,20085)
[1] 10545 <- (0,20086)
[1] 10546 <- (0,20087)
[1] 10547 <- (0,20088)
[1] 10548 <- (0,20089)
[1] 10549 <- (0,20090)
[1] 10550 <- (0,20091)
[1] 10551 <- (0,20092)
[1] 10552 <- (0,20093)
[1] 10553 <- (0,20094)
[1] 10554 <- (0,20095)
[1] 10555 <- (0,20096)
[1] 10556 <- (0,20097)
[1] 10557 <- (0,20122)
[1] 10558 <- (0,20123)
[1] 10559 <- (0,20124)
[1] 10560 <- (0,20125)
[1] 10561 <- (0,20126)
[1] 10562 <- (0,20127)
[1] 10563 <- (0,20128)
[1] 10564 <- (0,20129)
[1] 10565 <- (0,20130)
[1] 10566 <- (0,20131)
[1] 10567 <- (0,20132)
[1] 10568 <- (0,20133)
[1] 10569 <- (0,20134)
[1] 10570 <- (0,20135)
[1] 10571 <- (0,20136)
[1] 10572 <- (0,20137)
[1] 10573 <- (0,20138)
[1] 10574 <- (0,20139)
[1] 10575 <- (0,20140)
[1] 10576 <- (0,20141)
[1] 10577 <- (0,20142)
[1] 10578 <- (0,20143)
[1] 10579 <- (0,20144)
[1] 10580 <- (0,20145)
[1] 10581 <- (0,20146)
[1] 10582 <- (0,20147)
[1] 10583 <- (0,20148)
[1] 10584 <- (0,20174)
[1] 10585 <- (0,20175)
[1] 10586 <- (0,20176)
[1] 10587 <- (0,20177)
[1] 10588 <- (0,20178)
[1] 10589 <- (0,20179)
[1] 10590 <- (0,20180)
[1] 10591 <- (0,20181)
[1] 10592 <- (0,20182)
[1] 10593 <- (0,20183)
[1] 10594 <- (0,20184)
[1] 10595 <- (0,20185)
[1] 10596 <- (0,20186)
[1] 10597 <- (0,20187)
[1] 10598 <- (0,20188)
[1] 10599 <- (0,20189)
[1] 10600 <- (0,20190)
[1] 10601 <- (0,20191)
[1] 10602 <- (0,20192)
[1] 10603 <- (0,20193)
[1] 10604 <- (0,20194)
[1] 10605 <- (0,20195)
[1] 10606 <- (0,20196)
[1] 10607 <- (0,20197)
[1] 10608 <- (0,20198)
[1] 10609 <- (0,20199)
[1] 10610 <- (0,20225)
[1] 10611 <- (0,20226)
[1] 10612 <- (0,20227)
[1] 10613 <- (0,20228)
[1] 10614 <- (0,20229)
[1] 10615 <- (0,20230)
[1] 10616 <- (0,20231)
[1] 10617 <- (0,20232)
[1] 10618 <- (0,20233)
[1] 10619 <- (0,20234)
[1] 10620 <- (0,20235)
[1] 10621 <- (0,20236)
[1] 10622 <- (0,20237)
[1] 10623 <- (0,20238)
[1] 10624 <- (0,20239)
[1] 10625 <- (0,20240)
[1] 10626 <- (0,20241)
[1] 10627 <- (0,20242)
[1] 10628 <- (0,20243)
[1] 10629 <- (0,20244)
[1] 10630 <- (0,20245)
[1] 10631 <- (0,20246)
[1] 10632 <- (0,20247)
[1] 10633 <- (0,20248)
[1] 10634 <- (0,20249)
[1] 10635 <- (0,20250)
[1] 10636 <- (0,20277)
[1] 10637 <- (0,20278)
[1] 10638 <- (0,20279)
[1] 10639 <- (0,20280)
[1] 10640 <- (0,20281)
[1] 10641 <- (0,20282)
[1] 10642 <- (0,20283)
[1] 10643 <- (0,20284)
[1] 10644 <- (0,20285)
[1] 10645 <- (0,20286)
[1] 10646 <- (0,20287)
[1] 10647 <- (0,20288)
[1] 10648 <- (0,20289)
[1] 10649 <- (0,20290)
[1] 10650 <- (0,20291)
[1] 10651 <- (0,20292)
[1] 10652 <- (0,20293)
[1] 10653 <- (0,20294)
[1] 10654 <- (0,20295)
[1] 10655 <- (0,20296)
[1] 10656 <- (0,20297)
[1] 10657 <- (0,20298)
[1] 10658 <- (0,20299)
[1] 10659 <- (0,20300)
[1] 10660 <- (0,20301)
[1] 10661 <- (0,20328)
[1] 10662 <- (0,20329)
[1] 10663 <- (0,20330)
[1] 10664 <- (0,20331)
[1] 10665 <- (0,20332)
[1] 10666 <- (0,20333)
[1] 10667 <- (0,20334)
[1] 10668 <- (0,20335)
[1] 10669 <- (0,20336)
[1] 10670 <- (0,20337)
[1] 10671 <- (0,20338)
[1] 10672 <- (0,20339)
[1] 10673 <- (0,20340)
[1] 10674 <- (0,20341)
[1] 10675 <- (0,20342)
[1] 10676 <- (0,20343)
[1] 10677 <- (0,20344)
[1] 10678 <- (0,20345)
[1] 10679 <- (0,20346)
[1] 10680 <- (0,20347)
[1] 10681 <- (0,20348)
[1] 10682 <- (0,20349)
[1] 10683 <- (0,20350)
[1] 10684 <- (0,20351)
[1] 10685 <- (0,20352)
[1] 10686 <- (0,20380)
[1] 10687 <- (0,20381)
[1] 10688 <- (0,20382)
[1] 10689 <- (0,20383)
[1] 10690 <- (0,20384)
[1] 10691 <- (0,20385)
[1] 10692 <- (0,20386)
[1] 10693 <- (0,20387)
[1] 10694 <- (0,20388)
[1] 10695 <- (0,20389)
[1] 10696 <- (0,20390)
[1] 10697 <- (0,20391)
[1] 10698 <- (0,20392)
[1] 10699 <- (0,20393)
[1] 10700 <- (0,20394)
[1] 10701 <- (0,20395)
[1] 10702 <- (0,20396)
[1] 10703 <- (0,20397)
[1] 10704 <- (0,20398)
[1] 10705 <- (0,20399)
[1] 10706 <- (0,20400)
[1] 10707 <- (0,20401)
[1] 10708 <- (0,20402)
[1] 10709 <- (0,20403)
[1] 10710 <- (0,20431)
[1] 10711 <- (0,20432)
[1] 10712 <- (0,20433)
[1] 10713 <- (0,20434)
[1] 10714 <- (0,20435)
[1] 10715 <- (0,20436)
[1] 10716 <- (0,20437)
[1] 10717 <- (0,20438)
[1] 10718 <- (0,20439)
[1] 10719 <- (0,20440)
[1] 10720 <- (0,20441)
[1] 10721 <- (0,20442)
[1] 10722 <- (0,20443)
[1] 10723 <- (0,20444)
[1] 10724 <- (0,20445)
[1] 10725 <- (0,20446)
[1] 10726 <- (0,20447)
[1] 10727 <- (0,20448)
[1] 10728 <- (0,20449)
[1] 10729 <- (0,20450)
[1] 10730 <- (0,20451)
[1] 10731 <- (0,20452)
[1] 10732 <- (0,20453)
[1] 10733 <- (0,20454)
[1] 10734 <- (0,20482)
[1] 10735 <- (0,20483)
[1] 10736 <- (0,20484)
[1] 10737 <- (0,20485)
[1] 10738 <- (0,20486)
[1] 10739 <- (0,20487)
[1] 10740 <- (0,20488)
[1] 10741 <- (0,20489)
[1] 10742 <- (0,20490)
[1] 10743 <- (0,20491)
[1] 10744 <- (0,20492)
[1] 10745 <- (0,20493)
[1] 10746 <- (0,20494)
[1] 10747 <- (0,20495)
[1] 10748 <- (0,20496)
[1] 10749 <- (0,20497)
[1] 10750 <- (0,20498)
[1] 10751 <- (0,20499)
[1] 10752 <- (0,20500)
[1] 10753 <- (0,20501)
[1] 10754 <- (0,20502)
[1] 10755 <- (0,20503)
[1] 10756 <- (0,20504)
[1] 10757 <- (0,20505)
[1] 10758 <- (0,20533)
[1] 10759 <- (0,20534)
[1] 10760 <- (0,20535)
[1] 10761 <- (0,20536)
[1] 10762 <- (0,20537)
[1] 10763 <- (0,20538)
[1] 10764 <- (0,20539)
[1] 10765 <- (0,20540)
[1] 10766 <- (0,20541)
[1] 10767 <- (0,20542)
[1] 10768 <- (0,20543)
[1] 10769 <- (0,20544)
[1] 10770 <- (0,20545)
[1] 10771 <- (0,20546)
[1] 10772 <- (0,20547)
[1] 10773 <- (0,20548)
[1] 10774 <- (0,20549)
[1] 10775 <- (0,20550)
[1] 10776 <- (0,20551)
[1] 10777 <- (0,20552)
[1] 10778 <- (0,20553)
[1] 10779 <- (0,20554)
[1] 10780 <- (0,20555)
[1] 10781 <- (0,20556)
[1] 10782 <- (0,20584)
[1] 10783 <- (0,20585)
[1] 10784 <- (0,20586)
[1] 10785 <- (0,20587)
[1] 10786 <- (0,20588)
[1] 10787 <- (0,20589)
[1] 10788 <- (0,20590)
[1] 10789 <- (0,20591)
[1] 10790 <- (0,20592)
[1] 10791 <- (0,20593)
[1] 10792 <- (0,20594)
[1] 10793 <- (0,20595)
[1] 10794 <- (0,20596)
[1] 10795 <- (0,20597)
[1] 10796 <- (0,20598)
[1] 10797 <- (0,20599)
[1] 10798 <- (0,20600)
[1] 10799 <- (0,20601)
[1] 10800 <- (0,20602)
[1] 10801 <- (0,20603)
[1] 10802 <- (0,20604)
[1] 10803 <- (0,20605)
[1] 10804 <- (0,20606)
[1] 10805 <- (0,20607)
[1] 10806 <- (0,20635)
[1] 10807 <- (0,20636)
[1] 10808 <- (0,20637)
[1] 10809 <- (0,20638)
[1] 10810 <- (0,20639)
[1] 10811 <- (0,20640)
[1] 10812 <- (0,20641)
[1] 10813 <- (0,20642)
[1] 10814 <- (0,20643)
[1] 10815 <- (0,20644)
[1] 10816 <- (0,20645)
[1] 10817 <- (0,20646)
[1] 10818 <- (0,20647)
[1] 10819 <- (0,20648)
[1] 10820 <- (0,20649)
[1] 10821 <- (0,20650)
[1] 10822 <- (0,20651)
[1] 10823 <- (0,20652)
[1] 10824 <- (0,20653)
[1] 10825 <- (0,20654)
[1] 10826 <- (0,20655)
[1] 10827 <- (0,20656)
[1] 10828 <- (0,20657)
[1] 10829 <- (0,20658)
[1] 10830 <- (0,20686)
[1] 10831 <- (0,20687)
[1] 10832 <- (0,20688)
[1] 10833 <- (0,20689)
[1] 10834 <- (0,20690)
[1] 10835 <- (0,20691)
[1] 10836 <- (0,20692)
[1] 10837 <- (0,20693)
[1] 10838 <- (0,20694)
[1] 10839 <- (0,20695)
[1] 10840 <- (0,20696)
[1] 10841 <- (0,20697)
[1] 10842 <- (0,20698)
[1] 10843 <- (0,20699)
[1] 10844 <- (0,20700)
[1] 10845 <- (0,20701)
[1] 10846 <- (0,20702)
[1] 10847 <- (0,20703)
[1] 10848 <- (0,20704)
[1] 10849 <- (0,20705)
[1] 10850 <- (0,20706)
[1] 10851 <- (0,20707)
[1] 10852 <- (0,20708)
[1] 10853 <- (0,20709)
[1] 10854 <- (0,20732)
[1] 10855 <- (0,20733)
[1] 10856 <- (0,20734)
[1] 10857 <- (0,20735)
[1] 10858 <- (0,20736)
[1] 10859 <- (0,20737)
[1] 10860 <- (0,20738)
[1] 10861 <- (0,20739)
[1] 10862 <- (0,20740)
[1] 10863 <- (0,20741)
[1] 10864 <- (0,20742)
[1] 10865 <- (0,20743)
[1] 10866 <- (0,20744)
[1] 10867 <- (0,20745)
[1] 10868 <- (0,20746)
[1] 10869 <- (0,20747)
[1] 10870 <- (0,20748)
[1] 10871 <- (0,20749)
[1] 10872 <- (0,20750)
[1] 10873 <- (0,20751)
[1] 10874 <- (0,20752)
[1] 10875 <- (0,20753)
[1] 10876 <- (0,20754)
[1] 10877 <- (0,20755)
[1] 10878 <- (0,20756)
[1] 10879 <- (0,20757)
[1] 10880 <- (0,20758)
[1] 10881 <- (0,20759)
[1] 10882 <- (0,20760)
[1] 10883 <- (0,20783)
[1] 10884 <- (0,20784)
[1] 10885 <- (0,20785)
[1] 10886 <- (0,20786)
[1] 10887 <- (0,20787)
[1] 10888 <- (0,20788)
[1] 10889 <- (0,20789)
[1] 10890 <- (0,20790)
[1] 10891 <- (0,20791)
[1] 10892 <- (0,20792)
[1] 10893 <- (0,20793)
[1] 10894 <- (0,20794)
[1] 10895 <- (0,20795)
[1] 10896 <- (0,20796)
[1] 10897 <- (0,20797)
[1] 10898 <- (0,20798)
[1] 10899 <- (0,20799)
[1] 10900 <- (0,20800)
[1] 10901 <- (0,20801)
[1] 10902 <- (0,20802)
[1] 10903 <- (0,20803)
[1] 10904 <- (0,20804)
[1] 10905 <- (0,20805)
[1] 10906 <- (0,20806)
[1] 10907 <- (0,20807)
[1] 10908 <- (0,20808)
[1] 10909 <- (0,20809)
[1] 10910 <- (0,20810)
[1] 10911 <- (0,20811)
[1] 10912 <- (0,20834)
[1] 10913 <- (0,20835)
[1] 10914 <- (0,20836)
[1] 10915 <- (0,20837)
[1] 10916 <- (0,20838)
[1] 10917 <- (0,20839)
[1] 10918 <- (0,20840)
[1] 10919 <- (0,20841)
[1] 10920 <- (0,20842)
[1] 10921 <- (0,20843)
[1] 10922 <- (0,20844)
[1] 10923 <- (0,20845)
[1] 10924 <- (0,20846)
[1] 10925 <- (0,20847)
[1] 10926 <- (0,20848)
[1] 10927 <- (0,20849)
[1] 10928 <- (0,20850)
[1] 10929 <- (0,20851)
[1] 10930 <- (0,20852)
[1] 10931 <- (0,20853)
[1] 10932 <- (0,20854)
[1] 10933 <- (0,20855)
[1] 10934 <- (0,20856)
[1] 10935 <- (0,20857)
[1] 10936 <- (0,20858)
[1] 10937 <- (0,20859)
[1] 10938 <- (0,20860)
[1] 10939 <- (0,20861)
[1] 10940 <- (0,20862)
[1] 10941 <- (0,20885)
[1] 10942 <- (0,20886)
[1] 10943 <- (0,20887)
[1] 10944 <- (0,20888)
[1] 10945 <- (0,20889)
[1] 10946 <- (0,20890)
[1] 10947 <- (0,20891)
[1] 10948 <- (0,20892)
[1] 10949 <- (0,20893)
[1] 10950 <- (0,20894)
[1] 10951 <- (0,20895)
[1] 10952 <- (0,20896)
[1] 10953 <- (0,20897)
[1] 10954 <- (0,20898)
[1] 10955 <- (0,20899)
[1] 10956 <- (0,20900)
[1] 10957 <- (0,20901)
[1] 10958 <- (0,20902)
[1] 10959 <- (0,20903)
[1] 10960 <- (0,20904)
[1] 10961 <- (0,20905)
[1] 10962 <- (0,20906)
[1] 10963 <- (0,20907)
[1] 10964 <- (0,20908)
[1] 10965 <- (0,20909)
[1] 10966 <- (0,20910)
[1] 10967 <- (0,20911)
[1] 10968 <- (0,20912)
[1] 10969 <- (0,20913)
[1] 10970 <- (0,20936)
[1] 10971 <- (0,20937)
[1] 10972 <- (0,20938)
[1] 10973 <- (0,20939)
[1] 10974 <- (0,20940)
[1] 10975 <- (0,20941)
[1] 10976 <- (0,20942)
[1] 10977 <- (0,20943)
[1] 10978 <- (0,20944)
[1] 10979 <- (0,20945)
[1] 10980 <- (0,20946)
[1] 10981 <- (0,20947)
[1] 10982 <- (0,20948)
[1] 10983 <- (0,20949)
[1] 10984 <- (0,20950)
[1] 10985 <- (0,20951)
[1] 10986 <- (0,20952)
[1] 10987 <- (0,20953)
[1] 10988 <- (0,20954)
[1] 10989 <- (0,20955)
[1] 10990 <- (0,20956)
[1] 10991 <- (0,20957)
[1] 10992 <- (0,20958)
[1] 10993 <- (0,20959)
[1] 10994 <- (0,20960)
[1] 10995 <- (0,20961)
[1] 10996 <- (0,20962)
[1] 10997 <- (0,20963)
[1] 10998 <- (0,20964)
[1] 10999 <- (0,20988)
[1] 11000 <- (0,20989)
[1] 11001 <- (0,20990)
[1] 11002 <- (0,20991)
[1] 11003 <- (0,20992)
[1] 11004 <- (0,20993)
[1] 11005 <- (0,20994)
[1] 11006 <- (0,20995)
[1] 11007 <- (0,20996)
[1] 11008 <- (0,20997)
[1] 11009 <- (0,20998)
[1] 11010 <- (0,20999)
[1] 11011 <- (0,21000)
[1] 11012 <- (0,21001)
[1] 11013 <- (0,21002)
[1] 11014 <- (0,21003)
[1] 11015 <- (0,21004)
[1] 11016 <- (0,21005)
[1] 11017 <- (0,21006)
[1] 11018 <- (0,21007)
[1] 11019 <- (0,21008)
[1] 11020 <- (0,21009)
[1] 11021 <- (0,21010)
[1] 11022 <- (0,21011)
[1] 11023 <- (0,21012)
[1] 11024 <- (0,21013)
[1] 11025 <- (0,21014)
[1] 11026 <- (0,21015)
[1] 11027 <- (0,21039)
[1] 11028 <- (0,21040)
[1] 11029 <- (0,21041)
[1] 11030 <- (0,21042)
[1] 11031 <- (0,21043)
[1] 11032 <- (0,21044)
[1] 11033 <- (0,21045)
[1] 11034 <- (0,21046)
[1] 11035 <- (0,21047)
[1] 11036 <- (0,21048)
[1] 11037 <- (0,21049)
[1] 11038 <- (0,21050)
[1] 11039 <- (0,21051)
[1] 11040 <- (0,21052)
[1] 11041 <- (0,21053)
[1] 11042 <- (0,21054)
[1] 11043 <- (0,21055)
[1] 11044 <- (0,21056)
[1] 11045 <- (0,21057)
[1] 11046 <- (0,21058)
[1] 11047 <- (0,21059)
[1] 11048 <- (0,21060)
[1] 11049 <- (0,21061)
[1] 11050 <- (0,21062)
[1] 11051 <- (0,21063)
[1] 11052 <- (0,21064)
[1] 11053 <- (0,21065)
[1] 11054 <- (0,21066)
[1] 11055 <- (0,21090)
[1] 11056 <- (0,21091)
[1] 11057 <- (0,21092)
[1] 11058 <- (0,21093)
[1] 11059 <- (0,21094)
[1] 11060 <- (0,21095)
[1] 11061 <- (0,21096)
[1] 11062 <- (0,21097)
[1] 11063 <- (0,21098)
[1] 11064 <- (0,21099)
[1] 11065 <- (0,21100)
[1] 11066 <- (0,21101)
[1] 11067 <- (0,21102)
[1] 11068 <- (0,21103)
[1] 11069 <- (0,21104)
[1] 11070 <- (0,21105)
[1] 11071 <- (0,21106)
[1] 11072 <- (0,21107)
[1] 11073 <- (0,21108)
[1] 11074 <- (0,21109)
[1] 11075 <- (0,21110)
[1] 11076 <- (0,21111)
[1] 11077 <- (0,21112)
[1] 11078 <- (0,21113)
[1] 11079 <- (0,21114)
[1] 11080 <- (0,21115)
[1] 11081 <- (0,21116)
[1] 11082 <- (0,21117)
[1] 11083 <- (0,21141)
[1] 11084 <- (0,21142)
[1] 11085 <- (0,21143)
[1] 11086 <- (0,21144)
[1] 11087 <- (0,21145)
[1] 11088 <- (0,21146)
[1] 11089 <- (0,21147)
[1] 11090 <- (0,21148)
[1] 11091 <- (0,21149)
[1] 11092 <- (0,21150)
[1] 11093 <- (0,21151)
[1] 11094 <- (0,21152)
[1] 11095 <- (0,21153)
[1] 11096 <- (0,21154)
[1] 11097 <- (0,21155)
[1] 11098 <- (0,21156)
[1] 11099 <- (0,21157)
[1] 11100 <- (0,21158)
[1] 11101 <- (0,21159)
[1] 11102 <- (0,21160)
[1] 11103 <- (0,21161)
[1] 11104 <- (0,21162)
[1] 11105 <- (0,21163)
[1] 11106 <- (0,21164)
[1] 11107 <- (0,21165)
[1] 11108 <- (0,21166)
[1] 11109 <- (0,21167)
[1] 11110 <- (0,21168)
[1] 11111 <- (0,21193)
[1] 11112 <- (0,21194)
[1] 11113 <- (0,21195)
[1] 11114 <- (0,21196)
[1] 11115 <- (0,21197)
[1] 11116 <- (0,21198)
[1] 11117 <- (0,21199)
[1] 11118 <- (0,21200)
[1] 11119 <- (0,21201)
[1] 11120 <- (0,21202)
[1] 11121 <- (0,21203)
[1] 11122 <- (0,21204)
[1] 11123 <- (0,21205)
[1] 11124 <- (0,21206)
[1] 11125 <- (0,21207)
[1] 11126 <- (0,21208)
[1] 11127 <- (0,21209)
[1] 11128 <- (0,21210)
[1] 11129 <- (0,21211)
[1] 11130 <- (0,21212)
[1] 11131 <- (0,21213)
[1] 11132 <- (0,21214)
[1] 11133 <- (0,21215)
[1] 11134 <- (0,21216)
[1] 11135 <- (0,21217)
[1] 11136 <- (0,21218)
[1] 11137 <- (0,21219)
[1] 11138 <- (0,21245)
[1] 11139 <- (0,21246)
[1] 11140 <- (0,21247)
[1] 11141 <- (0,21248)
[1] 11142 <- (0,21249)
[1] 11143 <- (0,21250)
[1] 11144 <- (0,21251)
[1] 11145 <- (0,21252)
[1] 11146 <- (0,21253)
[1] 11147 <- (0,21254)
[1] 11148 <- (0,21255)
[1] 11149 <- (0,21256)
[1] 11150 <- (0,21257)
[1] 11151 <- (0,21258)
[1] 11152 <- (0,21259)
[1] 11153 <- (0,21260)
[1] 11154 <- (0,21261)
[1] 11155 <- (0,21262)
[1] 11156 <- (0,21263)
[1] 11157 <- (0,21264)
[1] 11158 <- (0,21265)
[1] 11159 <- (0,21266)
[1] 11160 <- (0,21267)
[1] 11161 <- (0,21268)
[1] 11162 <- (0,21269)
[1] 11163 <- (0,21270)
[1] 11164 <- (0,21296)
[1] 11165 <- (0,21297)
[1] 11166 <- (0,21298)
[1] 11167 <- (0,21299)
[1] 11168 <- (0,21300)
[1] 11169 <- (0,21301)
[1] 11170 <- (0,21302)
[1] 11171 <- (0,21303)
[1] 11172 <- (0,21304)
[1] 11173 <- (0,21305)
[1] 11174 <- (0,21306)
[1] 11175 <- (0,21307)
[1] 11176 <- (0,21308)
[1] 11177 <- (0,21309)
[1] 11178 <- (0,21310)
[1] 11179 <- (0,21311)
[1] 11180 <- (0,21312)
[1] 11181 <- (0,21313)
[1] 11182 <- (0,21314)
[1] 11183 <- (0,21315)
[1] 11184 <- (0,21316)
[1] 11185 <- (0,21317)
[1] 11186 <- (0,21318)
[1] 11187 <- (0,21319)
[1] 11188 <- (0,21320)
[1] 11189 <- (0,21321)
[1] 11190 <- (0,21348)
[1] 11191 <- (0,21349)
[1] 11192 <- (0,21350)
[1] 11193 <- (0,21351)
[1] 11194 <- (0,21352)
[1] 11195 <- (0,21353)
[1] 11196 <- (0,21354)
[1] 11197 <- (0,21355)
[1] 11198 <- (0,21356)
[1] 11199 <- (0,21357)
[1] 11200 <- (0,21358)
[1] 11201 <- (0,21359)
[1] 11202 <- (0,21360)
[1] 11203 <- (0,21361)
[1] 11204 <- (0,21362)
[1] 11205 <- (0,21363)
[1] 11206 <- (0,21364)
[1] 11207 <- (0,21365)
[1] 11208 <- (0,21366)
[1] 11209 <- (0,21367)
[1] 11210 <- (0,21368)
[1] 11211 <- (0,21369)
[1] 11212 <- (0,21370)
[1] 11213 <- (0,21371)
[1] 11214 <- (0,21372)
[1] 11215 <- (0,21399)
[1] 11216 <- (0,21400)
[1] 11217 <- (0,21401)
[1] 11218 <- (0,21402)
[1] 11219 <- (0,21403)
[1] 11220 <- (0,21404)
[1] 11221 <- (0,21405)
[1] 11222 <- (0,21406)
[1] 11223 <- (0,21407)
[1] 11224 <- (0,21408)
[1] 11225 <- (0,21409)
[1] 11226 <- (0,21410)
[1] 11227 <- (0,21411)
[1] 11228 <- (0,21412)
[1] 11229 <- (0,21413)
[1] 11230 <- (0,21414)
[1] 11231 <- (0,21415)
[1] 11232 <- (0,21416)
[1] 11233 <- (0,21417)
[1] 11234 <- (0,21418)
[1] 11235 <- (0,21419)
[1] 11236 <- (0,21420)
[1] 11237 <- (0,21421)
[1] 11238 <- (0,21422)
[1] 11239 <- (0,21423)
[1] 11240 <- (0,21451)
[1] 11241 <- (0,21452)
[1] 11242 <- (0,21453)
[1] 11243 <- (0,21454)
[1] 11244 <- (0,21455)
[1] 11245 <- (0,21456)
[1] 11246 <- (0,21457)
[1] 11247 <- (0,21458)
[1] 11248 <- (0,21459)
[1] 11249 <- (0,21460)
[1] 11250 <- (0,21461)
[1] 11251 <- (0,21462)
[1] 11252 <- (0,21463)
[1] 11253 <- (0,21464)
[1] 11254 <- (0,21465)
[1] 11255 <- (0,21466)
[1] 11256 <- (0,21467)
[1] 11257 <- (0,21468)
[1] 11258 <- (0,21469)
[1] 11259 <- (0,21470)
[1] 11260 <- (0,21471)
[1] 11261 <- (0,21472)
[1] 11262 <- (0,21473)
[1] 11263 <- (0,21474)
[1] 11264 <- (0,21502)
[1] 11265 <- (0,21503)
[1] 11266 <- (0,21504)
[1] 11267 <- (0,21505)
[1] 11268 <- (0,21506)
[1] 11269 <- (0,21507)
[1] 11270 <- (0,21508)
[1] 11271 <- (0,21509)
[1] 11272 <- (0,21510)
[1] 11273 <- (0,21511)
[1] 11274 <- (0,21512)
[1] 11275 <- (0,21513)
[1] 11276 <- (0,21514)
[1] 11277 <- (0,21515)
[1] 11278 <- (0,21516)
[1] 11279 <- (0,21517)
[1] 11280 <- (0,21518)
[1] 11281 <- (0,21519)
[1] 11282 <- (0,21520)
[1] 11283 <- (0,21521)
[1] 11284 <- (0,21522)
[1] 11285 <- (0,21523)
[1] 11286 <- (0,21524)
[1] 11287 <- (0,21525)
[1] 11288 <- (0,21553)
[1] 11289 <- (0,21554)
[1] 11290 <- (0,21555)
[1] 11291 <- (0,21556)
[1] 11292 <- (0,21557)
[1] 11293 <- (0,21558)
[1] 11294 <- (0,21559)
[1] 11295 <- (0,21560)
[1] 11296 <- (0,21561)
[1] 11297 <- (0,21562)
[1] 11298 <- (0,21563)
[1] 11299 <- (0,21564)
[1] 11300 <- (0,21565)
[1] 11301 <- (0,21566)
[1] 11302 <- (0,21567)
[1] 11303 <- (0,21568)
[1] 11304 <- (0,21569)
[1] 11305 <- (0,21570)
[1] 11306 <- (0,21571)
[1] 11307 <- (0,21572)
[1] 11308 <- (0,21573)
[1] 11309 <- (0,21574)
[1] 11310 <- (0,21575)
[1] 11311 <- (0,21576)
[1] 11312 <- (0,21604)
[1] 11313 <- (0,21605)
[1] 11314 <- (0,21606)
[1] 11315 <- (0,21607)
[1] 11316 <- (0,21608)
[1] 11317 <- (0,21609)
[1] 11318 <- (0,21610)
[1] 11319 <- (0,21611)
[1] 11320 <- (0,21612)
[1] 11321 <- (0,21613)
[1] 11322 <- (0,21614)
[1] 11323 <- (0,21615)
[1] 11324 <- (0,21616)
[1] 11325 <- (0,21617)
[1] 11326 <- (0,21618)
[1] 11327 <- (0,21619)
[1] 11328 <- (0,21620)
[1] 11329 <- (0,21621)
[1] 11330 <- (0,21622)
[1] 11331 <- (0,21623)
[1] 11332 <- (0,21624)
[1] 11333 <- (0,21625)
[1] 11334 <- (0,21626)
[1] 11335 <- (0,21627)
[1] 11336 <- (0,21655)
[1] 11337 <- (0,21656)
[1] 11338 <- (0,21657)
[1] 11339 <- (0,21658)
[1] 11340 <- (0,21659)
[1] 11341 <- (0,21660)
[1] 11342 <- (0,21661)
[1] 11343 <- (0,21662)
[1] 11344 <- (0,21663)
[1] 11345 <- (0,21664)
[1] 11346 <- (0,21665)
[1] 11347 <- (0,21666)
[1] 11348 <- (0,21667)
[1] 11349 <- (0,21668)
[1] 11350 <- (0,21669)
[1] 11351 <- (0,21670)
[1] 11352 <- (0,21671)
[1] 11353 <- (0,21672)
[1] 11354 <- (0,21673)
[1] 11355 <- (0,21674)
[1] 11356 <- (0,21675)
[1] 11357 <- (0,21676)
[1] 11358 <- (0,21677)
[1] 11359 <- (0,21678)
[1] 11360 <- (0,21706)
[1] 11361 <- (0,21707)
[1] 11362 <- (0,21708)
[1] 11363 <- (0,21709)
[1] 11364 <- (0,21710)
[1] 11365 <- (0,21711)
[1] 11366 <- (0,21712)
[1] 11367 <- (0,21713)
[1] 11368 <- (0,21714)
[1] 11369 <- (0,21715)
[1] 11370 <- (0,21716)
[1] 11371 <- (0,21717)
[1] 11372 <- (0,21718)
[1] 11373 <- (0,21719)
[1] 11374 <- (0,21720)
[1] 11375 <- (0,21721)
[1] 11376 <- (0,21722)
[1] 11377 <- (0,21723)
[1] 11378 <- (0,21724)
[1] 11379 <- (0,21725)
[1] 11380 <- (0,21726)
[1] 11381 <- (0,21727)
[1] 11382 <- (0,21728)
[1] 11383 <- (0,21729)
[1] 11384 <- (0,21757)
[1] 11385 <- (0,21758)
[1] 11386 <- (0,21759)
[1] 11387 <- (0,21760)
[1] 11388 <- (0,21761)
[1] 11389 <- (0,21762)
[1] 11390 <- (0,21763)
[1] 11391 <- (0,21764)
[1] 11392 <- (0,21765)
[1] 11393 <- (0,21766)
[1] 11394 <- (0,21767)
[1] 11395 <- (0,21768)
[1] 11396 <- (0,21769)
[1] 11397 <- (0,21770)
[1] 11398 <- (0,21771)
[1] 11399 <- (0,21772)
[1] 11400 <- (0,21773)
[1] 11401 <- (0,21774)
[1] 11402 <- (0,21775)
[1] 11403 <- (0,21776)
[1] 11404 <- (0,21777)
[1] 11405 <- (0,21778)
[1] 11406 <- (0,21779)
[1] 11407 <- (0,21780)
[1] 11408 <- (0,10021)
[1] 11409 <- (0,10072)
[1] 11410 <- (0,10123)
[1] 11411 <- (0,10174)
[1] 11412 <- (0,10225)
[1] 11413 <- (0,10276)
[1] 11414 <- (0,10277)
[1] 11415 <- (0,10328)
[1] 11416 <- (0,10379)
[1] 11417 <- (0,10430)
[1] 11418 <- (0,10481)
[1] 11419 <- (0,10482)
[1] 11420 <- (0,10533)
[1] 11421 <- (0,10584)
[1] 11422 <- (0,10585)
[1] 11423 <- (0,10636)
[1] 11424 <- (0,10637)
[1] 11425 <- (0,10688)
[1] 11426 <- (0,10739)
[1] 11427 <- (0,10740)
[1] 11428 <- (0,10791)
[1] 11429 <- (0,10842)
[1] 11430 <- (0,10893)
[1] 11431 <- (0,10944)
[1] 11432 <- (0,10995)
[1] 11433 <- (0,11046)
[1] 11434 <- (0,11092)
[1] 11435 <- (0,11143)
[1] 11436 <- (0,11194)
[1] 11437 <- (0,11245)
[1] 11438 <- (0,11296)
[1] 11439 <- (0,11347)
[1] 11440 <- (0,11348)
[1] 11441 <- (0,11399)
[1] 11442 <- (0,11450)
[1] 11443 <- (0,11501)
[1] 11444 <- (0,11552)
[1] 11445 <- (0,11553)
[1] 11446 <- (0,11604)
[1] 11447 <- (0,11655)
[1] 11448 <- (0,11656)
[1] 11449 <- (0,11707)
[1] 11450 <- (0,11708)
[1] 11451 <- (0,11759)
[1] 11452 <- (0,11810)
[1] 11453 <- (0,11811)
[1] 11454 <- (0,11862)
[1] 11455 <- (0,11913)
[1] 11456 <- (0,11964)
[1] 11457 <- (0,12015)
[1] 11458 <- (0,12066)
[1] 11459 <- (0,12117)
[1] 11460 <- (0,12163)
[1] 11461 <- (0,12214)
[1] 11462 <- (0,12265)
[1] 11463 <- (0,12316)
[1] 11464 <- (0,12367)
[1] 11465 <- (0,12418)
[1] 11466 <- (0,12419)
[1] 11467 <- (0,12470)
[1] 11468 <- (0,12521)
[1] 11469 <- (0,12572)
[1] 11470 <- (0,12623)
[1] 11471 <- (0,12624)
[1] 11472 <- (0,12675)
[1] 11473 <- (0,12726)
[1] 11474 <- (0,12727)
[1] 11475 <- (0,12778)
[1] 11476 <- (0,12779)
[1] 11477 <- (0,12830)
[1] 11478 <- (0,12881)
[1] 11479 <- (0,12882)
[1] 11480 <- (0,12933)
[1] 11481 <- (0,12984)
[1] 11482 <- (0,13035)
[1] 11483 <- (0,13086)
[1] 11484 <- (0,13137)
[1] 11485 <- (0,13188)
[1] 11486 <- (0,13234)
[1] 11487 <- (0,13285)
[1] 11488 <- (0,13336)
[1] 11489 <- (0,13387)
[1] 11490 <- (0,13438)
[1] 11491 <- (0,13489)
[1] 11492 <- (0,13490)
[1] 11493 <- (0,13541)
[1] 11494 <- (0,13592)
[1] 11495 <- (0,13643)
[1] 11496 <- (0,13694)
[1] 11497 <- (0,13695)
[1] 11498 <- (0,13746)
[1] 11499 <- (0,13797)
[1] 11500 <- (0,13798)
[1] 11501 <- (0,13849)
[1] 11502 <- (0,13850)
[1] 11503 <- (0,13901)
[1] 11504 <- (0,13952)
[1] 11505 <- (0,13953)
[1] 11506 <- (0,14004)
[1] 11507 <- (0,14055)
[1] 11508 <- (0,14106)
[1] 11509 <- (0,14157)
[1] 11510 <- (0,14208)
[1] 11511 <- (0,14259)
[1] 11512 <- (0,14305)
[1] 11513 <- (0,14356)
[1] 11514 <- (0,14407)
[1] 11515 <- (0,14458)
[1] 11516 <- (0,14509)
[1] 11517 <- (0,14560)
[1] 11518 <- (0,14561)
[1] 11519 <- (0,14612)
[1] 11520 <- (0,14663)
[1] 11521 <- (0,14714)
[1] 11522 <- (0,14765)
[1] 11523 <- (0,14766)
[1] 11524 <- (0,14817)
[1] 11525 <- (0,14868)
[1] 11526 <- (0,14869)
[1] 11527 <- (0,14920)
[1] 11528 <- (0,14921)
[1] 11529 <- (0,14972)
[1] 11530 <- (0,15023)
[1] 11531 <- (0,15024)
[1] 11532 <- (0,15075)
[1] 11533 <- (0,15126)
[1] 11534 <- (0,15177)
[1] 11535 <- (0,15228)
[1] 11536 <- (0,15279)
[1] 11537 <- (0,15330)
[1] 11538 <- (0,15376)
[1] 11539 <- (0,15427)
[1] 11540 <- (0,15478)
[1] 11541 <- (0,15529)
[1] 11542 <- (0,15580)
[1] 11543 <- (0,15631)
[1] 11544 <- (0,15632)
[1] 11545 <- (0,15683)
[1] 11546 <- (0,15734)
[1] 11547 <- (0,15785)
[1] 11548 <- (0,15836)
[1] 11549 <- (0,15837)
[1] 11550 <- (0,15888)
[1] 11551 <- (0,15939)
[1] 11552 <- (0,15940)
[1] 11553 <- (0,15991)
[1] 11554 <- (0,15992)
[1] 11555 <- (0,16043)
[1] 11556 <- (0,16094)
[1] 11557 <- (0,16095)
[1] 11558 <- (0,16146)
[1] 11559 <- (0,16197)
[1] 11560 <- (0,16248)
[1] 11561 <- (0,16299)
[1] 11562 <- (0,16350)
[1] 11563 <- (0,16401)
[1] 11564 <- (0,16447)
[1] 11565 <- (0,16498)
[1] 11566 <- (0,16549)
[1] 11567 <- (0,16600)
[1] 11568 <- (0,16651)
[1] 11569 <- (0,16702)
[1] 11570 <- (0,16703)
[1] 11571 <- (0,16754)
[1] 11572 <- (0,16805)
[1] 11573 <- (0,16856)
[1] 11574 <- (0,16907)
[1] 11575 <- (0,16908)
[1] 11576 <- (0,16959)
[1] 11577 <- (0,17010)
[1] 11578 <- (0,17011)
[1] 11579 <- (0,17062)
[1] 11580 <- (0,17063)
[1] 11581 <- (0,17114)
[1] 11582 <- (0,17165)
[1] 11583 <- (0,17166)
[1] 11584 <- (0,17217)
[1] 11585 <- (0,17268)
[1] 11586 <- (0,17319)
[1] 11587 <- (0,17370)
[1] 11588 <- (0,17421)
[1] 11589 <- (0,17472)
[1] 11590 <- (0,17518)
[1] 11591 <- (0,17569)
[1] 11592 <- (0,17620)
[1] 11593 <- (0,17671)
[1] 11594 <- (0,17722)
[1] 11595 <- (0,17773)
[1] 11596 <- (0,17774)
[1] 11597 <- (0,17825)
[1] 11598 <- (0,17876)
[1] 11599 <- (0,17927)
[1] 11600 <- (0,17978)
[1] 11601 <- (0,17979)
[1] 11602 <- (0,18030)
[1] 11603 <- (0,18031)
[1] 11604 <- (0,18081)
[1] 11605 <- (0,18082)
[1] 11606 <- (0,18133)
[1] 11607 <- (0,18134)
[1] 11608 <- (0,18185)
[1] 11609 <- (0,18236)
[1] 11610 <- (0,18237)
[1] 11611 <- (0,18288)
[1] 11612 <- (0,18339)
[1] 11613 <- (0,18390)
[1] 11614 <- (0,18441)
[1] 11615 <- (0,18492)
[1] 11616 <- (0,18543)
[1] 11617 <- (0,18589)
[1] 11618 <- (0,18640)
[1] 11619 <- (0,18691)
[1] 11620 <- (0,18742)
[1] 11621 <- (0,18793)
[1] 11622 <- (0,18844)
[1] 11623 <- (0,18845)
[1] 11624 <- (0,18896)
[1] 11625 <- (0,18947)
[1] 11626 <- (0,18998)
[1] 11627 <- (0,19049)
[1] 11628 <- (0,19050)
[1] 11629 <- (0,19101)
[1] 11630 <- (0,19102)
[1] 11631 <- (0,19153)
[1] 11632 <- (0,19204)
[1] 11633 <- (0,19205)
[1] 11634 <- (0,19256)
[1] 11635 <- (0,19307)
[1] 11636 <- (0,19308)
[1] 11637 <- (0,19359)
[1] 11638 <- (0,19410)
[1] 11639 <- (0,19461)
[1] 11640 <- (0,19512)
[1] 11641 <- (0,19563)
[1] 11642 <- (0,19614)
[1] 11643 <- (0,19660)
[1] 11644 <- (0,19711)
[1] 11645 <- (0,19762)
[1] 11646 <- (0,19813)
[1] 11647 <- (0,19864)
[1] 11648 <- (0,19915)
[1] 11649 <- (0,19916)
[1] 11650 <- (0,19967)
[1] 11651 <- (0,20018)
[1] 11652 <- (0,20069)
[1] 11653 <- (0,20120)
[1] 11654 <- (0,20121)
[1] 11655 <- (0,20172)
[1] 11656 <- (0,20173)
[1] 11657 <- (0,20224)
[1] 11658 <- (0,20275)
[1] 11659 <- (0,20276)
[1] 11660 <- (0,20327)
[1] 11661 <- (0,20378)
[1] 11662 <- (0,20379)
[1] 11663 <- (0,20430)
[1] 11664 <- (0,20481)
[1] 11665 <- (0,20532)
[1] 11666 <- (0,20583)
[1] 11667 <- (0,20634)
[1] 11668 <- (0,20685)
[1] 11669 <- (0,20731)
[1] 11670 <- (0,20782)
[1] 11671 <- (0,20833)
[1] 11672 <- (0,20884)
[1] 11673 <- (0,20935)
[1] 11674 <- (0,20986)
[1] 11675 <- (0,20987)
[1] 11676 <- (0,21038)
[1] 11677 <- (0,21089)
[1] 11678 <- (0,21140)
[1] 11679 <- (0,21191)
[1] 11680 <- (0,21192)
[1] 11681 <- (0,21243)
[1] 11682 <- (0,21244)
[1] 11683 <- (0,21295)
[1] 11684 <- (0,21346)
[1] 11685 <- (0,21347)
[1] 11686 <- (0,21398)
[1] 11687 <- (0,21449)
[1] 11688 <- (0,21450)
[1] 11689 <- (0,21501)
[1] 11690 <- (0,21552)
[1] 11691 <- (0,21603)
[1] 11692 <- (0,21654)
[1] 11693 <- (0,21705)
[1] 11694 <- (0,21756)
End of PetscSFView
# vtk DataFile Version 2.0
vtk mesh created by matlab code
ASCII
DATASET UNSTRUCTURED_GRID
POINTS 11781 double
-100.00000000 -50.00000000 0.00000000
-96.00000000 -50.00000000 0.00000000
-92.00000000 -50.00000000 0.00000000
-88.00000000 -50.00000000 0.00000000
-84.00000000 -50.00000000 0.00000000
-80.00000000 -50.00000000 0.00000000
-76.00000000 -50.00000000 0.00000000
-72.00000000 -50.00000000 0.00000000
-68.00000000 -50.00000000 0.00000000
-64.00000000 -50.00000000 0.00000000
-60.00000000 -50.00000000 0.00000000
-56.00000000 -50.00000000 0.00000000
-52.00000000 -50.00000000 0.00000000
-48.00000000 -50.00000000 0.00000000
-44.00000000 -50.00000000 0.00000000
-40.00000000 -50.00000000 0.00000000
-36.00000000 -50.00000000 0.00000000
-32.00000000 -50.00000000 0.00000000
-28.00000000 -50.00000000 0.00000000
-24.00000000 -50.00000000 0.00000000
-20.00000000 -50.00000000 0.00000000
-16.00000000 -50.00000000 0.00000000
-12.00000000 -50.00000000 0.00000000
-8.00000000 -50.00000000 0.00000000
-4.00000000 -50.00000000 0.00000000
-100.00000000 -45.00000000 0.00000000
-96.00000000 -45.00000000 0.00000000
-92.00000000 -45.00000000 0.00000000
-88.00000000 -45.00000000 0.00000000
-84.00000000 -45.00000000 0.00000000
-80.00000000 -45.00000000 0.00000000
-76.00000000 -45.00000000 0.00000000
-72.00000000 -45.00000000 0.00000000
-68.00000000 -45.00000000 0.00000000
-64.00000000 -45.00000000 0.00000000
-60.00000000 -45.00000000 0.00000000
-56.00000000 -45.00000000 0.00000000
-52.00000000 -45.00000000 0.00000000
-48.00000000 -45.00000000 0.00000000
-44.00000000 -45.00000000 0.00000000
-40.00000000 -45.00000000 0.00000000
-36.00000000 -45.00000000 0.00000000
-32.00000000 -45.00000000 0.00000000
-28.00000000 -45.00000000 0.00000000
-24.00000000 -45.00000000 0.00000000
-20.00000000 -45.00000000 0.00000000
-16.00000000 -45.00000000 0.00000000
-12.00000000 -45.00000000 0.00000000
-8.00000000 -45.00000000 0.00000000
-4.00000000 -45.00000000 0.00000000
-100.00000000 -40.00000000 0.00000000
-96.00000000 -40.00000000 0.00000000
-92.00000000 -40.00000000 0.00000000
-88.00000000 -40.00000000 0.00000000
-84.00000000 -40.00000000 0.00000000
-80.00000000 -40.00000000 0.00000000
-76.00000000 -40.00000000 0.00000000
-72.00000000 -40.00000000 0.00000000
-68.00000000 -40.00000000 0.00000000
-64.00000000 -40.00000000 0.00000000
-60.00000000 -40.00000000 0.00000000
-56.00000000 -40.00000000 0.00000000
-52.00000000 -40.00000000 0.00000000
-48.00000000 -40.00000000 0.00000000
-44.00000000 -40.00000000 0.00000000
-40.00000000 -40.00000000 0.00000000
-36.00000000 -40.00000000 0.00000000
-32.00000000 -40.00000000 0.00000000
-28.00000000 -40.00000000 0.00000000
-24.00000000 -40.00000000 0.00000000
-20.00000000 -40.00000000 0.00000000
-16.00000000 -40.00000000 0.00000000
-12.00000000 -40.00000000 0.00000000
-8.00000000 -40.00000000 0.00000000
-4.00000000 -40.00000000 0.00000000
-100.00000000 -35.00000000 0.00000000
-96.00000000 -35.00000000 0.00000000
-92.00000000 -35.00000000 0.00000000
-88.00000000 -35.00000000 0.00000000
-84.00000000 -35.00000000 0.00000000
-80.00000000 -35.00000000 0.00000000
-76.00000000 -35.00000000 0.00000000
-72.00000000 -35.00000000 0.00000000
-68.00000000 -35.00000000 0.00000000
-64.00000000 -35.00000000 0.00000000
-60.00000000 -35.00000000 0.00000000
-56.00000000 -35.00000000 0.00000000
-52.00000000 -35.00000000 0.00000000
-48.00000000 -35.00000000 0.00000000
-44.00000000 -35.00000000 0.00000000
-40.00000000 -35.00000000 0.00000000
-36.00000000 -35.00000000 0.00000000
-32.00000000 -35.00000000 0.00000000
-28.00000000 -35.00000000 0.00000000
-24.00000000 -35.00000000 0.00000000
-20.00000000 -35.00000000 0.00000000
-16.00000000 -35.00000000 0.00000000
-12.00000000 -35.00000000 0.00000000
-8.00000000 -35.00000000 0.00000000
-4.00000000 -35.00000000 0.00000000
-100.00000000 -30.00000000 0.00000000
-96.00000000 -30.00000000 0.00000000
-92.00000000 -30.00000000 0.00000000
-88.00000000 -30.00000000 0.00000000
-84.00000000 -30.00000000 0.00000000
-80.00000000 -30.00000000 0.00000000
-76.00000000 -30.00000000 0.00000000
-72.00000000 -30.00000000 0.00000000
-68.00000000 -30.00000000 0.00000000
-64.00000000 -30.00000000 0.00000000
-60.00000000 -30.00000000 0.00000000
-56.00000000 -30.00000000 0.00000000
-52.00000000 -30.00000000 0.00000000
-48.00000000 -30.00000000 0.00000000
-44.00000000 -30.00000000 0.00000000
-40.00000000 -30.00000000 0.00000000
-36.00000000 -30.00000000 0.00000000
-32.00000000 -30.00000000 0.00000000
-28.00000000 -30.00000000 0.00000000
-24.00000000 -30.00000000 0.00000000
-20.00000000 -30.00000000 0.00000000
-16.00000000 -30.00000000 0.00000000
-12.00000000 -30.00000000 0.00000000
-8.00000000 -30.00000000 0.00000000
-4.00000000 -30.00000000 0.00000000
-100.00000000 -25.00000000 0.00000000
-96.00000000 -25.00000000 0.00000000
-92.00000000 -25.00000000 0.00000000
-88.00000000 -25.00000000 0.00000000
-84.00000000 -25.00000000 0.00000000
-80.00000000 -25.00000000 0.00000000
-76.00000000 -25.00000000 0.00000000
-72.00000000 -25.00000000 0.00000000
-68.00000000 -25.00000000 0.00000000
-64.00000000 -25.00000000 0.00000000
-60.00000000 -25.00000000 0.00000000
-56.00000000 -25.00000000 0.00000000
-52.00000000 -25.00000000 0.00000000
-48.00000000 -25.00000000 0.00000000
-44.00000000 -25.00000000 0.00000000
-40.00000000 -25.00000000 0.00000000
-36.00000000 -25.00000000 0.00000000
-32.00000000 -25.00000000 0.00000000
-28.00000000 -25.00000000 0.00000000
-24.00000000 -25.00000000 0.00000000
-20.00000000 -25.00000000 0.00000000
-16.00000000 -25.00000000 0.00000000
-12.00000000 -25.00000000 0.00000000
-8.00000000 -25.00000000 0.00000000
-4.00000000 -25.00000000 0.00000000
-100.00000000 -20.00000000 0.00000000
-96.00000000 -20.00000000 0.00000000
-92.00000000 -20.00000000 0.00000000
-88.00000000 -20.00000000 0.00000000
-84.00000000 -20.00000000 0.00000000
-80.00000000 -20.00000000 0.00000000
-76.00000000 -20.00000000 0.00000000
-72.00000000 -20.00000000 0.00000000
-68.00000000 -20.00000000 0.00000000
-64.00000000 -20.00000000 0.00000000
-60.00000000 -20.00000000 0.00000000
-56.00000000 -20.00000000 0.00000000
-52.00000000 -20.00000000 0.00000000
-48.00000000 -20.00000000 0.00000000
-44.00000000 -20.00000000 0.00000000
-40.00000000 -20.00000000 0.00000000
-36.00000000 -20.00000000 0.00000000
-32.00000000 -20.00000000 0.00000000
-28.00000000 -20.00000000 0.00000000
-24.00000000 -20.00000000 0.00000000
-20.00000000 -20.00000000 0.00000000
-16.00000000 -20.00000000 0.00000000
-12.00000000 -20.00000000 0.00000000
-8.00000000 -20.00000000 0.00000000
-4.00000000 -20.00000000 0.00000000
-100.00000000 -15.00000000 0.00000000
-96.00000000 -15.00000000 0.00000000
-92.00000000 -15.00000000 0.00000000
-88.00000000 -15.00000000 0.00000000
-84.00000000 -15.00000000 0.00000000
-80.00000000 -15.00000000 0.00000000
-76.00000000 -15.00000000 0.00000000
-72.00000000 -15.00000000 0.00000000
-68.00000000 -15.00000000 0.00000000
-64.00000000 -15.00000000 0.00000000
-60.00000000 -15.00000000 0.00000000
-56.00000000 -15.00000000 0.00000000
-52.00000000 -15.00000000 0.00000000
-48.00000000 -15.00000000 0.00000000
-44.00000000 -15.00000000 0.00000000
-40.00000000 -15.00000000 0.00000000
-36.00000000 -15.00000000 0.00000000
-32.00000000 -15.00000000 0.00000000
-28.00000000 -15.00000000 0.00000000
-24.00000000 -15.00000000 0.00000000
-20.00000000 -15.00000000 0.00000000
-16.00000000 -15.00000000 0.00000000
-12.00000000 -15.00000000 0.00000000
-8.00000000 -15.00000000 0.00000000
-4.00000000 -15.00000000 0.00000000
-100.00000000 -10.00000000 0.00000000
-96.00000000 -10.00000000 0.00000000
-92.00000000 -10.00000000 0.00000000
-88.00000000 -10.00000000 0.00000000
-84.00000000 -10.00000000 0.00000000
-80.00000000 -10.00000000 0.00000000
-76.00000000 -10.00000000 0.00000000
-72.00000000 -10.00000000 0.00000000
-68.00000000 -10.00000000 0.00000000
-64.00000000 -10.00000000 0.00000000
-60.00000000 -10.00000000 0.00000000
-56.00000000 -10.00000000 0.00000000
-52.00000000 -10.00000000 0.00000000
-48.00000000 -10.00000000 0.00000000
-44.00000000 -10.00000000 0.00000000
-40.00000000 -10.00000000 0.00000000
-36.00000000 -10.00000000 0.00000000
-32.00000000 -10.00000000 0.00000000
-28.00000000 -10.00000000 0.00000000
-24.00000000 -10.00000000 0.00000000
-20.00000000 -10.00000000 0.00000000
-16.00000000 -10.00000000 0.00000000
-12.00000000 -10.00000000 0.00000000
-8.00000000 -10.00000000 0.00000000
-4.00000000 -10.00000000 0.00000000
-100.00000000 -5.00000000 0.00000000
-96.00000000 -5.00000000 0.00000000
-92.00000000 -5.00000000 0.00000000
-88.00000000 -5.00000000 0.00000000
-84.00000000 -5.00000000 0.00000000
-80.00000000 -5.00000000 0.00000000
-76.00000000 -5.00000000 0.00000000
-72.00000000 -5.00000000 0.00000000
-68.00000000 -5.00000000 0.00000000
-64.00000000 -5.00000000 0.00000000
-60.00000000 -5.00000000 0.00000000
-56.00000000 -5.00000000 0.00000000
-52.00000000 -5.00000000 0.00000000
-48.00000000 -5.00000000 0.00000000
-44.00000000 -5.00000000 0.00000000
-40.00000000 -5.00000000 0.00000000
-36.00000000 -5.00000000 0.00000000
-32.00000000 -5.00000000 0.00000000
-28.00000000 -5.00000000 0.00000000
-24.00000000 -5.00000000 0.00000000
-20.00000000 -5.00000000 0.00000000
-16.00000000 -5.00000000 0.00000000
-12.00000000 -5.00000000 0.00000000
-8.00000000 -5.00000000 0.00000000
-4.00000000 -5.00000000 0.00000000
-100.00000000 0.00000000 0.00000000
-96.00000000 0.00000000 0.00000000
-92.00000000 0.00000000 0.00000000
-88.00000000 0.00000000 0.00000000
-84.00000000 0.00000000 0.00000000
-80.00000000 0.00000000 0.00000000
-76.00000000 0.00000000 0.00000000
-72.00000000 0.00000000 0.00000000
-68.00000000 0.00000000 0.00000000
-64.00000000 0.00000000 0.00000000
-60.00000000 0.00000000 0.00000000
-56.00000000 0.00000000 0.00000000
-52.00000000 0.00000000 0.00000000
-48.00000000 0.00000000 0.00000000
-44.00000000 0.00000000 0.00000000
-40.00000000 0.00000000 0.00000000
-36.00000000 0.00000000 0.00000000
-32.00000000 0.00000000 0.00000000
-28.00000000 0.00000000 0.00000000
-24.00000000 0.00000000 0.00000000
-20.00000000 0.00000000 0.00000000
-16.00000000 0.00000000 0.00000000
-12.00000000 0.00000000 0.00000000
-8.00000000 0.00000000 0.00000000
-4.00000000 0.00000000 0.00000000
-100.00000000 5.00000000 0.00000000
-96.00000000 5.00000000 0.00000000
-92.00000000 5.00000000 0.00000000
-88.00000000 5.00000000 0.00000000
-84.00000000 5.00000000 0.00000000
-80.00000000 5.00000000 0.00000000
-76.00000000 5.00000000 0.00000000
-72.00000000 5.00000000 0.00000000
-68.00000000 5.00000000 0.00000000
-64.00000000 5.00000000 0.00000000
-60.00000000 5.00000000 0.00000000
-56.00000000 5.00000000 0.00000000
-52.00000000 5.00000000 0.00000000
-48.00000000 5.00000000 0.00000000
-44.00000000 5.00000000 0.00000000
-40.00000000 5.00000000 0.00000000
-36.00000000 5.00000000 0.00000000
-32.00000000 5.00000000 0.00000000
-28.00000000 5.00000000 0.00000000
-24.00000000 5.00000000 0.00000000
-20.00000000 5.00000000 0.00000000
-16.00000000 5.00000000 0.00000000
-12.00000000 5.00000000 0.00000000
-8.00000000 5.00000000 0.00000000
-4.00000000 5.00000000 0.00000000
-100.00000000 10.00000000 0.00000000
-96.00000000 10.00000000 0.00000000
-92.00000000 10.00000000 0.00000000
-88.00000000 10.00000000 0.00000000
-84.00000000 10.00000000 0.00000000
-80.00000000 10.00000000 0.00000000
-76.00000000 10.00000000 0.00000000
-72.00000000 10.00000000 0.00000000
-68.00000000 10.00000000 0.00000000
-64.00000000 10.00000000 0.00000000
-60.00000000 10.00000000 0.00000000
-56.00000000 10.00000000 0.00000000
-52.00000000 10.00000000 0.00000000
-48.00000000 10.00000000 0.00000000
-44.00000000 10.00000000 0.00000000
-40.00000000 10.00000000 0.00000000
-36.00000000 10.00000000 0.00000000
-32.00000000 10.00000000 0.00000000
-28.00000000 10.00000000 0.00000000
-24.00000000 10.00000000 0.00000000
-20.00000000 10.00000000 0.00000000
-16.00000000 10.00000000 0.00000000
-12.00000000 10.00000000 0.00000000
-8.00000000 10.00000000 0.00000000
-4.00000000 10.00000000 0.00000000
-100.00000000 15.00000000 0.00000000
-96.00000000 15.00000000 0.00000000
-92.00000000 15.00000000 0.00000000
-88.00000000 15.00000000 0.00000000
-84.00000000 15.00000000 0.00000000
-80.00000000 15.00000000 0.00000000
-76.00000000 15.00000000 0.00000000
-72.00000000 15.00000000 0.00000000
-68.00000000 15.00000000 0.00000000
-64.00000000 15.00000000 0.00000000
-60.00000000 15.00000000 0.00000000
-56.00000000 15.00000000 0.00000000
-52.00000000 15.00000000 0.00000000
-48.00000000 15.00000000 0.00000000
-44.00000000 15.00000000 0.00000000
-40.00000000 15.00000000 0.00000000
-36.00000000 15.00000000 0.00000000
-32.00000000 15.00000000 0.00000000
-28.00000000 15.00000000 0.00000000
-24.00000000 15.00000000 0.00000000
-20.00000000 15.00000000 0.00000000
-16.00000000 15.00000000 0.00000000
-12.00000000 15.00000000 0.00000000
-8.00000000 15.00000000 0.00000000
-4.00000000 15.00000000 0.00000000
-100.00000000 20.00000000 0.00000000
-96.00000000 20.00000000 0.00000000
-92.00000000 20.00000000 0.00000000
-88.00000000 20.00000000 0.00000000
-84.00000000 20.00000000 0.00000000
-80.00000000 20.00000000 0.00000000
-76.00000000 20.00000000 0.00000000
-72.00000000 20.00000000 0.00000000
-68.00000000 20.00000000 0.00000000
-64.00000000 20.00000000 0.00000000
-60.00000000 20.00000000 0.00000000
-56.00000000 20.00000000 0.00000000
-52.00000000 20.00000000 0.00000000
-48.00000000 20.00000000 0.00000000
-44.00000000 20.00000000 0.00000000
-40.00000000 20.00000000 0.00000000
-36.00000000 20.00000000 0.00000000
-32.00000000 20.00000000 0.00000000
-28.00000000 20.00000000 0.00000000
-24.00000000 20.00000000 0.00000000
-20.00000000 20.00000000 0.00000000
-16.00000000 20.00000000 0.00000000
-12.00000000 20.00000000 0.00000000
-8.00000000 20.00000000 0.00000000
-4.00000000 20.00000000 0.00000000
-100.00000000 25.00000000 0.00000000
-96.00000000 25.00000000 0.00000000
-92.00000000 25.00000000 0.00000000
-88.00000000 25.00000000 0.00000000
-84.00000000 25.00000000 0.00000000
-80.00000000 25.00000000 0.00000000
-76.00000000 25.00000000 0.00000000
-72.00000000 25.00000000 0.00000000
-68.00000000 25.00000000 0.00000000
-64.00000000 25.00000000 0.00000000
-60.00000000 25.00000000 0.00000000
-56.00000000 25.00000000 0.00000000
-52.00000000 25.00000000 0.00000000
-48.00000000 25.00000000 0.00000000
-44.00000000 25.00000000 0.00000000
-40.00000000 25.00000000 0.00000000
-36.00000000 25.00000000 0.00000000
-32.00000000 25.00000000 0.00000000
-28.00000000 25.00000000 0.00000000
-24.00000000 25.00000000 0.00000000
-20.00000000 25.00000000 0.00000000
-16.00000000 25.00000000 0.00000000
-12.00000000 25.00000000 0.00000000
-8.00000000 25.00000000 0.00000000
-4.00000000 25.00000000 0.00000000
-100.00000000 30.00000000 0.00000000
-96.00000000 30.00000000 0.00000000
-92.00000000 30.00000000 0.00000000
-88.00000000 30.00000000 0.00000000
-84.00000000 30.00000000 0.00000000
-80.00000000 30.00000000 0.00000000
-76.00000000 30.00000000 0.00000000
-72.00000000 30.00000000 0.00000000
-68.00000000 30.00000000 0.00000000
-64.00000000 30.00000000 0.00000000
-60.00000000 30.00000000 0.00000000
-56.00000000 30.00000000 0.00000000
-52.00000000 30.00000000 0.00000000
-48.00000000 30.00000000 0.00000000
-44.00000000 30.00000000 0.00000000
-40.00000000 30.00000000 0.00000000
-36.00000000 30.00000000 0.00000000
-32.00000000 30.00000000 0.00000000
-28.00000000 30.00000000 0.00000000
-24.00000000 30.00000000 0.00000000
-20.00000000 30.00000000 0.00000000
-16.00000000 30.00000000 0.00000000
-12.00000000 30.00000000 0.00000000
-8.00000000 30.00000000 0.00000000
-4.00000000 30.00000000 0.00000000
-100.00000000 35.00000000 0.00000000
-96.00000000 35.00000000 0.00000000
-92.00000000 35.00000000 0.00000000
-88.00000000 35.00000000 0.00000000
-84.00000000 35.00000000 0.00000000
-80.00000000 35.00000000 0.00000000
-76.00000000 35.00000000 0.00000000
-72.00000000 35.00000000 0.00000000
-68.00000000 35.00000000 0.00000000
-64.00000000 35.00000000 0.00000000
-60.00000000 35.00000000 0.00000000
-56.00000000 35.00000000 0.00000000
-52.00000000 35.00000000 0.00000000
-48.00000000 35.00000000 0.00000000
-44.00000000 35.00000000 0.00000000
-40.00000000 35.00000000 0.00000000
-36.00000000 35.00000000 0.00000000
-32.00000000 35.00000000 0.00000000
-28.00000000 35.00000000 0.00000000
-24.00000000 35.00000000 0.00000000
-20.00000000 35.00000000 0.00000000
-16.00000000 35.00000000 0.00000000
-12.00000000 35.00000000 0.00000000
-8.00000000 35.00000000 0.00000000
-4.00000000 35.00000000 0.00000000
-100.00000000 40.00000000 0.00000000
-96.00000000 40.00000000 0.00000000
-92.00000000 40.00000000 0.00000000
-88.00000000 40.00000000 0.00000000
-84.00000000 40.00000000 0.00000000
-80.00000000 40.00000000 0.00000000
-76.00000000 40.00000000 0.00000000
-72.00000000 40.00000000 0.00000000
-68.00000000 40.00000000 0.00000000
-64.00000000 40.00000000 0.00000000
-60.00000000 40.00000000 0.00000000
-56.00000000 40.00000000 0.00000000
-52.00000000 40.00000000 0.00000000
-48.00000000 40.00000000 0.00000000
-44.00000000 40.00000000 0.00000000
-40.00000000 40.00000000 0.00000000
-36.00000000 40.00000000 0.00000000
-32.00000000 40.00000000 0.00000000
-28.00000000 40.00000000 0.00000000
-24.00000000 40.00000000 0.00000000
-20.00000000 40.00000000 0.00000000
-16.00000000 40.00000000 0.00000000
-12.00000000 40.00000000 0.00000000
-8.00000000 40.00000000 0.00000000
-4.00000000 40.00000000 0.00000000
-100.00000000 45.00000000 0.00000000
-96.00000000 45.00000000 0.00000000
-92.00000000 45.00000000 0.00000000
-88.00000000 45.00000000 0.00000000
-84.00000000 45.00000000 0.00000000
-80.00000000 45.00000000 0.00000000
-76.00000000 45.00000000 0.00000000
-72.00000000 45.00000000 0.00000000
-68.00000000 45.00000000 0.00000000
-64.00000000 45.00000000 0.00000000
-60.00000000 45.00000000 0.00000000
-56.00000000 45.00000000 0.00000000
-52.00000000 45.00000000 0.00000000
-48.00000000 45.00000000 0.00000000
-44.00000000 45.00000000 0.00000000
-40.00000000 45.00000000 0.00000000
-36.00000000 45.00000000 0.00000000
-32.00000000 45.00000000 0.00000000
-28.00000000 45.00000000 0.00000000
-24.00000000 45.00000000 0.00000000
-20.00000000 45.00000000 0.00000000
-16.00000000 45.00000000 0.00000000
-12.00000000 45.00000000 0.00000000
-8.00000000 45.00000000 0.00000000
-4.00000000 45.00000000 0.00000000
-100.00000000 50.00000000 0.00000000
-96.00000000 50.00000000 0.00000000
-92.00000000 50.00000000 0.00000000
-88.00000000 50.00000000 0.00000000
-84.00000000 50.00000000 0.00000000
-80.00000000 50.00000000 0.00000000
-76.00000000 50.00000000 0.00000000
-72.00000000 50.00000000 0.00000000
-68.00000000 50.00000000 0.00000000
-64.00000000 50.00000000 0.00000000
-60.00000000 50.00000000 0.00000000
-56.00000000 50.00000000 0.00000000
-52.00000000 50.00000000 0.00000000
-48.00000000 50.00000000 0.00000000
-44.00000000 50.00000000 0.00000000
-40.00000000 50.00000000 0.00000000
-36.00000000 50.00000000 0.00000000
-32.00000000 50.00000000 0.00000000
-28.00000000 50.00000000 0.00000000
-24.00000000 50.00000000 0.00000000
-20.00000000 50.00000000 0.00000000
-16.00000000 50.00000000 0.00000000
-12.00000000 50.00000000 0.00000000
-8.00000000 50.00000000 0.00000000
-4.00000000 50.00000000 0.00000000
-97.50000000 -47.50000000 2.00000000
-93.60000000 -47.50000000 2.00000000
-89.70000000 -47.50000000 2.00000000
-85.80000000 -47.50000000 2.00000000
-81.90000000 -47.50000000 2.00000000
-78.00000000 -47.50000000 2.00000000
-74.10000000 -47.50000000 2.00000000
-70.20000000 -47.50000000 2.00000000
-66.30000000 -47.50000000 2.00000000
-62.40000000 -47.50000000 2.00000000
-58.50000000 -47.50000000 2.00000000
-54.60000000 -47.50000000 2.00000000
-50.70000000 -47.50000000 2.00000000
-46.80000000 -47.50000000 2.00000000
-42.90000000 -47.50000000 2.00000000
-39.00000000 -47.50000000 2.00000000
-35.10000000 -47.50000000 2.00000000
-31.20000000 -47.50000000 2.00000000
-27.30000000 -47.50000000 2.00000000
-23.40000000 -47.50000000 2.00000000
-19.50000000 -47.50000000 2.00000000
-15.60000000 -47.50000000 2.00000000
-11.70000000 -47.50000000 2.00000000
-7.80000000 -47.50000000 2.00000000
-3.90000000 -47.50000000 2.00000000
0.00000000 -47.50000000 2.00000000
-97.50000000 -42.75000000 2.00000000
-93.60000000 -42.75000000 2.00000000
-89.70000000 -42.75000000 2.00000000
-85.80000000 -42.75000000 2.00000000
-81.90000000 -42.75000000 2.00000000
-78.00000000 -42.75000000 2.00000000
-74.10000000 -42.75000000 2.00000000
-70.20000000 -42.75000000 2.00000000
-66.30000000 -42.75000000 2.00000000
-62.40000000 -42.75000000 2.00000000
-58.50000000 -42.75000000 2.00000000
-54.60000000 -42.75000000 2.00000000
-50.70000000 -42.75000000 2.00000000
-46.80000000 -42.75000000 2.00000000
-42.90000000 -42.75000000 2.00000000
-39.00000000 -42.75000000 2.00000000
-35.10000000 -42.75000000 2.00000000
-31.20000000 -42.75000000 2.00000000
-27.30000000 -42.75000000 2.00000000
-23.40000000 -42.75000000 2.00000000
-19.50000000 -42.75000000 2.00000000
-15.60000000 -42.75000000 2.00000000
-11.70000000 -42.75000000 2.00000000
-7.80000000 -42.75000000 2.00000000
-3.90000000 -42.75000000 2.00000000
0.00000000 -42.75000000 2.00000000
-97.50000000 -38.00000000 2.00000000
-93.60000000 -38.00000000 2.00000000
-89.70000000 -38.00000000 2.00000000
-85.80000000 -38.00000000 2.00000000
-81.90000000 -38.00000000 2.00000000
-78.00000000 -38.00000000 2.00000000
-74.10000000 -38.00000000 2.00000000
-70.20000000 -38.00000000 2.00000000
-66.30000000 -38.00000000 2.00000000
-62.40000000 -38.00000000 2.00000000
-58.50000000 -38.00000000 2.00000000
-54.60000000 -38.00000000 2.00000000
-50.70000000 -38.00000000 2.00000000
-46.80000000 -38.00000000 2.00000000
-42.90000000 -38.00000000 2.00000000
-39.00000000 -38.00000000 2.00000000
-35.10000000 -38.00000000 2.00000000
-31.20000000 -38.00000000 2.00000000
-27.30000000 -38.00000000 2.00000000
-23.40000000 -38.00000000 2.00000000
-19.50000000 -38.00000000 2.00000000
-15.60000000 -38.00000000 2.00000000
-11.70000000 -38.00000000 2.00000000
-7.80000000 -38.00000000 2.00000000
-3.90000000 -38.00000000 2.00000000
0.00000000 -38.00000000 2.00000000
-97.50000000 -33.25000000 2.00000000
-93.60000000 -33.25000000 2.00000000
-89.70000000 -33.25000000 2.00000000
-85.80000000 -33.25000000 2.00000000
-81.90000000 -33.25000000 2.00000000
-78.00000000 -33.25000000 2.00000000
-74.10000000 -33.25000000 2.00000000
-70.20000000 -33.25000000 2.00000000
-66.30000000 -33.25000000 2.00000000
-62.40000000 -33.25000000 2.00000000
-58.50000000 -33.25000000 2.00000000
-54.60000000 -33.25000000 2.00000000
-50.70000000 -33.25000000 2.00000000
-46.80000000 -33.25000000 2.00000000
-42.90000000 -33.25000000 2.00000000
-39.00000000 -33.25000000 2.00000000
-35.10000000 -33.25000000 2.00000000
-31.20000000 -33.25000000 2.00000000
-27.30000000 -33.25000000 2.00000000
-23.40000000 -33.25000000 2.00000000
-19.50000000 -33.25000000 2.00000000
-15.60000000 -33.25000000 2.00000000
-11.70000000 -33.25000000 2.00000000
-7.80000000 -33.25000000 2.00000000
-3.90000000 -33.25000000 2.00000000
0.00000000 -33.25000000 2.00000000
-97.50000000 -28.50000000 2.00000000
-93.60000000 -28.50000000 2.00000000
-89.70000000 -28.50000000 2.00000000
-85.80000000 -28.50000000 2.00000000
-81.90000000 -28.50000000 2.00000000
-78.00000000 -28.50000000 2.00000000
-74.10000000 -28.50000000 2.00000000
-70.20000000 -28.50000000 2.00000000
-66.30000000 -28.50000000 2.00000000
-62.40000000 -28.50000000 2.00000000
-58.50000000 -28.50000000 2.00000000
-54.60000000 -28.50000000 2.00000000
-50.70000000 -28.50000000 2.00000000
-46.80000000 -28.50000000 2.00000000
-42.90000000 -28.50000000 2.00000000
-39.00000000 -28.50000000 2.00000000
-35.10000000 -28.50000000 2.00000000
-31.20000000 -28.50000000 2.00000000
-27.30000000 -28.50000000 2.00000000
-23.40000000 -28.50000000 2.00000000
-19.50000000 -28.50000000 2.00000000
-15.60000000 -28.50000000 2.00000000
-11.70000000 -28.50000000 2.00000000
-7.80000000 -28.50000000 2.00000000
-3.90000000 -28.50000000 2.00000000
0.00000000 -28.50000000 2.00000000
-97.50000000 -23.75000000 2.00000000
-93.60000000 -23.75000000 2.00000000
-89.70000000 -23.75000000 2.00000000
-85.80000000 -23.75000000 2.00000000
-81.90000000 -23.75000000 2.00000000
-78.00000000 -23.75000000 2.00000000
-74.10000000 -23.75000000 2.00000000
-70.20000000 -23.75000000 2.00000000
-66.30000000 -23.75000000 2.00000000
-62.40000000 -23.75000000 2.00000000
-58.50000000 -23.75000000 2.00000000
-54.60000000 -23.75000000 2.00000000
-50.70000000 -23.75000000 2.00000000
-46.80000000 -23.75000000 2.00000000
-42.90000000 -23.75000000 2.00000000
-39.00000000 -23.75000000 2.00000000
-35.10000000 -23.75000000 2.00000000
-31.20000000 -23.75000000 2.00000000
-27.30000000 -23.75000000 2.00000000
-23.40000000 -23.75000000 2.00000000
-19.50000000 -23.75000000 2.00000000
-15.60000000 -23.75000000 2.00000000
-11.70000000 -23.75000000 2.00000000
-7.80000000 -23.75000000 2.00000000
-3.90000000 -23.75000000 2.00000000
0.00000000 -23.75000000 2.00000000
-97.50000000 -19.00000000 2.00000000
-93.60000000 -19.00000000 2.00000000
-89.70000000 -19.00000000 2.00000000
-85.80000000 -19.00000000 2.00000000
-81.90000000 -19.00000000 2.00000000
-78.00000000 -19.00000000 2.00000000
-74.10000000 -19.00000000 2.00000000
-70.20000000 -19.00000000 2.00000000
-66.30000000 -19.00000000 2.00000000
-62.40000000 -19.00000000 2.00000000
-58.50000000 -19.00000000 2.00000000
-54.60000000 -19.00000000 2.00000000
-50.70000000 -19.00000000 2.00000000
-46.80000000 -19.00000000 2.00000000
-42.90000000 -19.00000000 2.00000000
-39.00000000 -19.00000000 2.00000000
-35.10000000 -19.00000000 2.00000000
-31.20000000 -19.00000000 2.00000000
-27.30000000 -19.00000000 2.00000000
-23.40000000 -19.00000000 2.00000000
-19.50000000 -19.00000000 2.00000000
-15.60000000 -19.00000000 2.00000000
-11.70000000 -19.00000000 2.00000000
-7.80000000 -19.00000000 2.00000000
-3.90000000 -19.00000000 2.00000000
0.00000000 -19.00000000 2.00000000
-97.50000000 -14.25000000 2.00000000
-93.60000000 -14.25000000 2.00000000
-89.70000000 -14.25000000 2.00000000
-85.80000000 -14.25000000 2.00000000
-81.90000000 -14.25000000 2.00000000
-78.00000000 -14.25000000 2.00000000
-74.10000000 -14.25000000 2.00000000
-70.20000000 -14.25000000 2.00000000
-66.30000000 -14.25000000 2.00000000
-62.40000000 -14.25000000 2.00000000
-58.50000000 -14.25000000 2.00000000
-54.60000000 -14.25000000 2.00000000
-50.70000000 -14.25000000 2.00000000
-46.80000000 -14.25000000 2.00000000
-42.90000000 -14.25000000 2.00000000
-39.00000000 -14.25000000 2.00000000
-35.10000000 -14.25000000 2.00000000
-31.20000000 -14.25000000 2.00000000
-27.30000000 -14.25000000 2.00000000
-23.40000000 -14.25000000 2.00000000
-19.50000000 -14.25000000 2.00000000
-15.60000000 -14.25000000 2.00000000
-11.70000000 -14.25000000 2.00000000
-7.80000000 -14.25000000 2.00000000
-3.90000000 -14.25000000 2.00000000
0.00000000 -14.25000000 2.00000000
-97.50000000 -9.50000000 2.00000000
-93.60000000 -9.50000000 2.00000000
-89.70000000 -9.50000000 2.00000000
-85.80000000 -9.50000000 2.00000000
-81.90000000 -9.50000000 2.00000000
-78.00000000 -9.50000000 2.00000000
-74.10000000 -9.50000000 2.00000000
-70.20000000 -9.50000000 2.00000000
-66.30000000 -9.50000000 2.00000000
-62.40000000 -9.50000000 2.00000000
-58.50000000 -9.50000000 2.00000000
-54.60000000 -9.50000000 2.00000000
-50.70000000 -9.50000000 2.00000000
-46.80000000 -9.50000000 2.00000000
-42.90000000 -9.50000000 2.00000000
-39.00000000 -9.50000000 2.00000000
-35.10000000 -9.50000000 2.00000000
-31.20000000 -9.50000000 2.00000000
-27.30000000 -9.50000000 2.00000000
-23.40000000 -9.50000000 2.00000000
-19.50000000 -9.50000000 2.00000000
-15.60000000 -9.50000000 2.00000000
-11.70000000 -9.50000000 2.00000000
-7.80000000 -9.50000000 2.00000000
-3.90000000 -9.50000000 2.00000000
0.00000000 -9.50000000 2.00000000
-97.50000000 -4.75000000 2.00000000
-93.60000000 -4.75000000 2.00000000
-89.70000000 -4.75000000 2.00000000
-85.80000000 -4.75000000 2.00000000
-81.90000000 -4.75000000 2.00000000
-78.00000000 -4.75000000 2.00000000
-74.10000000 -4.75000000 2.00000000
-70.20000000 -4.75000000 2.00000000
-66.30000000 -4.75000000 2.00000000
-62.40000000 -4.75000000 2.00000000
-58.50000000 -4.75000000 2.00000000
-54.60000000 -4.75000000 2.00000000
-50.70000000 -4.75000000 2.00000000
-46.80000000 -4.75000000 2.00000000
-42.90000000 -4.75000000 2.00000000
-39.00000000 -4.75000000 2.00000000
-35.10000000 -4.75000000 2.00000000
-31.20000000 -4.75000000 2.00000000
-27.30000000 -4.75000000 2.00000000
-23.40000000 -4.75000000 2.00000000
-19.50000000 -4.75000000 2.00000000
-15.60000000 -4.75000000 2.00000000
-11.70000000 -4.75000000 2.00000000
-7.80000000 -4.75000000 2.00000000
-3.90000000 -4.75000000 2.00000000
0.00000000 -4.75000000 2.00000000
-97.50000000 0.00000000 2.00000000
-93.60000000 0.00000000 2.00000000
-89.70000000 0.00000000 2.00000000
-85.80000000 0.00000000 2.00000000
-81.90000000 0.00000000 2.00000000
-78.00000000 0.00000000 2.00000000
-74.10000000 0.00000000 2.00000000
-70.20000000 0.00000000 2.00000000
-66.30000000 0.00000000 2.00000000
-62.40000000 0.00000000 2.00000000
-58.50000000 0.00000000 2.00000000
-54.60000000 0.00000000 2.00000000
-50.70000000 0.00000000 2.00000000
-46.80000000 0.00000000 2.00000000
-42.90000000 0.00000000 2.00000000
-39.00000000 0.00000000 2.00000000
-35.10000000 0.00000000 2.00000000
-31.20000000 0.00000000 2.00000000
-27.30000000 0.00000000 2.00000000
-23.40000000 0.00000000 2.00000000
-19.50000000 0.00000000 2.00000000
-15.60000000 0.00000000 2.00000000
-11.70000000 0.00000000 2.00000000
-7.80000000 0.00000000 2.00000000
-3.90000000 0.00000000 2.00000000
0.00000000 0.00000000 2.00000000
-97.50000000 4.75000000 2.00000000
-93.60000000 4.75000000 2.00000000
-89.70000000 4.75000000 2.00000000
-85.80000000 4.75000000 2.00000000
-81.90000000 4.75000000 2.00000000
-78.00000000 4.75000000 2.00000000
-74.10000000 4.75000000 2.00000000
-70.20000000 4.75000000 2.00000000
-66.30000000 4.75000000 2.00000000
-62.40000000 4.75000000 2.00000000
-58.50000000 4.75000000 2.00000000
-54.60000000 4.75000000 2.00000000
-50.70000000 4.75000000 2.00000000
-46.80000000 4.75000000 2.00000000
-42.90000000 4.75000000 2.00000000
-39.00000000 4.75000000 2.00000000
-35.10000000 4.75000000 2.00000000
-31.20000000 4.75000000 2.00000000
-27.30000000 4.75000000 2.00000000
-23.40000000 4.75000000 2.00000000
-19.50000000 4.75000000 2.00000000
-15.60000000 4.75000000 2.00000000
-11.70000000 4.75000000 2.00000000
-7.80000000 4.75000000 2.00000000
-3.90000000 4.75000000 2.00000000
0.00000000 4.75000000 2.00000000
-97.50000000 9.50000000 2.00000000
-93.60000000 9.50000000 2.00000000
-89.70000000 9.50000000 2.00000000
-85.80000000 9.50000000 2.00000000
-81.90000000 9.50000000 2.00000000
-78.00000000 9.50000000 2.00000000
-74.10000000 9.50000000 2.00000000
-70.20000000 9.50000000 2.00000000
-66.30000000 9.50000000 2.00000000
-62.40000000 9.50000000 2.00000000
-58.50000000 9.50000000 2.00000000
-54.60000000 9.50000000 2.00000000
-50.70000000 9.50000000 2.00000000
-46.80000000 9.50000000 2.00000000
-42.90000000 9.50000000 2.00000000
-39.00000000 9.50000000 2.00000000
-35.10000000 9.50000000 2.00000000
-31.20000000 9.50000000 2.00000000
-27.30000000 9.50000000 2.00000000
-23.40000000 9.50000000 2.00000000
-19.50000000 9.50000000 2.00000000
-15.60000000 9.50000000 2.00000000
-11.70000000 9.50000000 2.00000000
-7.80000000 9.50000000 2.00000000
-3.90000000 9.50000000 2.00000000
0.00000000 9.50000000 2.00000000
-97.50000000 14.25000000 2.00000000
-93.60000000 14.25000000 2.00000000
-89.70000000 14.25000000 2.00000000
-85.80000000 14.25000000 2.00000000
-81.90000000 14.25000000 2.00000000
-78.00000000 14.25000000 2.00000000
-74.10000000 14.25000000 2.00000000
-70.20000000 14.25000000 2.00000000
-66.30000000 14.25000000 2.00000000
-62.40000000 14.25000000 2.00000000
-58.50000000 14.25000000 2.00000000
-54.60000000 14.25000000 2.00000000
-50.70000000 14.25000000 2.00000000
-46.80000000 14.25000000 2.00000000
-42.90000000 14.25000000 2.00000000
-39.00000000 14.25000000 2.00000000
-35.10000000 14.25000000 2.00000000
-31.20000000 14.25000000 2.00000000
-27.30000000 14.25000000 2.00000000
-23.40000000 14.25000000 2.00000000
-19.50000000 14.25000000 2.00000000
-15.60000000 14.25000000 2.00000000
-11.70000000 14.25000000 2.00000000
-7.80000000 14.25000000 2.00000000
-3.90000000 14.25000000 2.00000000
0.00000000 14.25000000 2.00000000
-97.50000000 19.00000000 2.00000000
-93.60000000 19.00000000 2.00000000
-89.70000000 19.00000000 2.00000000
-85.80000000 19.00000000 2.00000000
-81.90000000 19.00000000 2.00000000
-78.00000000 19.00000000 2.00000000
-74.10000000 19.00000000 2.00000000
-70.20000000 19.00000000 2.00000000
-66.30000000 19.00000000 2.00000000
-62.40000000 19.00000000 2.00000000
-58.50000000 19.00000000 2.00000000
-54.60000000 19.00000000 2.00000000
-50.70000000 19.00000000 2.00000000
-46.80000000 19.00000000 2.00000000
-42.90000000 19.00000000 2.00000000
-39.00000000 19.00000000 2.00000000
-35.10000000 19.00000000 2.00000000
-31.20000000 19.00000000 2.00000000
-27.30000000 19.00000000 2.00000000
-23.40000000 19.00000000 2.00000000
-19.50000000 19.00000000 2.00000000
-15.60000000 19.00000000 2.00000000
-11.70000000 19.00000000 2.00000000
-7.80000000 19.00000000 2.00000000
-3.90000000 19.00000000 2.00000000
0.00000000 19.00000000 2.00000000
-97.50000000 23.75000000 2.00000000
-93.60000000 23.75000000 2.00000000
-89.70000000 23.75000000 2.00000000
-85.80000000 23.75000000 2.00000000
-81.90000000 23.75000000 2.00000000
-78.00000000 23.75000000 2.00000000
-74.10000000 23.75000000 2.00000000
-70.20000000 23.75000000 2.00000000
-66.30000000 23.75000000 2.00000000
-62.40000000 23.75000000 2.00000000
-58.50000000 23.75000000 2.00000000
-54.60000000 23.75000000 2.00000000
-50.70000000 23.75000000 2.00000000
-46.80000000 23.75000000 2.00000000
-42.90000000 23.75000000 2.00000000
-39.00000000 23.75000000 2.00000000
-35.10000000 23.75000000 2.00000000
-31.20000000 23.75000000 2.00000000
-27.30000000 23.75000000 2.00000000
-23.40000000 23.75000000 2.00000000
-19.50000000 23.75000000 2.00000000
-15.60000000 23.75000000 2.00000000
-11.70000000 23.75000000 2.00000000
-7.80000000 23.75000000 2.00000000
-3.90000000 23.75000000 2.00000000
0.00000000 23.75000000 2.00000000
-97.50000000 28.50000000 2.00000000
-93.60000000 28.50000000 2.00000000
-89.70000000 28.50000000 2.00000000
-85.80000000 28.50000000 2.00000000
-81.90000000 28.50000000 2.00000000
-78.00000000 28.50000000 2.00000000
-74.10000000 28.50000000 2.00000000
-70.20000000 28.50000000 2.00000000
-66.30000000 28.50000000 2.00000000
-62.40000000 28.50000000 2.00000000
-58.50000000 28.50000000 2.00000000
-54.60000000 28.50000000 2.00000000
-50.70000000 28.50000000 2.00000000
-46.80000000 28.50000000 2.00000000
-42.90000000 28.50000000 2.00000000
-39.00000000 28.50000000 2.00000000
-35.10000000 28.50000000 2.00000000
-31.20000000 28.50000000 2.00000000
-27.30000000 28.50000000 2.00000000
-23.40000000 28.50000000 2.00000000
-19.50000000 28.50000000 2.00000000
-15.60000000 28.50000000 2.00000000
-11.70000000 28.50000000 2.00000000
-7.80000000 28.50000000 2.00000000
-3.90000000 28.50000000 2.00000000
0.00000000 28.50000000 2.00000000
-97.50000000 33.25000000 2.00000000
-93.60000000 33.25000000 2.00000000
-89.70000000 33.25000000 2.00000000
-85.80000000 33.25000000 2.00000000
-81.90000000 33.25000000 2.00000000
-78.00000000 33.25000000 2.00000000
-74.10000000 33.25000000 2.00000000
-70.20000000 33.25000000 2.00000000
-66.30000000 33.25000000 2.00000000
-62.40000000 33.25000000 2.00000000
-58.50000000 33.25000000 2.00000000
-54.60000000 33.25000000 2.00000000
-50.70000000 33.25000000 2.00000000
-46.80000000 33.25000000 2.00000000
-42.90000000 33.25000000 2.00000000
-39.00000000 33.25000000 2.00000000
-35.10000000 33.25000000 2.00000000
-31.20000000 33.25000000 2.00000000
-27.30000000 33.25000000 2.00000000
-23.40000000 33.25000000 2.00000000
-19.50000000 33.25000000 2.00000000
-15.60000000 33.25000000 2.00000000
-11.70000000 33.25000000 2.00000000
-7.80000000 33.25000000 2.00000000
-3.90000000 33.25000000 2.00000000
0.00000000 33.25000000 2.00000000
-97.50000000 38.00000000 2.00000000
-93.60000000 38.00000000 2.00000000
-89.70000000 38.00000000 2.00000000
-85.80000000 38.00000000 2.00000000
-81.90000000 38.00000000 2.00000000
-78.00000000 38.00000000 2.00000000
-74.10000000 38.00000000 2.00000000
-70.20000000 38.00000000 2.00000000
-66.30000000 38.00000000 2.00000000
-62.40000000 38.00000000 2.00000000
-58.50000000 38.00000000 2.00000000
-54.60000000 38.00000000 2.00000000
-50.70000000 38.00000000 2.00000000
-46.80000000 38.00000000 2.00000000
-42.90000000 38.00000000 2.00000000
-39.00000000 38.00000000 2.00000000
-35.10000000 38.00000000 2.00000000
-31.20000000 38.00000000 2.00000000
-27.30000000 38.00000000 2.00000000
-23.40000000 38.00000000 2.00000000
-19.50000000 38.00000000 2.00000000
-15.60000000 38.00000000 2.00000000
-11.70000000 38.00000000 2.00000000
-7.80000000 38.00000000 2.00000000
-3.90000000 38.00000000 2.00000000
0.00000000 38.00000000 2.00000000
-97.50000000 42.75000000 2.00000000
-93.60000000 42.75000000 2.00000000
-89.70000000 42.75000000 2.00000000
-85.80000000 42.75000000 2.00000000
-81.90000000 42.75000000 2.00000000
-78.00000000 42.75000000 2.00000000
-74.10000000 42.75000000 2.00000000
-70.20000000 42.75000000 2.00000000
-66.30000000 42.75000000 2.00000000
-62.40000000 42.75000000 2.00000000
-58.50000000 42.75000000 2.00000000
-54.60000000 42.75000000 2.00000000
-50.70000000 42.75000000 2.00000000
-46.80000000 42.75000000 2.00000000
-42.90000000 42.75000000 2.00000000
-39.00000000 42.75000000 2.00000000
-35.10000000 42.75000000 2.00000000
-31.20000000 42.75000000 2.00000000
-27.30000000 42.75000000 2.00000000
-23.40000000 42.75000000 2.00000000
-19.50000000 42.75000000 2.00000000
-15.60000000 42.75000000 2.00000000
-11.70000000 42.75000000 2.00000000
-7.80000000 42.75000000 2.00000000
-3.90000000 42.75000000 2.00000000
0.00000000 42.75000000 2.00000000
-97.50000000 47.50000000 2.00000000
-93.60000000 47.50000000 2.00000000
-89.70000000 47.50000000 2.00000000
-85.80000000 47.50000000 2.00000000
-81.90000000 47.50000000 2.00000000
-78.00000000 47.50000000 2.00000000
-74.10000000 47.50000000 2.00000000
-70.20000000 47.50000000 2.00000000
-66.30000000 47.50000000 2.00000000
-62.40000000 47.50000000 2.00000000
-58.50000000 47.50000000 2.00000000
-54.60000000 47.50000000 2.00000000
-50.70000000 47.50000000 2.00000000
-46.80000000 47.50000000 2.00000000
-42.90000000 47.50000000 2.00000000
-39.00000000 47.50000000 2.00000000
-35.10000000 47.50000000 2.00000000
-31.20000000 47.50000000 2.00000000
-27.30000000 47.50000000 2.00000000
-23.40000000 47.50000000 2.00000000
-19.50000000 47.50000000 2.00000000
-15.60000000 47.50000000 2.00000000
-11.70000000 47.50000000 2.00000000
-7.80000000 47.50000000 2.00000000
-3.90000000 47.50000000 2.00000000
0.00000000 47.50000000 2.00000000
-95.00000000 -45.00000000 4.00000000
-91.20000000 -45.00000000 4.00000000
-87.40000000 -45.00000000 4.00000000
-83.60000000 -45.00000000 4.00000000
-79.80000000 -45.00000000 4.00000000
-76.00000000 -45.00000000 4.00000000
-72.20000000 -45.00000000 4.00000000
-68.40000000 -45.00000000 4.00000000
-64.60000000 -45.00000000 4.00000000
-60.80000000 -45.00000000 4.00000000
-57.00000000 -45.00000000 4.00000000
-53.20000000 -45.00000000 4.00000000
-49.40000000 -45.00000000 4.00000000
-45.60000000 -45.00000000 4.00000000
-41.80000000 -45.00000000 4.00000000
-38.00000000 -45.00000000 4.00000000
-34.20000000 -45.00000000 4.00000000
-30.40000000 -45.00000000 4.00000000
-26.60000000 -45.00000000 4.00000000
-22.80000000 -45.00000000 4.00000000
-19.00000000 -45.00000000 4.00000000
-15.20000000 -45.00000000 4.00000000
-11.40000000 -45.00000000 4.00000000
-7.60000000 -45.00000000 4.00000000
-3.80000000 -45.00000000 4.00000000
0.00000000 -45.00000000 4.00000000
-95.00000000 -40.50000000 4.00000000
-91.20000000 -40.50000000 4.00000000
-87.40000000 -40.50000000 4.00000000
-83.60000000 -40.50000000 4.00000000
-79.80000000 -40.50000000 4.00000000
-76.00000000 -40.50000000 4.00000000
-72.20000000 -40.50000000 4.00000000
-68.40000000 -40.50000000 4.00000000
-64.60000000 -40.50000000 4.00000000
-60.80000000 -40.50000000 4.00000000
-57.00000000 -40.50000000 4.00000000
-53.20000000 -40.50000000 4.00000000
-49.40000000 -40.50000000 4.00000000
-45.60000000 -40.50000000 4.00000000
-41.80000000 -40.50000000 4.00000000
-38.00000000 -40.50000000 4.00000000
-34.20000000 -40.50000000 4.00000000
-30.40000000 -40.50000000 4.00000000
-26.60000000 -40.50000000 4.00000000
-22.80000000 -40.50000000 4.00000000
-19.00000000 -40.50000000 4.00000000
-15.20000000 -40.50000000 4.00000000
-11.40000000 -40.50000000 4.00000000
-7.60000000 -40.50000000 4.00000000
-3.80000000 -40.50000000 4.00000000
0.00000000 -40.50000000 4.00000000
-95.00000000 -36.00000000 4.00000000
-91.20000000 -36.00000000 4.00000000
-87.40000000 -36.00000000 4.00000000
-83.60000000 -36.00000000 4.00000000
-79.80000000 -36.00000000 4.00000000
-76.00000000 -36.00000000 4.00000000
-72.20000000 -36.00000000 4.00000000
-68.40000000 -36.00000000 4.00000000
-64.60000000 -36.00000000 4.00000000
-60.80000000 -36.00000000 4.00000000
-57.00000000 -36.00000000 4.00000000
-53.20000000 -36.00000000 4.00000000
-49.40000000 -36.00000000 4.00000000
-45.60000000 -36.00000000 4.00000000
-41.80000000 -36.00000000 4.00000000
-38.00000000 -36.00000000 4.00000000
-34.20000000 -36.00000000 4.00000000
-30.40000000 -36.00000000 4.00000000
-26.60000000 -36.00000000 4.00000000
-22.80000000 -36.00000000 4.00000000
-19.00000000 -36.00000000 4.00000000
-15.20000000 -36.00000000 4.00000000
-11.40000000 -36.00000000 4.00000000
-7.60000000 -36.00000000 4.00000000
-3.80000000 -36.00000000 4.00000000
0.00000000 -36.00000000 4.00000000
-95.00000000 -31.50000000 4.00000000
-91.20000000 -31.50000000 4.00000000
-87.40000000 -31.50000000 4.00000000
-83.60000000 -31.50000000 4.00000000
-79.80000000 -31.50000000 4.00000000
-76.00000000 -31.50000000 4.00000000
-72.20000000 -31.50000000 4.00000000
-68.40000000 -31.50000000 4.00000000
-64.60000000 -31.50000000 4.00000000
-60.80000000 -31.50000000 4.00000000
-57.00000000 -31.50000000 4.00000000
-53.20000000 -31.50000000 4.00000000
-49.40000000 -31.50000000 4.00000000
-45.60000000 -31.50000000 4.00000000
-41.80000000 -31.50000000 4.00000000
-38.00000000 -31.50000000 4.00000000
-34.20000000 -31.50000000 4.00000000
-30.40000000 -31.50000000 4.00000000
-26.60000000 -31.50000000 4.00000000
-22.80000000 -31.50000000 4.00000000
-19.00000000 -31.50000000 4.00000000
-15.20000000 -31.50000000 4.00000000
-11.40000000 -31.50000000 4.00000000
-7.60000000 -31.50000000 4.00000000
-3.80000000 -31.50000000 4.00000000
0.00000000 -31.50000000 4.00000000
-95.00000000 -27.00000000 4.00000000
-91.20000000 -27.00000000 4.00000000
-87.40000000 -27.00000000 4.00000000
-83.60000000 -27.00000000 4.00000000
-79.80000000 -27.00000000 4.00000000
-76.00000000 -27.00000000 4.00000000
-72.20000000 -27.00000000 4.00000000
-68.40000000 -27.00000000 4.00000000
-64.60000000 -27.00000000 4.00000000
-60.80000000 -27.00000000 4.00000000
-57.00000000 -27.00000000 4.00000000
-53.20000000 -27.00000000 4.00000000
-49.40000000 -27.00000000 4.00000000
-45.60000000 -27.00000000 4.00000000
-41.80000000 -27.00000000 4.00000000
-38.00000000 -27.00000000 4.00000000
-34.20000000 -27.00000000 4.00000000
-30.40000000 -27.00000000 4.00000000
-26.60000000 -27.00000000 4.00000000
-22.80000000 -27.00000000 4.00000000
-19.00000000 -27.00000000 4.00000000
-15.20000000 -27.00000000 4.00000000
-11.40000000 -27.00000000 4.00000000
-7.60000000 -27.00000000 4.00000000
-3.80000000 -27.00000000 4.00000000
0.00000000 -27.00000000 4.00000000
-95.00000000 -22.50000000 4.00000000
-91.20000000 -22.50000000 4.00000000
-87.40000000 -22.50000000 4.00000000
-83.60000000 -22.50000000 4.00000000
-79.80000000 -22.50000000 4.00000000
-76.00000000 -22.50000000 4.00000000
-72.20000000 -22.50000000 4.00000000
-68.40000000 -22.50000000 4.00000000
-64.60000000 -22.50000000 4.00000000
-60.80000000 -22.50000000 4.00000000
-57.00000000 -22.50000000 4.00000000
-53.20000000 -22.50000000 4.00000000
-49.40000000 -22.50000000 4.00000000
-45.60000000 -22.50000000 4.00000000
-41.80000000 -22.50000000 4.00000000
-38.00000000 -22.50000000 4.00000000
-34.20000000 -22.50000000 4.00000000
-30.40000000 -22.50000000 4.00000000
-26.60000000 -22.50000000 4.00000000
-22.80000000 -22.50000000 4.00000000
-19.00000000 -22.50000000 4.00000000
-15.20000000 -22.50000000 4.00000000
-11.40000000 -22.50000000 4.00000000
-7.60000000 -22.50000000 4.00000000
-3.80000000 -22.50000000 4.00000000
0.00000000 -22.50000000 4.00000000
-95.00000000 -18.00000000 4.00000000
-91.20000000 -18.00000000 4.00000000
-87.40000000 -18.00000000 4.00000000
-83.60000000 -18.00000000 4.00000000
-79.80000000 -18.00000000 4.00000000
-76.00000000 -18.00000000 4.00000000
-72.20000000 -18.00000000 4.00000000
-68.40000000 -18.00000000 4.00000000
-64.60000000 -18.00000000 4.00000000
-60.80000000 -18.00000000 4.00000000
-57.00000000 -18.00000000 4.00000000
-53.20000000 -18.00000000 4.00000000
-49.40000000 -18.00000000 4.00000000
-45.60000000 -18.00000000 4.00000000
-41.80000000 -18.00000000 4.00000000
-38.00000000 -18.00000000 4.00000000
-34.20000000 -18.00000000 4.00000000
-30.40000000 -18.00000000 4.00000000
-26.60000000 -18.00000000 4.00000000
-22.80000000 -18.00000000 4.00000000
-19.00000000 -18.00000000 4.00000000
-15.20000000 -18.00000000 4.00000000
-11.40000000 -18.00000000 4.00000000
-7.60000000 -18.00000000 4.00000000
-3.80000000 -18.00000000 4.00000000
0.00000000 -18.00000000 4.00000000
-95.00000000 -13.50000000 4.00000000
-91.20000000 -13.50000000 4.00000000
-87.40000000 -13.50000000 4.00000000
-83.60000000 -13.50000000 4.00000000
-79.80000000 -13.50000000 4.00000000
-76.00000000 -13.50000000 4.00000000
-72.20000000 -13.50000000 4.00000000
-68.40000000 -13.50000000 4.00000000
-64.60000000 -13.50000000 4.00000000
-60.80000000 -13.50000000 4.00000000
-57.00000000 -13.50000000 4.00000000
-53.20000000 -13.50000000 4.00000000
-49.40000000 -13.50000000 4.00000000
-45.60000000 -13.50000000 4.00000000
-41.80000000 -13.50000000 4.00000000
-38.00000000 -13.50000000 4.00000000
-34.20000000 -13.50000000 4.00000000
-30.40000000 -13.50000000 4.00000000
-26.60000000 -13.50000000 4.00000000
-22.80000000 -13.50000000 4.00000000
-19.00000000 -13.50000000 4.00000000
-15.20000000 -13.50000000 4.00000000
-11.40000000 -13.50000000 4.00000000
-7.60000000 -13.50000000 4.00000000
-3.80000000 -13.50000000 4.00000000
0.00000000 -13.50000000 4.00000000
-95.00000000 -9.00000000 4.00000000
-91.20000000 -9.00000000 4.00000000
-87.40000000 -9.00000000 4.00000000
-83.60000000 -9.00000000 4.00000000
-79.80000000 -9.00000000 4.00000000
-76.00000000 -9.00000000 4.00000000
-72.20000000 -9.00000000 4.00000000
-68.40000000 -9.00000000 4.00000000
-64.60000000 -9.00000000 4.00000000
-60.80000000 -9.00000000 4.00000000
-57.00000000 -9.00000000 4.00000000
-53.20000000 -9.00000000 4.00000000
-49.40000000 -9.00000000 4.00000000
-45.60000000 -9.00000000 4.00000000
-41.80000000 -9.00000000 4.00000000
-38.00000000 -9.00000000 4.00000000
-34.20000000 -9.00000000 4.00000000
-30.40000000 -9.00000000 4.00000000
-26.60000000 -9.00000000 4.00000000
-22.80000000 -9.00000000 4.00000000
-19.00000000 -9.00000000 4.00000000
-15.20000000 -9.00000000 4.00000000
-11.40000000 -9.00000000 4.00000000
-7.60000000 -9.00000000 4.00000000
-3.80000000 -9.00000000 4.00000000
0.00000000 -9.00000000 4.00000000
-95.00000000 -4.50000000 4.00000000
-91.20000000 -4.50000000 4.00000000
-87.40000000 -4.50000000 4.00000000
-83.60000000 -4.50000000 4.00000000
-79.80000000 -4.50000000 4.00000000
-76.00000000 -4.50000000 4.00000000
-72.20000000 -4.50000000 4.00000000
-68.40000000 -4.50000000 4.00000000
-64.60000000 -4.50000000 4.00000000
-60.80000000 -4.50000000 4.00000000
-57.00000000 -4.50000000 4.00000000
-53.20000000 -4.50000000 4.00000000
-49.40000000 -4.50000000 4.00000000
-45.60000000 -4.50000000 4.00000000
-41.80000000 -4.50000000 4.00000000
-38.00000000 -4.50000000 4.00000000
-34.20000000 -4.50000000 4.00000000
-30.40000000 -4.50000000 4.00000000
-26.60000000 -4.50000000 4.00000000
-22.80000000 -4.50000000 4.00000000
-19.00000000 -4.50000000 4.00000000
-15.20000000 -4.50000000 4.00000000
-11.40000000 -4.50000000 4.00000000
-7.60000000 -4.50000000 4.00000000
-3.80000000 -4.50000000 4.00000000
0.00000000 -4.50000000 4.00000000
-95.00000000 0.00000000 4.00000000
-91.20000000 0.00000000 4.00000000
-87.40000000 0.00000000 4.00000000
-83.60000000 0.00000000 4.00000000
-79.80000000 0.00000000 4.00000000
-76.00000000 0.00000000 4.00000000
-72.20000000 0.00000000 4.00000000
-68.40000000 0.00000000 4.00000000
-64.60000000 0.00000000 4.00000000
-60.80000000 0.00000000 4.00000000
-57.00000000 0.00000000 4.00000000
-53.20000000 0.00000000 4.00000000
-49.40000000 0.00000000 4.00000000
-45.60000000 0.00000000 4.00000000
-41.80000000 0.00000000 4.00000000
-38.00000000 0.00000000 4.00000000
-34.20000000 0.00000000 4.00000000
-30.40000000 0.00000000 4.00000000
-26.60000000 0.00000000 4.00000000
-22.80000000 0.00000000 4.00000000
-19.00000000 0.00000000 4.00000000
-15.20000000 0.00000000 4.00000000
-11.40000000 0.00000000 4.00000000
-7.60000000 0.00000000 4.00000000
-3.80000000 0.00000000 4.00000000
0.00000000 0.00000000 4.00000000
-95.00000000 4.50000000 4.00000000
-91.20000000 4.50000000 4.00000000
-87.40000000 4.50000000 4.00000000
-83.60000000 4.50000000 4.00000000
-79.80000000 4.50000000 4.00000000
-76.00000000 4.50000000 4.00000000
-72.20000000 4.50000000 4.00000000
-68.40000000 4.50000000 4.00000000
-64.60000000 4.50000000 4.00000000
-60.80000000 4.50000000 4.00000000
-57.00000000 4.50000000 4.00000000
-53.20000000 4.50000000 4.00000000
-49.40000000 4.50000000 4.00000000
-45.60000000 4.50000000 4.00000000
-41.80000000 4.50000000 4.00000000
-38.00000000 4.50000000 4.00000000
-34.20000000 4.50000000 4.00000000
-30.40000000 4.50000000 4.00000000
-26.60000000 4.50000000 4.00000000
-22.80000000 4.50000000 4.00000000
-19.00000000 4.50000000 4.00000000
-15.20000000 4.50000000 4.00000000
-11.40000000 4.50000000 4.00000000
-7.60000000 4.50000000 4.00000000
-3.80000000 4.50000000 4.00000000
0.00000000 4.50000000 4.00000000
-95.00000000 9.00000000 4.00000000
-91.20000000 9.00000000 4.00000000
-87.40000000 9.00000000 4.00000000
-83.60000000 9.00000000 4.00000000
-79.80000000 9.00000000 4.00000000
-76.00000000 9.00000000 4.00000000
-72.20000000 9.00000000 4.00000000
-68.40000000 9.00000000 4.00000000
-64.60000000 9.00000000 4.00000000
-60.80000000 9.00000000 4.00000000
-57.00000000 9.00000000 4.00000000
-53.20000000 9.00000000 4.00000000
-49.40000000 9.00000000 4.00000000
-45.60000000 9.00000000 4.00000000
-41.80000000 9.00000000 4.00000000
-38.00000000 9.00000000 4.00000000
-34.20000000 9.00000000 4.00000000
-30.40000000 9.00000000 4.00000000
-26.60000000 9.00000000 4.00000000
-22.80000000 9.00000000 4.00000000
-19.00000000 9.00000000 4.00000000
-15.20000000 9.00000000 4.00000000
-11.40000000 9.00000000 4.00000000
-7.60000000 9.00000000 4.00000000
-3.80000000 9.00000000 4.00000000
0.00000000 9.00000000 4.00000000
-95.00000000 13.50000000 4.00000000
-91.20000000 13.50000000 4.00000000
-87.40000000 13.50000000 4.00000000
-83.60000000 13.50000000 4.00000000
-79.80000000 13.50000000 4.00000000
-76.00000000 13.50000000 4.00000000
-72.20000000 13.50000000 4.00000000
-68.40000000 13.50000000 4.00000000
-64.60000000 13.50000000 4.00000000
-60.80000000 13.50000000 4.00000000
-57.00000000 13.50000000 4.00000000
-53.20000000 13.50000000 4.00000000
-49.40000000 13.50000000 4.00000000
-45.60000000 13.50000000 4.00000000
-41.80000000 13.50000000 4.00000000
-38.00000000 13.50000000 4.00000000
-34.20000000 13.50000000 4.00000000
-30.40000000 13.50000000 4.00000000
-26.60000000 13.50000000 4.00000000
-22.80000000 13.50000000 4.00000000
-19.00000000 13.50000000 4.00000000
-15.20000000 13.50000000 4.00000000
-11.40000000 13.50000000 4.00000000
-7.60000000 13.50000000 4.00000000
-3.80000000 13.50000000 4.00000000
0.00000000 13.50000000 4.00000000
-95.00000000 18.00000000 4.00000000
-91.20000000 18.00000000 4.00000000
-87.40000000 18.00000000 4.00000000
-83.60000000 18.00000000 4.00000000
-79.80000000 18.00000000 4.00000000
-76.00000000 18.00000000 4.00000000
-72.20000000 18.00000000 4.00000000
-68.40000000 18.00000000 4.00000000
-64.60000000 18.00000000 4.00000000
-60.80000000 18.00000000 4.00000000
-57.00000000 18.00000000 4.00000000
-53.20000000 18.00000000 4.00000000
-49.40000000 18.00000000 4.00000000
-45.60000000 18.00000000 4.00000000
-41.80000000 18.00000000 4.00000000
-38.00000000 18.00000000 4.00000000
-34.20000000 18.00000000 4.00000000
-30.40000000 18.00000000 4.00000000
-26.60000000 18.00000000 4.00000000
-22.80000000 18.00000000 4.00000000
-19.00000000 18.00000000 4.00000000
-15.20000000 18.00000000 4.00000000
-11.40000000 18.00000000 4.00000000
-7.60000000 18.00000000 4.00000000
-3.80000000 18.00000000 4.00000000
0.00000000 18.00000000 4.00000000
-95.00000000 22.50000000 4.00000000
-91.20000000 22.50000000 4.00000000
-87.40000000 22.50000000 4.00000000
-83.60000000 22.50000000 4.00000000
-79.80000000 22.50000000 4.00000000
-76.00000000 22.50000000 4.00000000
-72.20000000 22.50000000 4.00000000
-68.40000000 22.50000000 4.00000000
-64.60000000 22.50000000 4.00000000
-60.80000000 22.50000000 4.00000000
-57.00000000 22.50000000 4.00000000
-53.20000000 22.50000000 4.00000000
-49.40000000 22.50000000 4.00000000
-45.60000000 22.50000000 4.00000000
-41.80000000 22.50000000 4.00000000
-38.00000000 22.50000000 4.00000000
-34.20000000 22.50000000 4.00000000
-30.40000000 22.50000000 4.00000000
-26.60000000 22.50000000 4.00000000
-22.80000000 22.50000000 4.00000000
-19.00000000 22.50000000 4.00000000
-15.20000000 22.50000000 4.00000000
-11.40000000 22.50000000 4.00000000
-7.60000000 22.50000000 4.00000000
-3.80000000 22.50000000 4.00000000
0.00000000 22.50000000 4.00000000
-95.00000000 27.00000000 4.00000000
-91.20000000 27.00000000 4.00000000
-87.40000000 27.00000000 4.00000000
-83.60000000 27.00000000 4.00000000
-79.80000000 27.00000000 4.00000000
-76.00000000 27.00000000 4.00000000
-72.20000000 27.00000000 4.00000000
-68.40000000 27.00000000 4.00000000
-64.60000000 27.00000000 4.00000000
-60.80000000 27.00000000 4.00000000
-57.00000000 27.00000000 4.00000000
-53.20000000 27.00000000 4.00000000
-49.40000000 27.00000000 4.00000000
-45.60000000 27.00000000 4.00000000
-41.80000000 27.00000000 4.00000000
-38.00000000 27.00000000 4.00000000
-34.20000000 27.00000000 4.00000000
-30.40000000 27.00000000 4.00000000
-26.60000000 27.00000000 4.00000000
-22.80000000 27.00000000 4.00000000
-19.00000000 27.00000000 4.00000000
-15.20000000 27.00000000 4.00000000
-11.40000000 27.00000000 4.00000000
-7.60000000 27.00000000 4.00000000
-3.80000000 27.00000000 4.00000000
0.00000000 27.00000000 4.00000000
-95.00000000 31.50000000 4.00000000
-91.20000000 31.50000000 4.00000000
-87.40000000 31.50000000 4.00000000
-83.60000000 31.50000000 4.00000000
-79.80000000 31.50000000 4.00000000
-76.00000000 31.50000000 4.00000000
-72.20000000 31.50000000 4.00000000
-68.40000000 31.50000000 4.00000000
-64.60000000 31.50000000 4.00000000
-60.80000000 31.50000000 4.00000000
-57.00000000 31.50000000 4.00000000
-53.20000000 31.50000000 4.00000000
-49.40000000 31.50000000 4.00000000
-45.60000000 31.50000000 4.00000000
-41.80000000 31.50000000 4.00000000
-38.00000000 31.50000000 4.00000000
-34.20000000 31.50000000 4.00000000
-30.40000000 31.50000000 4.00000000
-26.60000000 31.50000000 4.00000000
-22.80000000 31.50000000 4.00000000
-19.00000000 31.50000000 4.00000000
-15.20000000 31.50000000 4.00000000
-11.40000000 31.50000000 4.00000000
-7.60000000 31.50000000 4.00000000
-3.80000000 31.50000000 4.00000000
0.00000000 31.50000000 4.00000000
-95.00000000 36.00000000 4.00000000
-91.20000000 36.00000000 4.00000000
-87.40000000 36.00000000 4.00000000
-83.60000000 36.00000000 4.00000000
-79.80000000 36.00000000 4.00000000
-76.00000000 36.00000000 4.00000000
-72.20000000 36.00000000 4.00000000
-68.40000000 36.00000000 4.00000000
-64.60000000 36.00000000 4.00000000
-60.80000000 36.00000000 4.00000000
-57.00000000 36.00000000 4.00000000
-53.20000000 36.00000000 4.00000000
-49.40000000 36.00000000 4.00000000
-45.60000000 36.00000000 4.00000000
-41.80000000 36.00000000 4.00000000
-38.00000000 36.00000000 4.00000000
-34.20000000 36.00000000 4.00000000
-30.40000000 36.00000000 4.00000000
-26.60000000 36.00000000 4.00000000
-22.80000000 36.00000000 4.00000000
-19.00000000 36.00000000 4.00000000
-15.20000000 36.00000000 4.00000000
-11.40000000 36.00000000 4.00000000
-7.60000000 36.00000000 4.00000000
-3.80000000 36.00000000 4.00000000
0.00000000 36.00000000 4.00000000
-95.00000000 40.50000000 4.00000000
-91.20000000 40.50000000 4.00000000
-87.40000000 40.50000000 4.00000000
-83.60000000 40.50000000 4.00000000
-79.80000000 40.50000000 4.00000000
-76.00000000 40.50000000 4.00000000
-72.20000000 40.50000000 4.00000000
-68.40000000 40.50000000 4.00000000
-64.60000000 40.50000000 4.00000000
