[petsc-users] MAT_NEW_NONZERO_LOCATIONS working?
Hong hzhang at mcs.anl.gov
Mon Jun 25 09:25:21 CDT 2018
Marius:
> Thanks a lot, I did not test it thoroughly but it seems to work well and
> really helpful. I have one question, is it necessary to do the MatTranspose
> step as in ex214.c, I thought this is handled internally by petsc?
MUMPS requires sparse compressed COLUMN  format in the host for rhs matrix,
which is not supported by PETSc. MatTranspose() is expensive for large size
matrices.
We added a new petsc function
MatMatTransposeSolve(): Solves A X = B^T, A: factored matrix
(see petsc/src/mat/examples/tests/ex214c)
With this function, user does not need to call MatTranspose, but needs to
create B^T in
AIJ matrix with all rows and columns stored in processor[0].
Let us know if any of you have better idea to handle it.
The easiest way for us is MUMPS supports sparse compressed row format for
rhs matrix.
The branch hzhang/mumps-spRHS will be merged to petsc-master soon.
Hong
> Marius:
> I added support for parallel sparse RHS (in host) for MatMatSolve_MUMPS()
> https://bitbucket.org/petsc/petsc/commits/2b691707dd0cf456c808def006e14b
> 6f56b364b6
> It is in the branch hzhang/mumps-spRHS.
> You may test it.
> I'll further cleanup the routine, test it, then merge it to petsc.
> Hong
> On Mon, Jun 4, 2018 at 9:54 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> On Mon, Jun 4, 2018 at 1:03 PM, Jean-Yves LExcellent <
>> Jean-Yves.L.Excellent at ens-lyon.fr> wrote:
>>> Thanks for the details of your needs.
>>> For the first application, the sparse RHS feature with distributed
>>> solution should effectively be fine.
>> I'll add parallel support of this feature in petsc after I'm back the ANL
>> after June 14th.
>> Hong
>>> For the second one, a future distributed RHS feature (not currently
>>> available in MUMPS) might help if the centralized sparse RHS is too
>>> memory consuming, depending on the size of B1.
>>> Regards,
>>> Jean-Yves, for the MUMPS developers
>>>  I want to  invert a rather large sparse matrix for this using a sparse
>>> rhs with centralized input would be ok as long as the solution is
>>> distributed.
>>> and the second application I have in mind is solving a system of the
>>> from AX=B where A and B are sparse and B is given by a block matrix of the
>>> form B=[B1 0, 0 0] where B1 is dense but the dimension is (much) smaller
>>> than that of the whole matrix B.
>>> Marius:
>>> Current PETSc interface supports sequential sparse multiple right-hand
>>> side, but not distributed.
>>> It turns out that mumps does not support distributed sparse multiple
>>> right-hand sides at
>>> the moment (see attached email).
>>> Jean-Yves invites you to communicate with him directly.
>>> Let me know what we can help on this matter,
>>> e.g., add support for parallel implementation of sparse multiple
>>> right-hand side with
>>> centralized rhs input?
>>> Hong
>>> Jean-Yves LExcellent <Jean-Yves.L.Excellent at ens-lyon.fr>
>>> 5:14 AM (3 hours ago)
>>> to Hong, mumps-dev
>>> Hello,
>>> We do not support distributed sparse multiple right-hand sides at
>>> the moment. From the feedback we have from applications, the
>>> right-hand sides are often very sparse, and having them distributed
>>> did not seem critical.
>>> Since we are specifying a distributed right-hand sides feature at the
>>> moment, could you let us know in more detail the need regarding
>>> distributed sparse right-hand side (e.g., do all columns have the same
>>> nonzero structure in that case) or put us in contact with the user who
>>> needs this?
>>> Thanks,
>>> Jean-Yves and Patrick
>>>> Thanks a lot guys, very helpful.
>>>> I see MUMPS http://mumps.enseeiht.fr/
>>>> Sparse multiple right-hand side, distributed solution; Exploitation of
>>>> sparsity in the right-hand sidesPETSc interface computes mumps distributed
>>>> solution as default (this is not new) (ICNTL(21) = 1)
>>>> I will add support for Sparse multiple right-hand side.
>>>> Hong
>>>> On Thu, May 31, 2018 at 11:25 AM, Smith, Barry F. <bsmith at mcs.anl.gov
>>>> [mailto:bsmith at mcs.anl.gov]> wrote:
>>>>   Hong,
>>>>     Can you see about adding support for distributed right hand side?
