[petsc-users] PETSc Solver: Large iteration count for first solution
Najeeb Ahmad
nahmad16 at ku.edu.tr
Sat Jun 23 06:36:59 CDT 2018
I am trying to solve a 64008000 x 64008000 system using PETSc. The
problem I am facing is that I am getting a very large iteration count for
the first solution (order of thousands). For the subsequent soluitons, the
iteration count is less. For instance, here is the iteration count for the
first solution when my code is run on 32 processes.
2772 KSP Residual norm 1.198554448053e-07
2773 KSP Residual norm 1.190214006391e-07
2774 KSP Residual norm 1.181931531360e-07
2775 KSP Residual norm 1.173706620648e-07
2776 KSP Residual norm 1.165538874733e-07
2777 KSP Residual norm 1.157427896857e-07
2778 KSP Residual norm 1.149373293013e-07
2779 KSP Residual norm 1.141374671925e-07
2780 KSP Residual norm 1.133431645025e-07
Linear solve converged due to CONVERGED_RTOL iterations 2780
For the subsequent solutions, the iteration count is as follows:
116 KSP Residual norm 2.657138978992e-04
117 KSP Residual norm 2.767485246885e-04
118 KSP Residual norm 2.071574619161e-04
119 KSP Residual norm 2.273562103015e-04
120 KSP Residual norm 1.693847273193e-04
121 KSP Residual norm 1.803833437167e-04
122 KSP Residual norm 1.443434809819e-04
123 KSP Residual norm 1.390878278231e-04
124 KSP Residual norm 1.247521972621e-04
125 KSP Residual norm 1.059224678494e-04
Linear solve converged due to CONVERGED_RTOL iterations 125
The solver setup for my code is as follows:
ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
ierr = KSPSetType(ksp, KSPCG);CHKERRQ(ierr);
ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
ierr = PCSetType(pc, PCJACOBI);
ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
ierr = KSPSetUp(ksp);CHKERRQ(ierr);
and the command line for running the code is:
mpiexec -n 32 ./main -mat_type mpiaij -ksp_atol 1E-7 -ksp_rtol 1E-7
-ksp_converged_reason -ksp_monitor
Any help is highly appreciated.
*Najeeb Ahmad*
*Research and Teaching Assistant*
*PARallel and MultiCORE Computing Laboratory (ParCoreLab) *
*Computer Science and Engineering*
*Koç University, Istanbul, Turkey*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180623/16a80f8a/attachment.html>