-60.80000000 40.50000000 4.00000000
-57.00000000 40.50000000 4.00000000
-53.20000000 40.50000000 4.00000000
-49.40000000 40.50000000 4.00000000
-45.60000000 40.50000000 4.00000000
-41.80000000 40.50000000 4.00000000
-38.00000000 40.50000000 4.00000000
-34.20000000 40.50000000 4.00000000
-30.40000000 40.50000000 4.00000000
-26.60000000 40.50000000 4.00000000
-22.80000000 40.50000000 4.00000000
-19.00000000 40.50000000 4.00000000
-15.20000000 40.50000000 4.00000000
-11.40000000 40.50000000 4.00000000
-7.60000000 40.50000000 4.00000000
-3.80000000 40.50000000 4.00000000
0.00000000 40.50000000 4.00000000
-95.00000000 45.00000000 4.00000000
-91.20000000 45.00000000 4.00000000
-87.40000000 45.00000000 4.00000000
-83.60000000 45.00000000 4.00000000
-79.80000000 45.00000000 4.00000000
-76.00000000 45.00000000 4.00000000
-72.20000000 45.00000000 4.00000000
-68.40000000 45.00000000 4.00000000
-64.60000000 45.00000000 4.00000000
-60.80000000 45.00000000 4.00000000
-57.00000000 45.00000000 4.00000000
-53.20000000 45.00000000 4.00000000
-49.40000000 45.00000000 4.00000000
-45.60000000 45.00000000 4.00000000
-41.80000000 45.00000000 4.00000000
-38.00000000 45.00000000 4.00000000
-34.20000000 45.00000000 4.00000000
-30.40000000 45.00000000 4.00000000
-26.60000000 45.00000000 4.00000000
-22.80000000 45.00000000 4.00000000
-19.00000000 45.00000000 4.00000000
-15.20000000 45.00000000 4.00000000
-11.40000000 45.00000000 4.00000000
-7.60000000 45.00000000 4.00000000
-3.80000000 45.00000000 4.00000000
0.00000000 45.00000000 4.00000000
-92.50000000 -42.50000000 6.00000000
-88.80000000 -42.50000000 6.00000000
-85.10000000 -42.50000000 6.00000000
-81.40000000 -42.50000000 6.00000000
-77.70000000 -42.50000000 6.00000000
-74.00000000 -42.50000000 6.00000000
-70.30000000 -42.50000000 6.00000000
-66.60000000 -42.50000000 6.00000000
-62.90000000 -42.50000000 6.00000000
-59.20000000 -42.50000000 6.00000000
-55.50000000 -42.50000000 6.00000000
-51.80000000 -42.50000000 6.00000000
-48.10000000 -42.50000000 6.00000000
-44.40000000 -42.50000000 6.00000000
-40.70000000 -42.50000000 6.00000000
-37.00000000 -42.50000000 6.00000000
-33.30000000 -42.50000000 6.00000000
-29.60000000 -42.50000000 6.00000000
-25.90000000 -42.50000000 6.00000000
-22.20000000 -42.50000000 6.00000000
-18.50000000 -42.50000000 6.00000000
-14.80000000 -42.50000000 6.00000000
-11.10000000 -42.50000000 6.00000000
-7.40000000 -42.50000000 6.00000000
-3.70000000 -42.50000000 6.00000000
0.00000000 -42.50000000 6.00000000
-92.50000000 -38.25000000 6.00000000
-88.80000000 -38.25000000 6.00000000
-85.10000000 -38.25000000 6.00000000
-81.40000000 -38.25000000 6.00000000
-77.70000000 -38.25000000 6.00000000
-74.00000000 -38.25000000 6.00000000
-70.30000000 -38.25000000 6.00000000
-66.60000000 -38.25000000 6.00000000
-62.90000000 -38.25000000 6.00000000
-59.20000000 -38.25000000 6.00000000
-55.50000000 -38.25000000 6.00000000
-51.80000000 -38.25000000 6.00000000
-48.10000000 -38.25000000 6.00000000
-44.40000000 -38.25000000 6.00000000
-40.70000000 -38.25000000 6.00000000
-37.00000000 -38.25000000 6.00000000
-33.30000000 -38.25000000 6.00000000
-29.60000000 -38.25000000 6.00000000
-25.90000000 -38.25000000 6.00000000
-22.20000000 -38.25000000 6.00000000
-18.50000000 -38.25000000 6.00000000
-14.80000000 -38.25000000 6.00000000
-11.10000000 -38.25000000 6.00000000
-7.40000000 -38.25000000 6.00000000
-3.70000000 -38.25000000 6.00000000
0.00000000 -38.25000000 6.00000000
-92.50000000 -34.00000000 6.00000000
-88.80000000 -34.00000000 6.00000000
-85.10000000 -34.00000000 6.00000000
-81.40000000 -34.00000000 6.00000000
-77.70000000 -34.00000000 6.00000000
-74.00000000 -34.00000000 6.00000000
-70.30000000 -34.00000000 6.00000000
-66.60000000 -34.00000000 6.00000000
-62.90000000 -34.00000000 6.00000000
-59.20000000 -34.00000000 6.00000000
-55.50000000 -34.00000000 6.00000000
-51.80000000 -34.00000000 6.00000000
-48.10000000 -34.00000000 6.00000000
-44.40000000 -34.00000000 6.00000000
-40.70000000 -34.00000000 6.00000000
-37.00000000 -34.00000000 6.00000000
-33.30000000 -34.00000000 6.00000000
-29.60000000 -34.00000000 6.00000000
-25.90000000 -34.00000000 6.00000000
-22.20000000 -34.00000000 6.00000000
-18.50000000 -34.00000000 6.00000000
-14.80000000 -34.00000000 6.00000000
-11.10000000 -34.00000000 6.00000000
-7.40000000 -34.00000000 6.00000000
-3.70000000 -34.00000000 6.00000000
0.00000000 -34.00000000 6.00000000
-92.50000000 -29.75000000 6.00000000
-88.80000000 -29.75000000 6.00000000
-85.10000000 -29.75000000 6.00000000
-81.40000000 -29.75000000 6.00000000
-77.70000000 -29.75000000 6.00000000
-74.00000000 -29.75000000 6.00000000
-70.30000000 -29.75000000 6.00000000
-66.60000000 -29.75000000 6.00000000
-62.90000000 -29.75000000 6.00000000
-59.20000000 -29.75000000 6.00000000
-55.50000000 -29.75000000 6.00000000
-51.80000000 -29.75000000 6.00000000
-48.10000000 -29.75000000 6.00000000
-44.40000000 -29.75000000 6.00000000
-40.70000000 -29.75000000 6.00000000
-37.00000000 -29.75000000 6.00000000
-33.30000000 -29.75000000 6.00000000
-29.60000000 -29.75000000 6.00000000
-25.90000000 -29.75000000 6.00000000
-22.20000000 -29.75000000 6.00000000
-18.50000000 -29.75000000 6.00000000
-14.80000000 -29.75000000 6.00000000
-11.10000000 -29.75000000 6.00000000
-7.40000000 -29.75000000 6.00000000
-3.70000000 -29.75000000 6.00000000
0.00000000 -29.75000000 6.00000000
-92.50000000 -25.50000000 6.00000000
-88.80000000 -25.50000000 6.00000000
-85.10000000 -25.50000000 6.00000000
-81.40000000 -25.50000000 6.00000000
-77.70000000 -25.50000000 6.00000000
-74.00000000 -25.50000000 6.00000000
-70.30000000 -25.50000000 6.00000000
-66.60000000 -25.50000000 6.00000000
-62.90000000 -25.50000000 6.00000000
-59.20000000 -25.50000000 6.00000000
-55.50000000 -25.50000000 6.00000000
-51.80000000 -25.50000000 6.00000000
-48.10000000 -25.50000000 6.00000000
-44.40000000 -25.50000000 6.00000000
-40.70000000 -25.50000000 6.00000000
-37.00000000 -25.50000000 6.00000000
-33.30000000 -25.50000000 6.00000000
-29.60000000 -25.50000000 6.00000000
-25.90000000 -25.50000000 6.00000000
-22.20000000 -25.50000000 6.00000000
-18.50000000 -25.50000000 6.00000000
-14.80000000 -25.50000000 6.00000000
-11.10000000 -25.50000000 6.00000000
-7.40000000 -25.50000000 6.00000000
-3.70000000 -25.50000000 6.00000000
0.00000000 -25.50000000 6.00000000
-92.50000000 -21.25000000 6.00000000
-88.80000000 -21.25000000 6.00000000
-85.10000000 -21.25000000 6.00000000
-81.40000000 -21.25000000 6.00000000
-77.70000000 -21.25000000 6.00000000
-74.00000000 -21.25000000 6.00000000
-70.30000000 -21.25000000 6.00000000
-66.60000000 -21.25000000 6.00000000
-62.90000000 -21.25000000 6.00000000
-59.20000000 -21.25000000 6.00000000
-55.50000000 -21.25000000 6.00000000
-51.80000000 -21.25000000 6.00000000
-48.10000000 -21.25000000 6.00000000
-44.40000000 -21.25000000 6.00000000
-40.70000000 -21.25000000 6.00000000
-37.00000000 -21.25000000 6.00000000
-33.30000000 -21.25000000 6.00000000
-29.60000000 -21.25000000 6.00000000
-25.90000000 -21.25000000 6.00000000
-22.20000000 -21.25000000 6.00000000
-18.50000000 -21.25000000 6.00000000
-14.80000000 -21.25000000 6.00000000
-11.10000000 -21.25000000 6.00000000
-7.40000000 -21.25000000 6.00000000
-3.70000000 -21.25000000 6.00000000
0.00000000 -21.25000000 6.00000000
-92.50000000 -17.00000000 6.00000000
-88.80000000 -17.00000000 6.00000000
-85.10000000 -17.00000000 6.00000000
-81.40000000 -17.00000000 6.00000000
-77.70000000 -17.00000000 6.00000000
-74.00000000 -17.00000000 6.00000000
-70.30000000 -17.00000000 6.00000000
-66.60000000 -17.00000000 6.00000000
-62.90000000 -17.00000000 6.00000000
-59.20000000 -17.00000000 6.00000000
-55.50000000 -17.00000000 6.00000000
-51.80000000 -17.00000000 6.00000000
-48.10000000 -17.00000000 6.00000000
-44.40000000 -17.00000000 6.00000000
-40.70000000 -17.00000000 6.00000000
-37.00000000 -17.00000000 6.00000000
-33.30000000 -17.00000000 6.00000000
-29.60000000 -17.00000000 6.00000000
-25.90000000 -17.00000000 6.00000000
-22.20000000 -17.00000000 6.00000000
-18.50000000 -17.00000000 6.00000000
-14.80000000 -17.00000000 6.00000000
-11.10000000 -17.00000000 6.00000000
-7.40000000 -17.00000000 6.00000000
-3.70000000 -17.00000000 6.00000000
0.00000000 -17.00000000 6.00000000
-92.50000000 -12.75000000 6.00000000
-88.80000000 -12.75000000 6.00000000
-85.10000000 -12.75000000 6.00000000
-81.40000000 -12.75000000 6.00000000
-77.70000000 -12.75000000 6.00000000
-74.00000000 -12.75000000 6.00000000
-70.30000000 -12.75000000 6.00000000
-66.60000000 -12.75000000 6.00000000
-62.90000000 -12.75000000 6.00000000
-59.20000000 -12.75000000 6.00000000
-55.50000000 -12.75000000 6.00000000
-51.80000000 -12.75000000 6.00000000
-48.10000000 -12.75000000 6.00000000
-44.40000000 -12.75000000 6.00000000
-40.70000000 -12.75000000 6.00000000
-37.00000000 -12.75000000 6.00000000
-33.30000000 -12.75000000 6.00000000
-29.60000000 -12.75000000 6.00000000
-25.90000000 -12.75000000 6.00000000
-22.20000000 -12.75000000 6.00000000
-18.50000000 -12.75000000 6.00000000
-14.80000000 -12.75000000 6.00000000
-11.10000000 -12.75000000 6.00000000
-7.40000000 -12.75000000 6.00000000
-3.70000000 -12.75000000 6.00000000
0.00000000 -12.75000000 6.00000000
-92.50000000 -8.50000000 6.00000000
-88.80000000 -8.50000000 6.00000000
-85.10000000 -8.50000000 6.00000000
-81.40000000 -8.50000000 6.00000000
-77.70000000 -8.50000000 6.00000000
-74.00000000 -8.50000000 6.00000000
-70.30000000 -8.50000000 6.00000000
-66.60000000 -8.50000000 6.00000000
-62.90000000 -8.50000000 6.00000000
-59.20000000 -8.50000000 6.00000000
-55.50000000 -8.50000000 6.00000000
-51.80000000 -8.50000000 6.00000000
-48.10000000 -8.50000000 6.00000000
-44.40000000 -8.50000000 6.00000000
-40.70000000 -8.50000000 6.00000000
-37.00000000 -8.50000000 6.00000000
-33.30000000 -8.50000000 6.00000000
-29.60000000 -8.50000000 6.00000000
-25.90000000 -8.50000000 6.00000000
-22.20000000 -8.50000000 6.00000000
-18.50000000 -8.50000000 6.00000000
-14.80000000 -8.50000000 6.00000000
-11.10000000 -8.50000000 6.00000000
-7.40000000 -8.50000000 6.00000000
-3.70000000 -8.50000000 6.00000000
0.00000000 -8.50000000 6.00000000
-92.50000000 -4.25000000 6.00000000
-88.80000000 -4.25000000 6.00000000
-85.10000000 -4.25000000 6.00000000
-81.40000000 -4.25000000 6.00000000
-77.70000000 -4.25000000 6.00000000
-74.00000000 -4.25000000 6.00000000
-70.30000000 -4.25000000 6.00000000
-66.60000000 -4.25000000 6.00000000
-62.90000000 -4.25000000 6.00000000
-59.20000000 -4.25000000 6.00000000
-55.50000000 -4.25000000 6.00000000
-51.80000000 -4.25000000 6.00000000
-48.10000000 -4.25000000 6.00000000
-44.40000000 -4.25000000 6.00000000
-40.70000000 -4.25000000 6.00000000
-37.00000000 -4.25000000 6.00000000
-33.30000000 -4.25000000 6.00000000
-29.60000000 -4.25000000 6.00000000
-25.90000000 -4.25000000 6.00000000
-22.20000000 -4.25000000 6.00000000
-18.50000000 -4.25000000 6.00000000
-14.80000000 -4.25000000 6.00000000
-11.10000000 -4.25000000 6.00000000
-7.40000000 -4.25000000 6.00000000
-3.70000000 -4.25000000 6.00000000
0.00000000 -4.25000000 6.00000000
-92.50000000 0.00000000 6.00000000
-88.80000000 0.00000000 6.00000000
-85.10000000 0.00000000 6.00000000
-81.40000000 0.00000000 6.00000000
-77.70000000 0.00000000 6.00000000
-74.00000000 0.00000000 6.00000000
-70.30000000 0.00000000 6.00000000
-66.60000000 0.00000000 6.00000000
-62.90000000 0.00000000 6.00000000
-59.20000000 0.00000000 6.00000000
-55.50000000 0.00000000 6.00000000
-51.80000000 0.00000000 6.00000000
-48.10000000 0.00000000 6.00000000
-44.40000000 0.00000000 6.00000000
-40.70000000 0.00000000 6.00000000
-37.00000000 0.00000000 6.00000000
-33.30000000 0.00000000 6.00000000
-29.60000000 0.00000000 6.00000000
-25.90000000 0.00000000 6.00000000
-22.20000000 0.00000000 6.00000000
-18.50000000 0.00000000 6.00000000
-14.80000000 0.00000000 6.00000000
-11.10000000 0.00000000 6.00000000
-7.40000000 0.00000000 6.00000000
-3.70000000 0.00000000 6.00000000
0.00000000 0.00000000 6.00000000
-92.50000000 4.25000000 6.00000000
-88.80000000 4.25000000 6.00000000
-85.10000000 4.25000000 6.00000000
-81.40000000 4.25000000 6.00000000
-77.70000000 4.25000000 6.00000000
-74.00000000 4.25000000 6.00000000
-70.30000000 4.25000000 6.00000000
-66.60000000 4.25000000 6.00000000
-62.90000000 4.25000000 6.00000000
-59.20000000 4.25000000 6.00000000
-55.50000000 4.25000000 6.00000000
-51.80000000 4.25000000 6.00000000
-48.10000000 4.25000000 6.00000000
-44.40000000 4.25000000 6.00000000
-40.70000000 4.25000000 6.00000000
-37.00000000 4.25000000 6.00000000
-33.30000000 4.25000000 6.00000000
-29.60000000 4.25000000 6.00000000
-25.90000000 4.25000000 6.00000000
-22.20000000 4.25000000 6.00000000
-18.50000000 4.25000000 6.00000000
-14.80000000 4.25000000 6.00000000
-11.10000000 4.25000000 6.00000000
-7.40000000 4.25000000 6.00000000
-3.70000000 4.25000000 6.00000000
0.00000000 4.25000000 6.00000000
-92.50000000 8.50000000 6.00000000
-88.80000000 8.50000000 6.00000000
-85.10000000 8.50000000 6.00000000
-81.40000000 8.50000000 6.00000000
-77.70000000 8.50000000 6.00000000
-74.00000000 8.50000000 6.00000000
-70.30000000 8.50000000 6.00000000
-66.60000000 8.50000000 6.00000000
-62.90000000 8.50000000 6.00000000
-59.20000000 8.50000000 6.00000000
-55.50000000 8.50000000 6.00000000
-51.80000000 8.50000000 6.00000000
-48.10000000 8.50000000 6.00000000
-44.40000000 8.50000000 6.00000000
-40.70000000 8.50000000 6.00000000
-37.00000000 8.50000000 6.00000000
-33.30000000 8.50000000 6.00000000
-29.60000000 8.50000000 6.00000000
-25.90000000 8.50000000 6.00000000
-22.20000000 8.50000000 6.00000000
-18.50000000 8.50000000 6.00000000
-14.80000000 8.50000000 6.00000000
-11.10000000 8.50000000 6.00000000
-7.40000000 8.50000000 6.00000000
-3.70000000 8.50000000 6.00000000
0.00000000 8.50000000 6.00000000
-92.50000000 12.75000000 6.00000000
-88.80000000 12.75000000 6.00000000
-85.10000000 12.75000000 6.00000000
-81.40000000 12.75000000 6.00000000
-77.70000000 12.75000000 6.00000000
-74.00000000 12.75000000 6.00000000
-70.30000000 12.75000000 6.00000000
-66.60000000 12.75000000 6.00000000
-62.90000000 12.75000000 6.00000000
-59.20000000 12.75000000 6.00000000
-55.50000000 12.75000000 6.00000000
-51.80000000 12.75000000 6.00000000
-48.10000000 12.75000000 6.00000000
-44.40000000 12.75000000 6.00000000
-40.70000000 12.75000000 6.00000000
-37.00000000 12.75000000 6.00000000
-33.30000000 12.75000000 6.00000000
-29.60000000 12.75000000 6.00000000
-25.90000000 12.75000000 6.00000000
-22.20000000 12.75000000 6.00000000
-18.50000000 12.75000000 6.00000000
-14.80000000 12.75000000 6.00000000
-11.10000000 12.75000000 6.00000000
-7.40000000 12.75000000 6.00000000
-3.70000000 12.75000000 6.00000000
0.00000000 12.75000000 6.00000000
-92.50000000 17.00000000 6.00000000
-88.80000000 17.00000000 6.00000000
-85.10000000 17.00000000 6.00000000
-81.40000000 17.00000000 6.00000000
-77.70000000 17.00000000 6.00000000
-74.00000000 17.00000000 6.00000000
-70.30000000 17.00000000 6.00000000
-66.60000000 17.00000000 6.00000000
-62.90000000 17.00000000 6.00000000
-59.20000000 17.00000000 6.00000000
-55.50000000 17.00000000 6.00000000
-51.80000000 17.00000000 6.00000000
-48.10000000 17.00000000 6.00000000
-44.40000000 17.00000000 6.00000000
-40.70000000 17.00000000 6.00000000
-37.00000000 17.00000000 6.00000000
-33.30000000 17.00000000 6.00000000
-29.60000000 17.00000000 6.00000000
-25.90000000 17.00000000 6.00000000
-22.20000000 17.00000000 6.00000000
-18.50000000 17.00000000 6.00000000
-14.80000000 17.00000000 6.00000000
-11.10000000 17.00000000 6.00000000
-7.40000000 17.00000000 6.00000000
-3.70000000 17.00000000 6.00000000
0.00000000 17.00000000 6.00000000
-92.50000000 21.25000000 6.00000000
-88.80000000 21.25000000 6.00000000
-85.10000000 21.25000000 6.00000000
-81.40000000 21.25000000 6.00000000
-77.70000000 21.25000000 6.00000000
-74.00000000 21.25000000 6.00000000
-70.30000000 21.25000000 6.00000000
-66.60000000 21.25000000 6.00000000
-62.90000000 21.25000000 6.00000000
-59.20000000 21.25000000 6.00000000
-55.50000000 21.25000000 6.00000000
-51.80000000 21.25000000 6.00000000
-48.10000000 21.25000000 6.00000000
-44.40000000 21.25000000 6.00000000
-40.70000000 21.25000000 6.00000000
-37.00000000 21.25000000 6.00000000
-33.30000000 21.25000000 6.00000000
-29.60000000 21.25000000 6.00000000
-25.90000000 21.25000000 6.00000000
-22.20000000 21.25000000 6.00000000
-18.50000000 21.25000000 6.00000000
-14.80000000 21.25000000 6.00000000
-11.10000000 21.25000000 6.00000000
-7.40000000 21.25000000 6.00000000
-3.70000000 21.25000000 6.00000000
0.00000000 21.25000000 6.00000000
-92.50000000 25.50000000 6.00000000
-88.80000000 25.50000000 6.00000000
-85.10000000 25.50000000 6.00000000
-81.40000000 25.50000000 6.00000000
-77.70000000 25.50000000 6.00000000
-74.00000000 25.50000000 6.00000000
-70.30000000 25.50000000 6.00000000
-66.60000000 25.50000000 6.00000000
-62.90000000 25.50000000 6.00000000
-59.20000000 25.50000000 6.00000000
-55.50000000 25.50000000 6.00000000
-51.80000000 25.50000000 6.00000000
-48.10000000 25.50000000 6.00000000
-44.40000000 25.50000000 6.00000000
-40.70000000 25.50000000 6.00000000
-37.00000000 25.50000000 6.00000000
-33.30000000 25.50000000 6.00000000
-29.60000000 25.50000000 6.00000000
-25.90000000 25.50000000 6.00000000
-22.20000000 25.50000000 6.00000000
-18.50000000 25.50000000 6.00000000
-14.80000000 25.50000000 6.00000000
-11.10000000 25.50000000 6.00000000
-7.40000000 25.50000000 6.00000000
-3.70000000 25.50000000 6.00000000
0.00000000 25.50000000 6.00000000
-92.50000000 29.75000000 6.00000000
-88.80000000 29.75000000 6.00000000
-85.10000000 29.75000000 6.00000000
-81.40000000 29.75000000 6.00000000
-77.70000000 29.75000000 6.00000000
-74.00000000 29.75000000 6.00000000
-70.30000000 29.75000000 6.00000000
-66.60000000 29.75000000 6.00000000
-62.90000000 29.75000000 6.00000000
-59.20000000 29.75000000 6.00000000
-55.50000000 29.75000000 6.00000000
-51.80000000 29.75000000 6.00000000
-48.10000000 29.75000000 6.00000000
-44.40000000 29.75000000 6.00000000
-40.70000000 29.75000000 6.00000000
-37.00000000 29.75000000 6.00000000
-33.30000000 29.75000000 6.00000000
-29.60000000 29.75000000 6.00000000
-25.90000000 29.75000000 6.00000000
-22.20000000 29.75000000 6.00000000
-18.50000000 29.75000000 6.00000000
-14.80000000 29.75000000 6.00000000
-11.10000000 29.75000000 6.00000000
-7.40000000 29.75000000 6.00000000
-3.70000000 29.75000000 6.00000000
0.00000000 29.75000000 6.00000000
-92.50000000 34.00000000 6.00000000
-88.80000000 34.00000000 6.00000000
-85.10000000 34.00000000 6.00000000
-81.40000000 34.00000000 6.00000000
-77.70000000 34.00000000 6.00000000
-74.00000000 34.00000000 6.00000000
-70.30000000 34.00000000 6.00000000
-66.60000000 34.00000000 6.00000000
-62.90000000 34.00000000 6.00000000
-59.20000000 34.00000000 6.00000000
-55.50000000 34.00000000 6.00000000
-51.80000000 34.00000000 6.00000000
-48.10000000 34.00000000 6.00000000
-44.40000000 34.00000000 6.00000000
-40.70000000 34.00000000 6.00000000
-37.00000000 34.00000000 6.00000000
-33.30000000 34.00000000 6.00000000
-29.60000000 34.00000000 6.00000000
-25.90000000 34.00000000 6.00000000
-22.20000000 34.00000000 6.00000000
-18.50000000 34.00000000 6.00000000
-14.80000000 34.00000000 6.00000000
-11.10000000 34.00000000 6.00000000
-7.40000000 34.00000000 6.00000000
-3.70000000 34.00000000 6.00000000
0.00000000 34.00000000 6.00000000
-92.50000000 38.25000000 6.00000000
-88.80000000 38.25000000 6.00000000
-85.10000000 38.25000000 6.00000000
-81.40000000 38.25000000 6.00000000
-77.70000000 38.25000000 6.00000000
-74.00000000 38.25000000 6.00000000
-70.30000000 38.25000000 6.00000000
-66.60000000 38.25000000 6.00000000
-62.90000000 38.25000000 6.00000000
-59.20000000 38.25000000 6.00000000
-55.50000000 38.25000000 6.00000000
-51.80000000 38.25000000 6.00000000
-48.10000000 38.25000000 6.00000000
-44.40000000 38.25000000 6.00000000
-40.70000000 38.25000000 6.00000000
-37.00000000 38.25000000 6.00000000
-33.30000000 38.25000000 6.00000000
-29.60000000 38.25000000 6.00000000
-25.90000000 38.25000000 6.00000000
-22.20000000 38.25000000 6.00000000
-18.50000000 38.25000000 6.00000000
-14.80000000 38.25000000 6.00000000
-11.10000000 38.25000000 6.00000000
-7.40000000 38.25000000 6.00000000
-3.70000000 38.25000000 6.00000000
0.00000000 38.25000000 6.00000000
-92.50000000 42.50000000 6.00000000
-88.80000000 42.50000000 6.00000000
-85.10000000 42.50000000 6.00000000
-81.40000000 42.50000000 6.00000000
-77.70000000 42.50000000 6.00000000
-74.00000000 42.50000000 6.00000000
-70.30000000 42.50000000 6.00000000
-66.60000000 42.50000000 6.00000000
-62.90000000 42.50000000 6.00000000
-59.20000000 42.50000000 6.00000000
-55.50000000 42.50000000 6.00000000
-51.80000000 42.50000000 6.00000000
-48.10000000 42.50000000 6.00000000
-44.40000000 42.50000000 6.00000000
-40.70000000 42.50000000 6.00000000
-37.00000000 42.50000000 6.00000000
-33.30000000 42.50000000 6.00000000
-29.60000000 42.50000000 6.00000000
-25.90000000 42.50000000 6.00000000
-22.20000000 42.50000000 6.00000000
-18.50000000 42.50000000 6.00000000
-14.80000000 42.50000000 6.00000000
-11.10000000 42.50000000 6.00000000
-7.40000000 42.50000000 6.00000000
-3.70000000 42.50000000 6.00000000
0.00000000 42.50000000 6.00000000
-90.00000000 -40.00000000 8.00000000
-86.40000000 -40.00000000 8.00000000
-82.80000000 -40.00000000 8.00000000
-79.20000000 -40.00000000 8.00000000
-75.60000000 -40.00000000 8.00000000
-72.00000000 -40.00000000 8.00000000
-68.40000000 -40.00000000 8.00000000
-64.80000000 -40.00000000 8.00000000
-61.20000000 -40.00000000 8.00000000
-57.60000000 -40.00000000 8.00000000
-54.00000000 -40.00000000 8.00000000
-50.40000000 -40.00000000 8.00000000
-46.80000000 -40.00000000 8.00000000
-43.20000000 -40.00000000 8.00000000
-39.60000000 -40.00000000 8.00000000
-36.00000000 -40.00000000 8.00000000
-32.40000000 -40.00000000 8.00000000
-28.80000000 -40.00000000 8.00000000
-25.20000000 -40.00000000 8.00000000
-21.60000000 -40.00000000 8.00000000
-18.00000000 -40.00000000 8.00000000
-14.40000000 -40.00000000 8.00000000
-10.80000000 -40.00000000 8.00000000
-7.20000000 -40.00000000 8.00000000
-3.60000000 -40.00000000 8.00000000
-90.00000000 -36.00000000 8.00000000
-86.40000000 -36.00000000 8.00000000
-82.80000000 -36.00000000 8.00000000
-79.20000000 -36.00000000 8.00000000
-75.60000000 -36.00000000 8.00000000
-72.00000000 -36.00000000 8.00000000
-68.40000000 -36.00000000 8.00000000
-64.80000000 -36.00000000 8.00000000
-61.20000000 -36.00000000 8.00000000
-57.60000000 -36.00000000 8.00000000
-54.00000000 -36.00000000 8.00000000
-50.40000000 -36.00000000 8.00000000
-46.80000000 -36.00000000 8.00000000
-43.20000000 -36.00000000 8.00000000
-39.60000000 -36.00000000 8.00000000
-36.00000000 -36.00000000 8.00000000
-32.40000000 -36.00000000 8.00000000
-28.80000000 -36.00000000 8.00000000
-25.20000000 -36.00000000 8.00000000
-21.60000000 -36.00000000 8.00000000
-18.00000000 -36.00000000 8.00000000
-14.40000000 -36.00000000 8.00000000
-10.80000000 -36.00000000 8.00000000
-7.20000000 -36.00000000 8.00000000
-3.60000000 -36.00000000 8.00000000
-90.00000000 -32.00000000 8.00000000
-86.40000000 -32.00000000 8.00000000
-82.80000000 -32.00000000 8.00000000
-79.20000000 -32.00000000 8.00000000
-75.60000000 -32.00000000 8.00000000
-72.00000000 -32.00000000 8.00000000
-68.40000000 -32.00000000 8.00000000
-64.80000000 -32.00000000 8.00000000
-61.20000000 -32.00000000 8.00000000
-57.60000000 -32.00000000 8.00000000
-54.00000000 -32.00000000 8.00000000
-50.40000000 -32.00000000 8.00000000
-46.80000000 -32.00000000 8.00000000
-43.20000000 -32.00000000 8.00000000
-39.60000000 -32.00000000 8.00000000
-36.00000000 -32.00000000 8.00000000
-32.40000000 -32.00000000 8.00000000
-28.80000000 -32.00000000 8.00000000
-25.20000000 -32.00000000 8.00000000
-21.60000000 -32.00000000 8.00000000
-18.00000000 -32.00000000 8.00000000
-14.40000000 -32.00000000 8.00000000
-10.80000000 -32.00000000 8.00000000
-7.20000000 -32.00000000 8.00000000
-3.60000000 -32.00000000 8.00000000
-90.00000000 -28.00000000 8.00000000
-86.40000000 -28.00000000 8.00000000
-82.80000000 -28.00000000 8.00000000
-79.20000000 -28.00000000 8.00000000
-75.60000000 -28.00000000 8.00000000
-72.00000000 -28.00000000 8.00000000
-68.40000000 -28.00000000 8.00000000
-64.80000000 -28.00000000 8.00000000
-61.20000000 -28.00000000 8.00000000
-57.60000000 -28.00000000 8.00000000
-54.00000000 -28.00000000 8.00000000
-50.40000000 -28.00000000 8.00000000
-46.80000000 -28.00000000 8.00000000
-43.20000000 -28.00000000 8.00000000
-39.60000000 -28.00000000 8.00000000
-36.00000000 -28.00000000 8.00000000
-32.40000000 -28.00000000 8.00000000
-28.80000000 -28.00000000 8.00000000
-25.20000000 -28.00000000 8.00000000
-21.60000000 -28.00000000 8.00000000
-18.00000000 -28.00000000 8.00000000
-14.40000000 -28.00000000 8.00000000
-10.80000000 -28.00000000 8.00000000
-7.20000000 -28.00000000 8.00000000
-3.60000000 -28.00000000 8.00000000
-90.00000000 -24.00000000 8.00000000
-86.40000000 -24.00000000 8.00000000
-82.80000000 -24.00000000 8.00000000
-79.20000000 -24.00000000 8.00000000
-75.60000000 -24.00000000 8.00000000
-72.00000000 -24.00000000 8.00000000
-68.40000000 -24.00000000 8.00000000
-64.80000000 -24.00000000 8.00000000
-61.20000000 -24.00000000 8.00000000
-57.60000000 -24.00000000 8.00000000
-54.00000000 -24.00000000 8.00000000
-50.40000000 -24.00000000 8.00000000
-46.80000000 -24.00000000 8.00000000
-43.20000000 -24.00000000 8.00000000
-39.60000000 -24.00000000 8.00000000
-36.00000000 -24.00000000 8.00000000
-32.40000000 -24.00000000 8.00000000
-28.80000000 -24.00000000 8.00000000
-25.20000000 -24.00000000 8.00000000
-21.60000000 -24.00000000 8.00000000
-18.00000000 -24.00000000 8.00000000
-14.40000000 -24.00000000 8.00000000
-10.80000000 -24.00000000 8.00000000
-7.20000000 -24.00000000 8.00000000
-3.60000000 -24.00000000 8.00000000
-90.00000000 -20.00000000 8.00000000
-86.40000000 -20.00000000 8.00000000
-82.80000000 -20.00000000 8.00000000
-79.20000000 -20.00000000 8.00000000
-75.60000000 -20.00000000 8.00000000
-72.00000000 -20.00000000 8.00000000
-68.40000000 -20.00000000 8.00000000
-64.80000000 -20.00000000 8.00000000
-61.20000000 -20.00000000 8.00000000
-57.60000000 -20.00000000 8.00000000
-54.00000000 -20.00000000 8.00000000
-50.40000000 -20.00000000 8.00000000
-46.80000000 -20.00000000 8.00000000
-43.20000000 -20.00000000 8.00000000
-39.60000000 -20.00000000 8.00000000
-36.00000000 -20.00000000 8.00000000
-32.40000000 -20.00000000 8.00000000
-28.80000000 -20.00000000 8.00000000
-25.20000000 -20.00000000 8.00000000
-21.60000000 -20.00000000 8.00000000
-18.00000000 -20.00000000 8.00000000
-14.40000000 -20.00000000 8.00000000
-10.80000000 -20.00000000 8.00000000
-7.20000000 -20.00000000 8.00000000
-3.60000000 -20.00000000 8.00000000
-90.00000000 -16.00000000 8.00000000
-86.40000000 -16.00000000 8.00000000
-82.80000000 -16.00000000 8.00000000
-79.20000000 -16.00000000 8.00000000
-75.60000000 -16.00000000 8.00000000
-72.00000000 -16.00000000 8.00000000
-68.40000000 -16.00000000 8.00000000
-64.80000000 -16.00000000 8.00000000
-61.20000000 -16.00000000 8.00000000
-57.60000000 -16.00000000 8.00000000
-54.00000000 -16.00000000 8.00000000
-50.40000000 -16.00000000 8.00000000
-46.80000000 -16.00000000 8.00000000
-43.20000000 -16.00000000 8.00000000
-39.60000000 -16.00000000 8.00000000
-36.00000000 -16.00000000 8.00000000
-32.40000000 -16.00000000 8.00000000
-28.80000000 -16.00000000 8.00000000
-25.20000000 -16.00000000 8.00000000
-21.60000000 -16.00000000 8.00000000
-18.00000000 -16.00000000 8.00000000
-14.40000000 -16.00000000 8.00000000
-10.80000000 -16.00000000 8.00000000
-7.20000000 -16.00000000 8.00000000
-3.60000000 -16.00000000 8.00000000
-90.00000000 -12.00000000 8.00000000
-86.40000000 -12.00000000 8.00000000
-82.80000000 -12.00000000 8.00000000
-79.20000000 -12.00000000 8.00000000
-75.60000000 -12.00000000 8.00000000
-72.00000000 -12.00000000 8.00000000
-68.40000000 -12.00000000 8.00000000
-64.80000000 -12.00000000 8.00000000
-61.20000000 -12.00000000 8.00000000
-57.60000000 -12.00000000 8.00000000
-54.00000000 -12.00000000 8.00000000
-50.40000000 -12.00000000 8.00000000
-46.80000000 -12.00000000 8.00000000
-43.20000000 -12.00000000 8.00000000
-39.60000000 -12.00000000 8.00000000
-36.00000000 -12.00000000 8.00000000
-32.40000000 -12.00000000 8.00000000
-28.80000000 -12.00000000 8.00000000
-25.20000000 -12.00000000 8.00000000
-21.60000000 -12.00000000 8.00000000
-18.00000000 -12.00000000 8.00000000
-14.40000000 -12.00000000 8.00000000
-10.80000000 -12.00000000 8.00000000
-7.20000000 -12.00000000 8.00000000
-3.60000000 -12.00000000 8.00000000
-90.00000000 -8.00000000 8.00000000
-86.40000000 -8.00000000 8.00000000
-82.80000000 -8.00000000 8.00000000
-79.20000000 -8.00000000 8.00000000
-75.60000000 -8.00000000 8.00000000
-72.00000000 -8.00000000 8.00000000
-68.40000000 -8.00000000 8.00000000
-64.80000000 -8.00000000 8.00000000
-61.20000000 -8.00000000 8.00000000
-57.60000000 -8.00000000 8.00000000
-54.00000000 -8.00000000 8.00000000
-50.40000000 -8.00000000 8.00000000
-46.80000000 -8.00000000 8.00000000
-43.20000000 -8.00000000 8.00000000
-39.60000000 -8.00000000 8.00000000
-36.00000000 -8.00000000 8.00000000
-32.40000000 -8.00000000 8.00000000
-28.80000000 -8.00000000 8.00000000
-25.20000000 -8.00000000 8.00000000
-21.60000000 -8.00000000 8.00000000
-18.00000000 -8.00000000 8.00000000
-14.40000000 -8.00000000 8.00000000
-10.80000000 -8.00000000 8.00000000
-7.20000000 -8.00000000 8.00000000
-3.60000000 -8.00000000 8.00000000
-90.00000000 -4.00000000 8.00000000
-86.40000000 -4.00000000 8.00000000
-82.80000000 -4.00000000 8.00000000
-79.20000000 -4.00000000 8.00000000
-75.60000000 -4.00000000 8.00000000
-72.00000000 -4.00000000 8.00000000
-68.40000000 -4.00000000 8.00000000
-64.80000000 -4.00000000 8.00000000
-61.20000000 -4.00000000 8.00000000
-57.60000000 -4.00000000 8.00000000
-54.00000000 -4.00000000 8.00000000
-50.40000000 -4.00000000 8.00000000
-46.80000000 -4.00000000 8.00000000
-43.20000000 -4.00000000 8.00000000
-39.60000000 -4.00000000 8.00000000
-36.00000000 -4.00000000 8.00000000
-32.40000000 -4.00000000 8.00000000
-28.80000000 -4.00000000 8.00000000
-25.20000000 -4.00000000 8.00000000
-21.60000000 -4.00000000 8.00000000
-18.00000000 -4.00000000 8.00000000
-14.40000000 -4.00000000 8.00000000
-10.80000000 -4.00000000 8.00000000
-7.20000000 -4.00000000 8.00000000
-3.60000000 -4.00000000 8.00000000
-90.00000000 0.00000000 8.00000000
-86.40000000 0.00000000 8.00000000
-82.80000000 0.00000000 8.00000000
-79.20000000 0.00000000 8.00000000
-75.60000000 0.00000000 8.00000000
-72.00000000 0.00000000 8.00000000
-68.40000000 0.00000000 8.00000000
-64.80000000 0.00000000 8.00000000
-61.20000000 0.00000000 8.00000000
-57.60000000 0.00000000 8.00000000
-54.00000000 0.00000000 8.00000000
-50.40000000 0.00000000 8.00000000
-46.80000000 0.00000000 8.00000000
-43.20000000 0.00000000 8.00000000
-39.60000000 0.00000000 8.00000000
-36.00000000 0.00000000 8.00000000
-32.40000000 0.00000000 8.00000000
-28.80000000 0.00000000 8.00000000
-25.20000000 0.00000000 8.00000000
-21.60000000 0.00000000 8.00000000
-18.00000000 0.00000000 8.00000000
-14.40000000 0.00000000 8.00000000
-10.80000000 0.00000000 8.00000000
-7.20000000 0.00000000 8.00000000
-3.60000000 0.00000000 8.00000000
-90.00000000 4.00000000 8.00000000
-86.40000000 4.00000000 8.00000000
-82.80000000 4.00000000 8.00000000
-79.20000000 4.00000000 8.00000000
-75.60000000 4.00000000 8.00000000
-72.00000000 4.00000000 8.00000000
-68.40000000 4.00000000 8.00000000
-64.80000000 4.00000000 8.00000000
-61.20000000 4.00000000 8.00000000
-57.60000000 4.00000000 8.00000000
-54.00000000 4.00000000 8.00000000
-50.40000000 4.00000000 8.00000000
-46.80000000 4.00000000 8.00000000
-43.20000000 4.00000000 8.00000000
-39.60000000 4.00000000 8.00000000
-36.00000000 4.00000000 8.00000000
-32.40000000 4.00000000 8.00000000
-28.80000000 4.00000000 8.00000000
-25.20000000 4.00000000 8.00000000
-21.60000000 4.00000000 8.00000000
-18.00000000 4.00000000 8.00000000
-14.40000000 4.00000000 8.00000000
-10.80000000 4.00000000 8.00000000
-7.20000000 4.00000000 8.00000000
-3.60000000 4.00000000 8.00000000
-90.00000000 8.00000000 8.00000000
-86.40000000 8.00000000 8.00000000
-82.80000000 8.00000000 8.00000000
-79.20000000 8.00000000 8.00000000
-75.60000000 8.00000000 8.00000000
-72.00000000 8.00000000 8.00000000
-68.40000000 8.00000000 8.00000000
-64.80000000 8.00000000 8.00000000
-61.20000000 8.00000000 8.00000000
-57.60000000 8.00000000 8.00000000
-54.00000000 8.00000000 8.00000000
-50.40000000 8.00000000 8.00000000
-46.80000000 8.00000000 8.00000000
-43.20000000 8.00000000 8.00000000
-39.60000000 8.00000000 8.00000000
-36.00000000 8.00000000 8.00000000
-32.40000000 8.00000000 8.00000000
-28.80000000 8.00000000 8.00000000
-25.20000000 8.00000000 8.00000000
-21.60000000 8.00000000 8.00000000
-18.00000000 8.00000000 8.00000000
-14.40000000 8.00000000 8.00000000
-10.80000000 8.00000000 8.00000000
-7.20000000 8.00000000 8.00000000
-3.60000000 8.00000000 8.00000000
-90.00000000 12.00000000 8.00000000
-86.40000000 12.00000000 8.00000000
-82.80000000 12.00000000 8.00000000
-79.20000000 12.00000000 8.00000000
-75.60000000 12.00000000 8.00000000
-72.00000000 12.00000000 8.00000000
-68.40000000 12.00000000 8.00000000
-64.80000000 12.00000000 8.00000000
-61.20000000 12.00000000 8.00000000
-57.60000000 12.00000000 8.00000000
-54.00000000 12.00000000 8.00000000
-50.40000000 12.00000000 8.00000000
-46.80000000 12.00000000 8.00000000
-43.20000000 12.00000000 8.00000000
-39.60000000 12.00000000 8.00000000
-36.00000000 12.00000000 8.00000000
-32.40000000 12.00000000 8.00000000
-28.80000000 12.00000000 8.00000000
-25.20000000 12.00000000 8.00000000
-21.60000000 12.00000000 8.00000000
-18.00000000 12.00000000 8.00000000
-14.40000000 12.00000000 8.00000000
-10.80000000 12.00000000 8.00000000
-7.20000000 12.00000000 8.00000000
-3.60000000 12.00000000 8.00000000
-90.00000000 16.00000000 8.00000000
-86.40000000 16.00000000 8.00000000
-82.80000000 16.00000000 8.00000000
-79.20000000 16.00000000 8.00000000
-75.60000000 16.00000000 8.00000000
-72.00000000 16.00000000 8.00000000
-68.40000000 16.00000000 8.00000000
-64.80000000 16.00000000 8.00000000
-61.20000000 16.00000000 8.00000000
-57.60000000 16.00000000 8.00000000
-54.00000000 16.00000000 8.00000000
-50.40000000 16.00000000 8.00000000
-46.80000000 16.00000000 8.00000000
-43.20000000 16.00000000 8.00000000
-39.60000000 16.00000000 8.00000000
-36.00000000 16.00000000 8.00000000
-32.40000000 16.00000000 8.00000000
-28.80000000 16.00000000 8.00000000
-25.20000000 16.00000000 8.00000000
-21.60000000 16.00000000 8.00000000
-18.00000000 16.00000000 8.00000000
-14.40000000 16.00000000 8.00000000
-10.80000000 16.00000000 8.00000000
-7.20000000 16.00000000 8.00000000
-3.60000000 16.00000000 8.00000000
-90.00000000 20.00000000 8.00000000
-86.40000000 20.00000000 8.00000000
-82.80000000 20.00000000 8.00000000
-79.20000000 20.00000000 8.00000000
-75.60000000 20.00000000 8.00000000
-72.00000000 20.00000000 8.00000000
-68.40000000 20.00000000 8.00000000
-64.80000000 20.00000000 8.00000000
-61.20000000 20.00000000 8.00000000
-57.60000000 20.00000000 8.00000000
-54.00000000 20.00000000 8.00000000
-50.40000000 20.00000000 8.00000000
-46.80000000 20.00000000 8.00000000
-43.20000000 20.00000000 8.00000000
-39.60000000 20.00000000 8.00000000
-36.00000000 20.00000000 8.00000000
-32.40000000 20.00000000 8.00000000
-28.80000000 20.00000000 8.00000000
-25.20000000 20.00000000 8.00000000
-21.60000000 20.00000000 8.00000000
-18.00000000 20.00000000 8.00000000
-14.40000000 20.00000000 8.00000000
-10.80000000 20.00000000 8.00000000
-7.20000000 20.00000000 8.00000000
-3.60000000 20.00000000 8.00000000
-90.00000000 24.00000000 8.00000000
-86.40000000 24.00000000 8.00000000
-82.80000000 24.00000000 8.00000000
-79.20000000 24.00000000 8.00000000
-75.60000000 24.00000000 8.00000000
-72.00000000 24.00000000 8.00000000
-68.40000000 24.00000000 8.00000000
-64.80000000 24.00000000 8.00000000
-61.20000000 24.00000000 8.00000000
-57.60000000 24.00000000 8.00000000
-54.00000000 24.00000000 8.00000000
-50.40000000 24.00000000 8.00000000
-46.80000000 24.00000000 8.00000000
-43.20000000 24.00000000 8.00000000
-39.60000000 24.00000000 8.00000000
-36.00000000 24.00000000 8.00000000
-32.40000000 24.00000000 8.00000000
-28.80000000 24.00000000 8.00000000
-25.20000000 24.00000000 8.00000000
-21.60000000 24.00000000 8.00000000
-18.00000000 24.00000000 8.00000000
-14.40000000 24.00000000 8.00000000
-10.80000000 24.00000000 8.00000000
-7.20000000 24.00000000 8.00000000
-3.60000000 24.00000000 8.00000000
-90.00000000 28.00000000 8.00000000
-86.40000000 28.00000000 8.00000000
-82.80000000 28.00000000 8.00000000
-79.20000000 28.00000000 8.00000000
-75.60000000 28.00000000 8.00000000
-72.00000000 28.00000000 8.00000000
-68.40000000 28.00000000 8.00000000
-64.80000000 28.00000000 8.00000000
-61.20000000 28.00000000 8.00000000
-57.60000000 28.00000000 8.00000000
-54.00000000 28.00000000 8.00000000
-50.40000000 28.00000000 8.00000000
-46.80000000 28.00000000 8.00000000
-43.20000000 28.00000000 8.00000000
-39.60000000 28.00000000 8.00000000
-36.00000000 28.00000000 8.00000000
-32.40000000 28.00000000 8.00000000
-28.80000000 28.00000000 8.00000000
-25.20000000 28.00000000 8.00000000
-21.60000000 28.00000000 8.00000000
-18.00000000 28.00000000 8.00000000
-14.40000000 28.00000000 8.00000000
-10.80000000 28.00000000 8.00000000
-7.20000000 28.00000000 8.00000000
-3.60000000 28.00000000 8.00000000
-90.00000000 32.00000000 8.00000000
-86.40000000 32.00000000 8.00000000
-82.80000000 32.00000000 8.00000000
-79.20000000 32.00000000 8.00000000
-75.60000000 32.00000000 8.00000000
-72.00000000 32.00000000 8.00000000
-68.40000000 32.00000000 8.00000000
-64.80000000 32.00000000 8.00000000
-61.20000000 32.00000000 8.00000000
-57.60000000 32.00000000 8.00000000
-54.00000000 32.00000000 8.00000000
-50.40000000 32.00000000 8.00000000
-46.80000000 32.00000000 8.00000000
-43.20000000 32.00000000 8.00000000
-39.60000000 32.00000000 8.00000000
-36.00000000 32.00000000 8.00000000
-32.40000000 32.00000000 8.00000000
-28.80000000 32.00000000 8.00000000
-25.20000000 32.00000000 8.00000000
-21.60000000 32.00000000 8.00000000
-18.00000000 32.00000000 8.00000000
-14.40000000 32.00000000 8.00000000
-10.80000000 32.00000000 8.00000000
-7.20000000 32.00000000 8.00000000
-3.60000000 32.00000000 8.00000000
-90.00000000 36.00000000 8.00000000
-86.40000000 36.00000000 8.00000000
-82.80000000 36.00000000 8.00000000
-79.20000000 36.00000000 8.00000000
-75.60000000 36.00000000 8.00000000
-72.00000000 36.00000000 8.00000000
-68.40000000 36.00000000 8.00000000
-64.80000000 36.00000000 8.00000000
-61.20000000 36.00000000 8.00000000
-57.60000000 36.00000000 8.00000000
-54.00000000 36.00000000 8.00000000
-50.40000000 36.00000000 8.00000000
-46.80000000 36.00000000 8.00000000
-43.20000000 36.00000000 8.00000000
-39.60000000 36.00000000 8.00000000
-36.00000000 36.00000000 8.00000000
-32.40000000 36.00000000 8.00000000
-28.80000000 36.00000000 8.00000000
-25.20000000 36.00000000 8.00000000
-21.60000000 36.00000000 8.00000000
-18.00000000 36.00000000 8.00000000
-14.40000000 36.00000000 8.00000000
-10.80000000 36.00000000 8.00000000
-7.20000000 36.00000000 8.00000000
-3.60000000 36.00000000 8.00000000
-90.00000000 40.00000000 8.00000000
-86.40000000 40.00000000 8.00000000
-82.80000000 40.00000000 8.00000000
-79.20000000 40.00000000 8.00000000
-75.60000000 40.00000000 8.00000000
-72.00000000 40.00000000 8.00000000
-68.40000000 40.00000000 8.00000000
-64.80000000 40.00000000 8.00000000
-61.20000000 40.00000000 8.00000000
-57.60000000 40.00000000 8.00000000
-54.00000000 40.00000000 8.00000000
-50.40000000 40.00000000 8.00000000
-46.80000000 40.00000000 8.00000000
-43.20000000 40.00000000 8.00000000
-39.60000000 40.00000000 8.00000000
-36.00000000 40.00000000 8.00000000
-32.40000000 40.00000000 8.00000000
-28.80000000 40.00000000 8.00000000
-25.20000000 40.00000000 8.00000000
-21.60000000 40.00000000 8.00000000
-18.00000000 40.00000000 8.00000000
-14.40000000 40.00000000 8.00000000
-10.80000000 40.00000000 8.00000000
-7.20000000 40.00000000 8.00000000
-3.60000000 40.00000000 8.00000000
-87.50000000 -37.50000000 10.00000000
-84.00000000 -37.50000000 10.00000000
-80.50000000 -37.50000000 10.00000000
-77.00000000 -37.50000000 10.00000000
-73.50000000 -37.50000000 10.00000000
-70.00000000 -37.50000000 10.00000000
-66.50000000 -37.50000000 10.00000000
-63.00000000 -37.50000000 10.00000000
-59.50000000 -37.50000000 10.00000000
-56.00000000 -37.50000000 10.00000000
-52.50000000 -37.50000000 10.00000000
-49.00000000 -37.50000000 10.00000000
-45.50000000 -37.50000000 10.00000000
-42.00000000 -37.50000000 10.00000000
-38.50000000 -37.50000000 10.00000000
-35.00000000 -37.50000000 10.00000000
-31.50000000 -37.50000000 10.00000000
-28.00000000 -37.50000000 10.00000000
-24.50000000 -37.50000000 10.00000000
-21.00000000 -37.50000000 10.00000000
-17.50000000 -37.50000000 10.00000000
-14.00000000 -37.50000000 10.00000000
-10.50000000 -37.50000000 10.00000000
-7.00000000 -37.50000000 10.00000000
-3.50000000 -37.50000000 10.00000000
-87.50000000 -33.75000000 10.00000000
-84.00000000 -33.75000000 10.00000000
-80.50000000 -33.75000000 10.00000000
-77.00000000 -33.75000000 10.00000000
-73.50000000 -33.75000000 10.00000000
-70.00000000 -33.75000000 10.00000000
-66.50000000 -33.75000000 10.00000000
-63.00000000 -33.75000000 10.00000000
-59.50000000 -33.75000000 10.00000000
-56.00000000 -33.75000000 10.00000000
-52.50000000 -33.75000000 10.00000000
-49.00000000 -33.75000000 10.00000000
-45.50000000 -33.75000000 10.00000000
-42.00000000 -33.75000000 10.00000000
-38.50000000 -33.75000000 10.00000000
-35.00000000 -33.75000000 10.00000000
-31.50000000 -33.75000000 10.00000000
-28.00000000 -33.75000000 10.00000000
-24.50000000 -33.75000000 10.00000000
-21.00000000 -33.75000000 10.00000000
-17.50000000 -33.75000000 10.00000000
-14.00000000 -33.75000000 10.00000000
-10.50000000 -33.75000000 10.00000000
-7.00000000 -33.75000000 10.00000000
-3.50000000 -33.75000000 10.00000000
-87.50000000 -30.00000000 10.00000000
-84.00000000 -30.00000000 10.00000000
-80.50000000 -30.00000000 10.00000000
-77.00000000 -30.00000000 10.00000000
-73.50000000 -30.00000000 10.00000000
-70.00000000 -30.00000000 10.00000000
-66.50000000 -30.00000000 10.00000000
-63.00000000 -30.00000000 10.00000000
-59.50000000 -30.00000000 10.00000000
-56.00000000 -30.00000000 10.00000000
-52.50000000 -30.00000000 10.00000000
-49.00000000 -30.00000000 10.00000000
-45.50000000 -30.00000000 10.00000000
-42.00000000 -30.00000000 10.00000000
-38.50000000 -30.00000000 10.00000000
-35.00000000 -30.00000000 10.00000000
-31.50000000 -30.00000000 10.00000000
-28.00000000 -30.00000000 10.00000000
-24.50000000 -30.00000000 10.00000000
-21.00000000 -30.00000000 10.00000000
-17.50000000 -30.00000000 10.00000000
-14.00000000 -30.00000000 10.00000000
-10.50000000 -30.00000000 10.00000000
-7.00000000 -30.00000000 10.00000000
-3.50000000 -30.00000000 10.00000000
-87.50000000 -26.25000000 10.00000000
-84.00000000 -26.25000000 10.00000000
-80.50000000 -26.25000000 10.00000000
-77.00000000 -26.25000000 10.00000000
-73.50000000 -26.25000000 10.00000000
-70.00000000 -26.25000000 10.00000000
-66.50000000 -26.25000000 10.00000000
-63.00000000 -26.25000000 10.00000000
-59.50000000 -26.25000000 10.00000000
-56.00000000 -26.25000000 10.00000000
-52.50000000 -26.25000000 10.00000000
-49.00000000 -26.25000000 10.00000000
-45.50000000 -26.25000000 10.00000000
-42.00000000 -26.25000000 10.00000000
-38.50000000 -26.25000000 10.00000000
-35.00000000 -26.25000000 10.00000000
-31.50000000 -26.25000000 10.00000000
-28.00000000 -26.25000000 10.00000000
-24.50000000 -26.25000000 10.00000000
-21.00000000 -26.25000000 10.00000000
-17.50000000 -26.25000000 10.00000000
-14.00000000 -26.25000000 10.00000000
-10.50000000 -26.25000000 10.00000000
-7.00000000 -26.25000000 10.00000000
-3.50000000 -26.25000000 10.00000000
-87.50000000 -22.50000000 10.00000000
-84.00000000 -22.50000000 10.00000000
-80.50000000 -22.50000000 10.00000000
-77.00000000 -22.50000000 10.00000000
-73.50000000 -22.50000000 10.00000000
-70.00000000 -22.50000000 10.00000000
-66.50000000 -22.50000000 10.00000000
-63.00000000 -22.50000000 10.00000000
-59.50000000 -22.50000000 10.00000000
-56.00000000 -22.50000000 10.00000000
-52.50000000 -22.50000000 10.00000000
-49.00000000 -22.50000000 10.00000000
-45.50000000 -22.50000000 10.00000000
-42.00000000 -22.50000000 10.00000000
-38.50000000 -22.50000000 10.00000000
-35.00000000 -22.50000000 10.00000000
-31.50000000 -22.50000000 10.00000000
-28.00000000 -22.50000000 10.00000000
-24.50000000 -22.50000000 10.00000000
-21.00000000 -22.50000000 10.00000000
-17.50000000 -22.50000000 10.00000000
-14.00000000 -22.50000000 10.00000000
-10.50000000 -22.50000000 10.00000000
-7.00000000 -22.50000000 10.00000000
-3.50000000 -22.50000000 10.00000000
-87.50000000 -18.75000000 10.00000000
-84.00000000 -18.75000000 10.00000000
-80.50000000 -18.75000000 10.00000000
-77.00000000 -18.75000000 10.00000000
-73.50000000 -18.75000000 10.00000000
-70.00000000 -18.75000000 10.00000000
-66.50000000 -18.75000000 10.00000000
-63.00000000 -18.75000000 10.00000000
-59.50000000 -18.75000000 10.00000000
-56.00000000 -18.75000000 10.00000000
-52.50000000 -18.75000000 10.00000000
-49.00000000 -18.75000000 10.00000000
-45.50000000 -18.75000000 10.00000000
-42.00000000 -18.75000000 10.00000000
-38.50000000 -18.75000000 10.00000000
-35.00000000 -18.75000000 10.00000000
-31.50000000 -18.75000000 10.00000000
-28.00000000 -18.75000000 10.00000000
-24.50000000 -18.75000000 10.00000000
-21.00000000 -18.75000000 10.00000000
-17.50000000 -18.75000000 10.00000000
-14.00000000 -18.75000000 10.00000000
-10.50000000 -18.75000000 10.00000000
-7.00000000 -18.75000000 10.00000000
-3.50000000 -18.75000000 10.00000000
-87.50000000 -15.00000000 10.00000000
-84.00000000 -15.00000000 10.00000000
-80.50000000 -15.00000000 10.00000000
-77.00000000 -15.00000000 10.00000000
-73.50000000 -15.00000000 10.00000000
-70.00000000 -15.00000000 10.00000000
-66.50000000 -15.00000000 10.00000000
-63.00000000 -15.00000000 10.00000000
-59.50000000 -15.00000000 10.00000000
-56.00000000 -15.00000000 10.00000000
-52.50000000 -15.00000000 10.00000000
-49.00000000 -15.00000000 10.00000000
-45.50000000 -15.00000000 10.00000000
-42.00000000 -15.00000000 10.00000000
-38.50000000 -15.00000000 10.00000000
-35.00000000 -15.00000000 10.00000000
-31.50000000 -15.00000000 10.00000000
-28.00000000 -15.00000000 10.00000000
-24.50000000 -15.00000000 10.00000000
-21.00000000 -15.00000000 10.00000000
-17.50000000 -15.00000000 10.00000000
-14.00000000 -15.00000000 10.00000000
-10.50000000 -15.00000000 10.00000000
-7.00000000 -15.00000000 10.00000000
-3.50000000 -15.00000000 10.00000000
-87.50000000 -11.25000000 10.00000000
-84.00000000 -11.25000000 10.00000000
-80.50000000 -11.25000000 10.00000000
-77.00000000 -11.25000000 10.00000000
-73.50000000 -11.25000000 10.00000000
-70.00000000 -11.25000000 10.00000000
-66.50000000 -11.25000000 10.00000000
-63.00000000 -11.25000000 10.00000000
-59.50000000 -11.25000000 10.00000000
-56.00000000 -11.25000000 10.00000000
-52.50000000 -11.25000000 10.00000000
-49.00000000 -11.25000000 10.00000000
-45.50000000 -11.25000000 10.00000000
-42.00000000 -11.25000000 10.00000000
-38.50000000 -11.25000000 10.00000000
-35.00000000 -11.25000000 10.00000000
-31.50000000 -11.25000000 10.00000000
-28.00000000 -11.25000000 10.00000000
-24.50000000 -11.25000000 10.00000000
-21.00000000 -11.25000000 10.00000000
-17.50000000 -11.25000000 10.00000000
-14.00000000 -11.25000000 10.00000000
-10.50000000 -11.25000000 10.00000000
-7.00000000 -11.25000000 10.00000000
-3.50000000 -11.25000000 10.00000000
-87.50000000 -7.50000000 10.00000000
-84.00000000 -7.50000000 10.00000000
-80.50000000 -7.50000000 10.00000000
-77.00000000 -7.50000000 10.00000000
-73.50000000 -7.50000000 10.00000000
-70.00000000 -7.50000000 10.00000000
-66.50000000 -7.50000000 10.00000000
-63.00000000 -7.50000000 10.00000000
-59.50000000 -7.50000000 10.00000000
-56.00000000 -7.50000000 10.00000000
-52.50000000 -7.50000000 10.00000000
-49.00000000 -7.50000000 10.00000000
-45.50000000 -7.50000000 10.00000000
-42.00000000 -7.50000000 10.00000000
-38.50000000 -7.50000000 10.00000000
-35.00000000 -7.50000000 10.00000000
-31.50000000 -7.50000000 10.00000000
-28.00000000 -7.50000000 10.00000000
-24.50000000 -7.50000000 10.00000000
-21.00000000 -7.50000000 10.00000000
-17.50000000 -7.50000000 10.00000000
-14.00000000 -7.50000000 10.00000000
-10.50000000 -7.50000000 10.00000000
-7.00000000 -7.50000000 10.00000000
-3.50000000 -7.50000000 10.00000000
-87.50000000 -3.75000000 10.00000000
-84.00000000 -3.75000000 10.00000000
-80.50000000 -3.75000000 10.00000000
-77.00000000 -3.75000000 10.00000000
-73.50000000 -3.75000000 10.00000000
-70.00000000 -3.75000000 10.00000000
-66.50000000 -3.75000000 10.00000000
-63.00000000 -3.75000000 10.00000000
-59.50000000 -3.75000000 10.00000000
-56.00000000 -3.75000000 10.00000000
-52.50000000 -3.75000000 10.00000000
-49.00000000 -3.75000000 10.00000000
-45.50000000 -3.75000000 10.00000000
-42.00000000 -3.75000000 10.00000000
-38.50000000 -3.75000000 10.00000000
-35.00000000 -3.75000000 10.00000000
-31.50000000 -3.75000000 10.00000000
-28.00000000 -3.75000000 10.00000000
-24.50000000 -3.75000000 10.00000000
-21.00000000 -3.75000000 10.00000000
-17.50000000 -3.75000000 10.00000000
-14.00000000 -3.75000000 10.00000000
-10.50000000 -3.75000000 10.00000000
-7.00000000 -3.75000000 10.00000000
-3.50000000 -3.75000000 10.00000000
-87.50000000 0.00000000 10.00000000
-84.00000000 0.00000000 10.00000000
-80.50000000 0.00000000 10.00000000
-77.00000000 0.00000000 10.00000000
-73.50000000 0.00000000 10.00000000
-70.00000000 0.00000000 10.00000000
-66.50000000 0.00000000 10.00000000
-63.00000000 0.00000000 10.00000000
-59.50000000 0.00000000 10.00000000
-56.00000000 0.00000000 10.00000000
-52.50000000 0.00000000 10.00000000
-49.00000000 0.00000000 10.00000000
-45.50000000 0.00000000 10.00000000
-42.00000000 0.00000000 10.00000000
-38.50000000 0.00000000 10.00000000
-35.00000000 0.00000000 10.00000000
-31.50000000 0.00000000 10.00000000
-28.00000000 0.00000000 10.00000000
-24.50000000 0.00000000 10.00000000
-21.00000000 0.00000000 10.00000000
-17.50000000 0.00000000 10.00000000
-14.00000000 0.00000000 10.00000000
-10.50000000 0.00000000 10.00000000
-7.00000000 0.00000000 10.00000000
-3.50000000 0.00000000 10.00000000
-87.50000000 3.75000000 10.00000000
-84.00000000 3.75000000 10.00000000
-80.50000000 3.75000000 10.00000000
-77.00000000 3.75000000 10.00000000
-73.50000000 3.75000000 10.00000000
-70.00000000 3.75000000 10.00000000
-66.50000000 3.75000000 10.00000000
-63.00000000 3.75000000 10.00000000
-59.50000000 3.75000000 10.00000000
-56.00000000 3.75000000 10.00000000
-52.50000000 3.75000000 10.00000000
-49.00000000 3.75000000 10.00000000
-45.50000000 3.75000000 10.00000000
-42.00000000 3.75000000 10.00000000
-38.50000000 3.75000000 10.00000000
-35.00000000 3.75000000 10.00000000
-31.50000000 3.75000000 10.00000000
-28.00000000 3.75000000 10.00000000
-24.50000000 3.75000000 10.00000000
-21.00000000 3.75000000 10.00000000
-17.50000000 3.75000000 10.00000000
-14.00000000 3.75000000 10.00000000
-10.50000000 3.75000000 10.00000000
-7.00000000 3.75000000 10.00000000
-3.50000000 3.75000000 10.00000000
-87.50000000 7.50000000 10.00000000
-84.00000000 7.50000000 10.00000000
-80.50000000 7.50000000 10.00000000
-77.00000000 7.50000000 10.00000000
-73.50000000 7.50000000 10.00000000
-70.00000000 7.50000000 10.00000000
-66.50000000 7.50000000 10.00000000
-63.00000000 7.50000000 10.00000000
-59.50000000 7.50000000 10.00000000
-56.00000000 7.50000000 10.00000000
-52.50000000 7.50000000 10.00000000
-49.00000000 7.50000000 10.00000000
-45.50000000 7.50000000 10.00000000
-42.00000000 7.50000000 10.00000000
-38.50000000 7.50000000 10.00000000
-35.00000000 7.50000000 10.00000000
-31.50000000 7.50000000 10.00000000
-28.00000000 7.50000000 10.00000000
-24.50000000 7.50000000 10.00000000
-21.00000000 7.50000000 10.00000000
-17.50000000 7.50000000 10.00000000
-14.00000000 7.50000000 10.00000000
-10.50000000 7.50000000 10.00000000
-7.00000000 7.50000000 10.00000000
-3.50000000 7.50000000 10.00000000
-87.50000000 11.25000000 10.00000000
-84.00000000 11.25000000 10.00000000
-80.50000000 11.25000000 10.00000000
-77.00000000 11.25000000 10.00000000
-73.50000000 11.25000000 10.00000000
-70.00000000 11.25000000 10.00000000
-66.50000000 11.25000000 10.00000000
-63.00000000 11.25000000 10.00000000
-59.50000000 11.25000000 10.00000000
-56.00000000 11.25000000 10.00000000
-52.50000000 11.25000000 10.00000000
-49.00000000 11.25000000 10.00000000
-45.50000000 11.25000000 10.00000000
-42.00000000 11.25000000 10.00000000
-38.50000000 11.25000000 10.00000000
-35.00000000 11.25000000 10.00000000
-31.50000000 11.25000000 10.00000000
-28.00000000 11.25000000 10.00000000
-24.50000000 11.25000000 10.00000000
-21.00000000 11.25000000 10.00000000
-17.50000000 11.25000000 10.00000000
-14.00000000 11.25000000 10.00000000
-10.50000000 11.25000000 10.00000000
-7.00000000 11.25000000 10.00000000
-3.50000000 11.25000000 10.00000000
-87.50000000 15.00000000 10.00000000
-84.00000000 15.00000000 10.00000000
-80.50000000 15.00000000 10.00000000
-77.00000000 15.00000000 10.00000000
-73.50000000 15.00000000 10.00000000
-70.00000000 15.00000000 10.00000000
-66.50000000 15.00000000 10.00000000
-63.00000000 15.00000000 10.00000000
-59.50000000 15.00000000 10.00000000
-56.00000000 15.00000000 10.00000000
-52.50000000 15.00000000 10.00000000
-49.00000000 15.00000000 10.00000000
-45.50000000 15.00000000 10.00000000
-42.00000000 15.00000000 10.00000000
-38.50000000 15.00000000 10.00000000
-35.00000000 15.00000000 10.00000000
-31.50000000 15.00000000 10.00000000
-28.00000000 15.00000000 10.00000000
-24.50000000 15.00000000 10.00000000
-21.00000000 15.00000000 10.00000000
-17.50000000 15.00000000 10.00000000
-14.00000000 15.00000000 10.00000000
-10.50000000 15.00000000 10.00000000
-7.00000000 15.00000000 10.00000000
-3.50000000 15.00000000 10.00000000
-87.50000000 18.75000000 10.00000000
-84.00000000 18.75000000 10.00000000
-80.50000000 18.75000000 10.00000000
-77.00000000 18.75000000 10.00000000
-73.50000000 18.75000000 10.00000000
-70.00000000 18.75000000 10.00000000
-66.50000000 18.75000000 10.00000000
-63.00000000 18.75000000 10.00000000
-59.50000000 18.75000000 10.00000000
-56.00000000 18.75000000 10.00000000
-52.50000000 18.75000000 10.00000000
-49.00000000 18.75000000 10.00000000
-45.50000000 18.75000000 10.00000000
-42.00000000 18.75000000 10.00000000
-38.50000000 18.75000000 10.00000000
-35.00000000 18.75000000 10.00000000
-31.50000000 18.75000000 10.00000000
-28.00000000 18.75000000 10.00000000
-24.50000000 18.75000000 10.00000000
-21.00000000 18.75000000 10.00000000
-17.50000000 18.75000000 10.00000000
-14.00000000 18.75000000 10.00000000
-10.50000000 18.75000000 10.00000000
-7.00000000 18.75000000 10.00000000
-3.50000000 18.75000000 10.00000000
-87.50000000 22.50000000 10.00000000
-84.00000000 22.50000000 10.00000000
-80.50000000 22.50000000 10.00000000
-77.00000000 22.50000000 10.00000000
-73.50000000 22.50000000 10.00000000
-70.00000000 22.50000000 10.00000000
-66.50000000 22.50000000 10.00000000
-63.00000000 22.50000000 10.00000000
-59.50000000 22.50000000 10.00000000
-56.00000000 22.50000000 10.00000000
-52.50000000 22.50000000 10.00000000
-49.00000000 22.50000000 10.00000000
-45.50000000 22.50000000 10.00000000
-42.00000000 22.50000000 10.00000000
-38.50000000 22.50000000 10.00000000
-35.00000000 22.50000000 10.00000000
-31.50000000 22.50000000 10.00000000
-28.00000000 22.50000000 10.00000000
-24.50000000 22.50000000 10.00000000
-21.00000000 22.50000000 10.00000000
-17.50000000 22.50000000 10.00000000
-14.00000000 22.50000000 10.00000000
-10.50000000 22.50000000 10.00000000
-7.00000000 22.50000000 10.00000000
-3.50000000 22.50000000 10.00000000
-87.50000000 26.25000000 10.00000000
-84.00000000 26.25000000 10.00000000
-80.50000000 26.25000000 10.00000000
-77.00000000 26.25000000 10.00000000
-73.50000000 26.25000000 10.00000000
-70.00000000 26.25000000 10.00000000
-66.50000000 26.25000000 10.00000000
-63.00000000 26.25000000 10.00000000
-59.50000000 26.25000000 10.00000000
-56.00000000 26.25000000 10.00000000
-52.50000000 26.25000000 10.00000000
-49.00000000 26.25000000 10.00000000
-45.50000000 26.25000000 10.00000000
-42.00000000 26.25000000 10.00000000
-38.50000000 26.25000000 10.00000000
-35.00000000 26.25000000 10.00000000
-31.50000000 26.25000000 10.00000000
-28.00000000 26.25000000 10.00000000
-24.50000000 26.25000000 10.00000000
-21.00000000 26.25000000 10.00000000
-17.50000000 26.25000000 10.00000000
-14.00000000 26.25000000 10.00000000
-10.50000000 26.25000000 10.00000000
-7.00000000 26.25000000 10.00000000
-3.50000000 26.25000000 10.00000000
-87.50000000 30.00000000 10.00000000
-84.00000000 30.00000000 10.00000000
-80.50000000 30.00000000 10.00000000
-77.00000000 30.00000000 10.00000000
-73.50000000 30.00000000 10.00000000
-70.00000000 30.00000000 10.00000000
-66.50000000 30.00000000 10.00000000
-63.00000000 30.00000000 10.00000000
-59.50000000 30.00000000 10.00000000
-56.00000000 30.00000000 10.00000000
-52.50000000 30.00000000 10.00000000
-49.00000000 30.00000000 10.00000000
-45.50000000 30.00000000 10.00000000
-42.00000000 30.00000000 10.00000000
-38.50000000 30.00000000 10.00000000
-35.00000000 30.00000000 10.00000000
-31.50000000 30.00000000 10.00000000
-28.00000000 30.00000000 10.00000000
-24.50000000 30.00000000 10.00000000
-21.00000000 30.00000000 10.00000000
-17.50000000 30.00000000 10.00000000
-14.00000000 30.00000000 10.00000000
-10.50000000 30.00000000 10.00000000
-7.00000000 30.00000000 10.00000000
-3.50000000 30.00000000 10.00000000
-87.50000000 33.75000000 10.00000000
-84.00000000 33.75000000 10.00000000
-80.50000000 33.75000000 10.00000000
-77.00000000 33.75000000 10.00000000
-73.50000000 33.75000000 10.00000000
-70.00000000 33.75000000 10.00000000
-66.50000000 33.75000000 10.00000000
-63.00000000 33.75000000 10.00000000
-59.50000000 33.75000000 10.00000000
-56.00000000 33.75000000 10.00000000
-52.50000000 33.75000000 10.00000000
-49.00000000 33.75000000 10.00000000
-45.50000000 33.75000000 10.00000000
-42.00000000 33.75000000 10.00000000
-38.50000000 33.75000000 10.00000000
-35.00000000 33.75000000 10.00000000
-31.50000000 33.75000000 10.00000000
-28.00000000 33.75000000 10.00000000
-24.50000000 33.75000000 10.00000000
-21.00000000 33.75000000 10.00000000
-17.50000000 33.75000000 10.00000000
-14.00000000 33.75000000 10.00000000
-10.50000000 33.75000000 10.00000000
-7.00000000 33.75000000 10.00000000
-3.50000000 33.75000000 10.00000000
-87.50000000 37.50000000 10.00000000
-84.00000000 37.50000000 10.00000000
-80.50000000 37.50000000 10.00000000
-77.00000000 37.50000000 10.00000000
-73.50000000 37.50000000 10.00000000
-70.00000000 37.50000000 10.00000000
-66.50000000 37.50000000 10.00000000
-63.00000000 37.50000000 10.00000000
-59.50000000 37.50000000 10.00000000
-56.00000000 37.50000000 10.00000000
-52.50000000 37.50000000 10.00000000
-49.00000000 37.50000000 10.00000000
-45.50000000 37.50000000 10.00000000
-42.00000000 37.50000000 10.00000000
-38.50000000 37.50000000 10.00000000
-35.00000000 37.50000000 10.00000000
-31.50000000 37.50000000 10.00000000
-28.00000000 37.50000000 10.00000000
-24.50000000 37.50000000 10.00000000
-21.00000000 37.50000000 10.00000000
-17.50000000 37.50000000 10.00000000
-14.00000000 37.50000000 10.00000000
-10.50000000 37.50000000 10.00000000
-7.00000000 37.50000000 10.00000000
-3.50000000 37.50000000 10.00000000
-85.00000000 -35.00000000 12.00000000
-81.60000000 -35.00000000 12.00000000
-78.20000000 -35.00000000 12.00000000
-74.80000000 -35.00000000 12.00000000
-71.40000000 -35.00000000 12.00000000
-68.00000000 -35.00000000 12.00000000
-64.60000000 -35.00000000 12.00000000
-61.20000000 -35.00000000 12.00000000
-57.80000000 -35.00000000 12.00000000
-54.40000000 -35.00000000 12.00000000
-51.00000000 -35.00000000 12.00000000
-47.60000000 -35.00000000 12.00000000
-44.20000000 -35.00000000 12.00000000
-40.80000000 -35.00000000 12.00000000
-37.40000000 -35.00000000 12.00000000
-34.00000000 -35.00000000 12.00000000
-30.60000000 -35.00000000 12.00000000
-27.20000000 -35.00000000 12.00000000
-23.80000000 -35.00000000 12.00000000
-20.40000000 -35.00000000 12.00000000
-17.00000000 -35.00000000 12.00000000
-13.60000000 -35.00000000 12.00000000
-10.20000000 -35.00000000 12.00000000
-6.80000000 -35.00000000 12.00000000
-3.40000000 -35.00000000 12.00000000
0.00000000 -35.00000000 12.00000000
-85.00000000 -31.50000000 12.00000000
-81.60000000 -31.50000000 12.00000000
-78.20000000 -31.50000000 12.00000000
-74.80000000 -31.50000000 12.00000000
-71.40000000 -31.50000000 12.00000000
-68.00000000 -31.50000000 12.00000000
-64.60000000 -31.50000000 12.00000000
-61.20000000 -31.50000000 12.00000000
-57.80000000 -31.50000000 12.00000000
-54.40000000 -31.50000000 12.00000000
-51.00000000 -31.50000000 12.00000000
-47.60000000 -31.50000000 12.00000000
-44.20000000 -31.50000000 12.00000000
-40.80000000 -31.50000000 12.00000000
-37.40000000 -31.50000000 12.00000000
-34.00000000 -31.50000000 12.00000000
-30.60000000 -31.50000000 12.00000000
-27.20000000 -31.50000000 12.00000000
-23.80000000 -31.50000000 12.00000000
-20.40000000 -31.50000000 12.00000000
-17.00000000 -31.50000000 12.00000000
-13.60000000 -31.50000000 12.00000000
-10.20000000 -31.50000000 12.00000000
-6.80000000 -31.50000000 12.00000000
-3.40000000 -31.50000000 12.00000000
0.00000000 -31.50000000 12.00000000
-85.00000000 -28.00000000 12.00000000
-81.60000000 -28.00000000 12.00000000
-78.20000000 -28.00000000 12.00000000
-74.80000000 -28.00000000 12.00000000
-71.40000000 -28.00000000 12.00000000
-68.00000000 -28.00000000 12.00000000
-64.60000000 -28.00000000 12.00000000
-61.20000000 -28.00000000 12.00000000
-57.80000000 -28.00000000 12.00000000
-54.40000000 -28.00000000 12.00000000
-51.00000000 -28.00000000 12.00000000
-47.60000000 -28.00000000 12.00000000
-44.20000000 -28.00000000 12.00000000
-40.80000000 -28.00000000 12.00000000
-37.40000000 -28.00000000 12.00000000
-34.00000000 -28.00000000 12.00000000
-30.60000000 -28.00000000 12.00000000
-27.20000000 -28.00000000 12.00000000
-23.80000000 -28.00000000 12.00000000
-20.40000000 -28.00000000 12.00000000
-17.00000000 -28.00000000 12.00000000
-13.60000000 -28.00000000 12.00000000
-10.20000000 -28.00000000 12.00000000
-6.80000000 -28.00000000 12.00000000
-3.40000000 -28.00000000 12.00000000
0.00000000 -28.00000000 12.00000000
-85.00000000 -24.50000000 12.00000000
-81.60000000 -24.50000000 12.00000000
-78.20000000 -24.50000000 12.00000000
-74.80000000 -24.50000000 12.00000000
-71.40000000 -24.50000000 12.00000000
-68.00000000 -24.50000000 12.00000000
-64.60000000 -24.50000000 12.00000000
-61.20000000 -24.50000000 12.00000000
-57.80000000 -24.50000000 12.00000000
-54.40000000 -24.50000000 12.00000000
-51.00000000 -24.50000000 12.00000000
-47.60000000 -24.50000000 12.00000000
-44.20000000 -24.50000000 12.00000000
-40.80000000 -24.50000000 12.00000000
-37.40000000 -24.50000000 12.00000000
-34.00000000 -24.50000000 12.00000000
-30.60000000 -24.50000000 12.00000000
-27.20000000 -24.50000000 12.00000000
-23.80000000 -24.50000000 12.00000000
-20.40000000 -24.50000000 12.00000000
-17.00000000 -24.50000000 12.00000000
-13.60000000 -24.50000000 12.00000000
-10.20000000 -24.50000000 12.00000000
-6.80000000 -24.50000000 12.00000000
-3.40000000 -24.50000000 12.00000000
0.00000000 -24.50000000 12.00000000
-85.00000000 -21.00000000 12.00000000
-81.60000000 -21.00000000 12.00000000
-78.20000000 -21.00000000 12.00000000
-74.80000000 -21.00000000 12.00000000
-71.40000000 -21.00000000 12.00000000
-68.00000000 -21.00000000 12.00000000
-64.60000000 -21.00000000 12.00000000
-61.20000000 -21.00000000 12.00000000
-57.80000000 -21.00000000 12.00000000
-54.40000000 -21.00000000 12.00000000
-51.00000000 -21.00000000 12.00000000
-47.60000000 -21.00000000 12.00000000
-44.20000000 -21.00000000 12.00000000
-40.80000000 -21.00000000 12.00000000
-37.40000000 -21.00000000 12.00000000
-34.00000000 -21.00000000 12.00000000
-30.60000000 -21.00000000 12.00000000
-27.20000000 -21.00000000 12.00000000
-23.80000000 -21.00000000 12.00000000
-20.40000000 -21.00000000 12.00000000
-17.00000000 -21.00000000 12.00000000
-13.60000000 -21.00000000 12.00000000
-10.20000000 -21.00000000 12.00000000
-6.80000000 -21.00000000 12.00000000
-3.40000000 -21.00000000 12.00000000
0.00000000 -21.00000000 12.00000000
-85.00000000 -17.50000000 12.00000000
-81.60000000 -17.50000000 12.00000000
-78.20000000 -17.50000000 12.00000000
-74.80000000 -17.50000000 12.00000000
-71.40000000 -17.50000000 12.00000000
-68.00000000 -17.50000000 12.00000000
-64.60000000 -17.50000000 12.00000000
-61.20000000 -17.50000000 12.00000000
-57.80000000 -17.50000000 12.00000000
-54.40000000 -17.50000000 12.00000000
-51.00000000 -17.50000000 12.00000000
-47.60000000 -17.50000000 12.00000000
-44.20000000 -17.50000000 12.00000000
-40.80000000 -17.50000000 12.00000000
-37.40000000 -17.50000000 12.00000000
-34.00000000 -17.50000000 12.00000000
-30.60000000 -17.50000000 12.00000000
-27.20000000 -17.50000000 12.00000000
-23.80000000 -17.50000000 12.00000000
-20.40000000 -17.50000000 12.00000000
-17.00000000 -17.50000000 12.00000000
-13.60000000 -17.50000000 12.00000000
-10.20000000 -17.50000000 12.00000000
-6.80000000 -17.50000000 12.00000000
-3.40000000 -17.50000000 12.00000000
0.00000000 -17.50000000 12.00000000
-85.00000000 -14.00000000 12.00000000
-81.60000000 -14.00000000 12.00000000
-78.20000000 -14.00000000 12.00000000
-74.80000000 -14.00000000 12.00000000
-71.40000000 -14.00000000 12.00000000
-68.00000000 -14.00000000 12.00000000
-64.60000000 -14.00000000 12.00000000
-61.20000000 -14.00000000 12.00000000
-57.80000000 -14.00000000 12.00000000
-54.40000000 -14.00000000 12.00000000
-51.00000000 -14.00000000 12.00000000
-47.60000000 -14.00000000 12.00000000
-44.20000000 -14.00000000 12.00000000
-40.80000000 -14.00000000 12.00000000
-37.40000000 -14.00000000 12.00000000
-34.00000000 -14.00000000 12.00000000
-30.60000000 -14.00000000 12.00000000
-27.20000000 -14.00000000 12.00000000
-23.80000000 -14.00000000 12.00000000
-20.40000000 -14.00000000 12.00000000
-17.00000000 -14.00000000 12.00000000
-13.60000000 -14.00000000 12.00000000
-10.20000000 -14.00000000 12.00000000
-6.80000000 -14.00000000 12.00000000
-3.40000000 -14.00000000 12.00000000
0.00000000 -14.00000000 12.00000000
-85.00000000 -10.50000000 12.00000000
-81.60000000 -10.50000000 12.00000000
-78.20000000 -10.50000000 12.00000000
-74.80000000 -10.50000000 12.00000000
-71.40000000 -10.50000000 12.00000000
-68.00000000 -10.50000000 12.00000000
-64.60000000 -10.50000000 12.00000000
-61.20000000 -10.50000000 12.00000000
-57.80000000 -10.50000000 12.00000000
-54.40000000 -10.50000000 12.00000000
-51.00000000 -10.50000000 12.00000000
-47.60000000 -10.50000000 12.00000000
-44.20000000 -10.50000000 12.00000000
-40.80000000 -10.50000000 12.00000000
-37.40000000 -10.50000000 12.00000000
-34.00000000 -10.50000000 12.00000000
-30.60000000 -10.50000000 12.00000000
-27.20000000 -10.50000000 12.00000000
-23.80000000 -10.50000000 12.00000000
-20.40000000 -10.50000000 12.00000000
-17.00000000 -10.50000000 12.00000000
-13.60000000 -10.50000000 12.00000000
-10.20000000 -10.50000000 12.00000000
-6.80000000 -10.50000000 12.00000000
-3.40000000 -10.50000000 12.00000000
0.00000000 -10.50000000 12.00000000
-85.00000000 -7.00000000 12.00000000
-81.60000000 -7.00000000 12.00000000
-78.20000000 -7.00000000 12.00000000
-74.80000000 -7.00000000 12.00000000
-71.40000000 -7.00000000 12.00000000
-68.00000000 -7.00000000 12.00000000
-64.60000000 -7.00000000 12.00000000
-61.20000000 -7.00000000 12.00000000
-57.80000000 -7.00000000 12.00000000
-54.40000000 -7.00000000 12.00000000
-51.00000000 -7.00000000 12.00000000
-47.60000000 -7.00000000 12.00000000
-44.20000000 -7.00000000 12.00000000
-40.80000000 -7.00000000 12.00000000
-37.40000000 -7.00000000 12.00000000
-34.00000000 -7.00000000 12.00000000
-30.60000000 -7.00000000 12.00000000
-27.20000000 -7.00000000 12.00000000
-23.80000000 -7.00000000 12.00000000
-20.40000000 -7.00000000 12.00000000
-17.00000000 -7.00000000 12.00000000
-13.60000000 -7.00000000 12.00000000
-10.20000000 -7.00000000 12.00000000
-6.80000000 -7.00000000 12.00000000
-3.40000000 -7.00000000 12.00000000
0.00000000 -7.00000000 12.00000000
-85.00000000 -3.50000000 12.00000000
-81.60000000 -3.50000000 12.00000000
-78.20000000 -3.50000000 12.00000000
-74.80000000 -3.50000000 12.00000000
-71.40000000 -3.50000000 12.00000000
-68.00000000 -3.50000000 12.00000000
-64.60000000 -3.50000000 12.00000000
-61.20000000 -3.50000000 12.00000000
-57.80000000 -3.50000000 12.00000000
-54.40000000 -3.50000000 12.00000000
-51.00000000 -3.50000000 12.00000000
-47.60000000 -3.50000000 12.00000000
-44.20000000 -3.50000000 12.00000000
-40.80000000 -3.50000000 12.00000000
-37.40000000 -3.50000000 12.00000000
-34.00000000 -3.50000000 12.00000000
-30.60000000 -3.50000000 12.00000000
-27.20000000 -3.50000000 12.00000000
-23.80000000 -3.50000000 12.00000000
-20.40000000 -3.50000000 12.00000000
-17.00000000 -3.50000000 12.00000000
-13.60000000 -3.50000000 12.00000000
-10.20000000 -3.50000000 12.00000000
-6.80000000 -3.50000000 12.00000000
-3.40000000 -3.50000000 12.00000000
0.00000000 -3.50000000 12.00000000
-85.00000000 0.00000000 12.00000000
-81.60000000 0.00000000 12.00000000
-78.20000000 0.00000000 12.00000000
-74.80000000 0.00000000 12.00000000
-71.40000000 0.00000000 12.00000000
-68.00000000 0.00000000 12.00000000
-64.60000000 0.00000000 12.00000000
-61.20000000 0.00000000 12.00000000
-57.80000000 0.00000000 12.00000000
-54.40000000 0.00000000 12.00000000
-51.00000000 0.00000000 12.00000000
-47.60000000 0.00000000 12.00000000
-44.20000000 0.00000000 12.00000000
-40.80000000 0.00000000 12.00000000
-37.40000000 0.00000000 12.00000000
-34.00000000 0.00000000 12.00000000
-30.60000000 0.00000000 12.00000000
-27.20000000 0.00000000 12.00000000
-23.80000000 0.00000000 12.00000000
-20.40000000 0.00000000 12.00000000
-17.00000000 0.00000000 12.00000000
-13.60000000 0.00000000 12.00000000
-10.20000000 0.00000000 12.00000000
-6.80000000 0.00000000 12.00000000
-3.40000000 0.00000000 12.00000000
0.00000000 0.00000000 12.00000000
-85.00000000 3.50000000 12.00000000
-81.60000000 3.50000000 12.00000000
-78.20000000 3.50000000 12.00000000
-74.80000000 3.50000000 12.00000000
-71.40000000 3.50000000 12.00000000
-68.00000000 3.50000000 12.00000000
-64.60000000 3.50000000 12.00000000
-61.20000000 3.50000000 12.00000000
-57.80000000 3.50000000 12.00000000
-54.40000000 3.50000000 12.00000000
-51.00000000 3.50000000 12.00000000
-47.60000000 3.50000000 12.00000000
-44.20000000 3.50000000 12.00000000
-40.80000000 3.50000000 12.00000000
-37.40000000 3.50000000 12.00000000
-34.00000000 3.50000000 12.00000000
-30.60000000 3.50000000 12.00000000
-27.20000000 3.50000000 12.00000000
-23.80000000 3.50000000 12.00000000
-20.40000000 3.50000000 12.00000000
-17.00000000 3.50000000 12.00000000
-13.60000000 3.50000000 12.00000000
-10.20000000 3.50000000 12.00000000
-6.80000000 3.50000000 12.00000000
-3.40000000 3.50000000 12.00000000
0.00000000 3.50000000 12.00000000
-85.00000000 7.00000000 12.00000000
-81.60000000 7.00000000 12.00000000
-78.20000000 7.00000000 12.00000000
-74.80000000 7.00000000 12.00000000
-71.40000000 7.00000000 12.00000000
-68.00000000 7.00000000 12.00000000
-64.60000000 7.00000000 12.00000000
-61.20000000 7.00000000 12.00000000
-57.80000000 7.00000000 12.00000000
-54.40000000 7.00000000 12.00000000
-51.00000000 7.00000000 12.00000000
-47.60000000 7.00000000 12.00000000
-44.20000000 7.00000000 12.00000000
-40.80000000 7.00000000 12.00000000
-37.40000000 7.00000000 12.00000000
-34.00000000 7.00000000 12.00000000
-30.60000000 7.00000000 12.00000000
-27.20000000 7.00000000 12.00000000
-23.80000000 7.00000000 12.00000000
-20.40000000 7.00000000 12.00000000
-17.00000000 7.00000000 12.00000000
-13.60000000 7.00000000 12.00000000
-10.20000000 7.00000000 12.00000000
-6.80000000 7.00000000 12.00000000
-3.40000000 7.00000000 12.00000000
0.00000000 7.00000000 12.00000000
-85.00000000 10.50000000 12.00000000
-81.60000000 10.50000000 12.00000000
-78.20000000 10.50000000 12.00000000
-74.80000000 10.50000000 12.00000000
-71.40000000 10.50000000 12.00000000
-68.00000000 10.50000000 12.00000000
-64.60000000 10.50000000 12.00000000
-61.20000000 10.50000000 12.00000000
-57.80000000 10.50000000 12.00000000
-54.40000000 10.50000000 12.00000000
-51.00000000 10.50000000 12.00000000
-47.60000000 10.50000000 12.00000000
-44.20000000 10.50000000 12.00000000
-40.80000000 10.50000000 12.00000000
-37.40000000 10.50000000 12.00000000
-34.00000000 10.50000000 12.00000000
-30.60000000 10.50000000 12.00000000
-27.20000000 10.50000000 12.00000000
-23.80000000 10.50000000 12.00000000
-20.40000000 10.50000000 12.00000000
-17.00000000 10.50000000 12.00000000
-13.60000000 10.50000000 12.00000000
-10.20000000 10.50000000 12.00000000
-6.80000000 10.50000000 12.00000000
-3.40000000 10.50000000 12.00000000
0.00000000 10.50000000 12.00000000
-85.00000000 14.00000000 12.00000000
-81.60000000 14.00000000 12.00000000
-78.20000000 14.00000000 12.00000000
-74.80000000 14.00000000 12.00000000
-71.40000000 14.00000000 12.00000000
-68.00000000 14.00000000 12.00000000
-64.60000000 14.00000000 12.00000000
-61.20000000 14.00000000 12.00000000
-57.80000000 14.00000000 12.00000000
-54.40000000 14.00000000 12.00000000
-51.00000000 14.00000000 12.00000000
-47.60000000 14.00000000 12.00000000
-44.20000000 14.00000000 12.00000000
-40.80000000 14.00000000 12.00000000
-37.40000000 14.00000000 12.00000000
-34.00000000 14.00000000 12.00000000
-30.60000000 14.00000000 12.00000000
-27.20000000 14.00000000 12.00000000
-23.80000000 14.00000000 12.00000000
-20.40000000 14.00000000 12.00000000
-17.00000000 14.00000000 12.00000000
-13.60000000 14.00000000 12.00000000
-10.20000000 14.00000000 12.00000000
-6.80000000 14.00000000 12.00000000
-3.40000000 14.00000000 12.00000000
0.00000000 14.00000000 12.00000000
-85.00000000 17.50000000 12.00000000
-81.60000000 17.50000000 12.00000000
-78.20000000 17.50000000 12.00000000
-74.80000000 17.50000000 12.00000000
-71.40000000 17.50000000 12.00000000
-68.00000000 17.50000000 12.00000000
-64.60000000 17.50000000 12.00000000
-61.20000000 17.50000000 12.00000000
-57.80000000 17.50000000 12.00000000
-54.40000000 17.50000000 12.00000000
-51.00000000 17.50000000 12.00000000
-47.60000000 17.50000000 12.00000000
-44.20000000 17.50000000 12.00000000
-40.80000000 17.50000000 12.00000000
-37.40000000 17.50000000 12.00000000
-34.00000000 17.50000000 12.00000000
-30.60000000 17.50000000 12.00000000
-27.20000000 17.50000000 12.00000000
-23.80000000 17.50000000 12.00000000
-20.40000000 17.50000000 12.00000000
-17.00000000 17.50000000 12.00000000
-13.60000000 17.50000000 12.00000000
-10.20000000 17.50000000 12.00000000
-6.80000000 17.50000000 12.00000000
-3.40000000 17.50000000 12.00000000
0.00000000 17.50000000 12.00000000
-85.00000000 21.00000000 12.00000000
-81.60000000 21.00000000 12.00000000
-78.20000000 21.00000000 12.00000000
-74.80000000 21.00000000 12.00000000
-71.40000000 21.00000000 12.00000000
-68.00000000 21.00000000 12.00000000
-64.60000000 21.00000000 12.00000000
-61.20000000 21.00000000 12.00000000
-57.80000000 21.00000000 12.00000000
-54.40000000 21.00000000 12.00000000
-51.00000000 21.00000000 12.00000000
-47.60000000 21.00000000 12.00000000
-44.20000000 21.00000000 12.00000000
-40.80000000 21.00000000 12.00000000
-37.40000000 21.00000000 12.00000000
-34.00000000 21.00000000 12.00000000
-30.60000000 21.00000000 12.00000000
-27.20000000 21.00000000 12.00000000
-23.80000000 21.00000000 12.00000000
-20.40000000 21.00000000 12.00000000
-17.00000000 21.00000000 12.00000000
-13.60000000 21.00000000 12.00000000
-10.20000000 21.00000000 12.00000000
-6.80000000 21.00000000 12.00000000
-3.40000000 21.00000000 12.00000000
0.00000000 21.00000000 12.00000000
-85.00000000 24.50000000 12.00000000
-81.60000000 24.50000000 12.00000000
-78.20000000 24.50000000 12.00000000
-74.80000000 24.50000000 12.00000000
-71.40000000 24.50000000 12.00000000
-68.00000000 24.50000000 12.00000000
-64.60000000 24.50000000 12.00000000
-61.20000000 24.50000000 12.00000000
-57.80000000 24.50000000 12.00000000
-54.40000000 24.50000000 12.00000000
-51.00000000 24.50000000 12.00000000
-47.60000000 24.50000000 12.00000000
-44.20000000 24.50000000 12.00000000
-40.80000000 24.50000000 12.00000000
-37.40000000 24.50000000 12.00000000
-34.00000000 24.50000000 12.00000000
-30.60000000 24.50000000 12.00000000
-27.20000000 24.50000000 12.00000000
-23.80000000 24.50000000 12.00000000
-20.40000000 24.50000000 12.00000000
-17.00000000 24.50000000 12.00000000
-13.60000000 24.50000000 12.00000000
-10.20000000 24.50000000 12.00000000
-6.80000000 24.50000000 12.00000000
-3.40000000 24.50000000 12.00000000
0.00000000 24.50000000 12.00000000
-85.00000000 28.00000000 12.00000000
-81.60000000 28.00000000 12.00000000
-78.20000000 28.00000000 12.00000000
-74.80000000 28.00000000 12.00000000
-71.40000000 28.00000000 12.00000000
-68.00000000 28.00000000 12.00000000
-64.60000000 28.00000000 12.00000000
-61.20000000 28.00000000 12.00000000
-57.80000000 28.00000000 12.00000000
-54.40000000 28.00000000 12.00000000
-51.00000000 28.00000000 12.00000000
-47.60000000 28.00000000 12.00000000
-44.20000000 28.00000000 12.00000000
-40.80000000 28.00000000 12.00000000
-37.40000000 28.00000000 12.00000000
-34.00000000 28.00000000 12.00000000
-30.60000000 28.00000000 12.00000000
-27.20000000 28.00000000 12.00000000
-23.80000000 28.00000000 12.00000000
-20.40000000 28.00000000 12.00000000
-17.00000000 28.00000000 12.00000000
-13.60000000 28.00000000 12.00000000
-10.20000000 28.00000000 12.00000000
-6.80000000 28.00000000 12.00000000
-3.40000000 28.00000000 12.00000000
0.00000000 28.00000000 12.00000000
-85.00000000 31.50000000 12.00000000
-81.60000000 31.50000000 12.00000000
-78.20000000 31.50000000 12.00000000
-74.80000000 31.50000000 12.00000000
-71.40000000 31.50000000 12.00000000
-68.00000000 31.50000000 12.00000000
-64.60000000 31.50000000 12.00000000
-61.20000000 31.50000000 12.00000000
-57.80000000 31.50000000 12.00000000
-54.40000000 31.50000000 12.00000000
-51.00000000 31.50000000 12.00000000
-47.60000000 31.50000000 12.00000000
-44.20000000 31.50000000 12.00000000
-40.80000000 31.50000000 12.00000000
-37.40000000 31.50000000 12.00000000
-34.00000000 31.50000000 12.00000000
-30.60000000 31.50000000 12.00000000
-27.20000000 31.50000000 12.00000000
-23.80000000 31.50000000 12.00000000
-20.40000000 31.50000000 12.00000000
-17.00000000 31.50000000 12.00000000
-13.60000000 31.50000000 12.00000000
-10.20000000 31.50000000 12.00000000
-6.80000000 31.50000000 12.00000000
-3.40000000 31.50000000 12.00000000
0.00000000 31.50000000 12.00000000
-85.00000000 35.00000000 12.00000000
-81.60000000 35.00000000 12.00000000
-78.20000000 35.00000000 12.00000000
-74.80000000 35.00000000 12.00000000
-71.40000000 35.00000000 12.00000000
-68.00000000 35.00000000 12.00000000
-64.60000000 35.00000000 12.00000000
-61.20000000 35.00000000 12.00000000
-57.80000000 35.00000000 12.00000000
-54.40000000 35.00000000 12.00000000
-51.00000000 35.00000000 12.00000000
-47.60000000 35.00000000 12.00000000
-44.20000000 35.00000000 12.00000000
-40.80000000 35.00000000 12.00000000
-37.40000000 35.00000000 12.00000000
-34.00000000 35.00000000 12.00000000
-30.60000000 35.00000000 12.00000000
-27.20000000 35.00000000 12.00000000
-23.80000000 35.00000000 12.00000000
-20.40000000 35.00000000 12.00000000
-17.00000000 35.00000000 12.00000000
-13.60000000 35.00000000 12.00000000
-10.20000000 35.00000000 12.00000000
-6.80000000 35.00000000 12.00000000
-3.40000000 35.00000000 12.00000000
0.00000000 35.00000000 12.00000000
-82.50000000 -32.50000000 14.00000000
-79.20000000 -32.50000000 14.00000000
-75.90000000 -32.50000000 14.00000000
-72.60000000 -32.50000000 14.00000000
-69.30000000 -32.50000000 14.00000000
-66.00000000 -32.50000000 14.00000000
-62.70000000 -32.50000000 14.00000000
-59.40000000 -32.50000000 14.00000000
-56.10000000 -32.50000000 14.00000000
-52.80000000 -32.50000000 14.00000000
-49.50000000 -32.50000000 14.00000000
-46.20000000 -32.50000000 14.00000000
-42.90000000 -32.50000000 14.00000000
-39.60000000 -32.50000000 14.00000000
-36.30000000 -32.50000000 14.00000000
-33.00000000 -32.50000000 14.00000000
-29.70000000 -32.50000000 14.00000000
-26.40000000 -32.50000000 14.00000000
-23.10000000 -32.50000000 14.00000000
-19.80000000 -32.50000000 14.00000000
-16.50000000 -32.50000000 14.00000000
-13.20000000 -32.50000000 14.00000000
-9.90000000 -32.50000000 14.00000000
-6.60000000 -32.50000000 14.00000000
-3.30000000 -32.50000000 14.00000000
0.00000000 -32.50000000 14.00000000
-82.50000000 -29.25000000 14.00000000
-79.20000000 -29.25000000 14.00000000
-75.90000000 -29.25000000 14.00000000
-72.60000000 -29.25000000 14.00000000
-69.30000000 -29.25000000 14.00000000
-66.00000000 -29.25000000 14.00000000
-62.70000000 -29.25000000 14.00000000
-59.40000000 -29.25000000 14.00000000
-56.10000000 -29.25000000 14.00000000
-52.80000000 -29.25000000 14.00000000
-49.50000000 -29.25000000 14.00000000
-46.20000000 -29.25000000 14.00000000
-42.90000000 -29.25000000 14.00000000
-39.60000000 -29.25000000 14.00000000
-36.30000000 -29.25000000 14.00000000
-33.00000000 -29.25000000 14.00000000
-29.70000000 -29.25000000 14.00000000
-26.40000000 -29.25000000 14.00000000
-23.10000000 -29.25000000 14.00000000
-19.80000000 -29.25000000 14.00000000
-16.50000000 -29.25000000 14.00000000
-13.20000000 -29.25000000 14.00000000
-9.90000000 -29.25000000 14.00000000
-6.60000000 -29.25000000 14.00000000
-3.30000000 -29.25000000 14.00000000
0.00000000 -29.25000000 14.00000000
-82.50000000 -26.00000000 14.00000000
-79.20000000 -26.00000000 14.00000000
-75.90000000 -26.00000000 14.00000000
-72.60000000 -26.00000000 14.00000000
-69.30000000 -26.00000000 14.00000000
-66.00000000 -26.00000000 14.00000000
-62.70000000 -26.00000000 14.00000000
-59.40000000 -26.00000000 14.00000000
-56.10000000 -26.00000000 14.00000000
-52.80000000 -26.00000000 14.00000000
-49.50000000 -26.00000000 14.00000000
-46.20000000 -26.00000000 14.00000000
-42.90000000 -26.00000000 14.00000000
-39.60000000 -26.00000000 14.00000000
-36.30000000 -26.00000000 14.00000000
-33.00000000 -26.00000000 14.00000000
-29.70000000 -26.00000000 14.00000000
-26.40000000 -26.00000000 14.00000000
-23.10000000 -26.00000000 14.00000000
-19.80000000 -26.00000000 14.00000000
-16.50000000 -26.00000000 14.00000000
-13.20000000 -26.00000000 14.00000000
-9.90000000 -26.00000000 14.00000000
-6.60000000 -26.00000000 14.00000000
-3.30000000 -26.00000000 14.00000000
0.00000000 -26.00000000 14.00000000
-82.50000000 -22.75000000 14.00000000
-79.20000000 -22.75000000 14.00000000
-75.90000000 -22.75000000 14.00000000
-72.60000000 -22.75000000 14.00000000
-69.30000000 -22.75000000 14.00000000
-66.00000000 -22.75000000 14.00000000
-62.70000000 -22.75000000 14.00000000
-59.40000000 -22.75000000 14.00000000
-56.10000000 -22.75000000 14.00000000
-52.80000000 -22.75000000 14.00000000
-49.50000000 -22.75000000 14.00000000
-46.20000000 -22.75000000 14.00000000
-42.90000000 -22.75000000 14.00000000
-39.60000000 -22.75000000 14.00000000
-36.30000000 -22.75000000 14.00000000