>>>>     Thanks
>>>>       Barry
>>>> > On May 31, 2018, at 2:37 AM, Marius Buerkle <mbuerkle at web.de[mailto:
>>>> mbuerkle at web.de]> wrote:
>>>> > The fix for MAT_NEW_NONZERO_LOCATIONS, thanks again.
>>>> > I have yet another question, sorry. The recent version of MUMPS
>>>> supports distributed and sparse RHS is there any chance that this will be
>>>> supported in PETSc in the near future?
>>>> >> On May 30, 2018, at 6:55 PM, Marius Buerkle <mbuerkle at web.de[mailto:
>>>> >> Thanks for the quick fix, I will test it and report back.
>>>> >> I have another maybe related question, if MAT_NEW_NONZERO_LOCATIONS
>>>> is true and let's say 1 new nonzero position is created it does not
>>>> allocated 1 but several new nonzeros but only use 1.
>>>> > Correct
>>>> >> I think that is normal, right?
>>>> > Yes
>>>> >> But, at least as far as I understand the manual, a subsequent call
>>>> of mat assemble with
>>>> >> MAT_FINAL_ASSEMBLY should compress out the unused allocations and
>>>> release the memory, is this correct?
>>>> > It "compresses it out" (by shifting all the nonzero entries to the
>>>> beginning of the internal i, j, and a arrays), but does NOT release any
>>>> memory. Since the values are stored in one big contiguous array (obtained
>>>> with a single malloc) it cannot just free part of the array, so the extra
>>>> locations just sit harmlessly at the end if the array unused.
>>>> >> If so, this did not work for me, even after doing
>>>> >> MAT_FINAL_ASSEMBLY the unused nonzero allocations remain. Is this
>>>> normal?
>>>> > Yes,
>>>> > Barry
>>>> >>> Fixed in the branch barry/fix-mat-new-nonzero-locations/maint
>>>> >>> Once this passes testing it will go into the maint branch and then
>>>> the next patch release but you can use it now in the branch
>>>> >>> Thanks for the report and reproducible example
>>>> >>> Barry
>>>> >>>> On May 29, 2018, at 7:51 PM, Marius Buerkle <mbuerkle at web.de
>>>> [mailto:mbuerkle at web.de]> wrote:
>>>> >>>> Sure, I made a small reproducer, it is Fortran though I hope that
>>>> is ok. If MAT_NEW_NONZERO_LOCATIONS is set to false I get an error, if it
>>>> is set to true the new nonzero element is inserted, if
>>>> MAT_NEW_NONZERO_LOCATIONS is false and either MAT_NEW_NONZERO_LOCATION_ERR
>>>> or MAT_NEW_NONZERO_ALLOCATION_ERR is set to false afterwards then the new
>>>> nonzero is also created without an error, but if MAT_NEW_NONZERO_LOCATIONS
>>>> is set to false after MAT_NEW_NONZERO_LOCATION_ERR/MAT_NEW_NONZERO_ALLOCATION_ERR
>>>> have been set to false I get an error again.