-33.00000000 -22.75000000 14.00000000
-29.70000000 -22.75000000 14.00000000
-26.40000000 -22.75000000 14.00000000
-23.10000000 -22.75000000 14.00000000
-19.80000000 -22.75000000 14.00000000
-16.50000000 -22.75000000 14.00000000
-13.20000000 -22.75000000 14.00000000
-9.90000000 -22.75000000 14.00000000
-6.60000000 -22.75000000 14.00000000
-3.30000000 -22.75000000 14.00000000
0.00000000 -22.75000000 14.00000000
-82.50000000 -19.50000000 14.00000000
-79.20000000 -19.50000000 14.00000000
-75.90000000 -19.50000000 14.00000000
-72.60000000 -19.50000000 14.00000000
-69.30000000 -19.50000000 14.00000000
-66.00000000 -19.50000000 14.00000000
-62.70000000 -19.50000000 14.00000000
-59.40000000 -19.50000000 14.00000000
-56.10000000 -19.50000000 14.00000000
-52.80000000 -19.50000000 14.00000000
-49.50000000 -19.50000000 14.00000000
-46.20000000 -19.50000000 14.00000000
-42.90000000 -19.50000000 14.00000000
-39.60000000 -19.50000000 14.00000000
-36.30000000 -19.50000000 14.00000000
-33.00000000 -19.50000000 14.00000000
-29.70000000 -19.50000000 14.00000000
-26.40000000 -19.50000000 14.00000000
-23.10000000 -19.50000000 14.00000000
-19.80000000 -19.50000000 14.00000000
-16.50000000 -19.50000000 14.00000000
-13.20000000 -19.50000000 14.00000000
-9.90000000 -19.50000000 14.00000000
-6.60000000 -19.50000000 14.00000000
-3.30000000 -19.50000000 14.00000000
0.00000000 -19.50000000 14.00000000
-82.50000000 -16.25000000 14.00000000
-79.20000000 -16.25000000 14.00000000
-75.90000000 -16.25000000 14.00000000
-72.60000000 -16.25000000 14.00000000
-69.30000000 -16.25000000 14.00000000
-66.00000000 -16.25000000 14.00000000
-62.70000000 -16.25000000 14.00000000
-59.40000000 -16.25000000 14.00000000
-56.10000000 -16.25000000 14.00000000
-52.80000000 -16.25000000 14.00000000
-49.50000000 -16.25000000 14.00000000
-46.20000000 -16.25000000 14.00000000
-42.90000000 -16.25000000 14.00000000
-39.60000000 -16.25000000 14.00000000
-36.30000000 -16.25000000 14.00000000
-33.00000000 -16.25000000 14.00000000
-29.70000000 -16.25000000 14.00000000
-26.40000000 -16.25000000 14.00000000
-23.10000000 -16.25000000 14.00000000
-19.80000000 -16.25000000 14.00000000
-16.50000000 -16.25000000 14.00000000
-13.20000000 -16.25000000 14.00000000
-9.90000000 -16.25000000 14.00000000
-6.60000000 -16.25000000 14.00000000
-3.30000000 -16.25000000 14.00000000
0.00000000 -16.25000000 14.00000000
-82.50000000 -13.00000000 14.00000000
-79.20000000 -13.00000000 14.00000000
-75.90000000 -13.00000000 14.00000000
-72.60000000 -13.00000000 14.00000000
-69.30000000 -13.00000000 14.00000000
-66.00000000 -13.00000000 14.00000000
-62.70000000 -13.00000000 14.00000000
-59.40000000 -13.00000000 14.00000000
-56.10000000 -13.00000000 14.00000000
-52.80000000 -13.00000000 14.00000000
-49.50000000 -13.00000000 14.00000000
-46.20000000 -13.00000000 14.00000000
-42.90000000 -13.00000000 14.00000000
-39.60000000 -13.00000000 14.00000000
-36.30000000 -13.00000000 14.00000000
-33.00000000 -13.00000000 14.00000000
-29.70000000 -13.00000000 14.00000000
-26.40000000 -13.00000000 14.00000000
-23.10000000 -13.00000000 14.00000000
-19.80000000 -13.00000000 14.00000000
-16.50000000 -13.00000000 14.00000000
-13.20000000 -13.00000000 14.00000000
-9.90000000 -13.00000000 14.00000000
-6.60000000 -13.00000000 14.00000000
-3.30000000 -13.00000000 14.00000000
0.00000000 -13.00000000 14.00000000
-82.50000000 -9.75000000 14.00000000
-79.20000000 -9.75000000 14.00000000
-75.90000000 -9.75000000 14.00000000
-72.60000000 -9.75000000 14.00000000
-69.30000000 -9.75000000 14.00000000
-66.00000000 -9.75000000 14.00000000
-62.70000000 -9.75000000 14.00000000
-59.40000000 -9.75000000 14.00000000
-56.10000000 -9.75000000 14.00000000
-52.80000000 -9.75000000 14.00000000
-49.50000000 -9.75000000 14.00000000
-46.20000000 -9.75000000 14.00000000
-42.90000000 -9.75000000 14.00000000
-39.60000000 -9.75000000 14.00000000
-36.30000000 -9.75000000 14.00000000
-33.00000000 -9.75000000 14.00000000
-29.70000000 -9.75000000 14.00000000
-26.40000000 -9.75000000 14.00000000
-23.10000000 -9.75000000 14.00000000
-19.80000000 -9.75000000 14.00000000
-16.50000000 -9.75000000 14.00000000
-13.20000000 -9.75000000 14.00000000
-9.90000000 -9.75000000 14.00000000
-6.60000000 -9.75000000 14.00000000
-3.30000000 -9.75000000 14.00000000
0.00000000 -9.75000000 14.00000000
-82.50000000 -6.50000000 14.00000000
-79.20000000 -6.50000000 14.00000000
-75.90000000 -6.50000000 14.00000000
-72.60000000 -6.50000000 14.00000000
-69.30000000 -6.50000000 14.00000000
-66.00000000 -6.50000000 14.00000000
-62.70000000 -6.50000000 14.00000000
-59.40000000 -6.50000000 14.00000000
-56.10000000 -6.50000000 14.00000000
-52.80000000 -6.50000000 14.00000000
-49.50000000 -6.50000000 14.00000000
-46.20000000 -6.50000000 14.00000000
-42.90000000 -6.50000000 14.00000000
-39.60000000 -6.50000000 14.00000000
-36.30000000 -6.50000000 14.00000000
-33.00000000 -6.50000000 14.00000000
-29.70000000 -6.50000000 14.00000000
-26.40000000 -6.50000000 14.00000000
-23.10000000 -6.50000000 14.00000000
-19.80000000 -6.50000000 14.00000000
-16.50000000 -6.50000000 14.00000000
-13.20000000 -6.50000000 14.00000000
-9.90000000 -6.50000000 14.00000000
-6.60000000 -6.50000000 14.00000000
-3.30000000 -6.50000000 14.00000000
0.00000000 -6.50000000 14.00000000
-82.50000000 -3.25000000 14.00000000
-79.20000000 -3.25000000 14.00000000
-75.90000000 -3.25000000 14.00000000
-72.60000000 -3.25000000 14.00000000
-69.30000000 -3.25000000 14.00000000
-66.00000000 -3.25000000 14.00000000
-62.70000000 -3.25000000 14.00000000
-59.40000000 -3.25000000 14.00000000
-56.10000000 -3.25000000 14.00000000
-52.80000000 -3.25000000 14.00000000
-49.50000000 -3.25000000 14.00000000
-46.20000000 -3.25000000 14.00000000
-42.90000000 -3.25000000 14.00000000
-39.60000000 -3.25000000 14.00000000
-36.30000000 -3.25000000 14.00000000
-33.00000000 -3.25000000 14.00000000
-29.70000000 -3.25000000 14.00000000
-26.40000000 -3.25000000 14.00000000
-23.10000000 -3.25000000 14.00000000
-19.80000000 -3.25000000 14.00000000
-16.50000000 -3.25000000 14.00000000
-13.20000000 -3.25000000 14.00000000
-9.90000000 -3.25000000 14.00000000
-6.60000000 -3.25000000 14.00000000
-3.30000000 -3.25000000 14.00000000
0.00000000 -3.25000000 14.00000000
-82.50000000 0.00000000 14.00000000
-79.20000000 0.00000000 14.00000000
-75.90000000 0.00000000 14.00000000
-72.60000000 0.00000000 14.00000000
-69.30000000 0.00000000 14.00000000
-66.00000000 0.00000000 14.00000000
-62.70000000 0.00000000 14.00000000
-59.40000000 0.00000000 14.00000000
-56.10000000 0.00000000 14.00000000
-52.80000000 0.00000000 14.00000000
-49.50000000 0.00000000 14.00000000
-46.20000000 0.00000000 14.00000000
-42.90000000 0.00000000 14.00000000
-39.60000000 0.00000000 14.00000000
-36.30000000 0.00000000 14.00000000
-33.00000000 0.00000000 14.00000000
-29.70000000 0.00000000 14.00000000
-26.40000000 0.00000000 14.00000000
-23.10000000 0.00000000 14.00000000
-19.80000000 0.00000000 14.00000000
-16.50000000 0.00000000 14.00000000
-13.20000000 0.00000000 14.00000000
-9.90000000 0.00000000 14.00000000
-6.60000000 0.00000000 14.00000000
-3.30000000 0.00000000 14.00000000
0.00000000 0.00000000 14.00000000
-82.50000000 3.25000000 14.00000000
-79.20000000 3.25000000 14.00000000
-75.90000000 3.25000000 14.00000000
-72.60000000 3.25000000 14.00000000
-69.30000000 3.25000000 14.00000000
-66.00000000 3.25000000 14.00000000
-62.70000000 3.25000000 14.00000000
-59.40000000 3.25000000 14.00000000
-56.10000000 3.25000000 14.00000000
-52.80000000 3.25000000 14.00000000
-49.50000000 3.25000000 14.00000000
-46.20000000 3.25000000 14.00000000
-42.90000000 3.25000000 14.00000000
-39.60000000 3.25000000 14.00000000
-36.30000000 3.25000000 14.00000000
-33.00000000 3.25000000 14.00000000
-29.70000000 3.25000000 14.00000000
-26.40000000 3.25000000 14.00000000
-23.10000000 3.25000000 14.00000000
-19.80000000 3.25000000 14.00000000
-16.50000000 3.25000000 14.00000000
-13.20000000 3.25000000 14.00000000
-9.90000000 3.25000000 14.00000000
-6.60000000 3.25000000 14.00000000
-3.30000000 3.25000000 14.00000000
0.00000000 3.25000000 14.00000000
-82.50000000 6.50000000 14.00000000
-79.20000000 6.50000000 14.00000000
-75.90000000 6.50000000 14.00000000
-72.60000000 6.50000000 14.00000000
-69.30000000 6.50000000 14.00000000
-66.00000000 6.50000000 14.00000000
-62.70000000 6.50000000 14.00000000
-59.40000000 6.50000000 14.00000000
-56.10000000 6.50000000 14.00000000
-52.80000000 6.50000000 14.00000000
-49.50000000 6.50000000 14.00000000
-46.20000000 6.50000000 14.00000000
-42.90000000 6.50000000 14.00000000
-39.60000000 6.50000000 14.00000000
-36.30000000 6.50000000 14.00000000
-33.00000000 6.50000000 14.00000000
-29.70000000 6.50000000 14.00000000
-26.40000000 6.50000000 14.00000000
-23.10000000 6.50000000 14.00000000
-19.80000000 6.50000000 14.00000000
-16.50000000 6.50000000 14.00000000
-13.20000000 6.50000000 14.00000000
-9.90000000 6.50000000 14.00000000
-6.60000000 6.50000000 14.00000000
-3.30000000 6.50000000 14.00000000
0.00000000 6.50000000 14.00000000
-82.50000000 9.75000000 14.00000000
-79.20000000 9.75000000 14.00000000
-75.90000000 9.75000000 14.00000000
-72.60000000 9.75000000 14.00000000
-69.30000000 9.75000000 14.00000000
-66.00000000 9.75000000 14.00000000
-62.70000000 9.75000000 14.00000000
-59.40000000 9.75000000 14.00000000
-56.10000000 9.75000000 14.00000000
-52.80000000 9.75000000 14.00000000
-49.50000000 9.75000000 14.00000000
-46.20000000 9.75000000 14.00000000
-42.90000000 9.75000000 14.00000000
-39.60000000 9.75000000 14.00000000
-36.30000000 9.75000000 14.00000000
-33.00000000 9.75000000 14.00000000
-29.70000000 9.75000000 14.00000000
-26.40000000 9.75000000 14.00000000
-23.10000000 9.75000000 14.00000000
-19.80000000 9.75000000 14.00000000
-16.50000000 9.75000000 14.00000000
-13.20000000 9.75000000 14.00000000
-9.90000000 9.75000000 14.00000000
-6.60000000 9.75000000 14.00000000
-3.30000000 9.75000000 14.00000000
0.00000000 9.75000000 14.00000000
-82.50000000 13.00000000 14.00000000
-79.20000000 13.00000000 14.00000000
-75.90000000 13.00000000 14.00000000
-72.60000000 13.00000000 14.00000000
-69.30000000 13.00000000 14.00000000
-66.00000000 13.00000000 14.00000000
-62.70000000 13.00000000 14.00000000
-59.40000000 13.00000000 14.00000000
-56.10000000 13.00000000 14.00000000
-52.80000000 13.00000000 14.00000000
-49.50000000 13.00000000 14.00000000
-46.20000000 13.00000000 14.00000000
-42.90000000 13.00000000 14.00000000
-39.60000000 13.00000000 14.00000000
-36.30000000 13.00000000 14.00000000
-33.00000000 13.00000000 14.00000000
-29.70000000 13.00000000 14.00000000
-26.40000000 13.00000000 14.00000000
-23.10000000 13.00000000 14.00000000
-19.80000000 13.00000000 14.00000000
-16.50000000 13.00000000 14.00000000
-13.20000000 13.00000000 14.00000000
-9.90000000 13.00000000 14.00000000
-6.60000000 13.00000000 14.00000000
-3.30000000 13.00000000 14.00000000
0.00000000 13.00000000 14.00000000
-82.50000000 16.25000000 14.00000000
-79.20000000 16.25000000 14.00000000
-75.90000000 16.25000000 14.00000000
-72.60000000 16.25000000 14.00000000
-69.30000000 16.25000000 14.00000000
-66.00000000 16.25000000 14.00000000
-62.70000000 16.25000000 14.00000000
-59.40000000 16.25000000 14.00000000
-56.10000000 16.25000000 14.00000000
-52.80000000 16.25000000 14.00000000
-49.50000000 16.25000000 14.00000000
-46.20000000 16.25000000 14.00000000
-42.90000000 16.25000000 14.00000000
-39.60000000 16.25000000 14.00000000
-36.30000000 16.25000000 14.00000000
-33.00000000 16.25000000 14.00000000
-29.70000000 16.25000000 14.00000000
-26.40000000 16.25000000 14.00000000
-23.10000000 16.25000000 14.00000000
-19.80000000 16.25000000 14.00000000
-16.50000000 16.25000000 14.00000000
-13.20000000 16.25000000 14.00000000
-9.90000000 16.25000000 14.00000000
-6.60000000 16.25000000 14.00000000
-3.30000000 16.25000000 14.00000000
0.00000000 16.25000000 14.00000000
-82.50000000 19.50000000 14.00000000
-79.20000000 19.50000000 14.00000000
-75.90000000 19.50000000 14.00000000
-72.60000000 19.50000000 14.00000000
-69.30000000 19.50000000 14.00000000
-66.00000000 19.50000000 14.00000000
-62.70000000 19.50000000 14.00000000
-59.40000000 19.50000000 14.00000000
-56.10000000 19.50000000 14.00000000
-52.80000000 19.50000000 14.00000000
-49.50000000 19.50000000 14.00000000
-46.20000000 19.50000000 14.00000000
-42.90000000 19.50000000 14.00000000
-39.60000000 19.50000000 14.00000000
-36.30000000 19.50000000 14.00000000
-33.00000000 19.50000000 14.00000000
-29.70000000 19.50000000 14.00000000
-26.40000000 19.50000000 14.00000000
-23.10000000 19.50000000 14.00000000
-19.80000000 19.50000000 14.00000000
-16.50000000 19.50000000 14.00000000
-13.20000000 19.50000000 14.00000000
-9.90000000 19.50000000 14.00000000
-6.60000000 19.50000000 14.00000000
-3.30000000 19.50000000 14.00000000
0.00000000 19.50000000 14.00000000
-82.50000000 22.75000000 14.00000000
-79.20000000 22.75000000 14.00000000
-75.90000000 22.75000000 14.00000000
-72.60000000 22.75000000 14.00000000
-69.30000000 22.75000000 14.00000000
-66.00000000 22.75000000 14.00000000
-62.70000000 22.75000000 14.00000000
-59.40000000 22.75000000 14.00000000
-56.10000000 22.75000000 14.00000000
-52.80000000 22.75000000 14.00000000
-49.50000000 22.75000000 14.00000000
-46.20000000 22.75000000 14.00000000
-42.90000000 22.75000000 14.00000000
-39.60000000 22.75000000 14.00000000
-36.30000000 22.75000000 14.00000000
-33.00000000 22.75000000 14.00000000
-29.70000000 22.75000000 14.00000000
-26.40000000 22.75000000 14.00000000
-23.10000000 22.75000000 14.00000000
-19.80000000 22.75000000 14.00000000
-16.50000000 22.75000000 14.00000000
-13.20000000 22.75000000 14.00000000
-9.90000000 22.75000000 14.00000000
-6.60000000 22.75000000 14.00000000
-3.30000000 22.75000000 14.00000000
0.00000000 22.75000000 14.00000000
-82.50000000 26.00000000 14.00000000
-79.20000000 26.00000000 14.00000000
-75.90000000 26.00000000 14.00000000
-72.60000000 26.00000000 14.00000000
-69.30000000 26.00000000 14.00000000
-66.00000000 26.00000000 14.00000000
-62.70000000 26.00000000 14.00000000
-59.40000000 26.00000000 14.00000000
-56.10000000 26.00000000 14.00000000
-52.80000000 26.00000000 14.00000000
-49.50000000 26.00000000 14.00000000
-46.20000000 26.00000000 14.00000000
-42.90000000 26.00000000 14.00000000
-39.60000000 26.00000000 14.00000000
-36.30000000 26.00000000 14.00000000
-33.00000000 26.00000000 14.00000000
-29.70000000 26.00000000 14.00000000
-26.40000000 26.00000000 14.00000000
-23.10000000 26.00000000 14.00000000
-19.80000000 26.00000000 14.00000000
-16.50000000 26.00000000 14.00000000
-13.20000000 26.00000000 14.00000000
-9.90000000 26.00000000 14.00000000
-6.60000000 26.00000000 14.00000000
-3.30000000 26.00000000 14.00000000
0.00000000 26.00000000 14.00000000
-82.50000000 29.25000000 14.00000000
-79.20000000 29.25000000 14.00000000
-75.90000000 29.25000000 14.00000000
-72.60000000 29.25000000 14.00000000
-69.30000000 29.25000000 14.00000000
-66.00000000 29.25000000 14.00000000
-62.70000000 29.25000000 14.00000000
-59.40000000 29.25000000 14.00000000
-56.10000000 29.25000000 14.00000000
-52.80000000 29.25000000 14.00000000
-49.50000000 29.25000000 14.00000000
-46.20000000 29.25000000 14.00000000
-42.90000000 29.25000000 14.00000000
-39.60000000 29.25000000 14.00000000
-36.30000000 29.25000000 14.00000000
-33.00000000 29.25000000 14.00000000
-29.70000000 29.25000000 14.00000000
-26.40000000 29.25000000 14.00000000
-23.10000000 29.25000000 14.00000000
-19.80000000 29.25000000 14.00000000
-16.50000000 29.25000000 14.00000000
-13.20000000 29.25000000 14.00000000
-9.90000000 29.25000000 14.00000000
-6.60000000 29.25000000 14.00000000
-3.30000000 29.25000000 14.00000000
0.00000000 29.25000000 14.00000000
-82.50000000 32.50000000 14.00000000
-79.20000000 32.50000000 14.00000000
-75.90000000 32.50000000 14.00000000
-72.60000000 32.50000000 14.00000000
-69.30000000 32.50000000 14.00000000
-66.00000000 32.50000000 14.00000000
-62.70000000 32.50000000 14.00000000
-59.40000000 32.50000000 14.00000000
-56.10000000 32.50000000 14.00000000
-52.80000000 32.50000000 14.00000000
-49.50000000 32.50000000 14.00000000
-46.20000000 32.50000000 14.00000000
-42.90000000 32.50000000 14.00000000
-39.60000000 32.50000000 14.00000000
-36.30000000 32.50000000 14.00000000
-33.00000000 32.50000000 14.00000000
-29.70000000 32.50000000 14.00000000
-26.40000000 32.50000000 14.00000000
-23.10000000 32.50000000 14.00000000
-19.80000000 32.50000000 14.00000000
-16.50000000 32.50000000 14.00000000
-13.20000000 32.50000000 14.00000000
-9.90000000 32.50000000 14.00000000
-6.60000000 32.50000000 14.00000000
-3.30000000 32.50000000 14.00000000
0.00000000 32.50000000 14.00000000
-80.00000000 -30.00000000 16.00000000
-76.80000000 -30.00000000 16.00000000
-73.60000000 -30.00000000 16.00000000
-70.40000000 -30.00000000 16.00000000
-67.20000000 -30.00000000 16.00000000
-64.00000000 -30.00000000 16.00000000
-60.80000000 -30.00000000 16.00000000
-57.60000000 -30.00000000 16.00000000
-54.40000000 -30.00000000 16.00000000
-51.20000000 -30.00000000 16.00000000
-48.00000000 -30.00000000 16.00000000
-44.80000000 -30.00000000 16.00000000
-41.60000000 -30.00000000 16.00000000
-38.40000000 -30.00000000 16.00000000
-35.20000000 -30.00000000 16.00000000
-32.00000000 -30.00000000 16.00000000
-28.80000000 -30.00000000 16.00000000
-25.60000000 -30.00000000 16.00000000
-22.40000000 -30.00000000 16.00000000
-19.20000000 -30.00000000 16.00000000
-16.00000000 -30.00000000 16.00000000
-12.80000000 -30.00000000 16.00000000
-9.60000000 -30.00000000 16.00000000
-6.40000000 -30.00000000 16.00000000
-3.20000000 -30.00000000 16.00000000
-80.00000000 -27.00000000 16.00000000
-76.80000000 -27.00000000 16.00000000
-73.60000000 -27.00000000 16.00000000
-70.40000000 -27.00000000 16.00000000
-67.20000000 -27.00000000 16.00000000
-64.00000000 -27.00000000 16.00000000
-60.80000000 -27.00000000 16.00000000
-57.60000000 -27.00000000 16.00000000
-54.40000000 -27.00000000 16.00000000
-51.20000000 -27.00000000 16.00000000
-48.00000000 -27.00000000 16.00000000
-44.80000000 -27.00000000 16.00000000
-41.60000000 -27.00000000 16.00000000
-38.40000000 -27.00000000 16.00000000
-35.20000000 -27.00000000 16.00000000
-32.00000000 -27.00000000 16.00000000
-28.80000000 -27.00000000 16.00000000
-25.60000000 -27.00000000 16.00000000
-22.40000000 -27.00000000 16.00000000
-19.20000000 -27.00000000 16.00000000
-16.00000000 -27.00000000 16.00000000
-12.80000000 -27.00000000 16.00000000
-9.60000000 -27.00000000 16.00000000
-6.40000000 -27.00000000 16.00000000
-3.20000000 -27.00000000 16.00000000
-80.00000000 -24.00000000 16.00000000
-76.80000000 -24.00000000 16.00000000
-73.60000000 -24.00000000 16.00000000
-70.40000000 -24.00000000 16.00000000
-67.20000000 -24.00000000 16.00000000
-64.00000000 -24.00000000 16.00000000
-60.80000000 -24.00000000 16.00000000
-57.60000000 -24.00000000 16.00000000
-54.40000000 -24.00000000 16.00000000
-51.20000000 -24.00000000 16.00000000
-48.00000000 -24.00000000 16.00000000
-44.80000000 -24.00000000 16.00000000
-41.60000000 -24.00000000 16.00000000
-38.40000000 -24.00000000 16.00000000
-35.20000000 -24.00000000 16.00000000
-32.00000000 -24.00000000 16.00000000
-28.80000000 -24.00000000 16.00000000
-25.60000000 -24.00000000 16.00000000
-22.40000000 -24.00000000 16.00000000
-19.20000000 -24.00000000 16.00000000
-16.00000000 -24.00000000 16.00000000
-12.80000000 -24.00000000 16.00000000
-9.60000000 -24.00000000 16.00000000
-6.40000000 -24.00000000 16.00000000
-3.20000000 -24.00000000 16.00000000
-80.00000000 -21.00000000 16.00000000
-76.80000000 -21.00000000 16.00000000
-73.60000000 -21.00000000 16.00000000
-70.40000000 -21.00000000 16.00000000
-67.20000000 -21.00000000 16.00000000
-64.00000000 -21.00000000 16.00000000
-60.80000000 -21.00000000 16.00000000
-57.60000000 -21.00000000 16.00000000
-54.40000000 -21.00000000 16.00000000
-51.20000000 -21.00000000 16.00000000
-48.00000000 -21.00000000 16.00000000
-44.80000000 -21.00000000 16.00000000
-41.60000000 -21.00000000 16.00000000
-38.40000000 -21.00000000 16.00000000
-35.20000000 -21.00000000 16.00000000
-32.00000000 -21.00000000 16.00000000
-28.80000000 -21.00000000 16.00000000
-25.60000000 -21.00000000 16.00000000
-22.40000000 -21.00000000 16.00000000
-19.20000000 -21.00000000 16.00000000
-16.00000000 -21.00000000 16.00000000
-12.80000000 -21.00000000 16.00000000
-9.60000000 -21.00000000 16.00000000
-6.40000000 -21.00000000 16.00000000
-3.20000000 -21.00000000 16.00000000
-80.00000000 -18.00000000 16.00000000
-76.80000000 -18.00000000 16.00000000
-73.60000000 -18.00000000 16.00000000
-70.40000000 -18.00000000 16.00000000
-67.20000000 -18.00000000 16.00000000
-64.00000000 -18.00000000 16.00000000
-60.80000000 -18.00000000 16.00000000
-57.60000000 -18.00000000 16.00000000
-54.40000000 -18.00000000 16.00000000
-51.20000000 -18.00000000 16.00000000
-48.00000000 -18.00000000 16.00000000
-44.80000000 -18.00000000 16.00000000
-41.60000000 -18.00000000 16.00000000
-38.40000000 -18.00000000 16.00000000
-35.20000000 -18.00000000 16.00000000
-32.00000000 -18.00000000 16.00000000
-28.80000000 -18.00000000 16.00000000
-25.60000000 -18.00000000 16.00000000
-22.40000000 -18.00000000 16.00000000
-19.20000000 -18.00000000 16.00000000
-16.00000000 -18.00000000 16.00000000
-12.80000000 -18.00000000 16.00000000
-9.60000000 -18.00000000 16.00000000
-6.40000000 -18.00000000 16.00000000
-3.20000000 -18.00000000 16.00000000
-80.00000000 -15.00000000 16.00000000
-76.80000000 -15.00000000 16.00000000
-73.60000000 -15.00000000 16.00000000
-70.40000000 -15.00000000 16.00000000
-67.20000000 -15.00000000 16.00000000
-64.00000000 -15.00000000 16.00000000
-60.80000000 -15.00000000 16.00000000
-57.60000000 -15.00000000 16.00000000
-54.40000000 -15.00000000 16.00000000
-51.20000000 -15.00000000 16.00000000
-48.00000000 -15.00000000 16.00000000
-44.80000000 -15.00000000 16.00000000
-41.60000000 -15.00000000 16.00000000
-38.40000000 -15.00000000 16.00000000
-35.20000000 -15.00000000 16.00000000
-32.00000000 -15.00000000 16.00000000
-28.80000000 -15.00000000 16.00000000
-25.60000000 -15.00000000 16.00000000
-22.40000000 -15.00000000 16.00000000
-19.20000000 -15.00000000 16.00000000
-16.00000000 -15.00000000 16.00000000
-12.80000000 -15.00000000 16.00000000
-9.60000000 -15.00000000 16.00000000
-6.40000000 -15.00000000 16.00000000
-3.20000000 -15.00000000 16.00000000
-80.00000000 -12.00000000 16.00000000
-76.80000000 -12.00000000 16.00000000
-73.60000000 -12.00000000 16.00000000
-70.40000000 -12.00000000 16.00000000
-67.20000000 -12.00000000 16.00000000
-64.00000000 -12.00000000 16.00000000
-60.80000000 -12.00000000 16.00000000
-57.60000000 -12.00000000 16.00000000
-54.40000000 -12.00000000 16.00000000
-51.20000000 -12.00000000 16.00000000
-48.00000000 -12.00000000 16.00000000
-44.80000000 -12.00000000 16.00000000
-41.60000000 -12.00000000 16.00000000
-38.40000000 -12.00000000 16.00000000
-35.20000000 -12.00000000 16.00000000
-32.00000000 -12.00000000 16.00000000
-28.80000000 -12.00000000 16.00000000
-25.60000000 -12.00000000 16.00000000
-22.40000000 -12.00000000 16.00000000
-19.20000000 -12.00000000 16.00000000
-16.00000000 -12.00000000 16.00000000
-12.80000000 -12.00000000 16.00000000
-9.60000000 -12.00000000 16.00000000
-6.40000000 -12.00000000 16.00000000
-3.20000000 -12.00000000 16.00000000
-80.00000000 -9.00000000 16.00000000
-76.80000000 -9.00000000 16.00000000
-73.60000000 -9.00000000 16.00000000
-70.40000000 -9.00000000 16.00000000
-67.20000000 -9.00000000 16.00000000
-64.00000000 -9.00000000 16.00000000
-60.80000000 -9.00000000 16.00000000
-57.60000000 -9.00000000 16.00000000
-54.40000000 -9.00000000 16.00000000
-51.20000000 -9.00000000 16.00000000
-48.00000000 -9.00000000 16.00000000
-44.80000000 -9.00000000 16.00000000
-41.60000000 -9.00000000 16.00000000
-38.40000000 -9.00000000 16.00000000
-35.20000000 -9.00000000 16.00000000
-32.00000000 -9.00000000 16.00000000
-28.80000000 -9.00000000 16.00000000
-25.60000000 -9.00000000 16.00000000
-22.40000000 -9.00000000 16.00000000
-19.20000000 -9.00000000 16.00000000
-16.00000000 -9.00000000 16.00000000
-12.80000000 -9.00000000 16.00000000
-9.60000000 -9.00000000 16.00000000
-6.40000000 -9.00000000 16.00000000
-3.20000000 -9.00000000 16.00000000
-80.00000000 -6.00000000 16.00000000
-76.80000000 -6.00000000 16.00000000
-73.60000000 -6.00000000 16.00000000
-70.40000000 -6.00000000 16.00000000
-67.20000000 -6.00000000 16.00000000
-64.00000000 -6.00000000 16.00000000
-60.80000000 -6.00000000 16.00000000
-57.60000000 -6.00000000 16.00000000
-54.40000000 -6.00000000 16.00000000
-51.20000000 -6.00000000 16.00000000
-48.00000000 -6.00000000 16.00000000
-44.80000000 -6.00000000 16.00000000
-41.60000000 -6.00000000 16.00000000
-38.40000000 -6.00000000 16.00000000
-35.20000000 -6.00000000 16.00000000
-32.00000000 -6.00000000 16.00000000
-28.80000000 -6.00000000 16.00000000
-25.60000000 -6.00000000 16.00000000
-22.40000000 -6.00000000 16.00000000
-19.20000000 -6.00000000 16.00000000
-16.00000000 -6.00000000 16.00000000
-12.80000000 -6.00000000 16.00000000
-9.60000000 -6.00000000 16.00000000
-6.40000000 -6.00000000 16.00000000
-3.20000000 -6.00000000 16.00000000
-80.00000000 -3.00000000 16.00000000
-76.80000000 -3.00000000 16.00000000
-73.60000000 -3.00000000 16.00000000
-70.40000000 -3.00000000 16.00000000
-67.20000000 -3.00000000 16.00000000
-64.00000000 -3.00000000 16.00000000
-60.80000000 -3.00000000 16.00000000
-57.60000000 -3.00000000 16.00000000
-54.40000000 -3.00000000 16.00000000
-51.20000000 -3.00000000 16.00000000
-48.00000000 -3.00000000 16.00000000
-44.80000000 -3.00000000 16.00000000
-41.60000000 -3.00000000 16.00000000
-38.40000000 -3.00000000 16.00000000
-35.20000000 -3.00000000 16.00000000
-32.00000000 -3.00000000 16.00000000
-28.80000000 -3.00000000 16.00000000
-25.60000000 -3.00000000 16.00000000
-22.40000000 -3.00000000 16.00000000
-19.20000000 -3.00000000 16.00000000
-16.00000000 -3.00000000 16.00000000
-12.80000000 -3.00000000 16.00000000
-9.60000000 -3.00000000 16.00000000
-6.40000000 -3.00000000 16.00000000
-3.20000000 -3.00000000 16.00000000
-80.00000000 0.00000000 16.00000000
-76.80000000 0.00000000 16.00000000
-73.60000000 0.00000000 16.00000000
-70.40000000 0.00000000 16.00000000
-67.20000000 0.00000000 16.00000000
-64.00000000 0.00000000 16.00000000
-60.80000000 0.00000000 16.00000000
-57.60000000 0.00000000 16.00000000
-54.40000000 0.00000000 16.00000000
-51.20000000 0.00000000 16.00000000
-48.00000000 0.00000000 16.00000000
-44.80000000 0.00000000 16.00000000
-41.60000000 0.00000000 16.00000000
-38.40000000 0.00000000 16.00000000
-35.20000000 0.00000000 16.00000000
-32.00000000 0.00000000 16.00000000
-28.80000000 0.00000000 16.00000000
-25.60000000 0.00000000 16.00000000
-22.40000000 0.00000000 16.00000000
-19.20000000 0.00000000 16.00000000
-16.00000000 0.00000000 16.00000000
-12.80000000 0.00000000 16.00000000
-9.60000000 0.00000000 16.00000000
-6.40000000 0.00000000 16.00000000
-3.20000000 0.00000000 16.00000000
-80.00000000 3.00000000 16.00000000
-76.80000000 3.00000000 16.00000000
-73.60000000 3.00000000 16.00000000
-70.40000000 3.00000000 16.00000000
-67.20000000 3.00000000 16.00000000
-64.00000000 3.00000000 16.00000000
-60.80000000 3.00000000 16.00000000
-57.60000000 3.00000000 16.00000000
-54.40000000 3.00000000 16.00000000
-51.20000000 3.00000000 16.00000000
-48.00000000 3.00000000 16.00000000
-44.80000000 3.00000000 16.00000000
-41.60000000 3.00000000 16.00000000
-38.40000000 3.00000000 16.00000000
-35.20000000 3.00000000 16.00000000
-32.00000000 3.00000000 16.00000000
-28.80000000 3.00000000 16.00000000
-25.60000000 3.00000000 16.00000000
-22.40000000 3.00000000 16.00000000
-19.20000000 3.00000000 16.00000000
-16.00000000 3.00000000 16.00000000
-12.80000000 3.00000000 16.00000000
-9.60000000 3.00000000 16.00000000
-6.40000000 3.00000000 16.00000000
-3.20000000 3.00000000 16.00000000
-80.00000000 6.00000000 16.00000000
-76.80000000 6.00000000 16.00000000
-73.60000000 6.00000000 16.00000000
-70.40000000 6.00000000 16.00000000
-67.20000000 6.00000000 16.00000000
-64.00000000 6.00000000 16.00000000
-60.80000000 6.00000000 16.00000000
-57.60000000 6.00000000 16.00000000
-54.40000000 6.00000000 16.00000000
-51.20000000 6.00000000 16.00000000
-48.00000000 6.00000000 16.00000000
-44.80000000 6.00000000 16.00000000
-41.60000000 6.00000000 16.00000000
-38.40000000 6.00000000 16.00000000
-35.20000000 6.00000000 16.00000000
-32.00000000 6.00000000 16.00000000
-28.80000000 6.00000000 16.00000000
-25.60000000 6.00000000 16.00000000
-22.40000000 6.00000000 16.00000000
-19.20000000 6.00000000 16.00000000
-16.00000000 6.00000000 16.00000000
-12.80000000 6.00000000 16.00000000
-9.60000000 6.00000000 16.00000000
-6.40000000 6.00000000 16.00000000
-3.20000000 6.00000000 16.00000000
-80.00000000 9.00000000 16.00000000
-76.80000000 9.00000000 16.00000000
-73.60000000 9.00000000 16.00000000
-70.40000000 9.00000000 16.00000000
-67.20000000 9.00000000 16.00000000
-64.00000000 9.00000000 16.00000000
-60.80000000 9.00000000 16.00000000
-57.60000000 9.00000000 16.00000000
-54.40000000 9.00000000 16.00000000
-51.20000000 9.00000000 16.00000000
-48.00000000 9.00000000 16.00000000
-44.80000000 9.00000000 16.00000000
-41.60000000 9.00000000 16.00000000
-38.40000000 9.00000000 16.00000000
-35.20000000 9.00000000 16.00000000
-32.00000000 9.00000000 16.00000000
-28.80000000 9.00000000 16.00000000
-25.60000000 9.00000000 16.00000000
-22.40000000 9.00000000 16.00000000
-19.20000000 9.00000000 16.00000000
-16.00000000 9.00000000 16.00000000
-12.80000000 9.00000000 16.00000000
-9.60000000 9.00000000 16.00000000
-6.40000000 9.00000000 16.00000000
-3.20000000 9.00000000 16.00000000
-80.00000000 12.00000000 16.00000000
-76.80000000 12.00000000 16.00000000
-73.60000000 12.00000000 16.00000000
-70.40000000 12.00000000 16.00000000
-67.20000000 12.00000000 16.00000000
-64.00000000 12.00000000 16.00000000
-60.80000000 12.00000000 16.00000000
-57.60000000 12.00000000 16.00000000
-54.40000000 12.00000000 16.00000000
-51.20000000 12.00000000 16.00000000
-48.00000000 12.00000000 16.00000000
-44.80000000 12.00000000 16.00000000
-41.60000000 12.00000000 16.00000000
-38.40000000 12.00000000 16.00000000
-35.20000000 12.00000000 16.00000000
-32.00000000 12.00000000 16.00000000
-28.80000000 12.00000000 16.00000000
-25.60000000 12.00000000 16.00000000
-22.40000000 12.00000000 16.00000000
-19.20000000 12.00000000 16.00000000
-16.00000000 12.00000000 16.00000000
-12.80000000 12.00000000 16.00000000
-9.60000000 12.00000000 16.00000000
-6.40000000 12.00000000 16.00000000
-3.20000000 12.00000000 16.00000000
-80.00000000 15.00000000 16.00000000
-76.80000000 15.00000000 16.00000000
-73.60000000 15.00000000 16.00000000
-70.40000000 15.00000000 16.00000000
-67.20000000 15.00000000 16.00000000
-64.00000000 15.00000000 16.00000000
-60.80000000 15.00000000 16.00000000
-57.60000000 15.00000000 16.00000000
-54.40000000 15.00000000 16.00000000
-51.20000000 15.00000000 16.00000000
-48.00000000 15.00000000 16.00000000
-44.80000000 15.00000000 16.00000000
-41.60000000 15.00000000 16.00000000
-38.40000000 15.00000000 16.00000000
-35.20000000 15.00000000 16.00000000
-32.00000000 15.00000000 16.00000000
-28.80000000 15.00000000 16.00000000
-25.60000000 15.00000000 16.00000000
-22.40000000 15.00000000 16.00000000
-19.20000000 15.00000000 16.00000000
-16.00000000 15.00000000 16.00000000
-12.80000000 15.00000000 16.00000000
-9.60000000 15.00000000 16.00000000
-6.40000000 15.00000000 16.00000000
-3.20000000 15.00000000 16.00000000
-80.00000000 18.00000000 16.00000000
-76.80000000 18.00000000 16.00000000
-73.60000000 18.00000000 16.00000000
-70.40000000 18.00000000 16.00000000
-67.20000000 18.00000000 16.00000000
-64.00000000 18.00000000 16.00000000
-60.80000000 18.00000000 16.00000000
-57.60000000 18.00000000 16.00000000
-54.40000000 18.00000000 16.00000000
-51.20000000 18.00000000 16.00000000
-48.00000000 18.00000000 16.00000000
-44.80000000 18.00000000 16.00000000
-41.60000000 18.00000000 16.00000000
-38.40000000 18.00000000 16.00000000
-35.20000000 18.00000000 16.00000000
-32.00000000 18.00000000 16.00000000
-28.80000000 18.00000000 16.00000000
-25.60000000 18.00000000 16.00000000
-22.40000000 18.00000000 16.00000000
-19.20000000 18.00000000 16.00000000
-16.00000000 18.00000000 16.00000000
-12.80000000 18.00000000 16.00000000
-9.60000000 18.00000000 16.00000000
-6.40000000 18.00000000 16.00000000
-3.20000000 18.00000000 16.00000000
-80.00000000 21.00000000 16.00000000
-76.80000000 21.00000000 16.00000000
-73.60000000 21.00000000 16.00000000
-70.40000000 21.00000000 16.00000000
-67.20000000 21.00000000 16.00000000
-64.00000000 21.00000000 16.00000000
-60.80000000 21.00000000 16.00000000
-57.60000000 21.00000000 16.00000000
-54.40000000 21.00000000 16.00000000
-51.20000000 21.00000000 16.00000000
-48.00000000 21.00000000 16.00000000
-44.80000000 21.00000000 16.00000000
-41.60000000 21.00000000 16.00000000
-38.40000000 21.00000000 16.00000000
-35.20000000 21.00000000 16.00000000
-32.00000000 21.00000000 16.00000000
-28.80000000 21.00000000 16.00000000
-25.60000000 21.00000000 16.00000000
-22.40000000 21.00000000 16.00000000
-19.20000000 21.00000000 16.00000000
-16.00000000 21.00000000 16.00000000
-12.80000000 21.00000000 16.00000000
-9.60000000 21.00000000 16.00000000
-6.40000000 21.00000000 16.00000000
-3.20000000 21.00000000 16.00000000
-80.00000000 24.00000000 16.00000000
-76.80000000 24.00000000 16.00000000
-73.60000000 24.00000000 16.00000000
-70.40000000 24.00000000 16.00000000
-67.20000000 24.00000000 16.00000000
-64.00000000 24.00000000 16.00000000
-60.80000000 24.00000000 16.00000000
-57.60000000 24.00000000 16.00000000
-54.40000000 24.00000000 16.00000000
-51.20000000 24.00000000 16.00000000
-48.00000000 24.00000000 16.00000000
-44.80000000 24.00000000 16.00000000
-41.60000000 24.00000000 16.00000000
-38.40000000 24.00000000 16.00000000
-35.20000000 24.00000000 16.00000000
-32.00000000 24.00000000 16.00000000
-28.80000000 24.00000000 16.00000000
-25.60000000 24.00000000 16.00000000
-22.40000000 24.00000000 16.00000000
-19.20000000 24.00000000 16.00000000
-16.00000000 24.00000000 16.00000000
-12.80000000 24.00000000 16.00000000
-9.60000000 24.00000000 16.00000000
-6.40000000 24.00000000 16.00000000
-3.20000000 24.00000000 16.00000000
-80.00000000 27.00000000 16.00000000
-76.80000000 27.00000000 16.00000000
-73.60000000 27.00000000 16.00000000
-70.40000000 27.00000000 16.00000000
-67.20000000 27.00000000 16.00000000
-64.00000000 27.00000000 16.00000000
-60.80000000 27.00000000 16.00000000
-57.60000000 27.00000000 16.00000000
-54.40000000 27.00000000 16.00000000
-51.20000000 27.00000000 16.00000000
-48.00000000 27.00000000 16.00000000
-44.80000000 27.00000000 16.00000000
-41.60000000 27.00000000 16.00000000
-38.40000000 27.00000000 16.00000000
-35.20000000 27.00000000 16.00000000
-32.00000000 27.00000000 16.00000000
-28.80000000 27.00000000 16.00000000
-25.60000000 27.00000000 16.00000000
-22.40000000 27.00000000 16.00000000
-19.20000000 27.00000000 16.00000000
-16.00000000 27.00000000 16.00000000
-12.80000000 27.00000000 16.00000000
-9.60000000 27.00000000 16.00000000
-6.40000000 27.00000000 16.00000000
-3.20000000 27.00000000 16.00000000
-80.00000000 30.00000000 16.00000000
-76.80000000 30.00000000 16.00000000
-73.60000000 30.00000000 16.00000000
-70.40000000 30.00000000 16.00000000
-67.20000000 30.00000000 16.00000000
-64.00000000 30.00000000 16.00000000
-60.80000000 30.00000000 16.00000000
-57.60000000 30.00000000 16.00000000
-54.40000000 30.00000000 16.00000000
-51.20000000 30.00000000 16.00000000
-48.00000000 30.00000000 16.00000000
-44.80000000 30.00000000 16.00000000
-41.60000000 30.00000000 16.00000000
-38.40000000 30.00000000 16.00000000
-35.20000000 30.00000000 16.00000000
-32.00000000 30.00000000 16.00000000
-28.80000000 30.00000000 16.00000000
-25.60000000 30.00000000 16.00000000
-22.40000000 30.00000000 16.00000000
-19.20000000 30.00000000 16.00000000
-16.00000000 30.00000000 16.00000000
-12.80000000 30.00000000 16.00000000
-9.60000000 30.00000000 16.00000000
-6.40000000 30.00000000 16.00000000
-3.20000000 30.00000000 16.00000000
-77.50000000 -27.50000000 18.00000000
-74.40000000 -27.50000000 18.00000000
-71.30000000 -27.50000000 18.00000000
-68.20000000 -27.50000000 18.00000000
-65.10000000 -27.50000000 18.00000000
-62.00000000 -27.50000000 18.00000000
-58.90000000 -27.50000000 18.00000000
-55.80000000 -27.50000000 18.00000000
-52.70000000 -27.50000000 18.00000000
-49.60000000 -27.50000000 18.00000000
-46.50000000 -27.50000000 18.00000000
-43.40000000 -27.50000000 18.00000000
-40.30000000 -27.50000000 18.00000000
-37.20000000 -27.50000000 18.00000000
-34.10000000 -27.50000000 18.00000000
-31.00000000 -27.50000000 18.00000000
-27.90000000 -27.50000000 18.00000000
-24.80000000 -27.50000000 18.00000000
-21.70000000 -27.50000000 18.00000000
-18.60000000 -27.50000000 18.00000000
-15.50000000 -27.50000000 18.00000000
-12.40000000 -27.50000000 18.00000000
-9.30000000 -27.50000000 18.00000000
-6.20000000 -27.50000000 18.00000000
-3.10000000 -27.50000000 18.00000000
0.00000000 -27.50000000 18.00000000
-77.50000000 -24.75000000 18.00000000
-74.40000000 -24.75000000 18.00000000
-71.30000000 -24.75000000 18.00000000
-68.20000000 -24.75000000 18.00000000
-65.10000000 -24.75000000 18.00000000
-62.00000000 -24.75000000 18.00000000
-58.90000000 -24.75000000 18.00000000
-55.80000000 -24.75000000 18.00000000
-52.70000000 -24.75000000 18.00000000
-49.60000000 -24.75000000 18.00000000
-46.50000000 -24.75000000 18.00000000
-43.40000000 -24.75000000 18.00000000
-40.30000000 -24.75000000 18.00000000
-37.20000000 -24.75000000 18.00000000
-34.10000000 -24.75000000 18.00000000
-31.00000000 -24.75000000 18.00000000
-27.90000000 -24.75000000 18.00000000
-24.80000000 -24.75000000 18.00000000
-21.70000000 -24.75000000 18.00000000
-18.60000000 -24.75000000 18.00000000
-15.50000000 -24.75000000 18.00000000
-12.40000000 -24.75000000 18.00000000
-9.30000000 -24.75000000 18.00000000
-6.20000000 -24.75000000 18.00000000
-3.10000000 -24.75000000 18.00000000
0.00000000 -24.75000000 18.00000000
-77.50000000 -22.00000000 18.00000000
-74.40000000 -22.00000000 18.00000000
-71.30000000 -22.00000000 18.00000000
-68.20000000 -22.00000000 18.00000000
-65.10000000 -22.00000000 18.00000000
-62.00000000 -22.00000000 18.00000000
-58.90000000 -22.00000000 18.00000000
-55.80000000 -22.00000000 18.00000000
-52.70000000 -22.00000000 18.00000000
-49.60000000 -22.00000000 18.00000000
-46.50000000 -22.00000000 18.00000000
-43.40000000 -22.00000000 18.00000000
-40.30000000 -22.00000000 18.00000000
-37.20000000 -22.00000000 18.00000000
-34.10000000 -22.00000000 18.00000000
-31.00000000 -22.00000000 18.00000000
-27.90000000 -22.00000000 18.00000000
-24.80000000 -22.00000000 18.00000000
-21.70000000 -22.00000000 18.00000000
-18.60000000 -22.00000000 18.00000000
-15.50000000 -22.00000000 18.00000000
-12.40000000 -22.00000000 18.00000000
-9.30000000 -22.00000000 18.00000000
-6.20000000 -22.00000000 18.00000000
-3.10000000 -22.00000000 18.00000000
0.00000000 -22.00000000 18.00000000
-77.50000000 -19.25000000 18.00000000
-74.40000000 -19.25000000 18.00000000
-71.30000000 -19.25000000 18.00000000
-68.20000000 -19.25000000 18.00000000
-65.10000000 -19.25000000 18.00000000
-62.00000000 -19.25000000 18.00000000
-58.90000000 -19.25000000 18.00000000
-55.80000000 -19.25000000 18.00000000
-52.70000000 -19.25000000 18.00000000
-49.60000000 -19.25000000 18.00000000
-46.50000000 -19.25000000 18.00000000
-43.40000000 -19.25000000 18.00000000
-40.30000000 -19.25000000 18.00000000
-37.20000000 -19.25000000 18.00000000
-34.10000000 -19.25000000 18.00000000
-31.00000000 -19.25000000 18.00000000
-27.90000000 -19.25000000 18.00000000
-24.80000000 -19.25000000 18.00000000
-21.70000000 -19.25000000 18.00000000
-18.60000000 -19.25000000 18.00000000
-15.50000000 -19.25000000 18.00000000
-12.40000000 -19.25000000 18.00000000
-9.30000000 -19.25000000 18.00000000
-6.20000000 -19.25000000 18.00000000
-3.10000000 -19.25000000 18.00000000
0.00000000 -19.25000000 18.00000000
-77.50000000 -16.50000000 18.00000000
-74.40000000 -16.50000000 18.00000000
-71.30000000 -16.50000000 18.00000000
-68.20000000 -16.50000000 18.00000000
-65.10000000 -16.50000000 18.00000000
-62.00000000 -16.50000000 18.00000000
-58.90000000 -16.50000000 18.00000000
-55.80000000 -16.50000000 18.00000000
-52.70000000 -16.50000000 18.00000000
-49.60000000 -16.50000000 18.00000000
-46.50000000 -16.50000000 18.00000000
-43.40000000 -16.50000000 18.00000000
-40.30000000 -16.50000000 18.00000000
-37.20000000 -16.50000000 18.00000000
-34.10000000 -16.50000000 18.00000000
-31.00000000 -16.50000000 18.00000000
-27.90000000 -16.50000000 18.00000000
-24.80000000 -16.50000000 18.00000000
-21.70000000 -16.50000000 18.00000000
-18.60000000 -16.50000000 18.00000000
-15.50000000 -16.50000000 18.00000000
-12.40000000 -16.50000000 18.00000000
-9.30000000 -16.50000000 18.00000000
-6.20000000 -16.50000000 18.00000000
-3.10000000 -16.50000000 18.00000000
0.00000000 -16.50000000 18.00000000
-77.50000000 -13.75000000 18.00000000
-74.40000000 -13.75000000 18.00000000
-71.30000000 -13.75000000 18.00000000
-68.20000000 -13.75000000 18.00000000
-65.10000000 -13.75000000 18.00000000
-62.00000000 -13.75000000 18.00000000
-58.90000000 -13.75000000 18.00000000
-55.80000000 -13.75000000 18.00000000
-52.70000000 -13.75000000 18.00000000
-49.60000000 -13.75000000 18.00000000
-46.50000000 -13.75000000 18.00000000
-43.40000000 -13.75000000 18.00000000
-40.30000000 -13.75000000 18.00000000
-37.20000000 -13.75000000 18.00000000
-34.10000000 -13.75000000 18.00000000
-31.00000000 -13.75000000 18.00000000
-27.90000000 -13.75000000 18.00000000
-24.80000000 -13.75000000 18.00000000
-21.70000000 -13.75000000 18.00000000
-18.60000000 -13.75000000 18.00000000
-15.50000000 -13.75000000 18.00000000
-12.40000000 -13.75000000 18.00000000
-9.30000000 -13.75000000 18.00000000
-6.20000000 -13.75000000 18.00000000
-3.10000000 -13.75000000 18.00000000
0.00000000 -13.75000000 18.00000000
-77.50000000 -11.00000000 18.00000000
-74.40000000 -11.00000000 18.00000000
-71.30000000 -11.00000000 18.00000000
-68.20000000 -11.00000000 18.00000000
-65.10000000 -11.00000000 18.00000000
-62.00000000 -11.00000000 18.00000000
-58.90000000 -11.00000000 18.00000000
-55.80000000 -11.00000000 18.00000000
-52.70000000 -11.00000000 18.00000000
-49.60000000 -11.00000000 18.00000000
-46.50000000 -11.00000000 18.00000000
-43.40000000 -11.00000000 18.00000000
-40.30000000 -11.00000000 18.00000000
-37.20000000 -11.00000000 18.00000000
-34.10000000 -11.00000000 18.00000000
-31.00000000 -11.00000000 18.00000000
-27.90000000 -11.00000000 18.00000000
-24.80000000 -11.00000000 18.00000000
-21.70000000 -11.00000000 18.00000000
-18.60000000 -11.00000000 18.00000000
-15.50000000 -11.00000000 18.00000000
-12.40000000 -11.00000000 18.00000000
-9.30000000 -11.00000000 18.00000000
-6.20000000 -11.00000000 18.00000000
-3.10000000 -11.00000000 18.00000000
0.00000000 -11.00000000 18.00000000
-77.50000000 -8.25000000 18.00000000
-74.40000000 -8.25000000 18.00000000
-71.30000000 -8.25000000 18.00000000
-68.20000000 -8.25000000 18.00000000
-65.10000000 -8.25000000 18.00000000
-62.00000000 -8.25000000 18.00000000
-58.90000000 -8.25000000 18.00000000
-55.80000000 -8.25000000 18.00000000
-52.70000000 -8.25000000 18.00000000
-49.60000000 -8.25000000 18.00000000
-46.50000000 -8.25000000 18.00000000
-43.40000000 -8.25000000 18.00000000
-40.30000000 -8.25000000 18.00000000
-37.20000000 -8.25000000 18.00000000
-34.10000000 -8.25000000 18.00000000
-31.00000000 -8.25000000 18.00000000
-27.90000000 -8.25000000 18.00000000
-24.80000000 -8.25000000 18.00000000
-21.70000000 -8.25000000 18.00000000
-18.60000000 -8.25000000 18.00000000
-15.50000000 -8.25000000 18.00000000
-12.40000000 -8.25000000 18.00000000
-9.30000000 -8.25000000 18.00000000
-6.20000000 -8.25000000 18.00000000
-3.10000000 -8.25000000 18.00000000
0.00000000 -8.25000000 18.00000000
-77.50000000 -5.50000000 18.00000000
-74.40000000 -5.50000000 18.00000000
-71.30000000 -5.50000000 18.00000000
-68.20000000 -5.50000000 18.00000000
-65.10000000 -5.50000000 18.00000000
-62.00000000 -5.50000000 18.00000000
-58.90000000 -5.50000000 18.00000000
-55.80000000 -5.50000000 18.00000000
-52.70000000 -5.50000000 18.00000000
-49.60000000 -5.50000000 18.00000000
-46.50000000 -5.50000000 18.00000000
-43.40000000 -5.50000000 18.00000000
-40.30000000 -5.50000000 18.00000000
-37.20000000 -5.50000000 18.00000000
-34.10000000 -5.50000000 18.00000000
-31.00000000 -5.50000000 18.00000000
-27.90000000 -5.50000000 18.00000000
-24.80000000 -5.50000000 18.00000000
-21.70000000 -5.50000000 18.00000000
-18.60000000 -5.50000000 18.00000000
-15.50000000 -5.50000000 18.00000000
-12.40000000 -5.50000000 18.00000000
-9.30000000 -5.50000000 18.00000000
-6.20000000 -5.50000000 18.00000000
-3.10000000 -5.50000000 18.00000000
0.00000000 -5.50000000 18.00000000
-77.50000000 -2.75000000 18.00000000
-74.40000000 -2.75000000 18.00000000
-71.30000000 -2.75000000 18.00000000
-68.20000000 -2.75000000 18.00000000
-65.10000000 -2.75000000 18.00000000
-62.00000000 -2.75000000 18.00000000
-58.90000000 -2.75000000 18.00000000
-55.80000000 -2.75000000 18.00000000
-52.70000000 -2.75000000 18.00000000
-49.60000000 -2.75000000 18.00000000
-46.50000000 -2.75000000 18.00000000
-43.40000000 -2.75000000 18.00000000
-40.30000000 -2.75000000 18.00000000
-37.20000000 -2.75000000 18.00000000
-34.10000000 -2.75000000 18.00000000
-31.00000000 -2.75000000 18.00000000
-27.90000000 -2.75000000 18.00000000
-24.80000000 -2.75000000 18.00000000
-21.70000000 -2.75000000 18.00000000
-18.60000000 -2.75000000 18.00000000
-15.50000000 -2.75000000 18.00000000
-12.40000000 -2.75000000 18.00000000
-9.30000000 -2.75000000 18.00000000
-6.20000000 -2.75000000 18.00000000
-3.10000000 -2.75000000 18.00000000
0.00000000 -2.75000000 18.00000000
-77.50000000 0.00000000 18.00000000
-74.40000000 0.00000000 18.00000000
-71.30000000 0.00000000 18.00000000
-68.20000000 0.00000000 18.00000000
-65.10000000 0.00000000 18.00000000
-62.00000000 0.00000000 18.00000000
-58.90000000 0.00000000 18.00000000
-55.80000000 0.00000000 18.00000000
-52.70000000 0.00000000 18.00000000
-49.60000000 0.00000000 18.00000000
-46.50000000 0.00000000 18.00000000
-43.40000000 0.00000000 18.00000000
-40.30000000 0.00000000 18.00000000
-37.20000000 0.00000000 18.00000000
-34.10000000 0.00000000 18.00000000
-31.00000000 0.00000000 18.00000000
-27.90000000 0.00000000 18.00000000
-24.80000000 0.00000000 18.00000000
-21.70000000 0.00000000 18.00000000
-18.60000000 0.00000000 18.00000000
-15.50000000 0.00000000 18.00000000
-12.40000000 0.00000000 18.00000000
-9.30000000 0.00000000 18.00000000
-6.20000000 0.00000000 18.00000000
-3.10000000 0.00000000 18.00000000
0.00000000 0.00000000 18.00000000
-77.50000000 2.75000000 18.00000000
-74.40000000 2.75000000 18.00000000
-71.30000000 2.75000000 18.00000000
-68.20000000 2.75000000 18.00000000
-65.10000000 2.75000000 18.00000000
-62.00000000 2.75000000 18.00000000
-58.90000000 2.75000000 18.00000000
-55.80000000 2.75000000 18.00000000
-52.70000000 2.75000000 18.00000000
-49.60000000 2.75000000 18.00000000
-46.50000000 2.75000000 18.00000000
-43.40000000 2.75000000 18.00000000
-40.30000000 2.75000000 18.00000000
-37.20000000 2.75000000 18.00000000
-34.10000000 2.75000000 18.00000000
-31.00000000 2.75000000 18.00000000
-27.90000000 2.75000000 18.00000000
-24.80000000 2.75000000 18.00000000
-21.70000000 2.75000000 18.00000000
-18.60000000 2.75000000 18.00000000
-15.50000000 2.75000000 18.00000000
-12.40000000 2.75000000 18.00000000
-9.30000000 2.75000000 18.00000000
-6.20000000 2.75000000 18.00000000
-3.10000000 2.75000000 18.00000000
0.00000000 2.75000000 18.00000000
-77.50000000 5.50000000 18.00000000
-74.40000000 5.50000000 18.00000000
-71.30000000 5.50000000 18.00000000
-68.20000000 5.50000000 18.00000000
-65.10000000 5.50000000 18.00000000
-62.00000000 5.50000000 18.00000000
-58.90000000 5.50000000 18.00000000
-55.80000000 5.50000000 18.00000000
-52.70000000 5.50000000 18.00000000
-49.60000000 5.50000000 18.00000000
-46.50000000 5.50000000 18.00000000
-43.40000000 5.50000000 18.00000000
-40.30000000 5.50000000 18.00000000
-37.20000000 5.50000000 18.00000000
-34.10000000 5.50000000 18.00000000
-31.00000000 5.50000000 18.00000000
-27.90000000 5.50000000 18.00000000
-24.80000000 5.50000000 18.00000000
-21.70000000 5.50000000 18.00000000
-18.60000000 5.50000000 18.00000000
-15.50000000 5.50000000 18.00000000
-12.40000000 5.50000000 18.00000000
-9.30000000 5.50000000 18.00000000
-6.20000000 5.50000000 18.00000000
-3.10000000 5.50000000 18.00000000
0.00000000 5.50000000 18.00000000
-77.50000000 8.25000000 18.00000000
-74.40000000 8.25000000 18.00000000
-71.30000000 8.25000000 18.00000000
-68.20000000 8.25000000 18.00000000
-65.10000000 8.25000000 18.00000000
-62.00000000 8.25000000 18.00000000
-58.90000000 8.25000000 18.00000000
-55.80000000 8.25000000 18.00000000
-52.70000000 8.25000000 18.00000000
-49.60000000 8.25000000 18.00000000
-46.50000000 8.25000000 18.00000000
-43.40000000 8.25000000 18.00000000
-40.30000000 8.25000000 18.00000000
-37.20000000 8.25000000 18.00000000
-34.10000000 8.25000000 18.00000000
-31.00000000 8.25000000 18.00000000
-27.90000000 8.25000000 18.00000000
-24.80000000 8.25000000 18.00000000
-21.70000000 8.25000000 18.00000000
-18.60000000 8.25000000 18.00000000
-15.50000000 8.25000000 18.00000000
-12.40000000 8.25000000 18.00000000
-9.30000000 8.25000000 18.00000000
-6.20000000 8.25000000 18.00000000
-3.10000000 8.25000000 18.00000000
0.00000000 8.25000000 18.00000000
-77.50000000 11.00000000 18.00000000
-74.40000000 11.00000000 18.00000000
-71.30000000 11.00000000 18.00000000
-68.20000000 11.00000000 18.00000000
-65.10000000 11.00000000 18.00000000
-62.00000000 11.00000000 18.00000000
-58.90000000 11.00000000 18.00000000
-55.80000000 11.00000000 18.00000000
-52.70000000 11.00000000 18.00000000
-49.60000000 11.00000000 18.00000000
-46.50000000 11.00000000 18.00000000
-43.40000000 11.00000000 18.00000000
-40.30000000 11.00000000 18.00000000
-37.20000000 11.00000000 18.00000000
-34.10000000 11.00000000 18.00000000
-31.00000000 11.00000000 18.00000000
-27.90000000 11.00000000 18.00000000
-24.80000000 11.00000000 18.00000000
-21.70000000 11.00000000 18.00000000
-18.60000000 11.00000000 18.00000000
-15.50000000 11.00000000 18.00000000
-12.40000000 11.00000000 18.00000000
-9.30000000 11.00000000 18.00000000
-6.20000000 11.00000000 18.00000000
-3.10000000 11.00000000 18.00000000
0.00000000 11.00000000 18.00000000
-77.50000000 13.75000000 18.00000000
-74.40000000 13.75000000 18.00000000
-71.30000000 13.75000000 18.00000000
-68.20000000 13.75000000 18.00000000
-65.10000000 13.75000000 18.00000000
-62.00000000 13.75000000 18.00000000
-58.90000000 13.75000000 18.00000000
-55.80000000 13.75000000 18.00000000
-52.70000000 13.75000000 18.00000000
-49.60000000 13.75000000 18.00000000
-46.50000000 13.75000000 18.00000000
-43.40000000 13.75000000 18.00000000
-40.30000000 13.75000000 18.00000000
-37.20000000 13.75000000 18.00000000
-34.10000000 13.75000000 18.00000000
-31.00000000 13.75000000 18.00000000
-27.90000000 13.75000000 18.00000000
-24.80000000 13.75000000 18.00000000
-21.70000000 13.75000000 18.00000000
-18.60000000 13.75000000 18.00000000
-15.50000000 13.75000000 18.00000000
-12.40000000 13.75000000 18.00000000
-9.30000000 13.75000000 18.00000000
-6.20000000 13.75000000 18.00000000
-3.10000000 13.75000000 18.00000000
0.00000000 13.75000000 18.00000000
-77.50000000 16.50000000 18.00000000
-74.40000000 16.50000000 18.00000000
-71.30000000 16.50000000 18.00000000
-68.20000000 16.50000000 18.00000000
-65.10000000 16.50000000 18.00000000
-62.00000000 16.50000000 18.00000000
-58.90000000 16.50000000 18.00000000
-55.80000000 16.50000000 18.00000000
-52.70000000 16.50000000 18.00000000
-49.60000000 16.50000000 18.00000000
-46.50000000 16.50000000 18.00000000
-43.40000000 16.50000000 18.00000000
-40.30000000 16.50000000 18.00000000
-37.20000000 16.50000000 18.00000000
-34.10000000 16.50000000 18.00000000
-31.00000000 16.50000000 18.00000000
-27.90000000 16.50000000 18.00000000
-24.80000000 16.50000000 18.00000000
-21.70000000 16.50000000 18.00000000
-18.60000000 16.50000000 18.00000000
-15.50000000 16.50000000 18.00000000
-12.40000000 16.50000000 18.00000000
-9.30000000 16.50000000 18.00000000
-6.20000000 16.50000000 18.00000000
-3.10000000 16.50000000 18.00000000
0.00000000 16.50000000 18.00000000
-77.50000000 19.25000000 18.00000000
-74.40000000 19.25000000 18.00000000
-71.30000000 19.25000000 18.00000000
-68.20000000 19.25000000 18.00000000
-65.10000000 19.25000000 18.00000000
-62.00000000 19.25000000 18.00000000
-58.90000000 19.25000000 18.00000000
-55.80000000 19.25000000 18.00000000
-52.70000000 19.25000000 18.00000000
-49.60000000 19.25000000 18.00000000
-46.50000000 19.25000000 18.00000000
-43.40000000 19.25000000 18.00000000
-40.30000000 19.25000000 18.00000000
-37.20000000 19.25000000 18.00000000
-34.10000000 19.25000000 18.00000000
-31.00000000 19.25000000 18.00000000
-27.90000000 19.25000000 18.00000000
-24.80000000 19.25000000 18.00000000
-21.70000000 19.25000000 18.00000000
-18.60000000 19.25000000 18.00000000
-15.50000000 19.25000000 18.00000000
-12.40000000 19.25000000 18.00000000
-9.30000000 19.25000000 18.00000000
-6.20000000 19.25000000 18.00000000
-3.10000000 19.25000000 18.00000000
0.00000000 19.25000000 18.00000000
-77.50000000 22.00000000 18.00000000
-74.40000000 22.00000000 18.00000000
-71.30000000 22.00000000 18.00000000
-68.20000000 22.00000000 18.00000000
-65.10000000 22.00000000 18.00000000
-62.00000000 22.00000000 18.00000000
-58.90000000 22.00000000 18.00000000
-55.80000000 22.00000000 18.00000000
-52.70000000 22.00000000 18.00000000
-49.60000000 22.00000000 18.00000000
-46.50000000 22.00000000 18.00000000
-43.40000000 22.00000000 18.00000000
-40.30000000 22.00000000 18.00000000
-37.20000000 22.00000000 18.00000000
-34.10000000 22.00000000 18.00000000
-31.00000000 22.00000000 18.00000000
-27.90000000 22.00000000 18.00000000
-24.80000000 22.00000000 18.00000000
-21.70000000 22.00000000 18.00000000
-18.60000000 22.00000000 18.00000000
-15.50000000 22.00000000 18.00000000
-12.40000000 22.00000000 18.00000000
-9.30000000 22.00000000 18.00000000
-6.20000000 22.00000000 18.00000000
-3.10000000 22.00000000 18.00000000
0.00000000 22.00000000 18.00000000
-77.50000000 24.75000000 18.00000000
-74.40000000 24.75000000 18.00000000
-71.30000000 24.75000000 18.00000000
-68.20000000 24.75000000 18.00000000
-65.10000000 24.75000000 18.00000000
-62.00000000 24.75000000 18.00000000
-58.90000000 24.75000000 18.00000000
-55.80000000 24.75000000 18.00000000
-52.70000000 24.75000000 18.00000000
-49.60000000 24.75000000 18.00000000
-46.50000000 24.75000000 18.00000000
-43.40000000 24.75000000 18.00000000
-40.30000000 24.75000000 18.00000000
-37.20000000 24.75000000 18.00000000
-34.10000000 24.75000000 18.00000000
-31.00000000 24.75000000 18.00000000
-27.90000000 24.75000000 18.00000000
-24.80000000 24.75000000 18.00000000
-21.70000000 24.75000000 18.00000000
-18.60000000 24.75000000 18.00000000
-15.50000000 24.75000000 18.00000000
-12.40000000 24.75000000 18.00000000
-9.30000000 24.75000000 18.00000000
-6.20000000 24.75000000 18.00000000
-3.10000000 24.75000000 18.00000000
0.00000000 24.75000000 18.00000000
-77.50000000 27.50000000 18.00000000
-74.40000000 27.50000000 18.00000000
-71.30000000 27.50000000 18.00000000
-68.20000000 27.50000000 18.00000000
-65.10000000 27.50000000 18.00000000
-62.00000000 27.50000000 18.00000000
-58.90000000 27.50000000 18.00000000
-55.80000000 27.50000000 18.00000000
-52.70000000 27.50000000 18.00000000
-49.60000000 27.50000000 18.00000000
-46.50000000 27.50000000 18.00000000
-43.40000000 27.50000000 18.00000000
-40.30000000 27.50000000 18.00000000
-37.20000000 27.50000000 18.00000000
-34.10000000 27.50000000 18.00000000
-31.00000000 27.50000000 18.00000000
-27.90000000 27.50000000 18.00000000
-24.80000000 27.50000000 18.00000000
-21.70000000 27.50000000 18.00000000
-18.60000000 27.50000000 18.00000000
-15.50000000 27.50000000 18.00000000
-12.40000000 27.50000000 18.00000000
-9.30000000 27.50000000 18.00000000
-6.20000000 27.50000000 18.00000000
-3.10000000 27.50000000 18.00000000
0.00000000 27.50000000 18.00000000
-75.00000000 -25.00000000 20.00000000
-72.00000000 -25.00000000 20.00000000
-69.00000000 -25.00000000 20.00000000
-66.00000000 -25.00000000 20.00000000
-63.00000000 -25.00000000 20.00000000
-60.00000000 -25.00000000 20.00000000
-57.00000000 -25.00000000 20.00000000
-54.00000000 -25.00000000 20.00000000
-51.00000000 -25.00000000 20.00000000
-48.00000000 -25.00000000 20.00000000
-45.00000000 -25.00000000 20.00000000
-42.00000000 -25.00000000 20.00000000
-39.00000000 -25.00000000 20.00000000
-36.00000000 -25.00000000 20.00000000
-33.00000000 -25.00000000 20.00000000
-30.00000000 -25.00000000 20.00000000
-27.00000000 -25.00000000 20.00000000
-24.00000000 -25.00000000 20.00000000
-21.00000000 -25.00000000 20.00000000
-18.00000000 -25.00000000 20.00000000
-15.00000000 -25.00000000 20.00000000
-12.00000000 -25.00000000 20.00000000
-9.00000000 -25.00000000 20.00000000
-6.00000000 -25.00000000 20.00000000
-3.00000000 -25.00000000 20.00000000
-75.00000000 -22.50000000 20.00000000
-72.00000000 -22.50000000 20.00000000
-69.00000000 -22.50000000 20.00000000
-66.00000000 -22.50000000 20.00000000
-63.00000000 -22.50000000 20.00000000
-60.00000000 -22.50000000 20.00000000
-57.00000000 -22.50000000 20.00000000
-54.00000000 -22.50000000 20.00000000
-51.00000000 -22.50000000 20.00000000
-48.00000000 -22.50000000 20.00000000
-45.00000000 -22.50000000 20.00000000
-42.00000000 -22.50000000 20.00000000
-39.00000000 -22.50000000 20.00000000
-36.00000000 -22.50000000 20.00000000
-33.00000000 -22.50000000 20.00000000
-30.00000000 -22.50000000 20.00000000
-27.00000000 -22.50000000 20.00000000
-24.00000000 -22.50000000 20.00000000
-21.00000000 -22.50000000 20.00000000
-18.00000000 -22.50000000 20.00000000
-15.00000000 -22.50000000 20.00000000
-12.00000000 -22.50000000 20.00000000
-9.00000000 -22.50000000 20.00000000
-6.00000000 -22.50000000 20.00000000
-3.00000000 -22.50000000 20.00000000
-75.00000000 -20.00000000 20.00000000
-72.00000000 -20.00000000 20.00000000
-69.00000000 -20.00000000 20.00000000
-66.00000000 -20.00000000 20.00000000
-63.00000000 -20.00000000 20.00000000
-60.00000000 -20.00000000 20.00000000
-57.00000000 -20.00000000 20.00000000
-54.00000000 -20.00000000 20.00000000
-51.00000000 -20.00000000 20.00000000
-48.00000000 -20.00000000 20.00000000
-45.00000000 -20.00000000 20.00000000
-42.00000000 -20.00000000 20.00000000
-39.00000000 -20.00000000 20.00000000
-36.00000000 -20.00000000 20.00000000
-33.00000000 -20.00000000 20.00000000
-30.00000000 -20.00000000 20.00000000
-27.00000000 -20.00000000 20.00000000
-24.00000000 -20.00000000 20.00000000
-21.00000000 -20.00000000 20.00000000
-18.00000000 -20.00000000 20.00000000
-15.00000000 -20.00000000 20.00000000
-12.00000000 -20.00000000 20.00000000
-9.00000000 -20.00000000 20.00000000
-6.00000000 -20.00000000 20.00000000
-3.00000000 -20.00000000 20.00000000
-75.00000000 -17.50000000 20.00000000
-72.00000000 -17.50000000 20.00000000
-69.00000000 -17.50000000 20.00000000
-66.00000000 -17.50000000 20.00000000
-63.00000000 -17.50000000 20.00000000
-60.00000000 -17.50000000 20.00000000
-57.00000000 -17.50000000 20.00000000
-54.00000000 -17.50000000 20.00000000
-51.00000000 -17.50000000 20.00000000
-48.00000000 -17.50000000 20.00000000
-45.00000000 -17.50000000 20.00000000
-42.00000000 -17.50000000 20.00000000
-39.00000000 -17.50000000 20.00000000
-36.00000000 -17.50000000 20.00000000
-33.00000000 -17.50000000 20.00000000
-30.00000000 -17.50000000 20.00000000
-27.00000000 -17.50000000 20.00000000
-24.00000000 -17.50000000 20.00000000
-21.00000000 -17.50000000 20.00000000
-18.00000000 -17.50000000 20.00000000
-15.00000000 -17.50000000 20.00000000
-12.00000000 -17.50000000 20.00000000
-9.00000000 -17.50000000 20.00000000
-6.00000000 -17.50000000 20.00000000
-3.00000000 -17.50000000 20.00000000
-75.00000000 -15.00000000 20.00000000
-72.00000000 -15.00000000 20.00000000
-69.00000000 -15.00000000 20.00000000
-66.00000000 -15.00000000 20.00000000
-63.00000000 -15.00000000 20.00000000
-60.00000000 -15.00000000 20.00000000
-57.00000000 -15.00000000 20.00000000
-54.00000000 -15.00000000 20.00000000
-51.00000000 -15.00000000 20.00000000
-48.00000000 -15.00000000 20.00000000
-45.00000000 -15.00000000 20.00000000
-42.00000000 -15.00000000 20.00000000
-39.00000000 -15.00000000 20.00000000
-36.00000000 -15.00000000 20.00000000
-33.00000000 -15.00000000 20.00000000
-30.00000000 -15.00000000 20.00000000
-27.00000000 -15.00000000 20.00000000
-24.00000000 -15.00000000 20.00000000
-21.00000000 -15.00000000 20.00000000
-18.00000000 -15.00000000 20.00000000
-15.00000000 -15.00000000 20.00000000
-12.00000000 -15.00000000 20.00000000
-9.00000000 -15.00000000 20.00000000
-6.00000000 -15.00000000 20.00000000
-3.00000000 -15.00000000 20.00000000
-75.00000000 -12.50000000 20.00000000
-72.00000000 -12.50000000 20.00000000
-69.00000000 -12.50000000 20.00000000
-66.00000000 -12.50000000 20.00000000
-63.00000000 -12.50000000 20.00000000
-60.00000000 -12.50000000 20.00000000
-57.00000000 -12.50000000 20.00000000
-54.00000000 -12.50000000 20.00000000
-51.00000000 -12.50000000 20.00000000
-48.00000000 -12.50000000 20.00000000
-45.00000000 -12.50000000 20.00000000
-42.00000000 -12.50000000 20.00000000
-39.00000000 -12.50000000 20.00000000
-36.00000000 -12.50000000 20.00000000
-33.00000000 -12.50000000 20.00000000
-30.00000000 -12.50000000 20.00000000
-27.00000000 -12.50000000 20.00000000
-24.00000000 -12.50000000 20.00000000
-21.00000000 -12.50000000 20.00000000
-18.00000000 -12.50000000 20.00000000
-15.00000000 -12.50000000 20.00000000
-12.00000000 -12.50000000 20.00000000
-9.00000000 -12.50000000 20.00000000
-6.00000000 -12.50000000 20.00000000
-3.00000000 -12.50000000 20.00000000
-75.00000000 -10.00000000 20.00000000
-72.00000000 -10.00000000 20.00000000
-69.00000000 -10.00000000 20.00000000
-66.00000000 -10.00000000 20.00000000
-63.00000000 -10.00000000 20.00000000
-60.00000000 -10.00000000 20.00000000
-57.00000000 -10.00000000 20.00000000
-54.00000000 -10.00000000 20.00000000
-51.00000000 -10.00000000 20.00000000
-48.00000000 -10.00000000 20.00000000
-45.00000000 -10.00000000 20.00000000
-42.00000000 -10.00000000 20.00000000
-39.00000000 -10.00000000 20.00000000
-36.00000000 -10.00000000 20.00000000
-33.00000000 -10.00000000 20.00000000
-30.00000000 -10.00000000 20.00000000
-27.00000000 -10.00000000 20.00000000
-24.00000000 -10.00000000 20.00000000
-21.00000000 -10.00000000 20.00000000
-18.00000000 -10.00000000 20.00000000
-15.00000000 -10.00000000 20.00000000
-12.00000000 -10.00000000 20.00000000
-9.00000000 -10.00000000 20.00000000
-6.00000000 -10.00000000 20.00000000
-3.00000000 -10.00000000 20.00000000
-75.00000000 -7.50000000 20.00000000
-72.00000000 -7.50000000 20.00000000
-69.00000000 -7.50000000 20.00000000
-66.00000000 -7.50000000 20.00000000
-63.00000000 -7.50000000 20.00000000
-60.00000000 -7.50000000 20.00000000
-57.00000000 -7.50000000 20.00000000
-54.00000000 -7.50000000 20.00000000
-51.00000000 -7.50000000 20.00000000
-48.00000000 -7.50000000 20.00000000
-45.00000000 -7.50000000 20.00000000
-42.00000000 -7.50000000 20.00000000
-39.00000000 -7.50000000 20.00000000
-36.00000000 -7.50000000 20.00000000
-33.00000000 -7.50000000 20.00000000
-30.00000000 -7.50000000 20.00000000
-27.00000000 -7.50000000 20.00000000
-24.00000000 -7.50000000 20.00000000
-21.00000000 -7.50000000 20.00000000
-18.00000000 -7.50000000 20.00000000
-15.00000000 -7.50000000 20.00000000
-12.00000000 -7.50000000 20.00000000
-9.00000000 -7.50000000 20.00000000
-6.00000000 -7.50000000 20.00000000
-3.00000000 -7.50000000 20.00000000
-75.00000000 -5.00000000 20.00000000
-72.00000000 -5.00000000 20.00000000
-69.00000000 -5.00000000 20.00000000
-66.00000000 -5.00000000 20.00000000
-63.00000000 -5.00000000 20.00000000
-60.00000000 -5.00000000 20.00000000
-57.00000000 -5.00000000 20.00000000
-54.00000000 -5.00000000 20.00000000
-51.00000000 -5.00000000 20.00000000
-48.00000000 -5.00000000 20.00000000
-45.00000000 -5.00000000 20.00000000
-42.00000000 -5.00000000 20.00000000
-39.00000000 -5.00000000 20.00000000
-36.00000000 -5.00000000 20.00000000
-33.00000000 -5.00000000 20.00000000
-30.00000000 -5.00000000 20.00000000
-27.00000000 -5.00000000 20.00000000
-24.00000000 -5.00000000 20.00000000
-21.00000000 -5.00000000 20.00000000
-18.00000000 -5.00000000 20.00000000
-15.00000000 -5.00000000 20.00000000
-12.00000000 -5.00000000 20.00000000
-9.00000000 -5.00000000 20.00000000
-6.00000000 -5.00000000 20.00000000
-3.00000000 -5.00000000 20.00000000
-75.00000000 -2.50000000 20.00000000
-72.00000000 -2.50000000 20.00000000
-69.00000000 -2.50000000 20.00000000
-66.00000000 -2.50000000 20.00000000
-63.00000000 -2.50000000 20.00000000
-60.00000000 -2.50000000 20.00000000
-57.00000000 -2.50000000 20.00000000
-54.00000000 -2.50000000 20.00000000
-51.00000000 -2.50000000 20.00000000
-48.00000000 -2.50000000 20.00000000
-45.00000000 -2.50000000 20.00000000
-42.00000000 -2.50000000 20.00000000
-39.00000000 -2.50000000 20.00000000
-36.00000000 -2.50000000 20.00000000
-33.00000000 -2.50000000 20.00000000
-30.00000000 -2.50000000 20.00000000
-27.00000000 -2.50000000 20.00000000
-24.00000000 -2.50000000 20.00000000
-21.00000000 -2.50000000 20.00000000
-18.00000000 -2.50000000 20.00000000
-15.00000000 -2.50000000 20.00000000
-12.00000000 -2.50000000 20.00000000
-9.00000000 -2.50000000 20.00000000
-6.00000000 -2.50000000 20.00000000
-3.00000000 -2.50000000 20.00000000
-75.00000000 0.00000000 20.00000000
-72.00000000 0.00000000 20.00000000
-69.00000000 0.00000000 20.00000000
-66.00000000 0.00000000 20.00000000
-63.00000000 0.00000000 20.00000000
-60.00000000 0.00000000 20.00000000
-57.00000000 0.00000000 20.00000000
-54.00000000 0.00000000 20.00000000
-51.00000000 0.00000000 20.00000000
-48.00000000 0.00000000 20.00000000
-45.00000000 0.00000000 20.00000000
-42.00000000 0.00000000 20.00000000
-39.00000000 0.00000000 20.00000000
-36.00000000 0.00000000 20.00000000
-33.00000000 0.00000000 20.00000000
-30.00000000 0.00000000 20.00000000
-27.00000000 0.00000000 20.00000000
-24.00000000 0.00000000 20.00000000
-21.00000000 0.00000000 20.00000000
-18.00000000 0.00000000 20.00000000
-15.00000000 0.00000000 20.00000000
-12.00000000 0.00000000 20.00000000
-9.00000000 0.00000000 20.00000000
-6.00000000 0.00000000 20.00000000
-3.00000000 0.00000000 20.00000000
-75.00000000 2.50000000 20.00000000
-72.00000000 2.50000000 20.00000000
-69.00000000 2.50000000 20.00000000
-66.00000000 2.50000000 20.00000000
-63.00000000 2.50000000 20.00000000
-60.00000000 2.50000000 20.00000000
-57.00000000 2.50000000 20.00000000
-54.00000000 2.50000000 20.00000000
-51.00000000 2.50000000 20.00000000
-48.00000000 2.50000000 20.00000000
-45.00000000 2.50000000 20.00000000
-42.00000000 2.50000000 20.00000000
-39.00000000 2.50000000 20.00000000
-36.00000000 2.50000000 20.00000000
-33.00000000 2.50000000 20.00000000
-30.00000000 2.50000000 20.00000000
-27.00000000 2.50000000 20.00000000
-24.00000000 2.50000000 20.00000000
-21.00000000 2.50000000 20.00000000
-18.00000000 2.50000000 20.00000000
-15.00000000 2.50000000 20.00000000
-12.00000000 2.50000000 20.00000000
-9.00000000 2.50000000 20.00000000
-6.00000000 2.50000000 20.00000000
-3.00000000 2.50000000 20.00000000
-75.00000000 5.00000000 20.00000000
-72.00000000 5.00000000 20.00000000
-69.00000000 5.00000000 20.00000000
-66.00000000 5.00000000 20.00000000
-63.00000000 5.00000000 20.00000000
-60.00000000 5.00000000 20.00000000
-57.00000000 5.00000000 20.00000000
-54.00000000 5.00000000 20.00000000
-51.00000000 5.00000000 20.00000000
-48.00000000 5.00000000 20.00000000
-45.00000000 5.00000000 20.00000000
-42.00000000 5.00000000 20.00000000
-39.00000000 5.00000000 20.00000000
-36.00000000 5.00000000 20.00000000
-33.00000000 5.00000000 20.00000000
-30.00000000 5.00000000 20.00000000
-27.00000000 5.00000000 20.00000000
-24.00000000 5.00000000 20.00000000
-21.00000000 5.00000000 20.00000000
-18.00000000 5.00000000 20.00000000
-15.00000000 5.00000000 20.00000000
-12.00000000 5.00000000 20.00000000
-9.00000000 5.00000000 20.00000000
-6.00000000 5.00000000 20.00000000
-3.00000000 5.00000000 20.00000000
-75.00000000 7.50000000 20.00000000
-72.00000000 7.50000000 20.00000000
-69.00000000 7.50000000 20.00000000
-66.00000000 7.50000000 20.00000000
-63.00000000 7.50000000 20.00000000
-60.00000000 7.50000000 20.00000000
-57.00000000 7.50000000 20.00000000
-54.00000000 7.50000000 20.00000000
-51.00000000 7.50000000 20.00000000
-48.00000000 7.50000000 20.00000000
-45.00000000 7.50000000 20.00000000
-42.00000000 7.50000000 20.00000000
-39.00000000 7.50000000 20.00000000
-36.00000000 7.50000000 20.00000000
-33.00000000 7.50000000 20.00000000
-30.00000000 7.50000000 20.00000000
-27.00000000 7.50000000 20.00000000
-24.00000000 7.50000000 20.00000000
-21.00000000 7.50000000 20.00000000
-18.00000000 7.50000000 20.00000000
-15.00000000 7.50000000 20.00000000
-12.00000000 7.50000000 20.00000000
-9.00000000 7.50000000 20.00000000
-6.00000000 7.50000000 20.00000000
-3.00000000 7.50000000 20.00000000
-75.00000000 10.00000000 20.00000000
-72.00000000 10.00000000 20.00000000
-69.00000000 10.00000000 20.00000000
-66.00000000 10.00000000 20.00000000
-63.00000000 10.00000000 20.00000000
-60.00000000 10.00000000 20.00000000
-57.00000000 10.00000000 20.00000000
-54.00000000 10.00000000 20.00000000
-51.00000000 10.00000000 20.00000000
-48.00000000 10.00000000 20.00000000
-45.00000000 10.00000000 20.00000000
-42.00000000 10.00000000 20.00000000
-39.00000000 10.00000000 20.00000000
-36.00000000 10.00000000 20.00000000
-33.00000000 10.00000000 20.00000000
-30.00000000 10.00000000 20.00000000
-27.00000000 10.00000000 20.00000000
-24.00000000 10.00000000 20.00000000
-21.00000000 10.00000000 20.00000000
-18.00000000 10.00000000 20.00000000
-15.00000000 10.00000000 20.00000000
-12.00000000 10.00000000 20.00000000
-9.00000000 10.00000000 20.00000000
-6.00000000 10.00000000 20.00000000
-3.00000000 10.00000000 20.00000000
-75.00000000 12.50000000 20.00000000
-72.00000000 12.50000000 20.00000000
-69.00000000 12.50000000 20.00000000
-66.00000000 12.50000000 20.00000000
-63.00000000 12.50000000 20.00000000
-60.00000000 12.50000000 20.00000000
-57.00000000 12.50000000 20.00000000
-54.00000000 12.50000000 20.00000000
-51.00000000 12.50000000 20.00000000
-48.00000000 12.50000000 20.00000000
-45.00000000 12.50000000 20.00000000
-42.00000000 12.50000000 20.00000000
-39.00000000 12.50000000 20.00000000
-36.00000000 12.50000000 20.00000000
-33.00000000 12.50000000 20.00000000
-30.00000000 12.50000000 20.00000000
-27.00000000 12.50000000 20.00000000
-24.00000000 12.50000000 20.00000000
-21.00000000 12.50000000 20.00000000
-18.00000000 12.50000000 20.00000000
-15.00000000 12.50000000 20.00000000
-12.00000000 12.50000000 20.00000000
-9.00000000 12.50000000 20.00000000
-6.00000000 12.50000000 20.00000000
-3.00000000 12.50000000 20.00000000
-75.00000000 15.00000000 20.00000000
-72.00000000 15.00000000 20.00000000
-69.00000000 15.00000000 20.00000000
-66.00000000 15.00000000 20.00000000
-63.00000000 15.00000000 20.00000000
-60.00000000 15.00000000 20.00000000
-57.00000000 15.00000000 20.00000000
-54.00000000 15.00000000 20.00000000
-51.00000000 15.00000000 20.00000000
-48.00000000 15.00000000 20.00000000
-45.00000000 15.00000000 20.00000000
-42.00000000 15.00000000 20.00000000
-39.00000000 15.00000000 20.00000000
-36.00000000 15.00000000 20.00000000
-33.00000000 15.00000000 20.00000000
-30.00000000 15.00000000 20.00000000
-27.00000000 15.00000000 20.00000000
-24.00000000 15.00000000 20.00000000
-21.00000000 15.00000000 20.00000000
-18.00000000 15.00000000 20.00000000
-15.00000000 15.00000000 20.00000000
-12.00000000 15.00000000 20.00000000
-9.00000000 15.00000000 20.00000000
-6.00000000 15.00000000 20.00000000
-3.00000000 15.00000000 20.00000000
-75.00000000 17.50000000 20.00000000
-72.00000000 17.50000000 20.00000000
-69.00000000 17.50000000 20.00000000
-66.00000000 17.50000000 20.00000000
-63.00000000 17.50000000 20.00000000
-60.00000000 17.50000000 20.00000000
-57.00000000 17.50000000 20.00000000
-54.00000000 17.50000000 20.00000000
-51.00000000 17.50000000 20.00000000
-48.00000000 17.50000000 20.00000000
-45.00000000 17.50000000 20.00000000
-42.00000000 17.50000000 20.00000000
-39.00000000 17.50000000 20.00000000
-36.00000000 17.50000000 20.00000000
-33.00000000 17.50000000 20.00000000
-30.00000000 17.50000000 20.00000000
-27.00000000 17.50000000 20.00000000
-24.00000000 17.50000000 20.00000000
-21.00000000 17.50000000 20.00000000
-18.00000000 17.50000000 20.00000000
-15.00000000 17.50000000 20.00000000
-12.00000000 17.50000000 20.00000000
-9.00000000 17.50000000 20.00000000
-6.00000000 17.50000000 20.00000000
-3.00000000 17.50000000 20.00000000
-75.00000000 20.00000000 20.00000000
-72.00000000 20.00000000 20.00000000
-69.00000000 20.00000000 20.00000000
-66.00000000 20.00000000 20.00000000
-63.00000000 20.00000000 20.00000000
-60.00000000 20.00000000 20.00000000
-57.00000000 20.00000000 20.00000000
-54.00000000 20.00000000 20.00000000
-51.00000000 20.00000000 20.00000000
-48.00000000 20.00000000 20.00000000
-45.00000000 20.00000000 20.00000000
-42.00000000 20.00000000 20.00000000
-39.00000000 20.00000000 20.00000000
-36.00000000 20.00000000 20.00000000
-33.00000000 20.00000000 20.00000000
-30.00000000 20.00000000 20.00000000
-27.00000000 20.00000000 20.00000000
-24.00000000 20.00000000 20.00000000
-21.00000000 20.00000000 20.00000000
-18.00000000 20.00000000 20.00000000
-15.00000000 20.00000000 20.00000000
-12.00000000 20.00000000 20.00000000
-9.00000000 20.00000000 20.00000000
-6.00000000 20.00000000 20.00000000
-3.00000000 20.00000000 20.00000000
-75.00000000 22.50000000 20.00000000
-72.00000000 22.50000000 20.00000000
-69.00000000 22.50000000 20.00000000
-66.00000000 22.50000000 20.00000000
-63.00000000 22.50000000 20.00000000
-60.00000000 22.50000000 20.00000000
-57.00000000 22.50000000 20.00000000
-54.00000000 22.50000000 20.00000000
-51.00000000 22.50000000 20.00000000
-48.00000000 22.50000000 20.00000000
-45.00000000 22.50000000 20.00000000
-42.00000000 22.50000000 20.00000000
-39.00000000 22.50000000 20.00000000
-36.00000000 22.50000000 20.00000000
-33.00000000 22.50000000 20.00000000
-30.00000000 22.50000000 20.00000000
-27.00000000 22.50000000 20.00000000
-24.00000000 22.50000000 20.00000000
-21.00000000 22.50000000 20.00000000
-18.00000000 22.50000000 20.00000000
-15.00000000 22.50000000 20.00000000
-12.00000000 22.50000000 20.00000000
-9.00000000 22.50000000 20.00000000
-6.00000000 22.50000000 20.00000000
-3.00000000 22.50000000 20.00000000
-75.00000000 25.00000000 20.00000000
-72.00000000 25.00000000 20.00000000
-69.00000000 25.00000000 20.00000000
-66.00000000 25.00000000 20.00000000
-63.00000000 25.00000000 20.00000000
-60.00000000 25.00000000 20.00000000
-57.00000000 25.00000000 20.00000000
-54.00000000 25.00000000 20.00000000
-51.00000000 25.00000000 20.00000000
-48.00000000 25.00000000 20.00000000
-45.00000000 25.00000000 20.00000000
-42.00000000 25.00000000 20.00000000
-39.00000000 25.00000000 20.00000000
-36.00000000 25.00000000 20.00000000
-33.00000000 25.00000000 20.00000000
-30.00000000 25.00000000 20.00000000
-27.00000000 25.00000000 20.00000000
-24.00000000 25.00000000 20.00000000
-21.00000000 25.00000000 20.00000000
-18.00000000 25.00000000 20.00000000
-15.00000000 25.00000000 20.00000000
-12.00000000 25.00000000 20.00000000
-9.00000000 25.00000000 20.00000000
-6.00000000 25.00000000 20.00000000
-3.00000000 25.00000000 20.00000000
CELLS 10000 90000
8 0 1 52 51 1071 1072 1123 1122
8 1 2 53 52 1072 1073 1124 1123
8 2 3 54 53 1073 1074 1125 1124
8 3 4 55 54 1074 1075 1126 1125
8 4 5 56 55 1075 1076 1127 1126
8 5 6 57 56 1076 1077 1128 1127
8 6 7 58 57 1077 1078 1129 1128
8 7 8 59 58 1078 1079 1130 1129
8 8 9 60 59 1079 1080 1131 1130
8 9 10 61 60 1080 1081 1132 1131
8 10 11 62 61 1081 1082 1133 1132
8 11 12 63 62 1082 1083 1134 1133
8 12 13 64 63 1083 1084 1135 1134
8 13 14 65 64 1084 1085 1136 1135
8 14 15 66 65 1085 1086 1137 1136
8 15 16 67 66 1086 1087 1138 1137
8 16 17 68 67 1087 1088 1139 1138
8 17 18 69 68 1088 1089 1140 1139
8 18 19 70 69 1089 1090 1141 1140
8 19 20 71 70 1090 1091 1142 1141
8 20 21 72 71 1091 1092 1143 1142
8 21 22 73 72 1092 1093 1144 1143
8 22 23 74 73 1093 1094 1145 1144
8 23 24 75 74 1094 1095 1146 1145
8 24 25 76 75 1095 1096 1147 1146
8 25 26 77 76 1096 1097 1148 1147
8 26 27 78 77 1097 1098 1149 1148
8 27 28 79 78 1098 1099 1150 1149
8 28 29 80 79 1099 1100 1151 1150
8 29 30 81 80 1100 1101 1152 1151
8 30 31 82 81 1101 1102 1153 1152
8 31 32 83 82 1102 1103 1154 1153
8 32 33 84 83 1103 1104 1155 1154
8 33 34 85 84 1104 1105 1156 1155
8 34 35 86 85 1105 1106 1157 1156
8 35 36 87 86 1106 1107 1158 1157
8 36 37 88 87 1107 1108 1159 1158
8 37 38 89 88 1108 1109 1160 1159
8 38 39 90 89 1109 1110 1161 1160
8 39 40 91 90 1110 1111 1162 1161
8 40 41 92 91 1111 1112 1163 1162
8 41 42 93 92 1112 1113 1164 1163
8 42 43 94 93 1113 1114 1165 1164
8 43 44 95 94 1114 1115 1166 1165
8 44 45 96 95 1115 1116 1167 1166
8 45 46 97 96 1116 1117 1168 1167
8 46 47 98 97 1117 1118 1169 1168
8 47 48 99 98 1118 1119 1170 1169
8 48 49 100 99 1119 1120 1171 1170
8 49 50 101 100 1120 1121 1172 1171
8 51 52 103 102 1122 1123 1174 1173
8 52 53 104 103 1123 1124 1175 1174
8 53 54 105 104 1124 1125 1176 1175
8 54 55 106 105 1125 1126 1177 1176
8 55 56 107 106 1126 1127 1178 1177
8 56 57 108 107 1127 1128 1179 1178
8 57 58 109 108 1128 1129 1180 1179
8 58 59 110 109 1129 1130 1181 1180
8 59 60 111 110 1130 1131 1182 1181
8 60 61 112 111 1131 1132 1183 1182
8 61 62 113 112 1132 1133 1184 1183
8 62 63 114 113 1133 1134 1185 1184
8 63 64 115 114 1134 1135 1186 1185
8 64 65 116 115 1135 1136 1187 1186
8 65 66 117 116 1136 1137 1188 1187
8 66 67 118 117 1137 1138 1189 1188
8 67 68 119 118 1138 1139 1190 1189
8 68 69 120 119 1139 1140 1191 1190
8 69 70 121 120 1140 1141 1192 1191
8 70 71 122 121 1141 1142 1193 1192
8 71 72 123 122 1142 1143 1194 1193
8 72 73 124 123 1143 1144 1195 1194
8 73 74 125 124 1144 1145 1196 1195
8 74 75 126 125 1145 1146 1197 1196
8 75 76 127 126 1146 1147 1198 1197
8 76 77 128 127 1147 1148 1199 1198
8 77 78 129 128 1148 1149 1200 1199
8 78 79 130 129 1149 1150 1201 1200
8 79 80 131 130 1150 1151 1202 1201
8 80 81 132 131 1151 1152 1203 1202
8 81 82 133 132 1152 1153 1204 1203
8 82 83 134 133 1153 1154 1205 1204
8 83 84 135 134 1154 1155 1206 1205
8 84 85 136 135 1155 1156 1207 1206
8 85 86 137 136 1156 1157 1208 1207
8 86 87 138 137 1157 1158 1209 1208
8 87 88 139 138 1158 1159 1210 1209
8 88 89 140 139 1159 1160 1211 1210
8 89 90 141 140 1160 1161 1212 1211
8 90 91 142 141 1161 1162 1213 1212
8 91 92 143 142 1162 1163 1214 1213
8 92 93 144 143 1163 1164 1215 1214
8 93 94 145 144 1164 1165 1216 1215
8 94 95 146 145 1165 1166 1217 1216
8 95 96 147 146 1166 1167 1218 1217
8 96 97 148 147 1167 1168 1219 1218
8 97 98 149 148 1168 1169 1220 1219
8 98 99 150 149 1169 1170 1221 1220
8 99 100 151 150 1170 1171 1222 1221
8 100 101 152 151 1171 1172 1223 1222
8 102 103 154 153 1173 1174 1225 1224
8 103 104 155 154 1174 1175 1226 1225
8 104 105 156 155 1175 1176 1227 1226
8 105 106 157 156 1176 1177 1228 1227
8 106 107 158 157 1177 1178 1229 1228
8 107 108 159 158 1178 1179 1230 1229
8 108 109 160 159 1179 1180 1231 1230
8 109 110 161 160 1180 1181 1232 1231
8 110 111 162 161 1181 1182 1233 1232
8 111 112 163 162 1182 1183 1234 1233
8 112 113 164 163 1183 1184 1235 1234
8 113 114 165 164 1184 1185 1236 1235
8 114 115 166 165 1185 1186 1237 1236
8 115 116 167 166 1186 1187 1238 1237
8 116 117 168 167 1187 1188 1239 1238
8 117 118 169 168 1188 1189 1240 1239
8 118 119 170 169 1189 1190 1241 1240
8 119 120 171 170 1190 1191 1242 1241
8 120 121 172 171 1191 1192 1243 1242
8 121 122 173 172 1192 1193 1244 1243
8 122 123 174 173 1193 1194 1245 1244
8 123 124 175 174 1194 1195 1246 1245
8 124 125 176 175 1195 1196 1247 1246
8 125 126 177 176 1196 1197 1248 1247
8 126 127 178 177 1197 1198 1249 1248
8 127 128 179 178 1198 1199 1250 1249
8 128 129 180 179 1199 1200 1251 1250
8 129 130 181 180 1200 1201 1252 1251
8 130 131 182 181 1201 1202 1253 1252
8 131 132 183 182 1202 1203 1254 1253
8 132 133 184 183 1203 1204 1255 1254
8 133 134 185 184 1204 1205 1256 1255
8 134 135 186 185 1205 1206 1257 1256
8 135 136 187 186 1206 1207 1258 1257
8 136 137 188 187 1207 1208 1259 1258
8 137 138 189 188 1208 1209 1260 1259
8 138 139 190 189 1209 1210 1261 1260
8 139 140 191 190 1210 1211 1262 1261
8 140 141 192 191 1211 1212 1263 1262
8 141 142 193 192 1212 1213 1264 1263
8 142 143 194 193 1213 1214 1265 1264
8 143 144 195 194 1214 1215 1266 1265
8 144 145 196 195 1215 1216 1267 1266
8 145 146 197 196 1216 1217 1268 1267
8 146 147 198 197 1217 1218 1269 1268
8 147 148 199 198 1218 1219 1270 1269
8 148 149 200 199 1219 1220 1271 1270
8 149 150 201 200 1220 1221 1272 1271
8 150 151 202 201 1221 1222 1273 1272
8 151 152 203 202 1222 1223 1274 1273
8 153 154 205 204 1224 1225 1276 1275
8 154 155 206 205 1225 1226 1277 1276
8 155 156 207 206 1226 1227 1278 1277
8 156 157 208 207 1227 1228 1279 1278
8 157 158 209 208 1228 1229 1280 1279
8 158 159 210 209 1229 1230 1281 1280
8 159 160 211 210 1230 1231 1282 1281
8 160 161 212 211 1231 1232 1283 1282
8 161 162 213 212 1232 1233 1284 1283
8 162 163 214 213 1233 1234 1285 1284
8 163 164 215 214 1234 1235 1286 1285
8 164 165 216 215 1235 1236 1287 1286
8 165 166 217 216 1236 1237 1288 1287
8 166 167 218 217 1237 1238 1289 1288
8 167 168 219 218 1238 1239 1290 1289
8 168 169 220 219 1239 1240 1291 1290
8 169 170 221 220 1240 1241 1292 1291
8 170 171 222 221 1241 1242 1293 1292
8 171 172 223 222 1242 1243 1294 1293
8 172 173 224 223 1243 1244 1295 1294
8 173 174 225 224 1244 1245 1296 1295
8 174 175 226 225 1245 1246 1297 1296
8 175 176 227 226 1246 1247 1298 1297
8 176 177 228 227 1247 1248 1299 1298
8 177 178 229 228 1248 1249 1300 1299
8 178 179 230 229 1249 1250 1301 1300
8 179 180 231 230 1250 1251 1302 1301
8 180 181 232 231 1251 1252 1303 1302
8 181 182 233 232 1252 1253 1304 1303
8 182 183 234 233 1253 1254 1305 1304
8 183 184 235 234 1254 1255 1306 1305
8 184 185 236 235 1255 1256 1307 1306
8 185 186 237 236 1256 1257 1308 1307
8 186 187 238 237 1257 1258 1309 1308
8 187 188 239 238 1258 1259 1310 1309
8 188 189 240 239 1259 1260 1311 1310
8 189 190 241 240 1260 1261 1312 1311
8 190 191 242 241 1261 1262 1313 1312
8 191 192 243 242 1262 1263 1314 1313
8 192 193 244 243 1263 1264 1315 1314
8 193 194 245 244 1264 1265 1316 1315
8 194 195 246 245 1265 1266 1317 1316
8 195 196 247 246 1266 1267 1318 1317
8 196 197 248 247 1267 1268 1319 1318
8 197 198 249 248 1268 1269 1320 1319
8 198 199 250 249 1269 1270 1321 1320
8 199 200 251 250 1270 1271 1322 1321
8 200 201 252 251 1271 1272 1323 1322
8 201 202 253 252 1272 1273 1324 1323
8 202 203 254 253 1273 1274 1325 1324
8 204 205 256 255 1275 1276 1327 1326
8 205 206 257 256 1276 1277 1328 1327
8 206 207 258 257 1277 1278 1329 1328
8 207 208 259 258 1278 1279 1330 1329
8 208 209 260 259 1279 1280 1331 1330
8 209 210 261 260 1280 1281 1332 1331
8 210 211 262 261 1281 1282 1333 1332
8 211 212 263 262 1282 1283 1334 1333
8 212 213 264 263 1283 1284 1335 1334
8 213 214 265 264 1284 1285 1336 1335
8 214 215 266 265 1285 1286 1337 1336
8 215 216 267 266 1286 1287 1338 1337
8 216 217 268 267 1287 1288 1339 1338
8 217 218 269 268 1288 1289 1340 1339
8 218 219 270 269 1289 1290 1341 1340
8 219 220 271 270 1290 1291 1342 1341
8 220 221 272 271 1291 1292 1343 1342
8 221 222 273 272 1292 1293 1344 1343
8 222 223 274 273 1293 1294 1345 1344
8 223 224 275 274 1294 1295 1346 1345
8 224 225 276 275 1295 1296 1347 1346
8 225 226 277 276 1296 1297 1348 1347
8 226 227 278 277 1297 1298 1349 1348
8 227 228 279 278 1298 1299 1350 1349
8 228 229 280 279 1299 1300 1351 1350
8 229 230 281 280 1300 1301 1352 1351
8 230 231 282 281 1301 1302 1353 1352
8 231 232 283 282 1302 1303 1354 1353
8 232 233 284 283 1303 1304 1355 1354
8 233 234 285 284 1304 1305 1356 1355
8 234 235 286 285 1305 1306 1357 1356
8 235 236 287 286 1306 1307 1358 1357
8 236 237 288 287 1307 1308 1359 1358
8 237 238 289 288 1308 1309 1360 1359
8 238 239 290 289 1309 1310 1361 1360
8 239 240 291 290 1310 1311 1362 1361
8 240 241 292 291 1311 1312 1363 1362
8 241 242 293 292 1312 1313 1364 1363
8 242 243 294 293 1313 1314 1365 1364
8 243 244 295 294 1314 1315 1366 1365
8 244 245 296 295 1315 1316 1367 1366
8 245 246 297 296 1316 1317 1368 1367
8 246 247 298 297 1317 1318 1369 1368
8 247 248 299 298 1318 1319 1370 1369
8 248 249 300 299 1319 1320 1371 1370
8 249 250 301 300 1320 1321 1372 1371
8 250 251 302 301 1321 1322 1373 1372
8 251 252 303 302 1322 1323 1374 1373
8 252 253 304 303 1323 1324 1375 1374
8 253 254 305 304 1324 1325 1376 1375
8 255 256 307 306 1326 1327 1378 1377
8 256 257 308 307 1327 1328 1379 1378
8 257 258 309 308 1328 1329 1380 1379
8 258 259 310 309 1329 1330 1381 1380
8 259 260 311 310 1330 1331 1382 1381
8 260 261 312 311 1331 1332 1383 1382
8 261 262 313 312 1332 1333 1384 1383
8 262 263 314 313 1333 1334 1385 1384
8 263 264 315 314 1334 1335 1386 1385
8 264 265 316 315 1335 1336 1387 1386
8 265 266 317 316 1336 1337 1388 1387
8 266 267 318 317 1337 1338 1389 1388
8 267 268 319 318 1338 1339 1390 1389
8 268 269 320 319 1339 1340 1391 1390
8 269 270 321 320 1340 1341 1392 1391
8 270 271 322 321 1341 1342 1393 1392
8 271 272 323 322 1342 1343 1394 1393
8 272 273 324 323 1343 1344 1395 1394
8 273 274 325 324 1344 1345 1396 1395
8 274 275 326 325 1345 1346 1397 1396
8 275 276 327 326 1346 1347 1398 1397
8 276 277 328 327 1347 1348 1399 1398
8 277 278 329 328 1348 1349 1400 1399
8 278 279 330 329 1349 1350 1401 1400
8 279 280 331 330 1350 1351 1402 1401
8 280 281 332 331 1351 1352 1403 1402
8 281 282 333 332 1352 1353 1404 1403
8 282 283 334 333 1353 1354 1405 1404
8 283 284 335 334 1354 1355 1406 1405
8 284 285 336 335 1355 1356 1407 1406
8 285 286 337 336 1356 1357 1408 1407
8 286 287 338 337 1357 1358 1409 1408
8 287 288 339 338 1358 1359 1410 1409
8 288 289 340 339 1359 1360 1411 1410
8 289 290 341 340 1360 1361 1412 1411
8 290 291 342 341 1361 1362 1413 1412
8 291 292 343 342 1362 1363 1414 1413
8 292 293 344 343 1363 1364 1415 1414
8 293 294 345 344 1364 1365 1416 1415
8 294 295 346 345 1365 1366 1417 1416
8 295 296 347 346 1366 1367 1418 1417
8 296 297 348 347 1367 1368 1419 1418
8 297 298 349 348 1368 1369 1420 1419
8 298 299 350 349 1369 1370 1421 1420
8 299 300 351 350 1370 1371 1422 1421
8 300 301 352 351 1371 1372 1423 1422
8 301 302 353 352 1372 1373 1424 1423
8 302 303 354 353 1373 1374 1425 1424
8 303 304 355 354 1374 1375 1426 1425
8 304 305 356 355 1375 1376 1427 1426
8 306 307 358 357 1377 1378 1429 1428
8 307 308 359 358 1378 1379 1430 1429
8 308 309 360 359 1379 1380 1431 1430
8 309 310 361 360 1380 1381 1432 1431
8 310 311 362 361 1381 1382 1433 1432
8 311 312 363 362 1382 1383 1434 1433
8 312 313 364 363 1383 1384 1435 1434
8 313 314 365 364 1384 1385 1436 1435
8 314 315 366 365 1385 1386 1437 1436
8 315 316 367 366 1386 1387 1438 1437
8 316 317 368 367 1387 1388 1439 1438
8 317 318 369 368 1388 1389 1440 1439
8 318 319 370 369 1389 1390 1441 1440
8 319 320 371 370 1390 1391 1442 1441
8 320 321 372 371 1391 1392 1443 1442
8 321 322 373 372 1392 1393 1444 1443
8 322 323 374 373 1393 1394 1445 1444
8 323 324 375 374 1394 1395 1446 1445
8 324 325 376 375 1395 1396 1447 1446
8 325 326 377 376 1396 1397 1448 1447
8 326 327 378 377 1397 1398 1449 1448
8 327 328 379 378 1398 1399 1450 1449
8 328 329 380 379 1399 1400 1451 1450
8 329 330 381 380 1400 1401 1452 1451
8 330 331 382 381 1401 1402 1453 1452
8 331 332 383 382 1402 1403 1454 1453
8 332 333 384 383 1403 1404 1455 1454
8 333 334 385 384 1404 1405 1456 1455
8 334 335 386 385 1405 1406 1457 1456
8 335 336 387 386 1406 1407 1458 1457
8 336 337 388 387 1407 1408 1459 1458
8 337 338 389 388 1408 1409 1460 1459
8 338 339 390 389 1409 1410 1461 1460
8 339 340 391 390 1410 1411 1462 1461
8 340 341 392 391 1411 1412 1463 1462
8 341 342 393 392 1412 1413 1464 1463
8 342 343 394 393 1413 1414 1465 1464
8 343 344 395 394 1414 1415 1466 1465
8 344 345 396 395 1415 1416 1467 1466
8 345 346 397 396 1416 1417 1468 1467
8 346 347 398 397 1417 1418 1469 1468
8 347 348 399 398 1418 1419 1470 1469
8 348 349 400 399 1419 1420 1471 1470
8 349 350 401 400 1420 1421 1472 1471
8 350 351 402 401 1421 1422 1473 1472
8 351 352 403 402 1422 1423 1474 1473
8 352 353 404 403 1423 1424 1475 1474
8 353 354 405 404 1424 1425 1476 1475
8 354 355 406 405 1425 1426 1477 1476
8 355 356 407 406 1426 1427 1478 1477
8 357 358 409 408 1428 1429 1480 1479
8 358 359 410 409 1429 1430 1481 1480
8 359 360 411 410 1430 1431 1482 1481
8 360 361 412 411 1431 1432 1483 1482
8 361 362 413 412 1432 1433 1484 1483
8 362 363 414 413 1433 1434 1485 1484
8 363 364 415 414 1434 1435 1486 1485
8 364 365 416 415 1435 1436 1487 1486
8 365 366 417 416 1436 1437 1488 1487
8 366 367 418 417 1437 1438 1489 1488
8 367 368 419 418 1438 1439 1490 1489
8 368 369 420 419 1439 1440 1491 1490
8 369 370 421 420 1440 1441 1492 1491
8 370 371 422 421 1441 1442 1493 1492
8 371 372 423 422 1442 1443 1494 1493
8 372 373 424 423 1443 1444 1495 1494
8 373 374 425 424 1444 1445 1496 1495
8 374 375 426 425 1445 1446 1497 1496
8 375 376 427 426 1446 1447 1498 1497
8 376 377 428 427 1447 1448 1499 1498
8 377 378 429 428 1448 1449 1500 1499
8 378 379 430 429 1449 1450 1501 1500
8 379 380 431 430 1450 1451 1502 1501
8 380 381 432 431 1451 1452 1503 1502
8 381 382 433 432 1452 1453 1504 1503
8 382 383 434 433 1453 1454 1505 1504
8 383 384 435 434 1454 1455 1506 1505
8 384 385 436 435 1455 1456 1507 1506
8 385 386 437 436 1456 1457 1508 1507
8 386 387 438 437 1457 1458 1509 1508
8 387 388 439 438 1458 1459 1510 1509
8 388 389 440 439 1459 1460 1511 1510
8 389 390 441 440 1460 1461 1512 1511
8 390 391 442 441 1461 1462 1513 1512
8 391 392 443 442 1462 1463 1514 1513
8 392 393 444 443 1463 1464 1515 1514
8 393 394 445 444 1464 1465 1516 1515
8 394 395 446 445 1465 1466 1517 1516
8 395 396 447 446 1466 1467 1518 1517
8 396 397 448 447 1467 1468 1519 1518
8 397 398 449 448 1468 1469 1520 1519
8 398 399 450 449 1469 1470 1521 1520
8 399 400 451 450 1470 1471 1522 1521
8 400 401 452 451 1471 1472 1523 1522
8 401 402 453 452 1472 1473 1524 1523
8 402 403 454 453 1473 1474 1525 1524
8 403 404 455 454 1474 1475 1526 1525
8 404 405 456 455 1475 1476 1527 1526
8 405 406 457 456 1476 1477 1528 1527
8 406 407 458 457 1477 1478 1529 1528
8 408 409 460 459 1479 1480 1531 1530
8 409 410 461 460 1480 1481 1532 1531
8 410 411 462 461 1481 1482 1533 1532
8 411 412 463 462 1482 1483 1534 1533
8 412 413 464 463 1483 1484 1535 1534
8 413 414 465 464 1484 1485 1536 1535
8 414 415 466 465 1485 1486 1537 1536
8 415 416 467 466 1486 1487 1538 1537
8 416 417 468 467 1487 1488 1539 1538
8 417 418 469 468 1488 1489 1540 1539
8 418 419 470 469 1489 1490 1541 1540
8 419 420 471 470 1490 1491 1542 1541
8 420 421 472 471 1491 1492 1543 1542
8 421 422 473 472 1492 1493 1544 1543
8 422 423 474 473 1493 1494 1545 1544
8 423 424 475 474 1494 1495 1546 1545
8 424 425 476 475 1495 1496 1547 1546
8 425 426 477 476 1496 1497 1548 1547
8 426 427 478 477 1497 1498 1549 1548
8 427 428 479 478 1498 1499 1550 1549
8 428 429 480 479 1499 1500 1551 1550
8 429 430 481 480 1500 1501 1552 1551
8 430 431 482 481 1501 1502 1553 1552
8 431 432 483 482 1502 1503 1554 1553
8 432 433 484 483 1503 1504 1555 1554
8 433 434 485 484 1504 1505 1556 1555
8 434 435 486 485 1505 1506 1557 1556
8 435 436 487 486 1506 1507 1558 1557
8 436 437 488 487 1507 1508 1559 1558
8 437 438 489 488 1508 1509 1560 1559
8 438 439 490 489 1509 1510 1561 1560
8 439 440 491 490 1510 1511 1562 1561
8 440 441 492 491 1511 1512 1563 1562
8 441 442 493 492 1512 1513 1564 1563
8 442 443 494 493 1513 1514 1565 1564
8 443 444 495 494 1514 1515 1566 1565
8 444 445 496 495 1515 1516 1567 1566
8 445 446 497 496 1516 1517 1568 1567
8 446 447 498 497 1517 1518 1569 1568
8 447 448 499 498 1518 1519 1570 1569
8 448 449 500 499 1519 1520 1571 1570
8 449 450 501 500 1520 1521 1572 1571
8 450 451 502 501 1521 1522 1573 1572
8 451 452 503 502 1522 1523 1574 1573
8 452 453 504 503 1523 1524 1575 1574
8 453 454 505 504 1524 1525 1576 1575
8 454 455 506 505 1525 1526 1577 1576
8 455 456 507 506 1526 1527 1578 1577
8 456 457 508 507 1527 1528 1579 1578
8 457 458 509 508 1528 1529 1580 1579
8 459 460 511 510 1530 1531 1582 1581
8 460 461 512 511 1531 1532 1583 1582
8 461 462 513 512 1532 1533 1584 1583
8 462 463 514 513 1533 1534 1585 1584
8 463 464 515 514 1534 1535 1586 1585
8 464 465 516 515 1535 1536 1587 1586
8 465 466 517 516 1536 1537 1588 1587
8 466 467 518 517 1537 1538 1589 1588
8 467 468 519 518 1538 1539 1590 1589
8 468 469 520 519 1539 1540 1591 1590
8 469 470 521 520 1540 1541 1592 1591
8 470 471 522 521 1541 1542 1593 1592
8 471 472 523 522 1542 1543 1594 1593
8 472 473 524 523 1543 1544 1595 1594
8 473 474 525 524 1544 1545 1596 1595
8 474 475 526 525 1545 1546 1597 1596
8 475 476 527 526 1546 1547 1598 1597
8 476 477 528 527 1547 1548 1599 1598
8 477 478 529 528 1548 1549 1600 1599
8 478 479 530 529 1549 1550 1601 1600
8 479 480 531 530 1550 1551 1602 1601
8 480 481 532 531 1551 1552 1603 1602
8 481 482 533 532 1552 1553 1604 1603
8 482 483 534 533 1553 1554 1605 1604
8 483 484 535 534 1554 1555 1606 1605
8 484 485 536 535 1555 1556 1607 1606
8 485 486 537 536 1556 1557 1608 1607
8 486 487 538 537 1557 1558 1609 1608
8 487 488 539 538 1558 1559 1610 1609
8 488 489 540 539 1559 1560 1611 1610
8 489 490 541 540 1560 1561 1612 1611
8 490 491 542 541 1561 1562 1613 1612
8 491 492 543 542 1562 1563 1614 1613
8 492 493 544 543 1563 1564 1615 1614
8 493 494 545 544 1564 1565 1616 1615
8 494 495 546 545 1565 1566 1617 1616
8 495 496 547 546 1566 1567 1618 1617
8 496 497 548 547 1567 1568 1619 1618
8 497 498 549 548 1568 1569 1620 1619
8 498 499 550 549 1569 1570 1621 1620
8 499 500 551 550 1570 1571 1622 1621
8 500 501 552 551 1571 1572 1623 1622
8 501 502 553 552 1572 1573 1624 1623
8 502 503 554 553 1573 1574 1625 1624
8 503 504 555 554 1574 1575 1626 1625
8 504 505 556 555 1575 1576 1627 1626
8 505 506 557 556 1576 1577 1628 1627
8 506 507 558 557 1577 1578 1629 1628
8 507 508 559 558 1578 1579 1630 1629
8 508 509 560 559 1579 1580 1631 1630
8 510 511 562 561 1581 1582 1633 1632
8 511 512 563 562 1582 1583 1634 1633
8 512 513 564 563 1583 1584 1635 1634
8 513 514 565 564 1584 1585 1636 1635
8 514 515 566 565 1585 1586 1637 1636
8 515 516 567 566 1586 1587 1638 1637
8 516 517 568 567 1587 1588 1639 1638
8 517 518 569 568 1588 1589 1640 1639
8 518 519 570 569 1589 1590 1641 1640
8 519 520 571 570 1590 1591 1642 1641
8 520 521 572 571 1591 1592 1643 1642
8 521 522 573 572 1592 1593 1644 1643
8 522 523 574 573 1593 1594 1645 1644
8 523 524 575 574 1594 1595 1646 1645
8 524 525 576 575 1595 1596 1647 1646
8 525 526 577 576 1596 1597 1648 1647
8 526 527 578 577 1597 1598 1649 1648
8 527 528 579 578 1598 1599 1650 1649
8 528 529 580 579 1599 1600 1651 1650
8 529 530 581 580 1600 1601 1652 1651
8 530 531 582 581 1601 1602 1653 1652
8 531 532 583 582 1602 1603 1654 1653
8 532 533 584 583 1603 1604 1655 1654
8 533 534 585 584 1604 1605 1656 1655
8 534 535 586 585 1605 1606 1657 1656
8 535 536 587 586 1606 1607 1658 1657
8 536 537 588 587 1607 1608 1659 1658
8 537 538 589 588 1608 1609 1660 1659
8 538 539 590 589 1609 1610 1661 1660
8 539 540 591 590 1610 1611 1662 1661
8 540 541 592 591 1611 1612 1663 1662
8 541 542 593 592 1612 1613 1664 1663
8 542 543 594 593 1613 1614 1665 1664
8 543 544 595 594 1614 1615 1666 1665
8 544 545 596 595 1615 1616 1667 1666
8 545 546 597 596 1616 1617 1668 1667
8 546 547 598 597 1617 1618 1669 1668
8 547 548 599 598 1618 1619 1670 1669
8 548 549 600 599 1619 1620 1671 1670
8 549 550 601 600 1620 1621 1672 1671
8 550 551 602 601 1621 1622 1673 1672
8 551 552 603 602 1622 1623 1674 1673
8 552 553 604 603 1623 1624 1675 1674
8 553 554 605 604 1624 1625 1676 1675
8 554 555 606 605 1625 1626 1677 1676
8 555 556 607 606 1626 1627 1678 1677
8 556 557 608 607 1627 1628 1679 1678
8 557 558 609 608 1628 1629 1680 1679
8 558 559 610 609 1629 1630 1681 1680
8 559 560 611 610 1630 1631 1682 1681
8 561 562 613 612 1632 1633 1684 1683
8 562 563 614 613 1633 1634 1685 1684
8 563 564 615 614 1634 1635 1686 1685
8 564 565 616 615 1635 1636 1687 1686
8 565 566 617 616 1636 1637 1688 1687
8 566 567 618 617 1637 1638 1689 1688
8 567 568 619 618 1638 1639 1690 1689
8 568 569 620 619 1639 1640 1691 1690
8 569 570 621 620 1640 1641 1692 1691
8 570 571 622 621 1641 1642 1693 1692
8 571 572 623 622 1642 1643 1694 1693
8 572 573 624 623 1643 1644 1695 1694
8 573 574 625 624 1644 1645 1696 1695
8 574 575 626 625 1645 1646 1697 1696
8 575 576 627 626 1646 1647 1698 1697
8 576 577 628 627 1647 1648 1699 1698
8 577 578 629 628 1648 1649 1700 1699
8 578 579 630 629 1649 1650 1701 1700
8 579 580 631 630 1650 1651 1702 1701
8 580 581 632 631 1651 1652 1703 1702
8 581 582 633 632 1652 1653 1704 1703
8 582 583 634 633 1653 1654 1705 1704
8 583 584 635 634 1654 1655 1706 1705
8 584 585 636 635 1655 1656 1707 1706
8 585 586 637 636 1656 1657 1708 1707
8 586 587 638 637 1657 1658 1709 1708
8 587 588 639 638 1658 1659 1710 1709
8 588 589 640 639 1659 1660 1711 1710
8 589 590 641 640 1660 1661 1712 1711
8 590 591 642 641 1661 1662 1713 1712
8 591 592 643 642 1662 1663 1714 1713
8 592 593 644 643 1663 1664 1715 1714
8 593 594 645 644 1664 1665 1716 1715
8 594 595 646 645 1665 1666 1717 1716
8 595 596 647 646 1666 1667 1718 1717
8 596 597 648 647 1667 1668 1719 1718
8 597 598 649 648 1668 1669 1720 1719
8 598 599 650 649 1669 1670 1721 1720
8 599 600 651 650 1670 1671 1722 1721
8 600 601 652 651 1671 1672 1723 1722
8 601 602 653 652 1672 1673 1724 1723
8 602 603 654 653 1673 1674 1725 1724
8 603 604 655 654 1674 1675 1726 1725
8 604 605 656 655 1675 1676 1727 1726
8 605 606 657 656 1676 1677 1728 1727
8 606 607 658 657 1677 1678 1729 1728
8 607 608 659 658 1678 1679 1730 1729
8 608 609 660 659 1679 1680 1731 1730
8 609 610 661 660 1680 1681 1732 1731
8 610 611 662 661 1681 1682 1733 1732
8 612 613 664 663 1683 1684 1735 1734
8 613 614 665 664 1684 1685 1736 1735
8 614 615 666 665 1685 1686 1737 1736
8 615 616 667 666 1686 1687 1738 1737
8 616 617 668 667 1687 1688 1739 1738
8 617 618 669 668 1688 1689 1740 1739
8 618 619 670 669 1689 1690 1741 1740
8 619 620 671 670 1690 1691 1742 1741
8 620 621 672 671 1691 1692 1743 1742
8 621 622 673 672 1692 1693 1744 1743
8 622 623 674 673 1693 1694 1745 1744
8 623 624 675 674 1694 1695 1746 1745
8 624 625 676 675 1695 1696 1747 1746
8 625 626 677 676 1696 1697 1748 1747
8 626 627 678 677 1697 1698 1749 1748
8 627 628 679 678 1698 1699 1750 1749
8 628 629 680 679 1699 1700 1751 1750
8 629 630 681 680 1700 1701 1752 1751
8 630 631 682 681 1701 1702 1753 1752
8 631 632 683 682 1702 1703 1754 1753
8 632 633 684 683 1703 1704 1755 1754
8 633 634 685 684 1704 1705 1756 1755
8 634 635 686 685 1705 1706 1757 1756
8 635 636 687 686 1706 1707 1758 1757
8 636 637 688 687 1707 1708 1759 1758
8 637 638 689 688 1708 1709 1760 1759
8 638 639 690 689 1709 1710 1761 1760
8 639 640 691 690 1710 1711 1762 1761
8 640 641 692 691 1711 1712 1763 1762
8 641 642 693 692 1712 1713 1764 1763
8 642 643 694 693 1713 1714 1765 1764
8 643 644 695 694 1714 1715 1766 1765
8 644 645 696 695 1715 1716 1767 1766
8 645 646 697 696 1716 1717 1768 1767
8 646 647 698 697 1717 1718 1769 1768
8 647 648 699 698 1718 1719 1770 1769
8 648 649 700 699 1719 1720 1771 1770
8 649 650 701 700 1720 1721 1772 1771
8 650 651 702 701 1721 1722 1773 1772
8 651 652 703 702 1722 1723 1774 1773
8 652 653 704 703 1723 1724 1775 1774
8 653 654 705 704 1724 1725 1776 1775
8 654 655 706 705 1725 1726 1777 1776
8 655 656 707 706 1726 1727 1778 1777
8 656 657 708 707 1727 1728 1779 1778
8 657 658 709 708 1728 1729 1780 1779
8 658 659 710 709 1729 1730 1781 1780
8 659 660 711 710 1730 1731 1782 1781
8 660 661 712 711 1731 1732 1783 1782
8 661 662 713 712 1732 1733 1784 1783
8 663 664 715 714 1734 1735 1786 1785
8 664 665 716 715 1735 1736 1787 1786
8 665 666 717 716 1736 1737 1788 1787
8 666 667 718 717 1737 1738 1789 1788
8 667 668 719 718 1738 1739 1790 1789
8 668 669 720 719 1739 1740 1791 1790
8 669 670 721 720 1740 1741 1792 1791
8 670 671 722 721 1741 1742 1793 1792
8 671 672 723 722 1742 1743 1794 1793
8 672 673 724 723 1743 1744 1795 1794
8 673 674 725 724 1744 1745 1796 1795
8 674 675 726 725 1745 1746 1797 1796
8 675 676 727 726 1746 1747 1798 1797
8 676 677 728 727 1747 1748 1799 1798
8 677 678 729 728 1748 1749 1800 1799
8 678 679 730 729 1749 1750 1801 1800
8 679 680 731 730 1750 1751 1802 1801
8 680 681 732 731 1751 1752 1803 1802
8 681 682 733 732 1752 1753 1804 1803
8 682 683 734 733 1753 1754 1805 1804
8 683 684 735 734 1754 1755 1806 1805
8 684 685 736 735 1755 1756 1807 1806
8 685 686 737 736 1756 1757 1808 1807
8 686 687 738 737 1757 1758 1809 1808
8 687 688 739 738 1758 1759 1810 1809
8 688 689 740 739 1759 1760 1811 1810
8 689 690 741 740 1760 1761 1812 1811
8 690 691 742 741 1761 1762 1813 1812
8 691 692 743 742 1762 1763 1814 1813
8 692 693 744 743 1763 1764 1815 1814
8 693 694 745 744 1764 1765 1816 1815
8 694 695 746 745 1765 1766 1817 1816
8 695 696 747 746 1766 1767 1818 1817
8 696 697 748 747 1767 1768 1819 1818
8 697 698 749 748 1768 1769 1820 1819
8 698 699 750 749 1769 1770 1821 1820
8 699 700 751 750 1770 1771 1822 1821
8 700 701 752 751 1771 1772 1823 1822
8 701 702 753 752 1772 1773 1824 1823
8 702 703 754 753 1773 1774 1825 1824
8 703 704 755 754 1774 1775 1826 1825
8 704 705 756 755 1775 1776 1827 1826
8 705 706 757 756 1776 1777 1828 1827
8 706 707 758 757 1777 1778 1829 1828
8 707 708 759 758 1778 1779 1830 1829
8 708 709 760 759 1779 1780 1831 1830
8 709 710 761 760 1780 1781 1832 1831
8 710 711 762 761 1781 1782 1833 1832
8 711 712 763 762 1782 1783 1834 1833
8 712 713 764 763 1783 1784 1835 1834
8 714 715 766 765 1785 1786 1837 1836
8 715 716 767 766 1786 1787 1838 1837
8 716 717 768 767 1787 1788 1839 1838
8 717 718 769 768 1788 1789 1840 1839
8 718 719 770 769 1789 1790 1841 1840
8 719 720 771 770 1790 1791 1842 1841
8 720 721 772 771 1791 1792 1843 1842
8 721 722 773 772 1792 1793 1844 1843
8 722 723 774 773 1793 1794 1845 1844
8 723 724 775 774 1794 1795 1846 1845
8 724 725 776 775 1795 1796 1847 1846
8 725 726 777 776 1796 1797 1848 1847
8 726 727 778 777 1797 1798 1849 1848
8 727 728 779 778 1798 1799 1850 1849
8 728 729 780 779 1799 1800 1851 1850
8 729 730 781 780 1800 1801 1852 1851
8 730 731 782 781 1801 1802 1853 1852
8 731 732 783 782 1802 1803 1854 1853
8 732 733 784 783 1803 1804 1855 1854
8 733 734 785 784 1804 1805 1856 1855
8 734 735 786 785 1805 1806 1857 1856
8 735 736 787 786 1806 1807 1858 1857
8 736 737 788 787 1807 1808 1859 1858
8 737 738 789 788 1808 1809 1860 1859
8 738 739 790 789 1809 1810 1861 1860
8 739 740 791 790 1810 1811 1862 1861
8 740 741 792 791 1811 1812 1863 1862
8 741 742 793 792 1812 1813 1864 1863
8 742 743 794 793 1813 1814 1865 1864
8 743 744 795 794 1814 1815 1866 1865
8 744 745 796 795 1815 1816 1867 1866
8 745 746 797 796 1816 1817 1868 1867
8 746 747 798 797 1817 1818 1869 1868
8 747 748 799 798 1818 1819 1870 1869
8 748 749 800 799 1819 1820 1871 1870
8 749 750 801 800 1820 1821 1872 1871
8 750 751 802 801 1821 1822 1873 1872
8 751 752 803 802 1822 1823 1874 1873
8 752 753 804 803 1823 1824 1875 1874
8 753 754 805 804 1824 1825 1876 1875
8 754 755 806 805 1825 1826 1877 1876
8 755 756 807 806 1826 1827 1878 1877
8 756 757 808 807 1827 1828 1879 1878
8 757 758 809 808 1828 1829 1880 1879
8 758 759 810 809 1829 1830 1881 1880
8 759 760 811 810 1830 1831 1882 1881
8 760 761 812 811 1831 1832 1883 1882
8 761 762 813 812 1832 1833 1884 1883
8 762 763 814 813 1833 1834 1885 1884
8 763 764 815 814 1834 1835 1886 1885
8 765 766 817 816 1836 1837 1888 1887
8 766 767 818 817 1837 1838 1889 1888
8 767 768 819 818 1838 1839 1890 1889
8 768 769 820 819 1839 1840 1891 1890
8 769 770 821 820 1840 1841 1892 1891
8 770 771 822 821 1841 1842 1893 1892
8 771 772 823 822 1842 1843 1894 1893
8 772 773 824 823 1843 1844 1895 1894
8 773 774 825 824 1844 1845 1896 1895
8 774 775 826 825 1845 1846 1897 1896
8 775 776 827 826 1846 1847 1898 1897
8 776 777 828 827 1847 1848 1899 1898
8 777 778 829 828 1848 1849 1900 1899
8 778 779 830 829 1849 1850 1901 1900
8 779 780 831 830 1850 1851 1902 1901
8 780 781 832 831 1851 1852 1903 1902
8 781 782 833 832 1852 1853 1904 1903
8 782 783 834 833 1853 1854 1905 1904
8 783 784 835 834 1854 1855 1906 1905
8 784 785 836 835 1855 1856 1907 1906
8 785 786 837 836 1856 1857 1908 1907
8 786 787 838 837 1857 1858 1909 1908
8 787 788 839 838 1858 1859 1910 1909
8 788 789 840 839 1859 1860 1911 1910
8 789 790 841 840 1860 1861 1912 1911
8 790 791 842 841 1861 1862 1913 1912
8 791 792 843 842 1862 1863 1914 1913
8 792 793 844 843 1863 1864 1915 1914
8 793 794 845 844 1864 1865 1916 1915
8 794 795 846 845 1865 1866 1917 1916
8 795 796 847 846 1866 1867 1918 1917
8 796 797 848 847 1867 1868 1919 1918
8 797 798 849 848 1868 1869 1920 1919
8 798 799 850 849 1869 1870 1921 1920
8 799 800 851 850 1870 1871 1922 1921
8 800 801 852 851 1871 1872 1923 1922
8 801 802 853 852 1872 1873 1924 1923
8 802 803 854 853 1873 1874 1925 1924
8 803 804 855 854 1874 1875 1926 1925
8 804 805 856 855 1875 1876 1927 1926
8 805 806 857 856 1876 1877 1928 1927
8 806 807 858 857 1877 1878 1929 1928
8 807 808 859 858 1878 1879 1930 1929
8 808 809 860 859 1879 1880 1931 1930
8 809 810 861 860 1880 1881 1932 1931
8 810 811 862 861 1881 1882 1933 1932
8 811 812 863 862 1882 1883 1934 1933
8 812 813 864 863 1883 1884 1935 1934
8 813 814 865 864 1884 1885 1936 1935
8 814 815 866 865 1885 1886 1937 1936
8 816 817 868 867 1887 1888 1939 1938
8 817 818 869 868 1888 1889 1940 1939
8 818 819 870 869 1889 1890 1941 1940
8 819 820 871 870 1890 1891 1942 1941
8 820 821 872 871 1891 1892 1943 1942
8 821 822 873 872 1892 1893 1944 1943
8 822 823 874 873 1893 1894 1945 1944
8 823 824 875 874 1894 1895 1946 1945
8 824 825 876 875 1895 1896 1947 1946
8 825 826 877 876 1896 1897 1948 1947
8 826 827 878 877 1897 1898 1949 1948
8 827 828 879 878 1898 1899 1950 1949
8 828 829 880 879 1899 1900 1951 1950
8 829 830 881 880 1900 1901 1952 1951
8 830 831 882 881 1901 1902 1953 1952
8 831 832 883 882 1902 1903 1954 1953
8 832 833 884 883 1903 1904 1955 1954
8 833 834 885 884 1904 1905 1956 1955
8 834 835 886 885 1905 1906 1957 1956
8 835 836 887 886 1906 1907 1958 1957
8 836 837 888 887 1907 1908 1959 1958
8 837 838 889 888 1908 1909 1960 1959
8 838 839 890 889 1909 1910 1961 1960
8 839 840 891 890 1910 1911 1962 1961
8 840 841 892 891 1911 1912 1963 1962
8 841 842 893 892 1912 1913 1964 1963
8 842 843 894 893 1913 1914 1965 1964
8 843 844 895 894 1914 1915 1966 1965
8 844 845 896 895 1915 1916 1967 1966
8 845 846 897 896 1916 1917 1968 1967
8 846 847 898 897 1917 1918 1969 1968
8 847 848 899 898 1918 1919 1970 1969
8 848 849 900 899 1919 1920 1971 1970
8 849 850 901 900 1920 1921 1972 1971
8 850 851 902 901 1921 1922 1973 1972
8 851 852 903 902 1922 1923 1974 1973
8 852 853 904 903 1923 1924 1975 1974
8 853 854 905 904 1924 1925 1976 1975
8 854 855 906 905 1925 1926 1977 1976
8 855 856 907 906 1926 1927 1978 1977
8 856 857 908 907 1927 1928 1979 1978
8 857 858 909 908 1928 1929 1980 1979
8 858 859 910 909 1929 1930 1981 1980
8 859 860 911 910 1930 1931 1982 1981
8 860 861 912 911 1931 1932 1983 1982
8 861 862 913 912 1932 1933 1984 1983
8 862 863 914 913 1933 1934 1985 1984
8 863 864 915 914 1934 1935 1986 1985
8 864 865 916 915 1935 1936 1987 1986
8 865 866 917 916 1936 1937 1988 1987
8 867 868 919 918 1938 1939 1990 1989
8 868 869 920 919 1939 1940 1991 1990
8 869 870 921 920 1940 1941 1992 1991
8 870 871 922 921 1941 1942 1993 1992
8 871 872 923 922 1942 1943 1994 1993
8 872 873 924 923 1943 1944 1995 1994
8 873 874 925 924 1944 1945 1996 1995
8 874 875 926 925 1945 1946 1997 1996
8 875 876 927 926 1946 1947 1998 1997
8 876 877 928 927 1947 1948 1999 1998
8 877 878 929 928 1948 1949 2000 1999
8 878 879 930 929 1949 1950 2001 2000
8 879 880 931 930 1950 1951 2002 2001
8 880 881 932 931 1951 1952 2003 2002
8 881 882 933 932 1952 1953 2004 2003
8 882 883 934 933 1953 1954 2005 2004
8 883 884 935 934 1954 1955 2006 2005
8 884 885 936 935 1955 1956 2007 2006
8 885 886 937 936 1956 1957 2008 2007
8 886 887 938 937 1957 1958 2009 2008
8 887 888 939 938 1958 1959 2010 2009
8 888 889 940 939 1959 1960 2011 2010
8 889 890 941 940 1960 1961 2012 2011
8 890 891 942 941 1961 1962 2013 2012
8 891 892 943 942 1962 1963 2014 2013
8 892 893 944 943 1963 1964 2015 2014
8 893 894 945 944 1964 1965 2016 2015
8 894 895 946 945 1965 1966 2017 2016
8 895 896 947 946 1966 1967 2018 2017
8 896 897 948 947 1967 1968 2019 2018
8 897 898 949 948 1968 1969 2020 2019
8 898 899 950 949 1969 1970 2021 2020
8 899 900 951 950 1970 1971 2022 2021
8 900 901 952 951 1971 1972 2023 2022
8 901 902 953 952 1972 1973 2024 2023
8 902 903 954 953 1973 1974 2025 2024
8 903 904 955 954 1974 1975 2026 2025
8 904 905 956 955 1975 1976 2027 2026
8 905 906 957 956 1976 1977 2028 2027
8 906 907 958 957 1977 1978 2029 2028
8 907 908 959 958 1978 1979 2030 2029
8 908 909 960 959 1979 1980 2031 2030
8 909 910 961 960 1980 1981 2032 2031
8 910 911 962 961 1981 1982 2033 2032
8 911 912 963 962 1982 1983 2034 2033
8 912 913 964 963 1983 1984 2035 2034
8 913 914 965 964 1984 1985 2036 2035
8 914 915 966 965 1985 1986 2037 2036
8 915 916 967 966 1986 1987 2038 2037
8 916 917 968 967 1987 1988 2039 2038
8 918 919 970 969 1989 1990 2041 2040
8 919 920 971 970 1990 1991 2042 2041
8 920 921 972 971 1991 1992 2043 2042
8 921 922 973 972 1992 1993 2044 2043
8 922 923 974 973 1993 1994 2045 2044
8 923 924 975 974 1994 1995 2046 2045
8 924 925 976 975 1995 1996 2047 2046
8 925 926 977 976 1996 1997 2048 2047
8 926 927 978 977 1997 1998 2049 2048
8 927 928 979 978 1998 1999 2050 2049
8 928 929 980 979 1999 2000 2051 2050
8 929 930 981 980 2000 2001 2052 2051
8 930 931 982 981 2001 2002 2053 2052
8 931 932 983 982 2002 2003 2054 2053
8 932 933 984 983 2003 2004 2055 2054
8 933 934 985 984 2004 2005 2056 2055
8 934 935 986 985 2005 2006 2057 2056
8 935 936 987 986 2006 2007 2058 2057
8 936 937 988 987 2007 2008 2059 2058
8 937 938 989 988 2008 2009 2060 2059
8 938 939 990 989 2009 2010 2061 2060
8 939 940 991 990 2010 2011 2062 2061
8 940 941 992 991 2011 2012 2063 2062
8 941 942 993 992 2012 2013 2064 2063
8 942 943 994 993 2013 2014 2065 2064
8 943 944 995 994 2014 2015 2066 2065
8 944 945 996 995 2015 2016 2067 2066
8 945 946 997 996 2016 2017 2068 2067
8 946 947 998 997 2017 2018 2069 2068
8 947 948 999 998 2018 2019 2070 2069
8 948 949 1000 999 2019 2020 2071 2070
8 949 950 1001 1000 2020 2021 2072 2071
8 950 951 1002 1001 2021 2022 2073 2072
8 951 952 1003 1002 2022 2023 2074 2073
8 952 953 1004 1003 2023 2024 2075 2074
8 953 954 1005 1004 2024 2025 2076 2075
8 954 955 1006 1005 2025 2026 2077 2076
8 955 956 1007 1006 2026 2027 2078 2077
8 956 957 1008 1007 2027 2028 2079 2078
8 957 958 1009 1008 2028 2029 2080 2079
8 958 959 1010 1009 2029 2030 2081 2080
8 959 960 1011 1010 2030 2031 2082 2081
8 960 961 1012 1011 2031 2032 2083 2082
8 961 962 1013 1012 2032 2033 2084 2083
8 962 963 1014 1013 2033 2034 2085 2084
8 963 964 1015 1014 2034 2035 2086 2085
8 964 965 1016 1015 2035 2036 2087 2086
8 965 966 1017 1016 2036 2037 2088 2087
8 966 967 1018 1017 2037 2038 2089 2088
8 967 968 1019 1018 2038 2039 2090 2089
8 969 970 1021 1020 2040 2041 2092 2091
8 970 971 1022 1021 2041 2042 2093 2092
8 971 972 1023 1022 2042 2043 2094 2093
8 972 973 1024 1023 2043 2044 2095 2094
8 973 974 1025 1024 2044 2045 2096 2095
8 974 975 1026 1025 2045 2046 2097 2096
8 975 976 1027 1026 2046 2047 2098 2097
8 976 977 1028 1027 2047 2048 2099 2098
8 977 978 1029 1028 2048 2049 2100 2099
8 978 979 1030 1029 2049 2050 2101 2100
8 979 980 1031 1030 2050 2051 2102 2101
8 980 981 1032 1031 2051 2052 2103 2102
8 981 982 1033 1032 2052 2053 2104 2103
8 982 983 1034 1033 2053 2054 2105 2104
8 983 984 1035 1034 2054 2055 2106 2105
8 984 985 1036 1035 2055 2056 2107 2106
8 985 986 1037 1036 2056 2057 2108 2107
8 986 987 1038 1037 2057 2058 2109 2108
8 987 988 1039 1038 2058 2059 2110 2109
8 988 989 1040 1039 2059 2060 2111 2110
8 989 990 1041 1040 2060 2061 2112 2111
8 990 991 1042 1041 2061 2062 2113 2112
8 991 992 1043 1042 2062 2063 2114 2113
8 992 993 1044 1043 2063 2064 2115 2114
8 993 994 1045 1044 2064 2065 2116 2115
8 994 995 1046 1045 2065 2066 2117 2116
8 995 996 1047 1046 2066 2067 2118 2117
8 996 997 1048 1047 2067 2068 2119 2118
8 997 998 1049 1048 2068 2069 2120 2119
8 998 999 1050 1049 2069 2070 2121 2120
8 999 1000 1051 1050 2070 2071 2122 2121
8 1000 1001 1052 1051 2071 2072 2123 2122
8 1001 1002 1053 1052 2072 2073 2124 2123
8 1002 1003 1054 1053 2073 2074 2125 2124
8 1003 1004 1055 1054 2074 2075 2126 2125
8 1004 1005 1056 1055 2075 2076 2127 2126
8 1005 1006 1057 1056 2076 2077 2128 2127
8 1006 1007 1058 1057 2077 2078 2129 2128
8 1007 1008 1059 1058 2078 2079 2130 2129
8 1008 1009 1060 1059 2079 2080 2131 2130
8 1009 1010 1061 1060 2080 2081 2132 2131
8 1010 1011 1062 1061 2081 2082 2133 2132
8 1011 1012 1063 1062 2082 2083 2134 2133
8 1012 1013 1064 1063 2083 2084 2135 2134
8 1013 1014 1065 1064 2084 2085 2136 2135
8 1014 1015 1066 1065 2085 2086 2137 2136
8 1015 1016 1067 1066 2086 2087 2138 2137
8 1016 1017 1068 1067 2087 2088 2139 2138
8 1017 1018 1069 1068 2088 2089 2140 2139
8 1018 1019 1070 1069 2089 2090 2141 2140
8 1071 1072 1123 1122 2142 2143 2194 2193
8 1072 1073 1124 1123 2143 2144 2195 2194
8 1073 1074 1125 1124 2144 2145 2196 2195
8 1074 1075 1126 1125 2145 2146 2197 2196
8 1075 1076 1127 1126 2146 2147 2198 2197
8 1076 1077 1128 1127 2147 2148 2199 2198
8 1077 1078 1129 1128 2148 2149 2200 2199
8 1078 1079 1130 1129 2149 2150 2201 2200
8 1079 1080 1131 1130 2150 2151 2202 2201
8 1080 1081 1132 1131 2151 2152 2203 2202
8 1081 1082 1133 1132 2152 2153 2204 2203
8 1082 1083 1134 1133 2153 2154 2205 2204
8 1083 1084 1135 1134 2154 2155 2206 2205
8 1084 1085 1136 1135 2155 2156 2207 2206
8 1085 1086 1137 1136 2156 2157 2208 2207
8 1086 1087 1138 1137 2157 2158 2209 2208
8 1087 1088 1139 1138 2158 2159 2210 2209
8 1088 1089 1140 1139 2159 2160 2211 2210
8 1089 1090 1141 1140 2160 2161 2212 2211
8 1090 1091 1142 1141 2161 2162 2213 2212
8 1091 1092 1143 1142 2162 2163 2214 2213
8 1092 1093 1144 1143 2163 2164 2215 2214
8 1093 1094 1145 1144 2164 2165 2216 2215
8 1094 1095 1146 1145 2165 2166 2217 2216
8 1095 1096 1147 1146 2166 2167 2218 2217
8 1096 1097 1148 1147 2167 2168 2219 2218
8 1097 1098 1149 1148 2168 2169 2220 2219
8 1098 1099 1150 1149 2169 2170 2221 2220
8 1099 1100 1151 1150 2170 2171 2222 2221
8 1100 1101 1152 1151 2171 2172 2223 2222
8 1101 1102 1153 1152 2172 2173 2224 2223
8 1102 1103 1154 1153 2173 2174 2225 2224
8 1103 1104 1155 1154 2174 2175 2226 2225
8 1104 1105 1156 1155 2175 2176 2227 2226
8 1105 1106 1157 1156 2176 2177 2228 2227
8 1106 1107 1158 1157 2177 2178 2229 2228
8 1107 1108 1159 1158 2178 2179 2230 2229
8 1108 1109 1160 1159 2179 2180 2231 2230
8 1109 1110 1161 1160 2180 2181 2232 2231
8 1110 1111 1162 1161 2181 2182 2233 2232
8 1111 1112 1163 1162 2182 2183 2234 2233
8 1112 1113 1164 1163 2183 2184 2235 2234
8 1113 1114 1165 1164 2184 2185 2236 2235
8 1114 1115 1166 1165 2185 2186 2237 2236
8 1115 1116 1167 1166 2186 2187 2238 2237
8 1116 1117 1168 1167 2187 2188 2239 2238
8 1117 1118 1169 1168 2188 2189 2240 2239
8 1118 1119 1170 1169 2189 2190 2241 2240
8 1119 1120 1171 1170 2190 2191 2242 2241
8 1120 1121 1172 1171 2191 2192 2243 2242
8 1122 1123 1174 1173 2193 2194 2245 2244
8 1123 1124 1175 1174 2194 2195 2246 2245
8 1124 1125 1176 1175 2195 2196 2247 2246
8 1125 1126 1177 1176 2196 2197 2248 2247
8 1126 1127 1178 1177 2197 2198 2249 2248
8 1127 1128 1179 1178 2198 2199 2250 2249
8 1128 1129 1180 1179 2199 2200 2251 2250
8 1129 1130 1181 1180 2200 2201 2252 2251
8 1130 1131 1182 1181 2201 2202 2253 2252
8 1131 1132 1183 1182 2202 2203 2254 2253
8 1132 1133 1184 1183 2203 2204 2255 2254
8 1133 1134 1185 1184 2204 2205 2256 2255
8 1134 1135 1186 1185 2205 2206 2257 2256
8 1135 1136 1187 1186 2206 2207 2258 2257
8 1136 1137 1188 1187 2207 2208 2259 2258
8 1137 1138 1189 1188 2208 2209 2260 2259
8 1138 1139 1190 1189 2209 2210 2261 2260
8 1139 1140 1191 1190 2210 2211 2262 2261
8 1140 1141 1192 1191 2211 2212 2263 2262
8 1141 1142 1193 1192 2212 2213 2264 2263
8 1142 1143 1194 1193 2213 2214 2265 2264
8 1143 1144 1195 1194 2214 2215 2266 2265
8 1144 1145 1196 1195 2215 2216 2267 2266
8 1145 1146 1197 1196 2216 2217 2268 2267
8 1146 1147 1198 1197 2217 2218 2269 2268
8 1147 1148 1199 1198 2218 2219 2270 2269
8 1148 1149 1200 1199 2219 2220 2271 2270
8 1149 1150 1201 1200 2220 2221 2272 2271
8 1150 1151 1202 1201 2221 2222 2273 2272
8 1151 1152 1203 1202 2222 2223 2274 2273
8 1152 1153 1204 1203 2223 2224 2275 2274
8 1153 1154 1205 1204 2224 2225 2276 2275
8 1154 1155 1206 1205 2225 2226 2277 2276
8 1155 1156 1207 1206 2226 2227 2278 2277
8 1156 1157 1208 1207 2227 2228 2279 2278
8 1157 1158 1209 1208 2228 2229 2280 2279
8 1158 1159 1210 1209 2229 2230 2281 2280
8 1159 1160 1211 1210 2230 2231 2282 2281
8 1160 1161 1212 1211 2231 2232 2283 2282
8 1161 1162 1213 1212 2232 2233 2284 2283
8 1162 1163 1214 1213 2233 2234 2285 2284
8 1163 1164 1215 1214 2234 2235 2286 2285
8 1164 1165 1216 1215 2235 2236 2287 2286
8 1165 1166 1217 1216 2236 2237 2288 2287
8 1166 1167 1218 1217 2237 2238 2289 2288
8 1167 1168 1219 1218 2238 2239 2290 2289
8 1168 1169 1220 1219 2239 2240 2291 2290
8 1169 1170 1221 1220 2240 2241 2292 2291
8 1170 1171 1222 1221 2241 2242 2293 2292
8 1171 1172 1223 1222 2242 2243 2294 2293
8 1173 1174 1225 1224 2244 2245 2296 2295
8 1174 1175 1226 1225 2245 2246 2297 2296
8 1175 1176 1227 1226 2246 2247 2298 2297
8 1176 1177 1228 1227 2247 2248 2299 2298
8 1177 1178 1229 1228 2248 2249 2300 2299
8 1178 1179 1230 1229 2249 2250 2301 2300
8 1179 1180 1231 1230 2250 2251 2302 2301
8 1180 1181 1232 1231 2251 2252 2303 2302
8 1181 1182 1233 1232 2252 2253 2304 2303
8 1182 1183 1234 1233 2253 2254 2305 2304
8 1183 1184 1235 1234 2254 2255 2306 2305
8 1184 1185 1236 1235 2255 2256 2307 2306
8 1185 1186 1237 1236 2256 2257 2308 2307
8 1186 1187 1238 1237 2257 2258 2309 2308
8 1187 1188 1239 1238 2258 2259 2310 2309
8 1188 1189 1240 1239 2259 2260 2311 2310
8 1189 1190 1241 1240 2260 2261 2312 2311
8 1190 1191 1242 1241 2261 2262 2313 2312
8 1191 1192 1243 1242 2262 2263 2314 2313
8 1192 1193 1244 1243 2263 2264 2315 2314
8 1193 1194 1245 1244 2264 2265 2316 2315
8 1194 1195 1246 1245 2265 2266 2317 2316
8 1195 1196 1247 1246 2266 2267 2318 2317
8 1196 1197 1248 1247 2267 2268 2319 2318
8 1197 1198 1249 1248 2268 2269 2320 2319
8 1198 1199 1250 1249 2269 2270 2321 2320
8 1199 1200 1251 1250 2270 2271 2322 2321
8 1200 1201 1252 1251 2271 2272 2323 2322
8 1201 1202 1253 1252 2272 2273 2324 2323
8 1202 1203 1254 1253 2273 2274 2325 2324
8 1203 1204 1255 1254 2274 2275 2326 2325
8 1204 1205 1256 1255 2275 2276 2327 2326
8 1205 1206 1257 1256 2276 2277 2328 2327
8 1206 1207 1258 1257 2277 2278 2329 2328
8 1207 1208 1259 1258 2278 2279 2330 2329
8 1208 1209 1260 1259 2279 2280 2331 2330
8 1209 1210 1261 1260 2280 2281 2332 2331
8 1210 1211 1262 1261 2281 2282 2333 2332
8 1211 1212 1263 1262 2282 2283 2334 2333
8 1212 1213 1264 1263 2283 2284 2335 2334
8 1213 1214 1265 1264 2284 2285 2336 2335
8 1214 1215 1266 1265 2285 2286 2337 2336
8 1215 1216 1267 1266 2286 2287 2338 2337
8 1216 1217 1268 1267 2287 2288 2339 2338
8 1217 1218 1269 1268 2288 2289 2340 2339
8 1218 1219 1270 1269 2289 2290 2341 2340
8 1219 1220 1271 1270 2290 2291 2342 2341
8 1220 1221 1272 1271 2291 2292 2343 2342
8 1221 1222 1273 1272 2292 2293 2344 2343
8 1222 1223 1274 1273 2293 2294 2345 2344
8 1224 1225 1276 1275 2295 2296 2347 2346
8 1225 1226 1277 1276 2296 2297 2348 2347
8 1226 1227 1278 1277 2297 2298 2349 2348
8 1227 1228 1279 1278 2298 2299 2350 2349
8 1228 1229 1280 1279 2299 2300 2351 2350
8 1229 1230 1281 1280 2300 2301 2352 2351
8 1230 1231 1282 1281 2301 2302 2353 2352
8 1231 1232 1283 1282 2302 2303 2354 2353
8 1232 1233 1284 1283 2303 2304 2355 2354
8 1233 1234 1285 1284 2304 2305 2356 2355
8 1234 1235 1286 1285 2305 2306 2357 2356
8 1235 1236 1287 1286 2306 2307 2358 2357
8 1236 1237 1288 1287 2307 2308 2359 2358
8 1237 1238 1289 1288 2308 2309 2360 2359
8 1238 1239 1290 1289 2309 2310 2361 2360
8 1239 1240 1291 1290 2310 2311 2362 2361
8 1240 1241 1292 1291 2311 2312 2363 2362
8 1241 1242 1293 1292 2312 2313 2364 2363
8 1242 1243 1294 1293 2313 2314 2365 2364
8 1243 1244 1295 1294 2314 2315 2366 2365
8 1244 1245 1296 1295 2315 2316 2367 2366
8 1245 1246 1297 1296 2316 2317 2368 2367
8 1246 1247 1298 1297 2317 2318 2369 2368
8 1247 1248 1299 1298 2318 2319 2370 2369
8 1248 1249 1300 1299 2319 2320 2371 2370
8 1249 1250 1301 1300 2320 2321 2372 2371
8 1250 1251 1302 1301 2321 2322 2373 2372
8 1251 1252 1303 1302 2322 2323 2374 2373
8 1252 1253 1304 1303 2323 2324 2375 2374
8 1253 1254 1305 1304 2324 2325 2376 2375
8 1254 1255 1306 1305 2325 2326 2377 2376
8 1255 1256 1307 1306 2326 2327 2378 2377
8 1256 1257 1308 1307 2327 2328 2379 2378
8 1257 1258 1309 1308 2328 2329 2380 2379
8 1258 1259 1310 1309 2329 2330 2381 2380
8 1259 1260 1311 1310 2330 2331 2382 2381
8 1260 1261 1312 1311 2331 2332 2383 2382
8 1261 1262 1313 1312 2332 2333 2384 2383
8 1262 1263 1314 1313 2333 2334 2385 2384
8 1263 1264 1315 1314 2334 2335 2386 2385
8 1264 1265 1316 1315 2335 2336 2387 2386
8 1265 1266 1317 1316 2336 2337 2388 2387
8 1266 1267 1318 1317 2337 2338 2389 2388
8 1267 1268 1319 1318 2338 2339 2390 2389
8 1268 1269 1320 1319 2339 2340 2391 2390
8 1269 1270 1321 1320 2340 2341 2392 2391
8 1270 1271 1322 1321 2341 2342 2393 2392
8 1271 1272 1323 1322 2342 2343 2394 2393
8 1272 1273 1324 1323 2343 2344 2395 2394
8 1273 1274 1325 1324 2344 2345 2396 2395
8 1275 1276 1327 1326 2346 2347 2398 2397
8 1276 1277 1328 1327 2347 2348 2399 2398
8 1277 1278 1329 1328 2348 2349 2400 2399
8 1278 1279 1330 1329 2349 2350 2401 2400
8 1279 1280 1331 1330 2350 2351 2402 2401
8 1280 1281 1332 1331 2351 2352 2403 2402
8 1281 1282 1333 1332 2352 2353 2404 2403
8 1282 1283 1334 1333 2353 2354 2405 2404
8 1283 1284 1335 1334 2354 2355 2406 2405
8 1284 1285 1336 1335 2355 2356 2407 2406
8 1285 1286 1337 1336 2356 2357 2408 2407
8 1286 1287 1338 1337 2357 2358 2409 2408
8 1287 1288 1339 1338 2358 2359 2410 2409
8 1288 1289 1340 1339 2359 2360 2411 2410
8 1289 1290 1341 1340 2360 2361 2412 2411
8 1290 1291 1342 1341 2361 2362 2413 2412
8 1291 1292 1343 1342 2362 2363 2414 2413
8 1292 1293 1344 1343 2363 2364 2415 2414
8 1293 1294 1345 1344 2364 2365 2416 2415
8 1294 1295 1346 1345 2365 2366 2417 2416
8 1295 1296 1347 1346 2366 2367 2418 2417
8 1296 1297 1348 1347 2367 2368 2419 2418
8 1297 1298 1349 1348 2368 2369 2420 2419
8 1298 1299 1350 1349 2369 2370 2421 2420
8 1299 1300 1351 1350 2370 2371 2422 2421
8 1300 1301 1352 1351 2371 2372 2423 2422
8 1301 1302 1353 1352 2372 2373 2424 2423
8 1302 1303 1354 1353 2373 2374 2425 2424
8 1303 1304 1355 1354 2374 2375 2426 2425
8 1304 1305 1356 1355 2375 2376 2427 2426
8 1305 1306 1357 1356 2376 2377 2428 2427
8 1306 1307 1358 1357 2377 2378 2429 2428
8 1307 1308 1359 1358 2378 2379 2430 2429
8 1308 1309 1360 1359 2379 2380 2431 2430
8 1309 1310 1361 1360 2380 2381 2432 2431
8 1310 1311 1362 1361 2381 2382 2433 2432
8 1311 1312 1363 1362 2382 2383 2434 2433
8 1312 1313 1364 1363 2383 2384 2435 2434
8 1313 1314 1365 1364 2384 2385 2436 2435
8 1314 1315 1366 1365 2385 2386 2437 2436
8 1315 1316 1367 1366 2386 2387 2438 2437
8 1316 1317 1368 1367 2387 2388 2439 2438
8 1317 1318 1369 1368 2388 2389 2440 2439
8 1318 1319 1370 1369 2389 2390 2441 2440
8 1319 1320 1371 1370 2390 2391 2442 2441
8 1320 1321 1372 1371 2391 2392 2443 2442
8 1321 1322 1373 1372 2392 2393 2444 2443
8 1322 1323 1374 1373 2393 2394 2445 2444
8 1323 1324 1375 1374 2394 2395 2446 2445
8 1324 1325 1376 1375 2395 2396 2447 2446
8 1326 1327 1378 1377 2397 2398 2449 2448
8 1327 1328 1379 1378 2398 2399 2450 2449
8 1328 1329 1380 1379 2399 2400 2451 2450
8 1329 1330 1381 1380 2400 2401 2452 2451
8 1330 1331 1382 1381 2401 2402 2453 2452
8 1331 1332 1383 1382 2402 2403 2454 2453
8 1332 1333 1384 1383 2403 2404 2455 2454
8 1333 1334 1385 1384 2404 2405 2456 2455
8 1334 1335 1386 1385 2405 2406 2457 2456
8 1335 1336 1387 1386 2406 2407 2458 2457
8 1336 1337 1388 1387 2407 2408 2459 2458
8 1337 1338 1389 1388 2408 2409 2460 2459
8 1338 1339 1390 1389 2409 2410 2461 2460
8 1339 1340 1391 1390 2410 2411 2462 2461
8 1340 1341 1392 1391 2411 2412 2463 2462
8 1341 1342 1393 1392 2412 2413 2464 2463
8 1342 1343 1394 1393 2413 2414 2465 2464
8 1343 1344 1395 1394 2414 2415 2466 2465
8 1344 1345 1396 1395 2415 2416 2467 2466
8 1345 1346 1397 1396 2416 2417 2468 2467
8 1346 1347 1398 1397 2417 2418 2469 2468
8 1347 1348 1399 1398 2418 2419 2470 2469
8 1348 1349 1400 1399 2419 2420 2471 2470
8 1349 1350 1401 1400 2420 2421 2472 2471
8 1350 1351 1402 1401 2421 2422 2473 2472
8 1351 1352 1403 1402 2422 2423 2474 2473
8 1352 1353 1404 1403 2423 2424 2475 2474
8 1353 1354 1405 1404 2424 2425 2476 2475
8 1354 1355 1406 1405 2425 2426 2477 2476
8 1355 1356 1407 1406 2426 2427 2478 2477
8 1356 1357 1408 1407 2427 2428 2479 2478
8 1357 1358 1409 1408 2428 2429 2480 2479
8 1358 1359 1410 1409 2429 2430 2481 2480
8 1359 1360 1411 1410 2430 2431 2482 2481
8 1360 1361 1412 1411 2431 2432 2483 2482
8 1361 1362 1413 1412 2432 2433 2484 2483
8 1362 1363 1414 1413 2433 2434 2485 2484
8 1363 1364 1415 1414 2434 2435 2486 2485
8 1364 1365 1416 1415 2435 2436 2487 2486
8 1365 1366 1417 1416 2436 2437 2488 2487
8 1366 1367 1418 1417 2437 2438 2489 2488
8 1367 1368 1419 1418 2438 2439 2490 2489
8 1368 1369 1420 1419 2439 2440 2491 2490
8 1369 1370 1421 1420 2440 2441 2492 2491
8 1370 1371 1422 1421 2441 2442 2493 2492
8 1371 1372 1423 1422 2442 2443 2494 2493
8 1372 1373 1424 1423 2443 2444 2495 2494
8 1373 1374 1425 1424 2444 2445 2496 2495
8 1374 1375 1426 1425 2445 2446 2497 2496
8 1375 1376 1427 1426 2446 2447 2498 2497
8 1377 1378 1429 1428 2448 2449 2500 2499
8 1378 1379 1430 1429 2449 2450 2501 2500
8 1379 1380 1431 1430 2450 2451 2502 2501
8 1380 1381 1432 1431 2451 2452 2503 2502
8 1381 1382 1433 1432 2452 2453 2504 2503
8 1382 1383 1434 1433 2453 2454 2505 2504
8 1383 1384 1435 1434 2454 2455 2506 2505
8 1384 1385 1436 1435 2455 2456 2507 2506
8 1385 1386 1437 1436 2456 2457 2508 2507
8 1386 1387 1438 1437 2457 2458 2509 2508
8 1387 1388 1439 1438 2458 2459 2510 2509
8 1388 1389 1440 1439 2459 2460 2511 2510
8 1389 1390 1441 1440 2460 2461 2512 2511
8 1390 1391 1442 1441 2461 2462 2513 2512
8 1391 1392 1443 1442 2462 2463 2514 2513
8 1392 1393 1444 1443 2463 2464 2515 2514
8 1393 1394 1445 1444 2464 2465 2516 2515
8 1394 1395 1446 1445 2465 2466 2517 2516
8 1395 1396 1447 1446 2466 2467 2518 2517
8 1396 1397 1448 1447 2467 2468 2519 2518
8 1397 1398 1449 1448 2468 2469 2520 2519
8 1398 1399 1450 1449 2469 2470 2521 2520
8 1399 1400 1451 1450 2470 2471 2522 2521
8 1400 1401 1452 1451 2471 2472 2523 2522
8 1401 1402 1453 1452 2472 2473 2524 2523
8 1402 1403 1454 1453 2473 2474 2525 2524
8 1403 1404 1455 1454 2474 2475 2526 2525
8 1404 1405 1456 1455 2475 2476 2527 2526
8 1405 1406 1457 1456 2476 2477 2528 2527
8 1406 1407 1458 1457 2477 2478 2529 2528
8 1407 1408 1459 1458 2478 2479 2530 2529
8 1408 1409 1460 1459 2479 2480 2531 2530
8 1409 1410 1461 1460 2480 2481 2532 2531
8 1410 1411 1462 1461 2481 2482 2533 2532
8 1411 1412 1463 1462 2482 2483 2534 2533
8 1412 1413 1464 1463 2483 2484 2535 2534
8 1413 1414 1465 1464 2484 2485 2536 2535
8 1414 1415 1466 1465 2485 2486 2537 2536
8 1415 1416 1467 1466 2486 2487 2538 2537
8 1416 1417 1468 1467 2487 2488 2539 2538
8 1417 1418 1469 1468 2488 2489 2540 2539
8 1418 1419 1470 1469 2489 2490 2541 2540
8 1419 1420 1471 1470 2490 2491 2542 2541
8 1420 1421 1472 1471 2491 2492 2543 2542
8 1421 1422 1473 1472 2492 2493 2544 2543
8 1422 1423 1474 1473 2493 2494 2545 2544
8 1423 1424 1475 1474 2494 2495 2546 2545
8 1424 1425 1476 1475 2495 2496 2547 2546
8 1425 1426 1477 1476 2496 2497 2548 2547
8 1426 1427 1478 1477 2497 2498 2549 2548
8 1428 1429 1480 1479 2499 2500 2551 2550
8 1429 1430 1481 1480 2500 2501 2552 2551
8 1430 1431 1482 1481 2501 2502 2553 2552
8 1431 1432 1483 1482 2502 2503 2554 2553
8 1432 1433 1484 1483 2503 2504 2555 2554
8 1433 1434 1485 1484 2504 2505 2556 2555
8 1434 1435 1486 1485 2505 2506 2557 2556
8 1435 1436 1487 1486 2506 2507 2558 2557
8 1436 1437 1488 1487 2507 2508 2559 2558
8 1437 1438 1489 1488 2508 2509 2560 2559
8 1438 1439 1490 1489 2509 2510 2561 2560
8 1439 1440 1491 1490 2510 2511 2562 2561
8 1440 1441 1492 1491 2511 2512 2563 2562
8 1441 1442 1493 1492 2512 2513 2564 2563
8 1442 1443 1494 1493 2513 2514 2565 2564
8 1443 1444 1495 1494 2514 2515 2566 2565
8 1444 1445 1496 1495 2515 2516 2567 2566
8 1445 1446 1497 1496 2516 2517 2568 2567
8 1446 1447 1498 1497 2517 2518 2569 2568
8 1447 1448 1499 1498 2518 2519 2570 2569
8 1448 1449 1500 1499 2519 2520 2571 2570
8 1449 1450 1501 1500 2520 2521 2572 2571
8 1450 1451 1502 1501 2521 2522 2573 2572
8 1451 1452 1503 1502 2522 2523 2574 2573
8 1452 1453 1504 1503 2523 2524 2575 2574
8 1453 1454 1505 1504 2524 2525 2576 2575
8 1454 1455 1506 1505 2525 2526 2577 2576
8 1455 1456 1507 1506 2526 2527 2578 2577
8 1456 1457 1508 1507 2527 2528 2579 2578
8 1457 1458 1509 1508 2528 2529 2580 2579
8 1458 1459 1510 1509 2529 2530 2581 2580
8 1459 1460 1511 1510 2530 2531 2582 2581
8 1460 1461 1512 1511 2531 2532 2583 2582
8 1461 1462 1513 1512 2532 2533 2584 2583
8 1462 1463 1514 1513 2533 2534 2585 2584
8 1463 1464 1515 1514 2534 2535 2586 2585
8 1464 1465 1516 1515 2535 2536 2587 2586
8 1465 1466 1517 1516 2536 2537 2588 2587
8 1466 1467 1518 1517 2537 2538 2589 2588
8 1467 1468 1519 1518 2538 2539 2590 2589
8 1468 1469 1520 1519 2539 2540 2591 2590
8 1469 1470 1521 1520 2540 2541 2592 2591
8 1470 1471 1522 1521 2541 2542 2593 2592
8 1471 1472 1523 1522 2542 2543 2594 2593
8 1472 1473 1524 1523 2543 2544 2595 2594
8 1473 1474 1525 1524 2544 2545 2596 2595
8 1474 1475 1526 1525 2545 2546 2597 2596
8 1475 1476 1527 1526 2546 2547 2598 2597
8 1476 1477 1528 1527 2547 2548 2599 2598
8 1477 1478 1529 1528 2548 2549 2600 2599
8 1479 1480 1531 1530 2550 2551 2602 2601
8 1480 1481 1532 1531 2551 2552 2603 2602
8 1481 1482 1533 1532 2552 2553 2604 2603
8 1482 1483 1534 1533 2553 2554 2605 2604
8 1483 1484 1535 1534 2554 2555 2606 2605
8 1484 1485 1536 1535 2555 2556 2607 2606
8 1485 1486 1537 1536 2556 2557 2608 2607
8 1486 1487 1538 1537 2557 2558 2609 2608
8 1487 1488 1539 1538 2558 2559 2610 2609
8 1488 1489 1540 1539 2559 2560 2611 2610
8 1489 1490 1541 1540 2560 2561 2612 2611
8 1490 1491 1542 1541 2561 2562 2613 2612
8 1491 1492 1543 1542 2562 2563 2614 2613
8 1492 1493 1544 1543 2563 2564 2615 2614
8 1493 1494 1545 1544 2564 2565 2616 2615
8 1494 1495 1546 1545 2565 2566 2617 2616
8 1495 1496 1547 1546 2566 2567 2618 2617
8 1496 1497 1548 1547 2567 2568 2619 2618
8 1497 1498 1549 1548 2568 2569 2620 2619
8 1498 1499 1550 1549 2569 2570 2621 2620
8 1499 1500 1551 1550 2570 2571 2622 2621
8 1500 1501 1552 1551 2571 2572 2623 2622
8 1501 1502 1553 1552 2572 2573 2624 2623
8 1502 1503 1554 1553 2573 2574 2625 2624
8 1503 1504 1555 1554 2574 2575 2626 2625
8 1504 1505 1556 1555 2575 2576 2627 2626
8 1505 1506 1557 1556 2576 2577 2628 2627
8 1506 1507 1558 1557 2577 2578 2629 2628
8 1507 1508 1559 1558 2578 2579 2630 2629
8 1508 1509 1560 1559 2579 2580 2631 2630
8 1509 1510 1561 1560 2580 2581 2632 2631
8 1510 1511 1562 1561 2581 2582 2633 2632
8 1511 1512 1563 1562 2582 2583 2634 2633
8 1512 1513 1564 1563 2583 2584 2635 2634
8 1513 1514 1565 1564 2584 2585 2636 2635
8 1514 1515 1566 1565 2585 2586 2637 2636
8 1515 1516 1567 1566 2586 2587 2638 2637
8 1516 1517 1568 1567 2587 2588 2639 2638
8 1517 1518 1569 1568 2588 2589 2640 2639
8 1518 1519 1570 1569 2589 2590 2641 2640
8 1519 1520 1571 1570 2590 2591 2642 2641
8 1520 1521 1572 1571 2591 2592 2643 2642
8 1521 1522 1573 1572 2592 2593 2644 2643
8 1522 1523 1574 1573 2593 2594 2645 2644
8 1523 1524 1575 1574 2594 2595 2646 2645
8 1524 1525 1576 1575 2595 2596 2647 2646
8 1525 1526 1577 1576 2596 2597 2648 2647
8 1526 1527 1578 1577 2597 2598 2649 2648
8 1527 1528 1579 1578 2598 2599 2650 2649
8 1528 1529 1580 1579 2599 2600 2651 2650
8 1530 1531 1582 1581 2601 2602 2653 2652
8 1531 1532 1583 1582 2602 2603 2654 2653
8 1532 1533 1584 1583 2603 2604 2655 2654
8 1533 1534 1585 1584 2604 2605 2656 2655
8 1534 1535 1586 1585 2605 2606 2657 2656
8 1535 1536 1587 1586 2606 2607 2658 2657
8 1536 1537 1588 1587 2607 2608 2659 2658
8 1537 1538 1589 1588 2608 2609 2660 2659
8 1538 1539 1590 1589 2609 2610 2661 2660
8 1539 1540 1591 1590 2610 2611 2662 2661
8 1540 1541 1592 1591 2611 2612 2663 2662
8 1541 1542 1593 1592 2612 2613 2664 2663
8 1542 1543 1594 1593 2613 2614 2665 2664
8 1543 1544 1595 1594 2614 2615 2666 2665
8 1544 1545 1596 1595 2615 2616 2667 2666
8 1545 1546 1597 1596 2616 2617 2668 2667
8 1546 1547 1598 1597 2617 2618 2669 2668
8 1547 1548 1599 1598 2618 2619 2670 2669
8 1548 1549 1600 1599 2619 2620 2671 2670
8 1549 1550 1601 1600 2620 2621 2672 2671
8 1550 1551 1602 1601 2621 2622 2673 2672
8 1551 1552 1603 1602 2622 2623 2674 2673
8 1552 1553 1604 1603 2623 2624 2675 2674
8 1553 1554 1605 1604 2624 2625 2676 2675
8 1554 1555 1606 1605 2625 2626 2677 2676
8 1555 1556 1607 1606 2626 2627 2678 2677
8 1556 1557 1608 1607 2627 2628 2679 2678
8 1557 1558 1609 1608 2628 2629 2680 2679
8 1558 1559 1610 1609 2629 2630 2681 2680
8 1559 1560 1611 1610 2630 2631 2682 2681
8 1560 1561 1612 1611 2631 2632 2683 2682
8 1561 1562 1613 1612 2632 2633 2684 2683
8 1562 1563 1614 1613 2633 2634 2685 2684
8 1563 1564 1615 1614 2634 2635 2686 2685
8 1564 1565 1616 1615 2635 2636 2687 2686
8 1565 1566 1617 1616 2636 2637 2688 2687
8 1566 1567 1618 1617 2637 2638 2689 2688
8 1567 1568 1619 1618 2638 2639 2690 2689
8 1568 1569 1620 1619 2639 2640 2691 2690
8 1569 1570 1621 1620 2640 2641 2692 2691
8 1570 1571 1622 1621 2641 2642 2693 2692
8 1571 1572 1623 1622 2642 2643 2694 2693
8 1572 1573 1624 1623 2643 2644 2695 2694
8 1573 1574 1625 1624 2644 2645 2696 2695
8 1574 1575 1626 1625 2645 2646 2697 2696
8 1575 1576 1627 1626 2646 2647 2698 2697
8 1576 1577 1628 1627 2647 2648 2699 2698
8 1577 1578 1629 1628 2648 2649 2700 2699
8 1578 1579 1630 1629 2649 2650 2701 2700
8 1579 1580 1631 1630 2650 2651 2702 2701
8 1581 1582 1633 1632 2652 2653 2704 2703
8 1582 1583 1634 1633 2653 2654 2705 2704
8 1583 1584 1635 1634 2654 2655 2706 2705
8 1584 1585 1636 1635 2655 2656 2707 2706
8 1585 1586 1637 1636 2656 2657 2708 2707
8 1586 1587 1638 1637 2657 2658 2709 2708
8 1587 1588 1639 1638 2658 2659 2710 2709
8 1588 1589 1640 1639 2659 2660 2711 2710
8 1589 1590 1641 1640 2660 2661 2712 2711
8 1590 1591 1642 1641 2661 2662 2713 2712
8 1591 1592 1643 1642 2662 2663 2714 2713
8 1592 1593 1644 1643 2663 2664 2715 2714
8 1593 1594 1645 1644 2664 2665 2716 2715
8 1594 1595 1646 1645 2665 2666 2717 2716
8 1595 1596 1647 1646 2666 2667 2718 2717
8 1596 1597 1648 1647 2667 2668 2719 2718
8 1597 1598 1649 1648 2668 2669 2720 2719
8 1598 1599 1650 1649 2669 2670 2721 2720
8 1599 1600 1651 1650 2670 2671 2722 2721
8 1600 1601 1652 1651 2671 2672 2723 2722
8 1601 1602 1653 1652 2672 2673 2724 2723
8 1602 1603 1654 1653 2673 2674 2725 2724
8 1603 1604 1655 1654 2674 2675 2726 2725
8 1604 1605 1656 1655 2675 2676 2727 2726
8 1605 1606 1657 1656 2676 2677 2728 2727
8 1606 1607 1658 1657 2677 2678 2729 2728
8 1607 1608 1659 1658 2678 2679 2730 2729
8 1608 1609 1660 1659 2679 2680 2731 2730
8 1609 1610 1661 1660 2680 2681 2732 2731
8 1610 1611 1662 1661 2681 2682 2733 2732
8 1611 1612 1663 1662 2682 2683 2734 2733
8 1612 1613 1664 1663 2683 2684 2735 2734
8 1613 1614 1665 1664 2684 2685 2736 2735
8 1614 1615 1666 1665 2685 2686 2737 2736
8 1615 1616 1667 1666 2686 2687 2738 2737
8 1616 1617 1668 1667 2687 2688 2739 2738
8 1617 1618 1669 1668 2688 2689 2740 2739
8 1618 1619 1670 1669 2689 2690 2741 2740
8 1619 1620 1671 1670 2690 2691 2742 2741
8 1620 1621 1672 1671 2691 2692 2743 2742
8 1621 1622 1673 1672 2692 2693 2744 2743
8 1622 1623 1674 1673 2693 2694 2745 2744
8 1623 1624 1675 1674 2694 2695 2746 2745
8 1624 1625 1676 1675 2695 2696 2747 2746
8 1625 1626 1677 1676 2696 2697 2748 2747
8 1626 1627 1678 1677 2697 2698 2749 2748
8 1627 1628 1679 1678 2698 2699 2750 2749
8 1628 1629 1680 1679 2699 2700 2751 2750
8 1629 1630 1681 1680 2700 2701 2752 2751
8 1630 1631 1682 1681 2701 2702 2753 2752
8 1632 1633 1684 1683 2703 2704 2755 2754
8 1633 1634 1685 1684 2704 2705 2756 2755
8 1634 1635 1686 1685 2705 2706 2757 2756
8 1635 1636 1687 1686 2706 2707 2758 2757
8 1636 1637 1688 1687 2707 2708 2759 2758
8 1637 1638 1689 1688 2708 2709 2760 2759
8 1638 1639 1690 1689 2709 2710 2761 2760
8 1639 1640 1691 1690 2710 2711 2762 2761
8 1640 1641 1692 1691 2711 2712 2763 2762
8 1641 1642 1693 1692 2712 2713 2764 2763
8 1642 1643 1694 1693 2713 2714 2765 2764
8 1643 1644 1695 1694 2714 2715 2766 2765
8 1644 1645 1696 1695 2715 2716 2767 2766
8 1645 1646 1697 1696 2716 2717 2768 2767
8 1646 1647 1698 1697 2717 2718 2769 2768
8 1647 1648 1699 1698 2718 2719 2770 2769
8 1648 1649 1700 1699 2719 2720 2771 2770
8 1649 1650 1701 1700 2720 2721 2772 2771
8 1650 1651 1702 1701 2721 2722 2773 2772
8 1651 1652 1703 1702 2722 2723 2774 2773
8 1652 1653 1704 1703 2723 2724 2775 2774
8 1653 1654 1705 1704 2724 2725 2776 2775
8 1654 1655 1706 1705 2725 2726 2777 2776
8 1655 1656 1707 1706 2726 2727 2778 2777
8 1656 1657 1708 1707 2727 2728 2779 2778
8 1657 1658 1709 1708 2728 2729 2780 2779
8 1658 1659 1710 1709 2729 2730 2781 2780
8 1659 1660 1711 1710 2730 2731 2782 2781
8 1660 1661 1712 1711 2731 2732 2783 2782
8 1661 1662 1713 1712 2732 2733 2784 2783
8 1662 1663 1714 1713 2733 2734 2785 2784
8 1663 1664 1715 1714 2734 2735 2786 2785
8 1664 1665 1716 1715 2735 2736 2787 2786
8 1665 1666 1717 1716 2736 2737 2788 2787
8 1666 1667 1718 1717 2737 2738 2789 2788
8 1667 1668 1719 1718 2738 2739 2790 2789
8 1668 1669 1720 1719 2739 2740 2791 2790
8 1669 1670 1721 1720 2740 2741 2792 2791
8 1670 1671 1722 1721 2741 2742 2793 2792
8 1671 1672 1723 1722 2742 2743 2794 2793
8 1672 1673 1724 1723 2743 2744 2795 2794
8 1673 1674 1725 1724 2744 2745 2796 2795
8 1674 1675 1726 1725 2745 2746 2797 2796
8 1675 1676 1727 1726 2746 2747 2798 2797
8 1676 1677 1728 1727 2747 2748 2799 2798
8 1677 1678 1729 1728 2748 2749 2800 2799
8 1678 1679 1730 1729 2749 2750 2801 2800
8 1679 1680 1731 1730 2750 2751 2802 2801
8 1680 1681 1732 1731 2751 2752 2803 2802
8 1681 1682 1733 1732 2752 2753 2804 2803
8 1683 1684 1735 1734 2754 2755 2806 2805
8 1684 1685 1736 1735 2755 2756 2807 2806
8 1685 1686 1737 1736 2756 2757 2808 2807
8 1686 1687 1738 1737 2757 2758 2809 2808
8 1687 1688 1739 1738 2758 2759 2810 2809
8 1688 1689 1740 1739 2759 2760 2811 2810
8 1689 1690 1741 1740 2760 2761 2812 2811
8 1690 1691 1742 1741 2761 2762 2813 2812
8 1691 1692 1743 1742 2762 2763 2814 2813
8 1692 1693 1744 1743 2763 2764 2815 2814
8 1693 1694 1745 1744 2764 2765 2816 2815
8 1694 1695 1746 1745 2765 2766 2817 2816
8 1695 1696 1747 1746 2766 2767 2818 2817
8 1696 1697 1748 1747 2767 2768 2819 2818
8 1697 1698 1749 1748 2768 2769 2820 2819
8 1698 1699 1750 1749 2769 2770 2821 2820
8 1699 1700 1751 1750 2770 2771 2822 2821
8 1700 1701 1752 1751 2771 2772 2823 2822
8 1701 1702 1753 1752 2772 2773 2824 2823
8 1702 1703 1754 1753 2773 2774 2825 2824
8 1703 1704 1755 1754 2774 2775 2826 2825
8 1704 1705 1756 1755 2775 2776 2827 2826
8 1705 1706 1757 1756 2776 2777 2828 2827
8 1706 1707 1758 1757 2777 2778 2829 2828
8 1707 1708 1759 1758 2778 2779 2830 2829
8 1708 1709 1760 1759 2779 2780 2831 2830
8 1709 1710 1761 1760 2780 2781 2832 2831
8 1710 1711 1762 1761 2781 2782 2833 2832
8 1711 1712 1763 1762 2782 2783 2834 2833
8 1712 1713 1764 1763 2783 2784 2835 2834
8 1713 1714 1765 1764 2784 2785 2836 2835
8 1714 1715 1766 1765 2785 2786 2837 2836
8 1715 1716 1767 1766 2786 2787 2838 2837
8 1716 1717 1768 1767 2787 2788 2839 2838
8 1717 1718 1769 1768 2788 2789 2840 2839
8 1718 1719 1770 1769 2789 2790 2841 2840
8 1719 1720 1771 1770 2790 2791 2842 2841
8 1720 1721 1772 1771 2791 2792 2843 2842
8 1721 1722 1773 1772 2792 2793 2844 2843
8 1722 1723 1774 1773 2793 2794 2845 2844
8 1723 1724 1775 1774 2794 2795 2846 2845
8 1724 1725 1776 1775 2795 2796 2847 2846
8 1725 1726 1777 1776 2796 2797 2848 2847
8 1726 1727 1778 1777 2797 2798 2849 2848
8 1727 1728 1779 1778 2798 2799 2850 2849
8 1728 1729 1780 1779 2799 2800 2851 2850
8 1729 1730 1781 1780 2800 2801 2852 2851
8 1730 1731 1782 1781 2801 2802 2853 2852
8 1731 1732 1783 1782 2802 2803 2854 2853
8 1732 1733 1784 1783 2803 2804 2855 2854
8 1734 1735 1786 1785 2805 2806 2857 2856
8 1735 1736 1787 1786 2806 2807 2858 2857
8 1736 1737 1788 1787 2807 2808 2859 2858
8 1737 1738 1789 1788 2808 2809 2860 2859
8 1738 1739 1790 1789 2809 2810 2861 2860
8 1739 1740 1791 1790 2810 2811 2862 2861
8 1740 1741 1792 1791 2811 2812 2863 2862
8 1741 1742 1793 1792 2812 2813 2864 2863
8 1742 1743 1794 1793 2813 2814 2865 2864
8 1743 1744 1795 1794 2814 2815 2866 2865
8 1744 1745 1796 1795 2815 2816 2867 2866
8 1745 1746 1797 1796 2816 2817 2868 2867
8 1746 1747 1798 1797 2817 2818 2869 2868
8 1747 1748 1799 1798 2818 2819 2870 2869
8 1748 1749 1800 1799 2819 2820 2871 2870
8 1749 1750 1801 1800 2820 2821 2872 2871
8 1750 1751 1802 1801 2821 2822 2873 2872
8 1751 1752 1803 1802 2822 2823 2874 2873
8 1752 1753 1804 1803 2823 2824 2875 2874
8 1753 1754 1805 1804 2824 2825 2876 2875
8 1754 1755 1806 1805 2825 2826 2877 2876
8 1755 1756 1807 1806 2826 2827 2878 2877
8 1756 1757 1808 1807 2827 2828 2879 2878
8 1757 1758 1809 1808 2828 2829 2880 2879
8 1758 1759 1810 1809 2829 2830 2881 2880
8 1759 1760 1811 1810 2830 2831 2882 2881
8 1760 1761 1812 1811 2831 2832 2883 2882
8 1761 1762 1813 1812 2832 2833 2884 2883
8 1762 1763 1814 1813 2833 2834 2885 2884
8 1763 1764 1815 1814 2834 2835 2886 2885
8 1764 1765 1816 1815 2835 2836 2887 2886
8 1765 1766 1817 1816 2836 2837 2888 2887
8 1766 1767 1818 1817 2837 2838 2889 2888
8 1767 1768 1819 1818 2838 2839 2890 2889
8 1768 1769 1820 1819 2839 2840 2891 2890
8 1769 1770 1821 1820 2840 2841 2892 2891
8 1770 1771 1822 1821 2841 2842 2893 2892
8 1771 1772 1823 1822 2842 2843 2894 2893
8 1772 1773 1824 1823 2843 2844 2895 2894
8 1773 1774 1825 1824 2844 2845 2896 2895
8 1774 1775 1826 1825 2845 2846 2897 2896
8 1775 1776 1827 1826 2846 2847 2898 2897
8 1776 1777 1828 1827 2847 2848 2899 2898
8 1777 1778 1829 1828 2848 2849 2900 2899
8 1778 1779 1830 1829 2849 2850 2901 2900
8 1779 1780 1831 1830 2850 2851 2902 2901
8 1780 1781 1832 1831 2851 2852 2903 2902
8 1781 1782 1833 1832 2852 2853 2904 2903
8 1782 1783 1834 1833 2853 2854 2905 2904
8 1783 1784 1835 1834 2854 2855 2906 2905
8 1785 1786 1837 1836 2856 2857 2908 2907
8 1786 1787 1838 1837 2857 2858 2909 2908
8 1787 1788 1839 1838 2858 2859 2910 2909
8 1788 1789 1840 1839 2859 2860 2911 2910
8 1789 1790 1841 1840 2860 2861 2912 2911
8 1790 1791 1842 1841 2861 2862 2913 2912
8 1791 1792 1843 1842 2862 2863 2914 2913
8 1792 1793 1844 1843 2863 2864 2915 2914
8 1793 1794 1845 1844 2864 2865 2916 2915
8 1794 1795 1846 1845 2865 2866 2917 2916
8 1795 1796 1847 1846 2866 2867 2918 2917
8 1796 1797 1848 1847 2867 2868 2919 2918
8 1797 1798 1849 1848 2868 2869 2920 2919
8 1798 1799 1850 1849 2869 2870 2921 2920
8 1799 1800 1851 1850 2870 2871 2922 2921
8 1800 1801 1852 1851 2871 2872 2923 2922
8 1801 1802 1853 1852 2872 2873 2924 2923
8 1802 1803 1854 1853 2873 2874 2925 2924
8 1803 1804 1855 1854 2874 2875 2926 2925
8 1804 1805 1856 1855 2875 2876 2927 2926
8 1805 1806 1857 1856 2876 2877 2928 2927
8 1806 1807 1858 1857 2877 2878 2929 2928
8 1807 1808 1859 1858 2878 2879 2930 2929
8 1808 1809 1860 1859 2879 2880 2931 2930
8 1809 1810 1861 1860 2880 2881 2932 2931
8 1810 1811 1862 1861 2881 2882 2933 2932
8 1811 1812 1863 1862 2882 2883 2934 2933
8 1812 1813 1864 1863 2883 2884 2935 2934
8 1813 1814 1865 1864 2884 2885 2936 2935
8 1814 1815 1866 1865 2885 2886 2937 2936
8 1815 1816 1867 1866 2886 2887 2938 2937
8 1816 1817 1868 1867 2887 2888 2939 2938
8 1817 1818 1869 1868 2888 2889 2940 2939
8 1818 1819 1870 1869 2889 2890 2941 2940
8 1819 1820 1871 1870 2890 2891 2942 2941
8 1820 1821 1872 1871 2891 2892 2943 2942
8 1821 1822 1873 1872 2892 2893 2944 2943
8 1822 1823 1874 1873 2893 2894 2945 2944
8 1823 1824 1875 1874 2894 2895 2946 2945
8 1824 1825 1876 1875 2895 2896 2947 2946
8 1825 1826 1877 1876 2896 2897 2948 2947
8 1826 1827 1878 1877 2897 2898 2949 2948
8 1827 1828 1879 1878 2898 2899 2950 2949
8 1828 1829 1880 1879 2899 2900 2951 2950
8 1829 1830 1881 1880 2900 2901 2952 2951
8 1830 1831 1882 1881 2901 2902 2953 2952
8 1831 1832 1883 1882 2902 2903 2954 2953
8 1832 1833 1884 1883 2903 2904 2955 2954
8 1833 1834 1885 1884 2904 2905 2956 2955
8 1834 1835 1886 1885 2905 2906 2957 2956
8 1836 1837 1888 1887 2907 2908 2959 2958
8 1837 1838 1889 1888 2908 2909 2960 2959
8 1838 1839 1890 1889 2909 2910 2961 2960
8 1839 1840 1891 1890 2910 2911 2962 2961
8 1840 1841 1892 1891 2911 2912 2963 2962
8 1841 1842 1893 1892 2912 2913 2964 2963
8 1842 1843 1894 1893 2913 2914 2965 2964
8 1843 1844 1895 1894 2914 2915 2966 2965
8 1844 1845 1896 1895 2915 2916 2967 2966
8 1845 1846 1897 1896 2916 2917 2968 2967
8 1846 1847 1898 1897 2917 2918 2969 2968
8 1847 1848 1899 1898 2918 2919 2970 2969
8 1848 1849 1900 1899 2919 2920 2971 2970
8 1849 1850 1901 1900 2920 2921 2972 2971
8 1850 1851 1902 1901 2921 2922 2973 2972
8 1851 1852 1903 1902 2922 2923 2974 2973
8 1852 1853 1904 1903 2923 2924 2975 2974
8 1853 1854 1905 1904 2924 2925 2976 2975
8 1854 1855 1906 1905 2925 2926 2977 2976
8 1855 1856 1907 1906 2926 2927 2978 2977
8 1856 1857 1908 1907 2927 2928 2979 2978
8 1857 1858 1909 1908 2928 2929 2980 2979
8 1858 1859 1910 1909 2929 2930 2981 2980
8 1859 1860 1911 1910 2930 2931 2982 2981
8 1860 1861 1912 1911 2931 2932 2983 2982
8 1861 1862 1913 1912 2932 2933 2984 2983
8 1862 1863 1914 1913 2933 2934 2985 2984
8 1863 1864 1915 1914 2934 2935 2986 2985
8 1864 1865 1916 1915 2935 2936 2987 2986
8 1865 1866 1917 1916 2936 2937 2988 2987
8 1866 1867 1918 1917 2937 2938 2989 2988
8 1867 1868 1919 1918 2938 2939 2990 2989
8 1868 1869 1920 1919 2939 2940 2991 2990
8 1869 1870 1921 1920 2940 2941 2992 2991
8 1870 1871 1922 1921 2941 2942 2993 2992
8 1871 1872 1923 1922 2942 2943 2994 2993
8 1872 1873 1924 1923 2943 2944 2995 2994
8 1873 1874 1925 1924 2944 2945 2996 2995
8 1874 1875 1926 1925 2945 2946 2997 2996
8 1875 1876 1927 1926 2946 2947 2998 2997
8 1876 1877 1928 1927 2947 2948 2999 2998
8 1877 1878 1929 1928 2948 2949 3000 2999
8 1878 1879 1930 1929 2949 2950 3001 3000
8 1879 1880 1931 1930 2950 2951 3002 3001
8 1880 1881 1932 1931 2951 2952 3003 3002
8 1881 1882 1933 1932 2952 2953 3004 3003
8 1882 1883 1934 1933 2953 2954 3005 3004
8 1883 1884 1935 1934 2954 2955 3006 3005
8 1884 1885 1936 1935 2955 2956 3007 3006
8 1885 1886 1937 1936 2956 2957 3008 3007
8 1887 1888 1939 1938 2958 2959 3010 3009
8 1888 1889 1940 1939 2959 2960 3011 3010
8 1889 1890 1941 1940 2960 2961 3012 3011
8 1890 1891 1942 1941 2961 2962 3013 3012
8 1891 1892 1943 1942 2962 2963 3014 3013
8 1892 1893 1944 1943 2963 2964 3015 3014
8 1893 1894 1945 1944 2964 2965 3016 3015
8 1894 1895 1946 1945 2965 2966 3017 3016
8 1895 1896 1947 1946 2966 2967 3018 3017
8 1896 1897 1948 1947 2967 2968 3019 3018
8 1897 1898 1949 1948 2968 2969 3020 3019
8 1898 1899 1950 1949 2969 2970 3021 3020
8 1899 1900 1951 1950 2970 2971 3022 3021
8 1900 1901 1952 1951 2971 2972 3023 3022
8 1901 1902 1953 1952 2972 2973 3024 3023
8 1902 1903 1954 1953 2973 2974 3025 3024
8 1903 1904 1955 1954 2974 2975 3026 3025
8 1904 1905 1956 1955 2975 2976 3027 3026
8 1905 1906 1957 1956 2976 2977 3028 3027
8 1906 1907 1958 1957 2977 2978 3029 3028
8 1907 1908 1959 1958 2978 2979 3030 3029
8 1908 1909 1960 1959 2979 2980 3031 3030
8 1909 1910 1961 1960 2980 2981 3032 3031
8 1910 1911 1962 1961 2981 2982 3033 3032
8 1911 1912 1963 1962 2982 2983 3034 3033
8 1912 1913 1964 1963 2983 2984 3035 3034
8 1913 1914 1965 1964 2984 2985 3036 3035
8 1914 1915 1966 1965 2985 2986 3037 3036
8 1915 1916 1967 1966 2986 2987 3038 3037
8 1916 1917 1968 1967 2987 2988 3039 3038
8 1917 1918 1969 1968 2988 2989 3040 3039
8 1918 1919 1970 1969 2989 2990 3041 3040
8 1919 1920 1971 1970 2990 2991 3042 3041
8 1920 1921 1972 1971 2991 2992 3043 3042
8 1921 1922 1973 1972 2992 2993 3044 3043
8 1922 1923 1974 1973 2993 2994 3045 3044
8 1923 1924 1975 1974 2994 2995 3046 3045
8 1924 1925 1976 1975 2995 2996 3047 3046
8 1925 1926 1977 1976 2996 2997 3048 3047
8 1926 1927 1978 1977 2997 2998 3049 3048
8 1927 1928 1979 1978 2998 2999 3050 3049
8 1928 1929 1980 1979 2999 3000 3051 3050
8 1929 1930 1981 1980 3000 3001 3052 3051
8 1930 1931 1982 1981 3001 3002 3053 3052
8 1931 1932 1983 1982 3002 3003 3054 3053
8 1932 1933 1984 1983 3003 3004 3055 3054
8 1933 1934 1985 1984 3004 3005 3056 3055
8 1934 1935 1986 1985 3005 3006 3057 3056
8 1935 1936 1987 1986 3006 3007 3058 3057
8 1936 1937 1988 1987 3007 3008 3059 3058
8 1938 1939 1990 1989 3009 3010 3061 3060
8 1939 1940 1991 1990 3010 3011 3062 3061
8 1940 1941 1992 1991 3011 3012 3063 3062
8 1941 1942 1993 1992 3012 3013 3064 3063
8 1942 1943 1994 1993 3013 3014 3065 3064
8 1943 1944 1995 1994 3014 3015 3066 3065
8 1944 1945 1996 1995 3015 3016 3067 3066
8 1945 1946 1997 1996 3016 3017 3068 3067
8 1946 1947 1998 1997 3017 3018 3069 3068
8 1947 1948 1999 1998 3018 3019 3070 3069
8 1948 1949 2000 1999 3019 3020 3071 3070
8 1949 1950 2001 2000 3020 3021 3072 3071
8 1950 1951 2002 2001 3021 3022 3073 3072
8 1951 1952 2003 2002 3022 3023 3074 3073
8 1952 1953 2004 2003 3023 3024 3075 3074
8 1953 1954 2005 2004 3024 3025 3076 3075
8 1954 1955 2006 2005 3025 3026 3077 3076
8 1955 1956 2007 2006 3026 3027 3078 3077
8 1956 1957 2008 2007 3027 3028 3079 3078
8 1957 1958 2009 2008 3028 3029 3080 3079
8 1958 1959 2010 2009 3029 3030 3081 3080
8 1959 1960 2011 2010 3030 3031 3082 3081
8 1960 1961 2012 2011 3031 3032 3083 3082
8 1961 1962 2013 2012 3032 3033 3084 3083
8 1962 1963 2014 2013 3033 3034 3085 3084
8 1963 1964 2015 2014 3034 3035 3086 3085
8 1964 1965 2016 2015 3035 3036 3087 3086
8 1965 1966 2017 2016 3036 3037 3088 3087
8 1966 1967 2018 2017 3037 3038 3089 3088
8 1967 1968 2019 2018 3038 3039 3090 3089
8 1968 1969 2020 2019 3039 3040 3091 3090
8 1969 1970 2021 2020 3040 3041 3092 3091
8 1970 1971 2022 2021 3041 3042 3093 3092
8 1971 1972 2023 2022 3042 3043 3094 3093
8 1972 1973 2024 2023 3043 3044 3095 3094
8 1973 1974 2025 2024 3044 3045 3096 3095
8 1974 1975 2026 2025 3045 3046 3097 3096
8 1975 1976 2027 2026 3046 3047 3098 3097
8 1976 1977 2028 2027 3047 3048 3099 3098
8 1977 1978 2029 2028 3048 3049 3100 3099
8 1978 1979 2030 2029 3049 3050 3101 3100
8 1979 1980 2031 2030 3050 3051 3102 3101
8 1980 1981 2032 2031 3051 3052 3103 3102
8 1981 1982 2033 2032 3052 3053 3104 3103
8 1982 1983 2034 2033 3053 3054 3105 3104
8 1983 1984 2035 2034 3054 3055 3106 3105
8 1984 1985 2036 2035 3055 3056 3107 3106
8 1985 1986 2037 2036 3056 3057 3108 3107
8 1986 1987 2038 2037 3057 3058 3109 3108
8 1987 1988 2039 2038 3058 3059 3110 3109
8 1989 1990 2041 2040 3060 3061 3112 3111
8 1990 1991 2042 2041 3061 3062 3113 3112
8 1991 1992 2043 2042 3062 3063 3114 3113
8 1992 1993 2044 2043 3063 3064 3115 3114
8 1993 1994 2045 2044 3064 3065 3116 3115
8 1994 1995 2046 2045 3065 3066 3117 3116
8 1995 1996 2047 2046 3066 3067 3118 3117
8 1996 1997 2048 2047 3067 3068 3119 3118
8 1997 1998 2049 2048 3068 3069 3120 3119
8 1998 1999 2050 2049 3069 3070 3121 3120
8 1999 2000 2051 2050 3070 3071 3122 3121
8 2000 2001 2052 2051 3071 3072 3123 3122
8 2001 2002 2053 2052 3072 3073 3124 3123
8 2002 2003 2054 2053 3073 3074 3125 3124
8 2003 2004 2055 2054 3074 3075 3126 3125
8 2004 2005 2056 2055 3075 3076 3127 3126
8 2005 2006 2057 2056 3076 3077 3128 3127
8 2006 2007 2058 2057 3077 3078 3129 3128
8 2007 2008 2059 2058 3078 3079 3130 3129
8 2008 2009 2060 2059 3079 3080 3131 3130
8 2009 2010 2061 2060 3080 3081 3132 3131
8 2010 2011 2062 2061 3081 3082 3133 3132
8 2011 2012 2063 2062 3082 3083 3134 3133
8 2012 2013 2064 2063 3083 3084 3135 3134
8 2013 2014 2065 2064 3084 3085 3136 3135
8 2014 2015 2066 2065 3085 3086 3137 3136
8 2015 2016 2067 2066 3086 3087 3138 3137
8 2016 2017 2068 2067 3087 3088 3139 3138
8 2017 2018 2069 2068 3088 3089 3140 3139
8 2018 2019 2070 2069 3089 3090 3141 3140
8 2019 2020 2071 2070 3090 3091 3142 3141
8 2020 2021 2072 2071 3091 3092 3143 3142
8 2021 2022 2073 2072 3092 3093 3144 3143
8 2022 2023 2074 2073 3093 3094 3145 3144
8 2023 2024 2075 2074 3094 3095 3146 3145
8 2024 2025 2076 2075 3095 3096 3147 3146
8 2025 2026 2077 2076 3096 3097 3148 3147
8 2026 2027 2078 2077 3097 3098 3149 3148
8 2027 2028 2079 2078 3098 3099 3150 3149
8 2028 2029 2080 2079 3099 3100 3151 3150
8 2029 2030 2081 2080 3100 3101 3152 3151
8 2030 2031 2082 2081 3101 3102 3153 3152
8 2031 2032 2083 2082 3102 3103 3154 3153
8 2032 2033 2084 2083 3103 3104 3155 3154
8 2033 2034 2085 2084 3104 3105 3156 3155
8 2034 2035 2086 2085 3105 3106 3157 3156
8 2035 2036 2087 2086 3106 3107 3158 3157
8 2036 2037 2088 2087 3107 3108 3159 3158
8 2037 2038 2089 2088 3108 3109 3160 3159
8 2038 2039 2090 2089 3109 3110 3161 3160
8 2040 2041 2092 2091 3111 3112 3163 3162
8 2041 2042 2093 2092 3112 3113 3164 3163
8 2042 2043 2094 2093 3113 3114 3165 3164
8 2043 2044 2095 2094 3114 3115 3166 3165
8 2044 2045 2096 2095 3115 3116 3167 3166
8 2045 2046 2097 2096 3116 3117 3168 3167
8 2046 2047 2098 2097 3117 3118 3169 3168
8 2047 2048 2099 2098 3118 3119 3170 3169
8 2048 2049 2100 2099 3119 3120 3171 3170
8 2049 2050 2101 2100 3120 3121 3172 3171
8 2050 2051 2102 2101 3121 3122 3173 3172
8 2051 2052 2103 2102 3122 3123 3174 3173
8 2052 2053 2104 2103 3123 3124 3175 3174
8 2053 2054 2105 2104 3124 3125 3176 3175
8 2054 2055 2106 2105 3125 3126 3177 3176
8 2055 2056 2107 2106 3126 3127 3178 3177
8 2056 2057 2108 2107 3127 3128 3179 3178
8 2057 2058 2109 2108 3128 3129 3180 3179
8 2058 2059 2110 2109 3129 3130 3181 3180
8 2059 2060 2111 2110 3130 3131 3182 3181
8 2060 2061 2112 2111 3131 3132 3183 3182
8 2061 2062 2113 2112 3132 3133 3184 3183
8 2062 2063 2114 2113 3133 3134 3185 3184
8 2063 2064 2115 2114 3134 3135 3186 3185
8 2064 2065 2116 2115 3135 3136 3187 3186
8 2065 2066 2117 2116 3136 3137 3188 3187
8 2066 2067 2118 2117 3137 3138 3189 3188
8 2067 2068 2119 2118 3138 3139 3190 3189
8 2068 2069 2120 2119 3139 3140 3191 3190
8 2069 2070 2121 2120 3140 3141 3192 3191
8 2070 2071 2122 2121 3141 3142 3193 3192
8 2071 2072 2123 2122 3142 3143 3194 3193
8 2072 2073 2124 2123 3143 3144 3195 3194
8 2073 2074 2125 2124 3144 3145 3196 3195
8 2074 2075 2126 2125 3145 3146 3197 3196
8 2075 2076 2127 2126 3146 3147 3198 3197
8 2076 2077 2128 2127 3147 3148 3199 3198
8 2077 2078 2129 2128 3148 3149 3200 3199
8 2078 2079 2130 2129 3149 3150 3201 3200
8 2079 2080 2131 2130 3150 3151 3202 3201
8 2080 2081 2132 2131 3151 3152 3203 3202
8 2081 2082 2133 2132 3152 3153 3204 3203
8 2082 2083 2134 2133 3153 3154 3205 3204
8 2083 2084 2135 2134 3154 3155 3206 3205
8 2084 2085 2136 2135 3155 3156 3207 3206
8 2085 2086 2137 2136 3156 3157 3208 3207
8 2086 2087 2138 2137 3157 3158 3209 3208
8 2087 2088 2139 2138 3158 3159 3210 3209
8 2088 2089 2140 2139 3159 3160 3211 3210
8 2089 2090 2141 2140 3160 3161 3212 3211
8 2142 2143 2194 2193 3213 3214 3265 3264
8 2143 2144 2195 2194 3214 3215 3266 3265
8 2144 2145 2196 2195 3215 3216 3267 3266
8 2145 2146 2197 2196 3216 3217 3268 3267
8 2146 2147 2198 2197 3217 3218 3269 3268
8 2147 2148 2199 2198 3218 3219 3270 3269
8 2148 2149 2200 2199 3219 3220 3271 3270
8 2149 2150 2201 2200 3220 3221 3272 3271
8 2150 2151 2202 2201 3221 3222 3273 3272
8 2151 2152 2203 2202 3222 3223 3274 3273
8 2152 2153 2204 2203 3223 3224 3275 3274
8 2153 2154 2205 2204 3224 3225 3276 3275
8 2154 2155 2206 2205 3225 3226 3277 3276
8 2155 2156 2207 2206 3226 3227 3278 3277
8 2156 2157 2208 2207 3227 3228 3279 3278
8 2157 2158 2209 2208 3228 3229 3280 3279
8 2158 2159 2210 2209 3229 3230 3281 3280
8 2159 2160 2211 2210 3230 3231 3282 3281
8 2160 2161 2212 2211 3231 3232 3283 3282
8 2161 2162 2213 2212 3232 3233 3284 3283
8 2162 2163 2214 2213 3233 3234 3285 3284
8 2163 2164 2215 2214 3234 3235 3286 3285
8 2164 2165 2216 2215 3235 3236 3287 3286
8 2165 2166 2217 2216 3236 3237 3288 3287
8 2166 2167 2218 2217 3237 3238 3289 3288
8 2167 2168 2219 2218 3238 3239 3290 3289
8 2168 2169 2220 2219 3239 3240 3291 3290
8 2169 2170 2221 2220 3240 3241 3292 3291
8 2170 2171 2222 2221 3241 3242 3293 3292
8 2171 2172 2223 2222 3242 3243 3294 3293
8 2172 2173 2224 2223 3243 3244 3295 3294
8 2173 2174 2225 2224 3244 3245 3296 3295
8 2174 2175 2226 2225 3245 3246 3297 3296
8 2175 2176 2227 2226 3246 3247 3298 3297
8 2176 2177 2228 2227 3247 3248 3299 3298
8 2177 2178 2229 2228 3248 3249 3300 3299
8 2178 2179 2230 2229 3249 3250 3301 3300
8 2179 2180 2231 2230 3250 3251 3302 3301
8 2180 2181 2232 2231 3251 3252 3303 3302
8 2181 2182 2233 2232 3252 3253 3304 3303
8 2182 2183 2234 2233 3253 3254 3305 3304
8 2183 2184 2235 2234 3254 3255 3306 3305
8 2184 2185 2236 2235 3255 3256 3307 3306
8 2185 2186 2237 2236 3256 3257 3308 3307
8 2186 2187 2238 2237 3257 3258 3309 3308
8 2187 2188 2239 2238 3258 3259 3310 3309
8 2188 2189 2240 2239 3259 3260 3311 3310
8 2189 2190 2241 2240 3260 3261 3312 3311
8 2190 2191 2242 2241 3261 3262 3313 3312
8 2191 2192 2243 2242 3262 3263 3314 3313
8 2193 2194 2245 2244 3264 3265 3316 3315
8 2194 2195 2246 2245 3265 3266 3317 3316
8 2195 2196 2247 2246 3266 3267 3318 3317
8 2196 2197 2248 2247 3267 3268 3319 3318
8 2197 2198 2249 2248 3268 3269 3320 3319
8 2198 2199 2250 2249 3269 3270 3321 3320
8 2199 2200 2251 2250 3270 3271 3322 3321
8 2200 2201 2252 2251 3271 3272 3323 3322
8 2201 2202 2253 2252 3272 3273 3324 3323
8 2202 2203 2254 2253 3273 3274 3325 3324
8 2203 2204 2255 2254 3274 3275 3326 3325
8 2204 2205 2256 2255 3275 3276 3327 3326
8 2205 2206 2257 2256 3276 3277 3328 3327
8 2206 2207 2258 2257 3277 3278 3329 3328
8 2207 2208 2259 2258 3278 3279 3330 3329
8 2208 2209 2260 2259 3279 3280 3331 3330
8 2209 2210 2261 2260 3280 3281 3332 3331
8 2210 2211 2262 2261 3281 3282 3333 3332
8 2211 2212 2263 2262 3282 3283 3334 3333
8 2212 2213 2264 2263 3283 3284 3335 3334
8 2213 2214 2265 2264 3284 3285 3336 3335
8 2214 2215 2266 2265 3285 3286 3337 3336
8 2215 2216 2267 2266 3286 3287 3338 3337
8 2216 2217 2268 2267 3287 3288 3339 3338
8 2217 2218 2269 2268 3288 3289 3340 3339
8 2218 2219 2270 2269 3289 3290 3341 3340
8 2219 2220 2271 2270 3290 3291 3342 3341
8 2220 2221 2272 2271 3291 3292 3343 3342
8 2221 2222 2273 2272 3292 3293 3344 3343
8 2222 2223 2274 2273 3293 3294 3345 3344
8 2223 2224 2275 2274 3294 3295 3346 3345
8 2224 2225 2276 2275 3295 3296 3347 3346
8 2225 2226 2277 2276 3296 3297 3348 3347
8 2226 2227 2278 2277 3297 3298 3349 3348
8 2227 2228 2279 2278 3298 3299 3350 3349
8 2228 2229 2280 2279 3299 3300 3351 3350
8 2229 2230 2281 2280 3300 3301 3352 3351
8 2230 2231 2282 2281 3301 3302 3353 3352
8 2231 2232 2283 2282 3302 3303 3354 3353
8 2232 2233 2284 2283 3303 3304 3355 3354
8 2233 2234 2285 2284 3304 3305 3356 3355
8 2234 2235 2286 2285 3305 3306 3357 3356
8 2235 2236 2287 2286 3306 3307 3358 3357
8 2236 2237 2288 2287 3307 3308 3359 3358
8 2237 2238 2289 2288 3308 3309 3360 3359
8 2238 2239 2290 2289 3309 3310 3361 3360
8 2239 2240 2291 2290 3310 3311 3362 3361
8 2240 2241 2292 2291 3311 3312 3363 3362
8 2241 2242 2293 2292 3312 3313 3364 3363
8 2242 2243 2294 2293 3313 3314 3365 3364
8 2244 2245 2296 2295 3315 3316 3367 3366
8 2245 2246 2297 2296 3316 3317 3368 3367
8 2246 2247 2298 2297 3317 3318 3369 3368
8 2247 2248 2299 2298 3318 3319 3370 3369
8 2248 2249 2300 2299 3319 3320 3371 3370
8 2249 2250 2301 2300 3320 3321 3372 3371
8 2250 2251 2302 2301 3321 3322 3373 3372
8 2251 2252 2303 2302 3322 3323 3374 3373
8 2252 2253 2304 2303 3323 3324 3375 3374
8 2253 2254 2305 2304 3324 3325 3376 3375
8 2254 2255 2306 2305 3325 3326 3377 3376
8 2255 2256 2307 2306 3326 3327 3378 3377
8 2256 2257 2308 2307 3327 3328 3379 3378
8 2257 2258 2309 2308 3328 3329 3380 3379
8 2258 2259 2310 2309 3329 3330 3381 3380
8 2259 2260 2311 2310 3330 3331 3382 3381
8 2260 2261 2312 2311 3331 3332 3383 3382
8 2261 2262 2313 2312 3332 3333 3384 3383
8 2262 2263 2314 2313 3333 3334 3385 3384
8 2263 2264 2315 2314 3334 3335 3386 3385
8 2264 2265 2316 2315 3335 3336 3387 3386
8 2265 2266 2317 2316 3336 3337 3388 3387
8 2266 2267 2318 2317 3337 3338 3389 3388
8 2267 2268 2319 2318 3338 3339 3390 3389
8 2268 2269 2320 2319 3339 3340 3391 3390
8 2269 2270 2321 2320 3340 3341 3392 3391
8 2270 2271 2322 2321 3341 3342 3393 3392
8 2271 2272 2323 2322 3342 3343 3394 3393
8 2272 2273 2324 2323 3343 3344 3395 3394
8 2273 2274 2325 2324 3344 3345 3396 3395
8 2274 2275 2326 2325 3345 3346 3397 3396
8 2275 2276 2327 2326 3346 3347 3398 3397
8 2276 2277 2328 2327 3347 3348 3399 3398
8 2277 2278 2329 2328 3348 3349 3400 3399
8 2278 2279 2330 2329 3349 3350 3401 3400
8 2279 2280 2331 2330 3350 3351 3402 3401
8 2280 2281 2332 2331 3351 3352 3403 3402
8 2281 2282 2333 2332 3352 3353 3404 3403
8 2282 2283 2334 2333 3353 3354 3405 3404
8 2283 2284 2335 2334 3354 3355 3406 3405
8 2284 2285 2336 2335 3355 3356 3407 3406
8 2285 2286 2337 2336 3356 3357 3408 3407
8 2286 2287 2338 2337 3357 3358 3409 3408
8 2287 2288 2339 2338 3358 3359 3410 3409
8 2288 2289 2340 2339 3359 3360 3411 3410
8 2289 2290 2341 2340 3360 3361 3412 3411
8 2290 2291 2342 2341 3361 3362 3413 3412
8 2291 2292 2343 2342 3362 3363 3414 3413
8 2292 2293 2344 2343 3363 3364 3415 3414
8 2293 2294 2345 2344 3364 3365 3416 3415
8 2295 2296 2347 2346 3366 3367 3418 3417
8 2296 2297 2348 2347 3367 3368 3419 3418
8 2297 2298 2349 2348 3368 3369 3420 3419
8 2298 2299 2350 2349 3369 3370 3421 3420
8 2299 2300 2351 2350 3370 3371 3422 3421
8 2300 2301 2352 2351 3371 3372 3423 3422
8 2301 2302 2353 2352 3372 3373 3424 3423
8 2302 2303 2354 2353 3373 3374 3425 3424
8 2303 2304 2355 2354 3374 3375 3426 3425
8 2304 2305 2356 2355 3375 3376 3427 3426
8 2305 2306 2357 2356 3376 3377 3428 3427
8 2306 2307 2358 2357 3377 3378 3429 3428
8 2307 2308 2359 2358 3378 3379 3430 3429
8 2308 2309 2360 2359 3379 3380 3431 3430
8 2309 2310 2361 2360 3380 3381 3432 3431
8 2310 2311 2362 2361 3381 3382 3433 3432
8 2311 2312 2363 2362 3382 3383 3434 3433
8 2312 2313 2364 2363 3383 3384 3435 3434
8 2313 2314 2365 2364 3384 3385 3436 3435
8 2314 2315 2366 2365 3385 3386 3437 3436
8 2315 2316 2367 2366 3386 3387 3438 3437
8 2316 2317 2368 2367 3387 3388 3439 3438
8 2317 2318 2369 2368 3388 3389 3440 3439
8 2318 2319 2370 2369 3389 3390 3441 3440
8 2319 2320 2371 2370 3390 3391 3442 3441
8 2320 2321 2372 2371 3391 3392 3443 3442
8 2321 2322 2373 2372 3392 3393 3444 3443
8 2322 2323 2374 2373 3393 3394 3445 3444
8 2323 2324 2375 2374 3394 3395 3446 3445
8 2324 2325 2376 2375 3395 3396 3447 3446
8 2325 2326 2377 2376 3396 3397 3448 3447
8 2326 2327 2378 2377 3397 3398 3449 3448
8 2327 2328 2379 2378 3398 3399 3450 3449
8 2328 2329 2380 2379 3399 3400 3451 3450
8 2329 2330 2381 2380 3400 3401 3452 3451
8 2330 2331 2382 2381 3401 3402 3453 3452
8 2331 2332 2383 2382 3402 3403 3454 3453
8 2332 2333 2384 2383 3403 3404 3455 3454
8 2333 2334 2385 2384 3404 3405 3456 3455
8 2334 2335 2386 2385 3405 3406 3457 3456
8 2335 2336 2387 2386 3406 3407 3458 3457
8 2336 2337 2388 2387 3407 3408 3459 3458
8 2337 2338 2389 2388 3408 3409 3460 3459
8 2338 2339 2390 2389 3409 3410 3461 3460
8 2339 2340 2391 2390 3410 3411 3462 3461
8 2340 2341 2392 2391 3411 3412 3463 3462
8 2341 2342 2393 2392 3412 3413 3464 3463
8 2342 2343 2394 2393 3413 3414 3465 3464
8 2343 2344 2395 2394 3414 3415 3466 3465
8 2344 2345 2396 2395 3415 3416 3467 3466
8 2346 2347 2398 2397 3417 3418 3469 3468
8 2347 2348 2399 2398 3418 3419 3470 3469
8 2348 2349 2400 2399 3419 3420 3471 3470
8 2349 2350 2401 2400 3420 3421 3472 3471
8 2350 2351 2402 2401 3421 3422 3473 3472
8 2351 2352 2403 2402 3422 3423 3474 3473
8 2352 2353 2404 2403 3423 3424 3475 3474
8 2353 2354 2405 2404 3424 3425 3476 3475
8 2354 2355 2406 2405 3425 3426 3477 3476
8 2355 2356 2407 2406 3426 3427 3478 3477
8 2356 2357 2408 2407 3427 3428 3479 3478
8 2357 2358 2409 2408 3428 3429 3480 3479
8 2358 2359 2410 2409 3429 3430 3481 3480
8 2359 2360 2411 2410 3430 3431 3482 3481
8 2360 2361 2412 2411 3431 3432 3483 3482
8 2361 2362 2413 2412 3432 3433 3484 3483
8 2362 2363 2414 2413 3433 3434 3485 3484
8 2363 2364 2415 2414 3434 3435 3486 3485
8 2364 2365 2416 2415 3435 3436 3487 3486
8 2365 2366 2417 2416 3436 3437 3488 3487
8 2366 2367 2418 2417 3437 3438 3489 3488
8 2367 2368 2419 2418 3438 3439 3490 3489
8 2368 2369 2420 2419 3439 3440 3491 3490
8 2369 2370 2421 2420 3440 3441 3492 3491
8 2370 2371 2422 2421 3441 3442 3493 3492
8 2371 2372 2423 2422 3442 3443 3494 3493
8 2372 2373 2424 2423 3443 3444 3495 3494
8 2373 2374 2425 2424 3444 3445 3496 3495
8 2374 2375 2426 2425 3445 3446 3497 3496
8 2375 2376 2427 2426 3446 3447 3498 3497
8 2376 2377 2428 2427 3447 3448 3499 3498
8 2377 2378 2429 2428 3448 3449 3500 3499
8 2378 2379 2430 2429 3449 3450 3501 3500
8 2379 2380 2431 2430 3450 3451 3502 3501
8 2380 2381 2432 2431 3451 3452 3503 3502
8 2381 2382 2433 2432 3452 3453 3504 3503
8 2382 2383 2434 2433 3453 3454 3505 3504
8 2383 2384 2435 2434 3454 3455 3506 3505
8 2384 2385 2436 2435 3455 3456 3507 3506
8 2385 2386 2437 2436 3456 3457 3508 3507
8 2386 2387 2438 2437 3457 3458 3509 3508
8 2387 2388 2439 2438 3458 3459 3510 3509
8 2388 2389 2440 2439 3459 3460 3511 3510
8 2389 2390 2441 2440 3460 3461 3512 3511
8 2390 2391 2442 2441 3461 3462 3513 3512
8 2391 2392 2443 2442 3462 3463 3514 3513
8 2392 2393 2444 2443 3463 3464 3515 3514
8 2393 2394 2445 2444 3464 3465 3516 3515
8 2394 2395 2446 2445 3465 3466 3517 3516
8 2395 2396 2447 2446 3466 3467 3518 3517
8 2397 2398 2449 2448 3468 3469 3520 3519
8 2398 2399 2450 2449 3469 3470 3521 3520
8 2399 2400 2451 2450 3470 3471 3522 3521
8 2400 2401 2452 2451 3471 3472 3523 3522
8 2401 2402 2453 2452 3472 3473 3524 3523
8 2402 2403 2454 2453 3473 3474 3525 3524
8 2403 2404 2455 2454 3474 3475 3526 3525
8 2404 2405 2456 2455 3475 3476 3527 3526
8 2405 2406 2457 2456 3476 3477 3528 3527
8 2406 2407 2458 2457 3477 3478 3529 3528
8 2407 2408 2459 2458 3478 3479 3530 3529
8 2408 2409 2460 2459 3479 3480 3531 3530
8 2409 2410 2461 2460 3480 3481 3532 3531
8 2410 2411 2462 2461 3481 3482 3533 3532
8 2411 2412 2463 2462 3482 3483 3534 3533
8 2412 2413 2464 2463 3483 3484 3535 3534
8 2413 2414 2465 2464 3484 3485 3536 3535
8 2414 2415 2466 2465 3485 3486 3537 3536
8 2415 2416 2467 2466 3486 3487 3538 3537
8 2416 2417 2468 2467 3487 3488 3539 3538
8 2417 2418 2469 2468 3488 3489 3540 3539
8 2418 2419 2470 2469 3489 3490 3541 3540