>>>> >>>> program newnonzero
>>>> >>>> #include <petsc/finclude/petscmat.h>
>>>> >>>> use petscmat
>>>> >>>> implicit none
>>>> >>>> Mat :: A
>>>> >>>> PetscInt :: dnnz,onnz,n,m,idxm(1),idxn(1),nl1,nl2
>>>> >>>> PetscScalar :: v(1)
>>>> >>>> PetscReal :: info(MAT_INFO_SIZE)
>>>> >>>> PetscErrorCode :: ierr
>>>> >>>> integer :: nproc,iproc,i
>>>> >>>> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>>> >>>> call MPI_COMM_SIZE(PETSC_COMM_WORLD, nproc,ierr)
>>>> >>>> call MPI_Comm_rank( PETSC_COMM_WORLD, iproc, ierr )
>>>> >>>> n=3
>>>> >>>> m=n
>>>> >>>> call MatCreateAIJ(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,n,m,
>>>> 1,PETSC_NULL_INTEGER,0,PETSC_NULL_INTEGER,A,ierr)
>>>> >>>> call MatGetOwnershipRange(A,nl1,nl2,ierr)
>>>> >>>> do i=nl1,nl2-1
>>>> >>>> idxn(1)=i
>>>> >>>> idxm(1)=i
>>>> >>>> v(1)=1d0
>>>> >>>> call MatSetValues(A,1,idxn,1,idxm, v,INSERT_VALUES,ierr)
>>>> >>>> end do
>>>> >>>> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>>> >>>> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>>> >>>> call MatSetOption(A,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ierr)
>>>> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_LOCATION_ERR,PETSC_
>>>> FALSE,ierr)
>>>> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR
>>>> ,PETSC_FALSE,ierr)
>>>> >>>> !~ call MatSetOption(A,MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ierr)
>>>> >>>> idxn(1)=0
>>>> >>>> idxm(1)=n-1
>>>> >>>> if ((idxn(1).ge.nl1).and.(idxn(1).le.nl2-1)) then
>>>> >>>> v(1)=2d0
>>>> >>>> end if
>>>> >>>> v(1)=2d0
>>>> >>>> call MatGetValues(A,1,idxn,1,idxm, v,ierr)
>>>> >>>> write(6,*) v
>>>> >>>> end if
>>>> >>>> call PetscFinalize(ierr)
>>>> >>>> end program newnonzero
>>>> >>>> $ mpiexec.hydra -n 3 ./a.out
>>>> >>>> [0]PETSC ERROR: --------------------- Error Message
>>>> >>>> [0]PETSC ERROR: Argument out of range
>>>> >>>> [0]PETSC ERROR: Inserting a new nonzero at global row/column (0,
>>>> 2) into matrix
>>>> >>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
>>>> documentation/faq.html[http://www.mcs.anl.gov/petsc/
>>>> documentation/faq.html] for trouble shooting.
>>>> >>>> [0]PETSC ERROR: Petsc Release Version 3.9.2, May, 20, 2018
>>>> >>>> [0]PETSC ERROR: ./a.out on a named tono-hpc1 by marius Wed May 30
>>>> 09:42:40 2018
>>>> >>>> [0]PETSC ERROR: Configure options --prefix=/home/marius/prog/petsc/3.9.2
>>>> --download-elemental=yes --download-metis=yes --download-parmetis=yes
>>>> --download-mumps=yes --with-scalapack-lib="/home/
>>>> marius/intel/compilers_and_libraries_2018.2.199/linux/
>>>> mkl/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group
>>>> /home/marius/intel/compilers_and_libraries_2018.2.199/
>>>> linux/mkl/lib/intel64/libmkl_intel_lp64.a /home/marius/intel/compilers_
>>>> and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_sequential.a
>>>> linux/mkl/lib/intel64/libmkl_core.a /home/marius/intel/compilers_
>>>> and_libraries_2018.2.199/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a
>>>> -Wl,--end-group -lpthread -lm -ldl" --FC=mpiifort --CC=mpicc --CXX=mpicxx
>>>> --with-scalar-type=complex --with-mpi-dir= --with-blaslapack-lib="/home/
>>>> -Wl,--end-group -lpthread -lm -ldl" --with-cxx-dialect=C++11
>>>> --download-superlu_dist=yes --download-ptscotch=yes --with-x
>>>> --with-debugging=1 --download-superlu=yes --with-mkl_cpardiso=1
>>>> --with-mkl_pardiso=1 --with-scalapack=1
>>>> >>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 607 in
>>>> /home/marius/prog/petsc/petsc-3.9.2/src/mat/impls/aij/mpi/mpiaij.c
>>>> >>>> [0]PETSC ERROR: #2 MatSetValues() line 1312 in
>>>> /home/marius/prog/petsc/petsc-3.9.2/src/mat/interface/matrix.c
>>>> >>>> (0.000000000000000E+000,0.000000000000000E+000)
>>>> >>>> Please send complete error message; type of matrix used etc.
>>>> Ideally code that demonstrates the problem.
>>>> >>>> Barry
>>>> >>>>> On May 29, 2018, at 3:31 AM, Marius Buerkle <mbuerkle at web.de
>>>> >>>>> Hi,
>>>> >>>>> I tried to set MAT_NEW_NONZERO_LOCATIONS to false, as far as I
>>>> understood MatSetValues should simply ignore entries which would give rise
>>>> to new nonzero values not creating a new entry and not cause an error, but
>>>> I get "[1]PETSC ERROR: Inserting a new nonzero at global row/column". Is
>>>> this option supposed to work or not?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180625/c913a84a/attachment-0001.html>