8 2419 2420 2471 2470 3490 3491 3542 3541
8 2420 2421 2472 2471 3491 3492 3543 3542
8 2421 2422 2473 2472 3492 3493 3544 3543
8 2422 2423 2474 2473 3493 3494 3545 3544
8 2423 2424 2475 2474 3494 3495 3546 3545
8 2424 2425 2476 2475 3495 3496 3547 3546
8 2425 2426 2477 2476 3496 3497 3548 3547
8 2426 2427 2478 2477 3497 3498 3549 3548
8 2427 2428 2479 2478 3498 3499 3550 3549
8 2428 2429 2480 2479 3499 3500 3551 3550
8 2429 2430 2481 2480 3500 3501 3552 3551
8 2430 2431 2482 2481 3501 3502 3553 3552
8 2431 2432 2483 2482 3502 3503 3554 3553
8 2432 2433 2484 2483 3503 3504 3555 3554
8 2433 2434 2485 2484 3504 3505 3556 3555
8 2434 2435 2486 2485 3505 3506 3557 3556
8 2435 2436 2487 2486 3506 3507 3558 3557
8 2436 2437 2488 2487 3507 3508 3559 3558
8 2437 2438 2489 2488 3508 3509 3560 3559
8 2438 2439 2490 2489 3509 3510 3561 3560
8 2439 2440 2491 2490 3510 3511 3562 3561
8 2440 2441 2492 2491 3511 3512 3563 3562
8 2441 2442 2493 2492 3512 3513 3564 3563
8 2442 2443 2494 2493 3513 3514 3565 3564
8 2443 2444 2495 2494 3514 3515 3566 3565
8 2444 2445 2496 2495 3515 3516 3567 3566
8 2445 2446 2497 2496 3516 3517 3568 3567
8 2446 2447 2498 2497 3517 3518 3569 3568
8 2448 2449 2500 2499 3519 3520 3571 3570
8 2449 2450 2501 2500 3520 3521 3572 3571
8 2450 2451 2502 2501 3521 3522 3573 3572
8 2451 2452 2503 2502 3522 3523 3574 3573
8 2452 2453 2504 2503 3523 3524 3575 3574
8 2453 2454 2505 2504 3524 3525 3576 3575
8 2454 2455 2506 2505 3525 3526 3577 3576
8 2455 2456 2507 2506 3526 3527 3578 3577
8 2456 2457 2508 2507 3527 3528 3579 3578
8 2457 2458 2509 2508 3528 3529 3580 3579
8 2458 2459 2510 2509 3529 3530 3581 3580
8 2459 2460 2511 2510 3530 3531 3582 3581
8 2460 2461 2512 2511 3531 3532 3583 3582
8 2461 2462 2513 2512 3532 3533 3584 3583
8 2462 2463 2514 2513 3533 3534 3585 3584
8 2463 2464 2515 2514 3534 3535 3586 3585
8 2464 2465 2516 2515 3535 3536 3587 3586
8 2465 2466 2517 2516 3536 3537 3588 3587
8 2466 2467 2518 2517 3537 3538 3589 3588
8 2467 2468 2519 2518 3538 3539 3590 3589
8 2468 2469 2520 2519 3539 3540 3591 3590
8 2469 2470 2521 2520 3540 3541 3592 3591
8 2470 2471 2522 2521 3541 3542 3593 3592
8 2471 2472 2523 2522 3542 3543 3594 3593
8 2472 2473 2524 2523 3543 3544 3595 3594
8 2473 2474 2525 2524 3544 3545 3596 3595
8 2474 2475 2526 2525 3545 3546 3597 3596
8 2475 2476 2527 2526 3546 3547 3598 3597
8 2476 2477 2528 2527 3547 3548 3599 3598
8 2477 2478 2529 2528 3548 3549 3600 3599
8 2478 2479 2530 2529 3549 3550 3601 3600
8 2479 2480 2531 2530 3550 3551 3602 3601
8 2480 2481 2532 2531 3551 3552 3603 3602
8 2481 2482 2533 2532 3552 3553 3604 3603
8 2482 2483 2534 2533 3553 3554 3605 3604
8 2483 2484 2535 2534 3554 3555 3606 3605
8 2484 2485 2536 2535 3555 3556 3607 3606
8 2485 2486 2537 2536 3556 3557 3608 3607
8 2486 2487 2538 2537 3557 3558 3609 3608
8 2487 2488 2539 2538 3558 3559 3610 3609
8 2488 2489 2540 2539 3559 3560 3611 3610
8 2489 2490 2541 2540 3560 3561 3612 3611
8 2490 2491 2542 2541 3561 3562 3613 3612
8 2491 2492 2543 2542 3562 3563 3614 3613
8 2492 2493 2544 2543 3563 3564 3615 3614
8 2493 2494 2545 2544 3564 3565 3616 3615
8 2494 2495 2546 2545 3565 3566 3617 3616
8 2495 2496 2547 2546 3566 3567 3618 3617
8 2496 2497 2548 2547 3567 3568 3619 3618
8 2497 2498 2549 2548 3568 3569 3620 3619
8 2499 2500 2551 2550 3570 3571 3622 3621
8 2500 2501 2552 2551 3571 3572 3623 3622
8 2501 2502 2553 2552 3572 3573 3624 3623
8 2502 2503 2554 2553 3573 3574 3625 3624
8 2503 2504 2555 2554 3574 3575 3626 3625
8 2504 2505 2556 2555 3575 3576 3627 3626
8 2505 2506 2557 2556 3576 3577 3628 3627
8 2506 2507 2558 2557 3577 3578 3629 3628
8 2507 2508 2559 2558 3578 3579 3630 3629
8 2508 2509 2560 2559 3579 3580 3631 3630
8 2509 2510 2561 2560 3580 3581 3632 3631
8 2510 2511 2562 2561 3581 3582 3633 3632
8 2511 2512 2563 2562 3582 3583 3634 3633
8 2512 2513 2564 2563 3583 3584 3635 3634
8 2513 2514 2565 2564 3584 3585 3636 3635
8 2514 2515 2566 2565 3585 3586 3637 3636
8 2515 2516 2567 2566 3586 3587 3638 3637
8 2516 2517 2568 2567 3587 3588 3639 3638
8 2517 2518 2569 2568 3588 3589 3640 3639
8 2518 2519 2570 2569 3589 3590 3641 3640
8 2519 2520 2571 2570 3590 3591 3642 3641
8 2520 2521 2572 2571 3591 3592 3643 3642
8 2521 2522 2573 2572 3592 3593 3644 3643
8 2522 2523 2574 2573 3593 3594 3645 3644
8 2523 2524 2575 2574 3594 3595 3646 3645
8 2524 2525 2576 2575 3595 3596 3647 3646
8 2525 2526 2577 2576 3596 3597 3648 3647
8 2526 2527 2578 2577 3597 3598 3649 3648
8 2527 2528 2579 2578 3598 3599 3650 3649
8 2528 2529 2580 2579 3599 3600 3651 3650
8 2529 2530 2581 2580 3600 3601 3652 3651
8 2530 2531 2582 2581 3601 3602 3653 3652
8 2531 2532 2583 2582 3602 3603 3654 3653
8 2532 2533 2584 2583 3603 3604 3655 3654
8 2533 2534 2585 2584 3604 3605 3656 3655
8 2534 2535 2586 2585 3605 3606 3657 3656
8 2535 2536 2587 2586 3606 3607 3658 3657
8 2536 2537 2588 2587 3607 3608 3659 3658
8 2537 2538 2589 2588 3608 3609 3660 3659
8 2538 2539 2590 2589 3609 3610 3661 3660
8 2539 2540 2591 2590 3610 3611 3662 3661
8 2540 2541 2592 2591 3611 3612 3663 3662
8 2541 2542 2593 2592 3612 3613 3664 3663
8 2542 2543 2594 2593 3613 3614 3665 3664
8 2543 2544 2595 2594 3614 3615 3666 3665
8 2544 2545 2596 2595 3615 3616 3667 3666
8 2545 2546 2597 2596 3616 3617 3668 3667
8 2546 2547 2598 2597 3617 3618 3669 3668
8 2547 2548 2599 2598 3618 3619 3670 3669
8 2548 2549 2600 2599 3619 3620 3671 3670
8 2550 2551 2602 2601 3621 3622 3673 3672
8 2551 2552 2603 2602 3622 3623 3674 3673
8 2552 2553 2604 2603 3623 3624 3675 3674
8 2553 2554 2605 2604 3624 3625 3676 3675
8 2554 2555 2606 2605 3625 3626 3677 3676
8 2555 2556 2607 2606 3626 3627 3678 3677
8 2556 2557 2608 2607 3627 3628 3679 3678
8 2557 2558 2609 2608 3628 3629 3680 3679
8 2558 2559 2610 2609 3629 3630 3681 3680
8 2559 2560 2611 2610 3630 3631 3682 3681
8 2560 2561 2612 2611 3631 3632 3683 3682
8 2561 2562 2613 2612 3632 3633 3684 3683
8 2562 2563 2614 2613 3633 3634 3685 3684
8 2563 2564 2615 2614 3634 3635 3686 3685
8 2564 2565 2616 2615 3635 3636 3687 3686
8 2565 2566 2617 2616 3636 3637 3688 3687
8 2566 2567 2618 2617 3637 3638 3689 3688
8 2567 2568 2619 2618 3638 3639 3690 3689
8 2568 2569 2620 2619 3639 3640 3691 3690
8 2569 2570 2621 2620 3640 3641 3692 3691
8 2570 2571 2622 2621 3641 3642 3693 3692
8 2571 2572 2623 2622 3642 3643 3694 3693
8 2572 2573 2624 2623 3643 3644 3695 3694
8 2573 2574 2625 2624 3644 3645 3696 3695
8 2574 2575 2626 2625 3645 3646 3697 3696
8 2575 2576 2627 2626 3646 3647 3698 3697
8 2576 2577 2628 2627 3647 3648 3699 3698
8 2577 2578 2629 2628 3648 3649 3700 3699
8 2578 2579 2630 2629 3649 3650 3701 3700
8 2579 2580 2631 2630 3650 3651 3702 3701
8 2580 2581 2632 2631 3651 3652 3703 3702
8 2581 2582 2633 2632 3652 3653 3704 3703
8 2582 2583 2634 2633 3653 3654 3705 3704
8 2583 2584 2635 2634 3654 3655 3706 3705
8 2584 2585 2636 2635 3655 3656 3707 3706
8 2585 2586 2637 2636 3656 3657 3708 3707
8 2586 2587 2638 2637 3657 3658 3709 3708
8 2587 2588 2639 2638 3658 3659 3710 3709
8 2588 2589 2640 2639 3659 3660 3711 3710
8 2589 2590 2641 2640 3660 3661 3712 3711
8 2590 2591 2642 2641 3661 3662 3713 3712
8 2591 2592 2643 2642 3662 3663 3714 3713
8 2592 2593 2644 2643 3663 3664 3715 3714
8 2593 2594 2645 2644 3664 3665 3716 3715
8 2594 2595 2646 2645 3665 3666 3717 3716
8 2595 2596 2647 2646 3666 3667 3718 3717
8 2596 2597 2648 2647 3667 3668 3719 3718
8 2597 2598 2649 2648 3668 3669 3720 3719
8 2598 2599 2650 2649 3669 3670 3721 3720
8 2599 2600 2651 2650 3670 3671 3722 3721
8 2601 2602 2653 2652 3672 3673 3724 3723
8 2602 2603 2654 2653 3673 3674 3725 3724
8 2603 2604 2655 2654 3674 3675 3726 3725
8 2604 2605 2656 2655 3675 3676 3727 3726
8 2605 2606 2657 2656 3676 3677 3728 3727
8 2606 2607 2658 2657 3677 3678 3729 3728
8 2607 2608 2659 2658 3678 3679 3730 3729
8 2608 2609 2660 2659 3679 3680 3731 3730
8 2609 2610 2661 2660 3680 3681 3732 3731
8 2610 2611 2662 2661 3681 3682 3733 3732
8 2611 2612 2663 2662 3682 3683 3734 3733
8 2612 2613 2664 2663 3683 3684 3735 3734
8 2613 2614 2665 2664 3684 3685 3736 3735
8 2614 2615 2666 2665 3685 3686 3737 3736
8 2615 2616 2667 2666 3686 3687 3738 3737
8 2616 2617 2668 2667 3687 3688 3739 3738
8 2617 2618 2669 2668 3688 3689 3740 3739
8 2618 2619 2670 2669 3689 3690 3741 3740
8 2619 2620 2671 2670 3690 3691 3742 3741
8 2620 2621 2672 2671 3691 3692 3743 3742
8 2621 2622 2673 2672 3692 3693 3744 3743
8 2622 2623 2674 2673 3693 3694 3745 3744
8 2623 2624 2675 2674 3694 3695 3746 3745
8 2624 2625 2676 2675 3695 3696 3747 3746
8 2625 2626 2677 2676 3696 3697 3748 3747
8 2626 2627 2678 2677 3697 3698 3749 3748
8 2627 2628 2679 2678 3698 3699 3750 3749
8 2628 2629 2680 2679 3699 3700 3751 3750
8 2629 2630 2681 2680 3700 3701 3752 3751
8 2630 2631 2682 2681 3701 3702 3753 3752
8 2631 2632 2683 2682 3702 3703 3754 3753
8 2632 2633 2684 2683 3703 3704 3755 3754
8 2633 2634 2685 2684 3704 3705 3756 3755
8 2634 2635 2686 2685 3705 3706 3757 3756
8 2635 2636 2687 2686 3706 3707 3758 3757
8 2636 2637 2688 2687 3707 3708 3759 3758
8 2637 2638 2689 2688 3708 3709 3760 3759
8 2638 2639 2690 2689 3709 3710 3761 3760
8 2639 2640 2691 2690 3710 3711 3762 3761
8 2640 2641 2692 2691 3711 3712 3763 3762
8 2641 2642 2693 2692 3712 3713 3764 3763
8 2642 2643 2694 2693 3713 3714 3765 3764
8 2643 2644 2695 2694 3714 3715 3766 3765
8 2644 2645 2696 2695 3715 3716 3767 3766
8 2645 2646 2697 2696 3716 3717 3768 3767
8 2646 2647 2698 2697 3717 3718 3769 3768
8 2647 2648 2699 2698 3718 3719 3770 3769
8 2648 2649 2700 2699 3719 3720 3771 3770
8 2649 2650 2701 2700 3720 3721 3772 3771
8 2650 2651 2702 2701 3721 3722 3773 3772
8 2652 2653 2704 2703 3723 3724 3775 3774
8 2653 2654 2705 2704 3724 3725 3776 3775
8 2654 2655 2706 2705 3725 3726 3777 3776
8 2655 2656 2707 2706 3726 3727 3778 3777
8 2656 2657 2708 2707 3727 3728 3779 3778
8 2657 2658 2709 2708 3728 3729 3780 3779
8 2658 2659 2710 2709 3729 3730 3781 3780
8 2659 2660 2711 2710 3730 3731 3782 3781
8 2660 2661 2712 2711 3731 3732 3783 3782
8 2661 2662 2713 2712 3732 3733 3784 3783
8 2662 2663 2714 2713 3733 3734 3785 3784
8 2663 2664 2715 2714 3734 3735 3786 3785
8 2664 2665 2716 2715 3735 3736 3787 3786
8 2665 2666 2717 2716 3736 3737 3788 3787
8 2666 2667 2718 2717 3737 3738 3789 3788
8 2667 2668 2719 2718 3738 3739 3790 3789
8 2668 2669 2720 2719 3739 3740 3791 3790
8 2669 2670 2721 2720 3740 3741 3792 3791
8 2670 2671 2722 2721 3741 3742 3793 3792
8 2671 2672 2723 2722 3742 3743 3794 3793
8 2672 2673 2724 2723 3743 3744 3795 3794
8 2673 2674 2725 2724 3744 3745 3796 3795
8 2674 2675 2726 2725 3745 3746 3797 3796
8 2675 2676 2727 2726 3746 3747 3798 3797
8 2676 2677 2728 2727 3747 3748 3799 3798
8 2677 2678 2729 2728 3748 3749 3800 3799
8 2678 2679 2730 2729 3749 3750 3801 3800
8 2679 2680 2731 2730 3750 3751 3802 3801
8 2680 2681 2732 2731 3751 3752 3803 3802
8 2681 2682 2733 2732 3752 3753 3804 3803
8 2682 2683 2734 2733 3753 3754 3805 3804
8 2683 2684 2735 2734 3754 3755 3806 3805
8 2684 2685 2736 2735 3755 3756 3807 3806
8 2685 2686 2737 2736 3756 3757 3808 3807
8 2686 2687 2738 2737 3757 3758 3809 3808
8 2687 2688 2739 2738 3758 3759 3810 3809
8 2688 2689 2740 2739 3759 3760 3811 3810
8 2689 2690 2741 2740 3760 3761 3812 3811
8 2690 2691 2742 2741 3761 3762 3813 3812
8 2691 2692 2743 2742 3762 3763 3814 3813
8 2692 2693 2744 2743 3763 3764 3815 3814
8 2693 2694 2745 2744 3764 3765 3816 3815
8 2694 2695 2746 2745 3765 3766 3817 3816
8 2695 2696 2747 2746 3766 3767 3818 3817
8 2696 2697 2748 2747 3767 3768 3819 3818
8 2697 2698 2749 2748 3768 3769 3820 3819
8 2698 2699 2750 2749 3769 3770 3821 3820
8 2699 2700 2751 2750 3770 3771 3822 3821
8 2700 2701 2752 2751 3771 3772 3823 3822
8 2701 2702 2753 2752 3772 3773 3824 3823
8 2703 2704 2755 2754 3774 3775 3826 3825
8 2704 2705 2756 2755 3775 3776 3827 3826
8 2705 2706 2757 2756 3776 3777 3828 3827
8 2706 2707 2758 2757 3777 3778 3829 3828
8 2707 2708 2759 2758 3778 3779 3830 3829
8 2708 2709 2760 2759 3779 3780 3831 3830
8 2709 2710 2761 2760 3780 3781 3832 3831
8 2710 2711 2762 2761 3781 3782 3833 3832
8 2711 2712 2763 2762 3782 3783 3834 3833
8 2712 2713 2764 2763 3783 3784 3835 3834
8 2713 2714 2765 2764 3784 3785 3836 3835
8 2714 2715 2766 2765 3785 3786 3837 3836
8 2715 2716 2767 2766 3786 3787 3838 3837
8 2716 2717 2768 2767 3787 3788 3839 3838
8 2717 2718 2769 2768 3788 3789 3840 3839
8 2718 2719 2770 2769 3789 3790 3841 3840
8 2719 2720 2771 2770 3790 3791 3842 3841
8 2720 2721 2772 2771 3791 3792 3843 3842
8 2721 2722 2773 2772 3792 3793 3844 3843
8 2722 2723 2774 2773 3793 3794 3845 3844
8 2723 2724 2775 2774 3794 3795 3846 3845
8 2724 2725 2776 2775 3795 3796 3847 3846
8 2725 2726 2777 2776 3796 3797 3848 3847
8 2726 2727 2778 2777 3797 3798 3849 3848
8 2727 2728 2779 2778 3798 3799 3850 3849
8 2728 2729 2780 2779 3799 3800 3851 3850
8 2729 2730 2781 2780 3800 3801 3852 3851
8 2730 2731 2782 2781 3801 3802 3853 3852
8 2731 2732 2783 2782 3802 3803 3854 3853
8 2732 2733 2784 2783 3803 3804 3855 3854
8 2733 2734 2785 2784 3804 3805 3856 3855
8 2734 2735 2786 2785 3805 3806 3857 3856
8 2735 2736 2787 2786 3806 3807 3858 3857
8 2736 2737 2788 2787 3807 3808 3859 3858
8 2737 2738 2789 2788 3808 3809 3860 3859
8 2738 2739 2790 2789 3809 3810 3861 3860
8 2739 2740 2791 2790 3810 3811 3862 3861
8 2740 2741 2792 2791 3811 3812 3863 3862
8 2741 2742 2793 2792 3812 3813 3864 3863
8 2742 2743 2794 2793 3813 3814 3865 3864
8 2743 2744 2795 2794 3814 3815 3866 3865
8 2744 2745 2796 2795 3815 3816 3867 3866
8 2745 2746 2797 2796 3816 3817 3868 3867
8 2746 2747 2798 2797 3817 3818 3869 3868
8 2747 2748 2799 2798 3818 3819 3870 3869
8 2748 2749 2800 2799 3819 3820 3871 3870
8 2749 2750 2801 2800 3820 3821 3872 3871
8 2750 2751 2802 2801 3821 3822 3873 3872
8 2751 2752 2803 2802 3822 3823 3874 3873
8 2752 2753 2804 2803 3823 3824 3875 3874
8 2754 2755 2806 2805 3825 3826 3877 3876
8 2755 2756 2807 2806 3826 3827 3878 3877
8 2756 2757 2808 2807 3827 3828 3879 3878
8 2757 2758 2809 2808 3828 3829 3880 3879
8 2758 2759 2810 2809 3829 3830 3881 3880
8 2759 2760 2811 2810 3830 3831 3882 3881
8 2760 2761 2812 2811 3831 3832 3883 3882
8 2761 2762 2813 2812 3832 3833 3884 3883
8 2762 2763 2814 2813 3833 3834 3885 3884
8 2763 2764 2815 2814 3834 3835 3886 3885
8 2764 2765 2816 2815 3835 3836 3887 3886
8 2765 2766 2817 2816 3836 3837 3888 3887
8 2766 2767 2818 2817 3837 3838 3889 3888
8 2767 2768 2819 2818 3838 3839 3890 3889
8 2768 2769 2820 2819 3839 3840 3891 3890
8 2769 2770 2821 2820 3840 3841 3892 3891
8 2770 2771 2822 2821 3841 3842 3893 3892
8 2771 2772 2823 2822 3842 3843 3894 3893
8 2772 2773 2824 2823 3843 3844 3895 3894
8 2773 2774 2825 2824 3844 3845 3896 3895
8 2774 2775 2826 2825 3845 3846 3897 3896
8 2775 2776 2827 2826 3846 3847 3898 3897
8 2776 2777 2828 2827 3847 3848 3899 3898
8 2777 2778 2829 2828 3848 3849 3900 3899
8 2778 2779 2830 2829 3849 3850 3901 3900
8 2779 2780 2831 2830 3850 3851 3902 3901
8 2780 2781 2832 2831 3851 3852 3903 3902
8 2781 2782 2833 2832 3852 3853 3904 3903
8 2782 2783 2834 2833 3853 3854 3905 3904
8 2783 2784 2835 2834 3854 3855 3906 3905
8 2784 2785 2836 2835 3855 3856 3907 3906
8 2785 2786 2837 2836 3856 3857 3908 3907
8 2786 2787 2838 2837 3857 3858 3909 3908
8 2787 2788 2839 2838 3858 3859 3910 3909
8 2788 2789 2840 2839 3859 3860 3911 3910
8 2789 2790 2841 2840 3860 3861 3912 3911
8 2790 2791 2842 2841 3861 3862 3913 3912
8 2791 2792 2843 2842 3862 3863 3914 3913
8 2792 2793 2844 2843 3863 3864 3915 3914
8 2793 2794 2845 2844 3864 3865 3916 3915
8 2794 2795 2846 2845 3865 3866 3917 3916
8 2795 2796 2847 2846 3866 3867 3918 3917
8 2796 2797 2848 2847 3867 3868 3919 3918
8 2797 2798 2849 2848 3868 3869 3920 3919
8 2798 2799 2850 2849 3869 3870 3921 3920
8 2799 2800 2851 2850 3870 3871 3922 3921
8 2800 2801 2852 2851 3871 3872 3923 3922
8 2801 2802 2853 2852 3872 3873 3924 3923
8 2802 2803 2854 2853 3873 3874 3925 3924
8 2803 2804 2855 2854 3874 3875 3926 3925
8 2805 2806 2857 2856 3876 3877 3928 3927
8 2806 2807 2858 2857 3877 3878 3929 3928
8 2807 2808 2859 2858 3878 3879 3930 3929
8 2808 2809 2860 2859 3879 3880 3931 3930
8 2809 2810 2861 2860 3880 3881 3932 3931
8 2810 2811 2862 2861 3881 3882 3933 3932
8 2811 2812 2863 2862 3882 3883 3934 3933
8 2812 2813 2864 2863 3883 3884 3935 3934
8 2813 2814 2865 2864 3884 3885 3936 3935
8 2814 2815 2866 2865 3885 3886 3937 3936
8 2815 2816 2867 2866 3886 3887 3938 3937
8 2816 2817 2868 2867 3887 3888 3939 3938
8 2817 2818 2869 2868 3888 3889 3940 3939
8 2818 2819 2870 2869 3889 3890 3941 3940
8 2819 2820 2871 2870 3890 3891 3942 3941
8 2820 2821 2872 2871 3891 3892 3943 3942
8 2821 2822 2873 2872 3892 3893 3944 3943
8 2822 2823 2874 2873 3893 3894 3945 3944
8 2823 2824 2875 2874 3894 3895 3946 3945
8 2824 2825 2876 2875 3895 3896 3947 3946
8 2825 2826 2877 2876 3896 3897 3948 3947
8 2826 2827 2878 2877 3897 3898 3949 3948
8 2827 2828 2879 2878 3898 3899 3950 3949
8 2828 2829 2880 2879 3899 3900 3951 3950
8 2829 2830 2881 2880 3900 3901 3952 3951
8 2830 2831 2882 2881 3901 3902 3953 3952
8 2831 2832 2883 2882 3902 3903 3954 3953
8 2832 2833 2884 2883 3903 3904 3955 3954
8 2833 2834 2885 2884 3904 3905 3956 3955
8 2834 2835 2886 2885 3905 3906 3957 3956
8 2835 2836 2887 2886 3906 3907 3958 3957
8 2836 2837 2888 2887 3907 3908 3959 3958
8 2837 2838 2889 2888 3908 3909 3960 3959
8 2838 2839 2890 2889 3909 3910 3961 3960
8 2839 2840 2891 2890 3910 3911 3962 3961
8 2840 2841 2892 2891 3911 3912 3963 3962
8 2841 2842 2893 2892 3912 3913 3964 3963
8 2842 2843 2894 2893 3913 3914 3965 3964
8 2843 2844 2895 2894 3914 3915 3966 3965
8 2844 2845 2896 2895 3915 3916 3967 3966
8 2845 2846 2897 2896 3916 3917 3968 3967
8 2846 2847 2898 2897 3917 3918 3969 3968
8 2847 2848 2899 2898 3918 3919 3970 3969
8 2848 2849 2900 2899 3919 3920 3971 3970
8 2849 2850 2901 2900 3920 3921 3972 3971
8 2850 2851 2902 2901 3921 3922 3973 3972
8 2851 2852 2903 2902 3922 3923 3974 3973
8 2852 2853 2904 2903 3923 3924 3975 3974
8 2853 2854 2905 2904 3924 3925 3976 3975
8 2854 2855 2906 2905 3925 3926 3977 3976
8 2856 2857 2908 2907 3927 3928 3979 3978
8 2857 2858 2909 2908 3928 3929 3980 3979
8 2858 2859 2910 2909 3929 3930 3981 3980
8 2859 2860 2911 2910 3930 3931 3982 3981
8 2860 2861 2912 2911 3931 3932 3983 3982
8 2861 2862 2913 2912 3932 3933 3984 3983
8 2862 2863 2914 2913 3933 3934 3985 3984
8 2863 2864 2915 2914 3934 3935 3986 3985
8 2864 2865 2916 2915 3935 3936 3987 3986
8 2865 2866 2917 2916 3936 3937 3988 3987
8 2866 2867 2918 2917 3937 3938 3989 3988
8 2867 2868 2919 2918 3938 3939 3990 3989
8 2868 2869 2920 2919 3939 3940 3991 3990
8 2869 2870 2921 2920 3940 3941 3992 3991
8 2870 2871 2922 2921 3941 3942 3993 3992
8 2871 2872 2923 2922 3942 3943 3994 3993
8 2872 2873 2924 2923 3943 3944 3995 3994
8 2873 2874 2925 2924 3944 3945 3996 3995
8 2874 2875 2926 2925 3945 3946 3997 3996
8 2875 2876 2927 2926 3946 3947 3998 3997
8 2876 2877 2928 2927 3947 3948 3999 3998
8 2877 2878 2929 2928 3948 3949 4000 3999
8 2878 2879 2930 2929 3949 3950 4001 4000
8 2879 2880 2931 2930 3950 3951 4002 4001
8 2880 2881 2932 2931 3951 3952 4003 4002
8 2881 2882 2933 2932 3952 3953 4004 4003
8 2882 2883 2934 2933 3953 3954 4005 4004
8 2883 2884 2935 2934 3954 3955 4006 4005
8 2884 2885 2936 2935 3955 3956 4007 4006
8 2885 2886 2937 2936 3956 3957 4008 4007
8 2886 2887 2938 2937 3957 3958 4009 4008
8 2887 2888 2939 2938 3958 3959 4010 4009
8 2888 2889 2940 2939 3959 3960 4011 4010
8 2889 2890 2941 2940 3960 3961 4012 4011
8 2890 2891 2942 2941 3961 3962 4013 4012
8 2891 2892 2943 2942 3962 3963 4014 4013
8 2892 2893 2944 2943 3963 3964 4015 4014
8 2893 2894 2945 2944 3964 3965 4016 4015
8 2894 2895 2946 2945 3965 3966 4017 4016
8 2895 2896 2947 2946 3966 3967 4018 4017
8 2896 2897 2948 2947 3967 3968 4019 4018
8 2897 2898 2949 2948 3968 3969 4020 4019
8 2898 2899 2950 2949 3969 3970 4021 4020
8 2899 2900 2951 2950 3970 3971 4022 4021
8 2900 2901 2952 2951 3971 3972 4023 4022
8 2901 2902 2953 2952 3972 3973 4024 4023
8 2902 2903 2954 2953 3973 3974 4025 4024
8 2903 2904 2955 2954 3974 3975 4026 4025
8 2904 2905 2956 2955 3975 3976 4027 4026
8 2905 2906 2957 2956 3976 3977 4028 4027
8 2907 2908 2959 2958 3978 3979 4030 4029
8 2908 2909 2960 2959 3979 3980 4031 4030
8 2909 2910 2961 2960 3980 3981 4032 4031
8 2910 2911 2962 2961 3981 3982 4033 4032
8 2911 2912 2963 2962 3982 3983 4034 4033
8 2912 2913 2964 2963 3983 3984 4035 4034
8 2913 2914 2965 2964 3984 3985 4036 4035
8 2914 2915 2966 2965 3985 3986 4037 4036
8 2915 2916 2967 2966 3986 3987 4038 4037
8 2916 2917 2968 2967 3987 3988 4039 4038
8 2917 2918 2969 2968 3988 3989 4040 4039
8 2918 2919 2970 2969 3989 3990 4041 4040
8 2919 2920 2971 2970 3990 3991 4042 4041
8 2920 2921 2972 2971 3991 3992 4043 4042
8 2921 2922 2973 2972 3992 3993 4044 4043
8 2922 2923 2974 2973 3993 3994 4045 4044
8 2923 2924 2975 2974 3994 3995 4046 4045
8 2924 2925 2976 2975 3995 3996 4047 4046
8 2925 2926 2977 2976 3996 3997 4048 4047
8 2926 2927 2978 2977 3997 3998 4049 4048
8 2927 2928 2979 2978 3998 3999 4050 4049
8 2928 2929 2980 2979 3999 4000 4051 4050
8 2929 2930 2981 2980 4000 4001 4052 4051
8 2930 2931 2982 2981 4001 4002 4053 4052
8 2931 2932 2983 2982 4002 4003 4054 4053
8 2932 2933 2984 2983 4003 4004 4055 4054
8 2933 2934 2985 2984 4004 4005 4056 4055
8 2934 2935 2986 2985 4005 4006 4057 4056
8 2935 2936 2987 2986 4006 4007 4058 4057
8 2936 2937 2988 2987 4007 4008 4059 4058
8 2937 2938 2989 2988 4008 4009 4060 4059
8 2938 2939 2990 2989 4009 4010 4061 4060
8 2939 2940 2991 2990 4010 4011 4062 4061
8 2940 2941 2992 2991 4011 4012 4063 4062
8 2941 2942 2993 2992 4012 4013 4064 4063
8 2942 2943 2994 2993 4013 4014 4065 4064
8 2943 2944 2995 2994 4014 4015 4066 4065
8 2944 2945 2996 2995 4015 4016 4067 4066
8 2945 2946 2997 2996 4016 4017 4068 4067
8 2946 2947 2998 2997 4017 4018 4069 4068
8 2947 2948 2999 2998 4018 4019 4070 4069
8 2948 2949 3000 2999 4019 4020 4071 4070
8 2949 2950 3001 3000 4020 4021 4072 4071
8 2950 2951 3002 3001 4021 4022 4073 4072
8 2951 2952 3003 3002 4022 4023 4074 4073
8 2952 2953 3004 3003 4023 4024 4075 4074
8 2953 2954 3005 3004 4024 4025 4076 4075
8 2954 2955 3006 3005 4025 4026 4077 4076
8 2955 2956 3007 3006 4026 4027 4078 4077
8 2956 2957 3008 3007 4027 4028 4079 4078
8 2958 2959 3010 3009 4029 4030 4081 4080
8 2959 2960 3011 3010 4030 4031 4082 4081
8 2960 2961 3012 3011 4031 4032 4083 4082
8 2961 2962 3013 3012 4032 4033 4084 4083
8 2962 2963 3014 3013 4033 4034 4085 4084
8 2963 2964 3015 3014 4034 4035 4086 4085
8 2964 2965 3016 3015 4035 4036 4087 4086
8 2965 2966 3017 3016 4036 4037 4088 4087
8 2966 2967 3018 3017 4037 4038 4089 4088
8 2967 2968 3019 3018 4038 4039 4090 4089
8 2968 2969 3020 3019 4039 4040 4091 4090
8 2969 2970 3021 3020 4040 4041 4092 4091
8 2970 2971 3022 3021 4041 4042 4093 4092
8 2971 2972 3023 3022 4042 4043 4094 4093
8 2972 2973 3024 3023 4043 4044 4095 4094
8 2973 2974 3025 3024 4044 4045 4096 4095
8 2974 2975 3026 3025 4045 4046 4097 4096
8 2975 2976 3027 3026 4046 4047 4098 4097
8 2976 2977 3028 3027 4047 4048 4099 4098
8 2977 2978 3029 3028 4048 4049 4100 4099
8 2978 2979 3030 3029 4049 4050 4101 4100
8 2979 2980 3031 3030 4050 4051 4102 4101
8 2980 2981 3032 3031 4051 4052 4103 4102
8 2981 2982 3033 3032 4052 4053 4104 4103
8 2982 2983 3034 3033 4053 4054 4105 4104
8 2983 2984 3035 3034 4054 4055 4106 4105
8 2984 2985 3036 3035 4055 4056 4107 4106
8 2985 2986 3037 3036 4056 4057 4108 4107
8 2986 2987 3038 3037 4057 4058 4109 4108
8 2987 2988 3039 3038 4058 4059 4110 4109
8 2988 2989 3040 3039 4059 4060 4111 4110
8 2989 2990 3041 3040 4060 4061 4112 4111
8 2990 2991 3042 3041 4061 4062 4113 4112
8 2991 2992 3043 3042 4062 4063 4114 4113
8 2992 2993 3044 3043 4063 4064 4115 4114
8 2993 2994 3045 3044 4064 4065 4116 4115
8 2994 2995 3046 3045 4065 4066 4117 4116
8 2995 2996 3047 3046 4066 4067 4118 4117
8 2996 2997 3048 3047 4067 4068 4119 4118
8 2997 2998 3049 3048 4068 4069 4120 4119
8 2998 2999 3050 3049 4069 4070 4121 4120
8 2999 3000 3051 3050 4070 4071 4122 4121
8 3000 3001 3052 3051 4071 4072 4123 4122
8 3001 3002 3053 3052 4072 4073 4124 4123
8 3002 3003 3054 3053 4073 4074 4125 4124
8 3003 3004 3055 3054 4074 4075 4126 4125
8 3004 3005 3056 3055 4075 4076 4127 4126
8 3005 3006 3057 3056 4076 4077 4128 4127
8 3006 3007 3058 3057 4077 4078 4129 4128
8 3007 3008 3059 3058 4078 4079 4130 4129
8 3009 3010 3061 3060 4080 4081 4132 4131
8 3010 3011 3062 3061 4081 4082 4133 4132
8 3011 3012 3063 3062 4082 4083 4134 4133
8 3012 3013 3064 3063 4083 4084 4135 4134
8 3013 3014 3065 3064 4084 4085 4136 4135
8 3014 3015 3066 3065 4085 4086 4137 4136
8 3015 3016 3067 3066 4086 4087 4138 4137
8 3016 3017 3068 3067 4087 4088 4139 4138
8 3017 3018 3069 3068 4088 4089 4140 4139
8 3018 3019 3070 3069 4089 4090 4141 4140
8 3019 3020 3071 3070 4090 4091 4142 4141
8 3020 3021 3072 3071 4091 4092 4143 4142
8 3021 3022 3073 3072 4092 4093 4144 4143
8 3022 3023 3074 3073 4093 4094 4145 4144
8 3023 3024 3075 3074 4094 4095 4146 4145
8 3024 3025 3076 3075 4095 4096 4147 4146
8 3025 3026 3077 3076 4096 4097 4148 4147
8 3026 3027 3078 3077 4097 4098 4149 4148
8 3027 3028 3079 3078 4098 4099 4150 4149
8 3028 3029 3080 3079 4099 4100 4151 4150
8 3029 3030 3081 3080 4100 4101 4152 4151
8 3030 3031 3082 3081 4101 4102 4153 4152
8 3031 3032 3083 3082 4102 4103 4154 4153
8 3032 3033 3084 3083 4103 4104 4155 4154
8 3033 3034 3085 3084 4104 4105 4156 4155
8 3034 3035 3086 3085 4105 4106 4157 4156
8 3035 3036 3087 3086 4106 4107 4158 4157
8 3036 3037 3088 3087 4107 4108 4159 4158
8 3037 3038 3089 3088 4108 4109 4160 4159
8 3038 3039 3090 3089 4109 4110 4161 4160
8 3039 3040 3091 3090 4110 4111 4162 4161
8 3040 3041 3092 3091 4111 4112 4163 4162
8 3041 3042 3093 3092 4112 4113 4164 4163
8 3042 3043 3094 3093 4113 4114 4165 4164
8 3043 3044 3095 3094 4114 4115 4166 4165
8 3044 3045 3096 3095 4115 4116 4167 4166
8 3045 3046 3097 3096 4116 4117 4168 4167
8 3046 3047 3098 3097 4117 4118 4169 4168
8 3047 3048 3099 3098 4118 4119 4170 4169
8 3048 3049 3100 3099 4119 4120 4171 4170
8 3049 3050 3101 3100 4120 4121 4172 4171
8 3050 3051 3102 3101 4121 4122 4173 4172
8 3051 3052 3103 3102 4122 4123 4174 4173
8 3052 3053 3104 3103 4123 4124 4175 4174
8 3053 3054 3105 3104 4124 4125 4176 4175
8 3054 3055 3106 3105 4125 4126 4177 4176
8 3055 3056 3107 3106 4126 4127 4178 4177
8 3056 3057 3108 3107 4127 4128 4179 4178
8 3057 3058 3109 3108 4128 4129 4180 4179
8 3058 3059 3110 3109 4129 4130 4181 4180
8 3060 3061 3112 3111 4131 4132 4183 4182
8 3061 3062 3113 3112 4132 4133 4184 4183
8 3062 3063 3114 3113 4133 4134 4185 4184
8 3063 3064 3115 3114 4134 4135 4186 4185
8 3064 3065 3116 3115 4135 4136 4187 4186
8 3065 3066 3117 3116 4136 4137 4188 4187
8 3066 3067 3118 3117 4137 4138 4189 4188
8 3067 3068 3119 3118 4138 4139 4190 4189
8 3068 3069 3120 3119 4139 4140 4191 4190
8 3069 3070 3121 3120 4140 4141 4192 4191
8 3070 3071 3122 3121 4141 4142 4193 4192
8 3071 3072 3123 3122 4142 4143 4194 4193
8 3072 3073 3124 3123 4143 4144 4195 4194
8 3073 3074 3125 3124 4144 4145 4196 4195
8 3074 3075 3126 3125 4145 4146 4197 4196
8 3075 3076 3127 3126 4146 4147 4198 4197
8 3076 3077 3128 3127 4147 4148 4199 4198
8 3077 3078 3129 3128 4148 4149 4200 4199
8 3078 3079 3130 3129 4149 4150 4201 4200
8 3079 3080 3131 3130 4150 4151 4202 4201
8 3080 3081 3132 3131 4151 4152 4203 4202
8 3081 3082 3133 3132 4152 4153 4204 4203
8 3082 3083 3134 3133 4153 4154 4205 4204
8 3083 3084 3135 3134 4154 4155 4206 4205
8 3084 3085 3136 3135 4155 4156 4207 4206
8 3085 3086 3137 3136 4156 4157 4208 4207
8 3086 3087 3138 3137 4157 4158 4209 4208
8 3087 3088 3139 3138 4158 4159 4210 4209
8 3088 3089 3140 3139 4159 4160 4211 4210
8 3089 3090 3141 3140 4160 4161 4212 4211
8 3090 3091 3142 3141 4161 4162 4213 4212
8 3091 3092 3143 3142 4162 4163 4214 4213
8 3092 3093 3144 3143 4163 4164 4215 4214
8 3093 3094 3145 3144 4164 4165 4216 4215
8 3094 3095 3146 3145 4165 4166 4217 4216
8 3095 3096 3147 3146 4166 4167 4218 4217
8 3096 3097 3148 3147 4167 4168 4219 4218
8 3097 3098 3149 3148 4168 4169 4220 4219
8 3098 3099 3150 3149 4169 4170 4221 4220
8 3099 3100 3151 3150 4170 4171 4222 4221
8 3100 3101 3152 3151 4171 4172 4223 4222
8 3101 3102 3153 3152 4172 4173 4224 4223
8 3102 3103 3154 3153 4173 4174 4225 4224
8 3103 3104 3155 3154 4174 4175 4226 4225
8 3104 3105 3156 3155 4175 4176 4227 4226
8 3105 3106 3157 3156 4176 4177 4228 4227
8 3106 3107 3158 3157 4177 4178 4229 4228
8 3107 3108 3159 3158 4178 4179 4230 4229
8 3108 3109 3160 3159 4179 4180 4231 4230
8 3109 3110 3161 3160 4180 4181 4232 4231
8 3111 3112 3163 3162 4182 4183 4234 4233
8 3112 3113 3164 3163 4183 4184 4235 4234
8 3113 3114 3165 3164 4184 4185 4236 4235
8 3114 3115 3166 3165 4185 4186 4237 4236
8 3115 3116 3167 3166 4186 4187 4238 4237
8 3116 3117 3168 3167 4187 4188 4239 4238
8 3117 3118 3169 3168 4188 4189 4240 4239
8 3118 3119 3170 3169 4189 4190 4241 4240
8 3119 3120 3171 3170 4190 4191 4242 4241
8 3120 3121 3172 3171 4191 4192 4243 4242
8 3121 3122 3173 3172 4192 4193 4244 4243
8 3122 3123 3174 3173 4193 4194 4245 4244
8 3123 3124 3175 3174 4194 4195 4246 4245
8 3124 3125 3176 3175 4195 4196 4247 4246
8 3125 3126 3177 3176 4196 4197 4248 4247
8 3126 3127 3178 3177 4197 4198 4249 4248
8 3127 3128 3179 3178 4198 4199 4250 4249
8 3128 3129 3180 3179 4199 4200 4251 4250
8 3129 3130 3181 3180 4200 4201 4252 4251
8 3130 3131 3182 3181 4201 4202 4253 4252
8 3131 3132 3183 3182 4202 4203 4254 4253
8 3132 3133 3184 3183 4203 4204 4255 4254
8 3133 3134 3185 3184 4204 4205 4256 4255
8 3134 3135 3186 3185 4205 4206 4257 4256
8 3135 3136 3187 3186 4206 4207 4258 4257
8 3136 3137 3188 3187 4207 4208 4259 4258
8 3137 3138 3189 3188 4208 4209 4260 4259
8 3138 3139 3190 3189 4209 4210 4261 4260
8 3139 3140 3191 3190 4210 4211 4262 4261
8 3140 3141 3192 3191 4211 4212 4263 4262
8 3141 3142 3193 3192 4212 4213 4264 4263
8 3142 3143 3194 3193 4213 4214 4265 4264
8 3143 3144 3195 3194 4214 4215 4266 4265
8 3144 3145 3196 3195 4215 4216 4267 4266
8 3145 3146 3197 3196 4216 4217 4268 4267
8 3146 3147 3198 3197 4217 4218 4269 4268
8 3147 3148 3199 3198 4218 4219 4270 4269
8 3148 3149 3200 3199 4219 4220 4271 4270
8 3149 3150 3201 3200 4220 4221 4272 4271
8 3150 3151 3202 3201 4221 4222 4273 4272
8 3151 3152 3203 3202 4222 4223 4274 4273
8 3152 3153 3204 3203 4223 4224 4275 4274
8 3153 3154 3205 3204 4224 4225 4276 4275
8 3154 3155 3206 3205 4225 4226 4277 4276
8 3155 3156 3207 3206 4226 4227 4278 4277
8 3156 3157 3208 3207 4227 4228 4279 4278
8 3157 3158 3209 3208 4228 4229 4280 4279
8 3158 3159 3210 3209 4229 4230 4281 4280
8 3159 3160 3211 3210 4230 4231 4282 4281
8 3160 3161 3212 3211 4231 4232 4283 4282
8 3213 3214 3265 3264 4284 4285 4336 4335
8 3214 3215 3266 3265 4285 4286 4337 4336
8 3215 3216 3267 3266 4286 4287 4338 4337
8 3216 3217 3268 3267 4287 4288 4339 4338
8 3217 3218 3269 3268 4288 4289 4340 4339
8 3218 3219 3270 3269 4289 4290 4341 4340
8 3219 3220 3271 3270 4290 4291 4342 4341
8 3220 3221 3272 3271 4291 4292 4343 4342
8 3221 3222 3273 3272 4292 4293 4344 4343
8 3222 3223 3274 3273 4293 4294 4345 4344
8 3223 3224 3275 3274 4294 4295 4346 4345
8 3224 3225 3276 3275 4295 4296 4347 4346
8 3225 3226 3277 3276 4296 4297 4348 4347
8 3226 3227 3278 3277 4297 4298 4349 4348
8 3227 3228 3279 3278 4298 4299 4350 4349
8 3228 3229 3280 3279 4299 4300 4351 4350
8 3229 3230 3281 3280 4300 4301 4352 4351
8 3230 3231 3282 3281 4301 4302 4353 4352
8 3231 3232 3283 3282 4302 4303 4354 4353
8 3232 3233 3284 3283 4303 4304 4355 4354
8 3233 3234 3285 3284 4304 4305 4356 4355
8 3234 3235 3286 3285 4305 4306 4357 4356
8 3235 3236 3287 3286 4306 4307 4358 4357
8 3236 3237 3288 3287 4307 4308 4359 4358
8 3237 3238 3289 3288 4308 4309 4360 4359
8 3238 3239 3290 3289 4309 4310 4361 4360
8 3239 3240 3291 3290 4310 4311 4362 4361
8 3240 3241 3292 3291 4311 4312 4363 4362
8 3241 3242 3293 3292 4312 4313 4364 4363
8 3242 3243 3294 3293 4313 4314 4365 4364
8 3243 3244 3295 3294 4314 4315 4366 4365
8 3244 3245 3296 3295 4315 4316 4367 4366
8 3245 3246 3297 3296 4316 4317 4368 4367
8 3246 3247 3298 3297 4317 4318 4369 4368
8 3247 3248 3299 3298 4318 4319 4370 4369
8 3248 3249 3300 3299 4319 4320 4371 4370
8 3249 3250 3301 3300 4320 4321 4372 4371
8 3250 3251 3302 3301 4321 4322 4373 4372
8 3251 3252 3303 3302 4322 4323 4374 4373
8 3252 3253 3304 3303 4323 4324 4375 4374
8 3253 3254 3305 3304 4324 4325 4376 4375
8 3254 3255 3306 3305 4325 4326 4377 4376
8 3255 3256 3307 3306 4326 4327 4378 4377
8 3256 3257 3308 3307 4327 4328 4379 4378
8 3257 3258 3309 3308 4328 4329 4380 4379
8 3258 3259 3310 3309 4329 4330 4381 4380
8 3259 3260 3311 3310 4330 4331 4382 4381
8 3260 3261 3312 3311 4331 4332 4383 4382
8 3261 3262 3313 3312 4332 4333 4384 4383
8 3262 3263 3314 3313 4333 4334 4385 4384
8 3264 3265 3316 3315 4335 4336 4387 4386
8 3265 3266 3317 3316 4336 4337 4388 4387
8 3266 3267 3318 3317 4337 4338 4389 4388
8 3267 3268 3319 3318 4338 4339 4390 4389
8 3268 3269 3320 3319 4339 4340 4391 4390
8 3269 3270 3321 3320 4340 4341 4392 4391
8 3270 3271 3322 3321 4341 4342 4393 4392
8 3271 3272 3323 3322 4342 4343 4394 4393
8 3272 3273 3324 3323 4343 4344 4395 4394
8 3273 3274 3325 3324 4344 4345 4396 4395
8 3274 3275 3326 3325 4345 4346 4397 4396
8 3275 3276 3327 3326 4346 4347 4398 4397
8 3276 3277 3328 3327 4347 4348 4399 4398
8 3277 3278 3329 3328 4348 4349 4400 4399
8 3278 3279 3330 3329 4349 4350 4401 4400
8 3279 3280 3331 3330 4350 4351 4402 4401
8 3280 3281 3332 3331 4351 4352 4403 4402
8 3281 3282 3333 3332 4352 4353 4404 4403
8 3282 3283 3334 3333 4353 4354 4405 4404
8 3283 3284 3335 3334 4354 4355 4406 4405
8 3284 3285 3336 3335 4355 4356 4407 4406
8 3285 3286 3337 3336 4356 4357 4408 4407
8 3286 3287 3338 3337 4357 4358 4409 4408
8 3287 3288 3339 3338 4358 4359 4410 4409
8 3288 3289 3340 3339 4359 4360 4411 4410
8 3289 3290 3341 3340 4360 4361 4412 4411
8 3290 3291 3342 3341 4361 4362 4413 4412
8 3291 3292 3343 3342 4362 4363 4414 4413
8 3292 3293 3344 3343 4363 4364 4415 4414
8 3293 3294 3345 3344 4364 4365 4416 4415
8 3294 3295 3346 3345 4365 4366 4417 4416
8 3295 3296 3347 3346 4366 4367 4418 4417
8 3296 3297 3348 3347 4367 4368 4419 4418
8 3297 3298 3349 3348 4368 4369 4420 4419
8 3298 3299 3350 3349 4369 4370 4421 4420
8 3299 3300 3351 3350 4370 4371 4422 4421
8 3300 3301 3352 3351 4371 4372 4423 4422
8 3301 3302 3353 3352 4372 4373 4424 4423
8 3302 3303 3354 3353 4373 4374 4425 4424
8 3303 3304 3355 3354 4374 4375 4426 4425
8 3304 3305 3356 3355 4375 4376 4427 4426
8 3305 3306 3357 3356 4376 4377 4428 4427
8 3306 3307 3358 3357 4377 4378 4429 4428
8 3307 3308 3359 3358 4378 4379 4430 4429
8 3308 3309 3360 3359 4379 4380 4431 4430
8 3309 3310 3361 3360 4380 4381 4432 4431
8 3310 3311 3362 3361 4381 4382 4433 4432
8 3311 3312 3363 3362 4382 4383 4434 4433
8 3312 3313 3364 3363 4383 4384 4435 4434
8 3313 3314 3365 3364 4384 4385 4436 4435
8 3315 3316 3367 3366 4386 4387 4438 4437
8 3316 3317 3368 3367 4387 4388 4439 4438
8 3317 3318 3369 3368 4388 4389 4440 4439
8 3318 3319 3370 3369 4389 4390 4441 4440
8 3319 3320 3371 3370 4390 4391 4442 4441
8 3320 3321 3372 3371 4391 4392 4443 4442
8 3321 3322 3373 3372 4392 4393 4444 4443
8 3322 3323 3374 3373 4393 4394 4445 4444
8 3323 3324 3375 3374 4394 4395 4446 4445
8 3324 3325 3376 3375 4395 4396 4447 4446
8 3325 3326 3377 3376 4396 4397 4448 4447
8 3326 3327 3378 3377 4397 4398 4449 4448
8 3327 3328 3379 3378 4398 4399 4450 4449
8 3328 3329 3380 3379 4399 4400 4451 4450
8 3329 3330 3381 3380 4400 4401 4452 4451
8 3330 3331 3382 3381 4401 4402 4453 4452
8 3331 3332 3383 3382 4402 4403 4454 4453
8 3332 3333 3384 3383 4403 4404 4455 4454
8 3333 3334 3385 3384 4404 4405 4456 4455
8 3334 3335 3386 3385 4405 4406 4457 4456
8 3335 3336 3387 3386 4406 4407 4458 4457
8 3336 3337 3388 3387 4407 4408 4459 4458
8 3337 3338 3389 3388 4408 4409 4460 4459
8 3338 3339 3390 3389 4409 4410 4461 4460
8 3339 3340 3391 3390 4410 4411 4462 4461
8 3340 3341 3392 3391 4411 4412 4463 4462
8 3341 3342 3393 3392 4412 4413 4464 4463
8 3342 3343 3394 3393 4413 4414 4465 4464
8 3343 3344 3395 3394 4414 4415 4466 4465
8 3344 3345 3396 3395 4415 4416 4467 4466
8 3345 3346 3397 3396 4416 4417 4468 4467
8 3346 3347 3398 3397 4417 4418 4469 4468
8 3347 3348 3399 3398 4418 4419 4470 4469
8 3348 3349 3400 3399 4419 4420 4471 4470
8 3349 3350 3401 3400 4420 4421 4472 4471
8 3350 3351 3402 3401 4421 4422 4473 4472
8 3351 3352 3403 3402 4422 4423 4474 4473
8 3352 3353 3404 3403 4423 4424 4475 4474
8 3353 3354 3405 3404 4424 4425 4476 4475
8 3354 3355 3406 3405 4425 4426 4477 4476
8 3355 3356 3407 3406 4426 4427 4478 4477
8 3356 3357 3408 3407 4427 4428 4479 4478
8 3357 3358 3409 3408 4428 4429 4480 4479
8 3358 3359 3410 3409 4429 4430 4481 4480
8 3359 3360 3411 3410 4430 4431 4482 4481
8 3360 3361 3412 3411 4431 4432 4483 4482
8 3361 3362 3413 3412 4432 4433 4484 4483
8 3362 3363 3414 3413 4433 4434 4485 4484
8 3363 3364 3415 3414 4434 4435 4486 4485
8 3364 3365 3416 3415 4435 4436 4487 4486
8 3366 3367 3418 3417 4437 4438 4489 4488
8 3367 3368 3419 3418 4438 4439 4490 4489
8 3368 3369 3420 3419 4439 4440 4491 4490
8 3369 3370 3421 3420 4440 4441 4492 4491
8 3370 3371 3422 3421 4441 4442 4493 4492
8 3371 3372 3423 3422 4442 4443 4494 4493
8 3372 3373 3424 3423 4443 4444 4495 4494
8 3373 3374 3425 3424 4444 4445 4496 4495
8 3374 3375 3426 3425 4445 4446 4497 4496
8 3375 3376 3427 3426 4446 4447 4498 4497
8 3376 3377 3428 3427 4447 4448 4499 4498
8 3377 3378 3429 3428 4448 4449 4500 4499
8 3378 3379 3430 3429 4449 4450 4501 4500
8 3379 3380 3431 3430 4450 4451 4502 4501
8 3380 3381 3432 3431 4451 4452 4503 4502
8 3381 3382 3433 3432 4452 4453 4504 4503
8 3382 3383 3434 3433 4453 4454 4505 4504
8 3383 3384 3435 3434 4454 4455 4506 4505
8 3384 3385 3436 3435 4455 4456 4507 4506
8 3385 3386 3437 3436 4456 4457 4508 4507
8 3386 3387 3438 3437 4457 4458 4509 4508
8 3387 3388 3439 3438 4458 4459 4510 4509
8 3388 3389 3440 3439 4459 4460 4511 4510
8 3389 3390 3441 3440 4460 4461 4512 4511
8 3390 3391 3442 3441 4461 4462 4513 4512
8 3391 3392 3443 3442 4462 4463 4514 4513
8 3392 3393 3444 3443 4463 4464 4515 4514
8 3393 3394 3445 3444 4464 4465 4516 4515
8 3394 3395 3446 3445 4465 4466 4517 4516
8 3395 3396 3447 3446 4466 4467 4518 4517
8 3396 3397 3448 3447 4467 4468 4519 4518
8 3397 3398 3449 3448 4468 4469 4520 4519
8 3398 3399 3450 3449 4469 4470 4521 4520
8 3399 3400 3451 3450 4470 4471 4522 4521
8 3400 3401 3452 3451 4471 4472 4523 4522
8 3401 3402 3453 3452 4472 4473 4524 4523
8 3402 3403 3454 3453 4473 4474 4525 4524
8 3403 3404 3455 3454 4474 4475 4526 4525
8 3404 3405 3456 3455 4475 4476 4527 4526
8 3405 3406 3457 3456 4476 4477 4528 4527
8 3406 3407 3458 3457 4477 4478 4529 4528
8 3407 3408 3459 3458 4478 4479 4530 4529
8 3408 3409 3460 3459 4479 4480 4531 4530
8 3409 3410 3461 3460 4480 4481 4532 4531
8 3410 3411 3462 3461 4481 4482 4533 4532
8 3411 3412 3463 3462 4482 4483 4534 4533
8 3412 3413 3464 3463 4483 4484 4535 4534
8 3413 3414 3465 3464 4484 4485 4536 4535
8 3414 3415 3466 3465 4485 4486 4537 4536
8 3415 3416 3467 3466 4486 4487 4538 4537
8 3417 3418 3469 3468 4488 4489 4540 4539
8 3418 3419 3470 3469 4489 4490 4541 4540
8 3419 3420 3471 3470 4490 4491 4542 4541
8 3420 3421 3472 3471 4491 4492 4543 4542
8 3421 3422 3473 3472 4492 4493 4544 4543
8 3422 3423 3474 3473 4493 4494 4545 4544
8 3423 3424 3475 3474 4494 4495 4546 4545
8 3424 3425 3476 3475 4495 4496 4547 4546
8 3425 3426 3477 3476 4496 4497 4548 4547
8 3426 3427 3478 3477 4497 4498 4549 4548
8 3427 3428 3479 3478 4498 4499 4550 4549
8 3428 3429 3480 3479 4499 4500 4551 4550
8 3429 3430 3481 3480 4500 4501 4552 4551
8 3430 3431 3482 3481 4501 4502 4553 4552
8 3431 3432 3483 3482 4502 4503 4554 4553
8 3432 3433 3484 3483 4503 4504 4555 4554
8 3433 3434 3485 3484 4504 4505 4556 4555
8 3434 3435 3486 3485 4505 4506 4557 4556
8 3435 3436 3487 3486 4506 4507 4558 4557
8 3436 3437 3488 3487 4507 4508 4559 4558
8 3437 3438 3489 3488 4508 4509 4560 4559
8 3438 3439 3490 3489 4509 4510 4561 4560
8 3439 3440 3491 3490 4510 4511 4562 4561
8 3440 3441 3492 3491 4511 4512 4563 4562
8 3441 3442 3493 3492 4512 4513 4564 4563
8 3442 3443 3494 3493 4513 4514 4565 4564
8 3443 3444 3495 3494 4514 4515 4566 4565
8 3444 3445 3496 3495 4515 4516 4567 4566
8 3445 3446 3497 3496 4516 4517 4568 4567
8 3446 3447 3498 3497 4517 4518 4569 4568
8 3447 3448 3499 3498 4518 4519 4570 4569
8 3448 3449 3500 3499 4519 4520 4571 4570
8 3449 3450 3501 3500 4520 4521 4572 4571
8 3450 3451 3502 3501 4521 4522 4573 4572
8 3451 3452 3503 3502 4522 4523 4574 4573
8 3452 3453 3504 3503 4523 4524 4575 4574
8 3453 3454 3505 3504 4524 4525 4576 4575
8 3454 3455 3506 3505 4525 4526 4577 4576
8 3455 3456 3507 3506 4526 4527 4578 4577
8 3456 3457 3508 3507 4527 4528 4579 4578
8 3457 3458 3509 3508 4528 4529 4580 4579
8 3458 3459 3510 3509 4529 4530 4581 4580
8 3459 3460 3511 3510 4530 4531 4582 4581
8 3460 3461 3512 3511 4531 4532 4583 4582
8 3461 3462 3513 3512 4532 4533 4584 4583
8 3462 3463 3514 3513 4533 4534 4585 4584
8 3463 3464 3515 3514 4534 4535 4586 4585
8 3464 3465 3516 3515 4535 4536 4587 4586
8 3465 3466 3517 3516 4536 4537 4588 4587
8 3466 3467 3518 3517 4537 4538 4589 4588
8 3468 3469 3520 3519 4539 4540 4591 4590
8 3469 3470 3521 3520 4540 4541 4592 4591
8 3470 3471 3522 3521 4541 4542 4593 4592
8 3471 3472 3523 3522 4542 4543 4594 4593
8 3472 3473 3524 3523 4543 4544 4595 4594
8 3473 3474 3525 3524 4544 4545 4596 4595
8 3474 3475 3526 3525 4545 4546 4597 4596
8 3475 3476 3527 3526 4546 4547 4598 4597
8 3476 3477 3528 3527 4547 4548 4599 4598
8 3477 3478 3529 3528 4548 4549 4600 4599
8 3478 3479 3530 3529 4549 4550 4601 4600
8 3479 3480 3531 3530 4550 4551 4602 4601
8 3480 3481 3532 3531 4551 4552 4603 4602
8 3481 3482 3533 3532 4552 4553 4604 4603
8 3482 3483 3534 3533 4553 4554 4605 4604
8 3483 3484 3535 3534 4554 4555 4606 4605
8 3484 3485 3536 3535 4555 4556 4607 4606
8 3485 3486 3537 3536 4556 4557 4608 4607
8 3486 3487 3538 3537 4557 4558 4609 4608
8 3487 3488 3539 3538 4558 4559 4610 4609
8 3488 3489 3540 3539 4559 4560 4611 4610
8 3489 3490 3541 3540 4560 4561 4612 4611
8 3490 3491 3542 3541 4561 4562 4613 4612
8 3491 3492 3543 3542 4562 4563 4614 4613
8 3492 3493 3544 3543 4563 4564 4615 4614
8 3493 3494 3545 3544 4564 4565 4616 4615
8 3494 3495 3546 3545 4565 4566 4617 4616
8 3495 3496 3547 3546 4566 4567 4618 4617
8 3496 3497 3548 3547 4567 4568 4619 4618
8 3497 3498 3549 3548 4568 4569 4620 4619
8 3498 3499 3550 3549 4569 4570 4621 4620
8 3499 3500 3551 3550 4570 4571 4622 4621
8 3500 3501 3552 3551 4571 4572 4623 4622
8 3501 3502 3553 3552 4572 4573 4624 4623
8 3502 3503 3554 3553 4573 4574 4625 4624
8 3503 3504 3555 3554 4574 4575 4626 4625
8 3504 3505 3556 3555 4575 4576 4627 4626
8 3505 3506 3557 3556 4576 4577 4628 4627
8 3506 3507 3558 3557 4577 4578 4629 4628
8 3507 3508 3559 3558 4578 4579 4630 4629
8 3508 3509 3560 3559 4579 4580 4631 4630
8 3509 3510 3561 3560 4580 4581 4632 4631
8 3510 3511 3562 3561 4581 4582 4633 4632
8 3511 3512 3563 3562 4582 4583 4634 4633
8 3512 3513 3564 3563 4583 4584 4635 4634
8 3513 3514 3565 3564 4584 4585 4636 4635
8 3514 3515 3566 3565 4585 4586 4637 4636
8 3515 3516 3567 3566 4586 4587 4638 4637
8 3516 3517 3568 3567 4587 4588 4639 4638
8 3517 3518 3569 3568 4588 4589 4640 4639
8 3519 3520 3571 3570 4590 4591 4642 4641
8 3520 3521 3572 3571 4591 4592 4643 4642
8 3521 3522 3573 3572 4592 4593 4644 4643
8 3522 3523 3574 3573 4593 4594 4645 4644
8 3523 3524 3575 3574 4594 4595 4646 4645
8 3524 3525 3576 3575 4595 4596 4647 4646
8 3525 3526 3577 3576 4596 4597 4648 4647
8 3526 3527 3578 3577 4597 4598 4649 4648
8 3527 3528 3579 3578 4598 4599 4650 4649
8 3528 3529 3580 3579 4599 4600 4651 4650
8 3529 3530 3581 3580 4600 4601 4652 4651
8 3530 3531 3582 3581 4601 4602 4653 4652
8 3531 3532 3583 3582 4602 4603 4654 4653
8 3532 3533 3584 3583 4603 4604 4655 4654
8 3533 3534 3585 3584 4604 4605 4656 4655
8 3534 3535 3586 3585 4605 4606 4657 4656
8 3535 3536 3587 3586 4606 4607 4658 4657
8 3536 3537 3588 3587 4607 4608 4659 4658
8 3537 3538 3589 3588 4608 4609 4660 4659
8 3538 3539 3590 3589 4609 4610 4661 4660
8 3539 3540 3591 3590 4610 4611 4662 4661
8 3540 3541 3592 3591 4611 4612 4663 4662
8 3541 3542 3593 3592 4612 4613 4664 4663
8 3542 3543 3594 3593 4613 4614 4665 4664
8 3543 3544 3595 3594 4614 4615 4666 4665
8 3544 3545 3596 3595 4615 4616 4667 4666
8 3545 3546 3597 3596 4616 4617 4668 4667
8 3546 3547 3598 3597 4617 4618 4669 4668
8 3547 3548 3599 3598 4618 4619 4670 4669
8 3548 3549 3600 3599 4619 4620 4671 4670
8 3549 3550 3601 3600 4620 4621 4672 4671
8 3550 3551 3602 3601 4621 4622 4673 4672
8 3551 3552 3603 3602 4622 4623 4674 4673
8 3552 3553 3604 3603 4623 4624 4675 4674
8 3553 3554 3605 3604 4624 4625 4676 4675
8 3554 3555 3606 3605 4625 4626 4677 4676
8 3555 3556 3607 3606 4626 4627 4678 4677
8 3556 3557 3608 3607 4627 4628 4679 4678
8 3557 3558 3609 3608 4628 4629 4680 4679
8 3558 3559 3610 3609 4629 4630 4681 4680
8 3559 3560 3611 3610 4630 4631 4682 4681
8 3560 3561 3612 3611 4631 4632 4683 4682
8 3561 3562 3613 3612 4632 4633 4684 4683
8 3562 3563 3614 3613 4633 4634 4685 4684
8 3563 3564 3615 3614 4634 4635 4686 4685
8 3564 3565 3616 3615 4635 4636 4687 4686
8 3565 3566 3617 3616 4636 4637 4688 4687
8 3566 3567 3618 3617 4637 4638 4689 4688
8 3567 3568 3619 3618 4638 4639 4690 4689
8 3568 3569 3620 3619 4639 4640 4691 4690
8 3570 3571 3622 3621 4641 4642 4693 4692
8 3571 3572 3623 3622 4642 4643 4694 4693
8 3572 3573 3624 3623 4643 4644 4695 4694
8 3573 3574 3625 3624 4644 4645 4696 4695
8 3574 3575 3626 3625 4645 4646 4697 4696
8 3575 3576 3627 3626 4646 4647 4698 4697
8 3576 3577 3628 3627 4647 4648 4699 4698
8 3577 3578 3629 3628 4648 4649 4700 4699
8 3578 3579 3630 3629 4649 4650 4701 4700
8 3579 3580 3631 3630 4650 4651 4702 4701
8 3580 3581 3632 3631 4651 4652 4703 4702
8 3581 3582 3633 3632 4652 4653 4704 4703
8 3582 3583 3634 3633 4653 4654 4705 4704
8 3583 3584 3635 3634 4654 4655 4706 4705
8 3584 3585 3636 3635 4655 4656 4707 4706
8 3585 3586 3637 3636 4656 4657 4708 4707
8 3586 3587 3638 3637 4657 4658 4709 4708
8 3587 3588 3639 3638 4658 4659 4710 4709
8 3588 3589 3640 3639 4659 4660 4711 4710
8 3589 3590 3641 3640 4660 4661 4712 4711
8 3590 3591 3642 3641 4661 4662 4713 4712
8 3591 3592 3643 3642 4662 4663 4714 4713
8 3592 3593 3644 3643 4663 4664 4715 4714
8 3593 3594 3645 3644 4664 4665 4716 4715
8 3594 3595 3646 3645 4665 4666 4717 4716
8 3595 3596 3647 3646 4666 4667 4718 4717
8 3596 3597 3648 3647 4667 4668 4719 4718
8 3597 3598 3649 3648 4668 4669 4720 4719
8 3598 3599 3650 3649 4669 4670 4721 4720
8 3599 3600 3651 3650 4670 4671 4722 4721
8 3600 3601 3652 3651 4671 4672 4723 4722
8 3601 3602 3653 3652 4672 4673 4724 4723
8 3602 3603 3654 3653 4673 4674 4725 4724
8 3603 3604 3655 3654 4674 4675 4726 4725
8 3604 3605 3656 3655 4675 4676 4727 4726
8 3605 3606 3657 3656 4676 4677 4728 4727
8 3606 3607 3658 3657 4677 4678 4729 4728
8 3607 3608 3659 3658 4678 4679 4730 4729
8 3608 3609 3660 3659 4679 4680 4731 4730
8 3609 3610 3661 3660 4680 4681 4732 4731
8 3610 3611 3662 3661 4681 4682 4733 4732
8 3611 3612 3663 3662 4682 4683 4734 4733
8 3612 3613 3664 3663 4683 4684 4735 4734
8 3613 3614 3665 3664 4684 4685 4736 4735
8 3614 3615 3666 3665 4685 4686 4737 4736
8 3615 3616 3667 3666 4686 4687 4738 4737
8 3616 3617 3668 3667 4687 4688 4739 4738
8 3617 3618 3669 3668 4688 4689 4740 4739
8 3618 3619 3670 3669 4689 4690 4741 4740
8 3619 3620 3671 3670 4690 4691 4742 4741
8 3621 3622 3673 3672 4692 4693 4744 4743
8 3622 3623 3674 3673 4693 4694 4745 4744
8 3623 3624 3675 3674 4694 4695 4746 4745
8 3624 3625 3676 3675 4695 4696 4747 4746
8 3625 3626 3677 3676 4696 4697 4748 4747
8 3626 3627 3678 3677 4697 4698 4749 4748
8 3627 3628 3679 3678 4698 4699 4750 4749
8 3628 3629 3680 3679 4699 4700 4751 4750
8 3629 3630 3681 3680 4700 4701 4752 4751
8 3630 3631 3682 3681 4701 4702 4753 4752
8 3631 3632 3683 3682 4702 4703 4754 4753
8 3632 3633 3684 3683 4703 4704 4755 4754
8 3633 3634 3685 3684 4704 4705 4756 4755
8 3634 3635 3686 3685 4705 4706 4757 4756
8 3635 3636 3687 3686 4706 4707 4758 4757
8 3636 3637 3688 3687 4707 4708 4759 4758
8 3637 3638 3689 3688 4708 4709 4760 4759
8 3638 3639 3690 3689 4709 4710 4761 4760
8 3639 3640 3691 3690 4710 4711 4762 4761
8 3640 3641 3692 3691 4711 4712 4763 4762
8 3641 3642 3693 3692 4712 4713 4764 4763
8 3642 3643 3694 3693 4713 4714 4765 4764
8 3643 3644 3695 3694 4714 4715 4766 4765
8 3644 3645 3696 3695 4715 4716 4767 4766
8 3645 3646 3697 3696 4716 4717 4768 4767
8 3646 3647 3698 3697 4717 4718 4769 4768
8 3647 3648 3699 3698 4718 4719 4770 4769
8 3648 3649 3700 3699 4719 4720 4771 4770
8 3649 3650 3701 3700 4720 4721 4772 4771
8 3650 3651 3702 3701 4721 4722 4773 4772
8 3651 3652 3703 3702 4722 4723 4774 4773
8 3652 3653 3704 3703 4723 4724 4775 4774
8 3653 3654 3705 3704 4724 4725 4776 4775
8 3654 3655 3706 3705 4725 4726 4777 4776
8 3655 3656 3707 3706 4726 4727 4778 4777
8 3656 3657 3708 3707 4727 4728 4779 4778
8 3657 3658 3709 3708 4728 4729 4780 4779
8 3658 3659 3710 3709 4729 4730 4781 4780
8 3659 3660 3711 3710 4730 4731 4782 4781
8 3660 3661 3712 3711 4731 4732 4783 4782
8 3661 3662 3713 3712 4732 4733 4784 4783
8 3662 3663 3714 3713 4733 4734 4785 4784
8 3663 3664 3715 3714 4734 4735 4786 4785
8 3664 3665 3716 3715 4735 4736 4787 4786
8 3665 3666 3717 3716 4736 4737 4788 4787
8 3666 3667 3718 3717 4737 4738 4789 4788
8 3667 3668 3719 3718 4738 4739 4790 4789
8 3668 3669 3720 3719 4739 4740 4791 4790
8 3669 3670 3721 3720 4740 4741 4792 4791
8 3670 3671 3722 3721 4741 4742 4793 4792
8 3672 3673 3724 3723 4743 4744 4795 4794
8 3673 3674 3725 3724 4744 4745 4796 4795
8 3674 3675 3726 3725 4745 4746 4797 4796
8 3675 3676 3727 3726 4746 4747 4798 4797
8 3676 3677 3728 3727 4747 4748 4799 4798
8 3677 3678 3729 3728 4748 4749 4800 4799
8 3678 3679 3730 3729 4749 4750 4801 4800
8 3679 3680 3731 3730 4750 4751 4802 4801
8 3680 3681 3732 3731 4751 4752 4803 4802
8 3681 3682 3733 3732 4752 4753 4804 4803
8 3682 3683 3734 3733 4753 4754 4805 4804
8 3683 3684 3735 3734 4754 4755 4806 4805
8 3684 3685 3736 3735 4755 4756 4807 4806
8 3685 3686 3737 3736 4756 4757 4808 4807
8 3686 3687 3738 3737 4757 4758 4809 4808
8 3687 3688 3739 3738 4758 4759 4810 4809
8 3688 3689 3740 3739 4759 4760 4811 4810
8 3689 3690 3741 3740 4760 4761 4812 4811
8 3690 3691 3742 3741 4761 4762 4813 4812
8 3691 3692 3743 3742 4762 4763 4814 4813
8 3692 3693 3744 3743 4763 4764 4815 4814
8 3693 3694 3745 3744 4764 4765 4816 4815
8 3694 3695 3746 3745 4765 4766 4817 4816
8 3695 3696 3747 3746 4766 4767 4818 4817
8 3696 3697 3748 3747 4767 4768 4819 4818
8 3697 3698 3749 3748 4768 4769 4820 4819
8 3698 3699 3750 3749 4769 4770 4821 4820
8 3699 3700 3751 3750 4770 4771 4822 4821
8 3700 3701 3752 3751 4771 4772 4823 4822
8 3701 3702 3753 3752 4772 4773 4824 4823
8 3702 3703 3754 3753 4773 4774 4825 4824
8 3703 3704 3755 3754 4774 4775 4826 4825
8 3704 3705 3756 3755 4775 4776 4827 4826
8 3705 3706 3757 3756 4776 4777 4828 4827
8 3706 3707 3758 3757 4777 4778 4829 4828
8 3707 3708 3759 3758 4778 4779 4830 4829
8 3708 3709 3760 3759 4779 4780 4831 4830
8 3709 3710 3761 3760 4780 4781 4832 4831
8 3710 3711 3762 3761 4781 4782 4833 4832
8 3711 3712 3763 3762 4782 4783 4834 4833
8 3712 3713 3764 3763 4783 4784 4835 4834
8 3713 3714 3765 3764 4784 4785 4836 4835
8 3714 3715 3766 3765 4785 4786 4837 4836
8 3715 3716 3767 3766 4786 4787 4838 4837
8 3716 3717 3768 3767 4787 4788 4839 4838
8 3717 3718 3769 3768 4788 4789 4840 4839
8 3718 3719 3770 3769 4789 4790 4841 4840
8 3719 3720 3771 3770 4790 4791 4842 4841
8 3720 3721 3772 3771 4791 4792 4843 4842
8 3721 3722 3773 3772 4792 4793 4844 4843
8 3723 3724 3775 3774 4794 4795 4846 4845
8 3724 3725 3776 3775 4795 4796 4847 4846
8 3725 3726 3777 3776 4796 4797 4848 4847
8 3726 3727 3778 3777 4797 4798 4849 4848
8 3727 3728 3779 3778 4798 4799 4850 4849
8 3728 3729 3780 3779 4799 4800 4851 4850
8 3729 3730 3781 3780 4800 4801 4852 4851
8 3730 3731 3782 3781 4801 4802 4853 4852
8 3731 3732 3783 3782 4802 4803 4854 4853
8 3732 3733 3784 3783 4803 4804 4855 4854
8 3733 3734 3785 3784 4804 4805 4856 4855
8 3734 3735 3786 3785 4805 4806 4857 4856
8 3735 3736 3787 3786 4806 4807 4858 4857
8 3736 3737 3788 3787 4807 4808 4859 4858
8 3737 3738 3789 3788 4808 4809 4860 4859
8 3738 3739 3790 3789 4809 4810 4861 4860
8 3739 3740 3791 3790 4810 4811 4862 4861
8 3740 3741 3792 3791 4811 4812 4863 4862
8 3741 3742 3793 3792 4812 4813 4864 4863
8 3742 3743 3794 3793 4813 4814 4865 4864
8 3743 3744 3795 3794 4814 4815 4866 4865
8 3744 3745 3796 3795 4815 4816 4867 4866
8 3745 3746 3797 3796 4816 4817 4868 4867
8 3746 3747 3798 3797 4817 4818 4869 4868
8 3747 3748 3799 3798 4818 4819 4870 4869
8 3748 3749 3800 3799 4819 4820 4871 4870
8 3749 3750 3801 3800 4820 4821 4872 4871
8 3750 3751 3802 3801 4821 4822 4873 4872
8 3751 3752 3803 3802 4822 4823 4874 4873
8 3752 3753 3804 3803 4823 4824 4875 4874
8 3753 3754 3805 3804 4824 4825 4876 4875
8 3754 3755 3806 3805 4825 4826 4877 4876
8 3755 3756 3807 3806 4826 4827 4878 4877
8 3756 3757 3808 3807 4827 4828 4879 4878
8 3757 3758 3809 3808 4828 4829 4880 4879
8 3758 3759 3810 3809 4829 4830 4881 4880
8 3759 3760 3811 3810 4830 4831 4882 4881
8 3760 3761 3812 3811 4831 4832 4883 4882
8 3761 3762 3813 3812 4832 4833 4884 4883
8 3762 3763 3814 3813 4833 4834 4885 4884
8 3763 3764 3815 3814 4834 4835 4886 4885
8 3764 3765 3816 3815 4835 4836 4887 4886
8 3765 3766 3817 3816 4836 4837 4888 4887
8 3766 3767 3818 3817 4837 4838 4889 4888
8 3767 3768 3819 3818 4838 4839 4890 4889
8 3768 3769 3820 3819 4839 4840 4891 4890
8 3769 3770 3821 3820 4840 4841 4892 4891
8 3770 3771 3822 3821 4841 4842 4893 4892
8 3771 3772 3823 3822 4842 4843 4894 4893
8 3772 3773 3824 3823 4843 4844 4895 4894
8 3774 3775 3826 3825 4845 4846 4897 4896
8 3775 3776 3827 3826 4846 4847 4898 4897
8 3776 3777 3828 3827 4847 4848 4899 4898
8 3777 3778 3829 3828 4848 4849 4900 4899
8 3778 3779 3830 3829 4849 4850 4901 4900
8 3779 3780 3831 3830 4850 4851 4902 4901
8 3780 3781 3832 3831 4851 4852 4903 4902
8 3781 3782 3833 3832 4852 4853 4904 4903
8 3782 3783 3834 3833 4853 4854 4905 4904
8 3783 3784 3835 3834 4854 4855 4906 4905
8 3784 3785 3836 3835 4855 4856 4907 4906
8 3785 3786 3837 3836 4856 4857 4908 4907
8 3786 3787 3838 3837 4857 4858 4909 4908
8 3787 3788 3839 3838 4858 4859 4910 4909
8 3788 3789 3840 3839 4859 4860 4911 4910
8 3789 3790 3841 3840 4860 4861 4912 4911
8 3790 3791 3842 3841 4861 4862 4913 4912
8 3791 3792 3843 3842 4862 4863 4914 4913
8 3792 3793 3844 3843 4863 4864 4915 4914
8 3793 3794 3845 3844 4864 4865 4916 4915
8 3794 3795 3846 3845 4865 4866 4917 4916
8 3795 3796 3847 3846 4866 4867 4918 4917
8 3796 3797 3848 3847 4867 4868 4919 4918
8 3797 3798 3849 3848 4868 4869 4920 4919
8 3798 3799 3850 3849 4869 4870 4921 4920
8 3799 3800 3851 3850 4870 4871 4922 4921
8 3800 3801 3852 3851 4871 4872 4923 4922
8 3801 3802 3853 3852 4872 4873 4924 4923
8 3802 3803 3854 3853 4873 4874 4925 4924
8 3803 3804 3855 3854 4874 4875 4926 4925
8 3804 3805 3856 3855 4875 4876 4927 4926
8 3805 3806 3857 3856 4876 4877 4928 4927
8 3806 3807 3858 3857 4877 4878 4929 4928
8 3807 3808 3859 3858 4878 4879 4930 4929
8 3808 3809 3860 3859 4879 4880 4931 4930
8 3809 3810 3861 3860 4880 4881 4932 4931
8 3810 3811 3862 3861 4881 4882 4933 4932
8 3811 3812 3863 3862 4882 4883 4934 4933
8 3812 3813 3864 3863 4883 4884 4935 4934
8 3813 3814 3865 3864 4884 4885 4936 4935
8 3814 3815 3866 3865 4885 4886 4937 4936
8 3815 3816 3867 3866 4886 4887 4938 4937
8 3816 3817 3868 3867 4887 4888 4939 4938
8 3817 3818 3869 3868 4888 4889 4940 4939
8 3818 3819 3870 3869 4889 4890 4941 4940
8 3819 3820 3871 3870 4890 4891 4942 4941
8 3820 3821 3872 3871 4891 4892 4943 4942
8 3821 3822 3873 3872 4892 4893 4944 4943
8 3822 3823 3874 3873 4893 4894 4945 4944
8 3823 3824 3875 3874 4894 4895 4946 4945
8 3825 3826 3877 3876 4896 4897 4948 4947
8 3826 3827 3878 3877 4897 4898 4949 4948
8 3827 3828 3879 3878 4898 4899 4950 4949
8 3828 3829 3880 3879 4899 4900 4951 4950
8 3829 3830 3881 3880 4900 4901 4952 4951
8 3830 3831 3882 3881 4901 4902 4953 4952
8 3831 3832 3883 3882 4902 4903 4954 4953
8 3832 3833 3884 3883 4903 4904 4955 4954
8 3833 3834 3885 3884 4904 4905 4956 4955
8 3834 3835 3886 3885 4905 4906 4957 4956
8 3835 3836 3887 3886 4906 4907 4958 4957
8 3836 3837 3888 3887 4907 4908 4959 4958
8 3837 3838 3889 3888 4908 4909 4960 4959
8 3838 3839 3890 3889 4909 4910 4961 4960
8 3839 3840 3891 3890 4910 4911 4962 4961
8 3840 3841 3892 3891 4911 4912 4963 4962
8 3841 3842 3893 3892 4912 4913 4964 4963
8 3842 3843 3894 3893 4913 4914 4965 4964
8 3843 3844 3895 3894 4914 4915 4966 4965
8 3844 3845 3896 3895 4915 4916 4967 4966
8 3845 3846 3897 3896 4916 4917 4968 4967
8 3846 3847 3898 3897 4917 4918 4969 4968
8 3847 3848 3899 3898 4918 4919 4970 4969
8 3848 3849 3900 3899 4919 4920 4971 4970
8 3849 3850 3901 3900 4920 4921 4972 4971
8 3850 3851 3902 3901 4921 4922 4973 4972
8 3851 3852 3903 3902 4922 4923 4974 4973
8 3852 3853 3904 3903 4923 4924 4975 4974
8 3853 3854 3905 3904 4924 4925 4976 4975
8 3854 3855 3906 3905 4925 4926 4977 4976
8 3855 3856 3907 3906 4926 4927 4978 4977
8 3856 3857 3908 3907 4927 4928 4979 4978
8 3857 3858 3909 3908 4928 4929 4980 4979
8 3858 3859 3910 3909 4929 4930 4981 4980
8 3859 3860 3911 3910 4930 4931 4982 4981
8 3860 3861 3912 3911 4931 4932 4983 4982
8 3861 3862 3913 3912 4932 4933 4984 4983
8 3862 3863 3914 3913 4933 4934 4985 4984
8 3863 3864 3915 3914 4934 4935 4986 4985
8 3864 3865 3916 3915 4935 4936 4987 4986
8 3865 3866 3917 3916 4936 4937 4988 4987
8 3866 3867 3918 3917 4937 4938 4989 4988
8 3867 3868 3919 3918 4938 4939 4990 4989
8 3868 3869 3920 3919 4939 4940 4991 4990
8 3869 3870 3921 3920 4940 4941 4992 4991
8 3870 3871 3922 3921 4941 4942 4993 4992
8 3871 3872 3923 3922 4942 4943 4994 4993
8 3872 3873 3924 3923 4943 4944 4995 4994
8 3873 3874 3925 3924 4944 4945 4996 4995
8 3874 3875 3926 3925 4945 4946 4997 4996
8 3876 3877 3928 3927 4947 4948 4999 4998
8 3877 3878 3929 3928 4948 4949 5000 4999
8 3878 3879 3930 3929 4949 4950 5001 5000
8 3879 3880 3931 3930 4950 4951 5002 5001
8 3880 3881 3932 3931 4951 4952 5003 5002
8 3881 3882 3933 3932 4952 4953 5004 5003
8 3882 3883 3934 3933 4953 4954 5005 5004
8 3883 3884 3935 3934 4954 4955 5006 5005
8 3884 3885 3936 3935 4955 4956 5007 5006
8 3885 3886 3937 3936 4956 4957 5008 5007
8 3886 3887 3938 3937 4957 4958 5009 5008
8 3887 3888 3939 3938 4958 4959 5010 5009
8 3888 3889 3940 3939 4959 4960 5011 5010
8 3889 3890 3941 3940 4960 4961 5012 5011
8 3890 3891 3942 3941 4961 4962 5013 5012
8 3891 3892 3943 3942 4962 4963 5014 5013
8 3892 3893 3944 3943 4963 4964 5015 5014
8 3893 3894 3945 3944 4964 4965 5016 5015
8 3894 3895 3946 3945 4965 4966 5017 5016
8 3895 3896 3947 3946 4966 4967 5018 5017
8 3896 3897 3948 3947 4967 4968 5019 5018
8 3897 3898 3949 3948 4968 4969 5020 5019
8 3898 3899 3950 3949 4969 4970 5021 5020
8 3899 3900 3951 3950 4970 4971 5022 5021
8 3900 3901 3952 3951 4971 4972 5023 5022
8 3901 3902 3953 3952 4972 4973 5024 5023
8 3902 3903 3954 3953 4973 4974 5025 5024
8 3903 3904 3955 3954 4974 4975 5026 5025
8 3904 3905 3956 3955 4975 4976 5027 5026
8 3905 3906 3957 3956 4976 4977 5028 5027
8 3906 3907 3958 3957 4977 4978 5029 5028
8 3907 3908 3959 3958 4978 4979 5030 5029
8 3908 3909 3960 3959 4979 4980 5031 5030
8 3909 3910 3961 3960 4980 4981 5032 5031
8 3910 3911 3962 3961 4981 4982 5033 5032
8 3911 3912 3963 3962 4982 4983 5034 5033
8 3912 3913 3964 3963 4983 4984 5035 5034
8 3913 3914 3965 3964 4984 4985 5036 5035
8 3914 3915 3966 3965 4985 4986 5037 5036
8 3915 3916 3967 3966 4986 4987 5038 5037
8 3916 3917 3968 3967 4987 4988 5039 5038
8 3917 3918 3969 3968 4988 4989 5040 5039
8 3918 3919 3970 3969 4989 4990 5041 5040
8 3919 3920 3971 3970 4990 4991 5042 5041
8 3920 3921 3972 3971 4991 4992 5043 5042
8 3921 3922 3973 3972 4992 4993 5044 5043
8 3922 3923 3974 3973 4993 4994 5045 5044
8 3923 3924 3975 3974 4994 4995 5046 5045
8 3924 3925 3976 3975 4995 4996 5047 5046
8 3925 3926 3977 3976 4996 4997 5048 5047
8 3927 3928 3979 3978 4998 4999 5050 5049
8 3928 3929 3980 3979 4999 5000 5051 5050
8 3929 3930 3981 3980 5000 5001 5052 5051
8 3930 3931 3982 3981 5001 5002 5053 5052
8 3931 3932 3983 3982 5002 5003 5054 5053
8 3932 3933 3984 3983 5003 5004 5055 5054
8 3933 3934 3985 3984 5004 5005 5056 5055
8 3934 3935 3986 3985 5005 5006 5057 5056
8 3935 3936 3987 3986 5006 5007 5058 5057
8 3936 3937 3988 3987 5007 5008 5059 5058
8 3937 3938 3989 3988 5008 5009 5060 5059
8 3938 3939 3990 3989 5009 5010 5061 5060
8 3939 3940 3991 3990 5010 5011 5062 5061
8 3940 3941 3992 3991 5011 5012 5063 5062
8 3941 3942 3993 3992 5012 5013 5064 5063
8 3942 3943 3994 3993 5013 5014 5065 5064
8 3943 3944 3995 3994 5014 5015 5066 5065
8 3944 3945 3996 3995 5015 5016 5067 5066
8 3945 3946 3997 3996 5016 5017 5068 5067
8 3946 3947 3998 3997 5017 5018 5069 5068
8 3947 3948 3999 3998 5018 5019 5070 5069
8 3948 3949 4000 3999 5019 5020 5071 5070
8 3949 3950 4001 4000 5020 5021 5072 5071
8 3950 3951 4002 4001 5021 5022 5073 5072
8 3951 3952 4003 4002 5022 5023 5074 5073
8 3952 3953 4004 4003 5023 5024 5075 5074
8 3953 3954 4005 4004 5024 5025 5076 5075
8 3954 3955 4006 4005 5025 5026 5077 5076
8 3955 3956 4007 4006 5026 5027 5078 5077
8 3956 3957 4008 4007 5027 5028 5079 5078
8 3957 3958 4009 4008 5028 5029 5080 5079
8 3958 3959 4010 4009 5029 5030 5081 5080
8 3959 3960 4011 4010 5030 5031 5082 5081
8 3960 3961 4012 4011 5031 5032 5083 5082
8 3961 3962 4013 4012 5032 5033 5084 5083
8 3962 3963 4014 4013 5033 5034 5085 5084
8 3963 3964 4015 4014 5034 5035 5086 5085
8 3964 3965 4016 4015 5035 5036 5087 5086
8 3965 3966 4017 4016 5036 5037 5088 5087
8 3966 3967 4018 4017 5037 5038 5089 5088
8 3967 3968 4019 4018 5038 5039 5090 5089
8 3968 3969 4020 4019 5039 5040 5091 5090
8 3969 3970 4021 4020 5040 5041 5092 5091
8 3970 3971 4022 4021 5041 5042 5093 5092
8 3971 3972 4023 4022 5042 5043 5094 5093
8 3972 3973 4024 4023 5043 5044 5095 5094
8 3973 3974 4025 4024 5044 5045 5096 5095
8 3974 3975 4026 4025 5045 5046 5097 5096
8 3975 3976 4027 4026 5046 5047 5098 5097
8 3976 3977 4028 4027 5047 5048 5099 5098
8 3978 3979 4030 4029 5049 5050 5101 5100
8 3979 3980 4031 4030 5050 5051 5102 5101
8 3980 3981 4032 4031 5051 5052 5103 5102
8 3981 3982 4033 4032 5052 5053 5104 5103
8 3982 3983 4034 4033 5053 5054 5105 5104
8 3983 3984 4035 4034 5054 5055 5106 5105
8 3984 3985 4036 4035 5055 5056 5107 5106
8 3985 3986 4037 4036 5056 5057 5108 5107
8 3986 3987 4038 4037 5057 5058 5109 5108
8 3987 3988 4039 4038 5058 5059 5110 5109
8 3988 3989 4040 4039 5059 5060 5111 5110
8 3989 3990 4041 4040 5060 5061 5112 5111
8 3990 3991 4042 4041 5061 5062 5113 5112
8 3991 3992 4043 4042 5062 5063 5114 5113
8 3992 3993 4044 4043 5063 5064 5115 5114
8 3993 3994 4045 4044 5064 5065 5116 5115
8 3994 3995 4046 4045 5065 5066 5117 5116
8 3995 3996 4047 4046 5066 5067 5118 5117
8 3996 3997 4048 4047 5067 5068 5119 5118
8 3997 3998 4049 4048 5068 5069 5120 5119
8 3998 3999 4050 4049 5069 5070 5121 5120
8 3999 4000 4051 4050 5070 5071 5122 5121
8 4000 4001 4052 4051 5071 5072 5123 5122
8 4001 4002 4053 4052 5072 5073 5124 5123
8 4002 4003 4054 4053 5073 5074 5125 5124
8 4003 4004 4055 4054 5074 5075 5126 5125
8 4004 4005 4056 4055 5075 5076 5127 5126
8 4005 4006 4057 4056 5076 5077 5128 5127
8 4006 4007 4058 4057 5077 5078 5129 5128
8 4007 4008 4059 4058 5078 5079 5130 5129
8 4008 4009 4060 4059 5079 5080 5131 5130
8 4009 4010 4061 4060 5080 5081 5132 5131
8 4010 4011 4062 4061 5081 5082 5133 5132
8 4011 4012 4063 4062 5082 5083 5134 5133
8 4012 4013 4064 4063 5083 5084 5135 5134
8 4013 4014 4065 4064 5084 5085 5136 5135
8 4014 4015 4066 4065 5085 5086 5137 5136
8 4015 4016 4067 4066 5086 5087 5138 5137
8 4016 4017 4068 4067 5087 5088 5139 5138
8 4017 4018 4069 4068 5088 5089 5140 5139
8 4018 4019 4070 4069 5089 5090 5141 5140
8 4019 4020 4071 4070 5090 5091 5142 5141
8 4020 4021 4072 4071 5091 5092 5143 5142
8 4021 4022 4073 4072 5092 5093 5144 5143
8 4022 4023 4074 4073 5093 5094 5145 5144
8 4023 4024 4075 4074 5094 5095 5146 5145
8 4024 4025 4076 4075 5095 5096 5147 5146
8 4025 4026 4077 4076 5096 5097 5148 5147
8 4026 4027 4078 4077 5097 5098 5149 5148
8 4027 4028 4079 4078 5098 5099 5150 5149
8 4029 4030 4081 4080 5100 5101 5152 5151
8 4030 4031 4082 4081 5101 5102 5153 5152
8 4031 4032 4083 4082 5102 5103 5154 5153
8 4032 4033 4084 4083 5103 5104 5155 5154
8 4033 4034 4085 4084 5104 5105 5156 5155
8 4034 4035 4086 4085 5105 5106 5157 5156
8 4035 4036 4087 4086 5106 5107 5158 5157
8 4036 4037 4088 4087 5107 5108 5159 5158
8 4037 4038 4089 4088 5108 5109 5160 5159
8 4038 4039 4090 4089 5109 5110 5161 5160
8 4039 4040 4091 4090 5110 5111 5162 5161
8 4040 4041 4092 4091 5111 5112 5163 5162
8 4041 4042 4093 4092 5112 5113 5164 5163
8 4042 4043 4094 4093 5113 5114 5165 5164
8 4043 4044 4095 4094 5114 5115 5166 5165
8 4044 4045 4096 4095 5115 5116 5167 5166
8 4045 4046 4097 4096 5116 5117 5168 5167
8 4046 4047 4098 4097 5117 5118 5169 5168
8 4047 4048 4099 4098 5118 5119 5170 5169
8 4048 4049 4100 4099 5119 5120 5171 5170
8 4049 4050 4101 4100 5120 5121 5172 5171
8 4050 4051 4102 4101 5121 5122 5173 5172
8 4051 4052 4103 4102 5122 5123 5174 5173
8 4052 4053 4104 4103 5123 5124 5175 5174
8 4053 4054 4105 4104 5124 5125 5176 5175
8 4054 4055 4106 4105 5125 5126 5177 5176
8 4055 4056 4107 4106 5126 5127 5178 5177
8 4056 4057 4108 4107 5127 5128 5179 5178
8 4057 4058 4109 4108 5128 5129 5180 5179
8 4058 4059 4110 4109 5129 5130 5181 5180
8 4059 4060 4111 4110 5130 5131 5182 5181
8 4060 4061 4112 4111 5131 5132 5183 5182
8 4061 4062 4113 4112 5132 5133 5184 5183
8 4062 4063 4114 4113 5133 5134 5185 5184
8 4063 4064 4115 4114 5134 5135 5186 5185
8 4064 4065 4116 4115 5135 5136 5187 5186
8 4065 4066 4117 4116 5136 5137 5188 5187
8 4066 4067 4118 4117 5137 5138 5189 5188
8 4067 4068 4119 4118 5138 5139 5190 5189
8 4068 4069 4120 4119 5139 5140 5191 5190
8 4069 4070 4121 4120 5140 5141 5192 5191
8 4070 4071 4122 4121 5141 5142 5193 5192
8 4071 4072 4123 4122 5142 5143 5194 5193
8 4072 4073 4124 4123 5143 5144 5195 5194
8 4073 4074 4125 4124 5144 5145 5196 5195
8 4074 4075 4126 4125 5145 5146 5197 5196
8 4075 4076 4127 4126 5146 5147 5198 5197
8 4076 4077 4128 4127 5147 5148 5199 5198
8 4077 4078 4129 4128 5148 5149 5200 5199
8 4078 4079 4130 4129 5149 5150 5201 5200
8 4080 4081 4132 4131 5151 5152 5203 5202
8 4081 4082 4133 4132 5152 5153 5204 5203
8 4082 4083 4134 4133 5153 5154 5205 5204
8 4083 4084 4135 4134 5154 5155 5206 5205
8 4084 4085 4136 4135 5155 5156 5207 5206
8 4085 4086 4137 4136 5156 5157 5208 5207
8 4086 4087 4138 4137 5157 5158 5209 5208
8 4087 4088 4139 4138 5158 5159 5210 5209
8 4088 4089 4140 4139 5159 5160 5211 5210
8 4089 4090 4141 4140 5160 5161 5212 5211
8 4090 4091 4142 4141 5161 5162 5213 5212
8 4091 4092 4143 4142 5162 5163 5214 5213
8 4092 4093 4144 4143 5163 5164 5215 5214
8 4093 4094 4145 4144 5164 5165 5216 5215
8 4094 4095 4146 4145 5165 5166 5217 5216
8 4095 4096 4147 4146 5166 5167 5218 5217
8 4096 4097 4148 4147 5167 5168 5219 5218
8 4097 4098 4149 4148 5168 5169 5220 5219
8 4098 4099 4150 4149 5169 5170 5221 5220
8 4099 4100 4151 4150 5170 5171 5222 5221
8 4100 4101 4152 4151 5171 5172 5223 5222
8 4101 4102 4153 4152 5172 5173 5224 5223
8 4102 4103 4154 4153 5173 5174 5225 5224
8 4103 4104 4155 4154 5174 5175 5226 5225
8 4104 4105 4156 4155 5175 5176 5227 5226
8 4105 4106 4157 4156 5176 5177 5228 5227
8 4106 4107 4158 4157 5177 5178 5229 5228
8 4107 4108 4159 4158 5178 5179 5230 5229
8 4108 4109 4160 4159 5179 5180 5231 5230
8 4109 4110 4161 4160 5180 5181 5232 5231
8 4110 4111 4162 4161 5181 5182 5233 5232
8 4111 4112 4163 4162 5182 5183 5234 5233
8 4112 4113 4164 4163 5183 5184 5235 5234
8 4113 4114 4165 4164 5184 5185 5236 5235
8 4114 4115 4166 4165 5185 5186 5237 5236
8 4115 4116 4167 4166 5186 5187 5238 5237
8 4116 4117 4168 4167 5187 5188 5239 5238
8 4117 4118 4169 4168 5188 5189 5240 5239
8 4118 4119 4170 4169 5189 5190 5241 5240
8 4119 4120 4171 4170 5190 5191 5242 5241
8 4120 4121 4172 4171 5191 5192 5243 5242
8 4121 4122 4173 4172 5192 5193 5244 5243
8 4122 4123 4174 4173 5193 5194 5245 5244
8 4123 4124 4175 4174 5194 5195 5246 5245
8 4124 4125 4176 4175 5195 5196 5247 5246
8 4125 4126 4177 4176 5196 5197 5248 5247
8 4126 4127 4178 4177 5197 5198 5249 5248
8 4127 4128 4179 4178 5198 5199 5250 5249
8 4128 4129 4180 4179 5199 5200 5251 5250
8 4129 4130 4181 4180 5200 5201 5252 5251
8 4131 4132 4183 4182 5202 5203 5254 5253
8 4132 4133 4184 4183 5203 5204 5255 5254
8 4133 4134 4185 4184 5204 5205 5256 5255
8 4134 4135 4186 4185 5205 5206 5257 5256
8 4135 4136 4187 4186 5206 5207 5258 5257
8 4136 4137 4188 4187 5207 5208 5259 5258
8 4137 4138 4189 4188 5208 5209 5260 5259
8 4138 4139 4190 4189 5209 5210 5261 5260
8 4139 4140 4191 4190 5210 5211 5262 5261
8 4140 4141 4192 4191 5211 5212 5263 5262
8 4141 4142 4193 4192 5212 5213 5264 5263
8 4142 4143 4194 4193 5213 5214 5265 5264
8 4143 4144 4195 4194 5214 5215 5266 5265
8 4144 4145 4196 4195 5215 5216 5267 5266
8 4145 4146 4197 4196 5216 5217 5268 5267
8 4146 4147 4198 4197 5217 5218 5269 5268
8 4147 4148 4199 4198 5218 5219 5270 5269
8 4148 4149 4200 4199 5219 5220 5271 5270
8 4149 4150 4201 4200 5220 5221 5272 5271
8 4150 4151 4202 4201 5221 5222 5273 5272
8 4151 4152 4203 4202 5222 5223 5274 5273
8 4152 4153 4204 4203 5223 5224 5275 5274
8 4153 4154 4205 4204 5224 5225 5276 5275
8 4154 4155 4206 4205 5225 5226 5277 5276
8 4155 4156 4207 4206 5226 5227 5278 5277
8 4156 4157 4208 4207 5227 5228 5279 5278
8 4157 4158 4209 4208 5228 5229 5280 5279
8 4158 4159 4210 4209 5229 5230 5281 5280
8 4159 4160 4211 4210 5230 5231 5282 5281
8 4160 4161 4212 4211 5231 5232 5283 5282
8 4161 4162 4213 4212 5232 5233 5284 5283
8 4162 4163 4214 4213 5233 5234 5285 5284
8 4163 4164 4215 4214 5234 5235 5286 5285
8 4164 4165 4216 4215 5235 5236 5287 5286
8 4165 4166 4217 4216 5236 5237 5288 5287
8 4166 4167 4218 4217 5237 5238 5289 5288
8 4167 4168 4219 4218 5238 5239 5290 5289
8 4168 4169 4220 4219 5239 5240 5291 5290
8 4169 4170 4221 4220 5240 5241 5292 5291
8 4170 4171 4222 4221 5241 5242 5293 5292
8 4171 4172 4223 4222 5242 5243 5294 5293
8 4172 4173 4224 4223 5243 5244 5295 5294
8 4173 4174 4225 4224 5244 5245 5296 5295
8 4174 4175 4226 4225 5245 5246 5297 5296
8 4175 4176 4227 4226 5246 5247 5298 5297
8 4176 4177 4228 4227 5247 5248 5299 5298
8 4177 4178 4229 4228 5248 5249 5300 5299
8 4178 4179 4230 4229 5249 5250 5301 5300
8 4179 4180 4231 4230 5250 5251 5302 5301
8 4180 4181 4232 4231 5251 5252 5303 5302
8 4182 4183 4234 4233 5253 5254 5305 5304
8 4183 4184 4235 4234 5254 5255 5306 5305
8 4184 4185 4236 4235 5255 5256 5307 5306
8 4185 4186 4237 4236 5256 5257 5308 5307
8 4186 4187 4238 4237 5257 5258 5309 5308
8 4187 4188 4239 4238 5258 5259 5310 5309
8 4188 4189 4240 4239 5259 5260 5311 5310
8 4189 4190 4241 4240 5260 5261 5312 5311
8 4190 4191 4242 4241 5261 5262 5313 5312
8 4191 4192 4243 4242 5262 5263 5314 5313
8 4192 4193 4244 4243 5263 5264 5315 5314
8 4193 4194 4245 4244 5264 5265 5316 5315
8 4194 4195 4246 4245 5265 5266 5317 5316
8 4195 4196 4247 4246 5266 5267 5318 5317
8 4196 4197 4248 4247 5267 5268 5319 5318
8 4197 4198 4249 4248 5268 5269 5320 5319
8 4198 4199 4250 4249 5269 5270 5321 5320
8 4199 4200 4251 4250 5270 5271 5322 5321
8 4200 4201 4252 4251 5271 5272 5323 5322
8 4201 4202 4253 4252 5272 5273 5324 5323
8 4202 4203 4254 4253 5273 5274 5325 5324
8 4203 4204 4255 4254 5274 5275 5326 5325
8 4204 4205 4256 4255 5275 5276 5327 5326
8 4205 4206 4257 4256 5276 5277 5328 5327
8 4206 4207 4258 4257 5277 5278 5329 5328
8 4207 4208 4259 4258 5278 5279 5330 5329
8 4208 4209 4260 4259 5279 5280 5331 5330
8 4209 4210 4261 4260 5280 5281 5332 5331
8 4210 4211 4262 4261 5281 5282 5333 5332
8 4211 4212 4263 4262 5282 5283 5334 5333
8 4212 4213 4264 4263 5283 5284 5335 5334
8 4213 4214 4265 4264 5284 5285 5336 5335
8 4214 4215 4266 4265 5285 5286 5337 5336
8 4215 4216 4267 4266 5286 5287 5338 5337
8 4216 4217 4268 4267 5287 5288 5339 5338
8 4217 4218 4269 4268 5288 5289 5340 5339
8 4218 4219 4270 4269 5289 5290 5341 5340
8 4219 4220 4271 4270 5290 5291 5342 5341
8 4220 4221 4272 4271 5291 5292 5343 5342
8 4221 4222 4273 4272 5292 5293 5344 5343
8 4222 4223 4274 4273 5293 5294 5345 5344
8 4223 4224 4275 4274 5294 5295 5346 5345
8 4224 4225 4276 4275 5295 5296 5347 5346
8 4225 4226 4277 4276 5296 5297 5348 5347
8 4226 4227 4278 4277 5297 5298 5349 5348
8 4227 4228 4279 4278 5298 5299 5350 5349
8 4228 4229 4280 4279 5299 5300 5351 5350
8 4229 4230 4281 4280 5300 5301 5352 5351
8 4230 4231 4282 4281 5301 5302 5353 5352
8 4231 4232 4283 4282 5302 5303 5354 5353
8 4284 4285 4336 4335 5355 5356 5407 5406
8 4285 4286 4337 4336 5356 5357 5408 5407
8 4286 4287 4338 4337 5357 5358 5409 5408
8 4287 4288 4339 4338 5358 5359 5410 5409
8 4288 4289 4340 4339 5359 5360 5411 5410
8 4289 4290 4341 4340 5360 5361 5412 5411
8 4290 4291 4342 4341 5361 5362 5413 5412
8 4291 4292 4343 4342 5362 5363 5414 5413
8 4292 4293 4344 4343 5363 5364 5415 5414
8 4293 4294 4345 4344 5364 5365 5416 5415
8 4294 4295 4346 4345 5365 5366 5417 5416
8 4295 4296 4347 4346 5366 5367 5418 5417
8 4296 4297 4348 4347 5367 5368 5419 5418
8 4297 4298 4349 4348 5368 5369 5420 5419
8 4298 4299 4350 4349 5369 5370 5421 5420
8 4299 4300 4351 4350 5370 5371 5422 5421
8 4300 4301 4352 4351 5371 5372 5423 5422
8 4301 4302 4353 4352 5372 5373 5424 5423
8 4302 4303 4354 4353 5373 5374 5425 5424
8 4303 4304 4355 4354 5374 5375 5426 5425
8 4304 4305 4356 4355 5375 5376 5427 5426
8 4305 4306 4357 4356 5376 5377 5428 5427
8 4306 4307 4358 4357 5377 5378 5429 5428
8 4307 4308 4359 4358 5378 5379 5430 5429
8 4308 4309 4360 4359 5379 5380 5431 5430
8 4309 4310 4361 4360 5380 5381 5432 5431
8 4310 4311 4362 4361 5381 5382 5433 5432
8 4311 4312 4363 4362 5382 5383 5434 5433
8 4312 4313 4364 4363 5383 5384 5435 5434
8 4313 4314 4365 4364 5384 5385 5436 5435
8 4314 4315 4366 4365 5385 5386 5437 5436
8 4315 4316 4367 4366 5386 5387 5438 5437
8 4316 4317 4368 4367 5387 5388 5439 5438
8 4317 4318 4369 4368 5388 5389 5440 5439
8 4318 4319 4370 4369 5389 5390 5441 5440
8 4319 4320 4371 4370 5390 5391 5442 5441
8 4320 4321 4372 4371 5391 5392 5443 5442
8 4321 4322 4373 4372 5392 5393 5444 5443
8 4322 4323 4374 4373 5393 5394 5445 5444
8 4323 4324 4375 4374 5394 5395 5446 5445
8 4324 4325 4376 4375 5395 5396 5447 5446
8 4325 4326 4377 4376 5396 5397 5448 5447
8 4326 4327 4378 4377 5397 5398 5449 5448
8 4327 4328 4379 4378 5398 5399 5450 5449
8 4328 4329 4380 4379 5399 5400 5451 5450
8 4329 4330 4381 4380 5400 5401 5452 5451
8 4330 4331 4382 4381 5401 5402 5453 5452
8 4331 4332 4383 4382 5402 5403 5454 5453
8 4332 4333 4384 4383 5403 5404 5455 5454
8 4333 4334 4385 4384 5404 5405 5456 5455
8 4335 4336 4387 4386 5406 5407 5458 5457
8 4336 4337 4388 4387 5407 5408 5459 5458
8 4337 4338 4389 4388 5408 5409 5460 5459
8 4338 4339 4390 4389 5409 5410 5461 5460
8 4339 4340 4391 4390 5410 5411 5462 5461
8 4340 4341 4392 4391 5411 5412 5463 5462
8 4341 4342 4393 4392 5412 5413 5464 5463
8 4342 4343 4394 4393 5413 5414 5465 5464
8 4343 4344 4395 4394 5414 5415 5466 5465
8 4344 4345 4396 4395 5415 5416 5467 5466
8 4345 4346 4397 4396 5416 5417 5468 5467
8 4346 4347 4398 4397 5417 5418 5469 5468
8 4347 4348 4399 4398 5418 5419 5470 5469
8 4348 4349 4400 4399 5419 5420 5471 5470
8 4349 4350 4401 4400 5420 5421 5472 5471
8 4350 4351 4402 4401 5421 5422 5473 5472
8 4351 4352 4403 4402 5422 5423 5474 5473
8 4352 4353 4404 4403 5423 5424 5475 5474
8 4353 4354 4405 4404 5424 5425 5476 5475
8 4354 4355 4406 4405 5425 5426 5477 5476
8 4355 4356 4407 4406 5426 5427 5478 5477
8 4356 4357 4408 4407 5427 5428 5479 5478
8 4357 4358 4409 4408 5428 5429 5480 5479
8 4358 4359 4410 4409 5429 5430 5481 5480
8 4359 4360 4411 4410 5430 5431 5482 5481
8 4360 4361 4412 4411 5431 5432 5483 5482
8 4361 4362 4413 4412 5432 5433 5484 5483
8 4362 4363 4414 4413 5433 5434 5485 5484
8 4363 4364 4415 4414 5434 5435 5486 5485
8 4364 4365 4416 4415 5435 5436 5487 5486
8 4365 4366 4417 4416 5436 5437 5488 5487
8 4366 4367 4418 4417 5437 5438 5489 5488
8 4367 4368 4419 4418 5438 5439 5490 5489
8 4368 4369 4420 4419 5439 5440 5491 5490
8 4369 4370 4421 4420 5440 5441 5492 5491
8 4370 4371 4422 4421 5441 5442 5493 5492
8 4371 4372 4423 4422 5442 5443 5494 5493
8 4372 4373 4424 4423 5443 5444 5495 5494
8 4373 4374 4425 4424 5444 5445 5496 5495
8 4374 4375 4426 4425 5445 5446 5497 5496
8 4375 4376 4427 4426 5446 5447 5498 5497
8 4376 4377 4428 4427 5447 5448 5499 5498
8 4377 4378 4429 4428 5448 5449 5500 5499
8 4378 4379 4430 4429 5449 5450 5501 5500
8 4379 4380 4431 4430 5450 5451 5502 5501
8 4380 4381 4432 4431 5451 5452 5503 5502
8 4381 4382 4433 4432 5452 5453 5504 5503
8 4382 4383 4434 4433 5453 5454 5505 5504
8 4383 4384 4435 4434 5454 5455 5506 5505
8 4384 4385 4436 4435 5455 5456 5507 5506
8 4386 4387 4438 4437 5457 5458 5509 5508
8 4387 4388 4439 4438 5458 5459 5510 5509
8 4388 4389 4440 4439 5459 5460 5511 5510
8 4389 4390 4441 4440 5460 5461 5512 5511
8 4390 4391 4442 4441 5461 5462 5513 5512
8 4391 4392 4443 4442 5462 5463 5514 5513
8 4392 4393 4444 4443 5463 5464 5515 5514
8 4393 4394 4445 4444 5464 5465 5516 5515
8 4394 4395 4446 4445 5465 5466 5517 5516
8 4395 4396 4447 4446 5466 5467 5518 5517
8 4396 4397 4448 4447 5467 5468 5519 5518
8 4397 4398 4449 4448 5468 5469 5520 5519
8 4398 4399 4450 4449 5469 5470 5521 5520
8 4399 4400 4451 4450 5470 5471 5522 5521
8 4400 4401 4452 4451 5471 5472 5523 5522
8 4401 4402 4453 4452 5472 5473 5524 5523
8 4402 4403 4454 4453 5473 5474 5525 5524
8 4403 4404 4455 4454 5474 5475 5526 5525
8 4404 4405 4456 4455 5475 5476 5527 5526
8 4405 4406 4457 4456 5476 5477 5528 5527
8 4406 4407 4458 4457 5477 5478 5529 5528
8 4407 4408 4459 4458 5478 5479 5530 5529
8 4408 4409 4460 4459 5479 5480 5531 5530
8 4409 4410 4461 4460 5480 5481 5532 5531
8 4410 4411 4462 4461 5481 5482 5533 5532
8 4411 4412 4463 4462 5482 5483 5534 5533
8 4412 4413 4464 4463 5483 5484 5535 5534
8 4413 4414 4465 4464 5484 5485 5536 5535
8 4414 4415 4466 4465 5485 5486 5537 5536
8 4415 4416 4467 4466 5486 5487 5538 5537
8 4416 4417 4468 4467 5487 5488 5539 5538
8 4417 4418 4469 4468 5488 5489 5540 5539
8 4418 4419 4470 4469 5489 5490 5541 5540
8 4419 4420 4471 4470 5490 5491 5542 5541
8 4420 4421 4472 4471 5491 5492 5543 5542
8 4421 4422 4473 4472 5492 5493 5544 5543
8 4422 4423 4474 4473 5493 5494 5545 5544
8 4423 4424 4475 4474 5494 5495 5546 5545
8 4424 4425 4476 4475 5495 5496 5547 5546
8 4425 4426 4477 4476 5496 5497 5548 5547
8 4426 4427 4478 4477 5497 5498 5549 5548
8 4427 4428 4479 4478 5498 5499 5550 5549
8 4428 4429 4480 4479 5499 5500 5551 5550
8 4429 4430 4481 4480 5500 5501 5552 5551
8 4430 4431 4482 4481 5501 5502 5553 5552
8 4431 4432 4483 4482 5502 5503 5554 5553
8 4432 4433 4484 4483 5503 5504 5555 5554
8 4433 4434 4485 4484 5504 5505 5556 5555
8 4434 4435 4486 4485 5505 5506 5557 5556
8 4435 4436 4487 4486 5506 5507 5558 5557
8 4437 4438 4489 4488 5508 5509 5560 5559
8 4438 4439 4490 4489 5509 5510 5561 5560
8 4439 4440 4491 4490 5510 5511 5562 5561
8 4440 4441 4492 4491 5511 5512 5563 5562
8 4441 4442 4493 4492 5512 5513 5564 5563
8 4442 4443 4494 4493 5513 5514 5565 5564
8 4443 4444 4495 4494 5514 5515 5566 5565
8 4444 4445 4496 4495 5515 5516 5567 5566
8 4445 4446 4497 4496 5516 5517 5568 5567
8 4446 4447 4498 4497 5517 5518 5569 5568
8 4447 4448 4499 4498 5518 5519 5570 5569
8 4448 4449 4500 4499 5519 5520 5571 5570
8 4449 4450 4501 4500 5520 5521 5572 5571
8 4450 4451 4502 4501 5521 5522 5573 5572
8 4451 4452 4503 4502 5522 5523 5574 5573
8 4452 4453 4504 4503 5523 5524 5575 5574
8 4453 4454 4505 4504 5524 5525 5576 5575
8 4454 4455 4506 4505 5525 5526 5577 5576
8 4455 4456 4507 4506 5526 5527 5578 5577
8 4456 4457 4508 4507 5527 5528 5579 5578
8 4457 4458 4509 4508 5528 5529 5580 5579
8 4458 4459 4510 4509 5529 5530 5581 5580
8 4459 4460 4511 4510 5530 5531 5582 5581
8 4460 4461 4512 4511 5531 5532 5583 5582
8 4461 4462 4513 4512 5532 5533 5584 5583
8 4462 4463 4514 4513 5533 5534 5585 5584
8 4463 4464 4515 4514 5534 5535 5586 5585
8 4464 4465 4516 4515 5535 5536 5587 5586
8 4465 4466 4517 4516 5536 5537 5588 5587
8 4466 4467 4518 4517 5537 5538 5589 5588
8 4467 4468 4519 4518 5538 5539 5590 5589
8 4468 4469 4520 4519 5539 5540 5591 5590
8 4469 4470 4521 4520 5540 5541 5592 5591
8 4470 4471 4522 4521 5541 5542 5593 5592
8 4471 4472 4523 4522 5542 5543 5594 5593
8 4472 4473 4524 4523 5543 5544 5595 5594
8 4473 4474 4525 4524 5544 5545 5596 5595
8 4474 4475 4526 4525 5545 5546 5597 5596
8 4475 4476 4527 4526 5546 5547 5598 5597
8 4476 4477 4528 4527 5547 5548 5599 5598
8 4477 4478 4529 4528 5548 5549 5600 5599
8 4478 4479 4530 4529 5549 5550 5601 5600
8 4479 4480 4531 4530 5550 5551 5602 5601
8 4480 4481 4532 4531 5551 5552 5603 5602
8 4481 4482 4533 4532 5552 5553 5604 5603
8 4482 4483 4534 4533 5553 5554 5605 5604
8 4483 4484 4535 4534 5554 5555 5606 5605
8 4484 4485 4536 4535 5555 5556 5607 5606
8 4485 4486 4537 4536 5556 5557 5608 5607
8 4486 4487 4538 4537 5557 5558 5609 5608
8 4488 4489 4540 4539 5559 5560 5611 5610
8 4489 4490 4541 4540 5560 5561 5612 5611
8 4490 4491 4542 4541 5561 5562 5613 5612
8 4491 4492 4543 4542 5562 5563 5614 5613
8 4492 4493 4544 4543 5563 5564 5615 5614
8 4493 4494 4545 4544 5564 5565 5616 5615
8 4494 4495 4546 4545 5565 5566 5617 5616
8 4495 4496 4547 4546 5566 5567 5618 5617
8 4496 4497 4548 4547 5567 5568 5619 5618
8 4497 4498 4549 4548 5568 5569 5620 5619
8 4498 4499 4550 4549 5569 5570 5621 5620
8 4499 4500 4551 4550 5570 5571 5622 5621
8 4500 4501 4552 4551 5571 5572 5623 5622
8 4501 4502 4553 4552 5572 5573 5624 5623
8 4502 4503 4554 4553 5573 5574 5625 5624
8 4503 4504 4555 4554 5574 5575 5626 5625
8 4504 4505 4556 4555 5575 5576 5627 5626
8 4505 4506 4557 4556 5576 5577 5628 5627
8 4506 4507 4558 4557 5577 5578 5629 5628
8 4507 4508 4559 4558 5578 5579 5630 5629
8 4508 4509 4560 4559 5579 5580 5631 5630
8 4509 4510 4561 4560 5580 5581 5632 5631
8 4510 4511 4562 4561 5581 5582 5633 5632
8 4511 4512 4563 4562 5582 5583 5634 5633
8 4512 4513 4564 4563 5583 5584 5635 5634
8 4513 4514 4565 4564 5584 5585 5636 5635
8 4514 4515 4566 4565 5585 5586 5637 5636
8 4515 4516 4567 4566 5586 5587 5638 5637
8 4516 4517 4568 4567 5587 5588 5639 5638
8 4517 4518 4569 4568 5588 5589 5640 5639
8 4518 4519 4570 4569 5589 5590 5641 5640
8 4519 4520 4571 4570 5590 5591 5642 5641
8 4520 4521 4572 4571 5591 5592 5643 5642
8 4521 4522 4573 4572 5592 5593 5644 5643
8 4522 4523 4574 4573 5593 5594 5645 5644
8 4523 4524 4575 4574 5594 5595 5646 5645
8 4524 4525 4576 4575 5595 5596 5647 5646
8 4525 4526 4577 4576 5596 5597 5648 5647
8 4526 4527 4578 4577 5597 5598 5649 5648
8 4527 4528 4579 4578 5598 5599 5650 5649
8 4528 4529 4580 4579 5599 5600 5651 5650
8 4529 4530 4581 4580 5600 5601 5652 5651
8 4530 4531 4582 4581 5601 5602 5653 5652
8 4531 4532 4583 4582 5602 5603 5654 5653
8 4532 4533 4584 4583 5603 5604 5655 5654
8 4533 4534 4585 4584 5604 5605 5656 5655
8 4534 4535 4586 4585 5605 5606 5657 5656
8 4535 4536 4587 4586 5606 5607 5658 5657
8 4536 4537 4588 4587 5607 5608 5659 5658
8 4537 4538 4589 4588 5608 5609 5660 5659
8 4539 4540 4591 4590 5610 5611 5662 5661
8 4540 4541 4592 4591 5611 5612 5663 5662
8 4541 4542 4593 4592 5612 5613 5664 5663
8 4542 4543 4594 4593 5613 5614 5665 5664
8 4543 4544 4595 4594 5614 5615 5666 5665
8 4544 4545 4596 4595 5615 5616 5667 5666
8 4545 4546 4597 4596 5616 5617 5668 5667
8 4546 4547 4598 4597 5617 5618 5669 5668
8 4547 4548 4599 4598 5618 5619 5670 5669
8 4548 4549 4600 4599 5619 5620 5671 5670
8 4549 4550 4601 4600 5620 5621 5672 5671
8 4550 4551 4602 4601 5621 5622 5673 5672
8 4551 4552 4603 4602 5622 5623 5674 5673
8 4552 4553 4604 4603 5623 5624 5675 5674
8 4553 4554 4605 4604 5624 5625 5676 5675
8 4554 4555 4606 4605 5625 5626 5677 5676
8 4555 4556 4607 4606 5626 5627 5678 5677
8 4556 4557 4608 4607 5627 5628 5679 5678
8 4557 4558 4609 4608 5628 5629 5680 5679
8 4558 4559 4610 4609 5629 5630 5681 5680
8 4559 4560 4611 4610 5630 5631 5682 5681
8 4560 4561 4612 4611 5631 5632 5683 5682
8 4561 4562 4613 4612 5632 5633 5684 5683
8 4562 4563 4614 4613 5633 5634 5685 5684
8 4563 4564 4615 4614 5634 5635 5686 5685
8 4564 4565 4616 4615 5635 5636 5687 5686
8 4565 4566 4617 4616 5636 5637 5688 5687
8 4566 4567 4618 4617 5637 5638 5689 5688
8 4567 4568 4619 4618 5638 5639 5690 5689
8 4568 4569 4620 4619 5639 5640 5691 5690
8 4569 4570 4621 4620 5640 5641 5692 5691
8 4570 4571 4622 4621 5641 5642 5693 5692
8 4571 4572 4623 4622 5642 5643 5694 5693
8 4572 4573 4624 4623 5643 5644 5695 5694
8 4573 4574 4625 4624 5644 5645 5696 5695
8 4574 4575 4626 4625 5645 5646 5697 5696
8 4575 4576 4627 4626 5646 5647 5698 5697
8 4576 4577 4628 4627 5647 5648 5699 5698
8 4577 4578 4629 4628 5648 5649 5700 5699
8 4578 4579 4630 4629 5649 5650 5701 5700
8 4579 4580 4631 4630 5650 5651 5702 5701
8 4580 4581 4632 4631 5651 5652 5703 5702
8 4581 4582 4633 4632 5652 5653 5704 5703
8 4582 4583 4634 4633 5653 5654 5705 5704
8 4583 4584 4635 4634 5654 5655 5706 5705
8 4584 4585 4636 4635 5655 5656 5707 5706
8 4585 4586 4637 4636 5656 5657 5708 5707
8 4586 4587 4638 4637 5657 5658 5709 5708
8 4587 4588 4639 4638 5658 5659 5710 5709
8 4588 4589 4640 4639 5659 5660 5711 5710
8 4590 4591 4642 4641 5661 5662 5713 5712
8 4591 4592 4643 4642 5662 5663 5714 5713
8 4592 4593 4644 4643 5663 5664 5715 5714
8 4593 4594 4645 4644 5664 5665 5716 5715
8 4594 4595 4646 4645 5665 5666 5717 5716
8 4595 4596 4647 4646 5666 5667 5718 5717
8 4596 4597 4648 4647 5667 5668 5719 5718
8 4597 4598 4649 4648 5668 5669 5720 5719
8 4598 4599 4650 4649 5669 5670 5721 5720
8 4599 4600 4651 4650 5670 5671 5722 5721
8 4600 4601 4652 4651 5671 5672 5723 5722
8 4601 4602 4653 4652 5672 5673 5724 5723
8 4602 4603 4654 4653 5673 5674 5725 5724
8 4603 4604 4655 4654 5674 5675 5726 5725
8 4604 4605 4656 4655 5675 5676 5727 5726
8 4605 4606 4657 4656 5676 5677 5728 5727
8 4606 4607 4658 4657 5677 5678 5729 5728
8 4607 4608 4659 4658 5678 5679 5730 5729
8 4608 4609 4660 4659 5679 5680 5731 5730
8 4609 4610 4661 4660 5680 5681 5732 5731
8 4610 4611 4662 4661 5681 5682 5733 5732
8 4611 4612 4663 4662 5682 5683 5734 5733
8 4612 4613 4664 4663 5683 5684 5735 5734
8 4613 4614 4665 4664 5684 5685 5736 5735
8 4614 4615 4666 4665 5685 5686 5737 5736
8 4615 4616 4667 4666 5686 5687 5738 5737
8 4616 4617 4668 4667 5687 5688 5739 5738
8 4617 4618 4669 4668 5688 5689 5740 5739
8 4618 4619 4670 4669 5689 5690 5741 5740
8 4619 4620 4671 4670 5690 5691 5742 5741
8 4620 4621 4672 4671 5691 5692 5743 5742
8 4621 4622 4673 4672 5692 5693 5744 5743
8 4622 4623 4674 4673 5693 5694 5745 5744
8 4623 4624 4675 4674 5694 5695 5746 5745
8 4624 4625 4676 4675 5695 5696 5747 5746
8 4625 4626 4677 4676 5696 5697 5748 5747
8 4626 4627 4678 4677 5697 5698 5749 5748
8 4627 4628 4679 4678 5698 5699 5750 5749
8 4628 4629 4680 4679 5699 5700 5751 5750
8 4629 4630 4681 4680 5700 5701 5752 5751
8 4630 4631 4682 4681 5701 5702 5753 5752
8 4631 4632 4683 4682 5702 5703 5754 5753
8 4632 4633 4684 4683 5703 5704 5755 5754
8 4633 4634 4685 4684 5704 5705 5756 5755
8 4634 4635 4686 4685 5705 5706 5757 5756
8 4635 4636 4687 4686 5706 5707 5758 5757
8 4636 4637 4688 4687 5707 5708 5759 5758
8 4637 4638 4689 4688 5708 5709 5760 5759
8 4638 4639 4690 4689 5709 5710 5761 5760
8 4639 4640 4691 4690 5710 5711 5762 5761
8 4641 4642 4693 4692 5712 5713 5764 5763
8 4642 4643 4694 4693 5713 5714 5765 5764
8 4643 4644 4695 4694 5714 5715 5766 5765
8 4644 4645 4696 4695 5715 5716 5767 5766
8 4645 4646 4697 4696 5716 5717 5768 5767
8 4646 4647 4698 4697 5717 5718 5769 5768
8 4647 4648 4699 4698 5718 5719 5770 5769
8 4648 4649 4700 4699 5719 5720 5771 5770
8 4649 4650 4701 4700 5720 5721 5772 5771
8 4650 4651 4702 4701 5721 5722 5773 5772
8 4651 4652 4703 4702 5722 5723 5774 5773
8 4652 4653 4704 4703 5723 5724 5775 5774
8 4653 4654 4705 4704 5724 5725 5776 5775
8 4654 4655 4706 4705 5725 5726 5777 5776
8 4655 4656 4707 4706 5726 5727 5778 5777
8 4656 4657 4708 4707 5727 5728 5779 5778
8 4657 4658 4709 4708 5728 5729 5780 5779
8 4658 4659 4710 4709 5729 5730 5781 5780
8 4659 4660 4711 4710 5730 5731 5782 5781
8 4660 4661 4712 4711 5731 5732 5783 5782
8 4661 4662 4713 4712 5732 5733 5784 5783
8 4662 4663 4714 4713 5733 5734 5785 5784
8 4663 4664 4715 4714 5734 5735 5786 5785
8 4664 4665 4716 4715 5735 5736 5787 5786
8 4665 4666 4717 4716 5736 5737 5788 5787
8 4666 4667 4718 4717 5737 5738 5789 5788
8 4667 4668 4719 4718 5738 5739 5790 5789
8 4668 4669 4720 4719 5739 5740 5791 5790
8 4669 4670 4721 4720 5740 5741 5792 5791
8 4670 4671 4722 4721 5741 5742 5793 5792
8 4671 4672 4723 4722 5742 5743 5794 5793
8 4672 4673 4724 4723 5743 5744 5795 5794
8 4673 4674 4725 4724 5744 5745 5796 5795
8 4674 4675 4726 4725 5745 5746 5797 5796
8 4675 4676 4727 4726 5746 5747 5798 5797
8 4676 4677 4728 4727 5747 5748 5799 5798
8 4677 4678 4729 4728 5748 5749 5800 5799
8 4678 4679 4730 4729 5749 5750 5801 5800
8 4679 4680 4731 4730 5750 5751 5802 5801
8 4680 4681 4732 4731 5751 5752 5803 5802
8 4681 4682 4733 4732 5752 5753 5804 5803
8 4682 4683 4734 4733 5753 5754 5805 5804
8 4683 4684 4735 4734 5754 5755 5806 5805
8 4684 4685 4736 4735 5755 5756 5807 5806
8 4685 4686 4737 4736 5756 5757 5808 5807
8 4686 4687 4738 4737 5757 5758 5809 5808
8 4687 4688 4739 4738 5758 5759 5810 5809
8 4688 4689 4740 4739 5759 5760 5811 5810
8 4689 4690 4741 4740 5760 5761 5812 5811
8 4690 4691 4742 4741 5761 5762 5813 5812
8 4692 4693 4744 4743 5763 5764 5815 5814
8 4693 4694 4745 4744 5764 5765 5816 5815
8 4694 4695 4746 4745 5765 5766 5817 5816
8 4695 4696 4747 4746 5766 5767 5818 5817
8 4696 4697 4748 4747 5767 5768 5819 5818
8 4697 4698 4749 4748 5768 5769 5820 5819
8 4698 4699 4750 4749 5769 5770 5821 5820
8 4699 4700 4751 4750 5770 5771 5822 5821
8 4700 4701 4752 4751 5771 5772 5823 5822
8 4701 4702 4753 4752 5772 5773 5824 5823
8 4702 4703 4754 4753 5773 5774 5825 5824
8 4703 4704 4755 4754 5774 5775 5826 5825
8 4704 4705 4756 4755 5775 5776 5827 5826
8 4705 4706 4757 4756 5776 5777 5828 5827
8 4706 4707 4758 4757 5777 5778 5829 5828
8 4707 4708 4759 4758 5778 5779 5830 5829
8 4708 4709 4760 4759 5779 5780 5831 5830
8 4709 4710 4761 4760 5780 5781 5832 5831
8 4710 4711 4762 4761 5781 5782 5833 5832
8 4711 4712 4763 4762 5782 5783 5834 5833
8 4712 4713 4764 4763 5783 5784 5835 5834
8 4713 4714 4765 4764 5784 5785 5836 5835
8 4714 4715 4766 4765 5785 5786 5837 5836
8 4715 4716 4767 4766 5786 5787 5838 5837
8 4716 4717 4768 4767 5787 5788 5839 5838
8 4717 4718 4769 4768 5788 5789 5840 5839
8 4718 4719 4770 4769 5789 5790 5841 5840
8 4719 4720 4771 4770 5790 5791 5842 5841
8 4720 4721 4772 4771 5791 5792 5843 5842
8 4721 4722 4773 4772 5792 5793 5844 5843
8 4722 4723 4774 4773 5793 5794 5845 5844
8 4723 4724 4775 4774 5794 5795 5846 5845
8 4724 4725 4776 4775 5795 5796 5847 5846
8 4725 4726 4777 4776 5796 5797 5848 5847
8 4726 4727 4778 4777 5797 5798 5849 5848
8 4727 4728 4779 4778 5798 5799 5850 5849
8 4728 4729 4780 4779 5799 5800 5851 5850
8 4729 4730 4781 4780 5800 5801 5852 5851
8 4730 4731 4782 4781 5801 5802 5853 5852
8 4731 4732 4783 4782 5802 5803 5854 5853
8 4732 4733 4784 4783 5803 5804 5855 5854
8 4733 4734 4785 4784 5804 5805 5856 5855
8 4734 4735 4786 4785 5805 5806 5857 5856
8 4735 4736 4787 4786 5806 5807 5858 5857
8 4736 4737 4788 4787 5807 5808 5859 5858
8 4737 4738 4789 4788 5808 5809 5860 5859
8 4738 4739 4790 4789 5809 5810 5861 5860
8 4739 4740 4791 4790 5810 5811 5862 5861
8 4740 4741 4792 4791 5811 5812 5863 5862
8 4741 4742 4793 4792 5812 5813 5864 5863
8 4743 4744 4795 4794 5814 5815 5866 5865
8 4744 4745 4796 4795 5815 5816 5867 5866
8 4745 4746 4797 4796 5816 5817 5868 5867
8 4746 4747 4798 4797 5817 5818 5869 5868
8 4747 4748 4799 4798 5818 5819 5870 5869
8 4748 4749 4800 4799 5819 5820 5871 5870
8 4749 4750 4801 4800 5820 5821 5872 5871
8 4750 4751 4802 4801 5821 5822 5873 5872
8 4751 4752 4803 4802 5822 5823 5874 5873
8 4752 4753 4804 4803 5823 5824 5875 5874
8 4753 4754 4805 4804 5824 5825 5876 5875
8 4754 4755 4806 4805 5825 5826 5877 5876
8 4755 4756 4807 4806 5826 5827 5878 5877
8 4756 4757 4808 4807 5827 5828 5879 5878
8 4757 4758 4809 4808 5828 5829 5880 5879
8 4758 4759 4810 4809 5829 5830 5881 5880
8 4759 4760 4811 4810 5830 5831 5882 5881
8 4760 4761 4812 4811 5831 5832 5883 5882
8 4761 4762 4813 4812 5832 5833 5884 5883
8 4762 4763 4814 4813 5833 5834 5885 5884
8 4763 4764 4815 4814 5834 5835 5886 5885
8 4764 4765 4816 4815 5835 5836 5887 5886
8 4765 4766 4817 4816 5836 5837 5888 5887
8 4766 4767 4818 4817 5837 5838 5889 5888
8 4767 4768 4819 4818 5838 5839 5890 5889
8 4768 4769 4820 4819 5839 5840 5891 5890
8 4769 4770 4821 4820 5840 5841 5892 5891
8 4770 4771 4822 4821 5841 5842 5893 5892
8 4771 4772 4823 4822 5842 5843 5894 5893
8 4772 4773 4824 4823 5843 5844 5895 5894
8 4773 4774 4825 4824 5844 5845 5896 5895
8 4774 4775 4826 4825 5845 5846 5897 5896
8 4775 4776 4827 4826 5846 5847 5898 5897
8 4776 4777 4828 4827 5847 5848 5899 5898
8 4777 4778 4829 4828 5848 5849 5900 5899
8 4778 4779 4830 4829 5849 5850 5901 5900
8 4779 4780 4831 4830 5850 5851 5902 5901
8 4780 4781 4832 4831 5851 5852 5903 5902
8 4781 4782 4833 4832 5852 5853 5904 5903
8 4782 4783 4834 4833 5853 5854 5905 5904
8 4783 4784 4835 4834 5854 5855 5906 5905
8 4784 4785 4836 4835 5855 5856 5907 5906
8 4785 4786 4837 4836 5856 5857 5908 5907
8 4786 4787 4838 4837 5857 5858 5909 5908
8 4787 4788 4839 4838 5858 5859 5910 5909
8 4788 4789 4840 4839 5859 5860 5911 5910
8 4789 4790 4841 4840 5860 5861 5912 5911
8 4790 4791 4842 4841 5861 5862 5913 5912
8 4791 4792 4843 4842 5862 5863 5914 5913
8 4792 4793 4844 4843 5863 5864 5915 5914
8 4794 4795 4846 4845 5865 5866 5917 5916
8 4795 4796 4847 4846 5866 5867 5918 5917
8 4796 4797 4848 4847 5867 5868 5919 5918
8 4797 4798 4849 4848 5868 5869 5920 5919
8 4798 4799 4850 4849 5869 5870 5921 5920
8 4799 4800 4851 4850 5870 5871 5922 5921
8 4800 4801 4852 4851 5871 5872 5923 5922
8 4801 4802 4853 4852 5872 5873 5924 5923
8 4802 4803 4854 4853 5873 5874 5925 5924
8 4803 4804 4855 4854 5874 5875 5926 5925
8 4804 4805 4856 4855 5875 5876 5927 5926
8 4805 4806 4857 4856 5876 5877 5928 5927
8 4806 4807 4858 4857 5877 5878 5929 5928
8 4807 4808 4859 4858 5878 5879 5930 5929
8 4808 4809 4860 4859 5879 5880 5931 5930
8 4809 4810 4861 4860 5880 5881 5932 5931
8 4810 4811 4862 4861 5881 5882 5933 5932
8 4811 4812 4863 4862 5882 5883 5934 5933
8 4812 4813 4864 4863 5883 5884 5935 5934
8 4813 4814 4865 4864 5884 5885 5936 5935
8 4814 4815 4866 4865 5885 5886 5937 5936
8 4815 4816 4867 4866 5886 5887 5938 5937
8 4816 4817 4868 4867 5887 5888 5939 5938
8 4817 4818 4869 4868 5888 5889 5940 5939
8 4818 4819 4870 4869 5889 5890 5941 5940
8 4819 4820 4871 4870 5890 5891 5942 5941
8 4820 4821 4872 4871 5891 5892 5943 5942
8 4821 4822 4873 4872 5892 5893 5944 5943
8 4822 4823 4874 4873 5893 5894 5945 5944
8 4823 4824 4875 4874 5894 5895 5946 5945
8 4824 4825 4876 4875 5895 5896 5947 5946
8 4825 4826 4877 4876 5896 5897 5948 5947
8 4826 4827 4878 4877 5897 5898 5949 5948
8 4827 4828 4879 4878 5898 5899 5950 5949
8 4828 4829 4880 4879 5899 5900 5951 5950
8 4829 4830 4881 4880 5900 5901 5952 5951
8 4830 4831 4882 4881 5901 5902 5953 5952
8 4831 4832 4883 4882 5902 5903 5954 5953
8 4832 4833 4884 4883 5903 5904 5955 5954
8 4833 4834 4885 4884 5904 5905 5956 5955
8 4834 4835 4886 4885 5905 5906 5957 5956
8 4835 4836 4887 4886 5906 5907 5958 5957
8 4836 4837 4888 4887 5907 5908 5959 5958
8 4837 4838 4889 4888 5908 5909 5960 5959
8 4838 4839 4890 4889 5909 5910 5961 5960
8 4839 4840 4891 4890 5910 5911 5962 5961
8 4840 4841 4892 4891 5911 5912 5963 5962
8 4841 4842 4893 4892 5912 5913 5964 5963
8 4842 4843 4894 4893 5913 5914 5965 5964
8 4843 4844 4895 4894 5914 5915 5966 5965
8 4845 4846 4897 4896 5916 5917 5968 5967
8 4846 4847 4898 4897 5917 5918 5969 5968
8 4847 4848 4899 4898 5918 5919 5970 5969
8 4848 4849 4900 4899 5919 5920 5971 5970
8 4849 4850 4901 4900 5920 5921 5972 5971
8 4850 4851 4902 4901 5921 5922 5973 5972
8 4851 4852 4903 4902 5922 5923 5974 5973
8 4852 4853 4904 4903 5923 5924 5975 5974
8 4853 4854 4905 4904 5924 5925 5976 5975
8 4854 4855 4906 4905 5925 5926 5977 5976
8 4855 4856 4907 4906 5926 5927 5978 5977
8 4856 4857 4908 4907 5927 5928 5979 5978
8 4857 4858 4909 4908 5928 5929 5980 5979
8 4858 4859 4910 4909 5929 5930 5981 5980
8 4859 4860 4911 4910 5930 5931 5982 5981
8 4860 4861 4912 4911 5931 5932 5983 5982
8 4861 4862 4913 4912 5932 5933 5984 5983
8 4862 4863 4914 4913 5933 5934 5985 5984
8 4863 4864 4915 4914 5934 5935 5986 5985
8 4864 4865 4916 4915 5935 5936 5987 5986
8 4865 4866 4917 4916 5936 5937 5988 5987
8 4866 4867 4918 4917 5937 5938 5989 5988
8 4867 4868 4919 4918 5938 5939 5990 5989
8 4868 4869 4920 4919 5939 5940 5991 5990
8 4869 4870 4921 4920 5940 5941 5992 5991
8 4870 4871 4922 4921 5941 5942 5993 5992
8 4871 4872 4923 4922 5942 5943 5994 5993
8 4872 4873 4924 4923 5943 5944 5995 5994
8 4873 4874 4925 4924 5944 5945 5996 5995
8 4874 4875 4926 4925 5945 5946 5997 5996
8 4875 4876 4927 4926 5946 5947 5998 5997
8 4876 4877 4928 4927 5947 5948 5999 5998
8 4877 4878 4929 4928 5948 5949 6000 5999
8 4878 4879 4930 4929 5949 5950 6001 6000
8 4879 4880 4931 4930 5950 5951 6002 6001
8 4880 4881 4932 4931 5951 5952 6003 6002
8 4881 4882 4933 4932 5952 5953 6004 6003
8 4882 4883 4934 4933 5953 5954 6005 6004
8 4883 4884 4935 4934 5954 5955 6006 6005
8 4884 4885 4936 4935 5955 5956 6007 6006
8 4885 4886 4937 4936 5956 5957 6008 6007
8 4886 4887 4938 4937 5957 5958 6009 6008
8 4887 4888 4939 4938 5958 5959 6010 6009
8 4888 4889 4940 4939 5959 5960 6011 6010
8 4889 4890 4941 4940 5960 5961 6012 6011
8 4890 4891 4942 4941 5961 5962 6013 6012
8 4891 4892 4943 4942 5962 5963 6014 6013
8 4892 4893 4944 4943 5963 5964 6015 6014
8 4893 4894 4945 4944 5964 5965 6016 6015
8 4894 4895 4946 4945 5965 5966 6017 6016
8 4896 4897 4948 4947 5967 5968 6019 6018
8 4897 4898 4949 4948 5968 5969 6020 6019
8 4898 4899 4950 4949 5969 5970 6021 6020
8 4899 4900 4951 4950 5970 5971 6022 6021
8 4900 4901 4952 4951 5971 5972 6023 6022
8 4901 4902 4953 4952 5972 5973 6024 6023
8 4902 4903 4954 4953 5973 5974 6025 6024
8 4903 4904 4955 4954 5974 5975 6026 6025
8 4904 4905 4956 4955 5975 5976 6027 6026
8 4905 4906 4957 4956 5976 5977 6028 6027
8 4906 4907 4958 4957 5977 5978 6029 6028
8 4907 4908 4959 4958 5978 5979 6030 6029
8 4908 4909 4960 4959 5979 5980 6031 6030
8 4909 4910 4961 4960 5980 5981 6032 6031
8 4910 4911 4962 4961 5981 5982 6033 6032
8 4911 4912 4963 4962 5982 5983 6034 6033
8 4912 4913 4964 4963 5983 5984 6035 6034
8 4913 4914 4965 4964 5984 5985 6036 6035
8 4914 4915 4966 4965 5985 5986 6037 6036
8 4915 4916 4967 4966 5986 5987 6038 6037
8 4916 4917 4968 4967 5987 5988 6039 6038
8 4917 4918 4969 4968 5988 5989 6040 6039
8 4918 4919 4970 4969 5989 5990 6041 6040
8 4919 4920 4971 4970 5990 5991 6042 6041
8 4920 4921 4972 4971 5991 5992 6043 6042
8 4921 4922 4973 4972 5992 5993 6044 6043
8 4922 4923 4974 4973 5993 5994 6045 6044
8 4923 4924 4975 4974 5994 5995 6046 6045
8 4924 4925 4976 4975 5995 5996 6047 6046
8 4925 4926 4977 4976 5996 5997 6048 6047
8 4926 4927 4978 4977 5997 5998 6049 6048
8 4927 4928 4979 4978 5998 5999 6050 6049
8 4928 4929 4980 4979 5999 6000 6051 6050
8 4929 4930 4981 4980 6000 6001 6052 6051
8 4930 4931 4982 4981 6001 6002 6053 6052
8 4931 4932 4983 4982 6002 6003 6054 6053
8 4932 4933 4984 4983 6003 6004 6055 6054
8 4933 4934 4985 4984 6004 6005 6056 6055
8 4934 4935 4986 4985 6005 6006 6057 6056
8 4935 4936 4987 4986 6006 6007 6058 6057
8 4936 4937 4988 4987 6007 6008 6059 6058
8 4937 4938 4989 4988 6008 6009 6060 6059
8 4938 4939 4990 4989 6009 6010 6061 6060
8 4939 4940 4991 4990 6010 6011 6062 6061
8 4940 4941 4992 4991 6011 6012 6063 6062
8 4941 4942 4993 4992 6012 6013 6064 6063
8 4942 4943 4994 4993 6013 6014 6065 6064
8 4943 4944 4995 4994 6014 6015 6066 6065
8 4944 4945 4996 4995 6015 6016 6067 6066
8 4945 4946 4997 4996 6016 6017 6068 6067
8 4947 4948 4999 4998 6018 6019 6070 6069
8 4948 4949 5000 4999 6019 6020 6071 6070
8 4949 4950 5001 5000 6020 6021 6072 6071
8 4950 4951 5002 5001 6021 6022 6073 6072
8 4951 4952 5003 5002 6022 6023 6074 6073
8 4952 4953 5004 5003 6023 6024 6075 6074
8 4953 4954 5005 5004 6024 6025 6076 6075
8 4954 4955 5006 5005 6025 6026 6077 6076
8 4955 4956 5007 5006 6026 6027 6078 6077
8 4956 4957 5008 5007 6027 6028 6079 6078
8 4957 4958 5009 5008 6028 6029 6080 6079
8 4958 4959 5010 5009 6029 6030 6081 6080
8 4959 4960 5011 5010 6030 6031 6082 6081
8 4960 4961 5012 5011 6031 6032 6083 6082
8 4961 4962 5013 5012 6032 6033 6084 6083
8 4962 4963 5014 5013 6033 6034 6085 6084
8 4963 4964 5015 5014 6034 6035 6086 6085
8 4964 4965 5016 5015 6035 6036 6087 6086
8 4965 4966 5017 5016 6036 6037 6088 6087
8 4966 4967 5018 5017 6037 6038 6089 6088
8 4967 4968 5019 5018 6038 6039 6090 6089
8 4968 4969 5020 5019 6039 6040 6091 6090
8 4969 4970 5021 5020 6040 6041 6092 6091
8 4970 4971 5022 5021 6041 6042 6093 6092
8 4971 4972 5023 5022 6042 6043 6094 6093
8 4972 4973 5024 5023 6043 6044 6095 6094
8 4973 4974 5025 5024 6044 6045 6096 6095
8 4974 4975 5026 5025 6045 6046 6097 6096
8 4975 4976 5027 5026 6046 6047 6098 6097
8 4976 4977 5028 5027 6047 6048 6099 6098
8 4977 4978 5029 5028 6048 6049 6100 6099
8 4978 4979 5030 5029 6049 6050 6101 6100
8 4979 4980 5031 5030 6050 6051 6102 6101
8 4980 4981 5032 5031 6051 6052 6103 6102
8 4981 4982 5033 5032 6052 6053 6104 6103
8 4982 4983 5034 5033 6053 6054 6105 6104
8 4983 4984 5035 5034 6054 6055 6106 6105
8 4984 4985 5036 5035 6055 6056 6107 6106
8 4985 4986 5037 5036 6056 6057 6108 6107
8 4986 4987 5038 5037 6057 6058 6109 6108
8 4987 4988 5039 5038 6058 6059 6110 6109
8 4988 4989 5040 5039 6059 6060 6111 6110
8 4989 4990 5041 5040 6060 6061 6112 6111
8 4990 4991 5042 5041 6061 6062 6113 6112
8 4991 4992 5043 5042 6062 6063 6114 6113
8 4992 4993 5044 5043 6063 6064 6115 6114
8 4993 4994 5045 5044 6064 6065 6116 6115
8 4994 4995 5046 5045 6065 6066 6117 6116
8 4995 4996 5047 5046 6066 6067 6118 6117
8 4996 4997 5048 5047 6067 6068 6119 6118
8 4998 4999 5050 5049 6069 6070 6121 6120
8 4999 5000 5051 5050 6070 6071 6122 6121
8 5000 5001 5052 5051 6071 6072 6123 6122
8 5001 5002 5053 5052 6072 6073 6124 6123
8 5002 5003 5054 5053 6073 6074 6125 6124
8 5003 5004 5055 5054 6074 6075 6126 6125
8 5004 5005 5056 5055 6075 6076 6127 6126
8 5005 5006 5057 5056 6076 6077 6128 6127
8 5006 5007 5058 5057 6077 6078 6129 6128
8 5007 5008 5059 5058 6078 6079 6130 6129
8 5008 5009 5060 5059 6079 6080 6131 6130
8 5009 5010 5061 5060 6080 6081 6132 6131
8 5010 5011 5062 5061 6081 6082 6133 6132
8 5011 5012 5063 5062 6082 6083 6134 6133
8 5012 5013 5064 5063 6083 6084 6135 6134
8 5013 5014 5065 5064 6084 6085 6136 6135
8 5014 5015 5066 5065 6085 6086 6137 6136
8 5015 5016 5067 5066 6086 6087 6138 6137
8 5016 5017 5068 5067 6087 6088 6139 6138
8 5017 5018 5069 5068 6088 6089 6140 6139
8 5018 5019 5070 5069 6089 6090 6141 6140
8 5019 5020 5071 5070 6090 6091 6142 6141
8 5020 5021 5072 5071 6091 6092 6143 6142
8 5021 5022 5073 5072 6092 6093 6144 6143
8 5022 5023 5074 5073 6093 6094 6145 6144
8 5023 5024 5075 5074 6094 6095 6146 6145
8 5024 5025 5076 5075 6095 6096 6147 6146
8 5025 5026 5077 5076 6096 6097 6148 6147
8 5026 5027 5078 5077 6097 6098 6149 6148
8 5027 5028 5079 5078 6098 6099 6150 6149
8 5028 5029 5080 5079 6099 6100 6151 6150
8 5029 5030 5081 5080 6100 6101 6152 6151
8 5030 5031 5082 5081 6101 6102 6153 6152
8 5031 5032 5083 5082 6102 6103 6154 6153
8 5032 5033 5084 5083 6103 6104 6155 6154
8 5033 5034 5085 5084 6104 6105 6156 6155
8 5034 5035 5086 5085 6105 6106 6157 6156
8 5035 5036 5087 5086 6106 6107 6158 6157
8 5036 5037 5088 5087 6107 6108 6159 6158
8 5037 5038 5089 5088 6108 6109 6160 6159
8 5038 5039 5090 5089 6109 6110 6161 6160
8 5039 5040 5091 5090 6110 6111 6162 6161
8 5040 5041 5092 5091 6111 6112 6163 6162
8 5041 5042 5093 5092 6112 6113 6164 6163
8 5042 5043 5094 5093 6113 6114 6165 6164
8 5043 5044 5095 5094 6114 6115 6166 6165
8 5044 5045 5096 5095 6115 6116 6167 6166
8 5045 5046 5097 5096 6116 6117 6168 6167
8 5046 5047 5098 5097 6117 6118 6169 6168
8 5047 5048 5099 5098 6118 6119 6170 6169
8 5049 5050 5101 5100 6120 6121 6172 6171
8 5050 5051 5102 5101 6121 6122 6173 6172
8 5051 5052 5103 5102 6122 6123 6174 6173
8 5052 5053 5104 5103 6123 6124 6175 6174
8 5053 5054 5105 5104 6124 6125 6176 6175
8 5054 5055 5106 5105 6125 6126 6177 6176
8 5055 5056 5107 5106 6126 6127 6178 6177
8 5056 5057 5108 5107 6127 6128 6179 6178
8 5057 5058 5109 5108 6128 6129 6180 6179
8 5058 5059 5110 5109 6129 6130 6181 6180
8 5059 5060 5111 5110 6130 6131 6182 6181
8 5060 5061 5112 5111 6131 6132 6183 6182
8 5061 5062 5113 5112 6132 6133 6184 6183
8 5062 5063 5114 5113 6133 6134 6185 6184
8 5063 5064 5115 5114 6134 6135 6186 6185
8 5064 5065 5116 5115 6135 6136 6187 6186
8 5065 5066 5117 5116 6136 6137 6188 6187
8 5066 5067 5118 5117 6137 6138 6189 6188
8 5067 5068 5119 5118 6138 6139 6190 6189
8 5068 5069 5120 5119 6139 6140 6191 6190
8 5069 5070 5121 5120 6140 6141 6192 6191
8 5070 5071 5122 5121 6141 6142 6193 6192
8 5071 5072 5123 5122 6142 6143 6194 6193
8 5072 5073 5124 5123 6143 6144 6195 6194
8 5073 5074 5125 5124 6144 6145 6196 6195
8 5074 5075 5126 5125 6145 6146 6197 6196
8 5075 5076 5127 5126 6146 6147 6198 6197
8 5076 5077 5128 5127 6147 6148 6199 6198
8 5077 5078 5129 5128 6148 6149 6200 6199
8 5078 5079 5130 5129 6149 6150 6201 6200
8 5079 5080 5131 5130 6150 6151 6202 6201
8 5080 5081 5132 5131 6151 6152 6203 6202
8 5081 5082 5133 5132 6152 6153 6204 6203
8 5082 5083 5134 5133 6153 6154 6205 6204
8 5083 5084 5135 5134 6154 6155 6206 6205
8 5084 5085 5136 5135 6155 6156 6207 6206
8 5085 5086 5137 5136 6156 6157 6208 6207
8 5086 5087 5138 5137 6157 6158 6209 6208
8 5087 5088 5139 5138 6158 6159 6210 6209
8 5088 5089 5140 5139 6159 6160 6211 6210
8 5089 5090 5141 5140 6160 6161 6212 6211
8 5090 5091 5142 5141 6161 6162 6213 6212
8 5091 5092 5143 5142 6162 6163 6214 6213
8 5092 5093 5144 5143 6163 6164 6215 6214
8 5093 5094 5145 5144 6164 6165 6216 6215
8 5094 5095 5146 5145 6165 6166 6217 6216
8 5095 5096 5147 5146 6166 6167 6218 6217
8 5096 5097 5148 5147 6167 6168 6219 6218
8 5097 5098 5149 5148 6168 6169 6220 6219
8 5098 5099 5150 5149 6169 6170 6221 6220
8 5100 5101 5152 5151 6171 6172 6223 6222
8 5101 5102 5153 5152 6172 6173 6224 6223
8 5102 5103 5154 5153 6173 6174 6225 6224
8 5103 5104 5155 5154 6174 6175 6226 6225
8 5104 5105 5156 5155 6175 6176 6227 6226
8 5105 5106 5157 5156 6176 6177 6228 6227
8 5106 5107 5158 5157 6177 6178 6229 6228
8 5107 5108 5159 5158 6178 6179 6230 6229
8 5108 5109 5160 5159 6179 6180 6231 6230
8 5109 5110 5161 5160 6180 6181 6232 6231
8 5110 5111 5162 5161 6181 6182 6233 6232
8 5111 5112 5163 5162 6182 6183 6234 6233
8 5112 5113 5164 5163 6183 6184 6235 6234
8 5113 5114 5165 5164 6184 6185 6236 6235
8 5114 5115 5166 5165 6185 6186 6237 6236
8 5115 5116 5167 5166 6186 6187 6238 6237
8 5116 5117 5168 5167 6187 6188 6239 6238
8 5117 5118 5169 5168 6188 6189 6240 6239
8 5118 5119 5170 5169 6189 6190 6241 6240
8 5119 5120 5171 5170 6190 6191 6242 6241
8 5120 5121 5172 5171 6191 6192 6243 6242
8 5121 5122 5173 5172 6192 6193 6244 6243
8 5122 5123 5174 5173 6193 6194 6245 6244
8 5123 5124 5175 5174 6194 6195 6246 6245
8 5124 5125 5176 5175 6195 6196 6247 6246
8 5125 5126 5177 5176 6196 6197 6248 6247
8 5126 5127 5178 5177 6197 6198 6249 6248
8 5127 5128 5179 5178 6198 6199 6250 6249
8 5128 5129 5180 5179 6199 6200 6251 6250
8 5129 5130 5181 5180 6200 6201 6252 6251
8 5130 5131 5182 5181 6201 6202 6253 6252
8 5131 5132 5183 5182 6202 6203 6254 6253
8 5132 5133 5184 5183 6203 6204 6255 6254
8 5133 5134 5185 5184 6204 6205 6256 6255
8 5134 5135 5186 5185 6205 6206 6257 6256
8 5135 5136 5187 5186 6206 6207 6258 6257
8 5136 5137 5188 5187 6207 6208 6259 6258
8 5137 5138 5189 5188 6208 6209 6260 6259
8 5138 5139 5190 5189 6209 6210 6261 6260
8 5139 5140 5191 5190 6210 6211 6262 6261
8 5140 5141 5192 5191 6211 6212 6263 6262
8 5141 5142 5193 5192 6212 6213 6264 6263
8 5142 5143 5194 5193 6213 6214 6265 6264
8 5143 5144 5195 5194 6214 6215 6266 6265
8 5144 5145 5196 5195 6215 6216 6267 6266
8 5145 5146 5197 5196 6216 6217 6268 6267
8 5146 5147 5198 5197 6217 6218 6269 6268
8 5147 5148 5199 5198 6218 6219 6270 6269
8 5148 5149 5200 5199 6219 6220 6271 6270
8 5149 5150 5201 5200 6220 6221 6272 6271
8 5151 5152 5203 5202 6222 6223 6274 6273
8 5152 5153 5204 5203 6223 6224 6275 6274
8 5153 5154 5205 5204 6224 6225 6276 6275
8 5154 5155 5206 5205 6225 6226 6277 6276
8 5155 5156 5207 5206 6226 6227 6278 6277
8 5156 5157 5208 5207 6227 6228 6279 6278
8 5157 5158 5209 5208 6228 6229 6280 6279
8 5158 5159 5210 5209 6229 6230 6281 6280
8 5159 5160 5211 5210 6230 6231 6282 6281
8 5160 5161 5212 5211 6231 6232 6283 6282
8 5161 5162 5213 5212 6232 6233 6284 6283
8 5162 5163 5214 5213 6233 6234 6285 6284
8 5163 5164 5215 5214 6234 6235 6286 6285
8 5164 5165 5216 5215 6235 6236 6287 6286
8 5165 5166 5217 5216 6236 6237 6288 6287
8 5166 5167 5218 5217 6237 6238 6289 6288
8 5167 5168 5219 5218 6238 6239 6290 6289
8 5168 5169 5220 5219 6239 6240 6291 6290
8 5169 5170 5221 5220 6240 6241 6292 6291
8 5170 5171 5222 5221 6241 6242 6293 6292
8 5171 5172 5223 5222 6242 6243 6294 6293
8 5172 5173 5224 5223 6243 6244 6295 6294
8 5173 5174 5225 5224 6244 6245 6296 6295
8 5174 5175 5226 5225 6245 6246 6297 6296
8 5175 5176 5227 5226 6246 6247 6298 6297
8 5176 5177 5228 5227 6247 6248 6299 6298
8 5177 5178 5229 5228 6248 6249 6300 6299
8 5178 5179 5230 5229 6249 6250 6301 6300
8 5179 5180 5231 5230 6250 6251 6302 6301
8 5180 5181 5232 5231 6251 6252 6303 6302
8 5181 5182 5233 5232 6252 6253 6304 6303
8 5182 5183 5234 5233 6253 6254 6305 6304
8 5183 5184 5235 5234 6254 6255 6306 6305
8 5184 5185 5236 5235 6255 6256 6307 6306
8 5185 5186 5237 5236 6256 6257 6308 6307
8 5186 5187 5238 5237 6257 6258 6309 6308
8 5187 5188 5239 5238 6258 6259 6310 6309
8 5188 5189 5240 5239 6259 6260 6311 6310
8 5189 5190 5241 5240 6260 6261 6312 6311
8 5190 5191 5242 5241 6261 6262 6313 6312
8 5191 5192 5243 5242 6262 6263 6314 6313
8 5192 5193 5244 5243 6263 6264 6315 6314
8 5193 5194 5245 5244 6264 6265 6316 6315
8 5194 5195 5246 5245 6265 6266 6317 6316
8 5195 5196 5247 5246 6266 6267 6318 6317
8 5196 5197 5248 5247 6267 6268 6319 6318
8 5197 5198 5249 5248 6268 6269 6320 6319
8 5198 5199 5250 5249 6269 6270 6321 6320
8 5199 5200 5251 5250 6270 6271 6322 6321
8 5200 5201 5252 5251 6271 6272 6323 6322
8 5202 5203 5254 5253 6273 6274 6325 6324
8 5203 5204 5255 5254 6274 6275 6326 6325
8 5204 5205 5256 5255 6275 6276 6327 6326
8 5205 5206 5257 5256 6276 6277 6328 6327
8 5206 5207 5258 5257 6277 6278 6329 6328
8 5207 5208 5259 5258 6278 6279 6330 6329
8 5208 5209 5260 5259 6279 6280 6331 6330
8 5209 5210 5261 5260 6280 6281 6332 6331
8 5210 5211 5262 5261 6281 6282 6333 6332
8 5211 5212 5263 5262 6282 6283 6334 6333
8 5212 5213 5264 5263 6283 6284 6335 6334
8 5213 5214 5265 5264 6284 6285 6336 6335
8 5214 5215 5266 5265 6285 6286 6337 6336
8 5215 5216 5267 5266 6286 6287 6338 6337
8 5216 5217 5268 5267 6287 6288 6339 6338
8 5217 5218 5269 5268 6288 6289 6340 6339
8 5218 5219 5270 5269 6289 6290 6341 6340
8 5219 5220 5271 5270 6290 6291 6342 6341
8 5220 5221 5272 5271 6291 6292 6343 6342
8 5221 5222 5273 5272 6292 6293 6344 6343
8 5222 5223 5274 5273 6293 6294 6345 6344
8 5223 5224 5275 5274 6294 6295 6346 6345
8 5224 5225 5276 5275 6295 6296 6347 6346
8 5225 5226 5277 5276 6296 6297 6348 6347
8 5226 5227 5278 5277 6297 6298 6349 6348
8 5227 5228 5279 5278 6298 6299 6350 6349
8 5228 5229 5280 5279 6299 6300 6351 6350
8 5229 5230 5281 5280 6300 6301 6352 6351
8 5230 5231 5282 5281 6301 6302 6353 6352
8 5231 5232 5283 5282 6302 6303 6354 6353
8 5232 5233 5284 5283 6303 6304 6355 6354
8 5233 5234 5285 5284 6304 6305 6356 6355
8 5234 5235 5286 5285 6305 6306 6357 6356
8 5235 5236 5287 5286 6306 6307 6358 6357
8 5236 5237 5288 5287 6307 6308 6359 6358
8 5237 5238 5289 5288 6308 6309 6360 6359
8 5238 5239 5290 5289 6309 6310 6361 6360
8 5239 5240 5291 5290 6310 6311 6362 6361
8 5240 5241 5292 5291 6311 6312 6363 6362
8 5241 5242 5293 5292 6312 6313 6364 6363
8 5242 5243 5294 5293 6313 6314 6365 6364
8 5243 5244 5295 5294 6314 6315 6366 6365
8 5244 5245 5296 5295 6315 6316 6367 6366
8 5245 5246 5297 5296 6316 6317 6368 6367
8 5246 5247 5298 5297 6317 6318 6369 6368
8 5247 5248 5299 5298 6318 6319 6370 6369
8 5248 5249 5300 5299 6319 6320 6371 6370
8 5249 5250 5301 5300 6320 6321 6372 6371
8 5250 5251 5302 5301 6321 6322 6373 6372
8 5251 5252 5303 5302 6322 6323 6374 6373
8 5253 5254 5305 5304 6324 6325 6376 6375
8 5254 5255 5306 5305 6325 6326 6377 6376
8 5255 5256 5307 5306 6326 6327 6378 6377
8 5256 5257 5308 5307 6327 6328 6379 6378
8 5257 5258 5309 5308 6328 6329 6380 6379
8 5258 5259 5310 5309 6329 6330 6381 6380
8 5259 5260 5311 5310 6330 6331 6382 6381
8 5260 5261 5312 5311 6331 6332 6383 6382
8 5261 5262 5313 5312 6332 6333 6384 6383
8 5262 5263 5314 5313 6333 6334 6385 6384
8 5263 5264 5315 5314 6334 6335 6386 6385
8 5264 5265 5316 5315 6335 6336 6387 6386
8 5265 5266 5317 5316 6336 6337 6388 6387
8 5266 5267 5318 5317 6337 6338 6389 6388
8 5267 5268 5319 5318 6338 6339 6390 6389
8 5268 5269 5320 5319 6339 6340 6391 6390
8 5269 5270 5321 5320 6340 6341 6392 6391
8 5270 5271 5322 5321 6341 6342 6393 6392
8 5271 5272 5323 5322 6342 6343 6394 6393
8 5272 5273 5324 5323 6343 6344 6395 6394
8 5273 5274 5325 5324 6344 6345 6396 6395
8 5274 5275 5326 5325 6345 6346 6397 6396
8 5275 5276 5327 5326 6346 6347 6398 6397
8 5276 5277 5328 5327 6347 6348 6399 6398
8 5277 5278 5329 5328 6348 6349 6400 6399
8 5278 5279 5330 5329 6349 6350 6401 6400
8 5279 5280 5331 5330 6350 6351 6402 6401
8 5280 5281 5332 5331 6351 6352 6403 6402
8 5281 5282 5333 5332 6352 6353 6404 6403
8 5282 5283 5334 5333 6353 6354 6405 6404
8 5283 5284 5335 5334 6354 6355 6406 6405
8 5284 5285 5336 5335 6355 6356 6407 6406
8 5285 5286 5337 5336 6356 6357 6408 6407
8 5286 5287 5338 5337 6357 6358 6409 6408
8 5287 5288 5339 5338 6358 6359 6410 6409
8 5288 5289 5340 5339 6359 6360 6411 6410
8 5289 5290 5341 5340 6360 6361 6412 6411
8 5290 5291 5342 5341 6361 6362 6413 6412
8 5291 5292 5343 5342 6362 6363 6414 6413
8 5292 5293 5344 5343 6363 6364 6415 6414
8 5293 5294 5345 5344 6364 6365 6416 6415
8 5294 5295 5346 5345 6365 6366 6417 6416
8 5295 5296 5347 5346 6366 6367 6418 6417
8 5296 5297 5348 5347 6367 6368 6419 6418
8 5297 5298 5349 5348 6368 6369 6420 6419
8 5298 5299 5350 5349 6369 6370 6421 6420
8 5299 5300 5351 5350 6370 6371 6422 6421
8 5300 5301 5352 5351 6371 6372 6423 6422
8 5301 5302 5353 5352 6372 6373 6424 6423
8 5302 5303 5354 5353 6373 6374 6425 6424
8 5355 5356 5407 5406 6426 6427 6478 6477
8 5356 5357 5408 5407 6427 6428 6479 6478
8 5357 5358 5409 5408 6428 6429 6480 6479
8 5358 5359 5410 5409 6429 6430 6481 6480
8 5359 5360 5411 5410 6430 6431 6482 6481
8 5360 5361 5412 5411 6431 6432 6483 6482
8 5361 5362 5413 5412 6432 6433 6484 6483
8 5362 5363 5414 5413 6433 6434 6485 6484
8 5363 5364 5415 5414 6434 6435 6486 6485
8 5364 5365 5416 5415 6435 6436 6487 6486
8 5365 5366 5417 5416 6436 6437 6488 6487
8 5366 5367 5418 5417 6437 6438 6489 6488
8 5367 5368 5419 5418 6438 6439 6490 6489
8 5368 5369 5420 5419 6439 6440 6491 6490
8 5369 5370 5421 5420 6440 6441 6492 6491
8 5370 5371 5422 5421 6441 6442 6493 6492
8 5371 5372 5423 5422 6442 6443 6494 6493
8 5372 5373 5424 5423 6443 6444 6495 6494
8 5373 5374 5425 5424 6444 6445 6496 6495
8 5374 5375 5426 5425 6445 6446 6497 6496
8 5375 5376 5427 5426 6446 6447 6498 6497
8 5376 5377 5428 5427 6447 6448 6499 6498
8 5377 5378 5429 5428 6448 6449 6500 6499
8 5378 5379 5430 5429 6449 6450 6501 6500
8 5379 5380 5431 5430 6450 6451 6502 6501
8 5380 5381 5432 5431 6451 6452 6503 6502
8 5381 5382 5433 5432 6452 6453 6504 6503
8 5382 5383 5434 5433 6453 6454 6505 6504
8 5383 5384 5435 5434 6454 6455 6506 6505
8 5384 5385 5436 5435 6455 6456 6507 6506
8 5385 5386 5437 5436 6456 6457 6508 6507
8 5386 5387 5438 5437 6457 6458 6509 6508
8 5387 5388 5439 5438 6458 6459 6510 6509
8 5388 5389 5440 5439 6459 6460 6511 6510
8 5389 5390 5441 5440 6460 6461 6512 6511
8 5390 5391 5442 5441 6461 6462 6513 6512
8 5391 5392 5443 5442 6462 6463 6514 6513
8 5392 5393 5444 5443 6463 6464 6515 6514
8 5393 5394 5445 5444 6464 6465 6516 6515
8 5394 5395 5446 5445 6465 6466 6517 6516
8 5395 5396 5447 5446 6466 6467 6518 6517
8 5396 5397 5448 5447 6467 6468 6519 6518
8 5397 5398 5449 5448 6468 6469 6520 6519
8 5398 5399 5450 5449 6469 6470 6521 6520
8 5399 5400 5451 5450 6470 6471 6522 6521
8 5400 5401 5452 5451 6471 6472 6523 6522
8 5401 5402 5453 5452 6472 6473 6524 6523
8 5402 5403 5454 5453 6473 6474 6525 6524
8 5403 5404 5455 5454 6474 6475 6526 6525
8 5404 5405 5456 5455 6475 6476 6527 6526
8 5406 5407 5458 5457 6477 6478 6529 6528
8 5407 5408 5459 5458 6478 6479 6530 6529
8 5408 5409 5460 5459 6479 6480 6531 6530
8 5409 5410 5461 5460 6480 6481 6532 6531
8 5410 5411 5462 5461 6481 6482 6533 6532
8 5411 5412 5463 5462 6482 6483 6534 6533
8 5412 5413 5464 5463 6483 6484 6535 6534
8 5413 5414 5465 5464 6484 6485 6536 6535
8 5414 5415 5466 5465 6485 6486 6537 6536
8 5415 5416 5467 5466 6486 6487 6538 6537
8 5416 5417 5468 5467 6487 6488 6539 6538
8 5417 5418 5469 5468 6488 6489 6540 6539
8 5418 5419 5470 5469 6489 6490 6541 6540
8 5419 5420 5471 5470 6490 6491 6542 6541
8 5420 5421 5472 5471 6491 6492 6543 6542
8 5421 5422 5473 5472 6492 6493 6544 6543
8 5422 5423 5474 5473 6493 6494 6545 6544
8 5423 5424 5475 5474 6494 6495 6546 6545
8 5424 5425 5476 5475 6495 6496 6547 6546
8 5425 5426 5477 5476 6496 6497 6548 6547
8 5426 5427 5478 5477 6497 6498 6549 6548
8 5427 5428 5479 5478 6498 6499 6550 6549
8 5428 5429 5480 5479 6499 6500 6551 6550
8 5429 5430 5481 5480 6500 6501 6552 6551
8 5430 5431 5482 5481 6501 6502 6553 6552
8 5431 5432 5483 5482 6502 6503 6554 6553
8 5432 5433 5484 5483 6503 6504 6555 6554
8 5433 5434 5485 5484 6504 6505 6556 6555
8 5434 5435 5486 5485 6505 6506 6557 6556
8 5435 5436 5487 5486 6506 6507 6558 6557
8 5436 5437 5488 5487 6507 6508 6559 6558
8 5437 5438 5489 5488 6508 6509 6560 6559
8 5438 5439 5490 5489 6509 6510 6561 6560
8 5439 5440 5491 5490 6510 6511 6562 6561
8 5440 5441 5492 5491 6511 6512 6563 6562
8 5441 5442 5493 5492 6512 6513 6564 6563
8 5442 5443 5494 5493 6513 6514 6565 6564
8 5443 5444 5495 5494 6514 6515 6566 6565
8 5444 5445 5496 5495 6515 6516 6567 6566
8 5445 5446 5497 5496 6516 6517 6568 6567
8 5446 5447 5498 5497 6517 6518 6569 6568
8 5447 5448 5499 5498 6518 6519 6570 6569
8 5448 5449 5500 5499 6519 6520 6571 6570
8 5449 5450 5501 5500 6520 6521 6572 6571
8 5450 5451 5502 5501 6521 6522 6573 6572
8 5451 5452 5503 5502 6522 6523 6574 6573
8 5452 5453 5504 5503 6523 6524 6575 6574
8 5453 5454 5505 5504 6524 6525 6576 6575
8 5454 5455 5506 5505 6525 6526 6577 6576
8 5455 5456 5507 5506 6526 6527 6578 6577
8 5457 5458 5509 5508 6528 6529 6580 6579
8 5458 5459 5510 5509 6529 6530 6581 6580
8 5459 5460 5511 5510 6530 6531 6582 6581
8 5460 5461 5512 5511 6531 6532 6583 6582
8 5461 5462 5513 5512 6532 6533 6584 6583
8 5462 5463 5514 5513 6533 6534 6585 6584
8 5463 5464 5515 5514 6534 6535 6586 6585
8 5464 5465 5516 5515 6535 6536 6587 6586
8 5465 5466 5517 5516 6536 6537 6588 6587
8 5466 5467 5518 5517 6537 6538 6589 6588
8 5467 5468 5519 5518 6538 6539 6590 6589
8 5468 5469 5520 5519 6539 6540 6591 6590
8 5469 5470 5521 5520 6540 6541 6592 6591
8 5470 5471 5522 5521 6541 6542 6593 6592
8 5471 5472 5523 5522 6542 6543 6594 6593
8 5472 5473 5524 5523 6543 6544 6595 6594
8 5473 5474 5525 5524 6544 6545 6596 6595
8 5474 5475 5526 5525 6545 6546 6597 6596
8 5475 5476 5527 5526 6546 6547 6598 6597
8 5476 5477 5528 5527 6547 6548 6599 6598
8 5477 5478 5529 5528 6548 6549 6600 6599
8 5478 5479 5530 5529 6549 6550 6601 6600
8 5479 5480 5531 5530 6550 6551 6602 6601
8 5480 5481 5532 5531 6551 6552 6603 6602
8 5481 5482 5533 5532 6552 6553 6604 6603
8 5482 5483 5534 5533 6553 6554 6605 6604
8 5483 5484 5535 5534 6554 6555 6606 6605
8 5484 5485 5536 5535 6555 6556 6607 6606
8 5485 5486 5537 5536 6556 6557 6608 6607
8 5486 5487 5538 5537 6557 6558 6609 6608
8 5487 5488 5539 5538 6558 6559 6610 6609
8 5488 5489 5540 5539 6559 6560 6611 6610
8 5489 5490 5541 5540 6560 6561 6612 6611
8 5490 5491 5542 5541 6561 6562 6613 6612
8 5491 5492 5543 5542 6562 6563 6614 6613
8 5492 5493 5544 5543 6563 6564 6615 6614
8 5493 5494 5545 5544 6564 6565 6616 6615
8 5494 5495 5546 5545 6565 6566 6617 6616
8 5495 5496 5547 5546 6566 6567 6618 6617
8 5496 5497 5548 5547 6567 6568 6619 6618
8 5497 5498 5549 5548 6568 6569 6620 6619
8 5498 5499 5550 5549 6569 6570 6621 6620
8 5499 5500 5551 5550 6570 6571 6622 6621
8 5500 5501 5552 5551 6571 6572 6623 6622
8 5501 5502 5553 5552 6572 6573 6624 6623
8 5502 5503 5554 5553 6573 6574 6625 6624
8 5503 5504 5555 5554 6574 6575 6626 6625
8 5504 5505 5556 5555 6575 6576 6627 6626
8 5505 5506 5557 5556 6576 6577 6628 6627
8 5506 5507 5558 5557 6577 6578 6629 6628
8 5508 5509 5560 5559 6579 6580 6631 6630
8 5509 5510 5561 5560 6580 6581 6632 6631
8 5510 5511 5562 5561 6581 6582 6633 6632
8 5511 5512 5563 5562 6582 6583 6634 6633
8 5512 5513 5564 5563 6583 6584 6635 6634
8 5513 5514 5565 5564 6584 6585 6636 6635
8 5514 5515 5566 5565 6585 6586 6637 6636
8 5515 5516 5567 5566 6586 6587 6638 6637
8 5516 5517 5568 5567 6587 6588 6639 6638
8 5517 5518 5569 5568 6588 6589 6640 6639
8 5518 5519 5570 5569 6589 6590 6641 6640
8 5519 5520 5571 5570 6590 6591 6642 6641
8 5520 5521 5572 5571 6591 6592 6643 6642
8 5521 5522 5573 5572 6592 6593 6644 6643
8 5522 5523 5574 5573 6593 6594 6645 6644
8 5523 5524 5575 5574 6594 6595 6646 6645
8 5524 5525 5576 5575 6595 6596 6647 6646
8 5525 5526 5577 5576 6596 6597 6648 6647
8 5526 5527 5578 5577 6597 6598 6649 6648
8 5527 5528 5579 5578 6598 6599 6650 6649
8 5528 5529 5580 5579 6599 6600 6651 6650
8 5529 5530 5581 5580 6600 6601 6652 6651
8 5530 5531 5582 5581 6601 6602 6653 6652
8 5531 5532 5583 5582 6602 6603 6654 6653
8 5532 5533 5584 5583 6603 6604 6655 6654
8 5533 5534 5585 5584 6604 6605 6656 6655
8 5534 5535 5586 5585 6605 6606 6657 6656
8 5535 5536 5587 5586 6606 6607 6658 6657
8 5536 5537 5588 5587 6607 6608 6659 6658
8 5537 5538 5589 5588 6608 6609 6660 6659
8 5538 5539 5590 5589 6609 6610 6661 6660
8 5539 5540 5591 5590 6610 6611 6662 6661
8 5540 5541 5592 5591 6611 6612 6663 6662
8 5541 5542 5593 5592 6612 6613 6664 6663
8 5542 5543 5594 5593 6613 6614 6665 6664
8 5543 5544 5595 5594 6614 6615 6666 6665
8 5544 5545 5596 5595 6615 6616 6667 6666
8 5545 5546 5597 5596 6616 6617 6668 6667
8 5546 5547 5598 5597 6617 6618 6669 6668
8 5547 5548 5599 5598 6618 6619 6670 6669
8 5548 5549 5600 5599 6619 6620 6671 6670
8 5549 5550 5601 5600 6620 6621 6672 6671
8 5550 5551 5602 5601 6621 6622 6673 6672
8 5551 5552 5603 5602 6622 6623 6674 6673
8 5552 5553 5604 5603 6623 6624 6675 6674
8 5553 5554 5605 5604 6624 6625 6676 6675
8 5554 5555 5606 5605 6625 6626 6677 6676
8 5555 5556 5607 5606 6626 6627 6678 6677
8 5556 5557 5608 5607 6627 6628 6679 6678
8 5557 5558 5609 5608 6628 6629 6680 6679
8 5559 5560 5611 5610 6630 6631 6682 6681
8 5560 5561 5612 5611 6631 6632 6683 6682
8 5561 5562 5613 5612 6632 6633 6684 6683
8 5562 5563 5614 5613 6633 6634 6685 6684
8 5563 5564 5615 5614 6634 6635 6686 6685
8 5564 5565 5616 5615 6635 6636 6687 6686
8 5565 5566 5617 5616 6636 6637 6688 6687
8 5566 5567 5618 5617 6637 6638 6689 6688
8 5567 5568 5619 5618 6638 6639 6690 6689
8 5568 5569 5620 5619 6639 6640 6691 6690
8 5569 5570 5621 5620 6640 6641 6692 6691
8 5570 5571 5622 5621 6641 6642 6693 6692
8 5571 5572 5623 5622 6642 6643 6694 6693
8 5572 5573 5624 5623 6643 6644 6695 6694
8 5573 5574 5625 5624 6644 6645 6696 6695
8 5574 5575 5626 5625 6645 6646 6697 6696
8 5575 5576 5627 5626 6646 6647 6698 6697
8 5576 5577 5628 5627 6647 6648 6699 6698
8 5577 5578 5629 5628 6648 6649 6700 6699
8 5578 5579 5630 5629 6649 6650 6701 6700
8 5579 5580 5631 5630 6650 6651 6702 6701
8 5580 5581 5632 5631 6651 6652 6703 6702
8 5581 5582 5633 5632 6652 6653 6704 6703
8 5582 5583 5634 5633 6653 6654 6705 6704
8 5583 5584 5635 5634 6654 6655 6706 6705
8 5584 5585 5636 5635 6655 6656 6707 6706
8 5585 5586 5637 5636 6656 6657 6708 6707
8 5586 5587 5638 5637 6657 6658 6709 6708
8 5587 5588 5639 5638 6658 6659 6710 6709
8 5588 5589 5640 5639 6659 6660 6711 6710
8 5589 5590 5641 5640 6660 6661 6712 6711
8 5590 5591 5642 5641 6661 6662 6713 6712
8 5591 5592 5643 5642 6662 6663 6714 6713
8 5592 5593 5644 5643 6663 6664 6715 6714
8 5593 5594 5645 5644 6664 6665 6716 6715
8 5594 5595 5646 5645 6665 6666 6717 6716
8 5595 5596 5647 5646 6666 6667 6718 6717
8 5596 5597 5648 5647 6667 6668 6719 6718
8 5597 5598 5649 5648 6668 6669 6720 6719
8 5598 5599 5650 5649 6669 6670 6721 6720
8 5599 5600 5651 5650 6670 6671 6722 6721
8 5600 5601 5652 5651 6671 6672 6723 6722
8 5601 5602 5653 5652 6672 6673 6724 6723
8 5602 5603 5654 5653 6673 6674 6725 6724
8 5603 5604 5655 5654 6674 6675 6726 6725
8 5604 5605 5656 5655 6675 6676 6727 6726
8 5605 5606 5657 5656 6676 6677 6728 6727
8 5606 5607 5658 5657 6677 6678 6729 6728
8 5607 5608 5659 5658 6678 6679 6730 6729
8 5608 5609 5660 5659 6679 6680 6731 6730
8 5610 5611 5662 5661 6681 6682 6733 6732
8 5611 5612 5663 5662 6682 6683 6734 6733
8 5612 5613 5664 5663 6683 6684 6735 6734
8 5613 5614 5665 5664 6684 6685 6736 6735
8 5614 5615 5666 5665 6685 6686 6737 6736
8 5615 5616 5667 5666 6686 6687 6738 6737
8 5616 5617 5668 5667 6687 6688 6739 6738
8 5617 5618 5669 5668 6688 6689 6740 6739
8 5618 5619 5670 5669 6689 6690 6741 6740
8 5619 5620 5671 5670 6690 6691 6742 6741
8 5620 5621 5672 5671 6691 6692 6743 6742
8 5621 5622 5673 5672 6692 6693 6744 6743
8 5622 5623 5674 5673 6693 6694 6745 6744
8 5623 5624 5675 5674 6694 6695 6746 6745
8 5624 5625 5676 5675 6695 6696 6747 6746
8 5625 5626 5677 5676 6696 6697 6748 6747
8 5626 5627 5678 5677 6697 6698 6749 6748
8 5627 5628 5679 5678 6698 6699 6750 6749
8 5628 5629 5680 5679 6699 6700 6751 6750
8 5629 5630 5681 5680 6700 6701 6752 6751
8 5630 5631 5682 5681 6701 6702 6753 6752
8 5631 5632 5683 5682 6702 6703 6754 6753
8 5632 5633 5684 5683 6703 6704 6755 6754
8 5633 5634 5685 5684 6704 6705 6756 6755
8 5634 5635 5686 5685 6705 6706 6757 6756
8 5635 5636 5687 5686 6706 6707 6758 6757
8 5636 5637 5688 5687 6707 6708 6759 6758
8 5637 5638 5689 5688 6708 6709 6760 6759
8 5638 5639 5690 5689 6709 6710 6761 6760
8 5639 5640 5691 5690 6710 6711 6762 6761
8 5640 5641 5692 5691 6711 6712 6763 6762
8 5641 5642 5693 5692 6712 6713 6764 6763
8 5642 5643 5694 5693 6713 6714 6765 6764
8 5643 5644 5695 5694 6714 6715 6766 6765
8 5644 5645 5696 5695 6715 6716 6767 6766
8 5645 5646 5697 5696 6716 6717 6768 6767
8 5646 5647 5698 5697 6717 6718 6769 6768
8 5647 5648 5699 5698 6718 6719 6770 6769
8 5648 5649 5700 5699 6719 6720 6771 6770
8 5649 5650 5701 5700 6720 6721 6772 6771
8 5650 5651 5702 5701 6721 6722 6773 6772
8 5651 5652 5703 5702 6722 6723 6774 6773
8 5652 5653 5704 5703 6723 6724 6775 6774
8 5653 5654 5705 5704 6724 6725 6776 6775
8 5654 5655 5706 5705 6725 6726 6777 6776
8 5655 5656 5707 5706 6726 6727 6778 6777
8 5656 5657 5708 5707 6727 6728 6779 6778
8 5657 5658 5709 5708 6728 6729 6780 6779
8 5658 5659 5710 5709 6729 6730 6781 6780
8 5659 5660 5711 5710 6730 6731 6782 6781
8 5661 5662 5713 5712 6732 6733 6784 6783
8 5662 5663 5714 5713 6733 6734 6785 6784
8 5663 5664 5715 5714 6734 6735 6786 6785
8 5664 5665 5716 5715 6735 6736 6787 6786
8 5665 5666 5717 5716 6736 6737 6788 6787
8 5666 5667 5718 5717 6737 6738 6789 6788
8 5667 5668 5719 5718 6738 6739 6790 6789
8 5668 5669 5720 5719 6739 6740 6791 6790
8 5669 5670 5721 5720 6740 6741 6792 6791
8 5670 5671 5722 5721 6741 6742 6793 6792
8 5671 5672 5723 5722 6742 6743 6794 6793
8 5672 5673 5724 5723 6743 6744 6795 6794
8 5673 5674 5725 5724 6744 6745 6796 6795
8 5674 5675 5726 5725 6745 6746 6797 6796
8 5675 5676 5727 5726 6746 6747 6798 6797
8 5676 5677 5728 5727 6747 6748 6799 6798
8 5677 5678 5729 5728 6748 6749 6800 6799
8 5678 5679 5730 5729 6749 6750 6801 6800
8 5679 5680 5731 5730 6750 6751 6802 6801
8 5680 5681 5732 5731 6751 6752 6803 6802
8 5681 5682 5733 5732 6752 6753 6804 6803
8 5682 5683 5734 5733 6753 6754 6805 6804
8 5683 5684 5735 5734 6754 6755 6806 6805
8 5684 5685 5736 5735 6755 6756 6807 6806
8 5685 5686 5737 5736 6756 6757 6808 6807
8 5686 5687 5738 5737 6757 6758 6809 6808
8 5687 5688 5739 5738 6758 6759 6810 6809
8 5688 5689 5740 5739 6759 6760 6811 6810
8 5689 5690 5741 5740 6760 6761 6812 6811
8 5690 5691 5742 5741 6761 6762 6813 6812
8 5691 5692 5743 5742 6762 6763 6814 6813
8 5692 5693 5744 5743 6763 6764 6815 6814
8 5693 5694 5745 5744 6764 6765 6816 6815
8 5694 5695 5746 5745 6765 6766 6817 6816
8 5695 5696 5747 5746 6766 6767 6818 6817
8 5696 5697 5748 5747 6767 6768 6819 6818
8 5697 5698 5749 5748 6768 6769 6820 6819
8 5698 5699 5750 5749 6769 6770 6821 6820
8 5699 5700 5751 5750 6770 6771 6822 6821
8 5700 5701 5752 5751 6771 6772 6823 6822
8 5701 5702 5753 5752 6772 6773 6824 6823
8 5702 5703 5754 5753 6773 6774 6825 6824
8 5703 5704 5755 5754 6774 6775 6826 6825
8 5704 5705 5756 5755 6775 6776 6827 6826
8 5705 5706 5757 5756 6776 6777 6828 6827
8 5706 5707 5758 5757 6777 6778 6829 6828
8 5707 5708 5759 5758 6778 6779 6830 6829
8 5708 5709 5760 5759 6779 6780 6831 6830
8 5709 5710 5761 5760 6780 6781 6832 6831
8 5710 5711 5762 5761 6781 6782 6833 6832
8 5712 5713 5764 5763 6783 6784 6835 6834
8 5713 5714 5765 5764 6784 6785 6836 6835
8 5714 5715 5766 5765 6785 6786 6837 6836
8 5715 5716 5767 5766 6786 6787 6838 6837
8 5716 5717 5768 5767 6787 6788 6839 6838
8 5717 5718 5769 5768 6788 6789 6840 6839
8 5718 5719 5770 5769 6789 6790 6841 6840
8 5719 5720 5771 5770 6790 6791 6842 6841
8 5720 5721 5772 5771 6791 6792 6843 6842
8 5721 5722 5773 5772 6792 6793 6844 6843
8 5722 5723 5774 5773 6793 6794 6845 6844
8 5723 5724 5775 5774 6794 6795 6846 6845
8 5724 5725 5776 5775 6795 6796 6847 6846
8 5725 5726 5777 5776 6796 6797 6848 6847
8 5726 5727 5778 5777 6797 6798 6849 6848
8 5727 5728 5779 5778 6798 6799 6850 6849
8 5728 5729 5780 5779 6799 6800 6851 6850
8 5729 5730 5781 5780 6800 6801 6852 6851
8 5730 5731 5782 5781 6801 6802 6853 6852
8 5731 5732 5783 5782 6802 6803 6854 6853
8 5732 5733 5784 5783 6803 6804 6855 6854
8 5733 5734 5785 5784 6804 6805 6856 6855
8 5734 5735 5786 5785 6805 6806 6857 6856
8 5735 5736 5787 5786 6806 6807 6858 6857
8 5736 5737 5788 5787 6807 6808 6859 6858
8 5737 5738 5789 5788 6808 6809 6860 6859
8 5738 5739 5790 5789 6809 6810 6861 6860
8 5739 5740 5791 5790 6810 6811 6862 6861
8 5740 5741 5792 5791 6811 6812 6863 6862
8 5741 5742 5793 5792 6812 6813 6864 6863
8 5742 5743 5794 5793 6813 6814 6865 6864
8 5743 5744 5795 5794 6814 6815 6866 6865
8 5744 5745 5796 5795 6815 6816 6867 6866
8 5745 5746 5797 5796 6816 6817 6868 6867
8 5746 5747 5798 5797 6817 6818 6869 6868
8 5747 5748 5799 5798 6818 6819 6870 6869
8 5748 5749 5800 5799 6819 6820 6871 6870
8 5749 5750 5801 5800 6820 6821 6872 6871
8 5750 5751 5802 5801 6821 6822 6873 6872
8 5751 5752 5803 5802 6822 6823 6874 6873
8 5752 5753 5804 5803 6823 6824 6875 6874
8 5753 5754 5805 5804 6824 6825 6876 6875
8 5754 5755 5806 5805 6825 6826 6877 6876
8 5755 5756 5807 5806 6826 6827 6878 6877
8 5756 5757 5808 5807 6827 6828 6879 6878
8 5757 5758 5809 5808 6828 6829 6880 6879
8 5758 5759 5810 5809 6829 6830 6881 6880
8 5759 5760 5811 5810 6830 6831 6882 6881
8 5760 5761 5812 5811 6831 6832 6883 6882
8 5761 5762 5813 5812 6832 6833 6884 6883
8 5763 5764 5815 5814 6834 6835 6886 6885
8 5764 5765 5816 5815 6835 6836 6887 6886
8 5765 5766 5817 5816 6836 6837 6888 6887
8 5766 5767 5818 5817 6837 6838 6889 6888
8 5767 5768 5819 5818 6838 6839 6890 6889
8 5768 5769 5820 5819 6839 6840 6891 6890
8 5769 5770 5821 5820 6840 6841 6892 6891
8 5770 5771 5822 5821 6841 6842 6893 6892
8 5771 5772 5823 5822 6842 6843 6894 6893
8 5772 5773 5824 5823 6843 6844 6895 6894
8 5773 5774 5825 5824 6844 6845 6896 6895
8 5774 5775 5826 5825 6845 6846 6897 6896
8 5775 5776 5827 5826 6846 6847 6898 6897
8 5776 5777 5828 5827 6847 6848 6899 6898
8 5777 5778 5829 5828 6848 6849 6900 6899
8 5778 5779 5830 5829 6849 6850 6901 6900
8 5779 5780 5831 5830 6850 6851 6902 6901
8 5780 5781 5832 5831 6851 6852 6903 6902
8 5781 5782 5833 5832 6852 6853 6904 6903
8 5782 5783 5834 5833 6853 6854 6905 6904
8 5783 5784 5835 5834 6854 6855 6906 6905
8 5784 5785 5836 5835 6855 6856 6907 6906
8 5785 5786 5837 5836 6856 6857 6908 6907
8 5786 5787 5838 5837 6857 6858 6909 6908
8 5787 5788 5839 5838 6858 6859 6910 6909
8 5788 5789 5840 5839 6859 6860 6911 6910
8 5789 5790 5841 5840 6860 6861 6912 6911
8 5790 5791 5842 5841 6861 6862 6913 6912
8 5791 5792 5843 5842 6862 6863 6914 6913
8 5792 5793 5844 5843 6863 6864 6915 6914
8 5793 5794 5845 5844 6864 6865 6916 6915
8 5794 5795 5846 5845 6865 6866 6917 6916
8 5795 5796 5847 5846 6866 6867 6918 6917
8 5796 5797 5848 5847 6867 6868 6919 6918
8 5797 5798 5849 5848 6868 6869 6920 6919
8 5798 5799 5850 5849 6869 6870 6921 6920
8 5799 5800 5851 5850 6870 6871 6922 6921
8 5800 5801 5852 5851 6871 6872 6923 6922
8 5801 5802 5853 5852 6872 6873 6924 6923
8 5802 5803 5854 5853 6873 6874 6925 6924
8 5803 5804 5855 5854 6874 6875 6926 6925
8 5804 5805 5856 5855 6875 6876 6927 6926
8 5805 5806 5857 5856 6876 6877 6928 6927
8 5806 5807 5858 5857 6877 6878 6929 6928
8 5807 5808 5859 5858 6878 6879 6930 6929
8 5808 5809 5860 5859 6879 6880 6931 6930
8 5809 5810 5861 5860 6880 6881 6932 6931
8 5810 5811 5862 5861 6881 6882 6933 6932
8 5811 5812 5863 5862 6882 6883 6934 6933
8 5812 5813 5864 5863 6883 6884 6935 6934
8 5814 5815 5866 5865 6885 6886 6937 6936
8 5815 5816 5867 5866 6886 6887 6938 6937
8 5816 5817 5868 5867 6887 6888 6939 6938
8 5817 5818 5869 5868 6888 6889 6940 6939
8 5818 5819 5870 5869 6889 6890 6941 6940
8 5819 5820 5871 5870 6890 6891 6942 6941
8 5820 5821 5872 5871 6891 6892 6943 6942
8 5821 5822 5873 5872 6892 6893 6944 6943
8 5822 5823 5874 5873 6893 6894 6945 6944
8 5823 5824 5875 5874 6894 6895 6946 6945
8 5824 5825 5876 5875 6895 6896 6947 6946
8 5825 5826 5877 5876 6896 6897 6948 6947
8 5826 5827 5878 5877 6897 6898 6949 6948
8 5827 5828 5879 5878 6898 6899 6950 6949
8 5828 5829 5880 5879 6899 6900 6951 6950
8 5829 5830 5881 5880 6900 6901 6952 6951
8 5830 5831 5882 5881 6901 6902 6953 6952
8 5831 5832 5883 5882 6902 6903 6954 6953
8 5832 5833 5884 5883 6903 6904 6955 6954
8 5833 5834 5885 5884 6904 6905 6956 6955
8 5834 5835 5886 5885 6905 6906 6957 6956
8 5835 5836 5887 5886 6906 6907 6958 6957
8 5836 5837 5888 5887 6907 6908 6959 6958
8 5837 5838 5889 5888 6908 6909 6960 6959
8 5838 5839 5890 5889 6909 6910 6961 6960
8 5839 5840 5891 5890 6910 6911 6962 6961
8 5840 5841 5892 5891 6911 6912 6963 6962
8 5841 5842 5893 5892 6912 6913 6964 6963
8 5842 5843 5894 5893 6913 6914 6965 6964
8 5843 5844 5895 5894 6914 6915 6966 6965
8 5844 5845 5896 5895 6915 6916 6967 6966
8 5845 5846 5897 5896 6916 6917 6968 6967
8 5846 5847 5898 5897 6917 6918 6969 6968
8 5847 5848 5899 5898 6918 6919 6970 6969
8 5848 5849 5900 5899 6919 6920 6971 6970
8 5849 5850 5901 5900 6920 6921 6972 6971
8 5850 5851 5902 5901 6921 6922 6973 6972
8 5851 5852 5903 5902 6922 6923 6974 6973
8 5852 5853 5904 5903 6923 6924 6975 6974
8 5853 5854 5905 5904 6924 6925 6976 6975
8 5854 5855 5906 5905 6925 6926 6977 6976
8 5855 5856 5907 5906 6926 6927 6978 6977
8 5856 5857 5908 5907 6927 6928 6979 6978
8 5857 5858 5909 5908 6928 6929 6980 6979
8 5858 5859 5910 5909 6929 6930 6981 6980
8 5859 5860 5911 5910 6930 6931 6982 6981
8 5860 5861 5912 5911 6931 6932 6983 6982
8 5861 5862 5913 5912 6932 6933 6984 6983
8 5862 5863 5914 5913 6933 6934 6985 6984
8 5863 5864 5915 5914 6934 6935 6986 6985
8 5865 5866 5917 5916 6936 6937 6988 6987
8 5866 5867 5918 5917 6937 6938 6989 6988
8 5867 5868 5919 5918 6938 6939 6990 6989
8 5868 5869 5920 5919 6939 6940 6991 6990
8 5869 5870 5921 5920 6940 6941 6992 6991
8 5870 5871 5922 5921 6941 6942 6993 6992
8 5871 5872 5923 5922 6942 6943 6994 6993
8 5872 5873 5924 5923 6943 6944 6995 6994
8 5873 5874 5925 5924 6944 6945 6996 6995
8 5874 5875 5926 5925 6945 6946 6997 6996
8 5875 5876 5927 5926 6946 6947 6998 6997
8 5876 5877 5928 5927 6947 6948 6999 6998
8 5877 5878 5929 5928 6948 6949 7000 6999
8 5878 5879 5930 5929 6949 6950 7001 7000
8 5879 5880 5931 5930 6950 6951 7002 7001
8 5880 5881 5932 5931 6951 6952 7003 7002
8 5881 5882 5933 5932 6952 6953 7004 7003
8 5882 5883 5934 5933 6953 6954 7005 7004
8 5883 5884 5935 5934 6954 6955 7006 7005
8 5884 5885 5936 5935 6955 6956 7007 7006
8 5885 5886 5937 5936 6956 6957 7008 7007
8 5886 5887 5938 5937 6957 6958 7009 7008
8 5887 5888 5939 5938 6958 6959 7010 7009
8 5888 5889 5940 5939 6959 6960 7011 7010
8 5889 5890 5941 5940 6960 6961 7012 7011
8 5890 5891 5942 5941 6961 6962 7013 7012
8 5891 5892 5943 5942 6962 6963 7014 7013
8 5892 5893 5944 5943 6963 6964 7015 7014
8 5893 5894 5945 5944 6964 6965 7016 7015
8 5894 5895 5946 5945 6965 6966 7017 7016
8 5895 5896 5947 5946 6966 6967 7018 7017
8 5896 5897 5948 5947 6967 6968 7019 7018
8 5897 5898 5949 5948 6968 6969 7020 7019
8 5898 5899 5950 5949 6969 6970 7021 7020
8 5899 5900 5951 5950 6970 6971 7022 7021
8 5900 5901 5952 5951 6971 6972 7023 7022
8 5901 5902 5953 5952 6972 6973 7024 7023
8 5902 5903 5954 5953 6973 6974 7025 7024
8 5903 5904 5955 5954 6974 6975 7026 7025
8 5904 5905 5956 5955 6975 6976 7027 7026
8 5905 5906 5957 5956 6976 6977 7028 7027
8 5906 5907 5958 5957 6977 6978 7029 7028
8 5907 5908 5959 5958 6978 6979 7030 7029
8 5908 5909 5960 5959 6979 6980 7031 7030
8 5909 5910 5961 5960 6980 6981 7032 7031
8 5910 5911 5962 5961 6981 6982 7033 7032
8 5911 5912 5963 5962 6982 6983 7034 7033
8 5912 5913 5964 5963 6983 6984 7035 7034
8 5913 5914 5965 5964 6984 6985 7036 7035
8 5914 5915 5966 5965 6985 6986 7037 7036
8 5916 5917 5968 5967 6987 6988 7039 7038
8 5917 5918 5969 5968 6988 6989 7040 7039
8 5918 5919 5970 5969 6989 6990 7041 7040
8 5919 5920 5971 5970 6990 6991 7042 7041
8 5920 5921 5972 5971 6991 6992 7043 7042
8 5921 5922 5973 5972 6992 6993 7044 7043
8 5922 5923 5974 5973 6993 6994 7045 7044
8 5923 5924 5975 5974 6994 6995 7046 7045
8 5924 5925 5976 5975 6995 6996 7047 7046
8 5925 5926 5977 5976 6996 6997 7048 7047
8 5926 5927 5978 5977 6997 6998 7049 7048
8 5927 5928 5979 5978 6998 6999 7050 7049
8 5928 5929 5980 5979 6999 7000 7051 7050
8 5929 5930 5981 5980 7000 7001 7052 7051
8 5930 5931 5982 5981 7001 7002 7053 7052
8 5931 5932 5983 5982 7002 7003 7054 7053
8 5932 5933 5984 5983 7003 7004 7055 7054
8 5933 5934 5985 5984 7004 7005 7056 7055
8 5934 5935 5986 5985 7005 7006 7057 7056
8 5935 5936 5987 5986 7006 7007 7058 7057
8 5936 5937 5988 5987 7007 7008 7059 7058
8 5937 5938 5989 5988 7008 7009 7060 7059
8 5938 5939 5990 5989 7009 7010 7061 7060
8 5939 5940 5991 5990 7010 7011 7062 7061
8 5940 5941 5992 5991 7011 7012 7063 7062
8 5941 5942 5993 5992 7012 7013 7064 7063
8 5942 5943 5994 5993 7013 7014 7065 7064
8 5943 5944 5995 5994 7014 7015 7066 7065
8 5944 5945 5996 5995 7015 7016 7067 7066
8 5945 5946 5997 5996 7016 7017 7068 7067
8 5946 5947 5998 5997 7017 7018 7069 7068
8 5947 5948 5999 5998 7018 7019 7070 7069
8 5948 5949 6000 5999 7019 7020 7071 7070
8 5949 5950 6001 6000 7020 7021 7072 7071
8 5950 5951 6002 6001 7021 7022 7073 7072
8 5951 5952 6003 6002 7022 7023 7074 7073
8 5952 5953 6004 6003 7023 7024 7075 7074
8 5953 5954 6005 6004 7024 7025 7076 7075
8 5954 5955 6006 6005 7025 7026 7077 7076
8 5955 5956 6007 6006 7026 7027 7078 7077
8 5956 5957 6008 6007 7027 7028 7079 7078
8 5957 5958 6009 6008 7028 7029 7080 7079
8 5958 5959 6010 6009 7029 7030 7081 7080
8 5959 5960 6011 6010 7030 7031 7082 7081
8 5960 5961 6012 6011 7031 7032 7083 7082
8 5961 5962 6013 6012 7032 7033 7084 7083
8 5962 5963 6014 6013 7033 7034 7085 7084
8 5963 5964 6015 6014 7034 7035 7086 7085
8 5964 5965 6016 6015 7035 7036 7087 7086
8 5965 5966 6017 6016 7036 7037 7088 7087
8 5967 5968 6019 6018 7038 7039 7090 7089
8 5968 5969 6020 6019 7039 7040 7091 7090
8 5969 5970 6021 6020 7040 7041 7092 7091
8 5970 5971 6022 6021 7041 7042 7093 7092
8 5971 5972 6023 6022 7042 7043 7094 7093
8 5972 5973 6024 6023 7043 7044 7095 7094
8 5973 5974 6025 6024 7044 7045 7096 7095
8 5974 5975 6026 6025 7045 7046 7097 7096
8 5975 5976 6027 6026 7046 7047 7098 7097
8 5976 5977 6028 6027 7047 7048 7099 7098
8 5977 5978 6029 6028 7048 7049 7100 7099
8 5978 5979 6030 6029 7049 7050 7101 7100
8 5979 5980 6031 6030 7050 7051 7102 7101
8 5980 5981 6032 6031 7051 7052 7103 7102
8 5981 5982 6033 6032 7052 7053 7104 7103
8 5982 5983 6034 6033 7053 7054 7105 7104
8 5983 5984 6035 6034 7054 7055 7106 7105
8 5984 5985 6036 6035 7055 7056 7107 7106
8 5985 5986 6037 6036 7056 7057 7108 7107
8 5986 5987 6038 6037 7057 7058 7109 7108
8 5987 5988 6039 6038 7058 7059 7110 7109
8 5988 5989 6040 6039 7059 7060 7111 7110
8 5989 5990 6041 6040 7060 7061 7112 7111
8 5990 5991 6042 6041 7061 7062 7113 7112
8 5991 5992 6043 6042 7062 7063 7114 7113
8 5992 5993 6044 6043 7063 7064 7115 7114
8 5993 5994 6045 6044 7064 7065 7116 7115
8 5994 5995 6046 6045 7065 7066 7117 7116
8 5995 5996 6047 6046 7066 7067 7118 7117
8 5996 5997 6048 6047 7067 7068 7119 7118
8 5997 5998 6049 6048 7068 7069 7120 7119
8 5998 5999 6050 6049 7069 7070 7121 7120
8 5999 6000 6051 6050 7070 7071 7122 7121
8 6000 6001 6052 6051 7071 7072 7123 7122
8 6001 6002 6053 6052 7072 7073 7124 7123
8 6002 6003 6054 6053 7073 7074 7125 7124
8 6003 6004 6055 6054 7074 7075 7126 7125
8 6004 6005 6056 6055 7075 7076 7127 7126
8 6005 6006 6057 6056 7076 7077 7128 7127
8 6006 6007 6058 6057 7077 7078 7129 7128
8 6007 6008 6059 6058 7078 7079 7130 7129
8 6008 6009 6060 6059 7079 7080 7131 7130
8 6009 6010 6061 6060 7080 7081 7132 7131
8 6010 6011 6062 6061 7081 7082 7133 7132
8 6011 6012 6063 6062 7082 7083 7134 7133
8 6012 6013 6064 6063 7083 7084 7135 7134
8 6013 6014 6065 6064 7084 7085 7136 7135
8 6014 6015 6066 6065 7085 7086 7137 7136
8 6015 6016 6067 6066 7086 7087 7138 7137
8 6016 6017 6068 6067 7087 7088 7139 7138
8 6018 6019 6070 6069 7089 7090 7141 7140
8 6019 6020 6071 6070 7090 7091 7142 7141
8 6020 6021 6072 6071 7091 7092 7143 7142
8 6021 6022 6073 6072 7092 7093 7144 7143
8 6022 6023 6074 6073 7093 7094 7145 7144
8 6023 6024 6075 6074 7094 7095 7146 7145
8 6024 6025 6076 6075 7095 7096 7147 7146
8 6025 6026 6077 6076 7096 7097 7148 7147
8 6026 6027 6078 6077 7097 7098 7149 7148
8 6027 6028 6079 6078 7098 7099 7150 7149
8 6028 6029 6080 6079 7099 7100 7151 7150
8 6029 6030 6081 6080 7100 7101 7152 7151
8 6030 6031 6082 6081 7101 7102 7153 7152
8 6031 6032 6083 6082 7102 7103 7154 7153
8 6032 6033 6084 6083 7103 7104 7155 7154
8 6033 6034 6085 6084 7104 7105 7156 7155
8 6034 6035 6086 6085 7105 7106 7157 7156
8 6035 6036 6087 6086 7106 7107 7158 7157
8 6036 6037 6088 6087 7107 7108 7159 7158
8 6037 6038 6089 6088 7108 7109 7160 7159
8 6038 6039 6090 6089 7109 7110 7161 7160
8 6039 6040 6091 6090 7110 7111 7162 7161
8 6040 6041 6092 6091 7111 7112 7163 7162
8 6041 6042 6093 6092 7112 7113 7164 7163
8 6042 6043 6094 6093 7113 7114 7165 7164
8 6043 6044 6095 6094 7114 7115 7166 7165
8 6044 6045 6096 6095 7115 7116 7167 7166
8 6045 6046 6097 6096 7116 7117 7168 7167
8 6046 6047 6098 6097 7117 7118 7169 7168
8 6047 6048 6099 6098 7118 7119 7170 7169
8 6048 6049 6100 6099 7119 7120 7171 7170
8 6049 6050 6101 6100 7120 7121 7172 7171
8 6050 6051 6102 6101 7121 7122 7173 7172
8 6051 6052 6103 6102 7122 7123 7174 7173
8 6052 6053 6104 6103 7123 7124 7175 7174
8 6053 6054 6105 6104 7124 7125 7176 7175
8 6054 6055 6106 6105 7125 7126 7177 7176
8 6055 6056 6107 6106 7126 7127 7178 7177
8 6056 6057 6108 6107 7127 7128 7179 7178
8 6057 6058 6109 6108 7128 7129 7180 7179
8 6058 6059 6110 6109 7129 7130 7181 7180
8 6059 6060 6111 6110 7130 7131 7182 7181
8 6060 6061 6112 6111 7131 7132 7183 7182
8 6061 6062 6113 6112 7132 7133 7184 7183
8 6062 6063 6114 6113 7133 7134 7185 7184
8 6063 6064 6115 6114 7134 7135 7186 7185
8 6064 6065 6116 6115 7135 7136 7187 7186
8 6065 6066 6117 6116 7136 7137 7188 7187
8 6066 6067 6118 6117 7137 7138 7189 7188
8 6067 6068 6119 6118 7138 7139 7190 7189
8 6069 6070 6121 6120 7140 7141 7192 7191
8 6070 6071 6122 6121 7141 7142 7193 7192
8 6071 6072 6123 6122 7142 7143 7194 7193
8 6072 6073 6124 6123 7143 7144 7195 7194
8 6073 6074 6125 6124 7144 7145 7196 7195
8 6074 6075 6126 6125 7145 7146 7197 7196
8 6075 6076 6127 6126 7146 7147 7198 7197
8 6076 6077 6128 6127 7147 7148 7199 7198
8 6077 6078 6129 6128 7148 7149 7200 7199
8 6078 6079 6130 6129 7149 7150 7201 7200
8 6079 6080 6131 6130 7150 7151 7202 7201
8 6080 6081 6132 6131 7151 7152 7203 7202
8 6081 6082 6133 6132 7152 7153 7204 7203
8 6082 6083 6134 6133 7153 7154 7205 7204
8 6083 6084 6135 6134 7154 7155 7206 7205
8 6084 6085 6136 6135 7155 7156 7207 7206
8 6085 6086 6137 6136 7156 7157 7208 7207
8 6086 6087 6138 6137 7157 7158 7209 7208
8 6087 6088 6139 6138 7158 7159 7210 7209
8 6088 6089 6140 6139 7159 7160 7211 7210
8 6089 6090 6141 6140 7160 7161 7212 7211
8 6090 6091 6142 6141 7161 7162 7213 7212
8 6091 6092 6143 6142 7162 7163 7214 7213
8 6092 6093 6144 6143 7163 7164 7215 7214
8 6093 6094 6145 6144 7164 7165 7216 7215
8 6094 6095 6146 6145 7165 7166 7217 7216
8 6095 6096 6147 6146 7166 7167 7218 7217
8 6096 6097 6148 6147 7167 7168 7219 7218
8 6097 6098 6149 6148 7168 7169 7220 7219
8 6098 6099 6150 6149 7169 7170 7221 7220
8 6099 6100 6151 6150 7170 7171 7222 7221
8 6100 6101 6152 6151 7171 7172 7223 7222
8 6101 6102 6153 6152 7172 7173 7224 7223
8 6102 6103 6154 6153 7173 7174 7225 7224
8 6103 6104 6155 6154 7174 7175 7226 7225
8 6104 6105 6156 6155 7175 7176 7227 7226
8 6105 6106 6157 6156 7176 7177 7228 7227
8 6106 6107 6158 6157 7177 7178 7229 7228
8 6107 6108 6159 6158 7178 7179 7230 7229
8 6108 6109 6160 6159 7179 7180 7231 7230
8 6109 6110 6161 6160 7180 7181 7232 7231
8 6110 6111 6162 6161 7181 7182 7233 7232
8 6111 6112 6163 6162 7182 7183 7234 7233
8 6112 6113 6164 6163 7183 7184 7235 7234
8 6113 6114 6165 6164 7184 7185 7236 7235
8 6114 6115 6166 6165 7185 7186 7237 7236
8 6115 6116 6167 6166 7186 7187 7238 7237
8 6116 6117 6168 6167 7187 7188 7239 7238
8 6117 6118 6169 6168 7188 7189 7240 7239
8 6118 6119 6170 6169 7189 7190 7241 7240
8 6120 6121 6172 6171 7191 7192 7243 7242
8 6121 6122 6173 6172 7192 7193 7244 7243
8 6122 6123 6174 6173 7193 7194 7245 7244
8 6123 6124 6175 6174 7194 7195 7246 7245
8 6124 6125 6176 6175 7195 7196 7247 7246
8 6125 6126 6177 6176 7196 7197 7248 7247
8 6126 6127 6178 6177 7197 7198 7249 7248
8 6127 6128 6179 6178 7198 7199 7250 7249
8 6128 6129 6180 6179 7199 7200 7251 7250
8 6129 6130 6181 6180 7200 7201 7252 7251
8 6130 6131 6182 6181 7201 7202 7253 7252
8 6131 6132 6183 6182 7202 7203 7254 7253
8 6132 6133 6184 6183 7203 7204 7255 7254
8 6133 6134 6185 6184 7204 7205 7256 7255
8 6134 6135 6186 6185 7205 7206 7257 7256
8 6135 6136 6187 6186 7206 7207 7258 7257
8 6136 6137 6188 6187 7207 7208 7259 7258
8 6137 6138 6189 6188 7208 7209 7260 7259
8 6138 6139 6190 6189 7209 7210 7261 7260
8 6139 6140 6191 6190 7210 7211 7262 7261
8 6140 6141 6192 6191 7211 7212 7263 7262
8 6141 6142 6193 6192 7212 7213 7264 7263
8 6142 6143 6194 6193 7213 7214 7265 7264
8 6143 6144 6195 6194 7214 7215 7266 7265
8 6144 6145 6196 6195 7215 7216 7267 7266
8 6145 6146 6197 6196 7216 7217 7268 7267
8 6146 6147 6198 6197 7217 7218 7269 7268
8 6147 6148 6199 6198 7218 7219 7270 7269
8 6148 6149 6200 6199 7219 7220 7271 7270
8 6149 6150 6201 6200 7220 7221 7272 7271
8 6150 6151 6202 6201 7221 7222 7273 7272
8 6151 6152 6203 6202 7222 7223 7274 7273
8 6152 6153 6204 6203 7223 7224 7275 7274
8 6153 6154 6205 6204 7224 7225 7276 7275
8 6154 6155 6206 6205 7225 7226 7277 7276
8 6155 6156 6207 6206 7226 7227 7278 7277
8 6156 6157 6208 6207 7227 7228 7279 7278
8 6157 6158 6209 6208 7228 7229 7280 7279
8 6158 6159 6210 6209 7229 7230 7281 7280
8 6159 6160 6211 6210 7230 7231 7282 7281
8 6160 6161 6212 6211 7231 7232 7283 7282
8 6161 6162 6213 6212 7232 7233 7284 7283
8 6162 6163 6214 6213 7233 7234 7285 7284
8 6163 6164 6215 6214 7234 7235 7286 7285
8 6164 6165 6216 6215 7235 7236 7287 7286
8 6165 6166 6217 6216 7236 7237 7288 7287
8 6166 6167 6218 6217 7237 7238 7289 7288
8 6167 6168 6219 6218 7238 7239 7290 7289
8 6168 6169 6220 6219 7239 7240 7291 7290
8 6169 6170 6221 6220 7240 7241 7292 7291
8 6171 6172 6223 6222 7242 7243 7294 7293
8 6172 6173 6224 6223 7243 7244 7295 7294
8 6173 6174 6225 6224 7244 7245 7296 7295
8 6174 6175 6226 6225 7245 7246 7297 7296
8 6175 6176 6227 6226 7246 7247 7298 7297
8 6176 6177 6228 6227 7247 7248 7299 7298
8 6177 6178 6229 6228 7248 7249 7300 7299
8 6178 6179 6230 6229 7249 7250 7301 7300
8 6179 6180 6231 6230 7250 7251 7302 7301
8 6180 6181 6232 6231 7251 7252 7303 7302
8 6181 6182 6233 6232 7252 7253 7304 7303
8 6182 6183 6234 6233 7253 7254 7305 7304
8 6183 6184 6235 6234 7254 7255 7306 7305
8 6184 6185 6236 6235 7255 7256 7307 7306
8 6185 6186 6237 6236 7256 7257 7308 7307
8 6186 6187 6238 6237 7257 7258 7309 7308
8 6187 6188 6239 6238 7258 7259 7310 7309
8 6188 6189 6240 6239 7259 7260 7311 7310
8 6189 6190 6241 6240 7260 7261 7312 7311
8 6190 6191 6242 6241 7261 7262 7313 7312
8 6191 6192 6243 6242 7262 7263 7314 7313
8 6192 6193 6244 6243 7263 7264 7315 7314
8 6193 6194 6245 6244 7264 7265 7316 7315
8 6194 6195 6246 6245 7265 7266 7317 7316
8 6195 6196 6247 6246 7266 7267 7318 7317
8 6196 6197 6248 6247 7267 7268 7319 7318
8 6197 6198 6249 6248 7268 7269 7320 7319
8 6198 6199 6250 6249 7269 7270 7321 7320
8 6199 6200 6251 6250 7270 7271 7322 7321
8 6200 6201 6252 6251 7271 7272 7323 7322
8 6201 6202 6253 6252 7272 7273 7324 7323
8 6202 6203 6254 6253 7273 7274 7325 7324
8 6203 6204 6255 6254 7274 7275 7326 7325
8 6204 6205 6256 6255 7275 7276 7327 7326
8 6205 6206 6257 6256 7276 7277 7328 7327
8 6206 6207 6258 6257 7277 7278 7329 7328
8 6207 6208 6259 6258 7278 7279 7330 7329
8 6208 6209 6260 6259 7279 7280 7331 7330
8 6209 6210 6261 6260 7280 7281 7332 7331
8 6210 6211 6262 6261 7281 7282 7333 7332
8 6211 6212 6263 6262 7282 7283 7334 7333
8 6212 6213 6264 6263 7283 7284 7335 7334
8 6213 6214 6265 6264 7284 7285 7336 7335
8 6214 6215 6266 6265 7285 7286 7337 7336
8 6215 6216 6267 6266 7286 7287 7338 7337
8 6216 6217 6268 6267 7287 7288 7339 7338
8 6217 6218 6269 6268 7288 7289 7340 7339
8 6218 6219 6270 6269 7289 7290 7341 7340
8 6219 6220 6271 6270 7290 7291 7342 7341
8 6220 6221 6272 6271 7291 7292 7343 7342
8 6222 6223 6274 6273 7293 7294 7345 7344
8 6223 6224 6275 6274 7294 7295 7346 7345
8 6224 6225 6276 6275 7295 7296 7347 7346
8 6225 6226 6277 6276 7296 7297 7348 7347
8 6226 6227 6278 6277 7297 7298 7349 7348
8 6227 6228 6279 6278 7298 7299 7350 7349
8 6228 6229 6280 6279 7299 7300 7351 7350
8 6229 6230 6281 6280 7300 7301 7352 7351
8 6230 6231 6282 6281 7301 7302 7353 7352
8 6231 6232 6283 6282 7302 7303 7354 7353
8 6232 6233 6284 6283 7303 7304 7355 7354
8 6233 6234 6285 6284 7304 7305 7356 7355
8 6234 6235 6286 6285 7305 7306 7357 7356
8 6235 6236 6287 6286 7306 7307 7358 7357
8 6236 6237 6288 6287 7307 7308 7359 7358
8 6237 6238 6289 6288 7308 7309 7360 7359
8 6238 6239 6290 6289 7309 7310 7361 7360
8 6239 6240 6291 6290 7310 7311 7362 7361
8 6240 6241 6292 6291 7311 7312 7363 7362
8 6241 6242 6293 6292 7312 7313 7364 7363
8 6242 6243 6294 6293 7313 7314 7365 7364
8 6243 6244 6295 6294 7314 7315 7366 7365
8 6244 6245 6296 6295 7315 7316 7367 7366
8 6245 6246 6297 6296 7316 7317 7368 7367
8 6246 6247 6298 6297 7317 7318 7369 7368
8 6247 6248 6299 6298 7318 7319 7370 7369
8 6248 6249 6300 6299 7319 7320 7371 7370
8 6249 6250 6301 6300 7320 7321 7372 7371
8 6250 6251 6302 6301 7321 7322 7373 7372
8 6251 6252 6303 6302 7322 7323 7374 7373
8 6252 6253 6304 6303 7323 7324 7375 7374
8 6253 6254 6305 6304 7324 7325 7376 7375
8 6254 6255 6306 6305 7325 7326 7377 7376
8 6255 6256 6307 6306 7326 7327 7378 7377
8 6256 6257 6308 6307 7327 7328 7379 7378
8 6257 6258 6309 6308 7328 7329 7380 7379
8 6258 6259 6310 6309 7329 7330 7381 7380
8 6259 6260 6311 6310 7330 7331 7382 7381
8 6260 6261 6312 6311 7331 7332 7383 7382
8 6261 6262 6313 6312 7332 7333 7384 7383
8 6262 6263 6314 6313 7333 7334 7385 7384
8 6263 6264 6315 6314 7334 7335 7386 7385
8 6264 6265 6316 6315 7335 7336 7387 7386
8 6265 6266 6317 6316 7336 7337 7388 7387
8 6266 6267 6318 6317 7337 7338 7389 7388
8 6267 6268 6319 6318 7338 7339 7390 7389
8 6268 6269 6320 6319 7339 7340 7391 7390
8 6269 6270 6321 6320 7340 7341 7392 7391
8 6270 6271 6322 6321 7341 7342 7393 7392
8 6271 6272 6323 6322 7342 7343 7394 7393
8 6273 6274 6325 6324 7344 7345 7396 7395
8 6274 6275 6326 6325 7345 7346 7397 7396
8 6275 6276 6327 6326 7346 7347 7398 7397
8 6276 6277 6328 6327 7347 7348 7399 7398
8 6277 6278 6329 6328 7348 7349 7400 7399
8 6278 6279 6330 6329 7349 7350 7401 7400
8 6279 6280 6331 6330 7350 7351 7402 7401
8 6280 6281 6332 6331 7351 7352 7403 7402
8 6281 6282 6333 6332 7352 7353 7404 7403
8 6282 6283 6334 6333 7353 7354 7405 7404
8 6283 6284 6335 6334 7354 7355 7406 7405
8 6284 6285 6336 6335 7355 7356 7407 7406
8 6285 6286 6337 6336 7356 7357 7408 7407
8 6286 6287 6338 6337 7357 7358 7409 7408
8 6287 6288 6339 6338 7358 7359 7410 7409
8 6288 6289 6340 6339 7359 7360 7411 7410
8 6289 6290 6341 6340 7360 7361 7412 7411
8 6290 6291 6342 6341 7361 7362 7413 7412
8 6291 6292 6343 6342 7362 7363 7414 7413
8 6292 6293 6344 6343 7363 7364 7415 7414
8 6293 6294 6345 6344 7364 7365 7416 7415
8 6294 6295 6346 6345 7365 7366 7417 7416
8 6295 6296 6347 6346 7366 7367 7418 7417
8 6296 6297 6348 6347 7367 7368 7419 7418
8 6297 6298 6349 6348 7368 7369 7420 7419
8 6298 6299 6350 6349 7369 7370 7421 7420
8 6299 6300 6351 6350 7370 7371 7422 7421
8 6300 6301 6352 6351 7371 7372 7423 7422
8 6301 6302 6353 6352 7372 7373 7424 7423
8 6302 6303 6354 6353 7373 7374 7425 7424
8 6303 6304 6355 6354 7374 7375 7426 7425
8 6304 6305 6356 6355 7375 7376 7427 7426
8 6305 6306 6357 6356 7376 7377 7428 7427
8 6306 6307 6358 6357 7377 7378 7429 7428
8 6307 6308 6359 6358 7378 7379 7430 7429
8 6308 6309 6360 6359 7379 7380 7431 7430
8 6309 6310 6361 6360 7380 7381 7432 7431
8 6310 6311 6362 6361 7381 7382 7433 7432
8 6311 6312 6363 6362 7382 7383 7434 7433
8 6312 6313 6364 6363 7383 7384 7435 7434
8 6313 6314 6365 6364 7384 7385 7436 7435
8 6314 6315 6366 6365 7385 7386 7437 7436
8 6315 6316 6367 6366 7386 7387 7438 7437
8 6316 6317 6368 6367 7387 7388 7439 7438
8 6317 6318 6369 6368 7388 7389 7440 7439
8 6318 6319 6370 6369 7389 7390 7441 7440
8 6319 6320 6371 6370 7390 7391 7442 7441
8 6320 6321 6372 6371 7391 7392 7443 7442
8 6321 6322 6373 6372 7392 7393 7444 7443
8 6322 6323 6374 6373 7393 7394 7445 7444
8 6324 6325 6376 6375 7395 7396 7447 7446
8 6325 6326 6377 6376 7396 7397 7448 7447
8 6326 6327 6378 6377 7397 7398 7449 7448
8 6327 6328 6379 6378 7398 7399 7450 7449
8 6328 6329 6380 6379 7399 7400 7451 7450
8 6329 6330 6381 6380 7400 7401 7452 7451
8 6330 6331 6382 6381 7401 7402 7453 7452
8 6331 6332 6383 6382 7402 7403 7454 7453
8 6332 6333 6384 6383 7403 7404 7455 7454
8 6333 6334 6385 6384 7404 7405 7456 7455
8 6334 6335 6386 6385 7405 7406 7457 7456
8 6335 6336 6387 6386 7406 7407 7458 7457
8 6336 6337 6388 6387 7407 7408 7459 7458
8 6337 6338 6389 6388 7408 7409 7460 7459
8 6338 6339 6390 6389 7409 7410 7461 7460
8 6339 6340 6391 6390 7410 7411 7462 7461
8 6340 6341 6392 6391 7411 7412 7463 7462
8 6341 6342 6393 6392 7412 7413 7464 7463
8 6342 6343 6394 6393 7413 7414 7465 7464
8 6343 6344 6395 6394 7414 7415 7466 7465
8 6344 6345 6396 6395 7415 7416 7467 7466
8 6345 6346 6397 6396 7416 7417 7468 7467
8 6346 6347 6398 6397 7417 7418 7469 7468
8 6347 6348 6399 6398 7418 7419 7470 7469
8 6348 6349 6400 6399 7419 7420 7471 7470
8 6349 6350 6401 6400 7420 7421 7472 7471
8 6350 6351 6402 6401 7421 7422 7473 7472
8 6351 6352 6403 6402 7422 7423 7474 7473
8 6352 6353 6404 6403 7423 7424 7475 7474
8 6353 6354 6405 6404 7424 7425 7476 7475
8 6354 6355 6406 6405 7425 7426 7477 7476
8 6355 6356 6407 6406 7426 7427 7478 7477
8 6356 6357 6408 6407 7427 7428 7479 7478
8 6357 6358 6409 6408 7428 7429 7480 7479
8 6358 6359 6410 6409 7429 7430 7481 7480
8 6359 6360 6411 6410 7430 7431 7482 7481
8 6360 6361 6412 6411 7431 7432 7483 7482
8 6361 6362 6413 6412 7432 7433 7484 7483
8 6362 6363 6414 6413 7433 7434 7485 7484
8 6363 6364 6415 6414 7434 7435 7486 7485
8 6364 6365 6416 6415 7435 7436 7487 7486
8 6365 6366 6417 6416 7436 7437 7488 7487
8 6366 6367 6418 6417 7437 7438 7489 7488
8 6367 6368 6419 6418 7438 7439 7490 7489
8 6368 6369 6420 6419 7439 7440 7491 7490
8 6369 6370 6421 6420 7440 7441 7492 7491
8 6370 6371 6422 6421 7441 7442 7493 7492
8 6371 6372 6423 6422 7442 7443 7494 7493
8 6372 6373 6424 6423 7443 7444 7495 7494
8 6373 6374 6425 6424 7444 7445 7496 7495
8 6426 6427 6478 6477 7497 7498 7549 7548
8 6427 6428 6479 6478 7498 7499 7550 7549
8 6428 6429 6480 6479 7499 7500 7551 7550
8 6429 6430 6481 6480 7500 7501 7552 7551
8 6430 6431 6482 6481 7501 7502 7553 7552
8 6431 6432 6483 6482 7502 7503 7554 7553
8 6432 6433 6484 6483 7503 7504 7555 7554
8 6433 6434 6485 6484 7504 7505 7556 7555
8 6434 6435 6486 6485 7505 7506 7557 7556
8 6435 6436 6487 6486 7506 7507 7558 7557
8 6436 6437 6488 6487 7507 7508 7559 7558
8 6437 6438 6489 6488 7508 7509 7560 7559
8 6438 6439 6490 6489 7509 7510 7561 7560
8 6439 6440 6491 6490 7510 7511 7562 7561
8 6440 6441 6492 6491 7511 7512 7563 7562
8 6441 6442 6493 6492 7512 7513 7564 7563
8 6442 6443 6494 6493 7513 7514 7565 7564
8 6443 6444 6495 6494 7514 7515 7566 7565
8 6444 6445 6496 6495 7515 7516 7567 7566
8 6445 6446 6497 6496 7516 7517 7568 7567
8 6446 6447 6498 6497 7517 7518 7569 7568
8 6447 6448 6499 6498 7518 7519 7570 7569
8 6448 6449 6500 6499 7519 7520 7571 7570
8 6449 6450 6501 6500 7520 7521 7572 7571
8 6450 6451 6502 6501 7521 7522 7573 7572
8 6451 6452 6503 6502 7522 7523 7574 7573
8 6452 6453 6504 6503 7523 7524 7575 7574
8 6453 6454 6505 6504 7524 7525 7576 7575
8 6454 6455 6506 6505 7525 7526 7577 7576
8 6455 6456 6507 6506 7526 7527 7578 7577
8 6456 6457 6508 6507 7527 7528 7579 7578
8 6457 6458 6509 6508 7528 7529 7580 7579
8 6458 6459 6510 6509 7529 7530 7581 7580
8 6459 6460 6511 6510 7530 7531 7582 7581
8 6460 6461 6512 6511 7531 7532 7583 7582
8 6461 6462 6513 6512 7532 7533 7584 7583
8 6462 6463 6514 6513 7533 7534 7585 7584
8 6463 6464 6515 6514 7534 7535 7586 7585
8 6464 6465 6516 6515 7535 7536 7587 7586
8 6465 6466 6517 6516 7536 7537 7588 7587
8 6466 6467 6518 6517 7537 7538 7589 7588
8 6467 6468 6519 6518 7538 7539 7590 7589
8 6468 6469 6520 6519 7539 7540 7591 7590
8 6469 6470 6521 6520 7540 7541 7592 7591
8 6470 6471 6522 6521 7541 7542 7593 7592
8 6471 6472 6523 6522 7542 7543 7594 7593
8 6472 6473 6524 6523 7543 7544 7595 7594
8 6473 6474 6525 6524 7544 7545 7596 7595
8 6474 6475 6526 6525 7545 7546 7597 7596
8 6475 6476 6527 6526 7546 7547 7598 7597
8 6477 6478 6529 6528 7548 7549 7600 7599
8 6478 6479 6530 6529 7549 7550 7601 7600
8 6479 6480 6531 6530 7550 7551 7602 7601
8 6480 6481 6532 6531 7551 7552 7603 7602
8 6481 6482 6533 6532 7552 7553 7604 7603
8 6482 6483 6534 6533 7553 7554 7605 7604
8 6483 6484 6535 6534 7554 7555 7606 7605
8 6484 6485 6536 6535 7555 7556 7607 7606
8 6485 6486 6537 6536 7556 7557 7608 7607
8 6486 6487 6538 6537 7557 7558 7609 7608
8 6487 6488 6539 6538 7558 7559 7610 7609
8 6488 6489 6540 6539 7559 7560 7611 7610
8 6489 6490 6541 6540 7560 7561 7612 7611
8 6490 6491 6542 6541 7561 7562 7613 7612
8 6491 6492 6543 6542 7562 7563 7614 7613
8 6492 6493 6544 6543 7563 7564 7615 7614
8 6493 6494 6545 6544 7564 7565 7616 7615
8 6494 6495 6546 6545 7565 7566 7617 7616
8 6495 6496 6547 6546 7566 7567 7618 7617
8 6496 6497 6548 6547 7567 7568 7619 7618
8 6497 6498 6549 6548 7568 7569 7620 7619
8 6498 6499 6550 6549 7569 7570 7621 7620
8 6499 6500 6551 6550 7570 7571 7622 7621
8 6500 6501 6552 6551 7571 7572 7623 7622
8 6501 6502 6553 6552 7572 7573 7624 7623
8 6502 6503 6554 6553 7573 7574 7625 7624
8 6503 6504 6555 6554 7574 7575 7626 7625
8 6504 6505 6556 6555 7575 7576 7627 7626
8 6505 6506 6557 6556 7576 7577 7628 7627
8 6506 6507 6558 6557 7577 7578 7629 7628
8 6507 6508 6559 6558 7578 7579 7630 7629
8 6508 6509 6560 6559 7579 7580 7631 7630
8 6509 6510 6561 6560 7580 7581 7632 7631
8 6510 6511 6562 6561 7581 7582 7633 7632
8 6511 6512 6563 6562 7582 7583 7634 7633
8 6512 6513 6564 6563 7583 7584 7635 7634
8 6513 6514 6565 6564 7584 7585 7636 7635
8 6514 6515 6566 6565 7585 7586 7637 7636
8 6515 6516 6567 6566 7586 7587 7638 7637
8 6516 6517 6568 6567 7587 7588 7639 7638
8 6517 6518 6569 6568 7588 7589 7640 7639
8 6518 6519 6570 6569 7589 7590 7641 7640
8 6519 6520 6571 6570 7590 7591 7642 7641
8 6520 6521 6572 6571 7591 7592 7643 7642
8 6521 6522 6573 6572 7592 7593 7644 7643
8 6522 6523 6574 6573 7593 7594 7645 7644
8 6523 6524 6575 6574 7594 7595 7646 7645
8 6524 6525 6576 6575 7595 7596 7647 7646
8 6525 6526 6577 6576 7596 7597 7648 7647
8 6526 6527 6578 6577 7597 7598 7649 7648
8 6528 6529 6580 6579 7599 7600 7651 7650
8 6529 6530 6581 6580 7600 7601 7652 7651
8 6530 6531 6582 6581 7601 7602 7653 7652
8 6531 6532 6583 6582 7602 7603 7654 7653
8 6532 6533 6584 6583 7603 7604 7655 7654
8 6533 6534 6585 6584 7604 7605 7656 7655
8 6534 6535 6586 6585 7605 7606 7657 7656
8 6535 6536 6587 6586 7606 7607 7658 7657
8 6536 6537 6588 6587 7607 7608 7659 7658
8 6537 6538 6589 6588 7608 7609 7660 7659
8 6538 6539 6590 6589 7609 7610 7661 7660
8 6539 6540 6591 6590 7610 7611 7662 7661
8 6540 6541 6592 6591 7611 7612 7663 7662
8 6541 6542 6593 6592 7612 7613 7664 7663
8 6542 6543 6594 6593 7613 7614 7665 7664
8 6543 6544 6595 6594 7614 7615 7666 7665
8 6544 6545 6596 6595 7615 7616 7667 7666
8 6545 6546 6597 6596 7616 7617 7668 7667
8 6546 6547 6598 6597 7617 7618 7669 7668
8 6547 6548 6599 6598 7618 7619 7670 7669
8 6548 6549 6600 6599 7619 7620 7671 7670
8 6549 6550 6601 6600 7620 7621 7672 7671
8 6550 6551 6602 6601 7621 7622 7673 7672
8 6551 6552 6603 6602 7622 7623 7674 7673
8 6552 6553 6604 6603 7623 7624 7675 7674
8 6553 6554 6605 6604 7624 7625 7676 7675
8 6554 6555 6606 6605 7625 7626 7677 7676
8 6555 6556 6607 6606 7626 7627 7678 7677
8 6556 6557 6608 6607 7627 7628 7679 7678
8 6557 6558 6609 6608 7628 7629 7680 7679
8 6558 6559 6610 6609 7629 7630 7681 7680
8 6559 6560 6611 6610 7630 7631 7682 7681
8 6560 6561 6612 6611 7631 7632 7683 7682
8 6561 6562 6613 6612 7632 7633 7684 7683
8 6562 6563 6614 6613 7633 7634 7685 7684
8 6563 6564 6615 6614 7634 7635 7686 7685
8 6564 6565 6616 6615 7635 7636 7687 7686
8 6565 6566 6617 6616 7636 7637 7688 7687
8 6566 6567 6618 6617 7637 7638 7689 7688
8 6567 6568 6619 6618 7638 7639 7690 7689
8 6568 6569 6620 6619 7639 7640 7691 7690
8 6569 6570 6621 6620 7640 7641 7692 7691
8 6570 6571 6622 6621 7641 7642 7693 7692
8 6571 6572 6623 6622 7642 7643 7694 7693
8 6572 6573 6624 6623 7643 7644 7695 7694
8 6573 6574 6625 6624 7644 7645 7696 7695
8 6574 6575 6626 6625 7645 7646 7697 7696
8 6575 6576 6627 6626 7646 7647 7698 7697
8 6576 6577 6628 6627 7647 7648 7699 7698
8 6577 6578 6629 6628 7648 7649 7700 7699
8 6579 6580 6631 6630 7650 7651 7702 7701
8 6580 6581 6632 6631 7651 7652 7703 7702
8 6581 6582 6633 6632 7652 7653 7704 7703
8 6582 6583 6634 6633 7653 7654 7705 7704
8 6583 6584 6635 6634 7654 7655 7706 7705
8 6584 6585 6636 6635 7655 7656 7707 7706
8 6585 6586 6637 6636 7656 7657 7708 7707
8 6586 6587 6638 6637 7657 7658 7709 7708
8 6587 6588 6639 6638 7658 7659 7710 7709
8 6588 6589 6640 6639 7659 7660 7711 7710
8 6589 6590 6641 6640 7660 7661 7712 7711
8 6590 6591 6642 6641 7661 7662 7713 7712
8 6591 6592 6643 6642 7662 7663 7714 7713
8 6592 6593 6644 6643 7663 7664 7715 7714
8 6593 6594 6645 6644 7664 7665 7716 7715
8 6594 6595 6646 6645 7665 7666 7717 7716
8 6595 6596 6647 6646 7666 7667 7718 7717
8 6596 6597 6648 6647 7667 7668 7719 7718
8 6597 6598 6649 6648 7668 7669 7720 7719
8 6598 6599 6650 6649 7669 7670 7721 7720
8 6599 6600 6651 6650 7670 7671 7722 7721
8 6600 6601 6652 6651 7671 7672 7723 7722
8 6601 6602 6653 6652 7672 7673 7724 7723
8 6602 6603 6654 6653 7673 7674 7725 7724
8 6603 6604 6655 6654 7674 7675 7726 7725
8 6604 6605 6656 6655 7675 7676 7727 7726
8 6605 6606 6657 6656 7676 7677 7728 7727
8 6606 6607 6658 6657 7677 7678 7729 7728
8 6607 6608 6659 6658 7678 7679 7730 7729
8 6608 6609 6660 6659 7679 7680 7731 7730
8 6609 6610 6661 6660 7680 7681 7732 7731
8 6610 6611 6662 6661 7681 7682 7733 7732
8 6611 6612 6663 6662 7682 7683 7734 7733
8 6612 6613 6664 6663 7683 7684 7735 7734
8 6613 6614 6665 6664 7684 7685 7736 7735
8 6614 6615 6666 6665 7685 7686 7737 7736
8 6615 6616 6667 6666 7686 7687 7738 7737
8 6616 6617 6668 6667 7687 7688 7739 7738
8 6617 6618 6669 6668 7688 7689 7740 7739
8 6618 6619 6670 6669 7689 7690 7741 7740
8 6619 6620 6671 6670 7690 7691 7742 7741
8 6620 6621 6672 6671 7691 7692 7743 7742
8 6621 6622 6673 6672 7692 7693 7744 7743
8 6622 6623 6674 6673 7693 7694 7745 7744
8 6623 6624 6675 6674 7694 7695 7746 7745
8 6624 6625 6676 6675 7695 7696 7747 7746
8 6625 6626 6677 6676 7696 7697 7748 7747
8 6626 6627 6678 6677 7697 7698 7749 7748
8 6627 6628 6679 6678 7698 7699 7750 7749
8 6628 6629 6680 6679 7699 7700 7751 7750
8 6630 6631 6682 6681 7701 7702 7753 7752
8 6631 6632 6683 6682 7702 7703 7754 7753
8 6632 6633 6684 6683 7703 7704 7755 7754
8 6633 6634 6685 6684 7704 7705 7756 7755
8 6634 6635 6686 6685 7705 7706 7757 7756
8 6635 6636 6687 6686 7706 7707 7758 7757
8 6636 6637 6688 6687 7707 7708 7759 7758
8 6637 6638 6689 6688 7708 7709 7760 7759
8 6638 6639 6690 6689 7709 7710 7761 7760
8 6639 6640 6691 6690 7710 7711 7762 7761
8 6640 6641 6692 6691 7711 7712 7763 7762
8 6641 6642 6693 6692 7712 7713 7764 7763
8 6642 6643 6694 6693 7713 7714 7765 7764
8 6643 6644 6695 6694 7714 7715 7766 7765
8 6644 6645 6696 6695 7715 7716 7767 7766
8 6645 6646 6697 6696 7716 7717 7768 7767
8 6646 6647 6698 6697 7717 7718 7769 7768
8 6647 6648 6699 6698 7718 7719 7770 7769
8 6648 6649 6700 6699 7719 7720 7771 7770
8 6649 6650 6701 6700 7720 7721 7772 7771
8 6650 6651 6702 6701 7721 7722 7773 7772
8 6651 6652 6703 6702 7722 7723 7774 7773
8 6652 6653 6704 6703 7723 7724 7775 7774
8 6653 6654 6705 6704 7724 7725 7776 7775
8 6654 6655 6706 6705 7725 7726 7777 7776
8 6655 6656 6707 6706 7726 7727 7778 7777
8 6656 6657 6708 6707 7727 7728 7779 7778
8 6657 6658 6709 6708 7728 7729 7780 7779
8 6658 6659 6710 6709 7729 7730 7781 7780
8 6659 6660 6711 6710 7730 7731 7782 7781
8 6660 6661 6712 6711 7731 7732 7783 7782
8 6661 6662 6713 6712 7732 7733 7784 7783
8 6662 6663 6714 6713 7733 7734 7785 7784
8 6663 6664 6715 6714 7734 7735 7786 7785
8 6664 6665 6716 6715 7735 7736 7787 7786
8 6665 6666 6717 6716 7736 7737 7788 7787
8 6666 6667 6718 6717 7737 7738 7789 7788
8 6667 6668 6719 6718 7738 7739 7790 7789
8 6668 6669 6720 6719 7739 7740 7791 7790
8 6669 6670 6721 6720 7740 7741 7792 7791
8 6670 6671 6722 6721 7741 7742 7793 7792
8 6671 6672 6723 6722 7742 7743 7794 7793
8 6672 6673 6724 6723 7743 7744 7795 7794
8 6673 6674 6725 6724 7744 7745 7796 7795
8 6674 6675 6726 6725 7745 7746 7797 7796
8 6675 6676 6727 6726 7746 7747 7798 7797
8 6676 6677 6728 6727 7747 7748 7799 7798
8 6677 6678 6729 6728 7748 7749 7800 7799
8 6678 6679 6730 6729 7749 7750 7801 7800
8 6679 6680 6731 6730 7750 7751 7802 7801
8 6681 6682 6733 6732 7752 7753 7804 7803
8 6682 6683 6734 6733 7753 7754 7805 7804
8 6683 6684 6735 6734 7754 7755 7806 7805
8 6684 6685 6736 6735 7755 7756 7807 7806
8 6685 6686 6737 6736 7756 7757 7808 7807
8 6686 6687 6738 6737 7757 7758 7809 7808
8 6687 6688 6739 6738 7758 7759 7810 7809
8 6688 6689 6740 6739 7759 7760 7811 7810
8 6689 6690 6741 6740 7760 7761 7812 7811
8 6690 6691 6742 6741 7761 7762 7813 7812
8 6691 6692 6743 6742 7762 7763 7814 7813
8 6692 6693 6744 6743 7763 7764 7815 7814
8 6693 6694 6745 6744 7764 7765 7816 7815
8 6694 6695 6746 6745 7765 7766 7817 7816
8 6695 6696 6747 6746 7766 7767 7818 7817
8 6696 6697 6748 6747 7767 7768 7819 7818
8 6697 6698 6749 6748 7768 7769 7820 7819
8 6698 6699 6750 6749 7769 7770 7821 7820
8 6699 6700 6751 6750 7770 7771 7822 7821
8 6700 6701 6752 6751 7771 7772 7823 7822
8 6701 6702 6753 6752 7772 7773 7824 7823
8 6702 6703 6754 6753 7773 7774 7825 7824
8 6703 6704 6755 6754 7774 7775 7826 7825
8 6704 6705 6756 6755 7775 7776 7827 7826
8 6705 6706 6757 6756 7776 7777 7828 7827
8 6706 6707 6758 6757 7777 7778 7829 7828
8 6707 6708 6759 6758 7778 7779 7830 7829
8 6708 6709 6760 6759 7779 7780 7831 7830
8 6709 6710 6761 6760 7780 7781 7832 7831
8 6710 6711 6762 6761 7781 7782 7833 7832
8 6711 6712 6763 6762 7782 7783 7834 7833
8 6712 6713 6764 6763 7783 7784 7835 7834
8 6713 6714 6765 6764 7784 7785 7836 7835
8 6714 6715 6766 6765 7785 7786 7837 7836
8 6715 6716 6767 6766 7786 7787 7838 7837
8 6716 6717 6768 6767 7787 7788 7839 7838
8 6717 6718 6769 6768 7788 7789 7840 7839
8 6718 6719 6770 6769 7789 7790 7841 7840
8 6719 6720 6771 6770 7790 7791 7842 7841
8 6720 6721 6772 6771 7791 7792 7843 7842
8 6721 6722 6773 6772 7792 7793 7844 7843
8 6722 6723 6774 6773 7793 7794 7845 7844
8 6723 6724 6775 6774 7794 7795 7846 7845
8 6724 6725 6776 6775 7795 7796 7847 7846
8 6725 6726 6777 6776 7796 7797 7848 7847
8 6726 6727 6778 6777 7797 7798 7849 7848
8 6727 6728 6779 6778 7798 7799 7850 7849
8 6728 6729 6780 6779 7799 7800 7851 7850
8 6729 6730 6781 6780 7800 7801 7852 7851
8 6730 6731 6782 6781 7801 7802 7853 7852
8 6732 6733 6784 6783 7803 7804 7855 7854
8 6733 6734 6785 6784 7804 7805 7856 7855
8 6734 6735 6786 6785 7805 7806 7857 7856
8 6735 6736 6787 6786 7806 7807 7858 7857
8 6736 6737 6788 6787 7807 7808 7859 7858
8 6737 6738 6789 6788 7808 7809 7860 7859
8 6738 6739 6790 6789 7809 7810 7861 7860
8 6739 6740 6791 6790 7810 7811 7862 7861
8 6740 6741 6792 6791 7811 7812 7863 7862
8 6741 6742 6793 6792 7812 7813 7864 7863
8 6742 6743 6794 6793 7813 7814 7865 7864
8 6743 6744 6795 6794 7814 7815 7866 7865
8 6744 6745 6796 6795 7815 7816 7867 7866
8 6745 6746 6797 6796 7816 7817 7868 7867
8 6746 6747 6798 6797 7817 7818 7869 7868
8 6747 6748 6799 6798 7818 7819 7870 7869
8 6748 6749 6800 6799 7819 7820 7871 7870
8 6749 6750 6801 6800 7820 7821 7872 7871
8 6750 6751 6802 6801 7821 7822 7873 7872
8 6751 6752 6803 6802 7822 7823 7874 7873
8 6752 6753 6804 6803 7823 7824 7875 7874
8 6753 6754 6805 6804 7824 7825 7876 7875
8 6754 6755 6806 6805 7825 7826 7877 7876
8 6755 6756 6807 6806 7826 7827 7878 7877
8 6756 6757 6808 6807 7827 7828 7879 7878
8 6757 6758 6809 6808 7828 7829 7880 7879
8 6758 6759 6810 6809 7829 7830 7881 7880
8 6759 6760 6811 6810 7830 7831 7882 7881
8 6760 6761 6812 6811 7831 7832 7883 7882
8 6761 6762 6813 6812 7832 7833 7884 7883
8 6762 6763 6814 6813 7833 7834 7885 7884
8 6763 6764 6815 6814 7834 7835 7886 7885
8 6764 6765 6816 6815 7835 7836 7887 7886
8 6765 6766 6817 6816 7836 7837 7888 7887
8 6766 6767 6818 6817 7837 7838 7889 7888
8 6767 6768 6819 6818 7838 7839 7890 7889
8 6768 6769 6820 6819 7839 7840 7891 7890
8 6769 6770 6821 6820 7840 7841 7892 7891
8 6770 6771 6822 6821 7841 7842 7893 7892
8 6771 6772 6823 6822 7842 7843 7894 7893
8 6772 6773 6824 6823 7843 7844 7895 7894
8 6773 6774 6825 6824 7844 7845 7896 7895
8 6774 6775 6826 6825 7845 7846 7897 7896
8 6775 6776 6827 6826 7846 7847 7898 7897
8 6776 6777 6828 6827 7847 7848 7899 7898
8 6777 6778 6829 6828 7848 7849 7900 7899
8 6778 6779 6830 6829 7849 7850 7901 7900
8 6779 6780 6831 6830 7850 7851 7902 7901
8 6780 6781 6832 6831 7851 7852 7903 7902
8 6781 6782 6833 6832 7852 7853 7904 7903
8 6783 6784 6835 6834 7854 7855 7906 7905
8 6784 6785 6836 6835 7855 7856 7907 7906
8 6785 6786 6837 6836 7856 7857 7908 7907
8 6786 6787 6838 6837 7857 7858 7909 7908
8 6787 6788 6839 6838 7858 7859 7910 7909
8 6788 6789 6840 6839 7859 7860 7911 7910
8 6789 6790 6841 6840 7860 7861 7912 7911
8 6790 6791 6842 6841 7861 7862 7913 7912
8 6791 6792 6843 6842 7862 7863 7914 7913
8 6792 6793 6844 6843 7863 7864 7915 7914
8 6793 6794 6845 6844 7864 7865 7916 7915
8 6794 6795 6846 6845 7865 7866 7917 7916
8 6795 6796 6847 6846 7866 7867 7918 7917
8 6796 6797 6848 6847 7867 7868 7919 7918
8 6797 6798 6849 6848 7868 7869 7920 7919
8 6798 6799 6850 6849 7869 7870 7921 7920
8 6799 6800 6851 6850 7870 7871 7922 7921
8 6800 6801 6852 6851 7871 7872 7923 7922
8 6801 6802 6853 6852 7872 7873 7924 7923
8 6802 6803 6854 6853 7873 7874 7925 7924
8 6803 6804 6855 6854 7874 7875 7926 7925
8 6804 6805 6856 6855 7875 7876 7927 7926
8 6805 6806 6857 6856 7876 7877 7928 7927
8 6806 6807 6858 6857 7877 7878 7929 7928
8 6807 6808 6859 6858 7878 7879 7930 7929
8 6808 6809 6860 6859 7879 7880 7931 7930
8 6809 6810 6861 6860 7880 7881 7932 7931
8 6810 6811 6862 6861 7881 7882 7933 7932
8 6811 6812 6863 6862 7882 7883 7934 7933
8 6812 6813 6864 6863 7883 7884 7935 7934
8 6813 6814 6865 6864 7884 7885 7936 7935
8 6814 6815 6866 6865 7885 7886 7937 7936
8 6815 6816 6867 6866 7886 7887 7938 7937
8 6816 6817 6868 6867 7887 7888 7939 7938
8 6817 6818 6869 6868 7888 7889 7940 7939
8 6818 6819 6870 6869 7889 7890 7941 7940
8 6819 6820 6871 6870 7890 7891 7942 7941
8 6820 6821 6872 6871 7891 7892 7943 7942
8 6821 6822 6873 6872 7892 7893 7944 7943
8 6822 6823 6874 6873 7893 7894 7945 7944
8 6823 6824 6875 6874 7894 7895 7946 7945
8 6824 6825 6876 6875 7895 7896 7947 7946
8 6825 6826 6877 6876 7896 7897 7948 7947
8 6826 6827 6878 6877 7897 7898 7949 7948
8 6827 6828 6879 6878 7898 7899 7950 7949
8 6828 6829 6880 6879 7899 7900 7951 7950
8 6829 6830 6881 6880 7900 7901 7952 7951
8 6830 6831 6882 6881 7901 7902 7953 7952
8 6831 6832 6883 6882 7902 7903 7954 7953
8 6832 6833 6884 6883 7903 7904 7955 7954
8 6834 6835 6886 6885 7905 7906 7957 7956
8 6835 6836 6887 6886 7906 7907 7958 7957
8 6836 6837 6888 6887 7907 7908 7959 7958
8 6837 6838 6889 6888 7908 7909 7960 7959
8 6838 6839 6890 6889 7909 7910 7961 7960
8 6839 6840 6891 6890 7910 7911 7962 7961
8 6840 6841 6892 6891 7911 7912 7963 7962
8 6841 6842 6893 6892 7912 7913 7964 7963
8 6842 6843 6894 6893 7913 7914 7965 7964
8 6843 6844 6895 6894 7914 7915 7966 7965
8 6844 6845 6896 6895 7915 7916 7967 7966
8 6845 6846 6897 6896 7916 7917 7968 7967
8 6846 6847 6898 6897 7917 7918 7969 7968
8 6847 6848 6899 6898 7918 7919 7970 7969
8 6848 6849 6900 6899 7919 7920 7971 7970
8 6849 6850 6901 6900 7920 7921 7972 7971
8 6850 6851 6902 6901 7921 7922 7973 7972
8 6851 6852 6903 6902 7922 7923 7974 7973
8 6852 6853 6904 6903 7923 7924 7975 7974
8 6853 6854 6905 6904 7924 7925 7976 7975
8 6854 6855 6906 6905 7925 7926 7977 7976
8 6855 6856 6907 6906 7926 7927 7978 7977
8 6856 6857 6908 6907 7927 7928 7979 7978
8 6857 6858 6909 6908 7928 7929 7980 7979
8 6858 6859 6910 6909 7929 7930 7981 7980
8 6859 6860 6911 6910 7930 7931 7982 7981
8 6860 6861 6912 6911 7931 7932 7983 7982
8 6861 6862 6913 6912 7932 7933 7984 7983
8 6862 6863 6914 6913 7933 7934 7985 7984
8 6863 6864 6915 6914 7934 7935 7986 7985
8 6864 6865 6916 6915 7935 7936 7987 7986
8 6865 6866 6917 6916 7936 7937 7988 7987
8 6866 6867 6918 6917 7937 7938 7989 7988
8 6867 6868 6919 6918 7938 7939 7990 7989
8 6868 6869 6920 6919 7939 7940 7991 7990
8 6869 6870 6921 6920 7940 7941 7992 7991
8 6870 6871 6922 6921 7941 7942 7993 7992
8 6871 6872 6923 6922 7942 7943 7994 7993
8 6872 6873 6924 6923 7943 7944 7995 7994
8 6873 6874 6925 6924 7944 7945 7996 7995
8 6874 6875 6926 6925 7945 7946 7997 7996
8 6875 6876 6927 6926 7946 7947 7998 7997
8 6876 6877 6928 6927 7947 7948 7999 7998
8 6877 6878 6929 6928 7948 7949 8000 7999
8 6878 6879 6930 6929 7949 7950 8001 8000
8 6879 6880 6931 6930 7950 7951 8002 8001
8 6880 6881 6932 6931 7951 7952 8003 8002
8 6881 6882 6933 6932 7952 7953 8004 8003
8 6882 6883 6934 6933 7953 7954 8005 8004
8 6883 6884 6935 6934 7954 7955 8006 8005
8 6885 6886 6937 6936 7956 7957 8008 8007
8 6886 6887 6938 6937 7957 7958 8009 8008
8 6887 6888 6939 6938 7958 7959 8010 8009
8 6888 6889 6940 6939 7959 7960 8011 8010
8 6889 6890 6941 6940 7960 7961 8012 8011
8 6890 6891 6942 6941 7961 7962 8013 8012
8 6891 6892 6943 6942 7962 7963 8014 8013
8 6892 6893 6944 6943 7963 7964 8015 8014
8 6893 6894 6945 6944 7964 7965 8016 8015
8 6894 6895 6946 6945 7965 7966 8017 8016
8 6895 6896 6947 6946 7966 7967 8018 8017
8 6896 6897 6948 6947 7967 7968 8019 8018
8 6897 6898 6949 6948 7968 7969 8020 8019
8 6898 6899 6950 6949 7969 7970 8021 8020
8 6899 6900 6951 6950 7970 7971 8022 8021
8 6900 6901 6952 6951 7971 7972 8023 8022
8 6901 6902 6953 6952 7972 7973 8024 8023
8 6902 6903 6954 6953 7973 7974 8025 8024
8 6903 6904 6955 6954 7974 7975 8026 8025
8 6904 6905 6956 6955 7975 7976 8027 8026
8 6905 6906 6957 6956 7976 7977 8028 8027
8 6906 6907 6958 6957 7977 7978 8029 8028
8 6907 6908 6959 6958 7978 7979 8030 8029
8 6908 6909 6960 6959 7979 7980 8031 8030
8 6909 6910 6961 6960 7980 7981 8032 8031
8 6910 6911 6962 6961 7981 7982 8033 8032
8 6911 6912 6963 6962 7982 7983 8034 8033
8 6912 6913 6964 6963 7983 7984 8035 8034
8 6913 6914 6965 6964 7984 7985 8036 8035
8 6914 6915 6966 6965 7985 7986 8037 8036
8 6915 6916 6967 6966 7986 7987 8038 8037
8 6916 6917 6968 6967 7987 7988 8039 8038
8 6917 6918 6969 6968 7988 7989 8040 8039
8 6918 6919 6970 6969 7989 7990 8041 8040
8 6919 6920 6971 6970 7990 7991 8042 8041
8 6920 6921 6972 6971 7991 7992 8043 8042
8 6921 6922 6973 6972 7992 7993 8044 8043
8 6922 6923 6974 6973 7993 7994 8045 8044
8 6923 6924 6975 6974 7994 7995 8046 8045
8 6924 6925 6976 6975 7995 7996 8047 8046
8 6925 6926 6977 6976 7996 7997 8048 8047
8 6926 6927 6978 6977 7997 7998 8049 8048
8 6927 6928 6979 6978 7998 7999 8050 8049
8 6928 6929 6980 6979 7999 8000 8051 8050
8 6929 6930 6981 6980 8000 8001 8052 8051
8 6930 6931 6982 6981 8001 8002 8053 8052
8 6931 6932 6983 6982 8002 8003 8054 8053
8 6932 6933 6984 6983 8003 8004 8055 8054
8 6933 6934 6985 6984 8004 8005 8056 8055
8 6934 6935 6986 6985 8005 8006 8057 8056
8 6936 6937 6988 6987 8007 8008 8059 8058
8 6937 6938 6989 6988 8008 8009 8060 8059
8 6938 6939 6990 6989 8009 8010 8061 8060
8 6939 6940 6991 6990 8010 8011 8062 8061
8 6940 6941 6992 6991 8011 8012 8063 8062
8 6941 6942 6993 6992 8012 8013 8064 8063
8 6942 6943 6994 6993 8013 8014 8065 8064
8 6943 6944 6995 6994 8014 8015 8066 8065
8 6944 6945 6996 6995 8015 8016 8067 8066
8 6945 6946 6997 6996 8016 8017 8068 8067
8 6946 6947 6998 6997 8017 8018 8069 8068
8 6947 6948 6999 6998 8018 8019 8070 8069
8 6948 6949 7000 6999 8019 8020 8071 8070
8 6949 6950 7001 7000 8020 8021 8072 8071
8 6950 6951 7002 7001 8021 8022 8073 8072
8 6951 6952 7003 7002 8022 8023 8074 8073
8 6952 6953 7004 7003 8023 8024 8075 8074
8 6953 6954 7005 7004 8024 8025 8076 8075
8 6954 6955 7006 7005 8025 8026 8077 8076
8 6955 6956 7007 7006 8026 8027 8078 8077
8 6956 6957 7008 7007 8027 8028 8079 8078
8 6957 6958 7009 7008 8028 8029 8080 8079
8 6958 6959 7010 7009 8029 8030 8081 8080
8 6959 6960 7011 7010 8030 8031 8082 8081
8 6960 6961 7012 7011 8031 8032 8083 8082
8 6961 6962 7013 7012 8032 8033 8084 8083
8 6962 6963 7014 7013 8033 8034 8085 8084
8 6963 6964 7015 7014 8034 8035 8086 8085
8 6964 6965 7016 7015 8035 8036 8087 8086
8 6965 6966 7017 7016 8036 8037 8088 8087
8 6966 6967 7018 7017 8037 8038 8089 8088
8 6967 6968 7019 7018 8038 8039 8090 8089
8 6968 6969 7020 7019 8039 8040 8091 8090
8 6969 6970 7021 7020 8040 8041 8092 8091
8 6970 6971 7022 7021 8041 8042 8093 8092
8 6971 6972 7023 7022 8042 8043 8094 8093
8 6972 6973 7024 7023 8043 8044 8095 8094
8 6973 6974 7025 7024 8044 8045 8096 8095
8 6974 6975 7026 7025 8045 8046 8097 8096
8 6975 6976 7027 7026 8046 8047 8098 8097
8 6976 6977 7028 7027 8047 8048 8099 8098
8 6977 6978 7029 7028 8048 8049 8100 8099
8 6978 6979 7030 7029 8049 8050 8101 8100
8 6979 6980 7031 7030 8050 8051 8102 8101
8 6980 6981 7032 7031 8051 8052 8103 8102
8 6981 6982 7033 7032 8052 8053 8104 8103
8 6982 6983 7034 7033 8053 8054 8105 8104
8 6983 6984 7035 7034 8054 8055 8106 8105
8 6984 6985 7036 7035 8055 8056 8107 8106
8 6985 6986 7037 7036 8056 8057 8108 8107
8 6987 6988 7039 7038 8058 8059 8110 8109
8 6988 6989 7040 7039 8059 8060 8111 8110
8 6989 6990 7041 7040 8060 8061 8112 8111
8 6990 6991 7042 7041 8061 8062 8113 8112
8 6991 6992 7043 7042 8062 8063 8114 8113
8 6992 6993 7044 7043 8063 8064 8115 8114
8 6993 6994 7045 7044 8064 8065 8116 8115
8 6994 6995 7046 7045 8065 8066 8117 8116
8 6995 6996 7047 7046 8066 8067 8118 8117
8 6996 6997 7048 7047 8067 8068 8119 8118
8 6997 6998 7049 7048 8068 8069 8120 8119
8 6998 6999 7050 7049 8069 8070 8121 8120
8 6999 7000 7051 7050 8070 8071 8122 8121
8 7000 7001 7052 7051 8071 8072 8123 8122
8 7001 7002 7053 7052 8072 8073 8124 8123
8 7002 7003 7054 7053 8073 8074 8125 8124
8 7003 7004 7055 7054 8074 8075 8126 8125
8 7004 7005 7056 7055 8075 8076 8127 8126
8 7005 7006 7057 7056 8076 8077 8128 8127
8 7006 7007 7058 7057 8077 8078 8129 8128
8 7007 7008 7059 7058 8078 8079 8130 8129
8 7008 7009 7060 7059 8079 8080 8131 8130
8 7009 7010 7061 7060 8080 8081 8132 8131
8 7010 7011 7062 7061 8081 8082 8133 8132
8 7011 7012 7063 7062 8082 8083 8134 8133
8 7012 7013 7064 7063 8083 8084 8135 8134
8 7013 7014 7065 7064 8084 8085 8136 8135
8 7014 7015 7066 7065 8085 8086 8137 8136
8 7015 7016 7067 7066 8086 8087 8138 8137
8 7016 7017 7068 7067 8087 8088 8139 8138
8 7017 7018 7069 7068 8088 8089 8140 8139
8 7018 7019 7070 7069 8089 8090 8141 8140
8 7019 7020 7071 7070 8090 8091 8142 8141
8 7020 7021 7072 7071 8091 8092 8143 8142
8 7021 7022 7073 7072 8092 8093 8144 8143
8 7022 7023 7074 7073 8093 8094 8145 8144
8 7023 7024 7075 7074 8094 8095 8146 8145
8 7024 7025 7076 7075 8095 8096 8147 8146
8 7025 7026 7077 7076 8096 8097 8148 8147
8 7026 7027 7078 7077 8097 8098 8149 8148
8 7027 7028 7079 7078 8098 8099 8150 8149
8 7028 7029 7080 7079 8099 8100 8151 8150
8 7029 7030 7081 7080 8100 8101 8152 8151
8 7030 7031 7082 7081 8101 8102 8153 8152
8 7031 7032 7083 7082 8102 8103 8154 8153
8 7032 7033 7084 7083 8103 8104 8155 8154
8 7033 7034 7085 7084 8104 8105 8156 8155
8 7034 7035 7086 7085 8105 8106 8157 8156
8 7035 7036 7087 7086 8106 8107 8158 8157
8 7036 7037 7088 7087 8107 8108 8159 8158
8 7038 7039 7090 7089 8109 8110 8161 8160
8 7039 7040 7091 7090 8110 8111 8162 8161
8 7040 7041 7092 7091 8111 8112 8163 8162
8 7041 7042 7093 7092 8112 8113 8164 8163
8 7042 7043 7094 7093 8113 8114 8165 8164
8 7043 7044 7095 7094 8114 8115 8166 8165
8 7044 7045 7096 7095 8115 8116 8167 8166
8 7045 7046 7097 7096 8116 8117 8168 8167
8 7046 7047 7098 7097 8117 8118 8169 8168
8 7047 7048 7099 7098 8118 8119 8170 8169
8 7048 7049 7100 7099 8119 8120 8171 8170
8 7049 7050 7101 7100 8120 8121 8172 8171
8 7050 7051 7102 7101 8121 8122 8173 8172
8 7051 7052 7103 7102 8122 8123 8174 8173
8 7052 7053 7104 7103 8123 8124 8175 8174
8 7053 7054 7105 7104 8124 8125 8176 8175
8 7054 7055 7106 7105 8125 8126 8177 8176
8 7055 7056 7107 7106 8126 8127 8178 8177
8 7056 7057 7108 7107 8127 8128 8179 8178
8 7057 7058 7109 7108 8128 8129 8180 8179
8 7058 7059 7110 7109 8129 8130 8181 8180
8 7059 7060 7111 7110 8130 8131 8182 8181
8 7060 7061 7112 7111 8131 8132 8183 8182
8 7061 7062 7113 7112 8132 8133 8184 8183
8 7062 7063 7114 7113 8133 8134 8185 8184
8 7063 7064 7115 7114 8134 8135 8186 8185
8 7064 7065 7116 7115 8135 8136 8187 8186
8 7065 7066 7117 7116 8136 8137 8188 8187
8 7066 7067 7118 7117 8137 8138 8189 8188
8 7067 7068 7119 7118 8138 8139 8190 8189
8 7068 7069 7120 7119 8139 8140 8191 8190
8 7069 7070 7121 7120 8140 8141 8192 8191
8 7070 7071 7122 7121 8141 8142 8193 8192
8 7071 7072 7123 7122 8142 8143 8194 8193
8 7072 7073 7124 7123 8143 8144 8195 8194
8 7073 7074 7125 7124 8144 8145 8196 8195
8 7074 7075 7126 7125 8145 8146 8197 8196
8 7075 7076 7127 7126 8146 8147 8198 8197
8 7076 7077 7128 7127 8147 8148 8199 8198
8 7077 7078 7129 7128 8148 8149 8200 8199
8 7078 7079 7130 7129 8149 8150 8201 8200
8 7079 7080 7131 7130 8150 8151 8202 8201
8 7080 7081 7132 7131 8151 8152 8203 8202
8 7081 7082 7133 7132 8152 8153 8204 8203
8 7082 7083 7134 7133 8153 8154 8205 8204
8 7083 7084 7135 7134 8154 8155 8206 8205
8 7084 7085 7136 7135 8155 8156 8207 8206
8 7085 7086 7137 7136 8156 8157 8208 8207
8 7086 7087 7138 7137 8157 8158 8209 8208
8 7087 7088 7139 7138 8158 8159 8210 8209
8 7089 7090 7141 7140 8160 8161 8212 8211
8 7090 7091 7142 7141 8161 8162 8213 8212
8 7091 7092 7143 7142 8162 8163 8214 8213
8 7092 7093 7144 7143 8163 8164 8215 8214
8 7093 7094 7145 7144 8164 8165 8216 8215
8 7094 7095 7146 7145 8165 8166 8217 8216
8 7095 7096 7147 7146 8166 8167 8218 8217
8 7096 7097 7148 7147 8167 8168 8219 8218
8 7097 7098 7149 7148 8168 8169 8220 8219
8 7098 7099 7150 7149 8169 8170 8221 8220
8 7099 7100 7151 7150 8170 8171 8222 8221
8 7100 7101 7152 7151 8171 8172 8223 8222
8 7101 7102 7153 7152 8172 8173 8224 8223
8 7102 7103 7154 7153 8173 8174 8225 8224
8 7103 7104 7155 7154 8174 8175 8226 8225
8 7104 7105 7156 7155 8175 8176 8227 8226
8 7105 7106 7157 7156 8176 8177 8228 8227
8 7106 7107 7158 7157 8177 8178 8229 8228
8 7107 7108 7159 7158 8178 8179 8230 8229
8 7108 7109 7160 7159 8179 8180 8231 8230
8 7109 7110 7161 7160 8180 8181 8232 8231
8 7110 7111 7162 7161 8181 8182 8233 8232
8 7111 7112 7163 7162 8182 8183 8234 8233
8 7112 7113 7164 7163 8183 8184 8235 8234
8 7113 7114 7165 7164 8184 8185 8236 8235
8 7114 7115 7166 7165 8185 8186 8237 8236
8 7115 7116 7167 7166 8186 8187 8238 8237
8 7116 7117 7168 7167 8187 8188 8239 8238
8 7117 7118 7169 7168 8188 8189 8240 8239
8 7118 7119 7170 7169 8189 8190 8241 8240
8 7119 7120 7171 7170 8190 8191 8242 8241
8 7120 7121 7172 7171 8191 8192 8243 8242
8 7121 7122 7173 7172 8192 8193 8244 8243
8 7122 7123 7174 7173 8193 8194 8245 8244
8 7123 7124 7175 7174 8194 8195 8246 8245
8 7124 7125 7176 7175 8195 8196 8247 8246
8 7125 7126 7177 7176 8196 8197 8248 8247
8 7126 7127 7178 7177 8197 8198 8249 8248
8 7127 7128 7179 7178 8198 8199 8250 8249
8 7128 7129 7180 7179 8199 8200 8251 8250
8 7129 7130 7181 7180 8200 8201 8252 8251
8 7130 7131 7182 7181 8201 8202 8253 8252
8 7131 7132 7183 7182 8202 8203 8254 8253
8 7132 7133 7184 7183 8203 8204 8255 8254
8 7133 7134 7185 7184 8204 8205 8256 8255
8 7134 7135 7186 7185 8205 8206 8257 8256
8 7135 7136 7187 7186 8206 8207 8258 8257
8 7136 7137 7188 7187 8207 8208 8259 8258
8 7137 7138 7189 7188 8208 8209 8260 8259
8 7138 7139 7190 7189 8209 8210 8261 8260
8 7140 7141 7192 7191 8211 8212 8263 8262
8 7141 7142 7193 7192 8212 8213 8264 8263
8 7142 7143 7194 7193 8213 8214 8265 8264
8 7143 7144 7195 7194 8214 8215 8266 8265
8 7144 7145 7196 7195 8215 8216 8267 8266
8 7145 7146 7197 7196 8216 8217 8268 8267
8 7146 7147 7198 7197 8217 8218 8269 8268
8 7147 7148 7199 7198 8218 8219 8270 8269
8 7148 7149 7200 7199 8219 8220 8271 8270
8 7149 7150 7201 7200 8220 8221 8272 8271
8 7150 7151 7202 7201 8221 8222 8273 8272
8 7151 7152 7203 7202 8222 8223 8274 8273
8 7152 7153 7204 7203 8223 8224 8275 8274
8 7153 7154 7205 7204 8224 8225 8276 8275
8 7154 7155 7206 7205 8225 8226 8277 8276
8 7155 7156 7207 7206 8226 8227 8278 8277
8 7156 7157 7208 7207 8227 8228 8279 8278
8 7157 7158 7209 7208 8228 8229 8280 8279
8 7158 7159 7210 7209 8229 8230 8281 8280
8 7159 7160 7211 7210 8230 8231 8282 8281
8 7160 7161 7212 7211 8231 8232 8283 8282
8 7161 7162 7213 7212 8232 8233 8284 8283
8 7162 7163 7214 7213 8233 8234 8285 8284
8 7163 7164 7215 7214 8234 8235 8286 8285
8 7164 7165 7216 7215 8235 8236 8287 8286
8 7165 7166 7217 7216 8236 8237 8288 8287
8 7166 7167 7218 7217 8237 8238 8289 8288
8 7167 7168 7219 7218 8238 8239 8290 8289
8 7168 7169 7220 7219 8239 8240 8291 8290
8 7169 7170 7221 7220 8240 8241 8292 8291
8 7170 7171 7222 7221 8241 8242 8293 8292
8 7171 7172 7223 7222 8242 8243 8294 8293
8 7172 7173 7224 7223 8243 8244 8295 8294
8 7173 7174 7225 7224 8244 8245 8296 8295
8 7174 7175 7226 7225 8245 8246 8297 8296
8 7175 7176 7227 7226 8246 8247 8298 8297
8 7176 7177 7228 7227 8247 8248 8299 8298
8 7177 7178 7229 7228 8248 8249 8300 8299
8 7178 7179 7230 7229 8249 8250 8301 8300
8 7179 7180 7231 7230 8250 8251 8302 8301
8 7180 7181 7232 7231 8251 8252 8303 8302
8 7181 7182 7233 7232 8252 8253 8304 8303
8 7182 7183 7234 7233 8253 8254 8305 8304
8 7183 7184 7235 7234 8254 8255 8306 8305
8 7184 7185 7236 7235 8255 8256 8307 8306
8 7185 7186 7237 7236 8256 8257 8308 8307
8 7186 7187 7238 7237 8257 8258 8309 8308
8 7187 7188 7239 7238 8258 8259 8310 8309
8 7188 7189 7240 7239 8259 8260 8311 8310
8 7189 7190 7241 7240 8260 8261 8312 8311
8 7191 7192 7243 7242 8262 8263 8314 8313
8 7192 7193 7244 7243 8263 8264 8315 8314
8 7193 7194 7245 7244 8264 8265 8316 8315
8 7194 7195 7246 7245 8265 8266 8317 8316
8 7195 7196 7247 7246 8266 8267 8318 8317
8 7196 7197 7248 7247 8267 8268 8319 8318
8 7197 7198 7249 7248 8268 8269 8320 8319
8 7198 7199 7250 7249 8269 8270 8321 8320
8 7199 7200 7251 7250 8270 8271 8322 8321
8 7200 7201 7252 7251 8271 8272 8323 8322
8 7201 7202 7253 7252 8272 8273 8324 8323
8 7202 7203 7254 7253 8273 8274 8325 8324
8 7203 7204 7255 7254 8274 8275 8326 8325
8 7204 7205 7256 7255 8275 8276 8327 8326
8 7205 7206 7257 7256 8276 8277 8328 8327
8 7206 7207 7258 7257 8277 8278 8329 8328
8 7207 7208 7259 7258 8278 8279 8330 8329
8 7208 7209 7260 7259 8279 8280 8331 8330
8 7209 7210 7261 7260 8280 8281 8332 8331
8 7210 7211 7262 7261 8281 8282 8333 8332
8 7211 7212 7263 7262 8282 8283 8334 8333
8 7212 7213 7264 7263 8283 8284 8335 8334
8 7213 7214 7265 7264 8284 8285 8336 8335
8 7214 7215 7266 7265 8285 8286 8337 8336
8 7215 7216 7267 7266 8286 8287 8338 8337
8 7216 7217 7268 7267 8287 8288 8339 8338
8 7217 7218 7269 7268 8288 8289 8340 8339
8 7218 7219 7270 7269 8289 8290 8341 8340
8 7219 7220 7271 7270 8290 8291 8342 8341
8 7220 7221 7272 7271 8291 8292 8343 8342
8 7221 7222 7273 7272 8292 8293 8344 8343
8 7222 7223 7274 7273 8293 8294 8345 8344
8 7223 7224 7275 7274 8294 8295 8346 8345
8 7224 7225 7276 7275 8295 8296 8347 8346
8 7225 7226 7277 7276 8296 8297 8348 8347
8 7226 7227 7278 7277 8297 8298 8349 8348
8 7227 7228 7279 7278 8298 8299 8350 8349
8 7228 7229 7280 7279 8299 8300 8351 8350
8 7229 7230 7281 7280 8300 8301 8352 8351
8 7230 7231 7282 7281 8301 8302 8353 8352
8 7231 7232 7283 7282 8302 8303 8354 8353
8 7232 7233 7284 7283 8303 8304 8355 8354
8 7233 7234 7285 7284 8304 8305 8356 8355
8 7234 7235 7286 7285 8305 8306 8357 8356
8 7235 7236 7287 7286 8306 8307 8358 8357
8 7236 7237 7288 7287 8307 8308 8359 8358
8 7237 7238 7289 7288 8308 8309 8360 8359
8 7238 7239 7290 7289 8309 8310 8361 8360
8 7239 7240 7291 7290 8310 8311 8362 8361
8 7240 7241 7292 7291 8311 8312 8363 8362
8 7242 7243 7294 7293 8313 8314 8365 8364
8 7243 7244 7295 7294 8314 8315 8366 8365
8 7244 7245 7296 7295 8315 8316 8367 8366
8 7245 7246 7297 7296 8316 8317 8368 8367
8 7246 7247 7298 7297 8317 8318 8369 8368
8 7247 7248 7299 7298 8318 8319 8370 8369
8 7248 7249 7300 7299 8319 8320 8371 8370
8 7249 7250 7301 7300 8320 8321 8372 8371
8 7250 7251 7302 7301 8321 8322 8373 8372
8 7251 7252 7303 7302 8322 8323 8374 8373
8 7252 7253 7304 7303 8323 8324 8375 8374
8 7253 7254 7305 7304 8324 8325 8376 8375
8 7254 7255 7306 7305 8325 8326 8377 8376
8 7255 7256 7307 7306 8326 8327 8378 8377
8 7256 7257 7308 7307 8327 8328 8379 8378
8 7257 7258 7309 7308 8328 8329 8380 8379
8 7258 7259 7310 7309 8329 8330 8381 8380
8 7259 7260 7311 7310 8330 8331 8382 8381
8 7260 7261 7312 7311 8331 8332 8383 8382
8 7261 7262 7313 7312 8332 8333 8384 8383
8 7262 7263 7314 7313 8333 8334 8385 8384
8 7263 7264 7315 7314 8334 8335 8386 8385
8 7264 7265 7316 7315 8335 8336 8387 8386
8 7265 7266 7317 7316 8336 8337 8388 8387
8 7266 7267 7318 7317 8337 8338 8389 8388
8 7267 7268 7319 7318 8338 8339 8390 8389
8 7268 7269 7320 7319 8339 8340 8391 8390
8 7269 7270 7321 7320 8340 8341 8392 8391
8 7270 7271 7322 7321 8341 8342 8393 8392
8 7271 7272 7323 7322 8342 8343 8394 8393
8 7272 7273 7324 7323 8343 8344 8395 8394
8 7273 7274 7325 7324 8344 8345 8396 8395
8 7274 7275 7326 7325 8345 8346 8397 8396
8 7275 7276 7327 7326 8346 8347 8398 8397
8 7276 7277 7328 7327 8347 8348 8399 8398
8 7277 7278 7329 7328 8348 8349 8400 8399
8 7278 7279 7330 7329 8349 8350 8401 8400
8 7279 7280 7331 7330 8350 8351 8402 8401
8 7280 7281 7332 7331 8351 8352 8403 8402
8 7281 7282 7333 7332 8352 8353 8404 8403
8 7282 7283 7334 7333 8353 8354 8405 8404
8 7283 7284 7335 7334 8354 8355 8406 8405
8 7284 7285 7336 7335 8355 8356 8407 8406
8 7285 7286 7337 7336 8356 8357 8408 8407
8 7286 7287 7338 7337 8357 8358 8409 8408
8 7287 7288 7339 7338 8358 8359 8410 8409
8 7288 7289 7340 7339 8359 8360 8411 8410
8 7289 7290 7341 7340 8360 8361 8412 8411
8 7290 7291 7342 7341 8361 8362 8413 8412
8 7291 7292 7343 7342 8362 8363 8414 8413
8 7293 7294 7345 7344 8364 8365 8416 8415
8 7294 7295 7346 7345 8365 8366 8417 8416
8 7295 7296 7347 7346 8366 8367 8418 8417
8 7296 7297 7348 7347 8367 8368 8419 8418
8 7297 7298 7349 7348 8368 8369 8420 8419
8 7298 7299 7350 7349 8369 8370 8421 8420
8 7299 7300 7351 7350 8370 8371 8422 8421
8 7300 7301 7352 7351 8371 8372 8423 8422
8 7301 7302 7353 7352 8372 8373 8424 8423
8 7302 7303 7354 7353 8373 8374 8425 8424
8 7303 7304 7355 7354 8374 8375 8426 8425
8 7304 7305 7356 7355 8375 8376 8427 8426
8 7305 7306 7357 7356 8376 8377 8428 8427
8 7306 7307 7358 7357 8377 8378 8429 8428
8 7307 7308 7359 7358 8378 8379 8430 8429
8 7308 7309 7360 7359 8379 8380 8431 8430
8 7309 7310 7361 7360 8380 8381 8432 8431
8 7310 7311 7362 7361 8381 8382 8433 8432
8 7311 7312 7363 7362 8382 8383 8434 8433
8 7312 7313 7364 7363 8383 8384 8435 8434
8 7313 7314 7365 7364 8384 8385 8436 8435
8 7314 7315 7366 7365 8385 8386 8437 8436
8 7315 7316 7367 7366 8386 8387 8438 8437
8 7316 7317 7368 7367 8387 8388 8439 8438
8 7317 7318 7369 7368 8388 8389 8440 8439
8 7318 7319 7370 7369 8389 8390 8441 8440
8 7319 7320 7371 7370 8390 8391 8442 8441
8 7320 7321 7372 7371 8391 8392 8443 8442
8 7321 7322 7373 7372 8392 8393 8444 8443
8 7322 7323 7374 7373 8393 8394 8445 8444
8 7323 7324 7375 7374 8394 8395 8446 8445
8 7324 7325 7376 7375 8395 8396 8447 8446
8 7325 7326 7377 7376 8396 8397 8448 8447
8 7326 7327 7378 7377 8397 8398 8449 8448
8 7327 7328 7379 7378 8398 8399 8450 8449
8 7328 7329 7380 7379 8399 8400 8451 8450
8 7329 7330 7381 7380 8400 8401 8452 8451
8 7330 7331 7382 7381 8401 8402 8453 8452
8 7331 7332 7383 7382 8402 8403 8454 8453
8 7332 7333 7384 7383 8403 8404 8455 8454
8 7333 7334 7385 7384 8404 8405 8456 8455
8 7334 7335 7386 7385 8405 8406 8457 8456
8 7335 7336 7387 7386 8406 8407 8458 8457
8 7336 7337 7388 7387 8407 8408 8459 8458
8 7337 7338 7389 7388 8408 8409 8460 8459
8 7338 7339 7390 7389 8409 8410 8461 8460
8 7339 7340 7391 7390 8410 8411 8462 8461
8 7340 7341 7392 7391 8411 8412 8463 8462
8 7341 7342 7393 7392 8412 8413 8464 8463
8 7342 7343 7394 7393 8413 8414 8465 8464
8 7344 7345 7396 7395 8415 8416 8467 8466
8 7345 7346 7397 7396 8416 8417 8468 8467
8 7346 7347 7398 7397 8417 8418 8469 8468
8 7347 7348 7399 7398 8418 8419 8470 8469
8 7348 7349 7400 7399 8419 8420 8471 8470
8 7349 7350 7401 7400 8420 8421 8472 8471
8 7350 7351 7402 7401 8421 8422 8473 8472
8 7351 7352 7403 7402 8422 8423 8474 8473
8 7352 7353 7404 7403 8423 8424 8475 8474
8 7353 7354 7405 7404 8424 8425 8476 8475
8 7354 7355 7406 7405 8425 8426 8477 8476
8 7355 7356 7407 7406 8426 8427 8478 8477
8 7356 7357 7408 7407 8427 8428 8479 8478
8 7357 7358 7409 7408 8428 8429 8480 8479
8 7358 7359 7410 7409 8429 8430 8481 8480
8 7359 7360 7411 7410 8430 8431 8482 8481
8 7360 7361 7412 7411 8431 8432 8483 8482
8 7361 7362 7413 7412 8432 8433 8484 8483
8 7362 7363 7414 7413 8433 8434 8485 8484
8 7363 7364 7415 7414 8434 8435 8486 8485
8 7364 7365 7416 7415 8435 8436 8487 8486
8 7365 7366 7417 7416 8436 8437 8488 8487
8 7366 7367 7418 7417 8437 8438 8489 8488
8 7367 7368 7419 7418 8438 8439 8490 8489
8 7368 7369 7420 7419 8439 8440 8491 8490
8 7369 7370 7421 7420 8440 8441 8492 8491
8 7370 7371 7422 7421 8441 8442 8493 8492
8 7371 7372 7423 7422 8442 8443 8494 8493
8 7372 7373 7424 7423 8443 8444 8495 8494
8 7373 7374 7425 7424 8444 8445 8496 8495
8 7374 7375 7426 7425 8445 8446 8497 8496
8 7375 7376 7427 7426 8446 8447 8498 8497
8 7376 7377 7428 7427 8447 8448 8499 8498
8 7377 7378 7429 7428 8448 8449 8500 8499
8 7378 7379 7430 7429 8449 8450 8501 8500
8 7379 7380 7431 7430 8450 8451 8502 8501
8 7380 7381 7432 7431 8451 8452 8503 8502
8 7381 7382 7433 7432 8452 8453 8504 8503
8 7382 7383 7434 7433 8453 8454 8505 8504
8 7383 7384 7435 7434 8454 8455 8506 8505
8 7384 7385 7436 7435 8455 8456 8507 8506
8 7385 7386 7437 7436 8456 8457 8508 8507
8 7386 7387 7438 7437 8457 8458 8509 8508
8 7387 7388 7439 7438 8458 8459 8510 8509
8 7388 7389 7440 7439 8459 8460 8511 8510
8 7389 7390 7441 7440 8460 8461 8512 8511
8 7390 7391 7442 7441 8461 8462 8513 8512
8 7391 7392 7443 7442 8462 8463 8514 8513
8 7392 7393 7444 7443 8463 8464 8515 8514
8 7393 7394 7445 7444 8464 8465 8516 8515
8 7395 7396 7447 7446 8466 8467 8518 8517
8 7396 7397 7448 7447 8467 8468 8519 8518
8 7397 7398 7449 7448 8468 8469 8520 8519
8 7398 7399 7450 7449 8469 8470 8521 8520
8 7399 7400 7451 7450 8470 8471 8522 8521
8 7400 7401 7452 7451 8471 8472 8523 8522
8 7401 7402 7453 7452 8472 8473 8524 8523
8 7402 7403 7454 7453 8473 8474 8525 8524
8 7403 7404 7455 7454 8474 8475 8526 8525
8 7404 7405 7456 7455 8475 8476 8527 8526
8 7405 7406 7457 7456 8476 8477 8528 8527
8 7406 7407 7458 7457 8477 8478 8529 8528
8 7407 7408 7459 7458 8478 8479 8530 8529
8 7408 7409 7460 7459 8479 8480 8531 8530
8 7409 7410 7461 7460 8480 8481 8532 8531
8 7410 7411 7462 7461 8481 8482 8533 8532
8 7411 7412 7463 7462 8482 8483 8534 8533
8 7412 7413 7464 7463 8483 8484 8535 8534
8 7413 7414 7465 7464 8484 8485 8536 8535
8 7414 7415 7466 7465 8485 8486 8537 8536
8 7415 7416 7467 7466 8486 8487 8538 8537
8 7416 7417 7468 7467 8487 8488 8539 8538
8 7417 7418 7469 7468 8488 8489 8540 8539
8 7418 7419 7470 7469 8489 8490 8541 8540
8 7419 7420 7471 7470 8490 8491 8542 8541
8 7420 7421 7472 7471 8491 8492 8543 8542
8 7421 7422 7473 7472 8492 8493 8544 8543
8 7422 7423 7474 7473 8493 8494 8545 8544
8 7423 7424 7475 7474 8494 8495 8546 8545
8 7424 7425 7476 7475 8495 8496 8547 8546
8 7425 7426 7477 7476 8496 8497 8548 8547
8 7426 7427 7478 7477 8497 8498 8549 8548
8 7427 7428 7479 7478 8498 8499 8550 8549
8 7428 7429 7480 7479 8499 8500 8551 8550
8 7429 7430 7481 7480 8500 8501 8552 8551
8 7430 7431 7482 7481 8501 8502 8553 8552
8 7431 7432 7483 7482 8502 8503 8554 8553
8 7432 7433 7484 7483 8503 8504 8555 8554
8 7433 7434 7485 7484 8504 8505 8556 8555
8 7434 7435 7486 7485 8505 8506 8557 8556
8 7435 7436 7487 7486 8506 8507 8558 8557
8 7436 7437 7488 7487 8507 8508 8559 8558
8 7437 7438 7489 7488 8508 8509 8560 8559
8 7438 7439 7490 7489 8509 8510 8561 8560
8 7439 7440 7491 7490 8510 8511 8562 8561
8 7440 7441 7492 7491 8511 8512 8563 8562
8 7441 7442 7493 7492 8512 8513 8564 8563
8 7442 7443 7494 7493 8513 8514 8565 8564
8 7443 7444 7495 7494 8514 8515 8566 8565
8 7444 7445 7496 7495 8515 8516 8567 8566
8 7497 7498 7549 7548 8568 8569 8620 8619
8 7498 7499 7550 7549 8569 8570 8621 8620
8 7499 7500 7551 7550 8570 8571 8622 8621
8 7500 7501 7552 7551 8571 8572 8623 8622
8 7501 7502 7553 7552 8572 8573 8624 8623
8 7502 7503 7554 7553 8573 8574 8625 8624
8 7503 7504 7555 7554 8574 8575 8626 8625
8 7504 7505 7556 7555 8575 8576 8627 8626
8 7505 7506 7557 7556 8576 8577 8628 8627
8 7506 7507 7558 7557 8577 8578 8629 8628
8 7507 7508 7559 7558 8578 8579 8630 8629
8 7508 7509 7560 7559 8579 8580 8631 8630
8 7509 7510 7561 7560 8580 8581 8632 8631
8 7510 7511 7562 7561 8581 8582 8633 8632
8 7511 7512 7563 7562 8582 8583 8634 8633
8 7512 7513 7564 7563 8583 8584 8635 8634
8 7513 7514 7565 7564 8584 8585 8636 8635
8 7514 7515 7566 7565 8585 8586 8637 8636
8 7515 7516 7567 7566 8586 8587 8638 8637
8 7516 7517 7568 7567 8587 8588 8639 8638
8 7517 7518 7569 7568 8588 8589 8640 8639
8 7518 7519 7570 7569 8589 8590 8641 8640
8 7519 7520 7571 7570 8590 8591 8642 8641
8 7520 7521 7572 7571 8591 8592 8643 8642
8 7521 7522 7573 7572 8592 8593 8644 8643
8 7522 7523 7574 7573 8593 8594 8645 8644
8 7523 7524 7575 7574 8594 8595 8646 8645
8 7524 7525 7576 7575 8595 8596 8647 8646
8 7525 7526 7577 7576 8596 8597 8648 8647
8 7526 7527 7578 7577 8597 8598 8649 8648
8 7527 7528 7579 7578 8598 8599 8650 8649
8 7528 7529 7580 7579 8599 8600 8651 8650
8 7529 7530 7581 7580 8600 8601 8652 8651
8 7530 7531 7582 7581 8601 8602 8653 8652
8 7531 7532 7583 7582 8602 8603 8654 8653
8 7532 7533 7584 7583 8603 8604 8655 8654
8 7533 7534 7585 7584 8604 8605 8656 8655
8 7534 7535 7586 7585 8605 8606 8657 8656
8 7535 7536 7587 7586 8606 8607 8658 8657
8 7536 7537 7588 7587 8607 8608 8659 8658
8 7537 7538 7589 7588 8608 8609 8660 8659
8 7538 7539 7590 7589 8609 8610 8661 8660
8 7539 7540 7591 7590 8610 8611 8662 8661
8 7540 7541 7592 7591 8611 8612 8663 8662
8 7541 7542 7593 7592 8612 8613 8664 8663
8 7542 7543 7594 7593 8613 8614 8665 8664
8 7543 7544 7595 7594 8614 8615 8666 8665
8 7544 7545 7596 7595 8615 8616 8667 8666
8 7545 7546 7597 7596 8616 8617 8668 8667
8 7546 7547 7598 7597 8617 8618 8669 8668
8 7548 7549 7600 7599 8619 8620 8671 8670
8 7549 7550 7601 7600 8620 8621 8672 8671
8 7550 7551 7602 7601 8621 8622 8673 8672
8 7551 7552 7603 7602 8622 8623 8674 8673
8 7552 7553 7604 7603 8623 8624 8675 8674
8 7553 7554 7605 7604 8624 8625 8676 8675
8 7554 7555 7606 7605 8625 8626 8677 8676
8 7555 7556 7607 7606 8626 8627 8678 8677
8 7556 7557 7608 7607 8627 8628 8679 8678
8 7557 7558 7609 7608 8628 8629 8680 8679
8 7558 7559 7610 7609 8629 8630 8681 8680
8 7559 7560 7611 7610 8630 8631 8682 8681
8 7560 7561 7612 7611 8631 8632 8683 8682
8 7561 7562 7613 7612 8632 8633 8684 8683
8 7562 7563 7614 7613 8633 8634 8685 8684
8 7563 7564 7615 7614 8634 8635 8686 8685
8 7564 7565 7616 7615 8635 8636 8687 8686
8 7565 7566 7617 7616 8636 8637 8688 8687
8 7566 7567 7618 7617 8637 8638 8689 8688
8 7567 7568 7619 7618 8638 8639 8690 8689
8 7568 7569 7620 7619 8639 8640 8691 8690
8 7569 7570 7621 7620 8640 8641 8692 8691
8 7570 7571 7622 7621 8641 8642 8693 8692
8 7571 7572 7623 7622 8642 8643 8694 8693
8 7572 7573 7624 7623 8643 8644 8695 8694
8 7573 7574 7625 7624 8644 8645 8696 8695
8 7574 7575 7626 7625 8645 8646 8697 8696
8 7575 7576 7627 7626 8646 8647 8698 8697
8 7576 7577 7628 7627 8647 8648 8699 8698
8 7577 7578 7629 7628 8648 8649 8700 8699
8 7578 7579 7630 7629 8649 8650 8701 8700
8 7579 7580 7631 7630 8650 8651 8702 8701
8 7580 7581 7632 7631 8651 8652 8703 8702
8 7581 7582 7633 7632 8652 8653 8704 8703
8 7582 7583 7634 7633 8653 8654 8705 8704
8 7583 7584 7635 7634 8654 8655 8706 8705
8 7584 7585 7636 7635 8655 8656 8707 8706
8 7585 7586 7637 7636 8656 8657 8708 8707
8 7586 7587 7638 7637 8657 8658 8709 8708
8 7587 7588 7639 7638 8658 8659 8710 8709
8 7588 7589 7640 7639 8659 8660 8711 8710
8 7589 7590 7641 7640 8660 8661 8712 8711
8 7590 7591 7642 7641 8661 8662 8713 8712
8 7591 7592 7643 7642 8662 8663 8714 8713
8 7592 7593 7644 7643 8663 8664 8715 8714
8 7593 7594 7645 7644 8664 8665 8716 8715
8 7594 7595 7646 7645 8665 8666 8717 8716
8 7595 7596 7647 7646 8666 8667 8718 8717
8 7596 7597 7648 7647 8667 8668 8719 8718
8 7597 7598 7649 7648 8668 8669 8720 8719
8 7599 7600 7651 7650 8670 8671 8722 8721
8 7600 7601 7652 7651 8671 8672 8723 8722
8 7601 7602 7653 7652 8672 8673 8724 8723
8 7602 7603 7654 7653 8673 8674 8725 8724
8 7603 7604 7655 7654 8674 8675 8726 8725
8 7604 7605 7656 7655 8675 8676 8727 8726
8 7605 7606 7657 7656 8676 8677 8728 8727
8 7606 7607 7658 7657 8677 8678 8729 8728
8 7607 7608 7659 7658 8678 8679 8730 8729
8 7608 7609 7660 7659 8679 8680 8731 8730
8 7609 7610 7661 7660 8680 8681 8732 8731
8 7610 7611 7662 7661 8681 8682 8733 8732
8 7611 7612 7663 7662 8682 8683 8734 8733
8 7612 7613 7664 7663 8683 8684 8735 8734
8 7613 7614 7665 7664 8684 8685 8736 8735
8 7614 7615 7666 7665 8685 8686 8737 8736
8 7615 7616 7667 7666 8686 8687 8738 8737
8 7616 7617 7668 7667 8687 8688 8739 8738
8 7617 7618 7669 7668 8688 8689 8740 8739
8 7618 7619 7670 7669 8689 8690 8741 8740
8 7619 7620 7671 7670 8690 8691 8742 8741
8 7620 7621 7672 7671 8691 8692 8743 8742
8 7621 7622 7673 7672 8692 8693 8744 8743
8 7622 7623 7674 7673 8693 8694 8745 8744
8 7623 7624 7675 7674 8694 8695 8746 8745
8 7624 7625 7676 7675 8695 8696 8747 8746
8 7625 7626 7677 7676 8696 8697 8748 8747
8 7626 7627 7678 7677 8697 8698 8749 8748
8 7627 7628 7679 7678 8698 8699 8750 8749
8 7628 7629 7680 7679 8699 8700 8751 8750
8 7629 7630 7681 7680 8700 8701 8752 8751
8 7630 7631 7682 7681 8701 8702 8753 8752
8 7631 7632 7683 7682 8702 8703 8754 8753
8 7632 7633 7684 7683 8703 8704 8755 8754
8 7633 7634 7685 7684 8704 8705 8756 8755
8 7634 7635 7686 7685 8705 8706 8757 8756
8 7635 7636 7687 7686 8706 8707 8758 8757
8 7636 7637 7688 7687 8707 8708 8759 8758
8 7637 7638 7689 7688 8708 8709 8760 8759
8 7638 7639 7690 7689 8709 8710 8761 8760
8 7639 7640 7691 7690 8710 8711 8762 8761
8 7640 7641 7692 7691 8711 8712 8763 8762
8 7641 7642 7693 7692 8712 8713 8764 8763
8 7642 7643 7694 7693 8713 8714 8765 8764
8 7643 7644 7695 7694 8714 8715 8766 8765
8 7644 7645 7696 7695 8715 8716 8767 8766
8 7645 7646 7697 7696 8716 8717 8768 8767
8 7646 7647 7698 7697 8717 8718 8769 8768
8 7647 7648 7699 7698 8718 8719 8770 8769
8 7648 7649 7700 7699 8719 8720 8771 8770
8 7650 7651 7702 7701 8721 8722 8773 8772
8 7651 7652 7703 7702 8722 8723 8774 8773
8 7652 7653 7704 7703 8723 8724 8775 8774
8 7653 7654 7705 7704 8724 8725 8776 8775
8 7654 7655 7706 7705 8725 8726 8777 8776
8 7655 7656 7707 7706 8726 8727 8778 8777
8 7656 7657 7708 7707 8727 8728 8779 8778
8 7657 7658 7709 7708 8728 8729 8780 8779
8 7658 7659 7710 7709 8729 8730 8781 8780
8 7659 7660 7711 7710 8730 8731 8782 8781
8 7660 7661 7712 7711 8731 8732 8783 8782
8 7661 7662 7713 7712 8732 8733 8784 8783
8 7662 7663 7714 7713 8733 8734 8785 8784
8 7663 7664 7715 7714 8734 8735 8786 8785
8 7664 7665 7716 7715 8735 8736 8787 8786
8 7665 7666 7717 7716 8736 8737 8788 8787
8 7666 7667 7718 7717 8737 8738 8789 8788
8 7667 7668 7719 7718 8738 8739 8790 8789
8 7668 7669 7720 7719 8739 8740 8791 8790
8 7669 7670 7721 7720 8740 8741 8792 8791
8 7670 7671 7722 7721 8741 8742 8793 8792
8 7671 7672 7723 7722 8742 8743 8794 8793
8 7672 7673 7724 7723 8743 8744 8795 8794
8 7673 7674 7725 7724 8744 8745 8796 8795
8 7674 7675 7726 7725 8745 8746 8797 8796
8 7675 7676 7727 7726 8746 8747 8798 8797
8 7676 7677 7728 7727 8747 8748 8799 8798
8 7677 7678 7729 7728 8748 8749 8800 8799
8 7678 7679 7730 7729 8749 8750 8801 8800
8 7679 7680 7731 7730 8750 8751 8802 8801
8 7680 7681 7732 7731 8751 8752 8803 8802
8 7681 7682 7733 7732 8752 8753 8804 8803
8 7682 7683 7734 7733 8753 8754 8805 8804
8 7683 7684 7735 7734 8754 8755 8806 8805
8 7684 7685 7736 7735 8755 8756 8807 8806
8 7685 7686 7737 7736 8756 8757 8808 8807
8 7686 7687 7738 7737 8757 8758 8809 8808
8 7687 7688 7739 7738 8758 8759 8810 8809
8 7688 7689 7740 7739 8759 8760 8811 8810
8 7689 7690 7741 7740 8760 8761 8812 8811
8 7690 7691 7742 7741 8761 8762 8813 8812
8 7691 7692 7743 7742 8762 8763 8814 8813
8 7692 7693 7744 7743 8763 8764 8815 8814
8 7693 7694 7745 7744 8764 8765 8816 8815
8 7694 7695 7746 7745 8765 8766 8817 8816
8 7695 7696 7747 7746 8766 8767 8818 8817
8 7696 7697 7748 7747 8767 8768 8819 8818
8 7697 7698 7749 7748 8768 8769 8820 8819
8 7698 7699 7750 7749 8769 8770 8821 8820
8 7699 7700 7751 7750 8770 8771 8822 8821
8 7701 7702 7753 7752 8772 8773 8824 8823
8 7702 7703 7754 7753 8773 8774 8825 8824
8 7703 7704 7755 7754 8774 8775 8826 8825
8 7704 7705 7756 7755 8775 8776 8827 8826
8 7705 7706 7757 7756 8776 8777 8828 8827
8 7706 7707 7758 7757 8777 8778 8829 8828
8 7707 7708 7759 7758 8778 8779 8830 8829
8 7708 7709 7760 7759 8779 8780 8831 8830
8 7709 7710 7761 7760 8780 8781 8832 8831
8 7710 7711 7762 7761 8781 8782 8833 8832
8 7711 7712 7763 7762 8782 8783 8834 8833
8 7712 7713 7764 7763 8783 8784 8835 8834
8 7713 7714 7765 7764 8784 8785 8836 8835
8 7714 7715 7766 7765 8785 8786 8837 8836
8 7715 7716 7767 7766 8786 8787 8838 8837
8 7716 7717 7768 7767 8787 8788 8839 8838
8 7717 7718 7769 7768 8788 8789 8840 8839
8 7718 7719 7770 7769 8789 8790 8841 8840
8 7719 7720 7771 7770 8790 8791 8842 8841
8 7720 7721 7772 7771 8791 8792 8843 8842
8 7721 7722 7773 7772 8792 8793 8844 8843
8 7722 7723 7774 7773 8793 8794 8845 8844
8 7723 7724 7775 7774 8794 8795 8846 8845
8 7724 7725 7776 7775 8795 8796 8847 8846
8 7725 7726 7777 7776 8796 8797 8848 8847
8 7726 7727 7778 7777 8797 8798 8849 8848
8 7727 7728 7779 7778 8798 8799 8850 8849
8 7728 7729 7780 7779 8799 8800 8851 8850
8 7729 7730 7781 7780 8800 8801 8852 8851
8 7730 7731 7782 7781 8801 8802 8853 8852
8 7731 7732 7783 7782 8802 8803 8854 8853
8 7732 7733 7784 7783 8803 8804 8855 8854
8 7733 7734 7785 7784 8804 8805 8856 8855
8 7734 7735 7786 7785 8805 8806 8857 8856
8 7735 7736 7787 7786 8806 8807 8858 8857
8 7736 7737 7788 7787 8807 8808 8859 8858
8 7737 7738 7789 7788 8808 8809 8860 8859
8 7738 7739 7790 7789 8809 8810 8861 8860
8 7739 7740 7791 7790 8810 8811 8862 8861
8 7740 7741 7792 7791 8811 8812 8863 8862
8 7741 7742 7793 7792 8812 8813 8864 8863
8 7742 7743 7794 7793 8813 8814 8865 8864
8 7743 7744 7795 7794 8814 8815 8866 8865
8 7744 7745 7796 7795 8815 8816 8867 8866
8 7745 7746 7797 7796 8816 8817 8868 8867
8 7746 7747 7798 7797 8817 8818 8869 8868
8 7747 7748 7799 7798 8818 8819 8870 8869
8 7748 7749 7800 7799 8819 8820 8871 8870
8 7749 7750 7801 7800 8820 8821 8872 8871
8 7750 7751 7802 7801 8821 8822 8873 8872
8 7752 7753 7804 7803 8823 8824 8875 8874
8 7753 7754 7805 7804 8824 8825 8876 8875
8 7754 7755 7806 7805 8825 8826 8877 8876
8 7755 7756 7807 7806 8826 8827 8878 8877
8 7756 7757 7808 7807 8827 8828 8879 8878
8 7757 7758 7809 7808 8828 8829 8880 8879
8 7758 7759 7810 7809 8829 8830 8881 8880
8 7759 7760 7811 7810 8830 8831 8882 8881
8 7760 7761 7812 7811 8831 8832 8883 8882
8 7761 7762 7813 7812 8832 8833 8884 8883
8 7762 7763 7814 7813 8833 8834 8885 8884
8 7763 7764 7815 7814 8834 8835 8886 8885
8 7764 7765 7816 7815 8835 8836 8887 8886
8 7765 7766 7817 7816 8836 8837 8888 8887
8 7766 7767 7818 7817 8837 8838 8889 8888
8 7767 7768 7819 7818 8838 8839 8890 8889
8 7768 7769 7820 7819 8839 8840 8891 8890
8 7769 7770 7821 7820 8840 8841 8892 8891
8 7770 7771 7822 7821 8841 8842 8893 8892
8 7771 7772 7823 7822 8842 8843 8894 8893
8 7772 7773 7824 7823 8843 8844 8895 8894
8 7773 7774 7825 7824 8844 8845 8896 8895
8 7774 7775 7826 7825 8845 8846 8897 8896
8 7775 7776 7827 7826 8846 8847 8898 8897
8 7776 7777 7828 7827 8847 8848 8899 8898
8 7777 7778 7829 7828 8848 8849 8900 8899
8 7778 7779 7830 7829 8849 8850 8901 8900
8 7779 7780 7831 7830 8850 8851 8902 8901
8 7780 7781 7832 7831 8851 8852 8903 8902
8 7781 7782 7833 7832 8852 8853 8904 8903
8 7782 7783 7834 7833 8853 8854 8905 8904
8 7783 7784 7835 7834 8854 8855 8906 8905
8 7784 7785 7836 7835 8855 8856 8907 8906
8 7785 7786 7837 7836 8856 8857 8908 8907
8 7786 7787 7838 7837 8857 8858 8909 8908
8 7787 7788 7839 7838 8858 8859 8910 8909
8 7788 7789 7840 7839 8859 8860 8911 8910
8 7789 7790 7841 7840 8860 8861 8912 8911
8 7790 7791 7842 7841 8861 8862 8913 8912
8 7791 7792 7843 7842 8862 8863 8914 8913
8 7792 7793 7844 7843 8863 8864 8915 8914
8 7793 7794 7845 7844 8864 8865 8916 8915
8 7794 7795 7846 7845 8865 8866 8917 8916
8 7795 7796 7847 7846 8866 8867 8918 8917
8 7796 7797 7848 7847 8867 8868 8919 8918
8 7797 7798 7849 7848 8868 8869 8920 8919
8 7798 7799 7850 7849 8869 8870 8921 8920
8 7799 7800 7851 7850 8870 8871 8922 8921
8 7800 7801 7852 7851 8871 8872 8923 8922
8 7801 7802 7853 7852 8872 8873 8924 8923
8 7803 7804 7855 7854 8874 8875 8926 8925
8 7804 7805 7856 7855 8875 8876 8927 8926
8 7805 7806 7857 7856 8876 8877 8928 8927
8 7806 7807 7858 7857 8877 8878 8929 8928
8 7807 7808 7859 7858 8878 8879 8930 8929
8 7808 7809 7860 7859 8879 8880 8931 8930
8 7809 7810 7861 7860 8880 8881 8932 8931
8 7810 7811 7862 7861 8881 8882 8933 8932
8 7811 7812 7863 7862 8882 8883 8934 8933
8 7812 7813 7864 7863 8883 8884 8935 8934
8 7813 7814 7865 7864 8884 8885 8936 8935
8 7814 7815 7866 7865 8885 8886 8937 8936
8 7815 7816 7867 7866 8886 8887 8938 8937
8 7816 7817 7868 7867 8887 8888 8939 8938
8 7817 7818 7869 7868 8888 8889 8940 8939
8 7818 7819 7870 7869 8889 8890 8941 8940
8 7819 7820 7871 7870 8890 8891 8942 8941
8 7820 7821 7872 7871 8891 8892 8943 8942
8 7821 7822 7873 7872 8892 8893 8944 8943
8 7822 7823 7874 7873 8893 8894 8945 8944
8 7823 7824 7875 7874 8894 8895 8946 8945
8 7824 7825 7876 7875 8895 8896 8947 8946
8 7825 7826 7877 7876 8896 8897 8948 8947
8 7826 7827 7878 7877 8897 8898 8949 8948
8 7827 7828 7879 7878 8898 8899 8950 8949
8 7828 7829 7880 7879 8899 8900 8951 8950
8 7829 7830 7881 7880 8900 8901 8952 8951
8 7830 7831 7882 7881 8901 8902 8953 8952
8 7831 7832 7883 7882 8902 8903 8954 8953
8 7832 7833 7884 7883 8903 8904 8955 8954
8 7833 7834 7885 7884 8904 8905 8956 8955
8 7834 7835 7886 7885 8905 8906 8957 8956
8 7835 7836 7887 7886 8906 8907 8958 8957
8 7836 7837 7888 7887 8907 8908 8959 8958
8 7837 7838 7889 7888 8908 8909 8960 8959
8 7838 7839 7890 7889 8909 8910 8961 8960
8 7839 7840 7891 7890 8910 8911 8962 8961
8 7840 7841 7892 7891 8911 8912 8963 8962
8 7841 7842 7893 7892 8912 8913 8964 8963
8 7842 7843 7894 7893 8913 8914 8965 8964
8 7843 7844 7895 7894 8914 8915 8966 8965
8 7844 7845 7896 7895 8915 8916 8967 8966
8 7845 7846 7897 7896 8916 8917 8968 8967
8 7846 7847 7898 7897 8917 8918 8969 8968
8 7847 7848 7899 7898 8918 8919 8970 8969
8 7848 7849 7900 7899 8919 8920 8971 8970
8 7849 7850 7901 7900 8920 8921 8972 8971
8 7850 7851 7902 7901 8921 8922 8973 8972
8 7851 7852 7903 7902 8922 8923 8974 8973
8 7852 7853 7904 7903 8923 8924 8975 8974
8 7854 7855 7906 7905 8925 8926 8977 8976
8 7855 7856 7907 7906 8926 8927 8978 8977
8 7856 7857 7908 7907 8927 8928 8979 8978
8 7857 7858 7909 7908 8928 8929 8980 8979
8 7858 7859 7910 7909 8929 8930 8981 8980
8 7859 7860 7911 7910 8930 8931 8982 8981
8 7860 7861 7912 7911 8931 8932 8983 8982
8 7861 7862 7913 7912 8932 8933 8984 8983
8 7862 7863 7914 7913 8933 8934 8985 8984
8 7863 7864 7915 7914 8934 8935 8986 8985
8 7864 7865 7916 7915 8935 8936 8987 8986
8 7865 7866 7917 7916 8936 8937 8988 8987
8 7866 7867 7918 7917 8937 8938 8989 8988
8 7867 7868 7919 7918 8938 8939 8990 8989
8 7868 7869 7920 7919 8939 8940 8991 8990
8 7869 7870 7921 7920 8940 8941 8992 8991
8 7870 7871 7922 7921 8941 8942 8993 8992
8 7871 7872 7923 7922 8942 8943 8994 8993
8 7872 7873 7924 7923 8943 8944 8995 8994
8 7873 7874 7925 7924 8944 8945 8996 8995
8 7874 7875 7926 7925 8945 8946 8997 8996
8 7875 7876 7927 7926 8946 8947 8998 8997
8 7876 7877 7928 7927 8947 8948 8999 8998
8 7877 7878 7929 7928 8948 8949 9000 8999
8 7878 7879 7930 7929 8949 8950 9001 9000
8 7879 7880 7931 7930 8950 8951 9002 9001
8 7880 7881 7932 7931 8951 8952 9003 9002
8 7881 7882 7933 7932 8952 8953 9004 9003
8 7882 7883 7934 7933 8953 8954 9005 9004
8 7883 7884 7935 7934 8954 8955 9006 9005
8 7884 7885 7936 7935 8955 8956 9007 9006
8 7885 7886 7937 7936 8956 8957 9008 9007
8 7886 7887 7938 7937 8957 8958 9009 9008
8 7887 7888 7939 7938 8958 8959 9010 9009
8 7888 7889 7940 7939 8959 8960 9011 9010
8 7889 7890 7941 7940 8960 8961 9012 9011
8 7890 7891 7942 7941 8961 8962 9013 9012
8 7891 7892 7943 7942 8962 8963 9014 9013
8 7892 7893 7944 7943 8963 8964 9015 9014
8 7893 7894 7945 7944 8964 8965 9016 9015
8 7894 7895 7946 7945 8965 8966 9017 9016
8 7895 7896 7947 7946 8966 8967 9018 9017
8 7896 7897 7948 7947 8967 8968 9019 9018
8 7897 7898 7949 7948 8968 8969 9020 9019
8 7898 7899 7950 7949 8969 8970 9021 9020
8 7899 7900 7951 7950 8970 8971 9022 9021
8 7900 7901 7952 7951 8971 8972 9023 9022
8 7901 7902 7953 7952 8972 8973 9024 9023
8 7902 7903 7954 7953 8973 8974 9025 9024
8 7903 7904 7955 7954 8974 8975 9026 9025
8 7905 7906 7957 7956 8976 8977 9028 9027
8 7906 7907 7958 7957 8977 8978 9029 9028
8 7907 7908 7959 7958 8978 8979 9030 9029
8 7908 7909 7960 7959 8979 8980 9031 9030
8 7909 7910 7961 7960 8980 8981 9032 9031
8 7910 7911 7962 7961 8981 8982 9033 9032
8 7911 7912 7963 7962 8982 8983 9034 9033
8 7912 7913 7964 7963 8983 8984 9035 9034
8 7913 7914 7965 7964 8984 8985 9036 9035
8 7914 7915 7966 7965 8985 8986 9037 9036
8 7915 7916 7967 7966 8986 8987 9038 9037
8 7916 7917 7968 7967 8987 8988 9039 9038
8 7917 7918 7969 7968 8988 8989 9040 9039
8 7918 7919 7970 7969 8989 8990 9041 9040
8 7919 7920 7971 7970 8990 8991 9042 9041
8 7920 7921 7972 7971 8991 8992 9043 9042
8 7921 7922 7973 7972 8992 8993 9044 9043
8 7922 7923 7974 7973 8993 8994 9045 9044
8 7923 7924 7975 7974 8994 8995 9046 9045
8 7924 7925 7976 7975 8995 8996 9047 9046
8 7925 7926 7977 7976 8996 8997 9048 9047
8 7926 7927 7978 7977 8997 8998 9049 9048
8 7927 7928 7979 7978 8998 8999 9050 9049
8 7928 7929 7980 7979 8999 9000 9051 9050
8 7929 7930 7981 7980 9000 9001 9052 9051
8 7930 7931 7982 7981 9001 9002 9053 9052
8 7931 7932 7983 7982 9002 9003 9054 9053
8 7932 7933 7984 7983 9003 9004 9055 9054
8 7933 7934 7985 7984 9004 9005 9056 9055
8 7934 7935 7986 7985 9005 9006 9057 9056
8 7935 7936 7987 7986 9006 9007 9058 9057
8 7936 7937 7988 7987 9007 9008 9059 9058
8 7937 7938 7989 7988 9008 9009 9060 9059
8 7938 7939 7990 7989 9009 9010 9061 9060
8 7939 7940 7991 7990 9010 9011 9062 9061
8 7940 7941 7992 7991 9011 9012 9063 9062
8 7941 7942 7993 7992 9012 9013 9064 9063
8 7942 7943 7994 7993 9013 9014 9065 9064
8 7943 7944 7995 7994 9014 9015 9066 9065
8 7944 7945 7996 7995 9015 9016 9067 9066
8 7945 7946 7997 7996 9016 9017 9068 9067
8 7946 7947 7998 7997 9017 9018 9069 9068
8 7947 7948 7999 7998 9018 9019 9070 9069
8 7948 7949 8000 7999 9019 9020 9071 9070
8 7949 7950 8001 8000 9020 9021 9072 9071
8 7950 7951 8002 8001 9021 9022 9073 9072
8 7951 7952 8003 8002 9022 9023 9074 9073
8 7952 7953 8004 8003 9023 9024 9075 9074
8 7953 7954 8005 8004 9024 9025 9076 9075
8 7954 7955 8006 8005 9025 9026 9077 9076
8 7956 7957 8008 8007 9027 9028 9079 9078
8 7957 7958 8009 8008 9028 9029 9080 9079
8 7958 7959 8010 8009 9029 9030 9081 9080
8 7959 7960 8011 8010 9030 9031 9082 9081
8 7960 7961 8012 8011 9031 9032 9083 9082
8 7961 7962 8013 8012 9032 9033 9084 9083
8 7962 7963 8014 8013 9033 9034 9085 9084
8 7963 7964 8015 8014 9034 9035 9086 9085
8 7964 7965 8016 8015 9035 9036 9087 9086
8 7965 7966 8017 8016 9036 9037 9088 9087
8 7966 7967 8018 8017 9037 9038 9089 9088
8 7967 7968 8019 8018 9038 9039 9090 9089
8 7968 7969 8020 8019 9039 9040 9091 9090
8 7969 7970 8021 8020 9040 9041 9092 9091
8 7970 7971 8022 8021 9041 9042 9093 9092
8 7971 7972 8023 8022 9042 9043 9094 9093
8 7972 7973 8024 8023 9043 9044 9095 9094
8 7973 7974 8025 8024 9044 9045 9096 9095
8 7974 7975 8026 8025 9045 9046 9097 9096
8 7975 7976 8027 8026 9046 9047 9098 9097
8 7976 7977 8028 8027 9047 9048 9099 9098
8 7977 7978 8029 8028 9048 9049 9100 9099
8 7978 7979 8030 8029 9049 9050 9101 9100
8 7979 7980 8031 8030 9050 9051 9102 9101
8 7980 7981 8032 8031 9051 9052 9103 9102
8 7981 7982 8033 8032 9052 9053 9104 9103
8 7982 7983 8034 8033 9053 9054 9105 9104
8 7983 7984 8035 8034 9054 9055 9106 9105
8 7984 7985 8036 8035 9055 9056 9107 9106
8 7985 7986 8037 8036 9056 9057 9108 9107
8 7986 7987 8038 8037 9057 9058 9109 9108
8 7987 7988 8039 8038 9058 9059 9110 9109
8 7988 7989 8040 8039 9059 9060 9111 9110
8 7989 7990 8041 8040 9060 9061 9112 9111
8 7990 7991 8042 8041 9061 9062 9113 9112
8 7991 7992 8043 8042 9062 9063 9114 9113
8 7992 7993 8044 8043 9063 9064 9115 9114
8 7993 7994 8045 8044 9064 9065 9116 9115
8 7994 7995 8046 8045 9065 9066 9117 9116
8 7995 7996 8047 8046 9066 9067 9118 9117
8 7996 7997 8048 8047 9067 9068 9119 9118
8 7997 7998 8049 8048 9068 9069 9120 9119
8 7998 7999 8050 8049 9069 9070 9121 9120
8 7999 8000 8051 8050 9070 9071 9122 9121
8 8000 8001 8052 8051 9071 9072 9123 9122
8 8001 8002 8053 8052 9072 9073 9124 9123
8 8002 8003 8054 8053 9073 9074 9125 9124
8 8003 8004 8055 8054 9074 9075 9126 9125
8 8004 8005 8056 8055 9075 9076 9127 9126
8 8005 8006 8057 8056 9076 9077 9128 9127
8 8007 8008 8059 8058 9078 9079 9130 9129
8 8008 8009 8060 8059 9079 9080 9131 9130
8 8009 8010 8061 8060 9080 9081 9132 9131
8 8010 8011 8062 8061 9081 9082 9133 9132
8 8011 8012 8063 8062 9082 9083 9134 9133
8 8012 8013 8064 8063 9083 9084 9135 9134
8 8013 8014 8065 8064 9084 9085 9136 9135
8 8014 8015 8066 8065 9085 9086 9137 9136
8 8015 8016 8067 8066 9086 9087 9138 9137
8 8016 8017 8068 8067 9087 9088 9139 9138
8 8017 8018 8069 8068 9088 9089 9140 9139
8 8018 8019 8070 8069 9089 9090 9141 9140
8 8019 8020 8071 8070 9090 9091 9142 9141
8 8020 8021 8072 8071 9091 9092 9143 9142
8 8021 8022 8073 8072 9092 9093 9144 9143
8 8022 8023 8074 8073 9093 9094 9145 9144
8 8023 8024 8075 8074 9094 9095 9146 9145
8 8024 8025 8076 8075 9095 9096 9147 9146
8 8025 8026 8077 8076 9096 9097 9148 9147
8 8026 8027 8078 8077 9097 9098 9149 9148
8 8027 8028 8079 8078 9098 9099 9150 9149
8 8028 8029 8080 8079 9099 9100 9151 9150
8 8029 8030 8081 8080 9100 9101 9152 9151
8 8030 8031 8082 8081 9101 9102 9153 9152
8 8031 8032 8083 8082 9102 9103 9154 9153
8 8032 8033 8084 8083 9103 9104 9155 9154
8 8033 8034 8085 8084 9104 9105 9156 9155
8 8034 8035 8086 8085 9105 9106 9157 9156
8 8035 8036 8087 8086 9106 9107 9158 9157
8 8036 8037 8088 8087 9107 9108 9159 9158
8 8037 8038 8089 8088 9108 9109 9160 9159
8 8038 8039 8090 8089 9109 9110 9161 9160
8 8039 8040 8091 8090 9110 9111 9162 9161
8 8040 8041 8092 8091 9111 9112 9163 9162
8 8041 8042 8093 8092 9112 9113 9164 9163
8 8042 8043 8094 8093 9113 9114 9165 9164
8 8043 8044 8095 8094 9114 9115 9166 9165
8 8044 8045 8096 8095 9115 9116 9167 9166
8 8045 8046 8097 8096 9116 9117 9168 9167
8 8046 8047 8098 8097 9117 9118 9169 9168
8 8047 8048 8099 8098 9118 9119 9170 9169
8 8048 8049 8100 8099 9119 9120 9171 9170
8 8049 8050 8101 8100 9120 9121 9172 9171
8 8050 8051 8102 8101 9121 9122 9173 9172
8 8051 8052 8103 8102 9122 9123 9174 9173
8 8052 8053 8104 8103 9123 9124 9175 9174
8 8053 8054 8105 8104 9124 9125 9176 9175
8 8054 8055 8106 8105 9125 9126 9177 9176
8 8055 8056 8107 8106 9126 9127 9178 9177
8 8056 8057 8108 8107 9127 9128 9179 9178
8 8058 8059 8110 8109 9129 9130 9181 9180
8 8059 8060 8111 8110 9130 9131 9182 9181
8 8060 8061 8112 8111 9131 9132 9183 9182
8 8061 8062 8113 8112 9132 9133 9184 9183
8 8062 8063 8114 8113 9133 9134 9185 9184
8 8063 8064 8115 8114 9134 9135 9186 9185
8 8064 8065 8116 8115 9135 9136 9187 9186
8 8065 8066 8117 8116 9136 9137 9188 9187
8 8066 8067 8118 8117 9137 9138 9189 9188
8 8067 8068 8119 8118 9138 9139 9190 9189
8 8068 8069 8120 8119 9139 9140 9191 9190
8 8069 8070 8121 8120 9140 9141 9192 9191
8 8070 8071 8122 8121 9141 9142 9193 9192
8 8071 8072 8123 8122 9142 9143 9194 9193
8 8072 8073 8124 8123 9143 9144 9195 9194
8 8073 8074 8125 8124 9144 9145 9196 9195
8 8074 8075 8126 8125 9145 9146 9197 9196
8 8075 8076 8127 8126 9146 9147 9198 9197
8 8076 8077 8128 8127 9147 9148 9199 9198
8 8077 8078 8129 8128 9148 9149 9200 9199
8 8078 8079 8130 8129 9149 9150 9201 9200
8 8079 8080 8131 8130 9150 9151 9202 9201
8 8080 8081 8132 8131 9151 9152 9203 9202
8 8081 8082 8133 8132 9152 9153 9204 9203
8 8082 8083 8134 8133 9153 9154 9205 9204
8 8083 8084 8135 8134 9154 9155 9206 9205
8 8084 8085 8136 8135 9155 9156 9207 9206
8 8085 8086 8137 8136 9156 9157 9208 9207
8 8086 8087 8138 8137 9157 9158 9209 9208
8 8087 8088 8139 8138 9158 9159 9210 9209
8 8088 8089 8140 8139 9159 9160 9211 9210
8 8089 8090 8141 8140 9160 9161 9212 9211
8 8090 8091 8142 8141 9161 9162 9213 9212
8 8091 8092 8143 8142 9162 9163 9214 9213
8 8092 8093 8144 8143 9163 9164 9215 9214
8 8093 8094 8145 8144 9164 9165 9216 9215
8 8094 8095 8146 8145 9165 9166 9217 9216
8 8095 8096 8147 8146 9166 9167 9218 9217
8 8096 8097 8148 8147 9167 9168 9219 9218
8 8097 8098 8149 8148 9168 9169 9220 9219
8 8098 8099 8150 8149 9169 9170 9221 9220
8 8099 8100 8151 8150 9170 9171 9222 9221
8 8100 8101 8152 8151 9171 9172 9223 9222
8 8101 8102 8153 8152 9172 9173 9224 9223
8 8102 8103 8154 8153 9173 9174 9225 9224
8 8103 8104 8155 8154 9174 9175 9226 9225
8 8104 8105 8156 8155 9175 9176 9227 9226
8 8105 8106 8157 8156 9176 9177 9228 9227
8 8106 8107 8158 8157 9177 9178 9229 9228
8 8107 8108 8159 8158 9178 9179 9230 9229
8 8109 8110 8161 8160 9180 9181 9232 9231
8 8110 8111 8162 8161 9181 9182 9233 9232
8 8111 8112 8163 8162 9182 9183 9234 9233
8 8112 8113 8164 8163 9183 9184 9235 9234
8 8113 8114 8165 8164 9184 9185 9236 9235
8 8114 8115 8166 8165 9185 9186 9237 9236
8 8115 8116 8167 8166 9186 9187 9238 9237
8 8116 8117 8168 8167 9187 9188 9239 9238
8 8117 8118 8169 8168 9188 9189 9240 9239
8 8118 8119 8170 8169 9189 9190 9241 9240
8 8119 8120 8171 8170 9190 9191 9242 9241
8 8120 8121 8172 8171 9191 9192 9243 9242
8 8121 8122 8173 8172 9192 9193 9244 9243
8 8122 8123 8174 8173 9193 9194 9245 9244
8 8123 8124 8175 8174 9194 9195 9246 9245
8 8124 8125 8176 8175 9195 9196 9247 9246
8 8125 8126 8177 8176 9196 9197 9248 9247
8 8126 8127 8178 8177 9197 9198 9249 9248
8 8127 8128 8179 8178 9198 9199 9250 9249
8 8128 8129 8180 8179 9199 9200 9251 9250
8 8129 8130 8181 8180 9200 9201 9252 9251
8 8130 8131 8182 8181 9201 9202 9253 9252
8 8131 8132 8183 8182 9202 9203 9254 9253
8 8132 8133 8184 8183 9203 9204 9255 9254
8 8133 8134 8185 8184 9204 9205 9256 9255
8 8134 8135 8186 8185 9205 9206 9257 9256
8 8135 8136 8187 8186 9206 9207 9258 9257
8 8136 8137 8188 8187 9207 9208 9259 9258
8 8137 8138 8189 8188 9208 9209 9260 9259
8 8138 8139 8190 8189 9209 9210 9261 9260
8 8139 8140 8191 8190 9210 9211 9262 9261
8 8140 8141 8192 8191 9211 9212 9263 9262
8 8141 8142 8193 8192 9212 9213 9264 9263
8 8142 8143 8194 8193 9213 9214 9265 9264
8 8143 8144 8195 8194 9214 9215 9266 9265
8 8144 8145 8196 8195 9215 9216 9267 9266
8 8145 8146 8197 8196 9216 9217 9268 9267
8 8146 8147 8198 8197 9217 9218 9269 9268
8 8147 8148 8199 8198 9218 9219 9270 9269
8 8148 8149 8200 8199 9219 9220 9271 9270
8 8149 8150 8201 8200 9220 9221 9272 9271
8 8150 8151 8202 8201 9221 9222 9273 9272
8 8151 8152 8203 8202 9222 9223 9274 9273
8 8152 8153 8204 8203 9223 9224 9275 9274
8 8153 8154 8205 8204 9224 9225 9276 9275
8 8154 8155 8206 8205 9225 9226 9277 9276
8 8155 8156 8207 8206 9226 9227 9278 9277
8 8156 8157 8208 8207 9227 9228 9279 9278
8 8157 8158 8209 8208 9228 9229 9280 9279
8 8158 8159 8210 8209 9229 9230 9281 9280
8 8160 8161 8212 8211 9231 9232 9283 9282
8 8161 8162 8213 8212 9232 9233 9284 9283
8 8162 8163 8214 8213 9233 9234 9285 9284
8 8163 8164 8215 8214 9234 9235 9286 9285
8 8164 8165 8216 8215 9235 9236 9287 9286
8 8165 8166 8217 8216 9236 9237 9288 9287
8 8166 8167 8218 8217 9237 9238 9289 9288
8 8167 8168 8219 8218 9238 9239 9290 9289
8 8168 8169 8220 8219 9239 9240 9291 9290
8 8169 8170 8221 8220 9240 9241 9292 9291
8 8170 8171 8222 8221 9241 9242 9293 9292
8 8171 8172 8223 8222 9242 9243 9294 9293
8 8172 8173 8224 8223 9243 9244 9295 9294
8 8173 8174 8225 8224 9244 9245 9296 9295
8 8174 8175 8226 8225 9245 9246 9297 9296
8 8175 8176 8227 8226 9246 9247 9298 9297
8 8176 8177 8228 8227 9247 9248 9299 9298
8 8177 8178 8229 8228 9248 9249 9300 9299
8 8178 8179 8230 8229 9249 9250 9301 9300
8 8179 8180 8231 8230 9250 9251 9302 9301
8 8180 8181 8232 8231 9251 9252 9303 9302
8 8181 8182 8233 8232 9252 9253 9304 9303
8 8182 8183 8234 8233 9253 9254 9305 9304
8 8183 8184 8235 8234 9254 9255 9306 9305
8 8184 8185 8236 8235 9255 9256 9307 9306
8 8185 8186 8237 8236 9256 9257 9308 9307
8 8186 8187 8238 8237 9257 9258 9309 9308
8 8187 8188 8239 8238 9258 9259 9310 9309
8 8188 8189 8240 8239 9259 9260 9311 9310
8 8189 8190 8241 8240 9260 9261 9312 9311
8 8190 8191 8242 8241 9261 9262 9313 9312
8 8191 8192 8243 8242 9262 9263 9314 9313
8 8192 8193 8244 8243 9263 9264 9315 9314
8 8193 8194 8245 8244 9264 9265 9316 9315
8 8194 8195 8246 8245 9265 9266 9317 9316
8 8195 8196 8247 8246 9266 9267 9318 9317
8 8196 8197 8248 8247 9267 9268 9319 9318
8 8197 8198 8249 8248 9268 9269 9320 9319
8 8198 8199 8250 8249 9269 9270 9321 9320
8 8199 8200 8251 8250 9270 9271 9322 9321
8 8200 8201 8252 8251 9271 9272 9323 9322
8 8201 8202 8253 8252 9272 9273 9324 9323
8 8202 8203 8254 8253 9273 9274 9325 9324
8 8203 8204 8255 8254 9274 9275 9326 9325
8 8204 8205 8256 8255 9275 9276 9327 9326
8 8205 8206 8257 8256 9276 9277 9328 9327
8 8206 8207 8258 8257 9277 9278 9329 9328
8 8207 8208 8259 8258 9278 9279 9330 9329
8 8208 8209 8260 8259 9279 9280 9331 9330
8 8209 8210 8261 8260 9280 9281 9332 9331
8 8211 8212 8263 8262 9282 9283 9334 9333
8 8212 8213 8264 8263 9283 9284 9335 9334
8 8213 8214 8265 8264 9284 9285 9336 9335
8 8214 8215 8266 8265 9285 9286 9337 9336
8 8215 8216 8267 8266 9286 9287 9338 9337
8 8216 8217 8268 8267 9287 9288 9339 9338
8 8217 8218 8269 8268 9288 9289 9340 9339
8 8218 8219 8270 8269 9289 9290 9341 9340
8 8219 8220 8271 8270 9290 9291 9342 9341
8 8220 8221 8272 8271 9291 9292 9343 9342
8 8221 8222 8273 8272 9292 9293 9344 9343
8 8222 8223 8274 8273 9293 9294 9345 9344
8 8223 8224 8275 8274 9294 9295 9346 9345
8 8224 8225 8276 8275 9295 9296 9347 9346
8 8225 8226 8277 8276 9296 9297 9348 9347
8 8226 8227 8278 8277 9297 9298 9349 9348
8 8227 8228 8279 8278 9298 9299 9350 9349
8 8228 8229 8280 8279 9299 9300 9351 9350
8 8229 8230 8281 8280 9300 9301 9352 9351
8 8230 8231 8282 8281 9301 9302 9353 9352
8 8231 8232 8283 8282 9302 9303 9354 9353
8 8232 8233 8284 8283 9303 9304 9355 9354
8 8233 8234 8285 8284 9304 9305 9356 9355
8 8234 8235 8286 8285 9305 9306 9357 9356
8 8235 8236 8287 8286 9306 9307 9358 9357
8 8236 8237 8288 8287 9307 9308 9359 9358
8 8237 8238 8289 8288 9308 9309 9360 9359
8 8238 8239 8290 8289 9309 9310 9361 9360
8 8239 8240 8291 8290 9310 9311 9362 9361
8 8240 8241 8292 8291 9311 9312 9363 9362
8 8241 8242 8293 8292 9312 9313 9364 9363
8 8242 8243 8294 8293 9313 9314 9365 9364
8 8243 8244 8295 8294 9314 9315 9366 9365
8 8244 8245 8296 8295 9315 9316 9367 9366
8 8245 8246 8297 8296 9316 9317 9368 9367
8 8246 8247 8298 8297 9317 9318 9369 9368
8 8247 8248 8299 8298 9318 9319 9370 9369
8 8248 8249 8300 8299 9319 9320 9371 9370
8 8249 8250 8301 8300 9320 9321 9372 9371
8 8250 8251 8302 8301 9321 9322 9373 9372
8 8251 8252 8303 8302 9322 9323 9374 9373
8 8252 8253 8304 8303 9323 9324 9375 9374
8 8253 8254 8305 8304 9324 9325 9376 9375
8 8254 8255 8306 8305 9325 9326 9377 9376
8 8255 8256 8307 8306 9326 9327 9378 9377
8 8256 8257 8308 8307 9327 9328 9379 9378
8 8257 8258 8309 8308 9328 9329 9380 9379
8 8258 8259 8310 8309 9329 9330 9381 9380
8 8259 8260 8311 8310 9330 9331 9382 9381
8 8260 8261 8312 8311 9331 9332 9383 9382
8 8262 8263 8314 8313 9333 9334 9385 9384
8 8263 8264 8315 8314 9334 9335 9386 9385
8 8264 8265 8316 8315 9335 9336 9387 9386
8 8265 8266 8317 8316 9336 9337 9388 9387
8 8266 8267 8318 8317 9337 9338 9389 9388
8 8267 8268 8319 8318 9338 9339 9390 9389
8 8268 8269 8320 8319 9339 9340 9391 9390
8 8269 8270 8321 8320 9340 9341 9392 9391
8 8270 8271 8322 8321 9341 9342 9393 9392
8 8271 8272 8323 8322 9342 9343 9394 9393
8 8272 8273 8324 8323 9343 9344 9395 9394
8 8273 8274 8325 8324 9344 9345 9396 9395
8 8274 8275 8326 8325 9345 9346 9397 9396
8 8275 8276 8327 8326 9346 9347 9398 9397
8 8276 8277 8328 8327 9347 9348 9399 9398
8 8277 8278 8329 8328 9348 9349 9400 9399
8 8278 8279 8330 8329 9349 9350 9401 9400
8 8279 8280 8331 8330 9350 9351 9402 9401
8 8280 8281 8332 8331 9351 9352 9403 9402
8 8281 8282 8333 8332 9352 9353 9404 9403
8 8282 8283 8334 8333 9353 9354 9405 9404
8 8283 8284 8335 8334 9354 9355 9406 9405
8 8284 8285 8336 8335 9355 9356 9407 9406
8 8285 8286 8337 8336 9356 9357 9408 9407
8 8286 8287 8338 8337 9357 9358 9409 9408
8 8287 8288 8339 8338 9358 9359 9410 9409
8 8288 8289 8340 8339 9359 9360 9411 9410
8 8289 8290 8341 8340 9360 9361 9412 9411
8 8290 8291 8342 8341 9361 9362 9413 9412
8 8291 8292 8343 8342 9362 9363 9414 9413
8 8292 8293 8344 8343 9363 9364 9415 9414
8 8293 8294 8345 8344 9364 9365 9416 9415
8 8294 8295 8346 8345 9365 9366 9417 9416
8 8295 8296 8347 8346 9366 9367 9418 9417
8 8296 8297 8348 8347 9367 9368 9419 9418
8 8297 8298 8349 8348 9368 9369 9420 9419
8 8298 8299 8350 8349 9369 9370 9421 9420
8 8299 8300 8351 8350 9370 9371 9422 9421
8 8300 8301 8352 8351 9371 9372 9423 9422
8 8301 8302 8353 8352 9372 9373 9424 9423
8 8302 8303 8354 8353 9373 9374 9425 9424
8 8303 8304 8355 8354 9374 9375 9426 9425
8 8304 8305 8356 8355 9375 9376 9427 9426
8 8305 8306 8357 8356 9376 9377 9428 9427
8 8306 8307 8358 8357 9377 9378 9429 9428
8 8307 8308 8359 8358 9378 9379 9430 9429
8 8308 8309 8360 8359 9379 9380 9431 9430
8 8309 8310 8361 8360 9380 9381 9432 9431
8 8310 8311 8362 8361 9381 9382 9433 9432
8 8311 8312 8363 8362 9382 9383 9434 9433
8 8313 8314 8365 8364 9384 9385 9436 9435
8 8314 8315 8366 8365 9385 9386 9437 9436
8 8315 8316 8367 8366 9386 9387 9438 9437
8 8316 8317 8368 8367 9387 9388 9439 9438
8 8317 8318 8369 8368 9388 9389 9440 9439
8 8318 8319 8370 8369 9389 9390 9441 9440
8 8319 8320 8371 8370 9390 9391 9442 9441
8 8320 8321 8372 8371 9391 9392 9443 9442
8 8321 8322 8373 8372 9392 9393 9444 9443
8 8322 8323 8374 8373 9393 9394 9445 9444
8 8323 8324 8375 8374 9394 9395 9446 9445
8 8324 8325 8376 8375 9395 9396 9447 9446
8 8325 8326 8377 8376 9396 9397 9448 9447
8 8326 8327 8378 8377 9397 9398 9449 9448
8 8327 8328 8379 8378 9398 9399 9450 9449
8 8328 8329 8380 8379 9399 9400 9451 9450
8 8329 8330 8381 8380 9400 9401 9452 9451
8 8330 8331 8382 8381 9401 9402 9453 9452
8 8331 8332 8383 8382 9402 9403 9454 9453
8 8332 8333 8384 8383 9403 9404 9455 9454
8 8333 8334 8385 8384 9404 9405 9456 9455
8 8334 8335 8386 8385 9405 9406 9457 9456
8 8335 8336 8387 8386 9406 9407 9458 9457
8 8336 8337 8388 8387 9407 9408 9459 9458
8 8337 8338 8389 8388 9408 9409 9460 9459
8 8338 8339 8390 8389 9409 9410 9461 9460
8 8339 8340 8391 8390 9410 9411 9462 9461
8 8340 8341 8392 8391 9411 9412 9463 9462
8 8341 8342 8393 8392 9412 9413 9464 9463
8 8342 8343 8394 8393 9413 9414 9465 9464
8 8343 8344 8395 8394 9414 9415 9466 9465
8 8344 8345 8396 8395 9415 9416 9467 9466
8 8345 8346 8397 8396 9416 9417 9468 9467
8 8346 8347 8398 8397 9417 9418 9469 9468
8 8347 8348 8399 8398 9418 9419 9470 9469
8 8348 8349 8400 8399 9419 9420 9471 9470
8 8349 8350 8401 8400 9420 9421 9472 9471
8 8350 8351 8402 8401 9421 9422 9473 9472
8 8351 8352 8403 8402 9422 9423 9474 9473
8 8352 8353 8404 8403 9423 9424 9475 9474
8 8353 8354 8405 8404 9424 9425 9476 9475
8 8354 8355 8406 8405 9425 9426 9477 9476
8 8355 8356 8407 8406 9426 9427 9478 9477
8 8356 8357 8408 8407 9427 9428 9479 9478
8 8357 8358 8409 8408 9428 9429 9480 9479
8 8358 8359 8410 8409 9429 9430 9481 9480
8 8359 8360 8411 8410 9430 9431 9482 9481
8 8360 8361 8412 8411 9431 9432 9483 9482
8 8361 8362 8413 8412 9432 9433 9484 9483
8 8362 8363 8414 8413 9433 9434 9485 9484
8 8364 8365 8416 8415 9435 9436 9487 9486
8 8365 8366 8417 8416 9436 9437 9488 9487
8 8366 8367 8418 8417 9437 9438 9489 9488
8 8367 8368 8419 8418 9438 9439 9490 9489
8 8368 8369 8420 8419 9439 9440 9491 9490
8 8369 8370 8421 8420 9440 9441 9492 9491
8 8370 8371 8422 8421 9441 9442 9493 9492
8 8371 8372 8423 8422 9442 9443 9494 9493
8 8372 8373 8424 8423 9443 9444 9495 9494
8 8373 8374 8425 8424 9444 9445 9496 9495
8 8374 8375 8426 8425 9445 9446 9497 9496
8 8375 8376 8427 8426 9446 9447 9498 9497
8 8376 8377 8428 8427 9447 9448 9499 9498
8 8377 8378 8429 8428 9448 9449 9500 9499
8 8378 8379 8430 8429 9449 9450 9501 9500
8 8379 8380 8431 8430 9450 9451 9502 9501
8 8380 8381 8432 8431 9451 9452 9503 9502
8 8381 8382 8433 8432 9452 9453 9504 9503
8 8382 8383 8434 8433 9453 9454 9505 9504
8 8383 8384 8435 8434 9454 9455 9506 9505
8 8384 8385 8436 8435 9455 9456 9507 9506
8 8385 8386 8437 8436 9456 9457 9508 9507
8 8386 8387 8438 8437 9457 9458 9509 9508
8 8387 8388 8439 8438 9458 9459 9510 9509
8 8388 8389 8440 8439 9459 9460 9511 9510
8 8389 8390 8441 8440 9460 9461 9512 9511
8 8390 8391 8442 8441 9461 9462 9513 9512
8 8391 8392 8443 8442 9462 9463 9514 9513
8 8392 8393 8444 8443 9463 9464 9515 9514
8 8393 8394 8445 8444 9464 9465 9516 9515
8 8394 8395 8446 8445 9465 9466 9517 9516
8 8395 8396 8447 8446 9466 9467 9518 9517
8 8396 8397 8448 8447 9467 9468 9519 9518
8 8397 8398 8449 8448 9468 9469 9520 9519
8 8398 8399 8450 8449 9469 9470 9521 9520
8 8399 8400 8451 8450 9470 9471 9522 9521
8 8400 8401 8452 8451 9471 9472 9523 9522
8 8401 8402 8453 8452 9472 9473 9524 9523
8 8402 8403 8454 8453 9473 9474 9525 9524
8 8403 8404 8455 8454 9474 9475 9526 9525
8 8404 8405 8456 8455 9475 9476 9527 9526
8 8405 8406 8457 8456 9476 9477 9528 9527
8 8406 8407 8458 8457 9477 9478 9529 9528
8 8407 8408 8459 8458 9478 9479 9530 9529
8 8408 8409 8460 8459 9479 9480 9531 9530
8 8409 8410 8461 8460 9480 9481 9532 9531
8 8410 8411 8462 8461 9481 9482 9533 9532
8 8411 8412 8463 8462 9482 9483 9534 9533
8 8412 8413 8464 8463 9483 9484 9535 9534
8 8413 8414 8465 8464 9484 9485 9536 9535
8 8415 8416 8467 8466 9486 9487 9538 9537
8 8416 8417 8468 8467 9487 9488 9539 9538
8 8417 8418 8469 8468 9488 9489 9540 9539
8 8418 8419 8470 8469 9489 9490 9541 9540
8 8419 8420 8471 8470 9490 9491 9542 9541
8 8420 8421 8472 8471 9491 9492 9543 9542
8 8421 8422 8473 8472 9492 9493 9544 9543
8 8422 8423 8474 8473 9493 9494 9545 9544
8 8423 8424 8475 8474 9494 9495 9546 9545
8 8424 8425 8476 8475 9495 9496 9547 9546
8 8425 8426 8477 8476 9496 9497 9548 9547
8 8426 8427 8478 8477 9497 9498 9549 9548
8 8427 8428 8479 8478 9498 9499 9550 9549
8 8428 8429 8480 8479 9499 9500 9551 9550
8 8429 8430 8481 8480 9500 9501 9552 9551
8 8430 8431 8482 8481 9501 9502 9553 9552
8 8431 8432 8483 8482 9502 9503 9554 9553
8 8432 8433 8484 8483 9503 9504 9555 9554
8 8433 8434 8485 8484 9504 9505 9556 9555
8 8434 8435 8486 8485 9505 9506 9557 9556
8 8435 8436 8487 8486 9506 9507 9558 9557
8 8436 8437 8488 8487 9507 9508 9559 9558
8 8437 8438 8489 8488 9508 9509 9560 9559
8 8438 8439 8490 8489 9509 9510 9561 9560
8 8439 8440 8491 8490 9510 9511 9562 9561
8 8440 8441 8492 8491 9511 9512 9563 9562
8 8441 8442 8493 8492 9512 9513 9564 9563
8 8442 8443 8494 8493 9513 9514 9565 9564
8 8443 8444 8495 8494 9514 9515 9566 9565
8 8444 8445 8496 8495 9515 9516 9567 9566
8 8445 8446 8497 8496 9516 9517 9568 9567
8 8446 8447 8498 8497 9517 9518 9569 9568
8 8447 8448 8499 8498 9518 9519 9570 9569
8 8448 8449 8500 8499 9519 9520 9571 9570
8 8449 8450 8501 8500 9520 9521 9572 9571
8 8450 8451 8502 8501 9521 9522 9573 9572
8 8451 8452 8503 8502 9522 9523 9574 9573
8 8452 8453 8504 8503 9523 9524 9575 9574
8 8453 8454 8505 8504 9524 9525 9576 9575
8 8454 8455 8506 8505 9525 9526 9577 9576
8 8455 8456 8507 8506 9526 9527 9578 9577
8 8456 8457 8508 8507 9527 9528 9579 9578
8 8457 8458 8509 8508 9528 9529 9580 9579
8 8458 8459 8510 8509 9529 9530 9581 9580
8 8459 8460 8511 8510 9530 9531 9582 9581
8 8460 8461 8512 8511 9531 9532 9583 9582
8 8461 8462 8513 8512 9532 9533 9584 9583
8 8462 8463 8514 8513 9533 9534 9585 9584
8 8463 8464 8515 8514 9534 9535 9586 9585
8 8464 8465 8516 8515 9535 9536 9587 9586
8 8466 8467 8518 8517 9537 9538 9589 9588
8 8467 8468 8519 8518 9538 9539 9590 9589
8 8468 8469 8520 8519 9539 9540 9591 9590
8 8469 8470 8521 8520 9540 9541 9592 9591
8 8470 8471 8522 8521 9541 9542 9593 9592
8 8471 8472 8523 8522 9542 9543 9594 9593
8 8472 8473 8524 8523 9543 9544 9595 9594
8 8473 8474 8525 8524 9544 9545 9596 9595
8 8474 8475 8526 8525 9545 9546 9597 9596
8 8475 8476 8527 8526 9546 9547 9598 9597
8 8476 8477 8528 8527 9547 9548 9599 9598
8 8477 8478 8529 8528 9548 9549 9600 9599
8 8478 8479 8530 8529 9549 9550 9601 9600
8 8479 8480 8531 8530 9550 9551 9602 9601
8 8480 8481 8532 8531 9551 9552 9603 9602
8 8481 8482 8533 8532 9552 9553 9604 9603
8 8482 8483 8534 8533 9553 9554 9605 9604
8 8483 8484 8535 8534 9554 9555 9606 9605
8 8484 8485 8536 8535 9555 9556 9607 9606
8 8485 8486 8537 8536 9556 9557 9608 9607
8 8486 8487 8538 8537 9557 9558 9609 9608
8 8487 8488 8539 8538 9558 9559 9610 9609
8 8488 8489 8540 8539 9559 9560 9611 9610
8 8489 8490 8541 8540 9560 9561 9612 9611
8 8490 8491 8542 8541 9561 9562 9613 9612
8 8491 8492 8543 8542 9562 9563 9614 9613
8 8492 8493 8544 8543 9563 9564 9615 9614
8 8493 8494 8545 8544 9564 9565 9616 9615
8 8494 8495 8546 8545 9565 9566 9617 9616
8 8495 8496 8547 8546 9566 9567 9618 9617
8 8496 8497 8548 8547 9567 9568 9619 9618
8 8497 8498 8549 8548 9568 9569 9620 9619
8 8498 8499 8550 8549 9569 9570 9621 9620
8 8499 8500 8551 8550 9570 9571 9622 9621
8 8500 8501 8552 8551 9571 9572 9623 9622
8 8501 8502 8553 8552 9572 9573 9624 9623
8 8502 8503 8554 8553 9573 9574 9625 9624
8 8503 8504 8555 8554 9574 9575 9626 9625
8 8504 8505 8556 8555 9575 9576 9627 9626
8 8505 8506 8557 8556 9576 9577 9628 9627
8 8506 8507 8558 8557 9577 9578 9629 9628
8 8507 8508 8559 8558 9578 9579 9630 9629
8 8508 8509 8560 8559 9579 9580 9631 9630
8 8509 8510 8561 8560 9580 9581 9632 9631
8 8510 8511 8562 8561 9581 9582 9633 9632
8 8511 8512 8563 8562 9582 9583 9634 9633
8 8512 8513 8564 8563 9583 9584 9635 9634
8 8513 8514 8565 8564 9584 9585 9636 9635
8 8514 8515 8566 8565 9585 9586 9637 9636
8 8515 8516 8567 8566 9586 9587 9638 9637
8 8568 8569 8620 8619 9639 9640 9691 9690
8 8569 8570 8621 8620 9640 9641 9692 9691
8 8570 8571 8622 8621 9641 9642 9693 9692
8 8571 8572 8623 8622 9642 9643 9694 9693
8 8572 8573 8624 8623 9643 9644 9695 9694
8 8573 8574 8625 8624 9644 9645 9696 9695
8 8574 8575 8626 8625 9645 9646 9697 9696
8 8575 8576 8627 8626 9646 9647 9698 9697
8 8576 8577 8628 8627 9647 9648 9699 9698
8 8577 8578 8629 8628 9648 9649 9700 9699
8 8578 8579 8630 8629 9649 9650 9701 9700
8 8579 8580 8631 8630 9650 9651 9702 9701
8 8580 8581 8632 8631 9651 9652 9703 9702
8 8581 8582 8633 8632 9652 9653 9704 9703
8 8582 8583 8634 8633 9653 9654 9705 9704
8 8583 8584 8635 8634 9654 9655 9706 9705
8 8584 8585 8636 8635 9655 9656 9707 9706
8 8585 8586 8637 8636 9656 9657 9708 9707
8 8586 8587 8638 8637 9657 9658 9709 9708
8 8587 8588 8639 8638 9658 9659 9710 9709
8 8588 8589 8640 8639 9659 9660 9711 9710
8 8589 8590 8641 8640 9660 9661 9712 9711
8 8590 8591 8642 8641 9661 9662 9713 9712
8 8591 8592 8643 8642 9662 9663 9714 9713
8 8592 8593 8644 8643 9663 9664 9715 9714
8 8593 8594 8645 8644 9664 9665 9716 9715
8 8594 8595 8646 8645 9665 9666 9717 9716
8 8595 8596 8647 8646 9666 9667 9718 9717
8 8596 8597 8648 8647 9667 9668 9719 9718
8 8597 8598 8649 8648 9668 9669 9720 9719
8 8598 8599 8650 8649 9669 9670 9721 9720
8 8599 8600 8651 8650 9670 9671 9722 9721
8 8600 8601 8652 8651 9671 9672 9723 9722
8 8601 8602 8653 8652 9672 9673 9724 9723
8 8602 8603 8654 8653 9673 9674 9725 9724
8 8603 8604 8655 8654 9674 9675 9726 9725
8 8604 8605 8656 8655 9675 9676 9727 9726
8 8605 8606 8657 8656 9676 9677 9728 9727
8 8606 8607 8658 8657 9677 9678 9729 9728
8 8607 8608 8659 8658 9678 9679 9730 9729
8 8608 8609 8660 8659 9679 9680 9731 9730
8 8609 8610 8661 8660 9680 9681 9732 9731
8 8610 8611 8662 8661 9681 9682 9733 9732
8 8611 8612 8663 8662 9682 9683 9734 9733
8 8612 8613 8664 8663 9683 9684 9735 9734
8 8613 8614 8665 8664 9684 9685 9736 9735
8 8614 8615 8666 8665 9685 9686 9737 9736
8 8615 8616 8667 8666 9686 9687 9738 9737
8 8616 8617 8668 8667 9687 9688 9739 9738
8 8617 8618 8669 8668 9688 9689 9740 9739
8 8619 8620 8671 8670 9690 9691 9742 9741
8 8620 8621 8672 8671 9691 9692 9743 9742
8 8621 8622 8673 8672 9692 9693 9744 9743
8 8622 8623 8674 8673 9693 9694 9745 9744
8 8623 8624 8675 8674 9694 9695 9746 9745
8 8624 8625 8676 8675 9695 9696 9747 9746
8 8625 8626 8677 8676 9696 9697 9748 9747
8 8626 8627 8678 8677 9697 9698 9749 9748
8 8627 8628 8679 8678 9698 9699 9750 9749
8 8628 8629 8680 8679 9699 9700 9751 9750
8 8629 8630 8681 8680 9700 9701 9752 9751
8 8630 8631 8682 8681 9701 9702 9753 9752
8 8631 8632 8683 8682 9702 9703 9754 9753
8 8632 8633 8684 8683 9703 9704 9755 9754
8 8633 8634 8685 8684 9704 9705 9756 9755
8 8634 8635 8686 8685 9705 9706 9757 9756
8 8635 8636 8687 8686 9706 9707 9758 9757
8 8636 8637 8688 8687 9707 9708 9759 9758
8 8637 8638 8689 8688 9708 9709 9760 9759
8 8638 8639 8690 8689 9709 9710 9761 9760
8 8639 8640 8691 8690 9710 9711 9762 9761
8 8640 8641 8692 8691 9711 9712 9763 9762
8 8641 8642 8693 8692 9712 9713 9764 9763
8 8642 8643 8694 8693 9713 9714 9765 9764
8 8643 8644 8695 8694 9714 9715 9766 9765
8 8644 8645 8696 8695 9715 9716 9767 9766
8 8645 8646 8697 8696 9716 9717 9768 9767
8 8646 8647 8698 8697 9717 9718 9769 9768
8 8647 8648 8699 8698 9718 9719 9770 9769
8 8648 8649 8700 8699 9719 9720 9771 9770
8 8649 8650 8701 8700 9720 9721 9772 9771
8 8650 8651 8702 8701 9721 9722 9773 9772
8 8651 8652 8703 8702 9722 9723 9774 9773
8 8652 8653 8704 8703 9723 9724 9775 9774
8 8653 8654 8705 8704 9724 9725 9776 9775
8 8654 8655 8706 8705 9725 9726 9777 9776
8 8655 8656 8707 8706 9726 9727 9778 9777
8 8656 8657 8708 8707 9727 9728 9779 9778
8 8657 8658 8709 8708 9728 9729 9780 9779
8 8658 8659 8710 8709 9729 9730 9781 9780
8 8659 8660 8711 8710 9730 9731 9782 9781
8 8660 8661 8712 8711 9731 9732 9783 9782
8 8661 8662 8713 8712 9732 9733 9784 9783
8 8662 8663 8714 8713 9733 9734 9785 9784
8 8663 8664 8715 8714 9734 9735 9786 9785
8 8664 8665 8716 8715 9735 9736 9787 9786
8 8665 8666 8717 8716 9736 9737 9788 9787
8 8666 8667 8718 8717 9737 9738 9789 9788
8 8667 8668 8719 8718 9738 9739 9790 9789
8 8668 8669 8720 8719 9739 9740 9791 9790
8 8670 8671 8722 8721 9741 9742 9793 9792
8 8671 8672 8723 8722 9742 9743 9794 9793
8 8672 8673 8724 8723 9743 9744 9795 9794
8 8673 8674 8725 8724 9744 9745 9796 9795
8 8674 8675 8726 8725 9745 9746 9797 9796
8 8675 8676 8727 8726 9746 9747 9798 9797
8 8676 8677 8728 8727 9747 9748 9799 9798
8 8677 8678 8729 8728 9748 9749 9800 9799
8 8678 8679 8730 8729 9749 9750 9801 9800
8 8679 8680 8731 8730 9750 9751 9802 9801
8 8680 8681 8732 8731 9751 9752 9803 9802
8 8681 8682 8733 8732 9752 9753 9804 9803
8 8682 8683 8734 8733 9753 9754 9805 9804
8 8683 8684 8735 8734 9754 9755 9806 9805
8 8684 8685 8736 8735 9755 9756 9807 9806
8 8685 8686 8737 8736 9756 9757 9808 9807
8 8686 8687 8738 8737 9757 9758 9809 9808
8 8687 8688 8739 8738 9758 9759 9810 9809
8 8688 8689 8740 8739 9759 9760 9811 9810
8 8689 8690 8741 8740 9760 9761 9812 9811
8 8690 8691 8742 8741 9761 9762 9813 9812
8 8691 8692 8743 8742 9762 9763 9814 9813
8 8692 8693 8744 8743 9763 9764 9815 9814
8 8693 8694 8745 8744 9764 9765 9816 9815
8 8694 8695 8746 8745 9765 9766 9817 9816
8 8695 8696 8747 8746 9766 9767 9818 9817
8 8696 8697 8748 8747 9767 9768 9819 9818
8 8697 8698 8749 8748 9768 9769 9820 9819
8 8698 8699 8750 8749 9769 9770 9821 9820
8 8699 8700 8751 8750 9770 9771 9822 9821
8 8700 8701 8752 8751 9771 9772 9823 9822
8 8701 8702 8753 8752 9772 9773 9824 9823
8 8702 8703 8754 8753 9773 9774 9825 9824
8 8703 8704 8755 8754 9774 9775 9826 9825
8 8704 8705 8756 8755 9775 9776 9827 9826
8 8705 8706 8757 8756 9776 9777 9828 9827
8 8706 8707 8758 8757 9777 9778 9829 9828
8 8707 8708 8759 8758 9778 9779 9830 9829
8 8708 8709 8760 8759 9779 9780 9831 9830
8 8709 8710 8761 8760 9780 9781 9832 9831
8 8710 8711 8762 8761 9781 9782 9833 9832
8 8711 8712 8763 8762 9782 9783 9834 9833
8 8712 8713 8764 8763 9783 9784 9835 9834
8 8713 8714 8765 8764 9784 9785 9836 9835
8 8714 8715 8766 8765 9785 9786 9837 9836
8 8715 8716 8767 8766 9786 9787 9838 9837
8 8716 8717 8768 8767 9787 9788 9839 9838
8 8717 8718 8769 8768 9788 9789 9840 9839
8 8718 8719 8770 8769 9789 9790 9841 9840
8 8719 8720 8771 8770 9790 9791 9842 9841
8 8721 8722 8773 8772 9792 9793 9844 9843
8 8722 8723 8774 8773 9793 9794 9845 9844
8 8723 8724 8775 8774 9794 9795 9846 9845
8 8724 8725 8776 8775 9795 9796 9847 9846
8 8725 8726 8777 8776 9796 9797 9848 9847
8 8726 8727 8778 8777 9797 9798 9849 9848
8 8727 8728 8779 8778 9798 9799 9850 9849
8 8728 8729 8780 8779 9799 9800 9851 9850
8 8729 8730 8781 8780 9800 9801 9852 9851
8 8730 8731 8782 8781 9801 9802 9853 9852
8 8731 8732 8783 8782 9802 9803 9854 9853
8 8732 8733 8784 8783 9803 9804 9855 9854
8 8733 8734 8785 8784 9804 9805 9856 9855
8 8734 8735 8786 8785 9805 9806 9857 9856
8 8735 8736 8787 8786 9806 9807 9858 9857
8 8736 8737 8788 8787 9807 9808 9859 9858
8 8737 8738 8789 8788 9808 9809 9860 9859
8 8738 8739 8790 8789 9809 9810 9861 9860
8 8739 8740 8791 8790 9810 9811 9862 9861
8 8740 8741 8792 8791 9811 9812 9863 9862
8 8741 8742 8793 8792 9812 9813 9864 9863
8 8742 8743 8794 8793 9813 9814 9865 9864
8 8743 8744 8795 8794 9814 9815 9866 9865
8 8744 8745 8796 8795 9815 9816 9867 9866
8 8745 8746 8797 8796 9816 9817 9868 9867
8 8746 8747 8798 8797 9817 9818 9869 9868
8 8747 8748 8799 8798 9818 9819 9870 9869
8 8748 8749 8800 8799 9819 9820 9871 9870
8 8749 8750 8801 8800 9820 9821 9872 9871
8 8750 8751 8802 8801 9821 9822 9873 9872
8 8751 8752 8803 8802 9822 9823 9874 9873
8 8752 8753 8804 8803 9823 9824 9875 9874
8 8753 8754 8805 8804 9824 9825 9876 9875
8 8754 8755 8806 8805 9825 9826 9877 9876
8 8755 8756 8807 8806 9826 9827 9878 9877
8 8756 8757 8808 8807 9827 9828 9879 9878
8 8757 8758 8809 8808 9828 9829 9880 9879
8 8758 8759 8810 8809 9829 9830 9881 9880
8 8759 8760 8811 8810 9830 9831 9882 9881
8 8760 8761 8812 8811 9831 9832 9883 9882
8 8761 8762 8813 8812 9832 9833 9884 9883
8 8762 8763 8814 8813 9833 9834 9885 9884
8 8763 8764 8815 8814 9834 9835 9886 9885
8 8764 8765 8816 8815 9835 9836 9887 9886
8 8765 8766 8817 8816 9836 9837 9888 9887
8 8766 8767 8818 8817 9837 9838 9889 9888
8 8767 8768 8819 8818 9838 9839 9890 9889
8 8768 8769 8820 8819 9839 9840 9891 9890
8 8769 8770 8821 8820 9840 9841 9892 9891
8 8770 8771 8822 8821 9841 9842 9893 9892
8 8772 8773 8824 8823 9843 9844 9895 9894
8 8773 8774 8825 8824 9844 9845 9896 9895
8 8774 8775 8826 8825 9845 9846 9897 9896
8 8775 8776 8827 8826 9846 9847 9898 9897
8 8776 8777 8828 8827 9847 9848 9899 9898
8 8777 8778 8829 8828 9848 9849 9900 9899
8 8778 8779 8830 8829 9849 9850 9901 9900
8 8779 8780 8831 8830 9850 9851 9902 9901
8 8780 8781 8832 8831 9851 9852 9903 9902
8 8781 8782 8833 8832 9852 9853 9904 9903
8 8782 8783 8834 8833 9853 9854 9905 9904
8 8783 8784 8835 8834 9854 9855 9906 9905
8 8784 8785 8836 8835 9855 9856 9907 9906
8 8785 8786 8837 8836 9856 9857 9908 9907
8 8786 8787 8838 8837 9857 9858 9909 9908
8 8787 8788 8839 8838 9858 9859 9910 9909
8 8788 8789 8840 8839 9859 9860 9911 9910
8 8789 8790 8841 8840 9860 9861 9912 9911
8 8790 8791 8842 8841 9861 9862 9913 9912
8 8791 8792 8843 8842 9862 9863 9914 9913
8 8792 8793 8844 8843 9863 9864 9915 9914
8 8793 8794 8845 8844 9864 9865 9916 9915
8 8794 8795 8846 8845 9865 9866 9917 9916
8 8795 8796 8847 8846 9866 9867 9918 9917
8 8796 8797 8848 8847 9867 9868 9919 9918
8 8797 8798 8849 8848 9868 9869 9920 9919
8 8798 8799 8850 8849 9869 9870 9921 9920
8 8799 8800 8851 8850 9870 9871 9922 9921
8 8800 8801 8852 8851 9871 9872 9923 9922
8 8801 8802 8853 8852 9872 9873 9924 9923
8 8802 8803 8854 8853 9873 9874 9925 9924
8 8803 8804 8855 8854 9874 9875 9926 9925
8 8804 8805 8856 8855 9875 9876 9927 9926
8 8805 8806 8857 8856 9876 9877 9928 9927
8 8806 8807 8858 8857 9877 9878 9929 9928
8 8807 8808 8859 8858 9878 9879 9930 9929
8 8808 8809 8860 8859 9879 9880 9931 9930
8 8809 8810 8861 8860 9880 9881 9932 9931
8 8810 8811 8862 8861 9881 9882 9933 9932
8 8811 8812 8863 8862 9882 9883 9934 9933
8 8812 8813 8864 8863 9883 9884 9935 9934
8 8813 8814 8865 8864 9884 9885 9936 9935
8 8814 8815 8866 8865 9885 9886 9937 9936
8 8815 8816 8867 8866 9886 9887 9938 9937
8 8816 8817 8868 8867 9887 9888 9939 9938
8 8817 8818 8869 8868 9888 9889 9940 9939
8 8818 8819 8870 8869 9889 9890 9941 9940
8 8819 8820 8871 8870 9890 9891 9942 9941
8 8820 8821 8872 8871 9891 9892 9943 9942
8 8821 8822 8873 8872 9892 9893 9944 9943
8 8823 8824 8875 8874 9894 9895 9946 9945
8 8824 8825 8876 8875 9895 9896 9947 9946
8 8825 8826 8877 8876 9896 9897 9948 9947
8 8826 8827 8878 8877 9897 9898 9949 9948
8 8827 8828 8879 8878 9898 9899 9950 9949
8 8828 8829 8880 8879 9899 9900 9951 9950
8 8829 8830 8881 8880 9900 9901 9952 9951
8 8830 8831 8882 8881 9901 9902 9953 9952
8 8831 8832 8883 8882 9902 9903 9954 9953
8 8832 8833 8884 8883 9903 9904 9955 9954
8 8833 8834 8885 8884 9904 9905 9956 9955
8 8834 8835 8886 8885 9905 9906 9957 9956
8 8835 8836 8887 8886 9906 9907 9958 9957
8 8836 8837 8888 8887 9907 9908 9959 9958
8 8837 8838 8889 8888 9908 9909 9960 9959
8 8838 8839 8890 8889 9909 9910 9961 9960
8 8839 8840 8891 8890 9910 9911 9962 9961
8 8840 8841 8892 8891 9911 9912 9963 9962
8 8841 8842 8893 8892 9912 9913 9964 9963
8 8842 8843 8894 8893 9913 9914 9965 9964
8 8843 8844 8895 8894 9914 9915 9966 9965
8 8844 8845 8896 8895 9915 9916 9967 9966
8 8845 8846 8897 8896 9916 9917 9968 9967
8 8846 8847 8898 8897 9917 9918 9969 9968
8 8847 8848 8899 8898 9918 9919 9970 9969
8 8848 8849 8900 8899 9919 9920 9971 9970
8 8849 8850 8901 8900 9920 9921 9972 9971
8 8850 8851 8902 8901 9921 9922 9973 9972
8 8851 8852 8903 8902 9922 9923 9974 9973
8 8852 8853 8904 8903 9923 9924 9975 9974
8 8853 8854 8905 8904 9924 9925 9976 9975
8 8854 8855 8906 8905 9925 9926 9977 9976
8 8855 8856 8907 8906 9926 9927 9978 9977
8 8856 8857 8908 8907 9927 9928 9979 9978
8 8857 8858 8909 8908 9928 9929 9980 9979
8 8858 8859 8910 8909 9929 9930 9981 9980
8 8859 8860 8911 8910 9930 9931 9982 9981
8 8860 8861 8912 8911 9931 9932 9983 9982
8 8861 8862 8913 8912 9932 9933 9984 9983
8 8862 8863 8914 8913 9933 9934 9985 9984
8 8863 8864 8915 8914 9934 9935 9986 9985
8 8864 8865 8916 8915 9935 9936 9987 9986
8 8865 8866 8917 8916 9936 9937 9988 9987
8 8866 8867 8918 8917 9937 9938 9989 9988
8 8867 8868 8919 8918 9938 9939 9990 9989
8 8868 8869 8920 8919 9939 9940 9991 9990
8 8869 8870 8921 8920 9940 9941 9992 9991
8 8870 8871 8922 8921 9941 9942 9993 9992
8 8871 8872 8923 8922 9942 9943 9994 9993
8 8872 8873 8924 8923 9943 9944 9995 9994
8 8874 8875 8926 8925 9945 9946 9997 9996
8 8875 8876 8927 8926 9946 9947 9998 9997
8 8876 8877 8928 8927 9947 9948 9999 9998
8 8877 8878 8929 8928 9948 9949 10000 9999
8 8878 8879 8930 8929 9949 9950 10001 10000
8 8879 8880 8931 8930 9950 9951 10002 10001
8 8880 8881 8932 8931 9951 9952 10003 10002
8 8881 8882 8933 8932 9952 9953 10004 10003
8 8882 8883 8934 8933 9953 9954 10005 10004
8 8883 8884 8935 8934 9954 9955 10006 10005
8 8884 8885 8936 8935 9955 9956 10007 10006
8 8885 8886 8937 8936 9956 9957 10008 10007
8 8886 8887 8938 8937 9957 9958 10009 10008
8 8887 8888 8939 8938 9958 9959 10010 10009
8 8888 8889 8940 8939 9959 9960 10011 10010
8 8889 8890 8941 8940 9960 9961 10012 10011
8 8890 8891 8942 8941 9961 9962 10013 10012
8 8891 8892 8943 8942 9962 9963 10014 10013
8 8892 8893 8944 8943 9963 9964 10015 10014
8 8893 8894 8945 8944 9964 9965 10016 10015
8 8894 8895 8946 8945 9965 9966 10017 10016
8 8895 8896 8947 8946 9966 9967 10018 10017
8 8896 8897 8948 8947 9967 9968 10019 10018
8 8897 8898 8949 8948 9968 9969 10020 10019
8 8898 8899 8950 8949 9969 9970 10021 10020
8 8899 8900 8951 8950 9970 9971 10022 10021
8 8900 8901 8952 8951 9971 9972 10023 10022
8 8901 8902 8953 8952 9972 9973 10024 10023
8 8902 8903 8954 8953 9973 9974 10025 10024
8 8903 8904 8955 8954 9974 9975 10026 10025
8 8904 8905 8956 8955 9975 9976 10027 10026
8 8905 8906 8957 8956 9976 9977 10028 10027
8 8906 8907 8958 8957 9977 9978 10029 10028
8 8907 8908 8959 8958 9978 9979 10030 10029
8 8908 8909 8960 8959 9979 9980 10031 10030
8 8909 8910 8961 8960 9980 9981 10032 10031
8 8910 8911 8962 8961 9981 9982 10033 10032
8 8911 8912 8963 8962 9982 9983 10034 10033
8 8912 8913 8964 8963 9983 9984 10035 10034
8 8913 8914 8965 8964 9984 9985 10036 10035
8 8914 8915 8966 8965 9985 9986 10037 10036
8 8915 8916 8967 8966 9986 9987 10038 10037
8 8916 8917 8968 8967 9987 9988 10039 10038
8 8917 8918 8969 8968 9988 9989 10040 10039
8 8918 8919 8970 8969 9989 9990 10041 10040
8 8919 8920 8971 8970 9990 9991 10042 10041
8 8920 8921 8972 8971 9991 9992 10043 10042
8 8921 8922 8973 8972 9992 9993 10044 10043
8 8922 8923 8974 8973 9993 9994 10045 10044
8 8923 8924 8975 8974 9994 9995 10046 10045
8 8925 8926 8977 8976 9996 9997 10048 10047
8 8926 8927 8978 8977 9997 9998 10049 10048
8 8927 8928 8979 8978 9998 9999 10050 10049
8 8928 8929 8980 8979 9999 10000 10051 10050
8 8929 8930 8981 8980 10000 10001 10052 10051
8 8930 8931 8982 8981 10001 10002 10053 10052
8 8931 8932 8983 8982 10002 10003 10054 10053
8 8932 8933 8984 8983 10003 10004 10055 10054
8 8933 8934 8985 8984 10004 10005 10056 10055
8 8934 8935 8986 8985 10005 10006 10057 10056
8 8935 8936 8987 8986 10006 10007 10058 10057
8 8936 8937 8988 8987 10007 10008 10059 10058
8 8937 8938 8989 8988 10008 10009 10060 10059
8 8938 8939 8990 8989 10009 10010 10061 10060
8 8939 8940 8991 8990 10010 10011 10062 10061
8 8940 8941 8992 8991 10011 10012 10063 10062
8 8941 8942 8993 8992 10012 10013 10064 10063
8 8942 8943 8994 8993 10013 10014 10065 10064
8 8943 8944 8995 8994 10014 10015 10066 10065
8 8944 8945 8996 8995 10015 10016 10067 10066
8 8945 8946 8997 8996 10016 10017 10068 10067
8 8946 8947 8998 8997 10017 10018 10069 10068
8 8947 8948 8999 8998 10018 10019 10070 10069
8 8948 8949 9000 8999 10019 10020 10071 10070
8 8949 8950 9001 9000 10020 10021 10072 10071
8 8950 8951 9002 9001 10021 10022 10073 10072
8 8951 8952 9003 9002 10022 10023 10074 10073
8 8952 8953 9004 9003 10023 10024 10075 10074
8 8953 8954 9005 9004 10024 10025 10076 10075
8 8954 8955 9006 9005 10025 10026 10077 10076
8 8955 8956 9007 9006 10026 10027 10078 10077
8 8956 8957 9008 9007 10027 10028 10079 10078
8 8957 8958 9009 9008 10028 10029 10080 10079
8 8958 8959 9010 9009 10029 10030 10081 10080
8 8959 8960 9011 9010 10030 10031 10082 10081
8 8960 8961 9012 9011 10031 10032 10083 10082
8 8961 8962 9013 9012 10032 10033 10084 10083
8 8962 8963 9014 9013 10033 10034 10085 10084
8 8963 8964 9015 9014 10034 10035 10086 10085
8 8964 8965 9016 9015 10035 10036 10087 10086
8 8965 8966 9017 9016 10036 10037 10088 10087
8 8966 8967 9018 9017 10037 10038 10089 10088
8 8967 8968 9019 9018 10038 10039 10090 10089
8 8968 8969 9020 9019 10039 10040 10091 10090
8 8969 8970 9021 9020 10040 10041 10092 10091
8 8970 8971 9022 9021 10041 10042 10093 10092
8 8971 8972 9023 9022 10042 10043 10094 10093
8 8972 8973 9024 9023 10043 10044 10095 10094
8 8973 8974 9025 9024 10044 10045 10096 10095
8 8974 8975 9026 9025 10045 10046 10097 10096
8 8976 8977 9028 9027 10047 10048 10099 10098
8 8977 8978 9029 9028 10048 10049 10100 10099
8 8978 8979 9030 9029 10049 10050 10101 10100
8 8979 8980 9031 9030 10050 10051 10102 10101
8 8980 8981 9032 9031 10051 10052 10103 10102
8 8981 8982 9033 9032 10052 10053 10104 10103
8 8982 8983 9034 9033 10053 10054 10105 10104
8 8983 8984 9035 9034 10054 10055 10106 10105
8 8984 8985 9036 9035 10055 10056 10107 10106
8 8985 8986 9037 9036 10056 10057 10108 10107
8 8986 8987 9038 9037 10057 10058 10109 10108
8 8987 8988 9039 9038 10058 10059 10110 10109
8 8988 8989 9040 9039 10059 10060 10111 10110
8 8989 8990 9041 9040 10060 10061 10112 10111
8 8990 8991 9042 9041 10061 10062 10113 10112
8 8991 8992 9043 9042 10062 10063 10114 10113
8 8992 8993 9044 9043 10063 10064 10115 10114
8 8993 8994 9045 9044 10064 10065 10116 10115
8 8994 8995 9046 9045 10065 10066 10117 10116
8 8995 8996 9047 9046 10066 10067 10118 10117
8 8996 8997 9048 9047 10067 10068 10119 10118
8 8997 8998 9049 9048 10068 10069 10120 10119
8 8998 8999 9050 9049 10069 10070 10121 10120
8 8999 9000 9051 9050 10070 10071 10122 10121
8 9000 9001 9052 9051 10071 10072 10123 10122
8 9001 9002 9053 9052 10072 10073 10124 10123
8 9002 9003 9054 9053 10073 10074 10125 10124
8 9003 9004 9055 9054 10074 10075 10126 10125
8 9004 9005 9056 9055 10075 10076 10127 10126
8 9005 9006 9057 9056 10076 10077 10128 10127
8 9006 9007 9058 9057 10077 10078 10129 10128
8 9007 9008 9059 9058 10078 10079 10130 10129
8 9008 9009 9060 9059 10079 10080 10131 10130
8 9009 9010 9061 9060 10080 10081 10132 10131
8 9010 9011 9062 9061 10081 10082 10133 10132
8 9011 9012 9063 9062 10082 10083 10134 10133
8 9012 9013 9064 9063 10083 10084 10135 10134
8 9013 9014 9065 9064 10084 10085 10136 10135
8 9014 9015 9066 9065 10085 10086 10137 10136
8 9015 9016 9067 9066 10086 10087 10138 10137
8 9016 9017 9068 9067 10087 10088 10139 10138
8 9017 9018 9069 9068 10088 10089 10140 10139
8 9018 9019 9070 9069 10089 10090 10141 10140
8 9019 9020 9071 9070 10090 10091 10142 10141
8 9020 9021 9072 9071 10091 10092 10143 10142
8 9021 9022 9073 9072 10092 10093 10144 10143
8 9022 9023 9074 9073 10093 10094 10145 10144
8 9023 9024 9075 9074 10094 10095 10146 10145
8 9024 9025 9076 9075 10095 10096 10147 10146
8 9025 9026 9077 9076 10096 10097 10148 10147
8 9027 9028 9079 9078 10098 10099 10150 10149
8 9028 9029 9080 9079 10099 10100 10151 10150
8 9029 9030 9081 9080 10100 10101 10152 10151
8 9030 9031 9082 9081 10101 10102 10153 10152
8 9031 9032 9083 9082 10102 10103 10154 10153
8 9032 9033 9084 9083 10103 10104 10155 10154
8 9033 9034 9085 9084 10104 10105 10156 10155
8 9034 9035 9086 9085 10105 10106 10157 10156
8 9035 9036 9087 9086 10106 10107 10158 10157
8 9036 9037 9088 9087 10107 10108 10159 10158
8 9037 9038 9089 9088 10108 10109 10160 10159
8 9038 9039 9090 9089 10109 10110 10161 10160
8 9039 9040 9091 9090 10110 10111 10162 10161
8 9040 9041 9092 9091 10111 10112 10163 10162
8 9041 9042 9093 9092 10112 10113 10164 10163
8 9042 9043 9094 9093 10113 10114 10165 10164
8 9043 9044 9095 9094 10114 10115 10166 10165
8 9044 9045 9096 9095 10115 10116 10167 10166
8 9045 9046 9097 9096 10116 10117 10168 10167
8 9046 9047 9098 9097 10117 10118 10169 10168
8 9047 9048 9099 9098 10118 10119 10170 10169
8 9048 9049 9100 9099 10119 10120 10171 10170
8 9049 9050 9101 9100 10120 10121 10172 10171
8 9050 9051 9102 9101 10121 10122 10173 10172
8 9051 9052 9103 9102 10122 10123 10174 10173
8 9052 9053 9104 9103 10123 10124 10175 10174
8 9053 9054 9105 9104 10124 10125 10176 10175
8 9054 9055 9106 9105 10125 10126 10177 10176
8 9055 9056 9107 9106 10126 10127 10178 10177
8 9056 9057 9108 9107 10127 10128 10179 10178
8 9057 9058 9109 9108 10128 10129 10180 10179
8 9058 9059 9110 9109 10129 10130 10181 10180
8 9059 9060 9111 9110 10130 10131 10182 10181
8 9060 9061 9112 9111 10131 10132 10183 10182
8 9061 9062 9113 9112 10132 10133 10184 10183
8 9062 9063 9114 9113 10133 10134 10185 10184
8 9063 9064 9115 9114 10134 10135 10186 10185
8 9064 9065 9116 9115 10135 10136 10187 10186
8 9065 9066 9117 9116 10136 10137 10188 10187
8 9066 9067 9118 9117 10137 10138 10189 10188
8 9067 9068 9119 9118 10138 10139 10190 10189
8 9068 9069 9120 9119 10139 10140 10191 10190
8 9069 9070 9121 9120 10140 10141 10192 10191
8 9070 9071 9122 9121 10141 10142 10193 10192
8 9071 9072 9123 9122 10142 10143 10194 10193
8 9072 9073 9124 9123 10143 10144 10195 10194
8 9073 9074 9125 9124 10144 10145 10196 10195
8 9074 9075 9126 9125 10145 10146 10197 10196
8 9075 9076 9127 9126 10146 10147 10198 10197
8 9076 9077 9128 9127 10147 10148 10199 10198
8 9078 9079 9130 9129 10149 10150 10201 10200
8 9079 9080 9131 9130 10150 10151 10202 10201
8 9080 9081 9132 9131 10151 10152 10203 10202
8 9081 9082 9133 9132 10152 10153 10204 10203
8 9082 9083 9134 9133 10153 10154 10205 10204
8 9083 9084 9135 9134 10154 10155 10206 10205
8 9084 9085 9136 9135 10155 10156 10207 10206
8 9085 9086 9137 9136 10156 10157 10208 10207
8 9086 9087 9138 9137 10157 10158 10209 10208
8 9087 9088 9139 9138 10158 10159 10210 10209
8 9088 9089 9140 9139 10159 10160 10211 10210
8 9089 9090 9141 9140 10160 10161 10212 10211
8 9090 9091 9142 9141 10161 10162 10213 10212
8 9091 9092 9143 9142 10162 10163 10214 10213
8 9092 9093 9144 9143 10163 10164 10215 10214
8 9093 9094 9145 9144 10164 10165 10216 10215
8 9094 9095 9146 9145 10165 10166 10217 10216
8 9095 9096 9147 9146 10166 10167 10218 10217
8 9096 9097 9148 9147 10167 10168 10219 10218
8 9097 9098 9149 9148 10168 10169 10220 10219
8 9098 9099 9150 9149 10169 10170 10221 10220
8 9099 9100 9151 9150 10170 10171 10222 10221
8 9100 9101 9152 9151 10171 10172 10223 10222
8 9101 9102 9153 9152 10172 10173 10224 10223
8 9102 9103 9154 9153 10173 10174 10225 10224
8 9103 9104 9155 9154 10174 10175 10226 10225
8 9104 9105 9156 9155 10175 10176 10227 10226
8 9105 9106 9157 9156 10176 10177 10228 10227
8 9106 9107 9158 9157 10177 10178 10229 10228
8 9107 9108 9159 9158 10178 10179 10230 10229
8 9108 9109 9160 9159 10179 10180 10231 10230
8 9109 9110 9161 9160 10180 10181 10232 10231
8 9110 9111 9162 9161 10181 10182 10233 10232
8 9111 9112 9163 9162 10182 10183 10234 10233
8 9112 9113 9164 9163 10183 10184 10235 10234
8 9113 9114 9165 9164 10184 10185 10236 10235
8 9114 9115 9166 9165 10185 10186 10237 10236
8 9115 9116 9167 9166 10186 10187 10238 10237
8 9116 9117 9168 9167 10187 10188 10239 10238
8 9117 9118 9169 9168 10188 10189 10240 10239
8 9118 9119 9170 9169 10189 10190 10241 10240
8 9119 9120 9171 9170 10190 10191 10242 10241
8 9120 9121 9172 9171 10191 10192 10243 10242
8 9121 9122 9173 9172 10192 10193 10244 10243
8 9122 9123 9174 9173 10193 10194 10245 10244
8 9123 9124 9175 9174 10194 10195 10246 10245
8 9124 9125 9176 9175 10195 10196 10247 10246
8 9125 9126 9177 9176 10196 10197 10248 10247
8 9126 9127 9178 9177 10197 10198 10249 10248
8 9127 9128 9179 9178 10198 10199 10250 10249
8 9129 9130 9181 9180 10200 10201 10252 10251
8 9130 9131 9182 9181 10201 10202 10253 10252
8 9131 9132 9183 9182 10202 10203 10254 10253
8 9132 9133 9184 9183 10203 10204 10255 10254
8 9133 9134 9185 9184 10204 10205 10256 10255
8 9134 9135 9186 9185 10205 10206 10257 10256
8 9135 9136 9187 9186 10206 10207 10258 10257
8 9136 9137 9188 9187 10207 10208 10259 10258
8 9137 9138 9189 9188 10208 10209 10260 10259
8 9138 9139 9190 9189 10209 10210 10261 10260
8 9139 9140 9191 9190 10210 10211 10262 10261
8 9140 9141 9192 9191 10211 10212 10263 10262
8 9141 9142 9193 9192 10212 10213 10264 10263
8 9142 9143 9194 9193 10213 10214 10265 10264
8 9143 9144 9195 9194 10214 10215 10266 10265
8 9144 9145 9196 9195 10215 10216 10267 10266
8 9145 9146 9197 9196 10216 10217 10268 10267
8 9146 9147 9198 9197 10217 10218 10269 10268
8 9147 9148 9199 9198 10218 10219 10270 10269
8 9148 9149 9200 9199 10219 10220 10271 10270
8 9149 9150 9201 9200 10220 10221 10272 10271
8 9150 9151 9202 9201 10221 10222 10273 10272
8 9151 9152 9203 9202 10222 10223 10274 10273
8 9152 9153 9204 9203 10223 10224 10275 10274
8 9153 9154 9205 9204 10224 10225 10276 10275
8 9154 9155 9206 9205 10225 10226 10277 10276
8 9155 9156 9207 9206 10226 10227 10278 10277
8 9156 9157 9208 9207 10227 10228 10279 10278
8 9157 9158 9209 9208 10228 10229 10280 10279
8 9158 9159 9210 9209 10229 10230 10281 10280
8 9159 9160 9211 9210 10230 10231 10282 10281
8 9160 9161 9212 9211 10231 10232 10283 10282
8 9161 9162 9213 9212 10232 10233 10284 10283
8 9162 9163 9214 9213 10233 10234 10285 10284
8 9163 9164 9215 9214 10234 10235 10286 10285
8 9164 9165 9216 9215 10235 10236 10287 10286
8 9165 9166 9217 9216 10236 10237 10288 10287
8 9166 9167 9218 9217 10237 10238 10289 10288
8 9167 9168 9219 9218 10238 10239 10290 10289
8 9168 9169 9220 9219 10239 10240 10291 10290
8 9169 9170 9221 9220 10240 10241 10292 10291
8 9170 9171 9222 9221 10241 10242 10293 10292
8 9171 9172 9223 9222 10242 10243 10294 10293
8 9172 9173 9224 9223 10243 10244 10295 10294
8 9173 9174 9225 9224 10244 10245 10296 10295
8 9174 9175 9226 9225 10245 10246 10297 10296
8 9175 9176 9227 9226 10246 10247 10298 10297
8 9176 9177 9228 9227 10247 10248 10299 10298
8 9177 9178 9229 9228 10248 10249 10300 10299
8 9178 9179 9230 9229 10249 10250 10301 10300
8 9180 9181 9232 9231 10251 10252 10303 10302
8 9181 9182 9233 9232 10252 10253 10304 10303
8 9182 9183 9234 9233 10253 10254 10305 10304
8 9183 9184 9235 9234 10254 10255 10306 10305
8 9184 9185 9236 9235 10255 10256 10307 10306
8 9185 9186 9237 9236 10256 10257 10308 10307
8 9186 9187 9238 9237 10257 10258 10309 10308
8 9187 9188 9239 9238 10258 10259 10310 10309
8 9188 9189 9240 9239 10259 10260 10311 10310
8 9189 9190 9241 9240 10260 10261 10312 10311
8 9190 9191 9242 9241 10261 10262 10313 10312
8 9191 9192 9243 9242 10262 10263 10314 10313
8 9192 9193 9244 9243 10263 10264 10315 10314
8 9193 9194 9245 9244 10264 10265 10316 10315
8 9194 9195 9246 9245 10265 10266 10317 10316
8 9195 9196 9247 9246 10266 10267 10318 10317
8 9196 9197 9248 9247 10267 10268 10319 10318
8 9197 9198 9249 9248 10268 10269 10320 10319
8 9198 9199 9250 9249 10269 10270 10321 10320
8 9199 9200 9251 9250 10270 10271 10322 10321
8 9200 9201 9252 9251 10271 10272 10323 10322
8 9201 9202 9253 9252 10272 10273 10324 10323
8 9202 9203 9254 9253 10273 10274 10325 10324
8 9203 9204 9255 9254 10274 10275 10326 10325
8 9204 9205 9256 9255 10275 10276 10327 10326
8 9205 9206 9257 9256 10276 10277 10328 10327
8 9206 9207 9258 9257 10277 10278 10329 10328
8 9207 9208 9259 9258 10278 10279 10330 10329
8 9208 9209 9260 9259 10279 10280 10331 10330
8 9209 9210 9261 9260 10280 10281 10332 10331
8 9210 9211 9262 9261 10281 10282 10333 10332
8 9211 9212 9263 9262 10282 10283 10334 10333
8 9212 9213 9264 9263 10283 10284 10335 10334
8 9213 9214 9265 9264 10284 10285 10336 10335
8 9214 9215 9266 9265 10285 10286 10337 10336
8 9215 9216 9267 9266 10286 10287 10338 10337
8 9216 9217 9268 9267 10287 10288 10339 10338
8 9217 9218 9269 9268 10288 10289 10340 10339
8 9218 9219 9270 9269 10289 10290 10341 10340
8 9219 9220 9271 9270 10290 10291 10342 10341
8 9220 9221 9272 9271 10291 10292 10343 10342
8 9221 9222 9273 9272 10292 10293 10344 10343
8 9222 9223 9274 9273 10293 10294 10345 10344
8 9223 9224 9275 9274 10294 10295 10346 10345
8 9224 9225 9276 9275 10295 10296 10347 10346
8 9225 9226 9277 9276 10296 10297 10348 10347
8 9226 9227 9278 9277 10297 10298 10349 10348
8 9227 9228 9279 9278 10298 10299 10350 10349
8 9228 9229 9280 9279 10299 10300 10351 10350
8 9229 9230 9281 9280 10300 10301 10352 10351
8 9231 9232 9283 9282 10302 10303 10354 10353
8 9232 9233 9284 9283 10303 10304 10355 10354
8 9233 9234 9285 9284 10304 10305 10356 10355
8 9234 9235 9286 9285 10305 10306 10357 10356
8 9235 9236 9287 9286 10306 10307 10358 10357
8 9236 9237 9288 9287 10307 10308 10359 10358
8 9237 9238 9289 9288 10308 10309 10360 10359
8 9238 9239 9290 9289 10309 10310 10361 10360
8 9239 9240 9291 9290 10310 10311 10362 10361
8 9240 9241 9292 9291 10311 10312 10363 10362
8 9241 9242 9293 9292 10312 10313 10364 10363
8 9242 9243 9294 9293 10313 10314 10365 10364
8 9243 9244 9295 9294 10314 10315 10366 10365
8 9244 9245 9296 9295 10315 10316 10367 10366
8 9245 9246 9297 9296 10316 10317 10368 10367
8 9246 9247 9298 9297 10317 10318 10369 10368
8 9247 9248 9299 9298 10318 10319 10370 10369
8 9248 9249 9300 9299 10319 10320 10371 10370
8 9249 9250 9301 9300 10320 10321 10372 10371
8 9250 9251 9302 9301 10321 10322 10373 10372
8 9251 9252 9303 9302 10322 10323 10374 10373
8 9252 9253 9304 9303 10323 10324 10375 10374
8 9253 9254 9305 9304 10324 10325 10376 10375
8 9254 9255 9306 9305 10325 10326 10377 10376
8 9255 9256 9307 9306 10326 10327 10378 10377
8 9256 9257 9308 9307 10327 10328 10379 10378
8 9257 9258 9309 9308 10328 10329 10380 10379
8 9258 9259 9310 9309 10329 10330 10381 10380
8 9259 9260 9311 9310 10330 10331 10382 10381
8 9260 9261 9312 9311 10331 10332 10383 10382
8 9261 9262 9313 9312 10332 10333 10384 10383
8 9262 9263 9314 9313 10333 10334 10385 10384
8 9263 9264 9315 9314 10334 10335 10386 10385
8 9264 9265 9316 9315 10335 10336 10387 10386
8 9265 9266 9317 9316 10336 10337 10388 10387
8 9266 9267 9318 9317 10337 10338 10389 10388
8 9267 9268 9319 9318 10338 10339 10390 10389
8 9268 9269 9320 9319 10339 10340 10391 10390
8 9269 9270 9321 9320 10340 10341 10392 10391
8 9270 9271 9322 9321 10341 10342 10393 10392
8 9271 9272 9323 9322 10342 10343 10394 10393
8 9272 9273 9324 9323 10343 10344 10395 10394
8 9273 9274 9325 9324 10344 10345 10396 10395
8 9274 9275 9326 9325 10345 10346 10397 10396
8 9275 9276 9327 9326 10346 10347 10398 10397
8 9276 9277 9328 9327 10347 10348 10399 10398
8 9277 9278 9329 9328 10348 10349 10400 10399
8 9278 9279 9330 9329 10349 10350 10401 10400
8 9279 9280 9331 9330 10350 10351 10402 10401
8 9280 9281 9332 9331 10351 10352 10403 10402
8 9282 9283 9334 9333 10353 10354 10405 10404
8 9283 9284 9335 9334 10354 10355 10406 10405
8 9284 9285 9336 9335 10355 10356 10407 10406
8 9285 9286 9337 9336 10356 10357 10408 10407
8 9286 9287 9338 9337 10357 10358 10409 10408
8 9287 9288 9339 9338 10358 10359 10410 10409
8 9288 9289 9340 9339 10359 10360 10411 10410
8 9289 9290 9341 9340 10360 10361 10412 10411
8 9290 9291 9342 9341 10361 10362 10413 10412
8 9291 9292 9343 9342 10362 10363 10414 10413
8 9292 9293 9344 9343 10363 10364 10415 10414
8 9293 9294 9345 9344 10364 10365 10416 10415
8 9294 9295 9346 9345 10365 10366 10417 10416
8 9295 9296 9347 9346 10366 10367 10418 10417
8 9296 9297 9348 9347 10367 10368 10419 10418
8 9297 9298 9349 9348 10368 10369 10420 10419
8 9298 9299 9350 9349 10369 10370 10421 10420
8 9299 9300 9351 9350 10370 10371 10422 10421
8 9300 9301 9352 9351 10371 10372 10423 10422
8 9301 9302 9353 9352 10372 10373 10424 10423
8 9302 9303 9354 9353 10373 10374 10425 10424
8 9303 9304 9355 9354 10374 10375 10426 10425
8 9304 9305 9356 9355 10375 10376 10427 10426
8 9305 9306 9357 9356 10376 10377 10428 10427
8 9306 9307 9358 9357 10377 10378 10429 10428
8 9307 9308 9359 9358 10378 10379 10430 10429
8 9308 9309 9360 9359 10379 10380 10431 10430
8 9309 9310 9361 9360 10380 10381 10432 10431
8 9310 9311 9362 9361 10381 10382 10433 10432
8 9311 9312 9363 9362 10382 10383 10434 10433
8 9312 9313 9364 9363 10383 10384 10435 10434
8 9313 9314 9365 9364 10384 10385 10436 10435
8 9314 9315 9366 9365 10385 10386 10437 10436
8 9315 9316 9367 9366 10386 10387 10438 10437
8 9316 9317 9368 9367 10387 10388 10439 10438
8 9317 9318 9369 9368 10388 10389 10440 10439
8 9318 9319 9370 9369 10389 10390 10441 10440
8 9319 9320 9371 9370 10390 10391 10442 10441
8 9320 9321 9372 9371 10391 10392 10443 10442
8 9321 9322 9373 9372 10392 10393 10444 10443
8 9322 9323 9374 9373 10393 10394 10445 10444
8 9323 9324 9375 9374 10394 10395 10446 10445
8 9324 9325 9376 9375 10395 10396 10447 10446
8 9325 9326 9377 9376 10396 10397 10448 10447
8 9326 9327 9378 9377 10397 10398 10449 10448
8 9327 9328 9379 9378 10398 10399 10450 10449
8 9328 9329 9380 9379 10399 10400 10451 10450
8 9329 9330 9381 9380 10400 10401 10452 10451
8 9330 9331 9382 9381 10401 10402 10453 10452
8 9331 9332 9383 9382 10402 10403 10454 10453
8 9333 9334 9385 9384 10404 10405 10456 10455
8 9334 9335 9386 9385 10405 10406 10457 10456
8 9335 9336 9387 9386 10406 10407 10458 10457
8 9336 9337 9388 9387 10407 10408 10459 10458
8 9337 9338 9389 9388 10408 10409 10460 10459
8 9338 9339 9390 9389 10409 10410 10461 10460
8 9339 9340 9391 9390 10410 10411 10462 10461
8 9340 9341 9392 9391 10411 10412 10463 10462
8 9341 9342 9393 9392 10412 10413 10464 10463
8 9342 9343 9394 9393 10413 10414 10465 10464
8 9343 9344 9395 9394 10414 10415 10466 10465
8 9344 9345 9396 9395 10415 10416 10467 10466
8 9345 9346 9397 9396 10416 10417 10468 10467
8 9346 9347 9398 9397 10417 10418 10469 10468
8 9347 9348 9399 9398 10418 10419 10470 10469
8 9348 9349 9400 9399 10419 10420 10471 10470
8 9349 9350 9401 9400 10420 10421 10472 10471
8 9350 9351 9402 9401 10421 10422 10473 10472
8 9351 9352 9403 9402 10422 10423 10474 10473
8 9352 9353 9404 9403 10423 10424 10475 10474
8 9353 9354 9405 9404 10424 10425 10476 10475
8 9354 9355 9406 9405 10425 10426 10477 10476
8 9355 9356 9407 9406 10426 10427 10478 10477
8 9356 9357 9408 9407 10427 10428 10479 10478
8 9357 9358 9409 9408 10428 10429 10480 10479
8 9358 9359 9410 9409 10429 10430 10481 10480
8 9359 9360 9411 9410 10430 10431 10482 10481
8 9360 9361 9412 9411 10431 10432 10483 10482
8 9361 9362 9413 9412 10432 10433 10484 10483
8 9362 9363 9414 9413 10433 10434 10485 10484
8 9363 9364 9415 9414 10434 10435 10486 10485
8 9364 9365 9416 9415 10435 10436 10487 10486
8 9365 9366 9417 9416 10436 10437 10488 10487
8 9366 9367 9418 9417 10437 10438 10489 10488
8 9367 9368 9419 9418 10438 10439 10490 10489
8 9368 9369 9420 9419 10439 10440 10491 10490
8 9369 9370 9421 9420 10440 10441 10492 10491
8 9370 9371 9422 9421 10441 10442 10493 10492
8 9371 9372 9423 9422 10442 10443 10494 10493
8 9372 9373 9424 9423 10443 10444 10495 10494
8 9373 9374 9425 9424 10444 10445 10496 10495
8 9374 9375 9426 9425 10445 10446 10497 10496
8 9375 9376 9427 9426 10446 10447 10498 10497
8 9376 9377 9428 9427 10447 10448 10499 10498
8 9377 9378 9429 9428 10448 10449 10500 10499
8 9378 9379 9430 9429 10449 10450 10501 10500
8 9379 9380 9431 9430 10450 10451 10502 10501
8 9380 9381 9432 9431 10451 10452 10503 10502
8 9381 9382 9433 9432 10452 10453 10504 10503
8 9382 9383 9434 9433 10453 10454 10505 10504
8 9384 9385 9436 9435 10455 10456 10507 10506
8 9385 9386 9437 9436 10456 10457 10508 10507
8 9386 9387 9438 9437 10457 10458 10509 10508
8 9387 9388 9439 9438 10458 10459 10510 10509
8 9388 9389 9440 9439 10459 10460 10511 10510
8 9389 9390 9441 9440 10460 10461 10512 10511
8 9390 9391 9442 9441 10461 10462 10513 10512
8 9391 9392 9443 9442 10462 10463 10514 10513
8 9392 9393 9444 9443 10463 10464 10515 10514
8 9393 9394 9445 9444 10464 10465 10516 10515
8 9394 9395 9446 9445 10465 10466 10517 10516
8 9395 9396 9447 9446 10466 10467 10518 10517
8 9396 9397 9448 9447 10467 10468 10519 10518
8 9397 9398 9449 9448 10468 10469 10520 10519
8 9398 9399 9450 9449 10469 10470 10521 10520
8 9399 9400 9451 9450 10470 10471 10522 10521
8 9400 9401 9452 9451 10471 10472 10523 10522
8 9401 9402 9453 9452 10472 10473 10524 10523
8 9402 9403 9454 9453 10473 10474 10525 10524
8 9403 9404 9455 9454 10474 10475 10526 10525
8 9404 9405 9456 9455 10475 10476 10527 10526
8 9405 9406 9457 9456 10476 10477 10528 10527
8 9406 9407 9458 9457 10477 10478 10529 10528
8 9407 9408 9459 9458 10478 10479 10530 10529
8 9408 9409 9460 9459 10479 10480 10531 10530
8 9409 9410 9461 9460 10480 10481 10532 10531
8 9410 9411 9462 9461 10481 10482 10533 10532
8 9411 9412 9463 9462 10482 10483 10534 10533
8 9412 9413 9464 9463 10483 10484 10535 10534
8 9413 9414 9465 9464 10484 10485 10536 10535
8 9414 9415 9466 9465 10485 10486 10537 10536
8 9415 9416 9467 9466 10486 10487 10538 10537
8 9416 9417 9468 9467 10487 10488 10539 10538
8 9417 9418 9469 9468 10488 10489 10540 10539
8 9418 9419 9470 9469 10489 10490 10541 10540
8 9419 9420 9471 9470 10490 10491 10542 10541
8 9420 9421 9472 9471 10491 10492 10543 10542
8 9421 9422 9473 9472 10492 10493 10544 10543
8 9422 9423 9474 9473 10493 10494 10545 10544
8 9423 9424 9475 9474 10494 10495 10546 10545
8 9424 9425 9476 9475 10495 10496 10547 10546
8 9425 9426 9477 9476 10496 10497 10548 10547
8 9426 9427 9478 9477 10497 10498 10549 10548
8 9427 9428 9479 9478 10498 10499 10550 10549
8 9428 9429 9480 9479 10499 10500 10551 10550
8 9429 9430 9481 9480 10500 10501 10552 10551
8 9430 9431 9482 9481 10501 10502 10553 10552
8 9431 9432 9483 9482 10502 10503 10554 10553
8 9432 9433 9484 9483 10503 10504 10555 10554
8 9433 9434 9485 9484 10504 10505 10556 10555
8 9435 9436 9487 9486 10506 10507 10558 10557
8 9436 9437 9488 9487 10507 10508 10559 10558
8 9437 9438 9489 9488 10508 10509 10560 10559
8 9438 9439 9490 9489 10509 10510 10561 10560
8 9439 9440 9491 9490 10510 10511 10562 10561
8 9440 9441 9492 9491 10511 10512 10563 10562
8 9441 9442 9493 9492 10512 10513 10564 10563
8 9442 9443 9494 9493 10513 10514 10565 10564
8 9443 9444 9495 9494 10514 10515 10566 10565
8 9444 9445 9496 9495 10515 10516 10567 10566
8 9445 9446 9497 9496 10516 10517 10568 10567
8 9446 9447 9498 9497 10517 10518 10569 10568
8 9447 9448 9499 9498 10518 10519 10570 10569
8 9448 9449 9500 9499 10519 10520 10571 10570
8 9449 9450 9501 9500 10520 10521 10572 10571
8 9450 9451 9502 9501 10521 10522 10573 10572
8 9451 9452 9503 9502 10522 10523 10574 10573
8 9452 9453 9504 9503 10523 10524 10575 10574
8 9453 9454 9505 9504 10524 10525 10576 10575
8 9454 9455 9506 9505 10525 10526 10577 10576
8 9455 9456 9507 9506 10526 10527 10578 10577
8 9456 9457 9508 9507 10527 10528 10579 10578
8 9457 9458 9509 9508 10528 10529 10580 10579
8 9458 9459 9510 9509 10529 10530 10581 10580
8 9459 9460 9511 9510 10530 10531 10582 10581
8 9460 9461 9512 9511 10531 10532 10583 10582
8 9461 9462 9513 9512 10532 10533 10584 10583
8 9462 9463 9514 9513 10533 10534 10585 10584
8 9463 9464 9515 9514 10534 10535 10586 10585
8 9464 9465 9516 9515 10535 10536 10587 10586
8 9465 9466 9517 9516 10536 10537 10588 10587
8 9466 9467 9518 9517 10537 10538 10589 10588
8 9467 9468 9519 9518 10538 10539 10590 10589
8 9468 9469 9520 9519 10539 10540 10591 10590
8 9469 9470 9521 9520 10540 10541 10592 10591
8 9470 9471 9522 9521 10541 10542 10593 10592
8 9471 9472 9523 9522 10542 10543 10594 10593
8 9472 9473 9524 9523 10543 10544 10595 10594
8 9473 9474 9525 9524 10544 10545 10596 10595
8 9474 9475 9526 9525 10545 10546 10597 10596
8 9475 9476 9527 9526 10546 10547 10598 10597
8 9476 9477 9528 9527 10547 10548 10599 10598
8 9477 9478 9529 9528 10548 10549 10600 10599
8 9478 9479 9530 9529 10549 10550 10601 10600
8 9479 9480 9531 9530 10550 10551 10602 10601
8 9480 9481 9532 9531 10551 10552 10603 10602
8 9481 9482 9533 9532 10552 10553 10604 10603
8 9482 9483 9534 9533 10553 10554 10605 10604
8 9483 9484 9535 9534 10554 10555 10606 10605
8 9484 9485 9536 9535 10555 10556 10607 10606
8 9486 9487 9538 9537 10557 10558 10609 10608
8 9487 9488 9539 9538 10558 10559 10610 10609
8 9488 9489 9540 9539 10559 10560 10611 10610
8 9489 9490 9541 9540 10560 10561 10612 10611
8 9490 9491 9542 9541 10561 10562 10613 10612
8 9491 9492 9543 9542 10562 10563 10614 10613
8 9492 9493 9544 9543 10563 10564 10615 10614
8 9493 9494 9545 9544 10564 10565 10616 10615
8 9494 9495 9546 9545 10565 10566 10617 10616
8 9495 9496 9547 9546 10566 10567 10618 10617
8 9496 9497 9548 9547 10567 10568 10619 10618
8 9497 9498 9549 9548 10568 10569 10620 10619
8 9498 9499 9550 9549 10569 10570 10621 10620
8 9499 9500 9551 9550 10570 10571 10622 10621
8 9500 9501 9552 9551 10571 10572 10623 10622
8 9501 9502 9553 9552 10572 10573 10624 10623
8 9502 9503 9554 9553 10573 10574 10625 10624
8 9503 9504 9555 9554 10574 10575 10626 10625
8 9504 9505 9556 9555 10575 10576 10627 10626
8 9505 9506 9557 9556 10576 10577 10628 10627
8 9506 9507 9558 9557 10577 10578 10629 10628
8 9507 9508 9559 9558 10578 10579 10630 10629
8 9508 9509 9560 9559 10579 10580 10631 10630
8 9509 9510 9561 9560 10580 10581 10632 10631
8 9510 9511 9562 9561 10581 10582 10633 10632
8 9511 9512 9563 9562 10582 10583 10634 10633
8 9512 9513 9564 9563 10583 10584 10635 10634
8 9513 9514 9565 9564 10584 10585 10636 10635
8 9514 9515 9566 9565 10585 10586 10637 10636
8 9515 9516 9567 9566 10586 10587 10638 10637
8 9516 9517 9568 9567 10587 10588 10639 10638
8 9517 9518 9569 9568 10588 10589 10640 10639
8 9518 9519 9570 9569 10589 10590 10641 10640
8 9519 9520 9571 9570 10590 10591 10642 10641
8 9520 9521 9572 9571 10591 10592 10643 10642
8 9521 9522 9573 9572 10592 10593 10644 10643
8 9522 9523 9574 9573 10593 10594 10645 10644
8 9523 9524 9575 9574 10594 10595 10646 10645
8 9524 9525 9576 9575 10595 10596 10647 10646
8 9525 9526 9577 9576 10596 10597 10648 10647
8 9526 9527 9578 9577 10597 10598 10649 10648
8 9527 9528 9579 9578 10598 10599 10650 10649
8 9528 9529 9580 9579 10599 10600 10651 10650
8 9529 9530 9581 9580 10600 10601 10652 10651
8 9530 9531 9582 9581 10601 10602 10653 10652
8 9531 9532 9583 9582 10602 10603 10654 10653
8 9532 9533 9584 9583 10603 10604 10655 10654
8 9533 9534 9585 9584 10604 10605 10656 10655
8 9534 9535 9586 9585 10605 10606 10657 10656
8 9535 9536 9587 9586 10606 10607 10658 10657
8 9537 9538 9589 9588 10608 10609 10660 10659
8 9538 9539 9590 9589 10609 10610 10661 10660
8 9539 9540 9591 9590 10610 10611 10662 10661
8 9540 9541 9592 9591 10611 10612 10663 10662
8 9541 9542 9593 9592 10612 10613 10664 10663
8 9542 9543 9594 9593 10613 10614 10665 10664
8 9543 9544 9595 9594 10614 10615 10666 10665
8 9544 9545 9596 9595 10615 10616 10667 10666
8 9545 9546 9597 9596 10616 10617 10668 10667
8 9546 9547 9598 9597 10617 10618 10669 10668
8 9547 9548 9599 9598 10618 10619 10670 10669
8 9548 9549 9600 9599 10619 10620 10671 10670
8 9549 9550 9601 9600 10620 10621 10672 10671
8 9550 9551 9602 9601 10621 10622 10673 10672
8 9551 9552 9603 9602 10622 10623 10674 10673
8 9552 9553 9604 9603 10623 10624 10675 10674
8 9553 9554 9605 9604 10624 10625 10676 10675
8 9554 9555 9606 9605 10625 10626 10677 10676
8 9555 9556 9607 9606 10626 10627 10678 10677
8 9556 9557 9608 9607 10627 10628 10679 10678
8 9557 9558 9609 9608 10628 10629 10680 10679
8 9558 9559 9610 9609 10629 10630 10681 10680
8 9559 9560 9611 9610 10630 10631 10682 10681
8 9560 9561 9612 9611 10631 10632 10683 10682
8 9561 9562 9613 9612 10632 10633 10684 10683
8 9562 9563 9614 9613 10633 10634 10685 10684
8 9563 9564 9615 9614 10634 10635 10686 10685
8 9564 9565 9616 9615 10635 10636 10687 10686
8 9565 9566 9617 9616 10636 10637 10688 10687
8 9566 9567 9618 9617 10637 10638 10689 10688
8 9567 9568 9619 9618 10638 10639 10690 10689
8 9568 9569 9620 9619 10639 10640 10691 10690
8 9569 9570 9621 9620 10640 10641 10692 10691
8 9570 9571 9622 9621 10641 10642 10693 10692
8 9571 9572 9623 9622 10642 10643 10694 10693
8 9572 9573 9624 9623 10643 10644 10695 10694
8 9573 9574 9625 9624 10644 10645 10696 10695
8 9574 9575 9626 9625 10645 10646 10697 10696
8 9575 9576 9627 9626 10646 10647 10698 10697
8 9576 9577 9628 9627 10647 10648 10699 10698
8 9577 9578 9629 9628 10648 10649 10700 10699
8 9578 9579 9630 9629 10649 10650 10701 10700
8 9579 9580 9631 9630 10650 10651 10702 10701
8 9580 9581 9632 9631 10651 10652 10703 10702
8 9581 9582 9633 9632 10652 10653 10704 10703
8 9582 9583 9634 9633 10653 10654 10705 10704
8 9583 9584 9635 9634 10654 10655 10706 10705
8 9584 9585 9636 9635 10655 10656 10707 10706
8 9585 9586 9637 9636 10656 10657 10708 10707
8 9586 9587 9638 9637 10657 10658 10709 10708
8 9639 9640 9691 9690 10710 10711 10762 10761
8 9640 9641 9692 9691 10711 10712 10763 10762
8 9641 9642 9693 9692 10712 10713 10764 10763
8 9642 9643 9694 9693 10713 10714 10765 10764
8 9643 9644 9695 9694 10714 10715 10766 10765
8 9644 9645 9696 9695 10715 10716 10767 10766
8 9645 9646 9697 9696 10716 10717 10768 10767
8 9646 9647 9698 9697 10717 10718 10769 10768
8 9647 9648 9699 9698 10718 10719 10770 10769
8 9648 9649 9700 9699 10719 10720 10771 10770
8 9649 9650 9701 9700 10720 10721 10772 10771
8 9650 9651 9702 9701 10721 10722 10773 10772
8 9651 9652 9703 9702 10722 10723 10774 10773
8 9652 9653 9704 9703 10723 10724 10775 10774
8 9653 9654 9705 9704 10724 10725 10776 10775
8 9654 9655 9706 9705 10725 10726 10777 10776
8 9655 9656 9707 9706 10726 10727 10778 10777
8 9656 9657 9708 9707 10727 10728 10779 10778
8 9657 9658 9709 9708 10728 10729 10780 10779
8 9658 9659 9710 9709 10729 10730 10781 10780
8 9659 9660 9711 9710 10730 10731 10782 10781
8 9660 9661 9712 9711 10731 10732 10783 10782
8 9661 9662 9713 9712 10732 10733 10784 10783
8 9662 9663 9714 9713 10733 10734 10785 10784
8 9663 9664 9715 9714 10734 10735 10786 10785
8 9664 9665 9716 9715 10735 10736 10787 10786
8 9665 9666 9717 9716 10736 10737 10788 10787
8 9666 9667 9718 9717 10737 10738 10789 10788
8 9667 9668 9719 9718 10738 10739 10790 10789
8 9668 9669 9720 9719 10739 10740 10791 10790
8 9669 9670 9721 9720 10740 10741 10792 10791
8 9670 9671 9722 9721 10741 10742 10793 10792
8 9671 9672 9723 9722 10742 10743 10794 10793
8 9672 9673 9724 9723 10743 10744 10795 10794
8 9673 9674 9725 9724 10744 10745 10796 10795
8 9674 9675 9726 9725 10745 10746 10797 10796
8 9675 9676 9727 9726 10746 10747 10798 10797
8 9676 9677 9728 9727 10747 10748 10799 10798
8 9677 9678 9729 9728 10748 10749 10800 10799
8 9678 9679 9730 9729 10749 10750 10801 10800
8 9679 9680 9731 9730 10750 10751 10802 10801
8 9680 9681 9732 9731 10751 10752 10803 10802
8 9681 9682 9733 9732 10752 10753 10804 10803
8 9682 9683 9734 9733 10753 10754 10805 10804
8 9683 9684 9735 9734 10754 10755 10806 10805
8 9684 9685 9736 9735 10755 10756 10807 10806
8 9685 9686 9737 9736 10756 10757 10808 10807
8 9686 9687 9738 9737 10757 10758 10809 10808
8 9687 9688 9739 9738 10758 10759 10810 10809
8 9688 9689 9740 9739 10759 10760 10811 10810
8 9690 9691 9742 9741 10761 10762 10813 10812
8 9691 9692 9743 9742 10762 10763 10814 10813
8 9692 9693 9744 9743 10763 10764 10815 10814
8 9693 9694 9745 9744 10764 10765 10816 10815
8 9694 9695 9746 9745 10765 10766 10817 10816
8 9695 9696 9747 9746 10766 10767 10818 10817
8 9696 9697 9748 9747 10767 10768 10819 10818
8 9697 9698 9749 9748 10768 10769 10820 10819
8 9698 9699 9750 9749 10769 10770 10821 10820
8 9699 9700 9751 9750 10770 10771 10822 10821
8 9700 9701 9752 9751 10771 10772 10823 10822
8 9701 9702 9753 9752 10772 10773 10824 10823
8 9702 9703 9754 9753 10773 10774 10825 10824
8 9703 9704 9755 9754 10774 10775 10826 10825
8 9704 9705 9756 9755 10775 10776 10827 10826
8 9705 9706 9757 9756 10776 10777 10828 10827
8 9706 9707 9758 9757 10777 10778 10829 10828
8 9707 9708 9759 9758 10778 10779 10830 10829
8 9708 9709 9760 9759 10779 10780 10831 10830
8 9709 9710 9761 9760 10780 10781 10832 10831
8 9710 9711 9762 9761 10781 10782 10833 10832
8 9711 9712 9763 9762 10782 10783 10834 10833
8 9712 9713 9764 9763 10783 10784 10835 10834
8 9713 9714 9765 9764 10784 10785 10836 10835
8 9714 9715 9766 9765 10785 10786 10837 10836
8 9715 9716 9767 9766 10786 10787 10838 10837
8 9716 9717 9768 9767 10787 10788 10839 10838
8 9717 9718 9769 9768 10788 10789 10840 10839
8 9718 9719 9770 9769 10789 10790 10841 10840
8 9719 9720 9771 9770 10790 10791 10842 10841
8 9720 9721 9772 9771 10791 10792 10843 10842
8 9721 9722 9773 9772 10792 10793 10844 10843
8 9722 9723 9774 9773 10793 10794 10845 10844
8 9723 9724 9775 9774 10794 10795 10846 10845
8 9724 9725 9776 9775 10795 10796 10847 10846
8 9725 9726 9777 9776 10796 10797 10848 10847
8 9726 9727 9778 9777 10797 10798 10849 10848
8 9727 9728 9779 9778 10798 10799 10850 10849
8 9728 9729 9780 9779 10799 10800 10851 10850
8 9729 9730 9781 9780 10800 10801 10852 10851
8 9730 9731 9782 9781 10801 10802 10853 10852
8 9731 9732 9783 9782 10802 10803 10854 10853
8 9732 9733 9784 9783 10803 10804 10855 10854
8 9733 9734 9785 9784 10804 10805 10856 10855
8 9734 9735 9786 9785 10805 10806 10857 10856
8 9735 9736 9787 9786 10806 10807 10858 10857
8 9736 9737 9788 9787 10807 10808 10859 10858
8 9737 9738 9789 9788 10808 10809 10860 10859
8 9738 9739 9790 9789 10809 10810 10861 10860
8 9739 9740 9791 9790 10810 10811 10862 10861
8 9741 9742 9793 9792 10812 10813 10864 10863
8 9742 9743 9794 9793 10813 10814 10865 10864
8 9743 9744 9795 9794 10814 10815 10866 10865
8 9744 9745 9796 9795 10815 10816 10867 10866
8 9745 9746 9797 9796 10816 10817 10868 10867
8 9746 9747 9798 9797 10817 10818 10869 10868
8 9747 9748 9799 9798 10818 10819 10870 10869
8 9748 9749 9800 9799 10819 10820 10871 10870
8 9749 9750 9801 9800 10820 10821 10872 10871
8 9750 9751 9802 9801 10821 10822 10873 10872
8 9751 9752 9803 9802 10822 10823 10874 10873
8 9752 9753 9804 9803 10823 10824 10875 10874
8 9753 9754 9805 9804 10824 10825 10876 10875
8 9754 9755 9806 9805 10825 10826 10877 10876
8 9755 9756 9807 9806 10826 10827 10878 10877
8 9756 9757 9808 9807 10827 10828 10879 10878
8 9757 9758 9809 9808 10828 10829 10880 10879
8 9758 9759 9810 9809 10829 10830 10881 10880
8 9759 9760 9811 9810 10830 10831 10882 10881
8 9760 9761 9812 9811 10831 10832 10883 10882
8 9761 9762 9813 9812 10832 10833 10884 10883
8 9762 9763 9814 9813 10833 10834 10885 10884
8 9763 9764 9815 9814 10834 10835 10886 10885
8 9764 9765 9816 9815 10835 10836 10887 10886
8 9765 9766 9817 9816 10836 10837 10888 10887
8 9766 9767 9818 9817 10837 10838 10889 10888
8 9767 9768 9819 9818 10838 10839 10890 10889
8 9768 9769 9820 9819 10839 10840 10891 10890
8 9769 9770 9821 9820 10840 10841 10892 10891
8 9770 9771 9822 9821 10841 10842 10893 10892
8 9771 9772 9823 9822 10842 10843 10894 10893
8 9772 9773 9824 9823 10843 10844 10895 10894
8 9773 9774 9825 9824 10844 10845 10896 10895
8 9774 9775 9826 9825 10845 10846 10897 10896
8 9775 9776 9827 9826 10846 10847 10898 10897
8 9776 9777 9828 9827 10847 10848 10899 10898
8 9777 9778 9829 9828 10848 10849 10900 10899
8 9778 9779 9830 9829 10849 10850 10901 10900
8 9779 9780 9831 9830 10850 10851 10902 10901
8 9780 9781 9832 9831 10851 10852 10903 10902
8 9781 9782 9833 9832 10852 10853 10904 10903
8 9782 9783 9834 9833 10853 10854 10905 10904
8 9783 9784 9835 9834 10854 10855 10906 10905
8 9784 9785 9836 9835 10855 10856 10907 10906
8 9785 9786 9837 9836 10856 10857 10908 10907
8 9786 9787 9838 9837 10857 10858 10909 10908
8 9787 9788 9839 9838 10858 10859 10910 10909
8 9788 9789 9840 9839 10859 10860 10911 10910
8 9789 9790 9841 9840 10860 10861 10912 10911
8 9790 9791 9842 9841 10861 10862 10913 10912
8 9792 9793 9844 9843 10863 10864 10915 10914
8 9793 9794 9845 9844 10864 10865 10916 10915
8 9794 9795 9846 9845 10865 10866 10917 10916
8 9795 9796 9847 9846 10866 10867 10918 10917
8 9796 9797 9848 9847 10867 10868 10919 10918
8 9797 9798 9849 9848 10868 10869 10920 10919
8 9798 9799 9850 9849 10869 10870 10921 10920
8 9799 9800 9851 9850 10870 10871 10922 10921
8 9800 9801 9852 9851 10871 10872 10923 10922
8 9801 9802 9853 9852 10872 10873 10924 10923
8 9802 9803 9854 9853 10873 10874 10925 10924
8 9803 9804 9855 9854 10874 10875 10926 10925
8 9804 9805 9856 9855 10875 10876 10927 10926
8 9805 9806 9857 9856 10876 10877 10928 10927
8 9806 9807 9858 9857 10877 10878 10929 10928
8 9807 9808 9859 9858 10878 10879 10930 10929
8 9808 9809 9860 9859 10879 10880 10931 10930
8 9809 9810 9861 9860 10880 10881 10932 10931
8 9810 9811 9862 9861 10881 10882 10933 10932
8 9811 9812 9863 9862 10882 10883 10934 10933
8 9812 9813 9864 9863 10883 10884 10935 10934
8 9813 9814 9865 9864 10884 10885 10936 10935
8 9814 9815 9866 9865 10885 10886 10937 10936
8 9815 9816 9867 9866 10886 10887 10938 10937
8 9816 9817 9868 9867 10887 10888 10939 10938
8 9817 9818 9869 9868 10888 10889 10940 10939
8 9818 9819 9870 9869 10889 10890 10941 10940
8 9819 9820 9871 9870 10890 10891 10942 10941
8 9820 9821 9872 9871 10891 10892 10943 10942
8 9821 9822 9873 9872 10892 10893 10944 10943
8 9822 9823 9874 9873 10893 10894 10945 10944
8 9823 9824 9875 9874 10894 10895 10946 10945
8 9824 9825 9876 9875 10895 10896 10947 10946
8 9825 9826 9877 9876 10896 10897 10948 10947
8 9826 9827 9878 9877 10897 10898 10949 10948
8 9827 9828 9879 9878 10898 10899 10950 10949
8 9828 9829 9880 9879 10899 10900 10951 10950
8 9829 9830 9881 9880 10900 10901 10952 10951
8 9830 9831 9882 9881 10901 10902 10953 10952
8 9831 9832 9883 9882 10902 10903 10954 10953
8 9832 9833 9884 9883 10903 10904 10955 10954
8 9833 9834 9885 9884 10904 10905 10956 10955
8 9834 9835 9886 9885 10905 10906 10957 10956
8 9835 9836 9887 9886 10906 10907 10958 10957
8 9836 9837 9888 9887 10907 10908 10959 10958
8 9837 9838 9889 9888 10908 10909 10960 10959
8 9838 9839 9890 9889 10909 10910 10961 10960
8 9839 9840 9891 9890 10910 10911 10962 10961
8 9840 9841 9892 9891 10911 10912 10963 10962
8 9841 9842 9893 9892 10912 10913 10964 10963
8 9843 9844 9895 9894 10914 10915 10966 10965
8 9844 9845 9896 9895 10915 10916 10967 10966
8 9845 9846 9897 9896 10916 10917 10968 10967
8 9846 9847 9898 9897 10917 10918 10969 10968
8 9847 9848 9899 9898 10918 10919 10970 10969
8 9848 9849 9900 9899 10919 10920 10971 10970
8 9849 9850 9901 9900 10920 10921 10972 10971
8 9850 9851 9902 9901 10921 10922 10973 10972
8 9851 9852 9903 9902 10922 10923 10974 10973
8 9852 9853 9904 9903 10923 10924 10975 10974
8 9853 9854 9905 9904 10924 10925 10976 10975
8 9854 9855 9906 9905 10925 10926 10977 10976
8 9855 9856 9907 9906 10926 10927 10978 10977
8 9856 9857 9908 9907 10927 10928 10979 10978
8 9857 9858 9909 9908 10928 10929 10980 10979
8 9858 9859 9910 9909 10929 10930 10981 10980
8 9859 9860 9911 9910 10930 10931 10982 10981
8 9860 9861 9912 9911 10931 10932 10983 10982
8 9861 9862 9913 9912 10932 10933 10984 10983
8 9862 9863 9914 9913 10933 10934 10985 10984
8 9863 9864 9915 9914 10934 10935 10986 10985
8 9864 9865 9916 9915 10935 10936 10987 10986
8 9865 9866 9917 9916 10936 10937 10988 10987
8 9866 9867 9918 9917 10937 10938 10989 10988
8 9867 9868 9919 9918 10938 10939 10990 10989
8 9868 9869 9920 9919 10939 10940 10991 10990
8 9869 9870 9921 9920 10940 10941 10992 10991
8 9870 9871 9922 9921 10941 10942 10993 10992
8 9871 9872 9923 9922 10942 10943 10994 10993
8 9872 9873 9924 9923 10943 10944 10995 10994
8 9873 9874 9925 9924 10944 10945 10996 10995
8 9874 9875 9926 9925 10945 10946 10997 10996
8 9875 9876 9927 9926 10946 10947 10998 10997
8 9876 9877 9928 9927 10947 10948 10999 10998
8 9877 9878 9929 9928 10948 10949 11000 10999
8 9878 9879 9930 9929 10949 10950 11001 11000
8 9879 9880 9931 9930 10950 10951 11002 11001
8 9880 9881 9932 9931 10951 10952 11003 11002
8 9881 9882 9933 9932 10952 10953 11004 11003
8 9882 9883 9934 9933 10953 10954 11005 11004
8 9883 9884 9935 9934 10954 10955 11006 11005
8 9884 9885 9936 9935 10955 10956 11007 11006
8 9885 9886 9937 9936 10956 10957 11008 11007
8 9886 9887 9938 9937 10957 10958 11009 11008
8 9887 9888 9939 9938 10958 10959 11010 11009
8 9888 9889 9940 9939 10959 10960 11011 11010
8 9889 9890 9941 9940 10960 10961 11012 11011
8 9890 9891 9942 9941 10961 10962 11013 11012
8 9891 9892 9943 9942 10962 10963 11014 11013
8 9892 9893 9944 9943 10963 10964 11015 11014
8 9894 9895 9946 9945 10965 10966 11017 11016
8 9895 9896 9947 9946 10966 10967 11018 11017
8 9896 9897 9948 9947 10967 10968 11019 11018
8 9897 9898 9949 9948 10968 10969 11020 11019
8 9898 9899 9950 9949 10969 10970 11021 11020
8 9899 9900 9951 9950 10970 10971 11022 11021
8 9900 9901 9952 9951 10971 10972 11023 11022
8 9901 9902 9953 9952 10972 10973 11024 11023
8 9902 9903 9954 9953 10973 10974 11025 11024
8 9903 9904 9955 9954 10974 10975 11026 11025
8 9904 9905 9956 9955 10975 10976 11027 11026
8 9905 9906 9957 9956 10976 10977 11028 11027
8 9906 9907 9958 9957 10977 10978 11029 11028
8 9907 9908 9959 9958 10978 10979 11030 11029
8 9908 9909 9960 9959 10979 10980 11031 11030
8 9909 9910 9961 9960 10980 10981 11032 11031
8 9910 9911 9962 9961 10981 10982 11033 11032
8 9911 9912 9963 9962 10982 10983 11034 11033
8 9912 9913 9964 9963 10983 10984 11035 11034
8 9913 9914 9965 9964 10984 10985 11036 11035
8 9914 9915 9966 9965 10985 10986 11037 11036
8 9915 9916 9967 9966 10986 10987 11038 11037
8 9916 9917 9968 9967 10987 10988 11039 11038
8 9917 9918 9969 9968 10988 10989 11040 11039
8 9918 9919 9970 9969 10989 10990 11041 11040
8 9919 9920 9971 9970 10990 10991 11042 11041
8 9920 9921 9972 9971 10991 10992 11043 11042
8 9921 9922 9973 9972 10992 10993 11044 11043
8 9922 9923 9974 9973 10993 10994 11045 11044
8 9923 9924 9975 9974 10994 10995 11046 11045
8 9924 9925 9976 9975 10995 10996 11047 11046
8 9925 9926 9977 9976 10996 10997 11048 11047
8 9926 9927 9978 9977 10997 10998 11049 11048
8 9927 9928 9979 9978 10998 10999 11050 11049
8 9928 9929 9980 9979 10999 11000 11051 11050
8 9929 9930 9981 9980 11000 11001 11052 11051
8 9930 9931 9982 9981 11001 11002 11053 11052
8 9931 9932 9983 9982 11002 11003 11054 11053
8 9932 9933 9984 9983 11003 11004 11055 11054
8 9933 9934 9985 9984 11004 11005 11056 11055
8 9934 9935 9986 9985 11005 11006 11057 11056
8 9935 9936 9987 9986 11006 11007 11058 11057
8 9936 9937 9988 9987 11007 11008 11059 11058
8 9937 9938 9989 9988 11008 11009 11060 11059
8 9938 9939 9990 9989 11009 11010 11061 11060
8 9939 9940 9991 9990 11010 11011 11062 11061
8 9940 9941 9992 9991 11011 11012 11063 11062
8 9941 9942 9993 9992 11012 11013 11064 11063
8 9942 9943 9994 9993 11013 11014 11065 11064
8 9943 9944 9995 9994 11014 11015 11066 11065
8 9945 9946 9997 9996 11016 11017 11068 11067
8 9946 9947 9998 9997 11017 11018 11069 11068
8 9947 9948 9999 9998 11018 11019 11070 11069
8 9948 9949 10000 9999 11019 11020 11071 11070
8 9949 9950 10001 10000 11020 11021 11072 11071
8 9950 9951 10002 10001 11021 11022 11073 11072
8 9951 9952 10003 10002 11022 11023 11074 11073
8 9952 9953 10004 10003 11023 11024 11075 11074
8 9953 9954 10005 10004 11024 11025 11076 11075
8 9954 9955 10006 10005 11025 11026 11077 11076
8 9955 9956 10007 10006 11026 11027 11078 11077
8 9956 9957 10008 10007 11027 11028 11079 11078
8 9957 9958 10009 10008 11028 11029 11080 11079
8 9958 9959 10010 10009 11029 11030 11081 11080
8 9959 9960 10011 10010 11030 11031 11082 11081
8 9960 9961 10012 10011 11031 11032 11083 11082
8 9961 9962 10013 10012 11032 11033 11084 11083
8 9962 9963 10014 10013 11033 11034 11085 11084
8 9963 9964 10015 10014 11034 11035 11086 11085
8 9964 9965 10016 10015 11035 11036 11087 11086
8 9965 9966 10017 10016 11036 11037 11088 11087
8 9966 9967 10018 10017 11037 11038 11089 11088
8 9967 9968 10019 10018 11038 11039 11090 11089
8 9968 9969 10020 10019 11039 11040 11091 11090
8 9969 9970 10021 10020 11040 11041 11092 11091
8 9970 9971 10022 10021 11041 11042 11093 11092
8 9971 9972 10023 10022 11042 11043 11094 11093
8 9972 9973 10024 10023 11043 11044 11095 11094
8 9973 9974 10025 10024 11044 11045 11096 11095
8 9974 9975 10026 10025 11045 11046 11097 11096
8 9975 9976 10027 10026 11046 11047 11098 11097
8 9976 9977 10028 10027 11047 11048 11099 11098
8 9977 9978 10029 10028 11048 11049 11100 11099
8 9978 9979 10030 10029 11049 11050 11101 11100
8 9979 9980 10031 10030 11050 11051 11102 11101
8 9980 9981 10032 10031 11051 11052 11103 11102
8 9981 9982 10033 10032 11052 11053 11104 11103
8 9982 9983 10034 10033 11053 11054 11105 11104
8 9983 9984 10035 10034 11054 11055 11106 11105
8 9984 9985 10036 10035 11055 11056 11107 11106
8 9985 9986 10037 10036 11056 11057 11108 11107
8 9986 9987 10038 10037 11057 11058 11109 11108
8 9987 9988 10039 10038 11058 11059 11110 11109
8 9988 9989 10040 10039 11059 11060 11111 11110
8 9989 9990 10041 10040 11060 11061 11112 11111
8 9990 9991 10042 10041 11061 11062 11113 11112
8 9991 9992 10043 10042 11062 11063 11114 11113
8 9992 9993 10044 10043 11063 11064 11115 11114
8 9993 9994 10045 10044 11064 11065 11116 11115
8 9994 9995 10046 10045 11065 11066 11117 11116
8 9996 9997 10048 10047 11067 11068 11119 11118
8 9997 9998 10049 10048 11068 11069 11120 11119
8 9998 9999 10050 10049 11069 11070 11121 11120
8 9999 10000 10051 10050 11070 11071 11122 11121
8 10000 10001 10052 10051 11071 11072 11123 11122
8 10001 10002 10053 10052 11072 11073 11124 11123
8 10002 10003 10054 10053 11073 11074 11125 11124
8 10003 10004 10055 10054 11074 11075 11126 11125
8 10004 10005 10056 10055 11075 11076 11127 11126
8 10005 10006 10057 10056 11076 11077 11128 11127
8 10006 10007 10058 10057 11077 11078 11129 11128
8 10007 10008 10059 10058 11078 11079 11130 11129
8 10008 10009 10060 10059 11079 11080 11131 11130
8 10009 10010 10061 10060 11080 11081 11132 11131
8 10010 10011 10062 10061 11081 11082 11133 11132
8 10011 10012 10063 10062 11082 11083 11134 11133
8 10012 10013 10064 10063 11083 11084 11135 11134
8 10013 10014 10065 10064 11084 11085 11136 11135
8 10014 10015 10066 10065 11085 11086 11137 11136
8 10015 10016 10067 10066 11086 11087 11138 11137
8 10016 10017 10068 10067 11087 11088 11139 11138
8 10017 10018 10069 10068 11088 11089 11140 11139
8 10018 10019 10070 10069 11089 11090 11141 11140
8 10019 10020 10071 10070 11090 11091 11142 11141
8 10020 10021 10072 10071 11091 11092 11143 11142
8 10021 10022 10073 10072 11092 11093 11144 11143
8 10022 10023 10074 10073 11093 11094 11145 11144
8 10023 10024 10075 10074 11094 11095 11146 11145
8 10024 10025 10076 10075 11095 11096 11147 11146
8 10025 10026 10077 10076 11096 11097 11148 11147
8 10026 10027 10078 10077 11097 11098 11149 11148
8 10027 10028 10079 10078 11098 11099 11150 11149
8 10028 10029 10080 10079 11099 11100 11151 11150
8 10029 10030 10081 10080 11100 11101 11152 11151
8 10030 10031 10082 10081 11101 11102 11153 11152
8 10031 10032 10083 10082 11102 11103 11154 11153
8 10032 10033 10084 10083 11103 11104 11155 11154
8 10033 10034 10085 10084 11104 11105 11156 11155
8 10034 10035 10086 10085 11105 11106 11157 11156
8 10035 10036 10087 10086 11106 11107 11158 11157
8 10036 10037 10088 10087 11107 11108 11159 11158
8 10037 10038 10089 10088 11108 11109 11160 11159
8 10038 10039 10090 10089 11109 11110 11161 11160
8 10039 10040 10091 10090 11110 11111 11162 11161
8 10040 10041 10092 10091 11111 11112 11163 11162
8 10041 10042 10093 10092 11112 11113 11164 11163
8 10042 10043 10094 10093 11113 11114 11165 11164
8 10043 10044 10095 10094 11114 11115 11166 11165
8 10044 10045 10096 10095 11115 11116 11167 11166
8 10045 10046 10097 10096 11116 11117 11168 11167
8 10047 10048 10099 10098 11118 11119 11170 11169
8 10048 10049 10100 10099 11119 11120 11171 11170
8 10049 10050 10101 10100 11120 11121 11172 11171
8 10050 10051 10102 10101 11121 11122 11173 11172
8 10051 10052 10103 10102 11122 11123 11174 11173
8 10052 10053 10104 10103 11123 11124 11175 11174
8 10053 10054 10105 10104 11124 11125 11176 11175
8 10054 10055 10106 10105 11125 11126 11177 11176
8 10055 10056 10107 10106 11126 11127 11178 11177
8 10056 10057 10108 10107 11127 11128 11179 11178
8 10057 10058 10109 10108 11128 11129 11180 11179
8 10058 10059 10110 10109 11129 11130 11181 11180
8 10059 10060 10111 10110 11130 11131 11182 11181
8 10060 10061 10112 10111 11131 11132 11183 11182
8 10061 10062 10113 10112 11132 11133 11184 11183
8 10062 10063 10114 10113 11133 11134 11185 11184
8 10063 10064 10115 10114 11134 11135 11186 11185
8 10064 10065 10116 10115 11135 11136 11187 11186
8 10065 10066 10117 10116 11136 11137 11188 11187
8 10066 10067 10118 10117 11137 11138 11189 11188
8 10067 10068 10119 10118 11138 11139 11190 11189
8 10068 10069 10120 10119 11139 11140 11191 11190
8 10069 10070 10121 10120 11140 11141 11192 11191
8 10070 10071 10122 10121 11141 11142 11193 11192
8 10071 10072 10123 10122 11142 11143 11194 11193
8 10072 10073 10124 10123 11143 11144 11195 11194
8 10073 10074 10125 10124 11144 11145 11196 11195
8 10074 10075 10126 10125 11145 11146 11197 11196
8 10075 10076 10127 10126 11146 11147 11198 11197
8 10076 10077 10128 10127 11147 11148 11199 11198
8 10077 10078 10129 10128 11148 11149 11200 11199
8 10078 10079 10130 10129 11149 11150 11201 11200
8 10079 10080 10131 10130 11150 11151 11202 11201
8 10080 10081 10132 10131 11151 11152 11203 11202
8 10081 10082 10133 10132 11152 11153 11204 11203
8 10082 10083 10134 10133 11153 11154 11205 11204
8 10083 10084 10135 10134 11154 11155 11206 11205
8 10084 10085 10136 10135 11155 11156 11207 11206
8 10085 10086 10137 10136 11156 11157 11208 11207
8 10086 10087 10138 10137 11157 11158 11209 11208
8 10087 10088 10139 10138 11158 11159 11210 11209
8 10088 10089 10140 10139 11159 11160 11211 11210
8 10089 10090 10141 10140 11160 11161 11212 11211
8 10090 10091 10142 10141 11161 11162 11213 11212
8 10091 10092 10143 10142 11162 11163 11214 11213
8 10092 10093 10144 10143 11163 11164 11215 11214
8 10093 10094 10145 10144 11164 11165 11216 11215
8 10094 10095 10146 10145 11165 11166 11217 11216
8 10095 10096 10147 10146 11166 11167 11218 11217
8 10096 10097 10148 10147 11167 11168 11219 11218
8 10098 10099 10150 10149 11169 11170 11221 11220
8 10099 10100 10151 10150 11170 11171 11222 11221
8 10100 10101 10152 10151 11171 11172 11223 11222
8 10101 10102 10153 10152 11172 11173 11224 11223
8 10102 10103 10154 10153 11173 11174 11225 11224
8 10103 10104 10155 10154 11174 11175 11226 11225
8 10104 10105 10156 10155 11175 11176 11227 11226
8 10105 10106 10157 10156 11176 11177 11228 11227
8 10106 10107 10158 10157 11177 11178 11229 11228
8 10107 10108 10159 10158 11178 11179 11230 11229
8 10108 10109 10160 10159 11179 11180 11231 11230
8 10109 10110 10161 10160 11180 11181 11232 11231
8 10110 10111 10162 10161 11181 11182 11233 11232
8 10111 10112 10163 10162 11182 11183 11234 11233
8 10112 10113 10164 10163 11183 11184 11235 11234
8 10113 10114 10165 10164 11184 11185 11236 11235
8 10114 10115 10166 10165 11185 11186 11237 11236
8 10115 10116 10167 10166 11186 11187 11238 11237
8 10116 10117 10168 10167 11187 11188 11239 11238
8 10117 10118 10169 10168 11188 11189 11240 11239
8 10118 10119 10170 10169 11189 11190 11241 11240
8 10119 10120 10171 10170 11190 11191 11242 11241
8 10120 10121 10172 10171 11191 11192 11243 11242
8 10121 10122 10173 10172 11192 11193 11244 11243
8 10122 10123 10174 10173 11193 11194 11245 11244
8 10123 10124 10175 10174 11194 11195 11246 11245
8 10124 10125 10176 10175 11195 11196 11247 11246
8 10125 10126 10177 10176 11196 11197 11248 11247
8 10126 10127 10178 10177 11197 11198 11249 11248
8 10127 10128 10179 10178 11198 11199 11250 11249
8 10128 10129 10180 10179 11199 11200 11251 11250
8 10129 10130 10181 10180 11200 11201 11252 11251
8 10130 10131 10182 10181 11201 11202 11253 11252
8 10131 10132 10183 10182 11202 11203 11254 11253
8 10132 10133 10184 10183 11203 11204 11255 11254
8 10133 10134 10185 10184 11204 11205 11256 11255
8 10134 10135 10186 10185 11205 11206 11257 11256
8 10135 10136 10187 10186 11206 11207 11258 11257
8 10136 10137 10188 10187 11207 11208 11259 11258
8 10137 10138 10189 10188 11208 11209 11260 11259
8 10138 10139 10190 10189 11209 11210 11261 11260
8 10139 10140 10191 10190 11210 11211 11262 11261
8 10140 10141 10192 10191 11211 11212 11263 11262
8 10141 10142 10193 10192 11212 11213 11264 11263
8 10142 10143 10194 10193 11213 11214 11265 11264
8 10143 10144 10195 10194 11214 11215 11266 11265
8 10144 10145 10196 10195 11215 11216 11267 11266
8 10145 10146 10197 10196 11216 11217 11268 11267
8 10146 10147 10198 10197 11217 11218 11269 11268
8 10147 10148 10199 10198 11218 11219 11270 11269
8 10149 10150 10201 10200 11220 11221 11272 11271
8 10150 10151 10202 10201 11221 11222 11273 11272
8 10151 10152 10203 10202 11222 11223 11274 11273
8 10152 10153 10204 10203 11223 11224 11275 11274
8 10153 10154 10205 10204 11224 11225 11276 11275
8 10154 10155 10206 10205 11225 11226 11277 11276
8 10155 10156 10207 10206 11226 11227 11278 11277
8 10156 10157 10208 10207 11227 11228 11279 11278
8 10157 10158 10209 10208 11228 11229 11280 11279
8 10158 10159 10210 10209 11229 11230 11281 11280
8 10159 10160 10211 10210 11230 11231 11282 11281
8 10160 10161 10212 10211 11231 11232 11283 11282
8 10161 10162 10213 10212 11232 11233 11284 11283
8 10162 10163 10214 10213 11233 11234 11285 11284
8 10163 10164 10215 10214 11234 11235 11286 11285
8 10164 10165 10216 10215 11235 11236 11287 11286
8 10165 10166 10217 10216 11236 11237 11288 11287
8 10166 10167 10218 10217 11237 11238 11289 11288
8 10167 10168 10219 10218 11238 11239 11290 11289
8 10168 10169 10220 10219 11239 11240 11291 11290
8 10169 10170 10221 10220 11240 11241 11292 11291
8 10170 10171 10222 10221 11241 11242 11293 11292
8 10171 10172 10223 10222 11242 11243 11294 11293
8 10172 10173 10224 10223 11243 11244 11295 11294
8 10173 10174 10225 10224 11244 11245 11296 11295
8 10174 10175 10226 10225 11245 11246 11297 11296
8 10175 10176 10227 10226 11246 11247 11298 11297
8 10176 10177 10228 10227 11247 11248 11299 11298
8 10177 10178 10229 10228 11248 11249 11300 11299
8 10178 10179 10230 10229 11249 11250 11301 11300
8 10179 10180 10231 10230 11250 11251 11302 11301
8 10180 10181 10232 10231 11251 11252 11303 11302
8 10181 10182 10233 10232 11252 11253 11304 11303
8 10182 10183 10234 10233 11253 11254 11305 11304
8 10183 10184 10235 10234 11254 11255 11306 11305
8 10184 10185 10236 10235 11255 11256 11307 11306
8 10185 10186 10237 10236 11256 11257 11308 11307
8 10186 10187 10238 10237 11257 11258 11309 11308
8 10187 10188 10239 10238 11258 11259 11310 11309
8 10188 10189 10240 10239 11259 11260 11311 11310
8 10189 10190 10241 10240 11260 11261 11312 11311
8 10190 10191 10242 10241 11261 11262 11313 11312
8 10191 10192 10243 10242 11262 11263 11314 11313
8 10192 10193 10244 10243 11263 11264 11315 11314
8 10193 10194 10245 10244 11264 11265 11316 11315
8 10194 10195 10246 10245 11265 11266 11317 11316
8 10195 10196 10247 10246 11266 11267 11318 11317
8 10196 10197 10248 10247 11267 11268 11319 11318
8 10197 10198 10249 10248 11268 11269 11320 11319
8 10198 10199 10250 10249 11269 11270 11321 11320
8 10200 10201 10252 10251 11271 11272 11323 11322
8 10201 10202 10253 10252 11272 11273 11324 11323
8 10202 10203 10254 10253 11273 11274 11325 11324
8 10203 10204 10255 10254 11274 11275 11326 11325
8 10204 10205 10256 10255 11275 11276 11327 11326
8 10205 10206 10257 10256 11276 11277 11328 11327
8 10206 10207 10258 10257 11277 11278 11329 11328
8 10207 10208 10259 10258 11278 11279 11330 11329
8 10208 10209 10260 10259 11279 11280 11331 11330
8 10209 10210 10261 10260 11280 11281 11332 11331
8 10210 10211 10262 10261 11281 11282 11333 11332
8 10211 10212 10263 10262 11282 11283 11334 11333
8 10212 10213 10264 10263 11283 11284 11335 11334
8 10213 10214 10265 10264 11284 11285 11336 11335
8 10214 10215 10266 10265 11285 11286 11337 11336
8 10215 10216 10267 10266 11286 11287 11338 11337
8 10216 10217 10268 10267 11287 11288 11339 11338
8 10217 10218 10269 10268 11288 11289 11340 11339
8 10218 10219 10270 10269 11289 11290 11341 11340
8 10219 10220 10271 10270 11290 11291 11342 11341
8 10220 10221 10272 10271 11291 11292 11343 11342
8 10221 10222 10273 10272 11292 11293 11344 11343
8 10222 10223 10274 10273 11293 11294 11345 11344
8 10223 10224 10275 10274 11294 11295 11346 11345
8 10224 10225 10276 10275 11295 11296 11347 11346
8 10225 10226 10277 10276 11296 11297 11348 11347
8 10226 10227 10278 10277 11297 11298 11349 11348
8 10227 10228 10279 10278 11298 11299 11350 11349
8 10228 10229 10280 10279 11299 11300 11351 11350
8 10229 10230 10281 10280 11300 11301 11352 11351
8 10230 10231 10282 10281 11301 11302 11353 11352
8 10231 10232 10283 10282 11302 11303 11354 11353
8 10232 10233 10284 10283 11303 11304 11355 11354
8 10233 10234 10285 10284 11304 11305 11356 11355
8 10234 10235 10286 10285 11305 11306 11357 11356
8 10235 10236 10287 10286 11306 11307 11358 11357
8 10236 10237 10288 10287 11307 11308 11359 11358
8 10237 10238 10289 10288 11308 11309 11360 11359
8 10238 10239 10290 10289 11309 11310 11361 11360
8 10239 10240 10291 10290 11310 11311 11362 11361
8 10240 10241 10292 10291 11311 11312 11363 11362
8 10241 10242 10293 10292 11312 11313 11364 11363
8 10242 10243 10294 10293 11313 11314 11365 11364
8 10243 10244 10295 10294 11314 11315 11366 11365
8 10244 10245 10296 10295 11315 11316 11367 11366
8 10245 10246 10297 10296 11316 11317 11368 11367
8 10246 10247 10298 10297 11317 11318 11369 11368
8 10247 10248 10299 10298 11318 11319 11370 11369
8 10248 10249 10300 10299 11319 11320 11371 11370
8 10249 10250 10301 10300 11320 11321 11372 11371
8 10251 10252 10303 10302 11322 11323 11374 11373
8 10252 10253 10304 10303 11323 11324 11375 11374
8 10253 10254 10305 10304 11324 11325 11376 11375
8 10254 10255 10306 10305 11325 11326 11377 11376
8 10255 10256 10307 10306 11326 11327 11378 11377
8 10256 10257 10308 10307 11327 11328 11379 11378
8 10257 10258 10309 10308 11328 11329 11380 11379
8 10258 10259 10310 10309 11329 11330 11381 11380
8 10259 10260 10311 10310 11330 11331 11382 11381
8 10260 10261 10312 10311 11331 11332 11383 11382
8 10261 10262 10313 10312 11332 11333 11384 11383
8 10262 10263 10314 10313 11333 11334 11385 11384
8 10263 10264 10315 10314 11334 11335 11386 11385
8 10264 10265 10316 10315 11335 11336 11387 11386
8 10265 10266 10317 10316 11336 11337 11388 11387
8 10266 10267 10318 10317 11337 11338 11389 11388
8 10267 10268 10319 10318 11338 11339 11390 11389
8 10268 10269 10320 10319 11339 11340 11391 11390
8 10269 10270 10321 10320 11340 11341 11392 11391
8 10270 10271 10322 10321 11341 11342 11393 11392
8 10271 10272 10323 10322 11342 11343 11394 11393
8 10272 10273 10324 10323 11343 11344 11395 11394
8 10273 10274 10325 10324 11344 11345 11396 11395
8 10274 10275 10326 10325 11345 11346 11397 11396
8 10275 10276 10327 10326 11346 11347 11398 11397
8 10276 10277 10328 10327 11347 11348 11399 11398
8 10277 10278 10329 10328 11348 11349 11400 11399
8 10278 10279 10330 10329 11349 11350 11401 11400
8 10279 10280 10331 10330 11350 11351 11402 11401
8 10280 10281 10332 10331 11351 11352 11403 11402
8 10281 10282 10333 10332 11352 11353 11404 11403
8 10282 10283 10334 10333 11353 11354 11405 11404
8 10283 10284 10335 10334 11354 11355 11406 11405
8 10284 10285 10336 10335 11355 11356 11407 11406
8 10285 10286 10337 10336 11356 11357 11408 11407
8 10286 10287 10338 10337 11357 11358 11409 11408
8 10287 10288 10339 10338 11358 11359 11410 11409
8 10288 10289 10340 10339 11359 11360 11411 11410
8 10289 10290 10341 10340 11360 11361 11412 11411
8 10290 10291 10342 10341 11361 11362 11413 11412
8 10291 10292 10343 10342 11362 11363 11414 11413
8 10292 10293 10344 10343 11363 11364 11415 11414
8 10293 10294 10345 10344 11364 11365 11416 11415
8 10294 10295 10346 10345 11365 11366 11417 11416
8 10295 10296 10347 10346 11366 11367 11418 11417
8 10296 10297 10348 10347 11367 11368 11419 11418
8 10297 10298 10349 10348 11368 11369 11420 11419
8 10298 10299 10350 10349 11369 11370 11421 11420
8 10299 10300 10351 10350 11370 11371 11422 11421
8 10300 10301 10352 10351 11371 11372 11423 11422
8 10302 10303 10354 10353 11373 11374 11425 11424
8 10303 10304 10355 10354 11374 11375 11426 11425
8 10304 10305 10356 10355 11375 11376 11427 11426
8 10305 10306 10357 10356 11376 11377 11428 11427
8 10306 10307 10358 10357 11377 11378 11429 11428
8 10307 10308 10359 10358 11378 11379 11430 11429
8 10308 10309 10360 10359 11379 11380 11431 11430
8 10309 10310 10361 10360 11380 11381 11432 11431
8 10310 10311 10362 10361 11381 11382 11433 11432
8 10311 10312 10363 10362 11382 11383 11434 11433
8 10312 10313 10364 10363 11383 11384 11435 11434
8 10313 10314 10365 10364 11384 11385 11436 11435
8 10314 10315 10366 10365 11385 11386 11437 11436
8 10315 10316 10367 10366 11386 11387 11438 11437
8 10316 10317 10368 10367 11387 11388 11439 11438
8 10317 10318 10369 10368 11388 11389 11440 11439
8 10318 10319 10370 10369 11389 11390 11441 11440
8 10319 10320 10371 10370 11390 11391 11442 11441
8 10320 10321 10372 10371 11391 11392 11443 11442
8 10321 10322 10373 10372 11392 11393 11444 11443
8 10322 10323 10374 10373 11393 11394 11445 11444
8 10323 10324 10375 10374 11394 11395 11446 11445
8 10324 10325 10376 10375 11395 11396 11447 11446
8 10325 10326 10377 10376 11396 11397 11448 11447
8 10326 10327 10378 10377 11397 11398 11449 11448
8 10327 10328 10379 10378 11398 11399 11450 11449
8 10328 10329 10380 10379 11399 11400 11451 11450
8 10329 10330 10381 10380 11400 11401 11452 11451
8 10330 10331 10382 10381 11401 11402 11453 11452
8 10331 10332 10383 10382 11402 11403 11454 11453
8 10332 10333 10384 10383 11403 11404 11455 11454
8 10333 10334 10385 10384 11404 11405 11456 11455
8 10334 10335 10386 10385 11405 11406 11457 11456
8 10335 10336 10387 10386 11406 11407 11458 11457
8 10336 10337 10388 10387 11407 11408 11459 11458
8 10337 10338 10389 10388 11408 11409 11460 11459
8 10338 10339 10390 10389 11409 11410 11461 11460
8 10339 10340 10391 10390 11410 11411 11462 11461
8 10340 10341 10392 10391 11411 11412 11463 11462
8 10341 10342 10393 10392 11412 11413 11464 11463
8 10342 10343 10394 10393 11413 11414 11465 11464
8 10343 10344 10395 10394 11414 11415 11466 11465
8 10344 10345 10396 10395 11415 11416 11467 11466
8 10345 10346 10397 10396 11416 11417 11468 11467
8 10346 10347 10398 10397 11417 11418 11469 11468
8 10347 10348 10399 10398 11418 11419 11470 11469
8 10348 10349 10400 10399 11419 11420 11471 11470
8 10349 10350 10401 10400 11420 11421 11472 11471
8 10350 10351 10402 10401 11421 11422 11473 11472
8 10351 10352 10403 10402 11422 11423 11474 11473
8 10353 10354 10405 10404 11424 11425 11476 11475
8 10354 10355 10406 10405 11425 11426 11477 11476
8 10355 10356 10407 10406 11426 11427 11478 11477
8 10356 10357 10408 10407 11427 11428 11479 11478
8 10357 10358 10409 10408 11428 11429 11480 11479
8 10358 10359 10410 10409 11429 11430 11481 11480
8 10359 10360 10411 10410 11430 11431 11482 11481
8 10360 10361 10412 10411 11431 11432 11483 11482
8 10361 10362 10413 10412 11432 11433 11484 11483
8 10362 10363 10414 10413 11433 11434 11485 11484
8 10363 10364 10415 10414 11434 11435 11486 11485
8 10364 10365 10416 10415 11435 11436 11487 11486
8 10365 10366 10417 10416 11436 11437 11488 11487
8 10366 10367 10418 10417 11437 11438 11489 11488
8 10367 10368 10419 10418 11438 11439 11490 11489
8 10368 10369 10420 10419 11439 11440 11491 11490
8 10369 10370 10421 10420 11440 11441 11492 11491
8 10370 10371 10422 10421 11441 11442 11493 11492
8 10371 10372 10423 10422 11442 11443 11494 11493
8 10372 10373 10424 10423 11443 11444 11495 11494
8 10373 10374 10425 10424 11444 11445 11496 11495
8 10374 10375 10426 10425 11445 11446 11497 11496
8 10375 10376 10427 10426 11446 11447 11498 11497
8 10376 10377 10428 10427 11447 11448 11499 11498
8 10377 10378 10429 10428 11448 11449 11500 11499
8 10378 10379 10430 10429 11449 11450 11501 11500
8 10379 10380 10431 10430 11450 11451 11502 11501
8 10380 10381 10432 10431 11451 11452 11503 11502
8 10381 10382 10433 10432 11452 11453 11504 11503
8 10382 10383 10434 10433 11453 11454 11505 11504
8 10383 10384 10435 10434 11454 11455 11506 11505
8 10384 10385 10436 10435 11455 11456 11507 11506
8 10385 10386 10437 10436 11456 11457 11508 11507
8 10386 10387 10438 10437 11457 11458 11509 11508
8 10387 10388 10439 10438 11458 11459 11510 11509
8 10388 10389 10440 10439 11459 11460 11511 11510
8 10389 10390 10441 10440 11460 11461 11512 11511
8 10390 10391 10442 10441 11461 11462 11513 11512
8 10391 10392 10443 10442 11462 11463 11514 11513
8 10392 10393 10444 10443 11463 11464 11515 11514
8 10393 10394 10445 10444 11464 11465 11516 11515
8 10394 10395 10446 10445 11465 11466 11517 11516
8 10395 10396 10447 10446 11466 11467 11518 11517
8 10396 10397 10448 10447 11467 11468 11519 11518
8 10397 10398 10449 10448 11468 11469 11520 11519
8 10398 10399 10450 10449 11469 11470 11521 11520
8 10399 10400 10451 10450 11470 11471 11522 11521
8 10400 10401 10452 10451 11471 11472 11523 11522
8 10401 10402 10453 10452 11472 11473 11524 11523
8 10402 10403 10454 10453 11473 11474 11525 11524
8 10404 10405 10456 10455 11475 11476 11527 11526
8 10405 10406 10457 10456 11476 11477 11528 11527
8 10406 10407 10458 10457 11477 11478 11529 11528
8 10407 10408 10459 10458 11478 11479 11530 11529
8 10408 10409 10460 10459 11479 11480 11531 11530
8 10409 10410 10461 10460 11480 11481 11532 11531
8 10410 10411 10462 10461 11481 11482 11533 11532
8 10411 10412 10463 10462 11482 11483 11534 11533
8 10412 10413 10464 10463 11483 11484 11535 11534
8 10413 10414 10465 10464 11484 11485 11536 11535
8 10414 10415 10466 10465 11485 11486 11537 11536
8 10415 10416 10467 10466 11486 11487 11538 11537
8 10416 10417 10468 10467 11487 11488 11539 11538
8 10417 10418 10469 10468 11488 11489 11540 11539
8 10418 10419 10470 10469 11489 11490 11541 11540
8 10419 10420 10471 10470 11490 11491 11542 11541
8 10420 10421 10472 10471 11491 11492 11543 11542
8 10421 10422 10473 10472 11492 11493 11544 11543
8 10422 10423 10474 10473 11493 11494 11545 11544
8 10423 10424 10475 10474 11494 11495 11546 11545
8 10424 10425 10476 10475 11495 11496 11547 11546
8 10425 10426 10477 10476 11496 11497 11548 11547
8 10426 10427 10478 10477 11497 11498 11549 11548
8 10427 10428 10479 10478 11498 11499 11550 11549
8 10428 10429 10480 10479 11499 11500 11551 11550
8 10429 10430 10481 10480 11500 11501 11552 11551
8 10430 10431 10482 10481 11501 11502 11553 11552
8 10431 10432 10483 10482 11502 11503 11554 11553
8 10432 10433 10484 10483 11503 11504 11555 11554
8 10433 10434 10485 10484 11504 11505 11556 11555
8 10434 10435 10486 10485 11505 11506 11557 11556
8 10435 10436 10487 10486 11506 11507 11558 11557
8 10436 10437 10488 10487 11507 11508 11559 11558
8 10437 10438 10489 10488 11508 11509 11560 11559
8 10438 10439 10490 10489 11509 11510 11561 11560
8 10439 10440 10491 10490 11510 11511 11562 11561
8 10440 10441 10492 10491 11511 11512 11563 11562
8 10441 10442 10493 10492 11512 11513 11564 11563
8 10442 10443 10494 10493 11513 11514 11565 11564
8 10443 10444 10495 10494 11514 11515 11566 11565
8 10444 10445 10496 10495 11515 11516 11567 11566
8 10445 10446 10497 10496 11516 11517 11568 11567
8 10446 10447 10498 10497 11517 11518 11569 11568
8 10447 10448 10499 10498 11518 11519 11570 11569
8 10448 10449 10500 10499 11519 11520 11571 11570
8 10449 10450 10501 10500 11520 11521 11572 11571
8 10450 10451 10502 10501 11521 11522 11573 11572
8 10451 10452 10503 10502 11522 11523 11574 11573
8 10452 10453 10504 10503 11523 11524 11575 11574
8 10453 10454 10505 10504 11524 11525 11576 11575
8 10455 10456 10507 10506 11526 11527 11578 11577
8 10456 10457 10508 10507 11527 11528 11579 11578
8 10457 10458 10509 10508 11528 11529 11580 11579
8 10458 10459 10510 10509 11529 11530 11581 11580
8 10459 10460 10511 10510 11530 11531 11582 11581
8 10460 10461 10512 10511 11531 11532 11583 11582
8 10461 10462 10513 10512 11532 11533 11584 11583
8 10462 10463 10514 10513 11533 11534 11585 11584
8 10463 10464 10515 10514 11534 11535 11586 11585
8 10464 10465 10516 10515 11535 11536 11587 11586
8 10465 10466 10517 10516 11536 11537 11588 11587
8 10466 10467 10518 10517 11537 11538 11589 11588
8 10467 10468 10519 10518 11538 11539 11590 11589
8 10468 10469 10520 10519 11539 11540 11591 11590
8 10469 10470 10521 10520 11540 11541 11592 11591
8 10470 10471 10522 10521 11541 11542 11593 11592
8 10471 10472 10523 10522 11542 11543 11594 11593
8 10472 10473 10524 10523 11543 11544 11595 11594
8 10473 10474 10525 10524 11544 11545 11596 11595
8 10474 10475 10526 10525 11545 11546 11597 11596
8 10475 10476 10527 10526 11546 11547 11598 11597
8 10476 10477 10528 10527 11547 11548 11599 11598
8 10477 10478 10529 10528 11548 11549 11600 11599
8 10478 10479 10530 10529 11549 11550 11601 11600
8 10479 10480 10531 10530 11550 11551 11602 11601
8 10480 10481 10532 10531 11551 11552 11603 11602
8 10481 10482 10533 10532 11552 11553 11604 11603
8 10482 10483 10534 10533 11553 11554 11605 11604
8 10483 10484 10535 10534 11554 11555 11606 11605
8 10484 10485 10536 10535 11555 11556 11607 11606
8 10485 10486 10537 10536 11556 11557 11608 11607
8 10486 10487 10538 10537 11557 11558 11609 11608
8 10487 10488 10539 10538 11558 11559 11610 11609
8 10488 10489 10540 10539 11559 11560 11611 11610
8 10489 10490 10541 10540 11560 11561 11612 11611
8 10490 10491 10542 10541 11561 11562 11613 11612
8 10491 10492 10543 10542 11562 11563 11614 11613
8 10492 10493 10544 10543 11563 11564 11615 11614
8 10493 10494 10545 10544 11564 11565 11616 11615
8 10494 10495 10546 10545 11565 11566 11617 11616
8 10495 10496 10547 10546 11566 11567 11618 11617
8 10496 10497 10548 10547 11567 11568 11619 11618
8 10497 10498 10549 10548 11568 11569 11620 11619
8 10498 10499 10550 10549 11569 11570 11621 11620
8 10499 10500 10551 10550 11570 11571 11622 11621
8 10500 10501 10552 10551 11571 11572 11623 11622
8 10501 10502 10553 10552 11572 11573 11624 11623
8 10502 10503 10554 10553 11573 11574 11625 11624
8 10503 10504 10555 10554 11574 11575 11626 11625
8 10504 10505 10556 10555 11575 11576 11627 11626
8 10506 10507 10558 10557 11577 11578 11629 11628
8 10507 10508 10559 10558 11578 11579 11630 11629
8 10508 10509 10560 10559 11579 11580 11631 11630
8 10509 10510 10561 10560 11580 11581 11632 11631
8 10510 10511 10562 10561 11581 11582 11633 11632
8 10511 10512 10563 10562 11582 11583 11634 11633
8 10512 10513 10564 10563 11583 11584 11635 11634
8 10513 10514 10565 10564 11584 11585 11636 11635
8 10514 10515 10566 10565 11585 11586 11637 11636
8 10515 10516 10567 10566 11586 11587 11638 11637
8 10516 10517 10568 10567 11587 11588 11639 11638
8 10517 10518 10569 10568 11588 11589 11640 11639
8 10518 10519 10570 10569 11589 11590 11641 11640
8 10519 10520 10571 10570 11590 11591 11642 11641
8 10520 10521 10572 10571 11591 11592 11643 11642
8 10521 10522 10573 10572 11592 11593 11644 11643
8 10522 10523 10574 10573 11593 11594 11645 11644
8 10523 10524 10575 10574 11594 11595 11646 11645
8 10524 10525 10576 10575 11595 11596 11647 11646
8 10525 10526 10577 10576 11596 11597 11648 11647
8 10526 10527 10578 10577 11597 11598 11649 11648
8 10527 10528 10579 10578 11598 11599 11650 11649
8 10528 10529 10580 10579 11599 11600 11651 11650
8 10529 10530 10581 10580 11600 11601 11652 11651
8 10530 10531 10582 10581 11601 11602 11653 11652
8 10531 10532 10583 10582 11602 11603 11654 11653
8 10532 10533 10584 10583 11603 11604 11655 11654
8 10533 10534 10585 10584 11604 11605 11656 11655
8 10534 10535 10586 10585 11605 11606 11657 11656
8 10535 10536 10587 10586 11606 11607 11658 11657
8 10536 10537 10588 10587 11607 11608 11659 11658
8 10537 10538 10589 10588 11608 11609 11660 11659
8 10538 10539 10590 10589 11609 11610 11661 11660
8 10539 10540 10591 10590 11610 11611 11662 11661
8 10540 10541 10592 10591 11611 11612 11663 11662
8 10541 10542 10593 10592 11612 11613 11664 11663
8 10542 10543 10594 10593 11613 11614 11665 11664
8 10543 10544 10595 10594 11614 11615 11666 11665
8 10544 10545 10596 10595 11615 11616 11667 11666
8 10545 10546 10597 10596 11616 11617 11668 11667
8 10546 10547 10598 10597 11617 11618 11669 11668
8 10547 10548 10599 10598 11618 11619 11670 11669
8 10548 10549 10600 10599 11619 11620 11671 11670
8 10549 10550 10601 10600 11620 11621 11672 11671
8 10550 10551 10602 10601 11621 11622 11673 11672
8 10551 10552 10603 10602 11622 11623 11674 11673
8 10552 10553 10604 10603 11623 11624 11675 11674
8 10553 10554 10605 10604 11624 11625 11676 11675
8 10554 10555 10606 10605 11625 11626 11677 11676
8 10555 10556 10607 10606 11626 11627 11678 11677
8 10557 10558 10609 10608 11628 11629 11680 11679
8 10558 10559 10610 10609 11629 11630 11681 11680
8 10559 10560 10611 10610 11630 11631 11682 11681
8 10560 10561 10612 10611 11631 11632 11683 11682
8 10561 10562 10613 10612 11632 11633 11684 11683
8 10562 10563 10614 10613 11633 11634 11685 11684
8 10563 10564 10615 10614 11634 11635 11686 11685
8 10564 10565 10616 10615 11635 11636 11687 11686
8 10565 10566 10617 10616 11636 11637 11688 11687
8 10566 10567 10618 10617 11637 11638 11689 11688
8 10567 10568 10619 10618 11638 11639 11690 11689
8 10568 10569 10620 10619 11639 11640 11691 11690
8 10569 10570 10621 10620 11640 11641 11692 11691
8 10570 10571 10622 10621 11641 11642 11693 11692
8 10571 10572 10623 10622 11642 11643 11694 11693
8 10572 10573 10624 10623 11643 11644 11695 11694
8 10573 10574 10625 10624 11644 11645 11696 11695
8 10574 10575 10626 10625 11645 11646 11697 11696
8 10575 10576 10627 10626 11646 11647 11698 11697
8 10576 10577 10628 10627 11647 11648 11699 11698
8 10577 10578 10629 10628 11648 11649 11700 11699
8 10578 10579 10630 10629 11649 11650 11701 11700
8 10579 10580 10631 10630 11650 11651 11702 11701
8 10580 10581 10632 10631 11651 11652 11703 11702
8 10581 10582 10633 10632 11652 11653 11704 11703
8 10582 10583 10634 10633 11653 11654 11705 11704
8 10583 10584 10635 10634 11654 11655 11706 11705
8 10584 10585 10636 10635 11655 11656 11707 11706
8 10585 10586 10637 10636 11656 11657 11708 11707
8 10586 10587 10638 10637 11657 11658 11709 11708
8 10587 10588 10639 10638 11658 11659 11710 11709
8 10588 10589 10640 10639 11659 11660 11711 11710
8 10589 10590 10641 10640 11660 11661 11712 11711
8 10590 10591 10642 10641 11661 11662 11713 11712
8 10591 10592 10643 10642 11662 11663 11714 11713
8 10592 10593 10644 10643 11663 11664 11715 11714
8 10593 10594 10645 10644 11664 11665 11716 11715
8 10594 10595 10646 10645 11665 11666 11717 11716
8 10595 10596 10647 10646 11666 11667 11718 11717
8 10596 10597 10648 10647 11667 11668 11719 11718
8 10597 10598 10649 10648 11668 11669 11720 11719
8 10598 10599 10650 10649 11669 11670 11721 11720
8 10599 10600 10651 10650 11670 11671 11722 11721
8 10600 10601 10652 10651 11671 11672 11723 11722
8 10601 10602 10653 10652 11672 11673 11724 11723
8 10602 10603 10654 10653 11673 11674 11725 11724
8 10603 10604 10655 10654 11674 11675 11726 11725
8 10604 10605 10656 10655 11675 11676 11727 11726
8 10605 10606 10657 10656 11676 11677 11728 11727
8 10606 10607 10658 10657 11677 11678 11729 11728
8 10608 10609 10660 10659 11679 11680 11731 11730
8 10609 10610 10661 10660 11680 11681 11732 11731
8 10610 10611 10662 10661 11681 11682 11733 11732
8 10611 10612 10663 10662 11682 11683 11734 11733
8 10612 10613 10664 10663 11683 11684 11735 11734
8 10613 10614 10665 10664 11684 11685 11736 11735
8 10614 10615 10666 10665 11685 11686 11737 11736
8 10615 10616 10667 10666 11686 11687 11738 11737
8 10616 10617 10668 10667 11687 11688 11739 11738
8 10617 10618 10669 10668 11688 11689 11740 11739
8 10618 10619 10670 10669 11689 11690 11741 11740
8 10619 10620 10671 10670 11690 11691 11742 11741
8 10620 10621 10672 10671 11691 11692 11743 11742
8 10621 10622 10673 10672 11692 11693 11744 11743
8 10622 10623 10674 10673 11693 11694 11745 11744
8 10623 10624 10675 10674 11694 11695 11746 11745
8 10624 10625 10676 10675 11695 11696 11747 11746
8 10625 10626 10677 10676 11696 11697 11748 11747
8 10626 10627 10678 10677 11697 11698 11749 11748
8 10627 10628 10679 10678 11698 11699 11750 11749
8 10628 10629 10680 10679 11699 11700 11751 11750
8 10629 10630 10681 10680 11700 11701 11752 11751
8 10630 10631 10682 10681 11701 11702 11753 11752
8 10631 10632 10683 10682 11702 11703 11754 11753
8 10632 10633 10684 10683 11703 11704 11755 11754
8 10633 10634 10685 10684 11704 11705 11756 11755
8 10634 10635 10686 10685 11705 11706 11757 11756
8 10635 10636 10687 10686 11706 11707 11758 11757
8 10636 10637 10688 10687 11707 11708 11759 11758
8 10637 10638 10689 10688 11708 11709 11760 11759
8 10638 10639 10690 10689 11709 11710 11761 11760
8 10639 10640 10691 10690 11710 11711 11762 11761
8 10640 10641 10692 10691 11711 11712 11763 11762
8 10641 10642 10693 10692 11712 11713 11764 11763
8 10642 10643 10694 10693 11713 11714 11765 11764
8 10643 10644 10695 10694 11714 11715 11766 11765
8 10644 10645 10696 10695 11715 11716 11767 11766
8 10645 10646 10697 10696 11716 11717 11768 11767
8 10646 10647 10698 10697 11717 11718 11769 11768
8 10647 10648 10699 10698 11718 11719 11770 11769
8 10648 10649 10700 10699 11719 11720 11771 11770
8 10649 10650 10701 10700 11720 11721 11772 11771
8 10650 10651 10702 10701 11721 11722 11773 11772
8 10651 10652 10703 10702 11722 11723 11774 11773
8 10652 10653 10704 10703 11723 11724 11775 11774
8 10653 10654 10705 10704 11724 11725 11776 11775
8 10654 10655 10706 10705 11725 11726 11777 11776
8 10655 10656 10707 10706 11726 11727 11778 11777
8 10656 10657 10708 10707 11727 11728 11779 11778
8 10657 10658 10709 10708 11728 11729 11780 11779
CELL_TYPES 10000
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
